[Ervaringen] MSI K8N Neo2 (-54G) deel 5
Pagina: 1 2 3 4 5 Laatste
  • 2.904 views sinds 30-01-2008
  • Tutti-frutti
Tutti-frutti
Graag gedaan!
Afbeeldingslocatie: http://www.computer-tuning.nl/topics/neo2/border.PNG
Hier deel 4 van het ervaringen topic van hét nforce-3 socket 939 bord.
In principe is het niet nodig om vorige delen door te nemen.
Mijn doel is om alle belangrijke informatie in de topicstart te hebben.
• [rml][Ervaringen] MSI K8N Neo2 (-54G) deel 1[/rml]
• [rml][Ervaringen] MSI K8N Neo2 (-54G) deel 2[/rml]
• [rml][Ervaringen] MSI K8N Neo2 (-54G) deel 3[/rml]
• [rml][Ervaringen] MSI K8N Neo2 (-54G) deel 4[/rml]
• [rml][OC-939] De MSI K8N Neo 2 - OC Thread[/rml]
• [rml][OC-939] De MSI K8N Neo 2 - OC Thread part 2[/rml]
In a nutshell, MSI can be greatly considered as the "King of K8 platform."
Afbeeldingslocatie: http://www.msi.com.tw/images/product_img/mbd_img/7025.jpg
Afbeeldingslocatie: http://www.computer-tuning.nl/topics/neo2/specs.PNG
CPU
• Supports Socket 939 for AMD® Athlon™ 64 FX / Athlon™ 64 processor
• Supports up to 3500+, 3800+ Athlon 64 FX 53, or higher CPU
Chipset
• nVIDIA® nForce3 Ultra Chipset
- HyperTransport link to the AMD Athlon 64/Athlon 64 FX CPU
- HyperTransport supporting speed up to 1GHz (2000MT/s)
- AGP3.0 8X interface at 533 MT/s (million transfers per second)
- Two independent SATA controllers, for four drives
- IEEE 802.3 NVIDIA MAC for 1000BASE-T
- Dual Fast ATA-133 IDE controllers
Main Memory
• Supports dual channel DDR 266/333/400, using four 184-pin DDR DIMMs.
• Supports a maximum memory size up to 4GB with ECC.
• Supports 2.5v DDR SDRAM DIMM.
Slots
• One AGP (Accelerated Graphics Port) 1.5V 4X/8X slot
• Five 32-bit v2.3 Master PCI bus slots (support 3.3v/5v PCI bus interface).
On-Board IDE/SATA
• An IDE controller on the nVIDIA nForce3 Ultra chipset provides IDE HDD/CD-ROM with PIO,
Bus Master and Ultra DMA133/100/66 operation modes.
- Can connect up to 4 IDE devices
• Supports 4 SATA ports. Transfer rate is up to 150MB/s.
• NV RAID (Software)
• Supports up to 4 SATA & 2 ATA133 Hard drives
- RAID O or 1, 0+1, JBOD is supported
- RAID function work w/ATA133 + SATA H/D or 2 SATA H/D
Audio
• 7.1 channel audio codec RealTek ALC850.
- Compliance with AC97 v2.3 Spec.
- Meet PC2001 audio performance requirement.
LAN
• Supports dual LAN jacks
- 1 LAN supports 10/100/1000 Fast Ethernet by Marvell 88E1111 PHY
- 1 LAN supports 10/100/1000 Fast Ethernet by Realtek 8110S (1000Mbps)
IEEE1394
• VIA 6306 chipset
- Supports up to 3 x 1394 ports.
- Transfer rate is up to 400Mbps
Afbeeldingslocatie: http://www.viperlair.com/images/reviews/cpu_mobo/msi/amd/s939/k8npe/io.jpg
On-Board Peripherals
On-Board Peripherals include:
- 1 floppy port supports 2 FDD with 360K, 720K, 1.2M, 1.44M and 2.88Mbytes
- 1 serial port
- 1 parallel port supports SPP/EPP/ECP mode
- 1 Audio jack(5-in-1), coaxial/fiber SPDIF out
- 8 USB 2.0 ports (Rear x 4 / Front x 4)
- 2 RJ45 LAN jack
- 3 IEEE 1394 connectors (Rear x 1/ Front x 2)
BIOS
• The mainboard BIOS provides "Plug & Play" BIOS which detects the peripheral devices and
expansion cards of the board automatically.
• The mainboard provides a Desktop Management Interface(DMI) function which records your mainboard specifications.
Dimension
• 30.5cm(L) x 24.5cm(W) ATX Form Factor
Mounting
• 6 mounting holes.
MSI’s Digicell
CoreCell Chip has four new technical features: Speedster, BuzzFree, PowerPro, and LifePro.
The Speedster technology of CoreCell Chip contains the most flexible BIOS options for overclocking, including async mode of FSB and memory frequency, 0.05V increment for memory voltage adjustment and the minimal increment of 0.0125V for Vcore.
BuzzFree technology examines the current system utilization and temperature level before leveraging thermal requirement & fan speed. It dramatically cuts the system noise by 50% by getting rid of the annoying buzz. Moreover, it also improves the quality of audio and video.
PowerPro prolongs the life of the motherboard, CPU, and fan by maintaining them under the optimum condition. It also detects and manages the motherboard utilization to prevent possible factors that may contribute to system crash.
LifePro technology prolongs the life of the motherboard, CPU and fan by maintaining then under the best condition. It can also detect and manage motherboard utilization to prevent possible factors that may contribute to system crash.
CoreCenter™, this all-in-one hardware console is an advanced combination of the popular PC alert and Fuzzy logic applications. It offers powerful functions such as hardware monitor, system alert, and instinctive overclocking UI.
Live Update™ 3 is a single utility software that automatically checks BIOS and driver updates. It includes MSI's Live BIOS™, Live Drive™, Live VGA BIOS™, and Live Utility™. Advanced users would also receive the latest information about MSI products and activities from MSI technical support.
De Doos :Y)
Afbeeldingslocatie: http://pics.computerbase.de/news/8228/2.jpg
[Meer...]
Inhoud:
• MSI Motherboard
• MSI Driver/Utility CD
• Sata(-raid)-Driver Floppy
• Sata-Cable (Optional)
• Sata Power-cable (for 2 Sata-devices)
• D-Bracket 2 (2 usb-ports)
• Round Cable of IDE-devices
• Round Cable of Floppydisk
• User's Guide
• Quick Guide
• Test Report
• Back IO Shield
Afbeeldingslocatie: http://www.computer-tuning.nl/topics/neo2/overklokken.PNG
Dit bordje is ook aardig interessant om over te klokken. Anandtech kreeg in hun review het bordje met gemak op het maximale instelbare, namelijk 300 mhz FSB >:). Met de nieuwste bios is 350 450 mhz instelbaar. Met het standaard fannetje is al aardig ver te komen... 300 was dus geen probleem voor anandtech.
Afbeeldingslocatie: http://www.computer-tuning.nl/topics/neo2/koelertje.JPG
Ik kreeg hem zelf met een zalman nj47b blokje op 330 HTT. Maar volgens mij was dit eerder het max van mn cpu, dan de nforce3.
Zoals te zien is, is het een wat andere plaats dan dat je gewend bent voor een northbridge (er is eigenlijk geen sprake meer van north- en southbridge, er is maar 1 chip). Voor waterkoeling op de northbridge lijkt deze plaats niet echt slim uitgekozen. Maar zoals je kan zien zou waterkoeling niet veel nut hebben, je zou er niet hoger door kunnen klokken. Verder zijn er wel wat wc-blokjes die erop passen. Bij koelercompatibility in de eerste reply staat welke koelers je zoal kan gebruiken.
Dit zijn de instelbare items met betrekking tot overklokken:
FSB: 200-450mhz, in stappen van 1mhz. Let wel dat je minimaal bios versie 1.2 erop moet hebben voor een max fsb van 450 mhz (bios 1.0: tot 300 mhz bios 1.1: tot 350 mhz) . Bios-links vind je onder links van dit topic.
CPU Multiplier: 4 - 20 x, Voor FX-cpu's kan men boven de standaard MP instellen. Vanaf bios 1.2 is het mogelijk dit met halve multipliers in te stellen :) Maar dit is niet altijd aan te raden (zie tips)
AGP: 66-100mhz, in stappen van 1mhz
Vcore: 1.55-1.85V, in stappen van 0,05V , maar met de Speedster technology van de Corecell in stappen van 0.0125V. Maar met modded bios kan je zelfs 1.55 v + 18,3 % pakken.
Vdimm: 2.50-2.85V, in stappen van 0,05V. (vind ik een klein beetje jammer :|, had liever tot 3.3 gezien ;) .. zie mods)
AGP-voltage: 1.50-1.85V, in stappen van 0,05V
Verder zijn er ook nog Hidden Bios Opties:
Vid Hiermee kan je het voltage van de voltageregulator regelen als ik het goed heb begrepen. Dit zou misschien wat impact kunnen hebben op de hoogte en stabiliteit van de vcore.
NV/ATI Speed up Met deze setting kan je jou agp-kaart wat extra mhz-en laten geven, geregeld door het moederboard. Zowel je videogeheugen als gpu wordt iets opgekrikt (10 à 20 mhz). Clock je liever zelf gewoon je kaart over, zet deze functie dan op disabled.
Lees voordat je aan het overklokken gaat nog even de tips door, hier staan belangrijke dingen zoals het gebruik van sata-poorten en overklokken...
• Mods
OCZ DDR-Booster
Na even rondgeneusd te hebben op Xtreme Systems kwam ik een post tegen waar iemand de OCZ DDR-Booster gebruikte op de k8n Neo 2 :) Deze lijkt dus compatible te zijn:
Ok I am now running the ddr booster at 3.2v on my Neo2. It does work fine and has allowed me to hit 300HTT 1:1 so far on my 3500 EBs.
* Tutti-frutti heeft zelf de ddrbooster getest, en het werkte
Vdimm @ Vio mod
Helaas geen tussen stappen, maar wel 3.3 volt op je dimmetjes ! Handig als je winbond chippies hebt.
Afbeeldingslocatie: http://www.computer-tuning.nl/topics/neo2/vdimmod.JPG
Thnx to Garrett
Nog een tipje die ik via mail van Thorry heb gehad:
Pak zo'n kort en dik mogelijke draad voor de vDimm = vio mod. Gebruik bijvoorbeeld een oude voeding kabel, of liever 2 naast elkaar.
Ik heb bij mijn board een 2e draad erbij gezet en nu kan ik ineens naar 265 1:1 ipv 245 1:1
Vdimm-, Vdrain- , Vcore- en vht mod
Leef je uit
(Vht = ht-bus voltage, dus meer volt erop.. meer mhz over de bus mogelijk.)
Andere mods en uitleg vind je in de OC-thread van dit bord in het DOC forum
Afbeeldingslocatie: http://www.computer-tuning.nl/topics/neo2/tips.PNG
Hier staan bekende problemen met oplossingen, of tips waardoor je meer performance kan krijgen.
Check de koelpasta onder de nb-koeler
Het blijkt dat sommige bordjes te weinig koelpasta onder de msikoeler hebben. Dit kan leiden tot een hete nforce 3 chip, wat op langere termijn niet goed is. Check daarom even of er bij jou genoeg pasta onderzit, zodat voldoende contact gemaakt word tussen koeler en nforce 3-chip.
Hogere Memory-bandwidth
Voor hogere geheugen scores moet je in het Cell-menu, bij memory settings de "1T/2T Memory Timings" op 1T zetten. De score met een HTT van 200 (ddr400) vliegt dan van zo'n 4800 MB/s naar 5900 MB/s !
Oplossing voor de combinatie: overklokken + Sata-schijven
Het blijkt dat de Sata-poorten 1 en 2 geen goedwerkende PCI-lock hebben. De pci-lock functioneert wel correct op de poorten 3 en 4. Gebruik daarom als je van plan bent te gaan overklokken de sata-poorten 3 en4. Zorg er ook voor dat je minimaal bios 1.2 draait. Mijn advies is ook om sata 1/2 op disabled te zetten bij Integrated Peripherals.
Met de satapoorten 1 en 2 zou je niet hoog kunnen komen met de htt. Misschien komt hier nog een biosupdate voor...
Pas op met het gebruik van halve multipliers
Sinds bios 1.2 kunnen er in de cell menu (bios) halve multipliers voor de cpu-speed ingesteld worden. Het is aan te raden om deze niet te gebruiken, omdat je dan performance verliest op je geheugensnelheid. Het werkt namelijk alsvolgt:
Als je cpu-HTT en mem 1:1 lopen, en de multiplier van de cpu is 11x, dan wordt de memspeed vastgelegd door de cpu speed door 11 te delen. Voorbeeld: HTT=250, MP=10. Mem speed = 2500/10 = 250 (ddr500).
Pak je nu 10.5 als multiplier, dan wordt de mem speed als volgt:
cpu-speed = 10.5x250 = 2625
Mem-speed = 2625/11 = 239 mhz.
Dit zit hem in de cpu memcontroler en kan helaas niet veranderd worden, de cpu kan alleen door hele multipliers delen.
Halve multipliers zijn wel aan te raden , als je cpu nog niet aan zn max zit, maar mem wel. Je kan zelf het beste even kijken wat het beste resultaat oplevert.
In mijn geval heb ik ook even getest. Ik ga zelf wél voor een halve mp:
11x232 , ddr464 = 6903 MB/s @ sisoft membench
10.5x243 , ddr464 = 6907 MB/s @ sisoft membench
ik heb meerdere malen getest, maar veel verschil is het natuurlijk niet...
thnx to Pakjebakmeel voor quote van forum
Windows installeren op een Sata-Raid array
Tijdens het laden van de windows setup moet je, zoals gewoonlijk met raid-configuraties, op F6 rammen. Bij het bord is een floppy geleverd met daarop de Raid drivers. Je moet tijdens de setup niet 1, maar 2 drivers installeren, namelijk:
-Raid Class Driver
-Storage Controller
Dit is erg belangrijk, anders ziet windows de schijven appart, en niet als 1 raidarray.
BSOD's ? Aggressive timings op Disabled zetten!
Aggressive Timings blijkt nu ook een erg bekende oorzaak te zijn van de blauwe schermen. Je zal waarschijnlijk, met Aggresive timings aan, veel BSOD's krijgen met "Beginning of dump Physical Memory". Wanneer je Aggressive timings uitzet in het Cel menu, zal je systeem hoogstwaarschijnlijk stabiel zijn :).
Nog steeds Instabiel ?
Nadat er erg wat postings geweest waren met instabiliteitsproblemen lijkt het erop dat de gegevens uit de SPD-chips op de geheugenmodules niet goed worden uitgelezen. Ik weet niet of dit aan het bord of aan de geheugencontroler van de cpu's ligt. Oplossing lijkt gewoon het zelf instellen van memorytimings en geheugen voltage.
Daarnaast is het aan te raden om ALTIJD satapoort 3 en 4 te gebruiken, zoals hierboven beschreven.
Dual Channel, welke slots ?
Als je DUAL CHANNEL wilt laten werken dan moet je de 2 latjes ram in het groen EN paarse slot steken(slot 1 & 2). Dit zijn dus de 2 onderste geheugenbanken. Dit is dus niet, zoals bij intel, in het eerste en derde slot. Als je het in slot 1 & 3 plaatst heb je kans op een instabiel systeem. Dit staat ook volledig uitgelegd in de manual :)
thnx to kennes
Windows blijft bij opstarten hangen bij logo
Wanneer je deze kwaal hebt, heb je waarschijnlijk een Benq/Philips/Nec dvd-brander. Door de IDE-drivers van nforce gaat er iets niet goed in combinatie met deze drives, waardoor het windowslogo ~20 seconde blijft hangen. Dit is op te lossen door de nieuwste firmwares te halen voor je dvd-drive.
Audio-driver installeren, erg belangrijk!
Nvidia heeft sinds 22 december een nieuw audiopack beschikbaar gesteld. Deze heeft ondersteuning voor de nforce 3 en 4 zodat de onderstaande truc niet meer toegepast hoeft te worden. Nvidia audiodriver
Als je standaard de drivers van nvidia installeerd (nforce drivers) dan worden de audio drivers niet geinstalleerd. En dan kan je de nvmixer ook niet gebruiken. En omdat de nvidia drivers veel beter klinken zijn die drivers toch aan te raden. Om hier gebruik van te kunnen maken moet je de drivers MANUEEL installeren. Rechts klikken in apparaatbeheer op het audiodingie. dan moet je NIET ZOEKEN nemen en dan bladeren en dan de file nvmcp.inf, en vervolgens 1 van de die items die erop komen. (die nvmcp.inf file haal je uit de c:\NVIDIA\4.27\audiodrv-map). Je kan op deze manier gebruik maken van alle nvidia geluidsfuncties, en bijvoorbeeld ook het volume per box instellen :).
Nadeel: Microfoon/line-in wordt waarschijnlijk onbruikbaar (niet getest met neo2, maar met ander 250gb bord)
thnx to kennes
Systeem hangt al VOOR de post
Misschien heb jij net zoals mindcrash het probleem dat het systeem niets doet. Dit kan natuurlijk aan van alles liggen. Het is natuurlijk zoals altijd goed, om in dat geval zo weinig mogelijk aan je moederboard te hangen, en een bios reset wil ook wel eens helpen. Mindcrash kwam erachter dat zijn muis voor het probleem zorgde:
Ik dacht eerst dat het spontane hangen bij het booten aan mijn videokaart lag, maar na het verwisselen van mijn Intellimouse aan de PS/2 poort voor mijn nieuwe MX1000 aan de USB poort start mijn rig zonder problemen op.
Gebruik geen Antec 350w
Wat er nu precies met dit type voeding aan de hand is dat het niet goed werkt met de neo 2, misschien de atx stekker (als je die aandrukt doet het systeem het), maar het is in ieder geval niet aan te raden deze voeding te kopen. Er zijn al 4 gevallen bekend onder de gotters hier met problemen.
De Antec NeoPower 480watt werkt wel.
Afbeeldingslocatie: http://www.computer-tuning.nl/topics/neo2/links.PNG
• Fabrikantinfo:
MSI K8N Neo 2 Platinum
• Handleiding
De Handleiding V1.1 (pdf , 7MB)
• Reviews
Anandtech Socket939 motherboard Round Up
PC Perspective Review
Een magere Zdnet review
Hot Hardware S939-motherboard round up
• Waar is de MSI K8N Neo2 het goedkoopste?
Link Naar de pricewatch
• Biossen
Update je bios, en je moederboard wordt instelbaar tot 450mhz }) Maar ook zitten er belangrijke bugfixes in (herkenning van satadrives etc)
Officiele Biossen:
Msi Biossen
Msi-Biossen (amerikaanse site)
Beta en modded:
- Hier
- Hier
- Hier
- Hier *
*Op deze site kun je ook modded biossen vinden, met alle hidden options unlocked, en hogere vcore >:))
Nummering van biossen werkt als volgt: 1.23 = 1.2 beta 3 , 1.2= 1.2 official
Afbeeldingslocatie: http://www.computer-tuning.nl/topics/neo2/etc.PNG
Mijn ervaring:
Voor mijn ervaring ga je naar deel 1 of 2 van dit topic. Mijn ervaring staat in de openingspost
Afbeeldingslocatie: http://www.computer-tuning.nl/topics/neo2/thumbneo1.JPG Afbeeldingslocatie: http://www.computer-tuning.nl/topics/neo2/thumbneo2.JPG
Afbeeldingslocatie: http://www.computer-tuning.nl/topics/neo2/thumbneo3.JPG Afbeeldingslocatie: http://www.computer-tuning.nl/topics/neo2/thumbneo4.JPG
Afbeeldingslocatie: http://www.computer-tuning.nl/topics/neo2/thumbneo5.JPG Afbeeldingslocatie: http://www.computer-tuning.nl/topics/neo2/thumbneo6.JPG
Toevoegingen / Vragen ?
Heb je nog vragen of toevoegingen waarvan je denkt dat dit de startpost moet komen ?
Mail me via Afbeeldingslocatie: http://www.computer-tuning.nl/topics/neo2/email.PNG
[ Voor 7% gewijzigd door Tutti-frutti op 26-12-2004 12:06 ]
4015Wp west (Dordrecht)
  • Tutti-frutti
Tutti-frutti
Graag gedaan!
(In)compatible Koelers
Als toevoeging op de startpost zal ik hier een lijst plaatsen met compatible koelers. Dit wegens de afwijkende lay-out van het bord die naast zijn voordelen (betere flow), helaas ook zijn nadelen kent dat er een aantal koelers niet passen. Hier plaats ik de koelers waar twijfels over kunnen bestaan.
Mail me dus als je weet dat jouw koeler/vgakoeler/cpukoeler-combinatie wel of niet past:
CPU
Zalman CNPS 7000 series
Afbeeldingslocatie: http://www.computer-tuning.nl/topics/neo2/zalman70001.JPG Afbeeldingslocatie: http://www.computer-tuning.nl/topics/neo2/zalman70002.JPG
Deze koeler past mits je geen passieve heatpipe koeling gebruikt. Mocht je ook gebruik maken van wat hogere geheugenmodules zoals Corsair XXL Pro geheugen, dan zou je deze in slot 3 en 4 moeten doen.
Zalman CNPS 7700 series
Afbeeldingslocatie: http://www.zalman.co.kr/upload/product/7700_cu_f_p.jpg
Deze koeler is helaas te groot, tenzij je een pci videokaart gebruikt :+.
[rml]DesertShooter in "[ Ervaringen] MSI K8N Neo2 (-54G) deel 5"[/rml]
Thermalright XP90/120
Afbeeldingslocatie: http://www.silentpcreview.com/files/images/XP-120/Top_01.jpg
Past. Bij de xp120 zou een condensatortje een klein beetje verbogen moeten worden, wat uiteraard geen probleem is :). klik
Coolermaster Hyper 6
Afbeeldingslocatie: http://www.computer-tuning.nl/topics/neo2/hyper6.JPG
Deze zou moeten passen, en verder niet voor belemmering moeten zorgen.
Chipset
Zalman N47J
Afbeeldingslocatie: http://www.computer-tuning.nl/topics/neo2/zalman47.JPG
De N47J past op de nforce3-chip, als je geen heatpipegeval of grote vgakoeler (Arctic silencer) gebruikt. Hij past in ieder geval met de volgende 3dkaarten:
-9800pro (evt. 2 pinnetjes iets naar binnen buigen, maar niet nodig)
-X800 (pro/xt) kaarten.
-Nvidia 6800 kaarten. Door de zalman heatsink iets te draaien of paar pinnen te verbuigen moet dit ook wel lukken.
Graph-O-Matic Rev2.0 VGA & Chipset
Afbeeldingslocatie: http://www.innovatek.de/contentServ/3.0/www.innovatek.de/data/media/191/500618.jpg
Deze past zonder problemen.
Frigus Chipset WC-blok
Afbeeldingslocatie: http://www.frigus.nl/products/images/NB-VIASiSnForce2-v1.0.jpg
VGA-koelers
Heatpipe Koelers
Afbeeldingslocatie: http://www.computer-tuning.nl/topics/neo2/zalman80hp.JPG
Door het gebruik van heatpipekoelers vervallen een aantal mogelijkheden voor het plaatsen van andere koelers. Bepaalde cpu-koelers zullen hierdoor in de knoop komen (zoals de 7000-serie van zalman). Andere chipset-koeling wordt onmogelijk, tenzij je een betere en net zo'n lage koeler als de standaard msi koeler weet te vinden.
Zalman VF700
Afbeeldingslocatie: http://www.casejunkies.com/images/artikel_upload/picture_5214.jpg
Past
Arctic Silencer
Afbeeldingslocatie: http://www.colorstone.com.tw/proimages/f1/arcticcooling/vga.jpg
Door het plaatsen van deze koeler wordt het moeilijker om andere chipsetkoelers te plaatsen.
[ Voor 17% gewijzigd door Tutti-frutti op 12-01-2005 22:37 ]
  • fstieger99
  • Laatst online: 23-10 23:01
fstieger99
www.Isaia.it
Topbord toch nog wat kleine dingen
Er zijn een aantal dingen waar ik nog steeds niet vrolijk van word. Namelijk, stel je hebt nog steeds 2 optical ide drives en 2 ide hdd's. Dan is het echt een BOUTwerk om sommige die ide kabels erin te frotten, vooral als je dus nog een floppy nodig hebt om die raid array te installeren.
Het onboard geluid vind ik echt heel erg matig, ok, me de nvidia driver klinkt het al een stuk beter, maar ik heb nu een audigy 2zs erbij gekocht, pppff wat een verschil, en ik heb gewoon 2 sterospeakers erop hangen.
The Sartorialist
  • Rival24
  • Laatst online: 08:56
Rival24
I'll Be Back
Het verschil met onboard en een audigy 2 zs is inderdaad behoorlijk groot, zelfs op mijn oude FPS 1000 speakertjes kan ik het verschil behoorlijk goed horen.
Overigens doe je het jezelf aan f.stieger als je een kabelrotzooi hebt, je kunt op je ide schijven gewoon een convertdingetje steken zodat je je sata er op aan kunt sluiten, en voor je opticals koop je gewoon een plextor sata drive :P
  • fstieger99
fstieger99
www.Isaia.it
Dat is wel een erg goede tip, heb je misschien een adres waar ik zoiets kan halen?
Ik doet het mezelf idd wel aan, maar het zou toch een kleine moeite van msi geweest zijn om 1 ide connector naar links of rechts te doen, dat zie je meteen al op alle nforce 4 mobos van msi dat ze dat hersteld hebben.
The Sartorialist
  • Rival24
Rival24
I'll Be Back
f.stieger schreef op vrijdag 24 december 2004 @ 23:56:
Vroeger stond dat gewoon in de pricewatch (niet echt goedkoop helaas), maar ik kan t niet meer vinden. Ik kan me herinneren dat ik er ooit eens een paar heb gehad bij een abit moederbord, misschien dat je iemand kent die ze niet gebruikt :p
  • juultje
  • Laatst online: 08:48
Quote uit deel 4
Satapoorten staan wel op enabled in bios he, en boot van hdd0 of iets staat ook aan he ? Misschien even een driver floppy proberen.. www.computer-tuning.nl/driverfloppy.zip. De 2 drivers moet je laden tijdens de setup door aan het begin f6 te rammen.
Quote uit deel 4
Bedankt voor je reactie :)
Die drivers zijn toch gewoon die op de floppy staan die bij het mobo geleverd worden?
njah..die drivers die hierboven staat ook ff op floppy gezet en die geprobeerd; nog steeds hetzelfde probleem; "fout bij het laden van besturingssysteem"
sata staat enabled in bios
boot is eerst cdrom, daarna hd (raptor is momenteel enigste schijf in m'n pc)
verder heb ik nog andere satakabels geprobeerd + WD tooltje om schijf te testen-->schijf=OK
nog enige suggesties?
  • Tutti-frutti
Tutti-frutti
Graag gedaan!
Hmm raptor.. daar zag ik volgens mij in het vorige deeltje een oplossing voor. Niet veel posts voor jouw probleem volgens mij :)
  • juultje
Tutti-frutti schreef op zaterdag 25 december 2004 @ 00:13:
Sorry, maar ik zie geen oplossing daarin?
heb behoorlijk door vorige topics gespit d8 ik zo :?
of kijk ik nu ergens overheen..?
  • Exar
  • Laatst online: 16-11 01:30
Is het ook mogelijk om in Windows een andere BIOS te flashen dan de laatste? Live-update geeft alleen de mogelijkheid de laatste (1.4) te flashen, maar ik wil 1.3 proberen, want m'n BIOS loopt bij 1.4 vast bij ehhh HTT multiplier ofzo. :X
(Ik heb geen diskettedrive, daarom vraag ik of het in Windows kan...)
Hoekwoning 2021, 100m2 vvw, ERST20D-VM2D, SUZ-SWM60VA
  • fstieger99
fstieger99
www.Isaia.it
Geen 1,3 doen, 1,4 is veel betere overklokker. Gewoon instellen in je bios met + en - die HTT.
The Sartorialist
  • Dupje
  • Laatst online: 20-11 12:38
Hier heb ik het ook met de 1.4 dat HT instellen bios doet vastlopen als ik niet met + en - werk :)
Intussen draait m'n cpu op 2620 Mhz, op 2640 had ik plots een vastloper gisteren, maar dit lijkt wel stabiel te werken nu. Ik draai trouwens constant met 100% cpu load ;)
nog ff over mijn probleem van dat booten, ik had gister die bracket van msi eraan gehangen met die ledjes en daar las ik van af dat mn bios moeilijk doet met starten. Ik kan nu wel gewoon weer wat wijzigen in het bios door eerst ff het bios te verlaten zonder save, dat niet boot bugje ben ik nog niet uit, niemand kent dit?
  • Tutti-frutti
Tutti-frutti
Graag gedaan!
meuktracker: nVidia nForce Audio 4.57 WHQL
Iemand die het geluid kan testen met deze nieuwe driver ?
  • Dupje
Ik heb hem net eens geinstalled, echt verschil in klank hoor ik niet, maar slecht is het zeker niet ;)
Het klinkt wel beter dan de originele driver :P
En beter dan iedere geluidskaart die ik hiervoor al gehad heb (SB live 5.1, Terrartec, ...)
  • Tutti-frutti
Tutti-frutti
Graag gedaan!
Dupje schreef op zaterdag 25 december 2004 @ 11:07:
Nice.. hij is dus net zo goed als de handmatige instalatie van een nforce driver, maar nu heeft hij echt ondersteuning zodat line-in en mic ook werkt ;)
  • Dupje
Tutti-frutti schreef op zaterdag 25 december 2004 @ 11:12:
Ik heb hem op dezelfde manier geinstalled als de nforce driver ;)
En line in en microfoon heb ik nog niet gebruikt
Microfoon ingang werkt wel, maar al het geluid komt uit mijn center speaker :?
Line in doet overigens niets. En als ik alles mute in nVidia control panel blijft er geluid komen uit speaker gek genoeg :?
Edit2:
De line ingang werkt wel goed, maar gek genoet moet ik die regelen met aux in nVidia NVMixer
:) De VU-meters doen btw nix als er geluid speelt dat via line-in binnen komt :?
[ Voor 37% gewijzigd door Dupje op 25-12-2004 11:45 ]
En hoe zit het met die nieuwe driver met de SPDIF out uitgang ik krijg hem met andere drivers niet aan de praat. :? 8)7 :?
[ Voor 16% gewijzigd door Verwijderd op 25-12-2004 12:40 ]
  • Bacosjaco
  • Laatst online: 16-11 21:35
Bacosjaco
Under constuction
Ik heb dit mobo ook aangeschaft ter vervanging van mijn K8N neo (S754) icm een 3500+.
Ik loop nu tegen het volgende probleem aan ik gebruik een WD360 raptor op s-ata 3 en dit krijg ik gewoon niet aan de praat,zet ik hem op s-ata1 geen enkel probleem.
S-ata 3+4 staan enabeld in de bios hij wordt dan ook gewoon herkent maar pc start echt niet op,zet ik hem op s-ata1 hup daargaat tie.
Er zitten nog geen andere schijven in mn systeem.
Op mn Neo(754) stond de schijf gewoon op s-ata 3 zonder problemen.
Is iemand dit probleem ook tegengekomen of zie ik iets over het hoofd? 8)7
  • Rival24
Rival24
I'll Be Back
Bacosjaco schreef op zaterdag 25 december 2004 @ 12:58:
Mja dat probleem heb ik ook, ik heb verder nog een 200GB IDE schijf, maar die wordt altijd wel herkend.
  • juultje
ja, ik heb ook problemen met m'n 360 Raptor, heb 'm wel aan de praat,...als secundaire schijf, maar een os van booten lukt gewoon niet :/ nadat m'n pc reboot als in win xp setup de bestanden zijn gecopieerd, krijg ik de melding "fout lezen besturingssysteem" of "windows kan niet worden gestart vanwege een schijfconfiguratieprobleem in de computer"
toch wel erg misselijk...aangezien hij juist is aangeschaft om m'n OS van te booten. :'(
hellupp! :>
  • Bacosjaco
Bacosjaco
Under constuction
Rival24 schreef op zaterdag 25 december 2004 @ 13:04:
Het vreemde is nu dat ik de raptor op s-ata1 heb gezet geen problemen,zodra ik mn andere schijf erbij zet op s-ata 3/4(maxtor 160gb) start windows niet meer op ook alleen de maxtor op 3/4 werkt niet.
Raptor op 1 en maxtor op 2 totaal geen problemen,maar ik wil ze op 3+4 ivm overklokken,ik denk dat dit mobo terug gaat naar de leverancier lijkt me niet helemaal fris :(
Hoi allemaal...
2dagen geleden kwam dus mijn nieuwe geheugen binnen Crosair XMS3200XLTP 1024
. Had eerst Kingston HyperX maar dat is dus absoluut NIET aan te raden. Het was de CL3 dit werkt dus niet met dit mobo.. Dus had ik bij salland een RMA ingevuld en heb ander geheugen gekregen. Dus ik zet het nieuwe geheugen erin.. en ja hoor in 1 x geen enkel probleem.
Dus ik windows installeren. Hoefde niks te installeren van de diskette. alles werkte in 1 x perfect. Achteraf het bios bekeken en had dus bios versie 1.36 er al op staan.. denk dat het daar aan ligt ??? Dus heb mijn bios geflashed naar 1.40 nu.
Verder werkt alles super.. mijn DVD-Brander ( de NEC3500) werkt ook zonder dat ik de firmware moet updaten.,..
Zit alleen met 1 ding.. mijn cardreader doet het niet.. heb de drivers geinstalleerd ( had de kabels al wel aangesloten voordat ik de drivers heb geinstalleerd maar het powerlampje brand wel ??? Kan iemand mij daar mee helpen..
Verder mijn videokaart de MSI NX6800GT al 10 % overgeclockt met de DOT technologie van MSI.. werkt echt super gewoon..
Verder echt een top bord gewoon... nu nog overklokken...
De voeding werkt echt super trouwens ondanks dat sommige mij iets anders aan rade.. ( heb de Thermaltake butterfly edtion 480W en alle volt lijnen zijn meer dan standaard ( dus 12 volt is: 12.11 , 5 volt lijn is: 5.08 ) Dit zijn denk ik wel goede voltages he ???
Case is : 21 graden mijn CPU is IDLE: 36 graden.. stressed weet ik het nog niet dus ga ik straks testen...
GReetz
  • styno
  • Laatst online: 20-11 12:19
styno
Koffie? Hmmm, ja, lekkerrr
Eergister mijzelf ook onder socket 939 aanhangers geschaard :)
- Antec Lifestyle Sonata kast met Antec TruePower 380 W voeding
- MSI K8N Neo2 Platinum :P
- AMD64 3000+ Winchester
- TwinMOS 2 x 512Mb DDR400 CL2.5
- Maxtor DiamondMax 10 200GB SATA 8Mb
- Ati Radeon 9700pro
Allemaal hartstikke leuk natuurlijk en het gaat ook als een speer (vergeleken met m'n oude P3 Celeron 1200), maar nu ben ik toch iets tegengekomen:
Ik heb de processor driver van AMD voor Windows XP geinstalleerd waarna Cool 'n Quiet werkt. In CoreCell onder Windows kan ik ook zien dat de CPU frequentie naar 1000MHz teruggeklokt wordt als het systeem niks te doen heeft. Als ik nu een spelletje (America's Army of Far Cry) ga spelen, daar heb ik 'em tenslotte voor gekocht, dan blijft het systeem op 1000 Mhz draaien waardoor de game performance grofweg ook tot 1/3 is gedaald.
Heeft iemand enig idee waarom CoreCell (Of de processor driver) de CPU niet op 100% zet als dat nodig is?
Climatechange is a super-wicked problem, but:
"The stone age came to an end not for lack of stones. And the oil age will come to an end not for lack of oil." -- Sheikh Yamani, Saudi oil minister
8xLG Neon MonoX 290Wp SMA SB2100TL / MY SR '22
  • Tutti-frutti
Tutti-frutti
Graag gedaan!
Styno schreef op zaterdag 25 december 2004 @ 15:18:
Het gebeurt in een paar ms, dus als jij naar windows terug gaat, en je cpu gebruik is laag, dan staat hij inderdaad meteen op 1000 mhz. Probeer eens in windows iets intensiefs te doen (bijvoorbeeld schijfopruiming starten), en kijk dan met cpu-z of je cpu speed omhoog gaat :)
  • styno
styno
Tutti-frutti schreef op zaterdag 25 december 2004 @ 15:21:
Hij blijft op 1000Mhz draaien ook tijdens Prime95. Bewijs:
Afbeeldingslocatie: http://www.lijsselstein.demon.nl/benchmark.JPG
Ik gebruik trouwens:
- BIOS versie 1.4 (was al geinstalleerd op het moederbord)
- De laatste drivers van de MSI website
- De laatste AMD64 driver van AMD voor Windows XP
In het BIOS staat Cool 'n Quiet op 'enabled' en ben nog niet aan het overclocken geslagen.
[ Voor 20% gewijzigd door styno op 25-12-2004 16:37 ]
  • Tutti-frutti
Tutti-frutti
Graag gedaan!
Oki...
Cool and quiet in bios Enabled ? AMD64 driver heb je dus geinstalleerd (1.0.0.14) ... In powermanagement/energiebeheer (configuratie scherm) op minimal power/minimale energieverbruik gezet ?
Btw.. corecell cnq moet je niets mee doen verder.. dat programma zuigt.
  • Dupje
Styno schreef op zaterdag 25 december 2004 @ 15:54:
Al eens op refresh gedrukt tijdens het runnen van prime? ;)
  • styno
styno
Ja.
Daar heb ik niet aangezeten en staat nog op 'Home/Office Desk', wat is de beste instelling hiervoor? 'Max battery' ofzo?
Oke, gedeinstalleerd.
@Dupje: Nee, niet op refresh gedrukt, maar de gameperformance is sinds de installatie van de AM64 driver tot 1/3 ingezakt, dus ik vermoed dat een refresh hetzelfde resultaat geeft.
[ Voor 3% gewijzigd door styno op 25-12-2004 17:11 ]
afijn, heb die diagnostic leds eraan gehangen, mobo heeft moeite met cpu detectie, althans daar lijkt het sterk op. ik heb al een mail naar msi gestuurd en bel ze maandag nog even(overlegd wat makkelijker) of zij misschien een oplossing weten, ik denk dat er wat mis is met mn bioschip.
  • Wingie
  • Laatst online: 19-11 16:46
Help ik wordt nuts,
Ik hoop dat iemand mij kan helpen ik heb vorig weekend mijn machine geupgraded naar een 3500 (newcastle ;-( , want coolprizes kon geen winchester leveren) en een msi k8n neo2 (met bios 15x maar ook 1.1 / 1.4 (standaard mee uitgeleverd) / 151 uitgeprobeerd) alles aangesloten en opgestart de machine geen netjes 4 groene dled lampjes maar het scherm bleef zwart en we hoorden 1 lange en 2 korte beeps en voor de rest startte hij gewoon door.
Na controle van een aantal zaken en eff op het net zoeken naar de betekenis van de piepjes kwamen we er achter dat het de graphic card moest zijn dus de Matrox Parhelia 128R Rev. A. eruit gehaald en een ti4280 erin gestopt en dit werkte direct. Mijn Parhelia in een andere machine gestopt met ook een AMD 64 erin (ASROCK) en werkte perfect. Ook in zijn originele machine een MSI K7T266 Pro2 RU werkt die perfect.
Hierna het bios van de parhelia geflashed naar 2.x en opnieuw geprobeerd maar nog steeds niks, daarna nog geflashed naar een oude versie 1.3-18 nog iets, maar ook geen resultaat nog steeds de piepjes.
We hebben ook nog een ATI geprobeerd ik geloof een 9800 en ook deze starte zonder problemen.
Dus help, volgens het testrapport boekje zou e.e.a. gewoon moeten werken, heb al een thread by matrox gestart maar dit gaat allemaal erg langzaam en op het nederlandse en engelse MSI forum maar op het nederlandse forum krijg je alleen niet ter zake doende antwoorden en bullshit.
Daarnaast heb ik zowel support van MSI nederland als Taiwan?? gemaild maar nog geen enkel antwoord gekregen.
Ik vindt het vreemd dat de dled aangeeft dat alles oke is maar dat er toch geen beeld is.
Het gaat om de MGI PH-A128R 404 A versie van de matrox kaart (7082-0401 Rev. A)
Mijn systeem bestaat voor de rest dus uit een:
msi k8n neo2 bios 1.5x (ook 1.4 standaard geprobeerd / 151 /1.1)
1gb corsiar geheugen value
een q-tec 550 watt dual fan inmiddels (sinds gisteren vervangen door een aeropower aerocool 550w kwam als winnaar uit de test bij ome thom) omdat iedereen de voeding als schuldige zag.
soundblaster audigy 2
matrox diamond plus 10 200gb sata
80 gig ata maxtor
nec 3500a 2.16
floppy drive
Aopen cd-drive
Voor de volledigheid ik ben ook een thread op het matrox forum gestart:
http://forum.matrox.com/mga/viewtopic.php?p=66644#66644
Indien jullie meer info nodig hebben dan hoor ik dit graag, en hoop dat we gezamenlijk dit probleem kunnen oplossen zodat ik mijn nieuwe systeem tenminste kan gaan gebruiken.
PS: Ik ben niet de enige met dit probleem meer personen met een Parhelia maar ook andere graphic cards hebben dit probleem.
Regards,
Wingie
Zit met een klein probleempje..
Ik wil net 3dmark2005 gaan draaien en ik zie daar tot mijn verbazing het volgende staan:
HyperThreadingTechnology N/A !!!!
En ik dacht toch echt dat mijn AMD 3500 + Athlon 64 HT ondersteunde ???
Ik ben net naar de site van AMD gegaan en heb daar de processor driver geinstalleerd. en pc opnieuw opgestart maar staat nog steeds :HyperThreadingTechnology N/A "
WAt kan ik hier aan doen ??? En nog een vraag eerst kon ik bij mijn video kaart DOT instellen maar nu kan ik dat niet meer :( Heb een MSI NX 6800 GT 256 MB , zie sig voor andere specificaties...
Kon niks vinden in GOT
Alvast onwijs bedankt..
  • styno
styno
Verwijderd schreef op zaterdag 25 december 2004 @ 23:11:
LOL, je bent in de war met Intel. AMD processoren hebben geen hyperthreading. Punt :)
weet niet of het al gemeld is maar niet enkel nec branders hebben dit probleem. Ik heb een pioneer brander 106D. Ook hiermee is het probleem van 20 sec blijven hangen geconstateerd. Ik hoop toch wel heeeeeel graag dat er nog een firmware voor uit komt want op dit moment is die er nog niet. (rpc1.org / pioneerelektronics.com)
  • JeroenNietDoen
  • Laatst online: 14:17
Vanochtend mijn Neo 2 met Winchester 3000 en 2 matched pairs Dane-Elec PC3200 reepjes geinstalleerd. 1ste poging ging fout, Systeem was gewoon onstabiel. Eens rondgekeken maar kon in eerste instantie niet het bios type checken.
MSI liveupdate geinstalleerd en deze vondt 1.4, laten flashen. Systeem bleef toch voor mijn gevoel onstabiel. De installatieprocedure ging ook niet helemaal correct. Daar ik onboard NIC gebruik kon ik mijn server niet benaderen voor de drivers. Dus maar de Realtec driver van cd gebruikt. Tevens ook de Realtec audio driver geinstalleerd.
Afijn, toch besloten maar opnieuw te installeren. GIng allemaal goed. Vanavond PC weer aangezet na het kerstdiner om verder te gaan, harddisk niet gevonden. WTF?! Reboot en hij pakte hem weer. Testen door wederom 10 maal te rebooten maar euvel weg. Hoop dat het permanent is.
Ik heb de 1T/2T timings van het geheugen op 1T gezet, volgens de tips in dit topic is dat aan te raden. Ik ga de CPU ook zeker nog overklokken naar 3200 of meer.
Voorlopig hoop ik dat het systeem stabiel blijft. Sinds mijn A7N8X en XP 2600+ hecht ik veel waarde aan de NForce stabiliteit.
  • styno
styno
Het seial nummer van mijn moederbord begint met: K0412xxxxxxx. Is dat nu een nieuwe serie (dan K0411 en K0410)?
  • Thorin
Thorin
Batman = Róbin's sidekick
Heeft er iemand enig idee of een Zalman VF700 op een Sapphire 9800 pro past icm dit moederbord met een Zalman NB47J Northbridge heatsink? :? Of zal je dan enkele pinnetjes om moeten buigen van die northbridge heatsink?
Een 0 is slechts een 1 in ontkenningsfase
  • styno
styno
Thorin schreef op zondag 26 december 2004 @ 00:43:
Daar ben ik ook wel benieuwd naar.
Styno schreef op zondag 26 december 2004 @ 00:35:
jep, 0412 is een van de nieuwere, heb 'm zelf ook alleen heb ik er een met een brak bioschipjeoid(hij heeft moeite met cpu detectie, cpu is ok).
  • Dupje
Ze hebben wel HT, maar het staat voor hypertransport bij AMD, wat iets anders betekend dan Hyper Threading bij Intel :)
  • Misterpc
  • Laatst online: 15:21
hallo ,
ik heb een klein vraagje ,
ik heb ook een msi k8n neo2 , hierop heb ik 2 verschillende corsair modulen , en nu ik de smaak van overklokken te pakken heb loop ik tegen de max frequentie van 1 van de twee modulen aan , nu is mijn vraag : ik heb een corsair CMX512 - 4000 op het oog , alleen hiervan vind ik bijna geen gegevens , er staat 250 MHz CL3 4-4-8 , maar zo ver wil ik het niet schoppen qua snelheid maar wel wil ik graag weten tot hoe ver ongeveer ik in CL2 zou kunnen gaan ,
hier het huidige geheugen en de snelheid die ze foutloos halen .
module in slot 1 : XMS CMX512 - 3200C2PT V1.2 (ouder type) max Freq 214 MHz 2-3-3-11
module in slot 2 : XMS CMX512 - 3200C2 V4.2 (pas gekocht) max Freq 220 MHz 2-3-3-8
nu is dus eigenlijk de ham vraag zal zo'n PC4000 module van corsair ook op
220 MHz CL 2 3-3-8 willen draaien ?
het andere module moet erin blijven want ik heb geen gouden bergen ....geld
tips zijn altijd welkom en ervaringen hiermee ook natuurlijk
B & W 5,8 KWp solar 12 * oost 10 * west
Ik heb nu de 1.4 bios maar wil de 1.3 terug wegens te instabiel. bios gedownd maar wat nu ? (ik draai xp prof). Bootdiskette maken in verkenner, bios file erop ... moet er nog iets bij ? I'm a mobo flash virgin :p
  • goof.
  • Laatst online: 20-11 15:03
Tutti-frutti schreef op zaterdag 25 december 2004 @ 16:39:
1.1.0.18 inmiddels ;)
Assumption is the mother of all fuck-ups
  • JeroenNietDoen
De AMD driver is toch alleen voor als je XP 64 bit gebruikt?
  • iambig
  • Laatst online: 21-11 20:16
iambig
* z.o.z *
Kaap schreef op zondag 26 december 2004 @ 17:46:
Nee, ook voor 32bits om de advanced features zoals cool & quiet goed te benutten.
NEE: dit is geen signature...
Heys,
heeft er iemand een zalman koeler op zen mobo(vast wel):p
is dat ding zijn laagste toerental 1394 rmp (of daar in de buurt)?
Cool and quiet werkt goed (via core center) en nog wel zonder de amd driver.
verder vraag ik me ook af of je samen met de zalman northbridge heatsink nog zo een actieve zalman vga koeler er kunt bijkrijgen :)
thankx
  • Warbringer
  • Laatst online: 11:37
Dit probleem heb ik dus.
Probleem is dat in Windows mijn brander niet herkent wordt.
De brander heeft gewoon gewerkt, maar ik heb geprobeerd op een 2e harde schijf de Windows XP 64-bit RC1 te installeren, om te testen met mijn 3500+.
Ik heb hem legaal gedownload van beta.microsoft.com en op CD gestookt.
Proberen te installeren, maar dit ging hopeloos fout (MBR ging de mist in).
Nadat ik met een hoop moeite mijn 1e installatie van Windows XP (32-bit dus) van de 1e oorspronkelijke harde schijf weer aan de gang had, merkte ik in windows dat mijn NEC 3500 ineens niet meer herkent werdt.
In de bios staat hij er mooi tussen op de secondary master, wordt daar prima herkent maar bij booten hangt het windows logo dus ong. 20 seconden en dan boot deze verder.
Als ik de firmware wil updaten van www.michieldeboer.nl (uit het NEC 3500 topic uit het opslagmedia forum gehaald) dan zegt de flasher dat hij geen NEC 3500 kan vinden. Dit klopt op zich wel want ook windows kan hem niet vinden.
Ik heb niet kunnen vinden of deze firmware ook vanuit dos te flashen is, dus dat is geen optie. Is er een andere manier op die brander aan de gang te krijgen behalve windows opnieuw te installeren en hopen dat het dan wel werkt?
Disk management van windows ziet de drive ook niet.
Ik heb sommige mensen gehoord die eens in de tig reboots WEL de NEC konden gebruiken maar bij mij komt hij gewoon NIET tevoorschijn.
Op zich komt er maandag een 300Gb Sata Maxtor plus 10 drive binnen waar ik opnieuw windows op ga installeren maar ik wil die drive wel gewoon aan de gang hebben.
Ik heb nog een 2e PC staan met een Asus mobotje waar ik de brander in zou kunnen bouwen, hopelijk wordt hij daar wel herkent en dan kan ik daar de firmware updaten. Ik zie in de sigs van verschillende mensen dat ze ook een nec 3500 hebben met de mobotje. Hebben jullie allemaal de default firmware of hebben jullie ook de firmware een update gegeven? zo ja.. welke? de modified bios of de officiele firmware? Ik heb namelijk begrepen dat er rip locks zitten op officiële firmwares..
Als iemand een firmware heeft voor de nec 3500 die goed werkt met de K8N Neo2, zou hij/zij die (of een linkje ernaar) binnen willen gooien op warbringer@ragnarok.demon.nl ?
Muchos gracias!
I want to live forever, so far.. so good.
Nou oke... Ik zit nu dus weer met een probleem en heb al een aantal dingen gedaan
zal voor de goede orde eerst even alles specs laten zien:
MOBO: MSI K8N NEo2
Proc: AMD Athlon 64 3500+
PSU: Thermaltake PurePower Butterfly edition 480 WATT
Geheugen: Corsair XMS 3200XLTP 1024mb\
Videokaart: MSI NX6800 GT 256 MB
Harddisk: WD 200 GB SATA
Beelkanon: BenQ FP783
Verder zit er alleen een Soundblaster live in en een Thermaltake Volcano 12 voor de processor cooling.
Hij heeft nu een aantal dagen super gewerkt als liep lekker en Aquamark 2003 en 3dMark 2003 en 2005 haalde allemaal hoge scores. en de N-BenchV3 van AMD ook hoge scores.
Nu gebeurd er alleen het vreemde. als ik iets installeer wat zeer groot is ( bijvoorbeeld Doom III ( orgineel ) dan loopt hij na 5 minuten installeren gewoon spontaan vast. Ik heb de temperaturen gecontroleerd: IDLE: ongeveer 38 graden en stressed na alle benchmark proggies nog niet boven de 50 graden..
Ik zou echt niet weten wat het kan zijn.. heeft iemand een idee ?? Ik zit met mijn hande in het haar !!
Hij liep ook 1 x vast tijdens MSN terwijl ik niks anders aan het doen was ???
  • Tutti-frutti
Tutti-frutti
Graag gedaan!
ALs je de sata schijf in poort 3 doet, heb je er dan nog last van ? Draai je de nieuwste bios ?
Mijn nieuwe mb de k8n neo die ik nu een week heb bevalt prima.
Alleen wanner de pc uit staat heeft de randapparatuur, zolas ps2 muis (optical) en mijn externe hdd nog steeds spanning. Het ledje van de muis blijft gewoon branden, vervelender is dat ik mijn externe hdd vsn western digital nu alleen uit krijg door de spanningsknop zo´n 8 seconden ingedrukt te houden.
Weet iemand of er in het bios iets in te stellen is, waardoor de randapparatuur, nadat de computer uit is, geen spanning meer heeft?
Tutti-frutti schreef op maandag 27 december 2004 @ 00:23:
Ja heb al jullie voorzorgs maatregelen gedaan... dus nieuwste bios : 1.40 en sata 3...
MAar heb ook nu even iets anders gedaan .. heb mijn aerogate en mijn cardreader en floppy drive uitgeschakeld. en al mijn fans aangesloten op mijn mobo en de temperaturen van zowel videokaart als processor blijven nu constanter en zijn rond de 36graden en ik heb geen vast lopers meer... het lijkt er dus op dat er ( DENK IK ) iets niet goed gaat met de aerogate III en of mijn cardreader / floppy..
EDIT: en oja heb mijn videokaart nu direct op mijn voeding kabel aangesloten,, eerst zat er een Y stekkertje tussen... om ook nog een fan aan te sturen...
Ook mijn Aqua mark en 3dmark2005 / 2003 scores zijn aanzienelijk hoger...
Maar als het aan mijn voeding ligt vind ik dit wel erg raar want het is toch een goede voeding. de thermaltake ( uit de reviews )
GReetz
[ Voor 8% gewijzigd door Verwijderd op 27-12-2004 02:10 ]
  • Dupje
Heeft er al iemand een softwarematig acces point gemaakt met de onboard wifi kaart?
Is dit überhaupt mogelijk ?
  • goof.
Exact zelfde "probleem" hiero...... toevallig al door waar dit aan ligt :?
Zelfde bios, drivers etc, ook geen OC alleen wat andere mem timings.
[ Voor 9% gewijzigd door goof. op 27-12-2004 14:16 ]
  • Race Eend
  • Laatst online: 17-12-2023
goof. schreef op maandag 27 december 2004 @ 14:15:
Welke test van prime doe je? Want als je blend doet, doe je alleen geheugen bijna. De andere 2 testen moeten je cpu wél stressen.
  • JeroenNietDoen
1 vreemd issue waar ik tegen aanloop sinds ik dit moederbord heb is als ik de PC s'ochtends opstart, hij de IDE HD detecteerd maar vervolgens een disk boot failure geeft. Als ik dan op enter druk, dan boot ie toch gewoon zoals het hoort. Als ik hierna reboot, of de PC uitzet en direct weer boot dan is er niks aan de hand. Komt dus eigenlijk voor als de PC langere tijd is uitgeweest.
En het probleem komt pas voor sinds de Neo 2 er inzit.
Vaag verhaal...
  • styno
styno
Bij mij is het probleem na een paar uur verder aanklooien spontaan als sneeuw voor de zon verdwenen :/
Geen idee wat de reden hiervan is geweest, ik heb geen extra software of drivers geinstalleerd, alleen een boel reboots en setting wijzigingen:
- Cool 'n Quiet aan en uit en aan gezet in bios.
- Power Option settings gewijzigd.
Anyway, geen idee dus waarom het eerst niet werkte en nu wel, maar ik ben er blij mee.
Hieronder staat een lijstje van de verschillende Power Options en het effect daarvan op Cool 'n Quiet bij een idle systeem (Gecontroleerd met CPU-Z, waarbij de 'Refresh' knop niet eens gebruikt hoeft te worden).
Home/Desk = 1800MHz
Portable/Laptop = 1000MHz
Presentation = 1000MHz
Always On = 1800MHz
Minimal Power Management = 1000MHz
Max Battery = 1000MHz
@Race Eend: De test die ik uitvoerde was 'In-place large FFT's', die de CPU dus wel zwaar belast.
Nieuwe vraag: Heeft iemand een idee over de manier waarop de chipset koeler aangestuurd wordt? De fan draait nu constant een dikke 5000 toeren en is verreweg de grootste/irritantste geluidsbron van mijn pc.Ook zie ik in MBM5 dat het derde temperatuursensor kanaal op de Winbond chip een temperatuur aangeeft van 27 - 32 graden, alleen ik kan nergens vinden waar deze sensor zich bevind....
[ Voor 5% gewijzigd door styno op 27-12-2004 18:25 ]
Nou helaas het is het dus niet.. na een avond super gedraaid te hebben 3 uur lang Prime95 en geen 1 fout en de CPU werd maar 51 graden liep hij na een dag niet aan gestaan te hebben net weer vast bij msn en bij het installeren van mijn nieuwe toetsenbord !!
Ik snap het nu dus echt niet meer !! Mijn videokaart lijkt goed te werken de aquamark scores zijn goed .. en 3dmark ook !!
Kan iemand nog iets bedenken wat ik kan doen ???
Ik denk zelf dat er iets is met mijn HD is ... iemand anders een sugesstie ?
Alvast bedankt
  • goof.
Race Eend schreef op maandag 27 december 2004 @ 14:17:
Eerst selftest (blend neem ik aan), daarna de (In-place large FFT's) torturetest, iig wel tijdje zoet geweest en er gebeurd geen aars, zie hiero;
Afbeeldingslocatie: http://www.zonked.demon.nl/pics/printscreen%20(570%20x%20428).gif
Styno schreef op maandag 27 december 2004 @ 18:23:
Home/Desk = 1800MHz
Always On = 1800MHz
Wel erg wazig idd, had vandaag wel dat CnQ uberhaupt niet meer werkte en dat ik het ook pas weer aan de praat kreeg na een disable, reboot en een enable in de bios. 8)7
Nou na een tijd aan te staan is er nu weer niks aan de hand.. had een nog 1 vastloper bij de installatie van Halflife 2!! maar nu draait hij weer een paar uur super goed... ga het vermoeden krijgen dat als hij een koude start heeft en dan gelijk iets moet doen dat hij dan vast loopt.. heeft iemand hier ervaringen mee ??? Mijn CPU wordt niet warmer dan 51 graden wat ik hem ook aan doe :p !! Dus ik snap er niks meer van !!!
Weet jij iets Tutti ??
Nadat ik de eindeloze topic's over dit moederbord heb gelezen ben ik van plan de volgende spullen te gaan bestellen:
- MSI K8N neo2 platinum :P
- Amd 64 3500+ (Winchester)
- 1 GB Corsair TWINX 1024 3200XL PRO
- MSI GeForce 6800 GT 256 MB
- 2x Maxtor Diamondplus 10 200 GB SATA
- NEC ND-3500A Dual Layer
- Tagan TG480-U01 480W
- behuizing moet ik nog kiezen...
Vinden jullie, de mensen die al met dit moederbord werken, dit een goede combinatie? Ik twijfelde een beetje aan het geheugen. Ik denk dat ik zo wel een aardig systeempje in elkaar hebt gezet..
  • r0el
Verwijderd schreef op maandag 27 december 2004 @ 22:48:
volgens mij gaat die brander niet helemaal lekker icm het mobo :(
  • JeroenNietDoen
Want? Wat is er mis met de brander dan?
  • goof.
@ Styno
Op welke power management optie heb je 'm nu staan dan? Ook ik zie dat hoewel CnQ aan staat, bij sommige opties de CPU (3000+) tóch op 1809 draait.
Verder lijken de opties in power management ook pas "effect" te hebben na een reboot :?
r0el schreef op dinsdag 28 december 2004 @ 07:28:
Ik heb van meerdere mensen gehoord dat deze brander normaal werkt icm dit moederbord. Waarom zou deze brander niet werken volgens jou?
  • styno
styno
goof. schreef op dinsdag 28 december 2004 @ 11:16:
@ Styno
Hij draait nu op Max Battery.
Klopt, in die settings gebruikt de AMD processor driver C'nQ niet.
Bij werken ze direct. Dat wil zeggen: je kiest een Power scheme, klikt op Apply en dan zie je CPU-Z direct (1-2 seconden) de wijziging in CPU frequentie.
  • styno
styno
Kaap schreef op dinsdag 28 december 2004 @ 11:06:
Ik heb deze brander ook, en het systeem is 'rock solid'.
  • goof.
Styno schreef op dinsdag 28 december 2004 @ 12:04:
Lama, het werkt!! Ben iets met me blik te vast gestaard op de dashboard van MBM5, deze geeft de verandering in CPU niet aan :( , CPU-Z wél, idd zonder refresh, zag 'm bij een reboot "ineens" omlaag kukelen!
Overigens, Corecenter (normaal niet in gebruik vanwege de veel besproken brakheid met hoop onnodige GUI) en Sandra geven óók de juiste CPU speed aan, jammer dat MBM hier toch even af doet :(
Voor de liefhebber nog ff een linkje naar een artikel/faq waar Cool 'n Quit duidelijk wordt uitgelegd. 8)
[ Voor 29% gewijzigd door goof. op 28-12-2004 12:25 ]
Ik ben van plan om dit bordje te gaan kopen, met een A64 3200+. Op het moment heb ik een AXP 2500+ op een A7N8X Deluxe. Nou was mijn vraag of je veel verschil in geluidskwaliteit hebt tussen de Soundstorm chip op de A7N8X Deluxe en de realtek chip op dit bordje. Ik gebruik als speakers de Cambridge Soundworks DTT3500 Digital over de coax kabel met Dolby Digital aan in de geluidssettings van m'n nvidia Soundstorm drivers.
  • fstieger99
fstieger99
www.Isaia.it
@ eibertjes
De nec3500a werkt in het begin NIET goed samen met dit mobo. Oplossing. Koppel de brander af, installeer de nforce drivers, ALLEMAAL onder windows safe mode. Koppel daarna pas je brander aan.
Dit werkte bij mij perfect. In het begin had ik alles aangekoppeld en bootte hij niet door, zie ook topicstart
The Sartorialist
Dit is niet waar !! Als je een nieuwe revisie van dit moederbord hebt met daar standaard 1.36 op dan werkt hij gelijk zonder moeilijk te doen !! Dit was bij mij ook zo !!
Tot mijn verbazing staat mijn pc nu al uren aan met CSS en Halflife 2 !! en hij loopt niet vast !! snap er dus geen drol meer van waarom hij dan af en toe vast loopt !!!
Iemand suggesties ??
  • Sayko
  • Laatst online: 19-11 15:44
Sayko
Knowledge Is Power
Voor de mensen die de nvidia firewall willen installeren. En een error 1609 message krijgen, het volgende;
Ga naar systeembeher, gebruikers en groepen, groepen en wijzig de naam van "gebruikers" in "Users" en je probleem is opgelost.
PS. Na de instalatie kun je het weer terugzetten naar "Gebruikers"
Had even niks te doen.
[ Voor 16% gewijzigd door Sayko op 28-12-2004 19:53 ]
  • iambig
iambig
* z.o.z *
Startpost materiaal @ hierboven?
Bedankt voor je 'ik had niks te doen' :P
f.stieger schreef op dinsdag 28 december 2004 @ 14:19:
@ eibertjes
ik had mobo met bios 1.0 (d8 ik) en die brander werkt prima zonder problemen...
  • Sayko
Sayko
Knowledge Is Power
Oh ja, voor de mensen die het niet weten. Als je bijvoorbeeld te hoog oc´ed en je krijgt geen beeld meer. Niet in paniek raken gewoon even de home toets ingedrukt houden en het systeem start opnieuw op met mem op standaard snelheid.
Ik ben sinds 2 dagen toegetreden tot het soc939 gezelschap _/-\o_
Eerst even mijn sysspecs:
MSI K8N NEO2
AMD64 3500+
Corsair 2x 512mb XMS
MSI A.R. 9800pro
2x Maxtor DM9 SATA 120gb
Nec 2500 dvd writer
Aopen dvdrom
Nu het probleem :)
Als ik "normaal" windows installeer loopt het als een zonnetje maar zodra ik raid0 ga draaien komt het probleem.
Ik ram netjes f6 in en installeer de driverS in de setup. Dan loopt tie door totdat de setup zegt : windows restarten, en dan............NIKS :( zwart scherm met een mooi knipperend streepje. Ik heb net een doorbraak gehad, na een half uur zwart beeld sprong hij ineens naar windows installeren. na die fase blijft hij nu hangen op zwart beeld met een heel vaag windows logo!
Ik heb de schijven op SATA3&4 zitten ze zijn allebei al geformateerd.
Ik heb de Nec al losgekoppeld omdat dat problemen zou kunnen geven.
Ik heb mijn mx1000 al overgezet naar een usb poort, maar het probleem blijft. |:(
wie o wie heeft er ideeen?
Alvast bedankt!!!!!!
  • Brainless-NL
  • Laatst online: 26-03 15:54
Brainless-NL
lolkipo
Hoodlum2000 schreef op woensdag 29 december 2004 @ 00:13:
bedankt voor de tip! Ik werd al zo moe van de hele tijd cmos resetten :D
btw ik heb ook een nec 3500a brander, die prima werkt met bios 1.1, 1.4 en 1.37
[ Voor 11% gewijzigd door Brainless-NL op 29-12-2004 11:12 ]
  • Exar
Hoodlum2000 schreef op dinsdag 28 december 2004 @ 19:33:
Op m'n werk zie ik dat je bij XP pro wel bij gebruikersgroepen kan komen, maar thuis lukte het me niet in XP home.... is het ook bekend hoe je het daar (in XP home dus) doet?
  • gri-
Ik heb gister ook dit bord ontvangen (zonder de wireless maar ach) en hij bevalt :)
Punt is alleen dat dmv cool&quiet ook de chipsetkoeler zachter kan gaan draaien. Nu lijkt hij dit alleen nooit uit zichzelf te doen. Stel ik speel een spel .. alles gaat hard draaien en alles wordt gekoeld. Als ik dan in windows kom gaat proc, voltage en cpukoeler omlaag .. maar niet de chipsetkoeler. Wanneer ik dan core center opnieuw opstart gaat alles even hard draaien en daarna zacht (dus ook de chipset), maar zodra ik weer iets inspannends doe blijft de chipsetkoeler vrolijk 5000 rondjes maken ook wanneer hij weer idle is.
Ik heb nieuwste driver voor winxp voor de processor (3200+).
Verder weet ik niet precies welke bios ik heb .. nog amper naar gekeken ;)
  • fstieger99
fstieger99
www.Isaia.it
@ toompje
niet iedereen heeft de nieuwste revisie met de nieuwste bios erop. Bij mij werkte het dus niet.
Ik geef alleen een oplossing aan wanneer het in eerste instantie niet mocht.
The Sartorialist
Okey.. weet het.. maar ik zei het alleen zodat sommige mensen eerst even kijken welke bios er opstaat want anders doen ze straks dingen die eigelijk niet hoeven :)
Maar ik hoor mensen over CoreCell hiero.. en ze vinden het niks maar ik hoor geen rede ??
Welk programma gebruiken jullie dan ??? En met overklokken welk programma gebruiken jullie zoal om alles uit te lezen en te testen ??
Ik heb het volgende al geinstalleerd:
Prime95
CPU-Z
N-Bench-V3 ( speciaal voor AMD systemen)
Everest Home Edition
Moet er nog iets bij ??? Alvast bedankt :D
  • Brainless-NL
Brainless-NL
lolkipo
Ik ben nu de neo2 bij mijn vader aan het installeren, maar nu heb ik het volgende probleem:
de nvidia lan geeft de hele tijd aan dat ie connected/niet connected is. En zo knippert het de hele tijd. Ik heb alles tig keer geinstalleerd en gedeinstalleert, ook heb ik de bios geupdate. Het lompe ervan is dat hij dit al eerder deed, maar toen heb ik het kunnen verhelpen door simpelweg de lan opnieuw te installeren.... maar nu heeft dat dus geen nut meer! Iemand een idee?
[ Voor 5% gewijzigd door Brainless-NL op 29-12-2004 16:01 ]
Na maanden lang met dit moederboard opgescheept te zitten met talloze problemen ga ik maar binnenkort een heel ander moederboard merk te kopen.
Probleem:
• Af en toe vast lopen bij CS:S / HL2, Doom3 en andere games
• Internet Explorer crashed veel en verschillende andere applicaties zoals ABC client
• Laatste 2 weken aardig veel blauwe schermen/reboten
• 3DMark benchmark proggies ongeveer 2 a 3 keer achterelkaar laten draaien lukt niet.
• Videokaart loopt soms 5 a 10 keer per dag vast (CPU recovery)
- Standaard Antec voeding (300watt) laten vervangen door een Antect Truepower 460 watt
- Mobo updates, bios updates, nieuwe en verschillende Radeon drivers
- Fast write aan/uitzetten
- Geheugentiming zelf instellen in de bios
- Mem/AGP voltage steeds verhogen
- Talloze nieuwe windows installs
- HDD op Sata 3 aansluiten
Specs
AMD Athlon64 3800
MSI K8N Neo2 Platinum-54GB
Corsair TWINX1024-3200LLPT PC3200
Western Digital 73GB (10.000rpm)
Sapphire Radeon X800XT PE 256MB
Creative Sound Blaster Audigy II ZS
Antec TruePower 460W
Heb laatst memtest laten draaien, 3 uur lang, geen errors. Wat kan het probleem zijn? De mobo? videokaart? geheugen?
  • Brainless-NL
Brainless-NL
lolkipo
bij mij gaf memtest ook geen errors! Maar ik kreeg wel blauwe schermen... Vervolgens heb ik anders geheugen in mn pc geprobeert... en voila geen bsods meer
  • styno
styno
gri- schreef op woensdag 29 december 2004 @ 11:23:
Dat klopt, de CPU fan wordt wel aangestuurd door de CoreCell chip op het mobo, maar de NB fan niet. Hiervoor kun je in Windows met Speedfan de fan snelheid regelen, werkt perfect bij mij.
  • ManiacScum
  • Laatst online: 15-10 16:00
Ik heb het volgende probleem bij dit mobo:
als ik de computer aanzet, krijg ik de volgende beep-errors, waar ik op internet geen oplossing voor kan vinden: ik hoor constant een lange beep, dus: beeeeep, - beeeeeep,- beeeeep, en dit houdt niet op.
Ik heb het volgende systeem:
Dit mobo dus,
2x 512 MB GEiL geheugen, pc 3200
AMD 64 3000+ winchester
Voeding: 340 watt chieftec
NEC DVD 3500A
Maxtor 160 GB HD 8mb cache.
Ik kan dit niet terug vinden bij de standaar beep errors (oa via google)
iemand die een oplossing heeft?
  • Tutti-frutti
Tutti-frutti
Graag gedaan!
Rekkie schreef op woensdag 29 december 2004 @ 22:53:
Dit mobo dus,
NEC DVD 3500A
Geheugen. Probeer eens 1 reepje erin te doen (in onderste slot). En reset het bios eens door de jumper die onder het oranje pcislot zit voor 3 sec te verwisselen. Als je opstart kan je ook meteen insert rammen (dit reset de settings voor 1x).
  • ManiacScum
Tutti-frutti schreef op woensdag 29 december 2004 @ 22:57:
Dit werkt, alleen heb ik nog totaal geen beeld!
Ik heb een Geforce 6800LE van XFX, de ventilator draait, dus er is stroom, de kaart zit er ook goed in, dit is gecontroleerd.
BTW, ik kan toch wel gewoon later die 2e 512mb er in stoppen (beetje domme vraag ik weet het)
  • charlie
  • Laatst online: 07-03 11:08
charlie
Heb mezelf ook nog eens getrakteerd op dit bordje, icm een 3500+, Raptor 72Gb, een 9800SE en een nieuwe antec Sonatie fluisterstille case, met Truepower 380W voeding.
Na een halve dag heeft de voeding het begeven.
Draai momenteel met een noname 420 Watter zonder enig probleem.
Blijkbaar zijn Antec en MSI geen beste maatjes.
Cool en Quiet werkt prima, SATA op Raptor is ook geen enkel probleem, heb wel even in de bios moeten zoeken, nadat ik er een exteren WD usb harddisk had aangehangen, deze werd immers als primaire bootschijf gezien, nog voor de Raptor, en dus wou de pc niet opstarten.
  • Rival24
Rival24
I'll Be Back
Charlie23 schreef op woensdag 29 december 2004 @ 23:35:
Beetje vreemd om de conclusie te trekken dat msi en antec geen beste maatjes zijn. Het kan ook puur toeval zijn.
Wat ik heb gedaan om van mijn SATA schijf op te starten is de gewone IDE poorten disablen. Windows kan je schijven dan toch gewoon vinden, en je start mooi van je SATA op :P
  • ManiacScum
Ik begin intussen een beetje te flippen.
Ik start mijn systeem op maar ik krijg dus niets in beeld.
Ik heb al het onnodige al van mijn mobo afgehaald (floppy, DVD, extra HD)
Ook hoor ik geen beep meer, het probleem met de beeps van het geheugen is nu niet meer, maar nu hoor ik bij het opstarten helemaal geen beep meer.
Op de D-bracket blijven de lampen constant branden op de volgende manier:
R G
G R
Specs:
AMD64 3000+ winchester
XFX 6800 LE
MAxtor HD 160 GB 8 mb cache
2x 512MB GEiL pc 3200
En uiteraard het MSI mobo
  • Sayko
Sayko
Knowledge Is Power
Zo te zien blijft ie hangen tijdens "CPU detect". Heb je al een CMOS clear geprobeerd?
  • ManiacScum
Hoodlum2000 schreef op donderdag 30 december 2004 @ 02:41:
Ja dat heb ik geprobeerd.
Ik heb ook al gekeken of de CPU er toevallig niet goed in zat, maar dat was ook niet het geval.
Damn ik word echt een beetje flauw onderhand.
  • Warbringer
Brainless-NL schreef op woensdag 29 december 2004 @ 10:47:
welke firmware? (kun je zien met Nero Infotool)
Mooi dat de NEC-3500A werkt op dit moederbord. Dit kan ik dus vast gaan bestelen..
Zijn er mensen die het volgende geheugen gebruiken..
Ik wil dit geheugen gaan gebruiken maar ik weet niet zeker of dit goed en snel werkt met dit moederbord. Iemand die mij meer kan vertellen?
  • styno
styno
Ik heb die Sonata kast ook met dezelfde voeding, werkt als een zonnetje hierzo. Ook overgeklokt en dan uren gamen geen problemen gehad.
  • Brainless-NL
Brainless-NL
lolkipo
Warbringer schreef op donderdag 30 december 2004 @ 11:00:
2.17
  • Dupje
Styno schreef op donderdag 30 december 2004 @ 11:33:
Ik draai nu op de voeding die in een Sonata zit ook zonder problemen :)
  • ManiacScum
Ik heb er ff een geforce 2 kaartje in gezet, nu werkt ie wel gewoon.
Alleen heb ik nog wel BSOD's, :X Ik heb windows nu al een tijdje niet op mijn favo pc'tje meer gezien. Sinds ik het mobo heb.
Agressive timing stond al uit, dus zal het ergens anders moeten zoeken.
  • ManiacScum
Rekkie schreef op donderdag 30 december 2004 @ 12:47:
Zou een bios-update oplossing kunnen brengen?
Ik momenteel versie 1.4 (Mobo is gister nieuw gebracht)
  • Tutti-frutti
Tutti-frutti
Graag gedaan!
Rekkie schreef op donderdag 30 december 2004 @ 14:37:
Welke voeding heb je ? Kan je misschien met een andere testen. Ook clear cmos al gedaan en settings van startpost (tips) uitgevoerd ?
[ Voor 12% gewijzigd door Tutti-frutti op 30-12-2004 19:22 ]
Pagina: 1 2 3 4 5 Laatste
