Het grote 'me nVidia drivers doent nie!' topic
Pagina: 1 ... 6 ... 9 Laatste
  • 6.231 views sinds 30-01-2008
Ok, je praat nu echt chinees voor mij :?
Maar ik ga wel ff kijken,
bedankt
Oke mensen ik heb het geprobeerd maar kwam wat problemen tegen, zoals gewoonlijk :( . Ik had met google een handige hulp gevonden waarin ook mijn probleem opgelost werd :*) namelijk:
http://www.madcow404.com/...a_drivers_Debian_3_0.html
met vooral dit stukje
You may receive an error message regarding different compiler version. If your GCC version is close enough to what was used to compile the kernel, you may ignore this by editing the Makefile that's located in the directory. Simply add the following line at the beggining of the file :
IGNORE_CC_MISMATCH=true
You may receive an error message that ends with something like "nv.c:22: linux/modversions.h: No such file or directory". That means you need to install the appropriate kernel headers files before compiling the driver. This can be done with dselect, but first you need to find out the version of your kernel with the command :
cat /proc/version
Then launch dselect (type in the command dselect). If you need a small introduction to dselect, I suggest the dselect Documentation for Beginners, available at http://www.debian.org/rel.../dselect-beginner.en.html.
In dselect, search for your kernel headers package (use /, then type in headers, then press enter; use \ to cycle through results). When you have selected your package, install it and exit dselect.
You may now receive an error message stating that some file cannot be found. Basically, the Nvidia driver installation looks for the kernel headers in /usr/src/linux, while they are somewhere in /usr/src/kernel-headers-XXXX (XXXX being some version number).
Go to /usr/src ("cd /usr/src"), locate your kernel-headers-XXXX directory ("ls -la | grep kernel"), and then create a symlink called linux to that kernel--headers-XXXX. This is done by typing :
ln -s /usr/src/kernel-headers-XXXX /usr/src/linux
wat ik dus netjes gevolgd heb alleen nu loop ik tegen een nieuw probleem op!!
bij het make install krijg ik:
depmod: Unresolved symbols in /lib/modules/2.2.20-idepci/video/nvidia.o
als ik nu modprobe nvidia doe dan krijg ik:
nvidia.o was compiled for kernel version 2.2.20 while kernel version is 2.2.20-idepci
Weet iemand wat ik hieraan kan doen? Me kernel versie veranderen misschien? maar hoe?
ohja het einde van me XFree86.0.log ziet er nu zo uit:
(II) Setting vga for screen 0.
(II) Loading sub module "vgahw"
(II) LoadModule: "vgahw"
(II) Loading /usr/X11R6/lib/modules/libvgahw.a
(II) Module vgahw: vendor="The XFree86 Project"
    compiled for 4.1.0.1, module version = 0.1.0
    ABI class: XFree86 Video Driver, version 0.4
(**) NVIDIA(0): Depth 24, (--) framebuffer bpp 32
(==) NVIDIA(0): RGB weight 888
(==) NVIDIA(0): Default visual is TrueColor
(==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
(--) NVIDIA(0): Linear framebuffer at 0xF0000000
(--) NVIDIA(0): MMIO registers at 0xEE000000
(EE) NVIDIA(0): Failed to initialize the NVIDIA kernel module!
(EE) NVIDIA(0):  *** Aborting ***
(II) UnloadModule: "nvidia"
(II) UnloadModule: "vgahw"
(II) Unloading /usr/X11R6/lib/modules/libvgahw.a
(EE) Screen(s) found, but none have a usable configuration.
Fatal server error:
no screens found
trouwens ik heb ook dat van intoxicaded aan het begin van dit topic geprobeert, alleen toen kreeg ik een foutmelding bij de 2e regel:
No rule te make target 'mrproper'. Stop
[ Voor 119% gewijzigd door Verwijderd op 19-03-2003 17:48 . Reden: leesbaar gemaakt ]
ok duidelijk een dode topic :(
Nouja goed ik hou debian wel even voor gezien want ik krijg een beetje last van maagzweer zo :P
Hm, na enkele weken 4191 ben ik toch teruggegaan naar 3123... 4191 heeft een aantal irritante bugs, waarbij de nieuwe framebuffer management de meest irritante is. Dit veroorzaakt regelmatig crashes bij specifieke overlay applicaties (m.n. xawtv) die eigenwijs zijn in hoe ze de framebuffer beschrijven.
Na overleg met Mark (de linux driver author van nvidia) bleek 4191 eigenlijk voornamelijk voor de NV30 gereleased te zijn... 3123 is nog steeds de geprefereerde voor GeForce/TNT kaarten.
Dus, voor overlay/crash problemen: neem (vooralsnog) 3123. :).
  • MadEgg
  • Laatst online: 08:22
MadEgg
Tux is lievvv
Bij mij kan ik met 3121 niets beginnen, deze kernel module doet het slechts een keer X-opstarten. Als ik X afsluit moet ik de kernel module opnieuw compileren voordat ik X opnieuw kan starten.
Met 4191 gaat het prima, geen enkel probleem meer mee gehad. En ik heb toch een een GeForce en geen NV30 dorito.
Tja
  • Buffy
  • Laatst online: 00:54
Buffy
Fire bad, Tree pretty
Simon_foo schreef op 13 (?) March 2003 @ 18:21:
Je hebt de nvidia module kernel module kennelijk gecompileerd tegen de verkeerde kernel headers. Als je de stock 2.2.20-idepci debian kernel image gebruikt moet je de juiste kernel headers installeren:
http://packages.debian.or...eaders-2.2.20-idepci.html
Heb je 'make mrproper' soms uitgevoerd in de directory waarin alleen de kernel headers staan?
Daar heb je wel de echte kernele source voor nodig :)
-edit-
Verwijderd schreef op 19 March 2003 @ 18:11:
Bedankt voor de waarschuwing. Was juist van plan te upgraden nadat vrotogel me er fijntjes op had gewezen dat ik een oude versie draai (NVdriver ipv nvidia.o).
Verwijderd schreef op 19 maart 2003 @ 17:35:
Als er 24 uur voorbij is gegaan mag je beste wel kicken ipv je laatste bericht editten. Anders ziet "niemand je kreten om hulp" :)
[ Voor 41% gewijzigd door Buffy op 19-03-2003 22:45 ]
That which doesn't kill us, makes us stranger - Trevor (AEon FLux)
When a finger points at the moon, the imbecile looks at the finger (Chinese Proverb)
  • Slaiter
Slaiter
Firesnake
Na een tijdje windows draaien was het weer eens tijd voor Linux, maar nvidia geeft weer problemen (de 3123 drivers).
Ik heb nu debian draaien (unstable) en de laatste tarballs van nvidia binnen gehaald, na de instalatie van de drivers X proberen te starten en het liep perfect.
Omdat ik multiboot ga ik ook wel eens uit linux en al ik dan weer inlog kom ik gewoon in console uit, dat is opzich geen probleem (zelfs wel handig), maar X word niet meer opgestart
de foutmelding die ik krijg is dat X de nvidiadriver niet kan inladen en dat terwijl die wel gewoon aanwezig is.
ALs ik naar X wil moet ik iedere keer de driver met de hand laden (modprobe NVdriver) en dan start X wel op, maar dat moet toch gewoon standaard gestart worden na een startx commando?
Tijdens het laden van X krijg ik geen verdere errors behalve dus dat de nvidia driver niet gevonden kan worden.
Tijdens het inladen van de module krijg ik ook wel de bekende taint kernel error en dat de dribver niet onder GPL valt, maar verder geen rare dingen gezien
Mijn systemconfiguratie staat in mijn sign
[ Voor 10% gewijzigd door Slaiter op 21-03-2003 08:12 ]
  • Buffy
Buffy
Staat er in /etc/modules.conf de volgende twee regels?
alias /dev/nvidia* NVdriver
alias char-major-195 NVdriver
Als je de kernel module de debian way gemaakt hebt dan zou dat er moeten staan. Want de .deb zet in /etc/modutils een bestand nvidia-kernel-2.X.XX-XXXX waarin deze twee regels staan (en voerd update-modules uit).
Als ze er wel instaan kan je altijd nog een regel met NVdriver in /etc/modules zetten zodat de module tijdens het boot al wordt geladen.
  • Magic
ook ik heb een probleempje met het installen van de nvidia kernel. ik heb hem al vaker geinstalleerd op alle redhat releases vanaf 7.0, en mandrake 9, en altijd zonder problemen. nou heb ik vandeweek mandrake 9.1 geinstalleerd en hier wil ik uiteraard ook ut2003 onder spelen, maar deze foutmelding gooit roet in het eten.
zodra ik de source rpm wil rebuilden, geeft hij dit:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
176
177
178
179
180
181
182
183
184
185
186
187
188
189
190
191
192
193
194
195
196
197
198
199
200
201
202
203
204
205
206
207
208
209
210
211
212
213
214
215
216
217
218
219
220
[root@Magic magic]# rpm --rebuild NVIDIA_kernel-1.0-4191.src.rpm
Installing NVIDIA_kernel-1.0-4191.src.rpm
Executing(%prep): /bin/sh -e /var/tmp/rpm-tmp.51173
+ umask 022
+ cd /usr/src/RPM/BUILD
+ rm -rf NVIDIA_kernel-1.0-4191
+ /bin/gzip -dc /usr/src/RPM/SOURCES/NVIDIA_kernel-1.0-4191.tar.gz
+ tar -xf -
+ STATUS=0
+ '[' 0 -ne 0 ']'
+ cd NVIDIA_kernel-1.0-4191
+ exit 0
Executing(%build): /bin/sh -e /var/tmp/rpm-tmp.51173
+ umask 022
+ set +e
++ rpm -q --queryformat '%{VERSION}' rpm
+ RPMVERSION=4.0.4
++ echo 4.0.4
++ awk -F . '{print $1;}'
+ RPMMAJOR=4
++ echo 4.0.4
++ awk -F . '{print $2;}'
+ RPMMINOR=0
++ echo 4.0.4
++ awk -F . '{print $3;}'
+ RPMPATCH=4
+ '[' 4 -le 3 -a 0 -le 0 -a 4 -lt 4 ']'
+ make nvidia.o
echo \#define NV_COMPILER \"`cc -v 2>&1 | tail -1`\" > nv_compiler.h
cc -c -Wall -Wimplicit -Wreturn-type -Wswitch -Wformat -Wchar-subscripts -Wparen
theses -Wpointer-arith -Wcast-qual -Wno-multichar  -O -MD -D__KERNEL__ -DMODULE
-D_LOOSE_KERNEL_NAMES -DNTRM -D_GNU_SOURCE -D_LOOSE_KERNEL_NAMES -D__KERNEL__ -D
MODULE  -DNV_MAJOR_VERSION=1 -DNV_MINOR_VERSION=0 -DNV_PATCHLEVEL=4191  -DNV_UNI
X   -DNV_LINUX   -DNV_INT64_OK   -DNVCPU_X86       -I. -I/usr/src/linux/include
-Wno-cast-qual nv.c
In file included from /usr/include/linux/prefetch.h:13,
                 from /usr/include/linux/list.h:6,
                 from /usr/include/linux/module.h:11,
                 from nv-linux.h:28,
                 from nv.c:14:
/usr/include/asm/processor.h:55: `CONFIG_X86_L1_CACHE_SHIFT' undeclared here (no
t in a function)
/usr/include/asm/processor.h:55: requested alignment is not a constant
In file included from /usr/include/linux/module.h:297,
                 from nv-linux.h:28,
                 from nv.c:14:
/usr/include/linux/version.h:2:2: #error "======================================
/usr/include/linux/version.h:3:2: #error "You should not include /usr/include/{l
inux,asm}/ header"
/usr/include/linux/version.h:4:2: #error "files directly for the compilation of
kernel modules."
/usr/include/linux/version.h:5:2: #error ""
/usr/include/linux/version.h:6:2: #error "glibc now uses kernel header files fro
m a well-defined"
/usr/include/linux/version.h:7:2: #error "working kernel version (as recommended
 by Linus Torvalds)"
/usr/include/linux/version.h:8:2: #error "These files are glibc internal and may
 not match the"
/usr/include/linux/version.h:9:2: #error "currently running kernel. They should
only be"
/usr/include/linux/version.h:10:2: #error "included via other system header file
s - user space"
/usr/include/linux/version.h:11:2: #error "programs should not directly include
<linux/*.h> or"
/usr/include/linux/version.h:12:2: #error "<asm/*.h> as well."
/usr/include/linux/version.h:13:2: #error ""
/usr/include/linux/version.h:14:2: #error "To build kernel modules please do the
 following:"
/usr/include/linux/version.h:15:2: #error ""
/usr/include/linux/version.h:16:2: #error " o Have the kernel sources installed"
/usr/include/linux/version.h:17:2: #error ""
/usr/include/linux/version.h:18:2: #error " o Make sure that the symbolic link"
/usr/include/linux/version.h:19:2: #error "   /lib/modules/`uname -r`/build exis
ts and points to"
/usr/include/linux/version.h:20:2: #error "   the matching kernel source directo
ry"
/usr/include/linux/version.h:21:2: #error ""
/usr/include/linux/version.h:22:2: #error " o Now copy /boot/vmlinuz.version.h t
o"
/usr/include/linux/version.h:23:2: #error "   /lib/modules/`uname -r`/build/incl
ude/linux/version.h"
/usr/include/linux/version.h:24:2: #error ""
/usr/include/linux/version.h:25:2: #error " o When compiling, make sure to use t
he following"
/usr/include/linux/version.h:26:2: #error "   compiler option to use the correct
 include files:"
/usr/include/linux/version.h:27:2: #error ""
/usr/include/linux/version.h:28:2: #error "   -I/lib/modules/`uname -r`/build/in
clude"
/usr/include/linux/version.h:29:2: #error ""
/usr/include/linux/version.h:30:2: #error "   instead of"
/usr/include/linux/version.h:31:2: #error ""
/usr/include/linux/version.h:32:2: #error "   -I/usr/include/linux"
/usr/include/linux/version.h:33:2: #error ""
/usr/include/linux/version.h:34:2: #error "   Please adjust the Makefile accordi
ngly."
/usr/include/linux/version.h:35:2: #error "=====================================
In file included from nv-linux.h:28,
                 from nv.c:14:
/usr/include/linux/module.h:299: parse error before "UTS_RELEASE"
/usr/include/linux/module.h: In function `print_symbol':
/usr/include/linux/module.h:433: `ESRCH' undeclared (first use in this function)
/usr/include/linux/module.h:433: (Each undeclared identifier is reported only on
ce
/usr/include/linux/module.h:433: for each function it appears in.)
In file included from nv-linux.h:29,
                 from nv.c:14:
inux,asm}/ header"
kernel modules."
m a well-defined"
 by Linus Torvalds)"
 not match the"
only be"
s - user space"
<linux/*.h> or"
 following:"
ts and points to"
ry"
o"
he following"
 include files:"
clude"
ngly."
In file included from nv.c:14:
nv-linux.h:31:40: missing binary operator before '('
nv-linux.h:33:42: missing binary operator before '('
nv-linux.h:35:42: missing binary operator before '('
nv-linux.h:37:42: missing binary operator before '('
nv-linux.h:39:42: missing binary operator before '('
nv-linux.h:43:4: #error This driver does not support 2.6.x or newer kernels!
In file included from /usr/include/asm/hardirq.h:6,
                 from /usr/include/linux/interrupt.h:46,
                 from nv-linux.h:71,
                 from nv.c:14:
/usr/include/linux/irq.h: At top level:
/usr/include/linux/irq.h:65: `CONFIG_X86_L1_CACHE_SHIFT' undeclared here (not in
 a function)
/usr/include/linux/irq.h:65: requested alignment is not a constant
In file included from /usr/include/linux/interrupt.h:46,
                 from nv-linux.h:71,
                 from nv.c:14:
/usr/include/asm/hardirq.h:16: `CONFIG_X86_L1_CACHE_SHIFT' undeclared here (not
in a function)
/usr/include/asm/hardirq.h:16: requested alignment is not a constant
In file included from nv-linux.h:71,
                 from nv.c:14:
/usr/include/linux/interrupt.h:129: `CONFIG_X86_L1_CACHE_SHIFT' undeclared here
(not in a function)
/usr/include/linux/interrupt.h:129: requested alignment is not a constant
nv-linux.h:184:64: missing binary operator before '('
nv.c:1335:65: missing binary operator before '('
nv.c: In function `nv_kern_mmap':
nv.c:1338: warning: implicit declaration of function `pgprot_writecombine'
nv.c:1338: incompatible types in assignment
make: *** [nv.o] Fout 1
+ exit 0
Executing(%install): /bin/sh -e /var/tmp/rpm-tmp.28561
+ umask 022
+ rm -f /tmp/files.lst
+ '[' -z '' ']'
++ uname -r
+ export TARGET_KERNEL=2.4.21-0.13mdk
+ TARGET_KERNEL=2.4.21-0.13mdk
+ '[' -d /lib/modules/2.4.21-0.13mdk/kernel ']'
+ INSTALLPATH=/lib/modules/2.4.21-0.13mdk/kernel/drivers/video
+ mkdir -p /var/tmp/NVIDIA_kernel-1.0//lib/modules/2.4.21-0.13mdk/kernel/drivers
/video
+ install -m 0444 nvidia.o /var/tmp/NVIDIA_kernel-1.0//lib/modules/2.4.21-0.13md
install: cannot stat `nvidia.o': No such file or directory
error: Bad exit status from /var/tmp/rpm-tmp.28561 (%install)
RPM build errors:
[root@Magic magic]#
sorry van de layout, maar ik quote gewoon alles, want ik weet niet wat precies van belang is, voor mij is het allemaal abracadabra.
  • JackHoeb
  • Laatst online: 03-10-2022
JackHoeb
Ben d'r klaar voor!
Ik maak altijd gretig gebruik van de door Texstar uitgebrachte rpm's.
Daar staan ook Nvidia drivers in. Instaleren en daarna niet xf86config-4 aanpassen zoals gebruikelijk maar eenvoudig via mandrake's controle centrum nogmaals X configureren. De NVidia en GLX module worden na het herstarten van X dan gewoon geladen. ftp://ftp.ibiblio.org/pub...ns/mandrake/9.1/rpms/i586
  • Magic
JackHoeb schreef op 29 maart 2003 @ 20:09:
baat het niet dan schaad het niet toch? (hoewel linux wel vaak het tegendeel bewijst). ik zal ze eens proberen, als het misgaat dan installeer ik mandrake wel weer opnieuw, thanx.
edit
ik heb ze geprobeert, en ze werken als een trein, thanx! _/-\o_
[ Voor 6% gewijzigd door Magic op 30-03-2003 15:10 ]
  • DAMAGE
  • Laatst online: 27-10 12:16
DAMAGE
a.k.a. Rice_NL
JackHoeb schreef op 29 March 2003 @ 20:09:
Zo makkelijk gaat het met de tar balls ook hoor... gewoon unpacken met tar xvzf nvidia-kernel-blaat.tar.gz en dan gewoon ./configure en make install... Als dat niet werkt moet je je kernel source installeren of je kernel headers. Daarna kun je de GLX nvidia uit pakken en compilen. Ik denk dat dat toch net even wat beter is als een rpm... Heb je nog geen problemen verder ondervonden met die module?
of is die rpm echt precies voor dat mandrake systeem wat jij draait?
  • JackHoeb
JackHoeb
Ben d'r klaar voor!
DAMAGE schreef op 29 March 2003 @ 21:50:
Helaas werkten bij mij zowel de source rpm's niet en de tarbals ook niet onder Mandrake 9.1.
Texstar heeft speciaal voor mandrake rpm's in elkaar gedraaid.
  • --MeAngry--
  • Laatst online: 19-11 13:07
--MeAngry--
aka Qonstrukt
bobo1on1 schreef op 18 februari 2003 @ 02:17:
Ik heb mandrake 9.0 geinstalleerd, daarna de mooie rpm's van nvidia voor mijn geforce 4 ti 4200 64 mb volgens de handleiding, maar als ik nou mijn X start dan krijg ik een beeld met allemaal rare tekentjes erop, het heeft wel iets weg van japans ;)
Ik heb ze al opnieuw geinstalleerd en nog wat andere dingen geprobeerd, maar het wil allemaal niet baten :(
Met de standaard driver die in mandrake zit kreeg ik wel beeld, al was 60 herz :( (de rede dat ik die nvidia drivers erop wil hebben onder andere).
Als ik in XF86Config-4 de driver op vesa instel krijg ik wel beeld, al is het op 640x480.
W03j hij doet het, ik moet "modprobe nvidia" en "modprobe agpgart" doen :)
Ik heb dus hetzelfde probleem, maar dan onder Red Hat 9, maar modprobe agpgart en modrpobe nvidia werkt bij mij niet. Ik krijg nog steeds een heleboel ASCII tekens telkens in dezelfde formatie op het scherm te zien ipv een mooie accelerated X-desktop.
Ik heb ook al oudere drivers geprobeerd (dus de niet .run versie), en ook onder Red Hat 8, maar weer hetzelfde probleem. Ik vind het wel vreemd, omdat deze zelfde GeForce2MX400 kaart al eens eerder prima had gewerkt onder linux op een ander moederbord (toen VIA KT266, nu NVIDIA nForce2...).
Wat gaat hier fout, anybody an idea?
Ik heb overigens al gebruik gemaakt van de search en daar wordt aangeraden bepaalde bios-opties in- of uit te schakelen, maar dat heeft ook niets geholpen.
Ook in het logfile staat geen foutmelding. Het logfile eindigd met de regels:
Succesfully changed AGP-mode to AGP4x
Changing display mode to 1024x768
Aan de monitor ligt het ook niet, want die kan dezelfde resolutie met de nv-driver wel goed weergeven @ 85 Hz, ik ben dus wanhopig op zoek naar een oplossing... ;(
Tesla Model Y RWD (2024) ▪︎ Daikin Altherma 3 6kW (300L SWW) ▪︎ 20x AIKO NeoStar 2S+ 465Wp ▪︎ Sigenergy SigenStor EC 10+10 (12kW + Gateway HomePro TP)
  • ZtaaB
  • Laatst online: 13-11 17:35
Hey mensen een klein probleempje waar ik al eeuwen tegenaanloop.
Mijn X server werkt momenteel ff niet (verkeerd zitten klooien met de xf86cconfig-4) en ik weet precies hoe ik het moet fixen
Maar ik heb geen flauw idee hoe ik een editor zonder X moet aanroepen.
Ik de files wel bekijken met "less", maar ik wil hem dus kunnen wijzigen.
Er moet haast wel zo'n tool native in linux zitten, maar zoeken op zoiets basics als een editor in google is haast ondoenlijk.
dus: wat is het commando voor een niet-x editor ?
Alvast bedankt.
Haal NOOIT een spookrijder in !
  • Access
  • Laatst online: 17-10 16:22
pico/vi/vim <bestandsnaam> :)
Hey,
Eerst mijn specs:
GF3 ti500 (MSI)
EPOX 8RDA+ (NFORCE2)
AMD ATHLON XP 2500+ (BARTON)
2x256mb ddr ram
Mijn probleem:
Debian is geïnstalleerd, met nforce2 drivers (net niet nieuwe versie, kzag net dat er vandaag nieuwe versie uit kwam), en de standaard NV driver. StartX werkt gewoon, en kde doet het goed(behalve movies kijken enz:P), zodra ik de Geforce drivers van nvidia installeer, en ik probeer kde te starten dmv StartX freezed alles, moek duzz resetten, kheb ook oudere versies van de geforce drivers geprobeerd, op den duur bleef SSH open, maar kon ik zelf niets duidelijks meer op beeld zien(kon ook niet meer met alt+ctrl+F# ''switchen''.
heeft iemand hetzelfde probleem, of weet iemand een oplossing:D
alvast thx,
BTW, er wordt nix in de logs vermeld, over dat freezen:??
[rml][ Mandrake 9.1]X crasht regelmatig[/rml]
Kijk eens in dit topic, hier hebben ze het over het toetsenbord; even er uit en er weer in en het zou verholpen zijn }:O
Access schreef op 11 April 2003 @ 21:09:
ja van, vi/vim snap ik dus echt geen k*t van. pico, hmmm ff proberen, is die minder uitgebreid?
@Sade: leen eens een boek over Linux in de plaatselijke bibliotheek. Kan nooit kwaad ;)
Ik krijg m'n nvidia drivers ook niet geinstalleerd :'(
Specs:
Slackware 9.0
Amd Athlon XP 1900+
Epox 8RDA+
Asus GeForce 4 MX440-SE
Ik heb NVIDIA-Linux-x86-1.0-4363.run geinstalleerd, hij had m'n kernel sources nodig om de driver te maken. Toen had ik modprobe nvidia gedaan. Toen mijn XF86Config aangepast:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
Section "Module"
    Load"/usr/X11R6/lib/modules/extensions/libglx.so" #also tried load "glx"
    Load        "dbe"
    SubSection  "extmod"
      Option    "omit xfree86-dga"
    EndSubSection
    Load        "type1"
    Load        "speedo"
EndSection
Section "Files"
    RgbPath"/usr/X11R6/lib/X11/rgb"
    FontPath"/usr/X11R6/lib/X11/fonts/local/"
    FontPath"/usr/X11R6/lib/X11/fonts/misc/"
    FontPath"/usr/X11R6/lib/X11/fonts/75dpi/:unscaled"
    FontPath"/usr/X11R6/lib/X11/fonts/100dpi/:unscaled"
    FontPath"/usr/X11R6/lib/X11/fonts/Speedo/"
    FontPath"/usr/X11R6/lib/X11/fonts/Type1/"
    FontPath"/usr/X11R6/lib/X11/fonts/75dpi/"
    FontPath"/usr/X11R6/lib/X11/fonts/100dpi/"
EndSection
Section "InputDevice"
    Identifier"Keyboard1"
    Driver"Keyboard"
    Option "AutoRepeat" "500 30"
    Option "XkbRules""xfree86"
    Option "XkbModel""pc101"
    Option "XkbLayout""us"
EndSection
    Identifier"Mouse1"
    Driver"mouse"
    Option "Protocol"    "IMPS/2"
    Option "Device"      "/dev/mouse"
EndSection
Section "Monitor"
    Identifier  "My Monitor"
    HorizSync   30-70
    VertRefresh 50-160
EndSection
Section "Device"
    Identifier  "NVIDIA GeForce"
    Driver      "nvidia"
    BusID       "PCI:2:0:0"
EndSection
Section "Screen"
    Identifier  "Screen 1"
    Device      "NVIDIA GeForce"
    Monitor     "My Monitor"
    DefaultDepth 24
    Subsection "Display"
        Depth       8
        Modes       "1024x768" "800x600" "640x480"
        ViewPort    0 0
    EndSubsection
        Depth       16
        ViewPort    0 0
    EndSubsection
        Depth       24
        ViewPort    0 0
    EndSubsection
EndSection
Section "ServerLayout"
    Identifier  "Simple Layout"
    Screen "Screen 1"
    InputDevice "Mouse1" "CorePointer"
    InputDevice "Keyboard1" "CoreKeyboard"
EndSection
Toen ik startx deed liep m'n pc vast, ik zag allemaal vreemde ansi/ascii codes op m'n scherm. CTRL+ALT+BACKSPACE deed het ook niet meer. Na rebooten bekeek ik m'n XFree86.0.log maar daar zaten dezelfde vreemde tekens in. Dus het heeft geen zin om dat hier te posten.
Ik heb de nvidia driver succesvol geinstalleerd onder Red Hat 9 maar ik kan nog steeds hardware acceleration niet aanvinken. Mijn videokaart is een Geforce 4 Ti 4200 64 MB. Word mijn kaart niet ondersteunt door Red Hat ofzo?
De driver werkt verder wel in games e.d. Tux Racer is gewoon accelerated door mijn videokaart.
[ Voor 18% gewijzigd door Verwijderd op 05-05-2003 12:56 ]
Ik kan ook geen hardware acceleration aanklikken, maar toch doet ie het. Gewoon effe XF86Config aanpassen zoals staat aangegeven aan het eind van installatie.(Dit gaat over de nieuwe .run driver)
Sade: Als je een simpele/begrijpbare text based editor wil hebben, zou ik joe eens proberen.
Ok, dus dat hoeft verder niet, bedankt :)
  • AkaXakA
  • Laatst online: 27-03 16:12
AkaXakA
Just Kidding...
Verwijderd schreef op 05 May 2003 @ 12:47:
http://www.akaxaka.tk/ - "Knowledge is power. Power corrupts. Study hard, be evil." - 4 Jaar GoT en nog steeds niet evil: er moet een verband zijn...
  • DGTL_Magician
  • Laatst online: 28-10 16:43
DGTL_Magician
Kijkt regelmatig vooruit
Ok, dan moet ik er ook maar eens aan geloven.
Ik heb de Nvidia drivers geinstalleerd onder SuSE 8.1.
Ik heb een NVidia Geforce 4 488Go, een custom made kaartje voor Medion. Dit alles draait in mijn laptop. Ik heb alle versies sinds 4191 geprobeerd, ze doen allemaal hetzelfde. Ik compileer de drivers (of de installer doet dat voor me) en de nvidia.o laadt vervolgens vervan in in mijn XF86Config-4 de vesa door nvidia (nv driver doet het ook niet). Als ik dan /etc/init.d/xdm restart draai, dan hangt mijn hele X omgeving. Zwart beeld, PC blijft helemaal hangen. Ook SSH e.d. doen het niet meer. Enige oplossing is Laptopje uitzetten en weer aan. Iemand dit al eens meegemaakt en heeft iemand een oplossing?
Blog | aaZoo - (Wireless) Networking, Security, DDoS Mitigatie, Virtualisatie en Storage
Heb je DRI wel uitgezet?
Gebruik je wel de rpm's?(dus niet de .run driver)
Note: If you are using SuSE 8.1 or earlier, or if you are using United Linux 1.0, we recommend installing from RPMs built by SuSE. These are available via ftp. If you install via the .run file, XFree86 configuration with SaX2/YaST2 will not work correctly. For more information, see the NVIDIA Installer HOWTO for SuSE Linux at http://www.suse.de/en/private/download/xfree86/index.html.
Linkje(was uit tekst gevallen): ftp://download.nvidia.com/XFree86/Linux-x86/1.0-4363
[ Voor 10% gewijzigd door Verwijderd op 05-05-2003 13:43 ]
  • DGTL_Magician
DGTL_Magician
Verwijderd schreef op 05 mei 2003 @ 13:40:
DRI is uit en ik gebruik de .run
Ik zal die link ff kijken, thx.
Die SuSE link geeft een 404 :X
Goeie link voor het nageslacht: ftp://ftp.suse.com/pub/su...86/nvidia-installer-HOWTO
[ Voor 20% gewijzigd door DGTL_Magician op 05-05-2003 13:49 ]
Heb je de rpm's al geprobeerd?
  • herminator
Ik zit nu ook te klooien met die drivers. Ik heb volgens mij die kernel header in /usr/src/linux staan
Maar ik kan niet eens in die dir komen om te kijken wat er in staat. Bij make install krijg ik dus ook een error missing linux/modversions.h
Kernel headers staan er ook al op. Wie wat wat ik misschien fout heb gedaan?
Het gaat om 4.2.18 debian 2.4
[ Voor 7% gewijzigd door herminator op 07-05-2003 21:54 ]
I'll be back
  • DGTL_Magician
DGTL_Magician
Verwijderd schreef op 05 mei 2003 @ 14:38:
Jep, werken niet. Maar ik denk dat ik RedHat 9 er morgen op het werk ff opzet.
  • --MeAngry--
--MeAngry--
aka Qonstrukt
Verwijderd schreef op 30 April 2003 @ 16:54:
[bladiebla...]
Juist, en waarom weet nu helemaal niemand op deze aardkloot waar dat aan ligt!!!!!! :(
Ik ben al op tig fora geweest, heb NVIDIA zelfs gemaild (waarop ik geen antwoord kreeg :? ) en niets, maar dan ook niets wat ik aan hulp krijg schijnt te werken. En ja, ik heb de goede modules geladen, en ja, ik heb de sources én de binaries geprobeerd en ja, ik heb 5 verschillende distro's geprobeert, maar telkens weer die gare ASCII-zooi op mijn scherm :(
Gelukkig haal ik volgende week een Radeon 9700, kijke of het daar wel mee wil vlotten, want dit suckt echt van elke kant... :'(
(Sorry voor de misschien wat opdringerige tekst, maar ik ben de wanhoop voor de zoveelste maal nabij met linux... ;( )
[ Voor 11% gewijzigd door --MeAngry-- op 07-05-2003 22:20 ]
  • herminator
Met goede hulp van een huisgenoot is het opgelost. Hij heeft drivers van debian zelf gebruikt. Hoe hij het precies gedaan heeft weet ik dus niet maar bij mij werkt het nu.
I'll be back
  • Okasha
hi!
zit nu met mandrak 9.1 en Geforce 4 mx 440. Log eerst in als root: su, en dan password.
voer dan in:
sh NVIDIA-Linux-x86-1.0-4363.run
Maarrrr, wat krijgen we dan, we moeten uit X... anders werkt hij niet..
maar hoe! het lukt met niet meer. Ctrl-Alt-backspace niet! hij gaat dan flikkeren, maar komt uiteindelijk weer gewoon bij inlog van user, en dat soort grappen. En hij zet de HD ff aan en uit. Ook Kill-X wil niet werken (vond ik ergens ;), weet verder niet wat het is)
Iemand?
Met een bootflop opstarten en zodra de prompt komt LINUX 3 intikken + enter...
Even nog over dat Suse8.1 verhaal..
Je moet de kernel en glx versie rpm's, twee stuks dus, voor suse8.1 eerst downloaden van de laatste (4363) versie.
(NVIDIA_GLX-1.0-4363.suse81.i586.rpm en NVIDIA_kernel-1.0-4363.suse81.i586.rpm)
Dan ook net als hierboven maar dan met de HD-boot LINUX 3 intikken om in de text mode te blijven.
Dan inloggen als root en de oude modules de-installeren
rpm -e NVIDIA_GLX
rpm -e NVIDIA_kernel
Als je veel drivers hebt geprobeerd, kun je die ook allemaal bijelkaar zetten en intikken :
(Doet soms wonderen..)
rpm -e *.rpm
dan is het 't makkelijkst om die twee nieuwe rpm's in een verder lege folder te zetten, anders moet je zoveel intikken.. ;)
rpm -ivh Nvidia_kernel*.rpm --nodeps --force
rpm -ivh NVIDIA_GLX*.rpm --nodeps --force
dan nog
switch2nvidia
Die laatste verandert de nv naar nvidia, checkt de OpenGL toestand, en zet XFREE om naar nvidia-glx
Soms, als het tegenzit, helpt het om eerst de originele drivers van Suse zelf (Ummhh versie 0,8 geloof ik) te installeren en met gears en een OGL spelletje als Descent3D te checken of er niets meer dwars zit. Daarna begin je weer bij het rpm -e NVIDIA_GLX etc....
Als het dan nog niet werkt, heb je echt een vet probleem daar....
Overigens is die hardware acceleratie alleen voor Quadro kaarten e.d. zover ik weet .. ;)
[ Voor 95% gewijzigd door Verwijderd op 10-05-2003 05:54 ]
  • DGTL_Magician
DGTL_Magician
OMG, het was zo simpel.
Voor mijn laptop moet ik dus blijkbaar de volgende optie meegeven:
Option "NVAGP" "0"
Zodat er geen AGP wordt gebruikt?
Iig, nu start ie, met hardware acceleratie! Als ik nu TV out aan de reut krijg ben ik tevreden! :P
  • M@rijn
  • Laatst online: 30-10 08:31
Ik ben een beetje n00b nog op dit moment, ik wou daarnet die driver installeren alleen toen kreeg in een 1 of andere melding van een kernel.
Ik heb het /var/log/nvidia-installer.log maar ff bijgevoegd, OS is Debian Woody (met meest recente KDE en Xfree dacht ik).
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
nvidia-installer log file '/var/log/nvidia-installer.log'
creation time: Sat May 10 12:25:27 2003
option status:
  license pre-accepted    : false
  update                  : false
  force update            : false
  expert                  : false
  uninstall               : false
  driver info             : false
  no precompiled interface: false
  no ncurses color        : false
  query latest driver ver : false
  OpenGL header files     : false
  no questions            : false
  silent                  : false
  XFree86 install prefix  : /usr/X11R6
  OpenGL install prefix   : /usr
  Installer install prefix: /usr
  kernel include path     : (not specified)
  kernel install path     : (not specified)
  proc mount point        : /proc
  ui                      : (not specified)
  tmpdir                  : /tmp
  ftp site                : ftp://download.nvidia.com
Using: nvidia-installer ncurses user interface
-> License accepted.
-> No precompiled kernel interface was found to match your kernel; would you li
   ke the installer to attempt to download a kernel interface for your kernel f
   rom the NVIDIA ftp site (ftp://download.nvidia.com)? (Answer: No)
-> No precompiled kernel interface was found to match your kernel; this means
   that the installer will need to compile a new kernel interface.
-> Kernel include path: '/lib/modules/2.4.20-xfs/build/include'
-> Cleaning kernel module build directory.
   executing: 'cd ./usr/src/nv; make clean'...
   rm -f nv.o os-agp.o os-interface.o os-registry.o  nv-linux.o nv_compiler.h *
   .d NVdriver nvidia.o
-> Building kernel module:
   executing: 'cd ./usr/src/nv; make nvidia.o SYSINCLUDE=/lib/modules/2.4.20-xf
   s/build/include'...
   You appear to be compiling the NVIDIA kernel module with
   a compiler different from the one that was used to compile
   the running kernel. This may be perfectly fine, but there
   are cases where this can lead to unexpected behaviour and
   system crashes.
   If you know what you are doing and want to override this
   check, you can do so by setting IGNORE_CC_MISMATCH.
   In any other case, set the CC environment variable to the
   name of the compiler that was used to compile the kernel.
   [1;31m*** Failed cc sanity check. Bailing out! ***
   [0mmake: *** [gcc-check] Fout 1
-> Error.
ERROR: Unable to build the NVIDIA kernel module.
ERROR: Installation has failed.  Please see the file
       '/var/log/nvidia-installer.log' for details.  You may find suggestions
       on fixing installation problems in the README available on the Linux
       driver download page at www.nvidia.com.
Hier kan ik een ding over zeggen, probeer de originele gcc van Woody eens.
Of compileer een nieuwe kernel, probeer eerst het bovenstaande
[ Voor 36% gewijzigd door Verwijderd op 10-05-2003 12:54 ]
  • M@rijn
ik heb dus gcc-3.0 1:3.0.4-7 en dan doet ie het nog niet. Wat nu?? En hoe te werk te gaan?? (compileren heb ik nog nooit echt gedaan)
Numero uno: Als alle compileer software goed geinstalleerd is, dan doet nvidia installer alles voor jouw(qua compileren, je moet ALTIJD handmatig de driver aanzetten).
Number two: Is dat de originele ggc die bij Debian zat?
Nummer drie: Heb jij kernel patches gebruikt?(i.v.m. xfs bij de kernel)
  • M@rijn
1. ok
2. Ik heb de laatste stable gcc gedownload, met alle stuff erbij
3. ik heb 2.4.20-xfs (deze zat er standaard bij, knoppix 3.2 op hdd ownz)
[ Voor 10% gewijzigd door M@rijn op 10-05-2003 14:31 ]
Je kunt of Knoppix herinstalleren en dan drivers installeren of de kernel die je nu hebt(met knoppix sources) opnieuw compileren(wel goed instellen). Werkt dat beide niet dan is er meer aan de hand.
Of het ligt aan het feit dat je een nieuwere gcc hebt, installeer de oude eens.(behalve als je daar ook al de problemen mee had)
SORRY VOOR DUBBELPOST, IK KON NIET EDITEN
  • M@rijn
Kleine update,
Ik heb de drivers geinstalleerd doormiddel van make install, alleen nu wil ik checken of het gelukt is en hoe kan ik die nvidia-installer aan de gang.
Misschien kun je hem gewoon opstarten en vertellen waar kernel module staat(dat is het gedeelte wat meestal gecompileerd word)(Bij mij dan).
  • M@rijn
nvidia-installer krijg ik niet opgestart (als ik er op klik en als ik het command "nvidia-installer" geef)
als dat de juiste executable is dan moet je of sh nvidia-installer of ./nvidia-installer doen.(Ik heb het gewoon geinstalleerd en het werkte, dus niet alleen uitgepakt ofzo, dus ik weet er niet super veel over)
  • DGTL_Magician
DGTL_Magician
DTC_marijn schreef op 10 mei 2003 @ 12:50:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
option status:
  update                  : false
  expert                  : false
  uninstall               : false
  driver info             : false
  silent                  : false
  tmpdir                  : /tmp
   s/build/include'...
   system crashes.
-> Error.
Het staat er gewoon letterlijk!
Doe:
export IGNORE_CC_MISMATCH=true
./nvidia-installer
Zo moeilijk is lezen toch niet?
  • M@rijn
Werkt dus nog niet :)
  • DGTL_Magician
DGTL_Magician
't werkt niet, wat werkt er niet? wat zegt het log? Als je die export hebt gedaan zal iig die CC mismatch niet meer voordoen, dus graag wat meer info. Ook DGTL is niet helderziend.
  • JSchut
  • Laatst online: 18-11 22:01
JSchut
Ik heb net mandrake 9 geinstalleerd.
Ik dacht nu nog ff me drivers regelen voor me Gforce 4 mx 420.
Maar krijg helemaal geen beeld dus kan ook niks doen.
Iemand een idee?
PSN jschut_82 | Xbox: JSchut82
Start X niet op of krijg je ook geen shell?
[ Voor 13% gewijzigd door Verwijderd op 12-05-2003 15:27 ]
  • M@rijn
DGTL_Magician schreef op 11 May 2003 @ 14:27:
Mijn welgemeende excuses O-) ik was een letter vergeten, nu is het wel geinstalleerd alleen nu heb ik het volgende, ik draai Knoppix 3.2 op mijn HDD en nu als ik XF86Config-4 aanpas volgens de NVidia manier dan doet ie het niet! X wil dan niet meer opstarten, ik heb voor jullie maar ff mijn XF86Config-4 bijgevoegd:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
    Identifier     "XFree86 Configured"
    Screen      0  "Screen0" 0 0
    InputDevice    "Keyboard0" "CoreKeyboard"
    InputDevice    "PS/2 Mouse" "CorePointer"
# Serial Mouse not detected
# USB Mouse not detected
EndSection
Section "ServerFlags"
    Option "AllowMouseOpenFail"  "true"
EndSection
Section "Files"
    RgbPath      "/usr/X11R6/lib/X11/rgb"
    ModulePath   "/usr/X11R6/lib/modules"
    FontPath     "/usr/X11R6/lib/X11/fonts/misc:unscaled"
    FontPath     "/usr/X11R6/lib/X11/fonts/misc"
    FontPath     "/usr/X11R6/lib/X11/fonts/75dpi:unscaled"
    FontPath     "/usr/X11R6/lib/X11/fonts/75dpi"
    FontPath     "/usr/X11R6/lib/X11/fonts/100dpi:unscaled"
    FontPath     "/usr/X11R6/lib/X11/fonts/100dpi"
    FontPath     "/usr/X11R6/lib/X11/fonts/Speedo"
    FontPath     "/usr/X11R6/lib/X11/fonts/PEX"
# Additional fonts: Locale, Gimp, TTF...
    FontPath     "/usr/X11R6/lib/X11/fonts/cyrillic"
#   FontPath     "/usr/X11R6/lib/X11/fonts/latin2/75dpi"
#   FontPath     "/usr/X11R6/lib/X11/fonts/latin2/100dpi"
# True type and type1 fonts are also handled via xftlib, see /etc/X11/XftConfig!
    FontPath     "/usr/X11R6/lib/X11/fonts/Type1"
    FontPath     "/usr/share/fonts/ttf/western"
    FontPath     "/usr/share/fonts/ttf/decoratives"
    FontPath     "/usr/share/fonts/truetype/openoffice"
    FontPath     "/usr/X11R6/lib/X11/fonts/defoma/CID"
    FontPath     "/usr/X11R6/lib/X11/fonts/defoma/TrueType"
EndSection
Section "Module"
        Load  "ddc"  # ddc probing of monitor
    Load  "dbe"
    Load  "extmod"
    Load  "glx"
        Load  "bitmap" # bitmap-fonts
    Load  "speedo"
    Load  "type1"
    Load  "freetype"
    Load  "record"
EndSection
    Identifier  "Keyboard0"
    Driver      "keyboard"
        Option      "CoreKeyboard"
    Option "XkbRules" "xfree86"
    Option "XkbModel" "pc104"
    Option "XkbLayout" "us"
EndSection
    Identifier  "Serial Mouse"
    Driver      "mouse"
    Option      "Protocol" "Microsoft"
    Option      "Device" "/dev/ttyS0"
    Option      "Emulate3Buttons" "true"
    Option      "Emulate3Timeout" "70"
    Option      "SendCoreEvents"  "true"
EndSection
    Identifier  "PS/2 Mouse"
    Driver      "mouse"
Option          "ZAxisMapping"          "4 5"
    Option      "Device" "/dev/psaux"
EndSection
        Identifier      "USB Mouse"
        Driver          "mouse"
        Option          "Device"                "/dev/input/mice"
        Option          "Buttons"               "5"
EndSection
[b]# Auto-generated by KNOPPIX mkxf86config[/b] <- Hier zit de fout volgens mij
Section "Monitor"
    Identifier  "Monitor0"
    Option  "DPMS"  "true"
    VendorName  "MAX"
    ModelName   "MAX0c03"
    HorizSync 30 - 70 # DDC-probed
    VertRefresh 50 - 160 # DDC-probed
    # These are the DDC-probed settings reported by your monitor.
    # 1024x768, 85.0Hz; hfreq=68.68, vfreq=85.00
    ModeLine "1024x768"  94.50 1024 1072 1168 1376  768  769  772  808 +hsync +vsync
    # 1024x768, 75.0Hz; hfreq=60.02, vfreq=75.03
    ModeLine "1024x768"  78.75 1024 1040 1136 1312  768  769  772  800 +hsync +vsync
    # 800x600, 85.0Hz; hfreq=53.67, vfreq=85.06
    ModeLine "800x600"   56.25  800  832  896 1048  600  601  604  631 +hsync +vsync
    # 800x600, 75.0Hz; hfreq=46.88, vfreq=75.00
    ModeLine "800x600"   49.50  800  816  896 1056  600  601  604  625 +hsync +vsync
    # 800x600, 60.0Hz; hfreq=37.88, vfreq=60.32
    ModeLine "800x600"   40.00  800  840  968 1056  600  601  605  628 +hsync +vsync
    # 640x480, 85.0Hz; hfreq=43.27, vfreq=85.01
    ModeLine "640x480"   36.00  640  696  752  832  480  481  484  509 -hsync -vsync
    # 640x480, 75.0Hz; hfreq=37.50, vfreq=75.00
    ModeLine "640x480"   31.50  640  656  720  840  480  481  484  500 -hsync -vsync
    # 640x480, 60.0Hz; hfreq=31.47, vfreq=59.94
    ModeLine "640x480"   25.17  640  648  744  784  480  482  484  509 -hsync -vsync
EndSection
Section "Device"
    ### Available Driver options are:-
# sw_cursor is needed for some ati and radeon cards
Option "sw_cursor"
        #Option     "hw_cursor"
        #Option     "NoAccel"
        #Option     "ShowCache"
        #Option     "ShadowFB"
        #Option     "UseFBDev"
        #Option     "Rotate"
    Identifier  "Card0"
# The following line is auto-generated by KNOPPIX mkxf86config
    Driver      "nv"
    VendorName  "All"
    BoardName   "All"
#   BusID       "PCI:1:0:0"
EndSection
Section "Screen"
    Identifier "Screen0"
    Device     "Card0"
    Monitor    "Monitor0"
    DefaultColorDepth 16
    SubSection "Display"
        Depth     1
    EndSubSection
        Depth     4
    EndSubSection
        Depth     8
    EndSubSection
        Depth     15
    EndSubSection
        Depth     16
    EndSubSection
        Depth     24
    EndSubSection
        Depth     32
    EndSubSection
EndSection
Section "DRI"
    Mode 0666
EndSection
Op aanvraag kan zet ik mkxf86config wel ff op m'n webspace :)
Ik krijg nu namelijk een vage melding als ik iets met GLX wil starten:
Xlib:  extension "GLX" missing on display ":0.0".
*** tuxracer error: Couldn't initialize video: Couldn't find matching GLX visual (Success)
[ Voor 17% gewijzigd door M@rijn op 12-05-2003 16:36 ]
  • JSchut
JSchut
Verwijderd schreef op 12 mei 2003 @ 15:20:
X start wel maar op dat moment gaat mijn beeldscherm op "out of scan range" als ik gewoon in de console opstart en dan x start krijg ik hetzelfde....
krijg verders geen foutmeldingen
Aan gedacht dat je misschien de refresh rates iets te hoog hebt staan?
  • JSchut
JSchut
ik heb nu red hat 9 geinstalled en die doet het nu wel....
  • DGTL_Magician
DGTL_Magician
DTC_marijn schreef op 12 mei 2003 @ 16:18:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
EndSection
EndSection
Section "Files"
EndSection
Section "Module"
    Load  "dbe"
    Load  "extmod"
    Load  "glx"
    Load  "speedo"
    Load  "type1"
    Load  "freetype"
    Load  "record"
EndSection
    Driver      "keyboard"
EndSection
    Driver      "mouse"
EndSection
    Driver      "mouse"
EndSection
        Driver          "mouse"
EndSection
Section "Monitor"
    VendorName  "MAX"
    ModelName   "MAX0c03"
EndSection
Section "Device"
Option "sw_cursor"
        #Option     "hw_cursor"
        #Option     "NoAccel"
        #Option     "ShowCache"
        #Option     "ShadowFB"
        #Option     "UseFBDev"
        #Option     "Rotate"
    Identifier  "Card0"
    Driver      "nv"
    VendorName  "All"
    BoardName   "All"
#   BusID       "PCI:1:0:0"
EndSection
Section "Screen"
    Device     "Card0"
    Monitor    "Monitor0"
        Depth     1
    EndSubSection
        Depth     4
    EndSubSection
        Depth     8
    EndSubSection
        Depth     15
    EndSubSection
        Depth     16
    EndSubSection
        Depth     24
    EndSubSection
        Depth     32
    EndSubSection
EndSection
Section "DRI"
    Mode 0666
EndSection
Ok, je hebt de file aangepast? Waarom staat er dan driver "nv" en niet driver "nvidia" ?
Dus niet aangepast.
En das het enige probleem in je hele config.
Anders eens spelen met je NVAgp options.
Dus in je Device section toevoegen:
Option "NVAgp" "0"
of "1" of "2"
Op mijn lappie moest ie op 0 staan.
[ Voor 17% gewijzigd door DGTL_Magician op 12-05-2003 21:51 ]
  • M@rijn
Ik dacht misschien zit het in dat mkxf86config filetje? maar ik zal je tips een uitvoeren.
[ Voor 25% gewijzigd door M@rijn op 13-05-2003 09:17 ]
  • T-Blizzard
  • Laatst online: 19-11 09:08
Ik heb het probleem met slackware9.0 dat ik met geen mogelijkheid met nvidia drivers me x goed krijg...
Zodra ik alles instel volges de sample die bij de installatie zit... krijg ik gewoon doodleuk een zwart scherm... en enigste wat nog dan kan is ctrl-alt-del
Heb echt bijna elk ander forum gehad... en er zijn meer mensen met problemen slack + nvidia (vaak ook met nforce)
Dus heb met allerlei instellingen zitten spelen... ( de ene zegt dit weer en de andere weer dat) maar krijg het met geen mogelijkheid werkend... :(
DTC_marijn schreef op 13 mei 2003 @ 09:17:
Nee, daar ligt het echt niet aan. Ik draai ook Knoppix 3.2 via mijn hd en heb hetzelfde probleem gehad (ook dat de drivers niet gecompileerd wouden worden). Het probleem is dat de nvidia kernelmodule niet geladen wordt. Mijn oplossing:
sudo su
echo > /etc/modutils/nvidia << EOF
alias char-major-195 nvidia
EOF
update-modules
Waarschijnlijk moet je nu nog wel /etc/X11/XF86Config-4 aanpassen, omdat hij waarschijnlijk is teruggevallen op de vesa-driver. Met aanpassen bedoel ik:
- zorgen dat Driver op "nvidia" staat
- zorgen dat Load "glx" aanstaat
Daarna:
ctrl+alt+f1
init 2
init 5
[ Voor 13% gewijzigd door Verwijderd op 13-05-2003 22:22 ]
  • M4RTiN
  • Laatst online: 24-11-2024
Mandrake 9.1 hier
installer.run gedraaid
XFree86-4 aangepast "nv op nvidia gezet en GLX staat aan"
opnieuw opstarten, kom ik in de console
doe ik su root
insmod nvidia
startx kdm
dan kom ik enigzins in een windows manager. Maar als user m4rtin kan ik X niet opstarten (geen Authority ofzo)
(het beeld is overigens perfect onder root en die "KDM" bootlogo enzo werkt)
[ Voor 11% gewijzigd door M4RTiN op 17-05-2003 20:42 ]
  • odysseus
  • Laatst online: 19-11 17:10
odysseus
Debian GNU/Linux Sid
Je kunt met het programma 'xhost' instellen wie er naar X mogen verbinden. Zelf gebruik ik 'XFree86 && xhost +', maar erg netjes is dat niet...het schakelt gewoon alle access control van XFree uit. Aangezien Debian standaard XFree zo configureert dat er geen connecties van andere hosts mogelijk zijn en ik de enige gebruiker op deze machine ben, is dat in mijn geval niet zo erg :). Je kunt ook specifieker toestemming geven tot toegang, maar daar weet de manpage vast meer over :).
Leven is het meervoud van lef | In order to make an apple pie from scratch, you must first create the universe.
  • M4RTiN
aha maar dan ben ik volgens mij nog niet van het probleem af....
  • Buffy
Buffy
M4RTiN schreef op 17 mei 2003 @ 20:40:
Mandrake 9.1 hier
doe ik su root
insmod nvidia
startx kdm
En als je eerst exit doet voor startx kdm?
  • M4RTiN
ik zal het zo proberen, maar wat verhelpt dat dan?
ik bedoel bij het normale opstarten wil ik niet telkens wat intypen voordat ik in KDE zit...
ik heb het idee dat bij het normale opstarten die driver niet word geladen...
  • M4RTiN
Hmm exit brengt mij terug naar user root, helpt dus ook niet
Zet als root de security settings onder het Mandrake Control Center (of hoe dat ding ook heet) op zijn laagst en probeer opnieuw. Er is een issue met standaard nogal erg paranoide beveiligings settings met Mandrake 9.1.
Haal ook eerst even de updates op.. ;)
  • M4RTiN
ik heb nu ff in dat mandrake control settings geweest
en wat ik heb gedaan is dat X door alles en iedereen mag gerund (wel veilig hoor in mijn geval)
enne ben nu wat dingen aan het updaten
en ik heb nog wat gegoogled, en aan de hand daarvan in de /etc/modules laat ik nu nvidia ook laden wie weet helpt dat!
EDIT ja het werkt nu!! tnx iedereen
[ Voor 6% gewijzigd door M4RTiN op 18-05-2003 13:51 ]
Mijn video kaart geeft ook problemen. Weet alleen niet of het nu aan de drivers ligt of dat de videokaart niet goed is?
Het is een nVidia Geforce 2 MX 400. Met de nieuwste drivers van Nvidia (Detornator) en ook iets oudere drivers loopt de pc bij spellen na een tijdje vast, geeft een blauw scherm en vervolgens in het spel weg. Ook het bladeren in verkenner, waar animaties bij verschijnen (veelvoorkomende taken) kan de pc helemaal freezen en moet ik dus rebooten.
Als ik de Microsoft Windows Publisher Driver gebruik (standaard) dan heb ik alleen last van spellen die terugcrashen naar de desktop. Maar zelfs dit is al zeel iritant. Ook kan ik met deze driver geen gebruik maken van de TV Out. Deze Windows driver geeft geen blauwe schermen met geheugendumps.
Weet iemand of het nu aan de videokaart ligt? Of is een specifieke driver hier de oplossing?
De rest van de specs:
HP Pavilion 7950 ( :X ouders pc )
AMD Athlon 1.3 Ghz
60 gig schijf
256 MB Ram
Meer specs lijken me niet nodig. En owjah de AC97 driver is helemaal up to date.
  • blouweKip
  • Laatst online: 17-11 23:53
Je moet natuurlijk ook geen windows driver in linux gebruiken he ;)
En misschien beter leren lezen...
"For my friends, anything; for my enemies, the law."
sorry verkeerde forum, ik had nl de search gebruikt... ik ga hem ff in de Wos posten
Ik heb Mandrake 9.1, en die werkt al geruime tijd prima met de standaard 'nv' drivers. Echter om de 'nvidia' drivers aan de praat te krijgen ben ik al een hele tijd aan het stoeien.
Uiteindelijk ben ik er achter gekomen dat ik de 'nvidia' drivers kan gebruiken door 'apic' in de bios uit te zetten. Hiermee is het probleem niet helemaal opgelost, want op mijn dual boot systeempje kan ik nu geen windows meer gebruiken, daar werken de drivers niet zonder dat 'apic' aanstaat.
Onder Linux werkt het nu allemaal, prima, en dat is voor mij het belangrijkste. Er is echter een grote 'maar'. Om het moment dat ik in Gnome 'logout' kies, bevriest mijn systeem volledig en zit er niets anders op dan een reset te doen.
Ik heb al diverse faq's, howto's, mans gelezen, en diverse forums doorgelezen, echt kan ik nergens dit specifieke probleem vinden.
Ik heb een MSI GeForce4 Ti 4800 SE. Ik gebruik driver versie 1.0-4363.
[ Voor 11% gewijzigd door Verwijderd op 13-06-2003 08:05 ]
  • Mpdrichel
  • Laatst online: 09-08-2024
Mischien een domme vraag. Maar hoe kom ik in Mandrake 9.1 in de text mode? Ik kon de vorige drivers gewoon in Xfree instaleren maar met deze wil het niet.
  • Blaasvis
  • Laatst online: 24-10 11:11
Blaasvis
Cidora \o/
door naar een ander runlevel te gaan met init.
dus bv init 3..... of lager
Freedom is everything you need ; <moto-moi|afk> ik verkloot het gewoon nooit :P
  • Mpdrichel
Blaasvis schreef op 07 juli 2003 @ 19:32:
En hoe doe ik dat? :?
  • moto-moi
  • Laatst online: 09-06-2011
moto-moi
Ja, ik haat jou ook :w
Misschien eens google.com aanwengelen op de keywords 'Mandrake runlevel' met eventueel de toevoeging 'init' :?
Niet te lui worden he ;)
God, root, what is difference? | Talga Vassternich | IBM zuigt
  • Mpdrichel
Na eerst inittab verprutst te hebben is het toch gelukt :) Gewoon met vi aanpassen.
  • woutur
  • Laatst online: 19-11 18:22
woutur
Klauwtjes uit!
Op mijn pIII 850 op een bx mobo speel ik graag ET. Ik wil hiervoor uiteraard het onderste uit de kan halen maar nu merk ik dat er vaak extreme framedrops zijn en dat een timedemo laten lopen en dat van 640 tot 1280 resolutie van 18 fps tot 16 fps loopt. Oftewel dit kan beter aangezien een vriend van mij hier toch beduidend hogere scores haalt (in de 33fps) met een vergelijkbare config. Teneinde wat dingen te optimaliseren wil ik van de NvAGP module gebuik maken ipv agpgart. Ik probeer NvAGP maar aan de praat te krijgen maar het lukt me niet, relevante secties in de XFree log:
(**) NVIDIA(0): Option "NvAGP" "1"
(**) NVIDIA(0): Option "IgnoreDisplayDevices" "DFP,TV"
(**) NVIDIA(0): Use of NVIDIA internal AGP requested
(--) NVIDIA(0): Linear framebuffer at 0xD0000000
(--) NVIDIA(0): MMIO registers at 0xDC000000
(II) NVIDIA(0): NVIDIA GPU detected as: GeForce4 Ti 4200 with AGP8X
(--) NVIDIA(0): VideoBIOS: 04.28.20.21.c1
(--) NVIDIA(0): VideoRAM: 65536 kBytes
---knip
(WW) NVIDIA(0): Failed to verify AGP usage
(II) NVIDIA(0): Setting mode "1280x1024"
(II) NVIDIA(0): Using the NVIDIA 2D acceleration architecture
Hieruit blijkt dat de optie NvAGP in de XF86Config-4 wel herkend wordt. Ik heb bovendien mttr in mijn kernel zitten zodat ie dus de bovenstaande dingen kan vinden.
Daarnaast is agpgart als module meegecompileerd in de kernel en wordt niet geladen tijdens het opstarten (zodat hier geen conflict ontstaat).
Na een startx met deze config geeft cat /proc/drivers/nvidia/agp/status aan dat AGP disabled is.
Ik kan het hele zootje wel laten lopen met de agpgart module maar ik heb vernomen dat er wat prestatie winst is te verwachten van de nvidia module. Heeft iemand nog een idee wat ik gemist heb om dit aan de praat te krijgen (ik heb volgens mij bijna alles geprobeerd wat in de nvfora stond)?
/edit met oplossing:
Ik ben stupide. Ik had alles werkelijk goed gedaan, slechts 1 ding vergeten: na het opnieuw compileren van mijn kernel met MTTR support had ik ook de nvidia driver zelf even opnieuw moeten compileren. Na dat gedaan te hebben werkt het.
[ Voor 9% gewijzigd door woutur op 13-07-2003 19:54 ]
Als je niet de moeite neemt je post in net Nederlands te schrijven, neem ik de moeite niet hem te lezen.
Ik heb geen probleem, maar een oplossing!
Ik ben net vorige week naar linux overgeschakeld *_/-\o_ *HALELUJA*_/-\o_ *
gelukkig heb ik ervaring met Solaris op mijn werk, dus de architectuur schrikt niet af......
Ik had ook problemen om mijn GF4 TI4600 aan de praat te krijgen in Mandrake 9.1
Mijn symptomen:
tijdens booten 3x flikkerend scherm, dan kom ik terecht op inlog prompt, geen X dus.
Als ik dan met de hand de boel probeerde te starten (modprobe nvidia), kreeg ik gemekker over "tainted kernel" etc. (met een url over de uitleg die ik nog niet gelezen heb)
Anyway, als ik daarna startx deed, kreeg ik alleen zwart scherm.
Nu ben ik erachter gekomen dat als je een 2e maal modprobe nvidia intikt, er niet meer gezeurt wordt en met startx kwam dan eindelijk mijn langverwachte Nvidia Splash.
Dus: De driver moet gewoon een extra keer een schop krijgen tijdens het booten, ik wist alleen niet waar. Stoutmoedig als ik ben heb ik dat ergens** in etc/rc4.d/K09dm gezet, want "dm" klonk mij wel als iets met een grafische kaart.
'T werkt!! Hopelijk kan iemand anders er ook wat mee...... of misschien kan iemand mij vertellen hoe ik dit eleganter had moeten doen?
doeidoei
**vlak voor "/etc/X11/prefdm &" in de start-sectie.
Hoi, ik heb ook een probleem! Suse wil me niet helpen en ik kom er zelf ook niet meer uit :(
Ik heb de installer gedaan dat leek allemaal goed te gaan (eerst de dummy driver verwijderd en mesa)
en toen switch2nvidia gedaan.. driver staat op " nvidia" en " glx" wordt geladen in XF86Config..
3Ddiag spuugt dit uit:
Checking GLU/glut runtime configuration:
GLU ... done (package mesaglu)
glut ... done (package mesaglut)
Dat lijkt me dat dat nvidia moet worden? kan ik dat veranderen?
*klein schopje* iemand?
Hallo Allemaal
Ik heb ook een probleem met mijn Nvidia Driver
Als ik ik X windows opstart krijg ik allemaal tekens in beeld (ASCII)
Voor mij systeemsspecs zie mijn sig.
Ik draai een eigen kernel op basis van de kernel bij bij red hat 9.0 wordt meegeleverd
Ik heb hier de patch voor de agpgart voor mijn Nforce 2 bord aan toegevoegd en vervolgens gecompileerd. De nvidia kernel module is gewoon geladen en volgens de Xf86 Log gaat er niks mis en start alles succesvol op.
Heeft er iemand enig idee???
Bij voorbaat dank
Njoy
P.S. Met de nv driver gaat alles gewoon goed
[ Voor 5% gewijzigd door Verwijderd op 08-08-2003 21:01 ]
Ik zag dat er op dit forum meer mensen last van hadden maar er nog geen oplossing was...
Ik heb zelf de oplossing al gevonden. Het schijnt een bekend probleem te zijn dat zich voor doet met alle epox 8rda MB.
De oplossing:
Upgrade je bios na de laatste versie.
Zet vervolgens je irq 10 ,11 en 12 als reserved
en zorg dat de midi op irq 10 staat.
Ik heb het ook niet bedacht, maar nadat ik het zo had ingesteld werkte bij mij alles netjes...
Is er ook iemand die me kan helpen de me kan helpen de drivers te patchen met de minion patch? Ik probeer dit nu al een poosje maar het lukt gewoon niet. Ik heb de drivers uitgepakt met de --extract-only optie. en voer de patch zo uit:
bash-2.05b$ patch -p0 < NVIDIA_kernel-1.0-4496-2.5.diff
Dan zegtie iedere keer datie de makefile niet kan vinden?? Terwijl die toch echt in dezelfde dir staat.
  • DGTL_Magician
DGTL_Magician
Heeft iemand hetzelfde probleem als ik?
Met de nieuwste NVidia drivers heb ik zowel onder 2.4.21 als 2.6.0-test2 dezelfde problemen. (de laatste is gepatched met de minion patch)
Zodra de nvidia driver is geladen worden mijn tekst consoles (geen Framebuffer) onbruikbaar. De VTY's 1 t/m 6 worden alleen opgevuld door een kakafonie van kleuren. En geen tekst! Heel vaag, en best wel irritant omdat ik die VTY's vaak gebruik om iets te testen.
  • YoNiE
  • Laatst online: 09:47
YoNiE
prei
Verwijderd schreef op 09 August 2003 @ 21:24:
doe p1. ik krijg de drivers trouwens uiteindelijk ook niet aan de gang. je moet nadat je ze gepatcht hebt een symlink maken naar een Makefile (je kan kiezen tussen 2 geleverde Makefiles, namelijk Makefile.nvidia en nog eentje :?) daarna kan je make install draaien maar let op dat je de environment variabele KERNDIR ff goedzet naar de plek van je kernel want 1 van de twee makefiles ging daarop mis bij mij.
vervolgens wordt module gecompiled en geladen, alleen doet ie het dan nog niet bij mij, startx geeft "(EE) cannot initialize kernel driver module" of iets dergelijks. ben ermee bezig! :)
bash-2.05b# patch -p1 < NVIDIA_kernel-1.0-4496-2.5.diff
patching file Makefile
patching file Makefile.kbuild
patching file Makefile.nvidia
can't find file to patch at input line 597
Perhaps you used the wrong -p or --strip option?
The text leading up to this was:
|diff -ruN NVIDIA_kernel-1.0-4496/conftest.sh NVIDIA_kernel-1.0-4496-2.5/conftest.sh
|--- NVIDIA_kernel-1.0-4496/conftest.sh 2003-07-17 04:56:13.000000000 +0200
|+++ NVIDIA_kernel-1.0-4496-2.5/conftest.sh     2003-07-31 19:52:13.000000000 +0200
File to patch:
Dit is wat ik krijg, zou niet weten wat ik hiermee moest :?
  • moto-moi
moto-moi
In welke directory sta je ?
Als je in je kernel directory staat, dan moet je -p0 gebruiken, sta je een niveau eronder, dan moet je -p1 gebruiken, en opletten dat de patchfile wel de juiste kerneldirectory pakt (Meestal 'linux' ).
  • hbokh
  • Laatst online: 07-09 17:38
hbokh
Unox: the worst OS!
Verwijderd schreef op 07 August 2003 @ 14:47:
Lijkt me niet, ik heb dat ook.
Je wou dus een "libNvidiaGLU" hebben? Hoezo?
En doe je geen "switch2nvidia_glx"?
[ Voor 7% gewijzigd door hbokh op 10-08-2003 14:50 . Reden: Aanvulling ]
This is my sick nature.
Dat laatste commando herkent hij niet.. maar als ik tuxracer opstart krijg ik geen melding emer dat 3D fout is ingesteld, maar wel een zwart scherm? kan dit ook aan wat anders liggen?
Ik dacht aan de frequenties ofzo, maar zou niet mogen want mijn monitor wordt netjes herkent ( IIYAMA VisionMaster Pro 411 )
bvd!
*pats*
  • hbokh
hbokh
Unox: the worst OS!
Zit toch echt in de SuSE-NVIDIA-RPM:
rpm -qf /usr/X11R6/bin/switch2nvidia_glx
NVIDIA_GLX-1.0-4496
Heb je DIE wel??!
Nej die heb ik niet.. maar ik heb niet meer de Nvidia drivers door RPM's maar door het run bestand..
anyway, mijn probleem lag aan dat de frequenties van mijn monitor fout in de database stonden, en die heb ik nu handmatig goedgezet.. probleem verholpen :)
  • Jaguar645
  • Laatst online: 17-11 21:06
ik geef jou een hele dikke kus :>
god dat het zo simpel op te lossen kon zijn. ik zat al 3 uur te klooien, alle files wel 5-6 keer nagelopen en elke keer weer dat hij niet die kernel wou loaden.
maargoed we gaan nu fijn verder met wat extra progjes ed installen :)
  • Rambo
  • Laatst online: 19-12-2024
ok, ik word gek hier.
Probeerde ook de nieuwste nvidia drivers te installeren onder Mandrake 9.1
ik voer in:
sh NVIDIA-Linux-x86-1.0-4496-pkg2.run
en krijg:
ERROR: Unable to find the system utility `ld`; please make sure you have the
package 'binutils' installed. If you do have binutils installed,
then please check that `ld` is in your PATH.
Geen idee wat ik daarmee moet. Met locate ld heb ik het in ieder geval niet kunnen vinden.
Nu gaf het starten van X ook problemen, maar dat heb ik op de gok opgelost door in de configfile te klooien. Het zou heel mooi zijn als iemand hier stap voor stap zou kunnen uitleggen hoe ik die driver installeer onder mandrake 9.1
Er is vanalles over geschreven, meestal net op een andere manier maar echt werken doet het niet :/
  • MadEgg
MadEgg
Tux is lievvv
M0rpheus schreef op 25 September 2003 @ 19:39:
Wat je ermee moet zegt die melding al wel lijkt me. Zorg ervoor dat je binutils hebt geinstalleerd.
Download dit pakketje en installeer het:
ftp://ftp.nluug.nl/vol/1/....13.90.0.18-3mdk.i586.rpm
Probeer het dan nog eens.
Nu mijn eigen probleem. De nvidia drivers werken goed, ik heb alleen problemen met de TV-out. Als ik met veel moeite al de TV-out aan het werk krijg, kan ik daarna met geen mogelijkheid meer het beeld naar mijn monitor krijgen. Die blijft gewoon zwart. Ook als ik naar een tekst-console ga.
Het device-stukje uit mijn XF86Config:
Section "Device"
    Identifier  "GF4Ti"
    Driver      "nvidia"
    Option "NvAGP" "1"
    Option "RenderAccel" "true"
    Option "HWCursor" "true"
    Option "CursorShadow" "true"
    Option "ConnectedMonitor" "TV"
    #Option "TwinView" "true"
    Option "TVStandard" "PAL-G"
    Option "TVOutFormat" "SVIDEO"
EndSection
Ook krijg ik twinview met geen mogelijkheid aan de praat.
Als ik van ConnectedMonitor "CRT,TV" of "TV,CRT" maak, dan wordt zowel mijn TV als mijn monitor zwart en kan ik er verder niets meer mee beginnen behalve rebooten.
Ook Option "TwinView" "true" erin dumpen helpt niet.
Wie kan me hiermee helpen? Vooral dat ik het beeld niet meer op m'n monitor krijg na naar de TV te zijn geswitched is irritant.
[ Voor 30% gewijzigd door MadEgg op 25-09-2003 20:20 ]
Tja
  • Rambo
[offtopic]
[ Voor 91% gewijzigd door Rambo op 25-09-2003 21:35 ]
  • MadEgg
MadEgg
Tux is lievvv
off-topic gezwam
[ Voor 94% gewijzigd door MadEgg op 25-09-2003 21:37 ]
Tja
  • Rambo
[offtopic]
[ Voor 71% gewijzigd door Rambo op 25-09-2003 21:35 ]
  • MadEgg
MadEgg
Tux is lievvv
offtopic-gezwam
[ Voor 112% gewijzigd door MadEgg op 25-09-2003 21:37 ]
Tja
  • Rambo
Eindelijk mijn probleem opgelost met de NVIDIA driver :)
De stappen die je moet doen om nvidia drivers te installeren onder Mandrake 9.1 zijn volgens mij:
1. downloaden NVIDIA-Linux-x86-1.0-4496-pkg2.run (van www.nvidia.com)
2. boot linux in safe mode als root (init 3 of lager)
3. ga naar de dir waar je de install file hebt staan
4. tik in: sh NVIDIA-Linux-x86-1.0-4496-pkg2.run
(zorg dat je binutils geinstalleerd hebt, zoek het anders via het configscherm)
5. vi /etc/X11/XF86Config-4
6. in de sectie 'module' toevoegen: Load "gfx" en voor de regel 'Load
/usr......libglx.so' een commentaarteken plaatsen, een #.
7. druk esc, sla op met : w+enter, sluit af met :q+enter
8. open /etc/modules (vi /etc/modules) en zorg dat daar de regel 'nvidia' staat, een andere regel die daar op lijkt zoals NVidia ofzo verwijderen. (nu wordt de nvidia module dus elke keer opgestart als je linux start)
9. weer opslaan en afsluiten (sla op met : w+enter, sluit af met :q+enter)
Nu booten en als het goed is zie je dan voordat je je login scherm ziet het nvidia logo. Zo heeft het voor mij gewerkt. Ik heb een iets andere volgorde aangehouden omdat ik aan het klooien ben geweest en niet zeker wist hoe het moest. Maar als het goed is werken de bovenstaande stappen.
[ Voor 4% gewijzigd door Rambo op 25-09-2003 21:37 ]
Pagina: 1 ... 6 ... 9 Laatste
