[SETI@Home] hitparade van week 46 Vorige deel Overzicht Volgende deel Laatste deel
  • grass460
  • Laatst online: 30-10 23:57
grass460
[DPC] Division_Brabant
Mede-auteur:
  • APClll
  • Laatst online: 00:11
APClll
Afbeeldingslocatie: http://tweakers.net/ext/f/JC7kwqqV82fi9ViRWtJgzDBy/full.jpg
Inhoudsopgave Seti@Home hitparades week 46
* geen correcte stats beschikbaar
Wat is Seti@Home ?
Wat is SETI@home?
SETI@home is de naam van een wetenschappelijk experiment dat computers die via het internet met elkaar verbonden zijn, inzet om buitenaardse intelligentie op te sporen. U kunt hieraan deelnemen middels een gratis computerprogramma dat radiotelescoop-data download en analyseert.
Nieuws Update
9 Nov 2011 | 20:53:50 UTC
Funny story. About 3 years ago I realized that the BOINC database has result ids stored a integers, which are 4 bytes long and signed by default. The sign takes up one bit, thus leaving 31 bits remaining for the value. That means the maximum value is 2^31 (2 to the power of 31, or 2147483648). I mentioned this at this time, noting we were well on our way towards this maximum value, and put it on the "things we'll need to fix eventually" list.
Nobody has been really watching this (I've been pretty much out for over two months until this week), and sure enough we hit that limit yesterday, and the whole BOINC backend pretty much barfed. We tried to implement a "quick fix" by changing the result id signed integer to an unsigned integer (both in mysql and the C code), thus giving us an extra bit for the value. Now that means the maximum value is 2^32 (2 to the power of 32, or 4294967296). That should have bought us a couple more years.
However, this quick fix didn't really work. There's all kinds of code in BOINC that needs to be changed to get unsigned integers to work. Dave made some of these changes and Jeff tested them this morning, but still to no avail. More necessary fixes were found. We seem to be once again creating and sending out work at the moment. However the hood is wide open on BOINC now, so we're watching things carefully over the next day or so.
We're certainly not done - there are tons of cosmetic fixes that need to be made (our logs are full of entries containing negative result ids). In the long term we'll have to do the same for workunit ids, and at that point we'll probably go ahead and make them long longs (which are always 8 bytes, as opposed to longs, which are 4 bytes on 32-bit systems and 8 bytes on 64-bit systems) in the C code and bigints in mysql. At that point our id space will max out at 2305843009213693952, which should probably be enough. That's a million results a day for 6.3 billion years. If we're still running SETI@home 6.3 billion years from now there's probably nobody out there. Agreed?
We've been bitten by this long ago in informix, and have since been storing larger numbers there as int8's (8 byte integers) or doubles.
Warning: since we didn't come across this problem in advance and solve is gracefully, there may be some ugliness in the form of blocked results in weird states - these will most likely time out on their own and get resent. Sorry if this causes any confusion in the coming weeks.
By the way, it should be mentioned there were some random download server issues over this past weekend. No big deal - usual stuff regarding linux kernel hangs. We kicked the servers on monday morning and they went back to work.
- Matt
Ga naar de DPC website
  • grass460
grass460
zo weer verse stats in een nieuwe week.
Velen van ons hebben weer moeten krabben van ochtend, dat betekend dat koning winter weer in aantocht is.
Wij vinden dat wat minder maar onze koeien kunnen deze koele temps best gebruiken zodat we niet bang hoeven te zijn dat ze oververhit raken van al dat grazen.
Zoals vermeld komt koning winter, maar ook de friezen (Grutte Pier [Wa Oars]) zijn bezig aan een opmars en de eerste 100k is binnen, ook Edwin Gozeling heeft flink doorgewerkt en heeft zijn 3k mijlpaal binnen.
DPC SETI@Home hitparade van 13 november 2011
Afbeeldingslocatie: http://gathering.tweakers.net/global/templates/got/images/layout/pixel.gif
Daily Top 30
Flushers: 72 / 1.319 (5,5 %)
posdailymembertotal
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)52.344[DPC] hansR44.157.498(1)
2.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)31.338Tijntje12.123.601(8)
3.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)30.177[DPC]Div.Delft7.589.129(11)
4.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)14.621Falcon105.697.835(13)
5.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)12.586apa4.707.131(15)
6.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif6)7.575Ensign Wildfire13.857.071(6)
7.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif2)6.339Sp@ceNv@der23.389.598(2)
8.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)4.855Grutte Pier [Wa Oars]103.619(216)
9.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif4)4.730Wolfje6661.952.760(27)
10.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif4)4.186F@stmem7.581.835(12)
11.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif4)3.737Mxstream99.032(231)
12.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)3.530Teachalot2.159.958(24)
13.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif8)3.486[DPC] Switch12.670.048(7)
14.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)2.886AmeComputers3.691.154(16)
15.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif4)2.050Herby2.524.625(20)
16.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)1.524o25o9.334.670(10)
17.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif30)1.444NexceveN27.526(441)
18.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif7)1.331Berkie2.044.416(25)
19.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)1.159Asgoroth1.068.863(43)
20.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif4)1.115luc dk205.074(148)
21.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif3)1.102Eagle3210571.892(59)
22.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif43)1.082Arie Klerk57.279(303)
23.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif25)1.009MartenZ148.397(174)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif8)967Hans vandebos760.996(51)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif12)832Arno18.505(516)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif9)777[DPC] Brainy0071.456.332(34)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif18)747Haico31.102(417)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif30)712mmenke41.576(364)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif11)685Edwin Gozeling3.409(819)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif9)462hermanmonique810.954(48)
More...
Overall Top 30
postotalmemberdaily
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)44.157.498[DPC] hansR52.344(1)
2.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)23.389.598Sp@ceNv@der6.339(7)
3.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)19.093.129[DPC]Division_Brabant150(49)
4.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)18.878.890Searchy! Internet Services V.O.F.55(61)
5.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)17.533.059[DPC]TeamGrazzie336(39)
6.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)13.857.071Ensign Wildfire7.575(6)
7.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)12.670.048[DPC] Switch3.486(13)
8.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)12.123.601Tijntje31.338(2)
9.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)9.642.206MaGNeT (a.k.a. BlueTooth76)0(-)
10.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)9.334.670o25o1.524(16)
11.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)7.589.129[DPC]Div.Delft30.177(3)
12.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)7.581.835F@stmem4.186(10)
13.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)5.697.835Falcon1014.621(4)
14.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)5.685.852Bas Laurier0(-)
15.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)4.707.131apa12.586(5)
16.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)3.691.154AmeComputers2.886(14)
17.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)3.441.484Team_Elteor_Borislavj0(-)
18.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)3.200.789Mr Beamer0(-)
19.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.595.626dpc_kluizenaar0(-)
20.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.524.625Herby2.050(15)
21.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.513.166Jan Zandvliet & x-RaY990(-)
22.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.394.425[DPC]Trancemaus0(-)
23.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.216.648[DPC]Spinpoint0(-)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.159.958Teachalot3.530(12)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.044.416Berkie1.331(18)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.035.199Override0(-)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.952.760Wolfje6664.730(9)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.710.061Intrud3r0(-)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.643.787NicoClown0(-)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.602.694[DPC]Team Zuid-Holland0(-)
More...
Teams Daily Top 15
posdailyteamtotal
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)544.337.515SETI.USA2.691.821.162(1)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)230.348999158.838.654(57)
31.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif2)225.368US NAVY507.331.070(18)
32.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif4)223.567Ars Technica402.643.605(23)
33.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif2)219.995Phoenix Rising327.316.490(30)
34.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)217.204Quebec160.162.570(56)
35.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)211.981Elite Games349.285.628(27)
36.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif2)205.005Sweden200.981.985(42)
37.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif6)199.918Dutch Power Cows326.574.695(31)
38.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)186.492Brasil [SETIBR]318.051.445(34)
39.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif6)184.635Sicituradastra.147.715.499(62)
40.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif6)181.429Team Starfire World BOINC540.292.790(16)
41.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)177.860Hungary245.545.874(38)
42.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif5)171.147Team Norway188.172.397(46)
43.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)168.370Space Quest84.097.725(108)
44.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif4)166.160Universe Examiners298.258.194(37)
More...
Teams Overall Top 15
postotalteamdaily
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.691.821.162SETI.USA544.337.515(1)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)369.373.079Amateur Radio Operators287.503(26)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)367.476.074BOINC SETI@home RUSSIA491.399(12)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)356.206.415U.S.Air Force162.650(45)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)349.285.628Elite Games211.981(35)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)348.924.458Team MacNN143.463(49)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)344.192.616BOINC.Italy369.820(19)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)327.316.490Phoenix Rising219.995(33)
31.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)326.574.695Dutch Power Cows199.918(37)
32.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)322.005.123UK BOINC Team250.407(29)
33.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)321.038.812Boone Community School District - Iowa498.156(11)
34.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)318.051.445Brasil [SETIBR]186.492(38)
35.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)315.334.100Team NIPPON265.474(28)
36.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)304.703.618Carl Sagan310.119(24)
37.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)298.258.194Universe Examiners166.160(44)
38.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)245.545.874Hungary177.860(41)
More...
Megaflush Top 5
posTeamFlushDate
1.[DPC]Division_Brabant1.790.71126-02-2010
2.[DPC] hansR1.156.60326-02-2010
3.MaGNeT (a.k.a. BlueTooth76)959.79215-10-2010
4.Searchy! Internet Services V.O.F.785.77526-02-2010
5.[DPC]TeamGrazzie553.05604-01-2008
More...
Mijlpalen
Grutte Pier [Wa Oars]100.000
Edwin Gozeling3.000
SETI@Home Links
SETI@Home webpage
SETI@Home forum
DPCH Suggestiepagina
Bron
  • Arjant2
  • Laatst online: 22:04
Dacht weer een paar daagjes mee te doen, maar krijg geen werk :S
  • APClll
APClll
FP ProMod
[DPC] Team Grazzie
Arjant2 schreef op maandag 14 november 2011 @ 15:54:
Ik ben er even een tijdje tussenuit geweest, dus zeker weten doe ik 't niet, maar kan 't te maken hebben met bovenstaande nieuwspost van 9 november?
@ Grass460: bedankt voor 't posten (en inhalen) van de stats _/-\o_
Ouwe troep? Wat is dat?.......Alles is leuk, zelfs modelracing..........BOINC ook mee met DPC!
......Team Grazzie~Power....!! Mooooooeeeee......
  • grass460
grass460
Graag gedaan voor het posten van de stats. De nieuwe stats zijn er niet en daarmee is ook een beetje de vraag van Arjant2 beantwoord. Zie indd ook het nieuws item van 9 november.
GEEN stats....
DPC SETI@Home hitparade van 14 november 2011
Daily Top 30
Flushers: 0 / 1.319 (0,0 %)
posdailymembertotal
More...
Overall Top 30
postotalmemberdaily
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)44.157.498[DPC] hansR0(-)
2.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)23.389.598Sp@ceNv@der0(-)
3.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)19.093.129[DPC]Division_Brabant0(-)
4.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)18.878.890Searchy! Internet Services V.O.F.0(-)
5.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)17.533.059[DPC]TeamGrazzie0(-)
6.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)13.857.071Ensign Wildfire0(-)
7.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)12.670.048[DPC] Switch0(-)
8.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)12.123.601Tijntje0(-)
10.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)9.334.670o25o0(-)
11.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)7.589.129[DPC]Div.Delft0(-)
12.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)7.581.835F@stmem0(-)
13.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)5.697.835Falcon100(-)
14.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)5.685.852Bas Laurier0(-)
15.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)4.707.131apa0(-)
16.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)3.691.154AmeComputers0(-)
20.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.524.625Herby0(-)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.159.958Teachalot0(-)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.044.416Berkie0(-)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.952.760Wolfje6660(-)
More...
Teams Daily Top 15
posdailyteamtotal
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)548.035.033SETI.USA2.695.518.680(1)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)265.254Team NIPPON315.599.354(35)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)256.967UK BOINC Team322.262.090(32)
31.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)253.408US NAVY507.584.478(18)
32.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif3)230.769Elite Games349.516.397(27)
33.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)229.732Ars Technica402.873.337(23)
34.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)226.443Phoenix Rising327.542.933(30)
35.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)218.939Quebec160.381.509(56)
36.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)218.358Dutch Power Cows326.793.053(31)
37.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif2)213.888Sicituradastra.147.929.387(62)
38.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif4)213.560Team Norway188.385.957(46)
39.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif7)212.442Greece Masters60.298.122(148)
40.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif12)205.930SETI@Ticino193.265.673(44)
41.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)199.961Hungary245.745.835(38)
42.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)196.534Space Quest84.294.259(107)
43.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif5)195.806Brasil [SETIBR]318.247.251(34)
More...
postotalteamdaily
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.695.518.680SETI.USA548.035.033(1)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)369.704.760Amateur Radio Operators331.681(26)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)368.077.002BOINC SETI@home RUSSIA600.928(11)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)356.398.478U.S.Air Force192.063(45)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)349.516.397Elite Games230.769(32)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)349.079.717Team MacNN155.259(52)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)344.631.330BOINC.Italy438.714(18)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)327.542.933Phoenix Rising226.443(34)
31.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)326.793.053Dutch Power Cows218.358(36)
32.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)322.262.090UK BOINC Team256.967(30)
33.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)321.633.155Boone Community School District - Iowa594.343(12)
34.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)318.247.251Brasil [SETIBR]195.806(43)
35.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)315.599.354Team NIPPON265.254(29)
36.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)305.050.786Carl Sagan347.168(23)
37.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)298.415.807Universe Examiners157.613(49)
38.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)245.745.835Hungary199.961(41)
More...
Megaflush Top 5
posTeamFlushDate
More...
SETI@Home Links
SETI@Home webpage
SETI@Home forum
Bron
  • APClll
APClll
FP ProMod
[DPC] Team Grazzie
De stats zijn er weer, maar ze lijken nog niet geheel correct te zijn.
Het advies van uw statsposter is dan ook: haal eruit wat je zelf mooi vind, onthoud de cijfers die je aanstaan en negeer de rest. Of verplaats denkbeeldig wat "output" en "nullen" :+
Oh, en vergeet de wekker niet een paar minuten vroeger te zetten. Dat scheelt morgenochtend weer te laat komen als je autoruiten wederom dichtgevroren zitten ;)
{verhaal}
DPC SETI@Home hitparade van 15 november 2011
Daily Top 30
Flushers: 73 / 1.319 (5,5 %)
posdailymembertotal
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)59.496[DPC] hansR44.216.994(1)
2.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif)30.303[DPC]Div.Delft7.619.432(11)
3.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)26.866Tijntje12.150.467(8)
4.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)16.520Falcon105.714.355(13)
5.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif)9.018Ensign Wildfire13.866.089(6)
6.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)6.563apa4.713.694(15)
7.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif)6.127Grutte Pier [Wa Oars]109.746(212)
8.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif)5.611F@stmem7.587.446(12)
9.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)5.489Sp@ceNv@der23.395.087(2)
10.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif)4.387Teachalot2.164.345(24)
11.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)3.677Wolfje6661.956.437(27)
12.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)3.594Mxstream102.626(221)
13.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif)2.897Herby2.527.522(20)
14.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.581AmeComputers3.693.735(16)
15.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif)2.524Berkie2.046.940(25)
16.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif)2.484[DPC]Blah.NET591.984(57)
17.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)2.259o25o9.336.929(10)
18.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif)2.202K3th3r1.539.499(31)
19.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif)2.108luc dk207.182(147)
20.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif7)1.844[DPC] Switch12.671.892(7)
21.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif)1.558Gjalt176.517(155)
22.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif)1.520HellBringer1.348.859(35)
23.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif)1.28262vette462.071(72)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif3)1.124Eagle3210573.016(58)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif)1.100Mickroz21.879(487)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif7)1.094Asgoroth1.069.957(43)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif)1.045Themman7854.347(315)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif)1.014Confuzer405.140(84)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif6)1.002MartenZ149.399(172)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif5)843Arno19.348(507)
More...
Overall Top 30
postotalmemberdaily
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)44.216.994[DPC] hansR59.496(1)
2.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)23.395.087Sp@ceNv@der5.489(9)
3.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)19.093.211[DPC]Division_Brabant82(59)
4.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)18.879.169Searchy! Internet Services V.O.F.279(44)
5.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)17.533.516[DPC]TeamGrazzie457(36)
6.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)13.866.089Ensign Wildfire9.018(5)
7.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)12.671.892[DPC] Switch1.844(20)
8.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)12.150.467Tijntje26.866(3)
10.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)9.336.929o25o2.259(17)
11.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)7.619.432[DPC]Div.Delft30.303(2)
12.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)7.587.446F@stmem5.611(8)
13.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)5.714.355Falcon1016.520(4)
15.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)4.713.694apa6.563(6)
16.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)3.693.735AmeComputers2.581(14)
20.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.527.522Herby2.897(13)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.164.345Teachalot4.387(10)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.046.940Berkie2.524(15)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.956.437Wolfje6663.677(11)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.644.506NicoClown719(32)
More...
Teams Daily Top 15
posdailyteamtotal
More...
postotalteamdaily
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)369.704.760Amateur Radio Operators0(-)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)368.077.002BOINC SETI@home RUSSIA0(-)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)356.398.478U.S.Air Force0(-)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)349.516.397Elite Games0(-)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)349.079.717Team MacNN0(-)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)344.631.330BOINC.Italy0(-)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)327.542.933Phoenix Rising0(-)
31.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)326.793.053Dutch Power Cows0(-)
32.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)322.262.090UK BOINC Team0(-)
33.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)321.633.155Boone Community School District - Iowa0(-)
34.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)318.247.251Brasil [SETIBR]0(-)
35.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)315.599.354Team NIPPON0(-)
36.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)305.050.786Carl Sagan0(-)
37.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)298.415.807Universe Examiners0(-)
38.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)245.745.835Hungary0(-)
More...
Megaflush Top 5
posTeamFlushDate
More...
Mijlpalen
Gjalt175.000
Mxstream100.000
GeppyZ3.000
SETI@Home Links
SETI@Home webpage
SETI@Home forum
Bron
  • grass460
grass460
DPC SETI@Home hitparade van 16 november 2011
Daily Top 30
posdailymembertotal
More...
Overall Top 30
postotalmemberdaily
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)44.216.994[DPC] hansR0(-)
2.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)23.395.087Sp@ceNv@der0(-)
3.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)19.093.211[DPC]Division_Brabant0(-)
4.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)18.879.169Searchy! Internet Services V.O.F.0(-)
5.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)17.533.516[DPC]TeamGrazzie0(-)
6.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)13.866.089Ensign Wildfire0(-)
7.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)12.671.892[DPC] Switch0(-)
8.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)12.150.467Tijntje0(-)
10.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)9.336.929o25o0(-)
11.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)7.619.432[DPC]Div.Delft0(-)
12.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)7.587.446F@stmem0(-)
13.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)5.714.355Falcon100(-)
15.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)4.713.694apa0(-)
16.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)3.693.735AmeComputers0(-)
20.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.527.522Herby0(-)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.164.345Teachalot0(-)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.046.940Berkie0(-)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.956.437Wolfje6660(-)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.644.506NicoClown0(-)
More...
Teams Daily Top 15
posdailyteamtotal
More...
postotalteamdaily
More...
Megaflush Top 5
posTeamFlushDate
More...
SETI@Home Links
SETI@Home webpage
SETI@Home forum
Bron
  • grass460
grass460
Compizfox heeft onze club als nieuwe stal gekozen. Welkom
De mijlpaal grazers ook weer van harte proficiat.
dan nu de stats.
DPC SETI@Home hitparade van 17 november 2011
Daily Top 30
Flushers: 89 / 1.320 (6,7 %)
posdailymembertotal
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)116.872[DPC] hansR44.333.866(1)
2.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)66.825[DPC]Div.Delft7.686.257(11)
3.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)54.889Tijntje12.205.356(8)
4.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)32.377Falcon105.746.732(13)
5.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif)20.859Grutte Pier [Wa Oars]130.605(191)
6.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)14.147Ensign Wildfire13.880.236(6)
7.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif)12.955F@stmem7.600.401(12)
8.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)10.871apa4.724.565(15)
9.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif)10.225Teachalot2.174.570(24)
10.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif)9.961o25o9.346.890(10)
11.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)8.290Wolfje6661.964.727(27)
12.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif)8.277Herby2.535.799(20)
13.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif)6.716[DPC] Switch12.678.608(7)
14.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif)5.841HellBringer1.354.700(35)
15.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif6)4.682Sp@ceNv@der23.399.769(2)
16.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)4.475AmeComputers3.698.210(16)
17.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif)4.249Asgoroth1.074.206(42)
18.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif)3.688luc dk210.870(147)
19.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif7)2.840Mxstream105.466(216)
20.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif)2.435TheCalculator52.590(323)
21.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif6)2.381Berkie2.049.321(25)
22.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif)2.363Searchy! Internet Services V.O.F.18.881.532(4)
23.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif5)2.101K3th3r1.541.600(31)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif)2.023Jox4441.522.790(32)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif)1.744Betrayedcover40.024(371)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif)1.655Andre Barnier435.677(79)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif)1.649MartenZ151.048(171)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif4)1.593Eagle3210574.609(58)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif)1.588JNSILVIUS95.976(236)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif)1.449Cronenborgh355.187(95)
More...
Overall Top 30
postotalmemberdaily
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)44.333.866[DPC] hansR116.872(1)
2.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)23.399.769Sp@ceNv@der4.682(15)
3.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)19.093.940[DPC]Division_Brabant729(45)
4.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)18.881.532Searchy! Internet Services V.O.F.2.363(22)
5.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)17.534.944[DPC]TeamGrazzie1.428(32)
6.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)13.880.236Ensign Wildfire14.147(6)
7.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)12.678.608[DPC] Switch6.716(13)
8.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)12.205.356Tijntje54.889(3)
10.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)9.346.890o25o9.961(10)
11.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)7.686.257[DPC]Div.Delft66.825(2)
12.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)7.600.401F@stmem12.955(7)
13.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)5.746.732Falcon1032.377(4)
15.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)4.724.565apa10.871(8)
16.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)3.698.210AmeComputers4.475(16)
20.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.535.799Herby8.277(12)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.174.570Teachalot10.225(9)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.049.321Berkie2.381(21)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.964.727Wolfje6668.290(11)
More...
Teams Daily Top 15
posdailyteamtotal
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)554.906.957SETI.USA2.702.390.604(1)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif)557.649Team NIPPON316.157.003(35)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)548.577999159.683.717(57)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)515.864UK BOINC Team322.777.954(32)
31.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)503.950US NAVY508.088.428(18)
32.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)494.783Elite Games350.011.180(27)
33.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif)457.429Quebec160.838.938(56)
34.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)455.517Ars Technica403.328.854(23)
35.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif)451.783Dutch Power Cows327.244.836(31)
36.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)447.328Phoenix Rising327.990.261(30)
37.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif)443.512SETI@Ticino193.709.185(44)
38.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)429.291Sicituradastra.148.358.678(62)
39.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif)413.272Team Starfire World BOINC540.889.645(16)
40.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif)412.730Space Quest84.706.989(107)
41.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif3)412.483Team Norway188.798.440(46)
42.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif)406.8872CPU.com209.092.185(41)
More...
postotalteamdaily
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.702.390.604SETI.USA554.906.957(1)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)370.375.247Amateur Radio Operators670.487(26)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)369.260.396BOINC SETI@home RUSSIA1.183.394(11)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)356.792.294U.S.Air Force393.816(44)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)350.011.180Elite Games494.783(32)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)349.393.124Team MacNN313.407(52)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)345.474.466BOINC.Italy843.136(19)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)327.990.261Phoenix Rising447.328(36)
31.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)327.244.836Dutch Power Cows451.783(35)
32.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)322.777.954UK BOINC Team515.864(30)
33.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)322.746.399Boone Community School District - Iowa1.113.244(14)
34.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)318.636.351Brasil [SETIBR]389.100(45)
35.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)316.157.003Team NIPPON557.649(28)
36.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)305.767.830Carl Sagan717.044(23)
37.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)298.741.871Universe Examiners326.064(50)
38.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)246.129.631Hungary383.796(46)
More...
Megaflush Top 5
posTeamFlushDate
More...
Mijlpalen
MartenZ150.000
Grutte Pier [Wa Oars]125.000
Handige Harrie100.000
Betrayedcover40.000
[DPC] Mastha-Hacker30.000
Kevin10.000
Edwin Gozeling4.000
Nieuwe Leden
Compizfox24
SETI@Home Links
SETI@Home webpage
SETI@Home forum
Bron
  • grass460
grass460
En Falcon10 heeft een mooie mijlpaal .... Congratz
DPC SETI@Home hitparade van 18 november 2011
Daily Top 30
Flushers: 73 / 1.320 (5,5 %)
posdailymembertotal
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)53.950[DPC] hansR44.387.816(1)
2.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)21.588Tijntje12.226.944(8)
3.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)20.483[DPC]Div.Delft7.706.740(11)
4.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)15.400Falcon105.762.132(13)
5.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)12.774Grutte Pier [Wa Oars]143.379(183)
6.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)6.479F@stmem7.606.880(12)
7.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif5)5.643Herby2.541.442(20)
8.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)5.634Teachalot2.180.204(24)
9.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif3)5.235Ensign Wildfire13.885.471(6)
10.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif5)5.092Sp@ceNv@der23.404.861(2)
11.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)4.064o25o9.350.954(10)
12.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)3.281Wolfje6661.968.008(27)
13.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)3.211[DPC] Switch12.681.819(7)
14.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif6)3.012apa4.727.577(15)
15.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)2.528AmeComputers3.700.738(16)
16.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)2.045Asgoroth1.076.251(42)
17.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif10)1.665MartenZ152.713(170)
18.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif13)1.650Gjalt179.600(154)
19.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif4)1.644K3th3r1.543.244(31)
20.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)1.588luc dk212.458(147)
21.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif7)1.322Eagle3210575.931(58)
22.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif41)1.322Maarten241.960(130)
23.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)1.285Berkie2.050.606(25)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif22)987hermanmonique812.704(48)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif11)952HellBringer1.355.652(35)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif43)904Handige Harrie100.973(227)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif5)879Searchy! Internet Services V.O.F.18.882.411(4)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif9)813[DPC] Brainy0071.458.758(34)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif12)789Jan Boer207.785(148)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif49)779Richard14.736(554)
More...
Overall Top 30
postotalmemberdaily
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)44.387.816[DPC] hansR53.950(1)
2.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)23.404.861Sp@ceNv@der5.092(10)
3.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)19.094.259[DPC]Division_Brabant319(43)
4.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)18.882.411Searchy! Internet Services V.O.F.879(27)
5.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)17.535.614[DPC]TeamGrazzie670(33)
6.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)13.885.471Ensign Wildfire5.235(9)
7.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)12.681.819[DPC] Switch3.211(13)
8.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)12.226.944Tijntje21.588(2)
10.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)9.350.954o25o4.064(11)
11.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)7.706.740[DPC]Div.Delft20.483(3)
12.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)7.606.880F@stmem6.479(6)
13.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)5.762.132Falcon1015.400(4)
15.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)4.727.577apa3.012(14)
16.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)3.700.738AmeComputers2.528(15)
20.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.541.442Herby5.643(7)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.180.204Teachalot5.634(8)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.050.606Berkie1.285(23)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.968.008Wolfje6663.281(12)
More...
Teams Daily Top 15
posdailyteamtotal
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)558.578.782SETI.USA2.706.062.429(1)
37.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif4)217.468Quebec161.056.406(56)
38.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif5)210.218Sweden201.792.576(42)
39.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif6)207.897Brasil [SETIBR]318.844.248(34)
40.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif2)206.7112CPU.com209.298.896(41)
41.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif5)199.818Hungary246.329.449(38)
42.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)197.125Team Norway188.995.565(46)
43.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif9)195.665Ars Technica403.524.519(23)
44.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif9)194.308Dutch Power Cows327.439.144(31)
45.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif6)192.599Team Starfire World BOINC541.082.244(16)
46.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)189.323U.S.Air Force356.981.617(26)
47.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif3)178.787Universe Examiners298.920.658(37)
48.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif9)162.094SwissTeam.NET156.779.015(58)
49.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif5)161.576Team MacAddict171.111.929(52)
50.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)159.757Greece Masters60.792.637(148)
51.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)157.394Team MacNN349.550.518(28)
More...
postotalteamdaily
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.706.062.429SETI.USA558.578.782(1)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)370.667.417Amateur Radio Operators292.170(26)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)369.923.690BOINC SETI@home RUSSIA663.294(11)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)356.981.617U.S.Air Force189.323(46)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)350.254.441Elite Games243.261(31)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)349.550.518Team MacNN157.394(51)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)345.956.578BOINC.Italy482.112(18)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)328.211.467Phoenix Rising221.206(35)
31.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)327.439.144Dutch Power Cows194.308(44)
32.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)323.242.317Boone Community School District - Iowa495.918(17)
33.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)323.038.539UK BOINC Team260.585(30)
34.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)318.844.248Brasil [SETIBR]207.897(39)
35.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)316.443.537Team NIPPON286.534(27)
36.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)306.146.247Carl Sagan378.417(22)
37.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)298.920.658Universe Examiners178.787(47)
38.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)246.329.449Hungary199.818(41)
More...
Megaflush Top 5
posTeamFlushDate
More...
Mijlpalen
Falcon105.750.000
SETI@Home Links
SETI@Home webpage
SETI@Home forum
Bron
  • APClll
APClll
FP ProMod
[DPC] Team Grazzie
En wederom dank voor 't inhalen van de stats.
Ik moet mezelf toch iets meer dwingen regelmatiger de stats te controleren. Want eigenlijk hoort 't niet te kunnen dat we een aantal dagen zonder stats zitten... :$
  • grass460
grass460
En de laatste van deze week
no fancy pancy story.
Vier mijlpaal grazers bij deze gefeliciteerd.
DPC SETI@Home hitparade van 19 november 2011
Daily Top 30
Flushers: 68 / 1.320 (5,2 %)
posdailymembertotal
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)46.412[DPC] hansR44.434.228(1)
2.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)42.453[DPC]Div.Delft7.749.193(11)
3.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)26.204Tijntje12.253.148(8)
4.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)12.683Falcon105.774.815(13)
5.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)9.316Grutte Pier [Wa Oars]152.695(171)
6.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif3)6.997Ensign Wildfire13.892.468(6)
7.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif3)6.496Sp@ceNv@der23.411.357(2)
8.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif6)6.173apa4.733.750(15)
9.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif2)5.151o25o9.356.105(10)
10.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif4)5.130F@stmem7.612.010(12)
11.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)4.550Wolfje6661.972.558(27)
12.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif5)4.366Herby2.545.808(20)
13.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif5)2.720Teachalot2.182.924(24)
14.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif28)2.403Betrayedcover42.755(360)
15.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif18)2.083[DPC]TeamGrazzie17.537.697(5)
16.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif3)1.870[DPC] Switch12.683.689(7)
17.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif2)1.732K3th3r1.544.976(31)
18.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif3)1.580AmeComputers3.702.318(16)
19.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif3)1.470Asgoroth1.077.721(42)
20.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.213luc dk213.671(147)
21.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif2)1.069Berkie2.051.675(25)
22.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)1.020Eagle3210576.951(58)
23.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif6)1.011MartenZ153.724(169)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif33)975Disaster_Master65.476(285)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif37)935jvissch2150.625(174)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif12)835Mxstream106.838(214)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif9)829Andre Barnier437.113(79)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif27)693Geejay173.854(156)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif4)689HellBringer1.356.341(35)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif14)636Maurice50435.279(753)
More...
Overall Top 30
postotalmemberdaily
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)44.434.228[DPC] hansR46.412(1)
2.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)23.411.357Sp@ceNv@der6.496(7)
3.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)19.094.393[DPC]Division_Brabant134(54)
4.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)18.882.735Searchy! Internet Services V.O.F.324(40)
5.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)17.537.697[DPC]TeamGrazzie2.083(15)
6.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)13.892.468Ensign Wildfire6.997(6)
7.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)12.683.689[DPC] Switch1.870(16)
8.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)12.253.148Tijntje26.204(3)
10.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)9.356.105o25o5.151(9)
11.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)7.749.193[DPC]Div.Delft42.453(2)
12.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)7.612.010F@stmem5.130(10)
13.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)5.774.815Falcon1012.683(4)
15.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)4.733.750apa6.173(8)
16.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)3.702.318AmeComputers1.580(18)
20.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.545.808Herby4.366(12)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.182.924Teachalot2.720(13)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.051.675Berkie1.069(21)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.035.228Override29(67)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.972.558Wolfje6664.550(11)
More...
Teams Daily Top 15
posdailyteamtotal
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)561.602.434SETI.USA2.709.086.081(1)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif2)256.799BOINC Synergy717.940.858(11)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)253.811Team NIPPON316.697.348(35)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)241.842US NAVY508.615.383(18)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)241.768UK BOINC Team323.280.307(33)
31.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)217.955Elite Games350.472.396(27)
32.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)210.732999160.134.397(57)
33.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif2)206.128Phoenix Rising328.417.595(30)
34.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif10)205.191Dutch Power Cows327.644.335(31)
35.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)204.466Sicituradastra.148.783.929(62)
36.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)193.996Space Quest85.126.952(107)
37.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)191.489Sweden201.984.065(42)
38.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif5)189.789SETI@Ticino194.126.073(44)
39.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)188.632Quebec161.245.038(56)
40.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)183.193Brasil [SETIBR]319.027.441(34)
41.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif2)181.521Ars Technica403.706.040(23)
More...
postotalteamdaily
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.709.086.081SETI.USA561.602.434(1)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)370.941.295Amateur Radio Operators273.878(26)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)370.449.112BOINC SETI@home RUSSIA525.422(12)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)357.153.562U.S.Air Force171.945(45)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)350.472.396Elite Games217.955(31)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)349.678.998Team MacNN128.480(57)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)346.395.082BOINC.Italy438.504(18)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)328.417.595Phoenix Rising206.128(33)
31.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)327.644.335Dutch Power Cows205.191(34)
32.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)323.737.863Boone Community School District - Iowa495.546(14)
33.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)323.280.307UK BOINC Team241.768(30)
34.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)319.027.441Brasil [SETIBR]183.193(40)
35.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)316.697.348Team NIPPON253.811(28)
36.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)306.497.019Carl Sagan350.772(21)
37.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)299.081.930Universe Examiners161.272(48)
38.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)246.502.170Hungary172.721(44)
More...
Megaflush Top 5
posTeamFlushDate
More...
Mijlpalen
rlmeijer300.000
Grutte Pier [Wa Oars]150.000
jvissch2150.000
Maurice50435.000
SETI@Home Links
SETI@Home webpage
SETI@Home forum
Bron
  • grass460
grass460
APClll schreef op zondag 20 november 2011 @ 13:52:
Graag gedaan :) , en ja geen stats plaatse doet het project ook geen goed natuurlijk. Ik zelf ga het ook weer wat beter bij houden :$
