Strava - Aanpassingen in voorwaarden en functies
Pagina: 1 2 3 4 Laatste
  • wisselwerking
  • Laatst online: 23:23
klaaas schreef op donderdag 21 november 2024 @ 09:20:
Je moet alleen je onderschrift nog even aanpassen 8)
Dank. Dat heb ik zelf niet in beeld. Gelijk aangepast
  • DoubleP38
  • Registratie: Juni 2015
  • Laatst online: 14:01
ik ken het verder niet maar welliciht kan dit een mogelijke oplossing zijn..
https://activityconduit.com/
lees meer: https://forum.intervals.i...want-with-your-data/80097
  • DDX
  • Laatst online: 23:20
DDX
Wandrer heeft update gepost :
https://www.strava.com/clubs/528504/posts/33606187
Hey folks -- got some things cleared up with Strava today, and it's about what we expected. They had two requests:
* Leaderboards should be opt-in by default for new wandrers. Ok, not a big deal.
* Wandrer maps should not be visible to other users. This is what took some back and forth with Strava's legal team because the change to Strava's API terms specifically covers the visibility of "Strava data", which is also defined in their terms as data originating from a Strava API endpoint. My pushback on this is that no data that originates from Strava is visible or accessible on your map: it's all drawn from OpenStreetMap geometries, and Strava data definitely informs the boundaries of those geometries, but only after it's gone through Wandrer's algorithms and datasets, and not in a way that identifies time or frequency of travel on a road. I don't think it's fair to call Wandrer's data "Strava data", but anyways.
The only options Strava sees going forward for sharing your map is that the user has something where they could export an image of their map, or maybe generate a one-time link that someone could use to view their map. Neither of those feel like great options to me. My proposal of "let people decide if they want their map visible to others, with a check-in pop-up every few months for those who have publicly-visible maps" was not accepted.
I know many of you love sharing your map and looking at other peoples' maps (I do, for sure), so I'm going to provide an option for you to be able to keep doing that going forward: getting your data in to Wandrer through some place other than Strava. If you don't care about other folks being able to see your map, you can just stay where you are.
I'll have a longer blog post with more details as we get those worked out, but I can tell you a few things right now:
* I'm still devoted to working on Wandrer and getting new features and updates out to you (there's new map data available as of last night)
* There will be alternative methods of getting data in to Wandrer if you want. If you have any services that you'd especially like Wandrer to work with, let me know.
* Nothing will change with your data visibility until mid December.
https://www.strava.com/athletes/2323035
  • Mistraller
Mistraller
mhr-zip schreef op donderdag 21 november 2024 @ 10:52:
Wat is een data verzamel alternatief voor Strava?
Heel vroeger nam ik op met een Endomondo app, Garmin en vanaf toen alles naar Strava gesynchroniseerd. Later alles rechtgetrokken met Tapiriik, dus mijn ritjes uit 2012 van Endomondo staan nu ook in Strava & Garmin.
Maar Strava doet raar en Garmin is ook maar een merk, kan natuurlijk ook overstappen op Wahoo (puur hypothetisch). Komoot doet volgens mij dan weer niet zoveel met power data.
Ik heb ook van die stokoude data, nog van windows mobile opgenomen met OziExplorer. Zit zelfs 2008 tussen geloof ik. Gemigreerd en heel lang runkeeper gebruikt. Maar toen dus met tapiriik alles naar strava doorgezet. Ik heb met Tapiriik geloof ik wel TCX aanstaan, ik dacht dat daar meer data in zat dan in GPX, tapiriik doet niet de originele fit file dacht ik?
  • Tom-Z
  • Laatst online: 22:27
@Arnoud Engelfriet heeft geblogd over de AVG en Strava's API-aanpassingen. Het zou wel eens in strijd kunnen zijn met het recht op dataportabiliteit.
Ik heb een paar dagen geleden al een speldenprikje aan Strava uitgedeeld door hun FG te mailen met het verzoek om mijn recht op dataportabiliteit niet te frustreren door anderen te verbieden mijn data te verwerken op de manier die ik wil.
  • L.Fields
  • Laatst online: 24-11-2025
Hmm, die nieuwe Strava T&C's zullen het lastig maken voor trainingsapps lijkt me. Join synct nu wel rechtstreeks met Zwift dus indoor is gecovered, maar buiten rij ik met een Karoo. Ik vermoed dat het dan van Hammerhead naar TrainingPeaks naar Join zal moeten lopen in de toekomst? Zo gaan de workouts ook heen dus vermoed dat ze zo ook terug kunnen...
Mezelf quoten uit ander topic:
Denk niet dat tweerichtingsverkeer kan in dit geval, maar ik neem aan dat ze bij Join heel haastig een uploadfunctie voor fitfiles in elkaar aan het draaien zijn? Blijft voorlopig stil vanuit de Joinhoek.
  • pdukers
Voor veloviewer is de impact verwaarloosbaar. Zou me verbazen als voor anderen de impact wel groot zal zijn.
https://blog.veloviewer.c...lications-for-veloviewer/
