• Balance
  • Laatst online: 20-10 06:51
Morgen krijgt de wereld de eerste vlucht te zien van de op dit moment grootste operationele raket op planeet Aarde: de SpaceX Falcon Heavy.
Falcon Heavy Test Flight
Afbeeldingslocatie: https://tweakers.net/ext/f/t0gzCr796pnNTj6jIENRfEdZ/full.pngThe first test flight of Falcon Heavy is targeted for Tuesday, Feb. 6th from Launch Complex 39A at Kennedy Space Center in Florida. When Falcon Heavy lifts off, it will be the most powerful operational rocket in the world by a factor of two.
With the ability to lift into orbit nearly 64 metric tons (141,000 lb)---a mass greater than a 737 jetliner loaded with passengers, crew, luggage and fuel--Falcon Heavy can lift more than twice the payload of the next closest operational vehicle, the Delta IV Heavy, at one-third the cost.
Falcon Heavy draws upon the proven heritage and reliability of Falcon 9. Its first stage is composed of three Falcon 9 nine-engine cores whose 27 Merlin engines together generate more than 5 million pounds of thrust at liftoff, equal to approximately eighteen 747 aircraft. Only the Saturn V moon rocket, last flown in 1973, delivered more payload to orbit. Falcon Heavy was designed from the outset to carry humans into space and restores the possibility of flying missions with crew to the Moon or Mars.
You can watch the test flight live below and find out more about the launch in our press kit (PDF, 262 kB).
Lift-off: Dinsdag 6 februari 19:30 20:50 21:15 (window tot 22:30)
Mission Specifications
Static fire completed:January 24th
Payload:Elon's midnight cherry Tesla Roadster
Payload mass:< 1305 kg
Destination orbit:Heliocentric 1 x ~1.5 AU
Vehicle:Falcon Heavy (1st launch of FH)
Cores:B1033.1 (core)
B1023.2 (side)
B1025.2 (side)
Flights of this core:B1023.2: 1, Thaicom 8
B1025.2: 1, CRS-9
Launch site:LC-39A, Kennedy Space Center, Florida
Landing:Yes, all 3 boosters
Landing Site:Side-boosters: LZ-1 & LZ-2
Core-booster: OCISLY, 342km downrange
Afbeeldingslocatie: https://tweakers.net/ext/f/vnpDFwVV29B1sQw83ANNpHFi/full.jpg
Timeline
Afbeeldingslocatie: https://tweakers.net/ext/f/yP818P1S2AUpGCZKexYG3gkt/full.png 00:00:00 Falcon Heavy liftoff
00:01:06 Max Q (moment of peak mechanical stress on the rocket)
00:02:29 Booster engine cutoff (BECO)
00:02:33 Side cores separate from center core
00:02:50 Side cores begin boostback burn
00:03:04 Center core engine shutdown/main engine cutoff (MECO)
00:03:07 Center core and 2nd stage separate
00:03:15 2nd stage engine starts
00:03:24 Center core begins boostback burn
00:03:49 Fairing deployment
00:06:41 Side cores begin entry burn
00:06:47 Center core begins entry burn
00:07:58 Side core landings
00:08:19 Center core landing
00:08:31 2nd stage engine cutoff (SECO-1)
00:28:22 2nd stage engine restarts
00:28:52 2nd stage engine cutoff (SECO-2)
Mission continues on an experimental long coast and third stage two burn to target a precessing Earth-Mars elliptical orbit around the sun
[ Voor 25% gewijzigd door Balance op 06-02-2018 21:14 . Reden: Tijdlijn, Mission Patch en nog wat Specs toegevoegd | Flight-plan toegevoegd ]
  • Balance
Op 5 april 2011 kondigde SpaceX de Falcon Heavy aan. De raket moest de krachtigste raket worden sinds de Saturn V en twee maal zoveel massa in een baan om de aarde krijgen als de op dat moment krachtigste raket, de Delta IV Heavy. Het idee was om simpelweg de succesvolle Falcon 9 te pakken, en daar aan de zijkant twee eerste trappen aan vast te maken. Hierdoor kon de raket op dezelfde basis gebouwd worden als Falcon 9 en moest de ontwikkeling relatief simpel zijn. De raket zou in 2014 zijn eerste vlucht gaan maken. De verbeterde Merlin-motoren zorgen voor de grootste veranderingen, door het hogere vermogen gaat er minder energie verloren aan het overwinnen van de zwaartekracht (TWR neemt toe) en kan de raket meer massa in een baan om de aarde krijgen.
Mass to Orbit (200 km, 28.5 deg):53 metric tons (117,000 lb)
Length:69.2 m (227 ft)
Max Stage Width:5.2 m (17 ft)
Total Width:11.6 meters (38 ft)
Weight at Liftoff:1,400 metric tons or 3.1 million lbs
Thrust on Liftoff:1,700 metric tons or 3.8 million lbs
In de jaren daarna was de Falcon Heavy toch een moeilijker project dan gedacht en is de raket meerdere malen uitgesteld. Ook de uiteindelijke specificaties zijn flink veranderd: de brandstof doorvoer van de buitenste boosters naar de centrum-booster is geschrapt, en de eerste trappen kunnen zichzelf net als bij de Falcon 9 landen.
Uiteindelijk is het na bijna 7 jaar dan eindelijk zover: De Falcon Heavy gaat vliegen. Het bleek toch een veel grotere uitdaging dan gedacht om twee extra boosters aan een Falcon 9 vast te maken, bijna de hele interne structuur van de centrum-booster moest verstevigd worden. De uiteindelijke specificaties zijn nog flink gewijzigd, de ontwikkelingen van de Falcon 9 hebben namelijk ook niet stil gestaan.
Mass to Orbit (LEO):63,8 metric tons
Mass to GTO:26,7 metric tons
Mass to Mars:16,8 metric tons
Mass to Pluto:3,5 metric tons
Length:70 m
Max Total Width:12.2 m
Weight at Liftoff:1,420 metric tons
Thrust on Liftoff:22.819 kN (2326 metric tons)
Op 26 janari 2017 vond de static fire plaats, waarbij alle motoren van de Falcon Heavy tegelijk zijn getest. Dit is de laatste grote test voor de lancering.
In vergelijking met andere raketten is de Falcon Heavy niet bijzonder groot, maar kan wel een gigantische massa in een baan om de aarde krijgen, 2,5 maal zoveel als de Falcon 9 en bijna twee maal zoveel als de Delta IV Heavy. Alleen de Saturn V waarmee we naar de maan zijn geweest was krachtiger, maar deze kostte dan ook meer dan een miljard dollar per lancering (omgerekend naar hedendaagse dollars), terwijl een lancering van de Falcon Heavy ongeveer een tiende van dat bedrag moet gaan kosten.
Afbeeldingslocatie: https://tweakers.net/ext/f/9vcmO7FRALe0OnAQoxLKnYPD/full.png
En dan is het eindelijk zo ver:
[ Voor 158% gewijzigd door Balance op 06-02-2018 13:51 ]
  • MAX3400
  • Laatst online: 23-10 08:51
MAX3400
XBL: OctagonQontrol
Wat een marginale ontwikkeling? Als ik snel lees; de Saturn woog bij ligt-off het dubbele van de Heavy X en kon "maar" 118 metric tons optillen (short range) tot een miserabele 41 metric tons (richting de maan).
Heavy kan maximaal 64 metric optillen dus "pound for pound" is de Saturn nog steeds de meest effectieve raket? Massa & acceleratie & thrust zijn geen lineaire waarden tot Vmax bereikt is.
  • Lau1406
  • Registratie: Juli 2013
  • Laatst online: 22-10 21:07
Lift-off: Maandag 6 februari 19:30 of 22:30
Volgens mij is 6 februari een dinsdag :P
  • DaniëlWW2
DaniëlWW2
Dyslectic history cynic
MAX3400 schreef op maandag 5 februari 2018 @ 15:09:
Ik denk dat het geheim de kennelijk veel lagere kosten zijn. ;)
  • MAX3400
MAX3400
XBL: OctagonQontrol
DaniëlWW2 schreef op maandag 5 februari 2018 @ 15:14:
Oh, ongetwijfeld :) En de snelheid van ontwikkelen / eventueel hergebruik / snellere turnaround. Allemaal zeker weten allemaal voordelen van de SpaceX.
Ik had mijn vorige antwoord moeten nuanceren; we zijn bijna 50 jaar verder sinds Saturn to the moon ging. En toch, op de een of andere manier, lijkt er dus een maximum "thrust per pound" te bestaan? Oftewel, ondanks dat "consumentenvervoer" zoals auto's, vliegtuigen etc. allemaal lijken te profiteren van de wedloop naar groen & zuinig, bereken ik snel een "muur" in de relatieve vermogens van raketmotoren?
  • DaniëlWW2
DaniëlWW2
MAX3400 schreef op maandag 5 februari 2018 @ 15:18:
In principe zijn die raketten allemaal solid of liquid fuel en dan zijn er maar zoveel samenstellingen. Als ik het goed onthouden heb is solid goedkoper en minder krachtig en visa versa. Als je dus een solid fuel raket kan bouwen die ook enorme trust geeft, kan dan je besparen. Het gaat uiteindelijk om de dampkring verlaten, dan kost de meeste energie. :)
  • mphilipp
  • Laatst online: 22:48
mphilipp
Let's noodle!
De vergelijking met de Saturn V gaat op allerlei manieren mank. Totaal verschillende concepten, en verschillende doelen. Uiteraard speelt de voortschreidende techniek ook een rol. De Saturn had echt alle brandstof nodig en werdt gewoon nog bijgetankt terwijl de motoren ontstoken werden. Pas bij liftoff werd die verbinding verbroken.
Maar volgens mij speelt ook een rol dat bij die Falcons de brandstof onder hogere druk opgeslagen wordt. Dat is ook het gevaar. Door die hogere druk heb je meer brandstof zonder extra meters/kilo's raket. En er zullen ook wel hier en daar andere materialen gebruikt zijn die een lichtere draagraket mogelijk maken.
Maar die Saturn V wordt er steeds bij gesleept omdat dat het de allergrootste is. Maar dat is dan ook het enige.
De massa van de Apollo LEM + CSM door Trans-lunar injection waren meer dan 45.000 kg.
De payload capacity van een Falcon Heavy met de side boosteres RTLS en de center core barge landing naar GTO (minder delta-V dan een TLI) is iets over 8000kg. Ter vergelijking, een Atlas-V 551 doet meer naar GTO (!!), vooral door z'n Centaur upper stage.
Ga je de Falcon Heavy expendable vliegen, dan heeft dat een zeer grote impact op de payload capacity, vooral voor high-energie trajectories. Alle nummers in de tabel hierboven zijn voor een fully-expendable Falcon Heavy.
mphilipp schreef op maandag 5 februari 2018 @ 15:42:
De brandstof is vloeibaar... Het verhogen van de druk zal dus niet (of nauwelijks) tot een hogere dichtheid leiden... Wat ze bij SpaceX doen is de vloeibare zuurstof wat subcoolen (tot onder de condensatietemperatuur) zodat de dichtheid daardoor wel iets (procenten) hoger wordt.
[ Voor 21% gewijzigd door Verwijderd op 05-02-2018 15:48 ]
  • mphilipp
mphilipp
Let's noodle!
DaniëlWW2 schreef op maandag 5 februari 2018 @ 15:25:
Maar daar kun je niet meer mee landen. Solid fuel is een vuurpijl: eenmaal aangestoken, blijft ie gaan tot het kruit op is. Met liquid fuel kun je gas geven, minderen, stoppen en weer starten. Veel handiger.
  • mphilipp
mphilipp
Let's noodle!
Verwijderd schreef op maandag 5 februari 2018 @ 15:42:
I stand corrected. Dat was het. Het verhaal is in mijn dementerende brein veranderd... :+ Krijg je op die leeftijd.
  • DaniëlWW2
DaniëlWW2
mphilipp schreef op maandag 5 februari 2018 @ 15:44:
Daarom worden ook meestal solid boosters gebruikt en dan een grote liquid fuel. Maar ik heb me niet bepaald verdiept in deze raket. In ieder geval is deze kennelijk best groot en zou die behoorlijk moeten presteren. :+
  • Balance
Er zijn vier belangrijke eigenschappen die de verhouding tussen de massa van de raket en de massa die in een baan om de aarde kan worden afgeleverd bepalen
  • Specific impulse (Isp) is de tijdsduur gedurende welke 1 kg reactiemassa een stuwkracht kan opwekken van 1 kilogramkracht (9,81 newton). Of ook wel: het aantal newton stuwkracht dat opgewekt kan worden bij een verbruik van 1 kg reactiemassa per seconde. De eenheid is in het eerste geval seconde, en in het tweede geval wordt de grootheid vermenigvuldigd met g, en is dan in m/s, de effectieve uitstootsnelheid (effective exhaust velocity). (Wiki)
  • Thrust-to-weight ratio (TWR) is de verhouding tussen de stuwkracht en het gewicht van de raket. Hoe hoger deze ratio, hoe sneller de raket in een baan om de aarde kan raken en hoe minder lang er dus tegen de zwaartekracht gevochten hoeft te worden. Vooral bij lift-off is een hoge TWR belangrijk, omdat de raket dan nog helemaal vol met brandstof zit en dus zwaar is.
  • Propellant mass fraction is de verhouding tussen het gewicht van de brandstof tegenover het gewicht van de raket. Hoe minder zwaar raket zelf is, hoe minder brandstof er gebruikt hoeft te worden om de raket zelf op snelheid te brengen.
  • Staging. Dit is iets complexer, de hoeveelheid stages hebben voornamelijk invloed op de hoeveelheid loos gewicht die je in bepaalden fases van de missie meesjouwt. Meer stages verhoogt de massa aan het begin van je vlucht (dus lagere propellant mass fraction), maar verhoogt die juist weer op het moment dat je een lege stage laat wegvallen.
Het eerste punt is niet heel erg verbeterd, de Saturn V had een Isp van 304 s (vacuum) tot 263 s (zeeniveau). Bij de Falcon 9 ligt dit iets hoger, maar ook weer niet heel schokkend met 311 s (vacuum) tot 282 s (zeeniveau).
De TWR is wel veel hoger, bij de Saturn V was dit 1,15, maar bij de Falcon Heavy gaat dit over de 1,5. Dit betekend dat bij de Saturn V op het moment van lift-off slechts 13% van de brandstof aan het versnellen krijgen van de raket wordt besteed (de rest gaat verloren aan zwaartekracht), terwijl bij de Falcon Heavy dit 33% is.
Propellant mass-ratio en staging zijn moeilijker te bepalen en zijn ook missie afhankelijk: Saturn V specifiek gemaakt voor maanmissies met één specifieke payload terwijl Falcon Heavy veel flexibeler moet zijn om naar LEO, GTO, de maan en Mars te kunnen.
RocketMass (lift-off)Mass to LEORatio
Delta IV Heavy733 t28,8 t3,93%
Falcon 9549 t22,8 t4,15%
Falcon Heavy1420 t63,8 t4,49%
Saturn V2970 t140 t4,71%
[ Voor 4% gewijzigd door Balance op 05-02-2018 16:30 ]
Balance schreef op maandag 5 februari 2018 @ 16:22:Saturn V specifiek gemaakt voor maanmissies met één specifieke payload terwijl Falcon Heavy veel flexibeler moet zijn om naar LEO, GTO, de maan en Mars te kunnen.
Uiteindelijk had (en was het plan) de SaturnV natuurlijk net zo goed voor andere dingen gebruikt kunnen worden. De minimale performance moest natuurlijk zijn om de Apollo stack naar de maan te krijgen, maar er zal nog behoorlijk wat 'groei' in de Saturn V. Upgrades aan de motoren "F-1A" en "J-2S" die gebruikt moesten worden voor de 1e en 2e trap in het post-Apollo tijdperk, en de Nerva nucleaire motor voor de 3e trap, die alle 3 vrijwel flight-ready (zelfs al gekwalificeerd voor flight) waren. Verder was er nog een complete range aan varianten voorgesteld, tot varianten met solid-boosters aan toe.
Hier de laatste lancering (2-traps variant) van de Saturn V, die Skylab naar LEO bracht:
Afbeeldingslocatie: https://www.armaghplanet.com/blog/wp-content/uploads/2013/05/image-of-Skylab-launch.jpg
Blijft altijd een enorme "what if" het Apollo-applications programma uitgevoerd zou zijn en de Apollo hardware doorontwikkeld zou zijn, in plaats van de Shuttle. Het uiteindelijke doel daarvan was om in de jaren 80 op Mars te staan, en een groot deel van de hardware daarvoor was dus al in ontwikkeling...
[ Voor 4% gewijzigd door Verwijderd op 05-02-2018 16:37 ]
Bensimpel
Positieve meneer
Even dit ook hier posten, prachtig gemaakt dit.
[ Voor 18% gewijzigd door Bensimpel op 05-02-2018 19:35 ]
😆 - Denk ook eens om ;)
  • Balance
@Shadow Klopt, zeker waar. Het zou zeer interessant zijn als het zeer dure maar succesvolle programma was doorgezet.
Nog precies 24 uur! We zijn er dan eindelijk echt bijna! *O*
Er is ook een artikel op de front-page verschenen:
[ Voor 23% gewijzigd door Balance op 05-02-2018 19:36 ]
  • onok
  • Laatst online: 15-10 20:38
It's happening! :D
  • relinquir
  • Laatst online: 09-10 15:34
Is het verschil in maximum payload weight van de Falcon Heavy vergeleken met de Saturn V niet te groot om ook een bemande missie naar Mars te doen? De maximum payload weight for mars orbit van de Falcon Heavy is 16.800 kg. Ik ben benieuwd of dat genoeg is om een bemande missie te doen. Ik heb even geen referentie met het gewicht van andere landers.
  • Balance
@relinquir Het is veel en veel te laag. Een Mars flyby zou wellicht nog kunnen, maar heel veel meer dan dat wordt het niet. Het is natuurlijk wel genoeg om best wel serieuze landers en rovers op Mars te zetten. Curiosity is met de Atlas V-raket op Mars gezet, die ongeveer even krachtig is als Falcon 9.
Het grootste probleem is niet daar komen en daar landen, maar dan weer lanceren, in een Mars-orbit komen, terug naar de Aarde, afremmen en weer landen. En al die zooi die je daar voor nodig hebt moet je ook op de heenweg meezeulen.
  • beantherio
  • Laatst online: 07-07 16:59
Wat voor "sonic boom" gaat er wel niet ontstaan als ze twee trappen gelijktijdig landen op vrij dichte afstand van elkaar? Ik zou nog even m'n glasverzekering controleren als ik aan de oostkant van Florida woonde. :)
  • Balance
Oh en ik ben nog iets vergeten te zeggen
ALL ABOARD THE HYPE TRAIN!!!!111!!1! *O*
[Vimeo: https://vimeo.com/125746164]
Afbeeldingslocatie: https://i.imgur.com/rH9S0Rk.jpg
  • mphilipp
mphilipp
Let's noodle!
Balance schreef op maandag 5 februari 2018 @ 20:21:
Is het grote probleem daarmee niet dat je eigenlijk niet meer terug kan? Je gaat naar Mars als ie op het moment van aankomst het dichtst bij de Aarde staat, anders moet je te ver vliegen. Als je eenmaal daar bent en gaat landen en je ding doen, de terugweg steeds langer wordt. Vandaar dat je (geloof ik) een jaar of twee moet blijven en dan terug. Maar ja...dan moeten we eerst nóg krachtiger raketten maken, want je kunt al die brandstof niet meenemen. Of andere brandstof, een manier om brandstof daar te maken of nog iets slimmers.
Meer brandstof meenemen is volgens mij eigenlijk geen optie, omdat je raket dan weer groter wordt, wat ook weer meer brandstof kost....een soort cirkeltje dus.
Bensimpel
Positieve meneer
mphilipp schreef op maandag 5 februari 2018 @ 22:00:
Eerst robots meenemen die al een soort van basis kunnen maken misschien. Ik zal gewoon zoveel mogelijk spul daar parkeren. (voor toekomstige mensen) En op den duur gewoon brandstof lokaal maken om terug te gaan.
  • mphilipp
mphilipp
Let's noodle!
Dat klinkt als het plan van Mars One... Behalve de brandstof daar maken dan.
  • SalimRMAF
SalimRMAF
SpaceX - 4K
Zou wat zijn als het misgaat. De eerste launch van een nieuw centerframe... :D
Gulfstream G650
  • Erazzzer
Erazzzer
Fear me, I'm German!
Was een apart topic eigenlijk nodig? Ik bedoel, in het ruimtevaart topic is dit op het moment toch alleen maar het enige thema...
  • Balance
@Erazzzer Ik verwacht dat op het moment van de lancering en vlak erna dit een slow-chat topic wordt. Zo blijft het ruimtevaart-topic enigszins netjes en blijft dit event tevens mooi bewaard. Bovendien heb je nu een topic-start met wat extra informatie.
Er is trouwens ook een poll gemaakt door @matroosoft :)
Poll: Tweakers progressieverwachtingen van Zware Valk
• Boem @ T minus zero
• Boem @ side core sep.
• Boem @ landing
• Moet wel lukken
• Wat een gedoe over een beetje CGI
Tussenstand:
Afbeeldingslocatie: http://poll.dezeserver.nl/results.cgi?pid=400014&layout=6&sort=prc
Ook een poll maken? Klik hier
  • Balance
Wat interessante informatie uit de persconferentie verzameld op Reddit:
After the first successful FH flight SpaceX will start flying commercial payloads on it. A new capability of the FH is the fact it can put payloads directly into GEO, with a 6 hour coast period that they will be testing tomorrow. This will mean going though the Van Allen Belts.
It also looks like there won't be any crewed dragon flights using FH for quite some, meaning no moon missions. As appose to human rating the FH, they have focused their efforts more so on BFR, which Elon says is coming along quickly, however he did state that if BFR development has issues/starts taking longer than expected, they will start looking at human rating the FH.
If all goes well tomorrow, we will see another FH launch within 3-6 months, and will be all block 5. On the other hand, if the rocket blows up on the pad it will take at least 9-12 months to restore it. However this wont affect F9 as this can still launch from SLC-40 on the East coast.
Looks like Elon also hinded at a Falcon Super Heavy with 4 side cores, but I hightly doubt that will ever happen. Also he says there are 3 cameras on the Roadster which should provide us with some epic shots. Does anyone know how long we will be getting footage from them for?
Sources
  • nieksvd
  • Registratie: Maart 2017
  • Laatst online: 11-10 14:08
Misschien heb ik niet goed gelezen, maar is er ergens een livestream o.i.d. te vinden van de lancering?
  • rvankruistum
  • Laatst online: 28-08 11:42
nieksvd schreef op dinsdag 6 februari 2018 @ 07:27:
http://www.spacex.com/webcast
  • anandus
Balance schreef op maandag 5 februari 2018 @ 15:00:
Lift-off: Dinsdag 6 februari 19:30 of 22:30
Is het een launch window of zijn het echt twee launchtijden?
Kan ik tussendoor nog iets anders doen, zeg maar? :)
Enorm onder de indruk van de payload-waardes, trouwens, zeker t.o.v. een Delta 4 Heavy.
Wat een inefficiënte machine is dat :P
Al zeg ik misschien iets heel doms, moet de discussie hierboven nog even doorlezen ;)
  • Flotter
  • Laatst online: 23-10 13:15
Flotter
Pelipper!
anandus schreef op dinsdag 6 februari 2018 @ 07:49:
Dat is een lanceertijd en en foutje. Bij de SpaceX livestream op YouTube stond blijkbaar een tijd van 22:30 uur, maar dat is al gecorrigeerd naar 19:30 uur.
Launch window is tussen 19:30 uur en 22:00 uur (alle genoemde tijden CET).
PSN ID: Flotmeister | Steam ID: Flotter
  • almightyarjen
  • Laatst online: 22:47
almightyarjen
When does the hurting stop?
Spannend.. :D
  • Bozevkwa
  • Laatst online: 15:03
Bozevkwa
The Falcons have landed
Ik zie er erg naar uit. Lijkt mij geweldig om te zien hoe twee boosters gelijktijdig gaan landen op de Cape :)
"What day is it?" asked Pooh. "It's today" squeaked Piglet. "My favorite day" said Pooh.
  • Semyon
  • Laatst online: 22:04
x
Balance schreef op dinsdag 6 februari 2018 @ 00:09:
@Erazzzer
• Boem @ landing
• Moet wel lukken
Tussenstand:
Elon Musk zelf denkt dat hij een 50% 50% kans heeft, al zegt hij dat het voelt als 66% 33% omdat hij een optimist is.
Only when it is dark enough, can you see the stars
  • Playa del C.
  • Laatst online: 20:36
Flotter gaf al antwoord over de launchtijden. Mijn plan: vanaf 19:00 klaarzitten met live streams. Vanaf 19:30 kan de launch beginnen, maar zoals bij elke launch, het kan uitgesteld of zelfs gecanceld worden, dus verder is er niks te plannen. Het hele event zal zo'n half uur duren. Dus in het beste scenario is alles om 20:00 klaar.
De Delta IV Heavy heeft een ander ontwerp, iets ander doel en er wordt een andere soort brandstof gebruikt. De getallen die je vergelijkt gaan over een bepaald doel, zoals LEO (low earth orbit). Dus een raket die specifiek ontworpen is om payload een stuk verder te brengen, zal op bepaalde cijfers slechter of beter scoren.
Hoe dan ook is de Falcon Heavy voor nu een behoorlijk efficiënte raket, vooral als je naar de kosten kijkt. De Delta IV Heavy is op zich prima, maar drie keer duurder.
De Falcon Heavy moet trouwens eerst nog veilig vliegen...
  • Fugitive2008
  • Laatst online: 19-10 17:01
Wauw dit is echt zo een ambitieus project ik wil gewoon dat t lukt maar er zit een grote duivel op mijn schouder die zegt dat het nooit zal lukken aangezien er zoveel dingen fout kunnen gaan bij het minste of geringste. Als engineer durf je toch bijna niet te kijken die launch...te spannend! Echt hoop zo dat het lukt!!
  • Playa del C.
@Fugitive2008 Als het nu mislukt, dan betekent het alleen dat alle komende projecten iets opschuiven. Als je als huidige 'einddoel' de kolonisatie van Mars neemt, dan kan dat succesvol plaatsvinden tussen 2025 en ~2100. Zolang de mensheid zich op aarde enigszins weet te gedragen, is het vrijwel zeker dat Mars bewoond gaat worden door ons.
Velen zullen er bekend mee zijn, maar alle lezers hier die huidige ontwikkelingen in de ruimtevaart boeiend vinden: probeer eens Kerbal Space Program. Een 'serieuze' simulatie waarin alle aspecten van huidige en toekomstige ruimtevaart naar voren komen.
  • KipCurreh
  • Laatst online: 23-10 15:17
KipCurreh
Nightcrawler
Is wel een tijd geleden dat ik zo hyped was voor een lancering :)
Jammer genoeg zal ik ze niet live kunnen volgen, tenzij ze later dan 21.30 plaatsvindt..
Steam | Ryzen 7 3700X Sapphire Pulse RX7900 GRE 16GB Asus Prime X470 Pro
  • Fugitive2008
@Playa del C. Ja snap je punt. Het is natuurlijk ook een gigantisch leer moment zo een grote raket bouwen voor een bedrijf mocht het fout gaan dan kun je van de fouten leren en het wss niet nog een tweede keer laten gebeuren. Toch maar eens kerbal kopen op steam.
  • loewie1984
  • Laatst online: 21:43
Idd helemaal leip van wat er vanavond gaat gebeuren. Ik hoop dat het ze gaat lukken. Hats off als alles goed gaat.
discogs
Bensimpel
Positieve meneer
Fugitive2008 schreef op dinsdag 6 februari 2018 @ 09:16:
Klopt, maar alsnog blijft het echte rocketscience
1. gaan alle motoren tegelijkertijd af?
2. hebben alle motoren dezelfde thrust?
3. gaat die wel omhoog?
4. vliegt die wel de goede kant op?
5. ontkoppelen beide falcon 9's op de juiste hoogte en tegelijkertijd?
6. haalt de core de juiste hoogte?
7. werkt de ontkoppeling tussen core en staging?
8. werkt de faring goed?
9. land alles weer netjes op zijn pootjes zoals we gewend zijn?
Alles moet echt gewoon precies kloppen, billenknijpen dus! :D
  • Balance
Ik denk dat het grootste risico nog wel de interactie tussen de cores is. Er komt natuurlijk enorme stuw en aerodynamische krachten op de raketten kijken, die stiekem best wel flexibel zijn (zo dun mogelijk om gewicht te besparen). Als een core besluit iets te ver door te buigen en dus een andere kant op te gaan...
  • Fugitive2008
Ja toen ik in de animatie zag welke stappen de onderdelen van de raket gaan doorlopen ist behoorlijke wat. maar goed de knappe koppen bij SpaceX die verzinnen daar wel wat op.
  • almightyarjen
almightyarjen
Balance schreef op dinsdag 6 februari 2018 @ 09:36:
Mee eens, maar ik neem aan dat ze dit ook wel als simulatie gedraaid hebben?
  • Balance
@almightyarjen Klopt, maar simulatie ≠ echte wereld.
Ik gok dat van lift-off tot MaxQ en de ontkoppeling van de side-boosters de meest spannende momenten worden.
  • Sand0rf
  • Laatst online: 20:47
Ja kan simuleren tot je een ons weegt maar de praktijk zal moeten uitwijzen of het ook daadwerkelijk werkt. Ik had ergens gelezen dat die boosters zover kunnen flexxen dat ze elkaar kunnen raken... Ik wacht met spanning af, als booster seperation succesvol is dan denk dat de missie een succes wordt maar ik geeft het, net als Elon, een 50/50 kans
/post
  • coelho
  • Laatst online: 24-09 10:10
Is MaxQ nu het meest kritische punt?
Ik ben een ontzettende liefhebber maar geen technicus. Kan iemand mij uitleggen hoe verschil in thrust een issue kan worden? Door de cores te koppelen mag het toch natuurkundig gezien worden als één object? Mijn auto gaat toch ook niet scheuren als mijn linkervoorwiel iets minder kracht levert als mijn rechtervoorwiel? Hooguit trekt hij wat schuin, maar dat is met relatief weinig stuurcorrectie wel te regelen.
Of is dit exact het issue, niet zo zeer de kans dat het uit elkaar scheurt maar wel dat de baan verlaten wordt en de raket dus onbestuurbaar wordt?
PVoutput 7.700Wp ZZO (50°)
  • DaniëlWW2
DaniëlWW2
* DaniëlWW2 weet niet of hij liever een geslaagde lancering of een ontploffende Tesla Roadster ziet. O-)
  • almightyarjen
almightyarjen
coelho schreef op dinsdag 6 februari 2018 @ 10:15:
Er komen dusdanig grote krachten vrij dat het de vraag is of de koppeling die de drie cores bij elkaar houdt wel sterk genoeg is.
  • Tallguy
Tallguy
There is no place like 127.0.0
@coelho MaxQ is het punt waarbij de aerodynamische krachten het meest op de raket inspelen. Om die reden hanteren ze bij de ruimtevaart (de lanceringen) vrijwel altijd (denk dat het iig geldt voor lanceringen met mensen en satellieten) dat ze rond dat punt de motoren wat 'terugschroeven' om iets minder snel door die zonde te gaan om daarmee de druk wat lager te houden.
Als je kijkt naar de lanceringen van bijv de Space Shuttle, deden ze op dat punt ook altijd een zgn throttle back.
specs | 3360wP met SE3000
  • Balance
@coelho Deze video, en dan drie keer :P.
Als je nog nooit een lancering van SpaceX hebt gezien, is het leuk om er alvast eentje te kijken. Dan heb je een wat beter beeld van wat er gaat gebeuren :).
[ Voor 9% gewijzigd door Balance op 06-02-2018 11:30 ]
  • coelho
Super! Bedankt.
  • mphilipp
mphilipp
Let's noodle!
Wat dat betreft moet er eigenlijk van alles fout gaan. Niet uit leedvermaak of cynisme, maar het doel van een test/demolancering is juist om te kijken of alle berekeningen en aannames kloppen. Als er iets niet goed is, moet je het zo snel mogelijk weten. "Dankzij" het ongeluk met Apollo 1 op de pad weten we dat het niet slim is om in 100% zuurstof te werken (vooral niet als je funky bedrading hebt). De Russen weten dat ook (vergelijkbaar incident).
Je durft er niet over na te denken als dat pas bij Apollo 11 was gebeurt...
Het zou dus niet goed zijn als alle testen goed gaan, terwijl er ergens nog een bug ligt te wachten op de samenkomst van de 'juiste' omstandigheden om op te treden.
Maar ik hoop natuurlijk op een glorieuze lancering en succesvolle landing van alle 3 trappen. Alleen Musk weet natuurlijk dat ie er daarmee nog lang niet is.
  • Balance
En er is nog een tweede probleem. Aan het begin van de lancering draaien de side-boosters op volle kracht. De core-booster draait naarmate de vlucht vordert wat langzamer om brandstof te bewaren voor wanneer de side-boosters loskoppelen. Het gewicht van de core-booster + eerste trap + lading is echter hoger dan het gewicht van een side-booster. De side boosters hebben dus minder gewicht maar meer stuwkracht waardoor er energie (en dus snelheid) wordt overgedragen vanuit de side-booster naar de centrum-booster, wat exact het idee is van een booster.
Afbeeldingslocatie: https://tweakers.net/ext/f/Eqx9AZDu86xyYFXNc7ryvSSS/full.png
Let op: Blauw open pijlen geven beweging aan, terwijl de dichte gekleurde peilen kracht aangeven die op het voertuig wordt uitgeoefend. Rood is stuwkracht, blauw is zwaartekracht, groen zijn de krachten die de centrum-booster uitoefent.
Nu komen daar echter twee uitdagingen bij kijken. Ten eerste is het behoorlijk wat energie die vanuit de de side-boosters naar de centrum-booster moet, waardoor hoge krachten in de lengterichting ontstaan. De verbindingen moeten dus sterk genoeg zijn om die kracht aan te kunnen.
De tweede en echte uitdaging is dat de voortstuwing van de side-booster (rode pijl) niet in een lijn ligt met de plek waar de energie wordt overgedragen naar de centrum-booster. Hier zit een klein verschil tussen, wat er voor zorgt dat de booster niet alleen omhoog wil maar ook langzaam naar binnen wil draaien (tweede afbeelding). Om de side-booster recht te houden moet de centrum-booster dus ook kracht uitoefenen in zijwaartse richting op de side-booster, anders gaat deze draaien (derde afbeelding). En deze krachten zijn heel naar, hier is zo'n raket namelijk helemaal niet voor gemaakt.
Pak eens een keuken- of toiletrol. Zet hem rechtop en probeer hem van bovenaf in te drukken. Dit zal best moeilijk gaan en kost dus flink wat kracht. Hier is een raket voor gemaakt, deze kracht in de lengterichting kan hij prima aan.
Leg die keukenrol nu op zijn kant en probeer de zijkant in te drukken. Dit gaat veel makkelijker, er is dus veel minder kracht voor nodig. Dit is precies het probleem met onze raket: Hij is niet gemaakt om zijwaartse krachten op te vangen.
  • XWB
XWB
Devver
relinquir schreef op maandag 5 februari 2018 @ 20:11:
Ter referentie, Apollo capsule + service module + maanlander was > 40 ton. En dan hebben we het over een spacecraft dat 3 mensen in een piepkleine ruimte een week lang in leven moest houden. De requirements voor Mars zijn zoveel groter en dan ga je al snel richting 100 ton payload, als het niet meer is. Niet alleen heb je hiervoor een ontzettend grote raket nodig, er is ook een krachtige second stage nodig die de payload richting Mars kan schieten.
March of the Eagles
  • Balance
  • Spooksel
  • Laatst online: 08:09
Man man man... ik ben zo hyper als een Duracel konijn :X
Bevalt mijn schrijfsel je niet? www.korrelatie.nl
  • Balance
Ik krijg vandaag ook echt niks meer gedaan :P.
  • relinquir
@XWB bedankt voor de informatie. Los van de fysieke kracht is ook het menselijk aspect van zijn reis niet onbelangrijk. Zo'n reis naar Mars duurt vrij lang en er kan van alles gebeuren. Ziekte, ruzie noem maar op. Om al niet te vergeten wat zo'n lange tijd gewichtloosheid met je doet. De faciliteiten die een astronaut op het ISS heeft zullen waarschijnlijk niet aanwezig.
Straling is ook een probleem. In een meet en Greet met André Kuipers zei dat hij de straling fysiek kon zien. Als een stralingsdeeltje zijn oog binnendrong zag hij dat als een soort lichtstreep die kortstondig over zijn zocht trok.
On-topic: Falcon-heavy zal geen mensen naar Mars sturen, maar het is wel eindelijk weer een stap vooruit sinds de space race is afgelopen!
  • almightyarjen
almightyarjen
Falcon Heavy geldt inmiddels ook als opstapje naar de BFR, welke wel bemande missies naar Mars kan doen.
  • anandus
Is de BFR niet een heel ander ontwerp, dan?
Of gewoon een hele grote Falcon? :P
[ Voor 30% gewijzigd door anandus op 06-02-2018 12:44 ]
  • Balance
@relinquir Dit is tevens de eerste missie waarbij direct in GEO gelanceerd wordt. Dat betekend dat de bovenste trap na 6 uur opnieuw opgestart moet worden voor een derde burn, terwijl het net uren blootgesteld is aan radiatie en vriestemperaturen. Dus dat wordt ook een leuke uitdaging! (zie ook: Ars Technica)
Afbeeldingslocatie: https://tweakers.net/ext/f/p04pfCmwxZU6Xo04Gogis36v/full.jpg
De schaal van dit ding blijft ook echt bizar. 70 meter hoog is moeilijk voor te stellen, maar dit geeft wel een aardig beeld!
  • loewie1984
Misschien een 'domme' vraag, maar zou de mensheid in staat zijn mits het technologisch lukt een raket te bouwen met zulke stuwkracht dat deze de aarde uit zijn baan zou kunnen duwen? Bedoel uiteindelijk waar twee objecten van elkaar bewegen speelt massa een rol welk object van het andere object weg beweegt.
Nu is het gewicht van de aarde 5,972E24 kg dus zal het zo'n vaart niet lopen, maar bij een komeet / meteoriet inslag van enkele tientallen meters komt ook al zeer veel energie vrij.
discogs
  • Spooksel
Misschien is deze video wat voor je? :)
  • onok
Technisch onmogelijk weet ik niet, maar waarom zou je het willen? :P De aarde uit z'n baan duwen lijkt me een vrij slecht idee :P
Spooksel schreef op dinsdag 6 februari 2018 @ 12:36:
Ik was al bang dat ik de enige was :P
[ Voor 45% gewijzigd door onok op 06-02-2018 12:53 ]
  • loewie1984
onok schreef op dinsdag 6 februari 2018 @ 12:52:
Zodat we mars in de baan van aarde kunnen duwen voor een beter klimaat als het eenmaal gekoloniseerd is :P
discogs
  • onok
loewie1984 schreef op dinsdag 6 februari 2018 @ 12:53:
Heh, geen slecht idee :P
  • Joao
  • Laatst online: 29-06 18:31
Kan iemand aub live-stream link posten. Kan het niet vinden, wellicht omdat het nog niet LIVE is.
  • Spooksel
Of: http://spacex.com/webcast
[ Voor 22% gewijzigd door Spooksel op 06-02-2018 12:57 ]
  • Balance
@Joao @Spooksel Hij staat gewoon in de topic-start...
  • XWB
XWB
Devver
Balance schreef op dinsdag 6 februari 2018 @ 12:47:
En dat is dan weer klein bier vergeleken met wat BFR moet worden :p
Afbeeldingslocatie: https://imagr.eu/up/ALvE7_Screenshot_from_2018-01-05_11-48-46.png
Afbeeldingslocatie: https://imagr.eu/up/QDcFL_BFR-house-768x2384.jpg
[ Voor 6% gewijzigd door XWB op 06-02-2018 13:31 ]
March of the Eagles
  • Balance
@XWB Klopt, dat ding is inderdaad bizar. Je tweede afbeelding is wel van de orginele BFR, de nieuwe is iets kleiner.
En als je een afbeelding van Wait But Why? gebruikt moet je daar natuurlijk wel naar linken...
Animatie: [OC] Falcon Heavy vs Various Rockets (requested)
Anyway: Matt Lowne is weer een totale eindbaas _/-\o_
Ik heb de topic-start trouwens geupdate met de Mission Patch en de Timeline. Shit gaat heel snel achter elkaar gebeuren (als het niet boem doet), dus kijk hem alvast goed door zodat je niks mist :).
[ Voor 24% gewijzigd door Balance op 06-02-2018 13:53 ]
  • Balance
Voor iedereen die een half uurtje tijd heeft:
  • Oosting
  • Registratie: Januari 2017
  • Laatst online: 20:11
Hoe laat begint de webcast eigenlijk? Dan doel ik niet op de lanceringstijd van 1930, maar hoeveel tijd beginnen de hosts te praten?
  • CrystalViriS
  • Laatst online: 21:55
Ik droomde vannacht dat minuten voor lancering, ik binnen liep bij mijn oma omdat ik er nog eff snel op bezoek ging en Elon (jaja) aan het helpen was met het uitboenen van de keukenkastjes. En ik dacht: "keh? Wat doet hij hier? Hij vindt het schijnbaar zelf niet zo'n big deal ofzo".
Lol...
  • jip_86
  • Laatst online: 11:14
Oosting schreef op dinsdag 6 februari 2018 @ 14:56:
Live over 4u staat er nu (15:00) staat er nu als je de stream start. Vermoedelijk dus 19:00. Normaal iets van een kwartier vooraf ofzo, maar zullen er nu wel iets grotere show van maken :)
  • XWB
XWB
Devver
CrystalViriS schreef op dinsdag 6 februari 2018 @ 14:59:
Lol...
8)7
Weet je zeker dat je gedroomd had, en niet aan één of andere gekke paddo naar binnengewerkt hebt? :p
March of the Eagles
  • CrystalViriS
XWB schreef op dinsdag 6 februari 2018 @ 15:03:
8)7
Nope, geen gekke paddo. Ik droom wel vaker eigenaardige dingen. :P
  • Felyrion
  • Laatst online: 23-10 23:46
Felyrion
goodgoan!
volgens de persconferentie hierboven starten ze ongeveer 20min voor de lancering met de actieve cast. stream zal dan wel rond 19u live gaan.
sleep: a completely inadequate substitute for caffeine
  • yorkick
  • Laatst online: 21:12
Lol...
Misschien teveel TBBT gekeken?
kimi
  • CrystalViriS
yorkick schreef op dinsdag 6 februari 2018 @ 16:19:
[video]
Gehehe dat heb ik wel ooit gezien ja. _/-\o_
  • diotav
  • Laatst online: 23:40
Grote vuurwerkshow of mijlpaal, dit gaat een spectaculaire launch worden. :*)
dion.dev
  • TweakTom92
  • Laatst online: 20:20
https://twitter.com/SpaceX/status/960910705808609280
O+
"All systems remain go for today’s test flight of Falcon Heavy. Weather is 90% favorable for today’s two-and-a-half hour launch window, which opens at 1:30 p.m. EST, or 18:30 UTC."
[ Voor 59% gewijzigd door TweakTom92 op 06-02-2018 17:23 ]
  • XWB
XWB
Devver
Delay van 30 minuten:
The countdown clock has been reset to target liftoff at 2 p.m. EST (1900 GMT). No word on the cause for this 30-minute delay.
The launch window extends until 4 p.m. EST (2100 GMT).
March of the Eagles
  • rednax70
Sources indicate the 30-minute delay will allow SpaceX to wait for improved upper level winds.
  • Erazzzer
Erazzzer
20 minuten extra delay. ScrubX is coming!
  • CrystalViriS
Tja, maak het nog spannender... haha.
  • Qu3st
  • Registratie: Juli 2015
  • Laatst online: 22:10
Qu3st
#36
Elon Musk:
Upper atmosphere winds currently 20% above max allowable load. Holding for an hour to allow winds to diminish. #FalconHeavy
  • matroosoft
  • Laatst online: 10:51
matroosoft
Lone Christian
Ik zag de tweet idd.. Hopen dat het weer afneemt..
  • Bullet NL
  • Laatst online: 22-10 08:04
Bullet NL
Eigen Wijs
Even om rekenen, i.p.v. 19:30 gaat hij nu om 20:30 omhoog?
  • Qu3st
Qu3st
#36
Bullet NL schreef op dinsdag 6 februari 2018 @ 18:14:
Goed gerekend ;)
  • Oosting
Dan heeft het bier wat langer de tijd koud te worden!
  • coelho
19.30 + 30 min delay + 20 min extra delay is bij mij toch 20.20 ;)
Kunnen we daarvoor mooi met z'n allen nog even GTST kijken :+
  • Qu3st
Qu3st
#36
coelho schreef op dinsdag 6 februari 2018 @ 18:17:
But but but, "holding for an hour" is 60 minuten wat weer bij mij 20.30 is :p
  • Tk55
De livestream op YouTube krijgt er elke paar minuten een paar duizend wachtende kijkers bij :P
Misschien de livestream linken in de topic waarschuwing?
YouTube: Falcon Heavy Test Flight
  • CrystalViriS
Verwijderd schreef op dinsdag 6 februari 2018 @ 18:17:
:+ Dat moet Elon ook gedacht hebben...
  • rednax70
SpaceX has set a new launch time of no earlier than 2:50 p.m. EST (1950 GMT) to give teams more time to assess upper level winds.
  • XWB
XWB
Devver
Ondertussen kunnen we even van het geplande vluchtprofiel genieten :p
Afbeeldingslocatie: https://imagr.eu/up/bKmOn_DVXbp4NUMAAdXcA.jpg
[ Voor 12% gewijzigd door XWB op 06-02-2018 18:27 ]
March of the Eagles
Pagina: 1 2 ... 16 Laatste
Voor algemene discussies over ruimtevaart hebben we dit topic: Ontwikkelingen in de ruimtevaart - Deel II
