ik kan deze nog meer aanbevelen (dp500 versie):
http://www.jacek.it.pl/ki...v-sub-8859-1-bold.iso.zip
beter leesbare ondertiteling, ook tinystocks, instelbare tijd voor subtitles (uitleg stata op site zelf wel) en nog veel meer
changelog:
8.1.2004 2.8.0-mv-sub
Differences to original 2.8.0:
- national characters in many encodings (also in filenames)
- tiny or bold font available
- fixed KiSS bug with breaking subtitle line into two in the middle of the word - now it is being broken at the space character nearest to the middle of the line
- macrovision disabled (Armagedon's patch)
- fixed subtitles display time
- subtitles display time configurable by user (while watching a movie press SEARCH on the remote and then 02 to 09 to set display time to 2 to 9 seconds. Don't use SEARCH 01 until you can read right to left. Your settings are valid up to the end of the movie.)
- reversing subtitles for people reading right to left (press SEARCH 01 to swich this feature on/off). Treat this feature rather like proof of concept - it reverses whole lines of text, regardles of their content (Hebrew text, numbers, Latin text). If you want this feature to work like it should, please send me a C function reversing a line of text properly.
- automagical subtitle file finder - file with subtitles does not have the same name as movie file. For example: abcde.avi and axyz.txt will be matched. The longer common prefix takes the precedence to the shorter one, so ab.sub will be preferred to axyz.txt in our example. Subtitle and movie files still have to be in the same directory and have to have one of extensions used by KiSS (utf, UTF, sub, SUB, srt, SRT, smi, SMI, txt, TXT, ssa, SSA, aqt, AQT, jss, JSS). This feature applies to CDs (and probably hard drive in DP508) only, not to PC-Link.
- if the previous algorithm (automagical subtitle file finder) doesn't find the subtitle file, any subtitle file will be opened
- LCD clock for DP-450 (the author of the clock is AaronL, I have only modified setting of the clock). To set a clock play any divx movie, press "SEARCH", and enter 99:hh:mm. For example to set 13:45 press SEARCH, 99:13:45 and press ENTER. Time will be displayed on LCD when player is turned off by remote.
- you can use DP-500 ntp clock even without internet connection - just set it as described above and select GMT+0 timezone in setup menu
- tinystocks' KML link instead of original one - that means weather information, imdb and more is available additionaly to original webradio. Weather information and more is developed by zorglub
Voor 70% gewijzigd door
Devian op 08-01-2004 20:15
