• Dragunov
  • Laatst online: 02-11 15:13
Mede-auteurs:
  • tiguan
  • Laatst online: 00:15
tiguan
  • spartacusNLD
  • Laatst online: 09-11 17:29
spartacusNLD
Afbeeldingslocatie: https://static.tweakers.net/ext/f/IGAR3BjZ3ES7JGmiYoBPlnWh/full.png
Welkom bij het Windows 10 Preview Topic! Dit topic is alleen bedoeld voor de Insider Preview versies van Windows 10. Weet je niet wat Insider Preview is, of heb je geen idee welke build van Windows 10 je draait? Dan moet je hier waarschijnlijk niet zijn..... :+
Vanaf heden worden de builds via UUP geleverd, meer informatie hier.
Huidige builds
Fast: 17004
Slow: 14965
Inhoudsopgave
Afbeeldingslocatie: https://static.tweakers.net/ext/f/kZyLgyHCn2BRCHwpfsljP0hJ/full.png
De volgende issues zijn bekend voor de Fast Ring met Build 15007.
  • After updating to this build, nonstop exceptions in the Spectrum.exe service may occur causing PCs to lose audio, disk I/O usage to become very high, and apps like Microsoft Edge to become unresponsive when doing certain actions. As a workaround to get out of this state, you can delete C:\ProgramData\Microsoft\Spectrum\PersistedSpatialAnchors and reboot. For more details, see this forum post.
  • We are investigating certain situations in which PCs might bugcheck (GSOD) during the installation of new builds (15002+) causing the PC to rollback to the previous build.
  • When clicking on certain elements in desktop (Win32) games, the game minimizes and cannot be restored.
  • Desktop shortcuts containing the “%” character (usually URI shortcuts with escaped characters) will result in a cyclical explorer.exe crash. To resolve this, use Task Manager to open PowerShell, and edit the shortcut to not include a % in the path.
  • When projecting to a secondary monitor, if you set the connection to “Extended”, Explorer.exe may start crashing in a loop. If this happens, turn off your PC, disconnect the secondary monitor, then restart your PC.
  • Windows Insiders will unexpected see a “Holographic” entry on the main page of Settings.
  • Brightness changes made via Settings > System > Display will unexpectedly revert after closing the Settings app. For now, please use either Action Center, power flyout or brightness keys to change the brightness.
  • The list of apps in the Surface Dial “Add an app” page via Settings > Devices > Wheel may unexpectedly be empty. If that happens, tap the “Browse for an app” button at the bottom of the screen to pick the desired app instead.
  • Taskbar preview icons are unexpectedly small on high-DPI devices.
  • Quicken will fail to run with an error stating .NET 4.6.1 is not installed. For Insiders familiar with Registry Editor, there is an optional workaround. Take ownership of the following registry keys and edit the “version” value to be 4.6.XXXXX instead of 4.7.XXXXX:
  • [center]
  • HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\Microsoft\NET Framework Setup\NDP\v4\Client
  • ​HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\Microsoft\NET Framework Setup\NDP\v4\Full
  • [/center] [b]Note:[/b] Please take caution when editing the registry. Changing the wrong value can have unexpected and undesirable results.[/li]
  • Using CTRL + C to copy in Command Prompt won’t work.
  • Some websites in Microsoft Edge may unexpectedly show “We can’t reach this page”. If you encounter this, please try accessing the site from an InPrivate tab.
  • Dragging apps from the all apps list to pin on Start’s tile grid won’t work. For now, please right-click on the desired app in order to pin it.
  • Miracast sessions will fail to connect.
  • On certain hardware types (e.g.: Acer Aspire), the Netflix app crashes when starting a movie.
  • 3rd party UWP apps would crash on devices if the DPI settings on the machine are >=150% (Generally people do this on high resolution devices – Surface book etc.).
  • If you upgrade from Windows 8.1 directly to Build 15002, all your store apps are lost during upgrade process but you can go and re-download all the lost apps from the Store.
  • When using Microsoft Edge with Narrator, you may hear “no item in view” or silence while tabbing or using other navigation commands. You can use Alt + Tab when this happens to move focus away from and back to the Edge browser. Narrator will then read as expected.
  • Saying “Hey Cortana, play on ” doesn’t work immediately after installing the app. Wait 5 minutes for indexing to begin and try again.
Deze lijst (laatste punt) kun je hier vinden bij Known Issues.
De volgende issues zijn bekend voor de Slow Ring met Build 14965.
  • Double-clicking on an Excel document to open it from File Explorer will crash Microsoft Excel. The workaround is to open the document from within Excel.
  • Microsoft Studios games like Microsoft Sudoku, Jigsaw, Minesweeper, Taptiles, and Treasure Hunt may freeze at the splash screen on launch.
  • ADDED 11/10: If your Surface Pro 3 has a SD memory card inserted, it will get stuck at “Working on Updates 22%”. If you remove the SD memory card, the update should complete normally.
  • ADDED 11/12: Apps such as Store, Photos, and People may launch on their own after your PC has been inactive for a period of time. To stop these apps from launching on their own, un-maximize the app before closing it.
  • ADDED 11/16: Using keyboard monitor hotkeys to adjust brightness won’t work as expected. Desired brightness change could be done via the Action Center or by going to Settings > System > Display.
Afbeeldingslocatie: https://static.tweakers.net/ext/f/tIZ7OdXQ2ZskJMRiuB2qOAVF/full.png
Heb je tips en/of aanvullingen? Laat het dan even weten...dan vullen we dit topic aan.
[ Voor 213% gewijzigd door TheVMaster op 21-06-2021 12:22 ]
  • SmokingCrop
Dragunov schreef op dinsdag 18 augustus 2015 @ 19:43:
Nieuwe build voor Insiders: 10525
yay :p
"Updated color options!
We got a lot of feedback on the default color for Start, Acton Center, Taskbar, and Title bars and that you wanted to be able to change to reflect your preferences. This feature is now available (though still early) in build 10525 for you to try. This is off by default, but you can turn it on by toggling this (Settings > Personalization > Colors):"
Afbeeldingslocatie: http://az648995.vo.msecnd.net/win/2015/08/Color-Option-751x1024.png
http://blogs.windows.com/...ider-preview-build-10525/
[ Voor 7% gewijzigd door SmokingCrop op 18-08-2015 20:00 ]
  • Turdie
  • Laatst online: 20-04 14:54
10525
  • Dragunov
Maar hier nog niks aan het downloaden
  • filenox
  • Laatst online: 31-10 15:57
SmokingCrop schreef op dinsdag 18 augustus 2015 @ 20:00:
yay :p
Voor de andere die het ook niet meteen door hadden: in de nieuwe build zal de kleur van de titelbalk ook veranderen :)
  • Turdie
Dragunov schreef op dinsdag 18 augustus 2015 @ 20:03:
Ook niet als je voor updates checkt?
  • Dragunov
Nope
  • Turdie
Zit je wel in het Windows Insiders programma (Fast Ring)? Deze build is alleen voor Insiders.
[ Voor 12% gewijzigd door Turdie op 18-08-2015 20:18 ]
  • Dragunov
Al heel lang hoor.
Hopelijk is in volgende versie de taakbalk ook transparant!
  • filenox
Dragunov schreef op dinsdag 18 augustus 2015 @ 20:18:
Al heel lang hoor.
De taakbalk is toch al transparant?
Afbeeldingslocatie: http://tweakers.net/ext/f/kTPIxg2ruZJSUQ7va56BPFTt/full.png
[ Voor 14% gewijzigd door filenox op 18-08-2015 20:19 ]
  • desalniettemin
  • Laatst online: 10-11 09:52
Al heel lang hoor.
Die is nu toch ook al transparant :?
  • Dragunov
Ja, maar hier niet...
  • SmokingCrop
Je hebt het toch aanstaan in instellingen eh? :p
Afbeeldingslocatie: http://i.imgur.com/Dlm1uPE.png
  • MAX3400
  • Laatst online: 11-11 12:04
MAX3400
XBL: OctagonQontrol
Jammer...
Al je wat minder one-liners plaatst zoals je afgelopen 10 replies op GoT, is het voor ons misschien mogelijk om mee te denken ipv te negeren dat het bij jou niet werkt en bij ons wel. Ik moet wel zeggen dat de Taskbar hier dusdanig transparant is, dat het amper transparant te noemen is afhankelijk van de kijkhoek op mijn laptop.
  • CAP-Team
  • Laatst online: 11-11 00:29
CAP-Team
XBL: CAPTeam
Nope, hier nog geen update. Komt vast omdat ik een Nederlandse versie heb ofzo
Microsoft Surface Pro 6 | Samsung Galaxy S26 | XBOX Series X
  • Dragunov
SmokingCrop schreef op dinsdag 18 augustus 2015 @ 20:22:
Alles staat aan om het transparant te maken.
Me Startmenu en Notificatiescherm zijn transparant, enkel de taakbalk krijg ik totaal niet transparant
Er schijnen nog mensen hier last van te hebben, al een Report gestuurd via Windows Feedback.
Kan inderdaad zijn dat het komt omdat we de Nederlandstalige versie hebben dat de nieuwe build nog niet beschikbaar is
  • Swerfer
  • Laatst online: 14:19
Swerfer
Hmm...
Voor de insiders: Build 10525 is te downloaden van de fast ring...
Home Assistant | Unifi | LG 51MR.U44 | Volvo EX30 SMER+ Vapour Grey, trekhaak | SmartEVSE V3 | Cronos Crypto.com
  • MAX3400
MAX3400
XBL: OctagonQontrol
Swerfer schreef op dinsdag 18 augustus 2015 @ 20:56:
Yupz...
/edit: mooi hoor; ik heb een local account op mijn PC maar als ik de Insider Build wil hebben, wordt in ieder geval mijn password vervangen met dat van mijn Insider-account. No thanks... :+
[ Voor 19% gewijzigd door MAX3400 op 18-08-2015 21:04 ]
  • MelvinB
  • Laatst online: 02-11 20:59
Microsoft also notes that there are improvements to memory manager too
http://www.neowin.net/new...0525-released-to-insiders
Known bugs in deze build:
•Mobile hotspot doesn’t work in this build. When sharing the Internet from your device with mobile broadband using Mobile Hotspot, it will fail to get a valid IP address from your device and will show no internet access.
•An update to Movies & TV application from the Store will be required to fix an issue with video playback.
•Optional languages packs will not be available during the initial launch of this flight, it will be available later this week.
[ Voor 62% gewijzigd door MelvinB op 18-08-2015 21:09 ]
| DELL XPS 15 Haswell QHD | APPLE iPhone X Silver | APPLE iPad Air |
  • desalniettemin
Misschien moet je dan dit programma'tje even proberen: http://chime.tv/products/glass2k.shtml
  • FREAKJAM
  • Laatst online: 21:57
FREAKJAM
"MAXIMUM"
Gelukkig zwerven er ook al ISO's rond van 10525. Ik had dusdanig met mijn privacy settings zitten rommelen (tooltje van github gebruikt) waardoor ik de nieuwe build niet binnen krijg (bijna alles staat ook greyed out).
Mochten mensen niet gerommeld hebben en ook niet de build binnen krijgen; bij privacy settings - feedback and diagnostic moet "diagnostic and usage data" op basic of enhanced staan, anders krijg je de build niet binnen.
[ Voor 4% gewijzigd door FREAKJAM op 18-08-2015 21:35 ]
is everything cool?
  • tiguan
FREAKJAM schreef op dinsdag 18 augustus 2015 @ 21:31:
Interessant. Is er eigenlijk een apart insider topic hiervoor? Om dat nou tussen de gewone Windows 10 dingen te bespreken lijkt me niet handig?
  • FREAKJAM
FREAKJAM
"MAXIMUM"
Chrome is trouwens stuk in build 10525, je kunt niet browsen en al je extensies crashen. Je kunt Chrome eventueel starten met parameter --no-sandbox dan werkt het wel. Verder ging de upgrade weer vrij aardig. Windows voelt ook veel sneller aan trouwens, de memory manager verbeteringen zijn duidelijk te merken. Mijn titelbalk is nu trouwens helderblauw, niet echt heel mooi, van mij mag deze ook transparent, net als de rest. Nu vloekt het met elkaar (een solid titelbalk en een transparante taskbar gaat niet samen vind ik). Edge is trouwens retesnel :D
tiguan schreef op dinsdag 18 augustus 2015 @ 22:31:
Voorheen werden de previews ook besproken in dit topic (deel 1), maar ik ben het met je eens dat een apart Insider topic nu wellicht handiger is.
[ Voor 81% gewijzigd door FREAKJAM op 18-08-2015 23:00 ]
is everything cool?
  • mysterieworld
  • th2_release Professional 10525 18-08-2015
[ Voor 143% gewijzigd door TheVMaster op 19-08-2015 08:53 ]
  • FREAKJAM
FREAKJAM
"MAXIMUM"
dubbel
[ Voor 91% gewijzigd door FREAKJAM op 18-08-2015 23:56 ]
is everything cool?
  • FREAKJAM
FREAKJAM
"MAXIMUM"
mysterieworld schreef op dinsdag 18 augustus 2015 @ 23:46:
spuit 11 :+
is everything cool?
  • tiguan
Ik wilde 'm gaan installeren, die insider in vmware player, maar heb m'n notebook ff hard nodig voor andere dingen. Man man man wat mis ik een SSD op dit moment :P
  • mysterieworld
tiguan schreef op dinsdag 18 augustus 2015 @ 23:51:
Eenmaal een ssd liefde, altijd deze liefde.
Ik zou dat ook niet willen, terug vallen. Vaak gedaan, maar je mis het wel.
SSD zou essentieel moeten worden tegenwoordig.
Ik hoor nog altijd vrienden zeuren, dat hun pc oer traag zijn geworden en ze het gewoon niet in hun hersens pan kunnen stoppen dat het nu eenmaal zo is met traditionele hardeschijven. |:(
[ Voor 22% gewijzigd door mysterieworld op 18-08-2015 23:55 ]
  • tiguan
mysterieworld schreef op dinsdag 18 augustus 2015 @ 23:52:
Ja I know. Op m'n werk zit er een EVO in , en dat is zo lekker. Thuis heb ik een hybrid Seagate, ook redelijik snel, maar haalt 't toch echt niet bij een SSD. Denk dat ik binnenkort toch ff eentje ga halen.
  • tiguan
Hmm, die optie wordt bij mij gemanaged door de insider program en ik krijg de nieuwe build vooralsnog niet binnen.
  • mysterieworld
Het is alleen dat Google Chrome niet werkt na upgraden van windows 10 build 10240 naar windows 10 build 10525
Chrome start wel, maar geen enkele functie van de browser werkt meer. Pagina's inladen dus ook niet.
Herinstalleren, los het probleem dus niet op.
Ik vermoed, maar ben er vrij zeker van. Dat het nieuwe geheugen management de boosdoener is.
Want alle error's die ik van chrome kan lezen, gaat over geheugen te kort of geheugen problemen.
[ Voor 69% gewijzigd door mysterieworld op 19-08-2015 01:40 ]
  • FREAKJAM
FREAKJAM
"MAXIMUM"
mysterieworld schreef op woensdag 19 augustus 2015 @ 01:10:
Met de parameter --no-sandbox doet hij het wel (zie mijn vorige post). Beta en canarybuilds doen het ook niet.
[ Voor 6% gewijzigd door FREAKJAM op 19-08-2015 07:50 ]
is everything cool?
  • CAP-Team
CAP-Team
XBL: CAPTeam
10525 wordt nu binnengehengeld door Windows Update. De Nederlandse versie liet dus ff op zich wachten.
  • Pykow
  • Laatst online: 10-11 19:14
Pykow
Angelo OTR
Ik had een website die niet werkte met Edge en Firefox.
Nu weet ik niet of ik iets mis (misschien heeft die site flash nodig ofzo).
maar dat was wel even jammer.
Momenteel draai ik zelf Firefox in Windows 10. heel soms heb ik nog een hapering in youtube (dit heb ik ook in Edge) en ik weet niet of dit aan de browser ligt of aan Youtube zelf.
Angelo NL / Global Cargo VTC
  • FREAKJAM
FREAKJAM
"MAXIMUM"
Chrome x86 doet het schijnbaar wel in build 10525. Alleen de x64 versie van Chrome doet het dus niet (mits je gebruik maakt van de parameter --no-sandbox).
Voor de imagers onder ons trouwens; gister is MDT 2013 Update 1 uitgebracht.
[ Voor 42% gewijzigd door FREAKJAM op 19-08-2015 10:48 ]
is everything cool?
  • FREAKJAM
FREAKJAM
"MAXIMUM"
Martinspire schreef op woensdag 19 augustus 2015 @ 12:20:
Iemand die dat kan bevestigen? Zou interessant zijn en maakt een fix ook een stuk makkelijker beschikbaar.
Ik denk niet dat het aan die update ligt. Volgens mij komt het alleen in de nieuwe preview build voor dat Chrome het dan niet meer doet. Ik kan in ieder geval nergens op internet vinden dat het door die update zou komen. (Bovendien is die update er nu al ~ 4 dagen en dan waren er vast meer klachten geweest op het net).
is everything cool?
  • Pyrone89
  • Laatst online: 04-02-2020
Hoe gaan ze dit trouwens verspreiden naar de uiteindelijke stabiele groep?
Worden dit allemaal losse patches zoals we gewend zijn of gaat dit een servicepack zijn (Windows 10.1)?
  • Martinspire
  • Laatst online: 13:27
Martinspire
Awesomeness
Die nieuwe preview sloopt meer dan dat ie brengt. Had fijn geweest als ze zelf al wat compatibiliteit hadden gecontroleerd, want ik zie meer apps falen. En ook mobile hotspot is irritant, want dat betekend dus ook dat ik mijn pc niet als accesspoint kan gebruiken nu voor mobiel omdat wifi hier zo ruk is. Want het gaat niet alleen om delen van bv 4G, maar ook Wifi.
Erg irritant dit. Heb nu maar 32bit Chrome draaien, zodat ik in ieder geval weer verder kan.
[ Voor 8% gewijzigd door Martinspire op 19-08-2015 13:34 ]
Martinspire - PC, PS5, XSX
  • FREAKJAM
FREAKJAM
"MAXIMUM"
Dat mobile hotspot niet werkt stond echter toch netjes in de releasenotes.
is everything cool?
  • Ashram
  • Laatst online: 01-11 17:27
Martinspire schreef op woensdag 19 augustus 2015 @ 13:34:
Ik heb er ook last van. Calendar en Mail werken bij mij ook niet meer sinds ik de nieuwste preview er op heb staan. Hebben meer mensen hier last van?
  • tiguan
Ik heb op m'n werk een enterprise versie geinstalleerd als insider preview. Die wil niet activeren, met waarschijnlijk als gevolg dat de nieuwe build niet binnenkomt. Als ik het nu goed begrijp moet je voor de enterprise versie eigenlijk een KMS server hebben, die hebben we niet.
Klopt het dat ik nu beter m'n VM opnieuw kan installeren met een Pro versie van de final build en dan weer verder gaan met insider builds?
  • Ashram
theduke1989 schreef op woensdag 19 augustus 2015 @ 14:32:
staat de apps wel aan, ik kan me voorstellen dat ze bij de nieuwe preview dit dus uit hebben gezet.
Voor ''privacy'' claimings!!!
App werkten daarvoor wel altijd, ook op eerdere preview-builds.
Maar het is alweer opgelost. Via Powershell de app verwijderd en daarna opnieuw uit de Store gedownload. Werkt weer als een zonnetje :-)
  • FREAKJAM
FREAKJAM
"MAXIMUM"
tiguan schreef op woensdag 19 augustus 2015 @ 14:33:
Je moet mag inderdaad een (eigen) KMS-server hebben als je Enterprise draait.
FREAKJAM in "[Windows 10] Ervaringen & Discussie - Deel 2"
Teruggaan naar Pro en dan upgraden naar een Insider build is dan wellicht een betere optie.
is everything cool?
  • sjimmie
  • Laatst online: 28-10 16:26
Ik draai mijn enterprise W10 gewoon met geactiveerde MAK hoor.
Maar heb je wel een MAK key dan?
Panasonic 7kW J-Series Split + 190 liter SWW, 2750+2100Wp Oost-West
  • tiguan
sjimmie schreef op woensdag 19 augustus 2015 @ 14:46:
Geen idee. Ik heb me gewoon aangemeld als insider destijds en heb de enterprise editie van hun site geplukt. Ik zou niet meer weten of er nou een key bij zat destijds.
  • MAX3400
MAX3400
XBL: OctagonQontrol
FREAKJAM schreef op woensdag 19 augustus 2015 @ 14:44:
Je moet inderdaad een (eigen) KMS-server hebben als je Enterprise draait.
Moet? Niks moet maar het is wel handiger. Wij draaien hier Enterprise door gewoon onze key in te tikken. Wel zo handig met 80% van de laptops buiten de deur.
  • FREAKJAM
FREAKJAM
"MAXIMUM"
MAX3400 schreef op woensdag 19 augustus 2015 @ 14:47:
Fixxed :> Ik vind persoonlijk KSM wel handiger 8)
is everything cool?
  • tiguan
Ja ik kan wel bij onze SPLA partner een KMS key pakken, maar daar heb ik niet zoveel aan :P
Jeuj, een apart topic oOo
Ik had geen idee dat er een nieuwe build was, maar heel sneaky is ie vandaag toch meegekomen (normaal ben ik er als de kippen bij :+)
Wel een behoorlijke bump in buildnummer trouwens.
  • Ashram
Iemand een idee wanneer die updates voor de Movie & TV en Groove Music apps komen? Beetje onhandig zo.
  • tiguan
Ok, ik heb nu pro opnieuw geïnstalleerd maar die kan ik ook niet activeren :P Ben ik nou mijn insider privileges kwijt ofzo? Thuis heb ik nog wel een insider draaien die wel goed werkt.
  • Swerfer
Swerfer
Hmm...
Gisteren voordat WU de update had gevonden even naar de slow ring gegaan. Vanavond toch maar weer naar de fast ring en lekker upgraden. Wilde eerst eigenlijk afwachten of er geen ernstige bugs waren geïntroduceerd, maar eigenlijk heb ik altijd in de fast ring gezeten vanaf oktober 2014 zonder problemen, dus waarom nu niet meer? Ik ben toch van living on the edge, dus vanavond ook naar 10525...
  • Martinspire
Martinspire
Awesomeness
FREAKJAM schreef op woensdag 19 augustus 2015 @ 13:37:
Klopt. Maar dat maakt het niet minder irritant. Zeker als ie al gaat downloaden en installeren zonder dat ik wist dat ik nog was ingeschreven :+
525 was een no go, ben weer terug naar 240 :(
  • Swerfer
Swerfer
Hmm...
Verwijderd schreef op woensdag 19 augustus 2015 @ 20:47:
Hier hebben we wat aan... Waarom???
Swerfer schreef op woensdag 19 augustus 2015 @ 20:50:
Dat deed Windows zelf :P
Nieuwe build zit erop, maar kunnen ze niet dat update/build process niet sneller maken? Downloaden>Prepare>Reboot>Copy Files> etc :F
Oh en mijn touchpad werkt half. Thanks.
  • tiguan
yay :p
[i]"Updated color options!
Ok, mijn build 10240 heeft dit ook. Wat is hier nieuw aan?
  • Dragunov
Watermerk is terug
  • tiguan
Reageer je op mij? In dat geval, welk watermerk?
  • SmokingCrop
tiguan schreef op woensdag 19 augustus 2015 @ 22:34:
Dat heeft hij niet volledig zonder truukjes toe te passen.
kijk maar eens naar titelbalken van bv verkenner. Dat heeft nu terug kleur (als de window actief is) zoals bij Windows 8/7/..)
[ Voor 13% gewijzigd door SmokingCrop op 20-08-2015 00:03 ]
  • tiguan
SmokingCrop schreef op donderdag 20 augustus 2015 @ 00:02:
Oh nu je 't zegt, dat was me niet eens opgevallen. :)
Ik heb al een maand lang diverse malen bericht gekregen dat ik mijn Windows 7 waar ik erg blij mee was,en 10 zou nog leuker zijn. Na lang denken en advies heb ik t gedaan en nu is mijn hele computer kapot. Ik heb niet t geld om n goede nieuwe te kopen en ik verwijt het Windows ten zeerste, maar wat nu te doen.Ik stel eigenlijk Microsoft verantwoordelijk en ik hoop dus echt snel iets van hun te horen, anders ben ik t tot alle staten boos. Echt ik flip de pan uit, ik kan niks en ik heb verdorie voor mijn gezondheid de computer nodig. Afwisselend boos en paniek,wat te doen???
*knip* mailadres is niet handig ik ben benieuwd
[ Voor 3% gewijzigd door TheVMaster op 20-08-2015 10:07 ]
  • dennis_rsb
  • Laatst online: 22:57
Verwijderd schreef op donderdag 20 augustus 2015 @ 09:12:
*knip* ik ben benieuwd
De computer is fysiek kapot door de update? Nooit gehoord, ik denk eerder een misluktte upgrade naar 10, laat even iemand er naar kijken die er verstand van heeft, dan komt het wel goed denk ik zo. Wijzig even je bericht en verwijder je mailadres bij je bericht i.v.m. spam.
[ Voor 1% gewijzigd door TheVMaster op 20-08-2015 10:07 ]
  • tonber
  • Laatst online: 28-09-2021
dennis_rsb schreef op donderdag 20 augustus 2015 @ 09:29:
De computer is fysiek kapot door de update? Nooit gehoord, ik denk eerder een misluktte upgrade naar 10, laat even iemand er naar kijken die er verstand van heeft, dan komt het wel goed denk ik zo. Wijzigig even je bericht en verwijder je mailadres ij jet bericht i.v.m. spam.
En je zit hier in de preview topic!
Moet normaal geen probleem zijn om hem terug te zetten.
Zoek iemand in de buurt die je daarbij kan helpen.
Voor onze Genealogie zie www.tonberendsen.com
  • Dragunov
tiguan schreef op woensdag 19 augustus 2015 @ 22:50:
Niet echt, enkel dat er terug een watermerk staat rechtsonder
  • CAP-Team
CAP-Team
XBL: CAPTeam
Dat ga je toch houden met preview builds. Ik erger me er niet aan.
  • FREAKJAM
FREAKJAM
"MAXIMUM"
[mbr]*knip* mailadres is niet handig[/mbr] ik ben benieuwd
Misschien ook wel handigt als je aangeeft wat er "stuk" is. Wij hebben namelijk geen glazen bol.
is everything cool?
  • G.Scholtens
  • Laatst online: 21:03
Heb er nu veel last van dat mijn systeem in slaap mode gaat, terwijl ik slaap modus in energie beheer op uitstaan. Heb voor mijn werk citrix verbindingen open staan, deze moet ik nu elke keer opnieuw verbinden met de nieuwe build
  • FREAKJAM
FREAKJAM
"MAXIMUM"
In de meest recente canary van Google Chrome is de zogenaamde crash-bug fixxed.
is everything cool?
  • engessa
Het is een beetje vragen naar de bekende weg maar toch: ik heb geen geldige Windows licentie. Ik heb mij wel aangemeld voor Windows Insider en een build gedownload en geinstalleerd maar niet geactiveerd voor de deadline die er was voor de release van Windows 10. Nu activeren Is er toch een manier om als Windows Insider legaal nu een licentie te activeren? Alles wat ik lees wijst erop dat ik nu toch gewoon een licentie moet kopen om legaal gebruik te blijven maken van Windows 10. Op zich prima maar als ik die 110 euro in mn zak kan houden heeft dat mijn voorkeur.
  • CAP-Team
CAP-Team
XBL: CAPTeam
Ik meen ergens gelezen te hebben dat als je op de betreffende pc eerder met insider builds hebt gewerkt dat het met nieuwe builds ook moet werken qua activatie.
Afbeeldingslocatie: http://tweakers.net/ext/f/29LsK10W4dj1SIbKlfgTuGVF/full.png
Zou het :D
Gabriel Aul
@GabeAul
Alright #WindowsInsiders, build 10532 is now making it's way to you via Windows Update:
http://blogs.windows.com/...eview-build-10532-for-pc/
oOo
  • FREAKJAM
FREAKJAM
"MAXIMUM"
Haha nice bday present dude! Congratz! :D
is everything cool?
  • Swerfer
Swerfer
Hmm...
Hmm... Update nog niet bij mij...
Zie de update bij het oorspronkelijke bericht:
http://www.windowscentral...indows-insiders-fast-ring
[ Voor 71% gewijzigd door Swerfer op 27-08-2015 21:52 ]
Update loopt binnen.
  • Swerfer
Swerfer
Hmm...
Zal wel weer een uur duren alles bij elkaar. Dat ze dat niet eens een keer aanpakken. Waarom niet gewoon een update ipv een complete build?
  • Going4Quests
  • Laatst online: 16-07-2023
Hm ik had mezelf op slow gezet nadat Windows 10 officieel uit was, en zou terug Insider Builds willen. Terug op fast gezet, maar hij vind de build niet. :(
  • Swerfer
Swerfer
Hmm...
Going4Quests schreef op donderdag 27 augustus 2015 @ 22:22:
Kan een dag duren totdat je weer in het systeem van fast zit. Had ik met de vorige build ook last van...
  • Going4Quests
Swerfer schreef op donderdag 27 augustus 2015 @ 22:31:
Hm.. hopelijk.. dan maar wachten. :)
  • FREAKJAM
FREAKJAM
"MAXIMUM"
Wat zijn je registry settings in HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\WindowsSelfHost\Applicability?
Zet Ring in ieder geval op "WIF" en EnablePreviewBuilds moet op 2 staan. Soms even switchen van fast -> slow -> fast wil ook wel eens helpen.
[ Voor 15% gewijzigd door FREAKJAM op 27-08-2015 22:38 ]
is everything cool?
  • Going4Quests
FREAKJAM schreef op donderdag 27 augustus 2015 @ 22:37:
Afbeeldingslocatie: http://i.imgur.com/m3uWxii.png
  • FREAKJAM
FREAKJAM
"MAXIMUM"
Dat is allemaal eigenlijk in orde. Hoe staan je privacy settings? Diagnostic and usage data (onder feedback and diagnostics) moet minimaal op enhanced staan wil je previews binnen krijgen.
In je lokale policy editor alle 3 de policies onder Computer Configuration - Administrative Templates - Windows Components - Data Collection and Preview builds op enabled zetten wil misschien ook wel helpen.
[ Voor 26% gewijzigd door FREAKJAM op 27-08-2015 22:42 ]
is everything cool?
  • Going4Quests
FREAKJAM schreef op donderdag 27 augustus 2015 @ 22:40:
Afbeeldingslocatie: http://i.imgur.com/j69Qw0T.png
Maar als ik terug kijk naar dat eerste plaatje, moet low misschien niet op high staan (low slow, high fast)?
  • Swerfer
Swerfer
Hmm...
Hmm... Restoring your previous version of Windows :(
Poging 2...
Poging 2 ook mislukt. Bij ongeveer 50% files copieren (15% totaal) een reboot en Restoring. Ik geef even op...
[ Voor 55% gewijzigd door Swerfer op 27-08-2015 23:14 ]
  • FREAKJAM
FREAKJAM
"MAXIMUM"
Going4Quests schreef op donderdag 27 augustus 2015 @ 22:44:
Treshold moet gewoon zo blijven staan, het gaat om de waarde WIF (Windows Insider Fast) of WIS (Windows Insider Slow) die goed ingesteld moet staan.
is everything cool?
  • Going4Quests
FREAKJAM schreef op donderdag 27 augustus 2015 @ 23:13:
Wat kan ik dan doen? Enkel wachten? :(
  • blmp
blmp
Life is Strange
Swerfer schreef op donderdag 27 augustus 2015 @ 22:45:
Poging 2...
Had de eerste keer ook een wazige upgrade (op desktop). Scherm bleef zwart na 2e reboot, net voor de stap 'configuring settings' dus. Op een paar toetsen gedrukt en plots rebootte de pc en ging de upgrade daarna door. Had ook al zoiets wazigs bij de vorige build.
edit: Wel genoeg ruimte vrij voor een upgrade?
[ Voor 6% gewijzigd door blmp op 28-08-2015 00:21 ]
Patient gamer
  • Xessive
  • Laatst online: 20-07-2025
Poging 2...
Update wordt nu binnen gehaald bij mij (66%). Ben benieuwd hoe dit verloopt.
Bij de vorige updates absoluut geen problemen ondervonden.
Sinds de vorige build en de nieuwe update wel mijn SSD (Crucial M500 120GB) vervangen door een Crucial BX100 van 250GB. Dus aan ruimte bij mij geen gebrek 8)
Kan echter niet zo snel achterhalen wat de verbeteringen / veranderingen zijn is Build 10532.
Aanvulling: Installatie zonder problemen doorlopen. Duurde wel lang en ben maar gaan slapen.
Pc stond deze ochtend keurig in slaapstand. Na invoeren pincode wel foutmelding van de gpupdate client. Hierna weer inlogscherm. Na 2e keer inloggen geen foutmeldingen.
Contextmenus zien er nu wel strak uit. Die van het startmenu heeft nu een donkergrijze achtergrond. Ff wennen maar wel rustgevend voor de ogen.
[ Voor 29% gewijzigd door Xessive op 28-08-2015 08:11 . Reden: Aanvulling / typo ]
Seriously? Nope, not a bit...
  • Going4Quests
Afbeeldingslocatie: http://i.imgur.com/FNlZUrw.png
Het klopte inderdaad van een dag! _/-\o_
  • Swerfer
Swerfer
Hmm...
blmp schreef op vrijdag 28 augustus 2015 @ 00:20:
Ja makkelijk. 47 Gig vrij...
Going4Quests schreef op vrijdag 28 augustus 2015 @ 09:16:
Top. Soms is geduld (helaas) een schone zaak...
  • geenstijl
Bijzonder. Hier vanochtend 10532 gedownload en geïnstalleerd (netjes het bekende zwarte scherm met de progressring), na rebooten zat ik echter nog op 10525 en kreeg ik de melding dat de update niet geïnstalleerd kan worden. Meer mensen dit probleem?
Poging twee is nu onderweg
  • Going4Quests
geenstijl schreef op vrijdag 28 augustus 2015 @ 10:13:
Mijn upgrade is nu voltooid en ben vlekkeloos van 10240 naar 10532 gesprongen. :)
  • FREAKJAM
FREAKJAM
"MAXIMUM"
Swerfer had volgens mij ook last van dit probleem.
Swerfer in "[Windows 10] Insider Preview Ervaringen & Discussie"
[ Voor 6% gewijzigd door FREAKJAM op 28-08-2015 10:50 ]
is everything cool?
  • Swerfer
Swerfer
Hmm...
Vanmorgen indedaad toch nog een poging gedaan en weer niet gelukt. Ik las bij Windows Central dat meer mensen hier last van hadden. Na ja, volgende build dan maar afwachten of misschien dat er een fix gaat komen...
  • FREAKJAM
FREAKJAM
"MAXIMUM"
Update is hier in ieder geval goed gegaan op 3 systemen (htpc en desktop thuis en surface pro 3 op het werk, de enterprise variant).
is everything cool?
  • geenstijl
Ook tweede keer mislukt. Maar feedback gegeven via de app.
Ben benieuwd of de mensen die succesvol naar 10532 zijn gegaan, afkomen van 10240/RTM of 10525.
Engels of Nederlands?
Hier dus van 10525 Nederlands naar 10532, mislukt.
10525 Engels naar 10532, in 1 keer goed gegaan.
  • tiguan
Ik weet niet of er iets is veranderd, maar mijn niet geactiveerde Windows 10 in een VM, kan nu wel een insider build downloaden. Beter :)
  • FREAKJAM
FREAKJAM
"MAXIMUM"
geenstijl schreef op vrijdag 28 augustus 2015 @ 12:40:
Ik draai op al 2 systemen eigenlijk vanaf het begin Insider builds en het upgraden gaat nog steeds goed. Ik denk dat ik op beiden systemen build 9926 (Engels) voor het eerst had draaien. Op mijn werk had ik eerst Windows 10 Enterprise 10240 (Nederlands) draaien die ik eerst heb geupgrade naar 10525 en vervolgens naar 10532.
Wat voor foutmeldingen heb je eigenlijk? Wat zeggen je logs?
[ Voor 4% gewijzigd door FREAKJAM op 28-08-2015 16:06 ]
is everything cool?
Pagina: 1 2 ... 14 Laatste
ALLEEN ervaringen met en discussie over het gebruik van Windows 10 Insider Preview builds!. Lees altijd de Topic Start voordat je begint met posten.
De reguliere Windows 10 versies? Bespreek die in het gewone topic : [Windows 10] Ervaringen & Discussie - Deel 2
Voor Windows Server 2019 Insider Preview Ervaringen & Discussie kun je hier terecht.
Problemen met Upgraden / Installeren van Windows 10?
Om te voorkomen dat het ervaringen topic overstroomt, graag je uitdagingen hier bespreken. Posts die in het ervaringen topic worden geplaatst, worden zonder meer verwijderd (of verplaatst) zonder verdere mededeling.
