[OC-Ervaringen] Lanparty NFII Ultra B en Infinity Deeltje 2
Pagina: 1 2 ... 6 Laatste
  • 2.200 views sinds 30-01-2008
  • Astennu
  • Laatst online: 19-08 17:53
Link naar het vorige topic:
LANPARTY NFII ULTRA B
Afbeeldingslocatie: http://www.dfi.com.tw/Imgs/Product/lp_kt400a_4s.jpg
[img=400,300]url= http://www.envynews.com/reviews/images/606/14.jpg[/img]
Klickbaar
[img=400,300]url= http://www.lanparty.com.tw/LP1/board3.jpg[/img]
Klickbaar
CPU
AMD Athlon XP 266/333/400MHz FSB
AMD Athlon 200/266MHz FSB
AMD Duron 200/266MHz FSB
Chipset
nVIDIA® nForce2 chipset
- nForce2 Ultra 400
- nForce2 MCP-T
System Memory
Supports dual channel memory interface
Supports up to 3GB memory (unbuffered DIMM)
Supports PC1600 (DDR200), PC2100 (DDR266), PC2700 (DDR333) and PC3200 (DDR400)
DDR SDRAM DIMM, 2.5V type
Three 184-pin DDR SDRAM DIMM sockets
BIOS
Award BIOS, Windows® 95/98/2000/ME/XP Plug and Play compatible
Genie BIOS provides:
- CPU/DRAM/AGP overclocking
- CPU/AGP/DRAM/Chipset overvoltage
4Mbit flash memory
CMOS Reloaded
Power Management
Supports ACPI STR (Suspend to RAM) function
Wake-On-Events include:
- Wake-On-PS/2 Keyboard/Mouse
- Wake-On-USB
- Wake-On-Ring (external modem)
- Wake-On-LAN
- RTC timer to power-on the system
AC power failure recovery
Hardware Monitor
Monitors CPU/system temperature
Monitors ±12V/5V/3.3V/VBAT(V)/5VSB(V) voltages
Monitors CPU/chassis fan speed
Read back capability that displays temperature, voltage and fan speed
CPU Temperature Protection function monitors CPU temperature during system boot-up
Audio
Realtek ALC650
AC'97 2.2 S/PDIF extension compliant codec
Supports Microsoft® DirectSound/DirectSound 3D
AC’97 supported with full duplex, independent sample rate converter for
audio recording and playback
S/PDIF-in/out interface
6-channel audio output
LAN
nVIDIA® nForce2 MCP-T and ICS1893 Phy
- Full duplex support at both 10 and 100 Mbps
Realtek RTL8110S Gigabit LAN
- Full duplex support at 10, 100 and 1000 Mbps
PCI IDE
Supports ATA/33, ATA/66, ATA/100 and ATA/133 hard drives
UDMA Modes 3, 4, 5 and 6 Enhanced IDE (data transfer rate up to 133MB/sec.)
SATA IDE with RAID
Silicon Image Sil3114 PCI to Serial ATA controller
Supports four SATA (Serial ATA) interfaces which are compliant with SATA 1.0
specification (1.5Gbps interface)
Supports RAID 0 and RAID 1
IEEE 1394
nVIDIA® nForce2 MCP-T and Agere FW803 Phy chips
Supports three 100/200/400 Mb/sec ports
AGP
Supports AGP 8x up to 2132MB/sec. and AGP 4x up to 1066MB/sec. bandwidth
for 3D graphics applications
Rear Panel I/O Ports #(piccie verderop)
1 PS/2 mouse port
1 PS/2 keyboard port
1 DB-9 serial port
1 DB-25 parallel port
4 USB 2.0/1.1 ports
2 RJ45 LAN ports
2 S/PDIF RCA jacks (S/PDIF-in and S/PDIF-out)
3 audio jacks: line-out, line-in and mic-in
2 audio jacks for center/bass and rear out
I/O Connectors
1 connector for 2 additional external USB 2.0/1.1 ports
3 connectors for 3 external IEEE 1394 ports
1 front audio connector for external line-out and mic-in jacks
2 internal audio connectors (AUX-in and CD-in)
1 S/PDIF connector for optical cable connection
1 connector for IrDA interface
4 Serial ATA connectors
2 IDE connectors
1 floppy connector
2 ATX power supply connectors
3 fan connectors for CPU fan, chassis fan and 2nd fan
4 diagnostic LEDs
1 diagnostic LED connector for external 4 diagnostic LEDs display
EZ touch switches (power switch and reset switch)
Expansion Slots
1 AGP slot that supports 8x/4x AGP
5 PCI slots
PCB
4 layers, ATX form factor
30.5cm (12") x 24.5cm (9.64")
#Rear Panel
heatsinkje southbridge (zit met thermal tape losjes vast)
Nog 2 klickbare gifjes :)
[img=400,300]url= http://www.xs4all.nl/~mvgemert/NF2Ultra_layout.gif[/img]
Klickbaar
[img=400,300]url= http://www.xs4all.nl/~mvgemert/NF2Ultra_glow.gif[/img]
Klickbaar
INFINITY
[img=400,300]url= http://www.dfi.com.tw/Upload/Product_Picture/NFII%20ULTRA%20INFINITY%20b.jpg[/img]
Klickbaar
CPU
Chipset
- nForce2 Ultra 400
- nForce2 MCP-T
Memory
BIOS
4Mbit flash memory
CMOS Reloaded
Power Management
- Wake-On-USB
- Wake-On-LAN
Hardware Monitor
Audio
Realtek ALC650
AC’97 supported with full duplex, independent sample rate converter for audio recording and playback
LAN
nVIDIA® nForce2 MCP-T and ICS1893 Phy chips
Integrated IEEE 802.3, 10BASE-T and 100BASE-TX compatible PHY
PCI IDE
SATA IDE with RAID
IEEE 1394
AGP
1 PS/2 mouse port
1 DB-9 serial port
4 USB 2.0/1.1 ports
1 RJ45 LAN port
I/O Connectors
2 IDE connectors
1 floppy connector
Expansion Slots
5 PCI slots
PCB
Meer specs
CPU Clock: 100MHz to 300MHz in 1MHz increments
CPU Multiplier: 5 to 22 in 0.5 increments
CPU Voltage: 1.1V to 2.0V in 0.025V increments
AGP Voltage: 1.5V to 1.8V in 0.1V increments
Chipset Voltage: 1.6V to 1.9V in 0.1V increments
DRAM Voltage: 2.6V to 3.3V in 0.1V increments
Verschillen LANPARTY NFII ULTRA B en LANPARTY NFII ULTRA rev. A
A ->Audio Connectivity 3 port backplane speaker
B ->S/PDIF I/O on I/O shield 5 port backplane speaker, S/PDIF I/O on backplane
A ->IDE RAID Highpoint HPT372N RAID controller w/ 2 ports
A ->SATA Marvell 88i8030, 1 port bridge from primary ATA
B ->SATA RAID 4 device RAID0, RAID1 Silicon Image Sil3114, 4 port
A ->NVIDIA 10/100, RTL8101 10/100
B ->NVIDIA 10/100, RTL8110S 10/100/1000
B ->Mounting holes rondom de socket
Uit de review van Hexus*
A nip here, a tuck there. The biggest change is the dropping of IDE RAID support in favour of SATA. The Sil3114 offers 4 full SATA channels which the board duly makes good use of, giving you 4 physical ports to hang your drives from. The chip does RAID0 and RAID1 on all channels, giving you decent flexibility in your disk configuration. You can run seperate RAID levels on two channel pairs, as far as I can make out without explicit testing anyway. The lack of physical IDE ports for the old Highpoint chip on the old board means a layout change for the B revision, I'll talk about that on the following page.
Verschillen LANPARTY NFII ULTRA B en Infinity
De lanparty heeft naast 100 Mbit Nvidia lan een Realtek RTL 10S Gigabit lan onboard.
De goodies zitten alleen bij de LANPARTY
[img=200,150]url= http://img.hexus.net/dfinf2ub/box_inside2.jpg[/img]
Klickbaar
Sleurtas (Transpo)
[img=200,150]url= http://img.hexus.net/dfinf2ub/transpo.jpg[/img]
Klickbaar
Rounded (uv-sensitive) cables (1 ide en 1 fdd)
[img=200,150]url= http://img.hexus.net/dfinf2ub/rounded_cables.jpg[/img]
Klickbaar
Frontx -> met o.a.: diagnostic LED connector for external 4 diagnostic LEDs display http://www.frontx.com
[img=200,150]url= http://img.hexus.net/dfinf2ub/frontx.jpg[/img]
Klickbaar
2 SATA-kabels en SATA voedingsconnector
1 DFI Lanpartysticker
1 DFI Lanpartycasebadge
and last but not least: power and resetbutton op het mobo, werkt dus dmv alleen de voeding aan te sluiten :).
[url= url=http://img.hexus.net/dfinf2ub/sata.jpg ][img=200,150]url= url=http://img.hexus.net/dfinf2ub/sata.jpg[/img][/url]
Klickbaar
De Lanparty heeft een UV-coating en 4 diagnostic LEDs op het mobo(en extern), de Infinity niet.
Even een plaatje van de UV-coating:
[img=200,150]url= http://www.lanparty.com.tw/LP1/board3.jpg[/img]
Klickbaar
Links naar fabrikant+mobo:
http://www.lanparty.com.t..._r_us.jsp?PRODUCT_ID=2320
http://www.lanparty.com.tw/LP1/index_lp_us.jsp
Bios’en:
http://www.lanparty.com.t...Y_TYPE=null&STATUS_FLAG=A
INFINITY
http://www.dfi.com.tw/Sup...Y_TYPE=null&STATUS_FLAG=A
Beta-bios:
Die duiken op 4 verschillende plekken op :(.
De meeste recente verschijnen op: http://forums.amdmb.com/s...ad.php?s=&threadid=281088
verder op**: http://www.dfi.com.tw/Sup...DEX_TYPE=MB&STATUS_FLAG=B
en op: http://www.angrygames.com/CMOS_Reloaded_NFIIB.htm
en tenslotte dook er 1tje op bij: http://www.xtremesystems....6&perpage=25&pagenumber=5
http://www.dfi-street.com/bios.html
http://www.midnightmachine.com/dfi/
Modded BIOS: http://underclock.proboar...on=display&num=1074106235
INFINITY
http://myweb.hinet.net/ho...dfi/betabios/N24IDC18.zip
bios en utilities verzameld door Psychosis op: http://www.midnightmachine.com/dfi/
What are recommened DDR memory modules on LANPARTY NFII UltraB?
http://www.lanparty.com.t...SUBMITTED=No&PAGE_TYPE=US
Issues
1) De ruimte rondom de socket
Die is krap. De volgende (onscherpe doch functionele) foto zal veel verduidelijken:
Vanaf hier gezien zit er linksboven een laag chipje naast de socket, door de gebruikte constructie van zalman heb ik er geen last van, de koeler wordt aangedraaid op de 2 dwarsverbindingen. Van andere gebruikers heb ik gehoord dat ze met wat washers onder de steunconstructie werken om te voorkomen dat dit chipje wordt geplet.
Zie ook: http://forums.amdmb.com/s...ad.php?s=&threadid=278704
2) 2,0 volt is momenteel het maximale van de Vcore, zonder mod
Hier (op GoT) werd er geopperd dat deze d.m.v. een bios update verhoogd kan worden, ik heb hier nog niks overgelezen! Zodra ik iets concreets weet zal ik het hier posten. Tot die tijd is het misschien een idee om na te gaan denken over een eventuele mod.
3) Grote fluctuaties op de 5 en 12 volt rail
Ik heb er zelf geen last van (TrueControl) maar het wordt wel genoemd in de diverse fora. Ik heb me er niet in verdiepd omdat ik er geen last van heb. Het staat wel als puntje op mijn agenda om het mee te nemen.
4) Memoryproblemen
Heb ik ook geen last van, ik gebuik dus A-data oem wat waarschijnlijk geen BH-5 chippies zijn. Het blijkt dat reepjes beplakt met winbond het beste werken op deze plank. Hiervoor geldt weer hetzelfde als voor het vorige punt, geen last van staat op de agenda
threads over wel/niet passen verschillende luchtkoelers
Thermalright 900a
http://forums.amdmb.com/s...ad.php?s=&threadid=280992
Zalman CNPS7000A
http://forums.amdmb.com/s...ad.php?s=&threadid=275858
Swiftech MCX462-V
http://forums.amdmb.com/s...ad.php?s=&threadid=279640
Thermalright AX-7
http://forums.amdmb.com/s...ad.php?s=&threadid=279623
reviews:
Op de onderstaande sites zijn revieuws te vinden van de: LANPARTY NFII ULTRA B:
Hexus*
FastLane
TheModFathers
Club OC
DataFuse.net
NinjaLane
Ohls-Place
Viperlair
[H]ard|OCP
Hexus.net
FiringSquad
PCStats
Hardwarezoom
Envy News
Legion Hardware
INFINITY
http://www.mbreview.com/nf2inf.php
links (fora-INFINITY en LANPARTY NFII ULTRA B meestal door elkaar in 1 topic):
Bijna alle topics op:
http://forums.amdmb.com/forumdisplay.php?s=&forumid=66
en hier de overige die ik heb gebruikt:
http://www.xtremesystems....6&perpage=25&pagenumber=1
http://www.xtremesystems....readid=24691&pagenumber=1
http://www.ocworkbench.co...b=get_topic;f=34;t=000015
En hier een handig forum over de DFI planken. Er is ook iemand van DFI support aanwezig die de vragen terug koppelt naar de technische mensen bij DFI.:
DFI Support @ AMDMB Forums
Voltmods
Dit natuurlijk voor het echte DOC werk :P
We hebben de volgende mods:
- V-Core mod
- OVP mod voor V-Core
- V-Dimm mod
V-Core mod en OVP mod
Deze doe ik maar in een keer want ze zitten op de zelfde chip:
Afbeeldingslocatie: http://www.xtremesystems.org/forums/attachment.php?s=&postid=327062
hier kun je dus zien welke pinnen je moet hebben.
Pin 7 is de V-core mod zonder OVP mod zul je ongeveer 2.1 volt halen en dan kick je mobo zichzelf uit. Hier kun je het beste een 20K tienslag potmeter pakken. Dan kun je het voltage precies afstellen.
Pin 10 is de OVP met deze mod is tot nu toe 2.17v gehaald hierbij was de weerstand van tussen pin 10 en ground 3K.
[img=400,300]url= http://home.kabelfoon.nl/~vnrswk/DSCF0761.JPG[/img]
Klickbaar !!
En een plaatje van hoe het resultaat zal zijn :).
V-Dimm mod
De V-Dimm mod. Voor de echte die hards aangezien de Infinity en de Lanparty beide standaard 3.3 v bieden. De V-Dimm wordt bij deze planken van de +5v lijn gehaald bij de meeste andere van de 3.3 en dan was er een 3.3v mod op de voeding nodig om een stabiele v-dimm te krijgen. Gelukkig is dat hier niet nodig :).
[img=400,300]url= http://www.xtremesystems.org/forums/attachment.php?s=&postid=307748[/img]
Klickbaar !!
Er wordt wel bij gezegd oppassen met het draaien aan de pod dus misschien verstanding ook hier weer een 200k 10 slag moet je misschien wel lang proberen voordat je het gewenste resultaat hebt maar wel minder kans op een kapot mobo ;)
Startpost door:
- Spice
- MaTr1x
- Astennu
Versie 2.6b
[ Voor 32% gewijzigd door Astennu op 16-02-2004 11:00 . Reden: modded BIOS URL met hoger vDIMM; underline bij specs; typos corrected ]
  • Astennu
Zijn er nog wensen voor de nieuwe start post ? zo jah post die even :)
[ Voor 5% gewijzigd door Astennu op 03-02-2004 19:00 ]
kan dat nog een fipo ? ;)
Doen HyperX PC3000 (BH-5) chippies het goed op dit mamaplankje ?
  • Astennu
Start post dan ;)
  • PD2JK
  • Laatst online: 12:54
PD2JK
ouwe meuk is leuk
Verwijderd schreef op 03 februari 2004 @ 18:59:
waarom niet? :?
Toen waren beige computers heel gewoon.
  • Astennu
Er zijn wel planken die er moeilijk mee doen maar deze niet.
  • Tjaps
Tjaps
Snap ik toch...
Astennu schreef op 03 februari 2004 @ 18:47:
Zou je me plaatje van die mod ff kunnen mirroren hij gaat namelijk over 1 a 2 dagen van me ftp af omdat ik gezeur heb van me provider en daardoor moet er flink wat van me ftp af :(
  • Spice
  • Laatst online: 09-01 14:46
Spice
- Mijn vader is een tovenaar -
nice :)
er zijn nog wat reviews:
http://www.cluboc.net/rev...i/LANPartyNFIIB/index.htm
http://www.legionhardware.com/html/doc.php?id=276
http://www.ninjalane.com/...lanparty-nf2ultrab&page=1
http://www.viperlair.com/...fi/amd/lp_nf2/index.shtml
http://www.pcstats.com/articleview.cfm?articleID=1527
B.S.O.D. heeft belooofd een mooie pic can koeling op de mosfets te maken.
Tenslotte: deze is ook wel handig: http://www.dfi-street.com/bios.html
Bedankt Astennu en ik zal hier zelf ook af en toe langskomen :).
o, nog 1 ding heb je maar 1 ide kabel (rounded) bij de Lanparty gekregen dan kun je mailen naar: DFI -> support@dfi-europe.nl en hij stuurt je een 2e. Alleen de Lanparty, niet de Infinity!
Verder _/-\o_ Astennu
[ Voor 7% gewijzigd door Spice op 05-02-2004 10:13 ]
Just call me angel of the morning, angel. Just touch my cheek before you leave me, baby. Just call me angel of the morning, angel.
  • Astennu
The Doctor schreef op 03 februari 2004 @ 19:22:
Jah al em wel ff op VYW hosten.
Spice schreef op 03 februari 2004 @ 19:32:
nice :)
o, nog 1 ding heb je maar 1 ide kabel (rounded) bij de Lanparty gekregen dan kun je mailen naar: Jeff Chen -> jcchen@dfi-europe.nl en hij stuurt je een 2e. Alleen de Lanparty, niet de Infinity!
Tnx doe me best.
[ Voor 61% gewijzigd door Astennu op 03-02-2004 19:34 ]
  • Remy
  • Laatst online: 06-11 16:39
Remy
I usually get 100% accuracy
Binnen enkele dagen gaat mijn trouwe A7N8X-Deluxe deruit, die heeft nu bijna een jaar en een maand braaf z'n diensten bewezen. En ik krijg dan een NFII Ultra B binnen :9, waarop ik mijn 2500+ (weliswaar gelockt, maar goeie core) en deze reepjes eens flink ga testen :) Wie weet als ik er genoeg tijd voor heb maak ik er een complete aparte overclocking guide van, dat zou mooi zijn voor de (nieuwe) DOC faq :)
Ben benieuwd hoe hij in verhouding tot de A7N8X-Deluxe gaat presteren, dat was nog geen Ultra-400 chipset namelijk.
LinkedIn
Instagram
  • Astennu
ReemF schreef op 03 februari 2004 @ 19:38:
Tja zal niet veel sneller zijn @ stock maar hij oc't wel veel beter :)
eeeh een A7N8X Deluxe is wel een ultra400 hoor, ik heb hem hier liggen...
  • Astennu
Verwijderd schreef op 03 februari 2004 @ 22:14:
De Ref 2.0 ja maar de voorgaande versies niet.
  • SlowikPL
  • Laatst online: 18-08 14:37
Astennu misschien is het beter als je de mama plank LANPARTY NFII ULTRA B de foto omruilt met deze : ( hier zit de Southbridge heatsink ) :
verder wel mooi start :)
Afbeeldingslocatie: http://www.envynews.com/reviews/images/606/14.jpg%20http://www.envynews.com/reviews/images/606/14.jpg
* Intel Core i7-6700K @ 4.8Ghz * Asus MAXIMUS VIII EXTREME* nVidia Asus Poseidon 1080Ti * Mushkin 16 GB * SSD Samsung M.2 2280 256GB + 3x Samsung 256GB 850Pro* Enermax Revolution85+ 1250W * CM Stacker 832 SE * Waretcooling CPU, NB ,VGA 3x Mora
  • DaOverclocker
  • Laatst online: 08-11 09:07
DaOverclocker
Overclocker for life...
Zeg waarom staat de DFI ULTRA AL nou niet in de startpost? Doet die helemaal niet mee ofzo?
Dit is ook een super bordje, heeft alle functies van een infinity, alleen geen raid en geen iIEEE1394. Ook geen fancy kleuren erop, en dit bordje kost 'maar' 85,-. Dit bordje heeft ook vier gaten om de socket heen, veel ruimte en een veel betere plaatsing van de powerconnector.
Dit is mijn toekomstige bordje, scheelt nogal wat in prijs, en raid gebruik ik de komende jaren toch niet.
plaatje:
http://www.dfi.com.tw/Upl...e/NFII%20ULTRA-AL%20b.jpg
systeem specs
  • World Citizen
  • Laatst online: 10:44
8) Daarom niet
  • Spice
Spice
Omdat de Lan Rev. B en de infinity totaal nieuw ontworpen plankjes zijn die goed oc'en en de ultra al verouderd is vergeleken met deze 2 planken en niet te oc'en is.
[ Voor 4% gewijzigd door Spice op 04-02-2004 12:53 ]
  • Astennu
SlowikPL schreef op 04 februari 2004 @ 01:02:
Done :)
  • Keen87
  • Laatst online: 10-11-2025
wat is de goeie bios voor een goeie 3d prestatie
ik heb nu 5100 punten bij 3dmark03..en dat met een overklokte barton 2500+ op 2350 mhz en een radeon 9700 pro op 400/320 :'(
ik had iets verwacht richting de 6000 of iig meer dan 5500
Keen87 schreef op 04 februari 2004 @ 15:19:
NoStra: 5100 is normaal voor een 9700 pro met die kloks....
  • Exigence
  • Laatst online: 14-11 12:21
Exigence
dnkroz
LET OP!
Nog een enorme waarschuwing van mijn kant, voordat mensen hun bordje mollen.
Bij de Vddr mod staat dat je het beste een 10k 10 slags potmeter kunt gebruiken. In het oude topic had ik ook al een keer opgemerkt dat dat echt te weinig is. Bij 50k heb je al 0,45v verhoging. Dat is nog wel acceptabel, maar ik wil niet weten wat er bij 10k gebeurt.
Ikzelf heb er dus gewoon een 50k opzitten.
  • Astennu
erik9287nl schreef op 04 februari 2004 @ 16:37:
LET OP!
Dus dan ga je van 3.3 naar 3.75 ??? :?
Lijkt me wel erg veel 8)7
[ Voor 6% gewijzigd door Astennu op 04-02-2004 17:00 ]
  • MaTr1x
  • Laatst online: 14-11 22:53
Astennu,
Ik heb laatst m'n DFI Ervaringen topic hierzo ge-update naar de Rev.B. met o.a. nog meer reviews dan jij gepost hebt, en links naar beta BIOSsen (er zijn alweer nieuwere). We kunnen dit eventueel wel samenvoegen aagezien dit topic toch vaker gebruikt wordt. Trouwens je kunt beter deze code gebruiken,
[url=http://www.www.www]naam van link hier[/url]
want dat ziet er een stuk overzichtelijker uit, zoals dit
[Ervaringen] DFI LanParty NFII Ultra 400 ipv http://gathering.tweakers.net/forum/list_messages/795365.
Ik kan eventueel mijn topic editten en dan jou de code toesturen, hoef je het zelf niet allemaal handmatig toe te voegen. :)
π MW finishers
  • Astennu
MaTr1x schreef op 04 februari 2004 @ 17:09:
Astennu,
Weet ik doe ik altijd ook maar dat kwam uit de post van spice dat veelomzetwerk. K wil het best wel doen hoor daar gaat het niet om. MAar ik al eens wat overnemen.
Edit
Zo gedaan waren veel dubbele.
maar start post > versie 2.5
[ Voor 6% gewijzigd door Astennu op 04-02-2004 18:38 ]
Post mijn berichtje nog maar een keer :(
Ik heb laatst de lanparty nfII ultra b gekocht.
Nou heb ik er een nieuwe bios opgegooid , de laatste !
En nou zegt hij steeds gvd fout tijdens laden van besturingssysteem !
Ik word er gek van , alles staat goed ingesteld.
Amd 2500
cosair pc 3700 cas 2.0
Ik denk dat ik vanaf maar weer is de ouwe (eerste versie ) er op ga zetten !
Hebben meer mensen hier last van ?
Heb win xp al 6 x opnieuw geinstalleerd, en telkens als hij wilt beginnen met installeren start hij fftjes opnieuw op. En steeds krijg ik dan die melding :( :'(
Het heeft btw niet geholpen die nieuwe os er op te zetten . Krijg steeds die stomme rot melding . Heb 98 se , windows 2000 sp4 en winxp prof geprobeerd !
Geen van alle doen ze het meer :'(
  • Astennu
Verwijderd schreef op 04 februari 2004 @ 18:39:
Amd 2500
tja @ def speeds had ik geen problemen met welke bios dan ook. Maar ik moet wel zeggen dat voor oc er zeker verschillen zijn. probeer de 12-10 mocht dat niet lukken kom ik wel ff een keer langs.
Astennu schreef op 04 februari 2004 @ 18:42:
Nou het is me gelukt , eindelijk .
Het lag aan de abl van de harddisk. Toen we die hadden ingesteld in de bios liep het ding opeens wel weer door 8)7 .
Snap er niet veel van , maar ben blij dat het ding weer loopt.
  • Vincentio
Hoe goed is dit mobo met overklokken en dan vooral in combinatie met de SATA controller?
Ik word er gek van om de paar dagen weer scandisk enzo voorbij te zien komen, die meld dat er weer fouten zitten op mijn S-ATA disk.... :(
  • Exigence
Exigence
dnkroz
Astennu schreef op 04 februari 2004 @ 17:00:
Ja, en ik kan het weten, want ik heb hem gedaan :)
Dus zet het altijd op de laagste waarde in het BIOS voordat je begint met modden: 2,6v dus.
Dan wordt het 2,6+0,45=3,05 Vddr. Als je me niet gelooft: probeer het maar uit met een 50k weerstand, en je zult het zien.
BTW, die mod is echt de makkelijkste die ik ooit gedaan ehb :)
  • Keen87
Verwijderd schreef op 04 februari 2004 @ 15:48:
daar geloof ik niks van.
ik hield 4700 met een amd athlon thunderbird 1400 jah!!!! en core op 370 (had toen nog stock koeler op me videokaart)
maar ik had toch echt gelezen dat sommige biossen langzaam zijn...en dat een nieuwe bios zou helpen....of niet? :|
welke zijn dat dan?
Keen87 schreef op 04 februari 2004 @ 21:33:
welke zijn dat dan?
Dat had ik niet gepost btw..deed NoStra onder mijn account.
Maar die score klopt wel ongeveer. Je systeem doet namelijk vrij weinig in 2003. NoStra had op een P3 1GHz ongeveer dezelfde score (wel wat lager natuurlijk) als met zn Athlon die dik sneller is.. Daarom is 2003 dus ook niks aan omdat het veel teveel op de VGA kaart hangt. 2001 profiteert veel meer van je systeem.
  • DaOverclocker
DaOverclocker
Spice schreef op 04 februari 2004 @ 11:53:
Waar slaat dat nou op dan? Hoe weet je dat?
Hier zit ook gewoon een Genie bios op, met alle instellingen van voltage etc.
En de infinity A was ook goed te overclocken, revb was alleen met extra gaten in het mobo.
Als hij niet goed over te clocken is wil ik dat wel graag weten, ander koop ik hem voor nix.
systeem specs
doe mij ff mailen???
  • Vincentio
welke zijn dat dan?
Ik install wel effe 3dmark en stel mijn GPU clocks wel in op die van jou. Mijn install is dan wel niet al te netjes en CPU/mem staat niet oc'ed op dit moment, maar dan heb je tenminste een beetje een vergelijking hopelijk.
ok, das dan 5184. Dit met Cat 4.1, geen tweaks en complete windows enzo.
[ Voor 7% gewijzigd door Vincentio op 04-02-2004 23:29 ]
  • Spice
Spice
Northbridge en mosfetcooling (niet allemaal en zeker niet de heetste) maar het is wel mooi om te zien. Poster heeft nog geen CPU maar is toch maar aan het plakken gegegaan -> geweldig >:)
Afbeeldingslocatie: http://www.titansfan098.com/uploader/P1010022.JPG
van: http://forums.amdmb.com/s...3&perpage=15&pagenumber=1
  • Syzzer
  • Laatst online: 11-11 00:18
Syzzer
Prutser
Ik zal binnenkort ook maar eens mijn mosfetjes sinken, maar daar komen wel wat flinkere sinks op dan die mini-profieltjes van die gast.
Toch wel uit verhouding vind ik, zo'n enorme NB cooler en dan alleen ALU profieltjes op die MOSFETS. Maar ach, hij doet maar wat hij leuk vind hé? :D
Wie kan mij even vertellen hoe deze plank op Vdd voltage reageerd?? Schaalt het lekker door als je de Vdd omhoog doet of doet het weinig?
  • Copycat
  • Laatst online: 13-07 00:36
Copycat
Stamgast @ HGGCT
Spice schreef op 05 februari 2004 @ 00:17:
Ik hoop voor hm dat ie daar BH-5 chippies te pakken heeft >:)
P4 2,53 512MB PC3200, GF4 Ti4200
  • Exigence
Exigence
dnkroz
Verwijderd schreef op 05 februari 2004 @ 00:45:
Op 1,7v kan die van mij niet voorbij de 245 MHz opstarten, en op 1,9v niet voorbij de 252 ongeveer. Dus ik heb nog ietsjes meer nodig. Maar er is nog geen Vdd mod :(
  • Remy
Remy
Mijn Ultra B heeft z'n crashtest tot nu toe netjes doorstaan, ik heb hem al met alleen maar wat extra Vcore en Vdimm tot 220 stabiel gekregen :) Vandaag ga ik als ik er tijd voor heb op 230 ~ 240 mikken, dat zal zon 2530 ~ 2640 MHz voor m'n Bartonneke betekenen :)
LinkedIn
Instagram
ReemF schreef op 05 februari 2004 @ 08:11:
Dat kan Harder..... >:)
Ik zit nog te twijfelen tussen de Infinity en de LanParty, maar ik kan nergens vinden of er verschillen zijn in de voltages zonder mod's. Volgens mij gaat VCore bij beiden tot 2V en Vmem tot 3,6V. Ik ben niet op zoek naar alle gadgets van de LanParty en 1GB lan hoeft voor mij ook niet. Iemand een goede reden waarom ik dan LanParty zou nemen?
Verwijderd schreef op 05 februari 2004 @ 13:06:
De pcb is exact 1der.
de voordelen van de lanparty zijn de reset en powerbutton en de leuke kleurtjes.
Daarnaast krijg je er ook een heleboel hebbedingetjes bij.... maar voorals nog zijn beide moederborden het zelfde.
  • Spice
Spice
een detail dan toch: 4 diagnostic LEDs op de LAN, voor mij hoeven ze niet maar het is wel een verschilletje, ik ben overigens best blij met Realtek RTL8110S Gigabit LAN Full duplex support at 10, 100 and 1000 Mbps nu ik een gigabitkaartje in mijn shuttle heb gestopt :).
Staat dus allemaal in de openingspost btw.
welke zijn dat dan?
Ik heb ook 4700 gehaald met een PIII @ 910Mhz op 380 core!!!!! Zegt dus helemaal niets...
  • DaOverclocker
DaOverclocker
Ik wil toch nog wel ff weten waarom een Ultra Al niet goed zou zijn. Als iemand dat weet, mag ie me ook mailen...
systeem specs
  • Exigence
Exigence
dnkroz
DaOverclocker schreef op 05 februari 2004 @ 18:36:
Kun je even uitleggen wat je precies bedoelt :?
  • PASware
  • Laatst online: 13:40
erik9287nl schreef op 05 februari 2004 @ 21:42:
nou hij denkt dat de ultra AL net zo goed overclockt als de Infinity en de Lanparty
Tesla Model 3 SR+ | 4425wp (Dak) - 1920wp (platdak) - 840wp (gevel 90gr) | Panasonic 5kW warmtepomp | Hewalex WPB 200L boiler
kan iemand mij vertellen of de DFI Lanparty NF-II ultra B Nvidia APU soundstorm onboard heeft ?
Spice schreef op 05 februari 2004 @ 13:52:
Er staat heel veel in de openingspost, maar geen gegevens over VCore, VMem, enz. en dat is nou net wat ik wil weten. Blijkbaar lopen ze dus beiden even hard en dat wil ik hebben: een bord wat hard kan.
  • Spice
Spice
Klopt alleen de verschillen staan angegeven, rest is dus hetzelfde :).
DaOverclocker -> Ik ben iet goed gehumeurd, zoek en gij zult vinden. Ik zeg elke keer lees de openingspost, waarom zou jouw plankje daar dan niet bijstaan?
Wacky Systems, de borden gebruiken Realtek ALC650 audio. Je kan wel alle soudstormstuff van Nvidia installeren en gebruiken. Verder kan ik je niet helpen daar ben ik teveel audinoob voor :(. -> http://forums.amdmb.com/forumdisplay.php?s=&forumid=66 voor meer info
[ Voor 6% gewijzigd door Spice op 06-02-2004 00:44 ]
  • _Droopy
  • Laatst online: 08-08-2019
_Droopy
Tweaken of school?,....Hmmm..
Verwijderd schreef op 05 februari 2004 @ 22:39:
check google, dfi.com.tw of de andere bronnen van informatie eens, misschien kom je er zelf dan ook wel achter. :(
[ Voor 7% gewijzigd door _Droopy op 06-02-2004 02:12 ]
Life is but a joke,.... But i see nobody laughing. Specs 3DMark2k1se 21671 3D Mark03 7195
  • gri-
Ik heb nu ook sinds paar dagen een infinity en moet zeggen dat het wel lekker bordje is. Het enige waar ik op het moment tegenaan loop is dat mijn sisoft sandra score voor memory bandwith echt bedroevend laag is.
Draai nu op 9,5x230 (11-3-3-2-2 biosvolgorde met cpc aan) en haal iets van 3200/2900, waarbij dus me efficiency in de 80% zit :(
Heeft iemand goede ideeen? ik draai bios 31/1 en me specs staan in me sig (al is die nf7-s niet meer hier ;))
  • Spice
Spice
cpc uit en fsb hoger (edit)
Command Per Clock Enable” means in the COMMAND and ADDRESS Cycle, the time between current COMMAND/ADDRESS and next COMMAND/ADDRESS is 1 DRAM clock. “Command Per Clock Disable” means in the COMMAND and ADDRESS Cycle, the time between current COMMAND/ADDRESS and next COMMAND/ADDRESS is 2 DRAM clock.
Because the COMMAND and ADDRESS bus loading is much higher than DATA bus, it's more difficult to overclock with double side DRAM because COMMAND and ADDRESS cycle is more difficult to meet the overclocked timing requirement than DATA bus in Double Side DRAM.
When you turn Command Per Clock Disabled, it will be much easier to overclock the DRAM because your DRAM working in 2 DRAM clock COMMAND and ADDRESS cycling. But, you might suffer some performance loss when DRAM is working in RANDOM Access mode because there is a lot of COMMAND and ADDRESS change in RANDOM Access mode
Afbeeldingslocatie: http://www.angrygames.com/pics/CPC.jpg
[ Voor 4% gewijzigd door Spice op 06-02-2004 13:42 ]
  • gri-
Cpc uit maakt het nog lager. Enige wat ik wel heb gelezen is als je het uit doet dat je dan hogere fsb kan halen en daardoor misschien je score kan verbeteren van je oude fsb met cpc aan. Zegmaar net alsof je je cas latency wat lager zou zetten om meer fsb te halen.
  • Exigence
Exigence
dnkroz
Ik kom met CPC uit geen mhz verder dan met CPC aan.
  • gri-
Ik ook niet geloof ik, maar nog niet super getest.
Trouwens ik heb dus een slk900U die niet paste vanwege die condensatoren, maar heb nou me bonnetjes naar thermalright gemaild en ik zou een andere backplate krijgen zodat het wel paste ofzo.
Heeft iemand hier al zo'n backplate gekregen? want snap zelf niet precies hoe dat het probleem met die condensatoren zou moeten oplossen aangezien dat ding even groot blijft ;)
Zat nog ff verder te kijken naar coolers, maar wil liever niet zo'n zwaar ding aan me socket hangen. Zoals bijvoorbeeld de slk900a of de swiftechs. Is mijn vrees gegrond of ben ik gewoon een mietje? Zou niet graag zo'n koeler op de grond willen zien liggen als ik me pc keer meeneem naar lan ofzo.
[ Voor 27% gewijzigd door gri- op 06-02-2004 13:38 ]
  • Maku
  • Laatst online: 04-09 14:34
Maku
Derp
Zolang je m bevestigd met de gaten rondom je socket kan je zolang je voorzichtig doet m makkelijk verhuizen ... alleen moet je bij wat ruiger werk m er toch maar even afhalen ... een Aero 7+ is geen probleem en die hangt alleen maar aan het socket .. al is dat niet met een swiffy te vergelijken ..
  • Exigence
Exigence
dnkroz
Shit, ik had de boel even weer oc'ed, alles verliep voor de rest goed.
2728 MHz
2,08 Vcore
3,55 Vddr
1,9 Vdd (@ 248 MHz)
En ineens valt hij uit..... :( Dus ik de boel resetten... niks FSB jumper veranderd.... niks. BIOS gereset.... niks. ATX reset... niks.
Alle fans gaan wel draaien, en de lampjes branden ook, maar voor de rest is er geen beweging in te krijgen. Ik heb hem nu op reset staan, ik zal 'm even een half uurtje daarop laten, met de stekker eruit. En dan even weer kijken.
Naja, anders wordt het een RMA.... naar Duitsland :X :/ Eigenlijk kan me het niet zo veel schelen, misschien krijg ik dan zelfs een betere 8)
  • gri-
Ik zou zeggen reset de bios nog een paar keer.
Had zelf namelijk ook gister dat ie niet wilde opstarten.. bios reset.. nog niet toen nog wat gekloot met aan uit en nog een reset en toen ging ie weer :)
Maare niemand een idee over me slechte memscore?
  • Maku
Maku
Derp
erik9287nl schreef op 06 februari 2004 @ 14:04:
2728 MHz
2,08 Vcore
3,55 Vddr
1,9 Vdd (@ 248 MHz)
Hoe kom jij bij duitsland dan ??? in rotterdam zitten ze ook naast tweakstore :)
  • Exigence
Exigence
dnkroz
gri- schreef op 06 februari 2004 @ 14:17:
Ja, die BIOS heb ik al 5 keer gereset ofzo. Ik laat hem nu nog een tien minuten op de reset en dan zal ik eens kijken.
  • Exigence
Exigence
dnkroz
Maku schreef op 06 februari 2004 @ 14:19:
Ja, maar hij moet toch terug naar Reichelt? Of kan ik hem direct naar de DFI importeur sturen?
(En ik weet dat ze naast tweakstore zitten ja ;) )
  • Maku
Maku
Derp
erik9287nl schreef op 06 februari 2004 @ 14:20:
Nou ik heb m via tweakstore gekocht en hun LOPEN er even heen met het bordje :D ( in mijn geval iig )
  • Syzzer
Syzzer
Prutser
Maku schreef op 06 februari 2004 @ 14:27:
Lopen :? Ik dacht dat DFI in de Botlek zat. Maar als het in de buurt is, kun je zowiezo een poging wagen.
  • Exigence
Exigence
dnkroz
Maar ik woon in friesland :+
Edit: nog niks, ik vermoed dat hij dood is :(
Ik zal eens met tweakstore mailen of zij het adres enzo weten van DFI
[ Voor 21% gewijzigd door Exigence op 06-02-2004 14:37 ]
Leuk bordje die Infinity. Heb hem er net een paar uurtjes in. Dit is wat ik tot nu toe heb:
Afbeeldingslocatie: http://www.fewture.cistron.nl/10x252sisoft.JPG
Niet slecht voor CH-5 op 3.2V. CPU wil niet echt harder..maar es op 9,5 verder pielen. 9,5 x 250 was pifast stable. De screenshot hierboven is aardig onstabiel..Vcore modje zal uitkomst bieden denk ik.
Vdd @ 1.8 btw
Ow en mn voltages zijn gaaaar..niet te doen :(
[ Voor 9% gewijzigd door Verwijderd op 06-02-2004 17:30 ]
  • gri-
Ziet er goed uit :)
En dat voor er net mee kloten ;)
Heb troouwens me lage memory score opgelost ... het kwaad heet 3.13 nforce drivers. Installeerde 2.45 van de cd en me memory score vloog omhoog \o/
gri- schreef op 06 februari 2004 @ 17:39:
Ziet er goed uit :)
Joh..ik draai ook met 3.13 :D
2728 MHz
2,08 Vcore
3,55 Vddr
1,9 Vdd (@ 248 MHz)
Laat nou eens wat resultaten zien...je beweert dat je een 52er hebt neergezet met pifast, maar heb nog geen screenshot gezien.
Ok..nu met nForce 2.45.. 40MB/s erbij.
Afbeeldingslocatie: http://www.fewture.cistron.nl/10x252sisoft2.JPG
FSB maar wat omhoog dan :)
Afbeeldingslocatie: http://www.fewture.cistron.nl/10x254sisoft.JPG
Pifast:
Afbeeldingslocatie: http://www.fewture.cistron.nl/10x249pifast.JPG
250MHz wilde net niet.. bij step 0 klapte hij eruit.. Waarschijnlijk Vcore te laag :D
MP 9,5 dan maar aangezien mn proc het niet trekt op 2.0V:
Afbeeldingslocatie: http://www.fewture.cistron.nl/255pifast2.JPG
256 draaide hij uit, maar met "Error in computation"..helaas..
[ Voor 81% gewijzigd door Verwijderd op 06-02-2004 19:35 ]
  • Exigence
Exigence
dnkroz
Verwijderd schreef op 06 februari 2004 @ 17:44:
Ja, nu issie dood :P
Geen beweging meer in te krijgen. Zal morgen even met DFI Nederland mailen.
Ik had geloof ik al eerder gezegd dat die 52.91 bij het starten van CPU Z vastliep, superinstabiel dus. Later had ik wel een screenshot (52.85) maar toen liep de boel bij paint vast :(
En ik wachtte nu weer op koud weer. Dit weekend zou het 's nachts 1 graad worden, dus ik kon weer.
Maar da's nu allemaal voorbij, nu kan ik weer wachten. :(
Verwijderd schreef op 06 februari 2004 @ 17:28:
Vdd @ 1.8 btw
Ik had op 250 een iets hogere score, met CH-5 @ 3,3v. En ik heb ook gemerkt dat de verschillende lijnen enorm belast worden ja. 12v @ 11,78 en 5v @ 4,82 bij mij.
En nee, weer geen screenshot, omdat ik nog druk bezig was, en ik dacht dat ik nog wel iets kon verbeteren. :/
[ Voor 45% gewijzigd door Exigence op 06-02-2004 19:18 ]
erik9287nl schreef op 06 februari 2004 @ 19:14:
Ja..drivers.. Zie de screen eronder. Draaide jij ook dezelfde MP? Want dat scheelt ook flink.
  • Spice
Spice
beetje offtopic maar wel leuk, zat in mijn mail:
Afbeeldingslocatie: http://www.thermaltake.com/images/accessories/hdcooler/hc12/hardcano12a.jpgAfbeeldingslocatie: http://www.thermaltake.com/images/accessories/hdcooler/hc12/hardcano12b.jpg
en
http://www.thermaltake.com/accessories/xray.htm -> flash
Afbeeldingslocatie: http://www.thermaltake.com/images/accessories/xray/F-beverageTray.jpg met daarnaast
Afbeeldingslocatie: http://www.thermaltake.com/images/accessories/xray/F-lighter.jpg, mm wordt het moeilijker om te stoppen :)
[ Voor 11% gewijzigd door Spice op 06-02-2004 19:35 ]
  • Tjaps
Tjaps
Snap ik toch...
Verwijderd schreef op 06 februari 2004 @ 17:58:
Pifast:
Woei :9~ :9~ :9~
Nice hoor nu nog ff wat meer vcore en dan word het helemaal leuk.
Ik kan echt niet wachten totdat ik volgende week me bordje terug krijg van de RMA :D
  • Exigence
Exigence
dnkroz
Verwijderd schreef op 06 februari 2004 @ 19:34:
Ik draaide met een MP van 10 of 10.5, dat weet ik niet meer. Maar hoog genoeg, om maar niet in CPU snelheid achter te blijven. Ik was nog lang niet uitgeklust, dus het was nog maar een vluggertje.
erik9287nl schreef op 06 februari 2004 @ 19:52:
Ja..ik draai 10 omdat ik aan mn cpu Mhzen vastzit met die lage Vcores.. Op 10,5 em wel hoger. Straks ga ik ff de nieuwe bios flashen en op 9,5 benchen.
  • Exigence
Exigence
dnkroz
Het probleem is dat ik doordeweeks niet achter de computer mag :( Anders had ik al lang resultaten gehad.
Nu moet ik dus alles in het weekend doen, en als het even tegenzit (zoals vorig weekend) dan moet ik dus weer een hele week wachten :/
Edit: batterij er driekwartier uit gehad -> nog niks
[ Voor 11% gewijzigd door Exigence op 06-02-2004 20:07 ]
Ok frank en de rest van het weekend ga ik hopelijk is een keer tijd vinden om mijn infinity in te bouwen, ik wil nog geen Vcore mod doen omdat die meschien nieteens nodig is. wel wil ik heatsinks plakken, zijn er nog bepaalde mosfets/chips die worden aangeraden om te heatsinke? (het makkelijkst is ff picca maken in paint en die chips/mosfets rood te kleuren)
  • Exigence
Exigence
dnkroz
Verwijderd schreef op 06 februari 2004 @ 21:58:
Ik zou een grotere heatsink op de southbridge plakken (zelf heb ik hem actief gekoeld met een zwart aluminium 4x4 blokje en een 4x4x2,5 Sunon)
En de mosfets hoeft niet echt, die worden handwarm, maar als je ze toch wilt doen, ik zou gewoon alle chips en mosfets in de buurt van de 12v stekker een leuk metalen dakje geven.
erik9287nl schreef op 06 februari 2004 @ 22:04:
En de mosfets hoeft niet echt, die worden handwarm, maar als je ze toch wilt doen, ik zou gewoon alle chips en mosfets in de buurt van de 12v stekker een leuk koperen / aluminium dakje geven.
  • Exigence
Exigence
dnkroz
Ik zei metaal om het algemeen te houden, jij mag kiezen wel metaal, koper of alu dus :P
erik9287nl schreef op 06 februari 2004 @ 22:24:
mijn voorkeur is koper natuurlijk maar die dingen die ik heb zijn alu, maarja ze worden niet uber heet dus veel verschil zal het niet maken ook.
  • Tjaps
Tjaps
Snap ik toch...
Mosfets en andere componentjes worden amper warm (op dit bord) denk dat je met het koelen ervan bar weinig op gaat schieten.
  • _Droopy
_Droopy
Dit is voor mij weer ff een nieuwe score.
Afbeeldingslocatie: http://home.hetnet.nl/~ayhks/Pictures/OC/PiFast-243x11=52,39_Bios1-12.JPG
Afbeeldingslocatie: http://home.hetnet.nl/~ayhks/Pictures/OC/3DMark2k1-240x11=21671_Bios1-12.JPG
Compare
Afbeeldingslocatie: http://home.hetnet.nl/~ayhks/Pictures/OC/3DMark03-240x11=7009_Bios1-12.JPG
Compare
Afbeeldingslocatie: http://home.hetnet.nl/~ayhks/Pictures/OC/CPU-240x11_Bios1-12.JPG
Afbeeldingslocatie: http://home.hetnet.nl/~ayhks/Pictures/OC/MemBW-240x11_Bios1-12.JPG
als ik mijn eigen PiFast score bekijk, en dan bedenk dat erik9287nl ook in de 52.xx scored, word ik steeds benieuwder wat ik dan fout doe met m'n prom-setup :X
  • SlowikPL
Ik van plan een geheugen kopen 1024MB , voor mijn Lanparty NFII Ultra B.
Wie kan mij vertellen wat het beste op de maakt is voor -/+ 250 EUro :) voor dit bord tbv. OC-en :?
  • iets
  • Laatst online: 15-11 00:47
Ik heb laatst een systeem in elkaar gezet voor een vriend, met als moederbord dus zo'n infinity.
Prachtig bordje, ook 100mhz fsb jumper is erg handig.
Alleen nu krijg ik het ding niet harder dan zo'n 225Mhz. Hij boot wel tot 235Mhz, maar dat is niet stabiel. Ook niet als ik hem 1.9V toedien.
Het is wel vrij warm in de kast. Geen casefans dus het ding staat atm nog ffkes gewoon open :X. System (NB?) temp is zo rond de 50C.
Verdere specs:
- Athlon 1800+ @ 10x225
- Aero 7+
- 2x 256MB Twinmos PC3200
- Enermax 350W
- GF4MX
- Maxtor 7.2K RPM 8MB
Is dit nu gewoon een slechter exemplaar of heb ik iets over het hoofd gezien?
tvw
SlowikPL schreef op 07 februari 2004 @ 03:47:
Als je het beste wil moet je 512 mushkin nemen.. 1GB is toch way overkill voor een bench systeem.
nu met bios 1-31 en MP 9,5..omfg.. CH-5 madness.. 8)7
Afbeeldingslocatie: http://www.fewture.cistron.nl/255sandra131bios.JPG
Morgen Vmods!! :D
[ Voor 23% gewijzigd door Verwijderd op 07-02-2004 05:41 ]
  • petervandamned
  • Laatst online: 02-11 12:07
Het gaat de lekker zo :) en je heb hem pas dus potentie genoeg.
ik heb net een mailtje gestuurd naar thermalright met mijn aankoopbon.
met een beetje geluk heb ik snel een nieuwe backplate,
als ik het goed versta past de slk947U eigenlijk perfect behalve dan dat de backplate ietwat uitzit bovenaan ,maar normaal is het geen probleem rond de gaten? of juist een beetje de vlootjes bijslijpen maarja.
  • DaOverclocker
DaOverclocker
Spice schreef op 06 februari 2004 @ 00:43:
In de openingspost staat ie niet.
ik wel heb het wel over de NFII Ultra AL, dus niet over de lanparty versie!
We hebben het hier aldoor over de lanparty en de infinity, maar er is dus ook nog een DFI NF-II Ultra-AL (Sound + LAN + SATA).
Over dit bord kan ik nix vinden op inet, blijkbaar gaat iedereen altijd voor de lanparty. Maar hij heeft verder dezelfde dingen als de andere 2. Ik zou niet weten waarom deze minder zou presteren als een Infinity of een lanparty Ultra B.
Er was iemand die zei dat dit bord oud was, en daarom slecht overclockte. Ik zou graag willen weten waar ie dat vandaan heeft.
systeem specs
DaOverclocker schreef op 07 februari 2004 @ 12:38:
Das dus een Infinity.. De planken zijn exact hetzelfde op de kleur en 2 knopjes na.
ff wat anders: hebben jullie ook van die brakke voltages?? Bij mij is dus gewoon alles veel te laag. Nu is mn voeding al tijden wat aan de slappe kant, maar ook op lagere OC's is het ruk :(
  • Exigence
Exigence
dnkroz
Verwijderd schreef op 07 februari 2004 @ 12:43:
Klopt ja, dit bord vreet echt van je voeding als een gek.
Ikzelf heb een CWT 480 Watt en dan nog zit de 12v rond de 11.8, de 5v rond de 4.8 en de 3v rond de 3.1
_Droopy schreef op 07 februari 2004 @ 01:43:
Jij hebt een Barton ten eerste, dus dat betekent dat je zowieso al een seconde sneller bent op dezelfde clocksnelheid. Ik draaide zo rond de 52.8 - 52.9, ik had iets meer FSB en een hogere clocksnelheid, dus je doet niks fout, je kloksnelheid zit alleen wat tegen. Dat haal ik op water :P
[ Voor 47% gewijzigd door Exigence op 07-02-2004 13:42 ]
  • SlowikPL
Verwijderd schreef op 07 februari 2004 @ 05:14:
Morgen Vmods!! :D
mushkin 512MB is voor mij echt te weinig :(
En de 1024MB Level 2 reepjes kosten meer als 400 Euro :?
Morgen Vmods!! :D
Hmm...je hebt me nu :(
  • Exigence
Exigence
dnkroz
SlowikPL schreef op 07 februari 2004 @ 13:41:
Hoezo is 512MB te weinig, ik heb zelf al een hele tijd 512MB en nooit behoefte gehad aan meer, kan alleen maar een barriere opleveren. Maarja, ik weet niet wat jij met je sys wilt doen.
  • Spice
Spice
Klopt nix van. Hij bedoelt NFII ULTRA-AL en dat is precies wat ik zeg een verouderd plankje.
http://www.dfi.com.tw/Pro..._r_us.jsp?PRODUCT_ID=1882 en heeft dus 0,0 met de infinity en de lanparty rev. B te maken!
Afbeeldingslocatie: http://www.dfi.com.tw/Upload/Product_Picture/NFII%20ULTRA-AL%20b.jpg
Daarom staat deze plank ook NIET in de openingspost, die is goed daar staan gewoon alles in wat tot-nu-toe bekend is.
Serenity er loopt een draadje over voeding(psu) voor de infinity/lan B op: http://forums.amdmb.com/s...ad.php?s=&threadid=295107
Iedereen is erg te spreken over Fortron, ik weet niet of die hier te krijgen zijn. De voeding die ik heb en wel meer die-hards hier een Antec True Control 550 (met regelbare 3,3/5,0/12,0 volt lijnen) doet het ook erg goed ik heb netjes 3,35. 5,02 en 11,97. (alles helemaal open).
Vanmorgen 2e ide-kabeltje in de bus, netjes!
Wel een tegenvaller, ik heb 2e oude hyperX 3000-reepjes die BH-5 zouden moeten zijn, die doen met met veel pijn op 220 gekregen, een tegenvaller dus. Ik ga komende week mijn infineon 2700 DDR (usa) proberen terug te krijgen.
Tweetyor, plaatje van de backplate die goed past:
Afbeeldingslocatie: http://www.angrygames.com/images/thermalright/thermalright947-1.jpg
[ Voor 20% gewijzigd door Spice op 07-02-2004 14:56 ]
Spice schreef op 07 februari 2004 @ 14:02:
Denk om je bloeddruk man.. ;)
Ja..ik zal es kijken. Ik heb nu een CWT380. Een TC is leuk, maar ik ben niet gek. 150 euro voor een voeding |:( Een CWT550 is exact hetzelfde en kost 50 euro minder. En die TC moet je nog steeds modden trouwens.
Schop! >:)
Het moest er van komen natuurlijk.. :D
Afbeeldingslocatie: http://www.fewture.cistron.nl/4K.JPG
