• slaay
  • Laatst online: 22:25
slaay
Natuurbeleven.com
Xiaomi Redmi Note 9
Afbeeldingslocatie: https://fdn2.gsmarena.com/vv/pics/xiaomi/xiaomi-redmi-note-9-4.jpg
Specificities Xiaomi Redmi Note 9, Bron: GSMARENA.COM
OS:Android 10.0; MIUI 11
Scherm formaat:1080 x 2340 pixels, 19.5:9 ratio (~395 ppi density)
Scherm type:IPS LCD capacitive touchscreen, 16M colors
Multitouch:Yes
Chipset:MediaTek Helio G85 (12nm)
CPU:Octa-core (2x2.0 GHz Cortex-A75 & 6x1.8 GHz Cortex-A55)
GPU:Mali-G52 MC2
2G Netwerk:GSM 850 / 900 / 1800 / 1900
3G Netwerk:HSDPA 850 / 900 / 1700(AWS) / 1900 / 2100
4G Netwerk:LTE band 1(2100), 2(1900), 3(1800), 4(1700/2100), 5(850), 7(2600), 8(900), 20(800), 38(2600), 40(2300), 41(2500)
Snelheid:HSPA 42.2/5.76 Mbps, LTE-A
Camera (achterkant):48 MP, f/1.8, 26mm (wide), 1/2.0", 0.8µm, PDAF
8 MP, f/2.2, 118˚ (ultrawide), 1/4.0", 1.12µm
2 MP, f/2.4, (macro), AF
2 MP, f/2.4, (depth)
Camera (voorkant):13 MP, f/2.3, 29mm (standard), 1/3.1", 1.12µm
SD card:microSDXC (dedicated slot)
Opslag geheugen (ROM):64/128 GB
Werkgeheugen (RAM):64GB 3GB RAM, 128GB 4GB RAM
Luidspreker:Yes
Simkaart:Dual SIM (Nano-SIM, dual stand-by)
WLAN:Wi-Fi 802.11 a/b/g/n/ac, dual-band, Wi-Fi Direct, hotspot
Bluetooth:5.0, A2DP, LE
NFC:Misschien (market/region dependent) - M2003J15SG (Ja); M2003J15SS (Nee)
USB:2.0, Type-C 1.0 reversible connector
Sensoren:Fingerprint (rear-mounted), accelerometer, gyro, proximity, compass
GPS:Yes, with A-GPS, GLONASS, BDS, GALILEO
Formaat:162.3 x 77.2 x 8.9 mm
Gewicht:209g
Accu:Non-removable Li-Po 5020 mAh battery, Charging Fast battery charging 18W
Kleuren verkrijgbaar:Forest Green, Midnight Grey, Polar White
Prijzen Xiaomi Redmi Note 9
https://www.belsimpel.nl/xiaomi-redmi-note-9/64gb-groen
https://www.belsimpel.nl/xiaomi-redmi-note-9/64gb-wit
https://www.belsimpel.nl/xiaomi-redmi-note-9/64gb-grijs
https://www.belsimpel.nl/xiaomi-redmi-note-9/128gb-groen
https://www.belsimpel.nl/xiaomi-redmi-note-9/128gb-grijs
https://www.belsimpel.nl/xiaomi-redmi-note-9/128gb-wit
Custom ROM Xiaomi.eu
https://xiaomi.eu/communi...ote-9s-pro-max-proeu.205/
Xiaomi Redmi Note 9 S
Afbeeldingslocatie: https://fdn2.gsmarena.com/vv/pics/xiaomi/xiaomi-redmi-note-9-pro-1.jpg
Specificities Xiaomi Redmi Note 9 S, Bron: GSMARENA.COM
Scherm formaat:1080 x 2400 pixels, 20:9 ratio (~395 ppi density)
Multitouch:Yes
Chipset:Qualcomm SM7125 Snapdragon 720G (8 nm)
CPU:Octa-core (2x2.3 GHz Kryo 465 Gold & 6x1.8 GHz Kryo 465 Silver)
GPU:Adreno 618
8 MP, f/2.2, 13mm (ultrawide), 1/4.0", 1.12µm
5 MP, f/2.4, (macro), 1.12µm
Camera (voorkant):16 MP, f/2.5, (wide), 1/3.1" 1.0µm
Werkgeheugen (RAM):64GB 4GB RAM, 128GB 6GB RAM
Luidspreker:Yes
NFC:Nee
Sensoren:Fingerprint (side-mounted), accelerometer, gyro, proximity, compass
Formaat:165.8 x 76.7 x 8.8 mm
Gewicht:209g
Kleuren verkrijgbaar:Aurora Blue, Glacier White, Interstellar Grey
Prijzen Xiaomi Redmi Note 9S
https://www.belsimpel.nl/xiaomi-redmi-note-9s
https://www.amazon.nl/qua...nale-versie/dp/B085S47W3M
Xiaomi Redmi Note 9 Pro
Afbeeldingslocatie: https://fdn2.gsmarena.com/vv/pics/xiaomi/xiaomi-redmi-note-9-pro-global-0.jpg
Specificities Xiaomi Redmi Note 9 Pro, Bron: GSMARENA.COM
Multitouch:Yes
GPU:Adreno 618
Camera (achterkant):64 MP, f/1.9, 26mm (wide), 1/1.72", 0.8µm, PDAF
Werkgeheugen (RAM):64GB 6GB RAM, 128GB 6GB RAM
Luidspreker:Yes
NFC:Nee
Gewicht:209g
Accu:Non-removable Li-Po 5020 mAh battery, Charging Fast battery charging 30W
Kleuren verkrijgbaar:Tropical Green, Glacier White, Interstellar Gray
Prijzen Xiaomi Redmi Note 9 Pro
https://www.belsimpel.nl/xiaomi-redmi-note-9-pro/64gb-grijs
https://www.belsimpel.nl/xiaomi-redmi-note-9-pro/64gb-groen
https://www.belsimpel.nl/xiaomi-redmi-note-9-pro/64gb-wit
https://www.belsimpel.nl/xiaomi-redmi-note-9-pro/128gb-groen
https://www.belsimpel.nl/xiaomi-redmi-note-9-pro/128gb-wit
https://www.belsimpel.nl/xiaomi-redmi-note-9-pro/128gb-grijs
[ Voor 52% gewijzigd door slaay op 07-06-2020 12:05 . Reden: Redmi Note 9 en Redmi Note 9 Pro toegevoegd ]
Dich bis echt unne foëzen haas
  • slaay
slaay
Natuurbeleven.com
Vanwege aanschaf maar meteen een topic aangemaakt! ;-)
  • CombatHermit
  • Laatst online: 22-11 11:37
Na toch wel redelijk veel wikken en wegen heb ik uiteindelijk ook de 6gb/128gb variant aangeschaft. Mijn Nokia 8, die ik toch nog steeds met veel plezier gebruik, heeft een accu probleem (4 uur gebruik en is dan leeg) en had een alternatieve telefoon nodig zodat ik de Nokia kan open maken en beetje zelf accu ga vervangen. :+
Het was een beetje een behoorlijk spannende strijd tussen deze en de Realme 6.
Grootste redenen voor aanschaf voor deze telefoon:
+ Batterij
+ Qualcom chipset
+ Betere Wifi capaciteiten
+ Modding is veel breder ondersteund met dit merk
+ Prijs (ik kon hem uiteindelijk voor 200 euries op kop tikken)
Belangrijke redenen dat ik dus ook naar de Realme zat te kijken:
- Bloatware out of the box
- Erg trage 18W recharge, 2 uur om batterij op te laden niet echt meer van deze tijd
- Technische kennis nodig voor optimalisatie (Rom loading)
- NFC ontbreekt (|:()
Ik denk dat persoonlijk grootste minpunt van de telefoon toch het ontbreken van NFC technologie zal zijn. Ben benieuwd of ik daar dan dus ook spijt van ga krijgen. Al gebruik ik op dit moment deze technologie nog niet.
Nu even afwachten wanneer hij binnenkomt, kijken hoe het rom verhaal voor me gaat uitpakken. O-)
  • slaay
slaay
Natuurbeleven.com
CombatHermit schreef op maandag 18 mei 2020 @ 12:10:
+ Batterij
+ Qualcom chipset
Er zijn momenteel enkele problemen bekend met de Redmi Note 9S. Zaken zoals camera app die onverwacht gesloten wordt en niet correct werkende nabijheidssensor en wifi.
Can't be sure about that. I am also waiting for an update on this. I checked with the Feedback/Bug mod and the result was the same. It seems there are a few bugs to fix this time - camera FC, proximity sensor bug, etc along with this WLAN issue. I'm reporting everything to the dev, and hoping to get a result soon. I cannot say when we can expect one - only a dev can say that, but as all devs say, no ETA.
Cheers! :-)
Bron: https://c.mi.com/thread-3025928-9-1.html
Xiaomi is druk bezig om deze problemen op te lossen.
Het laatste nieuws is dat het niet lang zal duren voor deze problemen middels een OTA opgelost zullen worden.
So, also die Antwort ist da. Die neue Version ist fertig und durchläuft gerade die Testprozesse und kommt in den nächsten paar Tagen als OTA. Beste Grüße Jonas
Bron: https://www.chinahandys.n...estbericht/#comment-62802
  • ChinaGeek
  • Registratie: Oktober 2017
  • Laatst online: 17-05-2021
+ Batterij
+ Qualcom chipset
De Note 9 Pro, die maar marginaal duurder is, heeft wel NFC en een betere camera.
  • CombatHermit
Oeh, ik moet eerlijk bekennen dat in het telefoon geweld, niet had gezien dat er een pro editie was. Dacht dat de Note 9s een 'rebrand' Note 9 Pro was. Ik las dat hier:
https://www.xda-developer...ote-9-pro-global-note-9s/
Maar ik zie inderdaad dat er een listing is voor een Note 9 Pro die dus wel anders is. Ook op tweakers is de NFC nog niet echt als zoek optie terug te vinden bij vergelijken. :F
https://www.mi.com/global/redmi-note-9-pro/specs
Volgens het internet heeft de Pro wel twee hoofdpunten die het beter maken:
+ 33w vs 18w voor opladen
+ 64MP vs 48 MP voor de camera
+ NFC
Hrm.. ik ga die 60 euro verschil maar in mijn zak steken. Maar had het misschien toch wel waard geweest, jammer dat die naamgevingsconventies zo ongelofelijk vaak op de schop gaan. 8)7
[ Voor 0% gewijzigd door CombatHermit op 18-05-2020 15:41 . Reden: Bedoelde NFC als vergelijking optie ]
  • ChinaGeek
CombatHermit schreef op maandag 18 mei 2020 @ 15:28:
Maar ik zie inderdaad dat er een listing is voor een Note 9 Pro die dus wel anders is. Ook op tweakers nog niet echt als zoek optie terug te vinden bij vergelijken. :F
+ NFC
Ik zie er zelfs 3 ;)
  • veertje
  • Laatst online: 04:25
Ik had ook al een topic voor de 9s gemaakt, maar niet zo mooi als deze.
Die van mij is nog steeds onderweg, meer dan een maand geleden besteld :'( :'( :'(
  • slaay
slaay
Natuurbeleven.com
Vandaag is de nieuwe versie 11.0.8 verschenen en de problemen met wifi zijn daarmee opgelost. Hopelijk wordt dit ook in de Xiaomi.eu versie snel doorgevoerd!
  • yanic
  • Laatst online: 05-03 11:48
Ik wou een Note 9S kopen, maar door de wekenlang aanhoudende Wifi problemen heb ik toch voor een andere gekozen (realme 5 pro).
In het kort : bij sommige routers verliest de Note 9S de wifi verbinding tijdens slaapstand (en schakelt ook niet autom. over naar bv. 4G, dus er komen bv. geen whatsapp berichtjes binnen).
Wie Duits kent en het Wifi verhaal wil volgen kan ik onderstaande thread aanraden :
https://www.android-hilfe...page-6.html#post-12065145
De ietwat actievere deelnemers aan de eerder aangehaalde threads (op c.mi.com en chinahandys.net) zijn trouwens dezelfde users uit deze android-hilfe.de thread. Je kunt netjes volgen wie wie is over de verschillende forums heen :)
Momenteel lijkt het erop dat 11.0.8 slechts een lapmiddeltje is - de verbinding gaat nog steeds verloren maar wordt "snel" terug opgezet. Bij sommige gebruikers duurt het echter nogal lang, bij anderen wordt er overgeschakeld van 5Ghz naar 2.4Ghz en er zijn nog een paar andere bekommernissen.
Een user op dat forum had trouwens als workaround een Tasker script geschreven dat iets gelijkaardigs doet.
De discussie over 11.0.8 begint in de android-hilfe.de thread bij post #119.
  • freakenstein
  • Laatst online: 13-11 09:43
Dank voor het openen van het topic.
+ NFC
Precies dit. Eerst las ik ook dat het gewoon om een andere naam ging, maar blijkt dus net wel ff anders. Had overigens niet het verschil met/zonder NFC gevonden. Voor mij denk ik wel de reden om voor de Pro te kiezen. Zo staat er ook op de achterkant 64MP camera geschreven, foto via GSMarena:
Afbeeldingslocatie: https://tweakers.net/i/rEQu6sT9u1QGpKlAPFGdIl2atWE=/full-fit-in/4920x3264/filters:max_bytes(3145728):no_upscale():strip_icc():fill(white):strip_exif()/f/image/Z7sUwD2TTLufsoMxkJEqhTVw.jpg?f=user_large
Direct een custom rom wordt dus wel aangeraden bij Xiaomi phones?
Horrorliefhebber op https://denachtvlinders.nl
  • freakenstein
Inmiddels iets meer gelezen.
Begrijp dat het idd een rebrand is, maar dan van Pro en Pro Max, naar S en Pro. Dus ja, de Pro is de S geworden, terwijl de Pro Max hier de Pro heet.
Duidelijk?
https://www.mi.com/in/redmi-note-9-pro-max/specs/
[ Voor 12% gewijzigd door freakenstein op 22-05-2020 10:42 ]
  • ChinaGeek
freakenstein schreef op donderdag 21 mei 2020 @ 16:03:
Custom ROM is niet per se noodzakelijk nee. Alle mensen die ik aan een Xiaomi helpt, geef ik gewoon de Global ROM, die voldoet prima.
De Xiaomi.eu rom is een optie, maar zie tegenwoordig nog maar weinig echte voordelen.
  • CombatHermit
Aangezien de bestelling status nogal lang op zich liep wachten qua verandering/update, en het verschil terug gelopen was tot nog maar zo'n 35 euro tussen pro versie en de 9s variant. Heb ik toch besloten om eerdere bestelling te cancellen. In plaats daarvan nu de 9 pro versie bestelt.
Het hebben van de eerder genoemde features, en iets betere camera vond ik toch wel een prettige gedachte. Toch een beetje 'Got to have all them features' tendens te bespeuren hier bij mijn persoon... 8)7
Bedankt @ChinaGeek voor de melding dat er nog een andere versie was!
Stiekum ga ik er vanuit dat de wifi problemen software issues zijn die tegen de tijd dat de telefoon aankomt al zijn opgelost, al ga ik me nog wel in custom roms verdiepen. O-)
[ Voor 0% gewijzigd door CombatHermit op 22-05-2020 12:12 . Reden: Grammatica ]
  • freakenstein
@CombatHermit Mag ik vragen waar je hem bestelt? Ik zie hier in NL alleen Belsimpel deze Pro aanbieden voor €300.
  • CombatHermit
Ik heb hem hier bestelt:
https://www.eglobalcentra...kvrij-tropical-green.html
Code 'CHKOUT5' erbij, en je komt op 235 euro. Hij heeft iets minder opslag geheugen (6GB/64GB) dan de 200 euro die ik anders voor de 9S (6GB/128GB) had neergelegd, maar aangezien microsd uitbreiding altijd mogelijk is vond ik dat niet erg. Ik upload / verwijder toch al mijn foto's e.d. naar mijn NAS, zelfs mijn huidige telefoon komt amper boven de 35GB gebruik uit.
Mochten linkjes naar winkels btw niet mogen in deze thread, laat me graag corrigeren door moderator. :+
Over die winkel gesproken, levertijd lijkt bij deze winkel wel wat langer dan gebruikelijk te zijn gezien het feit dat mijn bestelling al bijna week ongewijzigd bij hun in de boeken stond. Daar staat wel tegenover dat ze zonder problemen mijn annulering verwerkt hebben. Dus even afwachten hoe dat verder gaat.
  • ChinaGeek
Via coupon code 200 euro bij DHgate.
https://www.kimovil.com/e...y-xiaomi-redmi-note-9-pro
  • veertje
Mijn Note 9s is nog steeds onderweg, heel verleidelijk om deze te kopen en dan de 9s door te verkopen wanneer die eindelijk aankomt.
[ Voor 0% gewijzigd door veertje op 22-05-2020 19:33 . Reden: spelling ]
  • groggy
Sellers ships within 30 Days, dat zal dus nog wel even duren...
  • ChinaGeek
groggy schreef op vrijdag 22 mei 2020 @ 19:59:
Over het algemeen wordt er veel eerder geshipped.
  • Wildfire
  • Laatst online: 00:51
Wildfire
Joy to the world!
Zojuist de Note 9S besteld bij BelSimpel, zonder helaas van tevoren uit te zoeken of er hoesjes voor zijn. Ik ben namelijk een book cover gewend maar ik kan die zo 1-2-3 nog niet vinden (in NL iig) voor dit nieuwe model telefoon. Via China wordt het erg lang wachten :P
yanic schreef op donderdag 21 mei 2020 @ 05:41:
Ik las zojuist op XDA dat dat wifi probleem zich bij custom ROMs niet voor lijkt te doen en dat het dus MIUI gerelateerd lijkt te zijn. Aangezien ik er toch een custom ROM op ga knallen... :P (nou ja, niet meteen, de mod community begint nu net op stoom te komen, er is al wel een unofficial LineageOS 17.1 maar er is nog geen officiële TWRP en daar wacht ik liever nog even op)
Dit toestel wordt trouwens een vervanging van een Redmi Note 4X. Ik wilde weer eens wat nieuwers. :P
[ Voor 67% gewijzigd door Wildfire op 22-05-2020 23:42 ]
Systeemspecs | Mijn V&A spulletjes | Mijn RIPE Atlas probe
  • slaay
slaay
Natuurbeleven.com
Wildfire schreef op vrijdag 22 mei 2020 @ 23:22:
Er zit een transparant hoesje in de doos. Het is iig een hoesje dat net iets hoger is qua randjes om de camera waarbij de camera de tafel bijvoorbeeld niet raakt als je de telefoon plat op tafel legt. Ook slim om hier op te letten bij het aanschaffen van een nieuw hoesje!
De niet officiële TWRP versie is al uit: https://www.cyanogenmods....e-9-pro-9s-twrp-recovery/
  • Wildfire
Wildfire
Joy to the world!
slaay schreef op zaterdag 23 mei 2020 @ 08:51:
Er zijn twijfels over deze niet-officiële TWRP versie dus ik neem daar maar geen risico mee. :P
Het meegeleverde hoesje zal voorlopig maar moeten voldoen tot ik ergens een bookcover hoesje kan vinden. :)
  • cazzie
  • Laatst online: 05:49
ik had eerst de redmi 9s op het oog maar uiteindelijk is het de redmi 9 pro geworden.
De aanschaf via eglobalcentral is een sprong in het diepe want de berichten links
en rechts op internet zijn niet overal even positief over deze asian online retailer.
Over die bewuste wifi problemen, dat zal toch niet enkel en alleen om de 9s gaan
want beide toestellen zijn voor 97% gelijk aan elkaar toch ?
control alt oeps deleted
  • slaay
slaay
Natuurbeleven.com
cazzie schreef op zaterdag 23 mei 2020 @ 09:00:
want bij toestellen zijn voor 97% gelijk aan elkaar toch ?
Lees dan dit maar eens: nieuws: Nederlandse OM en Fiod halen webwinkel eGlobal Central offline
De wifi problemen komen ook bij de Pro voor ja, maar inmiddels is het al opgelost. Blijkbaar niet met erg nette code, maar het is opgelost. Een nette code oplossing zijn ze ook alweer mee bezig.
  • Marzman
Marzman
They'll never get caught.
4 camera's al. Kan een van die andere drie camera's niet gebruikt worden voor diepte? Dat kun je toch met twee camera's al? Infrarood was dan misschien handiger geweest en dan met wat AI en hulp van de andere camera's om er wat kleur in te krijgen.
  • Wildfire
Wildfire
Joy to the world!
Gezien de naamsverwarringen zal ik nog wel laten weten welke codenaam (en welk model) mijn bestelde Redmi Note 9S van BelSimpel nou precies is. :P
[ Voor 6% gewijzigd door Wildfire op 23-05-2020 10:15 ]
  • ChinaGeek
Wildfire schreef op zaterdag 23 mei 2020 @ 10:15:
Daar is toch weinig verwarring over? De 9S is de 9S. Zonder NFC, met 48 megapixel camera en beperkt snelladen.
  • Wildfire
Wildfire
Joy to the world!
ChinaGeek schreef op zaterdag 23 mei 2020 @ 11:12:
Ik las gisteren op meerdere plekken berichten dat de 9 Pro hier als 9S zou komen en dat geeft toch wel verwarring.
O.a. op XDA: "Xiaomi launches the Redmi Note 9 Pro globally as the Redmi Note 9S"
Er zijn dus twee verschillende Pro's. Om het handig te maken voor de klant. :P
Verder weinig aan de hand, de specs stonden erbij en het zal gewoon kloppen.
[ Voor 13% gewijzigd door Wildfire op 23-05-2020 11:21 ]
  • freakenstein
Volgens mij doet Belsimpel elke maandag een prijsupdate, zo gaat daar de nieuwe POCO ook in de aanbieding https://www.belsimpel.nl/xiaomi-poco-f2-pro/128gb-grijs
Wacht nog even met bestellen tot dan.
Wel fijn dat ze sowieso een hoesje meeleveren. :)
  • ChinaGeek
Wildfire schreef op zaterdag 23 mei 2020 @ 11:20:
Dat is van 23 maart toen er nog wat gegokt werd. Nu is het vrij simpel. Er is een Redmi Note 9, een Note 9S en een Note 9 Pro.
  • Wildfire
Wildfire
Joy to the world!
ChinaGeek schreef op zaterdag 23 mei 2020 @ 19:33:
Daar lijkt het wel op neer te komen.
Mijn Note 9S heb ik binnen, werkt fijn.
Wou 'm alvast unlocken om te rooten, voor de tussentijd totdat er een officiële TWRP is. Maar ja... MI Unlock is altijd fijn, was het alweer vergeten. "Please wait 168 hours". :F
Het is maar minimaal, het randje wat ze op het hoesje hebben gedaan is net zo hoog als het camera-eiland. Waardoor effectief de camera nog net gewoon de tafel aanraakt als je de telefoon neerlegt.
Afbeeldingslocatie: http://www.briandickens.nl/GoT/steektuit.jpg
[ Voor 46% gewijzigd door Wildfire op 23-05-2020 21:03 ]
  • CombatHermit
Ik vond persoonlijk dit overzicht nog het meest verhelderend:
https://c.mi.com/thread-3086213-1-0.html
Global Edities zoals we ze hier krijgen:
Afbeeldingslocatie: https://tweakers.net/i/weEMP_ewwsZoJZsYycj2g-N0zuE=/full-fit-in/4920x3264/filters:max_bytes(3145728):no_upscale():strip_icc():fill(white):strip_exif()/f/image/yTfOjwayd3hxLZ4Sin2IxLdD.jpg?f=user_large
Variant in India, en waar de meeste reviews momenteel over gaan:
Afbeeldingslocatie: https://tweakers.net/i/TtHPua77cnummbB9tFbFVEfXYaY=/full-fit-in/4920x3264/filters:max_bytes(3145728):no_upscale():strip_icc():fill(white):strip_exif()/f/image/NFhW00sRMtkNizDTbsjhZaQd.jpg?f=user_large
Maar zelfs in dat overzicht wordt de NFC niet bij de 'global' 9 pro genoemd als aparte feature. Misschien moet deze thread het meer generiek hebben over de Note 9 serie, en dit meenemen?
Ik was ook vol overtuiging in dat XDA artikel getrapt. :X
  • Marzman
Marzman
@CombatHermitEen Redmi 9 S die in een ander land Redmi 9 Pro heet en een ander toestel is dan de Global Redmi 9 pro. Dat is toch niet te doen? Zeg dan Redmi 9 GS en Redmi 9 IS (Global S en India S) ofzo.
  • Supertip
Vrijdag de global version 64 GB gray besteld bij Ali via Spanje, 175€ schoon aan de haak.
Nu al 2 jaar een redmi Note 5, dus een mooie overgang naar de 9s.
Ik zal mijn bevindingen/ervaring hier posten, als de 9s binnen is.
Wat nu al blijkt van YouTube is, bleeding van het scherm met wat lichte en donkere plaatsen in het LCD scherm.
Ook schijnt de helderheid niet helemaal top te zijn, in de volle zon.
Ook blijkt de camera toegang vanaf het lockscreen vaak te crashen, maar daar zal wel een update voor komen.
Hier nog een vergelijking met de realme 6 met de heilo 90 t chipset en 90hz scherm.
[ Voor 12% gewijzigd door Supertip op 26-05-2020 14:18 ]
12X Rec peak energy 275 WP pal Zuid platdak 20° Growatt 3000 MTL-S /bj. Half mei 2018
  • Wildfire
Wildfire
Joy to the world!
Hmmm, dat issue dat WiFi vanuit de slaapstand niet werkt is nog niet gefixed blijkbaar. Mijn Note 9S is volledig up-to-date maar ik heb nu al meerdere malen gehad dat ik geen internet had nadat de telefoon uit de slaapstand kwam. Er was wel een wifi-verbinding, maar geen internet. Uit- en weer inschakelen van wifi verhelpt het dan.
-- Edit:
[quote]
slaay schreef op maandag 18 mei 2020 @ 20:34:
Ah, in versie 11.0.8. Mijn Note 9S zit op 11.0.2 (na een update die ik gisteravond heb gedaan) en vermeldt nog steeds dat er geen updates zijn. Ik zit op de factory ROM van deze 9S, een global ROM.
[ Voor 42% gewijzigd door Wildfire op 24-05-2020 18:38 ]
  • ChinaGeek
Wildfire schreef op zondag 24 mei 2020 @ 18:35:
-- Edit:
[quote]
Ook in 11.0.8 is het nog niet volledig opgelost.
  • KvNwPPr
  • Laatst online: 20-11 09:36
Heb de Redmi note 9s nu een week in gebruik en heb nog niks gemerkt van de wifi problemen. Verder een mooie upgrade van mijn 5 pro. Enige minpunt wat ik kan bedenken is het ontbreken van nfc, maar daar valt mee te leven en is de prijs ook naar.
Twijfel nog of ik de EU rom ga gebruiken. Zie alleen "Optimized GPS settings for EU" als voordeel of mis ik nog iets belangrijks wat de global niet heeft?
  • Wildfire
Wildfire
Joy to the world!
KvNwPPr schreef op zondag 24 mei 2020 @ 23:19:
Op welke versie van het systeem zit je? Ik had zojuist iig weer het wifi-probleem: geen internet. Wifi uit- en weer aangezet en internet werkte weer...
  • slaay
slaay
Natuurbeleven.com
-- Edit:
[quote]
Als ik hier kijk: https://c.mi.com/oc/miuidownload/detail?device=1900378
Dan is de EEA versie bijvoorbeeld op 11.0.2
  • freakenstein
FYI: Voor wie (de Pro) bestelt via Belsimpel, levertijd op site 2-4 werkdagen. Bevestiging na bestelling: 10 werkdagen.
[ Voor 3% gewijzigd door freakenstein op 25-05-2020 18:39 ]
  • KvNwPPr
Wildfire schreef op maandag 25 mei 2020 @ 06:53:
Versie 11.0.8
  • henk200
  • Registratie: Mei 2017
  • Laatst online: 03-11-2024
Hoesjes nog verkrijgbaar via eBay
Komen uit Duitsland , 25-5 besteld vandaag in de bus .
Merk simpeak ,degelijk past goed,
Flip case niet modern .
Maar beschermt de telefoon goed
Ook hoesje in China besteld dit kan nog wel even duren ben nu dus gered
  • slaay
slaay
Natuurbeleven.com
Ik heb het toestel nu 3 weken in bezit, maar het leek een kleinigheid maar begint nu toch wel hinderlijk te worden.
Telkens wanneer je de telefoon op tafel legt dan schieten de apps die open staan naar landschapsmodus. Even het toestel optillen aan bovenzijde (waar de IR blaster zit bijv) en dan blijven de apps in portretmodus.
Ik heb al via het servicemenu de gyroscoop gekalibreerd, apps gedownload en daarmee gekalibreerd maar het is niet verholpen.
Om uit te sluiten dat het aan Xiaomi.eu ROM zou liggen net de telefoon teruggezet naar de originele global rom en ook daar dezelfde problemen.
De telefoon heb ik via een externe verkoper op amazon.nl gekocht, waarbij Amazon de verzending heeft geregeld.
Amazon biedt alleen de optie aan; stuur het toestel terug en je krijgt het volledige aankoopbedrag terug. Garantie of het toestel vervangen doen ze niet. Je kan zelf nadat je het geld hebt teruggekregen een nieuwe kopen.
Toch maar eens kijken of het aantrekkelijk is om een Redmi Note 9 Pro (global versie) aan te schaffen.
[ Voor 8% gewijzigd door slaay op 01-06-2020 13:15 ]
  • Wildfire
Wildfire
Joy to the world!
slaay schreef op maandag 1 juni 2020 @ 12:39:
Bij mij staat roteren altijd uit, maar om even te testen weer aangezet. Wat jij omschrijft tref ik dan maar af en toe, het heeft er mee te maken hoe ver je de telefoon over een bepaalde as heenkantelt bij het neerleggen.
Daar zal een ander toestel niet echt verschil in gaan maken vrees ik.
  • slaay
slaay
Natuurbeleven.com
Wildfire schreef op maandag 1 juni 2020 @ 15:12:
Ik heb het ook geprobeerd op de volgende manier:
Telefoon verticaal op de tafel gezet en daarna de telefoon laten kantelen. zodat de kant van de camera's ook de tafel raakt. Alle apps die landschapsmodus ondersteunen schieten dan vervolgens in deze modus.
Als ik dit probeer bij mijn Redmi note 7 (waar jammer genoeg de camera van stuk is), dan blijven de apps netjes in portretmodus staan. Pas wanneer je de telefoon over de lange zijde kantelt dan gaan de apps in landschapsmodus. En nooit bij het gewoon plat op de tafel leggen vanuit een verticale houding vooraf van de telefoon.
Bij de Redmi Note 9S ging het ook al mis als je telefoon uitzet. Plat op tafel legt, vervolgens aanzet en dan na het inloggen een app opent, die gaan dan ook meteen in landschapsmodus. Is dat bij jou ook het geval?
  • Wildfire
Wildfire
Joy to the world!
slaay schreef op maandag 1 juni 2020 @ 16:27:
Ik ervaar deze problemen niet (in ieder geval nu niet met de Xiaomi.eu 11.0.8.0 ROM voor de Note 9S, maar ook met de originele global ROM 11.0.2.0 die er eerst op zat heb ik dit gedrag niet meegemaakt).
[ Voor 4% gewijzigd door Wildfire op 01-06-2020 17:18 ]
  • slaay
slaay
Natuurbeleven.com
Wildfire schreef op maandag 1 juni 2020 @ 17:17:
Dank! Dan ligt het toch aan mijn toestel zoals ik al vermoedde.
Andere vraag over je Redmi Note 9S of aan andere Note 9S eigenaars....Heeft deze al vanuit de fabriek een pre applied screenprotector erop uit de verpakking?
[ Voor 3% gewijzigd door Verwijderd op 01-06-2020 19:19 ]
  • slaay
slaay
Natuurbeleven.com
Verwijderd schreef op maandag 1 juni 2020 @ 19:18:
De Redmi Note 9S heeft dat, weet ik uit ervaring.
  • Wildfire
Wildfire
Joy to the world!
slaay schreef op maandag 1 juni 2020 @ 19:33:
Dat kan ik bevestigen :)
Dankje @slaay en @Wildfire. Beetje kwaliteit ook? En hoe is de kwaliteit van de meegeleverde hoes?
  • Wildfire
Wildfire
Joy to the world!
Verwijderd schreef op maandag 1 juni 2020 @ 21:26:
Het is een siliconen hoesje puur om de zij- en achterkant van de telefoon te beschermen. Het is fatsoenlijk genoeg, maar ik ben geen fan van siliconen hoesjes. Daarom is er een bookcover hoesje onderweg (nepleer). Zoiets heb ik altijd gehad en werk ik ook liever mee, mede omdat daarmee ook het scherm nog extra wordt afgeschermd.
Ik ben verder erg tevreden over de telefoon, zeker nu ik de telefoon heb kunnen unlocken, de Xiaomi.eu ROM erop heb kunnen zetten (en daarmee meteen ook van v11.0.3.0 naar v11.0.8.0 ben gegaan) en heb kunnen rooten met Magisk. :P
slaay schreef op maandag 1 juni 2020 @ 17:19:
Ik wilde bijna gaan zeggen dat het probleem vaker lijkt voor te komen gezien een post op het Xiaomi.eu forum, maar die post daar blijkt van jou te zijn :P
[ Voor 18% gewijzigd door Wildfire op 01-06-2020 21:57 ]
  • magnum73
  • Laatst online: 28-04-2025
Het kantelen van het beeldscherm is inderdaad zeer gevoelig. Ik heb het afgezet want had er ook veel last van.
  • Fanaat
  • Laatst online: 19-08-2022
Fanaat
member of the former TeamBVD
Ik heb hem net ontdekt :P
I3 6100, 16 gb Corsair Asus Prime B250 plus, AMD Radeon HD 6800
  • dengregg
  • Laatst online: 10-11 19:56
Ik heb hem net ontvangen. Op het eerste zicht geen slecht toestel voor zijn prijs.
iRacing Profiel
  • magnum73
Ik heb hem een paar dagen in gebruik. Voorlopig niets dan lof ! Enkel de gebaren die niet werken met android 10 stoort mij...want werk met nova launcher.
  • KvNwPPr
magnum73 schreef op dinsdag 2 juni 2020 @ 07:05:
Ik heb ook regelmatig last van ongewild kantelen. Zou willen dat je dat minder agressief kon instellen.
Maar dit "probleem" had ik ook met m'n note 5 pro dus dat is niet een specifiek probleem van de 9s.
  • ChinaGeek
Als je gaat importeren, dan heb je voor nagenoeg dezelfde prijs de K30 5G. Je mist dan wel een 4G band maar je hebt dan een toestel dat qua performance duidelijk beter is...
  • homernt
  • Laatst online: 05-02 12:49
Ik heb dit toestel, de 64Gb variant, zins vorige week vrijdag. Nou zag ik vanmorgen dat onder systeem apps er drie apps draaien van facebook. Deze kun je gelukkig en misschien als enige wel uitschakelen. Maar weghalen kun je bijna niks. De bouwkwaliteit en zeker voor de prijs is top maar veel bloatware die je dus veelal niet eens kan uitschakelen.
  • dengregg
maar daar zijn we tweakers voor he, bootloader unlocken en de xiaomi.eu-rom erop gooien (of andere rom naar keuze)
iRacing Profiel
  • Marzman
Marzman
KvNwPPr schreef op woensdag 3 juni 2020 @ 13:33:
Wat is te gevoelig?
Ik heb een Note 7 en zet dat uit als ik in bed bijvoorbeeld een stuk tekst wil lezen (nadat het twee keer versprongen is). In normale situaties verspringt dat niet en in bed ben ik natuurlijk zelf degene die niet recht zit.
  • slaay
slaay
Natuurbeleven.com
dengregg schreef op donderdag 4 juni 2020 @ 08:52:
Of je moet er de EEA rom opzetten, het verschil tussen de EEA rom en Global rom is als ik het goed heb dat je maar een keer de vraag krijgt om advertenties uit te zetten ipv per app dit te moeten doen.
Nadeel van de EEA rom is wel dat deze minder vaak een update krijgt.
Zo is de global rom op versie 1.0.8 en de EEA rom op 1.0.2
Zie: https://c.mi.com/oc/miuidownload/detail?device=1900378
  • homernt
Zonet de update gedaan naar MIUI Global versie 11.0.3.0 met de security update van 1 mei.
  • KvNwPPr
Marzman schreef op donderdag 4 juni 2020 @ 09:00:
Wat is te gevoelig?
Hij schakelt over naar horizontaal beeld Als ik m'n telefoon in een hoek van ~20 graden naar de zijkant houdt. Als ik m op tafel leg dan zit m'n hand eronder, en komt ie over die bepaalde hoek én schakelt ongewenst over naar horizontaal beeld.
  • magnum73
Iemand problemen met cloud mi account backup ? Hij blijft hangen op 5%.
  • Wildfire
Wildfire
Joy to the world!
Ik klaagde onlangs over wifi problemen, ik heb met de 11.0.8.0 ROM tot nu toe geen rare issues met wifi meer gehad.
  • slaay
slaay
Natuurbeleven.com
magnum73 schreef op donderdag 4 juni 2020 @ 16:41:
Je hebt nog ruimte op je cloud opslag? Die loopt stiekem erg snel vol namelijk.
Of probeer je bij het in gebruik nemen de gegevens automatisch terug te zetten vanuit de cloud?
  • magnum73
slaay schreef op donderdag 4 juni 2020 @ 20:13:
Nee, gewoon een eerste backup. Dus nog geen ruimte gebruikt...
  • slaay
slaay
Natuurbeleven.com
Ik zat laatst eens op AliExpress te kijken naar een Redmi Note 9 Pro aangezien mijn Redmi Note 9S terug naar Amazon is. Tot ik opeens bij deze winkel kwam waar voor AliExpress Gold members € 30 euro korting was voor een aantal uren. Daarbij stond er ook nog een kortingscode van € 10,00.
Dus maar snel besteld en zoals zo vaak bij AliExpress eerst zien of het daadwerkelijk verstuurd en bezorgd gaat worden! Want vaak als een aanbieding te mooi is dan versturen ze het niet en proberen ze je geld via PayPal terug te storten in ruil voor 5 sterren reviews.
Mocht het toestel daadwerkelijk bezorgd worden dan zal ik het topic even updaten voor Redmi 9/9S/9Pro ;-)
Afbeeldingslocatie: https://tweakers.net/i/K-nRViO7n8_-9aO3wugBVzj0RJU=/800x/filters:strip_icc():strip_exif()/f/image/yUOGWAqNBAElIXd67x4zGke6.jpg?f=fotoalbum_large
  • groggy
Bedankt ik heb er net ook een redmi note 9 pro gekocht. Ik heb 3 tientjes meer betaald. Maar nog steeds goed geprijst. Ben benieuwd of ze daadwerkelijk gaan leveren.
  • ChinaGeek
slaay schreef op zaterdag 6 juni 2020 @ 10:58:
Ik ben diamond member, al tientallen telefoons gekocht daar en dat werkelijk nog nooit meegemaakt.
  • daboytonie
  • Registratie: September 2014
  • Laatst online: 06-03-2024
had hem besteld bij belsimpel op 25/05 en kom die pas tegen 09/06 toe zeg
ben echt aan het balen :(
  • cazzie
daboytonie schreef op zaterdag 6 juni 2020 @ 19:51:
Ik zit ook in de wait-game en ik denk dat mijn hoesje nog eerder binnen is dan de note 9 pro ;)
  • daboytonie
cazzie schreef op zaterdag 6 juni 2020 @ 22:02:
Ik denk dat ik net uit de boot ben gevallen. Was een phone voor mijn vriendin, heb het haar toch nog snel willen tonen en plots was het van voor 23h30 betellen morgen thuis naar 2-3 werkdagen.
Wordt dus 2 weken bijna :'(
Supplier zal de vraag niet aankunnen zeker?
Btw, waar heb je hoesjes gevonden?
[ Voor 3% gewijzigd door daboytonie op 07-06-2020 12:47 ]
  • magnum73
Dan had ik geluk...2 weken geleden besteld bij belsimpel en 3 dagen later in België in de bus, op een zaterdag nog wel.
  • cazzie
  • Barns
  • Laatst online: 23-11 12:46
Via Banggood had je een tijdje de mogelijkheid om te kiezen voor PDM verzendmethode, dan was de douane klaring geregeld / inclusief. Hoe zit dat met verzenden via Ali? Bijv. bij deze verkoper 128gb / €225?
Banggood heeft nu "Priority Line", wat vroeger PDM was. Bijv. deze 64gb / €215.
EU Priority Line Tracking
EU Priority Line is the new shipment without customs of Banggood! Banggood will ship your parcel with GLS or Post NL.
EU Priority Line it has no customs costs which are borne by the store originally before sending the purchased product.
[ Voor 39% gewijzigd door Barns op 08-06-2020 10:56 ]
  • ChinaGeek
Barns schreef op maandag 8 juni 2020 @ 10:52:
Bij AliExpress heb je dat alleen bij sommige (dure) DHL verzendingen.
  • daboytonie
Weeral eens uitgesteld bij Belsimpel. Overwegen waard om te annuleren of klagen voor iets extra? Want zitten ook nog oortjes in die ik eigenlijk asap wou
  • hgmaster
  • Registratie: Juni 2020
  • Laatst online: 12-03-2025
Niet om reclame te maken, maar ik heb uitstekende ervaring met xiaomiproducts.nl. Inmiddels mijn telefoon en smartwatch besteld daar. Gewoon volgende dag in huis!
  • groggy
hgmaster schreef op maandag 8 juni 2020 @ 22:23:
Heb je die prijzen gezien. Belsimpel en amazon zijn echt een heel stuk goedkoper. (nog even afgezien van zelf importeren)
  • slaay
slaay
Natuurbeleven.com
groggy schreef op maandag 8 juni 2020 @ 22:33:
Mocht je het op Amazon.nl of bij belsimpel.nl goedkoper zien dan mag je xiaomiproducts.nl wel wijzen op hun "Laagste prijzen in Nederland" claim die groot op hun website staat!
Zie ook: https://www.xiaomiproducts.nl/service/about/
  • hgmaster
Klopt, maar ik had eerst mijn tel besteld via ali. Die was kapot aangekomen, retour gestuurd, en wacht nu al maand op mijn geld.... Dan maar iets meer betalen bij een betrouwbare Nederlandse winkel.
  • Qui-Gon-Jinn
  • Laatst online: 19-08 17:58
Ik heb op 3 juni de Note 9 pro via onderstaande link besteld:
https://nl.pepper.com/aan...37?page=2#thread-comments
Bestelling loopt via Gshopper UK en ik heb de telefoon gisteren via DHL binnengekregen (via Duitsland). :?
Uiteindelijk dus de Note 9 Pro 6G/128G voor €249,- en dan krijg je als nieuwe klant nog 10% korting.
Ik heb de telefoon uiteindelijk voor € 224,10 via PayPal kunnen bestellen :)
Ik weet niet of de 10% korting nog geldig is (ben geen nieuwe klant meer O-)) maar anders dus €249,-; de 6G/64G versie is verkrijgbaar voor €229,- (met ook indien nog geldig de 10% korting)
[ Voor 5% gewijzigd door Qui-Gon-Jinn op 11-06-2020 10:02 ]
  • CombatHermit
Uiteindelijk nu pas het machientje binnen gekregen. Da's toch wel na aanzienlijke tijd.
Bestelling: 22 mei
Ontvangst: 12 juni
Winkel: https://www.eglobalcentralnl.com/
Nu bootloader unlocken, jeuj! :+
  • cazzie
Mijn bestelling is van 23/05 en de huidige status is:
2020-06-12
Due to unforseen circumstances there is a delay in your shipment.
We will update here once we have news.
Duimen draaien en billen knijpen.
  • Wildfire
Wildfire
Joy to the world!
CombatHermit schreef op vrijdag 12 juni 2020 @ 15:14:
Bestelling: 22 mei
Ontvangst: 12 juni
MI Unlock Tool: "please wait 168 hours"
:P
  • cazzie
cazzie schreef op vrijdag 12 juni 2020 @ 17:25:
Update:
2020-06-13
Your parcel has arrived at DPD, please follow this link for further information :)
  • slaay
slaay
Natuurbeleven.com
Vandaag het toestel ontvangen. Het is geen global zoals in de omschrijving staat op AliExpress maar een EEA versie, wat helemaal niet erg is! Op het toestel stond versie 11.0.1 en kreeg meteen de melding dat er een update klaar staat met versienummer 11.0.3.
  • dengregg
Wildfire schreef op vrijdag 12 juni 2020 @ 21:30:
:P
Hier was het wachten dinsdag gedaan en tot vandaag gewacht met de 'upgrade' naar de xiaomi.eu rom
iRacing Profiel
  • hars73
  • Laatst online: 12-11 22:36
Mijn vrouw heeft nu een Samsung S8+ die een beginnende barst in het scherm heeft. Doet het verder nog prima hoor, maar ze wil eventueel wel iets nieuws.
Ik heb zelf al een paar jaar de RMN 5, die prima bevalt. Dus ik zal voor haar eventueel aan de Note 9S te denken. Ze gebruikt toch 90% van de extra features van de Samsung niet.
Lees bij de recensies op Amazon nogal veel klachten over de wifi verbinding die regelmatig wegvalt. In dit topic hier zag ik het ook staan. Maar ook dat het recent opgelost is?
Is dat in z'n algemeenheid goed opgelost nu? Want ik krijg haar al niet zo makkelijk van Samsung af (ze wil eventueel de A51 of A71), dus dan moet een Xiaomi geen vervelende issues vertonen. ;-)
  • dengregg
Het wifi-probleem is opgelost met de laatste updates.
Mijn huisgenoot heeft trouwens de A71 en heeft al een beetje spijt van zijn aankoop sinds hij mijn RMN 9S heeft gezien. De A71 is in totaal net iets beter, maar de kleine verschillen zijn het grote prijsverschil niet waard.
iRacing Profiel
  • CombatHermit
dengregg schreef op maandag 15 juni 2020 @ 15:00:
Technisch gezien is het wifi probleem met een halve work-around gepatched in Miui release 11.0.8. Helaas is deze nog niet breed beschikbaar. Zelf zit ik op dit moment op release 11.0.2 en bij zoeken naar nieuwe versie is er nog geen beschikbaar.
Natuurlijk kun je bootloader unlocken (met 7 dagen wachttijd), en de beta versie op je machientje zetten, maar weet niet of dat iets is wat je de wederhelft van @hars73 aan wil doen. Ik zag een melding voorbij komen dat een LineageOS met een Pepsy kernel het probleem oplost. (bron: link)
Maar al met al voelt het allemaal nog als hap snap, en geen structurele oplossing. Heb er zelf ook last van, maar het internet heeft denk ik ook wat tijd nodig om te bepalen of dit inderdaad een telefoon is die ze gaan ondersteunen. (ook Curtana / Joyeuse feest helpt niet) Dus LineageOS e.a. versies zijn nog niet beschikbaar waar het misschien al in is opgelost. O-)
  • hars73
CombatHermit schreef op maandag 15 juni 2020 @ 15:54:
Las het inderdaad in een Duits forum... eigenlijk doet ie regelmatig opnieuw een connect naar het wifi netwerk nu. Dus dat is inderdaad een beetje half opgelost....
Zit geen verschil tussen de 9S of de Pro wat dit issue betreft denk ik?
  • CombatHermit
hars73 schreef op maandag 15 juni 2020 @ 15:58:
Helaas, ik heb een Pro (EU) versie die het ook heeft. Bij mij merkte ik op toen mijn webwhatsapp op gegeven moment de telefoon niet meer kon vinden. Het lijkt met een 'deep standby' stand te maken te hebben. Wifi aan/uit, en het werkt weer. Maar goed toch vervelend met de thuiswerkdagen van nu. :)
Volgens mij is het een software ding wat voor de gehele 9 serie lijkt te gelden. Ik zie nu dat de meer 'mainstream' media het nu ook op beginnen te pakken nu dat het allemaal wat langer lijkt te duren om dit issue netjes af te hechten zoals bijvoorbeeld Android Authority.
  • Wildfire
Wildfire
Joy to the world!
Ik zit op MIUI 11.0.8 (Xiaomi.eu ROM) en ik heb geen last van het wifi probleem meer. Wat voor workaround ze ook hebben gedaan, de praktijkervaring voor mij is nu dat wifi niet meer wegvalt.
  • Gandalf68
  • Laatst online: 24-11 17:00
even een vraag mijn zoon wil een note 9 kopen maar hoe zat dat ook al weer met reclame ...
Niet dat hij straks wat verkeerd doet en met een berg ellende opgescheept zit.
En valt de bloatware mee of tegen, ben met intresse dit topic aan het volgen .
  • uroy
Gandalf68 schreef op maandag 15 juni 2020 @ 20:27:
Ik heb de afgelopen weekend de 9S globale versie 11.0.3.0 in huis.
Na de installatie alle apps nagelopen en kwam geen reclame tegen.
Tijdens de setup wel uit vinken als je geen reclame wilt ontvangen
talkin' is cheap, people follow like sheep
  • slaay
slaay
Natuurbeleven.com
uroy schreef op dinsdag 16 juni 2020 @ 14:24:
Waarschijnlijk heb je de EEA versie, de Global versie zit al op 11.0.8.
Pagina: 1 2 ... 8 Laatste
