[Ervaringen] MSI K8N Neo2 Platinum (-54G) S939 deel 2
Pagina: 1 2 ... 6 Laatste
  • 3.790 views sinds 30-01-2008
  • Tutti-frutti
Tutti-frutti
Graag gedaan!
Afbeeldingslocatie: http://www.chastelet.demon.nl/1/border.PNG
Hier deel 2 van het ervaringen topic van hét nforce-3 socket 939 bord.
In principe is het niet nodig om vorige delen door te nemen.
Mijn doel is om alle belangrijke informatie in de topicstart te hebben.
• [rml][ Ervaringen] MSI K8N Neo2 (-54G) deel 1[/rml]
In a nutshell, MSI can be greatly considered as the "King of K8 platform."
Afbeeldingslocatie: http://www.msi.com.tw/images/product_img/mbd_img/7025.jpg
Afbeeldingslocatie: http://www.chastelet.demon.nl/1/specs.PNG
CPU
• Supports Socket 939 for AMD® Athlon™ 64 FX / Athlon™ 64 processor
• Supports up to 3500+, 3800+ Athlon 64 FX 53, or higher CPU
Chipset
• nVIDIA® nForce3 Ultra Chipset
- HyperTransport link to the AMD Athlon 64/Athlon 64 FX CPU
- HyperTransport supporting speed up to 1GHz (2000MT/s)
- AGP3.0 8X interface at 533 MT/s (million transfers per second)
- Two independent SATA controllers, for four drives
- IEEE 802.3 NVIDIA MAC for 1000BASE-T
- Dual Fast ATA-133 IDE controllers
Main Memory
• Supports dual channel DDR 266/333/400, using four 184-pin DDR DIMMs.
• Supports a maximum memory size up to 4GB with ECC.
• Supports 2.5v DDR SDRAM DIMM.
Slots
• One AGP (Accelerated Graphics Port) 1.5V 4X/8X slot
• Five 32-bit v2.3 Master PCI bus slots (support 3.3v/5v PCI bus interface).
On-Board IDE/SATA
• An IDE controller on the nVIDIA nForce3 Ultra chipset provides IDE HDD/CD-ROM with PIO,
Bus Master and Ultra DMA133/100/66 operation modes.
- Can connect up to 4 IDE devices
• Supports 4 SATA ports. Transfer rate is up to 150MB/s.
• NV RAID (Software)
• Supports up to 4 SATA & 2 ATA133 Hard drives
- RAID O or 1, 0+1, JBOD is supported
- RAID function work w/ATA133 + SATA H/D or 2 SATA H/D
Audio
• 7.1 channel audio codec RealTek ALC850.
- Compliance with AC97 v2.3 Spec.
- Meet PC2001 audio performance requirement.
LAN
• Supports dual LAN jacks
- 1 LAN supports 10/100/1000 Fast Ethernet by Marvell 88E1111 PHY
- 1 LAN supports 10/100/1000 Fast Ethernet by Realtek 8110S (1000Mbps)
IEEE1394
• VIA 6306 chipset
- Supports up to 3 x 1394 ports.
- Transfer rate is up to 400Mbps
Afbeeldingslocatie: http://www.viperlair.com/images/reviews/cpu_mobo/msi/amd/s939/k8npe/io.jpg
On-Board Peripherals
On-Board Peripherals include:
- 1 floppy port supports 2 FDD with 360K, 720K, 1.2M, 1.44M and 2.88Mbytes
- 1 serial port
- 1 parallel port supports SPP/EPP/ECP mode
- 1 Audio jack(5-in-1), coaxial/fiber SPDIF out
- 8 USB 2.0 ports (Rear x 4 / Front x 4)
- 2 RJ45 LAN jack
- 3 IEEE 1394 connectors (Rear x 1/ Front x 2)
BIOS
• The mainboard BIOS provides "Plug & Play" BIOS which detects the peripheral devices and
expansion cards of the board automatically.
• The mainboard provides a Desktop Management Interface(DMI) function which records your mainboard specifications.
Dimension
• 30.5cm(L) x 24.5cm(W) ATX Form Factor
Mounting
• 6 mounting holes.
MSI’s Digicell
CoreCell Chip has four new technical features: Speedster, BuzzFree, PowerPro, and LifePro.
The Speedster technology of CoreCell Chip contains the most flexible BIOS options for overclocking, including async mode of FSB and memory frequency, 0.05V increment for memory voltage adjustment and the minimal increment of 0.0125V for Vcore.
BuzzFree technology examines the current system utilization and temperature level before leveraging thermal requirement & fan speed. It dramatically cuts the system noise by 50% by getting rid of the annoying buzz. Moreover, it also improves the quality of audio and video.
PowerPro prolongs the life of the motherboard, CPU, and fan by maintaining them under the optimum condition. It also detects and manages the motherboard utilization to prevent possible factors that may contribute to system crash.
LifePro technology prolongs the life of the motherboard, CPU and fan by maintaining then under the best condition. It can also detect and manage motherboard utilization to prevent possible factors that may contribute to system crash.
CoreCenter™, this all-in-one hardware console is an advanced combination of the popular PC alert and Fuzzy logic applications. It offers powerful functions such as hardware monitor, system alert, and instinctive overclocking UI.
Live Update™ 3 is a single utility software that automatically checks BIOS and driver updates. It includes MSI's Live BIOS™, Live Drive™, Live VGA BIOS™, and Live Utility™. Advanced users would also receive the latest information about MSI products and activities from MSI technical support.
De Doos :Y)
Afbeeldingslocatie: http://pics.computerbase.de/news/8228/2.jpg
[Meer...]
Inhoud:
• MSI Motherboard
• MSI Driver/Utility CD
• Sata(-raid)-Driver Floppy
• Sata-Cable (Optional)
• Sata Power-cable (for 2 Sata-devices)
• D-Bracket 2 (2 usb-ports)
• Round Cable of IDE-devices
• Round Cable of Floppydisk
• User's Guide
• Quick Guide
• Test Report
• Back IO Shield
Afbeeldingslocatie: http://www.chastelet.demon.nl/1/overklokken.PNG
Dit bordje is ook aardig interessant om over te klokken. Anandtech kreeg in hun review het bordje met gemak op het maximale instelbare, namelijk 300 mhz FSB >:). Met de nieuwste bios is 350 450 mhz instelbaar. De nforce 3 ultra hoeft dan ook niet extra gekoeld te worden , want dit gebeurt allemaal met het standaard fannetje :).
Afbeeldingslocatie: http://www.chastelet.demon.nl/1/koelertje.JPG
Ik kreeg hem zelf met een zalman nj47b blokje op 330 HTT.
Zoals te zien is, is het een wat andere plaats dan dat je gewend bent voor een northbridge (er is eigenlijk geen sprake meer van north- en southbridge, er is maar 1 chip). Voor waterkoeling op de northbridge lijkt deze plaats niet echt slim uitgekozen. Maar zoals je kan zien zou waterkoeling niet veel nut hebben, je zou er niet hoger door kunnen klokken. Verder zijn er wel wat wc-blokjes die erop passen. Bij koelercompatibility in de eerste reply staat welke koelers je zoal kan gebruiken.
Dit zijn de instelbare items met betrekking tot overklokken:
FSB: 200-450mhz, in stappen van 1mhz. Let wel dat je minimaal bios versie 1.2 erop moet hebben voor een max fsb van 450 mhz (bios 1.0: tot 300 mhz bios 1.1: tot 350 mhz) . Bios-links vind je onder links van dit topic.
CPU Multiplier: 4 - 20 x, Voor FX-cpu's kan men boven de standaard MP instellen. Vanaf bios 1.2 is het mogelijk dit met halve multipliers in te stellen :) Maar dit is niet altijd aan te raden (zie tips)
AGP: 66-100mhz, in stappen van 1mhz
Vcore: 1.55-1.85V, in stappen van 0,05V , maar met de Speedster technology van de Corecell in stappen van 0.0125V
Vdimm: 2.50-2.85V, in stappen van 0,05V. (vind ik een klein beetje jammer :|, had liever tot 3.3 gezien ;) )
AGP-voltage: 1.50-1.85V, in stappen van 0,05V
Verder zijn er ook nog Hidden Bios Opties:
Vid Hiermee kan je het voltage van de voltageregulator regelen als ik het goed heb begrepen. Dit zou misschien wat impact kunnen hebben op de hoogte en stabiliteit van de vcore.
NV/ATI Speed up Met deze setting kan je jou agp-kaart wat extra mhz-en laten geven, geregeld door het moederboard. Zowel je videogeheugen als gpu wordt iets opgekrikt (10 à 20 mhz). Clock je liever zelf gewoon je kaart over, zet deze functie dan op disabled.
Lees voordat je aan het overklokken gaat nog even de tips door, hier staan belangrijke dingen zoals het gebruik van sata-poorten en overklokken...
• Mods
OCZ DDR-Booster
Na even rondgeneusd te hebben op Xtreme Systems kwam ik een post tegen waar iemand de OCZ DDR-Booster gebruikte op de k8n Neo 2 :) Deze lijkt dus compatible te zijn:
Ok I am now running the ddr booster at 3.2v on my Neo2. It does work fine and has allowed me to hit 300HTT 1:1 so far on my 3500 EBs.
* Tutti-frutti heeft zelf de ddrbooster getest, en het werkte :)
Afbeeldingslocatie: http://www.chastelet.demon.nl/1/tips.PNG
Hier staan bekende problemen met oplossingen, of tips waardoor je meer performance kan krijgen.
Hogere Memory-bandwidth
Voor hogere geheugen scores moet je in het Cell-menu, bij memory settings de "1T/2T Memory Timings" op 1T zetten. De score met een HTT van 200 (ddr400) vliegt dan van zo'n 4800 MB/s naar 5900 MB/s !
Oplossing voor de combinatie: overklokken + Sata-schijven
Het blijkt dat de Sata-poorten 1 en 2 geen goedwerkende PCI-lock hebben. De pci-lock functioneert wel correct op de poorten 3 en 4. Gebruik daarom als je van plan bent te gaan overklokken de sata-poorten 3 en4. Zorg er ook voor dat je minimaal bios 1.2 draait.
Met de satapoorten 1 en 2 zou je niet hoog kunnen komen met de htt. Misschien komt hier nog een biosupdate voor...
Pas op met het gebruik van halve multipliers
Sinds bios 1.2 kunnen er in de cell menu (bios) halve multipliers voor de cpu-speed ingesteld worden. Het is aan te raden om deze niet te gebruiken, omdat je dan performance verliest op je geheugensnelheid. Het werkt namelijk alsvolgt:
Als je cpu-HTT en mem 1:1 lopen, en de multiplier van de cpu is 11x, dan wordt de memspeed vastgelegd door de cpu speed door 11 te delen. Voorbeeld: HTT=250, MP=10. Mem speed = 2500/10 = 250 (ddr500).
Pak je nu 10.5 als multiplier, dan wordt de mem speed als volgt:
cpu-speed = 10.5x250 = 2625
Mem-speed = 2625/11 = 239 mhz.
Dit zit hem in de cpu memcontroler en kan helaas niet veranderd worden, de cpu kan alleen door hele multipliers delen.
Halve multipliers zijn wel aan te raden , als je cpu nog niet aan zn max zit, maar mem wel. Je kan zelf het beste even kijken wat het beste resultaat oplevert.
In mijn geval heb ik ook even getest. Ik ga zelf wél voor een halve mp:
11x232 , ddr464 = 6903 MB/s @ sisoft membench
10.5x243 , ddr464 = 6907 MB/s @ sisoft membench
ik heb meerdere malen getest, maar veel verschil is het natuurlijk niet...
thnx to Pakjebakmeel voor quote van forum
Windows installeren op een Sata-Raid array
Tijdens het laden van de windows setup moet je, zoals gewoonlijk met raid-configuraties, op F6 rammen. Bij het bord is een floppy geleverd met daarop de Raid drivers. Je moet tijdens de setup niet 1, maar 2 drivers installeren, namelijk:
-Raid Class Driver
-Storage Controller
Dit is erg belangrijk, anders ziet windows de schijven appart, en niet als 1 raidarray.
BSOD's ? Aggressive timings op Disabled zetten!
Aggressive Timings blijkt nu ook een erg bekende oorzaak te zijn van de blauwe schermen. Je zal waarschijnlijk, met Aggresive timings aan, veel BSOD's krijgen met "Beginning of dump Physical Memory". Wanneer je Aggressive timings uitzet in het Cel menu, zal je systeem hoogstwaarschijnlijk stabiel zijn :).
Nog steeds Instabiel ?
Nadat er erg wat postings geweest waren met instabiliteitsproblemen lijkt het erop dat de gegevens uit de SPD-chips op de geheugenmodules niet goed worden uitgelezen. Ik weet niet of dit aan het bord of aan de geheugencontroler van de cpu's ligt. Oplossing lijkt gewoon het zelf instellen van memorytimings en geheugen voltage.
Daarnaast is het aan te raden om ALTIJD satapoort 3 en 4 te gebruiken, zoals hierboven beschreven.
Dual Channel, welke slots ?
Als je DUAL CHANNEL wilt laten werken dan moet je de 2 latjes ram in het groen EN paarse slot steken(slot 1 & 2). Dit zijn dus de 2 onderste geheugenbanken. Dit is dus niet, zoals bij intel, in het eerste en derde slot. Als je het in slot 1 & 3 plaatst heb je kans op een instabiel systeem. Dit staat ook volledig uitgelegd in de manual :)
thnx to kennes
Audio-driver installeren, erg belangrijk!
Als je standaard de drivers van nvidia installeerd (nforce drivers) dan worden de audio drivers niet geinstalleerd. En dan kan je de nvmixer ook niet gebruiken. En omdat de nvidia drivers veel beter klinken zijn die drivers toch aan te raden. Om hier gebruik van te kunnen maken moet je de drivers MANUEEL installeren. Rechts klikken in apparaatbeheer op het audiodingie. dan moet je NIET ZOEKEN nemen en dan bladeren en dan de file nvmcp.inf, en vervolgens 1 van de die items die erop komen. (die nvmcp.inf file haal je uit de c:\NVIDIA\4.27\audiodrv-map). Je kan op deze manier gebruik maken van alle nvidia geluidsfuncties, en bijvoorbeeld ook het volume per box instellen :).
thnx to kennes
Systeem hangt al VOOR de post
Misschien heb jij net zoals mindcrash het probleem dat het systeem niets doet. Dit kan natuurlijk aan van alles liggen. Het is natuurlijk zoals altijd goed, om in dat geval zo weinig mogelijk aan je moederboard te hangen, en een bios reset wil ook wel eens helpen. Mindcrash kwam erachter dat zijn muis voor het probleem zorgde:
Ik dacht eerst dat het spontane hangen bij het booten aan mijn videokaart lag, maar na het verwisselen van mijn Intellimouse aan de PS/2 poort voor mijn nieuwe MX1000 aan de USB poort start mijn rig zonder problemen op.
Koop geen Antec 350w
Wat er nu precies met dit type voeding aan de hand is dat het niet goed werkt met de neo 2, misschien de atx stekker (als je die aandrukt doet het systeem het), maar het is in ieder geval niet aan te raden deze voeding te kopen. Er zijn al 4 gevallen bekend onder de gotters hier met problemen.
Afbeeldingslocatie: http://www.chastelet.demon.nl/1/links.PNG
• Fabrikantinfo:
MSI K8N Neo 2 Platinum
• Handleiding
De Handleiding V1.1 (pdf , 7MB)
• Reviews
Anandtech Socket939 motherboard Round Up
PC Perspective Review
Een magere Zdnet review
Hot Hardware S939-motherboard round up
• Waar is de MSI K8N Neo2 het goedkoopste?
Link Naar de pricewatch
• Biossen
Update je bios, en je moederboard wordt instelbaar tot 450mhz })
Msi Biossen
In bios 1.2 zitten de volgende changelogs:
- Support FSB to 450MHz
- Support K8 CPU Rev. D 939-Pin 128-bit
+ Added .5 multipliers !
+ Fixed CPU temps !
+ Pci-lock werkt correct. Helaas nog niet op sata-poort 1 en 2
Bios 1.3
- Update CPU ID.
- Support Sempron CPU 1800+
- Fixed K8-939 RevD CPU cool 'n' quiet can't work properly
Nu blijkt dat 1.3 beta 6 nog een toevoeging heeft op de officiele bios, hij is hieronder te downloaden:
-Fixes HT mess in the official 1.3 bios and adds higher CPU voltages.
Beta:
Hier en hier kan je beta biossen vinden. Je kan ze zelfs ook hier vinden ;)
Nummering van biossen werkt als volgt: 1.23 = 1.2 beta 3 , 1.2= 1.2 official (nieuwer dan 1.23).
Afbeeldingslocatie: http://www.chastelet.demon.nl/1/etc.PNG
Mijn ervaring:
Na hem bij de volgende shops besteld te hebben, heb ik hem eindelijk binnen:
-Euromaxi
-Salland Automatisering
-Rodep IT
-Komplett, de gelukkige verkoper :+
Ik zal jullie eerst een foto impressie geven!
Afbeeldingslocatie: http://www.chastelet.demon.nl/1/thumbneo1.JPG Afbeeldingslocatie: http://www.chastelet.demon.nl/1/thumbneo2.JPG
Afbeeldingslocatie: http://www.chastelet.demon.nl/1/thumbneo3.JPG Afbeeldingslocatie: http://www.chastelet.demon.nl/1/thumbneo4.JPG
Afbeeldingslocatie: http://www.chastelet.demon.nl/1/thumbneo5.JPG Afbeeldingslocatie: http://www.chastelet.demon.nl/1/thumbneo6.JPG
De lay-out
Het eerste wat mij opviel dat deze pcb van een ander materiaal is gemaakt, het lijkt wel een soort hardboard of iets. Ik weet niet wat voor materiaal het is :?
De lay-out van dit bord is erg goed. Zo is de socket bijvoorbeeld 90 graden gedraaid met wat we "gewend" zijn, s939 staat nog aardig in de kinderschoentjes natuurlijk. Maar voor bepaalde koelers heeft dit namelijk wel een voordeel, want de warme lucht wordt daardoor direct naarboven geblazen. Verder blaast de cpu koeler de lucht over de dimm sloten heen, zodat de ramreepjes gekoeld worden.
Op het bord zitten 4x 3-pin fan connectors, waarvan er 1 door de standaard southbridge koeler wordt gebruikt. Onderin, naast de bios chip zit een aansluiting voor een system-fan. Onder de atx-connector zit er een voor de standaard sb-koeler. Links van de socket vinden we de cpu-fan connector, en als laatste plaats voor een 2e systemfan boven in het bord (bij de dimsloten). Er is dus overal wel een aansluiting in de buurt.
Wat alleen een beetje jammer blijft is de plaatsing van de nforce-chip. Deze valt net onder de agp kaart, waardoor het plaatsen van bijvoorbeeld waterkoeling op de NB, of een grote koeler op je vga (als je ook een andere koeler op de nforce wilt) misschien een beetje moeilijk wordt.
Zelf heb ik een Zalman NB47-j die ik er heb opgezet. Dit bleek eigenlijk heel erg mee te vallen. Het enige wat ik nog hoefte te doen, is 3 koelvinnen naar binnen buigen. Dit is zelfs overbodig, omdat het alleen het chassis van een condensator van de 9800pro lichtjes aanraakt:
Afbeeldingslocatie: http://www.chastelet.demon.nl/1/neozalman1.JPG
Afbeeldingslocatie: http://www.chastelet.demon.nl/1/neozalman2.JPG
Wat ook me ook opvalt is dat de connectors: IDE, FDD, ATX bij elkaar geplaatst zijn. Dit heeft bij inbouwen het voordeel dat alles vanuit 1 punt naar de rest van de kast gaat, is weer wat netter :).
Revisie
De revisie die op mijn bord staat is:
Afbeeldingslocatie: http://www.chastelet.demon.nl/1/revisie.JPG
Resultaten
Ik zal hier binnenkort mijn ervaring plaatsen met betrekking tot overklokken.
Ik zal benchmarks plaatsen. Waar ik erg naar benieuwd ben is de memory score. Ik haalde met mijn asus A8V-deluxe namelijk maar 4800 MB/s op 200mhz fsb (cas2.5-3-3-7)
Dit zijn nu mijn systeem specs:
Msi K8N Neo2 Platinum + Wireless
AMD64 3500+ (code)
2x 512 MB DDR400 c2.5-3-3-7 Twinmos pair (maybe vervang ik deze)
2x Maxtor DMP9 SATA 80GB @ Raid0
Sapphire 9800pro 128MB R350 @ 420/365
Creative Audigy 2 Player
Levicom 500w voeding
Waterkoeling: Alphacool NexXxos HP cpublok, Tha_Mafkees gpublok, 900l/u pomp, evo360 rad.
Samsung dvd-rom
Lite-on 832s dvd-rw
Update:
De eerste resultaatjes. Dit is nog totaal on-getuned.
De Nvidia sata-raid controler vind ik erg goede prestaties leveren. Op elk niveau beter dan mijn nforce2-bordje met silicon image controler. Ik haalde daarmee max 105 MB/s. Dit is het resultaat nu:
Afbeeldingslocatie: http://www.chastelet.demon.nl/1/atto.PNG
Dan de geheugen bench >:) . Ik haalde eerst op ddr400-2.5-3-3-7 maar 4850 MB/s, maar ik had de 1t/2t Memory timing toen op 2T staan. Dit was waarschijnlijk ook het probleem bij mij asus a8v, dat ik niet hoog scoorde. Dit is het resultaat met een HTT van 215: ddr430 cas 2.5-3-3-7 (1T Timings):
Afbeeldingslocatie: http://www.chastelet.demon.nl/1/mem215fsb.PNG
Htt van 230 ddr460 2.5-3-3-7 (1t timings), helaas wel memtest errors:
Afbeeldingslocatie: http://www.chastelet.demon.nl/1/mem230htt.PNG
En ook een htt van 280 is no problemo voor dit bord:
Afbeeldingslocatie: http://www.chastelet.demon.nl/1/htt.PNG
3dmark heb ik ook gedraaid. Dit is met een 9800pro op 405mhz gpu en 365 mem. Cpuspeed is uitgelezen met cnq aan, waardoor de cpu op dat moment 1050mhz liep. Tijdens de test was dit 11x210= 2310 mhz.
http://service.futuremark.com/compare?2k3=2969671
Toevoegingen / Vragen ?
Heb je nog vragen of toevoegingen waarvan je denkt dat dit de startpost moet komen ?
Mail me via Afbeeldingslocatie: http://www.chastelet.demon.nl/1/neo2/email.GIF
[ Voor 17% gewijzigd door Tutti-frutti op 25-10-2004 12:09 ]
4015Wp west (Dordrecht)
  • Tutti-frutti
Tutti-frutti
Graag gedaan!
(In)compatible Koelers
Afbeeldingslocatie: http://www.tweakers.net/g/table/spacer.gif
Als toevoeging op de startpost zal ik hier een lijst plaatsen met compatible koelers. Dit wegens de afwijkende lay-out van het bord die naast zijn voordelen (betere flow), helaas ook zijn nadelen kent dat er een aantal koelers niet passen. Hier plaats ik de koelers waar twijfels over kunnen bestaan.
Mail me dus als je weet dat jouw koeler/vgakoeler/cpukoeler-combinatie wel of niet past:
CPU
Zalman 7000 CNPS 7000 (A/B) (Cu/Al/Al-Cu)
Afbeeldingslocatie: http://www.chastelet.demon.nl/1/neo2/zalman70001.JPG Afbeeldingslocatie: http://www.chastelet.demon.nl/1/neo2/zalman70002.JPG
Deze koeler past mits je geen passieve heatpipe koeling gebruikt. Mocht je ook gebruik maken van wat hogere geheugenmodules zoals Corsair XXL Pro geheugen, dan zou je deze in slot 3 en 4 moeten doen.
Coolermaster Hyper 6
Afbeeldingslocatie: http://www.viperlair.com/images/reviews/cpu_mobo/msi/amd/s939/k8npe/tight.jpg
Deze koeler past wel, alleen kan het zijn dat het niet echt super werkt voor de airflow in bepaalde kasten
Chipset
Zalman N47J
Afbeeldingslocatie: http://www.chastelet.demon.nl/1/neo2/zalman47.JPG
De N47J past op de nforce3-chip, als je geen heatpipegeval of grote vgakoeler (Arctic silencer) gebruikt. Hij past in ieder geval met de volgende 3dkaarten:
-9800pro (evt. 2 pinnetjes iets naar binnen buigen, maar niet nodig)
-X800 (pro/xt) kaarten.
Hij past NIET met de volgende kaarten:
-Nvidia 6800 series.
Graph-O-Matic Rev2.0 VGA & Chipset
Afbeeldingslocatie: http://www.innovatek.de/contentServ/3.0/www.innovatek.de/data/media/191/500618.jpg
Deze past zonder problemen.
VGA-koelers
Heatpipe Koelers
Afbeeldingslocatie: http://www.chastelet.demon.nl/1/neo2/zalman80hp.JPG
Door het gebruik van heatpipekoelers vervallen een aantal mogelijkheden voor het plaatsen van andere koelers. Bepaalde cpu-koelers zullen hierdoor in de knoop komen (zoals de 7000-serie van zalman). Andere chipset-koeling wordt onmogelijk, tenzij je een betere en net zo'n lage koeler als de standaard msi koeler weet te vinden.
Arctic Silencer
Afbeeldingslocatie: http://www.colorstone.com.tw/proimages/f1/arcticcooling/vga.jpg
Door het plaatsen van deze koeler wordt het moeilijker om andere chipsetkoelers te plaatsen.
[ Voor 34% gewijzigd door Tutti-frutti op 24-10-2004 11:29 ]
  • BalusC
BalusC
Carpe diem
Titelfix "deel 1" » "deel 2" :+
  • Tutti-frutti
Tutti-frutti
Graag gedaan!
BalusC schreef op 30 september 2004 @ 10:17:
dankje.. je bent sneller dan ik .. drukte bijna op post in sem :P
  • BalusC
BalusC
Carpe diem
Och, voor dat soort dingen volstaat een TR :)
Is het raadzaam indien men een overstap wil maken van een a7v266 mobo in combinatie van een xp2400+ naar dit moederbord? MSI k8n NEO2 PLat. met nforce3 ultra. Of wachten tot nforce4? met eerste versie de mogelijkheid dat Sata-2 en pci-express.
Mij dunkt dat ik indien ik dat wil tzt gewoon een pci kaart erin kan doen met Sata-2 erop. Of redeneer ik dan verkeerd?
  • MaxPayne
  • Laatst online: 29-09 22:31
MaxPayne
Supertweaker
Dat kan je natuurlijk doen, maar dan kan je altijd wel blijven wachten...er komt altijd wel weer wat nieuws en sneller uit.
Bijkomend feit is ook dat de "nForce 4" oftewel CRUSH CK8-04 (NVIDIA heeft de chipset deze naam officieel niet gegeven en het is nog maar de vraag of het daadwerkelijk deze naam krijgt!) in de begin periode ook last zal hebben van kinderziektes die inmiddels bij de nForc3 250 verholpen zijn/worden..
Draai zelf nu stabiel als een huis..
It's a plane, its a bird..no it's super tweaker
  • Patrlck
  • Laatst online: 07:20
@ Tutti-frutti
Wordt je Noort/South bridge niet warm met die zalman zonder ventilator erop??
Dit wil ik ff weten voordat ik um aanschaf anders moet ik denken aan een waterblokje erbij want dat fannetje maakt natuurlijk een verschrikkelijk lawaai :X ..
  • Tutti-frutti
Tutti-frutti
Graag gedaan!
SchiedamLauw schreef op 30 september 2004 @ 12:39:
@ Tutti-frutti
Een hele kleine flow is al genoeg.. zonder fan wordt hij bij mij warm, maar niet heet.
MaxPayne schreef op 30 september 2004 @ 12:22:
Het is enkel verstandig om te wachten als je van plan bent om een pci-e videokaart te gebruiken (en deze er gelijk of vrij snel bij te kopen). De verwachting is namelijk dat er verder weinig snelheidsverschil tussen de nf3 en 4 zal zijn.
En als je de 600 euro niet hebt of liever in je zak houdt omdat je een prima videokaart hebt die zeker nog een jaar vooruit kan dan kun je beter een goedkoper nf3 boards kopen.
  • Pakjebakmeel
  • Laatst online: 17-11 03:28
Zit er aan te denken om dit mobo + 3500+ aan te schaffen pc zal volgende bevatten
mobo
64 3500+
1024 corsair twinx led
2x 36gb raptor
dvd speler
dvd writer
zal worden gewaterkoeld
360watt chieftecie voldoende ??
of meer?
Ik heb ook een chieftec 360 en draai:
MSI K8n Neo 2 :+
Radeon Ax800pro
A64 3500+
1024 MB Pc3200 Mem
Wifi kaart
SB Live!
2x Maxtor 120Gb
1x Maxtor 200Gb
2x Cdrom/dvd unit
12 volt is tussen de 11.99 en 12.00 volgens de multimeter en niet de bios...
lijkt me wel ok :)
Misschien als je er een 6800U aanhangt dat ie het moeilijk gaat krijgen ... tis volgens mij wel net op het randje. Overklokken kan ook nog wel als je in deel 1 kijkt gaat mijn cpu 2600Mhz en haalt 7000MB/s op het mem.
Niet om wannabee mod te zijn maar dit kan je het beste posten in het "welke voeding moet ik nemen" topic...
ter info.
Als je een beetje flow in je kast hebt kun je hem dus gewoon passief laten draaien? Ik heb een 120mm NeXus in mijn window namelijk :) Dat zou dan goed moeten gaan toch?
[ Voor 40% gewijzigd door Pakjebakmeel op 30-09-2004 14:53 ]
  • Tutti-frutti
Tutti-frutti
Graag gedaan!
Pakjebakmeel schreef op 30 september 2004 @ 14:49:
Als de fan op goede hoogte zie, en de vlow niet tegengehouden wordt door je videokaart, dan is het goed. Heb je misschien een foto ?
Flow in de kast heb ik ook , maar dat is niet voldoende om de zalman lauw te laten.
MB binnen, als geheugen morgen binnenkomt kan ik ook beginnen. :)
Twee vragen:
- in de handleiding staat blz E2-18 verwijzing naar "nVidia Raid introduction for detailed software installation procedure". Heb gezocht in doos maar waar vind ik dat????
Ik wil iets wat wellicht vreemd lijkt voor de snelheidsliefhebbers, maar ik wil 3 250GB Sata disks los naast elkaar hagen.... geen RAID dus. Doel is gescheiden ... apart te booten .. systemen te hebben voor video bewerking, serieus werk en downloaden/spelen.
Moet ik bij installeren XP nu wel of niet via F6 de RAID drivers installeren ??? als je SATA disks los wil houden.
- ik zie in handleiding niet welke lan aansluiting nu de Marvell of de Realtek is.
Wat is nu welke???
BTW dank voor deze interessante thread.... heeft mij overgehaald de K8Nneo2 te kopen.
  • Tutti-frutti
Tutti-frutti
Graag gedaan!
Verwijderd schreef op 30 september 2004 @ 15:31:
Twee vragen:
Wat is nu welke???
De raid introduction staat achterin de handleiding ;) Geen ander boekje dus ofzo :)
Ik ben toch eens gaan kijken, maar ik zie het idd ook niet :? Ik kan het me zo goed herinneren ...
Raid drivers kan je gewoon installeren, maakt niet uit naar mij weten.
Onderste is realtek, marvell is bovenste.
[ Voor 8% gewijzigd door Tutti-frutti op 30-09-2004 15:51 ]
  • Pakjebakmeel
Twee vragen:
Wat is nu welke???
Dan zou ik 1 raid 0 array maken van 2 disks met 3 partities voor de OS'Sen en de derde stand alone als veilige data opslag...
@tutti:
Afbeeldingslocatie: http://picserver.org/view_image.php/QW3F76623586
dus, zoiets... ( kan meetfouten bevatten. ) De 120 mm fan voel je duidelijk op 50 cm afstand!Het is een intake
  • Tutti-frutti
Tutti-frutti
Graag gedaan!
Pakjebakmeel schreef op 30 september 2004 @ 15:56:
@tutti:
Prima :) Jij mag door voor de nb47j ;)
  • bpee
  • Laatst online: 15-11 17:00
Hehe na een maand geleden besteld te hebben heb ik gister mijn comp samen gesteld.
Met dit moederbord.
Nu wilde ik dus mijn 2 maxline III 300GB schijven in sataraid zetten.
Dus ik ram op f6 maar de instalatie gaat dus gewoon door zonder iets te merken. Na een reset nog eens geprobeerd. maar helaas gaat de instalatie gewoon door.
toch maar door gegaan met de instalatie in de hoop dat het toch in raid gezet werd. Het resultaat is nu dus 2 apparte schijven c: en een e: 8)7
Maar wil toch raid. wat nu te doen?
- Format c:
en kijken of die nu wel de f6 knop pakt of weet iemand iets beters?
bij de weg,
Heb mijn schijven op de sata-aansluitingen in het midden van het bord
[ Voor 7% gewijzigd door bpee op 30-09-2004 16:14 ]
  • Pakjebakmeel
Tutti-frutti schreef op 30 september 2004 @ 16:06:
nwah... das mooi maar ik moet wel flink gaan verbuigen ivm de cooler van de Ax800 :P ;)
  • Hoyden
  • Registratie: December 1999
bpee schreef op 30 september 2004 @ 16:12:
Met dit moederbord.
- Format c:
bij de weg,
Wat voor toetsenbord heb je ?
1tje met of zonder FLock toets ? :)
En btw, voordat je Windows installed moet je toch eerst een Raid-Array maken, en daarna pas F6 tijdens het installen..
[ Voor 7% gewijzigd door Hoyden op 30-09-2004 16:21 ]
  • blakez
  • Laatst online: 19-11 19:11
Ik draai nu ook een weekje met dit moederbord en ben d'r uiterst tevreden over! Ik heb enkel nog wat problemen/vraagjes met het aansluiten van de HD's en de DVD speler en writer.. Op het moment zit het het volgende:
WD raptor 37 gig HD zit aangesloten op de sata 1 aansluiting. Deze wordt echter in de bios gezien als third ide master.. :?
Ik heb een m'n dvd brander als master en m'n dvd speler als slave op de ide 1 aansluiting.. Deze wordt ook in de bios aangegeven als first ide master en first ide slave..
Verder nog een floppy disk geinstalleerd en dit werkt ook gewoon..
Nu wil ik zo windows XP opnieuw er op zetten en dit voor defenitief zegmaar.. Deze week heb ik zomaar wat lopen proberen..
Nu heb ik ook nog twee Hitachi deskstar 160GB liggen en deze wil ik in raid 0 combinatie gebruiken.. Is het verstandig om deze nu eerst te installeren voordat ik winxp er opnieuw opzet? En hoe komt het dat m'n bios m'n raptor sata als ide aangeeft? :?
  • Hoyden
Mijn Raptor74, op sata1, staat ook bij third IDE master :)
Ik heb me er niet zo in verdiept, maar t zal wel in orde zijn lijkt me.
Of zijn er nog dingen die je apart moet instellen, om em wat sneller te maken ? :)
  • bpee
Ik heb het met mijn dinovo geprobeerd maar op de een of andere manier gaat de Flock automatisch uit, dus daarna nog eens met een normaal ps/2 bordje geprobeerd. Maar toen ging het nog steeds niet.
Maar wat je dus zeggen wil is dat ik voor ik de windows cd erin knal. Die raid moet opzetten?
ik begrijp dat niet helemaal aangezien ik alleen een verwijzing naar andere informatie in de handleiding kan vinden. Kan iemand mij vertellen waar de informatie betreffende Nforce3 raid staat?
[ Voor 20% gewijzigd door bpee op 30-09-2004 17:28 ]
  • Hoyden
Ik heb sinds korte tijd ook iets vreemds :)
Ik heb net Windows XP geinstalleerd, op de MSI K8n Neo2 icm met een WD Raptor 74GB.
Maar nu zie ik rechtsonderin beeld het icoontje/pijltje "Hardware veilig verwijderen" en daar staat de WD Harddisk tussen (als enige)
Die is niet verwisselbaar oid, dus veilige verwijderd hoeft ie niet te worden.
Iemand enig idee hoe ik die daar weg krijg ?
  • Tutti-frutti
Tutti-frutti
Graag gedaan!
SandeR schreef op 30 september 2004 @ 17:58:
Dat hoort, en heeft iedereen met discs op zijn sata :) Ik heb het niet weggekregen, en ook niet mee bezig geweest. Niets om je zorgen over te maken. Sata is trouwens plug&play, dus vandaar dat er "veilig verwijderen" bij staat.
  • Hoyden
Tutti-frutti schreef op 30 september 2004 @ 18:38:
Oh ok :)
Dan verbergen we dat Icoon maar gewoon :+
  • Voyage
  • Laatst online: 09:42
The Source schreef op 29 september 2004 @ 22:44:
Ik heb een probleem, wie weet een oplossing...
Probleem: Computer start niet altijd op, komt wel door bios, maar blijft soms in windows boot scherm hangen. Of het duurt enorm lang voordat login scherm verschijnt. Helaas werkt het soms goed, maar soms kan het systeem ook 4 keer achter elkaar blijven hangen. Safe mode of last know config helpt ook niet.
Sinds: Upgrade naar nForce_4.27 drivers > nForce_5.10 drivers (alles behalve nvidia sound drivers installed)
Config: K8N NEO2 plat, 3500+, 2 s-ata HD's in raid 0/1 config
Ik heb het vermoeden dat het ligt aan de nVidia nforce3 IDE/S-ATA drivers... maar hoet kan ik dit het beste oplossen? Oudere versie gebruiken lukt helaas ook niet? Moet ik dan maar de standaard Microsoft drivers gebruiken???
Hier de oplossing: http://www.nforcershq.com/forum/viewtopic.php?t=52697 . Kortom je moet de IDE driver van nvidia verwijderen of vervangen door een ander. Voor verder uitleg check de link hierboven.
bpee
blijkbaar zoek jij ook naar de RAID informatie die blijkbaar inderdaad niet in de handleiding staat (dank je voor bevestiging tutti-frutti).
Ik heb na wat zoeken nog wat links gevonden:
zie PC Perspective / Amdmb Forums > AMD Motherboards > MSI Motherboards
NForce 3 SATA Raid Install Guide
link: http://forums.pcper.com/showthread.php?t=340514
of via link http://forums.pcper.com/showthread.php?t=208146
dan zie een grote lijst met relevant leesvoer.
Mn het verhaal K8N Neo Platinum Bios Settings Guide erg interessant.
Volgens andere info (auteur Jocko) die ik las zou je eerst de IDE harddisk moeten loskoppelen als je XP op een SATA schijf wil installeren. Dit omdat XP altijd eerst naar een c:> IDE schijf zoekt.
Zie http://forum.msi.com.tw/thread.php?threadid=62059 in de afdeling http://forum.msi.com.tw/board.php?boardid=28
  • bpee
@ peter_m
Zal eens kijken morgenvroeg op het werk, wat er allemaal te vinden is in die links >:)
iig hartstikke bedankt voor de hulp, :) maar ik begrijp nog steeds niet waarom die f6 bij mij niet werkt. Missschien heeft hier iemand anders ook problemen mee?
[ Voor 3% gewijzigd door bpee op 01-10-2004 09:52 . Reden: typooooos ]
  • KifArU
Op Anandtech staat een test van geheugen voor de Athlon 64 en hun testmachine is gebaseerd op de K8 Neo 2 platinum:
http://anandtech.com/memory/showdoc.aspx?i=2226&p=1
Een klein stukje uit de conclusie:
It is a bit early in Athlon 64 testing to select an Editor's Choice, but the OCZ 3200 Platinum Rev. 2 and Crucial Ballistix are former Gold Editor's choices. These two memories were also the standouts in a group of standouts in these tests. The Hynix-based OCZ 3700 Gold Rev. 3 takes a different approach to memory performance, but it is still an excellent choice, if it can be bought for a lower price than the Samsung TCCD and Micron-chip memories.
KifArU schreef op 01 oktober 2004 @ 10:15:
Wel jammer dat er geen corsair geheugen getest wordt.
Zo is het weer moeilijk vergelijken
  • sn0x0r
  • Laatst online: 18-11 09:49
Dat is idd jammer, aangezien ik mijn keuze op dit moment aan het bijschaven ben. Wilde eerst voor Corsair XLPRO gaan, maar ik twijfel op dit moment.
corsair wordt heel vaak gebruikt voor referentie testen van snelle processoren en moederborden dus het is zeker goed en stabiel spul.
En zo links en rechts zie ik ook goede oc resultaten.
Zelf koop ik niks anders meer.
  • sn0x0r
Dat ze quality shit hebben weet ik, maar die GeIL Ultra X (De Dual Channel kit van 2x 512) presteert ook best wel lekker. En die van OCZ zijn ook weer best goed :)
Oke. i made up my mind. Ik ga voor de OCZ EL 3200 Platinum Rev2. Toch wil ik nog altijd wel iemand met XL-PRO geheugen van Corsair op deze plank zien benchen. (En ook met oc's e.d.)
[ Voor 41% gewijzigd door sn0x0r op 01-10-2004 13:15 ]
Ik heb denk ik mijn plank gesloopt :/
Gisteren even 1.850v op de cpu geknald en 3.2 op de dimms. Saved bios en reboot... uhuh, niet dus. Pc ging uit en gaat niet meer aan.
Clear CMos gedaan, stroom eraf, batterij eruit, geen resultaat.
Andere voeding gekocht om te testen of het daaraan ligt, nee.
Cpu in ander mobo getest (Abit AV8), werkt.
De pc gaat een halve seconde aan, fans spinnen op en dan gaat ie weer uit...
Iemand een idee of kan ik hem rma gaan sturen?
Verwijderd schreef op 01 oktober 2004 @ 11:53:
kwestie van voldoende frankeren! :)
  • blakez
Zojuist Windows XP home geïnstalleerd en als eerste wou ik de stuurprogramma's installeren die op de cd bij het moederbord zijn geleverd.. Het ging dus om de volgende:
NVIDIA nforce3 system driver (Nvidia GART stuurprogramma, Nvidia SMbus stuurprogramma, Nvidia Ethernet stuurprogramma en Nvidia IDE stuurprogramma)
Maar toen de computer die aan het installeren was kreeg ik ineens een BSOD en stopte m'n gehele systeem, met als resultaat dat ik na veel prutsen en doen nog maar eens Win XP Home erop gezet heb.. Nu heb ik enkel de Ethernet drivers geinstalleerd van die vier.. Waar dienen die andere drie nu precies voor en is het nodig om deze allemaal te installeren? Ik heb tijdens de installatie van XP Home ook al de drivers van de raid diskette geinstalleerd..
  • Hoyden
Zijn er ook gebruikers hier die alle 4 de DDR sloten vol hebben, met 512MB DIMM's ?
Ik ben van plan om er dus 2GB geheugen in te zetten, maar heeft dat wel nut ?
Spellen zullen er wel niet veel sneller van worden, maar toch ook niet minder neem ik aan ?
  • Tutti-frutti
Tutti-frutti
Graag gedaan!
blakez schreef op 01 oktober 2004 @ 16:05:
Het beste kan je gewoon de nvidia nforce drivers installeren van het net, de drivers die in dit pakket zitten zorgen er voor dat alle apparaten goed met elkaar kunnen communiceren. Het zou jammer zijn als je deze niet installeerd, je levert dan redelijk wat performance in ;)
http://www.nvidia.com/object/nforce_udp_winxp_5.10
  • blakez
Tutti-frutti schreef op 01 oktober 2004 @ 16:13:
Ok, alles gedownload.. Heel het boeltje installeren én weer een vastloper bij het installeren van de ide drivers.. Gelukkig kon ik m'n systeem rebooten en kwam hij weer gewoon terug in XP.. Dan maar alles geinstalleerd, behalve die ide drivers.. En volgens mij werkt alles nu toch wel prima hoor! :)
  • Tutti-frutti
Tutti-frutti
Graag gedaan!
[ Voor 100% gewijzigd door Tutti-frutti op 01-10-2004 19:41 ]
  • sn0x0r
FF vraagje... dit is mijn situatie. Ik heb een zalman sandwich (De C versie), maar die blokken ervan lopen niet helemaal naar achteren, ze zitten best wel een eind van het mobo vandaan. Kan ik doorgaan voor de Zalman Passive Bridge cooler? Hier een schets van de situatie.
De groene cirkel is een 80mm fan die naar binnen blaast, en die zwarte cirkel is de fan van zalman die op de heatpipe vga cooler zit. Voldoende flow lijkt me?
Afbeeldingslocatie: http://droppert.pcextreme.nl/plusview1000amg.png
Klik hier voor bmp versie.
  • Tutti-frutti
Tutti-frutti
Graag gedaan!
sn0x0r schreef op 01 oktober 2004 @ 21:50:
Kan je opmeten hoeveel cm je vrij hebt vanaf je mobo tot de heatsink van je kaart ? Dit moet namelijk 5 cm zijn (47mm, maar 3 mm voor de chipset :) )
Ben bang dat dat niet lukt ;)
  • sn0x0r
5 CM wordt idd veel, maar ik zal eens meten. Het is natuurlijk ook nog de vraag in hoeverre de heatsinks van de vga plank over de heatsink van de chipset heen hangt.
  • Blade_357
  • Laatst online: 06-09 10:36
Nou, heb gisteren ook mijn K8N Neo2 Platinum 54G geinstalleerd in de PC, maar helaas, niks anders als problemen.
Het gaat direct al mis met de installatie van Win XP. Steeds meldingen dat hij de bestanden niet kan kopieren in de eerste baluwe schermen van setup.
Als dat uiteindelijk wel goed gaat: blauw scherm met foutmelding IRQL-LESS-OR-NOT-EQUAL.........
Als ik XP er na veel gemartel wel op heb constant reboots of vastlopers tijdens opstarten.
NA heel veel dingen te hebben geprobeerd heb ik uiteindelijk mijn A8V maar weer gepakt en dat gaat gewoon wel goed.
Mijn idee is dus: moederbord niet goed. Aangezien de hardware wel goed werkt met mijn A8V.
Of is er nog iemand met andere ideeën?
Heb XP trouwens geporbeerd te installeren op een RAid 0 array van twee sata schijven en later op 1 enkele sata schijf. Zowel op poorten 1 en 2 / 3 en 4 zelfde problemen.
Ook de nieuwste Bios staat erop.
Ben er eigenlijk een beetje flauw van :(
  • Tutti-frutti
Tutti-frutti
Graag gedaan!
Blade_357 schreef op 02 oktober 2004 @ 00:36:
Even wat vraagjes ;)
Heb je aggressive timings uit gezet, het je de caslatencies handmatig ingesteld ?Heb je memtest errors ? Hoe zijn je voltages ?
  • Blade_357
Aggressive timings staan standaard op disabled.
Voltages heb ik niks aan veranderd.
Verder zijn de voltages in mijn ogen goed: liggen allemaal heel dicht bij de 12, 5 en 3 volt.
Als voeding heb ik een Antec 480W Truepower. Dus die moet het allemaal makkelijk aankunnen lijkt me.
En zoals ik al zei: met de A8V heb ik dit soort problemen niet.
Met memtest+ 1.26 heb ik op de A8V in 7 uur niet 1 fout gehad.
Op de K8N heb ik hem maar even laten draaien en toen gaf hij ook geen fout aan.
Timings van het geheugen heb ik op auto laten staan. Later wel enige opties handmatig ingesteld, maar dit had geen invloed.
  • tormentor1985
  • Laatst online: 15-11 23:50
beetje veel heh 1,85 op de cpu |:( wat draaide je 4 ghz :S
  • Tutti-frutti
Tutti-frutti
Graag gedaan!
tormentor1985 schreef op 02 oktober 2004 @ 08:49:
Dat moet voor even niets uitmaken hoor. En dat zou niet je mobo slopen, eerder je cpu, als je dat 24/7 wilt draaien met air ;)
Toch is het erg naar dat hij meteen uitlaat. Ben bang dat je hem rma moet doen Takemenow...
  • Tutti-frutti
Tutti-frutti
Graag gedaan!
Blade_357 schreef op 02 oktober 2004 @ 07:39:
Eigk moet je even exact je voedingswaardes weten. Het maakt geen reet uit of je nu een goede voeding hebt, want daaar kan het nog steeds aan liggen. Ook goede voedingen kunnen brak zijn ;)
  • Voyage
Ik zie dat het alleen maar over overclocken gaat. Hoe ziet het nou met het geluid? Is het te evenaren met de soundstorm van de nforce 2 mobos's? Hoe vinden de mensen die van een nforce2 mobo zijn overgestapt het geluid klinken?
  • Tutti-frutti
Tutti-frutti
Graag gedaan!
deLeRixX schreef op 02 oktober 2004 @ 12:20:
Ik zie eigelijk alleen positieve reacties mbt het geluid... hier een quote uit vorig topic:
geluid:
heb hem gister via coax aangesloten op mijn versterker (digitaal) en het geluid is echt super! heb dan wel geen ondersteuning van 7.1 in windows, maar dvd en 2.0 klinkt echt super. komt heel dicht in de buurt van mijn pioneer dvd speler....
  • Blade_357
Ik zal straks de waardes eens even bekijken met de A8V. Zal denk ik niet zo veel uitmaken aangezien de hardware gelijk is op mobo na.
Post ze straks wel even.
Tutti-frutti schreef op 02 oktober 2004 @ 12:38:
het geluid is goed, alleen jammer dat battlefield het niet goed ondersteund de helft van de geluiden vallen weg, daarom gebruik ik mijn audigy 2
  • makje
  • Laatst online: 19-11 20:56
makje
Professioneel prutser
Weet iemand hier meer over? Ik heb net dit moederbord besteld om flink over te klokken en heb alle 4 sata poorten toch eigenlijks wel nodig.
Zijn er mensen die hier al tegenaan gelopen zijn, en zo ja, wanneer ongeveer, bij welke FSB?
9800x3d
Tutti-frutti schreef op 02 oktober 2004 @ 10:57:
Helemaal gelijk in.Mijn Enermax 470Watt noisetaker heeft het nog géén 2mnd volgehouden |:( En enermax staat wel bekend om goede voedingen te zijn.
En nou dat ik die voeding niet heb kan ik steeds niets uitproberen met mijn MSI mobo.Dat is balen :X
Videokaart heb ik terug gekregen(toch garantie afhandeling)maar nou druip mijn voeding weg O-) B)
Dus ik kan alweer niets.Dus van deze kant uit nog geen oordeel hoe dit moederbord is.Kan alleen maar in dit topic blijven lezen.Maar nog niks zelf doen
  • Blade_357
Mijn voltages in de bios zijn als volgt (gemeten met de A8V):
3,3 V : 3,264
5V : 4,999
12V : 12.032
Vcore: wisselt ivm Cool'N'Quiet, maar is meestal: 1,504
Alle hardware die ik aan de K8N Neo2 had hangen zit ook op de A8V,. Heb zelfs met de K8N al wat hardware eraf gehaald om zo te kijken of het een voedingsprobleem zou zijn. Had helaas geen effect.
  • Tutti-frutti
Tutti-frutti
Graag gedaan!
makje schreef op 02 oktober 2004 @ 14:06:
Daar heeft IEDEREEN last van... kheb het daarom ook in de topic start gezet. Heb er onderzoek naar gedaan etc. Met 4 sata-devices kan je niet verder overklokken dan rond de 220 htt... helaas
[ Voor 3% gewijzigd door Tutti-frutti op 02-10-2004 14:57 ]
  • Tutti-frutti
Tutti-frutti
Graag gedaan!
Blade_357 schreef op 02 oktober 2004 @ 14:30:
3,3 V : 3,264
5V : 4,999
12V : 12.032
Om het echt helemaal uit te sluiten dan het je voeding is, zou je de waardes van de voeding op je neo 2 moeten hebben. Heb je wel 2 gelijke ramreepjes, in de 2 onderste slots ?
  • Blade_357
Heb 2x 512MB Kingston HyperX geplaatst in slot 3 en 4 (bovenste twee) omdat het anders erg krap werd met mijn CNPS700B-Cu koeler.
Moet ook gewoon kunnen volgens de handleiding.
Zoals je kan zien past de Zalman N47J volgens mij wel probleemloos op de nforce 3 chipset als er een X800 in de AGP slot zit zonder de kaart veel te hinderen mischien een pinnetje buigen maar het is mogelijk volgens mij.
Maar bij de 6800 is past dit dus echt een ander verhaal.
Hoe rezise je die plaatjes eigenlijk :/ want ik verneuk heel de layout :(
Afbeeldingslocatie: http://www.firingsquad.com/hardware/nforce_3_ultra_shootout/images/22.jpg
Afbeeldingslocatie: http://www.firingsquad.com/hardware/nforce_3_ultra_shootout/images/19.jpg
[ Voor 62% gewijzigd door Abbadon op 03-10-2004 12:04 ]
  • Abbadon
In de FAQ staat precies hoe je plaatjes kunt resizen. Ik heb 't alvast even voor je gedaan :)
Dank :) Abbadon
  • jippen
  • Laatst online: 22-06 14:47
heb juist mijn asus x800xt geinstalleerd
En heb de 2 eerste koel vinnen moeten afknippen van de zalman northbridge cooler. En de onderste een beetje moeten buigen.
Daarna past het gelijk niets :)
  • Goofy
  • Laatst online: 20-10 13:19
Verwijderd schreef op 03 oktober 2004 @ 11:56:
En die tweede is dus een 6800GT? Spijtig, dan zal ik het prolly moet de standaard MSI koeler moeten doen |:(.
  • bpee
afgelopen zaterdag de heledag gezeten om mijn 2 Maxline III schijven in raid te zetten. Ik krijg het wel voormekaar om met de bijgeleverde diskette aante geven wat er extra geinstaleerd moet worden, dus nvidia RAID en die storage controller. ook heb ik in het bios aangegeven dat ik in Raid wil draaien. Echter wil de instalatie niet verder komen. De instalatie blijft dan hangen. Is het mogelijk dat dat komt dat het sata II schijven zijn of doe ik iets verkeerd. heb de sata schijven zowel op poort1/2 als oppoort 3/4 gehad maar mocht niets baten
Is er misschien iemand met dezelfde combinatie die het nu wel heeft draaien?
Over het algemeen worden er in dit soort topics (zeker bij de deel2) alleen meer problemen opgelost, en daar ga ik helemaal tegenin:
PRACHTIG bord. Na lang sparen kunnen kopen, en ik moet zeggen: ZEKER de moeite waard.
Nu nog mooi geheugen erbij, en ik kan er tegenaan, ik draai nu 1x 512MB SAMSUNG DDR 333(eerst 2x), omdat ik één latje in m'n oude config heb gedaan, die nu dienst doet in PC ouders (Asus a7n8x deluxe 2.0 met 1700+ @ 2600+). En ik moet zeggen: alhoewel ik eerst 4800MB/sec geheugenbandbreedte had (dual channel 333 Cas2.5-3-3-7, T1), vind ik dat hij nog steeds netjes draait in single channel (2400MB/sec). Maar je merkt het wel. Niet alleen ben ik gehalveert qua mem, wat natuurlijk een impact is, ook de bandbreedte merk je, het is allemaal nét een tikkie langzamer voor het gevoel.
Maar goed, komende week 2x DDR400 van een leuke kwaliteit, dan spreken we weer.
En ik moet zeggen, complimenten AMD, met die geheugencontroller (iets waar AMD niet zóó goed in was, Irongate?). Dat hij al die verschillende modi tegelijk jat (single channel, dual channel, DDR333, DDR266, DDR400), en dan onafhankelijk van de HT-bus, én ook nog eens op klok blijven EN stabiel daar valt iets voor te zeggen. Petje af!
  • Pakjebakmeel
Hmm, vreemd. Ik heb een Ax800 en mijn cooler is langer dan die op je plaatje. Hij komt bijna tegen die 2 condensatoren aan :? en zit over die achterste memblokjes heen. Volgens mij zijn er ook verschillende grootte coolers.
  • tormentor1985
Zojuist stuit ik op een programmaatje waarmee je de C&Q instellingen kunt wijzigen.
De meeste mensen kwamen erachter dat je op hoge HTT-speeds C&Q niet kon gebruiken. Dit kwam mede door een hogere cpu speed i.c.m. met 1.0 Vcore.
Hier is nu verandering in gekomen. Je kan de minimum Vcore en de maximum Vcore opnieuw instellen.
Ik ga het morgenochtend even testen, tenzij tutti eerder met resultaten komt :P
<edit>
Tsja de link :P
http://cpu.rightmark.org/
</edit>
[ Voor 9% gewijzigd door tormentor1985 op 04-10-2004 00:20 ]
Vraagje mannen,
Ik ga dit bord met een paar dagen kopen met waarschijnlijk de 3500. Nu twijfel ik nog over mijn videokaart. Ik baal van de drivers van Ati maar vind de brute kracht wel erg fijn. Nvidia heb ik ook een boel goede ervaringen mee en ik las een tijdje terug dat de nforce chipset de nvidia kaarten nog een leuke extra boost gaf. Ik heb nu een tijdje zitten googlen en gezocht via reviewsites maar kan hier niks meer over vinden. Zijn er misschien mensen hier met een 6800 Ultra & mensen met een X800XT met soortgelijk geheugen die een benchje hebben gedraaid > Of zijn er misschien mensen die een review weten te vinden van dit bord met zowel Ati als Nvidia kaarten ?
Alvast bedankt.
  • Pakjebakmeel
Pakjebakmeel schreef op 03 oktober 2004 @ 21:54:
ik heb ehm erin zitten en het scheelt VEEL herrie. Kleine kl*te fannetjes op 6000 rpm :(
2 pinnetjes moeten knippen. Paste prima. Wordt amper warm, heb wel As5 gebruikt })
[ Voor 5% gewijzigd door Pakjebakmeel op 04-10-2004 08:31 ]
  • sn0x0r
Wie weet er eigenlijk een goeie winkel om OCZ EL Platinum Rev2 (512MB x 2 PC3200 DDR CL2) te halen? In de pricewatch staat alleen iComputers, maar als iemand nog een winkel weet waar deze te koop zijn, goedkoper of even duur bij iComputers, zou hij deze of willen toevoegen aan de pricewatch, of ff hier neerzetten... thnx. Deze wil ik namelijk op me K8N Neo2 mobo'tje prikken :)
  • KifArU
tormentor1985 schreef op 04 oktober 2004 @ 00:19:
Pas goed op met dit stukje software. Mijn PC crasht keihard als ik op apply druk.
Alles gaat uit en hij wil ook niet meer opstarten. De enige oplossing is de stroom er helemaal vanaf en dan opnieuw opstarten. Verder geen schade.
  • Tutti-frutti
Tutti-frutti
Graag gedaan!
sn0x0r schreef op 04 oktober 2004 @ 10:51:
Je kan ook voor Gskill memory gaan. Die gaan gegarandeerd ddr600 op cl3.0 :)
Alleen komt dit uit taiwan, maar ze kosten maar 215 euro voor 2x512 MB :) !!!
http://www.xtremesystems.org/forums/showthread.php?t=42817
De site voor europese kopers staat in zijn signature :)
  • sn0x0r
Hmz, vanwege die Review wil ik eigenlijk toch wel voor deze gaan, zeker ook ivm garantie, ik heb namelijk geenz in om een halve maand zonder geheugen te zitten als het erop aan komt :)
Maar halleluja, die reepjes gaan wel als een trein zeg! :| Dat had ik niet verwacht!!!!!!
Edit2:
Halleluja 2! Dat geheugen wat ik dus wilde wordt hier dus van tafel geveegd :P Maar de bandbreedte zegt (lijkt mij) toch niet alles, ik wil eigenlijk ook wel benches zien als games, 3dmark e.d. Als hij daarin nog steeds zo geil presteert ga ik ze kopen. 260USD is toch geen geld voor zulke prestatie's!!!! En geen heatsinks, dus dan kun je tenminste nog een fatsoenlijke cooler erop zetten :)
[ Voor 68% gewijzigd door sn0x0r op 04-10-2004 11:52 ]
  • Tutti-frutti
Tutti-frutti
Graag gedaan!
Ik heb ze besteld, en ik krijg zeer nette mailtjes en antwoord op mijn vragen van G.Skill :)
Tot nu toe ben ik erg tevreden!
Kheb ook het geld al overgemaakt naar ze.. kost 17 euro extra omdat het naar taiwan is, maarja.. 230 euro voor 2x 512 MB ownage mem.. waar praten we over :D
[ Voor 39% gewijzigd door Tutti-frutti op 04-10-2004 13:41 ]
  • makje
makje
Tutti-frutti schreef op 04 oktober 2004 @ 13:40:
Ik neem aan dat de douane nog wel wat importbelastingen gaat heffen... :?
Dan nog zal het een hele redelijke prijs zijn waarschijnlijk :)
Wat mij echter het grootste nadeel lijkt is de garantie afhandeling. Lifetime warranty is 1 ding, daadwerkelijk van je garantie gebruik maken wanneer het nodig is, is een 2e. Zeker als het helemaal terug naar Taiwan moet daarvoor (tijd en kosten :'( ).
9800x3d
  • Tutti-frutti
Tutti-frutti
Graag gedaan!
makje schreef op 04 oktober 2004 @ 13:50:
Ik denk het niet:
"We are really sorry about not have any reseller in Europe. We will cover all the shipping and insurance cost. We only charge 5 USD for handling fee to ship from Taiwan until we have distributor or reseller in Europe. After that, everything is going to back to normal."
  • makje
makje
Maar shipping and insurance costs zijn geen importheffingen!!
Misschien willen zij die belasting en heffingen wel voor hun rekening nemen, maar ik vermoed dat dat iets teveel gevraagd is. Misschien dat ze het nog als een gift willen opsturen ipv een besteld produkt...
In principe is het namelijk zo dat als het als een gift verstuurd wordt er geen heffingen over komen. Echter, als de douane vermoed dat het een gift is met wederzijdse vergoeding (lees: een gelijkwaardig bedrag aan euroos) dan krijg je de heffing er nog wel overheen en ook nog een boete...
heb even rondgekeken op het forum en ik zie dat je 2 dingen moet betalen voor produkten van buiten de EU:
-douanerechten (ook wel invoerrechten genoemd) het precentage kan per produktgroep verschillen
-BTW (19%)
edit2 :
http://www.belastingdienst.nl/9229237/t/interneti.htm
Laatste edit:
Als ik het goed zie dan worden over er geen douanerechten geheven over computergeheugen, alleen de 19% BTW. Dat maakt dan over het totaal 230*1,19 = 273,70 euro. Nog steeds een leuke prijs voor TOP geheugen.
[ Voor 37% gewijzigd door makje op 04-10-2004 14:23 ]
9800x3d
Bijna hetzelfde als draadje boven mij
[ Voor 70% gewijzigd door Verwijderd op 04-10-2004 14:29 ]
  • Tutti-frutti
Tutti-frutti
Graag gedaan!
Tja.. ik heb ze erover gemaild, en ik zie wel wat ik terug krijg.. anders moet ikhet maar gewoon op de gok doen :+
Don't worry,
We will send it as a sample with a dummy price (lower price) show on the invoice.
There will be no problem.
[ Voor 43% gewijzigd door Tutti-frutti op 04-10-2004 14:44 ]
  • mindcrash
  • Laatst online: 25-09 21:15
mindcrash
Rebellious Monkey
Update voor de Topicstart en algemene mededeling voor de vaste k8n fanclub hier ;)
Sinds 24 september kan je bij MSI BIOS versie 1.3 neerhalen.
Changelog:
- Update CPU ID.
Have fun :)
[ Voor 6% gewijzigd door mindcrash op 04-10-2004 14:41 ]
"The people who are crazy enough to think they could change the world, are the ones who do." -- Steve Jobs (1955-2011) , Aaron Swartz (1986-2013)
  • Tutti-frutti
Tutti-frutti
Graag gedaan!
mindcrash schreef op 04 oktober 2004 @ 14:40:
Changelog:
Have fun :)
Dat is sinds vandaag :) Ik had vanochtend nog toevallig gecheckt!!! haha
Even een vraag.
Ben bezig ook met nieuw geheugen.Corsair gaat de laan uit.
Nou zat ik eerst te denken aan OCZ PC3200 Platinum Rev. 2 2x512mb
Of nou inderdaad Gskill(die wat Tutti-Frutti)besteld heeft.
Maar ik zie dat het ddr600(PC 4800) is , geeft dat alleen voordelen met overclocken of ook zo al op eventueel standaard.Die OCZ kan beide zeer goed.
Want voor de prijs hoef je het niet te laten ;)
  • Tutti-frutti
Tutti-frutti
Graag gedaan!
Verwijderd schreef op 04 oktober 2004 @ 14:46:
Even een vraag.
Geeft het voordeel dat je lekker hoge htt kan draaien. DDR550 zelfs op cas 2.5! (ddr400 op c2.0). Beter geheugen is er eigenlijk niet. Want op standaard kan je de strakste timings draaien.
[ Voor 9% gewijzigd door Tutti-frutti op 04-10-2004 14:49 ]
  • sn0x0r
Ik ga dat geheugen dus ook bestellen, ik ben er helemaal wild van!!!!! :P Ik snap alleen niet waarom ik er nog nooit eerder over gehoord heb. En hoe zit het met garantie? Dat is eigenlijk iets wat ik me nog afvraag, verder niets.
Op naar de 9000MB/s Bandwidth :P
[ Voor 11% gewijzigd door sn0x0r op 04-10-2004 14:58 ]
  • makje
makje
Afbeeldingslocatie: http://www.tweakers.net/ext/f/42582/full.jpg
9800x3d
  • sn0x0r
Volgens mij stond in deze thread dat dat het oude geheugen is. Degene die Tutti en ik hebben besteld (naja, ik erover gestuurd :P) zijn nieuwer.
  • makje
makje
Ik heb die thread ook gelezen ja. Volgens hem presteert het beter dan het door Anandtech geteste geheugen, ikzelf geloof echter niet alles wat een zeker iemand op het internet zegt. De test van Anandtech is het eerste en vooralsnog het enige bewijs dat ík kan vinden van goede prestaties, op meer zou ik dan ook nog niet (durven) hopen...
9800x3d
  • tormentor1985
Tsja, hierin wordt toch wel 1 ding duidelijk. Als je snel geheugen in je systeem propt, prop dan ook goeie koeling op je cpu zodat ie ver overklokbaar is. In de tabel wordt namelijk zeer duidelijk dat een hogere cpu snelheid resulteerd in een hoger aantal MB/sec. lage cpu snelheid i.c.m. ultra hoog geclocked geheugen, geeft geen performance winst.
  • sn0x0r
Dat kon ik je zoiezo al vertellen :P
  • sn0x0r
makje schreef op 04 oktober 2004 @ 15:08:
Dit bedoel ik dus klik
heeft iemand ervaringen met 2x 512mb twinmos (dual channel kit) icm met dit mobo :)?
  • Tutti-frutti
Tutti-frutti
Graag gedaan!
Verwijderd schreef op 04 oktober 2004 @ 16:26:
Ja. Ik kom tot 225 mhz ongeveer cl2.5 :)
Waar valt dat G.Skill geheugen te bestellen?
@Tutti frutti.
Jij schreef dat je geld had overgemaakt, gewoon via bank of paypal of CC.
Jij schreef ook 215 euro wel verschil tussen 260 dollar :9
Ben benieuwd hoe lang je moet wachten.
  • sn0x0r
$ 260,- is omgerekend € 213,84. Geloof je me niet? GWK
  • Tutti-frutti
Tutti-frutti
Graag gedaan!
Ik heb 265 dollar overgemaakt (5 dollar vzkosten) En er was nog 17 euro overmakingskosten dat voor mijn rekening komt. Dit heb ik via mn bank gedaan (abn amro).
Jawel hoor ik geloof je wel.Was een beetje lui ;) om het op te zoeken.En rekenen is niet mijn sterkste punt. :Y)
Tutti-frutti schreef op 04 oktober 2004 @ 17:17:
Werken die niet met een BIC code.Als ik hem eens mail moet ik eens vragen.Eerst even op de ABN Amro(ook mijn bank)eens lezen als dat mogelijk is.
Maar thx voor de nfo
Zal er veel verschil zitten tussen 2x512mb(1GB) of 4x512mb(2GB)?
[ Voor 6% gewijzigd door Verwijderd op 04-10-2004 17:37 ]
  • sn0x0r
Hmz, ligt eraan of je die 2Gb ook veel gebruikt, anders denk ik dat het niet veel voor je uit zal maken, maar mijn antwoord kon je denk ik zelf ook wel bedenken, dus je zal het aan iemand moeten vragen met 2Gb :) Zelf denk ik iig niet dat het veel zal uitmaken.
