Op Eindhoven transavia, ryanair en wizz.
Vervolgens injecteert hij alle vluchten die er op dat moment in reallife ook horen te vliegen. Dat werkt op basis van een online vluchtdatabase waar (uptodate) meer dan 500.000 vluchten staan over een week tijd. Je krijgt dus echt een vol luchtruim, zoals t in het echt ook is.
De voorlopige marketing specs zijn:
- Full airports! The engine is capable of rendering 100’s of planes making every airport a truly busy and living world. Each airport has correct airplanes and operators spawned based on the schedule of that day.
- Reads the scenery, so traffic is placed on the right gates and uses correct taxiways even on custom (addon) sceneries.
- 3D virtual world. Each airplane flies in a fully simulated environment and is as real as any other virtual pilot flying around.
- Animation engine. Gear will lower and raise in complex animation sequences. They won’t just drop the gear, but the animation will start off slow and end in an ease-put way.
- Intelligent planes - fly their own complex routes, follow SID and STARS fully adhering to their restrictions and respond fully to instructions from ATC or other external factors.
- Self-aware and aware of their environments. For example: they Will hold their speed while taxiing too close to other planes and give way to oncoming traffic while taxiing. They will force a go-around when traffic is blocking the runway.
- API which offers a direct way of communicating with each traffic handled by the engine.
- TCAS aware - planes will correctly appear on TCAS system
- Intelligent airplane generator which dynamically limits around the user in order to save FPS
- Sound: all planes generate FMOD enabled sounds using a custom build soundengine.
- Scheduling: all traffic follows REAL airline schedules and fly actual real-world air routes.
- model matching
- Realistic, up to date flight schedules refreshed periodically
- Ultrarealistic flightmodel ‘Real-time 6-DoF-lite kinematics’. Still cpu friendly
- Static aircraft are placed using realworld modeling on operators - if an airport has a number of top airlines operatinf there - you will see them parked
- Light on performance with proper multithreading and efficient plane spawning algoritms.
- User interface including a Departure board for the current airport, a overview of nearby flights and current runway usage for airports - all including the option to follow the planes by camera.
Ik ben nog aan alle kanten aan het schaven, uitbreiden en veranderen dus bovenstaande is niet volledig. Maar het geeft een idee!
Specs: 9800X3D, RTX 5090, 64GB, VR: Pimax Crystal-Light
Vraagje wat bij mij opkomt, zou ik een vlucht plannen van zeg EHGG naar EHAM, op een druk moment, kon ik er dan nog wel tussen? Ik vlieg dat soort dingen dus altijd bewust zonder traffic, maar het is ook wel eens leuk om een holding te vliegen (gebeurt me dus nooit)
Ik heb er een paar oplossingen voor geïmplementeerd. De toestellen houden rekening met jouw positie als speler en houden in of gaan wat sneller vliegen op final. Is niet de uiteindelijke oplossing maar het werkt best aardig al ik het test..
Andere oplossing is dat er een keybind is in te stellen die het verkeer in een ‘cone’ voor jouw toestel verwijderd. Beetje als last resort maatregel eigenlijk, want het is leuker om een toestel 5nm voor je te zien landen voor jij zelf aan de beurt bent natuurlijk.
Ik ben daarnaast met Sayintentions in gesprek om te integreren met de ATC die zij bieden. Maar weet nog niet helemaal wat daar uit gaat komen..
Mocht er trouwens iemand goed zijn in het maken van mooie ingame promoshots dan houd ik me ook aanbevolen!
Maar ik gebruik al een traffic plugin namelijk World Traffic (sinds X-Plane 10), wat is er anders dan de plugin wat jij nu voorstelt?
Ik zie een paar ding misschien.
- Multi threaded
- Ultra realistic flight models
https://valid.x86.fr/xhfd5e
FSLTL injector Niet gebruiken laat als je Beyond ATC heb .. laat hem dat regelen...Wilde schreef op zaterdag 10 januari 2026 @ 09:14:
Je hebt een goed punt en dat is een beetje een nadeel van verkeer injecteren. Vind ik zelf bv ook een nadeel van bv de FSLTL injector voor msfs..
Punt 1 je heb geen vreemd en dubbel verkeer , en twee Beyond ATC regel zelf wel het verkeer in de omgeving ..
bij Heatrow .. druk .. Bij Inssbrock ... rustig
Bij Dubai en Hongkong gekkenhuis.
Systeem:AMD Ryzen 7 9800X3D ,RTX 5080 OC,FURY 64 GB DDR5-6000,ASUS TUF Gaming B850M-PLUS WIFI, SAMSUNG 990 EVO Plus 4 TB
Ach ik vind het gewoon leuk om te bouwen en ik heb het idee dat WorldTraffic wat gedateerd begint te raken. Ik heb uptodate vliegschema’s en hoop met de tijd gewoon veel leuke nieuwe dingen te maken. Ook catering en gebeuren om het toestel heen aan de gate en wie weet ook nog een ATC component. Ik ben echter alleen dus het gaat niet heel snel allemaal (ben nu een half jaar bezig).Badtothebone schreef op zaterdag 10 januari 2026 @ 10:59:
Speel nog X-Plane regelmatig. Met map enhancement en xasnow plugin is het een prima sim.
- Multi threaded
Daarnaast zit er een copyright op de CSL models dus ik ga ook alle models repainten. Tis maar wat je leuk vind he
Voordeel is dat ik zelf ook veel vlieg in Xplane dus ik kan er zelf ook wel van genieten. En als een plane dan iets mafs doet gelijk ff in de code duiken
Dit lijkt een interessant project. De extra vluchten die X-Plane (V11) genereert bewegen op zijn zachts gezegd nogal doelloos en willekeurig.Wilde schreef op vrijdag 9 januari 2026 @ 21:43:
Topic lijkt even stil te liggen - ik ben toch niet de enige fanatieke X-planer hier hoop ik?
Ik ben inmiddels een half jaar aan het werk aan een nieuwe AI Traffic plugin voor XP. In feite Global traffic, maar dan anno 2026.. Het project nadert zo langzamerhand een eerste beta fase, mochten er hier personen zijn die het leuk vinden te testen en mee te denken: graag een PB !
Maar, ik vlieg op dit moment alleen maar GA. Is jouw plugin in die situatie ook interessant?
GA komt er inderdaad in. Maar dit zal logischerwijs niet volgens schema’s gaan, want die info heb ik nietJeppieW schreef op maandag 12 januari 2026 @ 13:55:
https://www.dropbox.com/s...b321dj86&st=1lsfcfpu&dl=0
Drop de inhoud in je Resources/Plugins folder.
Wees wel bereid een crash tegen te komen hier en daar! Mocht dat gebeuren, dan waarder ik het als je de log.txt naar me DM'd
Ga hem in de week eens beter testen, wat ik wel kan meegeven.Wilde schreef op zaterdag 7 februari 2026 @ 12:13:
Diegene die het leuk vind Alpha-tester te zijn kan de laatste daily build vinden op:
Stond op Brussel en zag een vlieger van Porto > Brussel.
Hij zit op moment van schrijven nog in Frankrijk, zag hem wel vliegen in Brussel.
Voor de rest was alles goed zichtbaar, deze week eens wat meer tijd proberen te investeren.
Dank alvast voor de alpha build te delen.
Leuk, laat vooral weten mocht je nog ideen hebben !KBE91 schreef op zaterdag 7 februari 2026 @ 19:53:
Het model werkt bij deze plugin anders dan het eenvoudigweg injecteren van (realtime) vluchten in de sim. Het nadeel daarvan is dat de vluchten dan erg statisch zijn. Ze kunnen alleen maar op de vaste plek vliegen, daar waar ze in het echt ook vliegen en houden nergens rekening mee, ook niet met jou als vlieger. Deze plugin kijkt waar een toestel zou moeten vliegen, injecteert hem maar vanaf dan neemt de sim(of de plugin) het toestel over. Dat maakt traffic sequencing mogelijk (zit er nog niet volledig in) en heeft meer voordelen. Het maakt het wel dat in de sim het toestel net ergens anders kan vliegen dan in RL
Even off-topic: de belichting en de wolken zijn overigens adembenemend! Een enorm verschil met de apocalyptische aswolken van MSFS2024.
Win11 Pro 64, 64 GB Asus Z690 Prime, i7-12700K, Watercooling, RTX4090, Valve Index, HP Reverb G2, Oculus Quest 3
Ben laatst weer eens naar het FS Weekend geweest in het Aviodrome en werd toch wel weer aangestoken met het sim-virus, maar een aparte pc ervoor aanschaffen vind ik (nog
Ben de grafische instellingen nog wel wat aan het bijschaven, op mijn Macbook is 5K is net wat teveel van het goede voor 20+ FPS, maar met de resolutie omlaag (naar 1440p) haal ik nu bijna overal wel zo'n 25-30 FPS. Ik moet nog nagaan in hoeverre de performance achteruit gaat met gebruik van plug-ins. Ik haal de meeste voldoening uit zo precies mogelijk procedures volgen, eye-candy is mooi meegenomen maar voor mij niet doorslaggevend. Moet dus nog even kijken welke plug-ins ik echt nodig ga hebben. Heb tot nu toe alleen X-Camera en BetterPushback geïnstalleerd.
Heb er inmiddels een paar vluchten op zitten met de default A330-300, die verbazingwekkend compleet is. Dat was 'vroeger' wel anders met de default vliegtuigen! Ook al aardig bedreven geraakt in het gebruik van Simbrief en Navigraph. Nieuwe tools voor me, wat een vooruitgang i.p.v. klooien met Jeppview dvd-images met gekraakte keys en internet afstruinen voor flightplans.
Ben ook al voorzichtig naar de ToLiss Airbussen aan het kijken, hoe vaak zijn die in de aanbieding? Ik overweeg de A321(met neo update) vanwege de veelzijdigheid qua mogelijk routes (en omdat KLM en Transavia aan het omschakelen zijn naar de A32x-familie).
En ik heb ook dringend wat hardware nodig, heb nu alleen een oude Logitech Force 3D joystick die wel aan vervanging toe is. Dat WinCtrl-spul is erg verleidelijk.
Vermaak me trouwens ook prima met het bingen van wat Youtubers (o.a. A330 Driver, Q8Pilot).
If our brain was easy to understand, we would be too dumb to understand.
Als het voldoende vloeiend is, is het voor mij goed genoeg, maar waarschijnlijk ook omdat ik ook vooral procedures en navigatie leuk vind.
Voordeel op de game pc is dat je verder vooruit scherp ziet, maar dat doe ik ook maar op 1440 (breedbeeld)
Veel plezier!
Ook al aardig bedreven geraakt in het gebruik van Simbrief en Navigraph. Nieuwe tools voor me, wat een vooruitgang i.p.v. klooien met Jeppview dvd-images met gekraakte keys en internet afstruinen voor flightplans.Tourniquet schreef op donderdag 9 april 2026 @ 16:53:
Heb tot een jaar of 15 geleden veel in MSFS gevlogen (van FS 4.0 t/m FSX), maar daarna overgestapt op een Apple iMac en daardoor het simmen wat laten zitten. Heb van een oudere versie van X-Plane wel eens de demo geprobeerd maar dat werkte toen niet best.
Ben laatst weer eens naar het FS Weekend geweest in het Aviodrome en werd toch wel weer aangestoken met het sim-virus, maar een aparte pc ervoor aanschaffen vind ik (nog) een stap te ver. Heb nu (na even de demo geprobeerd te hebben) X-Plane 12 gekocht en geïnstalleerd op mijn Macbook Pro (M3) met Studio Display en dat draait wonderwel best goed! Ga dit topic dus in de gaten houden.
Heb er inmiddels een paar vluchten op zitten met de default A330-300, die verbazingwekkend compleet is. Dat was 'vroeger' wel anders met de default vliegtuigen! Ook al aardig bedreven geraakt in het gebruik van Simbrief en Navigraph. Nieuwe tools voor me, wat een vooruitgang i.p.v. klooien met Jeppview dvd-images met gekraakte keys en internet afstruinen voor flightplans.![]()
LOL dat doet me weer denken aan FS2000 tot FSX .. wat een gezoek was dat ..
Nu is dat veel makkelijker allemaal EFB is echt een wereld uitvinding.
En die WinCTRL :-)
Ach wat moet ik er overzeggen...
:strip_exif()/f/image/bdv0YHO6RLgRhYmkIkAA6Mk8.jpg?f=fotoalbum_large)
Vind het zelf goed werken.
Maar met die FPS ik heb hem hier altijd op lock staan op 60FPS.
Zo lang je niet onder de 30 komt is het gewoon goed.
https://simheaven.com/package/x-world-pro-test/
The test area are 15 tiles in Europe, covering the Ruhr area in Germany, Luxembourg and parts of The Netherlands, Belgium and France (from +49+004 to +052+009).
In the download you can get:
simHeaven_X-WORLD-Pro_TEST.7z (1.9 GiB, the scenery having 13 layers now, 15 tiles)
simHeaven_X-WORLD-Pro_Library.7z (330 MB, for vegetation and all used XP12 assets, run the batch for WIN, Linux or Mac)
zOrtho-XP12_+49+008.7z (8.8 GiB, ZL17 and ZL19, optional for those want to test orthos)
zOrtho-XP12_+50+007.7z (9.1 GiB, ZL17 and ZL19, optional)
Frankfurt
Mannheim
Gaat een betaalde addon worden, maar de prijs weten we nog niet.
Heb deze methode gebruikt:
YouTube: A320 Traffic Pattern Setup (Circuits) | Step by Step (Made Easy)
YouTube: A320 Traffic Pattern (Downwind - Base - Final) | Fly It Properly
YouTube: A321 Visual Circuit & Touch and Go Tutorial with Real Airbus Pilot! X Plane 11 ToLiss A321
Onderweg naar Châteauroux mooi uitzicht op Parijs:
/f/image/MM4HGTTpj5N1WPvnIwDRK2cR.png?f=fotoalbum_large)
Circuits gingen niet slecht:
/f/image/Ykdvd0U4EpK6aSdulmoChQGV.png?f=fotoalbum_large)
/f/image/GMeIcVNzhEiLZTJBhrskIfyx.png?f=fotoalbum_large)
/f/image/CD6wxDZkHT7Bg5OMhmYTj0tk.png?f=fotoalbum_large)
Binnenkort dit nog eens oefenen met wat meer wind, maar ik heb nog geen rudder.
Tijdens taxi zijn pedalen wel veel fijner om de remmen te vedienen, maar het roer werkt prima op de airbus stick van thrustmaster.
Ik heb een (inmiddels denk ik bijna 20 jaar oude) Logitech Force 3D Pro, die ook een twist-optie heeft. Het werkt wel, maar ik merk dat ik regelmatig toch iets meer over de baan zwalk dan ik zou willen, ik hoop dat dat met pedalen wat beter gaat.franssie schreef op maandag 8 juni 2026 @ 22:46:
@Tourniquet ik heb pedalen, maar soms vlieg ik ook met de stick die een twist optie heeft, dat werkt best aardig goed om de peadelen te vedienen bij het landen.
Op den duur wil ik denk ik wel wat hardware gaan aanschaffen.
Met Pedals gaat het zeker beter.Tourniquet schreef op donderdag 11 juni 2026 @ 14:46:
Maar neem wel een beetje goede , ik had eerste die van logitech maar dat maakt herrie en zwabbert nog, nu een van Turtlebeach werkt perfect.
https://eu.turtlebeach.com/products/velocity-one-rudder
Zo wel te maken als GA en als Airline pedals .
Oja en als je er een bezit Ook voor XBox te gebruiken.
En werkt uit de doos. geen drivers nodig
[ Voor 6% gewijzigd door ravw op 11-06-2026 15:19 ]
Algemeen FS topic: Flight Simulator - Deel 85
MSFS topic: [PC/XBox] Microsoft Flight Simulator (2020)
