Het Unreal Tournament 2004 topic, deel 4
Pagina: 1 2 ... 10 Laatste
  • 4.356 views sinds 30-01-2008
  • Ramon
Afbeeldingslocatie: http://131.211.229.224/ut2004/headerbovenlinks.pngAfbeeldingslocatie: http://131.211.229.224/ut2004/headerbovenrechts.png
Afbeeldingslocatie: http://131.211.229.224/ut2004/headerlinks.png
deel 4
  1. Wat is Unreal Tournament 2004?
  2. Screenshots
  3. Nieuwe Voertuigen
  4. Nieuwe Wapens
  5. Downloads
  6. Specs
  7. GoT Servers
  8. Vragen
  9. Links
  10. Spraakherkenning
[ Voor 45% gewijzigd door Fuelke op 24-03-2004 13:43 ]
  • Ramon
[url=][/url]
Unreal Tournament 2004 is de volgende telg in de Unreal familie. Unreal Tournament 2004 komt met 2 nieuwe gametypes, Assault en Onslaught. Qua gameplay gaat Unreal Tournament 2004 weer wat meer terug richting UT'99. De full version van Unreal Tournament komt op 6 CD's of 1 DVD en er komen maarliefst 105 maps in. De volledige versie ligt inmiddels in de winkels!
Een beschrijving van Mark Rein over de nieuwe gamemodes in UT2004:
Assault
Assault is an objective/team based game mode in which two teams (attackers and defenders) battle each other in epic (and sometimes historical) battles taking place in the Unreal universe.
Attackers have several objectives to accomplish in order to win the round.
Defenders must prevent the attackers from doing so in order to win. Several rounds are played and teams can exchange
roles after each round. There are several configurable options, such as the number of rounds in a match, and the time limit for each round.
Accomplishing objectives may involve reaching a key location, using machinery or computers in the level, or destroying a critical piece of hardware.
Assault also features many different useable vehicles and turrets, including Space Fighters, Buggies, Tanks, Energy Turrets, a Minigun Turret and the all powerful Ion Cannon.
Onslaught
Onslaught is a large scale, team and vehicle based game mode in which players battle for control of huge exterior settings. Since these settings are so large one naturally needs a way to traverse these distances, hence there are a variety of vehicles that can be used in Onslaught. These vehicles are built to not only move but also destroy your foes.
Each team has their own vehicles and you cannot steal your foes vehicles unless they unlock them by first getting into them. If your enemy jumps into a tank and then leaps out to pick up ammo you can then hijack it and turn the tables on him!
The main objective in any Onslaught game is to destroy your enemies' "Power Core." This critical point is usually located in the heart of your opponent's base. Sounds simple, right? Here's the catch - a Power Core cannot be damaged unless your team has a link to it.
How do you acquire a link? By controlling the smaller "Power Nodes" on the map and making a connection from your own Power Core to your opponents. Power Nodes begin as neutral points in the level and once they're touched they begin to build for your team. At this point the opposing team can attack and try to destroy the Node as it is being constructed. If they manage to destroy it it will go neutral again and can be re-claimed by either team. If they fail to destroy it the Node will be built for your own team and a link will be made to your own Power Core.
The next step in an Onslaught map involves proceeding to the next Node. Since the enemies Power Core can only be damaged if there is a link to your own Core you'll have to take over a number of Nodes in order to make this connection. It is extremely important to note that you can ONLY take over a Node if you control an adjacent Node. You must progress across the map, taking over point by point, in order to stage an assault on your enemies' Core.
Since death comes quick in the Tournament it is also good to know that once your team controls a Node you can then choose to respawn at it. This allows a team to have an advancing presence on any given map.
Afbeeldingslocatie: http://131.211.229.224/UT2004/linksonder.pngAfbeeldingslocatie: http://131.211.229.224/UT2004/rechtsonder.png
[url=][/url]
 Unreal Tournament 2004 screenshots:
Omdat Unreal Tournament 2004 natuurlijk draait op de laatste versie van de Unreal engine - die overigens nog vrijwel hetzelfde is als de engine in Unreal Tournament 2003 - maar wel mooie visuals op het scherm tovert, heb ik hier even wat screenshots verzameld, uiteraard met dank aan de makers. ;)
User Interface:
Unreal Tournament heeft een vernieuwde UI tov UT of UT2003:
Afbeeldingslocatie: http://131.211.229.224/UT2004/small_Shot00034.jpg Afbeeldingslocatie: http://131.211.229.224/UT2004/small_Shot00036.jpg Afbeeldingslocatie: http://131.211.229.224/UT2004/small_Shot00038.jpg Afbeeldingslocatie: http://131.211.229.224/UT2004/small_Shot00031.jpg
Onslaught:
De belangrijkste nieuwe gamemode in Unreal Tournament 2004:
Afbeeldingslocatie: http://131.211.229.224/UT2004/small_Shot00052.jpg Afbeeldingslocatie: http://131.211.229.224/UT2004/small_Shot00053.jpg Afbeeldingslocatie: http://131.211.229.224/UT2004/small_Shot00060.jpg Afbeeldingslocatie: http://131.211.229.224/UT2004/small_Shot00066.jpg
Deathmatch:
DM-Deck17, opvolger van DM-Deck16 uit UT'99:
Afbeeldingslocatie: http://131.211.229.224/UT2004/small_Shot00088.jpg Afbeeldingslocatie: http://131.211.229.224/UT2004/small_Shot00089.jpg Afbeeldingslocatie: http://131.211.229.224/UT2004/small_Shot00091.jpg Afbeeldingslocatie: http://131.211.229.224/UT2004/small_Shot00092.jpg
DM-Morpheus3, opvolger van DM-Morpheus uit UT'99:
Afbeeldingslocatie: http://131.211.229.224/UT2004/small_Shot00095.jpg Afbeeldingslocatie: http://131.211.229.224/UT2004/small_Shot00097.jpg Afbeeldingslocatie: http://131.211.229.224/UT2004/small_Shot00100.jpg Afbeeldingslocatie: http://131.211.229.224/UT2004/small_Shot00101.jpg
[url=][/url]
 Unreal Tournament 2004 voertuigen:
Om in Onslaught jezelf een beetje snel door de grote levels te verplaatsen (en je vijand te crushen) zijn er een aantal voertuigen bij gekomen. Hier volgt een lijstje van de voertuigen in UT2004 Onslaught:
Afbeeldingslocatie: http://131.211.229.224/UT2004/vehicles_goliath_tank.gif
Large
Bemanning: 2 personen
Having been recently replaced by a new model, the Goliath tank served the military for two decades as a front-line offensive weapon. Entirely protected by a double-plate Carbon-Duranium shell, the Goliath may lack in top speed, but more than makes up for it in sheer endurance and brute force.
Afbeeldingslocatie: http://131.211.229.224/UT2004/vehicles_hellbender.gif
Large
Bemanning: 3 personen
Purpose-built for both anti-vehicular and anti-personnel combat, the Hellbender offers strong maneuverability, heavy armor and powerful weaponry. Powered by a neutron-induction reactor, both weapons on the Hellbender deliver a considerable punch.
Afbeeldingslocatie: http://131.211.229.224/UT2004/vehicles_manta.gif
Large
Bemanning: 1 persoon
Despite its light weight and diminutive size, the Manta is one of the more fearsome sights in battle.
Afbeeldingslocatie: http://131.211.229.224/UT2004/vehicles_scorpion.gif
Large
More effective in a supporting combat role than in outright attack, the Scorpion is light and fast, offering little in the way of armor but effective against infantry.
Afbeeldingslocatie: http://131.211.229.224/UT2004/vehicles_raptor.gif
Large
Since its inception, the Raptor has maintained a stranglehold on air superiority in combat.
Afbeeldingslocatie: http://131.211.229.224/UT2004/vehicles_leviathan.gif
Large
Bemanning: 5 personen
Originally designed for urban pacification, the Leviathan found its greatest deployment near the end of the Human/Skaarj wars.
Afbeeldingslocatie: http://131.211.229.224/UT2004/vehicles_phoenix.gif
Large
Bemanning: geen
A fully autonomous vehicle, the Phoenix serves as a remote-bombing device,capable of delivering staggering ordnance to a specified target.
Daarnaast zijn er nog enkele voertuigen die je niet in Onslaught maar wel in Assault zal kunnen gaan gebruiken:
Afbeeldingslocatie: http://131.211.229.224/UT2004/vehicles_human_spacefighter.gif
Large
Used for over half a century, the Human Spacefighters (known as "Eagles") were the main choice for military interception, sabotage and infiltration missions.
Afbeeldingslocatie: http://131.211.229.224/UT2004/vehicles_skaarj_spacefighter.gif
Large
Very few details are available on these rarely seen SpaceFighters, as they appeared and disappeared during the final battle against the Skaarj which ended the '7 Day Siege' over a century ago.
[url=][/url]
 Unreal Tournament 2004 wapens:
Bij een nieuw spel horen natuurlijk nieuwe wapens. Voor verschillende gamemodes zijn de wapens vernieuwd of verbeterd, de volgende wapens zijn erbij gekomen:
Afbeeldingslocatie: http://131.211.229.224/UT2004/weapons_avril.gif
Large
The AVRiL, or Anti-Vehicle Rocket Launcher, shoots homing missiles that pack quite a punch.
Afbeeldingslocatie: http://131.211.229.224/UT2004/weapons_grenade_launcher.gif
Large
The Grenade Launcher is a flexible combat tool, providing excellent tactical and combat support solutions to the competitive warrior.
Afbeeldingslocatie: http://131.211.229.224/UT2004/weapons_sniper_rifle.gif
Large
This high muzzle velocity sniper rifle has a 10x zoom scope and is a lethal weapon at any range, especially if you can nail a headshot.
De rest van de wapens is bijna gelijk aan die van UT2003, sommige hebben wat visuele en/of gameplay tweakjes ondergaan waardoor het allemaal wat lekkerder en vloeiender speelt, maar niets schokkends.
[url=][/url]
 Unreal Tournament 2004 downloads:
Een overzichtje van bestanden die te downloaden zijn mbt Unreal Tournament 2004:
Unreal Tournament 2004 demo:
Zoals bekend van Epic releasen ze zo goed als altijd een demo voor de full version uitkomt. Zo ook in dit geval. De demo is 209MB groot, heeft 5 maps (AS-Convoy, ONS-Torlan, DM-Rankin, CTF-BridgeOfFate, BR-Colossus) en 6 gamemodes ( Assault, Onslaught, DM, CTF, TDM, BR).
Download de windows versie hier, hier of hier.
Voor mac en linux versies kan je op www.unrealtournament.com een mirror zoeken.
Kevin Riepl's muziek:
Kevin Riepl heeft muziek voor UT2003 en UT2004 gemaakt. Deze staan uiteraard ook als .ogg in je \Music\ folder, maar je kan ze ook hiervandaan direct als .mp3 downloaden.
Dedicated Server:
Er zijn voor UT2004 twee dedicated servers beschikbaar, ééntje voor de full version, en ééntje voor de demo:
Full Version Dedicated Server - v3186
Linux Demo Dedicated Server - 3120
Unreal Tournament 2004 movies:
Voor diegene die nog extra overtuiging nodig hebben voor ze de demo willen proberen hier wat filmpjes:
Reload. Rev-up. Ride Out.
UT2004 Onslaught video
Intro ATi Logo:
Net zoals in UT2003 wordt je bij het opstarten van UT2004 getrakteerd op een stukje nVidia propaganda ;) Mensen die een ATi videokaart hebben kunnen hier het ATi logo downloaden. Instructies inbegrepen. (Met dank aan Lord_Mithril)
[url=][/url]
 Unreal Tournament 2004 System Specifications:
Om UT2004 een beetje lekker te spelen heb je minimaal het volgende nodig als systeem:
Operating System: Windows® 98/Me/2000/XP
Processor: Pentium® III or AMD Athlon 1.0 GHz processor or faster (1.5 GHz or faster processor recommended)
Memory: 128 MB RAM minimum (256 MB recommended)
Hard Disk Space: 3.5 GB free
Video: Any Windows-compatible video card(NVIDIA GeForce 2 or ATI Radeon with at least 64 megs of video memory recommended.)
Sound: Windows®-compatible sound card. NVIDIA® nForce(tm) or other motherboards/soundcards containing the Dolby® Digital Interactive Content Encoder required for Dolby Digital audio.
DirectX®: DirectX® version 8.1(included)or higher
Multiplayer: Internet (TCP/IP) and LAN (TCP/IP)play supported. 33.6K baud modem or broadband Internet connection recommended.
[url=][/url]
 UT2004 Frequently Asked Questions:
De volgende vragen heb ik verzamelt en bij elkaar gezet omdat ze nogal vaak gesteld worden:
Hoe maak ik ingame screens van UT2004?
Screens maken kan met F9, maar andere programma's zoals FRAPS werken ook gewoon (mocht je dat willen). Indien je gewoon de F9 functie van UT2004 gebruikt, dan komen de screenshots in \UT2004\Screenshots\ terecht.
Hoe zie ik mijn FPS tijdens een potje?
Je kan je FPS zien door op <tab> of <~> te drukken en dan 'stat fps' intikken. Er komt dan rechtsboven een FPS countertje te staan.
Kan ik UT2004 ook in OpenGL draaien?
Ja dat kan! Doe het volgende:
open je ut2004.ini, die zich in in UT2004\System\ bevind.
verander dit:
RenderDevice=D3DDrv.D3DRenderDevice
;RenderDevice=D3D9Drv.D3D9RenderDevice
;RenderDevice=Engine.NullRenderDevice
;RenderDevice=OpenGLDrv.OpenGLRenderDevice
;RenderDevice=PixoDrv.PixoRenderDevice
naar dit:
;RenderDevice=D3DDrv.D3DRenderDevice
Hoe connect ik direct naar IP's?
Je kan je direct naar IP's connecten door op <tab> of <~> te drukken en dan 'open <ip>' intikken.
Hoe gebruik ik adrenaline?
Als je 100 adrenaline punten hebt (kijk rechtsboven op het tellertje) kan je de volgende moves gebruiken:
- 4x vooruit = Speed (je beweegt sneller)
- 4x achteruit = Booster (je health en shield worden langzaam gevuld)
- 2x rechts 2x links = Invisible (onzichtbaar dus ;) )
- 2x vooruit 2x achteruit = Berserk (sterkere en snellere schoten)
Hoe zie ik mijn ping?
Je ping staat doorgaans op het scoreboard, die je vind door op F1 te drukken. Wil je meer uitgebreide statistieken over je verbinding met de gameserver, druk dan op <tab> of <~>, tik daar 'stat net' in en druk op ENTER.
Wat is TruFORM en hoe zet ik het aan in UT2004?
Wel TruFORMGeen TruFORM
Afbeeldingslocatie: http://131.211.229.224/UT2004/TruForm_klein_Shot00075.jpgAfbeeldingslocatie: http://131.211.229.224/UT2004/TruForm_klein_Shot00086.jpg
TruFORM is in essentie een techniek van ATi om alles wat levensechter te maken door hardwarematig polygonen toe te voegen. Voor UT2004 betekent dit dat models er mooier en ronder uitzien.
Hoe zet ik TruFORM aan dan?
- Zorg ervoor dat je een ATi kaart hebt ;)
- Zet in je ATi Control Panel TruFORM aan.
- Ga naar je UT2004.ini (UT2004\System\)
- ctrl + F naar 'npatches' verander dit van False naar True
- Zet tesselationfactor (staat direct onder npatches) op 2, 4, 6 of 8. Dit is het aantal waarmee UT2004 uitrekent hoeveel polygonen een mannetje moet hebben. heeft een mannetje bijv 5.000 polygonen, en kies jij voor 8, dan heeft het mannetje dus 40.000 polygonen. Ik raad je wel aan om niet hoger dan 4 te gaan als je een kaart onder de 9500 hebt.
Of het verschil in beeldkwaliteit de performancepenalty waard is, mag je zelf beslissen ;)
Hoe werkt spraakherkenning in UT2004?
Kijk in de post hieronder voor een uitgebreide guide over hoe spraakherkenning te gebruiken is in UT2004. (met dank aan Rafe)
Ik vind die intro irritant/lame/te lang duren! Kan ik die overslaan?
Ja dat kan! Ga naar UT2004\System\ en open je ut2004.ini. Ctrl+F naar "LocalMap" en verander dit naar "LocalMap=nointro.ut2". (Met dank aan Lord_Mithril)
De Installer pakt mijn CD-key niet! Wat nu?
Atari heeft inmiddels al toegegeven dat er iets niet goed is gegaan bij het drukken van de CD-key stickers. Ze geven als advies om overal waar je een B of een 8 leest, het tegenovergestelde te proberen.
[url=][/url]
 Links mbt Unreal Tournament 2004:
Een overzichtje van sites met als onderwerp Unreal Tournament 2004:
Officiële UT2004 website
BeyondUnreal
UnrealOps
PlanetUnreal
Officiële UT2003/4 forums
Links naar Unreal topics hier op GoT:
UnrealEd:
Voor meer informatie over UnrealEd 3.0:
Het UnrealEd 3.0 topic
UT2004:
Het Unreal Tournament 2004 topic, deel 3
Het Unreal Tournament 2004 topic, deel 2
Het grote Unreal Tournament 2004 topic
UT2003:
[rml]-[ Het Unreal Tournament 2003 topic deel 7]-[/rml]
[rml]-[ Het Unreal Tournament 2003 topic deel 6]-[/rml]
-[Het Unreal Tournament 2003 topic deel 5]-
[rml]-[ Het Unreal Tournament 2003 topic deel 4]-[/rml]
-[Het grote Unreal Tournament 2003 topic deel 3]-
[rml]-[ Het grote Unreal Tournament 2003 topic deel 2]-[/rml]
[rml]-[ Het grote Unreal Tournament 2003 topic]-[/rml]
[ Voor 32% gewijzigd door Ramon op 23-03-2004 20:43 ]
  • Rafe
  • Laatst online: 27-06-2025
Spraakherkenning in UT2004
Afbeeldingslocatie: http://www.tweakers.net/g/nblt.gif Installatie, training & instellen
Download eerst de 68 MB wegende Microsoft Speech SDK, en installeer deze op je computer. Ga vervolgens naar het configuratiescherm, zoek het onderdeel 'Spraak' op, en je krijgt dit voor je neus:
Afbeeldingslocatie: http://crew.tweakers.net/Rafe/pics/ut2k4_speech1.png
Zorg dat je microfoon/headset is ingeplugd en werkt, en klik op 'Nieuw...' om een nieuw herkenningsprofiel aan te maken. Je begint met de microfoonwizard, om er voor te zorgen dat het systeem je stem goed kan horen.
Afbeeldingslocatie: http://crew.tweakers.net/Rafe/pics/ut2k4_speech2.png
Herhaal de zin een aantal keer, tot dat de meter niet meer zo sterk uitschiet naar het rode vak, en dus voornamelijk bij groen blijft hangen.
Nadat je de microfoonwizard hebt gehad, moet je de spraakwizard doorlopen om het systeem je stem te leren herkennen. Eerst moet je je geslacht en leeftijd invullen als basis voor de herkenning, en daarna ga je een aantal keer een tekst oplezen.
Afbeeldingslocatie: http://crew.tweakers.net/Rafe/pics/ut2k4_speech3.png
Elke woord dat wordt herkend, zal een lichtblauw kleurtje krijgen.
Mocht je je verspreken, of 'snapt' het systeem niet wat je zegt, zullen de net uitgesproken woorden geen kleur krijgen. Houdt dan even een paar tellen je mond, zodat het systeem kan bijwerken wat hij voor het laatst begreep.
Na dat paar tellen zal de kleur van lichtblauw naar donkerblauw veranderen, en alles wat donkerblauw is, is goed herkend. Lees vanaf daar dan het eerste niet-blauwe woord om weer verder te gaan met de training.
Als je de introductie van de spraaktraining hebt gehad, wordt volgens MS ongeveer 85-90% van wat je zegt goed herkent. Genoeg om het te gaan testen in het spel ;)
Standaard staat speech recognition al aan, en is de F-knop verantwoordelijk voor het activeren van je microfoon, maar loop dit even voor de zekerheid in de settings na.
Op de game-tab kan je rechts onderin de 'speech recognition' optie aanzetten, en op de input-tab, onder de knop 'configure controls', kan je een knop hangen aan 'activate microphone' (te vinden onder het kopje 'communication').
Start nu maar een potje CTF (of een andere gamemode waarin je met teams speelt) :)
Afbeeldingslocatie: http://www.tweakers.net/g/nblt.gif Ingame voice commands
Elke bot krijgt een callsign (bijv. Alpha) toegewezen, en je zult zijn/haar callsign moeten zeggen om die bot een opdracht te geven. Je kunt op twee manieren achter een bot z'n callsign komen: op het scoreboard, onder de naam van de bot, of als je in de buurt van een bot bent, staat zijn callsign in blokhaken achter de naam.
Een lijstje van mogelijke callsigns:
  • Alpha
  • Bravo
  • Charlie
  • Delta
  • Echo
  • Foxtrot
  • Golf
  • Hotel
  • India
  • Juliet
  • Kilo
  • Lima
  • Mike
  • November
  • Oscar
Meerdere bots tegelijkertijd een opdracht geven kan door er "and" tussen te zeggen.
Je kunt het hele team op deze manieren aanspreken:
  • Team
  • Everyone
  • Everybody
Nu je weet hoe je de juiste perso(o)n(en) kan commanderen, moet je ook wel weten welke commando's je ze kan geven.
Voor elke gamemode zijn de volgende commando's beschikbaar:
  • Attack
  • Defend
  • Cover me
  • Freelance
  • Taunt/Dance - bot doet een kunstje
  • Status
  • Gimme - bot dropt zijn wapen zodat jij die kan pakken
  • Suicide
  • Jump
  • Hold ((this) position)
De meeste commands spreken voor zich. :)
"Taunt" en "Dance" zijn dus twee verschillende opdrachten die je kunt geven, maar ze hebben hetzelfde resultaat. Wat tussen haakjes staat mag je weglaten, dus "Hold", "Hold this position" en "Hold position" behoren tot de mogelijkheden.
Voor de verschillende gamemodes zijn ook nog verschillende opdrachten.
Bombing Run:
• Defend (the ball)
• Take/Attack/Get (the ball)
Capture The Flag:
• Defend (the flag)
• Take/Get ((their) flag)
Double Domination:
• Take/Attack alpha/bravo
"Take alpha" en/of "Attack bravo".
Let op! Standaard werkt speech recognition in Double Domination niet, klik hier voor de oplossing.
Onslaught:
• Get out - bot stapt uit het voertuig waar hij/zij in zit
Dus uiteindelijk moet je dingen als dit zeggen:
  • "Everybody attack"
  • "Alpha and Bravo cover me"
  • "Delta get out"
  • "Kilo take the ball"
  • "Team dance" Afbeeldingslocatie: http://crew.tweakers.net/hlpdsk/cheer.gif :P
Mocht het nog niet duidelijk zijn: je moet wel de knop voor 'Activate microphone' (standaard F) ingedrukt houden om te praten. ALs je dat doet verschijnt er aan de linkerkant op je scherm een meter die het geluidsniveau aangeeft, en gaat overige gamegeluid even op een laag pitje.
Praat op dezelfde, rustige, manier zoals je praatte met de spraaktraining, anders herkent het spel de opdracht niet goed. Heb ook geduld, soms kan het wel 5 seconden duren voordat je opdracht op het scherm verschijnt.
Mocht de herkenning nog steeds niet echt goed werken (wat best kan als je alleen de introductietraining hebt gedaan), ga dan weer naar 'Spraak' in het configuratiescherm, en druk op 'Profiel trainen', waar je uit een aantal teksten kiezen, die je weer zal moeten voorlezen. Volgens MS ligt de kans op herkenning na extra training rond de 95%.
Afbeeldingslocatie: http://www.tweakers.net/g/nblt.gif Speech recognition in DOM[url=][/url]
Bij mij werkte speech recognition in een potje Double Domination niet, en toen ik dom.xml (in UT2004\Speech) opende, zaten er allemaal rare tekens in en alles stond op een regel. Waarschijnlijk 'snapte' UT2004 het bestand niet, waardoor het niet werkte. Hier kan je een gefixte dom.xml halen, zet 'm in je UT2004\Speech map :)
Dit is deels overgenomen/vertaalt van BeyondUnreal, maar ik heb zelf ook nog dingen toegevoegd (zoals screenshots, de gametype specifieke commands, de 'kapotte' dom.xml).
Al met al hoop ik dat jullie er wat aan hebben :)
[ Voor 8% gewijzigd door Rafe op 24-03-2004 08:44 ]
  • Venxir
  • Laatst online: 20:47
mooie startposts, goeie informatie maar die speech recognition link is nogal heel sloom :/
If it aint broke, fix it till it is!
  • You-Suk
  • Laatst online: 16-11-2025
nog een paar daagjes wachten :)
Your order for "Unreal Tournament 2004 (DVD version)" has been posted.
Please allow 3-5 days for delivery.
Please check the following order information:
Order Reference: *******
Title: Unreal Tournament 2004 (DVD version)
Price: £17.99
Delivery Cost: FREE
Payment: Credit Card
Delivery Address:
(via play.com) :D
  • Stewie!
  • Laatst online: 13:17
Stewie!
Keen must die!
D4V3 schreef op 23 maart 2004 @ 20:08:
voor de liefhebbers is hier mijn eigen vCTF map te downloaden: Face Classic met 2 manta's en 2 AVRiL's, 1 voor elk team :) hf er mee
DOWNLOAD!
Als je webspace hebt zou ik het erg graag zien dat je hem mirrored :)
5 april gaat onze nieuwe website in de lucht en dan heb ik ook flinke ruimte op onze servers. E-mail me dan even, dan plaats ik alle custom maps op onze site en de gameservers die UT2004 draaien en natuurlijk in de redirect map voor snelle ingame downloads B) O-)
Strava: https://www.strava.com/athletes/149347154
Mirror voor D4V3's Vehicle CTF variant van CTF-FaceClassic: link
D4V3: De map bevat nog wel een paar fouten. Sommige wapens/ammo zweven in de lucht en de Manta's staan misschien niet helemaal handig geplaatst: Ze staan een beetje in de weg :P
  • LordMithril
  • Laatst online: 10:20
Mooie start post :P
maar 1 ding toe te voegen.. de downloads die we hier posten ;
Hier nogmaals het ATI logo voor het intro (ipv van het nvidia logo)
DOWNLOAD
handleiding inbegrepen.
Tevens kan je het intro overslaan door in je UT2004.INI "LocalMap=NvidiaLogo.ut2" te veranderen in "LocalMap=nointro.ut2"
Bier, Whiskey en Metal!!
  • Venxir
Lord_Mithril schreef op 23 maart 2004 @ 20:26:
Mooie start post :P
DOWNLOAD
nu nog iemand die het GoT logo erin doet ;)
  • riffey#4
  • Laatst online: 13-11 19:11
riffey#4
aka Beever#4
Misschien ook voor de startpost:
De sticker met het serienummer is bagger.
B's kunnen een 8 zijn, maar ook gewoon een B.
In mijn geval (een key met 4 B's) zijn dat dus al 16 mogelijkheden.
Heeft me dus een dag gekost voordat ik kon gaan spelen.
Het officiele, en vrij belachelijke antwoord van Atari Nederland op mijn vraag waarom mijn key niet werkte:
Hoi Riffey#4,
De Key staat op het hoesje waar CD1 in zit.
Dat deze niet klopt komt omdat de drukker de B en de 8 door elkaar gehaald
heeft. Als je hiermee een beetje speelt zou het moeten lukken.
Met vriendelijke groet,
_____
Bij antwoord gelieve het originele bericht bij sluiten.
Naam Helpdeskmedewerker
Helpdesk
Atari Benelux BV
Tel : +3140-2393580
Fax:+3140-2446636
mail :nl.helpdesk@atari.com
  • Brent
  • Laatst online: 17:53
Ik speel (helaas) nog met de demo, maar dat voice command werkt best vetjes :) Ik heb wel een hele slechte mic (zo'n 5 euro kijkshop geval), maar als je een beetje duidelijk articuleert, gaat het allemaal toppie :)
  • Stacium
Stacium
Perfect Molecular Chaos
Weet iemand al hoe je de 'Benchmark'-directory kan benutten in UT2004?
ik zie dat er onder windows een benchmark.exe bestaat, draai UT hier onder linux :/ Het gaat me juist om het verschil tussen windows en linux-performance
[ Voor 62% gewijzigd door Stacium op 23-03-2004 20:48 ]
It seemed like a good idea at the time
  • Bernd
  • Laatst online: 15-08-2022
Morgen middag eerst nog ff langs de Scheltema om te kijken of die misschien wel de dvd versie hebben, anders zaterdag maar ff op stap gaan naar de MediaMarkt (stomme k*t Free Record Shop en Bart Smit hebben UT2k4 alleen in cdr versie).
Frogstar#2151
  • Rafe
Breepee schreef op 23 maart 2004 @ 20:40:
Op mijn headset zit normaal zo'n 'dopje' om er voor te zorgen dat langsstromende lucht niet wordt opgenomen, maar die ben ik kwijtgeraakt. Toen ik eens "Everybody attack" zei, maakte dat ding er "Kilo defend" van 8)7
  • LordMithril
HOWTO 1: Hoe maak ik mijn eigen intro logo's
Benodigd heden:
UT2004
Photoshop of een ander programma wat TGA files aankan
Dit file
10 minuten de tijd
Wat nu:
Download het filetje en pak de rar uit. Hierin bevind zich het file Playseal_T.TGA. Open deze in Photoshop. Je ziet nu voornamelijk veel zwart met een wit rondje, in dit witte rondje staat normaal het Nvidia logo. Zet hier je eigen creatie in.
Bewaar het geheel als TGA file (photoshop wil normaal alleen als psd saven, ff opletten dus).
Open nu de Unreal Level Editor, deze bevind zich in "UT2004/System" onder de naam "UnrealEd.exe". Zodra deze opent zou er een scherm moeten verschijnen. Verschijnt deze niet dan is deze te vinden onder "View -> Show Texture Browser".
Hier ga je naar "File -> Open" en zoek in de Textures map het bestand NvidiaLogo_T.utx en open deze. Ga nu naar "File -> Import" en zoek de net gesavede PlaySeal_T.TGA en open deze. In het volgende scherm moet de inhoud van Groep leeg zijn, is deze het niet hanteer dan uw delete toets. Klik hierna op OK en Save de texture (File -> save in de texture browser) en overschrijf het originele bestand.
Enjoy :Y)
  • ScrooLoose
ScrooLoose
A muddle of nervous words...
Ik speel nog steeds de demo (wacht nog op de SE version) en nu heb ik een nieuwe videokaart, de Nvidia Geforce FX 5950 Ultra dit samen met AMD Athlon 2500+ en 1024MB geheugen....... leuk systeempje...... zou je zeggen :|
Als ik alles aan zet heb ik in ONS een framerate tussen 80fps en 30 fps aan, licht er maar net aan waar ik naar kijk en wat er in beeld is. (in DM is dit tussen 110fps en 50fps in)
Gemiddelde is zo'n 40fps in een ONS-potje,(het maakt bijna geen verschil als ik alles op de hoogste setting speel (details en kleurdiepte) of de laagste setting)
Is dit niet vreselijk laag voor mijn specs of verwacht ik te veel van mijn nieuwe videokaart. of ligt dit puur aan de demo en is dit in de full version beter ? :|
[ Voor 4% gewijzigd door ScrooLoose op 23-03-2004 21:06 ]
  • Sjah
  • Laatst online: 20:35
Vraag: hoe benchmark je? In UT 2k3 was dat makkelijk, maar in 2k4 zie ik nergens een benchmark.bat staan in de folders :?
  • ScrooLoose
ScrooLoose
Rafe schreef op 23 maart 2004 @ 20:06:
Onslaught:
Als zo'n bot nou in een raptor zit op grote hoogte........ :Y)
En hou kun je bots laten instappen dan ?........ lijkt mij ook wel handig :z
[ Voor 12% gewijzigd door ScrooLoose op 23-03-2004 21:40 ]
ScrooLoose schreef op 23 maart 2004 @ 21:00:
ik denk dat je gemiddeld wel 70 fps mag hebben..
ik heb in de demo met een Ati Radeon 9800 pro en een 2.8ghz HT met 1024mb geheugen al gauw 80 a 90 fps constant op een resolutie van 1280 bij 1024. 1600x1200 haal ik ong 50 a 60 fps..
zoek eens banchmarks op van je vga kaart en vergelijk daar eens mee..
  • D4V3
  • Laatst online: 18-08 14:44
Verwijderd schreef op 23 maart 2004 @ 20:25:
ja ik weet het van die sniper, daar moet je voor springen om hem te pakken,
moet ik nog een keer goedzetten, en de plaats van de manta's maakt het eigenlijk wel spannend, ik heb het net met arnoud, tha handy en ene ferdy online gespeeld en het is nu al mn favoriet (en niet omdat ik hem zelf heb gemaakt). Het beste uit facing worlds (de level zelf) en dan het slechte er uit gehaald (het lange lopen naar de andere basis :P)
helaas heb ik geen nieuwe screenies van ingame vehicles, maar wel van een scoretje :P
Afbeeldingslocatie: http://home.hccnet.nl/jjm.evers/score.jpg
en nog bedankt voor de mirror Terr!
[ Voor 12% gewijzigd door D4V3 op 23-03-2004 21:32 ]
op-voorraad.nl - Realtime voorraad updates voor de Playstation 5!
ik heb nog een vraagje..
bij de dvd versie heb je 2 dvd's 1 dvd is voor de installatie en om te spelen.
kan iemand mij vertellen wat er allemaal op de 2e dvd staat?? ben wel benieuwd naar alle extra's wat ik erbij krijg aan softe goederen..
  • Nara Shikamaru
  • Laatst online: 01-10 14:39
Nara Shikamaru
Cleverest Strategist
ik heb de full game installed maar
waar zijn alle insta server :S ik zie niks
wanneer komen ze :D
Antec Sonata II EC/MT 450Watt | AMD Athlon 64 3700+ s754 | Asus K8N4-E Deluxe | 2X512MB Kingston DDR PC3200|Maxtor 250Gig 16MB cache | Asus EN6600GT 128 MB PCI-E | MX500
  • D4V3
DaMorpheus schreef op 23 maart 2004 @ 20:24:
mooi,
komt goed uit want wij van de GoT clan gaan van de week een servertje bij jou huren :D (en daar wordt deze map natuurlijk ook op gespeeld :P)
  • Irby
  • Laatst online: 08:24
Verwijderd schreef op 23 maart 2004 @ 21:31:
150 uur aan film met making of, tutorials etc. :) (Is wel de SE-versie)
11 x 270wp / 10 x 300wp, All electric
  • El Snorro
  • Laatst online: 16:08
Weet iemand hoe het zit met ut2003 inruilen (met bijbetaling) tegen ut2004??
Kan dit en zo ja bij welke shops?
E6600||Gigabyte P35C-DS3R||2x1gb Crucial Pc8500||Sapphire X1900XTX||2xSamsung Spinpoint F1 750GB RAID-0
  • D4V3
kan niet in nederland...
  • Irby
Ik dacht dat dit niet voor ons landje is, maar voor America.
  • LordMithril
  • El Snorro
hmz, erg jammer, kan ik en vele andere hem niet naar atari opsturen?
El Snorro schreef op 23 maart 2004 @ 21:50:
bestel hem anders gewoon bij play.com. scheelt 22 euro met de prijs in nederland..
daar kan een 10 euro korting van atari niet tegenop.
  • D4V3
Mijn custom startscreen:
Afbeeldingslocatie: http://members.chello.nl/dfijter/ut2004/startscreen.jpg
Afbeeldingslocatie: http://members.chello.nl/dfijter/ut2004/startscreen2.jpg
net mn verzendbevestiging gekregen van bol.com :D
  • Jaguar645
  • Laatst online: 15-11 22:18
hoe zit het trouwens met de SE? ik wil em morgen graag halen maar wil weten of alle winkels ook de SE hebben of moet ik dan speciaal op zoek gaan? :)
  • Brent
Rafe schreef op 23 maart 2004 @ 20:53:
Precies, dat heb ik ook wel eens :D Zeg ik "Bravo, cover me", en gaat Echo verdedigen. Als ik de R en de A op zijn Nederlands uitspreek gaat het om de een of andere reden al een stuk beter. Ik heb de spraakherkenning gewoon op mn beste Engels ingesproken (1e vijf oefeningen), met de Amerikaanse R(wrwrw), maargoed. Het is erg leuk :)
  • Irby
D4V3 schreef op 23 maart 2004 @ 21:54:
Die is erg goed :D
  • Epitome
  • Laatst online: 01-11 11:40
Nu is het om de beste te maken!! :)
[ Voor 74% gewijzigd door Epitome op 23-03-2004 22:50 ]
  • Bzzje
  • Laatst online: 24-06 14:55
Bzzje
Negeren is vooruitzien
quote:
Bzzje schreef op 23 maart 2004 @ 18:08:
wel een mooie domper trouwens... hadden ze ook wel op de buitenkant van de box mogen zetten dat er geen headset in zit. Nu kan je lekker wachten tot 6 mei... da's ruim een maand!!!!
Heb je mijn post gelezen
(beetje raar om te quoten uit vorig topic...)
Tweakviper: ik heb je post prima gelezen.
Ik heb hier naast mij dezelfde doos staan
maar dan met een briefje dat ik de headset op kan komen halen na 6 mei
we zijn niet allemaal alleen maar aan het kijken naar jouw dvd's
  • Jovas
  • Laatst online: 17:12
Verwijderd schreef op 23 maart 2004 @ 22:21:
Same here :) :Y)
  • Bikkel-Rulez
  • Laatst online: 21-12-2025
ik vindt het echt wel vet geworden met die wagens en vliegtuigjes waar je mee kunt vliegen echt wel mastelijk
  • CyberTijn
  • Laatst online: 15-11 17:56
Ik vind het maar een rare gang van zaken hoor bij ATARI, weet je wat gigantisch veel werk ze nu erbij krijgen als ze nu later allemaal nog die headsets moeten gaan leveren.
[ Voor 71% gewijzigd door CyberTijn op 23-03-2004 23:23 ]
De Ion tank staat nog steeds niet in de start post :p
  • ebborazor
  • Laatst online: 10-09-2022
aangezien ik geen nvidia kaart heb en het logo gewoon veranderen in ati een beetje saai is:
Afbeeldingslocatie: http://home.planet.nl/~matho041/gotlogo1.jpg
Afbeeldingslocatie: http://home.planet.nl/~matho041/gotlogo2.jpg
DL: http://home.planet.nl/~matho041/PlaySeal_T.rar
  • pimpimmers
Ik heb vandaag de Limited Edition - DVD opgehaald bij dimensionplus voor 57,99 zonder headset :( zat een brief bij van Atari dat die later komt. Nouja maakt niet zoveel uit.
Maar mijn vraag weet iemand hoeveel Limited Edition/Special Edition er gemaakt zijn ?
En ik hoop dat er snel een officiële no-cd patch komt, ik haat namelijk dat steeds die dvd/cd erin moet. Bij al mijn battlefield versies heb ik ook een image gemaakt van de CD en die mount ik met Daemon tool, zo hoef ik niet steeds die cd erin te doen. Maar om nu de helle DVD op mijn HD te zetten vind ik ook niet nodig, alleen voor DVD check.
  • skullsplitter
  • Laatst online: 15-11 18:00
skullsplitter
Eat brain, high fibre!
Dit is een hele handige OP geworden _O_
www.avpnews.com
  • Exar
  • Laatst online: 01:30
Zijn er nog meer mensen die de SE versie bij DVDzone2 hebben besteld?
Ik krijg niet eens een reactie als ik mail met de vraag wanneer ze denken te kunnen leveren en of ik em uberhaubt nog wel krijg... :|
Hoekwoning 2021, 100m2 vvw, ERST20D-VM2D, SUZ-SWM60VA
  • skullsplitter
skullsplitter
ebborazor schreef op 23 maart 2004 @ 23:26:
Speaking of butt-ugly :D
www.avpnews.com
  • STIMPPYYY
  • Laatst online: 19:58
Verwijderd schreef op 23 maart 2004 @ 21:52:
wat is de levertijd van play.com ?
btw bij D3D heb je bij ATI kaarten toch hogere FPS als bij OpenGL?
[ Voor 12% gewijzigd door STIMPPYYY op 23-03-2004 23:47 ]
  • LordMithril
STIMPPYYY schreef op 23 maart 2004 @ 23:40:
Engine is gebaseerd op D3D dus mag aanemen van wel :P anders kunnen die programeurs beter stoppen ;)
Exar_Kunn schreef op 23 maart 2004 @ 23:34:
Ze krijgen hem niet. Heb afgelopen zaterdag gemaild met dezelfde vraag, en vandaag antwoord gekregen.
Blijkbaar hebben zij maar 12 exemplaren gekregen, en zij krijgen er GEEN meer binnen.
  • nhimf
  • Laatst online: 09-10 14:19
nhimf
Lekker belangrijk allemaal
Kan iemand mij vertellen hoe ik ooit de dedicated server zo ver krijg dat hij een config file gaat gebruiken?
Het gaat om de dedicated server onder linux. Maar die flippo's bij epic zijn vergeten om een simpele help (oid) erbij te doen.
Het moet allemaal commandline. (ik heb dus de dedicated server gedownload bij epic en ik wil geen cd key gebruiken, want ik wil niet op de lijsten komen te staan).
Ik stink niet, ik ruik gewoon anders
  • Yagermeister
  • Laatst online: 13:10
Yagermeister
Bedrijfsprutser on call
Nu maar eens ff kont schoppen hier met een aantal pics :P
Afbeeldingslocatie: http://home.hetnet.nl/~yagermeister/ut2k4/Tshot000.jpgAfbeeldingslocatie: http://home.hetnet.nl/~yagermeister/ut2k4/Tshot001.jpg
Afbeeldingslocatie: http://home.hetnet.nl/~yagermeister/ut2k4/Tshot002.jpgAfbeeldingslocatie: http://home.hetnet.nl/~yagermeister/ut2k4/Tshot003.jpg
Afbeeldingslocatie: http://home.hetnet.nl/~yagermeister/ut2k4/Tshot004.jpgAfbeeldingslocatie: http://home.hetnet.nl/~yagermeister/ut2k4/Tshot005.jpg
Afbeeldingslocatie: http://home.hetnet.nl/~yagermeister/ut2k4/Tshot006.jpgAfbeeldingslocatie: http://home.hetnet.nl/~yagermeister/ut2k4/Tshot007.jpg
Afbeeldingslocatie: http://home.hetnet.nl/~yagermeister/ut2k4/Tshot008.jpgAfbeeldingslocatie: http://home.hetnet.nl/~yagermeister/ut2k4/Tshot009.jpg
Zo :P dit krijg je dus als je teveel tijd hebt en een aantal personen wat met zelfde prob zitten :P
Ik heb er maar ff aantal weggehaald ik krijg ze niet met thumbs gedaan :S
De andere foto's maar puur als linkje alleen
[ Voor 158% gewijzigd door Yagermeister op 24-03-2004 00:42 ]
-Te huur
Ga hier eens heel snel echte thumbnails van maken, 180-250KB per screenshot is echt teveel :/
  • Yagermeister
Yagermeister
Verwijderd schreef op 24 maart 2004 @ 00:19:
Ik zal ze ff gaan aanpassen :X
-Te huur
  • X-t-r-e-m-e
  • Laatst online: 12-11 19:49
Yagermeister schreef op 24 maart 2004 @ 00:14:
Beetje overkill niet?
[ Voor 89% gewijzigd door X-t-r-e-m-e op 24-03-2004 00:52 ]
  • Orangeman
  • Laatst online: 15-11 19:09
Je zal er ongetwijfeld heel lang mee bezig geweest zijn yagermeister, maar die plaatjes hebben weinig toegevoegde waarde... Als je nou eens 90 % van die plaatjes weghaalde en een leuk verhaaltje erbij vertelt dan weten we evenveel :)
Dit is een duidelijk geval van overkill...
  • Epitome
Sjeik Ahmed "Unreal" Yassin
Afbeeldingslocatie: http://www.dutchfightclub.nl/datas/users/5-yassin01.jpg
Afbeeldingslocatie: http://www.dutchfightclub.nl/datas/users/5-yassin02.jpg
The way it's meant to be played ;)
  • Yagermeister
Yagermeister
Orangeman schreef op 24 maart 2004 @ 00:27:
Het is al allemaal aangepast :X (op zich nog niet echt overkill aangezien we er ruim 300 gemaakt hadden :P)
Omdat je zo lief een verhaaltje vraagt het was eigenlijk simpel: gewoon met raptor die levi oppakken en er dan mee gaan rondvliegen, maar in ons geval is dus een aantal keer ook de raptor gecrashed terwijl de levi dus gewoon bleef hangen todat je inklapte :+
[ Voor 5% gewijzigd door Yagermeister op 24-03-2004 00:43 ]
-Te huur
  • Exar
Verwijderd schreef op 24 maart 2004 @ 00:02:
OMFG! Maar hij staat nog gewoon in mijn order! Bedoel je niet dat je hem zaterdag had willen bestellen? Of had jij ook een pre-order en worden de pre-orders niet voldaan dan? WTF ik schiet hier zwaar in de stress, ik zit al een extra week te wachten..... :( :'(
  • Yagermeister
Yagermeister
Pimpimmers20 schreef op 23 maart 2004 @ 23:28:
Ik lees in een paar posts voor je dat die rond 2 mei uitkomt pas, staat toevallig wel in die brief hoe ze je die gaan opsturen? (aanmelden of iets dergelijks)
-Te huur
  • johnneman
  • Laatst online: 13-11 15:26
johnneman
rofl de bofl
Yagermeister schreef op 24 maart 2004 @ 00:39:
mwah, zo gewoon vind ik dat niet ;)
heb wel ff gezocht, maar kon niet zo snel vinden hoe dat moet..
Dus, vertel! Hoe flik je dat :)
Tempus: It is said we all have a twin someplace in the world. Why Mr. Kent, without those glasses, I'd say you'd look exactly like.. well, d0h:\:p
  • LordMithril
johnuitalmelo schreef op 24 maart 2004 @ 01:10:
Raptor naast de levi zetten, levi uitpakken. Dan komt 1 van de side panels over de raptor heen en die clipped. Stap weer in je raptor en als je een teammate hebt, Lame Away :P
  • Webgnome
hoe kun je dat opstartding veranderen met die tga file ? oftewel waar moet ik die planten?
Strava | AP | IP | AW | SM
  • LordMithril
Webgnome schreef op 24 maart 2004 @ 01:28:
staat allemaal netjes uitgelegd hoor in die post ;)
tga file editen, importeren in het texturepack via unrealedit en klaar :P
of als je heel erg n00b bent liev vragen wat je wilt hebben :+
  • Webgnome
ok thanx :D
Afbeeldingslocatie: http://picserver.student.utwente.nl/view_image.php/NORW6Q2446XN/picserver.jpeg
  • pimpimmers
Yagermeister schreef op 24 maart 2004 @ 01:03:
In mij brief staat dat op het moment dat de LE verpakking gefabriceerd werd de logitech headset nog niet beschikbaar was..... Ter compensatie hebben we speciaal voor u een originele poster van UT2004 bijgesloten.
bla bla bla bla
Stuur voor 26 april een email naar nl.helpdesk@atari.com en laat op de onderstaande wijze weten waar u uw headset wilt ophalen.
Je moet invullen waar je hem gekocht heb etc.
En dan kan je hem vanaf 6 me 2004 op halen bij de winkel waar je hem hebt gekocht op vertoon van originele kassabon.
Maar ik heb ook een brief van de winkel waarin hem heb gekocht en daar staat in dat mensen die hem via postorde hebben besteld iets hoeven te doen. Atari stuurt zelf de headset op. Maar ik heb hem zelf opgehaald dus moet hem weer ophalen :( Ik had hem beter op laten opsturen voor 2,25 ik ben nu meer benzine kwijt.
  • Webgnome
dan ga je toch met de fiets :P
komt een beetje over als dieresex hoor
[ Voor 52% gewijzigd door Webgnome op 24-03-2004 02:05 ]
  • LordMithril
_o_ dies koe(l) :P
Zal morgen ff proberen de tekst te editen ;) kan je em compleet maken :P
hmz ff snel gekeken.. die hele ring is een static mesh.. word lastig maar zal kijken ;)
[ Voor 13% gewijzigd door LordMithril op 24-03-2004 02:21 ]
  • Webgnome
als die static mesh aangepast zou kunnen worden zou dat ERG vet zjin :D dan no geen modelletje van een rennende koe met een rocket achter zich aan en klaar :P (en nee dat kan ik helaas niet maken :( )
Bzzje schreef op 23 maart 2004 @ 23:12:
Vreemde distributiedienst daar bij Atari.
Eerst dat bericht dat ze de Special Editions voor Benelux vergeten waren en nu de headsets die er soms wel, soms niet bij zit.
  • Phydomir
  • Laatst online: 06:33
Phydomir
Dennis
1: wtf is static mesh?
2: Mocht er nog iemand een clan zoeken: www.blacklotus.co.uk . Skills zijn wel welkom :)
[ Voor 58% gewijzigd door Phydomir op 24-03-2004 08:06 ]
  • DeX
  • Laatst online: 13-01 09:52
DeX
ik vind die custom opstart logo's wel bruut!
Overigens mijn hulde aan Ramon voor een van de mooiste startposts die ik ooit heb gezien _/-\o_
levertijd is ongeveer een week is mijn ervaring. ik heb afgelopen maandag een mailtje gehad dat die verstuurd is dus ik zal hem wel volgende week maandag wel krijgen. of met een beetje geluk heb ik hem zaterdag.. maar de vorige keren duurde het 6 a 7 dagen..
maarja als ik 22 euro kan besparen dan wil ik wel een weekje wachten..
  • DeX
DeX
Verwijderd schreef op 24 maart 2004 @ 08:14:
Mijn redenering was niet om 22 euro te besparen. Maar 2 voor de prijs van 1 is toch een stuk beter :) .
  • dimane
  • Laatst online: 28-07 21:22
ik snap er echt nix van ik zie volgens mij geen instagib servers :S
wie weet waar dit aan ligt?
[ Voor 19% gewijzigd door dimane op 24-03-2004 08:48 ]
  • Smoonshine
  • Laatst online: 13:11
Smoonshine
Feyenoord!!
Pimpimmers20 schreef op 24 maart 2004 @ 01:56:
Je gaat toch niet serieus menen dat we ook daadwerkelijk nog weer verzendkosten moeten betalen voor de blunder die Atari begaan is? Ik heb al 2 euro verzendkosten betaald voor mijn SE en ik ga er vanuit dat me die headset gratis wordt toegestuurd.
Woei! ik zie nu net dat de status van mijn bestelling bij GCshop is gewijzigd in "in Behandeling"! _/-\o_ , alleen jammer dat er morgen niemand thuis is om het pakketje in ontvangst te nemen, zodat ik nog tot vrijdag moet wachten voor ik hem kan ophalen :'(
[ Voor 21% gewijzigd door Smoonshine op 24-03-2004 10:05 ]
uhm...
  • Venxir
die die eigen gemaakte logo's worden er ook uitgetrapt door dat monster? :)
  • dimane
moet je eigenlijk poorten open zetten voor ut 2004 ?
  • johnneman
johnneman
rofl de bofl
dimane schreef op 24 maart 2004 @ 10:09:
ik hoefde het iig niet, en voor zover ik weet,
is er nog niemand geweest die dat wel moest dus:)
@ Venxir;
nee ik denk dat ie zon tweakers logo er niet uit durft te trappen :9
[ Voor 15% gewijzigd door johnneman op 24-03-2004 10:50 ]
  • pasta
  • Laatst online: 29-08 10:23
pasta
Ondertitel
Venxir schreef op 24 maart 2004 @ 10:07:
Ja, volgens mij wel.. Aan de scene wordt niks veranderd afaik. :)
Signature
  • dimane
johnuitalmelo schreef op 24 maart 2004 @ 10:49:
maar hoe kan het dan komen dat ik lang niet alle servers zie?
  • ErA
  • Laatst online: 20:06
ErA
FF en repost van mijn map :Y)
De gebruikte Tutorial: (4 uur werk)
Tutorial
De eerste map: (1 uur werk)
Screenie:
Afbeeldingslocatie: http://www.rutgersmit.demon.nl/anda.jpg
En spelen maar: (weken lang fun, hijs best goed namelijk, mutator instagib is favoriet of course)
Klikkie Download Hier
  • johnneman
johnneman
rofl de bofl
dimane schreef op 24 maart 2004 @ 10:52:
gebruik je de ingame browser dan?
je zou 't anders ook es kunnen proberen met The All-Seeing Eye,
maargoed, voor de rest heb ik niet veel verstand van poortmappen ivm ut2004..
check the manual anders :)
  • dimane
oke ik zal als ik thuis ben is gaan kijku
[newbi mode]
uhm ingame browser je bedoelt als je op escape drukt bedoel je dat?
[/newbi mode]
[...]Maar ik heb hem zelf opgehaald dus moet hem weer ophalen :( Ik had hem beter op laten opsturen voor 2,25 ik ben nu meer benzine kwijt.
Same here, ik heb dan wel een lease, maar het is wel een takkuhstuk rijden!
  • ErA
ErA
dimane schreef op 24 maart 2004 @ 11:09:
[newbi mode]
[/newbi mode]
De ingame browser is dat ding dat je krijg als je op "Join Game" drukt. En overigens: Als jij 10 games ziet zie je ze allemaal. Let wel dat rechtsboven je gametypes kan kiezen waar hij op filtert ( de browser) Hij laat dus bijvoorbeeld games zien van het type onslaught
  • johnneman
johnneman
rofl de bofl
[newbi mode]
[/newbi mode]
ja denk t.. (als je al aant spelen was ja)
gwoon de manier van servers opzoeken in het spel zelf,
als je op multiplayer drukt en dan op internet zegmaar :)
  • ErA
ErA
johnuitalmelo schreef op 24 maart 2004 @ 11:14:
Dat is unreal tournament '99 8)7
[ Voor 3% gewijzigd door ErA op 24-03-2004 11:23 ]
  • dimane
ja ik snap dat hij op een soort game selecteert maar op een of andere manier ziet hij geen instagib:S:S:S:S
ik had gezien in een van de vorige post in dit topic dat iemand anders daar ook last van had.
[ Voor 32% gewijzigd door dimane op 24-03-2004 11:28 ]
  • johnneman
johnneman
rofl de bofl
ErAdiCToR schreef op 24 maart 2004 @ 11:23:
ohja rofl! (net ff gecheckt), het is dus "Join game".. ging al helemaal uit van multiplayer, stupid me }:O
  • Schaapje_BlaaT
  • Laatst online: 13-11 11:43
hmm, ligt het aan mij of missen de GoT servers in de startpost
ASUS ROG Strix B650-A | AMD 7600X | Kingston 32GB DDR5 6000 CL36 | Kingston KC3000 1TB | Powercolor hellhound RX9070 16GB
  • dimane
miss tog iets met de poorten ofzo
[ Voor 80% gewijzigd door dimane op 24-03-2004 11:38 ]
  • Turismo
woei vandaag UT 2004 SE versie binnengekregen hier, maar echt blij kan ik niet zijn.
de dozen zijn helemaal krom en gekrast |:( hier aangekomen, erg jammer.
en slecht gedaan door atari, want ze zien er totaal niet meer uit nu. :(
Ik wou er zelf 1 kopen, maar nu weet ik t niet meer. ;(
Afbeeldingslocatie: http://picserver.org/view_image.php/5O30XJCSEYL3/picserver.jpeg
Afbeeldingslocatie: http://picserver.org/view_image.php/2HIO1BL12P5N/picserver.jpeg
Gamebak Look Behind you, a Three Headed Monkey!
  • Smoonshine
Smoonshine
Feyenoord!!
Turismo schreef op 24 maart 2004 @ 11:38:
Dat is ook lekker zeg, kun je er niet voor zorgen dat je een paar nieuwe krijgt. Zulke dozen zijn toch eigenlijk niet verkoopbaar.
uhm...
  • LordMithril
Schaapje_BlaaT schreef op 24 maart 2004 @ 11:31:
Komt meer doordat er nog geen full version servers zijn ;)
  • Sensei_D
  • Laatst online: 29-10 13:17
dimane schreef op 24 maart 2004 @ 11:27:
Misschien staat onderaan het vinkje met "standard servers" aan... Die moet dan uit ;) Ook kan het zijn dat je misschien een filtertje hebt aanstaan, maar het eerste lijkt me waarschijnlijker...
sensei_d.fpv channel
  • dimane
zien er wel sjiek uit die dozen :*)
[ Voor 8% gewijzigd door dimane op 24-03-2004 11:52 ]
  • dimane
echt *** zit ik hier op mijn stage een beetje de systeembeheerder uit te hangen :Z
geen fok te doen kan beter een beetje thuis gaan gamen :*)
  • Turismo
Smoonshine schreef op 24 maart 2004 @ 11:49:
Ik kan ze wel retour sturen en dan worden ze gecrediteerd, maar dan moet ik wel weer gewoon nieuwe bestellen, en dat duurt weer :S
  • Yagermeister
Yagermeister
Turismo schreef op 24 maart 2004 @ 11:58:
Voor die met die krassen erop zou ik zeker nieuwe eisen, met die deukjes ben ik bang dat je niet veel kunt aangezien je dat altijd krijgt. Heb je btw headset of brief of iets erbij over hoe ze dat nasturen?
-Te huur
  • D4V3
er zijn er 60.000 gemaakt,
waarvan 40.000 voor de USA en de rest van de
wereld 20.000...
Ter vergelijking: the UK had er dus maar 500 ter beschikking :X
