[Multi] Het Quake 4 Topic
Pagina: 1 2 ... 11 Laatste
  • 3.210 views sinds 30-01-2008
  • XWB
XWB
Devver
Afbeeldingslocatie: http://users.telenet.be/betapics/q4.JPG
Het verhaal
Earth is under siege by an alien race. The Strogg are cybernetic warriors -- a mechanical frame and decaying body parts stabilized by flesh consumed in a systematic annihilation of other species and civilizations. In a desperate attempt to survive a Strogg attack on Earth, an armada of Earth's finest warriors is sent to take the battle to the Strogg home planet. Earth's initial assault force is nearly annihilated immediately, but one marine manages to infiltrate the base, bring down their planetary defense systems, and kill the Strogg's collective brain and leader -- the Makron. Earth assumed the destruction of the Makron would end it all, but it didn't.
That's where QUAKE II leaves off and QUAKE 4 begins.
The Strogg are quickly regrouping. However, with the Strogg's planetary defenses still destroyed, Earth's forces can deliver a full and final assault. This time, you're not alone. You are Matthew Kane, an elite member of Rhino Squad, and part of Earth's next invasion wave. An army of soldiers are fighting with you and an arsenal of weapons and vehicles are at your disposal in this heroic and epic battle between worlds.
Kort gezegd: het verhaal van Quake 4 gaat verder waar Quake 2 gestopt is, en de multiplayer van Quake 4 zal dezelfde sfeer van Quake 3 uitstralen.
Screenshots
Afbeeldingslocatie: http://users.telenet.be/betapics/quake4/Q4_PC_GroupE_11.jpg
Afbeeldingslocatie: http://users.telenet.be/betapics/quake4/Quake_IV_08.jpg
Afbeeldingslocatie: http://users.telenet.be/betapics/quake4/Q4_360_1919_06.jpg
Afbeeldingslocatie: http://users.telenet.be/betapics/quake4/Quake_IV_05.jpg
Wapens
The Gauntlet
Afbeeldingslocatie: http://users.telenet.be/betapics/quake4/wapens/1.jpg
The melee weapon from Quake 3 returns, and the team went through many different concepts before arriving at a final design -- you can see the final version in the bottom pic. When you've thoroughly beat your opponent into embarassment, there's no better humilation than a final gauntlet kill.
Blaster
Afbeeldingslocatie: http://users.telenet.be/betapics/quake4/wapens/2.jpg
This is the standard Marine-issue energy pistol, with two different modes of fire. Press the Attack key to quickly fire smaller blasts. Fire a stronger blast by holding down the Attack key briefly and charging up, and then releasing it to fire. A lit panel on the back of the weapon indicates a full charge.
Powered by nuclear batteries, the blaster never runs out of ammo. In addition, there's an under-barrel-mounted flashlight for use in dark areas.
Machinegun
Afbeeldingslocatie: http://users.telenet.be/betapics/quake4/wapens/3.jpg
Combining fully automatic fire and a single-shot scoped mode, the machinegun is a versatile weapon. It holds 40 rounds in the clip, and, like the blaster, it includes an under-barrel flashlight. When zoomed in, rapidly pressing the attack key to get off a series of shots can prove extremely effective.
Shotgun
Afbeeldingslocatie: http://users.telenet.be/betapics/quake4/wapens/4.jpg
With an eight-round internal magazine, the shotgun is exactly what you'd expect: excellent for close-range combat, but less useful against targets at medium or long ranges.
In the single-player campaign, most of the weapons will receive modifications by helpful Marine technicians. Some will work automatically, like a rate-of-fire increase, while pressing the Zoom/Weapon Special key activates other modifications. In the case of the shotgun, weapon mods included an extended clip as well as automatic fire, as opposed to pump action.
Railgun
Afbeeldingslocatie: http://users.telenet.be/betapics/quake4/wapens/6.jpg
It just wouldn't feel like Quake any more without a proper railgun, and here it is. This model is actually a smaller design than the Quake 2 and Quake 3 variants, but still serves the same purpose: to put a hole clean through anyone standing in your way. Upgrades allow for increased rate of fire, increased accuracy, increased damage, and increased capacity.
Nailgun
Afbeeldingslocatie: http://users.telenet.be/betapics/quake4/wapens/7.jpg
The nailgun was introduced in the original Quake, and then returned in the Quake 3 expansion pack, Team Arena. This new Strogg nailgun operates a little different from its two predecessors, however; there's a brief windup time before unleashing a stream of nails at anyone unfortunate enough to be in its path. In some ways, it's closer to the Quake 2 chaingun than any other weapon in the series.
FAQ
• Kleurtjes in je nickname :?
Zet gewoon ^ gevolgd door een cijfer van 1 tot 8 voor je nick.
^1 = rood
^2 = groen
^3 = geel
^4 = blauw
^5 = lichtblauw
^6 = magenta
^7 = wit
^8 = zwart
• Kleur voor je crosshair :?
In de console: g_crosshaircolor 0 1 1 1
1 0 0 = rood
0 1 0 = groen
0 0 1 = blauw
0 1 1 = cyan
• Crosshair grootte :?
Gebruik het commando g_crosshairsize in de console.
• Hoe zie ik mijn FPS :?
com_showfps 1 in de console. De framerate staat gelockt op 60 FPS.
• Brightness aanpassen :?
Speel wat met r_gamma in de console.
• Hoe neem ik nou screenshots :?
Standaard met de F12 toets. Screens worden opgeslagen in de quake 4\q4base\screenshots map. Standaard zijn deze van het TGA formaat. Om je screenshots in JPG formaat te hebben moet je van het commando "screenshotJPEG" gebruik maken.
Hieronder een bind welke screens neemt zonder het wapen en de HUD in beeld:
bind F11 "set ui_showGun 0; set g_showHud 0; screenshot; set g_showHud 1; set ui_showGun 1"
• Een demo opnemen :?
Ram recordNetDemo in de console om de opname te starten en stopNetDemo om de opname te stoppen. Demo's komen in de quake 4\q4base\demos map terecht.
• Zijn er bots :?
Kortweg: nee.
• Mijn beeld is groen :?
Voor mensen met een kaart zoals de Radeon 9200 die een voornamelijk groen beeld krijgen of iets soortgelijks, zet in de shortcut van Q4 achter "<pad>\quake4.exe" +seta r_renderer "ARB" of verander ARB in ARB2 of R200 als het niet werkt. Zet die commandline optie dus buiten de aanhalingstekentjes die om het pad naar quake4.exe staan. (met dank aan Aham brahmasmi)
Awards
Afbeeldingslocatie: http://users.telenet.be/betapics/quake4/awards/humiliation.jpg Humiliation: krijg je wanneer je iemand met de Gauntlet molt.
Afbeeldingslocatie: http://users.telenet.be/betapics/quake4/awards/excellent.jpg Excellent: krijg je wanneer je 2 frags in 2 seconden maakt.
Afbeeldingslocatie: http://users.telenet.be/betapics/quake4/awards/impressive.jpg Impressive: krijg je wanneer je 2 of meer hits na elkaar met de railgun maakt.
Afbeeldingslocatie: http://users.telenet.be/betapics/quake4/awards/rampage.jpg Rampage: krijg je wanneer je 3 of meer frags in 2 seconden maakt.
Afbeeldingslocatie: http://users.telenet.be/betapics/quake4/awards/combo.jpg Combo: krijg je wanneer je iemand met de rocket launcher raakt en die direct daarna met de railgun afmaakt.
Afbeeldingslocatie: http://users.telenet.be/betapics/quake4/awards/capture.jpg Flag Capture: award die je krijgt wanneer je de vlag van de enemy verovert. Levert je tevens 5 punten op.
Afbeeldingslocatie: http://users.telenet.be/betapics/quake4/awards/assist.jpg Assist: award die je krijgt wanneer je je eigen vlag terugbrengt en een teammate direct daarna scoort. Levert je 2 punten op.
Afbeeldingslocatie: http://users.telenet.be/betapics/quake4/awards/defense.jpg Defense: award die je krijgt wanneer je je eigen vlag verdedigt of de flag carrier van de enemy afmaakt Levert je 2 punten op.
Systeemeisen
Minimum
Pentium 4 2.0 GHz or Athlon XP 2000+ Processor
512MB RAM
8x speed CD-ROM drive and latest drivers
2.8GB uncompressed hard-drive space, plus 400MB for Windows swap file
100% DirectX 9.0c compatible 16-bit sound card and latest drivers
100% Windows 2000/XP compatible mouse, keyboard and latest drivers
DirectX 9.0c included
3D Hardware Accelerator Card required
100% DirectX 9.0c compatible 64MB
Hardware Accelerated video card and the latest drivers
ATI Radeon 9700
ATI Radeon X300 Series
ATI Radeon X550 Series
ATI Radeon X600 Series
ATI Radeon X700 Series
ATI Radeon X800 Series
ATI Radeon X850 Series
NVIDIA GeForce 3/Ti Series
NVIDIA GeForce 4/Ti Series
NVIDIA GeForce FX Series
NVIDIA GeForce 6 Series
NVIDIA GeForce 7 Series
Internet (TCP/IP) and LAN (TCP/IP) Supported
Internet play requires broadband connection and latest drivers
LAN play requires network interfaces card and latest drivers
Aanbevolen
Nog niet bekend
Links
Website: http://www.quake4game.com
Het vorige topic: Quake 4
[ Voor 84% gewijzigd door XWB op 23-10-2005 22:08 ]
March of the Eagles
  • biobak
  • Registratie: Augustus 1999
  • Laatst online: 05:57
Twee ingame filmpjes:
http://www.zen84106.zen.co.uk/quake4/eoc.bad_q2dm1_run.avi
http://www.zen84106.zen.co.uk/quake4/eoc.bad_q4ctf.avi
Ik heb er alweer erg veel zin in. Echt weer ouderwets hersenloos fraggen net als bij Q1/2/3 en UT/2003/2004 :)
  • Alexji
  • Laatst online: 20-10 11:31
mijn laatste post uit het vorige topic over de graphics:
Help!!!! schreef op maandag 17 oktober 2005 @ 19:23:
Als het je alleen om de gameplay gaat, waarom blijf je dan geen D2 spelen :?
Zo'n beetje het enige dat in de Q en D serie in de loop der jaren is verbeterd is de grafische kant van het spel.
De gameplay is toch echt wel anders, en ik speel het liefste waar de community het grootst is.
En sommigen de game wel op het allerhoogst draaien en het niet eerlijk vinden dat anderen op lager spelen is een beetje onzin, maarja deze discussie krijg je meestal wel met de wat minder competitive spelers.(nofi)
Verder eensch met hierboven
dit mischien iets voor de startpost?
http://www.quake3world.com/forum/viewtopic.php?t=11829
[ Voor 9% gewijzigd door Alexji op 17-10-2005 20:01 ]
Waarschijnlijk luid q4 ook eindelijk een tijdperk in waarbij online gamen een sport wordt bevonden.
Als ik zo kijk naar de CPL lijst zie ik daar toch 200 namen op waarvan er minimaal 50 gesponsord naar de lan toe gaan. Es kijken hoe dat uitpakt, gaat allemaal sneller dan wat ik het zelf had verwacht :P
  • Alexji
Verwijderd schreef op maandag 17 oktober 2005 @ 20:01:
Lijkt me ook erg interessant, veel grote namen. Hopen op GTV voor die tijd :>
  • Shaidar
  • Laatst online: 02-04 15:01
Shaidar
Ik denk dat ik nog nooit zó hard naar een game uitgekeken heb ...
Ik herinner me de tijd nog gelijk het gisteren was ... de q3 alpha downloaden met GetRight over een 33k6, en dan q3dm17 spelen en totaal freaken over die railgun :D
Oh my dear god, q4 is soooo gonna rock!
Ook heb ik vernomen van m'n vriendjes dat het een custom safedisc protectie gebruikt, dat is bijna ongeveer zo krachtig als StarForce ... ik zie q4 niet direct uitkomen in de warez-scene, tenzij alle grote groepen zich er op storten. Maar q4 wordt niet als 'de' titel aangezien, dus het zou even kunnen duren ... In Australië is ie trouwens al legaal te verkrijgen (van gisteren al denk ik)
Nuja, kopen doe ik hem toch, maar ik had hem graag zo snel mogelijk getest :d
 iPhone 12 Pro 128GB  MacBook Pro (13-inch, 2020, i7, 16GB, 1TB)
  • XyritZz
  • Laatst online: 28-09 13:53
In australie heeft hij inmiddels in de winkels gelegen (Misschien is dit een fout, misschien ligt hij er nu nog steeds. Kan het niet ff gaan checken sorry ;))
Er zijn wat screenshots en user reviews gepost, en die waren allemaal erg positief. De graphics waren er in vergelijking met Doom3 erg op vooruit gegaan. Niet meer die plastic achtige look op iedere texture, en er was ook veel meer licht in de maps. De donkere Doom3 stukken zouden er niet meer in zitten!
http://www.quake3world.com/forum/viewtopic.php?t=11824
Daar kan je alles lezen wat de gebruiker er over te vertellen had, wat verder naar onder staan nog wat foto's om het te bewijzen!
I think there is a world market for maybe five computers. - Thomas Watson (1874-1956), Directeur van IBM (1943)
  • Glorix Jim
  • Laatst online: 20-09 08:28
Mwa ik denk wel dat het 'de' titel wordt hoor.. t is alleen niet zo gehyped als HL2 en Doom3 en misschien wordt dat wel de kracht van q4 (al is de recensie op IGN btje matig) dus ik gok dat er volgende week wel warez versies te vinden zijn :)
[ Voor 24% gewijzigd door Glorix Jim op 17-10-2005 20:16 ]
  • XWB
XWB
Devver
AleXnl schreef op maandag 17 oktober 2005 @ 19:59:
Thx, startpost updated :)
March of the Eagles
En weer open. Dit was afgesproken via electronische post :)
  • Cloud
  • Laatst online: 08:22
Cloud
FP ProMod
Ex-moderatie mobster
Misschien is t wat om een linkje naar het oude Quake 4 topic in de TS op te nemen? Hier stonden nog wel wat leuke discussies/screenies/informatie in ;) Verder begint de TS al aardig te lijken!
Kan niet wachten tot Q4 uitkomt!
Never attribute to malice that which can be adequately explained by stupidity. - Robert J. Hanlon
60% of the time, it works all the time. - Brian Fantana
Kan niet wachten om weer eens een paar noobs te fraggen >:)
  • Sjoerd
Ik vind echt nergens specs die nodig zijn om alles volop te kunnen draaien |:(
Kan het ook niet vinden op de doos ui Austrialië.
Ben erg benieuwd naar Q4 heeft toch een grotere herspeelbaarheid dan HL2 denk ik (buiten css dan natuurlijk)
Hoop dat er genoeg voorzien zijn anders zijn ze de eerste dag weer uitverkocht in alle winkels.
Modelbouw - Alles over modelbouw, van RC tot diorama
  • Aham brahmasmi
  • Laatst online: 21-12-2025
Verwijderd schreef op maandag 17 oktober 2005 @ 20:42:
Dat zou je nog eens kunnen tegenvallen. Veel meer of minder doorgewinterde Q3 spelers zullen Q4 gaan spelen. Bring it! :Y)
  • ThaHandy
  • Laatst online: 14-10 16:39
ThaHandy
Discovery Channel
woor de gene die dat niet gezien hebben op de Q4 site dat je rondom links en rechts 4 links hebt met meer info ect. vooral de "Game Feature Videos" :9
direckte link, voor degene die een popup blocker gebruiken :) main menu (1.2MB)
[ Voor 4% gewijzigd door ThaHandy op 17-10-2005 21:00 ]
  • biobak
langezwieper schreef op maandag 17 oktober 2005 @ 20:45:
Meestal staan op de doos ook alleen mimimal en recommended specs en dat zegt nog niet zoveel.
Commentaar van ID Software over de specs:
Tim Willits: If you had a machine that could run Doom 3 decently, it will run Quake 4 decently. If you can run games like Half-Life 2 or EverQuest 2, you should be fine. However, make sure that if you get a computer as a new upgrade, particularly one that's advertised as a gaming machine, that it has a few important features to help your experience. Most computers now would probably want at least 512 megs of RAM, and don't get a video card that has less than 128 megs of RAM - 256 megs is the way to go.
-- Tim Willits from id Software, inteviewed by IGN in April 29, 2005
Dus als je Half Life en Doom 3 voluit kunt draaien, moet je Q4 ook wel voluit kunnen draaien. Misschien niet op ultra-high als die optie erin zit.
  • archetta
  • Laatst online: 14-05-2022
mooie startpost, stuk waardiger voor zo'n spel dan het oude topic _/-\o_
hopelijk ligt hij ook snel in de winkels, ik ga hem niet online bestellen en had hem toch graag snel gehad >:)
  • Splash
  • Laatst online: 20-10 08:29
biobak schreef op maandag 17 oktober 2005 @ 19:57:
Hmm, ben eigenlijk zwaar teleurgesteld na het zien van deze filmpjes. :( Precies dezelfde wapens als in q3, zelfde powerups, zelfde soort levels... kortom de gameplay is niet veranderd. Waarom zou ik hem dan aanschaffen? De vierkante blokkendooslevels zien er idd fantastisch mooi uit, maar iedereen weet toch dat je alles zo lelijk mogelijk moet zetten om een beetje kans te maken online. En wat houd je dan over? Idd, gewoon quake ]|[ .
  • Strikie
  • Laatst online: 05-10 17:04
Strikie
Athletics
Quake 4 ik kan er niet op wachten, ik heb bij Bol een preorder staan.
Als fervent Quake 3 speler (nu al 7 jaar) ga ik zeker overstappen naar deel 4 _/-\o_
Hier nog een link met 4 ingame filmpjes gespeeld op Quakecon.
http://www.envysoft.net/quake4/
Dit topic ga ik zeker volgen ;)
::: All Terrain Boys ::: Cube LTD race
  • Shaidar
Shaidar
mm .. ik vraag me af of dat de rocketlauncher wel dezelfde raket-snelheid/reloadsnelheid heeft als die in q3... en als dat niet zo is, dan hoop ik dat het aan te passen is op serverniveau ...
Ik vermoed evenwel dat er gewoon een Q3conversion pack uitkomt voor Quak4 ... dus q3 in een q4 jasje. Alhoewel sommige games toch nog een puntje kunnen zuigen aan q3 op 1600x1200 ...
  • Alexji
Splash schreef op maandag 17 oktober 2005 @ 21:08:
Ik klaag niet... quake 3 was is gewoon geweldig.
  • Bartjuh
Bartjuh
Hej
Ik zit er echt over te denken deze legaal aan te schaffen, koop niet zovaak games, omdat ik niet zo vaak speel :P Maar q3 was echt geniaal.... als ik die filmpjes zie is dit echt meesterlijk >:)
  • melly
  • Registratie: Mei 2001
  • Laatst online: 03-03-2023
Ik ben een echte Q3 fan en zal zeker Q4 aanschaffen.
Maar om eerlijk te zijn maken de filmpjes weinig indruk op mij.
Ben benieuwd :)
  • Vinnienerd
  • Laatst online: 17:40
Misschien handig voor in de startpost: Als de 1 1 0 etc. in de crosshair zijn RGB waardes genormaliseerd tot 1, oftewel, van 8-bit rgb naar de consolewaardes toe: r/255 g/255 b/255
[ Voor 3% gewijzigd door Vinnienerd op 17-10-2005 22:07 ]
  • Glorix Jim
shaidar schreef op maandag 17 oktober 2005 @ 21:35:
Nou te zien aan t filmpje lijkt de RL meer op de q2 RL :\
  • roberts
  • Laatst online: 15-10 13:57
Grafische maakt filmpje ook niet z`n indruk op mij, wel super dat ze map(the edge) uit q2 er al in zit.
Hopen dat gameplay heeft van Q2.
ij post toch niet toevallig ook op esreality?
nee hoor hehe ik kom oorspronkelijk van http://www.falconfly-central.de ;)
  • JJ Le Funk
JJ Le Funk
:twk
de snelheid van de raket lijkt inderdaad wat trager, maar betekent dat je nog beter moet anticiperen. kwestie van wennen lijkt me. als alles 1:1 hetzelfde zou zijn als Quake3 was het ook jammer geweest.
d:)b :henk d:)b
  • djerror
  • Laatst online: 24-07 13:14
Mis nog wat wapens in de openingspost volgens mij... :? ...rocketlauncher, lightninggun
kan niet wachten om mn ass gekicked te krijgen online...gisteren nog even potje Q3 gedaan maar raakte echt geen reet terwijl meestal 1 rocket genoeg was om mij te fraggen. Ander potje op dm17 won ik dan wel weer dik met 50 tegen 2, -2 ofzo maar die gasten zaten steeds te campen op het platform tja dan stuur ik er een zooi raketten op af *lol*
[ Voor 67% gewijzigd door djerror op 18-10-2005 09:49 ]
Noem me ongeduldig, ik heb zelfs in overweging genomen om via een bekende in australie Quake 4 op te laten sturen via UPS. :)
Maar de tarieven en hoe lang het onderweg zou zijn vielen me te veel tegen.
Iemand enig idee wanneer hij hier in Nederland in de schappen komt te liggen?
  • Pallas
  • Laatst online: 12-07-2025
Nou ik heb em in engeland besteld en daar zou de levering tussen 21/25 oktober zijn dus ik denk dat ze em ook rond die koers opsturen :)
Ben je al naar gamewinkels geweest in nl? Want ik denk dat ze dat wel kunnen zeggen wanneer ie echt in de schappen ligt
Ik heb er zin in ! :D O+
  • cybermans
  • Laatst online: 14-10 12:16
voor de xbox 360 issie afaik op 2 december te verkrijgen. Lijkt me echt een goed spel om de kwaliteit mee te gaan vergelijken van een eerste generatie 360 spel.
Strava | Runkeeper | Endomondo (mijn leikr uploads)
Pallas schreef op dinsdag 18 oktober 2005 @ 10:26:
Zoals het er nu naar uitziet gaat het me nog lukken ook om de 20ste in het bezit te geraken van een doosje met daarin een 12cm schijfje wat mij Quake 4 laat spelen :)
Nu alleen die winkel nog zo ver krijgen dat ze er eentje reserveren voor mij. Dit gaat een goed weekend worden _/-\o_
  • MethodP
  • Laatst online: 12-11-2025
MethodP
baanaan
Ik zit nog een beetje te twijfelen of ik het spel Quake 4 zal kopuh...
ik zou graag willen weten of er air control in voor komt, aangezien ik quake 3, wat een bruut spel is , een beetje te traag vind , in vergelijking met painkiller...
mss komt er een mod uit, die dit wel mogelijk maakt, weten jullie daar meer over???
  • Alsem
  • Laatst online: 27-01-2022
op die filmpjes ziet het er het zelfde uit als q3 op high :D
  • Strikie
Strikie
Athletics
Ik heb een preorder staan bij Bol.com ,volgens de site:
(Nog niet verschenen - U kunt deze titel reserveren) Beschikbaar op 25.10.2005
Hopelijk de 27ste in huis !
Ik zie net in de prijswatch een releasedate van 21 oktober
pricewatch: Quake 4
[ Voor 24% gewijzigd door Strikie op 18-10-2005 16:38 ]
  • Aham brahmasmi
MethodP schreef op dinsdag 18 oktober 2005 @ 11:21:
Je zou de Q3 mod CPMA eens moeten proberen. PK heeft veel weg van CPMA, alleen vind ik CPMA wat soepeler en de wapens beter (geen stakes ;) ).
  • Bosmonster
  • Laatst online: 29-08 19:47
Bosmonster
*zucht*
Alsem1 schreef op dinsdag 18 oktober 2005 @ 11:43:
Yeah.. ik weet niet waar die filmpjes vandaan komen, maar er zijn een aantal mogelijkheden:
- Het is nep en gewoon Q3/high met wat 'Q4' aanpassingen
- Quake 4 is gewoon meer van hetzelfde en stelt niet zoveel voor
- Hij draait Q4 op laagste setting (beetje dom)
Keuze laat ik aan anderen. Ik was niet onder de indruk van de filmpjes iig, integendeel.
  • Aham brahmasmi
Bosmonster schreef op dinsdag 18 oktober 2005 @ 12:10:
De Q4 single player is helemaal nieuw en een vervolg op Q2. Voor de MP is uitdrukkelijk gekozen om het succes van Q3 voort te zetten. Het is dus een facelift (betere engine en wat nieuwe artwork maar wel grotendeels in dezelfde stijl). Je moet de Q4 MP vooral zien als een soort revival van Q3 (zonder bots dan helaas). Enemy Territory:Quakewars gaat nieuwe dingen bieden met vehicles enzo, maar Q4 MP is een geupdate klassieker. Simpel zat.
  • Freak
  • Laatst online: 13-05-2025
Weet iemand of er ook een demo uitkomt van dit spel ?
  • Rone
Rone
Moderator Tweaking
Mooi topic :) Edoch een tweetal opmerkingen:
In de startpost moet
^6 = magneta
'magenta' zijn.
En waarom staat de ATi Radeon X1K serie niet tussen supported videokaarten en de GeForce 7-serie wel? :)
[ Voor 8% gewijzigd door Rone op 18-10-2005 12:37 ]
PC1: 9800X3D + RX 9070 XT
PC2: 5800X3D + RTX 3080
  • magnifor
Ga er maar van uit dat het wel zal gebeuren. :)
  • Jerry
  • Laatst online: 24-03 16:08
Jerry
Who?
Net even dat filmpje van q2dm1 (the edge) gezien, maar het is wel bagger dat ze de map bijna helemaal vernaggeld hebben :(. Het enige stuk dat een beetje hetzelfde is, is het middenstuk.
- Geen water bij railgun
- Megahealth makkelijker te pakken (geen skills meer nodig)
- Stukje bij lift waar je via platform naar rocket launcher loopt (bovenste RL) zit een afbuigend stuk in waardoor je weinig snelheid kan halen.
Beetje jammer. Hopelijk port iemand de originele q2dm1 naar Q4, want deze versie is bagger.
  • Shaidar
Shaidar
Hou de warez praat maar achterwege
The old days are gone ... really gone :)
[ Voor 73% gewijzigd door Fuelke op 18-10-2005 13:20 ]
  • Alexji
haha
  • Shaidar
Shaidar
shaidar schreef op dinsdag 18 oktober 2005 @ 12:59:
Oh. Zoveel speciaals zei ik toch niet?
het vreemde is dat het verhaal van Quake 1geen vervolg heeft gehad oke de Mission Packs Scourge of Armegaddon en Dissolution Of Eternity wel maar Quake II was infeite een heel ander verhaal vergeleken met Quake 1.
mischien heeft Quake4 ook meer betrekking tot het verhaal van 1 en 2 , iemand nog meer info hier over?
BTW er komt ook een nieuwe Wolfenstein hehe :9
http://www.idsoftware.com/
effe de headlines gelezen.
[ Voor 16% gewijzigd door Verwijderd op 18-10-2005 13:52 ]
  • Ramon
  • Laatst online: 17:56
Weet je wat ik mis aan die filmpjes? KEIharde industrial beat erdoorheen.
Ik zou me doodvervelen als ik zo'n spel moest spelen zonder opzwepende muziek! Misschien komt het nog? :)
  • XWB
XWB
Devver
r00n schreef op dinsdag 18 oktober 2005 @ 12:37:
'magenta' zijn.
Geen idee, ik heb die specs zo van een ander forum gehaald. Misschien omdat het game opengl is en dat het gebied van nVidia is? (ik zeg maar wat)
[ Voor 4% gewijzigd door XWB op 18-10-2005 14:17 ]
March of the Eagles
  • FatalError
  • Laatst online: 20-10 23:26
Omdat die nog niet uit was ten tijde van het drukken van de hoesjes lijkt me.
If it ain't broken, tweak it! | gasloos sinds oktober 2025, hoekwoning 1978 | 10kWp PV, Panasonic K serie 7kW, Atlantic Explorer V5 270L | Tesla Model Y | 3x Victron MP2 6k5, 48kWh
  • Rone
Rone
Moderator Tweaking
Hacku schreef op dinsdag 18 oktober 2005 @ 14:14:
Nee, natuurlijk is FatalError's opmerking de juiste, dat wist ik ook wel.
Het was een retorische vraag met als doel dat je deze erbij zou zetten ;)
  • Blue-eagle
Looks good, ik vraag me alleen af of ik met een ATI Radeon 9700 Pro dit spel ook kan spelen terwijl het er een beetje goed uitziet. Of zal ik dan toch maar een Asus GeForce 7800 GTX kopen?
Ik ben wel benieuwd hoe deze game eruit gaat zien met alle settings op "HARDCORE!" :)
  • andreict
  • Laatst online: 11:11
magnifor schreef op dinsdag 18 oktober 2005 @ 12:52:
ik geef ze 3 dagen :)
maar zijn er nu ook mensen die het spel al echt fanatiek aan het spelen zijn? (beetje ervaringen graag)
er gaat een gerucht dat er een winkel in nederland is (misschien meer?) die Quake 4 al aan het verkopen is/zijn.
weet iemand er meer van ?
  • andreict
Verwijderd schreef op dinsdag 18 oktober 2005 @ 15:15:
jij blijkbaar :? wat is je bron?
andreict schreef op dinsdag 18 oktober 2005 @ 15:16:
een iets te enhousiaste gast op gamelux.nl
http://www2.gamelux.nl/forum/topics/5704/ mag wel nep lijken, maar die gast lijkt toch best vaak gelijk te hebben
  • amahusu
  • Laatst online: 16:20
amahusu
taking over the world!
dus hij is uit alleen nog niet in nl?
Always Outnumbered, Never Outgunned // Some people feel the rain, others just get wet
  • Shaidar
Shaidar
Hier in België wordt ie geleverd vrijdag tussen 10 en 12 uur ... Heb gebeld naar de GameMania, maar dat zal wel voor bijna alle games-winkels hetzelfde zijn zeker?
'k heb vrijdagnamiddag maar verlof genomen, want van tegoei concentreren op m'n werk komt nu al helemaal niets meer terecht ...
  • R-B
  • Laatst online: 17:17
R-B
Blokkert
shaidar schreef op dinsdag 18 oktober 2005 @ 16:18:
mijne verwacht ik ook vrijdag op me mat.. Helaas is zaterdag pas speeltijd :'(
| NL | 2.2k Wp (ZW) | MHI SRC/SRK35ZS-W2 & ME MXZ-2F42+AP20+AP25 | MT E 5.12KWh | Home Assistant |
Van NEDgame heb ik per telefoon de bevestiging dat Quake 4 de 20ste krijgen.
En anders blijf ik gewoon in die winkel zitten totdat ze me quake 4 dvd geven })
ik hoop dat er ook een Collectors Edition van alle Quake uit komt Quake t/m Quake4 :9
met wat units en items , posters, extra hidden info van alle 4 titels.
Dat lijkt me erg cool :D
[ Voor 25% gewijzigd door Verwijderd op 18-10-2005 16:42 ]
  • Aham brahmasmi
Jammer trouwens dat ze niet iets hebben gemaakt als Valve met HL:Source en DoD:Source, etc. Alleen de multiplayer van Q1, 2 en 3 samen in één spel met D3 engine en opgepoetst artwork enzo. :) Maar goed, het is praktisch hetzelfde als Q3 dus ik ben tevreden. :9
  • Shaidar
Shaidar
Verwijderd schreef op dinsdag 18 oktober 2005 @ 16:41:
Ik heb hier een simpele DVDbox met quake1, quake2 én quake3 in, maar veel extra zit daar niet bij :)
  • @r!k
  • Laatst online: 06-10 09:23
@r!k
It is I, Leclerq
Dat zou idd wel gaaf zijn.
Een hele rij microsoft certificeringen.
  • Cloud
Cloud
FP ProMod
Er komt vast wel een mod die dat gedrag produceert, maar standaard zal het er niet inzitten, dat weet ik denk ik wel zeker ;) Die mod heet waarschijnlijk CPMA die ook al beschikbaar was voor Quake 3 :)
Zelf heb ik liever normale control ;)
edit: spuit 11 :X
[ Voor 3% gewijzigd door Cloud op 18-10-2005 17:13 ]
spuit 11?
  • Michael
  • Laatst online: 19-10 07:55
Ik vind het opvallend dat iedereen het maar over CPMA heeft. Destijds dat ik promode speelde (en dan niet de osp versie, maar de echte) waren er maar weinig anderen.
  • Cloud
Cloud
FP ProMod
Michael schreef op dinsdag 18 oktober 2005 @ 17:24:
Dat komt omdat de control (met name de air control) overeen komt met Painkiller. Ik ben zelf absoluut geen fan van CPMA, ik vind het zelf nogal een een ruk-controle als je het mij vraagt. Geef mij maar OSP! 8)
  • Rone
Rone
Moderator Tweaking
  • XWB
XWB
Devver
Voor iedereen die niet van de starforce beveiliging moet weten: Quake 4 heeft Safedisc 4 aan boord :)
[ Voor 104% gewijzigd door XWB op 18-10-2005 22:16 ]
March of the Eagles
Ik dacht dat het interessant was om op te merken dat cd-wow.nl de Quake 4 DVD versie verkoopt voor € 39,99 -> http://www2.cd-wow.nl/det...duct_code=20979&subcat=pc en de CD versie zelfs voor € 31,99 (!) -> http://www2.cd-wow.nl/det...duct_code=20978&subcat=pc deze winkel staat niet in de Pricewatch (misschien kan iemand dat even toevoegen?), maar het is wel erg goedkoop.
[ Voor 18% gewijzigd door Verwijderd op 18-10-2005 21:46 ]
  • m00n
  • Laatst online: 25-09 17:11
Modbreak:Lees de faq nog eens, en dan met name dit gedeelte: Even melden dat m'n download bijna binnen is! :{
[ Voor 89% gewijzigd door Crash op 18-10-2005 22:55 ]
SteamID: m00n22NL | GT: m00n22 | My Game PC
  • archetta
heb je hem al legaal kunnen kopen? maak anders ook wat screensshots voor ons :9
nee je bent niet stoer
[ Voor 18% gewijzigd door Crash op 18-10-2005 22:55 ]
  • m00n
Modbreak:Kansloos :{
[ Voor 88% gewijzigd door Crash op 18-10-2005 22:56 ]
Mja CPMA'ers hebben een kleine community maar schreeuwen het hardst (komt zelf ook uit de CPMA scene).
Afbeeldingslocatie: http://img413.imageshack.us/img413/9498/shot000069cg.jpg
paar vrienden van me hebben het al en zitten tegen elkaar te spelen :)
een ding viel op, je kan elkaars ping niet zien, gameplay vinden ze wel
geweldig
  • Shaidar
Shaidar
Modbreak:Zie Spielerij - Algemene policy :{
[ Voor 81% gewijzigd door Crash op 18-10-2005 22:57 ]
  • JJ Le Funk
JJ Le Funk
:twk
Verwijderd schreef op dinsdag 18 oktober 2005 @ 22:18:
geweldig
je bedoelt 'freunden' ;)
d:)b :henk d:)b
*gedelete*
[ Voor 99% gewijzigd door Verwijderd op 18-10-2005 23:30 ]
  • XWB
XWB
Devver
Alles op high, maar zo te zien staat AA niet aan.
March of the Eagles
En dan is de grootte vraag: Waar heb je hem gekocht?
  • XWB
XWB
Devver
Die screens zijn niet van hem, zie onderste regel.
@diOndOrAntt, pics resizen zou fijn zijn :)
March of the Eagles
  • Shaidar
Shaidar
Niet relevant voor dit topic :|
[ Voor 85% gewijzigd door Crash op 18-10-2005 22:57 ]
  • Crash
  • Laatst online: 10:03
diOndOrAntt: resize je pics :)
Modbreak:Voor de rest: tot hier en niet verder. Patsen met warez is direct een OW :{
Is het trouwens alweer mogelijk om de poppetjes wit en groen te maken binnen die paks :+? Was altijd al legaal binnen q2 (dunno about q3) dus zou wel mooi zijn als dat nu ook het geval is :) (maar zal wel afhangen van de server / league / whatever)..
moet helaas alleen even wachten tot er een nieuwe compu verschijnt op mijn bureau :P
  • johan12
  • Laatst online: 07:35
weet iemand of ze in het multiplayer gedeelte meer maps uit de originele Q2 patch voor multiplayer hebben ge-update voor Quake 4??
Edge wisten we al (was dat niet q2dm1?)
wil ook wel eens 'warehouse' spelen, god wat heb ik die map vaak gespeelt, Super!
anyone?
  • m00n
Even mijn excuses aanbieden, is niet netjes geweest sorry.
Spel ziet er iig goed uit.
  • Maverick
  • Laatst online: 20-10 22:15
Tja, ff zitten kijken een stukje, maar kan werkelijk (na 100en potjes op de originele edge) niet inzien wat q4 nu meer heeft dan q2. Is na al die jaren de enige verbetering nu een grafische? Beetje teleurstellend imho.
PSN: DutchTrickle PVoutput
  • HyperioN
  • Laatst online: 13-10 20:50
HOE vet, Quake 4... ik schaam mezelf dat ik niet eens wist dat deze eraan stond te komen! Ben altijd meer een fan geweest van de UT-serie maar Quake vind ik ook geweldig.
Ga hem zeker wel kopen, dit wordt een blijvertje dat weet ik nu al.
Ik heb wat screenshots en de filmpjes gezien en ik ben heeel blij om te zien dat de gameplay niet onder hoeft te doen voor de graphics!! Dit is wat helaas wel het geval bij bijvoorbeeld CS:Source, en ook de reden waarom nog steeds meer mensen CS1.6 spelen dan CS:S.
  • Aham brahmasmi
Rofl, de mods hebben hun handen vol aan dit topic zo te zien. :D
wolkje schreef op dinsdag 18 oktober 2005 @ 17:29:
OSP... de mod voor gevorderde noobs. :P Rail, shaft en MG zijn mij allemaal veel te sterk in VQ3/OSP. Alle hitscan wapens dus, waar dus ook erg mee wordt ge-pingraped. Ik ben bang dat het met Q4 weer hetzelfde zal zijn (100 rail dmg en sterke MG heb ik al gehoord). :/
Wat CPMA betreft: je moet denk ik een beetje mazzel hebben dat je te zien krijgt hoe je het moet spelen en hoe relaxed het dan is. De eerste keer dat ik het probeerde vond ik het ook te raar aanvoelen maar toen ik het later weer probeerde omdat een paar vrienden het ook speelden was ik verkocht. Als je na CPMA weer teruggaat naar VQ3/OSP voelt het echt lomp en vooral sloom aan. Die lange weapon switch time wordt ook echt irritant dan.
  • Shaidar
Shaidar
id Software and Activision announced today that Quake 4 for the PC has shipped. Quake 4 for the PC is available at retail outlets nationwide for a suggested retail price of $49.99. Additionally, fans can purchase the Quake 4 Special DVD Edition for a suggested retail price of $59.99, which includes Quake II, the Quake II expansion packs, and exclusive behind-the-scenes content. Both versions carry an M (Mature) rating by the ESRB.
dan is het dié versie die ik vrijdag ga halen :p
  • XWB
XWB
Devver
Maverick schreef op dinsdag 18 oktober 2005 @ 23:11:
Tjah, dat was al lang bekend.
Quake 4 SP is het vervolg op Q2 (dus een nieuw verhaal is er wel) en de MP is gewoon een kopie van Q3 (dit gewoon omdat Q3 een succes was/is). Een goed verhaal + een goede MP, wat wil je nog meer? :p
March of the Eagles
  • Jerry
Jerry
Who?
Hacku schreef op dinsdag 18 oktober 2005 @ 23:17:
Een goed verhaal, moeten we nog maar afwachten ;).
  • XWB
XWB
Devver
Ik heb van Raven nog geen slechte titels gezien, dus ik heb er alle vertrouwen in. Nuja, dat zie ik morgen wel :)
March of the Eagles
  • Sak3d
  • Laatst online: 10-12-2023
Sak3d
Reise, Reise
Check je mail
[ Voor 84% gewijzigd door Verwijderd op 19-10-2005 13:50 ]
  • Shaidar
Shaidar
  • defiant
  • Laatst online: 17:10
defiant
Ik weet dat het zinloos is :) maar ik had graag ook het MP wat vernieuwender willen zien dan een kopie van Q3 .. voortbouwen op het succes van een vorige game is natuurlijk makkelijk scoren. Iets vernieuwends neerzetten/durven is wat anders. Met q2/q3 is het ook gelukt om met vernieuwende MP te komen, waarom zou 't met q4 niet lukken.
Maargoed, ik leg me er bij neer, want ik heb toch geen tijd om fatsoenlijk te multiplayeren :)
"When I am weaker than you I ask you for freedom because that is according to your principles; when I am stronger than you I take away your freedom because that is according to my principles"- Frank Herbert
  • LoWang
  • Laatst online: 14-09 10:13
shaidar schreef op dinsdag 18 oktober 2005 @ 23:14:
Dus de cd-rom versie is puur en alleen Quake 4, maar de DVD versie heeft deze extra's? Of is dat weer een speciale DVD versie en is de standaard DVD versie de ik overal zie ook alleen Quake 4 zonder extra's.
Hou het ontopic, nuttig en begeef je vooral niet op 'grijs' gebied!
Gameafspraakjes kan je maken buiten dit topic om!
Techvragen en problemen met dit spel horen niet in dit topic thuis, maar in SPV!
