Het SiS 655 topic
Pagina: 1 2 ... 6 Laatste
  • 2.326 views sinds 30-01-2008
  • |sWORDs|
  • Laatst online: 14-04 12:48
|sWORDs|
vSphere/ESXi
Aangezien de Granite Bay dreigt te floppen, lijkt me een topic over de grote concurrent wel nuttig. Specs van de chipset (uit de asus preview):
Technical Specifications (subject to changes)
Processor Socket 478 for Intel® Pentium 4 / Celeron processors
Intel® Pentium 4 Processors 1.4GHz - 2.80GHz or higher
Intel® Celeron Processors 1.7GHz - 2.2GHz or higher
Supports processors at 400 / 533MHz front side bus
Chipset SiS 655 Open Architecture DDR333 Chipset
Supports DDR333/DDR266/DDR200 SDRAM DIMMs
Supports dual channel DDR333 :9
400/533MHz system bus
AGP 4x/8x :9
SIS 963 MuTIOL Medio I/O Chipset
Bi-directional 16-bit data bus at 533MHz operating frequency
Proprietary interconnect between SiS north-south bridge at 1GB/s bandwidth :9
2-channel Ultra ATA 133/100/66/33 Bus Master IDE controller
Six USB 2.0 ports
Supports AC'97 v2.2 audio and modem codec
ACPI 1.0b and APM 1.2 compliant
LPC 1.0 interface
PCI 2.2 interface
Cache memory CPU Built-in 256KB (Willamette) or 512KB (Northwood) L2 cache for Pentium 4
CPU Built-in 128KB L2 cache for Celeron
System memory 4 x 184-pin dual-channel DDR SDRAM DIMM
Supports 128/256/512MB or 1GB DIMM Module
Supports 2.5V DDR SDRAM
Supports a maximum of 4GB of memory
PCI IDE 2 x Bus Master UDMA-33/66/100/133 IDE ports (up to 4 devices)
Support for PIO, UDMA-33, UDMA-66, UDMA-100, UDMA-133 IDE
Built-in Promise PDC20376 RAID controller supporting additional two ATA133 devices and two Serial ATA devices (optional)
I/O Interface 1x floppy connector (360KB - 2.88MB)
2x serial ports
1x parallel port (SPP/EPP/ECP)
PS/2 Keyboard
PS/2 Mouse
4x USB ports
Audio ports for on-board sound (Line-Out, Line-In, Mic)
Game port
2x IEEE-1394 headers :9
ASUS front panel audio connector
1x IR header
1x S/PDIF input/output (module optional)
1x RJ45 Gigabit Ethernet port :9
Expansion slots 6x 32-bit PCI slots, PCI 2.2 compliant
1x AGP (4x/8x mode) slot
Power Management Supports ACPI 1.0b (Advanced Configuration and Power Interface) and APM 1.2
Supports Desktop Management Interface (DMI) 2.0
Form Factor ATX Form Factor : 30.5cm x 24.4cm
Fits into regular ATX case
BIOS 4Mbit (512KB) Flash EEPROM
Award Flash BIOS with PnP, ACPI and DMI 2.0, Green, TCAV support
Multi-boot on ZIP, USB, ATAPI CD-ROM, SCSI, IDE #1, #2, #3, #4
Links
De prijs van de ASUS P4SDX gaat liggen onder die van deze.
Ben ik nou de enige die :9~ van deze chipset?
edit: Zo weinig zelf getypte tekst en dan nog een typo. |:(
[ Voor 5% gewijzigd door |sWORDs| op 11-12-2002 10:12 ]
Te Koop:24 Core Intel Upgradeset
  • Abbadon
  • Laatst online: 09:50
sWORDs schreef op 11 December 2002 @ 10:07:
Qua basis opzet heeft 'ie wel wat van de Granite Bay, echter, daar had ik ook iets meer van verwacht. Als deze chipset minimaal net zo presteert en de borden die hierop gebasseerd zijn idd niet meer kosten dan een evengoed aangekleed i845PE bord is het zeker een leuke optie :)
  • BalusC
BalusC
Carpe diem
  • Spice
  • Laatst online: 09-01 14:46
Spice
- Mijn vader is een tovenaar -
Wat pics lijken me ook wel leuk:
De asus:
Afbeeldingslocatie: http://www.clubic.com/images/auto/img32104.jpg
Iwill P4DR SiS 655
Afbeeldingslocatie: http://www.ocworkbench.com/archives/dec2002/p4dr.jpg
Het is wel verstandig om te wachten om de revisie van de SiS 655, de eerste exemplaren ondersteunen namelijk geen HyperThreading.
[ Voor 1% gewijzigd door Spice op 11-12-2002 11:24 . Reden: typo ]
Just call me angel of the morning, angel. Just touch my cheek before you leave me, baby. Just call me angel of the morning, angel.
  • Ibidem
  • Laatst online: 05-10 20:11
K heb nu ook Asus P4S533 gebasseed op een SiS 645DX Chipset, en ben er super tevree over, nooit probs e.d. Dus nu wil ik ook wel zo'n SiS 655 bordje hebben, kijken wat dit doet! :D
..::System Specs::..
jammer dat het zo verdomde stil is rond deze chipset op het moment!
je zou bijna achterdochtig worden... :)
Granite Bay werd veel meer gepreviewd en er verschenen al test voor ie uitkwam... wat zou er mis zijn met de SiS655?
  • Dr_Love
  • Laatst online: 01-05 09:23
Dr_Love
Best drugs are made by love
Heeft nog geen hypertrading dat is er mis mee. er kwam waarschijnlijk wel een revisi uit. stond laats op warp2search en geloof ook oop tweaker.net.
http://specs.tweak.to/3331 SPECS :) A miracle
Dr_Love schreef op 12 December 2002 @ 00:02:
de moderator/medewerker van OCWorkBench wist me te vertellen dat revisie A, zonder HTT, geschrapt is en dat straks dus gelijk revisie B uitkomt.
uit het laatste tweakers.net nieuwsbericht over SiS chipsets (zie boven) wordt het in ieder geval niet echt duidelijk!
maar ja, laten we het hopen...
  • PhuSioN
  • Laatst online: 27-11 17:00
ben benieuwd hoe het zit met het oc-en ervan. de sis 648 bakte er in ieder geval niks van (wat ik gelezen heb in de reviews)
  • |sWORDs|
|sWORDs|
vSphere/ESXi
Verwijderd schreef op 12 december 2002 @ 01:43:
Ook Asus start pas met produktie zodra de tweede revisie uit is.
maar zal het wel een groot verschil zijn?? De granite bay was ook al niet zo denderend, en ik zie eigenlijk niet meteen in dat deze chipset zo een enorm verschil zal maken.
De features zijn wel mooi natuurlijk. dus dat is wel een mooi pluspunt op de granite bay.
dan nog twee vraagjes:
1) zal deze tweede revisie dan ook de 800mhz fsb ondersteunen? ( wss niet zeker )
2) wat moet ik mij eigenlijk voorstellen bij die hyperthreading ondersteuning?
want ik dacht altijd dat je voor hyperthreading gewoon speciale software nodig had
maar dat blijkt dus niet zo, je hebt dus ook speciale hardware nodig ....
  • KaMiKaZe
  • Laatst online: 25-11 21:03
Hij ziet er wel beter uit dan de granite bay met z'n firewire/UDMA133/AGP 8x en DDR333 ondersteuning.
ff domme vraag : voor dual DDR kun je toch gewoon normale DDR modules gebruiken ?
het is toch niet zo dat dit een nieuwe DDR soort is ofzow
Humanity is acquiring all the right technology for all the wrong reasons.
KaMiKaZe schreef op 12 december 2002 @ 14:48:
nee hoor :)
  • Weeds
  • Laatst online: 09-07 20:39
Weeds
what is a weed...
Heeft iemand enig idee wanneer de eerste moederborden hier in de winkel gaan liggen?
Hopelijk snel !
  • KaMiKaZe
Ik vond de prestaties van de granite bay eigenlijk zwaar tegenvallen en mede ook met het oog op die AGP8X bug vraag ik me toch af hoe goed dit ding gaat presteren :)
Ik heb nu een Gigabyte GA-8SG667 (sis648) en die is net zo snel als m'n 845PE board
DDR333+AGP4x vs DDR333+AGP8x , maar voor mijn gevoel is ide performance beter van de SiS 648. zit dus met spanning te wachten op dit board :)
  • Weeds
Weeds
what is a weed...
ik ook ... ik hoop dat ie snel komt.. hoewel et nog wel er stil blijft...
Misschien een rare vraag, maar waarom zitten de geheugenbanken op allebei die bordjes boven en naast de cpu socket? is dat sneller?
Die Iwill is btw wel :9~
  • Spice
Spice
Oshoflow heeft gelijk hierboven met zijn opmerking mbt vertraging van de SiS 655
op ocworkbench vandaag:
SiS 655 boards delayed
Tuesday, December 17, 2002
Posted by overclocker at 13:22
According to our friends in Taiwan, we have been told that most boards that weer previously ready will not be sold. The reason is because this first stepping of the SiS 655 doesn't support Hyperthreading. Instead, they are waiting for the SiS 655 newer revision B which will support the hyperthreaded CPUs.
[ Voor 8% gewijzigd door Spice op 17-12-2002 18:45 ]
  • Mizitras
Spice schreef op 17 December 2002 @ 18:44:
Erg kl*te want ik zat er zelf een lange tijd op te hopen deze als vervangmoederbord tekopen voor m'n P4S8X met SIS648.
En zoveel deftige concurentie is er niet voor dit bordje, dat ik bij naderinzien misschien ten onrechte heb weggedaan terug :(
"the fucking alpha cpp compiler seems to fuck up the goddam type "LPITEMIDLIST", so to work around the fucking peice of shit compiler we pass the last param as an void *instead of a LPITEMIDLIST"
  • Mister_X
  • Laatst online: 16-09 11:38
is dit die chipset met een geintegreerde nort/south bridge?
  • Mizitras
Mister_X schreef op 23 december 2002 @ 22:46:
Uhm, bij mijn weten is er nog altijd een 'link' tussen beide SIS MultiTol-'brug', dus ze zijn niet samengesmolten.
Meer kan ik ook niet zeggen, sorry.
btw, hem gezien dat Gigabyte al een SIS655-mobo in het gamma heeft staan.
De support zij zelfs dat ik me maar gewoon totm'n dealer moest wenden, vrij 'lax', dus zij zien het ook voor een van de volgende twee weken misschien :?
  • BalusC
BalusC
Carpe diem
Mister_X schreef op 23 December 2002 @ 22:46:
Neehoor, het bestaat uit de SiS655 Notrhbridge en de SiS963 Southbridge. Dat had je ook wel gewoon uit de specs in de openingspost kunnen opmaken :)
  • |sWORDs|
|sWORDs|
vSphere/ESXi
SIS 655 will take dual DDR route by year end
DDR 333 in late December
By Fuad Abazovic: donderdag 28 november 2002, 07:31
WE HEARD that SIS is about to have its first dual DDR chipset ready very soon.
Plucky little SIS just wont give up its hard fought for piece of the juicy Pentium 4 market and it is ready to attack the Granite Bay market at a much lower price and will introduce its SIS 655 chipset.
This chipset will have support for dual channel 333 memory and should give you some performance boost.
It will have support for Intel's new Hyper Threading marchitecture that currently operates only for the very expensive and hard to get 3.06 GHz Pentium 4.
Whether this chipset will officially have support for Intel's 800MHz system bus remains unknown at this time
Hmm dan mogen ze wel opschieten.
* |sWORDs| vind het verdacht stil.
Edit: Ik heb een mailtje naar sis gestuurd, hopelijk krijg ik een antwoord.
Dear Sir/Madam,
after reading a lot of rumors on the mayor hardware forums, I've decided to ask you. Will the sis 655 board be delayed? And when will those boards hit the shelves? Will the first boards support Hyperthreading, or only after a revision? Is the prise lower then the Intel 845? I'd like to remind you that your reply will be published on those forums/sites too.
With Best Regards and thanks for your time,
[ Voor 24% gewijzigd door |sWORDs| op 27-12-2002 09:15 ]
  • Afwezig
  • Laatst online: 20-05 16:25
http://club.aopen.com.tw/...cNo=1031&Language=English
Misschien is dit wat leuks van AOpen ?
  • Mizitras
Inderdaad zeer leuk nieuws Afwezig :) Doch wil ikzelf op ASUS wachten.
Ze mailden mij terug (op 2de mail) met een neutrale toon die min of meer zei:
"Ja inderdaad, ASUStek zal eind december een met SIS655-uitegeruste chipset uitbrengen"
Dus bij mijn weten P4SD8X...nu nog hopen dat deze in tegenstelling tot de website van ASUS ook wel degelijk de HT-features meekrijgt. (Staan nav. niet vermeld op de site, maarja, 'foutje' zeker).
Ik ga sebiet eens horen bij de hardwareboer of ik een P4SD8X kan bestellen of toch de bestelling achterlaten. Ben benieuwd hoelang dat ik zou moeten wachten.
(Sommige bronnen spraken toch van februari voor de SIS-chipset hé, wel hopelijk heeft Aopen het nu het ijs doorbroken en laten horen dat ze wel degelijk gesampled worden)
Misschien een wat knulige vraag (tikkie n00b), maar is de performance met dual channel DDR 333 tov RDram 1066 nu zelfs beter ? (.. in ieder geval goedkoper...?!).
Zoja, dan zou mijn keus voor de SiS 658 vervallen en wordt het wachten op de 655.... ( lijkt mij niet onverstandig... toch ?).
  • The Source
  • Laatst online: 01:42
Rambus is redelijk dood dus daar zou ik weinig geld aan uitgeven. Er komen nog wel enkele 32bits Rambus mainbaords op de markt echter denk ik dat er weinig van verkocht zullen gaan worden. Qua performance is dual channel DDR333 net niet snel genoeg om het van 1066 Rambus geheugen te winnen iets sneller dan 1066 Rambus... dual channel DDR (zit op de Granite Bay) is net iets trager dan 1066 Rambus. Echter qua prijs/performance is dual channel DDR aantrekkelijker.
[ Voor 19% gewijzigd door The Source op 27-12-2002 20:35 ]
The Source schreef op 27 December 2002 @ 19:53:
Qua performance is dual channel DDR333 net niet snel genoeg om het van 1066 Rambus geheugen te winnen. Echter qua prijs/performance wel :)
Maar het verschil in performance is niet schrikbarend ? Zijn er ergens benchmarks ?
(... hierna maar weer ontopic !)
  • The Source
Zoek naar review van de Granite Bay. Deze heeft ook dual channel DDR (266 welliswaar). In de meeste test wordt deze vergeleken met de 850 (Rambus pc800 / pc1066). In de praktijk zal met de SiS655 straks denk ik wel blijken dat het iets sneller is dan Rambus maar dat zal afhankelijk zijn van de applicatie en de test.
[ Voor 11% gewijzigd door The Source op 27-12-2002 20:33 ]
Ik weet genoeg ;) .... ik wacht gezellig met iedereen van dit topic op de Mobo's met SiS 655 chip :9 .
  • Mizitras
Verwijderd schreef op 27 december 2002 @ 20:38:
Je kan de bovengenoemde Aopen moederbord dan al bestellen ;)
Misschien datn iemand nog iets weet van MSI of ASUS zijn next move; ook een van dezer dagen eindelijk die boel releasen en nog naar de dealers sturen misschien?
winkelier zie me daarstraks: hebben we niet, kunnen we niet bestellen
  • KaMiKaZe
Mizitras schreef op 27 december 2002 @ 21:18:
er kwam toch een nieuwe revisie van de 655 en 648 die HT ondersteunen ?
  • Mizitras
KaMiKaZe schreef op 28 december 2002 @ 13:41:
SIS655FX en SIS648FX. Eerste is B-revisie SIS655 wordt aangenomen en ondersteund HT. (Licensie voor SIS is enkele dagen geleden goedgekeurd)
SIS648FX zal de HT-ondersteunende chip zijn die men 'zou combineren met vga-chipset om als goedkoop alternatief tegen wat ist er, i845GLE etc te conqureren' iets tegen eind Q1 begin Q2.
=> Zeker van is dat ze allebij HT zullen ondersteunen. Van 200Mhz FSB Quad Pumped...misschien iets voor 655FX, misschien.
Heb daarjuist langs shop geweest, eindelijk, men heeft ASUS P4SDX toch al genoteerd om te bestellen voor mij. Ben benieuwd hoelang nog te moeten wachten :?
Mizitras schreef op 28 december 2002 @ 17:13:
Ben wel erg nieuwschierig wanneer die binnenkomt... houdt ons op de hoogte. Sta inmiddels zelf ook te springen voor zo'n ding. Ben benieuwd naar de prijs trouwens (.. iemand een idee wat de Aopen kost... ?).
[ Voor 2% gewijzigd door Verwijderd op 28-12-2002 18:02 . Reden: spelling ]
Heb zelf [ http://www.xbitlabs.com/news/story.html?id=1035928828] een kreet met een prijs gelezen;
The P4SDX will be available in mid-November, or in about three weeks time. The price depends on the actual model and may be in 150 to 200 Euros range.
Klinkt (vooralsnog) niet echt verkeerd IMO.
  • KaMiKaZe
Ik ga dus maar even wachten op de 655FX dan. M'n 648 voldoet nog prima tot die tijd ;)
Verwijderd schreef op 29 december 2002 @ 20:45:
ik zou het maar ff afwachten...
voordat de Granite Bay uitkwam, las ik ook ergens dat de prijs rond de 150 a 200 euro zou gaan liggen.... is 250 euro geworden!
  • The Source
Het blijkt dat deze van AOpen gebaseerd is op de eerste revisie van het SiS655 chipset. Dus zonder HT support. Imho kun je beter wachten met kopen totdat er mainboards komen die de nieuwe stepping ondersteunen met HT support. Maar dit gaat nog even duren.
Ik snap ook totaal niet waarom AOpen deze revisie op de markt zet, heeft niemand iets aan en ze brengen alleen maar verwarring of krijgen achteraf klachten.
The Source schreef op 30 December 2002 @ 22:13:
Zolang je geen pentiumIV boven de 3.x koopt geeft dat toch niet, of babbel ik nu onzin ?
  • The Source
nop, maakt inderdaad nu niets uit, maar zodra over een jaar de prijzen van de CPU's zijn gedaald en je wilt upgraden (naar CPU met HT) baal je wel. Daarnaast geloof ik niet dat de kosten van de nieuwe SIS revisie hoger zullen zijn, dus even wachten lijkt me slim.
Voorzover ik heb gehoord is Aopen de enige die deze revisie op de markt zet. Dus de grote jongens als Asus, MSI en ECS doen het niet en dan lijkt het me gewoon een publiciteits stunt een klein bedrijfje als Aopen.
[ Voor 36% gewijzigd door The Source op 30-12-2002 22:26 ]
  • Mizitras
The Source schreef op 30 December 2002 @ 22:23:
Echter de SIS met B-revisie wordt toch al gesampled, niet dan? De licentie is binnen voor HT en SIS zal dit toch al verwerkt hebben en klaarstaan.
Voor mijn part hoeft mijn ASUS mobo geen HT te ondersteunen, zal daar dit jaar, noch tot eind volgend jaar gebruik van maken. Alleen kan ik niet wachten tot midde januari, en ben bang dat het weleens zo lang kan duren.
  • The Source
Ander bijkomend probleem is ook dat SiS zwaar productie tekort heeft. Hebben ze afgelopen maand veel problemen mee gehad (chipset orders niet uitleveren, etc). Maar dat zal o.a. door de deal met UMC opgelost worden (maar pas in mid feb verwachten ze)
  • Mizitras
The Source schreef op 30 December 2002 @ 23:55:
...(maar pas in mid feb verwachten ze)...
Wat ? Een samenwerking verbond of die chips voor te leveren aan de moederbord-fabrikanten?
nieuwsflash;(Gigabyte mobo)
nieuws: Informatie over Gigabytes SiS 655 moederbord .... nu lijkt het te gaan over DDR 400 Dual channel ? Wow ! (... volgens het artikel wordt ie wat duur... dus dan maar geduldig wachten op de ASUS...).
Hier nog wat meer over deze Gigabyteplank;
http://tw.giga-byte.com/products/8sq800ultra.htm
[ Voor 60% gewijzigd door Verwijderd op 02-01-2003 23:27 ]
  • Mizitras
De ASUS zal volgens mij al dan niet on-officiëel moeiteloos DDR400 aansturen :)
Zelfde chipset en het geheel is nog van ASUS ook, lijkt me wel te moeten kunnen met degelijke RAM-sticks :)
  • Mizitras
Nieuwtje van Xbitlabs.com (http://www.xbitlabs.com/news/story.html?id=1041603871)
Although SiS does not issue any press-releases in regards the Hyper-Threading technology support by their chipsets for the Pentium 4 platform, they add their products that can take advantage of the main feature of Intel’s Pentium 4 3.06GHz processor to this table over their web-site, as sources reveal.
Just about a week ago we told you that the B-steppings of SiSR658, SiS648, SiS645DX, SiS651 and mobile SiSM650 can take advantage of the mentioned feature of Intel Pentium 4 processors. There was no word about the SiS655 core-logic, as you can learn from this news-story. Now SiS quietly added their SiS655 chipset to the table, they noted that only B-revisions of the North Bridge can provide the Hyper-Threading technology support.
Fortunately, there have been no mentions about any SiS655-based mainboards for sale anywhere yet. I believer, there is a chance that SiS will start to supply only B-stepping of their dual-channel core-logic. Anyway – keep your eyes open if you buy such mainboards.
Jammer van dat laatste :(
..... euhmmm.....hoezo, volgens mij gaan de B-stepping mobo toch dus op de markt komen ? Of is mijn engels niet goed genoeg om het te snappen ;) ?
  • Spice
Spice
vandaag wat meer nieuws op digitimes
http://www.digitimes.com/...003/01/06&pages=04&seq=19
Motherboards based on the dual-channel-DDR333 SiS655 chipset from Silicon Integrated Systems (SiS) have recently started hitting the market. For the first batch of products, chipsets used in these boards are the A0-version SiS655, which does not support Intel’s Hyper-Threading Technology.
Currently, Gigabyte Technology, Micro-Star International (MSI) and AOpen have all introduced products based on the A0-version SiS655. Asustek Computer, however, said that it would adopt the Hyper-Threading-enabled B0 version directly. The B0-version SiS655 is sampling at present. Asustek said that volume production of the supporting motherboards is expected to begin at the end of this month.
Although the A0-version SiS655 features dual-channel-DDR333 support, many companies have enhanced their motherboards to support DDR400 through overclocking.
Dat laatste vind ik wel ok :)
Voor de volledigheid, een aanvulling / verduidelijking;
nieuws: SiS ondersteunt HT met SiS 655-chipset=
  • Spice
Spice
hehe er is weer wat nieuws
GA-8SQ800 Ultra2 – The Ultimate Solution for Intel Pentium 4 Platform
The “Dual” Miracle – Leading the Industry with Innovative Technology
ü Ultimate Solution for Intel Pentium 4 Platform
Gigabyte, the worldwide leading motherboard manufacturer, announces the newest GA-8SQ800 Ultra2 as the ultimate solution for the desktop platform. Powered by the latest developed SiS 655/ 963 chipsets and enhanced by Gigabyte solid R&D expertise, GA-8SQ800 Ultra2 delivers an excellent platform equipped with new generation architecture of AGP8X, Dual Channel DDR400, the “Dual” Miracle design, and a variety of notable features. GA-8SQ800 Ultra2 is designed to provide the best solution with highest performance for today's most demanding tasks and for full range of applications now and future.
ü Leading the Industry with “Dual” Miracle Design Plus Enhanced Dual Channel DDR400 Support
The GA-8SQ800 Ultra2 integrates a complete set of cutting-edge technology including the revolutionary “Dual” Miracle design in this full ATX board. The “Dual” concept of the preceding product GA-8INXP had received great awareness and appreciation from media and customer. Five building blocks constitute the “Dual” Miracle design. The first element represents the innovative Dual Power System (DPS) design. The second one is the new generation memory architecture - Dual Channel DDR with enhanced strength for DDR400. The third component is Dual RAID including SATA RAID and ATA133 RAID, which deliver substantial storage capacity and performance. Dual Cooling System, the forth element, is design to further reduce the thermal issue. The last is the well-known DualBIOS™.
ü The “Dual” Miracle
Driven by strong motivation of innovation for excellent quality, Dual Power System (DPS) is the newly developed technology and applied to enhance the stability of the system. The DPS technology is an ingenious design that gives you a power circuit with a total of 6 “phases” - twice the amount recommended by the standard motherboard design guideline. In a DPS (Dual Power System) designed motherboard, an additional 3-phase power circuit DPVRM (Dual Power Voltage Regulator Module) daughter card is added on the motherboard. This effectively provides a more durable and stable power circuit to sustain a larger electric current of up to 150A. The DPS (Dual Power System) technology is conceived and specially designed for intensifying the stability of current system and for future processors that demand a higher working frequency and a more stable and durable power circuit.
Afbeeldingslocatie: http://www.ocworkbench.com/2003/archives/jan/8sq800.png
The SiS655 chipset represents the next generation Dual Channel DDR solution for Intel Pentium 4 platform, while GA-8SQ800 Ultra2 had set the ultimate standard with the support of upcoming mainstream DDR400 memory. The dual channel DDR400 solution provides an supreme bandwidth of 6.4GB/s and gives users even greater performance than that of RDRAM memory which is already well known for its outstanding speed.
Dual RAID
With Silicon Image Serial ATA controller chip and ITE GigaRAID RAID controller chips, the GA-8SQ800 Ultra2 provides two RAID interfaces which provide sound data protection and tremendous capacity for data storage.
Silicon Image Serial ATA controller chip furnish both emerging Serial ATA interface and RAID function to the platform. The Serial ATA interface is the next generation storage interface with scalable performance for desktop platform. With the initial bandwidth of 150MB/s, Serial ATA out-perform current Parallel ATA and delivers superior performance.
The brand new ITE GigaRAID IDE RAID chip, a full function RAID controller, supports RAID 0(Striping), RAID 1(Mirroring), RAID 0+1 function, and JBOD (Just a Bunch Of Drives). JBOD is newly developed function that makes disks appear to be logical one for easier disk management. The ITE GigaRAID also provides additional two UDMA ATA-133/100 interfaces that support up to 4 ATAPI devices such as CD-ROM, and DVD-RW.
Dual Cooling System
The Dual Cooling System consists of a DPVRM active fan sink which gives out a cool, stylish neon-blue colored light when activated, and an active fan sink located on the chipset’s memory controller. With these two active fan sinks, the heat produced by the memory controller and MOSFET located on the DPVRM are greatly reduced. In addition, the airflow path is designed to drain heat out from the fan sink ditches, providing extra ventilation to the surrounding heat dissipating components. With the Dual Cooling System, the GA-8SQ800 Ultra2 further reduces an extra 5 to 10°C as compared to other motherboards without an active fan sink.
DualBIOS™
On Gigabyte motherboards with DualBIOS™ there are physically two BIOS chips. If the main BIOS fail to boot up due to virus infection or catastrophic failure, the back up BIOS automatically takes over on the next system start up. This innovative technology assures the motherboard’s stability and reliability.
ü Supporting Hyper-Threading Technology
Empowered by Gigabyte R&D expertise of hardware and software, 8SQ800 Ultra2, ahead of its competitors, supports Intel Pentium 4 processor with Hyper-Threading Technology even SiS655 (A stepping) chipset is not ready for the new technology at this stage. Gigabyte R&D have strived to solve chipset issue to support Hyper-Threading Technology processor as considering it could be important for customers that the supreme platform to be able to support the latest technology. With the support of Hyper-Threading Technology, 8SQ800 Ultra2 delivers significant performance increase for most multitasking process, especially for multi-media applications. This platform provides exceptional capacity for today’s most demanding Programs and emerging software applications of the future.
üMore Features and benefits
8SQ800 Ultra2 also equips with rich features such as Gigabit LAN, IEEE1394, USB2.0 and 6-Channel Audio for full function desktop computer. Intel 82540EM Gigabit LAN controller is deployed to delivers one Gigabit data throughput for high quality and high performance network connectivity. The highly anticipated IEEE 1394 FireWire is also built-in to enhance PC connectivity for consumer electronics audio/ video (A/V) appliances, and storage peripherals.
The platform had also integrated 6 USB2.0 ports for high-speed connectivity with PC peripherals, 6-channel audio for the enjoyment of 3D surround sound effect. Bundled with rich features, GA-8SQ800 Ultra2 represent an ideal solution for multi-purpose platform.
ü Xpress™ install – Make Driver Installation Just so Simple
The Xpress™ install is a unique utility developed by Gigabyte’s creative engineering team to simplify driver installation and is revealed to the market recently. It is aimed to ease the driver installation for the computer hardware and deliver a complete different experience. Simply a few clicks to select the recommended drivers, and the drivers will be completely installed automatically. With the Xpress™ install utility, not only the time saving is significant, the driver accuracy is also improved. The Xpress™ Install makes driver installation just so simple!
ü Value-Added Gigabyte Unique Designs
Several user-friendly designs are implemented in GA-8SQ800 Ultra2. The orange color of memory DIMMs is applied to indicate the 1st DIMM of each channel for user to easily utilize dual channel bandwidth, while the purple color of remains memory DIMMs shall indicate DDR400 supporting. With color-coded front panel connector design, user should feel much easier during the system installation. The EZ-Fix AGP slot is designed for easy installation and preventing from discarding. Finally, The Gigabyte patented Crack-Proof design of IDE and floppy connectors is aim to prevent damage even if un-proper handling of cable during installation. All of these value-added designs contribute to the merit of GA-8SQ800 Ultra2.
ü 8SQ800 Ultra2 Main Specification
• Socket 478 for Intel® new 0.13 micron-process Pentium® 4 processor
• SiS 655/963 Chipset
• Supports FSB 533/400 MHz
• AGP 8x/4x, 5 PCI slot
• Dual Channel DDR400*/333 with 4 DIMMs, support up to 4GB memory
• DPVRM (Dual Power Voltage Regulator Module) for Dual Power System
• Intel 82540EM Gigabit LAN connection
• Silicon Image Serial-ATA interface
• ITE GigaRAID IDE RAID interface
• 3 IEEE1394 ports (via daughter card)
• 6 USB 2.0/1.1 ports
• 6-channel AC97 audio
• 2 Ultra ATA133 Connectors
• Xpress Installation, Easytune™ 4, Q-Flash™, @BIOS™
*DDR400 recommended memory modules are listed in GIGABYTE website
  • Mizitras
Spice schreef op 13 January 2003 @ 14:29:
hehe er is weer wat nieuws..
[knip]
Bron ? Gigabyte zelf?
Wanneer zou deze dan gaan uitkomen vraag ik mij af?
Iemand nog reviews gezien ergens? Ik spot die SIS655-equiped moederborden dus nergens hé, noch reviews op het net,laat staan dat er een winkel mij kan zeggen wanneer ze die binnen gaan hebben. :(
Knip added
[ Voor 92% gewijzigd door Abbadon op 14-01-2003 09:21 ]
  • Spice
Spice
bron. sorrie kon je uit de pic halen :)
http://www.ocworkbench.co...gi?newsid1042455381,28936,
Mizitras schreef op 13 januari 2003 @ 22:38:
Kopieerd de hele grote lap tekst....
Kan je misschien effe je knippen.... anders staan er 2 van diezelfde grote lappen tekst ;)
  • Mizitras
-In vervolg knippen en niet te lui zijn dus
-Beter opletten op de belekes.
Heren, mijn excuses aan jullie beide _/-\o_
Over de ASUS P4SDX:
Deze lijkt me wat 'oud' in vgl. met de gigabyte.
-Die ASUS, ondersteunt die RAId ook JBOD-'modus' ? (Doen die RAID-chips op
meeste moederborden dat eigenlijk allemaal, of toch niet zooo standaard?)
-Gaat die ASUS zijn FSB ook naar 667Mhz of zelfs 800Mhz te clocken zijn?
Bij de granite bay kon je met 'gemak' naar 200Mhz (quad pumped, dus 800Mhz),
maar wat met deze ???
-Op features alleen, afgezien van prestatie of andere zaken, zou je dan ZELF niet Gigabyte kiezen? Lijkt mij dat zei toch meer waarde voor je geld gaan aanbieden, denk ik toch immo.
Ivm beschikbaarheid:
Wacht zelf op reactie winkel, zal mij iets laten weten zodra de dealer iets aan hun heeft laten weten. Verwacht nog iets van ze deze werkweek.
Morgen bel ik naar m'n eigen hardwareboer of ga er langs en ga eens horen hoever het met mijn bestelling staat,...uiteraard volledig onschuldig en een beetje misnoegd dat het zolang duurt hé :p
Maja, als onwetende van wat er allemaal gebeurt met die chips enzovoort, zal ik is vies zien en misschien wat afpingelen???
Vraag van de dag:
-Als je 2-maand zonder moederbord zou zittenomdat je er één hebt besteld en dat maar blijft aanslepen, zou je, en mag je dan eigenlijk wel iets terugeisen???
[ Voor 29% gewijzigd door Mizitras op 14-01-2003 21:40 . Reden: Deeply Dipply 'bout the curves you got. ]
ik denk dat ik er persoonlijk, nu wel uitkom :P
  • GekkeR
  • Laatst online: 11-11 12:35
GekkeR
key = key
Mizitras schreef op 14 January 2003 @ 21:17:
<knip>
<knip>
En waar heb jij dat gelezen ?
Overal lees ik maximum 195FSB (met geluk) en meestal 166FSB normaal.
[ pctje te zien hier ] - Miauw
  • The Source
SiS655 komen pas na chinees nieuwjaar op de markt maar ze zullen wel over B0 revisie beschikken, dus met HT support. Dus gok maar dat ze eind feb te krijgen zijn.
  • Spice
Spice
membench op ocworkbench
Afbeeldingslocatie: http://www.ocworkbench.com/2003/archives/jan/sis655memory.jpg
SiSoft Memory benchmarks running SIS 655 on 2 x DDR400 module at Async DDR333 mode using P4 2.4G. e.g. 133/166 at CAS 2,2-2-5
als dit met een fsb van 133 is kan het nog leuk worden, extrapoleer maar naar 166 :)
  • Spice
Spice
AOpen AX45-4D Max review
Mit dem SiS655 präsentiert die taiwanesische Chipsatzschmiede den derzeit schnellsten DDR-SDRAM Chipsatz für Pentium 4 Prozessoren - und das nicht nur auf dem Papier. Teils mögen die Unterschiede marginal sein, das stellt unsere Aussage allerdings nicht in Frage. Das überraschende ist allerdings, dass bei dieser Plattform nicht zwingend das Dual Channel Feature verwendet werden muss, um ein performantes System zu erhalten.
Im Game-Bereich lagen die Leistungsvorteile des Zweikanalbetriebs zwischen Single und Dual Channel Betrieb ledglich zwischen 1 und 2 % und im Applikationsbereich gerade einmal zwischen 0,5 und 2,2%. Somit erhält der Anwender also auch mit nur einem DDR333-Modul ein sehr schnelles System, welches sich vor Intels i845PE-Chipsatz platzieren kann.
Absolut leistungsschwach ist der SiS655 jedoch im Dual Channel DDR266 Betrieb. Hier sieht man an unseren Messungen, dass Intel dieses System mit dem E7205 Chipsatz deutlich besser umgesetzt hat. Um sich aber in Leistungsregionen des i850E-Chipsatzes zu begeben, bedarf es dann wie auch schon beim E7205-Chipsatz, dem Dual Channel Mode und zwar mit scharfen Speichersettings. Möglicherweise kann die kommende Chipsatzrevision B0 noch einmal leichte Vorteile für sich verzeichnen, was jedoch die Zukunft zeigen muss. Wirkliche Schwächen konnten wir bei dem jungen Chipsatz nicht verzeichnen.
Afbeeldingslocatie: http://www.hardtecs.de/reviews/2003/aopen_ax45-4d_max/intro.jpg
Dem Träger dieses Chipsatzes, dem AOpen AX45-4D Max, welches in einer sehr frühen Revision und mit frühen Beta BIOS-Versionen antrat, können wir ebenfalls Lob aussprechen. Im alltäglichen Einsatz fanden sich bislang lediglich Schwachpunkte bei der Umsetzung der Suspend Modes, was jedoch, wie uns der Hersteller versicherte, bereits gefixt wurde, und teilweise bei den USB 2.0 und Firewire Messungen, was sicherlich noch gefixt werden kann. Damit kaum wirkliche Kritikpunkte für ein solch junges Testboard.
Im Bereich Layout haben die AOpen Ingeneuere ein durchdachtes Mainboard präsentiert, welches zudem mit sehr sinnvollen Features wie Dual BIOS ("Die Hard BIOS") oder Lüftersteuerung per BIOS ("Silenttek") aufwartet. Im Bereich Hardware-Lieferumfang zeigte sich das AX45-4D Max absolut komplett, softwareseitig findet man aber lediglich einen Viren-Scanner von Symantec und Hersteller-eigene Tools vor.
Die finalen Revisionen des AX45-4D Max werden in den kommenden Wochen den deutschen Markt erreichen. Als unverbindliche Preisempfehlung nannte AOpen uns ca. 159 Euro, was ein wirklich attraktiver Preis für ein brandneues Board mit brandneuem Chipsatz ist. Berücksichtigt man, dass sich gut ausgestattete SiS648-Platinen in Preisregionen zwischen 135 und 150 Euro bewegen, performante und gut ausgestattete Platinen mit Intel-Chipsatz sogar noch darüber, so darf man schlussendlich behaupten, dass AOpen mit dem AX45-4D Max nicht nur das Mainboard mit dem derzeit schnellsten DDR-SDRAM Chipsatz für Pentium 4 CPUs im Programm hat, sondern auch eine Platinen mit wirklich ausgezeichnetem Preis/Leistungsverhältnis.
http://www.hardtecs4u.com/reviews/2003/aopen_ax45-4d_max/
  • NitroX infinity
  • Laatst online: 13:30
En voor de mensen die moeite hebben met Duits: http://babel.altavista.com :)
Over de foto die spice postte van de GA-8SQ800 Ultra2:
Wat is dat slot tussen de paralelle poort en de socket?
Graphene; a material that can do everything, except leave the lab. - Asianometry
  • |sWORDs|
|sWORDs|
vSphere/ESXi
NitroX_infinity schreef op 15 januari 2003 @ 11:44:
Afbeeldingslocatie: http://www.tweakers.net/ext/i.dsp/1037195231.jpg
"DPS is een extra plankje dat onder andere zorgt voor betere stabiliteit. Interessanter is echter de mogelijkheid die dit systeem biedt om de power op te fokken naar 225W en de stroomsterkte tot 150A te duwen. Deze boost moet zorgen dat ook de nieuwe Pentium 4 processors met een Prescott core in de plank kunnen worden geprikt. "
[ Voor 33% gewijzigd door |sWORDs| op 15-01-2003 11:56 . Reden: plaatje en uitleg ]
  • Mizitras
The Source schreef op 15 januari 2003 @ 00:45:
*krijgt zenuwinzinking*
* Mizitras herinnert zich nog de mail van ASUS de 23ste december 2002:
"The P4SDX with SIS655 will be out due end of december 2002"
  • Spice
Spice
AOPEN AX45-4D Max Dual Channel SiS 655 Gallery
http://www.ocworkbench.co...gi?newsid1042636944,64965,
Dan zal de review ook wel snel komen, herstel staat er al.
Afbeeldingslocatie: http://www.ocworkbench.com/2003/aopen/ax45-4dmax/Picture%20380%20copy.jpg
Conclusion
AOPEN AX45-4D Max is the first SiS 655 board we review at OCworkbench. As this is a board with a beta bios, performance of this board is mixed, with good scores in certain categories like the CCWS, BWS. In terms of 3D performance, it somehow needs some fine tuning.
Features-wise, this board has some nice features like the Diehard bios, ezrestore, silent bios and Silent tek. There is also 1394 and voice diagnostics. Installation is easy but we had to "hunt down" the +12v connector. It is camouflaged around capacitors. The BIOS is not really finalised and we would expect future BIOS to introduce fix pci/agp settings as the current bios seems to only supply a divider of 3.
Overclocking wise, this board has 1Mhz stepping and also an independent PCI/AGP setting if you wish to keep your FSB at 133(533) and just overclock your PCI and AGP bus. Voltage adjustments are also available for Vcore, VDIMM, VAGP.
Overall, it is a good board based on the latest dual channel ddr chipset. If the price is right and you won't be pairing it with a P4 3.06G Hyperthreading CPU, this board might be a good choice for you.
* The benchmarks done so far are based on a beta bios supplied by AOPEN. We expect the final BIOS will improve the performance further and solve some of the problems we faced during testing.
Afbeeldingslocatie: http://www.ocworkbench.com/2003/aopen/ax45-4dmax/sisoft.gif :)
Beste p4 plank overall tot-nu-toe imho, helaas was dit exemplaar niet geweldig te oc'en :(
  • The Source
Mizitras schreef op 15 January 2003 @ 15:43:
Ik hoorde vandaag dan Asus ook A0 revisies op de markt gaat brengen... B0 revisie (met HT support) is nog niet klaar en wordt pas in februari verwacht. Dus pas goed op als je iets koopt!!!
  • Mizitras
The Source schreef op 16 January 2003 @ 20:11:
Mijn P4 2.53 (gekocht in september, rararara naar de prijs) die ik dus al sinds oktober niet heb kunnen gebruiken ondersteunt geen HT. alé ja, 'het is niet geactiveerd door Intel", als dat beter klinkt ;)
Ik hoop dan echt dat die A0 revisie in snelheid (los van HT) en stabiliteit niet gaat moeten onderdoen voor de B0/B1 versie(s).
Hopelijk komt die hap dan ZEER snel naar de dealers, die het zelf nu nog altijd niet weten. (Heb de Belgische ASUS verdelers al het vuur aan de schenen zitten leggen, en drie winkels ook non-stop naar de beschikbaarheid van hun producten zitten vragen >:)
Eind januari geen SIS655 bordje, koop ik me wel een Granite Bay bord, waar ik ferm tegenop zal kijken :(
  • The Source
Mizitras schreef op 16 januari 2003 @ 22:32:
Damien Cloetens in België wist vandaag iig nog niets van Asus 655.
Nog ff over granite bay.Wat is er dan mis met de GA 8INXP van Gigabyte bijv?Het lijkt me een geweldig moederbord,is leuk over te klokken en FSB loopt synchroon met (relatief goedkoop)DDR 266 geheugen in dualconfiguratie.Misschien moet ik erbij vermelden dat ik ga voor de P4 op 2,2 of 2.66Gig.Ik zou niet weten wat dit bord,behalve Firewire mist.1394 gebruik ik toch niet.Ik heb em besteld en w8 met smart!!! :Y)
[ Voor 5% gewijzigd door Verwijderd op 17-01-2003 00:09 ]
  • Spice
Spice
SiS 655 North Bridge A0 stepping. Although it does not officially support Hyperthreading, it seems that there are chances that it might just unofficially support it
Afbeeldingslocatie: http://www.ocworkbench.com/2003/gigabyte/sinxp1394/Picture%20432%20copy.jpg
Alternatief voor Mindscan :)
Gigabyte SINXP1394 SiS655 Dual Channel DDR Mainboard:
The BIOS version M01 dated 3 Jan 2003
FSB can be tuned from 100 to 355 at 1mhz stepping. You can also adjust the FSB within Windows using EasyTune 4. In this screen, you can also fix the PCI/AGP to 33/66 to run independently of the FSB.
Afbeeldingslocatie: http://www.ocworkbench.com/2003/gigabyte/sinxp1394/Picture%20435%20copy.jpg
There are multiple DRAM Clk which is this case, you can run your memory at Async memory settings. e.g. CPU at 133, memory at DDR333, DDR360 etc.
Afbeeldingslocatie: http://www.ocworkbench.com/2003/gigabyte/sinxp1394/Picture%20436%20copy.jpg
meer op: http://www.ocworkbench.co...cgi?newsid1042727923,4205,
  • Mizitras
The Source schreef op 16 januari 2003 @ 22:56:
Hehe, jep. Zelf heb ik een andere Cloetens gemaild. Wist ook nog niets.
Wacht nu nog op reactie van een andere dealer, 4mbo.be denk ik.
  • Afwezig
Is er al meer bekend over de release van de P4SDX ? Mijn comp is namelijk nu aan het overlijden ;)
  • |sWORDs|
|sWORDs|
vSphere/ESXi
* |sWORDs| krijgt ook haast met z'n Gigabyte SINXP1394, mijn huidige moederbord moet over 1 week weg.
thnx spice ik ga ff kijken
  • Mizitras
GigaByte 8SQ800 bordje is al verkrijgbaar, als je interesse zou hebben...
  • |sWORDs|
|sWORDs|
vSphere/ESXi
Mizitras schreef op 22 januari 2003 @ 14:10:
wat raar. Hier staat dat de 8SQ800, sis 655 chipset heeft. Echter de bedrijven in de pricewatch hebben er 645 of 648 bij staan. Ook vreemd is dat het bord nog steeds zo heet, gezien dit bericht. Hoe kan dit?
edit het lijkt erop dat deze bedrijven zich in de sg en sq vergist hebben, bij easy com staat wel de goede in de lijst voor 130 euro.
[ Voor 27% gewijzigd door |sWORDs| op 22-01-2003 19:44 ]
  • Mizitras
sWORDs schreef op 22 januari 2003 @ 19:36:
Erg hé :(
  • |sWORDs|
|sWORDs|
vSphere/ESXi
??? Wat bedoel je?
  • Spice
Spice
review is nu officieel af bij ocworkbench.
De conclusie:
This is definitely one of the most exciting boards released in 1Q 2003. It has a neat set of features. In our local terms, we say that it's the most KIASU board ever producted. It has almost everything that you can think of - Gigabit Ethernet, USB 2.0, RAID (SATA and IDE), External bracket for SATA devices, it makes connectivity to other devices easier than before. It also has 6 channel audio, 1394, Dual RAID, Dual Channel DDR400, Dual Power System (DPS), Hyper threading support (P4 3.06), Dual BIOS, SPDIF In/out, overclocking, AGP 8x, 1394 etc.
The DPS makes its way to a SiS based board. If you recall, the DPS allows backup or use together to form a 6 phase voltage regulator. Some boards only uses 2 phase while Gigabyte chose a 3 phase. We have known that some companies implemented 4 phase solutions before and now a 6 phase. DPS is indeed an innovative way to make systems more reliable.
In contrary to the 8INXP, the SINXP1394 seems to be a better performer in desktop applications and performs average in 3D benchmarks. This seems to be the case with BIOS and I think future BIOS should be able to tune it up.
Overclocking wise, this board has 1Mhz stepping and also an independent PCI/AGP setting if you wish to keep your FSB at 133(533) and just overclock your PCI and AGP bus. Voltage adjustments are also available for Vcore, DIMM. We are able to o/c to 143Mhz fsb using a P4 1.8A SL63X with DPS. If not DPS is used, 139 is the max we can go.
Suggested Retail ~ USD 210.00
Discuss
Pros 好处:
Overclocking features
6 Channel audio
USB 2.0
1394 thru external bracket
Dual Channel DDR333/400
SATA RAID 0/1+ ATA RAID 0/1/0+1
DPS
Exterior bracket for SATA ports
Cons 坏处:
Voltage tweaking limited, only +0.1v
CLR_CMOS has no jumpers for clearing CMOS
Performance can be further tuned up
Should have included 1394 ports on back panel
Ratings
Here are my ratings out of 10 stars.
Category
Score
Performance 9 / 10
Features 10 / 10
Ease Of Installation 10 / 10
Overclocking Features 8 / 10
Documentation 9 / 10
Overall Rating : 9.2 / 10
link: http://www.ocworkbench.co...gi?newsid1043309542,91658,
  • Mizitras
Wel over het feit dat ze verkeerd adverteren.
Ps: Iemand een idee (webgoeroe?) wanneer die Gigabyte gaat uitkomen die hierboven gereviewed is?
  • The Source
Mizitras schreef op 23 januari 2003 @ 21:51:
De SiS655 mainboards worden na Chinees nieuwjaar gereleased maar in low Q. Dus MP begin mrt.
  • The Source
Sis 655 met B0 stepping... weet niet of het final versie is...
http://www.ocworkbench.com/2003/archives/jan/sis655b0.jpg
[ Voor 5% gewijzigd door The Source op 25-01-2003 11:44 ]
  • Mizitras
The Source schreef op 24 January 2003 @ 20:18:
En dat nieuwjaar is toch al voorbij, niet? En in kleine hoeveelheden, wil dat zeggen, niet voor de particulier???
Volgende post zei je iets van B0-stepping...had je het hierboven ook over B0 specifiek?
Winkel zei me nu, "eind januari" dat ze het zouden hebben.
(ASUS P4SDX bordje dat is)
  • The Source
url plaatje b0 stepping was weggevallen :)
nop, chinees nieuwjaar is nog niet voorbij, dat is eind jan / beg feb. Dus dan ligt alles een week stil in Taiwan, etc. Aangezien er nu net B0 steppings samples zijn dan weet je dus 100% zeker dat alle Sis 655 mainboards die je voor half februari kunt krijgen voorzien zijn van een A0 stepping (zonder HT support).
  • EfBe
Ik zou de mensen die meteen een nieuwe ASUS plank willen gaan aanschaffen op het hart willen drukken: wees geduldig en wacht een maandje of 2. ASUS brengt, net als vele andere mobo-fabrikanten, veelal na een maandje een revisie uit van het 1e ontwerp. Dit kan veelal onverklaarbare crashes/lockups schelen. Just a thought... (ik heb dit 2 keer gehad al bij ASUS, dat een 1e release board niet goed werkte en werd vervangen door een bord dat een revisie later bleek te zijn, kost je toch weer een maandje...)
Creator of: LLBLGen Pro | Camera mods for games
Photography portfolio: https://fransbouma.com
  • Spice
Spice
Afbeeldingslocatie: http://www.ocworkbench.com/2003/archives/jan/sis655b0.jpg
overduidelijk b0
  • Mizitras
EfBe schreef op 25 January 2003 @ 19:18:
Als je lang moet wachten kan dit er echter -soms- niet meer bij :)
En als het echt een verschil zou geven, dan laat ik die wel omruilen,
ze kennen me toch bij de winkel :D
Voor al de anderen, zou ik je advies ten zeerste aanraden! Of je moet goed bij je winkel staan.
  • |sWORDs|
|sWORDs|
vSphere/ESXi
Mizitras schreef op 26 januari 2003 @ 01:21:
Om maar even aan te geven hoe erg het hier. Ik zit nu op een 486 met 16 mb te internetten. (laden van tweakers.net homepage duurt 1 minuut en 20 seconden)
Ik moet het bordje snel hebben voor ik echt gek wordt. (was ik dat niet al?)
  • Mizitras
sWORDs schreef op 28 January 2003 @ 00:01:
Hm, oké niet zo erg, maar ik heb er wel tot eind vorig jaar op gewerkt:
Pentium 166 64mb (geen mmx) 2meg videokaart(tje).
Tegen pcmark zegt ie toch f*ck you, dus zelfs testen ging niet :p
gigabyte GA-8SQ800 met sis 655 zou hier te koop zijn.
http://www.computeruniverse.net/
Verwijderd schreef op 31 January 2003 @ 19:16:
... en dat voor 135-. ... niet onaardig !
Giga Byte GA-8SQ800, Sockel 478, ATX,
SIS655, Sound, IEEE1394, USB 2.0, AGP,
FSB533, ATA133, 5x PCI
135,-
  • EfBe
AnandTech heeft het MSI bordje met deze chipset gereviewed, zag het net op de FP: nieuws: MSI 655 Max moederbordreview @ AnandTech. Nu maar hopen dat de retail binnenkort wat bordjes met een B0 stepping in de schappen heeft...
  • Spice
Spice
Dan is de volgende link ook wel handig: http://www.msi.com.tw/htm...t_news/2003_0130_6730.htm
Afbeeldingslocatie: http://www.msi.com.tw/images/news_img/655max001.jpg
  • Kawaii
Een ding is mij niet helemaal duidelijk sommige reviewers zeggen dat de SiS 655 chipset dual-channel DDR 333 ondersteunen en andere dat ie dual-channel DDR 400 :?
Wat is het nou......
  • Mizitras
An00bis schreef op 03 februari 2003 @ 20:33:
SIS655 ondersteund om tegen Graniten Bay van den Intel te gaan DDR333 (ipv DDR266), maar net zoals hun SIS648-chipset, zal ook deze officiëus DDR400 ondersteunen, al dan niet garantie bieden voor DIMM's getest door de fabrikanten en daarmee in de lijst opgenomen (met zo'n sterretje ;) ***) op hun website.
Kortom, imho, SIS655-bordjes zullen met meeste DDR400-stick's wel degelijk werken.
  • ken
  • Laatst online: 20-11 22:28
ken
Verwijderd schreef op 31 januari 2003 @ 19:16:
zou deze al uit zijn dan en met HT ??
Canon 5D Mark II, Canon 35 f/1.4L
  • Spice
Spice
ASUS P4SDX DualChannel SiS 655 B0 board - Gallery is up!
http://www.ocworkbench.co...gi?newsid1044311753,87770,
  • EfBe
Ook sterk naar SiS' reference design zo te zien :) (de plaatsing van de dimm sockets verraad dat). Goed om te zien dat Asus' niet ver weg is met zn plankje met deze geweldige chipset :P Het review van OCWB zal zo wel komen neem ik aan. Wel gaaf aan dit bordje is dat itt MSI's plank, de powersockets erg goed geplaatst zijn, strak aan de rand.
[ Voor 12% gewijzigd door EfBe op 04-02-2003 11:47 ]
zijn er al goede bench maks van de nieuwe sis tegen de granite bay?
ik ben erg benieuwd.
Hopelijk scoort de granite bay beter :P
Zo niet dan ga ik waarschijnlijk voor de gigabyte 8SQ800 ultra 2
  • Abbadon
Verwijderd schreef op 04 February 2003 @ 18:15:
MSI 655 MX review :) Heb 'm nog niet gelezen maar volgens de samenvatting doet 'ie het goed, vooral als je er DDR400 geheugen in propt.
Anandtech: First off, we can safely say that MSI's 655 Max motherboard is the fastest Pentium 4 motherboard we've ever tested
Zag dat EfBe deze gisteren hier al neergeplant had :P
[ Voor 6% gewijzigd door Abbadon op 04-02-2003 20:52 ]
Weet er iemand of dit moederbord al in Nederland te verkrijgen is, en zoja waar?
-->of wanneer het dan in NL uitkomt?
Heeft er iemand ervaring met Giga Byte moederborden?
-->of weet iemand een review van dit merk te vinden?
Overwegen er al meer om dit bord te gaan kopen in die zaak in DL ? :9
thnx!
/edit/ ffkes zinnetje bijgezet
[ Voor 13% gewijzigd door Verwijderd op 04-02-2003 21:02 ]
