[OC-Ervaringen] Lanparty NFII Ultra B en Infinity Deeltje 4
Pagina: 1 2 ... 6 Laatste
  • 5.217 views sinds 30-01-2008
  • Exigence
  • Laatst online: 09-07 15:19
Link naar het vorige topic:
[OC-Ervaringen] Lanparty NFII Ultra B en Infinity Deeltje 2
[OC-Ervaringen] Lanparty NFII Ultra B en Infinity Deeltje 3
LANPARTY NFII ULTRA B:
• Specs: http://www.dfi.com.tw/Pro...&CATEGORY_TYPE=LP&SITE=US
[img=400,300]url= http://www.envynews.com/reviews/images/606/14.jpg[/img]
Klikbaar
[img=400,300]url= http://www.lanparty.com.tw/LP1/board3.jpg[/img]
Klikbaar
Backplane:
Afbeeldingslocatie: http://img.hexus.net/dfinf2ub/backplane.jpg
Heatsinkje southbridge (zit met thermal tape losjes vast)
Afbeeldingslocatie: http://img.hexus.net/dfinf2ub/sb_sink.jpg
[img=400,300]url= http://www.xs4all.nl/~mvgemert/NF2Ultra_layout.gif[/img]
Klikbaar
[img=400,300]url= http://www.xs4all.nl/~mvgemert/NF2Ultra_glow.gif[/img]
Klikbaar
NFII ULTRA INFINITY:
• Specs: http://www.dfi.com.tw/Pro...&CATEGORY_TYPE=MB&SITE=US
[img=400,300]url= http://www.dfi.com.tw/Upload/Product_Picture/NFII%20ULTRA%20INFINITY%20b.jpg[/img]
Klikbaar
Verschillen LANPARTY NFII ULTRA B en LANPARTY NFII ULTRA rev. A
A ->Audio Connectivity 3 port backplane speaker
B ->S/PDIF I/O on I/O shield 5 port backplane speaker, S/PDIF I/O on backplane
A ->IDE RAID Highpoint HPT372N RAID controller w/ 2 ports
A ->SATA Marvell 88i8030, 1 port bridge from primary ATA
B ->SATA RAID 4 device RAID0, RAID1 Silicon Image Sil3114, 4 port
A ->NVIDIA 10/100, RTL8101 10/100
B ->NVIDIA 10/100, RTL8110S 10/100/1000
B ->Mounting holes rondom de socket
Uit de review van Hexus*
A nip here, a tuck there. The biggest change is the dropping of IDE RAID support in favour of SATA. The Sil3114 offers 4 full SATA channels which the board duly makes good use of, giving you 4 physical ports to hang your drives from. The chip does RAID0 and RAID1 on all channels, giving you decent flexibility in your disk configuration. You can run seperate RAID levels on two channel pairs, as far as I can make out without explicit testing anyway. The lack of physical IDE ports for the old Highpoint chip on the old board means a layout change for the B revision, I'll talk about that on the following page.
Verschillen LANPARTY NFII ULTRA B en Infinity
De lanparty heeft naast 100 Mbit Nvidia lan een Realtek RTL 10S Gigabit lan onboard.
De goodies zitten alleen bij de LANPARTY
[img=200,150]url= http://img.hexus.net/dfinf2ub/box_inside2.jpg[/img]
Klickbaar
Sleurtas (Transpo)
[img=200,150]url= http://img.hexus.net/dfinf2ub/transpo.jpg[/img]
Klickbaar
Rounded (uv-sensitive) cables (1 ide en 1 fdd)
[img=200,150]url= http://img.hexus.net/dfinf2ub/rounded_cables.jpg[/img]
Klickbaar
Frontx -> met o.a.: diagnostic LED connector for external 4 diagnostic LEDs display http://www.frontx.com
[img=200,150]url= http://img.hexus.net/dfinf2ub/frontx.jpg[/img]
Klickbaar
2 SATA-kabels en SATA voedingsconnector
1 DFI Lanpartysticker
1 DFI Lanpartycasebadge
and last but not least: power and resetbutton op het mobo, werkt dus dmv alleen de voeding aan te sluiten :).
[url= url=http://img.hexus.net/dfinf2ub/sata.jpg ][img=200,150]url= url=http://img.hexus.net/dfinf2ub/sata.jpg[/img][/url]
Klickbaar
De Lanparty heeft een UV-coating en 4 diagnostic LEDs op het mobo(en extern), de Infinity niet.
Even een plaatje van de UV-coating:
[img=200,150]url= http://www.lanparty.com.tw/LP1/board3.jpg[/img]
Klickbaar
Links naar fabrikant+mobo:
http://www.lanparty.com.t..._r_us.jsp?PRODUCT_ID=2320
http://www.lanparty.com.tw/LP1/index_lp_us.jsp
Bios’en:
http://www.lanparty.com.t...Y_TYPE=null&STATUS_FLAG=A
INFINITY
http://www.dfi.com.tw/Sup...Y_TYPE=null&STATUS_FLAG=A
Beta-bios:
Die duiken op 4 verschillende plekken op :(.
De meeste recente verschijnen op: http://forums.amdmb.com/s...ad.php?s=&threadid=281088
verder op**: http://www.dfi.com.tw/Sup...DEX_TYPE=MB&STATUS_FLAG=B
en op: http://www.angrygames.com/CMOS_Reloaded_NFIIB.htm
en tenslotte dook er 1tje op bij: http://www.xtremesystems....6&perpage=25&pagenumber=5
http://www.dfi-street.com/bios.html
http://www.midnightmachine.com/dfi/
Modded BIOS: http://underclock.proboar...on=display&num=1074106235
INFINITY
http://myweb.hinet.net/ho...dfi/betabios/N24IDC18.zip
bios en utilities verzameld door Psychosis op: http://www.midnightmachine.com/dfi/
What are recommened DDR memory modules on LANPARTY NFII UltraB?
http://www.lanparty.com.t...SUBMITTED=No&PAGE_TYPE=US
Issues
1) De ruimte rondom de socket
Die is krap. De volgende (onscherpe doch functionele) foto zal veel verduidelijken:
Afbeeldingslocatie: http://www.experimentalinsanity.com/upload/images/zalmanonscherp.jpg
Klikbaar
Vanaf hier gezien zit er linksboven een laag chipje naast de socket, door de gebruikte constructie van zalman heb ik er geen last van, de koeler wordt aangedraaid op de 2 dwarsverbindingen. Van andere gebruikers heb ik gehoord dat ze met wat washers onder de steunconstructie werken om te voorkomen dat dit chipje wordt geplet.
Zie ook: http://forums.amdmb.com/s...ad.php?s=&threadid=278704
2) 2,0 volt is momenteel het maximale van de Vcore, zonder mod
Hier (op GoT) werd er geopperd dat deze d.m.v. een bios update verhoogd kan worden, ik heb hier nog niks overgelezen! Zodra ik iets concreets weet zal ik het hier posten. Tot die tijd is het misschien een idee om na te gaan denken over een eventuele mod.
3) Grote fluctuaties op de 5 en 12 volt rail
Ik heb er zelf geen last van (TrueControl) maar het wordt wel genoemd in de diverse fora. Ik heb me er niet in verdiepd omdat ik er geen last van heb. Het staat wel als puntje op mijn agenda om het mee te nemen.
4) Memoryproblemen
Heb ik ook geen last van, ik gebuik dus A-data oem wat waarschijnlijk geen BH-5 chippies zijn. Het blijkt dat reepjes beplakt met winbond het beste werken op deze plank. Hiervoor geldt weer hetzelfde als voor het vorige punt, geen last van staat op de agenda
Threads over wel/niet passen verschillende luchtkoelers
Thermalright 900a
http://forums.amdmb.com/s...ad.php?s=&threadid=280992
Zalman CNPS7000A
http://forums.amdmb.com/s...ad.php?s=&threadid=275858
Swiftech MCX462-V
http://forums.amdmb.com/s...ad.php?s=&threadid=279640
Thermalright AX-7
http://forums.amdmb.com/s...ad.php?s=&threadid=279623
Reviews:
Op de onderstaande sites zijn revieuws te vinden van de: LANPARTY NFII ULTRA B:
Hexus*
FastLane
TheModFathers
Club OC
DataFuse.net
NinjaLane
Ohls-Place
Viperlair
[H]ard|OCP
Hexus.net
FiringSquad
PCStats
Hardwarezoom
Envy News
Legion Hardware
INFINITY
http://www.mbreview.com/nf2inf.php
Links (fora-INFINITY en LANPARTY NFII ULTRA B meestal door elkaar in 1 topic):
Bijna alle topics op:
http://forums.amdmb.com/forumdisplay.php?s=&forumid=66
en hier de overige die ik heb gebruikt:
http://www.xtremesystems....6&perpage=25&pagenumber=1
http://www.xtremesystems....readid=24691&pagenumber=1
http://www.ocworkbench.co...b=get_topic;f=34;t=000015
En hier een handig forum over de DFI planken. Er is ook iemand van DFI support aanwezig die de vragen terug koppelt naar de technische mensen bij DFI.:
DFI Support @ AMDMB Forums
CPC uitgelegd
http://forums.amdmb.com/s...ghlight=command+per+clock
Things to cool:
Afbeeldingslocatie: http://upl.silentwhisper.net/uplfolders/upload0/coolingmosfettsandchips.jpg
Zoals je ziet worden de mosfets bij de CPU en bij het geheugen nogal warm. Het valt aan te raden hier een goede airflow overheen te hebben, of er even een heatsinkje op te zetten als je gaat OC'en.
Voltmods
Dit natuurlijk voor het echte DOC werk :P
We hebben de volgende mods:
- V-Core mod
- OVP mod voor V-Core
- V-Dimm mod
- Vdd mod
[/u]V-Core mod en OVP mod[/u]
Deze doe ik maar in een keer want ze zitten op de zelfde chip:
Afbeeldingslocatie: http://www.xtremesystems.org/forums/attachment.php?s=&postid=327062
hier kun je dus zien welke pinnen je moet hebben.
Pin 7 is de V-core mod zonder OVP mod zul je ongeveer 2.1 volt halen en dan kick je mobo zichzelf uit. Hier kun je het beste een 20K tienslag potmeter pakken. Dan kun je het voltage precies afstellen.
Pin 10 is de OVP met deze mod is tot nu toe 2.17v gehaald hierbij was de weerstand van tussen pin 10 en ground 3K.
V-Dimm mod
De V-Dimm mod. Voor de echte die hards aangezien de Infinity en de Lanparty beide standaard 3.3 v bieden. De V-Dimm wordt bij deze planken van de +5v lijn gehaald bij de meeste andere van de 3.3 en dan was er een 3.3v mod op de voeding nodig om een stabiele v-dimm te krijgen. Gelukkig is dat hier niet nodig :).
[img=400,300]url= http://www.xtremesystems.org/forums/attachment.php?s=&postid=307748[/img]
Klikbaar
Er wordt wel bij gezegd oppassen met het draaien aan de pod dus misschien verstanding ook hier weer een 200k 10 slag moet je misschien wel lang proberen voordat je het gewenste resultaat hebt maar wel minder kans op een kapot mobo ;)
VDD-mod
In deze draad wordt alles uitgelegd: http://www.xtremesystems.org/forums/showthread.php?s=da95d71772cf871d7d608287750ed11b&threadid=28585&highlight=infinity
Solder pin 6 to pin 4 via 100k trimmer, lower resistance for more volts.
I got 1.63 @ 60.5kohm, so you could start at 60-70kohm, if you will.
Afbeeldingslocatie: http://www.xtremesystems.org/forums/attachment.php?s=da95d71772cf871d7d608287750ed11b&postid=354127
Startpost door:
- Spice
- MaTr1x
- Astennu
- Exigence
Versie 4.0 béta :P
[ Voor 39% gewijzigd door Exigence op 14-05-2004 15:34 ]
  • mydogisgone
  • Laatst online: 09:22
mydogisgone
Watskeburtwithmydog
mooie start post :) mijn complimenten!!!
Mijn hond is nog steeds echt weg! En die komt ook niet weer. :O
  • Astennu
  • Laatst online: 24-04 12:13
Zo is i al 2 deeltjes hoor ;)
Misschien ff de layout fixen en een link naar de specs ipv een lap info?
  • sapphire
  • Laatst online: 13:36
sapphire
Die-hard pruts0r
yes eindelijk de VDD mod erin :)
Hoef ik neit steeds 'helemaal te zoeken' :P
Gabriël AM5
  • Exigence
Shit, heb ik een heel stuk aangepast aan de OP, krijg ik ineens een "Pagina niet gevonden" toen ik op bekijken drukte :(
Dus nog even geduld ;)
Edit: updated :)
[ Voor 13% gewijzigd door Exigence op 14-05-2004 15:35 ]
  • sapphire
sapphire
Die-hard pruts0r
Yow Exi, Kan je mij ff toevoegen op msn (staat in profile) want op de een of andere manier lukt het bij mij niet 8)7
Gabriël AM5
  • Henk
  • Laatst online: 06-07 10:15
Ik ben dus ook een gelukkig bezitter van de Lan Party Ultra B. Morgen gaat de vcore + OVP mod erop, maar ik heb daarover toch een vraag.
Als die voltmod nou gedaan is, moet je dan nog via je bios het 1 en ander instellen (bijvoorbeeld in bios het voltage op 2.000 volt zetten en daarna pas met de potmeter aan de slag) of moet alles gewoon met de potmeter?
  • Exigence
RedXraD schreef op 14 mei 2004 @ 17:11:
Met een vmod stel je de verhoging boven het ingestelde voltage in. Dus je zet hem op 1,5v in het BIOS (bijvoorbeeld) En dan zet je de Vmod erop. Dan ga je naar het BIOS en dan draai je langzaam aan de potmeter (wel een multiturn nemen) en dan houd je bijvoorbeeld op bij 1,55v. Dan is je verhoging 0,05v. Dus als je dan 2v instelt daarna, dan kom je op 2,05 v uit :) (In de praktijk ligt dit iets lager)
  • Henk
Exigence schreef op 14 mei 2004 @ 17:18:
Graçias voor de uitleg :) dan ga ik morgen me mijn mobo en videokaart maar eens modden... :Y) Dit was namelijk 1 van de grootste problemen voor mijn van de Lan Party. Mijn 8rda3+ trok nl. makkelijk een hogere vcore, en dat is nét wat mijn AQXEA 2500+ nodig heeft :) veeeel stroom >:)
[ Voor 15% gewijzigd door Henk op 14-05-2004 18:05 ]
  • Exigence
RedXraD schreef op 14 mei 2004 @ 18:04:
't Is trouwens spanning, maarja :z
Verwacht ook niet veel meer dan 2,05v hoor :) Wees niet te optimistisch. Of je moet deze OVP mod al doen:
Afbeeldingslocatie: http://www.xtremesystems.org/forums/attachment.php?s=e7e0309d70702419349b51877210b724&postid=392495
Daar moet je dus de geel omcirkelde SMD weerstanden vervangen door weerstanden met een hogere waarde. (Alledrie exact gelijk) Óf je soldeert 3 weerstanden aan de pootjes van de chip en aan de drie mosfets. Een van de twee dus. Helemaal links staat de Vdrop mod. Voor een stabielere Vcore. De normale Vsense mod gaat maar tot max 2,1v ongeveer. In het bovenstaande plaatje staan alle mods voor de DFI behalve de Vdd :)
De normale OVP mod, zoals die in de startpost staat, werkt niet. Die zal ik ook nog even verwijderen.
[ Voor 6% gewijzigd door Exigence op 14-05-2004 18:36 ]
  • Henk
Exigence schreef op 14 mei 2004 @ 18:35:
weet ik, maar stroom klinkt leuker :Y) :P
Maar als ik het goed begrijp (ik wil alleen vcore modden :P ) hoef ik dus alleen de vsense mod en de vcore mod te doen als ik een hogere vcore wil als 2.1? En hoe zit het met de potmeters? want in die van de openings post wordt een 200k aanbevolen, op bovenstaand schemaatje een 50k... :P
[ Voor 8% gewijzigd door Henk op 14-05-2004 19:20 ]
  • Exigence
Vcore mod: 50k
Vddr mod: Minimaal 50k, liefst 100 of 200. (50k geeft 0,4v verhoging)
Vsense mod: op de chip->werkt niet
Vsense mod: SMD's vervangen door hogere waarde
Vsense mod: Weerstanden tussen chip en mosfet
Vdd mod: 50k of 100k
Vdrop mod: 50k
De Vsense mod op de chip heeft geen enkel nut, omdat deze gewoon niet werkt :) Zonder Vsense mod zal je grens zo rond de 2,1v liggen. De enige oplossingen zijn de andere twee sense mod's, die hierboven in het plaatje staan.
  • Henk
Exigence schreef op 14 mei 2004 @ 20:02:
Vcore mod: 50k
Vdrop mod: 50k
Ok, me ook ff ingelezen te hebben in wat andere topics begint het me allemaal wat duidelijker te worden :) Wat voor weerstanden moet ik aan denken als ik de 3e Vsense mod uit wil voeren? of is daar nog weinig over bekend? en wat moet ik me eigenlijk voorstellen bij een vdrop mod? :P want vdrop zegt me echt nix :P
[ Voor 7% gewijzigd door Henk op 14-05-2004 20:42 ]
  • DaWaN
  • Laatst online: 12:45
DaWaN
'r you wicked ??
ff n00b vraagie, maar dat battery koelen is toch zeker niet waar?
If you do not change direction, you may end up where you are heading
Hoi, 8)7
ik denk dat het niet lang meer gaat duren of ik smijt diene f****ng DFI en al de rest hier gewoon uit het raam hé.
Clean xp gedaan,hij detecteerd gewoon mijn IDE Maxtor HD niet,blokeerd voordurend geeft van helse error beeps terwijl alles op defauld draaid. :X En dan nog als ik ook nog maar probeer om een beetje te oc dan start em gewoon niet meer op. Ik ben het stront beu aan het worden. (sorry) Da kost dan 2x keer zo veel als een doorgaans mobo en dat werkt langs geen kanten. })
Ik weet me gewoon geen raad.
  • PASware
  • Laatst online: 12:54
AMD Mafkees schreef op 14 mei 2004 @ 21:22:
nee, dat lijkt mij ook niet, foutje neem ik aan
Ik heb gisteren een infinity besteld, kan ik eindelijk mijn xp-m 2400+ testen :D
Tesla Model 3 SR+ | 4425wp (Dak) - 1920wp (platdak) - 840wp (gevel 90gr) | Panasonic 5kW warmtepomp | Hewalex WPB 200L boiler
  • Henk
PASware schreef op 14 mei 2004 @ 22:33:
Hehe, ik denk dat jullie gewoon het gele omhulsel van de batterij aanzien voor een cirkel ;)
  • Exigence
RedXraD schreef op 14 mei 2004 @ 22:37:
Yep, dat is gewoon de UV reactive batterij behuizing op de lanparty :P
Over die weerstanden vervangen.... tsja, er zijn volgens mij heel weinig mensen die hem ooit uitgevoerd hebben. Op Xtreme waren er een paar geloof ik. Maar niemand weet precies welke waardes. En de Vdrop mod zorg voor een stabielere Vcore, minder drop bij load enzo :)
  • Henk
Exigence schreef op 14 mei 2004 @ 22:51:
Aha, maar het is allemaal nog vrij expirimenteel begrijp ik. Denk dat ik mijn vingers (en mobo :P ) er dan maar niet aan ga branden. Ik heb opzich niet écht veel verstand van electronica (de persoon die het voor mij doet wel trouwens :) ), en bovenal, absoluut geen stuiver meer in mijn zak. Dus ik denk dat mijn moederbord voorlopig ongemod blijft tot er betere (lees, duidelijkere) voltmods zijn. En natuurlijk keihard hopen op die bios :9
  • MaTr1x
  • Laatst online: 08-07 17:21
Heb nu m'n LP al een weekje draaien met een 2500 Mobile op 200x10 op luchtkoeling. Op http://matr1x.nl.tt heb ik wat pics gezet.
Alles werkt perfect en ga binnenkort waterkoeling inbouwen.
Daarstraks tijdens het internetten liep die opeens vast, zomaar uit het niets??? Daarna CMOS gereset met alle stroom eraf, dat werkte ook niet. Heb uiteindelijk een RAMmetje eruit gehaald en m'n backup schijf losgekoppeld, want voor de crash was die al spinned down had ik gehoord, nu gereset en alles weer aangesloten en alles werkt weer???
Anyway ff MBM en Sisoftsandra geïnstalleerd en zie nu dat me -5V op 0,58V staat :?
Zie de pics.
Afbeeldingslocatie: http://www.xs4all.nl/~mvgemert/MBM.jpg
Afbeeldingslocatie: http://www.xs4all.nl/~mvgemert/sisoftsandra_voltage.jpg
Kan dat kwaad, wat doet de -5V precies? PSU is een Levicom 450W.
Heb wel me PSU gemod met UV plexi en een andere fan erin en omdat een blokje niet paste omdat de fan nu meer naar het midden zit heb ik dat blokje buiten de voeding in de case vastgemaakt omdat het snoertje eraan lang genoeg was. Zou het daardoor komen? Het is dat blokje wat je hier rechts van de PSU ziet liggen, geen idee wat het precies doet:
Afbeeldingslocatie: http://www.xs4all.nl/~mvgemert/PSU_open.jpg
[ Voor 6% gewijzigd door MaTr1x op 15-05-2004 02:43 ]
π MW finishers
  • mydogisgone
mydogisgone
Watskeburtwithmydog
weetje dat heb ik OOK gehad met dezelfde voeding!!! en heb PRECIES dezelfde voeding.
en hij knalde net bij mij ook vast.. :S maar starte wel weer op.
heel raar allemaal 8)7 gewoon WHAM vast.. en ik zat alleen maar de surfen. meer niet 8)7
Ik heb gewoon bijna hetzelfde systeem als jij.. ook op 2000mhz en een fsb van 200 en hetzelfde geheugen!!
maar dit gebeurt best vaak bij mij dat hij vast loopt.
soms draait ie gewoon dagen probleemloos en dan heb ik uren lopen gamen en is er niks aan de hand. en dan als ik beetje dom aan het msn'en of surfen ben loopt ie vast 8)7
ik verdenk de voeding er gewoon van. en ga dan ook binnenkort een andere aanschaffen! want deze voeding valt gewoon op zich zelf al zwaar tegen :(
[ Voor 52% gewijzigd door mydogisgone op 15-05-2004 03:47 ]
  • erikdeperik
  • Laatst online: 25-07-2024
Door SlowikPL - Tuesday 09 March 2004 20:39
Ik heb nu problemen met mijn mobo
Eerst dacht ik dat het eenmalig was deze vastloper van gisteren. Maar nu het ik het om de 5 min. Zelfs als ik niets doe op de PC
In begin valt mijn geluid weg , in nForce op de equalizer gaan alle kanalen op rood en vervolgens bevriest mijn systeem. Geheugen zetten om losse timing helpt niets , allen als ik de FSB ze van 220 naar 200 gaat het goed
Ik vind het echt shit. Ook begin ik nu boot problemen ondervinden en het systeem boot niet goed , blijft steken in bios. USB gaan vanzelf uit
Shit shit, ik denk dat mijn mobo niet lang meer volhoud. Maar ik moet het meet onderzoek doen voordat ik de mobo schuld geef.
Alle voltages en temps zijn ok
Had iemand ook deze ervaring ?
hoe zit het met jouw probleem,is het opgelost/rma :?
ik heb nl hetzelfde probleem >geluide hapert errst dan valt het uit >alle kanelen rood>freeze :(
heeft iemand een oplossing pls
infinnety mobo
xp-m2500
nvida 4800 ti vga
400 wat noname voding
corsair bh5
ik zeg maar zo "zeg maar niks"
  • SlowikPL
  • Laatst online: 17-03 11:01
erikdeprik schreef op 15 mei 2004 @ 13:04:
infinnety mobo
xp-m2500
nvida 4800 ti vga
corsair bh5
Ja ik heb het opgelost: een betere koeling vgan de southbrige !!
NU heb ik zalman erop , maar binnenkort doe ik een waterblokje op.
* Intel Core i7-6700K @ 4.8Ghz * Asus MAXIMUS VIII EXTREME* nVidia Asus Poseidon 1080Ti * Mushkin 16 GB * SSD Samsung M.2 2280 256GB + 3x Samsung 256GB 850Pro* Enermax Revolution85+ 1250W * CM Stacker 832 SE * Waretcooling CPU, NB ,VGA 3x Mora
  • MaTr1x
mydogisgone schreef op 15 mei 2004 @ 03:43:
DAMN dat is echt wel toevallig. Ja ik kon me idd herinneren dat ik laatst hier had gelezen dat iemand ook zo'n soort probleem had. Ik heb gisteren alleen ff wat 3Dmark gedraaid en daarna geïnternet en ik wilde een PDFje bewaren en toen bevroor die. Erg vreemd allemaal. Wel toevallig dat we het zelfde mobo, RAM en PSU hebben op dezelfe snelheid en het zelfde probleem. Ik weet dat m'n RAM goed is want daar heb ik een paar maanden mee in een A7V8X gedraaid, en de PSU had ik al een jaar draaiende. Toen was de -5V alleen wel goed. Enige verschil nou is dat het mobo wat meer stroom trekt, dat ik twee Raptors in RAID0 (he jij hebt ook twee schijven in RAID0!) draai en wat meer fannetjes en een liquid neon ccfl heb dus in totaal wordt er wel meer aan de voeding getrokken. Heb jij ook die Levicom 450W met die twee blauwe fans dan?
Ik zie het nog ff aan voordat ik een nieuwe PSU koop, laat ff weten wanneer jij een nieuwe heb ingebouwd en of dat het probleem oplost. Trouwens welke BIOS heb jij, die van mij is van 27-11-2003
π MW finishers
Verwijderd schreef op 14 mei 2004 @ 21:44:
detecteerd gewoon mijn IDE Maxtor HD niet.
Je hebt in het bios je hdd toch op auto staan he?
Denk het wel sinds je xp erop hebt gezet...
Ik heb zelf een maxtor en met auto op heeft het nog nooit moeilijk gedaan.
Je nf² drivers toch niet vergeten ofzo?
Verder is de dfi meer afhankeljik aan een psu met goeie 5V rail met goed aantal amperes. Een aantal dingen die normaal op de 3.3 rail hangen zitten bij de dfi op de 5V rail en bij sommige psu's komt dat slecht uit.
[ Voor 24% gewijzigd door Verwijderd op 15-05-2004 16:51 ]
  • erikdeperik
SlowikPL schreef op 15 mei 2004 @ 13:16:
hmz ik heb fan's op de nord en soutbridge,en ze voelen erg koel aan
ook op fsb 200 loopt hij vast :'(
i
welke bios heb jij erin?
mijn vdd = max
  • mydogisgone
mydogisgone
Watskeburtwithmydog
MaTr1x schreef op 15 mei 2004 @ 13:40:
ik heb de bios van 21-01-2004 en dat was de beste bios die het minst vastliep. met de 31-01-2004 bios liep die om de haverklap vast :(
en trouwens ik heb echt precies dezelfde voeding :P en ook 2 schijven in raid-0.
kijk maar op http://www.anink.nl/Casemod
daar staan foto's van mijn systeem. dus dan weet je het.
maar ik verdenk mijn voeding er 100% van. want het is gewooon raar dat dit gebeurt. 8)7
dit snap ik effe niet, als je alleen de Vcore mod doet kan je tot 2.1 maar gaat je mobo uit? 8)7
en als je de OVP mod erbij doet valt die niet uit :?
ik ga maandag mijn DFI infinity bestellen, kan ik eindelijk mijn 2400-m peinigen }) mijn asus a7n8x wil niet echt ver :X
  • SlowikPL
erikdeprik schreef op 15 mei 2004 @ 16:56:
i
mijn vdd = max
AAAA, nog iets, namelijk: ik heb zelf een AMD XP2800+ ( en ook XP2500+) deze beide procesors liepen voor geen meter met multi 11 X en ook niet all te goed met 11.5 X !!!! did was voor mij de enige grootte obtakel die ik na veel onderzoek zelf moest uivinden!!!
nu draai ik 10 of 10.5 x 252 Mhz en CPC off ivm. mijn BH-5 1024MB.
Verger ale volts op MAX behalve de AGP 1.5v.
Beste Bios voor mijn id tot nu toe de N24LD121 !
[ Voor 6% gewijzigd door SlowikPL op 15-05-2004 17:52 ]
  • Exigence
Verwijderd schreef op 15 mei 2004 @ 17:50:
Ovp op de chip werk niet.... zoals ook al uitgebreid uitgelegd op de 1e pagina.
dus ik moet alleen de Vcore mod doen? :)
  • Smarron
  • Laatst online: 09-07 22:35
Smarron
The bend
Ik krijg op een fsb van 240 meteen een piepend mobo (sirene). Waar ligt dan aan? Mijn mem (PC3200 BH-5 ook op losse timings) of de NB? Alle voltages staan op max. behalve AGP niet. Moet daarna weer cmos clearen om hem weer aan te krijgen (insert werkt dan niet).
Toch wel jammer, aangezien ik iets meer verwachtingen had van de Infinity.
Ik verdenk trouwens mijn voeding ook van slechte lijnen op een hoge fsb. Er komt binnenkort eerst een Antec Truepower 550watt in, dan zien we wel verder.
[ Voor 20% gewijzigd door Smarron op 15-05-2004 20:03 ]
-=Dell Inspiron 7591=- -=Samsung Galaxy A52s 8GB=- -=Nikon D750=- -=Flickr=-
Bij mij loopt 6x233Mhz steeds vast,zelfs met de standaard vcore van 1,45V terwijl 10x233 geen problemen geeft.
Hij start wel op en ik kom gewoon in Windows maar na een tijdje dan loopt alles wat ik draai langzaam vast.
Dat is nu ook wel een ZEER lage multiper en lijkt me geen verstandige keuze
Kan het dat mijn LP gewoon stuk is?
Dat loopt hier voordurend vast,heb al een andere bios geprobeerd alles loopt voor een paar momenten goed maar dan blokkeerd em weer. Eender wat ik doe pc freast gewoon.
Aan temps kan het niet liggen,idle nu 32 à 33° stressed 43 à 45°.
Heb al eens een Prime test kunnen doen van ettelijke uren zonder errors maar dan, boem weer vast. 8)7 Aan wat kan dat nu liggen? Of ik nu alles op standaard settings zet of ik OC eender hoe hij blokkeerd gewoon.
Is mijn LP klaar voor RMA of ligt het aan wat anders? :r :'( .
Pls help me........................
Specs:
DFI LP
Barton-M 2600+
Corsair XMS 3200 , 2 lattekes van 256
Hercules 9700 pro
Maxtor SATA 120 G
  • erikdeperik
SlowikPL schreef op 15 mei 2004 @ 17:50:
aha ik heb de bios van 31 01.
hij stond bij mij nu ook op multy 11
nu heb ik windhoos opnieuw geinstaleerd en alleen de audio drivers geinstaleerd die echt nodig zijn
het probleem lijkt nu verholpen(afkloppen 7(8)7 )
verder heb ik de netwerk en sm bus drivers geinstalleerd,
tot zover alles goed :X
  • DeSire
  • Laatst online: 30-11-2025
Zo heb net dit bordje besteld. (zat tijdelijk met een asrock bordje opgecheept van 35 euro ofzo:P).
Is ff kijken wat ik uit mijn barton 2600+ kan krijgen nu :) })
Mijn Barton-M 2600 loopt nu al enkele uren stabiel op 2500mhz, FSB op 250 :9~ :9~ en multi op 10, OCP enabeld. Had nooit kunnen dromen dat mijn Corsair geheugen dit ging draaien.
Ik heb wel wat aan het sukkelen geweest tot ik dit bereikte maar ik heb gewoon AGP in bios op 66mhz gezet,voordien op auto,en plots loopte alles vlotjes.
DFI===> _/-\o_ _/-\o_ _/-\o_
  • DeSire
_/-\o_
Verwijderd schreef op 17 mei 2004 @ 22:40:
das wel netjes zeg :) . Erg geile fsb :) :+
Ik moet het voorlopig doen met een reepje dat ik bij de funprice heb gehaald(transcend). Even kijken wat ik daar uit kan halen en als het tegenvalt, verkoop ik em en dan haal ik wel beter geheugen :). (ik heb toevallig een vriend die een nieuw systeempje gaat halen dus me mobo kan ik al kwijt iig ;))
op het moment haal ik 2300 mhz (iets hoger wil wel maar niet zo stabiel en ut is btw een barton) @ een asrock k7s8x. Maarja daar kan je dus geen reet doen qua overclocken ..je kan de vcore nie hoger dan 1.7 volt laten draaien(of je moet modden). Valt me nog wel mee dus tot nu toe dat overclock resultaat :P
Hopen dat ik er wat meer uit krijg op mijn nieuwe bordje })
[ Voor 7% gewijzigd door DeSire op 17-05-2004 23:15 ]
  • ChkDsk
  • Laatst online: 12:32
ChkDsk
Beter laat dan morgen
Hallo dan... Na al enige tijd bijzonder tevreden te zijn met mijn DFI Lanparty Ultra B, loop ik nu tegen een probleempje op. Ik heb de volgende hardware:
- DFI Lanparty Ultra B
- AMD Athlon XP-M 2500+ @ 250 × 10.5
- 2x 256 PC3500 GeIL
- 2x 160GB Maxtor S-ATA @ Raid 0
- Sapphire 9800XT
- Water op NB, VGA en CPU
- blablabla....
Nu heb ik het geheugen al op 250MHz gehad, 6-3-3-2. Lekker booten, lekker klooien, en dus nu naar 10.5 × 250 (1.85V), maar na een tijdje schopt ie m'n lanverbinding eruit... Ik denk dat de southbridge het probleem is, dat ie te warm wordt. Maar wilde dit even met jullie delen en kijken of jullie dat ook dachten, om nou ff 20km heen, en 20km terug te gaan naar een pc zaak voor een 40×40mm koeler... :/ Of zalman blokkie...
[ Voor 3% gewijzigd door ChkDsk op 18-05-2004 12:49 ]
ChkDsk schreef op 18 mei 2004 @ 12:48:
- Sapphire 9800XT
- blablabla....
Ja heb ik ook voorgehad.
Booten op 10*250 @ 1.7V no prob en dan op 10.5*250 met V op 1.8 lan gewoon weg en niets stabiel meer.
Ik d8 dat het aan mijn proc lag opdat die niet van een hoog voltage houd maar kan even goed de SB zijn.
  • ChkDsk
ChkDsk
CPU doet het ook nog op 2V dus dat mag het probleem niet zijn denk... CPU en NB zijn koud dus da ken het ook niet zijn denk ik. Maar nou is de SB std al erg warm, maar brand toch me vingertjes nu na 5sec vasthouden... Denk wel dat dat het is :Y)
Met dat warm weer is het hier bijna 10° warmer en valt mn muis soms wel eens weg.
Best lastig
ChkDsk schreef op 18 mei 2004 @ 13:39:
Check dan eerst eens of hij nog wel op een hogere MP die cpusnelheid kan draaien...
  • ChkDsk
ChkDsk
Ja heb m al op 2.8GHz gehad... :Y) met lagere FSB
[ Voor 19% gewijzigd door ChkDsk op 18-05-2004 21:33 ]
  • ikman
  • Laatst online: 10-11-2025
ik heb wat testen op mijn infinity gedaan met mijn timings van mijn golden dragon pc3500 2 x 512mb dual kit van geil.
standaard zijn de timings 2-3-3-6 op 2,60v loopt prima iets van 66 sec
op turbo zijn de timings 2-2-2-5 op 2,60v loopt prima iets van 65 sec
op expert heb ik de timings op 2-2-2-11 op 2,60v gezet toen boote de pc niet dus ik reset en in bios de timings weer op standaard gezet. daarna kreeg ik een error van een boot sector failure dus ik winxp cd er in format c klaar reboot het zelfde.
toen maar cmos gecleared en nu gebeurt er niks meer.
ik heb een andere hdd kabels en ide porten geprobeert maar niks terwijl alle lampje branden.
heb ik een corrupte bios of iets anders.
  • charrel
  • Laatst online: 07:40
charrel
Cortisol4life..
ikman schreef op 18 mei 2004 @ 21:52:
Ik heb dat ook wel is, wat bij mij helpt is om mijn harde schijven handmatig op LBA te zetten. Die staan dan op auto en dat werkt gewoon niet.
  • ikman
ik kom niet eens in mijn bios. er is geen post niks en mijn video kaart is goed.
alle stekkers zitten ook goed.
  • Syzzer
  • Laatst online: 15-06 20:21
Syzzer
Prutser
ikman schreef op 18 mei 2004 @ 22:22:
Bios chipbatterij eruit, stekker uit je voeding, mobo nachtje laten liggen en nog een keer proebren te booten. Je kunt ook nog proberen met de 100 MHz jumper er eens af halen, dan wil het bord soms nog net ff booten om je cmos te reseetten via de bios waarna het weer werkt. Ook met insert ingedrukt gehouden booten al geprobeerd?
Als je het dan nog niet voor elkaar krijgt is vrij zeker je bios corrupt. Oplossingen zijn dan hotflashen, bord RMA-en of een nieuwe bios bestellen.
  • sapphire
sapphire
Die-hard pruts0r
Was Geil nou niet dat geheugen wat juist hooge(re) volts nodig had om op stock speeds te draaien ?
Gabriël AM5
  • eviltweaker
  • Laatst online: 08-07 00:15
eviltweaker
DDPEEKIW
Is er trouwens een bios waarmee ik mijn multiplier op 12,5 kan zetten? Want met de bios die ik nu heb kan ik alleen 12 of 13 kiezen en 13 is net te hoog en 12 te laag. Mijn geheugen valt namelijk niet zo hoog te clocken :( .
DDPEEKIW
  • ikman
de bios chip kan ik er niet uit halen maar ik laat hem vannacht lekker staan zonder voeding in geplugt.
ik probeer die 100mhz jumper en de insert toets zo even en anders moet ik even naar rotterdam.
of geil van veel sap houd / nodig heeft, geen idee er staat op van 2,60v tot 2,95v.
op standaard had hij 2,60v en dat liep prima op 166mhz en 200mhz tijdens benchmarks.
nog steeds niks
edit2:
zegt syzzer
[ Voor 11% gewijzigd door ikman op 18-05-2004 23:24 ]
  • sapphire
sapphire
Die-hard pruts0r
wrom wil je je bios chip eruit ?
gewoon zonde stroom zetten en batterij eruit, doet echt wonderen bij mij ;)
Gabriël AM5
  • Syzzer
Syzzer
Prutser
Sorry, moest idd batterij zijn. Was blijkbaar niet helemaal helder gisteren ;) . Heb het maar gelijk verbeterd in me post.
  • Spice
  • Laatst online: 09-01 14:46
Spice
- Mijn vader is een tovenaar -
mm, ik vind het leuk om te zien dat die Geil-latjes het zo goed doen.
Deel IV alweer :) ga zo door!
Just call me angel of the morning, angel. Just touch my cheek before you leave me, baby. Just call me angel of the morning, angel.
  • charrel
charrel
Cortisol4life..
Verwijderd schreef op 18 mei 2004 @ 13:30:
Had ongeveer hetzelde, met sommige games knalde de lan eruit. Nu ff snel 4cm fannetje op southbridge blokje geplakt en nu blijft het wel werken.
Ding word gewoon te heet. Wel vaag trouwens, mijn vorige abit nf7-s gaf mijn southbridge meer stroom en werd minder heet.
  • sapphire
sapphire
Die-hard pruts0r
eindelijk foto online kunne zetten, zie mij mooie SB koelertje :)
SB koeler 1600x1200 :) (750kb)
edit: hotlink prob fixed.
[ Voor 21% gewijzigd door sapphire op 19-05-2004 12:27 ]
Gabriël AM5
  • Smarron
Smarron
The bend
eviltweaker schreef op 18 mei 2004 @ 22:33:
Moet je minimaal de 21-1-04 betabios voor hebben. Dan kun je 12,5 kiezen.
sapphire schreef op 19 mei 2004 @ 11:55:
Hotlinking not allowed :D
[ Voor 27% gewijzigd door Smarron op 19-05-2004 12:17 ]
  • sapphire
sapphire
Die-hard pruts0r
H**ren host, eerst 2 maanden offline, dan me 80 mb aan pics weg en nu ookal neit meer hotlinken :(
ff html van gemaakt :P : SB koeler 1600x1200 (750kb)
[ Voor 34% gewijzigd door sapphire op 19-05-2004 12:26 ]
Gabriël AM5
Blijft mooi mobo! :9
  • ChkDsk
ChkDsk
En vaag mobo ;)
Ik heb nu Zalman heatsink op SB en 40mm fan, sinkje is bijna ijskoud... Vcore maar op 1.9V gegooid... Maar ik lekker streaming audio op de achtergrond en unreal 2k4 spelen... Gaat een slordige 10min goed en toen viel me audio weg... Maar gamen ging nog gewoon. Ik terug naar windows, dit bericht tikken en winamp proberen draaiende te krijgen... Geen geluid. Tellertje bleef ook stug op 0 staan. De audiostream doet om de paar seconden een halve seconde geluid geven. Maar surfen lukt wel. Lijkt er niet op dat de southbridge nu het probleem is... :| :?
Op 10x 250 is me geheugen gewoon stabiel... draai nu op 11×240 ns kijken hoe lang die dat volhoudt. Anders is bord misschien gewoon niet capabel met 250FSB icm hoge clock? 8)7
Edit: Juist ja... 0.0 problemen tot nu toe... :O Ziet er niet best uit dan... I.i.g. niet met 250FSB in het vooruitzicht...
sapphire schreef op 19 mei 2004 @ 12:21:
Hoeveel herrie maakt jouw fannetje? Ik vind de mijn vrij lawaaierig...
[ Voor 84% gewijzigd door ChkDsk op 19-05-2004 14:17 ]
  • sapphire
sapphire
Die-hard pruts0r
Fannetje is bijna onhoorbaar, me voeding komt er toch wel bovenuit :P
Maar die DFI zal een fsb van 250 wel trekken hoor ;), red ik ook gewoon.
Maar hoe heb je die sink op je SB bevestigd? want ik had het eerst tijdelijk met thermal tape gedaan en toen kwam ik erachter dat het gewoon geen contact maakte met het midden vande chip maar alleen emt de randen (holle chip zoals gewoonlijk).
Gabriël AM5
  • ChkDsk
ChkDsk
sapphire schreef op 19 mei 2004 @ 14:39:
Edit: Ow ja, sinkje zit gelijmd met 2 componentendinges van Zalman...
Aha, maar mijn voeding doet blazen op 7V dus die is ook zo goed als niet te horen... En dat icm water maakt pc bijzonder stil. Alleen da rotte 40mm fannetje maak herrie :9
Hij doet 250FSB ook wel... maar met multiplier van 10x :( Zodra ik m op 10.5×250 zet gaat alles fout... Nu al bijna uur aant stressen op 11×240 en geen problemen :/ 11x240 geeft zelfs een nog iets hogere clock en hij loopt gewoon vrolijk door... Beetje jammer ;)
Edit 2:
Te vroeg gejuichd :)
Alhoewel... Ik kreeg dus een TRAP_CAUSE_UNKNOWN error...
Beetje google-en en ik ziet dit:
0x00000012: TRAP_CAUSE_UNKNOWN
Lies bitte den Online gestellten MSDN Artikel (Englisch)
und Allgemeine Fehlersuche.
0x00000013: EMPTY_THREAD_REAPER_LIST MSDN Artikel (Englisch)
0x00000014: CREATE_DELETE_LOCK_NOT_LOCKED MSDN Artikel (Englisch)
0x00000015: LAST_CHANCE_CALLED_FROM_KMODE MSDN Artikel (Englisch)
0x00000016: CID_HANDLE_CREATION MSDN Artikel (Englisch)
0x00000017: CID_HANDLE_DELETION MSDN Artikel (Englisch)
0x00000018: REFERENCE_BY_POINTER MSDN Artikel (Englisch)
0x00000019: BAD_POOL_HEADER MSDN Artikel (Englisch)
Problems When You Use Sound Blaster Live Driver with Your Windows 2000-Based Computer {297088 } (Win2000)
Wenn Sie sich an einen Win2000 basierenden Computer anmelden, kann die folgende Fehlermeldung angezeigt werden:
STOP 0x00000012 (0x00000000, 0x00000000, 0x00000000, 0x00000000) TRAP_CAUSE_UNKNOWN
Goed, ik heb dan wel geen SB Live! maar een Audigy... Zou het daar ook nog mee te maken kunnen hebben da me geluid ook zo vaag doet? Of lul ik nou maar wat in de rondte? ;)
En nog maar een edit:
Vaag... Heb m nu weer ff op 10×250 en dan start Skype gewoon weer op met windows. Deed het net de hele tijd niet. Is dit puur toeval? :? Het is me al een paar keer opgevallen dat ie dan wel dan niet komt. :/
Ik wor nie goed ;(
Ook op 10×250 geen lan meer na tijdje surfen en stressen....
En op 11×237 start Skype weer nie automatisch... (Das dan nog het minst erge probleem ;) )
[ Voor 54% gewijzigd door ChkDsk op 19-05-2004 15:19 ]
  • Smarron
Smarron
The bend
Neem mijn woorden terug van slecht plankje. Boot door een nieuwe bios (21-01-04) wel op 240fsb terwijl de officiele (27-11-03) niet verder dan 235 kwam. Geheugentimings ook op 11-2-2-2-2 !! Vanwege het warme weer ff op 10*240 gezet op 1.85v. Laat ik hem zo een tijdje staan.
Pifast doet exact 60 secs met deze instellingen. Kan veel beter, maar voorlopig vind ik het best. Ben allang blij dat hij op 240 boot !
Voeding staat op dit moment op de volgende waarden:
+3,3V- 3,22
+5V - 4,95
+12V - 11,80
-12V - 12,36
Is dit nog een beetje acceptabel ?
[ Voor 16% gewijzigd door Smarron op 19-05-2004 14:53 ]
  • Spice
Spice
En vaag mobo
Ik heb er over gelezen. Je moet de SB wat extra juice geven -> http://forums.pcper.com/showthread.php?t=320912&page=1
  • ChkDsk
ChkDsk
Spice schreef op 19 mei 2004 @ 16:00:
Hmmz,... ziet er wel erg priegelug uit... :? Iemand die dit al geprobeerd heeft op GoT? :7
Ik ben nu een beetje aant het moordneigingen krijgen! Me geluid is weer pleite! Waarom stopt mijn PCI geluidskaart ermee, doet mijn lan het, mijn muis het en verder geen problemen! En waarom alleen op hogere FSB dan 227 (ruim geschat)?
Waarom? :'( En ik heb me SB nog wel zo goed gekoeld ;(
Ok, beetje overdreven, maar wel gaar! :(
Edit...
Aarg!! Heel lang stabiel gehad... Nu hoor ik net "klikklik" door me headset,... gewoon geen geluid meer uit da ding te krijgen! (ja na reboot)
[ Voor 77% gewijzigd door ChkDsk op 19-05-2004 20:47 ]
  • sapphire
sapphire
Die-hard pruts0r
wat is volgens jou goede koeling ?
en idd, kan iemand wijs worden uit die pic van Portugal, k snap er bijster weinig van. mm k ga denk die components maar ff op me bord bekijken, ligt nu toch naast me :P
Gabriël AM5
  • ChkDsk
ChkDsk
sapphire schreef op 19 mei 2004 @ 23:01:
Ik heb een Zalman NB heatsink met 40mm fan op me SB gelijmd. Mag aannemen dat dat goed werkt... ;)
  • geforce666
  • Laatst online: 15-04 14:55
geforce666
a.k.a Jan (nl)
he mensen , heb even een vraagje
heb nu een 2500+ erin zitten maar bij My Computer --> Properties geeft i em altijd aan als Unknown CPU Type: zal wel aan BIOS liggen ofzo (166X11)
maar wat is nu de meest recente BIOS die het doet (dus niet degene waarvan je em flasht en dat i dan dood is) heb het al een tijdje niet meer gevolgd namelijk
en als ik ga rond zitten kijken wordt ik gek , kan door de bomen het bos niet meer zien
( wou net WinXp opnieuw gaan installen dus , gelijk maar effe alles update :P)
bij voorbaat dank.
  • Smarron
Smarron
The bend
geforce666 schreef op 19 mei 2004 @ 23:12:
bij voorbaat dank.
Kijk eens in de openingspost. Daar staan zat links.
http://www.midnightmachine.com/dfi/ voor betabiossen. De laatste officiele is die van 27-11-03.
  • ChkDsk
ChkDsk
bij voorbaat dank.
Ik heb de laatste bèta BIOS (6 mei op DFI site).
Het probleem van een crashende CMOS heb ik niet meer... Maar begin te twijfelen of het overclocken niet wil vlotten vanwege dit BIOS... :?
  • Syzzer
Syzzer
Prutser
Het geel omcirkelde weerstandje moet vervangen worden door een weerstand van 33 KOhm om je southbridgevoltage te verhogen naar ~1.72V . Ik persoolijk zou dus voor een 50K potmeter gaan (omdat je dan neit aan een vaste waarde vastzit). Hoe hoger de weerstand, hoe hoger het voltage op je SB. Pot dus instellen op 25K ofzo als je begint.
Op het punt bij de gele pijl kun je het voltage meten.
[ Voor 9% gewijzigd door Syzzer op 20-05-2004 12:12 ]
  • sapphire
sapphire
Die-hard pruts0r
ik snap ook wel dat je het weerstandje door een andere of een potje moet vervangen, maar ik snap geen hol van z'n tekening, dus welk weerstande het nou precies is en waar het meetpunt zit. Komt omdat het nogal 'amateuristisch' geaint is :P
Maja ik heb zga geen probs met meSB dus ik ben niet van plan deze mod uit te voeren, gewoon puur uit intresse, ik denk zelfs dat het niet eens kan omdat me zalman blokje daarvoor in de weg zit
Gabriël AM5
  • Syzzer
Syzzer
Prutser
Helaas is mijn digicam naar zijn mallemoer, anders had ik even een high-res plaatje geschoten en wat netter ingetekend. Het betreffende weerstandje is 'R151'. Deze zit (zoals je op die pic kunt zien) als je het bord 'rechtop' houdt boven de batterij. Het meetpunt is als je bord wederom 'rechtop' houdt de bovenste poot van de FC4, dat kleine cilindertje boven je batterij.
Ook met een sink zal de weerstand vrij liggen, het meetpunt misschien niet. Ik moet wel zeggen dat je erg weinig ruimte hebt. Een soldeerbout met een écht fijne punt lijkt me wel een must voor deze mod.
[ Voor 8% gewijzigd door Syzzer op 20-05-2004 14:16 ]
  • Exigence
Was het niet zo dat het VDD voltage voor de NB én de SB gold? :? Of is dat op de DFI's niet zo?
  • Syzzer
Syzzer
Prutser
Bij de Vdd mods voor Epox en Abit plankjes werd idd altijd aangeraden om extra koeling op je SB te zetten, omdat die ook extra heet werd van de mod. Dat zou dan idd moeten betekenen dat het VDD voltage ook voor de SB gold...
Maar als deze mod bij PORTUGAL toch zijn problemen met geluid/LAN verdwijnen, moet het aan de andere kant toch wel het SB voltage zijn dat je verhoogd? :?
Ik ga die draad op pcper maar eens doorlezen.
Voor een andere pic van de mod, met ene potmeter gedaan zie http://forums.pcper.com/s...hp?p=2797655&postcount=69 .
Edit2:
SAE heeft de mod dus geprobeerd, maar is niet van zijn problemen van wegvallende LAN/SOUNd/etc af :( . De mod lijkt dus niet te werken zoals PORTUGAL dacht dat hij werkte. Wel meld PORTUGAL er hogere fsb's mee te kunnen draaien.
[ Voor 32% gewijzigd door Syzzer op 20-05-2004 15:31 ]
  • sapphire
sapphire
Die-hard pruts0r
mja maar dan noem je ook iemand he, tis wel Portugal :P kweenie k vind die gozer altijd maar beetje vaag.
En waarom zou je hier een kleine ppunt soldeer bout voor moeten gebruiken, hij lijkt mij makkelijker dan de vdimm mod en daarbij had jij ook geen kleine punt gebruikt.
[ Voor 45% gewijzigd door sapphire op 20-05-2004 20:11 ]
Gabriël AM5
  • Syzzer
Syzzer
Prutser
* Syzzer pakt zijn bout erbij en gaat eens kijken of dat een beetje past :p (standaard 2.4mm punt).
Ik voorzag meer problemen, omdat het weerstandje van het bord af moet voor de mod. Bij de Vdimm is het alleen vertind draadje erboven houden, bout erop, even vasthouden en hij zit. Maar bij nader inzien moet het idd ook met een standaard puntje te doen zijn. SMD terugplaatsen wordt wel lastiger :p . Zo handig ben ik nou niet echt ;) .
Wat betreft PORTUGAL: ik zie hem altijd als een van de eersten die een mod gewoon doet en zijn bevindingen post. Hoewel het in dit geval sterk te betwijfelen valt of het echt aan de mod ligt dat hij verderkomt, denk ik toch dat er wel degelijk waarde aan zijn posts gehecht mag worden.
[ Voor 26% gewijzigd door Syzzer op 21-05-2004 00:32 ]
  • ChkDsk
ChkDsk
Ik ben het een beetje moe...
Op de snelheid waarop ik meer dan 15uur (jaja bier en lol doet veel goed) heb zitten lannen tript ie nu ook... (227×11) Klinkt als RMA :(
[ Voor 3% gewijzigd door ChkDsk op 21-05-2004 12:34 ]
  • Exigence
ChkDsk schreef op 21 mei 2004 @ 11:57:
Dus, jij clockt de handel over, en zodra hij niet overclockt zoals jij het wilt wil je de boel RMA'en 8)7 :X
  • ChkDsk
ChkDsk
Exigence schreef op 21 mei 2004 @ 14:25:
Niet helemaal... Ook op 200FSB klapt ie eruit...
  • sapphire
sapphire
Die-hard pruts0r
met een 200 fsb proc neem ik aan ? (3000+/3200+)
[ Voor 19% gewijzigd door sapphire op 21-05-2004 15:16 ]
Gabriël AM5
  • PASware
blijheid:
ik heb mijn infinity binnen, nu nog een paar andere dingen (volgende week) en ik kan me resultaten posten!!1
  • Silent Hunter
  • Laatst online: 31-05 14:56
Mijn infinity komt morgen, maar heb zwaar een Neo Back-plate nodig... anders past me SP97 ( of 94 wat was het :P ) niet op 8)7
maar ja iemand een winkel met die Back-plate op het net gevonden, IN nederland :P ?
12.4 kWh Thuisbatterijen + 1.8kWp balkon systeem - 5kW Zendure Units - Doet iets met content voor batterijen
  • Bacosjaco
  • Laatst online: 19-05 21:11
Bacosjaco
Under constuction
Silent Hunter schreef op 21 mei 2004 @ 21:25:
Als je maar wel op tijd op die rotonde sta. :Z
En hou hem heel he,het doet pijn zo lekker mobotje (FSB250 >:) ) te verkopen,maar ik ga nu toch maar naar de A64.
  • Silent Hunter
Bacosjaco schreef op 21 mei 2004 @ 22:28:
Helaas niet door gegaan heh wel jammer 260 Mooie FSB'tjes :'( :'(
  • quarantaine
  • Laatst online: 24-06-2013
quarantaine
mongtastic.be
mijn pc boot nietmeer :(
ik was gewoon een paar keer men bios aan het resetten en nu werkt er opeens niks meer.
mem al verstoken, met de fsb jumper gespeeld , graka gewisseld.
dit zuigt gewoon :'(
quarantaine schreef op 22 mei 2004 @ 17:02:
Batterij eruit en jumper clear cmos al gedaan?
  • quarantaine
quarantaine
mongtastic.be
Verwijderd schreef op 22 mei 2004 @ 17:23:
helpt die batterij eruit?
heb hem al 10mins op cmos clear gezet
  • sapphire
sapphire
Die-hard pruts0r
heb ik ook wel eens, dan helpt gewoone reset niet, dan gewoon ff stroom eraf en batterij eruit :)
Gabriël AM5
sapphire schreef op 22 mei 2004 @ 21:25:
Mijn internet verbinding wordt na een tijdje steeds trager en daarna staat ook Windows XP helemaal vast,ik begin een beetje een hekel aan het Infinity bord te krijgen want hiervoor had ik met een Asus A7N8X nooit problemen,altijd stabiel.
Ik heb een adsl USB modem en heb alles alweer een keer opnieuw geinstalleerd en draai gewoon op 200Mhz maar nog steeds problemen,verder de laatste officiele bios.
Iemand een idee waar dit aan kan liggen of zelfde probleem?
Verwijderd schreef op 23 mei 2004 @ 20:52:
De officiele bios had een probleem met bepaalde MP's. Ik weet niet op welke instellingen je draait, maar heb je al een andere MP geprobeerd? Ik zou in ieder geval ff aan de gang gaan met een andere beta-bios.1-21 en 1-31 schijnen bij de meesten wel lekker te lopen.
  • sapphire
sapphire
Die-hard pruts0r
Ik snap dat niet dan zeggen sommige mensen "ja maar ik draai gewoon maar fsb van 200" wat is daar gewoon aan dan? Tis overclocked dus tis niet gewoon, als ie daardoor instabiel word is dat toch niet heel erg raar. Of ligt het dan aan mij ?
@ MMMMM, zijn die Béta's die je hierboven noemt ook dezelfde waarbij het flashen vaak niet lukt ? Want na me examens wil ik weer verder gaan emt OCen dus moet ik ff goeie béta hebben :).
Gabriël AM5
  • Smarron
Smarron
The bend
sapphire schreef op 24 mei 2004 @ 10:23:
Ik had tijdens het installeren van 21-1 geen enkel probleem. Ik geloof dat die beta van mei alleen maar problemen opleverde.
(De 21-1 werkt bij mij trouwens uitstekend! Met de officiele kwam ik niet boven 235fsb instabiel, draai nu 250 helemaal stabiel!!)
  • Vandread
  • Laatst online: 14:26
Ik weet dat overal wel dingen staat hoe je je bios reset maar na een flash (naar de nieuwste beta) boot mijn infinity niet meer.
Dus welke stappen/manieren etc zijn er nou precies om te kijken of ik er nog leven in krijg?
  • woutur
  • Laatst online: 09-07 14:44
woutur
Klauwtjes uit!
Wat zijn de meest veilige stappen om er een nieuw bios in te gooien?
Toch gewoon via de oude vertrouwde DOS manier met een flop of is onder windows flashen tegenwoordig veilig genoeg?
Welke biossen zijn betrouwbaar, want zo te zien hierboven ben ik nog niet toe aan een nieuw bios (wordt harstikke bang van "boot niet" verhalen). Ik kwam elders ook nog "windows sluit niet meer af" verhalen tegen na het updaten van het bios.
Als je niet de moeite neemt je post in net Nederlands te schrijven, neem ik de moeite niet hem te lezen.
  • Vandread
  • sapphire
sapphire
Die-hard pruts0r
Asl het echt zoveel scheelt qua preformance met die béta's dan word het nog leuk >:) (kan nu 250 @3,3v 2-3-2-11 draaien)
Maja wel eerst een andere proc kopen want deze wil niet echt werken boven de 2,1 ghz :P
[ Voor 13% gewijzigd door sapphire op 24-05-2004 11:47 ]
Gabriël AM5
Smarron schreef op 24 mei 2004 @ 10:48:
Klopt. Ik had ook eerst 1-21 geflasht, maar met 1-31 ging ik nog een trapje harder. :) Mijn plank kwam met 11-27 geloof ik..
