Is VIA gewoon gaar?
Pagina: 1 2 Laatste
  • 338 views sinds 30-01-2008
Dit vindt ik toch echt sloeberig, ze lossen
hun eigen problemen niet eens op!
PCI Latency Patch
It was not VIA, but independent programmer George Breese of Networking Resources from New York who first came up with a patch for some of VIAs problems with the PCI bus. George often posts in the independent forums at VIAHardware, who also offer the patch as a direct download.
Please note: This is not an "official" patch supplied by VIA or any motherboard manufacturer. You may use it at your own risk. To date, we could not verify if there are any stability issues implied through longer burst cycles. However, we did not see any crashes or incompatibilities after applying this patch. But, taking its severe modifications into account, this is not completely impossible. You should read the files included in the download before going any further.
The patch deals with PCI Latency, among other things. This PCI Latency sets the number of cycles, that one PCI-Busmaster-Device can request the bus for exclusive use, before releasing it. This minimum amount of clock cycles is set, so PCI performance will not decrease too much, if burst transfers are interrupted too often. On the other hand, the latency timer also prevents one device from making exclusive use of the bus for too long. After the PCI latency during one burst has passed, every other device can request usage of the bus. The burst is then cancelled immediately.
  • Martinus_E
Martinus_E
Suck on my Boomstick...
Das zwaargenieten he
Never get in a discussion with an idiot, he will bring you down to his level, and beat you with experience.
Is dit topic nou nog steeds open?
Had toch wel verwacht dat ie dicht gegooid zou worden :)
Verder heb ik weinig te melden, heb m'n punt duidelijk gemaakt en daar blijf ik voorlopig bij.
Abbadon: Nee ik heb nog geen AMD chipsets geprobeerd, hoe zit het met die 760MP? MP = Multi Processing :?
twee CPU's = twee keer zo heet = twee keer zoveel lawaai = niet wat onze klanten willen :(
Misschien toch maar eens checken want sommige klanten gaan gewoon ergens anders heen omdat wij geen AMD systemen voor ze bouwen.
Lullig maar wij hebben geen zin om later uren aan zo'n systeem te sleutelen omdat iemand zonodig AMD moest hebben, terwijl hij ook Intel had kunnen nemen.
Ik hou maar op voordat mensen het te persoonlijk opvatten ;)
/me heeft ook nog geen problemen gehad...
  • Abbadon
  • Laatst online: 19:37
Op vrijdag 04 januari 2002 22:31 schreef Roefoes het volgende:
De temperatuur valt alleszins mee (als je een goede airflow hebt), maar twee goedkope koelers makken idd samen erg veel lawaai :( (da's ook het eerste wat ik wil veranderen). En op een box van 5 tot 15 Euromille doen een paar goede geruisloze fans ook niet veel op de totaalprijs.
Maar je kan er ook één cpu op prikken. Toegegeven dat zo'n bord tamelijk prijzig is voor een uniprocessor oplossing, maar die 110 extra Euro's (vergeleken met een A-merk KT266A bord) bieden wel meer zekerheid, eventuele uitbreidbaarheid naar SMP en 64bit PCI sloten. Daarnaast kun je er een sloot aan stabiel registered ram op kwijt. Je kunt 't wellicht eens proberen (is toch altijd wel leuk toch, iets nieuws proberen). Heb geen ervaring met videobewerkingskaarten in combinatie met deze chipset, dus daar kan ik niks over zeggen.
Op vrijdag 04 januari 2002 22:43 schreef abbadon het volgende:
Ik ben wel in voor een geintje maar m'n baas is de gene die het moet betalen. En als ik over AMD begin verklaard ie me helemaal voor gek :( Hij is echt anti-AMD sinds dat gezeik met VIA, zo erg ben ik nog niet.
Dus als het aan mij lag ging ik voortaan dual AMD MP systemen bouwen(mits die AMD chipset goed is)!
Maar then again, hij moet dit geintje betalen en als het niet werkt zitten we met z'n dual MP systeem.
Met wat kloten krijgen we het wel aan de praat maar ons doel is juist om zo min mogelijk aan de systemen te kloten maar gewoon lekker films te gaan editing!
Iig bedankt voor de tip, Abbadon.
Ik ga ook zeker even met m'n baas overleggen want dagelijks Intel systemen bouwen begint toch wel te vervelen, je bouwd, installeert, en klaar, zit helemaal geen actie meer in >:)
[edit]
Hoe zit het nou met die herrie? Goede airflow brengt vaak ook een flinke hoeveelheid herrie met zich mee en low noice fans produceren weer te weinig airflow.
  • Abbadon
Op vrijdag 04 januari 2002 23:00 schreef Roefoes het volgende:
Ik heb een stille 80mm in en een iets luidere 80mm uit (die ook vervangen gaat worden). Da's alles qua in- en outtake (heb de kabels allemaal weggewerkt voor de airflow). Daarnaast heb ik ook nog disk fan's.
Nu heb ik el cheapo 38dB(A)Coolermasters op de cpu's zitten, maar ga er binnenkort 60 -> 80mm adapters opzetten plus 80mm 19dB(A) Pabst fans, dat zal wel een heel stuk schelen (vergelijkbare CFM)
Laat ik het zo stellen, de lucht rond m'n GF3 is duidelijk warmer dan die rond beide XP's.
Wat de 760MP betreft, tot dusver draait alles als een huis :) Alleen de nieuwste 23.11 detonator werkt niet goed met dit bord (ik gebruik W2K SP2)
Binnenkort komen er meerdere 760MPX borden uit, kijk de kat even uit de boom zou ik zeggen en zie wat je (en/of je baas) er eventueel mee kunt doen.
Ik heb een Gigabyte 7VTHX met de via KT266A chipset en geen problemen hiero.
er zit een PCI isdn modem op, en een SB Live! Player 1024 en dat werkt top en geen instabiel systeem.
ik gebruik de onboard netwerkkaart, maar de geluidskaart geeft in UT wel een schokkerig geluid.
Tweaty
*D
  • Glacier
Met de VIA KT133 chipset heb ik op de ene bak geen problemen, maar hier op een Asus A7V,AMD Duron700 kraakt het geluid als ik Seti@Home aankachel (die er voor zorgt dat de CPU 100% gebruikt wordt)...
  • NiGeLaToR
  • Laatst online: 18:08
NiGeLaToR
Luister Kophi Podcast!
Op donderdag 03 januari 2002 20:10 schreef nigelator het volgende:
NA een dag lang KLOTEN met drivers werkt mijn pc naar behoren. Alleen crasht/reset ie wel eens spontaan, waarschijnlijk door een brakke kutvoeding (laat vcore regelmatig naar de 1,6v droppen ;) ).
Mijn advies: Probeer/download/installeer alle nieuwste drivers en patches, van je hw makers, M$ en Via (op via is er ook een generic AMD patch voor AGP met windows te vinden, die hielp tegen lockups.
misschien moeten meer mensen meer dingen proberen.. zoals drivertjes enzo :) Helpt echt :P
Maakt reviews bij IOTDomotica.nl . Podcast bij Kophi: ook op YT.
Tja of alleen hardware kopen welke met via samen werkt.
Had eerst een mooie dual P3 750 plank met bx chipset, toen overgestapt op een via kt133a bordje en toen begon de ellende ... raid controller wou niet werken en kwam niet eens door zijn zelf diagnose heen. Dacht eerst mobo is stuk dus ander mobo geregeld en weer zelfde probleem. Toen maar weer een Intel gekocht en dat werkte gewoon wel in een keer. Dit was echter geen probleem welke je ff met een drivertje oplost. Later lees je dat er iets niet helemaal lekker zit met de pci bus van via ... Ik ben voorlopig wel ff genezen van via en nog maar niet te spreken van ali ... maar da's een ander verhaal. Volgende keer maar eens kijken naar AMD.
Je wil niet weten hoe vaak ik al met Powerquest DriveImage m'n image heb teruggezet om daarna die fantastische VIA service packs + drivercombinaties te proberen..
Das echt 100% genieten!!!! Zwaargenieten kan ik je vertellen |:(
Oke, maar toch kwa gaming-performance en tekstverwerking performance is AMD/VIA genieten...
Alleen moet je toevallig geen exotische componennten (zoals Hauppauge) hebben in je bak, omdat die voornamelijk intel compatibel zijn. Als VIA nu echte service zou geven dan zouden ze samen met die lui van Hauppauge een oplossing bedenken in plaats van lekekr de schuld af te schuiven...
Das altijd makkelijk! En wat kan VIA de gebruikers schelen?
Wat ik nu doe is gewoon elke review-site (zoals anandtech en tomshardware) mailen en vragen wat ik eraan kan doen. Hopelijk plaatsen ze eens een af-fik review van VIA in combinatie met hauppauge, hoewel ik dit betwijfel. Dan komen die lui wel in actie..
Zoveel mensen die gezeik hebben met VIA chipsets, en nog blijven er mensen hard brullen dat het komt door de ondeskundigheid van de VIA slachtoffers en dat VIA chipsets ruleren.
Da's toch lachen? :+
  • tweakduke
tweakduke
ja echt wel
via moet je altijd ff netjes bouwen
EN DE GOEDE DRIVERS!!!!!!!!!!!!!!!!!
je hoort wel mensen die een standaard pc hebben
formateren
en dan dus de drivers weg en nie installeren
goh mijn windows is opeens brekkun??? =)
wahaaa lolz!!!!!!!
Tweakers Discord
  • Redje
  • Laatst online: 18-08 21:30
Op zaterdag 05 januari 2002 12:56 schreef Roefoes het volgende:
Da's zwaar genieten :7
Heb iemand dan nog ervaringen (goeie) van die PCI latency patch?
  • JeroenNietDoen
  • Laatst online: 21:29
ah het mooie is dat er van SiS nu ook erug mooie alternatieven zijn, en van NVidia natuurlijk. plus dat deze alternatieven nog retesnel zijn ook.
  • gitaarwerk
gitaarwerk
Plays piano,…
hmmz.. ik heb ookw at van via,...maar jah..ik heb een amd 760 chipset..dies wel behoorlijk stabiel...alleen zit ik met een probleem dat als ik me geluidskaart erin douw...dat heel ding niets meer wilt doen (net alsof de voeding brak is)
Ontwikkelaar van NPM library Gleamy
ik heb een epox 8KHA+ mobo en ook een tv-kaart (pinnacle, PC TV Rave) en een geluidskaart van terratec, maar ik heb helemaal geen problemen hoor. Werkt allemaal perfect!
  • gitaarwerk
gitaarwerk
Plays piano,…
epox maakt gewoon goede dingen.. ik vind dat AMD net wat teveel problemen geeft..en dat ligt neit alleen aan de chipset.. darom word men volgende pc toch weer een p4 northwood..omdat ik ook een celly hier heb staan een 466mhz..en dat ding heb nooit problemen gegeven..en kijk me amd eens.. ok..ik vind em nog wel stabiel..maar toch..je moet teveel kennis hebben om em goed te laten lopen
  • LordLynx
  • Laatst online: 14:38
Nou snap ik het helemaal niet meer, ik lees net een topic over die Abit KR7a-raid plank, en dat ding zou absoluut de topplank van het moment zijn. Maar dat ding heeft wel die Via266A chipset erop. Kan ik nou hiermee ook niks als problemen verwachten, want als ik mag kiezen tussen een paar procentjes sneller en zo instabiel als een kaartenhuis, of een stabiel KG7-raid bordje (met AMD 760 chip) heb ik toch liever dat stabiele ding.
Heb vroeger een KT133 en KT133A gehad en geen (noemenswaardige) problemen mee ondervonden.
Momenteel heb ik een plank met AMD 761 chip en ik moet wel eerlijk toegeven dat ie toch stabieler aanvoelt, basically is hij ook stabieler.
Het zit hem in de kleine dinkjes :)
  • k7of9
  • Laatst online: 02-09 23:19
Ik heb met hardware altijd geluk geloof ik. VIA 133, werkt prima, VIA 133a, niks geen problemen. Bij vriend van me 266a ingebouwd, als een zonnetje. En dat er zoveel mensen problemen hebben met VIA moet je ook relativeren, mensen die geen problemen gaan geen topics openen met de titel "he moet je horen, mijn VIA bord loopt lekker". Dit geld ook voor zaken als OSen, videokaarten, etc, bla, bla.
Mijn fotografie en videografie
  • porn*
  • Laatst online: 07-09 14:42
porn*
...take on the world!
Zwaargenieten: heb je al geprobeerd om wat met BIOS waarden te spelen, zoals PCI latency enzo?
Probeer die eens op 3 te zetten en Memory Hole enabled. Testen of het werkt. Zoja, blij zijn :)
Zo nee, kun je nog de Master PCI caching aan/uit proberen te zetten.
Bnet pindle#2913
  • Abbadon
Op zondag 06 januari 2002 17:26 schreef gitaarwerk het volgende:
Soundblaster zeker? Je hebt dan wel een bord met een AMD northbridge, maar de southbridge is gewoon ViA. Tja, Soundblasters en ViA southbridges zijn geen vrienden van elkaar. Jammer dat er geen single-cpu borden zijn gemaakt met een écht volledige AMD-760 chipset.
  • QuestGamer
  • Laatst online: 14-05 22:58
QuestGamer
Questje
Heb ook geen problemen met mijn KT133A mobo (Asus)...
Ik stream Poker, Retro Games & Good Vibes op Twitch.tv/Questje :-)
Dit topic wordt nu meer een opsomming dan dat het behulpzaam is.
De éen heeft wel problemen met VIA en de ander niet, dat mag nu wel duidelijk zijn.
Als er nou nog nuttige dingen werden gepost, maar da's niet echt het geval.
Zo ongeveer net zo nuttig als deze post :)
  • Packardhell
  • Laatst online: 22:46
Ik had even problemen met me VIA chipset KT266, ik had wat IDE apparaten van plaats veranderd. En toen deed me hardeschijf niks meer als je reset en soms opstart. Dus in een goed moment de 4.37 drivers van VIA geinstalleerd en de problemen waren opgelost. Ze hebben wel een perfecte driver/updates afdeling. Ze proberen in ieder geval de chipset zo stabiel mogelijk te maken.
En tegenworodig heb je zat keuze in de chipset markt: AMD, SiS en nForce. Om een paar belangrijke te noemen.
Powered by KPN
  • flippo
  • Laatst online: 07-11-2023
hoi daar,,
Ik had zelf problemen met mijn sb128 en a7v266.. ik heb mijn sb128 nu in een ander pci slot gezet en toen werkte het perfect. je moet proberen om de "zwaarste" kaarten in een slot te steken met een vrij irq en niet een gedeeld irq
met het AGP slot..
kijk voor info op http://www.teccentral.de/asus_a7v266_guide/
tis helaas in het duits maar doet het wel
groetjes
  • gitaarwerk
gitaarwerk
Plays piano,…
Op zondag 06 januari 2002 18:45 schreef abbadon het volgende:
neej..in dit systeem zit wel een SB live.. maar die vervang ik juist door een Guillemot maxi studio isis (jah sorry met kopen,..ik hoorde nu dat ie fout wa..maar ik doe em toch niet weg)
  • TERW_DAN
TERW_DAN
Met een hamer past alles.
Wat denken we trouwens van VIA cpu's
:D :D :D :D :D :D :D
* TERW_DAN komt niet meer bij aangezien een intel/amd 300 mhz, de huidige via 933 in kan halen
  • gitaarwerk
gitaarwerk
Plays piano,…
kt266 is jee
de erst is :r :r :r :r :r :r :r :r
ow kut..geen sjipsets
neej de via :r
U gaat niet VIA af,..en krijgt geen 500MHz erbij
Op zondag 06 januari 2002 17:06 schreef Zwaargenieten het volgende:
ja hoor, ik had een a7v van asus en ik kon geen divxjes van de ene naar de andere harddisk kopieren(backup van mijn DVD backup natuurlijk :) ). Die patch geinstalleerd en het liep weer als een trein! En dat MET een sb live in m'n pc.
Op zondag 06 januari 2002 21:44 schreef terw_dan het volgende:
Nee, duh! |:(
Deze CPU's zijn ook niet gemaakt als snelheids monsters maar voor kantoor machines, en als het even kan om passief te koelen.
  • VeldKoe
WAT IS DIT VOOR EEN WIBRA TOPIC? de enige reden dat zoveel mensen zitten te zeiken op VIA is omdat het de meest gebruikte chipsets zijn, en omdat de meeste gebruikers redelijk hersendood zijn kwa pc intelligentie en dus denken dat als je iets koopt het meteen vanzelfsprekend werkt.
NEE! je moet er IETS voor doen
wat dan? om van een PERFECTE non-error werking van je chipset verzekerd te zijn simpelweg je OS opnieuw installeren en de 4in1 drivers van VIA pakken! is dat nou zo'n klus? NEEEEEEEEEEEEE DAT IS HET NIEEEEEEEEEEET
bah
sneue topic
Op zondag 06 januari 2002 22:25 schreef VeldKoe het volgende:
bah
sneue topic
/me komt niet meer bij van het lachen(janken)
Ik denk dat deze post meer zegt over jouw intellegentie dan over die van het gemiddelde VIA slachtoffer hoor :+
/me snapt niet dat mensen zo stront eigenwijs kunnen zijn!
  • ronaldmathies
Heb de KT133A, samen met een SBLive en een hauppauge desktop theater kaart erin, nergens probs mee.
3015 Wp-z 5360 Wp-nno op 2 x SMA-SB3600 TL-21, Warmtepomp: ERSC-VM2CR2 / PUHZ-SHW140 YHA, WTW Q350, EV Kia Ev6 GT-Line
  • VeldKoe
Op zondag 06 januari 2002 22:30 schreef Roefoes het volgende:
en ik denk dat jouw spelling nog meer zegt over jouw INTELLIGENTIE >:)
Belachelijk! Ergens geld voor betalen en dan ook nog verwachten dat het werkt!
Als VIA hun cipsets nou eens zodanig goed zouden maken dat er geen drivers nodig zijn om voor alle bugs te compenseren.
  • Beaves
  • Laatst online: 16:56
Beaves
Usque ad Finem
Op zondag 06 januari 2002 22:33 schreef VeldKoe het volgende:
En ik op mijn beurt denk (nee weet) dat jouw nick heel toepasselijk is, het niet toe kunnen geven dat VIA brak is, is een teken dat je echt een }:O bent.
Schotlandofiel | Godzijdank ben ik atheïst
Canon 7D / 20D / 300D + glas | Just Light | Flickr
Ja maar da's weer een heel andere vorm van intelligentie, je kan ook niet alles hebben he ;)
Triest, maar waar.. Ik blijk dus niet de enige te zijn met serieuze problemen. Ik denk toch dat VIA nu echt een serieus image probleem gaat (heeft??) krijgen als ze niet snel deze PCI performance gaan fixen. De klachten + feiten stromen hier letterlijk binnen op dit forum. En die "John Gatt", dat figuur dat de klachten officieel afhandeld gaat er naar kijken... Ik vraag me af wat ik me daarbij voor moet stellen.... :'(
http://forums.viaarena.com/messageview.cfm?catid=6&threadid=5402&start=1
  • EaS
  • Laatst online: 30-08 08:24
EaS
bah
sneue topic
Ben het voor een groot deel met je eens.....veel van die idiote fouten die hier voorbij komen rollen zijn errug vaak aan user-error's te wijten. Echt waar, de meest idiote fouten worden hier altijd afgeschoven op VIA (en zo nog wat anderen)......en dan zie je ze later weer met een post: "ja ik met m'n domme kop had de drivers niet geinstalleerd...of de koeler zat er niet goed op |:("....
En even antwoord op de vraag: Is VIA gewoon gaar?".... Nee.
  • Glacier
Op maandag 07 januari 2002 20:45 schreef EaS het volgende:
Voor Zwaargenieten gaat dit niet echt op...hij is al een maand aan het klooien met 4in1 drivers, BIOS instellingen, latency patches, shared PCI slots, testen van andere hardware in zijn bak....als je van iemand kan zeggen dat hij er alles aan gedaan heeft, is het ZG wel...en op een gegeven moment is je inspiratie qua oplossingen gewoon op...en dan ga je naar GoT om te vragen of er meer mensen probs hebben en of er oplossingen zijn...
* Glacier vindt het een beetje jammer dat ZG afgezeken wordt, blijkt dat degenen die dat doen, niet de moeite hebben genomen om de ontopic posts in deze thread te lezen...
Heb antwoord gekregen :) van die duitse review site die het artikel: "VIA-chipsets slows down PCI cards" online heeft gezet en ze gingen nog meer reviews doen. En het probleem grondiger bekijken. Ook die "John Gatt" (van Via support) is wakker geworden en heeft belooft om aan een solution te gaan werken met VIA engineers. De klachten over PCI kaarten +VIA chipsets en performance lopen nu echt binnen :9 namelijk.
Vooral als je een redelijk volle bak heb zoals ik, 4 pci kaarten is tegenwoordig meer dan normaal (TV,Audio,Netwerk,SCSI,enz) en als je dan net zoals ik ook nog RAID hebt die continu de PCI bus een deel opeist, is het niet vreemd dat je lijnen of geruis krijgt door TV/SB.
Via schijnt er nu aan te gaan werken. Misschien dat
een oplossing helemaal niet gaat lukken, omdat het
hardware based is, maar daar ga ik niet vanuit...
En voor al die figuren die "Maar iets rondbleren :r ".. zou
ik zeggen, lees de topic ff grondig en geef dan een
mening + argumenten. :)
Werd wel eens tijd dat ze de problemen met hun chipsets serieus begonnen te nemen.
Misschien nuttig om te vermelden: Ik heb zelf een KT133A chipset op m'n mobo zitten.
In deze bak zitten 2 pci netwerk kaarten, 1 pci geluidskaart en wel eens een pci TV kaartje(pinnacle pctv).
Het beeld van de TV kaart was behoorlijk goed te noemen, de pctv pro daar in tegen gaf heel erg brak beeld.
Dus 4 pci kaarten die allemaal tegelijk gebruikt worden, geen enkel probleem hier. Nee tis geen SCSI maar ik had toch wel een redelijke vertraging van de PCI bus verwacht wanneer alle 4 de pci kaarten gebruikt worden.
Wat trouwens ook opviel was dat al m'n problemen met VIA opgelost waren sinds ik m'n SB Live! heb vervangen door een SB Audigy!
Niet alleen het data corruption probleem en het feit dat ik geen grote bestanden kon kopieren, maar echt alle problemen waren weg!
Van random crashes en reboots tot blauwe schermen en errors aan toe!
Nee, dit lach niet aan m'n geheugen en ook niet aan het OS.
Ik had het redelijk grote probleem dat m'n RAID-0 niet lekker werkte, 2x 60GB IBM 60GXP gaf in Sandra 33.000 punten, deze 2 zelfde schijven laatst getest op een P4-systeem met een Intel chipset gaf 46.000.
Na de PCI Latency Patch zit ik nu op een nette 45.000
Mooi is dit topic :P Wil ik net een upgrade doen naar een Abit Kr7A-RAID en een AMDXP2000+, kom ik dit topic tegen. Daar beginnen de twijfels weer. Had ik net mezelf overtuigd :( :) Kan ik ook nog een paar postieve dingen horen of moet ik maar geld gaan verspillen aan een P4 systeem (no flame intended). Tot zover deze zinloze ( :? ) reply :) .
  • LordLynx
Ik heb precies hetzelfde, ik heb nou al 6 dagen een KR7a-raid met XP 1700 in mijn bestellijstje staan, maar ik twijfel nog steeds of ik niet beter 'gewoon' een Tyan Dual mobo (met AMD north en south bridge) kan nemen, tis wat duurder, maar als ik daarmee beter uit ben...
Wat ik toch wel heel vreemd blijf vinden is dat ik 45 reviews van mobo's met KT266a chip gelezen heb en GEEN ENKELE (ook deze op tweakers.net zelf niet) heeft het over problemen met die mobo's...
Dan vraag ik me toch wel af of het gewoon gezeur is, of echt alleen met best wel vreemde componenten voorkomt...
Op woensdag 09 januari 2002 11:41 schreef LordLynx het volgende:
Idd ja. Ik heb gvd al een hele hoop binnen ( cooler, spacer, kast,etc) En nou moet ik dit lezen :P grrrr :) Dan toch maar wachten op de KT333A chipset (Q2-2002) :? :P
Ik kan je vertellen waarom dit zo weinig aan het licht is gekomen. Review sites testen het bord meestal standaard met 1 snelle Videokaart (GeForce 3 Ti500 bijv), 1 audio kaart die op een los vrij IRQ zit. Of ze gebruiken de onboard sound die ook geen problemen geeft. Netwerkkaart geeft tevens ook weinig tot geen performance problemen. Fancy dingen zoals RAID in comb. met Tv-kaarten komen niet aan bod, omdat dit niet echt standaard is (niet voor de doelgroep). Dingen die ze belichten zijn meestal
Office Performance + Games Performance benchmarks. En als
er 1 goed game-systeem is, dan is dat wel AMD XP + VIA of andere chipset. Daarom meel ik nu zo veel mogelijk hardware sites of ze dit probleem eens kritisch willen bekijken en hun mening willen geven!
  • LordLynx
Oke, dan bij deze mijn vraag: kan ik hier problemen mee verwachten:
Abit KR7a-RAID
XP 1700+
512MB Kingston DDR (1 reepje)
Coolermaster coolertje (eenvoudig dingetje)
2X20GB IBM ATA66 7200RPM (2 jaar oud, komen in raid-0 op de Highpoint onboard)
1X60GB 7200RPM, ATA100, komt op de onboard IDE
1X Pioneer 10*DVD
1X LiteOn 24*Burner
Hercules Geforce 2 Ti
Soundblaster Live! kaart, maar binnen twee maanden een Audigy
1 netwerkkaart
floppydrive, en misschien nog een zip 100
Lijkt me niet zo'n vreemde config, dus hier ga ik waarschijnlijk geen last mee hebben?
Op woensdag 09 januari 2002 16:46 schreef LordLynx het volgende:
Abit KR7a-RAID
XP 1700+
1X Pioneer 10*DVD
1X LiteOn 24*Burner
1 netwerkkaart
Hangt er van af hoeveel je van je prestaties verwacht. Op zich moet een SB-kaart met een beetje goed klussen in een vrij IRQ + eventueel latency patch wel werken. Zet i.i.g eventuele onboard sound uit.. Van de "Highpoint controller" weet ik niet zoveel aangezien ik een "Promise" heb. Ik hoorde van iemand dat de audigy minder problemen geeft dan de live, alleen blijft nog steeds de vraag als je net als ik enkele GB's dagelijks overpompt van bak naar bak naar writer of je sound/multimedia performance dan nog goed blijft....
  • Microkid
  • Laatst online: 22:39
Microkid
Smile
Ik ga niet zeiken of VIA nu goed of slecht is. In het algemeen maken ze goede chipsets. Helaas zijn er bij de KT133A blijkbaar meer problemen dan normaal.
Zelf heb ik ontdekt dat deze chipset in combinatie met een USB ISDN modem niet lekker werkt. Goed, het is even lastig, maar ik ga er van uit dat VIA met een oplossing komt.
  • LollieStick
  • Laatst online: 27-08 09:29
Wie zegt dat het aan je chipset ligt? Slechts in 5% van de gevallen ligt het aan de chipset, in alle overige gevallen gewoon aan Windows of aan je videokaart (driver). Smijt daar eerst een een nieuwe, of als dat niet werkt, de op cd/diskette geleverde versie, van in. Kom daarna maar weer.
Dat VIA problemen heeft met de PCI aansturing is al wel duidelijk, maar daar hoef je VIA niet op af te zeiken. Ik heb 2 computers allebei met een VIA chipset (MVP3 en KT133) en heb nergens last van. Als ik problemen heb, kwak ik de latency patch er in en is het probleem opgelost.
Als je het met de latency patch niet lukt, is het dus zeker geen chipset bug maar ligt het duidelijk ergens anders.
  • gitaarwerk
gitaarwerk
Plays piano,…
ja..dat wel.mee eens..maar ja..tis een ebetje onhandigheid/nieuwigheid van et spulletje
et rare is.. dat et officieel zo gelijk met werken..maar toch.. je zou meoten weten wat je doet als je et koopt.. dus jah.. beetje fifty fifty
ik ben gewoon te spreken..bij mij doet alles et normaal als et eenmaal aan kan gaan!
ondanks mijn kleine beetje kennis kan ik alles behoorlijk fixen..kost allees veel tijd..net als netwerken..
ik vind dat als ze die ocmputers zo snel moeten maken vanwege de snelheid, moeten ze ook maar eens wat sneller in elkaar gezet kunnen worden. enneh.. ligt ook grotendeels aan MS... tis niet alleen de VIA..
het OS wilt via wat minder onderteunen
was al eens rel over geweest d8 ik
  • LollieStick
Dat is ook zo. Iedereen zegt dat VIA chipsets zo instabiel zijn. Ik gebruik Windows en zie wel eens een blauw scherm ja, maar dat ligt niet aan VIA, dat ligt eerder aan Windows zelf omdat Windows geen goede support levert. Ik gebruik naast Windows ook Linux en die heeft helemaal geen rare vastlopers of foutmeldingen. Beetje raar toch??
en kom nou niet met het verhaal dat Linux stabieler is dan Windows want dat is ook zo, maar Linux kan door hardwarematige bugs ook vastlopen.
Op donderdag 03 januari 2002 20:18 schreef gabberjoost het volgende:
Ben ik het helemaal mee eens, nooit problemen gehad...
daar sluit ik me bij aan!
  • AP3X
ik had ook lijnen door m'n beeld van de tv-kaart
maar met de (on)officiële patch zijn ze nu weg
die patch kon je geloof ik op www.viahardware.com halen
Op zaterdag 12 januari 2002 13:04 schreef Chaser2600 het volgende:
Wat voor kaart heb je? Een Hauppauge WinTV PCI en een KT266a chipset? In dat geval ben ik errug benieuwd...
  • Speedpete
  • Laatst online: 05-09 11:10
Speedpete
was barman
Het beeld van m'n TV-kaart is perfect, M'n netwerk werkt naar behoren (ingebouwde 4x hub), modempje doet het fantastisch... dusse, ik heb niets te klagen... Enne ja, het is VIA..:P
Object-oriented programming offers a sustainable way to write spaghetti code | Hoe vleugels wel werken.
Op donderdag 03 januari 2002 20:32 schreef Zwaargenieten het volgende:
Yepz.. zekers.. hoeveel tweakers hebben eigenlijk een TV-kaart??? Zit nu een maand te kloten met dit vage grafprobleem en wil binnenkort een audigy kopen.
Heb dan natuurlijk geen zin om een beetje haperend geluid te experiencen... Iemand ervaringen al met Audigy+KT266a?
Post ze! Dan weet ik of ik dat risico kan nemen :)
Zeker WinXP?
  • sharkzor
  • Laatst online: 05-09 12:36
is via gaar? jazeker.
heb alle ellende meegemaakt.
eerst een asus a7v. big mistake. gewoon niet stabiel te krijgen, wat ik ook deed.
omgerolen voor abit kt7. draai nu wel goed als 2e pc, maar in het begin alleen maar gezeik met usb, isdn, irq's you name it.
nu een abit kg7-raid. nogsteeds via686b, maar t draait als een trein. usb, sblive, irq management (dat word door amd sjipgedaan ;) ) werkt allemaal perfect.
alleen laatst had ik m'n ide zipdrive teruggeschroeft. bleek dus dat dat niet werkt met die 686b :( zeker niet met firmware 14A (en wat heb ik |:( )
volgende keer eerst alle forums sjekken of er geen problemen zijn met m'n hardware :r
Wat dachten jullie hiervan (thread hieronder), lijkt verdacht veel op mijn problemen... Hoewel ik kwa stabiliteit niet te klagen heb...Alleen die VIA figuren willen maar niet reageren.
Waarschijnlijk zijn ze bang voor slechte recensies ofzo, want ze locken continue bepaalde forum threads... Vrijheid van mening kennen die lui waarschijnlijk niet..
http://forums.viaarena.com/messageview.cfm?catid=6&threadid=897
He
same problems for me,
I have it all, via, sblive, wintv and an alcatel adsl modem. So a lot of problems.
I have an epox kx 133,so 686a southbridge,but same problems.
Before i had my adsl connection i could solve all my problems by putting the PCI latency timer on 96. My tv-card worked fine and also the sblive.
After i bought the modem ... trouble.
I upgraded my wintv driver (Wtvdrv42.exe), screen looks great(latency has no influence anymore, so i put it back on 32), but i have sound problems, sometimes it's gone and i have to reboot to get it back (problem on tv-card, checked it). And if i watch TV and use my modem, after an hour i have no power on my USB. (Checked this, twice more than 36 h online without any problems, 1 hour online when watching tv and it happens)
So i installed the old driver back from wintv, black stripes in TV-mode as result. Began to experiment with the patch (latency 0.18), then i had cracking sound on my Sblive. Without the patch and PCI latency on 0, everything works fine only when theres no traffic on the USB, maybe here's a solution for some people.
I think throughout with all the upgrades i did my powersupply has become insuffient, i only have one of 250W. Is this the problem?Maybe the voltages are not stable enough. Please look into it,
i'm still not satisfied, maybe somebody from via can give me a solution.
greatz
bobke666
system
AMD athlon 700Mhz on EPOX kx133, 386Mb Sdram, Sblive 1024, Wintv PCI dbx & radio, Alcatel USB modem, Pioneer DVD, HP-writer 8100, HD western digital 10Gb 5400rpm
  • supershoe
Ik heb een Abit KR7a met Via 266a en een Audigy en het werkt perfect allemaal onder XP.
Enige probleem was dat mijn ASUS DVD E616 lees errors gaf, maar na een update van de Via4in1 drives ofzo heb ik dat ook niet meer.
Sigs van meer dan 1 regel sucken.
Op donderdag 03 januari 2002 21:13 schreef chucky666 het volgende:
heb hier de kt133,kt133a,kt266 en nu de kt266a :)
en heb bij allemaal toch echt geen problemen gehad, en ook niet toen ik er een sb instopte :)
het lijkt me sterk dat ik iedere keer weer geluk heb :+
Nee, je hebt niet elke keer geluk. Die fout betreffende de SBLive kwam door een foute instelling van een van de registers op de chipset. Dat is allang opgelost. Zie de specs in mijn signature. Die computer draait net zo stabiel als mijn (verkochte) p2 350 met 440BX. Deze VIA pc heeft vaak uptimes van 3 weken, voordat ik hem reboot vanwege een nieuwe driver of een update. Over andere VIA chipsets dan de KT-133a kan ik niet oordelen; ik heb er nooit een gehad. Ik ken mensen die enorme problemen hebben met de Abit KT7A-raid. (Ook KT-133a) Het lijkt erop dat niet alleen de chipset goed moet zijn, maar OOK de implementatie ervan door de moederbord fabrikant.
  • T.T.
  • Laatst online: 22-01 14:13
T.T.
Sowieso
Op dinsdag 08 januari 2002 21:35 schreef Zwaargenieten het volgende:
Ik heb 5 PCI kaarten (2 netwerkkaarten + soundblaster audigy + pci videokaart (tseng et6000) + tvkaart)
en een AGP GeForce2 GTS videokaart.
Ik heb nu echt alles geprobeerd, maar ik krijg het niet voor elkaar om mijn soundblaster "kraak-vrij" te krijgen. Gaat altijd kraken wanneer er ("te veel") pci-verkeer is lijkt het wel.
Ik heb dus een Abit KT7 + TB1200 @ 1365, en voor mij lijkt VIA chipset dus vrij brak.
Oh ja, hiervoor had ik een ISA SB 64, nooit problemen mee. Ik heb dus het befaamde Soundblaster - VIA probleem in een volle PC :(
In de PCI-slot / IRQ handleiding in de manual van de A7V266-E zitten drukfouten. De hele tabel klopt niet.
Momenteel heb ik ff m'n netwerkkaart ge-shared met m'n onboard soundkaart, en met netwerk usage hapert m'n onboard dus ook. PCI 4 schijnt vrij te zijn, 3 ook als je onboard sound uitgooit, netwerkkaart in PCI 1, In PCI 2 wordt geadviseerd op helemaal niks in te gooien wat een IRQ nodig heeft. Das toch gewoon te gek voor woorden.
VIA moet die share van de PCI bus gewoon maar verbeteren.
Op m'n oude intel bak (ok, ouder design, dus langzamer) ging alles gewoon samen, welk PCI slot je ook nam...
Op donderdag 03 januari 2002 21:42 schreef Zwaargenieten het volgende:
Best... Open een topic "Zijn Hauppauge en Etech kaarten gaar?".. Hoewel in mijn geval dit topic beter zou zijn:
"Asus A7V266-E en Hauppauge bezitters gezocht"
Vraag me af of het een hot topic wordt.. heb zo'n idee van niet :)
Asus A7V266-E
AMD 1700+
Asus V3400 TNT/TV (AGP)
SB Live Value (PCI 3)
Hauppauge WinTV/PCI Radio (PCI 4)
Realtek RT8139 (PCI 1)
IBM-DPTA-372050
IBM-IC35L040A
Iomega Zip 100
HP CD-Writer 8100+
512 Mb
Win2K SP2
No problems hier. :z Probeer eens andere PCI sloten (in de handleiding staat een verkerd slot als "in use" aangegeven.)
Ik weet niet wat 'een' probleem moet zijn, vastlopen doet toch elk systeem wel eens, windows is toch niet stabiel. XP ook niet. Dat ligt echt niet alleen aan de chipset. De laatste drivers 4in1 hebben mijn systeem wel goed gedaan. 8-)
Op zondag 13 januari 2002 12:12 schreef marcellic het volgende:
Asus A7V266-E
AMD 1700+
IBM-DPTA-372050
IBM-IC35L040A
Iomega Zip 100
HP CD-Writer 8100+
512 Mb
Win2K SP2
Heb nog es ff naar m'n vrije PCI sloten gekeken.. Vrij slot PCI 4 is bij mij dus niet vrij, want die graf PCI kaart van PCI past er niet in, zit tegen de onboard audio aux connector met een videoaansluiting aan |:( |:( Hoe heb jij dat dan geklust? Afgebroken ofzo?
Verder nog ff een vraagie? Heb jij de A7V266-E met onboard sound en onboard RAID? Want dan ben ik toch erruggg benieuwd of als jij je RESERVE-KOPIE'S kopieert tijdens het TV kijken geen strepen door het beeld hebt... Met normale ATAPI IDE drives heb je dit natuurlijk niet.
Ben dus errug benieuwd, de config lijkt enigzins hetzelfde...
  • RainbowSix
  • Laatst online: 20-09-2025
Of via gaar is dat weet ik niet, maar om een via based bordje "optimaal" te laten werken ben je inderdaad behoorlijk aan het prutsen met drivers, patches en tweakjes.
Iets wat ik bij bordjes met intel chipsets niet hoeft te doen.
Hieronder nog ff een posting geplakt van een gast die precies hetzelfde probleem aanduid... Hij verwoord het probleem erg goed >:) en verwacht gewoon goede service en een oplossing.. HIER GAAT HET DUS ALLEMAAL OM (DIT TOPIC)
yeah, and i disagree with the other thread on this subject - much too apologistic for my liking
i find it very patronising to say "what problem? you haven't got a pci problem! don't worry about it! you're not a professional user running SCSI RAID array doing big file transfers! there is no issue...look how fast KT266A benchmark is against Northwood" But hey, this has got nothing to do with the processor comparison of AMD vs INTEL.
DIVERSIONARY TACTICS! This is also nothing to do with performance of the integrated Via IDE controllers on the VLINK.
The issue at hand is: PCI performance and wrongful bus-timeouts and interrupts found in the core logic of Via chipsets since the MVP3!!! We are talking Via < Intel, AMD, SIS, ALI, Nvidia.
We are waiting for some kind of response on this initial study of these guys with their logic analyser.
I think I read another user on anand forums express this well - it's like if you buy a car, let's say you buy a ford, and you look at the speedometer and you see maximum speed is 150 MPH. OK, so you may or may not ever drive that fast, but then you find out, no, the car will have big problems, and your radio will have stuttering, and your windscreen wipers will jam, and your car will start shaking when you go over 100 MPH!! But hey, there is no problem, because you're not a power driver anyway - if you wanted a car to drive at 150MPH, you should have bought a lamborghini diablo instead!
Bah! But, hey, we're saying I can hit 120 MPH with no problems if I buy Mazda, Honda, etc...that's the problem!
Nog meer fun!!! Binnenkort ga ik een audigy kopen. Waarschijnlijk blaast die ook op de VIA PCI-bus... Ga dus echt vloeken als ik dat ding heb, en tijdens het kopieeren de sound hapert... Iemand een audigy + A7V266-E (raid)?? Ik geloof dat deze combinatie wel kan lukken mits je em in een goed PCI slot pleurt.
http://forums.viaarena.com/messageview.cfm?start=21&catid=6&threadid=1428
Ik heb de NO-RAID versie.
Voorheen heb ik ook storingen in m'n TV beeld en vervorming in m'n wav geluid gehad. Afhankelijk van kleurdiepte (weet niet meer of 16 of 32 was) verdwenenen de strepen.
Ik heb de hauppauge opnieuw geinstalleerd in de juiste volgorde (RTFM) en de onboard sound in de bios disabled.
Hiermee waren de problemen over.
Op zondag 13 januari 2002 18:26 schreef Zwaargenieten het volgende:
Heb nog es ff naar m'n vrije PCI sloten gekeken.. Vrij slot PCI 4 is bij mij dus niet vrij, want die graf PCI kaart van PCI past er niet in, zit tegen de onboard audio aux connector met een videoaansluiting aan Hoe heb jij dat dan geklust? Afgebroken ofzo?
Wat bedoel je? Ik heb 5 PCI sloten waarvan #5 vlak naast de ACR zit (useless) Hoe heb jij je sloten verdeeld?
  • LollieStick
Op zondag 13 januari 2002 18:34 schreef jhiemstra het volgende:
Maar zeg nou zelf dat Intel ook niet 100% is. Intel heeft ook problemen met hardware (Intel 440 met sb live + realtek kaart = een onbruikbaar systeem)
  • LollieStick
Op zondag 13 januari 2002 03:10 schreef T.T. het volgende:
Weet je wel wat je zegt?
5 pci kaarten!!!
Een PCI bus heeft ook niet onbeperkte mogelijkheden. Je soundblaster vreet van het systeem en je videokaart doet daar nog een stapje bovenop. Trek die videokaart er eens uit en probeer het dan weer!7
yo ik heb zo'n chip zitten en op mijn mamma plank!
ik heb hier een safeway 5.1 :P, 2 netwerkkaarten, en een tv kaart en alles loopt als een zonnetje! NIET ZEIKEN DUS!!
Ha, ik ben zeker een hele grote mazzelaar. Ik heb een van de eerste releases van de Asus A7v, en het is zoals we van Asus gewend zijn een zeer stabiel moederbord. En het installeren van de VIA 4in1 vind ik geen onoverkomelijk nadeel, ook bij Intel borden moeten wel eens patches of drivers worden geïnstalleerd. Dus VIA is in mijn ogen niet gaar, en volgens mij zijn mensen die daar zo'n problemen mee ondervinden gewoon raar aan het rotzooien.
Op maandag 14 januari 2002 19:01 schreef marcellic het volgende:
Op de unofficial A7V homepage staat dat dit aangeraden wordt..
PCI1 wordt geshared met PCI5 en AGP en PROMISE RAID
PCI2 wordt afgeraden om daar iets met een IRQ in te stoppen
PCI3 is vrij, mits de onboard audio uit staat
PCI4 is vrij
PCI5 is weer geshared met PCI1, enz...
Nu past m'n WinTV niet in PCI4, omdat er een externe aux connector klem tegen het intakeslot van m'n hauppauge zit (de videoaansluiting zit dus klem tegen een onboard component). Dus pleur ik die in 3! Nu moet ik dus weten
of de audigy (die ik ga kopen) in PCI slot 4 gaat passen...
Omdat die dus ook weer vrij veel uitgangen achter heeft..
Ik blijf er toch bij dat de support van VIA enorm triest is. Het bewijs???? Check www.viaarena.com en zie het leed wat daar gaande is. Voor de rest vindt ik ook dat Asus z'n PCI opties in de BIOS wel wat mag uitbreiden. Je kan daar helemaal niks instellen behalve de PCI latency! Beroerd gewoon....
Graag reacties. Ben benieuwd.. :) (vooral over A7V266-e PCI slot4 en de audigy)
  • digifun
digifun
Op dinsdag 15 januari 2002 21:03 schreef LinuxUser het volgende:
3com en intel kaarten geven geen problemen . Dit probleem treedt op bij meerdere configuraties. Vergeet niet dat realtekkaartjes wel erg goedkoop zijn.
Dat het een onbruikbaar systeem is, is pertinent niet waar allleen de netwerk kaart doet het niet. Verder werkt het systeem prima.
u can fool all people some time and fool some people alltime
Ik moet zeggen ik heb ook wel eens problemen, maar ik durf niet te beweren dat die te wijten is aan VIA, kan net zo goed bepaalde driver problemen zijn of XP bugs...
Ik heb zelf een kt133a chip, realtek netwerk kaart, USB modem, SB Live, SB 128PCI, USB scanner, Epson LPT printer, GF2 Videokaart en alles werkt gewoon.
HEt enige is dat ik de laatste tijd haperingen heb om een willekeurige tijd... hapering duurt iets van 5 seconde waarbinnen ik niets meer kan doen, geluid looped en alles locked... daarna kan ik gewoon vrolijk weer verder met alles.
Weet nog steeds niet waar het aan ligt, omdat ik dit pas een week of 3 heb
  • Vinnie
Lees dit uns door:
[topic=269758/1/192]
erg uitgebreid topicje van HlpDsK :)
C:\>_
  • R2D2
  • Registratie: Mei 2001
Of VIA gaar is? -> Nee als je er ff wat moeite aan besteed niet nee maar zodra je vergeet de 4-1 drivers te instaleren dan is het hopeloos.
Ik heb nu ook een PC staan met een SIS 735 chipset en die bevalt me eigenlijk 10* beter. Geen gezeik en gezeur -> gewoon draaien en nog stabiel ook.
Alles werkt gewoon perfect op dat ECS boardje -> video - TV - netwerk kaarten alles doet het probleemloos. Dat kon ik van mijn EX VIA KT266 boardje niet zeggen.
iRacing profiel | Sim-Racer.nl
Joow mensen, ik heb geprobeerd om alle 7 pagina's door te lezen om de oplossing voor mijn probleem te vinden... maar helaas beginnen de 3 bakken koffie uit te werken :D
Ik heb een AMD athlon TB 1,33 GH en een MSI 266KT(nogwat)/VIA chipset systeem + een MSI Geforce Ti 4400 en een soundblaster live 5.1 digital. (Je voelt hem aankomen, eh?)
Het werkt voor geen meter!
In windows XP loopt het goed, maar als je dan een tijd lang een spel draait, reboot hij spontaan }:O
Ik ben voornamelijk een gamer, en ik speel veel UT en UT2k3. Deze speel ik in win98 met als enige reden dat het daar 3x sneller gaat dan in XP.
Als ik langer dan 10 minuten GEEN spel speel in 98 looptie gewoon vast en reageert hij nergens meer op, behalve een fikse ram op de rebootknop.
Maar! Als ik langer dan 20 minuten een spel speel, looptie ook vast, maar gaat het geluid gewoon door! |:(
Ik heb alle drivers supernieuw en het wil gewoon niet! Weet IEMAND hier een oplossing voor :? ? (Naast nieuwe shit kopen natuurlijk :| )
[ Voor 1% gewijzigd door Verwijderd op 08-05-2003 01:05 . Reden: Typo's! ]
  • BalusC
BalusC
Carpe diem
Óf jouw voeding is brak óf je lijdt aan het MSI syndroom (vooral als je dit alleen de laatste tijd ondervindt en de systeem dus all the time before perfect draaide). Zie ook de PMG sticky en FAQ welke je verwijzen naar een uiterst handige B)
Dit graag lezen eer je een topic opent / Technische PMG FAQ
  • Dualdude
  • Laatst online: 18-06 23:18
'k heb momenteel alleen nog maar VIA ChipSets, en ben zeer tevreden. Heb alleen met m'n Turbo2 onder WinXP problemen gehad met SB128. Die had ik onder Win2000 niet. XP is ook een zeikgeval volgens mij :) 'k heb alleen maar MSI gehad. M'n K7T Pro 2 - KT133 doet het nogsteeds prima, nooit wat mee gehad. K7T Turbo (KT-133a) ook nooit probs, zelfde geld voor 6340M KM133a als ik me niet vergis :) 'k heb nu een KT4V - KT400 en draait ook allemaal super :)
  • Metro2002
  • Laatst online: 03-09 16:48
Metro2002
Memento mori
Heb zelf de via KT133a, Kt333 en nu Kt400 en nog met geen 1 van die chipsets problemen gehad (ook niet met sis 735 en 745 overigens)
gewoon chipsetdrivers installeren en je hebt nergens last van :)
Heb een Kt133,kt266a en kt333 chipset gehad en het werkte allemaal perfect.
  • Barazinbar
  • Laatst online: 07-09 07:48
te laat
[ Voor 93% gewijzigd door Barazinbar op 08-05-2003 09:58 ]
Failure is nothing compared to regret
  • K-2SO
  • Laatst online: 26-08 15:47
Ik zou inderdaad eerst eens je voeding checken.
En anders begin je met een kale config zonder PCI kaarten, dus alleen je videokaart. Geeft dat geen problemen, ga dan verder met opbouwen.
Je moet gewoon proberen wat dingen uit te sluiten.
Suc6.
  • Mentalist
  • Laatst online: 02:39
Mentalist
[avdD]
Verwijderd schreef op 03 January 2002 @ 20:05:
Ik ben dus een van de gelukkigen die een KT266a chipset heb gekocht en vraag me af of het wel zo'n genieten keuze is...
Persoonlijk vindt ik de VIA support enorm ZUIGEN en heb ik dus nu al een maand een probleem met m'n TV-kaart.
Laatst las ik ook al op tweakers dat de PCI aansturing van de VIA KT266a superbrak is, en heb laatst ook iemand gesproken die die chipset had + soundblaster live en die ook tijdens het kopieren haperingen in z'n sound hoorde (ikzelfde heb dat dus met m'n TV (lijnen door beeld)).
Hoeveel tweakers met die chipset hebben dit soort problemen nu ook? Persoonlijk ken ik al 4 lui met dit soort gezeik.
En dan af en toe komen die debielen met een VIA 4in1 Driver pack wat geen ene pleuris oplost... Moe wordt je er van, en contacten lukt al helemaal niet... :r
Iemand hier ervaringen mee? Ik ben errug benieuwd!
Ik heb nooit problemen gehad met Via chipsets (wel met de mobo's waar ze opzitten ;)). Maar de chipset zelf, prima dingen.
Ik heb ook een tvkaart, soms moet je nog een patch oid hebben, maar uiteindelijk werkt het toch wel. Zo had ik een Pinnacle PCLE patch (of hoe het ding ook heette :D) nodig, en toen werkte m'n PCTV Rave perfect met m'n Via chipset.
Ik heb hier een Via VPX, Via 693A, 694X en Via KT333. Op die laatste 3 heeft m'n tvkaart allemaal gedraait, zonder problemen, eventueel met patch.
Je tvkaart draait in feite trouwens niet op die KT266A van je, of op mijn 694X. Hij draait namelijk op je southbridge, die verzorgt PCI e.d.
In mijn geval : 686A (bij 693a), 686B (bij 694X) en 8233A (bij KT333). Je kunt niet zeggen dat de pci aansturing van de KT266A superbrak is, hoogstens dat de southbridge op jou mobo zuig is. En zelfs dat niet volgens mij, eventueel een patch erover voor die tvkaart (ook lang niet altijd nodig, bij jou dus wel), en een tvkaart werkt perfect.
En die 4-in-1 drivers werken meestal prima... Soms hebben mensen er problemen mee, al vraag je je dan weer wel af of die mensen alles wel goed installen, ik heb zelf op al die mamaplanken nooit probs met 4-in-1 gehad. Al weet ik zo niet meer hoe de 4-in-1 drivers begin 2002 waren...
Volgens mij was het begin 2002 al WEL bekend dat een SBLive/Audigy + Via southbridge problemen geeft, een tijdje terug verzon Intel wat extra PCI extensies. Deze stonden niet in de PCI standaard, maar veel chipsetbakkers namen de extra PCI extensies wel over. Via niet, goed recht want het staat niet in de pci standaard.
En toen kwam Creative, zo stom om die extra PCI extensies te gebruiken op hun kaarten... En als je chipset die dus niet ondersteund |:(
En vandaag de dag word de SBLive/Audigy nog steeds gecombineerd met Via chipsets, dan werkt het niet en gaan mensen klagen. Waarom, denk ik? Dit is een bekend probleem, eigen schuld. Je kiest er dan eigenlijk zelf voor met patches te gaan knoeien...
En ja, ik weet dat de topicstart al een beetje oud is, maar het probleem is jammer genoeg nog steeds actueel - flinke schop trouwens!.
Verstuurd vanaf mijn Computer®
  • dikiedik
  • Laatst online: 08-04-2025
dikiedik
de verkeers ont regelaar
ik heb nu 2 boordjes met via chipset draaien, geen problemen, de 1 is een a7n266 (via kt266a) en de ander een ep8k9a (via kt400), en idd de 4 in 1 scheelen nooit echt veel, maar als je ook de andere patches erop zet sheelt dat meestal wel weer de helft van je vastlopers. maar brak nee, wel snel, en mischien daardoor niet altijd even stabiel. 0,02
[typo's]
ride on
Niet mee eens dat via gaar is.....
Heb zelf nog alleen maar via gehad namelijk de: kt133, kt266, kt333 en de kt400 op dit moment, en nog nooit problemen gehad!!!!Dus het ligt niet alleen maar de via chipset, ook de ondersteuning van andere hardware heeft er mee te maken....Als die geen goeie ondersteuning geven voor VIA, dan is dat product brak, niet de sjipset!!
I rest my case!
  • Mentalist
Mentalist
[avdD]
dikiedik schreef op 08 mei 2003 @ 18:27:
[typo's]
a7v266 neem ik aan :?
Die n is van nVidia ;)
  • dikiedik
dikiedik
sorrie, je hebt gelijk, is trouwens een AK77-pro met kt266a chipset, die a7n266 heb ik wel gehad, maar die is kapot gegaan :(, heb ik nu die 8K9A daarvoor in de plaats :)
ride on
ik heb ook verschillende via's gehad kt133/kt266/kt333 en i.c.m sb live en audigy nooit probs mee gehad ook een hercules tv kaart erbij was geen probleem
Klinkt gewoon als een zwakke voeding en/of lekke elcos op het moederbord.
  • htol
  • Laatst online: 29-04-2024
Nou mijn MSI K7T266A Pro2-RU + Pinnacle PCTV Remote + Realtek10/100 + SB 5.1 Live +Win XP + Alle drivers geïnstalleerd draait perfect!! Helaas is mijn IBM 120GXP 40GB naar de RMA
Pagina: 1 2 Laatste
