Afbeeldingslocatie: http://www.frontierlabs.com/Img/modeltopIA_01.jpg
Een nieuwe mp3 speler van Frontier Labs, de opvolger van de NEX IIe. Deze heeft een fm radio en kan opnemen. Het lijkt me niet echt een heel mooi apparaat, maar ik denk dat 'ie qua prijs erg goed te doen is.
Jullie mening?
  • nikao
  • Laatst online: 10-02-2022
tsja.. wat is de afmeting.. heeft ie intern geheugen? .. gewicht?.. batterij?.. enz. enz. ..
oftewel .. SPECS! :)
Van de website:
Distortion rate... <0.05% at 32 ohm
Signal to noise ratio: 95dB
Maximum headphone output.. 30mW@32ohm
Frequency Range.. 20Hz to 20KHz
Ave. play time (2XAA alkaline).. 13 hours /w CF card; 7 hours using 1 GB Microdrive
USB transfer rate.. approximately 400 KBPS
LCD display.. 132X64 bitmapped
http://www.frontierlabs.com/NEXIA.html
Afbeeldingslocatie: http://www.frontierlabs.com/headnexia.jpg
4 in 1 Capability – NEX ia is a full featured digital music player with FM tuner, voice/FM recording and doubles as a portable drive for fast & easy file transfer and storage.
Remote Control – NEX ia comes with a separate remote control with a shirt clip so you can control your audio ever more so easily.
Flexible – New firmware design to support multiple folders, access of menu functions during song playback and other unique and improved features.
Infinite memory & storage expansion configuration with Type I & II Compact Flash memory cards or MicroDrivesTM (currently up to 1 gigabyte)
Simple drag & drop file transfer on Windows Explorer via ultra fast USB mode. No proprietary software needed.
Compact ergonomic design, super light, and portable. Intuitive controls with a single 5 way jog lever, operable with just your thumb, for easy, direct and precise control of your audio.
Fully interactive high-resolution LCD user interface: 132x64 matrix. Configurable (normal, always on, always off) Neon blue EL backlight that can display scrolling ID3 tags, song duration, memory level, battery level, and more!
5 band user programmable equalizer with 5 preset sound modes: Jazz, Rock, Classic, Dance, and Latin
Compliance with ID3 tags. Plays bitrates up to 320kbps and VBR for MP3 files.
Smart play functions (normal, repeat one, repeat all and shuffle)
Supports multiple formats (MP3 and WMATM)) and emerging formats such as Ogg Vorbis through firmware upgrades.
Solid state construction with no moving parts
"Smart Power" - Draws power from USB. This not only allows you to save battery life during song transfers but it can also power itself via AC power adapter.
  • MaDLiVe
  • Laatst online: 09:40
MaDLiVe
.-Observer-.
De schoonheids prijs wint hij iig niet. Maargoed de NEXII(e) waren beide een groot succes. Budget, goeie geluidskwaliteit, en cf expansion. Helaas waren ze beide nogal buggie.
Leuke verbeteringen:
-remote (ja wat voor 1)
-fm tuner
-fm/voice recorder
-Yay, ogg vorbis ondersteuning in de toekomst.
-Usb 2.0 (400MBPS?)?
Ik hoop dat hij ook nog in het zwat komt, dat wit is zo een vies kleurtje.
{\/}/-\[) [_[ \/(-© - Turn off your mind, relax and float downstream. Volg mijn disease outbreak detective en andere geweldige Avonturen
  • Haaguit
  • Laatst online: 03-10 18:08
Haaguit
HBZNPLT!
Nice! Zeker het overwegen waard als vervanger van mijn NexIIe als hij een beetje betallbaar en leverbaar is!
Snelle pc | 40D achterdop voor lenzen
  • henkleerssen
henkleerssen
Your life is as you narrate it
beetje camp.. dat wit ja...als er een ander kleurtje op zat.. dan is het weer te overwegen.. (ondanks dat ik al de nex II heb)..
noem de prijs maar, denk op zich als ie betaalbaar is dat er genoeginteresse is
  • nikao
tering wat een lelijk ding is het zeg.. snap gewoon niet hoe sommige bedrijven met dingen op de markt komen als je bijvoorbeeld de I-Bead of de Mpio's ziet.. das pas design..
Ja hoor, net de Nex iie ontvangen (gisteren) en nu is er een nieuw model :'(
Met radio nog wel.
  • the_Omniscient
  • Laatst online: 16-02 10:11
the_Omniscient
Geen oplossing zonder probleem
Spelertje op zich is goed aan te zien. De in-wire-remote is denk ik zo'n beetje de lelijkste die ik de afgelopen tijd hebt waargenomen. Soort van telefoonkabel met daaraan een parkeermeter. Die gare oordoppen van de NexIIe zitten er ook nog bij.
Voordelen: ik denk dat in het zwart een stukkie mooier zal zijn, blauw backlit LCD + zwarte behuizing doet het veel beter. Daar heb je gelijk het 2e voordeel: het LCD'tje is mooier dan bij de NexIIe. Het geheel ziet er iets robuuster uit. CF I & II + MicroDrive met acceptabele "recharge-rates": enorm pluspunt.
Als de prijs ook nog eens mee gaat vallen, tja: ik zou niet zien waarom je hem dan tenminste niet zou kunnen proberen, mocht het nodig zijn.
Schrijveralijeren | Hier stond een wijze sig
  • the_Omniscient
the_Omniscient
k*t, quote ipv edit, is me ook nog nie zo vaak overkomen... Hier komt ooit iets nuttigs te staan.
[ Voor 90% gewijzigd door the_Omniscient op 10-04-2003 13:56 ]
NEX IA Digital Audio Player US$139.00
NEX IIe Digital Audio MP3 Player - US$115.00
Niet veel meer dus t.o.v de nex IIe maar wel veel leuke extra's voor dat geld.
  • Haaguit
Haaguit
HBZNPLT!
Ik denk dat de Ia ook wel in het zwart uit gaat komen hoor. Zijn er ook nex skins te gebruiken? Met beeteje photoshoppen kan je best aardig eigen skins maken namelijk. Voor de IIe komt voor einde Q2 een nieuwe firmware uit trouwens.
  • Freehumor
  • Laatst online: 12:45
Freehumor
koekwous
Wat meer info nadat ik een mailtje had gestuurd.
Ze reageerde nog binnen 30minuten!
Dear Sir,
- The dimension is 80mm x22mm x 65mm.
- Only in white now.
- There are a 5 band adjustable equalizer.
- We are working on Ogg Vorbis now and will release it as a firmware upgrade.
- NEX ia is a new and improved design over NEX IIe.
- It supports ID3tag v.2
- The recording is 64Kbps.
- You may pre-order one right now at our online store at www.store.yahoo.com/frontierstore. Or you may wait until our resellers get the players from us.
Thank you.
Customer Support
Frontier Labs.
Jammer dat die nu nog alleen in het wit verkrijgbaar is. Want eigenlijk ziet dat ding er niet echt mooi uit. Het leek me dat die in het zwart nog wel zou meevallen.
Jammer is ook dat het opnemen in slechte kwaliteit is en dat je geen eigen equalizer kan maken.
Ogg Vorbis ondersteuning binnenkort, is natuurlijk wel weer helemaal perfect! Net zoals het formaat.
Opzich klinkt het allemaal erg goed, echter die firmware update wil ik eerst ook echt zien, net zoals die voor de nexIIe.
  • the_Omniscient
the_Omniscient
Freehumor schreef op 11 April 2003 @ 18:56:
Ehrm, 5-bands equalizer houdt mijns inziens in, dat je gewoon die "banden" (100 Hz, 10 KHz etc) zelf in kunt stellen, ipv of naast de gebruikelijke presets (pop, rock etc).
Ogg Vorbis gaat tegenwoordig iedereen ondersteunen, ik hoop dat het waar is: dat zou idd een enorm pluspunt zijn.
Wat ik persoonlijk onbegrijpelijk vind, is de plaatsing v.d. koptelefoon-uitgang! Wie zet zoiets nu aan de onderkant van een speler neer? Das werkelijk de stomste plaats van allemaal, zo gaat je draadje+koptelefoonaansluiting behoorlijk snel naar de gaar... of je moet de speler op z'n kop blijven houden... 8)7 ... dan werkt het wel goed.
  • Freehumor
Freehumor
koekwous
the_Omniscient schreef op 11 April 2003 @ 19:43:
Tja, ik vroeg in mijn mailtje of gebruikers hun eigen equalizers konden maken. Hij gaf als antwoord: There are a 5 band adjustable equalizer.
Zie website, dus ik denk dat het wel waar is.
Ja das een goed punt. Niet echt over na gedacht bij het ontwerpen. Ik vind het ontwerp nou ook niet echt: "yooo, das is nu ipod design". Het ontwerp is in mijn ogen matig. Maar dat weegt niet op tegen de voordelen.
Hopelijk brengen ze een zwarte versie uit. Dan zie je niet in het donker dat die lelijk is O-)
  • Aidix
  • Laatst online: 11:10
Aidix
Geluidspietlut
2stuks aa alkaline in 13 uur????
Een MD speler doet iets van 50 uur op 1 aa, en dat is niet eens solidstate :D
[ Voor 17% gewijzigd door Aidix op 11-04-2003 21:03 ]
  • Tranquility
  • Laatst online: 14:37
Een MD speler 50 uur op één AA batterij? Zal er wel geen bas inzitten om over een fatsoenlijk volumeniveau maar te zwijgen...
Maar prachtig spelertje die nieuwe NEX!
Groot voordeel is dat er teminste normale AA penlitebatterijen ingaan i.p.v. die irritante kleine AAA die ze steeds vaker gebruiken. De capaciteit van oplaadbare AAA is gewoon veel te laag (hooguit 700 mAH waar AA tot 2100 mAH gaat) En door er twee te gebruiken heb je teminste nog wat power over om een fatsounlijke bas te krijgen, die bij de 1-batterij spelertjes vaak ontbreekt. Ik heb een Nex II gehad die perfect klonk. Alleen op héél zacht volume kon je tijdens stille passages digitaal geruis horen, dus wanneer ik naar rustige muziek luisterde. Daarom heb ik hem toen maar weer verkocht. Van anderen hoorde ik dat dit probleem bij de Nex IIe nog steeds niet opgelost was. Ook het batterijvakje was een crime! Erg fragiel en je kon de achterste batterij er heel moeilijk uithalen. Hopelijk is dat bij deze nieuwe speler opgelost.
Mij maakt het iniedergeval weinig meer uit, ik ga toch voor een harddisk based player, de MamboX met 20Gig HDD :P
[ Voor 16% gewijzigd door Tranquility op 12-04-2003 03:31 ]
  • armageddon_2k1
  • Laatst online: 06-07 10:25
Aidix schreef op 11 april 2003 @ 21:03:
Ja, maar zo'n ding hoeft dus ook niet mp3 te encoden en is eigenlijk te vergelijken met een gewone CD speler. Hij draait gewoon een dingetje rond en daar kan ie het direct vanaf lezen.
Engineering is like Tetris. Succes disappears and errors accumulate.
  • Tranquility
Niet helemaal waar. Hij moet ook nog het geluid wat geëncodeerd is in ATRAC weer decoderen. Maar het blijft een hele prestatie, dat batterijverbruik, hoewel het dus jammer is dat daardoor de output erg zwak wordt. En Sony heeft al een reputatie van portable audio met een erg zachte output. Dat was vroeger al zo met hun cassettewalkmans die als eerste op één batterijtje konden lopen... Basweergave? wasda?
zo lelijk ziet ie er toch ook weer niet uit :?
  • Freehumor
Freehumor
koekwous
Verwijderd schreef op 12 April 2003 @ 11:58:
Je hebt wel een beetje gelijk. Als je er andere oordoppen bij doet, dan ziet het er al een stuk beter uit.
Maar dit plaatje, vind ik toch wel über lelijk:
Die headset, het telefoondraadje en de knoppen in het snoer. Bah. :r
Als je die dingen wegdenkt, dan kan het nog wat worden :D. Tis gaat tenslotte wel om de specs. En die zien er zeer indrukwekkend uit. _/-\o_
Trouwens is het kunstof of is het aluminium? Neem aan dat het kunstof is.
[ Voor 30% gewijzigd door Freehumor op 12-04-2003 16:12 ]
Hey,
Mijn Frontier labs Nex II is net naar de klote, en ik was er wel te vreden over, en heb het geheugenkaartje 'over'. Nu overweeg ik een NEX IIe Te kopen, of te wachtten op een NEx IA. Wat adviseren jullie?
  • Freehumor
Freehumor
koekwous
Verwijderd schreef op 13 April 2003 @ 17:17:
Hey,
Ik zou voor de NEX IA gaan.
De redenen:
- fm tuner
- kleiner (?)
- voice recorder
- ID3tag v.2
Voor de prijs hoef je het niet te laten. Zie hun website:
http://www.store.yahoo.com/frontierstore/
- NEX IIe $115
- NEX IA $139
  • Tranquility
Bovendien heeft de Nex IIe nog steeds hetzelfde probleem van de "digitale ruis" bij stille passages, net zoals bij de Nex II. Dus ook daarom een reden om nog even te wachten op de Nex IA, teminste dat is wat ik zou doen.
  • Haaguit
Haaguit
HBZNPLT!
Definately de NexIA. Vooral die tuner is relaxed als je de mp3 een beetje zat bent. Hij kost erg weinig meer, dus ik zou wachten.
  • Freehumor
Freehumor
koekwous
Waar zou ik de NEXIA kunnen verkrijgen? Graag wel in Nederland.
[ Voor 45% gewijzigd door Freehumor op 15-04-2003 09:48 ]
  • Tranquility
Is er nog niet...
  • Jaded
  • Laatst online: 07-05 10:59
Wanneer zou ie er wel zijn dan? :(
Op de website vind ik dit:
ALL ORDERS ARE SCHEDULED TO SHIP ON APRIL 30TH, 2003
http://www.store.yahoo.com/frontierstore/nexiadigaudp.html
[ Voor 69% gewijzigd door Jaded op 30-04-2003 10:58 ]
Gadverdamme wat ziet dat ding er lelijk uit!
Het lijkt wel een speelgoed mp3 speler, kom nou met zo een ding zou ik dus nooit rond gaan lopen. En die rare telefoon draad, hoe komen ze erop?? |:(
/me zweert trouw aan zijn nex2e
  • tweak_dude
  • Laatst online: 11:06
Cool, de rest van de specs is bekend (gewicht en afmetingen):
Dimensions.. 3.1"(80mm) X 2.5"(65mm) X 0.9"(22mm)
Weight.. 3 oz (80 grams)
Best klein dus :)
  • smallboy
  • Laatst online: 15-11 07:29
smallboy
N/A
Vanaf maandag is ie leverbaar bij mp3cdspeler.nl, volgens de site... De nexIIe gaat er bij hen uit.
van de site:
03 Mei 2003,
Vanaf maandag leverbaar Frontier Labs NEX IA. De 25,- euro goedkopere NEXIIe komt dan te vervallen.
Hmmz wel weer 25 euro meer... Maar ja hij kan nu ook meer. Al vind ik die draad erg lelijk van de afstandsbediening. Maarja de echte tweakert doet er gewoon een andere draad aan.
[ Voor 63% gewijzigd door smallboy op 03-05-2003 09:02 ]
Lijkt me wel een fijn spelertje. Heb 'm vandaag besteld, ik post mijn ervaringen wel hier. Iemand trouwens al een review gevonden van het dingetje? Ik vind niks nuttigs met Google...
  • smallboy
smallboy
N/A
Nee ik heb ook nog geen reviews gevonden. Ik w8 vol spanning op je ervaringen. Ik zit zelf ook aan deze speler te denken. Maar aan de andere kant is de Nex IIe weer 40 euro goedkoper. Hmmz...
  • tweak_dude
smallboy schreef op 06 May 2003 @ 13:30:
Nah, die 40 euro boeien me niet zoveel ik hoop iig dat die nex ia wat steviger is dan die nex IIe, want daar scheen het batterklepje het na een tijdje te begeven.
Ik ben benieuwd wat Bollino er van vind, want dit lijkt me een flex dingetje :)
  • Jaded
Ik heb de NexIIe en het batterijklepje is wel redelijk solide volgens mij, als je er normaal mee omgaat :D
  • Maestro.mosjuh
Haaguit schreef op 11 April 2003 @ 09:21:
weet je ook wat die firmwareupdate voor een goeds brengt?
ik bedoel, een nieuwe firmware uitbrengen, ok.... maar als er niets verbeterd word.
zit ik eigenlijk al een tijdje op te w88, op een nieuwe firmware.. weet eigenlijk nieteens waarom :X :P
At the beginning there was nothing. So God said 'apt-get install light'.
vaag, net een helemooie post geschreven, klik op de knop, alles foetsie.... 8)7
morge maar weer probere
  • pvdlaan
  • Laatst online: 14-11 19:35
heeft iemand hem al ontvangen ...
zoja wat zijn jullie bevindingen ervan ?
zit er toch ook serieus over te denken, zeker na de goede reakties van de nex II(e)
Xbox One X | iPhone 12 | iPad Pro 11 | MacBook Air M1 | Sony HX50v | Sony HX400
  • DenniX
  • Laatst online: 17-11 20:16
Ik wil ook graag een review zien hiervan!! Ik ben namelijk erg aan het twijfelen tussen deze en de Ibead.
Over de I-bead zijn heel veel positieve reacties, dus dan heb ik zeker geen miskoop, maar toen ik deze zag (de specs dan :) ), leek me deze ook wel heel fijn..(uitbreiding mogelijk met CF kaartjes!! en universele batterijen :) !!)
Ik zie dus ook HEEL graag wat ervaringen van jullie!!!
ik heb gisteren reactie van de fabriek terug gehad, op de vraag of er ook 4 gig microdrives in kunnen van hitatchi, en, eh.......ze hoeven aleen maar de firmware aan te passen!!!!
ze zijn bezig met een ogg vorbis verie van de firmware.
ze zijden ook nog : we may concidder to produce an black version of th AI in the future.
een zwarte!!!, ieddereen die hem wil hebben, mailen naar frontierlabs dus!!!!
  • tweak_dude
Heeft iemand hem nou al?
ik ga hem kope, ff w8te tot ik me gba heb verkocht, btw, 135,- inc. 6 games en 100% gegarandeerd on bekrast ;) :9 8)7
(weet niet of ik nu de regels overtreed)
ik schrok even van de prijs 159,- euro voor 0MB , maar als je even verder kijkt dan is de 128MB 179,- euro of de 256MB 209,- en dat vind ik dan weer 'goedkoop'.Die CF kaartjes zijn tegenwoordig echt goedkoop een half jaar geleden was het echt absurd duur.
jah, eerst was de prijs van een 256 versie van de IA 219.-, nu is het ineens 209!!!!!!!!
maar de prijs van de bare mp3 speler is helaas nier veranderd 8)7
heb dus op een duitse site gevonden dat hij met een 1800 mah paar baterijen 20 uur kan draaien (cf) :
Betriebsdauer (mit 1800 mAh NiMH) mit CF-Karte: bis zu 20 Stunden; mit 1GB Microdrive: bis zu 8 Stunden
of ben ik nou gek?
mischien met het geluid heel zacht?
  • tweak_dude
* KICK *
Bollino op maandag zei je dat je hem besteld had. Heb je um nog niet binnen? Ik ben echt benieuwd namelijk...
  • Piggen
  • Laatst online: 14:33
Piggen
Lekker bakkie
Hmm, i-bead of Nex IA? Ze kosten me evenveel (Nex: 179, i-bead met tweakkorting + oplader en tasje: 179)
i-bead:
+ uiterlijk
+ pendrive functie (hoewel de Nex ook als harddisk gebruikt kan worden)
- geheugen niet uitbreidbaar
- werkt alleen op accu
Nex:
+ afstandbediening
+ geheugen uitbreidbaar
+ werkt op batterijen en netstroom
- uiterlijk (vooral draad en oordoppen)
Ik ga toch maar voor de i-bead, denk ik (alhoewel ik er nog niet helemaal uit ben, misschien verander ik nog van mening als ik wat reviews van de Nex heb gelezen). Die 128 lijkt me genoeg, en de batterij schijnt erg lang mee te gaan.
[ Voor 6% gewijzigd door Piggen op 10-05-2003 20:13 ]
Ik zou voor de i-bead gaan, heb em zelf ook, en hij is toch wel erg klein hoor. En dat met die accu vs. batterijen, dat had ik ook heel erg, reis nl. zeer veel. maar ik hoef hem 1 hele week nie op te laden bij normaal gebruik, dus die gaat goed mee.
Het geluid kan ik ook zeer goed noemen, ik wilde eerst het voor de nex IIe gaan vanwege uitbreidbaarheid en grotere output per kanaal, dus ben ik ze beide gaan bekijken in de mediamarkt, en ik moet zeggen, ben toch tevreden met mijn keuze
tweak_dude schreef op 10 May 2003 @ 18:51:
* KICK *
Sorry dat ik het nu pas vertel hier ;) maar ik heb hem op het laatste moment afbesteld. Hij leek me toch te dik enzo, heb maar een I-Bead gekocht nu.
  • tweak_dude
Verwijderd schreef op 10 mei 2003 @ 23:31:
Ow. i see. Nou ja de i-bead is geen optie voor mij (ik wil cf ivm met mijn digicam). Dus dan zal ik de reviewtjes maar af moeten wachten :| :X
ik hoop dat ik niet de eerste zal zijn die een uitgebrijde review ga schrijven over een tijdje, want ik zie dat ding dus echt wel sitten, de groote boeit me niet, veel zal je er niet van merken, mischien wel van het gewicht (130 gram incl. 2000mah bats die zijn over het algemeen iets zwaarder) dat is best veel.
ik denk wel dat ik voor de IA ga, niet aleen omdat er ook over een paar maandjes de hitatchi 4gig drives in kunnen (mits nieuwe firmware) maar ook om de prijs.
ik weet niet of iemand anders problemen heeft met afstands bedieningen, maar dat heb ik dus wel, ik heb er dus gewoon echt een hekel aan! ten eerste is het snoer van je oordoppen al ongeveer een meter, als het niet groter is, dan komt er ook nog extra snoer bij van de afstandsbediening, veel handiger om er geen te gebruiken of zo'n ding wat er dus bij de IA zit, ok, mischien wel lelijk (mening) maar wel handig, 1,5 meter snoer is al groter dan de verkochte i-beat!!
en het dikke van de IA speler merk je volgens mij wijnig van (mischien als je een strakke broek draagt ofsow) omdat alle hoekken zijn afgerond (slim-soap-disign) waardoor het apparaatje ook kleiner lijkt.
het intergreren van een oplaadbare (kleinere) baterij vind ik totaal geen nadeel, als ze dit hadden gedaan bij de IA was het aparaatje waarschijnlijk een mm of 5 slanker.
mi hoen.
  • easydisk
  • Laatst online: 06:54
Er zijn een aantal die zeiden een reviewtje te schrijven ...
Ben erg geinteresseerd, want A-tembo heeft deze week goedkope compact falsh card's en kan ik die vast inslaan.
  • DenniX
Nou, die kaartjes zijn NU op meer plekken rond de 30 euro te koop hoor, dus daarom zou ik me niet overhaasten om een beslissing te maken hoor....
en trouwens die kaartjes worden alleen maar goedkoper hoor :) !!
Ik zou btw ook HEEL GRAAG nogsteeds een review van iemand(?) zien!!
mzzl.
  • tweak_dude
Tweak_dude hoopt dat iemand nex ia koopt en een reviewtje schrijft ;)
  • x-man
  • Laatst online: 29-10 20:49
x-man
Proud newbie!
Als je echt van plan bent ooit een microdrive te kopen of om het geheugenkaartje te vervangen lijkt het me wel een goede keus.
Ik zat hier ook over na te denken. Maar kans is dat ik toch door financiele redenen (te hoge kosten) nooit zo'n ding zal uitbreiden. Dus waarom dan zo'n groot ding kopen als je de iBead 256 Mb kan halen?
Better a newbie in one hand then ten wannabe-hacker-scriptkiddies on your server.
  • DenniX
Ja, das echt helemaal waar! Meestal ben je met het dagelijkse gebruik wel binnen een dag bij je/een computer, zodat je er weer andere muziek op kan zetten of opladen.
Het wordt alleen iets anders als je op vakantie gaat. Dan zul je toch iets anders moeten verzinnen voor meer muziek dan 256MB en eventuele stroom (als er geen 220 te krijgen is!! :s .
Toch maar die oude discman met veel penlites meenemen : D ! Dan is het BTW ook niet zo erg als je 'm kwijtraakt!!
  • tweak_dude
Ik heb hem net besteld, hopelijk heb ik m morgen binnen :). Dan zal ik mijn bevindingen wel ff posten.
Ik wou deze eerst ook kopen, maar de kleur, de afstandsbediening en het gewicht + de koptelefoons die spuug lelijk zijn hebben mij ervan weerhouden. Ik wacht tot er iets kleiners komt met CF...
  • smallboy
smallboy
N/A
tweak_dude schreef op 27 May 2003 @ 14:00:
Graag... Ik ben benieuwd. Zit zelf ook aan deze te denken, maar heb nog geen reviews gezien.
  • smallboy
smallboy
N/A
*Schopje*
Heb je um al tweak_dude?
  • Jaded
smallboy schreef op 31 mei 2003 @ 13:15:
*Schopje*
geloof het niet:
[rml]tweak_dude in "[ NEXia] probleem met geheugen"[/rml]
[ Voor 25% gewijzigd door Jaded op 31-05-2003 13:17 ]
  • simon
  • Laatst online: 18-11 17:24
Ik heb em nu, maar zit met een probleem: [rml][ NEXia] probleem met geheugen[/rml] verder alles zeer positief :)
  • smallboy
smallboy
N/A
Jaded: oeps ik zie dat topic pas net :)
Hoe klinkt hij verder Simon? Zit er een fatsoenlijke bass in? (bass ontbreekt nog wel ns bij portables). Kan ie met een gewone grote koptelefoon ook nog hard genoeg om normaal te luisteren?
  • simon
smallboy schreef op 31 May 2003 @ 13:25:
Er zit (vind ik) een aardige bas in (ik voelde het in mijn onderkaak :P) en de koptelefoon kan hard genoeg om 'normaal' te luisteren, maar ontleen geen rechten aan deze tekst :P
  • smallboy
smallboy
N/A
Nee zal ik niet doen, maar bedankt voor je reactie. Ik denk dat ik hem ook ga bestellen.
  • simon
smallboy schreef op 31 May 2003 @ 14:43:
Hopelijk ben ik de enigste met het 'kopieer' probleem, denk dat ik morgen maar mp3cdspeler.nl bel, waar heb jij em besteld?
  • smallboy
smallboy
N/A
Nog niet besteld (zie vorig bericht) of bedoel je tweak_dude?
Enne hoe klinkt de radio btw? (Binnenkort id&t in de ether dus dan wordt die functie toch misschien nog nuttig :) )
Ik heb net nog ff een mail gestuurd over die Ogg Vorbis support of dat nou waar was of niet.
Deze had ik gestuurd:
Dear Sir/Madam,
In a forum on the internet I read something about Ogg Vorbis support.
Since I am considering to buy this mp3 player, I'd like to know if
there will be Ogg Vorbis support and when the firmware upgrade (if it
will support Ogg) will be available.
Yours sincerely,
Ik
En deze kreeg ik terug:
Dear Sir,
We are working on the Ogg Vorbis right now. When it is ready, we will
release a firmware upgrade.
Thank you.
Customer Support
Frontier Labs
Dat lijkt me wel relaxed Ogg Vorbis support. Klink bij dezelfde bitrate als mp3 toch stukken beter.
[ Voor 94% gewijzigd door smallboy op 31-05-2003 15:55 . Reden: Aanvulling * 2 ]
  • simon
De radio is zwaar brak, dat heb ik ook in andere reviews gezien, ligt dus niet aan mij. Maar het is wel grappig :)
  • smallboy
smallboy
N/A
Andere reviews? Waar? Ik heb nog geen andere gevonden nl.
  • simon
@smallboy: http://www.fixup.net/tips/mp3/ :) (google ;))
  • smallboy
smallboy
N/A
Dank u... Ik had met google nog niks gevonden :)
  • simon
@smallboy: nog iets voor je:
regmaster schreef op 01 June 2003 @ 14:30:
FF een minireview'tje voor jullie.
Ik weet het niet met die Nex iA. Ik had de NexIIe maar zat me te storen aan het schermpje en de bediening. Wat dat betreft is de Nex iA een enorme vooruitgang qua bediening en qua scherm. In ieder geval eidenlijk ook een fatsoenlijk batterij vak. Is wel qua gewicht zwaarder dan de NexIIe maar voelt daardoor ook veel robuuster aan.
Alleen de uitlees snelheid is er niet bepaald op vooruit gegaan. Het lezen van een 1 gb microdrive duurt 3 keer zolang als via de Nex IIe. En staat de disc maar voor 75% gevuld.
Is best wel irritant als je even tussen de FM tuner en de MP3 speler switch't.
Verder lijkt het batterij verbruik met de microdrive gunstiger te zijn als met de NexIIe combi, ik gebruik GP's 2000. Ik heb de Nex iA nu een week en heb um iedere dag zeker een uurtje of anderhalf in gebruik. Na een week staat de meter nu op de helft. Valt reuze mee dus.
Geluidskwaliteit is op gelijk niveau als de NexIIe dus gewoon heel erg goed.
Tuner is een aardige toevoeging maar ook niet meer dan dat. De remote is zeer bruikbaar doordat de 'joystick' dezelfde functie heeft als op het apparaat zelf. Werkt erg goed.
Qua scherm en bediening zou ik zeker de Nex iA adviseren maar als je een microdrive hebt of een grote CF kaart dan is de muziek via de NexIIe toch veel sneller beschikbaar. Qua geluidskwaliteit doen ze, wat mij betreft, niet voor elkaar onder dus daar hoeft je keuze niet van af te hangen...........
  • Tranquility
Ik zit er ook over te denken om deze te kopen. Ik heb de Nex II gehad en was in principe zeer te spreken over de geluidskwaliteit. Alleen had ik bij de Nex II het probleem dat hij bij laag volume met rustige muziek (bijv. solo piano) nogal ruiste. Het was wel meer een soort 'digitale' ruis, welke ook goed waarneembaar was bij het in- en/of uitfaden van een muziekstuk. Is dit probleem verholpen bij de Nex iA?
En kraakt 'ie nog wenneer je het volume wat hoger zet? (was ook een bekend probleem van de Nex II)
Ik ben dan van plan er een 1 gieg CF-kaartje bij te kopen, dus geen mechanisch kwetsbare microdrive. Ook wil ik graag weten hoe het zit met pauzes tussen de tracks bij live- of aan elkaar gemixte muziek.
Hopelijk kan iemand antwoord geven op bovenstaande vragen? Ik vind het namelijk best wel een perfect mooi no-nonsense spelertje waar teminste ook gewoon twee normale (oplaadbare) AA penlite batterijen in gaan.
[ Voor 9% gewijzigd door Tranquility op 01-06-2003 21:00 ]
  • smallboy
smallboy
N/A
Dank je Simon, ik zag de mini review net in andere topic... Ik denk dat ik hem ook ga bestellen van de week (nog even de financien i.v.m. een vakantie checken) :P
  • tweak_dude
Ik heb hem dinsdag bestelt en nog steeds niet binnen :( Zal wel door hemelvaart komen.
*ering zooi ik wil hem echt hebben :9
Hiervoor had ik een Sony NW-MS9 digitale walkman. Destijds zat ik al te kijken naar een compact flash mp3 player. De Nex II bestond al maar die had een aantal bugs en de geluidskwaliteit was niet zo goed. Toen ben ik maar voor kwaliteit gegaan. Na 2 jaar er plezier van te hebben gehad, was ik de beperkte geheugen van de 1e generatie MG memorysticks en de copyright gedoe zat. Een extra stickie en een nieuwe batterij accu leek me te duur. Ik heb de boel maar verkocht voor een leuk prijsje en daarvoor in de plaats een NEX IA gekocht. Ik had zelf al wat CF kaartjes en een USB reader van een digitale camera. Verder was een CF 512 mb kaartje van Dane-Elec voor 131 euro te koop. Die had ik ook maar meteen gekocht. Ik heb nu bijna 14 uur aan muziek in mijn NEX IA zitten (wma,80 kbit) :9
Hier komen mijn plus en min punten over de NEX IA :
+ klein, compact
+ verwisselbaar CF geheugen (wat betaalbaar is, garantie heeft en multi-functioneel)
+ 5 bands EQ (5 presets, 1 custom
+ verbruikt 2x AA of netspanning via een meegeleverde adaptor
+ uitstekende joystick bediening met een eenvoudig menu.
+ draagtasje erbij
+ bij datatransfer via de usb kabel gebruikt de NEX IA stroom van je USB port
+ skip vrij, geen bewegende direct slijtende onderdelen
+ browsen gedurende weergave
+ ook te gebruiken als REMOVABLE DRIVE
+ Resume functie, zowel bij het verwisselen van batterijen of als je naar de radio even luistert.
+ beveiligingsfunctie ,als je de Nex IA (afspelend) op een versterker aansluit die ook al aan staat dan gaat de volume van de Nex IA automatisch naar nul en de track wordt gereset naar het begin
- speler is wel gemaakt uit doorzichtig dikke plastic/poly ?(wat wel kraakt hier en daar als je er op drukt)
- behuizing is snel bekrast
- radio functie is brak (was voor mij niet belangrijk)
- memo functie werkt maar de mic niet echt heel gevoelig
- er zitten hier en daar wat software bugs in mbt vbr files, volume monitor meter, radio recording (ik heb er persoonlijk geen last van, ik gebruik de NEX IA puur voor mp3 weergave)
- datatransfer is traag, een aparte reader is de oplossing hiervoor
- geheugenklepje is vrij fragiel in elkaar gezet, zolang je maar voorzichtig bent kan het niet zo snel kapot gaan
- batterijen zijn moeilijk te verwijderen, verder zit het klepje vast
- stof achter de LCD
- batterij meter kan niet helemaal nauwkeurig zijn
- als je op de rewind << drukt met de joystick, gaat de Nex IA ook daadwerkelijk naar de vorige track, dus het werkt niet zoals bij cd spelers dat je een nummer opnieuw kan laten starten door 1 keer op de rewind knop te drukken
- RESUME functie op WMA files werkt niet op tijdweergave, wel op track, skippen gaat ook moeizamer
Verder hoor je wel ruis als je de NEX IA aanzet maar tijdens het spelen van tracks hoor je dat niet echt. Geluidskwaliteit is redelijk tot goed. Verder is het voor mij persoonlijk wel een groot verschil om van een Sony Gadget (hoog kwaliteit met andere beperkingen) naar een mp3 speler over te stappen die vrij low/mid budget is gemaakt door een klein bedrijfje. Maar verder boeit mij dat niet echt.
Tot slot ben ik gewoon onwijs tevreden met de NEX IA dankij de eenvoudigheid in gebruik met mp3's en de geheugenomvang :)
[ Voor 35% gewijzigd door Verwijderd op 17-06-2003 00:05 ]
JazzySOB schreef op 01 June 2003 @ 17:17:
>>>> kraakt niet
>>>>> wat bedoel je precies? je hoort wel kraakjes tussen het skippen van mp3's
[ Voor 4% gewijzigd door Verwijderd op 02-06-2003 04:18 ]
  • Tranquility
Wel, ik bedoel dus of je een stilte hoort tussen twee nummers in (die op een audio-CD gewoon naadloos in elkaar overgaan). Bij de ene mp3-speler duurt die stilte langer dan bij de andere. Ik had een MamboX waarbij de pauze soms wel enkele seconden duurde! Waarschijnlijk kwam dat door slecht gebruik van het beschikbare buffergeheugen en het -te laat- opspinnen van de harddisk. Nu weet ik uiteraard wel dat de Nex iA een flashplayer is die geen last heeft van een te laat opspinnende harddisk, maar bij de Nex II die ik heb gehad was desondanks toch een pauze van een halve seconde ofzo hoorbaar bij aan elkaar gemixte muziek.
JazzySOB schreef op 02 June 2003 @ 03:20:
ja , een halve seconde. Maar dat had ik ook met me sony nw-ms9.
Een audio cd kan je natuurlijk track at one of disc at once schrijven.
(geen pauze of instelbaar) Technisch gezien is dit anders.
Een cd speler leeslens draait continue en met flash geheugen zouden ze dus een soort aparte overgang buffer in moeten bouwen om een naadloos overgang te hebben, denk ik... :7
[ Voor 35% gewijzigd door Verwijderd op 02-06-2003 04:48 ]
  • Tranquility
Ik snap nog steeds niet waarom dit zo'n groot probleem is bij veel mp3-spelers. Live en dance-CD's zijn dan niet mooi af te spelen, ok al encode je ze zonder pauzes. Technisch is het gewoon mogelijk om -net zoals bij CD- "gapless" weergave toe te passen. En bij geheugenspelers moet dit toch helemaal niet moeilijk zijn omdat daar de datastroom meteen beschikbaar is? (een flash speler is immers één groot buffer) Het schijnt dat de iPod en de Zen wel "gapless" kunnen afspelen.
JazzySOB schreef op 02 juni 2003 @ 10:56:
ik zal zeggen , mail ze : techsupport@frontierlabs.com
Zelf zet ik mix cd's om tot 1 grote mp3 file. Al hoewel
wat jij bedoelt wel handig is.
  • smallboy
smallboy
N/A
Nou ik heb um net besteld. Als ik hem heb (zal wel woensdag worden want de post komt morgenochtend en dan is er niemand, dus woensdag zelf ophalen) dan zal ik ook ff een mini-review posten.
  • Tranquility
quote]knite schreef op 02 June 2003 @ 15:06:
ik zal zeggen , mail ze : techsupport@frontierlabs.com.
Ik denk dat dit soort zaken een hardwarematige oorzaak heeft en niet d.m.v. een firmware-update is op te lossen, anders hadden ze dat al lang gedaan denk ik (zo zijn er heel wat firmware-updates geweest voor de Nex II)
Dat is inderdaad ook een mogelijkheid: mp3's in één groot bestand zetten (kan trouwens héél makkelijk met winzip, zonder opnieuw te moeten encoden) maar dan moet de speler wél over een resume beschikken die werkt binnen een nummer (dus die de tijd onthoudt), anders moet je elke keer zoeken naar het punt waar je de speler ongeveer hebt uitgezet. Of zit er alleen een resume op die het nummer weer vanaf het begin laat spelen?
En als ik je verhaal zo lees, hoor je dus ruis bij het aanzetten, maar niet bij het luisteren van een mp3. Zou je mij een plezier willen doen en even een rustig muziekstuk van een CD willen encoden (op hoge bitrate, bijv. 256 kbps), waarvan je weet dat het een digitale opname is, en vervolgens willen afspelen en goed horen of bij laag volume (bij bijv. uitfaden) de ruisvloer hoger wordt, en er een soort "rommelige" ruis hoorbaar wordt? Dit was namelijk een erg irritante bug bij de Nex II. Ik hoop echt dat dit probleem bij de Nex iA verholpen (of teminste sterk verminderd) is. De Nex iA is eigenlijk de enige leuke CF-speler in zijn soort en wil hem graag kopen mits bovenstaande problemen niet te ernstig zijn. Helaas kun je de speler nergens eerst beluisteren voordat je hem kunt kopen.
Alvast bedankt voor de te nemen moeite :)
ik heb een rustig nummer van M.Jackson (i can't stop loving you) geripped en met LAME encodeert op 256/stereo. Het rare is dat ik net pas ontdek heb dat ik eigenlijk minder achtergrond ruis hoor zodra ik een mp3 afspeelde nadat ik de Nex IA aan had gezet.
Dus volgens mij als je de Nex IA aanzet hoor je een duidelijk ruis, deze verdwijnt nadat je een mp3tje afspeelt. Als je vervolgens skipt tussen mp3's of de Nex IA op pauze zet, is deze ruis nergens meer te bekennen. (je hoort waarschijnlijk wel de bijna onwaarneembare <0.05% distortion rate)
Het mp3'tje zelf had eigenlijk meer een zachte niet rommelige achtergrondruis die ook constant is bij het uitfaden. Volgens mij ligt het aan het mp3tje zelf ! Ik heb niet echt goeie muziek cd's om te testen. Meeste muziek waar ik naar luister komt van Vinyl af en is meestal niet rustig.
Verder heb ik de resume functie uitgetest. Als je tijdens een mix de Nex IA op pauze of stop zet en je zet de Nex IA uit voor bijvoorbeeld 30min of je verwisselt de batterijen en daarna vervolgens de Nex IA weer aanzet, moet je eerst weer player kiezen uit het menu en daarna zie je de keuze vink achter het laatst afgespeelde mp3tje staan. Als je vervolgens op play drukt met de joystick, resumed het weer op de juiste tijd. ;)
Ik kwam helaas ook een ander mogelijk minpuntje tegen, ik had er splinternieuwe 1800 GP batterijen inzitten. De batterijmeter stond op circa 1/3 en plotselng viel de Nex IA uit. Maar deze batterijen had ik wel 3 weken laten liggen in een kast nadat ze waren opgeladen voor de eerste keer.
Ik heb er nu verse duracell batterijen in zitten, ik ben benieuwd.
Update : als je de Nex IA (al afspelend) op pc boxjes aansluit met een ingebouwde versterker die aanstaat, gaat de volume van de Nex IA automatisch naar 0 en het begint de track opnieuw af te spelen. (een soort beveiliging ?)
Plus en min punten updated.
[ Voor 26% gewijzigd door Verwijderd op 03-06-2003 04:12 ]
  • Tranquility
Bedankt voor het proberen! het is jammer dat je geen CD hebt liggen met een digitale opname. Het is in iedergeval prettig te horen dat er een goede resume-functie op zit.
Ik heb wel een kort muziekstukje om goed te testen. Het is een stukje akoestische gitaarmuziek van nog geen minuut lang welke digitaal is opgenomen en perfect is voor het testen van ruis bij mp3spelers. Dit kun je hier downloaden (het is ongeveer 1 mb groot) en dan ben ik benieuwd naar je mening... Ook anderen die net de Nex iA hebben gekocht wil ik hierbij uitnodigen dit bestandje te downloaden en te testen.
Wat die batterijen betreft het volgende: Oplaadbare NiMH batterijen zijn nogal gevoelig voor lang ongebruikt laten liggen. Zeker wanneer de baterijen nieuw zijn moeten ze eigenlijk (met een goede computergestuurde smart-lader!) een keer of 8 opgeladen en weer ontladen worden voordat de volledige capaciteit bereikt wordt. Ik heb namelijk precies hetzelfde gehad bij een digitale camera (die stroomzuipers zijn). Na het "conditioneren" van de NiMH cellen werkte het weer perfect. Het beste is sowieso om een goede smartlader te gebruiken die vier onafhankelijke schachten bezit, waarbij dus elke batterij individueel ontladen en geladen wordt.
  • tweak_dude
JazzySOB ik heb dat nummer ff geprobeerd en ik moet zeggen dat ie eg goed klinkt. Ik ben dan geen audiofiel ofzo, maar volgens mij zit er niet veel ruis in (ik hoor iig geen ruis). t klinkt gewoon erg helder :)
Ik ben erg tevreden met deze speler. Ik vind het geluid is erg goed, maar dat is niet zo gek omdat ik hiervoor een napa 315 had (= :r ). Het enige nadeel vind ik de fouten in de firmware, bijvoorbeeld nadat je iets opgenomen hebt en dat opgespeeld hebt kun je die opname niet nog een keer beluisteren voordat je de speler uit hebt gezet :S. Maar opnemen doe ik toch niet zo vaak en dit zal ook wel gefixt worden met een nieuwe firmware hoop ik.
Het klepje van het CF vakje is ook niet al te stevig. Het klepje van het batterij vakje is echter weer heel solide.
[ Voor 61% gewijzigd door tweak_dude op 03-06-2003 00:01 ]
JazzySOB schreef op 02 June 2003 @ 23:21:
Ik heb wel een kort muziekstukje om goed te testen. Het is een stukje akoestische gitaarmuziek van nog geen minuut lang welke digitaal is opgenomen en perfect is voor het testen van ruis bij mp3spelers. .
ik heb het getest, je hoort wel ruis op de achtergrond die duidelijk te horen is bij hoge volumes, maar mijn soundblaster Live geeft dezelfde weergave.
Was het trouwens een VBR mp3 ? De tijdweergave deed helemaal raar.
[ Voor 14% gewijzigd door Verwijderd op 03-06-2003 04:09 ]
  • Tranquility
Ja, dat klopt. Het muziekstuk is geëncode met Lame @ --alt-preset standard als ik me niet vergis. Mijn oude Nex II had ook last van verkeerde weergave van de tijd bij VBR. Toch vreems dat ze dit nog niet opgelost hebben twee generatie spelers verder (Nex IIe en iA). Maar ik vind dit verder niet erg, het gaat me vooral om de muziek.
Nog over die ruis. Je zei dat dit bij hoge volumes te horen was. Dit is in princiepe vrij normaal en valt gewoon onder versterkerruis welke toeneemt bij hoger volume. Maar de Nex II had er juist last van bij laag volume. Je kon het verschil vooral goed horen tussen de nummers door. De Nex heeft een pauze van een halve seconde of zo (net zoals bij de Nex iA zoals nu blijkt) waar je dan op dat moment helemaal geen ruis hoort. Is dit soort ruis ook aanwezig bij de Nex iA?
In iedergeval bedankt dat jullie de moeite wilde nemen _/-\o_
JazzySOB schreef op 03 June 2003 @ 11:20:
De Nex heeft een pauze van een halve seconde of zo (net zoals bij de Nex iA zoals nu blijkt) waar je dan op dat moment helemaal geen ruis hoort. Is dit soort ruis ook aanwezig bij de Nex iA?_
Geen ruis tussen de overgangen, maar je hoort bij sommige mp3's wel een klikje
op het einde of aan het begin (afhankelijk van het mp3tje) en als je de NEX IA op pauze zet dan hoor je ook geen ruis meer.
[ Voor 75% gewijzigd door Verwijderd op 03-06-2003 12:55 ]
  • blaatbeest
  • Laatst online: 04-12-2017
blaatbeest
fuck
Ik heb hem nu ook!
Dit is mijn eerste "walkman" dus ik heb compleet geen referentie maar ik vind het best een goed apparaat.
Belangrijkste min punt voor mij is de TRAGE verbinding met de computer, duurt me echt te lang om muziek op mijn 512MB ding te zetten. Met een compact flash usb2.0 reader is dit natuurlijk opgelost.
Ook is het jammer dat het klepje van de CF kaart inderdaad behoorlijk brak is. Dit zie ik in de nabije toekomst nog wel kapot gaan, vooral als je hem niet in het beschermtasje houd.
Qua geluid vind ik hem harstikke goed! Ik hoor echt geen ruis, ook niet in dat gitaar stukje van jazzysob. Kan natuurlijk ook aan mijn brakke oren liggen :) Of het feit dat ik hem net een uur heb en het niet echt stil is hier in de stad :)
Voor de mensen met een digicam met een grote CF kaart is dit wat mij betreft een aanrader.
edit: Nog een nadeeltje waar ik achter kwam: Hij draait de mp3's uit een directory op alfabet af, afgaande op de title uit de id3 tag. Waarom ie niet kijkt naar de track is mij een vraag
edit2: Dear Sir,
We will add an option to allow you to switch off this automatic sorting in
the next firmware release.
Thank you.
[ Voor 19% gewijzigd door blaatbeest op 04-06-2003 09:58 ]
x
  • smallboy
smallboy
N/A
Zo, heb hem vandaag ff opgehaald bij het postkantoor.
Het geluid is erg goed, beter als mijn soul dmp 01 (die al goed klinkt). Ook met een grote koptelefoon kun je nog op goed volume luisteren. Ook handig is de handmatige EQ stand. Verder is het handig dat de knopjes op de afstandbediening hetzelfde zijn als op de speler, dan weet je precies wat wat doet. De bediening werkt erg goed. Je hebt het zo door en alle functies zijn snel bereikbaar.
Een paar foto's van de Nex IA kun je hier vinden.
Daar kan je ook zien dat er geen telefoonsnoer aan de afstandbediening zit, zoals op de eerste plaatjes die (ik dan) te zien kreeg.
Nog een paar minpuntjes:
- radio is gaar (maar dat wist ik van tevoren)
- de voorbij scrollende titels mogen wat sneller scrollen
- hij speelt de files op alfabetische volgorde af (maar kan in volgende firmware worden uitgezet volgens frontier labs), dit probleem was bij mij op te lossen door id3 tags weg te halen (gebruik ik toch niet), al mijn geripte cd's hebben volgende layout: tracknummer - artiest - titel (bijv. 03 - Daft Punk - One More Time). Id3 tags weghalen en de volgorde ging goed (is wel handig bij gemixte cd's).
- het klepje van de geheugenkaart is ietwat kwetsbaar, maar als het eenmaal dichtzit gaat het wel goed en zal 't niet snel kapot gaan (hoop ik :) )
En nu maar hopen dat de Ogg Vorbis support er snel komt (frontier labs is ermee bezig).
Als iemand nog iets wil weten, roep maar.
nog een paar bugs ondekt :
Nex IA en een 512 Dane Elec Cf kaart, was geformateerd via de Nex IA
Ik had er een paar mixes op staan in 2 mappen en een map met losse nummers.
Ik was aan het skippen in een mix mp3 na ongeveer 20 minuten in de mix geskipt te hebben, ging de tijdweergave raar doen. Het geluid was weggevallen. Vervolgens deed geen enkele mix het meer, ook niet in het andere mapje.
Je zag de tijdweergave rare sprongen maken zonder geluid ( en het zijn geen VBR mp3's) De losse nummers deden het wel. Via Windows en een usb reader kreeg ik de mixes ook niet afgespeeld. Melding : corrupte map of file onder Window Media Player.
Daarna de CF kaart geformateerd onder Windows, dezelfde mp3's er opnieuw opgezet. Alles werkte weer.
Er was ook een situatie dat ik een aantal mp3's had bewerkt met een mp3 file editor. De mp3's speelde goed af via een CF reader. Maar via de Nex IA klonken sommige mp3's raar aan het begin. Een stuk dat ineens rommelig klonk of was weggevallen, supervaag ??! De betreffende mp3's opnieuw gekopieerd van backup en alles deed het weer.
Ik heb alleen niet opnieuw de langdurigde skipfunctie uitgetest...
  • fjorden
Je kunt deze speler bij de Mediamarkt uitproberen.
  • simon
Als het goed is krijg ik een dezer dagen mijn mp3 speler terug, jullie horen nog ;)
  • smallboy
smallboy
N/A
Nog een bugje: bij een wma files werkt resume niet. Tenminste, hij gaat wel naar het goede tijdstip, en dan begint de tijd weer te lopen, maar hoor je niks. Als je de file dan gewoon vanaf het begin laat afspelen werkt het wel, en vooruit en terug spoelen werkt ook gewoon. Beetje raar, maar vind ik niet zo'n probleem aangezien ik toch vrijwel nooit wma gebruik.
  • Tranquility
@ smallboy;
Zou je een paar foto's kunnen maken van het (open) batterijklepje en het CF-card slot?
Ik ben namelijk benieuwd of de batterijen er nog steeds zo k*t uitgaan als bij de Nex II(e) waarbij je de tweede batterij er haast niet uit kon krijgen zonder dat koordje wat bij mij al de eerste dag afbrak...
Thanks ;)
  • tweak_dude
Ik ken die NEX II niet, maar bij de IA gaan de batterijen er redelijk makkelijk uit. Het enig brakke is ook het cf klepje, die ziet er namelijk niet al te stevig uit :(
  • smallboy
smallboy
N/A
JazzySOB: ze staan hier.
De batterijen eruit halen gaat enigzins moeilijk. Er zit geen koordje in, maar met je nagel naast de batterij heb je ze er wel gauw uit.
Pagina: 1 2 3 4 Laatste
