[SETI@Home] hitparade van week 45 Vorige deel Overzicht Volgende deel Laatste deel
  • grass460
  • Laatst online: 30-10 23:57
grass460
[DPC] Division_Brabant
Afbeeldingslocatie: http://tweakers.net/ext/f/JC7kwqqV82fi9ViRWtJgzDBy/full.jpg
Inhoudsopgave Seti@Home hitparades week 45
* geen correcte stats beschikbaar
Wat is Seti@Home ?
Wat is SETI@home?
SETI@home is de naam van een wetenschappelijk experiment dat computers die via het internet met elkaar verbonden zijn, inzet om buitenaardse intelligentie op te sporen. U kunt hieraan deelnemen middels een gratis computerprogramma dat radiotelescoop-data download en analyseert.
Nieuws Update
9 Nov 2011 | 20:53:50 UTC
Funny story. About 3 years ago I realized that the BOINC database has result ids stored a integers, which are 4 bytes long and signed by default. The sign takes up one bit, thus leaving 31 bits remaining for the value. That means the maximum value is 2^31 (2 to the power of 31, or 2147483648). I mentioned this at this time, noting we were well on our way towards this maximum value, and put it on the "things we'll need to fix eventually" list.
Nobody has been really watching this (I've been pretty much out for over two months until this week), and sure enough we hit that limit yesterday, and the whole BOINC backend pretty much barfed. We tried to implement a "quick fix" by changing the result id signed integer to an unsigned integer (both in mysql and the C code), thus giving us an extra bit for the value. Now that means the maximum value is 2^32 (2 to the power of 32, or 4294967296). That should have bought us a couple more years.
However, this quick fix didn't really work. There's all kinds of code in BOINC that needs to be changed to get unsigned integers to work. Dave made some of these changes and Jeff tested them this morning, but still to no avail. More necessary fixes were found. We seem to be once again creating and sending out work at the moment. However the hood is wide open on BOINC now, so we're watching things carefully over the next day or so.
We're certainly not done - there are tons of cosmetic fixes that need to be made (our logs are full of entries containing negative result ids). In the long term we'll have to do the same for workunit ids, and at that point we'll probably go ahead and make them long longs (which are always 8 bytes, as opposed to longs, which are 4 bytes on 32-bit systems and 8 bytes on 64-bit systems) in the C code and bigints in mysql. At that point our id space will max out at 2305843009213693952, which should probably be enough. That's a million results a day for 6.3 billion years. If we're still running SETI@home 6.3 billion years from now there's probably nobody out there. Agreed?
We've been bitten by this long ago in informix, and have since been storing larger numbers there as int8's (8 byte integers) or doubles.
Warning: since we didn't come across this problem in advance and solve is gracefully, there may be some ugliness in the form of blocked results in weird states - these will most likely time out on their own and get resent. Sorry if this causes any confusion in the coming weeks.
By the way, it should be mentioned there were some random download server issues over this past weekend. No big deal - usual stuff regarding linux kernel hangs. We kicked the servers on monday morning and they went back to work.
- Matt
Ga naar de DPC website
  • grass460
grass460
DPC SETI@Home hitparade van 6 november 2011
Afbeeldingslocatie: http://gathering.tweakers.net/global/templates/got/images/layout/pixel.gif
Daily Top 30
Flushers: 71 / 1.319 (5,4 %)
posdailymembertotal
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)60.354[DPC] hansR43.775.976(1)
2.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)37.618Tijntje11.891.370(8)
3.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)31.139[DPC]Div.Delft7.377.849(12)
4.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)26.080Falcon105.554.667(14)
5.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif2)8.523Ensign Wildfire13.795.516(6)
6.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)6.797apa4.648.245(15)
7.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif7)6.202F@stmem7.541.092(11)
8.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)5.496Sp@ceNv@der23.341.301(2)
9.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif3)4.720Grutte Pier [Wa Oars]47.708(338)
10.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif24)4.563[DPC]Blah.NET571.938(58)
11.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)3.750Teachalot2.125.873(24)
12.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)3.680Herby2.494.829(21)
13.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif4)3.627Wolfje6661.922.806(27)
14.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif6)2.509o25o9.304.187(10)
15.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif3)2.413[DPC] Switch12.646.798(7)
16.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif27)1.874groentje65.616(282)
17.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif6)1.828AmeComputers3.671.022(16)
18.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif60)1.690Hans vandebos758.217(51)
19.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif9)1.611rlmeijer292.730(112)
20.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif22)1.563Jox4441.518.136(32)
21.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif4)1.445K3th3r1.527.062(31)
22.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif2)1.405Confuzer393.376(88)
23.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)1.130MartenZ142.154(184)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif5)1.122Asgoroth1.053.463(43)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif41)1.089Cronenborgh350.792(96)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.070Disaster_Master57.995(301)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif11)1.039[DPC] Brainy0071.445.839(34)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif13)1.027Maarten234.710(134)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)1.007Opiate176.414(154)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif18)882hermanmonique807.769(48)
More...
Overall Top 30
postotalmemberdaily
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)43.775.976[DPC] hansR60.354(1)
2.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)23.341.301Sp@ceNv@der5.496(8)
3.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)19.091.101[DPC]Division_Brabant660(34)
4.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)18.874.747Searchy! Internet Services V.O.F.139(61)
5.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)17.531.557[DPC]TeamGrazzie142(59)
6.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)13.795.516Ensign Wildfire8.523(5)
7.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)12.646.798[DPC] Switch2.413(15)
8.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)11.891.370Tijntje37.618(2)
9.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)9.642.206MaGNeT (a.k.a. BlueTooth76)0(-)
10.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)9.304.187o25o2.509(14)
11.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)7.541.092F@stmem6.202(7)
12.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)7.377.849[DPC]Div.Delft31.139(3)
13.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)5.685.852Bas Laurier0(-)
14.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)5.554.667Falcon1026.080(4)
15.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)4.648.245apa6.797(6)
16.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)3.671.022AmeComputers1.828(17)
17.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)3.441.484Team_Elteor_Borislavj0(-)
18.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)3.200.789Mr Beamer0(-)
19.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.595.626dpc_kluizenaar0(-)
20.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.513.166Jan Zandvliet & x-RaY990(-)
21.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.494.829Herby3.680(12)
22.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.394.425[DPC]Trancemaus0(-)
23.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.216.648[DPC]Spinpoint0(-)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.125.873Teachalot3.750(11)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.035.669Berkie320(49)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.035.199Override0(-)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.922.806Wolfje6663.627(13)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.710.061Intrud3r0(-)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.643.787NicoClown0(-)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.602.694[DPC]Team Zuid-Holland0(-)
More...
Teams Daily Top 15
posdailyteamtotal
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)524.351.651SETI.USA2.671.835.298(1)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)337.117BroadbandReports.com Team Starfire617.539.635(14)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif6)307.046999156.880.321(57)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)305.923BOINC Synergy714.232.664(11)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)303.079Amateur Radio Operators366.992.787(24)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)267.141UK BOINC Team320.027.634(32)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)262.801Team NIPPON313.388.692(35)
31.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)258.204US NAVY505.535.643(18)
32.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif4)253.979Dutch Power Cows324.926.790(31)
33.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif6)242.414Quebec158.372.769(56)
34.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)231.647Space Quest82.577.437(111)
35.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)218.713Team Norway186.589.373(46)
36.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif5)211.695Elite Games347.525.340(28)
37.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)206.285Ars Technica400.993.503(23)
38.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)198.704U.S.Air Force354.702.626(26)
39.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif6)195.260Nosu dba team110.916.310(82)
More...
Teams Overall Top 15
postotalteamdaily
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.671.835.298SETI.USA524.351.651(1)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)366.992.787Amateur Radio Operators303.079(28)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)363.249.847BOINC SETI@home RUSSIA584.465(9)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)354.702.626U.S.Air Force198.704(38)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)347.832.303Team MacNN141.637(56)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)347.525.340Elite Games211.695(36)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)340.952.718BOINC.Italy499.215(18)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)325.741.819Phoenix Rising153.534(49)
31.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)324.926.790Dutch Power Cows253.979(32)
32.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)320.027.634UK BOINC Team267.141(29)
33.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)317.045.023Boone Community School District - Iowa535.854(14)
34.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)316.610.035Brasil [SETIBR]181.420(41)
35.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)313.388.692Team NIPPON262.801(30)
36.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)302.122.297Carl Sagan339.054(24)
37.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)297.092.443Universe Examiners157.651(48)
38.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)244.100.918Hungary178.045(42)
More...
Megaflush Top 5
posTeamFlushDate
1.[DPC]Division_Brabant1.790.71126-02-2010
2.[DPC] hansR1.156.60326-02-2010
3.MaGNeT (a.k.a. BlueTooth76)959.79215-10-2010
4.Searchy! Internet Services V.O.F.785.77526-02-2010
5.[DPC]TeamGrazzie553.05604-01-2008
More...
Mijlpalen
Kevin6.000
Edwin Gozeling1.000
SETI@Home Links
SETI@Home webpage
SETI@Home forum
DPCH Suggestiepagina
Bron
  • grass460
grass460
DPC SETI@Home hitparade van 7 november 2011
Daily Top 30
Flushers: 73 / 1.319 (5,5 %)
posdailymembertotal
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)46.173[DPC] hansR43.822.149(1)
2.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)28.253Tijntje11.919.623(8)
3.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)24.919[DPC]Div.Delft7.402.768(12)
4.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)24.889Falcon105.579.556(14)
5.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)10.149apa4.658.394(15)
6.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)8.750F@stmem7.549.842(11)
7.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif7)8.665o25o9.312.852(10)
8.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)7.139Grutte Pier [Wa Oars]54.847(312)
9.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)5.024Sp@ceNv@der23.346.325(2)
10.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif5)4.336Ensign Wildfire13.799.852(6)
11.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)4.147[DPC]Blah.NET576.085(57)
12.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)4.118Herby2.498.947(21)
13.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif2)3.576[DPC] Switch12.650.374(7)
14.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif22)3.320HellBringer1.343.235(35)
15.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)3.264Wolfje6661.926.070(27)
16.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif6)2.621Confuzer395.997(88)
17.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif6)2.371Teachalot2.128.244(24)
18.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif3)2.113K3th3r1.529.175(31)
19.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif19)1.870Gjalt167.600(158)
20.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif29)1.740Berkie2.037.409(25)
21.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif22)1.691Betrayedcover34.388(393)
22.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif15)1.576Jan Boer201.238(148)
23.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif6)1.463AmeComputers3.672.485(16)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif7)1.415Eagle3210564.769(59)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif8)1.335Andre Barnier430.049(80)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)1.234[DPC] Brainy0071.447.073(34)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif28)1.161Haico28.964(430)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif35)1.045Bigfoot73.481(268)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.038Opiate177.452(154)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif11)1.026Mickroz16.778(532)
More...
Overall Top 30
postotalmemberdaily
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)43.822.149[DPC] hansR46.173(1)
2.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)23.346.325Sp@ceNv@der5.024(9)
3.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)19.091.215[DPC]Division_Brabant114(65)
4.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)18.874.962Searchy! Internet Services V.O.F.215(54)
5.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)17.532.088[DPC]TeamGrazzie531(39)
6.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)13.799.852Ensign Wildfire4.336(10)
7.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)12.650.374[DPC] Switch3.576(13)
8.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)11.919.623Tijntje28.253(2)
10.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)9.312.852o25o8.665(7)
11.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)7.549.842F@stmem8.750(6)
12.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)7.402.768[DPC]Div.Delft24.919(3)
14.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)5.579.556Falcon1024.889(4)
15.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)4.658.394apa10.149(5)
16.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)3.672.485AmeComputers1.463(23)
21.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.498.947Herby4.118(12)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.128.244Teachalot2.371(17)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.037.409Berkie1.740(20)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.926.070Wolfje6663.264(15)
More...
Teams Daily Top 15
posdailyteamtotal
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)526.670.387SETI.USA2.674.154.034(1)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif5)270.109Space Quest82.847.546(111)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)255.196UK BOINC Team320.282.830(32)
31.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif5)248.733999157.129.054(57)
32.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif4)229.202Elite Games347.754.542(28)
33.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)225.843Quebec158.598.612(56)
34.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif3)222.930Ars Technica401.216.433(23)
35.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif4)219.864US NAVY505.755.507(18)
36.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif4)212.071Dutch Power Cows325.138.861(31)
37.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)200.428U.S.Air Force354.903.054(26)
38.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif3)198.851Team Norway186.788.224(46)
39.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif3)185.337Hungary244.286.255(38)
40.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif9)178.423Phoenix Rising325.920.242(30)
41.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)177.448Sweden199.699.201(42)
42.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif8)175.490Sicituradastra.146.594.353(63)
43.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif3)174.355Team Starfire World BOINC539.069.405(16)
More...
postotalteamdaily
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.674.154.034SETI.USA526.670.387(1)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)367.290.374Amateur Radio Operators297.587(26)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)363.759.767BOINC SETI@home RUSSIA509.920(14)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)354.903.054U.S.Air Force200.428(37)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)347.976.037Team MacNN143.734(51)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)347.754.542Elite Games229.202(32)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)341.343.314BOINC.Italy390.596(20)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)325.920.242Phoenix Rising178.423(40)
31.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)325.138.861Dutch Power Cows212.071(36)
32.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)320.282.830UK BOINC Team255.196(30)
33.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)317.605.965Boone Community School District - Iowa560.942(11)
34.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)316.768.451Brasil [SETIBR]158.416(46)
35.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)313.671.969Team NIPPON283.277(28)
36.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)302.443.439Carl Sagan321.142(24)
37.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)297.226.900Universe Examiners134.457(55)
38.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)244.286.255Hungary185.337(39)
More...
Megaflush Top 5
posTeamFlushDate
More...
Mijlpalen
Jan Boer200.000
Shalingoul60.000
Grutte Pier [Wa Oars]50.000
didi10.000
Kevin7.000
SETI@Home Links
SETI@Home webpage
SETI@Home forum
Bron
  • grass460
grass460
DPC SETI@Home hitparade van 8 November 2011
Daily Top 30
Flushers: 81 / 1.319 (6,1 %)
posdailymembertotal
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)35.676[DPC] hansR43.857.825(1)
2.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)31.495Tijntje11.951.118(8)
3.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)27.763[DPC]Div.Delft7.430.531(12)
4.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)23.267Falcon105.602.823(14)
5.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif3)10.225Grutte Pier [Wa Oars]65.072(285)
6.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif4)8.890Ensign Wildfire13.808.742(6)
7.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif2)7.681Sp@ceNv@der23.354.006(2)
8.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)7.501F@stmem7.557.343(11)
9.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif2)7.498[DPC]Blah.NET583.583(57)
10.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif5)6.759apa4.665.153(15)
11.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif6)6.573Teachalot2.134.817(24)
12.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif3)4.935Wolfje6661.931.005(27)
13.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif6)4.887o25o9.317.739(10)
14.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)4.457Herby2.503.404(21)
15.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif8)4.365AmeComputers3.676.850(16)
16.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif3)3.029Gjalt170.629(155)
17.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)2.933K3th3r1.532.108(31)
18.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)2.299Confuzer398.296(86)
19.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif22)2.287Asgoroth1.056.254(43)
20.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif7)2.022[DPC] Switch12.652.396(7)
21.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif41)1.903Disaster_Master60.025(298)
22.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.661Jan Boer202.899(147)
23.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif3)1.431[DPC] Brainy0071.448.504(34)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif12)1.374MartenZ144.163(181)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif22)1.102hermanmonique809.167(48)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif12)1.064Maarten236.375(133)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif7)1.015rlmeijer294.479(111)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif4)938Eagle3210565.707(59)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif3)882jvissch2144.773(178)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif36)777Rob Smeets32.713(402)
More...
Overall Top 30
postotalmemberdaily
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)43.857.825[DPC] hansR35.676(1)
2.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)23.354.006Sp@ceNv@der7.681(7)
3.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)19.091.308[DPC]Division_Brabant93(70)
4.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)18.875.371Searchy! Internet Services V.O.F.409(43)
5.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)17.532.212[DPC]TeamGrazzie124(57)
6.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)13.808.742Ensign Wildfire8.890(6)
7.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)12.652.396[DPC] Switch2.022(20)
8.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)11.951.118Tijntje31.495(2)
10.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)9.317.739o25o4.887(13)
11.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)7.557.343F@stmem7.501(8)
12.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)7.430.531[DPC]Div.Delft27.763(3)
14.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)5.602.823Falcon1023.267(4)
15.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)4.665.153apa6.759(10)
16.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)3.676.850AmeComputers4.365(15)
21.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.503.404Herby4.457(14)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.134.817Teachalot6.573(11)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.037.927Berkie518(38)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.931.005Wolfje6664.935(12)
More...
Teams Daily Top 15
posdailyteamtotal
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)529.260.988SETI.USA2.676.744.635(1)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif2)289.743UK BOINC Team320.572.573(32)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif2)277.350999157.406.404(57)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)257.787Team NIPPON313.929.756(35)
31.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif4)256.771US NAVY506.012.278(18)
32.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)242.857Quebec158.841.469(56)
33.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)240.764Elite Games347.995.306(28)
34.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif3)240.036U.S.Air Force355.143.090(26)
35.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)232.450Dutch Power Cows325.371.311(31)
36.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif2)230.291Team Norway187.018.515(46)
37.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif8)224.215Space Quest83.071.761(110)
38.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif4)219.107Ars Technica401.435.540(23)
39.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif7)212.211Brasil [SETIBR]316.980.662(34)
40.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)210.056Sweden199.909.257(42)
41.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)206.878Phoenix Rising326.127.120(30)
42.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif3)202.383Hungary244.488.638(38)
More...
postotalteamdaily
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.676.744.635SETI.USA529.260.988(1)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)367.608.757Amateur Radio Operators318.383(27)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)364.370.438BOINC SETI@home RUSSIA610.671(12)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)355.143.090U.S.Air Force240.036(34)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)348.130.716Team MacNN154.679(55)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)347.995.306Elite Games240.764(33)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)341.854.540BOINC.Italy511.226(17)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)326.127.120Phoenix Rising206.878(41)
31.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)325.371.311Dutch Power Cows232.450(35)
32.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)320.572.573UK BOINC Team289.743(28)
33.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)318.091.042Boone Community School District - Iowa485.077(18)
34.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)316.980.662Brasil [SETIBR]212.211(39)
35.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)313.929.756Team NIPPON257.787(30)
36.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)302.800.288Carl Sagan356.849(23)
37.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)297.385.845Universe Examiners158.945(54)
38.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)244.488.638Hungary202.383(42)
More...
Megaflush Top 5
posTeamFlushDate
More...
Mijlpalen
Herby2.500.000
QuasaR70.000
Disaster_Master60.000
Grutte Pier [Wa Oars]60.000
SETI@Home Links
SETI@Home webpage
SETI@Home forum
Bron
  • grass460
grass460
DPC SETI@Home hitparade van 9 november 2011
Daily Top 30
Flushers: 65 / 1.319 (4,9 %)
posdailymembertotal
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)31.620[DPC] hansR43.889.445(1)
2.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)16.585Tijntje11.967.703(8)
3.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)16.583Falcon105.619.406(14)
4.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)16.359[DPC]Div.Delft7.446.890(12)
5.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)5.071Ensign Wildfire13.813.813(6)
6.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)4.658Grutte Pier [Wa Oars]69.730(278)
7.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif3)4.573apa4.669.726(15)
8.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)3.205Sp@ceNv@der23.357.211(2)
9.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif2)2.828Teachalot2.137.645(24)
10.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif53)2.651Cronenborgh353.558(95)
11.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif3)2.205F@stmem7.559.548(11)
12.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif8)2.083[DPC] Switch12.654.479(7)
13.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif2)1.960AmeComputers3.678.810(16)
14.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif5)1.573Asgoroth1.057.827(43)
15.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif3)1.455Wolfje6661.932.460(27)
16.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif10)1.388Maarten237.763(132)
17.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif21)1.279Berkie2.039.206(25)
18.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif9)1.276rlmeijer295.755(111)
19.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif10)1.275[DPC]Blah.NET584.858(57)
20.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif7)1.160o25o9.318.899(10)
21.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif50)1.096Jox4441.519.446(32)
22.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif6)1.010Gjalt171.639(155)
23.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif6)997K3th3r1.533.105(31)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif10)909Herby2.504.313(21)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif18)849Searchy! Internet Services V.O.F.18.876.220(4)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif2)820Eagle3210566.527(59)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif2)714jvissch2145.487(178)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif10)596Confuzer398.892(86)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif5)456MartenZ144.619(179)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif4)429Andre Barnier431.112(80)
More...
Overall Top 30
postotalmemberdaily
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)43.889.445[DPC] hansR31.620(1)
2.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)23.357.211Sp@ceNv@der3.205(8)
3.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)19.091.497[DPC]Division_Brabant189(37)
4.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)18.876.220Searchy! Internet Services V.O.F.849(25)
5.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)17.532.383[DPC]TeamGrazzie171(38)
6.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)13.813.813Ensign Wildfire5.071(5)
7.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)12.654.479[DPC] Switch2.083(12)
8.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)11.967.703Tijntje16.585(2)
10.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)9.318.899o25o1.160(20)
11.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)7.559.548F@stmem2.205(11)
12.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)7.446.890[DPC]Div.Delft16.359(4)
14.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)5.619.406Falcon1016.583(3)
15.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)4.669.726apa4.573(7)
16.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)3.678.810AmeComputers1.960(13)
21.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.504.313Herby909(24)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.137.645Teachalot2.828(9)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.039.206Berkie1.279(17)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.932.460Wolfje6661.455(15)
More...
Teams Daily Top 15
posdailyteamtotal
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)531.301.462SETI.USA2.678.785.109(1)
35.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)174.509U.S.Air Force355.317.599(26)
36.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif7)172.735999157.579.139(57)
37.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)170.627Space Quest83.242.388(110)
38.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)168.494Team Norway187.187.009(46)
39.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif2)167.193Phoenix Rising326.294.313(30)
40.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)160.888Sweden200.070.145(42)
41.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)160.305Hungary244.648.943(38)
42.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif7)157.388Dutch Power Cows325.528.699(31)
43.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif2)151.207Team Starfire World BOINC539.405.643(16)
44.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif7)137.155SETI Sverige [Sweden]185.515.257(47)
45.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif8)136.287Team MacAddict169.735.306(52)
46.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)132.211SETI@Ticino192.313.025(44)
47.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif4)131.188SwissTeam.NET155.511.822(58)
48.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif2)129.968The Search for EVE168.544.156(53)
49.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)129.782Sicituradastra.146.897.810(63)
More...
postotalteamdaily
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.678.785.109SETI.USA531.301.462(1)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)367.871.185Amateur Radio Operators262.428(25)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)364.880.931BOINC SETI@home RUSSIA510.493(10)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)355.317.599U.S.Air Force174.509(35)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)348.256.166Team MacNN125.450(50)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)348.189.712Elite Games194.406(31)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)342.192.439BOINC.Italy337.899(19)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)326.294.313Phoenix Rising167.193(39)
31.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)325.528.699Dutch Power Cows157.388(42)
32.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)320.792.521UK BOINC Team219.948(28)
33.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)318.577.198Boone Community School District - Iowa486.156(12)
34.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)317.159.655Brasil [SETIBR]178.993(34)
35.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)314.135.072Team NIPPON205.316(30)
36.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)303.087.212Carl Sagan286.924(22)
37.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)297.504.244Universe Examiners118.399(54)
38.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)244.648.943Hungary160.305(41)
More...
Megaflush Top 5
posTeamFlushDate
More...
SETI@Home Links
SETI@Home webpage
SETI@Home forum
Bron
  • grass460
grass460
DPC SETI@Home hitparade van 10 november 2011
Daily Top 30
Flushers: 0 / 1.319 (0,0 %)
posdailymembertotal
More...
Overall Top 30
postotalmemberdaily
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)43.889.445[DPC] hansR0(-)
2.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)23.357.211Sp@ceNv@der0(-)
3.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)19.091.497[DPC]Division_Brabant0(-)
4.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)18.876.220Searchy! Internet Services V.O.F.0(-)
5.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)17.532.383[DPC]TeamGrazzie0(-)
6.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)13.813.813Ensign Wildfire0(-)
7.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)12.654.479[DPC] Switch0(-)
8.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)11.967.703Tijntje0(-)
10.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)9.318.899o25o0(-)
11.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)7.559.548F@stmem0(-)
12.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)7.446.890[DPC]Div.Delft0(-)
14.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)5.619.406Falcon100(-)
15.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)4.669.726apa0(-)
16.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)3.678.810AmeComputers0(-)
21.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.504.313Herby0(-)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.137.645Teachalot0(-)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.039.206Berkie0(-)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.932.460Wolfje6660(-)
More...
Teams Daily Top 15
posdailyteamtotal
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)535.619.069SETI.USA2.683.102.716(1)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif9)516.787999158.095.926(57)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)510.586BOINC Synergy715.639.465(11)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)454.571UK BOINC Team321.247.092(32)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)432.195Elite Games348.621.907(27)
31.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)430.589Team NIPPON314.565.661(35)
32.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)430.427Quebec159.452.405(56)
33.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif4)401.226US NAVY506.626.287(18)
34.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif8)399.353Dutch Power Cows325.928.052(31)
35.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)381.746Ars Technica401.997.219(23)
36.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif3)380.321Phoenix Rising326.674.634(30)
37.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)378.705Team Norway187.565.714(46)
38.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif5)342.093Team Starfire World BOINC539.747.736(16)
39.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif4)339.076U.S.Air Force355.656.675(26)
40.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)335.547Hungary244.984.490(38)
41.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)334.356Sweden200.404.501(42)
More...
postotalteamdaily
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.683.102.716SETI.USA535.619.069(1)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)368.495.143Amateur Radio Operators623.958(22)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)365.907.238BOINC SETI@home RUSSIA1.026.307(12)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)355.656.675U.S.Air Force339.076(39)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)348.621.907Elite Games432.195(30)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)348.511.246Team MacNN255.080(53)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)342.988.356BOINC.Italy795.917(18)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)326.674.634Phoenix Rising380.321(36)
31.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)325.928.052Dutch Power Cows399.353(34)
32.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)321.247.092UK BOINC Team454.571(29)
33.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)319.554.759Boone Community School District - Iowa977.561(13)
34.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)317.493.309Brasil [SETIBR]333.654(42)
35.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)314.565.661Team NIPPON430.589(31)
36.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)303.700.267Carl Sagan613.055(23)
37.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)297.713.694Universe Examiners209.450(57)
38.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)244.984.490Hungary335.547(40)
More...
Megaflush Top 5
posTeamFlushDate
More...
SETI@Home Links
SETI@Home webpage
SETI@Home forum
Bron
  • grass460
grass460
DPC SETI@Home hitparade van 11 november 2011
Daily Top 30
Flushers: 91 / 1.319 (6,9 %)
posdailymembertotal
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)148.611[DPC] hansR44.038.056(1)
2.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)95.254Tijntje12.062.957(8)
3.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif)77.393[DPC]Div.Delft7.524.283(12)
4.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)47.344Falcon105.666.750(14)
5.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)31.815Ensign Wildfire13.845.628(6)
6.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)22.855Grutte Pier [Wa Oars]92.585(242)
7.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif)20.547Sp@ceNv@der23.377.758(2)
8.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)16.546apa4.686.272(15)
9.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif)13.970Herby2.518.283(20)
10.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)13.940Teachalot2.151.585(24)
11.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif)12.142Wolfje6661.944.602(27)
12.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif)11.125o25o9.330.024(10)
13.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)10.900[DPC] Switch12.665.379(7)
14.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif3)10.025F@stmem7.569.573(11)
15.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)7.698Asgoroth1.065.525(43)
16.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif3)6.466AmeComputers3.685.276(16)
17.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif)5.605Mxstream88.344(250)
18.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif)4.444[DPC] Brainy0071.453.220(34)
19.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)4.181[DPC]Blah.NET589.039(57)
20.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif)3.949luc dk201.091(149)
21.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif)3.729Confuzer402.621(84)
22.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif)3.589K3th3r1.536.694(31)
23.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif)3.314Eagle3210569.841(59)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif7)2.950Berkie2.042.156(25)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif3)2.912Gjalt174.551(155)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif8)2.844rlmeijer298.599(109)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif)2.750Jan Boer205.790(147)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif)2.591Mickroz20.156(499)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif4)2.558Searchy! Internet Services V.O.F.18.878.778(4)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)2.496MartenZ147.115(176)
More...
Overall Top 30
postotalmemberdaily
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)44.038.056[DPC] hansR148.611(1)
2.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)23.377.758Sp@ceNv@der20.547(7)
3.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)19.092.070[DPC]Division_Brabant573(55)
4.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)18.878.778Searchy! Internet Services V.O.F.2.558(29)
5.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)17.532.664[DPC]TeamGrazzie281(65)
6.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)13.845.628Ensign Wildfire31.815(5)
7.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)12.665.379[DPC] Switch10.900(13)
8.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)12.062.957Tijntje95.254(2)
10.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)9.330.024o25o11.125(12)
11.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)7.569.573F@stmem10.025(14)
12.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)7.524.283[DPC]Div.Delft77.393(3)
14.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)5.666.750Falcon1047.344(4)
15.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)4.686.272apa16.546(8)
16.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)3.685.276AmeComputers6.466(16)
20.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)2.518.283Herby13.970(9)
21.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)2.513.166Jan Zandvliet & x-RaY990(-)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.151.585Teachalot13.940(10)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.042.156Berkie2.950(24)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.944.602Wolfje66612.142(11)
More...
Teams Daily Top 15
posdailyteamtotal
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)538.331.801SETI.USA2.685.815.448(1)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif)255.815Quebec159.708.220(56)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)248.241UK BOINC Team321.495.333(32)
31.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif)244.627US NAVY506.870.914(18)
32.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)234.628Team NIPPON314.800.289(35)
33.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif3)227.677Elite Games348.849.584(27)
34.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif)224.583Universe Examiners297.938.277(37)
35.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif)219.988Team Norway187.785.702(46)
36.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)207.196Dutch Power Cows326.135.248(31)
37.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)205.611Ars Technica402.202.830(23)
38.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)204.080Phoenix Rising326.878.714(30)
39.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)195.816Team Starfire World BOINC539.943.552(16)
40.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)194.305U.S.Air Force355.850.980(26)
41.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)190.093Hungary245.174.583(38)
42.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif)178.380Sicituradastra.147.358.421(63)
43.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif)176.895SETI@Ticino192.786.462(44)
More...
postotalteamdaily
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.685.815.448SETI.USA538.331.801(1)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)368.797.497Amateur Radio Operators302.354(26)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)366.441.046BOINC SETI@home RUSSIA533.808(13)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)355.850.980U.S.Air Force194.305(40)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)348.849.584Elite Games227.677(33)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)348.653.423Team MacNN142.177(53)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)343.436.421BOINC.Italy448.065(18)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)326.878.714Phoenix Rising204.080(38)
31.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)326.135.248Dutch Power Cows207.196(36)
32.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)321.495.333UK BOINC Team248.241(30)
33.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)320.092.735Boone Community School District - Iowa537.976(12)
34.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)317.666.394Brasil [SETIBR]173.085(44)
35.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)314.800.289Team NIPPON234.628(32)
36.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)304.062.893Carl Sagan362.626(21)
37.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)297.938.277Universe Examiners224.583(34)
38.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)245.174.583Hungary190.093(41)
More...
Megaflush Top 5
posTeamFlushDate
More...
Mijlpalen
[DPC] hansR44.000.000
Tijntje12.000.000
[DPC]Div.Delft7.500.000
Confuzer400.000
luc dk200.000
Grutte Pier [Wa Oars]90.000
Haico30.000
Mickroz20.000
Kevin8.000
Edwin Gozeling2.000
SETI@Home Links
SETI@Home webpage
SETI@Home forum
Bron
  • grass460
grass460
HEHE de stats zijn weer up to date, even 2 weken stats geplaatst want die ontbraken. Valt niet mee om altijd maar weer motivatie te vinden ( spreek uit ervaring zeker als er wat strubbelingen op het project zijn).
Meteen even wat tekst neer rammen is ook weer goed voor mijn whatpulse keycount heheh.
Waren er eergisteren nog een hele stapel met HELE GROTE mijlpalen, is de stapel van gisteren iets bescheidener, maar zeker net zo belangrijk. Dus congratz allemaal *O* .
Ik draai zelf tijdelijk een ander project maar met al die nieuwe koetjes hier blijft onze output wel redelijk constant. Gelukkig blijven de koeien lekker door buffelen wat met deze temperaturen geen straf is.
DPC SETI@Home hitparade van 12 november 2011
Daily Top 30
posdailymembertotal
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)67.098[DPC] hansR44.105.154(1)
2.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)34.669[DPC]Div.Delft7.558.952(12)
3.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)29.306Tijntje12.092.263(8)
4.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)16.464Falcon105.683.214(14)
5.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif3)8.273apa4.694.545(15)
6.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif8)8.076F@stmem7.577.649(11)
7.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif10)6.951Mxstream95.295(238)
8.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)6.179Grutte Pier [Wa Oars]98.764(230)
9.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)5.501Sp@ceNv@der23.383.259(2)
10.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)4.843Teachalot2.156.428(24)
11.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)4.292Herby2.522.575(20)
12.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif7)3.868Ensign Wildfire13.849.496(6)
13.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)3.428Wolfje6661.948.030(27)
14.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)3.122o25o9.333.146(10)
15.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)2.992AmeComputers3.688.268(16)
16.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif4)2.868luc dk203.959(148)
17.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)2.335[DPC] Brainy0071.455.555(34)
18.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif3)2.179Asgoroth1.067.704(43)
19.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif18)1.701jvissch2148.560(173)
20.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif19)1.352Disaster_Master62.726(290)
21.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif8)1.183[DPC] Switch12.666.562(7)
22.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)1.180Confuzer403.801(84)
23.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif10)1.099HellBringer1.347.127(35)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)949Eagle3210570.790(59)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)929Berkie2.043.085(25)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif29)909[DPC]Division_Brabant19.092.979(3)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif22)891[DPC] Mastha-Hacker29.566(426)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif7)889Herman J.C. van der Bent274.647(116)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif23)840Geronimous60.791(298)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)830Geejay171.515(156)
More...
Overall Top 30
postotalmemberdaily
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)44.105.154[DPC] hansR67.098(1)
2.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)23.383.259Sp@ceNv@der5.501(9)
3.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)19.092.979[DPC]Division_Brabant909(26)
4.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)18.878.835Searchy! Internet Services V.O.F.57(68)
5.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)17.532.723[DPC]TeamGrazzie59(67)
6.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)13.849.496Ensign Wildfire3.868(12)
7.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)12.666.562[DPC] Switch1.183(21)
8.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)12.092.263Tijntje29.306(3)
10.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)9.333.146o25o3.122(14)
11.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)7.577.649F@stmem8.076(6)
12.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)7.558.952[DPC]Div.Delft34.669(2)
14.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)5.683.214Falcon1016.464(4)
15.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)4.694.545apa8.273(5)
16.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)3.688.268AmeComputers2.992(15)
20.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.522.575Herby4.292(11)
21.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.513.166Jan Zandvliet & x-RaY990(-)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.156.428Teachalot4.843(10)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.043.085Berkie929(25)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.948.030Wolfje6663.428(13)
More...
Teams Daily Top 15
posdailyteamtotal
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)541.489.130SETI.USA2.688.972.777(1)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)322.240BroadbandReports.com Team Starfire619.794.441(14)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif2)314.652BOINC Synergy716.233.464(11)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)306.042TeAm AnandTech528.593.444(17)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)288.079Amateur Radio Operators369.085.576(24)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif4)268.337Team NIPPON315.068.626(35)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)259.383UK BOINC Team321.754.716(32)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)247.438999158.608.306(57)
31.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif5)239.529Dutch Power Cows326.374.777(31)
32.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif3)237.146Quebec159.945.366(56)
33.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)234.788US NAVY507.105.702(18)
34.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)224.063Elite Games349.073.647(27)
35.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif3)217.781Phoenix Rising327.096.495(30)
36.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)217.208Ars Technica402.420.038(23)
37.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)215.548Team Norway188.001.250(46)
38.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif7)200.087Sweden200.776.980(42)
More...
postotalteamdaily
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.688.972.777SETI.USA541.489.130(1)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)369.085.576Amateur Radio Operators288.079(27)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)366.984.675BOINC SETI@home RUSSIA543.629(11)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)356.043.765U.S.Air Force192.785(41)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)349.073.647Elite Games224.063(34)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)348.780.995Team MacNN127.572(60)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)343.822.796BOINC.Italy386.375(19)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)327.096.495Phoenix Rising217.781(35)
31.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)326.374.777Dutch Power Cows239.529(31)
32.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)321.754.716UK BOINC Team259.383(29)
33.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)320.540.656Boone Community School District - Iowa447.921(18)
34.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)317.864.953Brasil [SETIBR]198.559(39)
35.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)315.068.626Team NIPPON268.337(28)
36.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)304.393.499Carl Sagan330.606(23)
37.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)298.092.034Universe Examiners153.757(48)
38.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)245.368.014Hungary193.431(40)
More...
Megaflush Top 5
posTeamFlushDate
More...
Mijlpalen
Mxstream90.000
Geronimous60.000
TheCalculator50.000
Kevin9.000
SETI@Home Links
SETI@Home webpage
SETI@Home forum
Bron
