Alles went behalve een Twent.
nggyu nglyd
Bij judo delen ze dan maar straffen uit om een winnaar te bepalen
26.8.4
If it concerns the first place, a jump-off between these athletes shall be conducted in accordance with Rule 26.9 of the Technical Rules, unless otherwise decided, either in advance according to the regulations applying to the competition, or during the competition but before the start of the event by the Technical Delegate(s) or the Referee if no Technical Delegate has been appointed. If no jump-off is carried out, including where the relevant athletes at any stage decide not to jump further, the tie for first place shall remain.
There are a number of ways in which a jump-off may be terminated:Whilst any decision by the Technical Delegate or Referee not to conduct a jump-off should be made before the start of the event, there may be circumstances where this might not be possible such as where conditions at the place of competition make it impossible or undesirable to begin or continue with a jump-off. The Referee could use their powers under Rule 18 of the Competition Rules or Rule 25 of the Technical Rules to deal with this situation. It is emphasised that the athletes may make the decision not to jump further either before or at any stage during the jump-off.
- a. by provision in advance of the competition set out in the regulations;
- b. by decision during the competition by the Technical Delegate (or Referee if there is no Technical Delegate);
- c. by decision of the athletes not to jump further prior to or at any stage of the jump-off.
[ Voor 101% gewijzigd door apis29 op 01-08-2021 20:38 ]
Ook bij judo, Daar is het normaal dat 2 bronzen plakken worden uitgereikt. Waarom snap ik eigenlijk niet. Bij boksen gebeurt het ook, maar daar snap ik het beter. Als je gehavend uit de halve finales bent gekomen, kun je wellicht niet meer om het brons strijden (of met gevaar voor je eigen gezondheid). Dat kan natuurlijk ook gelden als je een halve finale wint, maar de kans daarop is natuurlijk wel kleiner.
Elke sport heeft zijn eigen regels qua medailles. Ben je wel olympisch kampioen als je dit met z’n tweeën bent? Ik vind van wel. Het enige wat ik wel vreemd vind is dat dit een keuze van de sporters zelf was.
Verder is het verhaal van deze mannen natuurlijk ook speciaal. Het zijn echt goede vrienden en Barshim is eigenlijk de enige reden dat Tamberi nu in Tokyo staat. Hij heeft hem echt uit de put gehaald na die zware enkelblessure.
Bij judo heb je ook 2x brons omdat ze niet nog een keer een losermatch doen.Quad schreef op zondag 1 augustus 2021 @ 20:10:
Ik snap wel wat @Ankona zegt. Anders kan je bij Judo wel stoppen met golden score, met voetbal stoppen met verlengen enz.
En voor degenen die denken: dat gebeurd nooit, dit is puur hypothetisch: het is al eens gebeurd. Op de Amerikaanse trials (de Amerikaanse selectiewedstrijden voor de WK en OS) liepen de nummer 3 en 4 exact dezelfde tijd: er was op meerdere finishfoto's geen verschil te zien. En dan heb je een probleem want de nummer 3 gaat wel door, de nummer 4 blijft thuis. Wie kies je?apis29 schreef op zondag 1 augustus 2021 @ 20:15:
Na een 100 meter met gelijke finish wordt met toch ook niet gevraagd even opnieuw een sprintje te trekken om een winnaar te bepalen ...
Zo ook in dit geval: ze zijn simpelweg gelijk als nummer 1 geëindigd. Waarom dan opnieuw springen omdat je maar 1 nummer 1 wilt hebben? Dat doet toch juist afbreuk aan de originele prestatie waarbij ze allebei hetzelfde hebben gepresteerd?
Het was wel een vrij uniek in iets zoals het hoogspringen dat het EXACT gelijk is (meestal heeft iemand op een lagere afstand wel een misser extra, wat de doorslag geeft).
Ik vind de afloop in dit geval wel heel mooi.
Wat maakt het uit dat iemand van nationaliteit wisselt. Dat gebeurt nu eenmaal lijkt me gewoon het onnodig moeilijk maken voor sommige vluchtelingen/migranten .zacht schreef op zondag 1 augustus 2021 @ 15:17:
Hij is geboren in de VS, Italiaanse moeder. Ik snap de vraag overigens wel, denk ik. Persoonlijk krijg ik kromme tenen van de wildgroei van het wisselen van nationaliteiten van sporters.
[ Voor 20% gewijzigd door k995 op 01-08-2021 23:19 ]
Dus bij het dames voetbal mogen ze er in de finale ook voor kiezen om geen penalty's te nemen bij gelijke stand na verlenging? Want dat is vergelijkbaar met wat hier nu gebeurde en daarom begrijp ik @Ankona volledig.autje schreef op zondag 1 augustus 2021 @ 19:43:
Het is nu eenmaal de regel dat ze hiervoor kunnen kiezen. Prachtig dat ze het ook doen.
Ben je er ook voor om atleten te straffen met 2x zilver als ze niet verder willen met de strijd? Want dat kleinzielige en rancuneuze is een onderdeel van Ankona's probleem. Laat je ze doorspringen tot er eentje geblesseerd is en moet opgeven, of struikelt of zo?toolkist schreef op zondag 1 augustus 2021 @ 23:24:
[ Voor 8% gewijzigd door gambieter op 01-08-2021 23:30 ]
Hier is niks sportiefs aan want ze ondervinden geen van beiden nadeel van hun beslissing.Bensimpel|IA schreef op zondag 1 augustus 2021 @ 19:53:
Niet mee eens, beide heren hebben het maximale gedaan wat ze konden. Het zou dan eerder aan het geluk hangen wie er dan goud wint. Dus juist erg sportief van ze! Tevens hebben ze allebei een blessure gehad en konden ze zelfs bijna niet meedoen aan de spelen. Ik vind dit echt geweldig sportief. Zo kan het ook
Het was pas sportief geweest als bv die Italiaan had gezegd ' je hebt me zoveel geholpen na Rio, pak jij goud maar dan pak ik zilver'
Zilver? Geen medaille als ze allebei de wedstrijd niet af willen maken.gambieter schreef op zondag 1 augustus 2021 @ 23:28:
Gefeliciteerd, je bent geslaagd voor het bobo-examen. Speciaal gereserveerd voor hen die maximaal sport willen verstoren en vernietigen vanuit de luie stoel.toolkist schreef op zondag 1 augustus 2021 @ 23:30:
Zilver? Geen medaille als je de wedstrijd niet af wil maken.
Jij en anderen blijven de fout maken dit te vergelijken met sport waar twee ploegen direct interactie met elkaar hebben en de prestatie daarvan afhankelijk is. Hoogspringen is een individuele sport waar de prestaties van de ene sporter die van de ander niet direct beinvloeden (ze schoppen niet tegen dezelfde bal). Net als de sprint, zwemmen etc waar ze in hun eigen baan blijven en de ander niet direct beinvloeden.toolkist schreef op zondag 1 augustus 2021 @ 23:34:
Ok volgens jou voortaan dus prima dat er 2 CL winnaars zijn omdat ze besluiten geen penalty's te nemen? Waarom überhaupt eigenlijk nog spelen die finale?
Dus doe je best, en kom met een vergelijking die wel zinvol is. Of geniet van sport en niet van bloedvergieten. Want een jump-off van sporters die al de hele dag bezig zijn gaat beslist worden door prestaties die niet gebaseerd zijn op wie het beste springt, maar wie mazzel heeft en niet geblesseerd raakt, of struikelt etc.
[ Voor 11% gewijzigd door gambieter op 01-08-2021 23:39 ]
Ze zeggen wel eens dat je nooit te oud bent om te leren, blijkbaar wil je het tegendeel bewijzen. Ciao, ik zal je verder negeren.toolkist schreef op zondag 1 augustus 2021 @ 23:42:
Onzin, je kunt dit gewoon vergelijken met een gelijk spel. En bloedvergieten nogwel....
https://en.wikipedia.org/...pics_–_Women%27s_downhill
De atleet uit Qatar vroeg het, de official gaf het niet zelf als optie; maar op de directe vraag gaf de official aan dat het kon als ze het beiden wilden. En creerden zo wat voor veel mensen tot nu toe het mooiste moment is van deze Olympische Spelen.evleerdam schreef op maandag 2 augustus 2021 @ 00:02:
Ik vind het opzich niet gek om beide sporters een gouden medaille te geven. Maar ik vind het wel vreemd dat ze een keuze hadden. Ik kan het moment niet op YouTube vinden, maar toen een official de keuze voorlegde, leken ze zelf ook verbaasd dat ze konden kiezen.
Gezien ze beiden voor deze optie gekozen hebben en hun reactie daarna lijken ze dit zelf verre van een devaluatie van de gouden medaille te vinden.toolkist schreef op zondag 1 augustus 2021 @ 23:45:
Dit blijft gewoon een devaluatie van een goude medaille.
Vond het zelf ook wel erg mooi. Maar niet iedereen blijkbaar.
Die official leek het te suggereren, maar inderdaad gaf hij het niet direct zelf aan.gambieter schreef op maandag 2 augustus 2021 @ 00:07:
Mee eens dat het een mooi moment was. Dat ze beide een gouden medaille kregen maakte het alleen maar mooier (dus tegenovergestelde van devalueren
Is deze al voorbij gekomenPinobigbird schreef op zaterdag 24 juli 2021 @ 11:09:
En wéér een positieve uitslag op dezelfde vlucht:
[Twitter]
Gelukkig geen sporter, maar een verslaggever.
[Instagram: ⠀⠀⠀⠀⠀⠀⠀⠀⠀ Yesterday this video story was posted by Jeroen Elshoff (@jeroen.elshoff), the Olympic commentator for Dutch Public broadcaster @nossport. In the video we can hear him ‘trying to replicate how the Japanese commentary sounds in his ears’, according to himself as a reply after some Twitter users called him out for ridiculing a foreign language and complaining about foreign food and hospitality (see second slide). ⠀⠀⠀⠀⠀⠀⠀⠀⠀ The Dutch TV Sports commentator is currently in a mandatory hotel quarantine in Japan for the Olympics, and also posted a series highlight on his Instagram called ‘Quarantaine Hel’, complaining about his stay and the quarantine protocol set by the Japanese government (see last two videos).]
Struikelt? Er botsten twee voor haar op elkaar, een ging onderuit en daar ging Hassan over naar de grond. Ze kon hier niets aan doen, knap teruggevochten.pinda powerrr schreef op maandag 2 augustus 2021 @ 02:57:
Sifan Hassan struikelt, ligt op de grond en wint alsnog met ogenschijnlijk gemak de heat. Bizar dit!
[ Voor 6% gewijzigd door gambieter op 02-08-2021 02:59 ]
Gewoon bizar goed en even dominantie laten zien.
Ik neem aan dat ze weet wat ze doet. We zullen zien wat dit voor haar betekend. Als het inderdaad zo is dat ze de finale niet met een respectabele tijd uitloopt ja dan was dit stom. Aan de andere kant, blijkbaar zit het winnen er zo in dat zelfs een valpartij haar niet van dat winnen af kan brengenautje schreef op maandag 2 augustus 2021 @ 06:30:
Kost wel veel energie die ze voor de 5000m finale had kunne gebruiken vanmiddag...
Zuinige Schippers houdt net genoeg over voor halve finale 200 meter - https://nos.nl/l/2392083
Schippers mag al blij zijn als ze de finale haalt.Exocet schreef op maandag 2 augustus 2021 @ 06:47:
Schippers was verre van overtuigend, daar verwacht ik geen medaille van.
Jammer, ik denk dat zij meer uit haar carrière had kunnen halen, maar rugblessures en de keuze om met Rana Reider te werken hebben haar tegengewerkt.
nggyu nglyd
De baansprinters zijn toch wel de echte gewichtheffers onder de wielrenners
Als je ook die lichamen zit van de heren, absurde spierbonken.
PS4 PSN: Dazzler2120
https://www.velodrome.sho...ck-cycling-starting-gate/Quad schreef op maandag 2 augustus 2021 @ 08:45:
Wat is dat voor apparaat waar ze de fietsen in zetten bij de start van het baanwielrennen?
Schippers net zien lopen; of ze loopt nog met de rem erop of ze kan niet beter helaas.
nggyu nglyd
11:06 ROC-NL voor 3e plaatsQuad schreef op maandag 2 augustus 2021 @ 10:01:
Snelle baan in Izu, nieuw WR. Nederland met nieuw NR. Ze gaan mogelijk strijden om het brons.
Dat wordt er weer eentje… verschil met de Russinnen was maar 11 duizendsten.. hopelijk val het kwartje deze keer de goede (bronzen) kant op.Quad schreef op maandag 2 augustus 2021 @ 10:01:
nggyu nglyd
En als ze de finale haalt is dat niet voor de medailles, terwijl een aantal concurrenten al niet mee (mogen) doen.autje schreef op maandag 2 augustus 2021 @ 06:51:
Achteraf lastig te zeggen of er meer in haar carrière had gezeten… ze heeft eerst meerkamp gedaan op wereldtop niveau en dat vergt enorm veel van je lichaam. In de eerste jaren nadat ze de keus voor het sprinten heeft gemaakt was ze waarschijnlijk op haar top. Daarna begonnen ook de fysieke klachten (b.v. lies bij vorige OS).
Sifan Hassan blijft soms een beetje eigenzinnige atleet met bepaalde keuzemomenten die eveneens eigenzinnig en of dubieus kunnen zijn. Ik hoop dat ze het kunstje in Doha kan herhalen al heb ik wel wat twijfels of het de juiste keuze is om 3 zware nummers te lopen. Afwachten maar. Qua positionering zat ze overigens niet al te best - ze liet een gaatje vallen - waardoor ze uiteindelijk naar de groep moest lopen.gambieter schreef op maandag 2 augustus 2021 @ 02:59:
Ik ben daarnaast ook wel benieuwd hoe Krumins de 10000m zal gaan lopen, haar voorbereiding ging niet helemaal van een leien dakje vanwege haar (oude) blessure die opnieuw op speelde maar mentaal is ze wel erg sterk.
Het is helaas niet anders, ik vond het al bijzonder dat ze überhaupt Tokyo haalde gezien haar situatie met d'r rug. Het blijft een zwakke plek bij haar. De podcast van De Pacer met haar is wel een aanrader om te beluisteren.Willem30 schreef op maandag 2 augustus 2021 @ 09:27:
[ Voor 4% gewijzigd door vhal op 02-08-2021 10:39 ]
Ik heb wel het idee dat ze eerst vooral op souplesse liep, maar door Reider meer het krachthonk ingegaan is om explosiever te zijn bij de start. Dat zal ook een zwaardere belasting op het lichaam zijn geweest. En al die spieren hebben haar niet echt geholpen.PatrickC schreef op maandag 2 augustus 2021 @ 10:24:
Een beetje hetzelfde zoals met onze Belgische Kim Gevaert. Beide zijn van nature uit flyers en 200m lopers waarvan hun coach/de atleet zelf een 100m loper wil maken die gebaseerd is op de traditionele Amerikaanse school = krachtlopers.autje schreef op maandag 2 augustus 2021 @ 10:28:
Vergelijking met andere sporten is wel degelijk relevant. Dan zie je dat waar mogelijk geen genoegen genomen wordt met een gelijkspel als doorstrijden voor een overwinning maar enigszins mogelijk is. Dat is het punt, niet of sporten zelf andere spelregels hebben.Horla schreef op maandag 2 augustus 2021 @ 10:26:
Waarom willen mensen zoals @toolkist persé vergelijkingen maken met andere sporten? Ik zeg toch ook niet dat het belachelijk is dat in het voetbal alleen een keeper de bal met de handen mag spelen terwijl in het rugby iedereen dit mag? Het is een freaking andere sport met andere regels. Is toch helemaal niet moeilijk te begrijpen? De vijf ringen symboliseren ook passie, vertrouwen, overwinning, ethiek en sportiviteit. Ik kan mij niet meer passie en sportiviteit voorstellen als dit.
En wat betreft je laatste punt. Het is een topsport evenement, winnen van de OS is voor veel sporters het hoogst haalbare en winnen gaat om het verslaan van je tegenstanders. Het is geen pupillen toernooitje waarin iedereen lekker bezig moet zijn en niemand mag verliezen.
alles kan off-topic
Heel simpel. 1 OS, 1 soort gouden medaille voor de beste sporter/teamprestatie. Niet bij de ene sport voor de beste 3 sporters en bij de andere niet.Horla schreef op maandag 2 augustus 2021 @ 10:26:
En als jij het verschil niet kunt zien tussen eenduidige regels mbt het winnen van een medaille of een spelregel, dan tja....
nggyu nglyd
Ik heb nu inderdaad al 3x dezelfde beelden gezienQuad schreef op maandag 2 augustus 2021 @ 10:45:
Op BBC meer baanwielrennen, op Eurosport voetbal have finale dames. Voor als je geen zin hebt in de herhalingen bij de NOS.
Ff zappen dus.
[ Voor 7% gewijzigd door Vos op 02-08-2021 10:47 ]
#36
De baan fixen ze ff met..... Duct tape.
nggyu nglyd
Ik zou hier eens de lange lijst van olympische gelijkspellen voor goud bekijken, en de daarbij behorende beslissingen: Wikipedia: List of ties for medals at the Olympics
Het gebeurt in meerdere sporten waarbij sporters niet in direct duel aan elkaar spelen. Tuurlijk mogen vergelijken gemaakt worden, vergelijk echter wel het zelfde type sporten. (Je zou zelfs zwemmen met het hoogspringen kunnen vergelijken, Historisch bekeken zijn daar o.b.v. dezelfde tijden ook vaker dubbel goud uitgedeeld.)
Voor dit soort sporten is hiervoor gekozen. Voor teamsporten zoals voetbal, hockey zijn voor bepaalde tiebreakers gekozen. Mag je uiteraard van vinden wat je wilt, maar sobeit.
Ja bizar ongeluk ook trouwens, z'n handlebars gewoon ineens afgebroken! Zag er niet lekker uit!Quad schreef op maandag 2 augustus 2021 @ 10:51:
Flinke crash bij Australië op de baan.
Ik zag ze gisteren een F1 auto fixen met duct tape. Magisch spul.Quad schreef op maandag 2 augustus 2021 @ 10:51:
Dat laatste is eigenlijk wat het meeste steekt in deze discussie, het lijkt wel of je er niet iets van mag vinden. (En ik vind er dus duidelijk wel iets van)Dazzler2120 schreef op maandag 2 augustus 2021 @ 10:51:
alles kan off-topic
Dat heeft denk ik vooral te maken met de manier waarop je je mening verkondigt.Ankona schreef op maandag 2 augustus 2021 @ 10:59:
Je stelt hier twee topatleten eigenlijk voor als losers die niet willen strijden tot op het gaatje. Daar ga ik altijd tegen in gaan.
Heftig, ook haar partner en kind die het land moeten ontvluchten. Maar waarvoor eigenlijk is mij niet duidelijk.Pierre schreef op maandag 2 augustus 2021 @ 11:05:
Wat een bizar verhaal trouwens dit https://nos.nl/tokyo2020/...binnen-voor-asielaanvraag
nggyu nglyd
Dit doet me denken aan de jaren 70 met de koude oorlog, toen gebeurde dat zeker vaker.Webgnome schreef op maandag 2 augustus 2021 @ 11:06:
@Pierre dat is nog zacht uitgedrukt. Als het klopt dat de atlete moet vrezen voor haar leven omdat ze geen medaille heeft gewonnen, of gewoon tegen het 'management' in gaat dan vraag ik mij ten strengste af wat een land als Belarus eigenlijk op die spelen doen? De eerder aangehaalde kernwaarden van de OS zijn bij dat land toch dan ver te zoeken?
Jammer! Zou wel een unieke prestatie zijn (plak op de winter & zomerspelen)
Ze heeft nog een kans op de keirin.Dazzler2120 schreef op maandag 2 augustus 2021 @ 11:11:
Langzamere tijd ook dan de halve finale.
China pakt gouden plak nr 28.
nggyu nglyd
Is ze ook daadwerkelijk een kanshebber voor een medaille? Of een outsider?Quad schreef op maandag 2 augustus 2021 @ 11:13:
Dat weet ik niet.Dazzler2120 schreef op maandag 2 augustus 2021 @ 11:14:
Laten we het hopen.
nggyu nglyd
Zijn wel degelijk kanshebsters
[ Voor 3% gewijzigd door Dazzler2120 op 02-08-2021 11:19 ]
Het Olympische motto is sneller, hoger, sterker. Als er nu twee spelers even hoog komen in evenveel pogingen dan zijn ze gewoon even goed. Kan gebeuren bij sporten waarbij een objectieve maatstaaf de winnaar bepaalt (tijd, hoogte, gewicht) Dat is anders dan met teamsporten en sporten waarbij je direct tegen een tegenstander duelleert om de punten.Ankona schreef op maandag 2 augustus 2021 @ 10:43:
Helaas…PatrickC schreef op maandag 2 augustus 2021 @ 10:17:
Schippers 200m, 1e heat om 12:25 in baan 2, halve finale
Bol: 400mH, 3e heat,13:55, baan 5, halve finale
Hassan 5000m, finale, 14:40
Het wordt een lange lunch
Vergeet ook Bonevacia en Dobber niet om 13:05.jan390 schreef op maandag 2 augustus 2021 @ 12:14:
KarmaExocet schreef op maandag 2 augustus 2021 @ 12:12:
Amerikaanse voetbalsters uitgeschakeld tegen Canada
Staat klaar op de baan.
Weer baan 2, was ze zelf vanochtend niet blij mee.
[ Voor 32% gewijzigd door Quad op 02-08-2021 12:25 ]
nggyu nglyd
[ Voor 9% gewijzigd door Pierre op 02-08-2021 12:27 ]
Kansloos helaasQuad schreef op maandag 2 augustus 2021 @ 12:24:
We gaan het zien wat Schippers kan.
Vooral te weinig training gehad. De kansen vooraf waren natuurlijk al heel klein hierdoor.autje schreef op maandag 2 augustus 2021 @ 12:27:
Kon geen push geven op de laatste 100 meter. Toch te veel last van de fysieke problemen, denk ik.
Hopelijk kan ze nog iets op de estafette.
Ze kan juist niet alles doen. Als (top)sporter kampen met zoveel fysieke ongemakken is erg frustrerend.PatrickC schreef op maandag 2 augustus 2021 @ 12:28:
Het lijkt me zo frustrerend voor een topsporter als je zo ver van je beste tijden af zit, terwijl je er wel alles aan doet.
#36
Laat dat nou net niet het geval zijn op de Olympische Spelentoolkist schreef op maandag 2 augustus 2021 @ 10:45:
In het kader van blink and you'll miss it: Schippers dus zo te lezen uitgeschakeld
[ Voor 14% gewijzigd door apis29 op 02-08-2021 13:23 ]
Als je zo geblesseerd aan je rug bent, had er eigenlijk van bovenaf ingegrepen moeten worden. Je kan ook niet met een gebroken been de 100 meter winnen.
Voor haar rugproblemen kwam ze ook niet meer aan haar tijden, maar inderdaad… had ze volop kunnen trainen, dan had ze wellicht nog de finale kunnen halen.Vos schreef op maandag 2 augustus 2021 @ 12:30:
Dat is een verlies van 1.5 seconden - dat is in atletiek termen ongeveer 10 lichtjaar. Wel echt heel heel erg zonde dat ze een verkeerde afslag genomen heeft in haar carrière, waardoor ze jaar op jaar alleen maar langzamer is gaan lopen.
Ik deel het vermoeden van anderen dat haar keuze om met Rana Ryder te gaan werken achteraf het vroegtijdig einde van haar carrière heeft betekent op hoog niveau. Het idee van die keuze was om aan haar start te werken, aangezien dat in 2015-16 haar zwakke punt was. Haar start werd beter, maar ging significant ten koste van haar vermogen om te blijven versnellen op zowel de 100m als de 200m.
Daarnaast lijkt het erop alsof de vele krachttraining haar (onder?) rug dusdanig geblesseerd heeft dat ze nooit meer op haar oude niveau kan komen.
Eén van onze grootste talenten ooit, die nooit beter gaat worden dan ze in het begin van haar carrière was - dat doet echt pijn.
Reider en waarschijnlijk niks op zichzelf. Is netzoiets als een Heemskerk die in Frankrijk wilde trainen maar er ook niet beter van geworden is. Soms liggen trainingsmethodes iemand gewoon niet ...Pierre schreef op maandag 2 augustus 2021 @ 12:37:
Wat is er eigenlijk mis met die Rana Ryder, heb het niet zo op mijn netvlies staan.
Er is niets mis met Rana Reider.Pierre schreef op maandag 2 augustus 2021 @ 12:37:
Hij is een Amerikaanse coach die voordat hij Schippers ging trainen al heel veel atleten succesvol begeleid heeft en beter gemaakt heeft en ook medailles gewonnen heeft met z'n atleten.
Schippers trainde tot 2016 onder Bart Bennema en wilde een volgende stap maken. Rana Reider is door de Nederlandse atletiekunie naar Nederland gehad als een 'grote aankoop', een Amerikaans succesvolle sprint coach en Schippers kon met hem gaan werken.
Hij had een bewezen track record en hij had een plan om aan Schippers zwakke start te werken. Een groot deel van dat plan was / is ouderwetse krachttraining. Squatten, (power) clean etc. Hierdoor creëer je een groter absoluut vermogen, wat met name helpt bij het gedeelte stilstand - acceleratie.
Op het moment dat je geaccelereerd bent is pure kracht minder belangrijk dan explosiviteit / plyometrics ('soeplesse'). Zo is Schippers van een atleet die op soeplesse heel efficiënt liep en door haar fysiek haar snelheid lang kon vasthouden omgevormd naar een kracht atleet. Uiteindelijk paste dat niet bij haar kernkwaliteiten en kun je de vraag stellen of die rugblessure mede kwam door het vele kracht trainen...
Uiteindelijk zullen we nooit weten hoe het was gegaan als ze bij Bart Bennema gebleven was in 2016 - wellicht zat ze fysiek toen al op de top van wat er in haar zat. Dus een alternatief scenario uitwerken heeft geen zin.
Het is alleen zo jammer als iemand van 25-26 nooit beter wordt dan ze op dat moment zijn .Terwijl je bij bijv de Jamaicaanse dames ziet dat je op je 34e ook nog rete hard kunt lopen.
https://www.volkskrant.nl...mpisch-toernooi~b4b6dbe4/
Herhalend commentaar op de commentatoren is niet nodig. Wanneer de behoefte er wel is, open maar een eigen topic
Dat geldt dus ook voor wat de NOS of Eurosport wel of juist niet uitzenden.
