• Dragunov
  • Laatst online: 30-03 12:39
Mede-auteurs:
  • tiguan
  • Laatst online: 21:16
tiguan
  • spartacusNLD
  • Laatst online: 21:54
spartacusNLD
Afbeeldingslocatie: https://static.tweakers.net/ext/f/IGAR3BjZ3ES7JGmiYoBPlnWh/full.png
Welkom bij het Windows 10 Preview Topic! Dit topic is alleen bedoeld voor de Insider Preview versies van Windows 10. Weet je niet wat Insider Preview is, of heb je geen idee welke build van Windows 10 je draait? Dan moet je hier waarschijnlijk niet zijn..... :+
Vanaf heden worden de builds via UUP geleverd, meer informatie hier.
Huidige builds
Fast: 17004
Slow: 14965
Inhoudsopgave
Afbeeldingslocatie: https://static.tweakers.net/ext/f/kZyLgyHCn2BRCHwpfsljP0hJ/full.png
De volgende issues zijn bekend voor de Fast Ring met Build 15007.
  • After updating to this build, nonstop exceptions in the Spectrum.exe service may occur causing PCs to lose audio, disk I/O usage to become very high, and apps like Microsoft Edge to become unresponsive when doing certain actions. As a workaround to get out of this state, you can delete C:\ProgramData\Microsoft\Spectrum\PersistedSpatialAnchors and reboot. For more details, see this forum post.
  • We are investigating certain situations in which PCs might bugcheck (GSOD) during the installation of new builds (15002+) causing the PC to rollback to the previous build.
  • When clicking on certain elements in desktop (Win32) games, the game minimizes and cannot be restored.
  • Desktop shortcuts containing the “%” character (usually URI shortcuts with escaped characters) will result in a cyclical explorer.exe crash. To resolve this, use Task Manager to open PowerShell, and edit the shortcut to not include a % in the path.
  • When projecting to a secondary monitor, if you set the connection to “Extended”, Explorer.exe may start crashing in a loop. If this happens, turn off your PC, disconnect the secondary monitor, then restart your PC.
  • Windows Insiders will unexpected see a “Holographic” entry on the main page of Settings.
  • Brightness changes made via Settings > System > Display will unexpectedly revert after closing the Settings app. For now, please use either Action Center, power flyout or brightness keys to change the brightness.
  • The list of apps in the Surface Dial “Add an app” page via Settings > Devices > Wheel may unexpectedly be empty. If that happens, tap the “Browse for an app” button at the bottom of the screen to pick the desired app instead.
  • Taskbar preview icons are unexpectedly small on high-DPI devices.
  • Quicken will fail to run with an error stating .NET 4.6.1 is not installed. For Insiders familiar with Registry Editor, there is an optional workaround. Take ownership of the following registry keys and edit the “version” value to be 4.6.XXXXX instead of 4.7.XXXXX:
  • [center]
  • HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\Microsoft\NET Framework Setup\NDP\v4\Client
  • ​HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\Microsoft\NET Framework Setup\NDP\v4\Full
  • [/center] [b]Note:[/b] Please take caution when editing the registry. Changing the wrong value can have unexpected and undesirable results.[/li]
  • Using CTRL + C to copy in Command Prompt won’t work.
  • Some websites in Microsoft Edge may unexpectedly show “We can’t reach this page”. If you encounter this, please try accessing the site from an InPrivate tab.
  • Dragging apps from the all apps list to pin on Start’s tile grid won’t work. For now, please right-click on the desired app in order to pin it.
  • Miracast sessions will fail to connect.
  • On certain hardware types (e.g.: Acer Aspire), the Netflix app crashes when starting a movie.
  • 3rd party UWP apps would crash on devices if the DPI settings on the machine are >=150% (Generally people do this on high resolution devices – Surface book etc.).
  • If you upgrade from Windows 8.1 directly to Build 15002, all your store apps are lost during upgrade process but you can go and re-download all the lost apps from the Store.
  • When using Microsoft Edge with Narrator, you may hear “no item in view” or silence while tabbing or using other navigation commands. You can use Alt + Tab when this happens to move focus away from and back to the Edge browser. Narrator will then read as expected.
  • Saying “Hey Cortana, play on ” doesn’t work immediately after installing the app. Wait 5 minutes for indexing to begin and try again.
Deze lijst (laatste punt) kun je hier vinden bij Known Issues.
De volgende issues zijn bekend voor de Slow Ring met Build 14965.
  • Double-clicking on an Excel document to open it from File Explorer will crash Microsoft Excel. The workaround is to open the document from within Excel.
  • Microsoft Studios games like Microsoft Sudoku, Jigsaw, Minesweeper, Taptiles, and Treasure Hunt may freeze at the splash screen on launch.
  • ADDED 11/10: If your Surface Pro 3 has a SD memory card inserted, it will get stuck at “Working on Updates 22%”. If you remove the SD memory card, the update should complete normally.
  • ADDED 11/12: Apps such as Store, Photos, and People may launch on their own after your PC has been inactive for a period of time. To stop these apps from launching on their own, un-maximize the app before closing it.
  • ADDED 11/16: Using keyboard monitor hotkeys to adjust brightness won’t work as expected. Desired brightness change could be done via the Action Center or by going to Settings > System > Display.
Afbeeldingslocatie: https://static.tweakers.net/ext/f/tIZ7OdXQ2ZskJMRiuB2qOAVF/full.png
Heb je tips en/of aanvullingen? Laat het dan even weten...dan vullen we dit topic aan.
[ Voor 213% gewijzigd door TheVMaster op 21-06-2021 12:22 ]
  • SmokingCrop
Dragunov schreef op dinsdag 18 augustus 2015 @ 19:43:
Nieuwe build voor Insiders: 10525
yay :p
"Updated color options!
We got a lot of feedback on the default color for Start, Acton Center, Taskbar, and Title bars and that you wanted to be able to change to reflect your preferences. This feature is now available (though still early) in build 10525 for you to try. This is off by default, but you can turn it on by toggling this (Settings > Personalization > Colors):"
Afbeeldingslocatie: http://az648995.vo.msecnd.net/win/2015/08/Color-Option-751x1024.png
http://blogs.windows.com/...ider-preview-build-10525/
[ Voor 7% gewijzigd door SmokingCrop op 18-08-2015 20:00 ]
  • filenox
  • Laatst online: 01-04 19:44
Dragunov schreef op dinsdag 18 augustus 2015 @ 20:18:
Al heel lang hoor.
Hopelijk is in volgende versie de taakbalk ook transparant!
De taakbalk is toch al transparant?
Afbeeldingslocatie: http://tweakers.net/ext/f/kTPIxg2ruZJSUQ7va56BPFTt/full.png
[ Voor 14% gewijzigd door filenox op 18-08-2015 20:19 ]
  • SmokingCrop
Je hebt het toch aanstaan in instellingen eh? :p
Afbeeldingslocatie: http://i.imgur.com/Dlm1uPE.png
Afbeeldingslocatie: http://tweakers.net/ext/f/29LsK10W4dj1SIbKlfgTuGVF/full.png
Zou het :D
  • Going4Quests
  • Laatst online: 16-07-2023
FREAKJAM schreef op donderdag 27 augustus 2015 @ 22:37:
Wat zijn je registry settings in HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\WindowsSelfHost\Applicability?
Zet Ring in ieder geval op "WIF" en EnablePreviewBuilds moet op 2 staan. Soms even switchen van fast -> slow -> fast wil ook wel eens helpen.
Afbeeldingslocatie: http://i.imgur.com/m3uWxii.png
  • Going4Quests
FREAKJAM schreef op donderdag 27 augustus 2015 @ 22:40:
Dat is allemaal eigenlijk in orde. Hoe staan je privacy settings? Diagnostic and usage data (onder feedback and diagnostics) moet minimaal op enhanced staan wil je previews binnen krijgen.
In je lokale policy editor alle 3 de policies onder Computer Configuration - Administrative Templates - Windows Components - Data Collection and Preview builds op enabled zetten wil misschien ook wel helpen.
Afbeeldingslocatie: http://i.imgur.com/j69Qw0T.png
Maar als ik terug kijk naar dat eerste plaatje, moet low misschien niet op high staan (low slow, high fast)?
  • Going4Quests
Swerfer schreef op donderdag 27 augustus 2015 @ 22:31:
Kan een dag duren totdat je weer in het systeem van fast zit. Had ik met de vorige build ook last van...
Afbeeldingslocatie: http://i.imgur.com/FNlZUrw.png
Het klopte inderdaad van een dag! _/-\o_
Afbeeldingslocatie: http://tweakers.net/ext/f/CChXzbjXhKEmlp8y41BQM8oV/full.png
Hebben jullie ook zo'n kleurig geheel als je win+x doet en met de muis over de items heen gaat?
  • Xessive
  • Laatst online: 20-07-2025
Nee, die van mij ziet er in 10532 zo uit:
Win-X Build 10532
Seriously? Nope, not a bit...
  • Dragunov
Als Insider rolt hij altijd terug naar vorige versie (10525), blijft tijdens eerste stap steken op Bestanden kopiëren 61% en de ring staat op 18%, als ik de ESD omgezet heb naar ISO en zo start dan krijg ik zelfde resultaat met volgend scherm na de terugdraai:
Afbeeldingslocatie: http://i60.tinypic.com/4ugyn4.jpg
  • Yilar
  • Laatst online: 31-03 15:19
Ik zit ook al (sinds maanden) op de fast ring, maar sinds de upgrade naar de RTM versie krijg ik geen insider builds meer binnen.. Kijkende naar het plaatje van Going4quests, zie ik een verschil met mijn regedit settings, weet iemand of het verstandig is om de setting EnablePreviewBuilds naar (2) aan te passen?
Afbeeldingslocatie: http://i.imgur.com/6Knehkj.jpg
[ Voor 14% gewijzigd door Yilar op 31-08-2015 14:30 ]
“The trouble with having an open mind, of course, is that people will insist on coming along and trying to put things in it.” Terry Pratchett, Diggers
  • blmp
blmp
Life is Strange
FREAKJAM schreef op dinsdag 15 september 2015 @ 10:17:
Dit rechtermuisknop menu was er toch ook al in build 10532? Het ziet er bij mij in build 10537 in ieder geval hetzelfde uit.
Ze zijn nu net een iets ander tintje. Even een poging gedaan tot een screenshot. Links oud (10532), rechts nieuw (10537).
Afbeeldingslocatie: http://img.photobucket.com/albums/v385/hxkclan/context-menu-color%202.png
Edit/update:
Partners hebben schijnbaar een tijdje geleden build 10540 gekregen, brengt jumplists naar UWP apps en fixt bugs van audio tot graphics.
En Gabe Aul heeft op Twitter gemeld dat ze build 10547 inmiddels in de internal 'slow ring' hebben zitten. Dus komt wellicht binnenkort naar ons toe.
Edit2:
Zelfde build lijkt nu ook in de 'interne ringen' te gaan voor Windows 10 Mobile. Dus wellicht een keer een dual release.
Edit3: Desktop 10547 is inmiddels uit en Windows 10 Mobile 10547 is gepushed naar 'Internal Fast Ring', dus denk volgende week uitgebracht.
[ Voor 51% gewijzigd door blmp op 18-09-2015 19:47 . Reden: update3 ]
Patient gamer
  • Turdie
  • Laatst online: 20-08-2024
Grrrrrr, 10547 wil hier niet installeren, blijft op dit scherm hangen, hangt ik de vorige keer ook, en heb niet zo'n zin weer een clean install
10547
  • karimmm
  • Laatst online: 25-03 13:10
Hey!
Ik wil graag ook gebruik maken van Windows 10 Insider maar ik kan dat niet, omdat ik blijkbaar beheerd word door een organisatie (wat dus totaal niet zo is)
Afbeeldingslocatie: http://i.imgur.com/JXwngam.png
[ Voor 3% gewijzigd door karimmm op 07-10-2015 10:33 ]
  • Kapitein187
  • Laatst online: 29-03 18:53
Kapitein187 schreef op dinsdag 13 oktober 2015 @ 14:26:
Hoe kan ik de weergave taal veranderen naar Engels? Ik draai 10565, en heb Engels (vs) ingesteld bij taal maar kan hem niet als weergavetaal instellen..
Misschien dat nu iemand me verder kan helpen.
Ik heb al gezocht op internet.
Bij mij is er geen optie om de weergavetaal om te zetten. Ik heb bij de clean install nederlands geinstalleerd maar wil graag cortana gebruiken.
Afbeeldingslocatie: http://tweakers.net/ext/f/4MS4zmuS3VMZWaSG7TiwM27X/thumb.png
Afbeeldingslocatie: http://tweakers.net/ext/f/jB8RX4h5xO5WU7SJhqrpuqyx/thumb.png
"Op de wind van gisteren kun je vandaag niet zeilen"
  • Kapitein187
Swerfer schreef op woensdag 14 oktober 2015 @ 17:57:
Al in het 'oude' configuatiescherm gekeken? Daar staat soms net wat meer info waarom je wel of geen Windows Installatietaal kan kiezen...
Ja gecheckt.
Zie plaatjes.
Afbeeldingslocatie: http://tweakers.net/ext/f/l8DUKH1d15CyNWrybB6FMs4d/thumb.png
Afbeeldingslocatie: http://tweakers.net/ext/f/6HAhOZ1al3JCmHwVyGkqlAxT/thumb.png
  • hjs
hjs
blmp schreef op vrijdag 06 november 2015 @ 01:32:
Als je in de Fast ring zat zou je ook al 10565 gehad moeten hebben ;).
Ja zat blijkbaar, maar waarom krijg ik dan geen updates meer?
Afbeeldingslocatie: http://static.tweakers.net/ext/f/Wx17VqeHsdnUpoLjdUj624iL/full.png
  • devil-strike
  • Laatst online: 20-03 22:03
blmp schreef op vrijdag 06 november 2015 @ 19:52:
Toevallig AMD graphics? Probeer de laatste 15.11 beta eens. Hier werkt dxva sindsdien weer icm de laatste build.
Ja de 280x met 15.11, probleem blijft nogsteeds bestaan, niet dat het zo een ramp is pc snel zat.
dxva checker ziet ook niets wat toch erg apart is.
Afbeeldingslocatie: http://devil-strike.com/no_dxva_win10_build10586.jpg
[ Voor 15% gewijzigd door devil-strike op 07-11-2015 09:40 ]
  • Swerfer
  • Laatst online: 02-04 17:07
Swerfer
Hmm...
Home Assistant | Unifi | LG 51MR.U44 | Volvo EX30 SMER+ Vapour Grey, trekhaak | SmartEVSE V3 | Cronos Crypto.com
De what now?
Afbeeldingslocatie: http://i.imgur.com/GaipuSL.png
Martinspire - PC, PS5, XSX
FREAKJAM schreef op woensdag 17 februari 2016 @ 12:37:
Elke preview build heeft een eigen key met een einddatum. Je bent verplicht om de zoveel tijd te updaten naar een recente(re) preview build. Met het commando slmgr /dli kun je zien hoeveel dagen je de build nog mag gebruiken.
Afbeeldingslocatie: http://tweakers.net/ext/f/aBmVhtwBSKaklh8YTk303eX9/full.jpg
Niet echt..
Afbeeldingslocatie: http://tweakers.net/ext/f/3CydNjRfQtdLEvVfYcLAk6sU/full.jpg
Windowskey+r -> winver
  • Dragunov
Windows laadt terug van de eerste keer, maar systeemvak ligt wel overhoop nu....
Gans het systeemvak is stuk naar links opgeschoven:
Afbeeldingslocatie: http://i66.tinypic.com/15hzzm1.png
[ Voor 4% gewijzigd door Dragunov op 25-02-2016 18:11 ]
Afbeeldingslocatie: http://tweakers.net/ext/f/yK8eMboimV6Akr5ywNoXo8ok/full.jpg
Ik moest het toch proberen :D
Het begin is er zeg maar, kwestie van de Xming X server for windows downloaden en installeren, bash starten en het volgende intypen:
Bash:
export DISPLAY=localhost:0.0
Afbeeldingslocatie: http://tweakers.net/ext/f/8dTuA0D4RR5aLxAylNWWDzZE/thumb.jpg
Hoezo één grote verwarring :P
  • Ewivis
  • Laatst online: 02-04 16:04
EricJH schreef op woensdag 31 augustus 2016 @ 19:35:
En eerste.... :9 14915 wordt nu gedownload. Naast Improving app and update downloads in Windows 10 with Delivery Optimization zijn er de volgende veranderingen te melden:
Net geïnstalleerd, maar krijg nu allemaal witte blokken waar normaal tekst te zien zou moeten zijn...
Afbeeldingslocatie: https://tweakers.net/ext/f/e4BjYb4BMvivUWWwdwiXoBZw/thumb.jpg
Andere ook last van?
AMD Ryzen 7 5800X3D / 64GB@3600mhz / ASUS 4080 Super TUF Gaming OC
  • racinfo
  • Laatst online: 19-02-2022
racinfo
E-MTB
Echter wanneer je ECHT gehecht bent aan het Control Panel (Configuratiescherm) dan is er toch nog een mogelijkheid een icoon op de desktop te plaatsen met de link naar Control Panel.
1. Klik met rechtmuisknop op start (of W-Key + X)
2. Kies geheel bovenaan voor Programma's en Onderdelen
3. Klik met rechter muisknop op "alle configuratie onderdelen" en kies adres kopieren
zie plaatje
Afbeeldingslocatie: https://dl.dropboxusercontent.com/u/13814150/controlpanel.jpg
4. Klik dan op je desktop (buroblad) met rechter muisknop en kies snelkoppeling plakken.
5. Je hebt nu een icoon met link naar het klassieke configuratiescherm.
ps.
Je kunt natuurlijk ook gewoon bovenaan op regel configuratie scherm klikken 8)7
[ Voor 12% gewijzigd door racinfo op 30-10-2016 10:18 . Reden: plaatje ]
  • racinfo
racinfo
E-MTB
De zoveelste, maar ik heb hem nu, na 14959 op slow gezet. Dan heb ik een paar maanden rust ;)
Edit
De nieuwe build 14959 ook op mijn andere laptop geplaatst, maar dit gaat niet
geheel zoals het hoort. Feedback al verzonden aan Bill.
Afbeeldingslocatie: https://dl.dropboxusercontent.com/u/13814150/14959.JPG
[ Voor 54% gewijzigd door racinfo op 04-11-2016 17:48 ]
Ik kon het niet laten.
Afbeeldingslocatie: http://www.rtlz.nl/sites/default/files/styles/inline_large/public/content/images/2015/10/30/schuld_0.jpg?itok=ack0sz6p
is everything cool?
  • racinfo
racinfo
E-MTB
Je kunt nu ook "update drivers" naar believen regelen bij build updates,
Afbeeldingslocatie: https://dl.dropboxusercontent.com/u/13814150/Schermafdruk%202017-01-22%2006.14.04.png
[ Voor 43% gewijzigd door racinfo op 22-01-2017 06:23 . Reden: afb. ]
  • Swerfer
Swerfer
Hmm...
Dragunov schreef op donderdag 26 januari 2017 @ 20:13:
Nieuwe build komt normaal morgen uit
Nu dus... 15019
Heb nu wel al 20 minuten dit scherm:
Afbeeldingslocatie: https://tweakers.net/ext/f/uuVEMyf2XoqPNE7ybFf1DSJO/full.png
Afwachten of dit de zogenaamde '0% bug is'...
[ Voor 33% gewijzigd door Swerfer op 27-01-2017 21:03 ]
  • Swerfer
Swerfer
Hmm...
Hmm... Iets vreemds met Edge:
Mijn PC was in sleep modus en toen ik die wakker maakte en naar Edge ging, en naar de favorieten, werden die van onderaf naar boven allemaal gewist in ongeveer 2 seconden. Geen favorieten meer |:(
Toen nog vreemder, het 'hub' icoon (wist niet dat hij zo heette) veranderde:
Afbeeldingslocatie: https://tweakers.net/ext/f/ar5al7m8SG4nRNLniRDbFXJj/full.png
Iemand hetzelfde?
Lijkt een probleem met mijn toetsenbord te zijn (Surface Book). Ik wilde wat in Google tikken, begint mijn toetsenbord de letter w oneindig uit te spuwen. Lijkt erop dat bij mijn favorieten de 'del'-knop hetzelfde deed.
Maar dat icoon... Dat blijft wel vreemd...
[ Voor 25% gewijzigd door Swerfer op 16-02-2017 21:15 ]
  • racinfo
racinfo
E-MTB
wildhagen schreef op zaterdag 4 maart 2017 @ 09:57:
Echt iets mis met 15046 was er niet, deed het prima. Vanochtend 15048 geinstalleerd, ook die werkt prima.
Er is weinig spannends veranderd tov 15046 eigenlijk https://blogs.windows.com...bile/#yfQ0xZsbqDDwF0LU.97
Wat wel opvalt is dat de watermark rechtsonder weer terug is in 15048, in 15046 was deze weg...
Niets nieuws? Was die virusbescherming er eigenlijk al eerder? Dat we sinds jaar en dag Defender hebben was mij bekend maar nu ook nog allerlei extra's erbij (zie afbeelding)
Afbeeldingslocatie: https://dl.dropboxusercontent.com/u/13814150/virusw10.jpg
  • Fonta
  • Laatst online: 08-03 15:55
Dit had ik ook nog niet gezien, afsluiten zonder bij te werken.
Afbeeldingslocatie: https://i.imgur.com/qGRx0z8.png
  • Raven
jaaoie17 schreef op woensdag 15 maart 2017 @ 20:36:
Sinds de normale update, heb ik iets vaags met schijf-opruiming. Bij Windows Update opschonen staat 3,99TB en dat ik in totaal 4TB kan opschonen. Maar deze SSD is 500GB. Kan ik die 4TB gewoon veilig opschonen?
Zoals ik hier gister had? :P
Afbeeldingslocatie: http://www.ravenslair.nl/GoT2/W10-disk%20cleanup.jpg
Zag ik gister toen ik de W10-VM weer eens wilde gebruiken voor insider previews, waar ik nog niet mee begonnen ben. Dit zit dus ook in de gewone installaties.
Gebruik iig niet de schijfopruimer van Windows, die heb ik uiteindelijk maar stopgezet omdat het veel te lang duurde en er niets leek te gebeuren. Voortaan maar met de hand doen. Windows Update service uitschakelen, restart en dan c:\windows\softwaredistribution leegmaken.
Oscar Wilde
  • Stefan22
Ik draai inmiddels 15063.11, maar kan al sinds 15063 op de taakbalk niet het verschil zien als een applicatie open is of niet (gepind aan de taakbalk).
Afbeeldingslocatie: https://i.imgur.com/Bgrh2oA.png
Op deze screenshot heb ik ook File Explorer geopend, maar dat is verder niet te zien, normaal is de kleur om het icon van File Explorer dan lichter. Firefox heb ik ook geopend, en heb ik voor me, die kleur is wel licht. Is dit nieuw of een bug?
Edit: Laat maar, het is te zien aan het streepje onder het icoon, zie ik nu op de screenshot. Monitor was niet goed ingesteld, waardoor ik dat streepje niet zag. Heb net even op de auto knop gedrukt. 8)7
[ Voor 32% gewijzigd door Stefan22 op 02-04-2017 13:49 ]
  • NSG
  • Laatst online: 24-03 19:20
NSG
Je weet niks!
Ik heb sinds een paar dagen Build 15063 draaien, in het begin een aantal keer meegemaakt dat Windows Spotlight het even niet deed, maar na opnieuw locken werkte het dan weer wel. Maar nu werkt het helemaal niet meer, ook nergens meer te vinden in de instellingen.
Iemand een idee?
Edit: zo ziet het eruit. Die melding in het rood kan ik mij niet herinneren uit vorige builds, ik heb de Education versie draaien en voorheen ook.
Afbeeldingslocatie: https://i.imgur.com/xI3ia0q.png
Edit: ik heb de update teruggedraaid en nu werkt het weer..
Edit 2: Erg fijn dat Windows even verteld dat je alle wijzingen in je sticky notes kwijtraakt tot het moment dat je geupgrade had... En het zelfde voor installatie van software..... erg pissig nu :-(
Edit 3: Nu nog pissiger (wat een pauper update is dit zeg), mail app deed het niet meer en ook het instellen van een pin lukte niet meer met als gevolg dat ik Windows Hello niet kon gebruiken. Dus nee weer de update uitgevoerd en ja Spotlight is weer weg..
[ Voor 63% gewijzigd door NSG op 09-04-2017 14:36 ]
  • racinfo
racinfo
E-MTB
Verwijderd schreef op zondag 27 augustus 2017 @ 21:08:
We zitten inmiddels op build 16273 ;)
Ik weet het! Gisteren 16251 erop gezet, handmatig.
Vreemd blijft echter dat ik geen instelling Fast of Slow meer kan vinden bij de preview instellingen. Er staat bovenaan dat het update beleid door mijn organisatie wordt geregeld en dat het iets met telemetrie te maken heeft of bepaald wordt.
Afbeeldingslocatie: http://www.rac-info.nl/fotos/tele.jpg
[ Voor 7% gewijzigd door racinfo op 28-08-2017 08:04 ]
  • racinfo
racinfo
E-MTB
FREAKJAM schreef op donderdag 7 september 2017 @ 15:31:
Je had even moeten spieken in je local group policy editor of je hebt je privacy settings mogelijk aangepast.
Heb ik gedaan; ben zelfs in register aan het sleutelen geweest maar dat haalde allemaal niets uit.
Dit was de melding in build 16251
[ Voor 9% gewijzigd door racinfo op 07-09-2017 16:25 ]
  • racinfo
racinfo
E-MTB
Zojuist een update naar 16299.15 gehad en nu is het watermerk weer verdwenen. Dit schijnt de definitieve versie RTM te zijn.
Afbeeldingslocatie: http://www.rac-info.nl/fotos/16299.jpg
[ Voor 43% gewijzigd door racinfo op 03-10-2017 10:01 ]
Gaaf....Connected Home is nu ook aanwezig in (in ieder geval de Preview Build van) Windows 10! Even de regio op US zetten (en natuurlijk Cortana enabled hebben staan, dus Engelstalige Windows versie :+)
Afbeeldingslocatie: https://tweakers.net/ext/f/tt7vaEbTorgKinrajzbRiWwe/full.png
Wauw...wel erg gaaf om gewoon 'Hey Cortana, turn the thermostat to 21 degrees'...en dat de NEST dan naar 21 graden springt of 'Hey Cortana, turn on the lights in the living room' en dat dan de lampen aan gaan.
[ Voor 50% gewijzigd door TheVMaster op 06-10-2017 17:20 ]
  • racinfo
racinfo
E-MTB
Brahiewahiewa schreef op vrijdag 23 februari 2018 @ 00:14:
Niet mee eens. Hij zegt:
Klinkt alsof tijdens de update de program files folder opnieuw is aangemaakt en een ander volgnummer heeft meegekregen. Grote kans dat c:\progra~4 of c:\progra~5 wel werkt
[q]
(geen idee wat dat is overigens, maar dat terzijde)...
[/quote]
Eind jaren '80, begin jaren '90 was dat dè schil om dBaseIII
Dacht ook dat 't al min of meer uitgestorven was, maar dat heeft kennelijk nog niet iedereen door
Nee, nog niet uitgestorven, Bill G. zou dat wel willen ;).
Wikipedia: Clipper (programmeertaal)
Afbeeldingslocatie: http://www.rac-info.nl/fotos/msdos.jpg
[ Voor 7% gewijzigd door racinfo op 23-02-2018 16:31 . Reden: clipper url ]
En weer een nieuwe build. Is jullie trouwens al opgevallen dat in de laatste paar builds Edge ook ineens Tweakers notificaties kan weergeven..?
Afbeeldingslocatie: https://tweakers.net/ext/f/m7SLsIe4e9ODjQ1zWwgVgoEc/full.png
Ik heb overigens nog niet gemerkt dat ze het ook doen, bij Facebook werkt het overigens wel..
[ Voor 17% gewijzigd door TheVMaster op 03-03-2018 16:03 ]
  • Swerfer
Swerfer
Hmm...
racinfo schreef op zondag 4 maart 2018 @ 06:55:
Inderdaad, build 17112 staat weer op de rol. Notificaties in Edge van Tweakers heb ik nog niet gezien. Het schijnt overigens nu ook mogelijk te zijn dat er notificaties worden ontvangen en weergegeven van app's die niet eens zijn opgestart.
JackSparrow schreef op zondag 4 maart 2018 @ 20:18:
Ik kreeg de notificatie melding, maar heb nog geen notificaties gezien. Zou wel nice zijn...van apps die niet zijn opgestart ;)
Vandaag mijn eerste:
Afbeeldingslocatie: https://tweakers.net/ext/f/VXFZPdwCb8EcuSFaX9tw7k1s/full.png
[ Voor 33% gewijzigd door Swerfer op 16-03-2018 17:27 ]
  • racinfo
racinfo
E-MTB
Fiander schreef op donderdag 21 juni 2018 @ 09:53:
wow, met deze laatste build (17692) verdwijnt mijn vrije schijf ruimte als sneeuw voor de zon.
system\storage\this PC (c:) geeft aan dat er nu 91.3 GB voor het systeem gebruikt word :S
Hier geen last daarvan, met build 17692, waarden zijn:
Afbeeldingslocatie: http://www.rac-info.nl/fotos/opslag.jpg
En dat is nog met de vorige windows 10 installatie (windows.old) inbegrepen!
Edit 23 juni
17692 leek zonder problemen totdat ik iets wilde gaan printen via de wi-fi printer, nu, die was die kwijt en wat ik ook ondernam, app installeren kwam niet meer in beeld. :?
Dus de vorige build teruggezet (17686), maar dat ging niet zonder slag of stoot, toen ie er eindelijk op stond bleek de verkenner vertraagt (en niet alleen dat) , zelfs uitzetten ging niet meer.
Ik was het zo zachtjes aan wel helemaal beu met deze RS5 preview's build's en besloot een compleet nieuwe installatie met 'n oude build 17127 op ISO te doen! Alle verdere software was na de installatie verdwenen, restte mij, na een autom. update van build 17134.112 alles opnieuw installeren. Vandaag, zaterdag was mijn dag weer gevuld. :(
Voorlopig verder in de SLOW mode... _/-\o_
Oja,na deze schone installatie had ik weer 127 GB van de 134 GB terug; ook dat scheelt een slok op 'n borrel. >:)
[ Voor 50% gewijzigd door racinfo op 23-06-2018 17:57 ]
  • wildhagen
JackSparrow schreef op zaterdag 27 oktober 2018 @ 11:29:
Maar eh...heb je een screenshot van die balk (of die optie waarmee je hem uitzet). Heb je het al gemeld in de Feedback hub?
Screenshot van de balk:
Afbeeldingslocatie: https://tweakers.net/ext/f/9aITlAFt6RhUPxboJYXs8YcI/full.png
De optie om hem uit te zetten:
Afbeeldingslocatie: https://tweakers.net/ext/f/1DmjFbQAF2b4LJwxIiuQ5iBA/full.png
Nog niet gemeld op de Feedback Hub, zal ik zo eens gaan doen :)
Virussen? Scan ze hier!
  • dutchnltweaker
  • Laatst online: 00:33
https://blogs.windows.com...ider-preview-build-21343/
We first began updating the icons in Windows 10 last year starting with the built-in apps. Since then, we have continued updating icons throughout Windows 10 including the icon for Windows Security, the Narrator icon, and most recently the icon for Notepad. Now we’re taking the next step by updating many of the system icons used throughout File Explorer.
Afbeeldingslocatie: https://46c4ts1tskv22sdav81j9c69-wpengine.netdna-ssl.com/wp-content/uploads/prod/sites/44/2021/03/file-explorer-icons.png
Afbeeldingslocatie: https://46c4ts1tskv22sdav81j9c69-wpengine.netdna-ssl.com/wp-content/uploads/prod/sites/44/2021/03/Pictures-Folder@2x-refresh.png
[ Voor 10% gewijzigd door dutchnltweaker op 25-03-2021 10:54 ]
ALLEEN ervaringen met en discussie over het gebruik van Windows 10 Insider Preview builds!. Lees altijd de Topic Start voordat je begint met posten.
De reguliere Windows 10 versies? Bespreek die in het gewone topic : [Windows 10] Ervaringen & Discussie - Deel 2
Voor Windows Server 2019 Insider Preview Ervaringen & Discussie kun je hier terecht.
Problemen met Upgraden / Installeren van Windows 10?
Om te voorkomen dat het ervaringen topic overstroomt, graag je uitdagingen hier bespreken. Posts die in het ervaringen topic worden geplaatst, worden zonder meer verwijderd (of verplaatst) zonder verdere mededeling.
