Hoofdcategorieën
Topicacties
FloAt's Mobile Agent
Pagina: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 last
Reageer Nieuw Topic
just as clear as a foggy night
Reg. datum: 05 april 2002
nouja het is niet echt een bug, er gaat volgens FMA niks mis en het bestand word ook gewoon verstuurd en ontvangen maar zodra ik op mijn tel wil kijken is het bestand er wel maar word weergegeven als een kruisje
maar hier is de activity log:
18:28:58:322 Key Buffer: [[:R:J]*:Jv<:J:Jc
18:28:58:322 Script: Calling OnKeyPress
18:28:58:322 [Script] Debug: EventManager: Event KeyPress triggered
18:28:58:322 [Script] Debug: EventManager: Executing KeyManager.OnKey "c", "1" for event KeyPress
18:28:58:322 [Script] Debug: KeyManager: Key c pressed
18:28:58:322 [Script] Debug: KeyManager: Key c has no registered keys in it's chain
18:28:58:494 Script: Calling OnKeyPress
18:28:58:510 [Script] Debug: EventManager: Event KeyPress triggered
18:28:58:510 [Script] Debug: EventManager: Executing KeyManager.OnKey "", "0" for event KeyPress
18:28:58:510 [Script] Debug: KeyManager: Key c released
18:28:58:510 [Script] Debug: KeyManager: Key c has no registered keys in it's chain
18:28:59:619 Key Buffer: [[:R:J]*:Jv<:J:Jc[
18:28:59:619 Script: Calling OnKeyPress
18:28:59:619 [Script] Debug: EventManager: Event KeyPress triggered
18:28:59:635 [Script] Debug: EventManager: Executing KeyManager.OnKey "[", "1" for event KeyPress
18:28:59:635 [Script] Debug: KeyManager: Key [ pressed
18:28:59:635 [Script] Debug: KeyManager: Key [ has no registered keys in it's chain
18:28:59:729 Script: Calling OnKeyPress
18:28:59:729 [Script] Debug: EventManager: Event KeyPress triggered
18:28:59:729 [Script] Debug: EventManager: Executing KeyManager.OnKey "", "0" for event KeyPress
18:28:59:744 [Script] Debug: KeyManager: Key [ released
18:28:59:744 [Script] Debug: KeyManager: Key [ has no registered keys in it's chain
18:29:15:088 Script: Calling MenuStack.Top.Quit
18:29:15:088 [Script] Debug: EventManager: Event MenuClose triggered
18:29:15:088 [Script] Debug: EventManager: Event MenuClose has no registered events in it's chain
18:29:15:088 [Script] Debug: KeyManager: Deregistered command: MenuStack.Top.PrevPage for key <
18:29:15:088 [Script] Debug: KeyManager: Deregistered command: MenuStack.Top.NextPage for key >
18:29:15:104 [Script] Debug: KeyManager: Deregistered all commands for the plugin: Main Menu
Rubman wijzigde dit bericht 24-01-2005 18:31 (83%)
Laaiend enthousiast kwam hij uit de brandende kerncentrale en keek stralen om zich heen!
Aut disce aut discede
Reg. datum: 26 juli 2001
Ik zie graag het Debug log en niet het activity log. Zie http://www.mobileagent.info/forums/index.php?showtopic=928 als je niet kan vinden hoe je die krijgt.
We adore chaos because we like to restore order - M.C. Escher
ok dit is wat ik krijg met het debug log:
http://www27.brinkster.com/infolinux/db/debug.txt
beetje snel gedaan maar goed te lezen
De link werkt helaas niet.
ff kopieren en plakken (in nieuwe browser) wil wel helpen
Dat hielp idd. Aan je log is niets vreemds te zien. Weet je wel zeker dat het een jpg is?
T630 -K750 -Z800 -K800 -P1
Bij fma2 kan ik niet meer dan 2 plaatjes van m'n T630 naar m'n pc uploaden (BT), want dan weet fma2 kennelijk niet meer of het 2e plaatje was opgeslagen en vraagt hij of hij de bestaande moet overschrijven.
Of je nu ja of nee antwoordt, hij stopt met uploaden :/
Als je 1 of 2 plaatjes upload, dan gaat het wel goed .... :?
Met fma 0.1.1.16c stable lukt meer dan 2 plaatjes wel :)
Speedy-Andre wijzigde dit bericht 27-01-2005 22:19 (10%)
Gsus is my homeboy
Reg. datum: 24 oktober 2004
Lekker onzinnige post dit maar toch: FMA 2 is suuuuuuuuuuuupertjes!!!!!!
Zepto Znote 6224W: 14,1" @ 1440 x 900 | nVidia GO 8600M GT 512MB | Intel Core 2 Duo T7500 2,20GHz 800MHz 4MB 3072MB PC6400 - 800MHz | 200GB 7200 rpm HD | DVD+-RW | Integrated BT & Wi-Fi | Windows Vista Home Premium x86 :-)
Gsus is my homeboy
quote:
Speedy-Andre schreef op donderdag 27 januari 2005 @ 22:10:
Bij mij liep de stable versie telkens vast en bij FMA 2 niet. Dus dan maar 1 plaatje per keer sturen :-) (maar bij mij zijn 't vooral spellen en thema's)
ik ben er zeker van dat het jpg was/is heb het met verschillende plaatjes geprobeerd zelfs een plaatje wat er al opstond eraf gehaald en opnieuw geprobeerd,. niks alleen kruisje
nouja ga fma 2 wel ff proberen dan.
alsnog bedankt voor alle moeite
en kom er door geklooi net achter dat het niet fma is maar waarschijnlijk me tel of de BT dongle, want als ik het via het gewone windows bluetooth pictogram in het systeemvak verzend dan verzend hij ook prima maar herkent me telefoon hem ook niet.
denk dat ik dan voor probleem in t610 topic moet zijn he?
Rubman wijzigde dit bericht 28-01-2005 20:48 (39%)
Vreemd. Ja, dat topic lijkt me dan beter.
Overigens is net FMA v2.0 Stable uitgekomen. Deze versie heeft wat minder features, maar is wel stabieler dan de v2.1 Beta versie. Zie http://www.mobileagent.info/forums/index.php?showtopic=3438
Gsus is my homeboy
quote:
LordLarry schreef op zaterdag 29 januari 2005 @ 20:05:
Hmm raar dan dat er minder features in zitten als 't wel in de beta zit (of ligt dit aan mij) Hmm bij mij werkt beta nog gewoon supertjes (en ik heb dan die extra features) dus die laat ik er maar op staan!
Reg. datum: 20 juni 2001
Heeft iemand al ontdekt hoe je archieven vane en vorige versie terug kunt halen? Ik heb namelijk 3 archief bestanden staan welke ik graag zou importeren oid.
Life is to short to spend behind your keyboard.
en wat zijn archiefbestanden? Hoe maak je die?
52 30 N, 5 45 E
Reg. datum: 05 maart 2001
Waarschijnlijk is het gewoon een sms-je, dat is opgeslagen in het archief.
Iets anders kan ik er ook niet van maken.
The Tweaker Pin Show | Bjusterbaarlik lekker
Reg. datum: 25 december 2004
Ik heb een probleempje. Ik heb alle topics al doorgespit, maar blijf bij het volgende hangen.
Ik kan connecten met FMA. Ikzelf heb een S700i. Nou geeft hij op mijn telefoon de melding: fma loaded onder mijn providernaam. Wat nu? Ik kan nergens iets vinden waardoor ik b.v. winamp kan controlen of i.d.??
In het menu Connectivity - Accessories op je telefoon vind je dat terug. Het script moet wel goed ingesteld zijn. Zie http://fma.sourceforge.net/docs.php en http://www.mobileagent.in...67d901f73&showforum=8
Reg. datum: 19 januari 2005
FMA2 full geinstaleerd maar ik kan geen verbinding krijgen?????
wat ik ook probeer met de instellingen steeds geen verbinding.
xp pro sp1
bta-3100 adapter via bleusoleil
wat gaat er vouttttttttttttttttttttttttttttttttttt????????????? 8)7
Bluesoleil werkt niet icm met FMA.
quote:
LordLarry schreef op dinsdag 01 februari 2005 @ 21:34:
wat moet ik doen om het toch aan het werken te krijgen???
0.1.0.35 RC5 of ouder gebruiken of gebruik gepatchte Widcom drivers. Zie http://www.mobileagent.in...view=findpost&p=11328
LordLarry wijzigde dit bericht 02-02-2005 22:50 (8%)
|BEWARE|
Hoelang hoort het normaal te duren om de gegevens uit je phonebook (op de telefoon) uit te lezen op een T68i .... de sim gegevens waren in 10 sec binnen ....
De telefoongegevens zelf zijn al 10 min bezig ofzo?
Gsus is my homeboy
quote:
Vidra schreef op zaterdag 05 februari 2005 @ 13:29:
Bij mij (K700i) duurde dat idd ook een tijdje. Ik denk wel een dikke 5 a 6 minuten. 10 minuten lijkt me wat lang, maar ja misschien moet hij bij jouw wel meer gegevens verwerken (meer contacten dan in mijn lijst)
Reg. datum: 06 februari 2005
Hoi,
Gisteren FMA2 gedownload. Ik heb zojuist al mijn afspraken en verjaardagen ingetypt in FMA. Wanneer ik nu wil synchroniseren met met K700i (via bluetooth) krijg ik onmiddellijk op mijn telefoon een melding dat de sessie voltooid is. Als ik echter ga kijken in de kalender van mijn gsm staat er niets in.
Wat doe ik verkeerd?
Reg. datum: 04 juli 2004
Ik heb een waarschijnlijk erg suf probleem:
Ik heb een bluetooth adapter (Sitecom CN-500), een K700, Windos XP home en SP2.
Alles werkte prima tot gisteren, toen kreeg ik geen contact meer met mn pc, laat staan met FMA (2.0 beta - zonder al die 9 foutmeldingen bij het opstarten)
Eerst contact met Sitecom opgenomen en na het navolgen van de manual addendum :? (Sitecom USB Bluetooth device ingeschakeld) heb ik weer verbinding, zij het met moeite.
Allen met FMA krijg ik nog steeds geen verbinding.
Dus de inleiding gelezen van dit topic en daar staat:
3: Zodra de GSM 'gepaired' is aan jouw PC kan je de serial port connecten. Als je dat gedaan heb, kan je teruggaan naar 'My Bluetooth Places' en daar kan je links onderaan vinden via welke COM poort jouw GSM verbonden is met jouw PC. (In plaatje via COM 4)
Maar.. bij mij staat er dus bij 'details' alleen de naam van mn telefoon en dat het een mobiele telefoon is (goh) maar geen poort-info.
Nu vind ik wel van zowel mn bluetooth apparaat als van mn telefoon een apparaat-adres van een combi van 12 cijfers en letter, maar bij beiden kan ie geen verbinding maken als ik ze invul bij opties: Native Bluetooth (er gebeurt dan zelfs helemaal niets) (maar misschien is dit dus ook wel een hele suffe actie van mij en slaat het ook helemaal nergens op :*) )
Als ik in de bluetooth wizard setup de seriele poort (1 en 2) wil configuren dan krijg ik een dropdownbox voor mn com-poorten - maar deze zijn in beide gevallen leeg
(bij opties in FMA - serial port heb ik ook alleen maar de keuze uit com 1 en com 2)
Ik heb echt géén idee meer wat ik bij opties in moet vullen om toch die verbinding tot stand te brengen.
Kan iemand mij helpen of is dit verhaal echt te warrig/incompleet? ;)
VNU Media logo Powered by True
© 1998 - 2008 Tweakers.net - Alle rechten voorbehouden
Uitgever van:
