Reg. datum: 31 januari 2005
Informatique inNote 154-GTX90 (1680x1050) - Intel Core 2 Duo T7500 2.2GHz - 4GB DDR2 - 160GB 7200RPM - nVidia Go 8600M GT 512MB - Bluetooth - Intel a/b/g/n - Vista Ultimate x64 - XP Pro - OS X Leopard | iPhone 8GB 2.1
Forum » Apple Talk » Apple Media Devices » [iPhone] Ervaringen & Discussie Deel 5
Pagina: 1 2 3 4 ... 28 29 30 31 32 33 34 35 36 37 38 39 40 last
Nieuw Topicofftopic:quote:CLB schreef op dinsdag 18 maart 2008 @ 17:03:
Bedankt voor alle reacties tot nu toe!![]()
M'n iPhone komt vrijdag dus wil me er in het weekend druk om maken...
Een herinstall van Office (lees: Outlook) is misschien nog wel een goed idee, ga ik zeker doen!
Anders tsjaa dan maar in een week tijd alle contactpersonen in Outlook typen ofzo, ik zie 't wel
quote:* Exchange is so on! Changes are pushed over the network, but over WiFi it does check-ins, so it's not as instantaneous.
* There's no contact search that we can see, so far. Maybe that only gets turned on if you have thousands of contacts (which we definitely do not).
* There's a new button in the calendar, but we don't know what it is and can't make it do anything.
* The App Store is there, of course, but doesn't do anything yet (except error out that it can't connect).
* Wondering when Apple will make good on its agreement to license Cisco technology? Well, the branded Cisco VPN screen has definitely been added to the VPN settings. We couldn't really test this one, but assume it works as advertised. We don't yet know if it supports SecurID or other hardware token authenticators.
* Parental controls most certainly work. Marvel as we turn off YouTube!
* You can now order your preferred WiFi networks.
* In addition to having a new sideways scientific mode(!), the basic calculator now does commas and has new, useful functions for the math nerds; both the calc and the iTunes icons have changed.
* By far our favorite new feature is multi-select in mail, though. Now when you hit edit you can select as many messages as you want and delete or move them as a group. Friggin' finally. Now where's that two-pane client?
Ik snap niet zo dat mensen zo graag contact-search willen hebben. Die alfabet-lijst aan de rechterkant is praktisch hetzelfdequote:
[url=http://specs.tweak.to/13146][b]Specs[/b][/url]
PSN: iwaarden | Games: Condemned 2: Bloodshot, GTA IV, Metal Gear Solid 4: Guns of the Patriots, Ratchet & Clank: Tools of Destruction, Uncharted: Drake's Fortune
Kan je niet je contacten kopieren naar je sim? en dan via iSim of Simport (een van die 2 was het) je contacten importeren op je iphone? Zo heb ik het namelijk gedaan.quote:CLB schreef op dinsdag 18 maart 2008 @ 17:03:
Ik zou het anders geweldig vinden als ik alle contacts van een bepaald bedrijf kan vinden.quote:R4NCOR schreef op dinsdag 18 maart 2008 @ 21:02:
Ik snap niet zo dat mensen zo graag contact-search willen hebben. Die alfabet-lijst aan de rechterkant is praktisch hetzelfdeWat ik veeeel meer mis is e-mailsearch!
Adblock Plus
Geen Mac,wel fan! Apple
Nokia E71
Met mijn huidige aantal contacts is dat niet zo'n probleem. Op het moment dat ik push-contacts zou krijgen hier van de zaak krijg ik ongeveer 35.000 contacts doorgestuurd. Op dat moment is een dergelijke zoekfunctie best belangrijk.quote:R4NCOR schreef op dinsdag 18 maart 2008 @ 21:02:
HAI
CAN HAS STDIO?
VISIBLE "HAI WORLD!"
KTHXBYE
Persoonlijk heb ik nooit problemen gehad met IMAP vanaf firmware 1.0.2. Traag komt vooral door de connectie, over wifi is het gewoon snel.quote:HyperBart schreef op woensdag 19 maart 2008 @ 13:40:
Hoe zit het met mail, er waren wat problemen, het was wat traag, markeren als gelezen ging niet met IMAP, meerdere mails ineens deleten is ondertussen opgelost (bij firmware 2, dacht ik ?).
Nee, dat is onzin. Het geluid is niet slechter dan dat van de Nokia's e.d. die ik heb gehad. Sterker nog: het is gewoon kraakvrijquote:Het geluid tijdens het bellen, er zit hier iemand in de klas die heel de tijd zit te mekkeren dat het niet goed gaat met bellen (ruis/gekraak enz), is dit een feit?
Ik gebruik zelf de iPod niet veel, maar een dag of 3 lijkt me realistisch.quote:Batterij-duur: af en toe een beetje wifi, vaak sms'en, niet veel foto's trekken, en ipod 1,5u per dag, hoelang houdt ie het ongeveer vol?
Hij hangt af en toe wanneer 'ie aan m'n carkit hangt sinds ik 'm heb laten stuiteren, daarvoor nooit problemen mee gehad op 1.0.2, 1.1.1 en 1.1.3.quote:Hangt jouw iphone veel? Heb je 'm gejailbreaked en komt dat daardoor?
Die is er ook voor het Nederlands, maar ook zonder dat typ ik tegenwoordig 10 keer zo snel dan op "ouderwetse" telefoons. Het is even wennen, maar daarna kun je er supersnel mee typen.quote:Gaat typen makkelijk zonder woordenboek/prediction (je weet wel, die functie om je te helpen geen fouten te maken (neen, heb het niet alleen over T9)
Mail werkt prima. Kan wat traag aan doen voelen, maar dat is alleen over GPRS via WiFi werkt het echt prima. Een 'markeren als gelezen' functie is er niet. Je kan natuurlijk wel even de mail aan klikken.quote:HyperBart schreef op woensdag 19 maart 2008 @ 13:40:
Enkele mensen van onze klas (waaronder ikzelf dus ook), zijn aan het kijken om een iPhone te halen.
Enkele dingen willen wij toch ng graag opgehelderd hebben, maar we vinden er niet veel/willen het iets persoonlijker horen van enkele tweakers:
[list]
• Hoe zit het met mail, er waren wat problemen, het was wat traag, markeren als gelezen ging niet met IMAP, meerdere mails ineens deleten is ondertussen opgelost (bij firmware 2, dacht ik ?).
Ik heb daar nog nooit last van gehad. Ook nog nooit gehoord. Misschien woont hij wel in de anus-van-de-wereld waar nog geen fatsoenlijke GSM dekking isquote:• Het geluid tijdens het bellen, er zit hier iemand in de klas die heel de tijd zit te mekkeren dat het niet goed gaat met bellen (ruis/gekraak enz), is dit een feit?
Een dag, dan moet je de iPhone toch echt opladen. Het is voor mij een automatisme geworden om de iPhone aan het stopcontact te hangen als ik thuis kom.quote:• Batterij-duur: af en toe een beetje wifi, vaak sms'en, niet veel foto's trekken, en ipod 1,5u per dag, hoelang houdt ie het ongeveer vol?
Het komt wel eens voor. Ik heb er nu 4 maanden en het is één keer gebeurd dat ik in DFU mode kwam onderweg en dat ik moest wachten tot dat ik thuis was om hem te herstellen. Soms loopt de telefoon wel vast, het blijft een computer. Ik heb er voor de rest helemaal niks op geïnstalleerd, zelfs de installer.app heb ik er niet op staan.quote:• Hangt jouw iphone veel? Heb je 'm gejailbreaked en komt dat daardoor?
Het woordenboek moet je echt installeren. Zonder kan het wel, ik heb het zelf ook een tijdje zonder gedaan, maar met is toch handiger. Je kan dan wat sneller typen en je fouten worden perfect gecorrigeerd. Top functie!quote:• Gaat typen makkelijk zonder woordenboek/prediction (je weet wel, die functie om je te helpen geen fouten te maken (neen, heb het niet alleen over T9)
Graag gedaanquote:[/list]
Alvast bedankt
Da's wel extreem volgens mij. Ik gebruik zoals gezegd de iPod vrijwel niet, maar ik kan wel gewoon een paar uur GPRS'en, bellen en SMS'en gedurende een dag of 5 voordat 'ie leeg is.quote:MadMark schreef op woensdag 19 maart 2008 @ 14:06:
Creative clutter is better than tidy idleness | iPhone 2G + 3G | iMac 24" | PB 12" | Nikon D40 | Mac Mini C2D 1.83
Adblock Plus
Nokia E71
Minnema wijzigde dit bericht 19-03-2008 15:12 (31%)
XBL/PSN: Freeply
Volgens mij kan je ook activeren en unlocken zonder jailbreak hoor.quote:Minnema schreef op woensdag 19 maart 2008 @ 15:08:
En jailbreaken zal je sowieso moeten doen, anders kan je niet eens activaten/unlocken. Het is natuurlijk altijd mogelijk dat apps de iPhone doen crashen, zelfs officiële AT&T iPhones in amerika lopen wel eens vast. Check de Apple fora maar.
PSN: Sluuz
Op vakantie? Let goed op je spullen ! || Omg, check deze sick fetisch German shizzle eens !
Ik denk niet dat er op korte termijn een 3G-variant van de iPhone aankomt. Dat lijkt me meer iets voor de iPhone 2.quote:Sluuz schreef op woensdag 19 maart 2008 @ 15:47:
zelfs een blendnieuwe nokia (smartphone of niet) en sony ericsson (smartphone of niet) loopt wel eens vast. Dat zijn geen punten om een bepaalde telefoon wel of niet te kopen. Telefoons worden steeds meer kleine computers, met alle voor- en nadelen van dien.
ontopic: wanneer het bericht dat de 3G variant in mei in Belgie uitkomt waar is, zou dat perfect zijn. Ik ga begin mei naar New York. Dan zou de 3G variant daar toch ook al beschikbaar moeten zijn neem ik aan...(of hebben ze daar geen 3G en zou die alleen voor Europa zijn?)
MarcoC wijzigde dit bericht 19-03-2008 16:02 (82%)
