[SETI@Home] hitparade van week 44 Vorige deel Overzicht Volgende deel Laatste deel
  • grass460
  • Laatst online: 00:16
grass460
[DPC] Division_Brabant
Afbeeldingslocatie: http://tweakers.net/ext/f/JC7kwqqV82fi9ViRWtJgzDBy/full.jpg
Inhoudsopgave Seti@Home hitparades week 44
  • DPC SETI@Home hitparade van 30 oktober 2011
  • DPC SETI@Home hitparade van 31 oktober 2011
  • DPC SETI@Home hitparade van 01 november 2011
  • DPC SETI@Home hitparade van 02 november 2011
  • DPC SETI@Home hitparade van 03 november 2011
  • DPC SETI@Home hitparade van 04 november 2011
  • DPC SETI@Home hitparade van 05 november 2011
* geen correcte stats beschikbaar
Wat is Seti@Home ?
Wat is SETI@home?
SETI@home is de naam van een wetenschappelijk experiment dat computers die via het internet met elkaar verbonden zijn, inzet om buitenaardse intelligentie op te sporen. U kunt hieraan deelnemen middels een gratis computerprogramma dat radiotelescoop-data download en analyseert.
Nieuws Update
9 Nov 2011 | 20:53:50 UTC
Funny story. About 3 years ago I realized that the BOINC database has result ids stored a integers, which are 4 bytes long and signed by default. The sign takes up one bit, thus leaving 31 bits remaining for the value. That means the maximum value is 2^31 (2 to the power of 31, or 2147483648). I mentioned this at this time, noting we were well on our way towards this maximum value, and put it on the "things we'll need to fix eventually" list.
Nobody has been really watching this (I've been pretty much out for over two months until this week), and sure enough we hit that limit yesterday, and the whole BOINC backend pretty much barfed. We tried to implement a "quick fix" by changing the result id signed integer to an unsigned integer (both in mysql and the C code), thus giving us an extra bit for the value. Now that means the maximum value is 2^32 (2 to the power of 32, or 4294967296). That should have bought us a couple more years.
However, this quick fix didn't really work. There's all kinds of code in BOINC that needs to be changed to get unsigned integers to work. Dave made some of these changes and Jeff tested them this morning, but still to no avail. More necessary fixes were found. We seem to be once again creating and sending out work at the moment. However the hood is wide open on BOINC now, so we're watching things carefully over the next day or so.
We're certainly not done - there are tons of cosmetic fixes that need to be made (our logs are full of entries containing negative result ids). In the long term we'll have to do the same for workunit ids, and at that point we'll probably go ahead and make them long longs (which are always 8 bytes, as opposed to longs, which are 4 bytes on 32-bit systems and 8 bytes on 64-bit systems) in the C code and bigints in mysql. At that point our id space will max out at 2305843009213693952, which should probably be enough. That's a million results a day for 6.3 billion years. If we're still running SETI@home 6.3 billion years from now there's probably nobody out there. Agreed?
We've been bitten by this long ago in informix, and have since been storing larger numbers there as int8's (8 byte integers) or doubles.
Warning: since we didn't come across this problem in advance and solve is gracefully, there may be some ugliness in the form of blocked results in weird states - these will most likely time out on their own and get resent. Sorry if this causes any confusion in the coming weeks.
By the way, it should be mentioned there were some random download server issues over this past weekend. No big deal - usual stuff regarding linux kernel hangs. We kicked the servers on monday morning and they went back to work.
- Matt
Ga naar de DPC website
  • grass460
grass460
Afbeeldingslocatie: http://gathering.tweakers.net/global/templates/got/images/layout/pixel.gif
Daily Top 30
Flushers: 79 / 1.318 (6,0 %)
posdailymembertotal
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)79.337[DPC] hansR43.308.750(1)
2.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)60.616[DPC]Div.Delft7.150.300(12)
3.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)25.100Tijntje11.689.591(8)
4.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)21.915Falcon105.410.725(14)
5.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)13.482apa4.585.767(15)
6.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif5)12.822F@stmem7.501.334(11)
7.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)10.295Sp@ceNv@der23.287.052(2)
8.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif2)10.131Herby2.459.145(21)
9.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)8.621o25o9.252.489(10)
10.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)8.054rlmeijer265.329(118)
11.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif4)6.203Teachalot2.100.789(24)
12.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)5.867Arjant231.296(412)
13.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif4)4.857[DPC]Blah.NET541.636(62)
14.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif8)4.223Wolfje6661.890.831(27)
15.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif8)4.087AmeComputers3.649.488(16)
16.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif2)3.934[DPC]Division_Brabant19.084.528(3)
17.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif12)3.838Ensign Wildfire13.728.518(6)
18.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif5)3.653HellBringer1.330.744(35)
19.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)3.612[DPC] Switch12.628.401(7)
20.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.988Confuzer381.362(91)
21.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif5)2.940K3th3r1.514.108(32)
22.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif10)2.853Asgoroth1.042.618(44)
23.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif15)2.553sander2774237.477(131)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif19)2.400Berkie2.027.700(26)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif40)2.323[DPC] Mastha-Hacker27.547(436)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)1.654MartenZ133.410(188)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif10)1.543Rob Smeets27.409(437)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)1.527NexceveN22.159(483)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif42)1.393Jox4441.514.249(31)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)1.340Eagle3210555.942(59)
More...
Overall Top 30
postotalmemberdaily
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)43.308.750[DPC] hansR79.337(1)
2.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)23.287.052Sp@ceNv@der10.295(7)
3.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)19.084.528[DPC]Division_Brabant3.934(16)
4.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)18.870.971Searchy! Internet Services V.O.F.283(55)
5.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)17.527.082[DPC]TeamGrazzie1.298(31)
6.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)13.728.518Ensign Wildfire3.838(17)
7.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)12.628.401[DPC] Switch3.612(19)
8.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)11.689.591Tijntje25.100(3)
9.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)9.642.206MaGNeT (a.k.a. BlueTooth76)0(-)
10.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)9.252.489o25o8.621(9)
11.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)7.501.334F@stmem12.822(6)
12.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)7.150.300[DPC]Div.Delft60.616(2)
13.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)5.685.852Bas Laurier0(-)
14.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)5.410.725Falcon1021.915(4)
15.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)4.585.767apa13.482(5)
16.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)3.649.488AmeComputers4.087(15)
17.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)3.441.484Team_Elteor_Borislavj0(-)
18.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)3.200.789Mr Beamer0(-)
19.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.595.626dpc_kluizenaar0(-)
20.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.513.166Jan Zandvliet & x-RaY990(-)
21.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.459.145Herby10.131(8)
22.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.394.425[DPC]Trancemaus0(-)
23.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.216.648[DPC]Spinpoint0(-)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.100.789Teachalot6.203(11)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.035.095Override113(73)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.027.700Berkie2.400(24)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.890.831Wolfje6664.223(14)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.710.061Intrud3r0(-)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.642.748NicoClown0(-)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.602.694[DPC]Team Zuid-Holland0(-)
More...
Teams Daily Top 15
posdailyteamtotal
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)499.228.911SETI.USA2.646.712.558(1)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)412.360999154.165.596(57)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)393.676BOINC.Italy337.668.963(29)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)387.793U.S.Air Force352.851.542(26)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)387.125Amateur Radio Operators364.649.452(24)
31.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)370.742Ars Technica399.148.493(23)
32.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif6)359.425UK BOINC Team317.972.236(32)
33.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif2)355.399Team NIPPON311.375.939(35)
34.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)341.047Dutch Power Cows323.117.322(31)
35.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)336.471Elite Games345.738.958(28)
36.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif3)330.629SETI ITALIA Team G. Cocconi115.019.451(79)
37.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)320.992Quebec156.572.626(56)
38.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)309.194Space Quest80.719.169(114)
39.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif8)306.170The Search for EVE166.723.625(53)
40.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif5)302.299Sweden198.033.485(42)
41.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)295.386Sicituradastra.144.905.538(63)
More...
Teams Overall Top 15
postotalteamdaily
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.646.712.558SETI.USA499.228.911(1)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)364.649.452Amateur Radio Operators387.125(30)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)358.556.551BOINC SETI@home RUSSIA870.888(10)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)352.851.542U.S.Air Force387.793(29)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)346.685.562Team MacNN202.434(55)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)345.738.958Elite Games336.471(35)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)337.668.963BOINC.Italy393.676(28)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)324.550.351Phoenix Rising281.908(44)
31.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)323.117.322Dutch Power Cows341.047(34)
32.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)317.972.236UK BOINC Team359.425(32)
33.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)315.189.909Brasil [SETIBR]262.160(45)
34.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)313.358.144Boone Community School District - Iowa563.755(17)
35.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)311.375.939Team NIPPON355.399(33)
36.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)299.381.928Carl Sagan514.579(20)
37.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)295.830.420Universe Examiners234.284(49)
38.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)242.663.043Hungary227.215(50)
More...
Megaflush Top 5
posTeamFlushDate
1.[DPC]Division_Brabant1.790.71126-02-2010
2.[DPC] hansR1.156.60326-02-2010
3.MaGNeT (a.k.a. BlueTooth76)959.79215-10-2010
4.Searchy! Internet Services V.O.F.785.77526-02-2010
5.[DPC]TeamGrazzie553.05604-01-2008
More...
Mijlpalen
o25o9.250.000
F@stmem7.500.000
coredump60.000
Arjant230.000
Tha -=KinGuiN=-8.000
nrg20093.000
Nieuwe Leden
Grutte Pier [Wa Oars]15.199
MAB The Frisian15.199
Leaves
Grutte Pier [Wa Oars].MAB The Frisian0
SETI@Home Links
SETI@Home webpage
SETI@Home forum
DPCH Suggestiepagina
Bron
  • grass460
grass460
Daily Top 30
Flushers: 73 / 1.318 (5,5 %)
posdailymembertotal
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)54.180[DPC] hansR43.362.930(1)
2.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)41.420[DPC]Div.Delft7.191.720(12)
3.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)23.724Tijntje11.713.315(8)
4.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)18.100Falcon105.428.825(14)
5.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif4)9.125o25o9.261.614(10)
6.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)8.750F@stmem7.510.084(11)
7.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)8.385apa4.594.152(15)
8.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)6.505Herby2.465.650(21)
9.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif4)6.480[DPC]Blah.NET548.116(61)
10.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)5.798Grutte Pier [Wa Oars]20.997(493)
11.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)5.427Arjant236.723(383)
12.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)5.287rlmeijer270.616(116)
13.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif4)5.085Ensign Wildfire13.733.603(6)
14.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)4.736Wolfje6661.895.567(27)
15.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif8)4.563Sp@ceNv@der23.291.615(2)
16.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif25)4.073Ross24.026(464)
17.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)3.452AmeComputers3.652.940(16)
18.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif7)3.000Teachalot2.103.789(24)
19.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)2.084HellBringer1.332.828(35)
20.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)2.076K3th3r1.516.184(31)
21.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif5)2.007[DPC]Division_Brabant19.086.535(3)
22.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif49)1.844Dain_Bramage24.568(456)
23.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif3)1.661Confuzer383.023(91)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)1.534Asgoroth1.044.152(44)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif9)1.522[DPC] Brainy0071.435.592(34)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif7)1.447[DPC] Switch12.629.848(7)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif4)1.219[DPC]TeamGrazzie17.528.301(5)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif4)1.006Berkie2.028.706(26)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)1.005Rob Smeets28.414(429)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif4)962MartenZ134.372(187)
More...
Overall Top 30
postotalmemberdaily
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)43.362.930[DPC] hansR54.180(1)
2.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)23.291.615Sp@ceNv@der4.563(15)
3.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)19.086.535[DPC]Division_Brabant2.007(21)
4.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)18.871.168Searchy! Internet Services V.O.F.197(57)
5.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)17.528.301[DPC]TeamGrazzie1.219(27)
6.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)13.733.603Ensign Wildfire5.085(13)
7.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)12.629.848[DPC] Switch1.447(26)
8.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)11.713.315Tijntje23.724(3)
10.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)9.261.614o25o9.125(5)
11.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)7.510.084F@stmem8.750(6)
12.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)7.191.720[DPC]Div.Delft41.420(2)
14.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)5.428.825Falcon1018.100(4)
15.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)4.594.152apa8.385(7)
16.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)3.652.940AmeComputers3.452(17)
21.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.465.650Herby6.505(8)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.103.789Teachalot3.000(18)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.035.095Override0(-)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.028.706Berkie1.006(28)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.895.567Wolfje6664.736(14)
More...
Teams Daily Top 15
posdailyteamtotal
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)502.051.249SETI.USA2.649.534.896(1)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)285.513Ars Technica399.434.006(23)
31.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif2)281.295Team NIPPON311.657.234(35)
32.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif7)280.671US NAVY503.678.915(18)
33.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif3)265.184SETI ITALIA Team G. Cocconi115.284.635(79)
34.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)261.263UK BOINC Team318.233.499(32)
35.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif3)260.268Space Quest80.979.437(113)
36.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)244.490Quebec156.817.116(56)
37.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif3)243.098Dutch Power Cows323.360.420(31)
38.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif4)240.448SETI@Ticino190.565.230(45)
39.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif4)235.636Elite Games345.974.594(28)
40.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)229.144Sicituradastra.145.134.682(63)
41.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif5)218.018Nosu dba team109.513.834(82)
42.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)211.960Sweden198.245.445(42)
43.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif2)210.088Brasil [SETIBR]315.399.997(33)
44.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)203.496Team Norway185.223.972(46)
More...
postotalteamdaily
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.649.534.896SETI.USA502.051.249(1)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)364.959.906Amateur Radio Operators310.454(27)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)359.215.790BOINC SETI@home RUSSIA659.239(10)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)353.143.984U.S.Air Force292.442(28)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)346.824.575Team MacNN139.013(58)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)345.974.594Elite Games235.636(39)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)337.958.671BOINC.Italy289.708(29)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)324.738.210Phoenix Rising187.859(48)
31.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)323.360.420Dutch Power Cows243.098(37)
32.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)318.233.499UK BOINC Team261.263(34)
33.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)315.399.997Brasil [SETIBR]210.088(43)
34.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)313.863.503Boone Community School District - Iowa505.359(16)
35.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)311.657.234Team NIPPON281.295(31)
36.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)299.766.883Carl Sagan384.955(22)
37.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)296.004.827Universe Examiners174.407(51)
38.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)242.863.027Hungary199.984(46)
More...
Megaflush Top 5
posTeamFlushDate
More...
Mijlpalen
Grutte Pier [Wa Oars]20.000
Ross20.000
SETI@Home Links
SETI@Home webpage
SETI@Home forum
Bron
  • grass460
grass460
DPC SETI@Home hitparade van 1 november 2011
Daily Top 30
Flushers: 86 / 1.318 (6,5 %)
posdailymembertotal
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)74.536[DPC] hansR43.437.466(1)
2.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)42.061[DPC]Div.Delft7.233.781(12)
3.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)22.954Tijntje11.736.269(8)
4.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)17.177Falcon105.446.002(14)
5.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif2)11.182apa4.605.334(15)
6.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif7)10.011Ensign Wildfire13.743.614(6)
7.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)8.736o25o9.270.350(10)
8.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif7)8.029Sp@ceNv@der23.299.644(2)
9.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif3)6.821F@stmem7.516.905(11)
10.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)6.214[DPC]Blah.NET554.330(60)
11.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif3)5.377Wolfje6661.900.944(27)
12.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)4.889Grutte Pier [Wa Oars]25.886(447)
13.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif5)4.528Herby2.470.178(21)
14.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)4.433rlmeijer275.049(115)
15.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif3)3.398Teachalot2.107.187(24)
16.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif10)3.043[DPC] Switch12.632.891(7)
17.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)3.028AmeComputers3.655.968(16)
18.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif5)2.757Confuzer385.780(89)
19.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif8)2.747Arjant239.470(371)
20.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif23)2.179hermanmonique804.665(48)
21.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif11)2.099Haico25.829(450)
22.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif14)1.793Dr.Drax933.897(45)
23.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif4)1.671[DPC]TeamGrazzie17.529.972(5)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif4)1.625K3th3r1.517.809(31)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.500[DPC] Brainy0071.437.092(34)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif4)1.402MartenZ135.774(187)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif2)1.308Rob Smeets29.722(423)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.161Berkie2.029.867(26)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif8)1.127[DPC]Division_Brabant19.087.662(3)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif15)1.102Andre Barnier424.818(81)
More...
Overall Top 30
postotalmemberdaily
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)43.437.466[DPC] hansR74.536(1)
2.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)23.299.644Sp@ceNv@der8.029(8)
3.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)19.087.662[DPC]Division_Brabant1.127(29)
4.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)18.871.940Searchy! Internet Services V.O.F.772(41)
5.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)17.529.972[DPC]TeamGrazzie1.671(23)
6.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)13.743.614Ensign Wildfire10.011(6)
7.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)12.632.891[DPC] Switch3.043(16)
8.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)11.736.269Tijntje22.954(3)
10.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)9.270.350o25o8.736(7)
11.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)7.516.905F@stmem6.821(9)
12.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)7.233.781[DPC]Div.Delft42.061(2)
14.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)5.446.002Falcon1017.177(4)
15.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)4.605.334apa11.182(5)
16.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)3.655.968AmeComputers3.028(17)
21.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.470.178Herby4.528(13)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.107.187Teachalot3.398(15)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.029.867Berkie1.161(28)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.900.944Wolfje6665.377(11)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.643.487NicoClown739(42)
More...
Teams Daily Top 15
posdailyteamtotal
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)506.183.409SETI.USA2.653.667.056(1)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif6)377.542BroadbandReports.com Team Starfire615.569.849(14)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)369.373TeAm AnandTech524.714.601(17)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif5)335.646US NAVY504.014.561(18)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)332.256Amateur Radio Operators365.292.162(24)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)322.231U.S.Air Force353.466.215(26)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)307.467Ars Technica399.741.473(23)
31.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif5)297.656USA209.919.962(40)
32.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif5)284.373Dutch Power Cows323.644.793(31)
33.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif2)280.397Space Quest81.259.834(112)
34.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif5)279.892Elite Games346.254.486(28)
35.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)272.807Quebec157.089.923(56)
36.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif5)266.208Team NIPPON311.923.442(35)
37.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif3)259.892UK BOINC Team318.493.391(32)
38.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif4)251.312Sweden198.496.757(42)
39.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif7)218.206Hungary243.081.233(38)
More...
postotalteamdaily
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.653.667.056SETI.USA506.183.409(1)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)365.292.162Amateur Radio Operators332.256(28)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)359.959.484BOINC SETI@home RUSSIA743.694(11)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)353.466.215U.S.Air Force322.231(29)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)347.017.369Team MacNN192.794(47)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)346.254.486Elite Games279.892(34)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)338.371.370BOINC.Italy412.699(20)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)324.889.997Phoenix Rising151.787(57)
31.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)323.644.793Dutch Power Cows284.373(32)
32.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)318.493.391UK BOINC Team259.892(37)
33.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)315.617.146Brasil [SETIBR]217.149(41)
34.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)314.372.585Boone Community School District - Iowa509.082(17)
35.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)311.923.442Team NIPPON266.208(36)
36.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)300.164.725Carl Sagan397.842(22)
37.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)296.191.919Universe Examiners187.092(50)
38.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)243.081.233Hungary218.206(39)
More...
Megaflush Top 5
posTeamFlushDate
More...
Mijlpalen
rlmeijer275.000
Kevin3.000
SETI@Home Links
SETI@Home webpage
SETI@Home forum
Bron
  • grass460
grass460
DPC SETI@Home hitparade van 2 november 2011
Daily Top 30
Flushers: 82 / 1.319 (6,2 %)
posdailymembertotal
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)61.304[DPC] hansR43.498.770(1)
2.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)42.457[DPC]Div.Delft7.276.238(12)
3.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)23.230Tijntje11.759.499(8)
4.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)15.878Falcon105.461.880(14)
5.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)12.359Ensign Wildfire13.755.973(6)
6.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif2)10.649Sp@ceNv@der23.310.293(2)
7.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)8.492apa4.613.826(15)
8.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)6.498o25o9.276.848(10)
9.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif3)4.698Grutte Pier [Wa Oars]30.584(417)
10.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif3)4.497Herby2.474.675(21)
11.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif3)4.067rlmeijer279.116(114)
12.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif3)3.291Teachalot2.110.478(24)
13.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif4)3.150AmeComputers3.659.118(16)
14.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif3)3.021Wolfje6661.903.965(27)
15.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)2.977[DPC] Switch12.635.868(7)
16.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif7)2.735F@stmem7.519.640(11)
17.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif2)2.575Arjant242.045(361)
18.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif8)2.568[DPC]Blah.NET556.898(60)
19.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif16)2.271HellBringer1.336.008(35)
20.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif5)1.845[DPC] Brainy0071.438.937(34)
21.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif3)1.839K3th3r1.519.648(31)
22.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif17)1.531Asgoroth1.046.486(44)
23.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif5)1.396Berkie2.031.263(26)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif9)1.155luc dk193.554(150)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)1.133MartenZ136.907(186)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif3)1.108[DPC]Division_Brabant19.088.770(3)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif5)1.094Dr.Drax934.991(45)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif33)1.071Mickroz14.140(559)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif46)939Gjalt161.040(163)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif15)929tukkie141.721(182)
More...
Overall Top 30
postotalmemberdaily
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)43.498.770[DPC] hansR61.304(1)
2.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)23.310.293Sp@ceNv@der10.649(6)
3.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)19.088.770[DPC]Division_Brabant1.108(26)
4.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)18.872.805Searchy! Internet Services V.O.F.865(31)
5.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)17.530.208[DPC]TeamGrazzie236(52)
6.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)13.755.973Ensign Wildfire12.359(5)
7.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)12.635.868[DPC] Switch2.977(15)
8.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)11.759.499Tijntje23.230(3)
10.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)9.276.848o25o6.498(8)
11.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)7.519.640F@stmem2.735(16)
12.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)7.276.238[DPC]Div.Delft42.457(2)
14.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)5.461.880Falcon1015.878(4)
15.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)4.613.826apa8.492(7)
16.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)3.659.118AmeComputers3.150(13)
21.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.474.675Herby4.497(10)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.110.478Teachalot3.291(12)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.035.199Override104(75)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.031.263Berkie1.396(23)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.903.965Wolfje6663.021(14)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.643.787NicoClown300(47)
More...
Teams Daily Top 15
posdailyteamtotal
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)510.657.829SETI.USA2.658.141.476(1)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif2)348.205USA210.268.167(40)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif7)326.583UK BOINC Team318.819.974(32)
31.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif5)322.104Team NIPPON312.245.546(35)
32.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif3)311.879U.S.Air Force353.778.094(26)
33.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif2)308.532Quebec157.398.455(56)
34.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)303.273Space Quest81.563.107(112)
35.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif5)300.818Ars Technica400.042.291(23)
36.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif4)271.329Dutch Power Cows323.916.122(31)
37.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif3)269.031Elite Games346.523.517(28)
38.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif6)258.576Sicituradastra.145.601.658(63)
39.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif4)234.909SETI@Ticino191.013.185(45)
40.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif2)230.760Team Norway185.668.193(46)
41.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif5)227.637Team Starfire World BOINC538.144.901(16)
42.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif4)224.844Sweden198.721.601(42)
43.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif3)220.250The Search for EVE167.359.548(53)
More...
postotalteamdaily
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.658.141.476SETI.USA510.657.829(1)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)365.665.076Amateur Radio Operators372.914(26)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)360.697.831BOINC SETI@home RUSSIA738.347(11)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)353.778.094U.S.Air Force311.879(32)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)347.201.237Team MacNN183.868(53)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)346.523.517Elite Games269.031(37)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)338.864.734BOINC.Italy493.364(18)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)325.055.504Phoenix Rising165.507(59)
31.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)323.916.122Dutch Power Cows271.329(36)
32.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)318.819.974UK BOINC Team326.583(30)
33.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)315.809.309Brasil [SETIBR]192.163(51)
34.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)314.911.751Boone Community School District - Iowa539.166(17)
35.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)312.245.546Team NIPPON322.104(31)
36.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)300.592.985Carl Sagan428.260(22)
37.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)296.395.627Universe Examiners203.708(47)
38.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)243.292.334Hungary211.101(45)
More...
Megaflush Top 5
posTeamFlushDate
More...
Mijlpalen
[DPC]Div.Delft7.250.000
Arjant240.000
Grutte Pier [Wa Oars]30.000
Rob Smeets30.000
GeppyZ2.000
Nieuwe Leden
Edwin Gozeling170
SETI@Home Links
SETI@Home webpage
SETI@Home forum
Bron
  • grass460
grass460
DPC SETI@Home hitparade van 3 november 2011
Daily Top 30
Flushers: 89 / 1.319 (6,7 %)
posdailymembertotal
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)78.319[DPC] hansR43.577.089(1)
2.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)35.846Tijntje11.795.345(8)
3.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)34.256[DPC]Div.Delft7.310.494(12)
4.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)25.172Falcon105.487.052(14)
5.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)10.663Sp@ceNv@der23.320.956(2)
6.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)10.006Ensign Wildfire13.765.979(6)
7.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)9.214o25o9.286.062(10)
8.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif2)7.016Herby2.481.691(21)
9.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif5)6.588Wolfje6661.910.553(27)
10.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)6.502rlmeijer285.618(112)
11.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif5)6.224F@stmem7.525.864(11)
12.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif5)6.117apa4.619.943(15)
13.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif4)5.190Grutte Pier [Wa Oars]35.774(387)
14.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)4.874Teachalot2.115.352(24)
15.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)3.759AmeComputers3.662.877(16)
16.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif23)3.001Confuzer389.286(88)
17.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)2.890[DPC] Switch12.638.758(7)
18.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)2.758Arjant244.803(348)
19.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)2.260[DPC]Blah.NET559.158(59)
20.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif10)2.212tukkie143.933(180)
21.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)2.174HellBringer1.338.182(35)
22.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)1.879K3th3r1.521.527(31)
23.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)1.733Asgoroth1.048.219(44)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.657luc dk195.211(150)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.610MartenZ138.517(185)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif6)1.604[DPC] Brainy0071.440.541(34)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif15)1.445Rob Smeets31.614(411)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif5)1.436Eagle3210560.006(58)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif15)1.324sander2774241.075(129)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif37)1.314Arno15.267(546)
More...
Overall Top 30
postotalmemberdaily
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)43.577.089[DPC] hansR78.319(1)
2.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)23.320.956Sp@ceNv@der10.663(5)
3.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)19.089.906[DPC]Division_Brabant1.136(36)
4.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)18.873.262Searchy! Internet Services V.O.F.457(49)
5.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)17.530.786[DPC]TeamGrazzie578(47)
6.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)13.765.979Ensign Wildfire10.006(6)
7.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)12.638.758[DPC] Switch2.890(17)
8.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)11.795.345Tijntje35.846(2)
10.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)9.286.062o25o9.214(7)
11.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)7.525.864F@stmem6.224(11)
12.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)7.310.494[DPC]Div.Delft34.256(3)
14.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)5.487.052Falcon1025.172(4)
15.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)4.619.943apa6.117(12)
16.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)3.662.877AmeComputers3.759(15)
21.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.481.691Herby7.016(8)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.115.352Teachalot4.874(14)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.035.199Override0(-)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.032.109Berkie846(39)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.910.553Wolfje6666.588(9)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.643.787NicoClown0(-)
More...
Teams Daily Top 15
posdailyteamtotal
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)514.516.646SETI.USA2.662.000.293(1)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)363.599Amateur Radio Operators366.028.675(24)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)338.122US NAVY504.703.362(18)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)329.197UK BOINC Team319.149.171(32)
31.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)300.880Team NIPPON312.546.426(35)
32.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif12)282.329Nosu dba team110.197.465(82)
33.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif2)279.724Ars Technica400.322.015(23)
34.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif3)276.841Elite Games346.800.358(28)
35.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)274.083Dutch Power Cows324.190.205(31)
36.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)265.342Space Quest81.828.449(112)
37.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif2)263.712SETI@Ticino191.276.897(45)
38.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif6)263.216U.S.Air Force354.041.310(26)
39.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif6)260.963Quebec157.659.418(56)
40.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)242.962Sicituradastra.145.844.620(63)
41.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif4)232.662Hungary243.524.996(38)
42.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)229.840Team Norway185.898.033(46)
More...
postotalteamdaily
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.662.000.293SETI.USA514.516.646(1)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)366.028.675Amateur Radio Operators363.599(28)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)361.454.105BOINC SETI@home RUSSIA756.274(10)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)354.041.310U.S.Air Force263.216(38)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)347.369.478Team MacNN168.241(55)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)346.800.358Elite Games276.841(34)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)339.434.912BOINC.Italy570.178(17)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)325.252.626Phoenix Rising197.122(50)
31.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)324.190.205Dutch Power Cows274.083(35)
32.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)319.149.171UK BOINC Team329.197(30)
33.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)316.026.046Brasil [SETIBR]216.737(45)
34.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)315.429.650Boone Community School District - Iowa517.899(18)
35.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)312.546.426Team NIPPON300.880(31)
36.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)300.999.175Carl Sagan406.190(23)
37.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)296.593.682Universe Examiners198.055(49)
38.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)243.524.996Hungary232.662(41)
More...
Megaflush Top 5
posTeamFlushDate
More...
Mijlpalen
Edwin Gozeling250
SETI@Home Links
SETI@Home webpage
SETI@Home forum
Bron
  • grass460
grass460
DPC SETI@Home hitparade van 4 november 2011
Daily Top 30
Flushers: 76 / 1.319 (5,8 %)
posdailymembertotal
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)68.648[DPC] hansR43.645.737(1)
2.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)29.341Tijntje11.824.686(8)
3.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)19.847Falcon105.506.899(14)
4.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)17.149[DPC]Div.Delft7.327.643(12)
5.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)11.660Ensign Wildfire13.777.639(6)
6.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif6)9.559apa4.629.502(15)
7.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)7.778o25o9.293.840(10)
8.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif11)7.326[DPC]Blah.NET566.484(58)
9.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif4)5.115Sp@ceNv@der23.326.071(2)
10.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)5.040F@stmem7.530.904(11)
11.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif3)4.938Herby2.486.629(21)
12.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)4.477rlmeijer290.095(112)
13.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif4)3.777[DPC] Switch12.642.535(7)
14.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif5)3.433Wolfje6661.913.986(27)
15.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)2.528Grutte Pier [Wa Oars]38.302(379)
16.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif7)2.470Asgoroth1.050.689(43)
17.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif11)2.163Eagle3210562.169(59)
18.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif21)1.719Berkie2.033.828(26)
19.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif5)1.703Teachalot2.117.055(24)
20.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif17)1.676Gjalt163.694(160)
21.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)1.497K3th3r1.523.024(31)
22.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif4)1.489[DPC] Brainy0071.442.030(34)
23.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif8)1.418AmeComputers3.664.295(16)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif8)1.212Confuzer390.498(88)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif16)1.010hermanmonique806.622(48)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif30)995Kevin4.873(764)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)957MartenZ139.474(185)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif20)947Andre Barnier426.408(81)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif23)939Ross26.258(446)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif9)930HellBringer1.339.112(35)
More...
Overall Top 30
postotalmemberdaily
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)43.645.737[DPC] hansR68.648(1)
2.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)23.326.071Sp@ceNv@der5.115(9)
3.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)19.090.219[DPC]Division_Brabant313(45)
4.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)18.873.713Searchy! Internet Services V.O.F.451(38)
5.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)17.531.322[DPC]TeamGrazzie536(35)
6.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)13.777.639Ensign Wildfire11.660(5)
7.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)12.642.535[DPC] Switch3.777(13)
8.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)11.824.686Tijntje29.341(2)
10.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)9.293.840o25o7.778(7)
11.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)7.530.904F@stmem5.040(10)
12.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)7.327.643[DPC]Div.Delft17.149(4)
14.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)5.506.899Falcon1019.847(3)
15.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)4.629.502apa9.559(6)
16.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)3.664.295AmeComputers1.418(23)
21.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.486.629Herby4.938(11)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.117.055Teachalot1.703(19)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.033.828Berkie1.719(18)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.913.986Wolfje6663.433(14)
More...
Teams Daily Top 15
posdailyteamtotal
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)518.344.233SETI.USA2.665.827.880(1)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)313.506UK BOINC Team319.462.677(32)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)299.887US NAVY505.003.249(18)
31.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)290.682Team NIPPON312.837.108(35)
32.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)265.159Nosu dba team110.462.624(82)
33.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif3)258.809Space Quest82.087.258(111)
34.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)251.076Elite Games347.051.434(28)
35.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif4)247.469Quebec157.906.887(56)
36.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)241.371Dutch Power Cows324.431.576(31)
37.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif4)232.771Ars Technica400.554.786(23)
38.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)231.482SETI@Ticino191.508.379(45)
39.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)229.643U.S.Air Force354.270.953(26)
40.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif5)219.422Brasil [SETIBR]316.245.468(33)
41.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)216.292Team Norway186.114.325(46)
42.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif2)208.882Sweden199.152.150(42)
43.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif3)207.868Sicituradastra.146.052.488(63)
More...
postotalteamdaily
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.665.827.880SETI.USA518.344.233(1)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)366.349.858Amateur Radio Operators321.183(28)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)362.060.229BOINC SETI@home RUSSIA606.124(12)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)354.270.953U.S.Air Force229.643(39)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)347.529.531Team MacNN160.053(55)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)347.051.434Elite Games251.076(34)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)339.927.882BOINC.Italy492.970(18)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)325.416.777Phoenix Rising164.151(52)
31.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)324.431.576Dutch Power Cows241.371(36)
32.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)319.462.677UK BOINC Team313.506(29)
33.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)316.245.468Brasil [SETIBR]219.422(40)
34.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)315.961.305Boone Community School District - Iowa531.655(16)
35.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)312.837.108Team NIPPON290.682(31)
36.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)301.390.333Carl Sagan391.158(22)
37.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)296.754.593Universe Examiners160.911(54)
38.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)243.731.643Hungary206.647(44)
More...
Megaflush Top 5
posTeamFlushDate
More...
Mijlpalen
Falcon105.500.000
Kevin4.000
Edwin Gozeling750
SETI@Home Links
SETI@Home webpage
SETI@Home forum
Bron
  • grass460
grass460
DPC SETI@Home hitparade van 5 november 2011
Daily Top 30
Flushers: 81 / 1.319 (6,1 %)
posdailymembertotal
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)69.885[DPC] hansR43.715.622(1)
2.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)29.066Tijntje11.853.752(8)
3.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)21.688Falcon105.528.587(14)
4.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)19.067[DPC]Div.Delft7.346.710(12)
5.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)11.946apa4.641.448(15)
6.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif3)9.734Sp@ceNv@der23.335.805(2)
7.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)9.354Ensign Wildfire13.786.993(6)
8.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)7.838o25o9.301.678(10)
9.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif5)5.193Wolfje6661.919.179(27)
10.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif9)5.068Teachalot2.122.123(24)
11.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif12)4.899AmeComputers3.669.194(16)
12.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif3)4.686Grutte Pier [Wa Oars]42.988(359)
13.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)4.520Herby2.491.149(21)
14.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif4)3.986F@stmem7.534.890(11)
15.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif58)2.858Maarten233.683(134)
16.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif6)2.770[DPC] Brainy0071.444.800(34)
17.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif4)2.593K3th3r1.525.617(31)
18.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif5)1.850[DPC] Switch12.644.385(7)
19.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif3)1.652Asgoroth1.052.341(43)
20.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif8)1.581Andre Barnier427.989(80)
21.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif6)1.550MartenZ141.024(184)
22.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)1.522Gjalt165.216(159)
23.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif5)1.521Berkie2.035.349(25)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.473Confuzer391.971(88)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif14)1.385Jan Boer199.136(149)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif43)1.314Disaster_Master56.925(302)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif14)1.035Opiate175.407(154)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif16)1.024rlmeijer291.119(112)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif2)987Arjant246.661(341)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif7)929luc dk196.609(150)
More...
Overall Top 30
postotalmemberdaily
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)43.715.622[DPC] hansR69.885(1)
2.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)23.335.805Sp@ceNv@der9.734(6)
3.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)19.090.441[DPC]Division_Brabant222(54)
4.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)18.874.608Searchy! Internet Services V.O.F.895(33)
5.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)17.531.415[DPC]TeamGrazzie93(73)
6.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)13.786.993Ensign Wildfire9.354(7)
7.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)12.644.385[DPC] Switch1.850(18)
8.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)11.853.752Tijntje29.066(2)
10.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)9.301.678o25o7.838(8)
11.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)7.534.890F@stmem3.986(14)
12.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)7.346.710[DPC]Div.Delft19.067(4)
14.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)5.528.587Falcon1021.688(3)
15.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)4.641.448apa11.946(5)
16.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)3.669.194AmeComputers4.899(11)
21.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.491.149Herby4.520(13)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.122.123Teachalot5.068(10)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)2.035.349Berkie1.521(23)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)2.035.199Override0(-)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.919.179Wolfje6665.193(9)
More...
Teams Daily Top 15
posdailyteamtotal
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)521.823.336SETI.USA2.669.306.983(1)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif2)288.783Team NIPPON313.125.891(35)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)274.190US NAVY505.277.439(18)
31.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif3)262.211Elite Games347.313.645(28)
32.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)258.532Space Quest82.345.790(111)
33.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)258.426Nosu dba team110.721.050(82)
34.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif7)256.335Team Norway186.370.660(46)
35.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif16)243.479SAIC: From Science to Solutions127.925.816(69)
36.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)241.235Dutch Power Cows324.672.811(31)
37.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif2)232.969U.S.Air Force354.503.922(26)
38.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)232.432Ars Technica400.787.218(23)
39.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif4)223.468Quebec158.130.355(56)
40.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif3)216.570Sicituradastra.146.269.058(63)
41.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif3)200.674SETI@Ticino191.709.053(45)
42.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif2)191.230Hungary243.922.873(38)
43.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif7)188.703Team Starfire World BOINC538.728.405(16)
More...
postotalteamdaily
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.669.306.983SETI.USA521.823.336(1)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)366.689.708Amateur Radio Operators339.850(27)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)362.665.382BOINC SETI@home RUSSIA605.153(13)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)354.503.922U.S.Air Force232.969(37)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)347.690.666Team MacNN161.135(53)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)347.313.645Elite Games262.211(31)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)340.453.503BOINC.Italy525.621(17)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)325.588.285Phoenix Rising171.508(51)
31.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)324.672.811Dutch Power Cows241.235(36)
32.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)319.760.493UK BOINC Team297.816(28)
33.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)316.509.169Boone Community School District - Iowa547.864(15)
34.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)316.428.615Brasil [SETIBR]183.147(48)
35.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)313.125.891Team NIPPON288.783(29)
36.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)301.783.243Carl Sagan392.910(22)
37.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)296.934.792Universe Examiners180.199(49)
38.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)243.922.873Hungary191.230(42)
More...
Megaflush Top 5
posTeamFlushDate
More...
Mijlpalen
Opiate175.000
Siddo70.000
Grutte Pier [Wa Oars]40.000
Kevin5.000
Nick5.000
SETI@Home Links
SETI@Home webpage
SETI@Home forum
Bron
