[OS X Mountain Lion 10.8] Ervaring & Discussie - Deel 2 Vorige deel Overzicht
Pagina: 1 ... 10 11 Laatste
in applescript het onderstaande plakken, aanpassen en opslaan als application.
application kan je dan in je user opstart gooien.
heb dan 2 "apps" voor thuis en een voor werk, zou in een kunnen maar zo net zo makkelijk:)
SSID aanpassen, run van de voren in terminal set ssid om te kijken wat werkelijk je ssid is (in mijn geval korte osx het af naar Xen terwijl het Xen Apple Network is.)
Shares
profilename
en je custom growl texten aanpassen.
-- PREP SSID DETECTION
set SSID to do shell script "/System/Library/PrivateFrameworks/Apple80211.framework/Resources/airport -I | awk '/ SSID: / {print $2}'"
-- IF NETWORK IS HOME
if SSID is "Xen" then
-- MOUNT DRIVE
tell application "Finder"
try
mount volume "smb://*.*.*.100/Films"
mount volume "smb://*.*.*.100/Apps"
mount volume "smb://*.*.*.100/Series"
mount volume "smb://*.*.*.100/transmission"
mount volume "smb://*.*.*.100/Downloads"
end try
end tell
-- SET RESULT VAR TO "WIN"
set endresult to "win"
-- ELSE
else
-- DO NOTHING
-- SET RESULT VAR TO "FAIL"
set endresult to "fail"
-- END
end if
-- START GROWL
tell application "Growl"
set the allNotificationsList to ¬
{"Win", "Fail"}
set the enabledNotificationsList to ¬
{"Win", "Fail"}
-- REGISTER GROWL
register as application ¬
"Mount Elements" all notifications allNotificationsList ¬
default notifications enabledNotificationsList ¬
-- NOTIFY GROWL
if endresult = "win" then
-- NOTIFY WIN
notify with name ¬
"Win" title ¬
"Diskstation Drives Now Available" description ¬
"Drive mount successful" application name ¬
"Mount Elements" image from location ¬
"file:///Users/profilename/Documents/Scripts/airdisk.png"
-- (just a local image of Mac OS X's "Airdisk")
else if endresult = "fail" then
-- NOTIFY FAIL
notify with name ¬
"Fail" title ¬
"Xen Apple Network Not Detected" description ¬
"Unable to mount network drive" application name ¬
"Mount Elements" icon of application "AirPort Utility.app"
end if
-- END GROWL
end tell
-- EPIC WIN
[ Voor 7% gewijzigd door Verwijderd op 29-03-2013 13:55 ]
  • TranceSetter
  • Laatst online: 19-10 12:04
Verwijderd schreef op vrijdag 29 maart 2013 @ 13:28:
Dit is perfect. Meteen voor mijn 4 shares aangemaakt. Heb trouwens wel de Growl notificaties eruit gegooid, want die gebruik ik niet, maar eindelijk niet meer die Finder vensters bij het starten van m'n mac :)
TranceSetter schreef op vrijdag 29 maart 2013 @ 19:40:
tja ik vind de growl optie wel handig en doormiddel van ssid check krijg ik alleen de shares op de plek waar ik ben:)
maar ben blij dat je er wat aan hebt, het is mateloos irritant dat shares openen bij login, snap niet dat osx dit zelf al niet onderdrukt bij een opstart.
  • TranceSetter
Verwijderd schreef op vrijdag 29 maart 2013 @ 22:19:
Ja, growl is wel handig, maar ik gebruik het alleen maar voor een paar kleine dingetjes. Moet niet steeds van die berichten zien ;-) En ik zie de drives natuurlijk wel op de desktop verschijnen :)
Het zou er inderdaad standaard in moeten zitten. Er zit zelfs een "hide" vinkje bij de login items, maar dat helpt niets.
ja je kan connected drives hiden maar waarom zou je als je ze al connect:)
  • TranceSetter
Verwijderd schreef op zaterdag 30 maart 2013 @ 13:03:
Wat ik wil hiden is de popup Finder windows. Dus ik wil bij het opstarten wel de network drives mounten, maar geen Finder windows zien.
[ Voor 5% gewijzigd door TranceSetter op 30-03-2013 13:09 ]
  • Rijk Lemming
  • Laatst online: 13-12-2024
Ik ben op zoek naar een mogelijkheid om tekst te selecteren in MacOS zoals je dat op een iPhone doet. Dus dat je twee van die bolletjes aan het uiteinde van je selectie krijgt die je heen en weer kan slepen.
Dat zou toch super handig zijn?
Iemand?
  • RnB
  • Laatst online: 08:52
RnB
Eh, waarom zou je dat willen?
In iOS is het nogal lastig om tekst te selecteren en is het dus wel handig dat je nog terug en vooruit kan selecteren, maar in OS X heb je een muis of trackpad en kan je alles selecteren wat je wilt.
  • Rijk Lemming
Als je tekst aan het bewerken bent, kan het volgens mij soms handig zijn. Als je een deel van een zin wil kopiëren bijvoorbeeld en je begint per ongeluk een woordje te vroeg of je eindigt een woordje te laat, ik zeg maar wat, moet je nu *helemaal* opnieuw selecteren...
Ik geef toe... er zijn ergere dingen in het leven, maar toch. Ik zou het volgens mij dagelijks gebruiken als het er was!
Edit: in mijn zoektocht ben ik wel dit tegengekomen: http://pilotmoon.com/popclip/ Best gaaf, maar nog net niet wat ik bedoel.
[ Voor 14% gewijzigd door Rijk Lemming op 30-03-2013 20:19 ]
  • tarlitz
Rijk Lemming schreef op zaterdag 30 maart 2013 @ 20:16:
Je kan altijd shift+pijltjes gebruiken om een selectie aan te passen.
  • RnB
RnB
Dat is inderdaad klote. Maar dan heb je dus die twee bolletjes; dan moet je alsnog ontzettend veel moeite doen om je muis vast te pakken, je cursor naar het linkerbolletje bewegen en de andere woorden selecteren. Oh, en dan raak je net niet het bolletje, kan je weer opnieuw beginnen met selecteren... :O
Scheelt erg veel tov hoe het nu werkt..
  • DaemonAngel
  • Laatst online: 18-02-2025
RnB schreef op zaterdag 30 maart 2013 @ 22:13:
Ben ik het mee eens. ik vind dat niet echt goed werken op de iPad hoor. Iets selecteren lijkt daar altijd 1 of ander sadistisch spelletje.
  • RnB
RnB
Ik heb een cosmetisch probleempje in mijn Dropbox folder:
Afbeeldingslocatie: http://tweakers.net/ext/f/Y4qCa0Q2mLNnENknJYjVhoNZ/full.png
Wanneer ik foto's verwijder, blijven die plekken leeg ipv dat ze opgevuld worden met de foto's die wel aanwezig zijn in de folder. De view options veranderen of de manier waarop de foto's geordend moeten worden (op naam, op kind, etc), veranderd niks aan de lege plekken.
Dit heb ik trouwens alleen in mijn Dropbox folder.
Mensen die dit herkennen en een oplossing ervoor hebben?
[ Voor 3% gewijzigd door RnB op 31-03-2013 13:44 ]
  • RoelJuun
  • Laatst online: 15-09 20:13
Een kwestie van rechtermuisknop -> rangschik (sort) op *keuze*
Standaard (OS X rarigheid) staat er niet echt een sortering aan, waardoor files niet verspringen. Doordat ook scrollbars ontbreken bij gebruik van een trackpad denkt de user soms dat er slechts 3 files in een map aanwezig zijn terwijl er bijvoorbeeld nog 100 daaronder staan.
Uiteraard is Colom en List view de oplossing.
  • RnB
RnB
Er staat toch echt bij dat dat niet werkt.
RnB schreef op zondag 31 maart 2013 @ 13:43:
Overigens alleen in mijn Dropbox folder, bij andere folders met foto's erin, verspringen de foto's wel zelf (op naam gerangschikt).
  • Tjoekie
RnB schreef op zondag 31 maart 2013 @ 16:26:
Als het echt alleen bij Dropbox het geval is dan zou ik het ook in de richting zoeken. Even contact opnemen met Dropbox support dus.
  • Rijk Lemming
Ok, point taken. Was een raar idee misschien... :X
  • pvdlaan
  • Laatst online: 06-10 20:29
Na maanden niet gebruikt te hebben, mis ik opeens m'n iDVD ...
Ik wil nu een film branden op mijn MacBook Pro en zie ik geen mogelijkheid hiervoor .
Ik weet dat iDVD tijdens Mountain (lion) upgrade verwijderd in uit iLife, maar is er een mogelijkheid om deze weer terug te zetten.
Ik heb iLife wel geïnstalleerd staan, maar deze komt uit de app-store.
Hoe kan ik evengoed een film via mijn MacBook Pro op een DVD-RW branden ...?
Xbox One X | iPhone 12 | iPad Pro 11 | MacBook Air M1 | Sony HX50v | Sony HX400
  • posttoast
  • Laatst online: 23:16
Shares
profilename
-- MOUNT DRIVE
try
end try
end tell
-- ELSE
else
-- DO NOTHING
-- END
end if
-- START GROWL
{"Win", "Fail"}
{"Win", "Fail"}
-- REGISTER GROWL
-- NOTIFY GROWL
-- NOTIFY WIN
notify with name ¬
"Win" title ¬
-- NOTIFY FAIL
notify with name ¬
"Fail" title ¬
end if
-- END GROWL
end tell
-- EPIC WIN
Handig, precies wat ik zocht :) Ik ben alleen een beetje een OSX noob en heb geen idee hoe ik dit bij opstarten moet draaien. Ik heb wat gezocht en kwam erop dat ik met Automator een app moet aanmaken. Dit heb ik geprobeerd (uit de library Run Shell Script gekozen), maar ik krijg deze error als ik hem run: "/bin/sh invalid option".
Als ik er gewoon een .sh bestand van maak en deze run werkt het wel, maar die krijg ik weer niet automatisch gestart bij het booten. Enig idee wat ik verkeerd doe?
omniscale.nl
  • CyBeR
CyBeR
Om te beginnen is 't geen shell script maar een AppleScript.
  • posttoast
CyBeR schreef op woensdag 10 april 2013 @ 11:05:
Oeps, ik ga me even in een hoekje zitten schamen :X Nu werkt het inderdaad perfect. Bedankt :)
omniscale.nl
  • Richard!
  • Laatst online: 23-04 20:54
Iemand die mij kan helpen hoe ik dit kan oplossen?
Ik heb het vervelende dat continu de Macintosh HD tussen mijn favorieten komt te staan terwijl ik dit helemaal niet wil. Ik verwijder hem telkens uit de navigatiekolom maar naar verloop van tijd komt hij gewoon weer terug. Ik word er onderhand een beetje moe van hem telkens te moeten verwijderen. Iemand een idee wat hier het probleem kan zijn?
Afbeeldingslocatie: https://dump.partyflock.nl/8997/Schermafbeelding%202013-04-10%20om%2013.50.03.png
richardbrunsveld.nl - Facebook - Flickr
  • Smultie
Het eerste stapje gaat bij mij al mis:
set ssid doet niks.. ;(
  • Underworld
  • Laatst online: 24-08 20:40
Underworld
+1 Inzichtvol
Richard! schreef op woensdag 10 april 2013 @ 13:53:
Heb je bij Finder --> Voorkeuren wel die vinkjes weg gezet bij navigatiekolom?
“Victorious warriors win first and then go to war,
while defeated warriors go to war first and then seek to win”
― Sun Tzu, The Art of War
  • Richard!
Ja alleen programma's en bureaublad zijn aangevinkt.
  • the tempter
  • Laatst online: 16-09 10:23
Misschien een noob vraag maar ik moet 36 audiobestanden met elk een grootte van 9,6mb versturen naar een maat van me. Ik wil ze graag samenvoegen naar een bestand en dan ( zsm ) versturen.
Hoe kan ik dit het beste doen?
  • Smultie
Bestanden selecteren en "Compress Items" klikken in Finder.app?
  • filenox
  • Laatst online: 23-08 12:18
En dan vervolgens uploaden bij MEGA bijvoorbeeld. :)
  • Bosmonster
  • Laatst online: 29-08 19:47
Bosmonster
*zucht*
Of WeTransfer, ook lekker makkelijk voor dat soort dingen.
  • filenox
Ik heb net WeTransfer eens getest maar MEGA gaat bij mij sneller :)
Het testbestand is 14MB groot en MEGA deed er 30sec over om het bestand online te krijgen.
WeTransfer deed het op 50sec. 20 lijken niet veel maar bij 350MB kan het toch wat schelen denk ik :P
Downloaden duurde 14seconden bij WeTransfer en slechts 7 bij MEGA.
Daarbij vind ik het niet zo leuk dat ik mijn mailadres moet geven bij WeTransfer
[ Voor 12% gewijzigd door filenox op 10-04-2013 17:51 ]
  • filenox
Bosmonster, je had toch gelijk. WeTransfer is gemiddeld sneller. :)
Het downloaden gaat echter wel sneller bij MEGA.
Indien interesse: ik heb verschillende up/downloaddiensten met elkaar vergeleken; http://www.filenox.net/snel-een-groot-bestand-delen/
  • CyBeR
CyBeR
* CyBeR merkt op dat bosmonster alleen "makkelijk" zei.
Dat de site van Mega eerst een tijdje een progress bar laat zien voor ik er überhaubt iets kan doen maakt overigens wel dat ik ook lekker wetransfer blijf gebruiken.
[ Voor 57% gewijzigd door CyBeR op 11-04-2013 00:43 ]
  • Muchachooo
  • Laatst online: 02-10 19:56
Nadeel van WeTransfer is dat je niet een linkje oid krijgt die je kan delen. Als je dus dezelfde bestanden nog een keer wilt delen met iemand anders dien je ze opnieuw te uploaden. Of zie ik iets over het hoofd?
  • filenox
CyBeR schreef op donderdag 11 april 2013 @ 00:43:
Dat komt omdat MEGA eerst alles encrypteerd. Dat duurt langer ja maar sommige zullen het vast een voordeel vinden.
Je krijgt het downloadlinkje via een mail toegestuurd. :)
  • CyBeR
CyBeR
filenox schreef op donderdag 11 april 2013 @ 00:55:
Dat vind ik wel knap dat ze dat doen al voordat ik überhaubt een knop "upload" te zien krijg.
  • filenox
Ik dacht dat je iets anders bedoelde :) Hier blijft de progress balk namelijk nog even op 100% staan voordat ik iets met het bestand kan doen.
Edit: ik ben nu een gelijkaardige test aan het doen met een bestand van 560MB :)
Edit2: Conclusie: gebruik best MEGA voor grote bestanden. http://www.filenox.net/snel-een-groter-bestand-delen/
[ Voor 42% gewijzigd door filenox op 11-04-2013 15:28 ]
  • the tempter
Bedankt voor jullie hulp.
Ik wist niet dat apple zelf kon comprimeren terwijl ik het al 100x gezien heb. Echter nooit geprobeerd.
Ik heb de bestanden via wetranfer verstuurd, het was 34x10mb en het duurde ongeveer 1 uur en een kwartier.
Nogmaals dank.
  • N14
  • Laatst online: 10-10 11:08
N14
Voor comprimeren en uitpakken ('decomprimeren'?) kun je ook Keka gebruiken (gratis op de developer website http://www.kekaosx.com/en/, betaald in de app store volgens mij), erg handige app vind ik zelf! 'The Unarchiver' is ook een prima alternatief.
  • peakrever
  • Laatst online: 28-06 16:35
Ik heb even een vraagje over het dock:
Laatst had ik de app 'docker' geinstalleerd om mijn dock 2D te laten worden, nu wou ik hem vandaag weer 3D maken, maar kreeg ik het Lion dock terug ipv het Mountain Lion dock, ik heb de app al verwijderd, en de Mac opnieuw opgestart, maar dat hielp niet, weet iemand hoe ik het dock weer normaal krijg?
  • BombaAriba
  • Laatst online: 15-09 20:48
BombaAriba
Ondertitel
Arthur-M. schreef op zondag 14 april 2013 @ 12:14:
Al bij dock gekeken in Settings? Ik snap ook niet precies wat je bedoeld met 2D/3D? Volgens mij is de dock altijd 2D? :P
We can believe what we choose. We are answerable for what we choose to believe. -John Henry Newman
  • me_mrtn
  • Laatst online: 19-10 15:47
BombaAriba schreef op zondag 14 april 2013 @ 14:16:
Zet je dock maar eens links of rechts neer, dan krijg je een 2D-dock. Standaard is het dock 3D, maar de iconen zijn uiteraard wel plat.
Beste mensen,
wie kan en/of wil mij helpen met mijn kleine probleempje?
Sinds een week of wat wil ik graag iets gaan proberen te programmeren voor mijn Iphone.
Echter heb ik geen OSX mountain lion dus heb ik het één en ander met VMware 9 gehost.
Alles werkende gekregen dmv een itunes login en een gedownde OSX ML. Alles werk, internet ed.
Ik had begrepen dat Xcode 4 hetgene was wat je nodig hebt om te programmeren.
Xcode 4 was dus na een tijdje binnen en zo geinstalleerd.
Echter probeerde ik het op te starten en toen begon het, er was een update en die moest worden gedownd.
Dit wilde ik doen alleen kwam toen de vraag om in te loggen. Echter had ik daar de login gegevens van de maker van de ISO file nodig die ik niet heb. Wat kan ik doen?
Begrijp me goed, ik wil het proberen en als ik er iets mee kan kan ik overgaan tot aanschaffen van het een en ander maar nu wil ik graag ff spelen.
Kan iemand met helpen om Xcode 4 draaiende te krijgen onder OSX ML.
BVD
  • Jouke74
  • Laatst online: 10-03 21:03
(jarig!)
Xcode kan je via de Appstore gratis installeren. Het zou dan, net als de updates moeten werken, en het is vreemd dat dit niet gebeurd. Het is ook vreemd dat je een "iso" voorgeschoteld krijgt; voor zover ik weet download en installeert de app zich praktisch vanzelf. Je moet je misschien wel eerst even registreren als developer bij Apple en deze credentials (of je itunes login) zijn misschien nodig voor de install.
"That was left handed..." - JJH
  • Muchachooo
Met de ISO bedoelde hij volgens mij de image van Mountain Lion die hij heeft geinstalleerd. Ik kan er alleen niet uithalen of je ML aan het virtualiseren bent op een Windows bak of op een Mac?
Jouke74 schreef op maandag 15 april 2013 @ 15:26:
Thx voor de reactie, echter bedoelde ik dat OSX ML een bestaande ISO is die ik via VMware Host en met een itunes account gewoon Xcode 4 heb binnen gehaald en geinstaleerd. Vanaf daar is pas het probleem ontstaan toe ik Xcode 4 wilde opstarten en meteen een file moest downen voor Xcode 4. Toen moest ik inloggen met een naam die ik niet ken. Kan het misschien zo zijn dat er van de orginele poster van de OSX ML Iso nog gegevens er in zitten.
PS ik heb wel geprobeerd om het met mijn eigen account op te lossen maar das niet gelukt.
Is het een idee om mijn account te resetten zodat alles weer schoon is, misschien een andere verse OSX ML opzoeken en hosten met VMware.
Thx voor de reactie, echter bedoelde ik dat OSX ML een bestaande ISO is die ik via VMware host on Win7 en met een itunes account gewoon Xcode 4 heb binnen gehaald en geinstaleerd. Vanaf daar is pas het probleem ontstaan toe ik Xcode 4 wilde opstarten en meteen een file moest downen voor Xcode 4. Toen moest ik inloggen met een naam die ik niet ken. Kan het misschien zo zijn dat er van de orginele poster van de OSX ML ISO nog gegevens er in zitten.
  • me_mrtn
Ik denk niet dat je hulp moet verwachten, want het hosten van een VM met OS Xonder niet-Apple apparaten mag niet volgens de voorwaarden. Wil je ontwikkelen voor OS X/iOS, dan zul je gewoon een Mac moeten aanschaffen.
  • tiguan
  • Laatst online: 07:20
Ik wou net al zeggen. Is het mogelijk om een officiele OS X in op een ESX server te hosten bijvoorbeeld. Dat zou wel leuk wezen, maar ik kon het me al niet voorstellen.
  • Zak aarde
  • Laatst online: 27-03-2025
Nadelen van WE Transfer is dat je link naar max 20 ontvangersgestuurd kan worden en dat het maar 2 weken op de server blijft staan. Daarna maken ze de ruimte weer vrij...
@CyBeR (onder) ik benoem slechts de limieten, misschien dat dat zeurend overkwam. Maar ik gebruik de dienst zelf ook naar tevredenheid.
[ Voor 17% gewijzigd door Zak aarde op 16-04-2013 20:20 ]
  • CyBeR
CyBeR
Zak aarde schreef op dinsdag 16 april 2013 @ 20:02:
wetransfer pro nemen (100 ontvangers) of gewoon zelf even 't linkje doormailen. Het aantal mensen wat in die twee weken kan downloaden is namelijk onbeperkt, ongeacht of je betaalt.
Verder vind ik die twee weken heel redelijk: het is een dienst om files te transferren van jou naar een aantal andere mensen, niet een generieke file hosting dienst voor het hele internet.
  • ppl
tiguan schreef op dinsdag 16 april 2013 @ 15:45:
Nee, ESX is EoL. In ESXi (en dus ook de overige vSphere producten) kan het wel maar dan alleen wanneer het op Apple hardware draait (men heeft het werkend weten te krijgen op o.a. een Mac mini model 2010 maar ook op een Xserve versie 3.1). Als je VMware Fusion, Parallels Desktop of Oracle Virtualbox gebruikt op je OS X systeem dan kun je ook daar de officiële OS X versie mee virtualiseren. Parallels en VMware hebben daar zelfs nog howto's voor (en het staat in hun help).
Het kan dus alleen als het op Apple hardware of op OS X kan draaien omdat dit zo in de licentie van OS X staat vermeld.
  • RnB
RnB
Ik heb net mijn Safari geüpdatet, maar ik merk nog steeds geen vooruitgang met scrollen op mijn rMBP. Is het voor Apple moeilijk om de nieuwste webkit versie te implementeren (licentie/coderen/etc?) of zijn ze gewoon lui om het te doen?
De WebKit nightly is de laatste tijd erg instabiel op mijn systeem, dus ik gebruik liever de standaard Safari, maar het scrollen is echt een drama.
me_mrtn schreef op dinsdag 16 april 2013 @ 15:41:
Thx voor de reactie.
Helaas ga ik geen Mec aanschaffen voor iets te gaan programmeren wat nog maar als een idee in mijn hoofd bestaat. Eerst proberen en dan kan ik altijd nog een besluit nemen een Appel te kopen ( denk het niet ). Echter ga ik toch met VMware 9 nog eens proberen een officiele voor 16 euro gekochte versie te hosten. Ik heb toch een gevoel dat het moet kunnen, en die voorwaarden, ach dat zal dan maar zo. Als het toch lukt zal ik nog even een reactie plaatsen, het is de mannen van Hackintosh ook gelukt. 8)
  • ppl
RnB schreef op woensdag 17 april 2013 @ 17:11:
Duh. Deze 6.0.4 had maar 1 wijziging namelijk de uitbreiding van het in-/uit kunnen schakelen van Java. Eerst was dit voor alle sites, nu heb je de optie om dit specifieker te doen. Je kunt per site aangeven wat ie met Java moet doen. Dan moet je niet allerlei additionele bugfixes gaan verwachten ondanks het feit dat fabrikanten zo nu en dan dit soort releases nog wel eens gebruiken om die fixes te pushen. Dat scrollen is waarschijnlijk een probleem wat groter is dan Safari alleen. Er zijn meer animaties die niet helemaal lekker lopen in diverse applicaties en OS X zelf. Het lijkt Safari te overstijgen waardoor je eerder op een algemene fix in de display driver en/of CoreAnimation moet wachten.
Verwijderd schreef op donderdag 18 april 2013 @ 08:44:
VMware 9 bestaat niet, VMware is een bedrijf. Wat jij lijkt te bedoelen is een specifiek product van VMware en wel Workstation 9. Als je de volledige productnaam nou eens gebruikt icm OS X als zoekactie moet je toch wel het nodige kunnen terugvinden. Er zijn namelijk wel mensen die het voor elkaar hebben gekregen. Echter, het blijft illegaal omdat je de licentievoorwaarden overtreedt maar dat is geheel je eigen verantwoordelijkheid en risico :)
Overigens is het programmeren voor OS X wel erg breed. Dat kun je in Cocoa doen (wat OS X z'n eigen taal is en waar je ook daadwerkelijk een Mac met Xcode voor nodig hebt) maar ook in iets als Java of C/C++ en diverse andere talen. Voor alles wat niet-Cocoa is heb je niet specifiek een Mac nodig hoewel het wel erg handig is. Als je echter toch die kant op wil gaan is het uiteindelijk wel een heel stuk makkelijker om een echte Mac te gebruiken. Hackintoshes en het draaien in een vm op niet-Apple machines is nogal fragiel; updates kunnen het helemaal om zeep helpen. Om dan alles weer recht te breien...
  • RnB
RnB
ppl schreef op donderdag 18 april 2013 @ 17:33:
Een mens mag toch wel hoop hebben. :P
Tuurlijk vind het probleem zich niet alleen plaats bij Safari, maar waarom kan ik met de WebKit nightly wel vloeiend scrollen?
Daarom had ik ook een verkapte vraag erin gezet of het moeilijk is om de nieuwste webkit engine te implementeren in Safari of dat ze bij Apple gewoon lui zijn.
ido schreef op vrijdag 14 december 2012 @ 10:19:
dit in de Terminal plakken verhelpt de dubbele entries:
/System/Library/Frameworks/CoreServices.framework/Frameworks/LaunchServices.framework/Support/lsregister -kill -r -domain local -domain system -domain user
en
DaSaN schreef op vrijdag 14 december 2012 @ 10:20:
1. Go to your Home/Library/Preferences folder
2 .Find "com.apple.LaunchServices" file and trash it
werkt niet meer voor dit:
RnB schreef op vrijdag 14 december 2012 @ 00:10:
Heeft iemand hier ook last van? Het dubbel voorkomen van Adobe Photoshop CS6 (en Pixelmator).
En hoe krijg ik dit weg?
Ik heb het nu echter bij audiofiles, maar dit zou niet uit hoeven maken.
Afbeeldingslocatie: http://tweakers.net/ext/f/GXeIunVSvsAnXLXjlRHpPuEn/full.png
Is er een andere optie die wel werkt?
[ Voor 33% gewijzigd door RnB op 18-04-2013 19:04 ]
  • ppl
RnB schreef op donderdag 18 april 2013 @ 19:02:
Wellicht dat ze het daar voor bepaalde web elementen wel hebben opgelost. Heb verder geen idee hoe het precies zit, alleen dat MBP Retina eigenaren nogal veel klachten hebben over het niet vloeiend zijn van de animaties binnen OS X, in allerlei applicaties. Kan dus ook zijn dat het probleem wat dieper gaat dan alleen Safari. Maar hoop doet leven :)
Geen van beiden. Safari wordt afgeleid van die webkit nightlies maar een nightly is hele verse code. Dat kan vriezen, dat kan dooien. Er is geen enkele garantie. Zie daar het probleem. Dat wil je dus absoluut niet in een final release die je naar weet ik niet hoeveel miljoen devices uitrolt hebben. Dat moet gewoon stabiel zijn, naar behoren werken. Dus ga je heel veel testen en pas als hetgeen je getest hebt goed is schuif je dat door. Daardoor loopt een final release vaak maanden achter op een nightly maar is ie wel een heel stuk stabieler. Dat is bij een Opera, Firefox en Chrome niet anders. Heeft dus niets met luiheid of complexiteit te maken.
Het is van essentieel belang om na het toepassen van die fixes uit te loggen en daarna weer in te loggen. Doe je dat ook steeds? Mij lukte de fix laatst met 10.8.3 namelijk wel.
  • RnB
RnB
Ah natuurlijk, de stabiliteit. Die laat soms wel wat te wensen over bij de nightlies inderdaad. Stom dat ik daar nog niet aan gedacht had.
En over die fixes, ik heb na de terminal optie en het handmatig verwijderen van de .plist mijn systeem herstart. Wel één voor één natuurlijk, maar het mocht bij mij niet baten.
  • Michiel706
  • Laatst online: 04-10 07:39
Sinds vrijdag heb ik (eindelijk) de upgrade gemaakt naar ML, maar nu loop ik tegen het volgende:
De draadloze verbinding tussen mijn MacBook Pro en mijn netwerkschijf (WD MyBook Live 2TB) is nu beduidend minder snel geworden. Ik kan in Finder niet eens lekker door de mappen heen zoeken. Laat staan een film afspelen vanaf mijn netwerkschijf.
Iemand hier eenzelfde soort ervaring, of tips?
Waarom duurt snoozen maar 9 minuten?
  • filenox
Heeft die MyBook Live de laatste firmware en is ML up-to-date?
Zou iemand mij misschien kunnen helpen met het antwoord op de volgende "https" vraag?
Als ik onder OS X 10.8.3 naar https://extensions.apple.com surf zie ik keurig een groene URL en het bekende hangslotje. Surf ik daarentegen naar https://rabobank.nl of eender welke andere https-site dan ook, dan zie ik wel heel eventjes een groene URL en het hangslotje, maar binnen een enkele seconde is dit weer verdwenen en is de gewone http-URL in safari zichtbaar. Ik vraag mij daarom af: heb ik als de groene URl omgezet wordt in een gewone http verbinding nu alsnog een secure verbinding of niet? Zijn er meer mensen die dit verschijnsel hebben, en zo ja is hier midels een instelling verandering in te brengen?
Vriendelijk dank voor het eventuele antwoord.
  • Aherin
  • Laatst online: 04-10 20:08
Verwijderd schreef op dinsdag 23 april 2013 @ 21:44:
Als ik naar https://www.rabobank.nl surf, geeft safari aan dat het certificaat ongeldig is, en wordt ik dus ook omgeleid naar de gewone pagina.
Nee, dan heb je geen veilige verbinding, alleen als er een groene balk is heb je een beveiligde verbinding.
overigens, nu doet ie het wel weer?
en nu blijft het ook netjes groen
[ Voor 3% gewijzigd door Aherin op 23-04-2013 22:32 . Reden: aangepast ]
  • Zer0
  • Registratie: September 1999
Zer0
Destroy 2000 Years Of Culture
Het certificaat wat gebruikt wordt op https://rabobank.nl heeft als domeinnaam www.rabobank.nl en wordt dus als ongeldig gezien. Als je naar https://www.rabobank.nl gaat is alles in orde.
maybe we sit down and talk about the revolution and stuff
but it doesn't work like that
you can't turn back now there's no way back
you feel the power to destroy your enemy..
  • Aherin
Zer0 schreef op dinsdag 23 april 2013 @ 22:30:
Dat dus ;)
[b][message=40146584,noline]. Als je naar https://www.rabobank.nl gaat is alles in orde.
Ik vind het wel een beetje vreemd hoor. Het verschijnsel doet zich nog steeds voor. Ook als ik bovenstaande link gebruik. Ik zie dus een korte groene URL en binnen een seconde de gewone. Gek toch?
  • CyBeR
CyBeR
Dat komt omdat ze niet-https content in de pagina gebruiken als je dat doet. Bijvoorbeeld stylesheets en plaatjes.
ja kan, moet je op vmware fusion de image maken en dan package converten + uploaden naar je esx host.
heb het werkend gehad onder esxi 5.1 met 10.8 maar stabiel en snel is wat anders:)
  • tiguan
@XennOX: Dat klinkt als teveel moeite. Ik was ook niet van plan om het uit te proberen hoor, het lijkt me gewoon leuk als 't kan.
  • ppl
Verwijderd schreef op maandag 29 april 2013 @ 12:36:
Het werkt niet zonder geknutsel. Wat ik zelf heb gevonden is dat je het nodige aan EFI moet wijzigen vooraleer het gaat werken op een non-Mac (op een Mac werkt het gewoon, kwestie van vm kopiëren), ook al gebruik je een vm die prima werkt in VMware Fusion. Ik neem aan dat dit het deel van "package converten" is, je hebt hier namelijk wel een handig tooltje voor. Het gebrek aan snelheid is vooral beperkt tot de GUI en is iets wat een CoreImage probleem is. Volgens VMware is dat lastig, ze kunnen geen goede 3D stuff maken waardoor de performance van de GUI gewoon slecht is. Voor de rest werkt het eigenlijk wel prima.
  • tiguan
Zou hetzelfde eventueel te realiseren zijn in Hyper-V? Deze heeft iig ondersteuning voor 3D acceleratie. Ik weet niet of VMWare dit ook heeft eigenlijk.
  • ppl
VMware heeft dat ook in al haar producten (Fusion had het al in 2007). Parallels Desktop ook en zelfs Virtualbox hoewel dat erg beperkt is vergeleken met de producten van Parallels en VMware. Het probleem zit hem in OS X zelf aldus VMware. Ik probeer de info over die graphics terug te vinden op communities.vmware.com maar dat is niet zo makkelijk met die brakke search daar.
Trouwens, die 3D acceleratie geldt voor Windows en Linux. OS X als guest heeft geen 3D acceleratie.
[ Voor 12% gewijzigd door ppl op 30-04-2013 00:32 ]
  • RnB
RnB
Ik gebruik sinds kort Mail ipv Sparrow en dat is toch wel even wennen met Gmail.
Sparrow was natuurlijk gemaakt voor Gmail en werkte heerlijk samen, bij Mail is dat toch minder.
Toch wil ik Mail een kans geven. Voor mijn labels heb ik al min of meer een workaround voor, maar het verwijderen van mijn e-mails gaat niet zoals ik wil.
Wanneer ik een mail verwijder dmv backspace of het prullenbakicoontje, word mijn mail niet verwijderd, maar gearchiveerd. En dat is raar, want ik heb natuurlijk ook een archiveer icoontje.
Op het moment is mijn mail zo ingesteld:
Afbeeldingslocatie: http://tweakers.net/ext/f/eMuXlcWdSdvsAaIZW5SkiJD1/full.png
Maar ik krijg hetzelfde gedrag wanneer ik ''Store deleted messages on the server'' aangevinkt heb.
Hoe krijg ik dit voor elkaar?
[ Voor 16% gewijzigd door RnB op 30-04-2013 10:50 ]
  • thaan
  • Laatst online: 21:47
Gebruik OnyX om LaunchServices op te schonen, werkt hier prima. Heb het regelmatig als ik een Mac OS X Bootdisk via USB aansluit, dan verschijnen alle apps die op die schijf staan spontaan als LaunchServices in dat contextmenu.
[ Voor 24% gewijzigd door thaan op 30-04-2013 10:51 ]
  • ankhie
  • Laatst online: 19-10 00:16
ankhie
Co-founder bij Mobile2Morrow
RnB schreef op dinsdag 30 april 2013 @ 10:48:
Je moet nog even in de mail.app de Gmail folders expanden en dan de 'Prullenbak' of 'Trash' aanklikken en dan in het menu bovenaan kiezen voor 'Mailbox --> Use this mailbox for --> Trash' aanklikken. Dan gaan alle verwijderde berichting richting de prullenmand zoals je wil. Anders blijft hij archiveren op de manier die je nu hebt.
Heb de Engelse OS X maar denk dat je er wel uitkomt mocht je NL hebben ;)
  • RnB
RnB
Great, thanks! That did the trick. :)
thaan schreef op dinsdag 30 april 2013 @ 10:51:
Ik zal dat eens gaan proberen, thanks.
  • Steenvoorde
  • Registratie: Augustus 1999
  • Laatst online: 11-10 22:23
Ik heb gisteren de Thunderbold update gedraaid op mijn 2011 iMac. De installer gaf aan dat ik moest rebooten, dus dat heb ik meteen maar gedaan. Na het uitloggen werd de daadwerkelijke installatie gedaan en na het rebooten bleef mijn scherm zwart. Voor best een lange tijd. Na 10 minuten mijn iMac maar hard uitgezet met de aan/uit knop, maar na het aanzetten van mijn Mac kreeg ik meteen een kernel panic, iets met drivers die niet gevonden konden worden. Op geen manier meer aan te krijgen. In safe mode kreeg ik exact dezelfde melding, dus met CMD-R recovery mode opgestart. Dat werkte wel. Opnieuw de OS X installer gedraaid en na een uurtje kon ik weer opstarten en inloggen, maarrr... Het geluid klink nu echt heel raar, ik hoor alleen hoge tonen. Alsof het door een high pass filter is gehaald. En als de Mac in sleep mode gaat dan blijft ie daar ook in, dan moet ik 'm weer hard uit en aanzetten. Iemand een idee wat ik hier aan zou kunnen doen? Of in welke hoek ik het zou moeten zoeken? Mijn last resort is natuurlijk de schijf leeg halen en van scratch aan opnieuw installeren, maar liever doe ik dat natuurlijk niet. :'(
  • yeehaw
  • Laatst online: 16-10 14:16
Als je een externe harde schijf hebt zonder data of een usb stick groter dan 8GB zou je daar even OSX op kunnen installeren en kijken of het probleem zich dan ook voordoet als je daarvanaf boot.
Als dat het oplost, herinstalleren, eventueel na time machine back-up.
Zo niet, naar Apple Store..
  • RnB
RnB
Ik krijg het niet meer voor elkaar om Windows 7 te installeren m.b.v. de Boot Camp Assistant. Ik heb werkelijk waar geen idee waar het aan ligt.
Bij het opstarten van de Windows installatie blijft ie hangen:
Afbeeldingslocatie: http://tweakers.net/ext/f/HnRf5BJpI08RGKqJnfAkSdyg/full.jpg
Daarna de opstartschijf maar opnieuw gemaakt. Eerst geformatteerd d.m.v. Disk Utility en Boot Camp Assistant weer aan het werk gezet. Het viel me trouwens op dat het ontzettend langzaam ging, de Windows files werden gekopieerd met een snelheid van rond de 19MBps. Geen idee hoeveel dit eerder was, maar ik kan me herinneren dat het een stuk sneller ging (dus volle snelheid USB3.0).
Tweede poging gewaagd om Windows te installeren, maar weer bleef ie hangen.
Toen maar alle peripherals eruit gehaald (dvi extern scherm en thunderbolt), maar toen kreeg ik na een herstart een andere melding:
Afbeeldingslocatie: http://tweakers.net/ext/f/qRtnQNh8F3K7sydYSEAF9BvJ/full.jpg
Toen heb ik het opgegeven, Windows is zoveel moeite niet waard. Maar toch vind ik het vreemd, ik heb Windows 7 en 8 tientallen keren geïnstalleerd op mijn systeem, zonder zucht of steun.
In de tussentijd is er niks veranderd aan mijn systeem, alleen is Boot Camp volgens mij geüpdatet. Die schijnt nu betere Windows 8 ondersteuning te hebben, maar dat heeft voor mij op het moment weinig zin natuurlijk.
Iemand enig idee waar het aan zou kunnen liggen?
  • Viresh87
  • Laatst online: 23:18
Als ik in Safari een nieuw tabblad wil openen, dan komt er een tabblad met top sites en history. Hoe kan ik instellen als ik een nieuwe tabblad open dat deze gedupliceerd wordt?
Alvast bedankt!
  • breinonline
  • Laatst online: 07:43
breinonline
Are you afraid to be known?
Gewoon: Safari > Preferences.. > General > New tabs open with:
  • Viresh87
breinonline schreef op zondag 19 mei 2013 @ 13:15:
Hahah, zo makkelijk! Thanks man! Fijne dag verder! :*)
Afbeeldingslocatie: http://i43.tinypic.com/2lnzjhe.png
Hey gasten,
ik kreeg vanmorgen dit probleem toen ik mijn volume wilde aanpassen. Ik heb al een safeboot geprobeerd, wilde niet werken. Bij uitvoer staat nu helemaal geen apparaat. Wat kan ik hier tegen doen?
MacBook Pro 13inch medio 2010, heb nog Mac OS X 10.7.5.
  • Zer0
Zer0
  • peakrever
Ik heb deze vraag hier al eerder gesteld, maar geen goed antwoord gekregen, dus stel ik hem nog een keer. Het probleem; Ik draai Mountain Lion op mijn MBP, deze had eerst het gewonen Mountain Lion dock, maar nadat ik de app 'Docker' had geïnstalleerd kreeg hij weer een Lion/Snow Leopard dock.. Ik vind dit raar en zou graag weer het Mountian Lion dock willen hebben, weten jullie hoe ik dit op kan lossen?
Ik kan Mountain Lion niet opnieuw installeren, want het is gekocht op het Apple ID van mijn vader, en die zit nu in het buitenland..
  • Hansie_P
  • Laatst online: 03:23
Kijk even bij je instellingen: System Preferences -> Dock. Hier kan je misschien wat instellen. En het feit dat je vader in het buitenland zit maakt voor je apple id toch niets uit? Of kan hij zijn account gegevens niet met je delen? Je kan anders ook altijd nog een recovery uitvoeren die je installatie kan herstellen.
Succes!
  • Psycho_Mantis
  • Laatst online: 00:06
Psycho_Mantis
Wow. So Amaze.
Hansie_P schreef op dinsdag 28 mei 2013 @ 20:37:
Succes!
Ik heb gisteren een recovery toevallig gedaan. Tijdens de recovery word er eerst om je Apple ID gevraagd. Dus zonder Apple ID gaat een recovery niet lukken.
  • peakrever
Ik was dus ook van plan om een recovery te doen, maar er werd inderdaad om het Apple ID gevraagd ;( Komt er misschien nog snel een 10.8.4 uit, en zal het dock dan wel weer normaal zijn?
  • m_a_rnix
  • Laatst online: 15-09 09:28
Ik geloof dat je daar je eigen Apple id moet invullen...
  • peakrever
Dat kan dus niet, want ik heb het niet gekocht..
  • HaterFrame
  • Laatst online: 08:11
HaterFrame
Well... Poo came out!
Ik ga even vloeken in de kerk hoor, maar als je de licentie hebt aangeschaft (jij of je vader, aangezien je 5 pcs er mee mag installeren) kun je de DMG toch via minder legale manieren downloaden en branden?
* HaterFrame ziet geen probleem?
I am the great Cornholio!
  • BillSpaarbank
MetaFrame schreef op woensdag 29 mei 2013 @ 07:41:
* BillSpaarbank ziet geen probleem?
Probleem is volgens mij dat beide Macs dan hetzelfde Apple-ID moeten gebruiken.
Een optimist is een slecht geïnformeerde pessimist...
  • HaterFrame
HaterFrame
Bij een nieuwe installatie heb je geen Apple id nodig toch?
  • THE_BASE
Arthur-M. schreef op dinsdag 28 mei 2013 @ 19:08:
Kun je niet naar Terminal en deze invoeren:
killall Dock
Dat reset Finder en Dock normaliter.
  • HaterFrame
HaterFrame
Mja maar dat zet evt. aangepaste bestanden en instellingen niet terug toch?
  • ankhie
ankhie
MetaFrame schreef op woensdag 29 mei 2013 @ 09:11:
HD/Users/YourUserName/Library/Preferences/com.apple.dock.plist
Deze even verplaatsen naar je bureaublad en opnieuw opstarten. Als het goed is maakt hij dan een nieuwe dock.plist aan en is alles zoals je je computer kreeg. Moet je alleen nog je icons er weer inzetten.
Anders kan je met Candybar proberen alles naar default terug te zetten. Zou in principe ook moeten werken.
Succes!
  • m_a_rnix
Arthur-M. schreef op woensdag 29 mei 2013 @ 07:36:
Je vult een Apple ID in om je kalenders en dergelijke te synchen, niet om te verifiëren dat het jouw kopie is...
  • JustRob
  • Laatst online: 07:19
Verbal_Kint schreef op woensdag 29 mei 2013 @ 12:31:
Tegenwoordig wel. Als je systeem niet out-of-the-box met ML kwam moet je bij een recovery een Apple ID invullen om te verifiëren dat je hem ook aangeschaft hebt. Kan oneindig vaak, maar moet wel een ID zijn waar het mee is aangeschaft.
Sony A6700 - 10-18 F4 - 18-50 F2.8 - 24 F1.8 - 56 F1.4 - 70-350G
  • peakrever
@THE_BASE en Ankhie; Bedankt! Het heeft allebei geholpen!
  • wrcveen
  • Registratie: Juli 1999
  • Laatst online: 12-10 16:47
Zou iemand iets voor mij willen proberen? Ik betaal een bedrijf om een camping reserveringsformulier te hosten. Nu schijnt dit niet te werken met Safari in OS X10.8?
Kan iemand deze pagina openen www.hetpolderbos.nl/component/content/article/36
Krijg je dan meteen een foutmelding in het formulier of kan je accommodaties reserveren? Als cookies accepteren aan staat zou het moeten werken volgens dat bedrijf.
Bedankt!
  • funske
  • Laatst online: 31-01-2023
wrcveen schreef op vrijdag 31 mei 2013 @ 14:09:
Bedankt!
Zowel bij NetNewsWire als bij Safari krijg ik de foutmelding:
U sessie is verlopen. Controleer of uw browser cookies accepteert
Als ik dan bij Safari ga kijken, is mijn standaard instelling "Blokker cookies van derden en adverteerders" Hiermee heb ik nooit problemen. Als ik de instelling op "nooit" blokkeren zet kan ik inderdaad wel meteen een accomodatie selecteren.
Have Fun Funske
  • thaan
Bedankt!
Komt inderdaad door wat funske zegt, je maakt gebruik van een iframe en cookies die door de iframe worden gezet worden niet altijd geaccepteerd. Niet zo'n nette manier om een formulier op je site te plaatsen.
Het bedrijf kan hier vast een mooie oplossing voor vinden, daar betaal je ze immers voor ;)
