[SETI@Home] hitparade van week 47 Vorige deel Overzicht Volgende deel Laatste deel
  • grass460
  • Laatst online: 30-10 23:57
grass460
[DPC] Division_Brabant
Mede-auteurs:
  • APClll
  • Laatst online: 22:32
APClll
Afbeeldingslocatie: http://tweakers.net/ext/f/JC7kwqqV82fi9ViRWtJgzDBy/full.jpg
Inhoudsopgave Seti@Home hitparades week 47
* geen correcte stats beschikbaar
Wat is Seti@Home ?
Wat is SETI@home?
SETI@home is de naam van een wetenschappelijk experiment dat computers die via het internet met elkaar verbonden zijn, inzet om buitenaardse intelligentie op te sporen. U kunt hieraan deelnemen middels een gratis computerprogramma dat radiotelescoop-data download en analyseert.
Nieuws Update
9 Nov 2011 | 20:53:50 UTC
Funny story. About 3 years ago I realized that the BOINC database has result ids stored a integers, which are 4 bytes long and signed by default. The sign takes up one bit, thus leaving 31 bits remaining for the value. That means the maximum value is 2^31 (2 to the power of 31, or 2147483648). I mentioned this at this time, noting we were well on our way towards this maximum value, and put it on the "things we'll need to fix eventually" list.
Nobody has been really watching this (I've been pretty much out for over two months until this week), and sure enough we hit that limit yesterday, and the whole BOINC backend pretty much barfed. We tried to implement a "quick fix" by changing the result id signed integer to an unsigned integer (both in mysql and the C code), thus giving us an extra bit for the value. Now that means the maximum value is 2^32 (2 to the power of 32, or 4294967296). That should have bought us a couple more years.
However, this quick fix didn't really work. There's all kinds of code in BOINC that needs to be changed to get unsigned integers to work. Dave made some of these changes and Jeff tested them this morning, but still to no avail. More necessary fixes were found. We seem to be once again creating and sending out work at the moment. However the hood is wide open on BOINC now, so we're watching things carefully over the next day or so.
We're certainly not done - there are tons of cosmetic fixes that need to be made (our logs are full of entries containing negative result ids). In the long term we'll have to do the same for workunit ids, and at that point we'll probably go ahead and make them long longs (which are always 8 bytes, as opposed to longs, which are 4 bytes on 32-bit systems and 8 bytes on 64-bit systems) in the C code and bigints in mysql. At that point our id space will max out at 2305843009213693952, which should probably be enough. That's a million results a day for 6.3 billion years. If we're still running SETI@home 6.3 billion years from now there's probably nobody out there. Agreed?
We've been bitten by this long ago in informix, and have since been storing larger numbers there as int8's (8 byte integers) or doubles.
Warning: since we didn't come across this problem in advance and solve is gracefully, there may be some ugliness in the form of blocked results in weird states - these will most likely time out on their own and get resent. Sorry if this causes any confusion in the coming weeks.
By the way, it should be mentioned there were some random download server issues over this past weekend. No big deal - usual stuff regarding linux kernel hangs. We kicked the servers on monday morning and they went back to work.
- Matt
Ga naar de DPC website
  • grass460
grass460
Zo iedereen veilig de mist doorgekomen? Gelukkig hoefde ik niet weg. [DPC]Div.Delft en Edwin Gozeling hebben het vandaag weer gered want zij hebben een mijlpaal afgehaald. Jox444 heeft ook geen last van de mist gehad gisteren want met 25 plaatsen stijgen heeft hij goed door gegraasd.
Ook Nick verdiend een vermelding als hoogste nieuwe binnenkomer op plaats 30 *O*
DPC SETI@Home hitparade van 20 november 2011
Afbeeldingslocatie: http://gathering.tweakers.net/global/templates/got/images/layout/pixel.gif
Daily Top 30
Flushers: 70 / 1.320 (5,3 %)
posdailymembertotal
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)61.905[DPC] hansR44.496.133(1)
2.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)39.733[DPC]Div.Delft7.788.926(11)
3.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)31.629Tijntje12.284.777(8)
4.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)19.271Falcon105.794.086(13)
5.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif3)10.427apa4.744.177(15)
6.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)9.606Ensign Wildfire13.902.074(6)
7.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)7.764Grutte Pier [Wa Oars]160.459(165)
8.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif2)6.669F@stmem7.618.679(12)
9.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)6.507Sp@ceNv@der23.417.864(2)
10.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)4.838o25o9.360.943(10)
11.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)4.372Herby2.550.180(20)
12.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)4.068Wolfje6661.976.626(27)
13.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif6)3.650Asgoroth1.081.371(42)
14.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)3.591Teachalot2.186.515(24)
15.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)2.735[DPC] Switch12.686.424(7)
16.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif2)2.337AmeComputers3.704.655(16)
17.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif8)1.833jvissch2152.458(172)
18.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif3)1.215Berkie2.052.890(25)
19.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif5)1.134Betrayedcover43.889(355)
20.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif2)1.120Eagle3210578.071(58)
21.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif4)1.092K3th3r1.546.068(31)
22.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif7)970[DPC]TeamGrazzie17.538.667(5)
23.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif6)846HellBringer1.357.187(35)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)834MartenZ154.558(170)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif25)802Jox4441.523.783(32)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif6)772luc dk214.443(146)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif9)755DarthKoala154.875(167)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif5)687Rogier Wessel12.995(577)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif8)627coredump63.481(290)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif)528Nick5.843(731)
More...
Overall Top 30
postotalmemberdaily
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)44.496.133[DPC] hansR61.905(1)
2.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)23.417.864Sp@ceNv@der6.507(9)
3.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)19.094.900[DPC]Division_Brabant507(31)
4.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)18.882.769Searchy! Internet Services V.O.F.34(63)
5.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)17.538.667[DPC]TeamGrazzie970(22)
6.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)13.902.074Ensign Wildfire9.606(6)
7.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)12.686.424[DPC] Switch2.735(15)
8.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)12.284.777Tijntje31.629(3)
9.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)9.642.206MaGNeT (a.k.a. BlueTooth76)0(-)
10.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)9.360.943o25o4.838(10)
11.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)7.788.926[DPC]Div.Delft39.733(2)
12.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)7.618.679F@stmem6.669(8)
13.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)5.794.086Falcon1019.271(4)
14.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)5.685.852Bas Laurier0(-)
15.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)4.744.177apa10.427(5)
16.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)3.704.655AmeComputers2.337(16)
17.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)3.441.484Team_Elteor_Borislavj0(-)
18.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)3.200.789Mr Beamer0(-)
19.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.595.626dpc_kluizenaar0(-)
20.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.550.180Herby4.372(11)
21.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.513.166Jan Zandvliet & x-RaY990(-)
22.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.394.425[DPC]Trancemaus0(-)
23.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.216.648[DPC]Spinpoint0(-)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.186.515Teachalot3.591(14)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.052.890Berkie1.215(18)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.035.228Override0(-)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.976.626Wolfje6664.068(12)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.710.061Intrud3r0(-)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.644.506NicoClown0(-)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.602.694[DPC]Team Zuid-Holland0(-)
More...
Teams Daily Top 15
posdailyteamtotal
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)565.712.734SETI.USA2.713.196.381(1)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif4)362.014Carl Sagan306.859.033(36)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)324.502Amateur Radio Operators371.265.797(24)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)320.696TeAm AnandTech530.831.164(17)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)302.046Team NIPPON316.999.394(35)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif3)284.845999160.419.242(57)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)269.998UK BOINC Team323.550.305(33)
31.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)262.577US NAVY508.877.960(18)
32.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif2)241.737Dutch Power Cows327.886.072(31)
33.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif10)235.654Greece Masters61.204.753(148)
34.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif2)231.386Space Quest85.358.338(107)
35.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif4)230.652Quebec161.475.690(56)
36.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif5)227.960Elite Games350.700.356(27)
37.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif4)225.870Ars Technica403.931.910(23)
38.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)224.951Sweden202.209.016(42)
39.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)221.404SETI@Ticino194.347.477(44)
More...
Teams Overall Top 15
postotalteamdaily
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.713.196.381SETI.USA565.712.734(1)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)371.265.797Amateur Radio Operators324.502(26)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)371.025.386BOINC SETI@home RUSSIA576.274(14)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)357.347.978U.S.Air Force194.416(44)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)350.700.356Elite Games227.960(36)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)349.832.499Team MacNN153.501(53)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)346.921.816BOINC.Italy526.734(16)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)328.624.610Phoenix Rising207.015(43)
31.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)327.886.072Dutch Power Cows241.737(32)
32.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)324.243.155Boone Community School District - Iowa505.292(19)
33.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)323.550.305UK BOINC Team269.998(30)
34.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)319.243.359Brasil [SETIBR]215.918(42)
35.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)316.999.394Team NIPPON302.046(28)
36.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)306.859.033Carl Sagan362.014(25)
37.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)299.246.087Universe Examiners164.157(50)
38.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)246.693.285Hungary191.115(45)
More...
Megaflush Top 5
posTeamFlushDate
1.[DPC]Division_Brabant1.790.71126-02-2010
2.[DPC] hansR1.156.60326-02-2010
3.MaGNeT (a.k.a. BlueTooth76)959.79215-10-2010
4.Searchy! Internet Services V.O.F.785.77526-02-2010
5.[DPC]TeamGrazzie553.05604-01-2008
More...
Mijlpalen
[DPC]Div.Delft7.750.000
Edwin Gozeling5.000
SETI@Home Links
SETI@Home webpage
SETI@Home forum
DPCH Suggestiepagina
Bron
  • APClll
APClll
FP ProMod
[DPC] Team Grazzie
:Y
Zolang je niet de voorste in de rij bent, hoef je alleen maar je voorligger te volgen. En zolang de voorste de weg op z'n duimpje kent, rijdt de rest er niet achteraan het kanaal in :P
Ouwe troep? Wat is dat?.......Alles is leuk, zelfs modelracing..........BOINC ook mee met DPC!
......Team Grazzie~Power....!! Mooooooeeeee......
  • APClll
APClll
FP ProMod
[DPC] Team Grazzie
Ook deze mistige dag ben ik weer goed doorgekomen :P
En omdat ik vanavond zonder mist naar huis kon komen, ben ik ook nog op tijd voor de stats. Smakelijk eten allemaal :)
DPC SETI@Home hitparade van 21 november 2011
Daily Top 30
Flushers: 69 / 1.320 (5,2 %)
posdailymembertotal
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)66.358[DPC] hansR44.562.491(1)
2.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)44.101[DPC]Div.Delft7.833.027(11)
3.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)26.423Tijntje12.311.200(8)
4.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)19.132Falcon105.813.218(13)
5.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif2)12.856Grutte Pier [Wa Oars]173.315(157)
6.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)10.756apa4.754.933(15)
7.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)6.935Ensign Wildfire13.909.009(6)
8.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)6.894F@stmem7.625.573(12)
9.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)6.234Sp@ceNv@der23.424.098(2)
10.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)4.584o25o9.365.527(10)
11.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif4)3.119[DPC] Switch12.689.543(7)
12.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)3.045Herby2.553.225(20)
13.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)2.846Wolfje6661.979.472(27)
14.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.325Teachalot2.188.840(24)
15.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif7)2.151[DPC]TeamGrazzie17.540.818(5)
16.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.127AmeComputers3.706.782(16)
17.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif2)1.682Betrayedcover45.571(345)
18.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif19)1.209Andre Barnier438.666(78)
19.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif8)912DarthKoala155.787(167)
20.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif31)900Arie Klerk59.607(300)
21.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)839Eagle3210578.910(58)
22.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif13)819Kevin11.996(590)
23.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif34)814Confuzer407.664(84)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif3)755K3th3r1.546.823(31)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif11)753Mickroz24.449(465)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif24)749sander2774246.395(128)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif41)697Handige Harrie101.695(224)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif3)671Jox4441.524.454(32)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif11)525Berkie2.053.415(25)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif17)521Asgoroth1.081.892(42)
More...
Overall Top 30
postotalmemberdaily
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)44.562.491[DPC] hansR66.358(1)
2.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)23.424.098Sp@ceNv@der6.234(9)
3.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)19.095.046[DPC]Division_Brabant146(45)
4.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)18.882.917Searchy! Internet Services V.O.F.148(44)
5.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)17.540.818[DPC]TeamGrazzie2.151(15)
6.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)13.909.009Ensign Wildfire6.935(7)
7.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)12.689.543[DPC] Switch3.119(11)
8.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)12.311.200Tijntje26.423(3)
10.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)9.365.527o25o4.584(10)
11.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)7.833.027[DPC]Div.Delft44.101(2)
12.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)7.625.573F@stmem6.894(8)
13.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)5.813.218Falcon1019.132(4)
15.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)4.754.933apa10.756(6)
16.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)3.706.782AmeComputers2.127(16)
20.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.553.225Herby3.045(12)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.188.840Teachalot2.325(14)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.053.415Berkie525(29)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.979.472Wolfje6662.846(13)
More...
Teams Daily Top 15
posdailyteamtotal
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)569.588.981SETI.USA2.717.072.628(1)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)305.831UK BOINC Team323.856.136(33)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif6)271.933Elite Games350.972.289(27)
31.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif9)269.272Sicituradastra.149.274.013(61)
32.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif3)262.190999160.681.432(57)
33.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif8)260.7692CPU.com209.955.864(41)
34.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)258.983Quebec161.734.673(56)
35.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif3)256.785Sweden202.465.801(42)
36.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif4)245.763Dutch Power Cows328.131.835(31)
37.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif2)243.490SETI@Ticino194.590.967(44)
38.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif4)230.977Brasil [SETIBR]319.474.336(34)
39.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)226.152Ars Technica404.158.062(23)
40.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif6)225.329Space Quest85.583.667(107)
41.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif2)215.739Phoenix Rising328.840.349(30)
42.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif2)215.212U.S.Air Force357.563.190(26)
43.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif15)203.824Hewlett-Packard144.795.314(64)
More...
postotalteamdaily
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.717.072.628SETI.USA569.588.981(1)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)371.767.148BOINC SETI@home RUSSIA741.762(9)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)371.578.190Amateur Radio Operators312.393(27)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)357.563.190U.S.Air Force215.212(42)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)350.972.289Elite Games271.933(30)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)349.986.998Team MacNN154.499(55)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)347.432.958BOINC.Italy511.142(17)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)328.840.349Phoenix Rising215.739(41)
31.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)328.131.835Dutch Power Cows245.763(36)
32.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)324.756.332Boone Community School District - Iowa513.177(16)
33.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)323.856.136UK BOINC Team305.831(29)
34.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)319.474.336Brasil [SETIBR]230.977(38)
35.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)317.310.969Team NIPPON311.575(28)
36.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)307.235.242Carl Sagan376.209(24)
37.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)299.426.043Universe Examiners179.956(51)
38.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)246.887.472Hungary194.187(47)
More...
Megaflush Top 5
posTeamFlushDate
More...
Mijlpalen
apa4.750.000
Arno20.000
Maurice50436.000
SETI@Home Links
SETI@Home webpage
SETI@Home forum
Bron
  • grass460
grass460
bedankt voor de stats. Mist weg.... slagbomen dicht |:(
  • APClll
APClll
FP ProMod
[DPC] Team Grazzie
grass460 schreef op dinsdag 22 november 2011 @ 20:10:
:D
Met de mist ook, maar toen zag je ze niet :+
  • APClll
APClll
FP ProMod
[DPC] Team Grazzie
Nieuwe dag, nieuwe stats, nieuwe mijlpalen.
Er zijn van die dagen dat je niet weet wat je met een mijlpaal moet, maar met de mist zijn ze handig. Je kunt er bijvoorbeeld een felle lamp aan hangen of een touw aanvast te knopen om de weg naar huis te vinden.
Of, als 'ie hoog genoeg is, steekt 'ie misschien wel boven de mist uit. Ideaal voor de helicopterbezitters onder ons. Al gok ik dat dat er niet zo veel zullen zijn :P
{verhaal}
DPC SETI@Home hitparade van 22 november 2011
Daily Top 30
posdailymembertotal
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)63.731[DPC] hansR44.626.222(1)
2.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)33.239[DPC]Div.Delft7.866.266(11)
3.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)25.871Tijntje12.337.071(8)
4.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)17.758Falcon105.830.976(13)
5.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)15.488Grutte Pier [Wa Oars]188.803(153)
6.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)10.453apa4.765.386(15)
7.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)8.479Ensign Wildfire13.917.488(6)
8.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)8.069F@stmem7.633.642(12)
9.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif3)4.102Herby2.557.327(20)
10.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)3.796Sp@ceNv@der23.427.894(2)
11.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif2)3.774Wolfje6661.983.246(27)
12.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)3.133o25o9.368.660(10)
13.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif17)2.851Asgoroth1.084.743(42)
14.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif2)2.522AmeComputers3.709.304(16)
15.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)2.346Teachalot2.191.186(24)
16.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif8)2.322K3th3r1.549.145(31)
17.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif42)1.935Herman J.C. van der Bent276.881(115)
18.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif7)1.733[DPC] Switch12.691.276(7)
19.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif39)1.657Dain_Bramage29.428(427)
20.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif3)1.384Betrayedcover46.955(344)
21.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif24)1.333rlmeijer301.554(108)
22.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif3)1.267DarthKoala157.054(167)
23.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif21)1.172Searchy! Internet Services V.O.F.18.884.089(4)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif5)887Berkie2.054.302(25)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif4)876Eagle3210579.786(58)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif6)738Arie Klerk60.345(300)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif4)736HellBringer1.357.923(35)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif6)665Kevin12.661(582)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif2)648MartenZ155.667(168)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif20)625[DPC] de7geitjes484.893(68)
More...
Overall Top 30
postotalmemberdaily
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)44.626.222[DPC] hansR63.731(1)
2.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)23.427.894Sp@ceNv@der3.796(10)
3.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)19.095.322[DPC]Division_Brabant276(42)
4.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)18.884.089Searchy! Internet Services V.O.F.1.172(23)
5.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)17.541.433[DPC]TeamGrazzie615(31)
6.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)13.917.488Ensign Wildfire8.479(7)
7.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)12.691.276[DPC] Switch1.733(18)
8.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)12.337.071Tijntje25.871(3)
10.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)9.368.660o25o3.133(12)
11.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)7.866.266[DPC]Div.Delft33.239(2)
12.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)7.633.642F@stmem8.069(8)
13.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)5.830.976Falcon1017.758(4)
15.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)4.765.386apa10.453(6)
16.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)3.709.304AmeComputers2.522(14)
20.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.557.327Herby4.102(9)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.191.186Teachalot2.346(15)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.054.302Berkie887(24)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.983.246Wolfje6663.774(11)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.644.532NicoClown26(69)
More...
Teams Daily Top 15
posdailyteamtotal
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)573.293.835SETI.USA2.720.777.482(1)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)281.105UK BOINC Team324.137.241(33)
31.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)261.075Elite Games351.233.364(27)
32.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)254.299Sicituradastra.149.528.312(61)
33.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif4)253.030SETI@Ticino194.843.997(44)
34.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif4)241.612Brasil [SETIBR]319.715.948(34)
35.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)239.748Sweden202.705.549(42)
36.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)232.702Quebec161.967.375(56)
37.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)225.147Dutch Power Cows328.356.982(31)
38.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif2)224.896Space Quest85.808.563(107)
39.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif7)218.806999160.900.238(57)
40.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif7)212.7542CPU.com210.168.618(41)
41.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)209.785Phoenix Rising329.050.134(30)
42.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif3)209.398Team Norway189.759.788(46)
43.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)205.784The Search for EVE170.586.695(53)
44.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif5)200.700Ars Technica404.358.762(23)
More...
postotalteamdaily
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.720.777.482SETI.USA573.293.835(1)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)372.471.343BOINC SETI@home RUSSIA704.195(10)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)371.889.769Amateur Radio Operators311.579(28)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)357.743.565U.S.Air Force180.375(47)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)351.233.364Elite Games261.075(31)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)350.138.968Team MacNN151.970(55)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)347.896.319BOINC.Italy463.361(18)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)329.050.134Phoenix Rising209.785(41)
31.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)328.356.982Dutch Power Cows225.147(37)
32.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)325.296.267Boone Community School District - Iowa539.935(17)
33.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)324.137.241UK BOINC Team281.105(30)
34.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)319.715.948Brasil [SETIBR]241.612(34)
35.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)317.611.922Team NIPPON300.953(29)
36.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)307.618.267Carl Sagan383.025(24)
37.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)299.583.399Universe Examiners157.356(52)
38.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)247.074.804Hungary187.332(46)
More...
Megaflush Top 5
posTeamFlushDate
More...
Mijlpalen
Herman J.C. van der Bent275.000
Grutte Pier [Wa Oars]175.000
Arie Klerk60.000
SETI@Home Links
SETI@Home webpage
SETI@Home forum
Bron
[SETI@Home] hitparade van 23 november
De mist is opgetrokken... maar wat zien wij hieronder?
Niets of eh bijna niets.
DPC SETI@Home hitparade van 23 november 2011
Daily Top 30
Flushers: 0 / 1.320 (0,0 %)
posdailymembertotal
More...
Overall Top 30
postotalmemberdaily
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)44.626.222[DPC] hansR0(-)
2.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)23.427.894Sp@ceNv@der0(-)
3.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)19.095.322[DPC]Division_Brabant0(-)
4.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)18.884.089Searchy! Internet Services V.O.F.0(-)
5.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)17.541.433[DPC]TeamGrazzie0(-)
6.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)13.917.488Ensign Wildfire0(-)
7.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)12.691.276[DPC] Switch0(-)
8.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)12.337.071Tijntje0(-)
10.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)9.368.660o25o0(-)
11.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)7.866.266[DPC]Div.Delft0(-)
12.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)7.633.642F@stmem0(-)
13.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)5.830.976Falcon100(-)
15.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)4.765.386apa0(-)
16.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)3.709.304AmeComputers0(-)
20.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.557.327Herby0(-)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.191.186Teachalot0(-)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.054.302Berkie0(-)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.983.246Wolfje6660(-)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.644.532NicoClown0(-)
More...
Teams Daily Top 15
posdailyteamtotal
More...
postotalteamdaily
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)372.471.343BOINC SETI@home RUSSIA0(-)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)371.889.769Amateur Radio Operators0(-)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)357.743.565U.S.Air Force0(-)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)351.233.364Elite Games0(-)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)350.138.968Team MacNN0(-)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)347.896.319BOINC.Italy0(-)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)329.050.134Phoenix Rising0(-)
31.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)328.356.982Dutch Power Cows0(-)
32.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)325.296.267Boone Community School District - Iowa0(-)
33.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)324.137.241UK BOINC Team0(-)
34.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)319.715.948Brasil [SETIBR]0(-)
35.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)317.611.922Team NIPPON0(-)
36.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)307.618.267Carl Sagan0(-)
37.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)299.583.399Universe Examiners0(-)
38.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)247.074.804Hungary0(-)
More...
Megaflush Top 5
posTeamFlushDate
More...
SETI@Home Links
SETI@Home webpage
SETI@Home forum
Bron
8)7
  • APClll
APClll
FP ProMod
[DPC] Team Grazzie
^^ Dat was ook pechhebben. Wil je de stats gaan posten, blijken het statsloze stats te zijn 8)7
Eens even kijken of ik meer gelukt heb ;)
jAAAAAAAAAAAAAAAAAAAA. Of zou 't toch geen geluk zijn? Niemand die 't weet
{verhaal}
DPC SETI@Home hitparade van 24 november 2011
Daily Top 30
Flushers: 83 / 1.320 (6,3 %)
posdailymembertotal
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)108.493[DPC] hansR44.734.715(1)
2.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)60.783[DPC]Div.Delft7.927.049(11)
3.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)57.301Tijntje12.394.372(8)
4.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif)32.035Grutte Pier [Wa Oars]220.838(143)
5.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)30.160Falcon105.861.136(13)
6.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif)17.204Ensign Wildfire13.934.692(6)
7.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)15.978apa4.781.364(15)
8.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)13.959F@stmem7.647.601(12)
9.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif)13.109Sp@ceNv@der23.441.003(2)
10.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)8.201Herby2.565.528(20)
11.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)7.021Wolfje6661.990.267(27)
12.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)6.998o25o9.375.658(10)
13.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif)5.556Teachalot2.196.742(24)
14.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)4.965AmeComputers3.714.269(16)
15.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif)3.365K3th3r1.552.510(31)
16.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif)3.300Berkie2.057.602(25)
17.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif)3.266Betrayedcover50.221(333)
18.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.059[DPC] Switch12.693.335(7)
19.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif6)2.042Asgoroth1.086.785(42)
20.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif)1.846Eagle3210581.632(58)
21.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif)1.778Geejay176.523(157)
22.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif)1.693[DPC]TeamGrazzie17.543.126(5)
23.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif)1.635Mickroz26.501(449)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif)1.521Confuzer409.472(84)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif)1.378Andre Barnier440.649(76)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif)1.344jvissch2154.772(169)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif)1.274MartenZ156.941(168)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif)1.271Disaster_Master67.402(283)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif)1.098Maarten244.590(130)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif)1.063groentje68.521(280)
More...
Overall Top 30
postotalmemberdaily
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)44.734.715[DPC] hansR108.493(1)
2.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)23.441.003Sp@ceNv@der13.109(9)
3.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)19.096.262[DPC]Division_Brabant940(33)
4.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)18.884.368Searchy! Internet Services V.O.F.279(53)
5.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)17.543.126[DPC]TeamGrazzie1.693(22)
6.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)13.934.692Ensign Wildfire17.204(6)
7.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)12.693.335[DPC] Switch2.059(18)
8.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)12.394.372Tijntje57.301(3)
10.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)9.375.658o25o6.998(12)
11.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)7.927.049[DPC]Div.Delft60.783(2)
12.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)7.647.601F@stmem13.959(8)
13.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)5.861.136Falcon1030.160(5)
15.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)4.781.364apa15.978(7)
16.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)3.714.269AmeComputers4.965(14)
20.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.565.528Herby8.201(10)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.196.742Teachalot5.556(13)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.057.602Berkie3.300(16)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.990.267Wolfje6667.021(11)
More...
Teams Daily Top 15
posdailyteamtotal
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)580.269.757SETI.USA2.727.753.404(1)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif)549.282UK BOINC Team324.686.523(33)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)545.591Team NIPPON318.157.513(35)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif)486.434Elite Games351.719.798(27)
31.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif)478.268999161.378.506(57)
32.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif)465.507Quebec162.432.882(56)
33.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)464.829Sicituradastra.149.993.141(61)
34.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)464.251SETI@Ticino195.308.248(44)
35.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif)434.317Dutch Power Cows328.791.299(31)
36.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif)433.721Space Quest86.242.284(107)
37.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif)413.6232CPU.com210.582.241(41)
38.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif3)409.228Sweden203.114.777(42)
39.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif)407.809Ars Technica404.766.571(23)
40.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif6)398.755Brasil [SETIBR]320.114.703(34)
41.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)384.505Phoenix Rising329.434.639(30)
42.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif)375.669Hungary247.450.473(38)
More...
postotalteamdaily
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.727.753.404SETI.USA580.269.757(1)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)373.819.232BOINC SETI@home RUSSIA1.347.889(9)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)372.480.889Amateur Radio Operators591.120(26)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)358.099.237U.S.Air Force355.672(45)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)351.719.798Elite Games486.434(30)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)350.455.358Team MacNN316.390(52)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)348.550.895BOINC.Italy654.576(24)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)329.434.639Phoenix Rising384.505(41)
31.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)328.791.299Dutch Power Cows434.317(35)
32.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)326.344.964Boone Community School District - Iowa1.048.697(15)
33.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)324.686.523UK BOINC Team549.282(28)
34.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)320.114.703Brasil [SETIBR]398.755(40)
35.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)318.157.513Team NIPPON545.591(29)
36.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)308.301.561Carl Sagan683.294(23)
37.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)299.903.208Universe Examiners319.809(50)
38.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)247.450.473Hungary375.669(42)
More...
Megaflush Top 5
posTeamFlushDate
More...
Mijlpalen
Grutte Pier [Wa Oars]200.000
Geejay175.000
Betrayedcover50.000
Compizfox1.000
SETI@Home Links
SETI@Home webpage
SETI@Home forum
Bron
[SETI@Home] hitparade van 25 november
En wie komen wij hier o.a. tegen?
Grutte Pier [Wa Oars] 225.000
denniswoot 150.000
Edwin Gozeling 6.000
Die hun mijlpalen mogen afhalen in het mijlpalen magazijn.
groentje, Arie Klerk, e.v.a. die gewoon lekker flushen in de Daily.
Siddo, die de FotD bokaal wint.
En Ron? Die gaat voortaan onder een andere naam door het koeienleven.
{verhaal}
DPC SETI@Home hitparade van 25 november 2011
Daily Top 30
Flushers: 71 / 1.320 (5,4 %)
posdailymembertotal
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)50.532[DPC] hansR44.785.247(1)
2.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)38.638[DPC]Div.Delft7.965.687(11)
3.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)32.500Tijntje12.426.872(8)
4.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)23.576Grutte Pier [Wa Oars]244.414(131)
5.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)17.346Falcon105.878.482(13)
6.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif3)14.138Sp@ceNv@der23.455.141(2)
7.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)7.710F@stmem7.655.311(12)
8.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)6.428Ensign Wildfire13.941.120(6)
9.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif4)5.262Teachalot2.202.004(24)
10.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif2)4.228o25o9.379.886(10)
11.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif4)4.163apa4.785.527(15)
12.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)3.973Herby2.569.501(20)
13.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)3.528Wolfje6661.993.795(27)
14.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif5)2.767Asgoroth1.089.552(41)
15.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)2.621AmeComputers3.716.890(16)
16.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.610Berkie2.059.212(25)
17.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif13)1.378groentje69.899(279)
18.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif7)1.377Andre Barnier442.026(75)
19.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif4)1.363K3th3r1.553.873(31)
20.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif3)1.361Betrayedcover51.582(326)
21.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)1.176Eagle3210582.808(58)
22.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.115[DPC]TeamGrazzie17.544.241(5)
23.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif10)861[DPC]Division_Brabant19.097.123(3)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif26)821Siddo73.760(270)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif2)811MartenZ157.752(167)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif5)798hermanmonique815.830(48)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif6)756Geejay177.279(157)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)745jvissch2155.517(169)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif5)694Confuzer410.166(84)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif32)691Arie Klerk61.199(298)
More...
Overall Top 30
postotalmemberdaily
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)44.785.247[DPC] hansR50.532(1)
2.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)23.455.141Sp@ceNv@der14.138(6)
3.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)19.097.123[DPC]Division_Brabant861(23)
4.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)18.884.604Searchy! Internet Services V.O.F.236(46)
5.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)17.544.241[DPC]TeamGrazzie1.115(22)
6.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)13.941.120Ensign Wildfire6.428(8)
7.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)12.693.481[DPC] Switch146(53)
8.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)12.426.872Tijntje32.500(3)
10.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)9.379.886o25o4.228(10)
11.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)7.965.687[DPC]Div.Delft38.638(2)
12.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)7.655.311F@stmem7.710(7)
13.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)5.878.482Falcon1017.346(5)
15.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)4.785.527apa4.163(11)
16.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)3.716.890AmeComputers2.621(15)
20.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.569.501Herby3.973(12)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.202.004Teachalot5.262(9)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.059.212Berkie1.610(16)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.993.795Wolfje6663.528(13)
More...
Teams Daily Top 15
posdailyteamtotal
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)584.066.149SETI.USA2.731.549.796(1)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)287.149Team NIPPON318.444.662(35)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif6)266.746Space Quest86.509.030(107)
31.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif2)258.985Sicituradastra.150.252.126(61)
32.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif8)257.304BOINC.Italy348.808.199(29)
33.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)254.687SETI@Ticino195.562.935(44)
34.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)253.789Quebec162.686.671(56)
35.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif5)242.043Elite Games351.961.841(27)
36.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)234.427Dutch Power Cows329.025.726(31)
37.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)228.771Sweden203.343.548(42)
38.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif7)227.536999161.606.042(57)
39.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)223.990Brasil [SETIBR]320.338.693(34)
40.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)211.361Phoenix Rising329.646.000(30)
41.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)210.733Ars Technica404.977.304(23)
42.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif5)204.9732CPU.com210.787.214(41)
43.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif4)201.912Greece Masters62.090.686(146)
More...
postotalteamdaily
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.731.549.796SETI.USA584.066.149(1)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)374.585.003BOINC SETI@home RUSSIA765.771(10)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)372.794.974Amateur Radio Operators314.085(26)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)358.276.534U.S.Air Force177.297(49)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)351.961.841Elite Games242.043(35)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)350.625.415Team MacNN170.057(50)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)348.808.199BOINC.Italy257.304(32)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)329.646.000Phoenix Rising211.361(40)
31.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)329.025.726Dutch Power Cows234.427(36)
32.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)326.842.797Boone Community School District - Iowa497.833(17)
33.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)325.000.560UK BOINC Team314.037(27)
34.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)320.338.693Brasil [SETIBR]223.990(39)
35.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)318.444.662Team NIPPON287.149(29)
36.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)308.687.267Carl Sagan385.706(21)
37.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)300.088.032Universe Examiners184.824(47)
38.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)247.649.231Hungary198.758(46)
More...
Megaflush Top 5
posTeamFlushDate
More...
Mijlpalen
Grutte Pier [Wa Oars]225.000
denniswoot150.000
Edwin Gozeling6.000
Nieuwe Leden
Ron S te E28.694
Leaves
Ron0
SETI@Home Links
SETI@Home webpage
SETI@Home forum
Bron
  • grass460
grass460
Zo even de week compleet maken met de stats, dan kunnen we morgen weer met een schone lei beginnen.
Gisteren zijn er twee plekken in de DPC gevuld, dus welkom Fierljeppen en Mikkie. *O*
Afd Delft heeft weer flink gegraasd want de 8 miljoen mijlpaal staat klaar, ook de friezen zijn op dreef en hebben het kwart miljoen binnen, maar groentje doet het in zijn eentje erg goed en is op weg naar zijn eerste ton maar pakt eerst 70k mijlpaal mee. d:)b
DPC SETI@Home hitparade van 26 november 2011
Daily Top 30
Flushers: 75 / 1.321 (5,7 %)
posdailymembertotal
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)49.914[DPC] hansR44.835.161(1)
2.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)36.214[DPC]Div.Delft8.001.901(11)
3.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)28.689Tijntje12.455.561(8)
4.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)25.302Grutte Pier [Wa Oars]269.716(118)
5.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)15.857Sp@ceNv@der23.470.998(2)
6.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)15.672Falcon105.894.154(13)
7.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif2)8.044Teachalot2.210.048(24)
8.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)7.432F@stmem7.662.743(12)
9.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif2)6.902apa4.792.429(15)
10.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)5.228Ensign Wildfire13.946.348(6)
11.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)4.224o25o9.384.110(10)
12.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)2.630Wolfje6661.996.425(27)
13.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)2.456Herby2.571.957(20)
14.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.782Asgoroth1.091.334(41)
15.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.570AmeComputers3.718.460(16)
16.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif13)1.476Confuzer411.642(84)
17.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif2)1.357K3th3r1.555.230(31)
18.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)1.287groentje71.186(277)
19.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)1.160Andre Barnier443.186(75)
20.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif25)1.130Gjalt181.193(155)
21.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)1.120[DPC]TeamGrazzie17.545.361(5)
22.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)998Eagle3210583.806(58)
23.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif3)988hermanmonique816.818(48)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif7)930DarthKoala159.499(166)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif9)788Berkie2.060.000(25)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif28)780[DPC] Brainy0071.461.134(34)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif25)752Da-Wizzkid492.350(66)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif32)726[DPC]Blah.NET593.618(57)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif5)624Shalingoul61.810(297)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif9)577Jox4441.526.357(32)
More...
Overall Top 30
postotalmemberdaily
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)44.835.161[DPC] hansR49.914(1)
2.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)23.470.998Sp@ceNv@der15.857(5)
3.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)19.097.274[DPC]Division_Brabant151(53)
4.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)18.884.772Searchy! Internet Services V.O.F.168(52)
5.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)17.545.361[DPC]TeamGrazzie1.120(21)
6.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)13.946.348Ensign Wildfire5.228(10)
7.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)12.693.932[DPC] Switch451(37)
8.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)12.455.561Tijntje28.689(3)
10.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)9.384.110o25o4.224(11)
11.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)8.001.901[DPC]Div.Delft36.214(2)
12.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)7.662.743F@stmem7.432(8)
13.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)5.894.154Falcon1015.672(6)
15.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)4.792.429apa6.902(9)
16.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)3.718.460AmeComputers1.570(15)
20.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.571.957Herby2.456(13)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.210.048Teachalot8.044(7)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.060.000Berkie788(25)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)1.996.425Wolfje6662.630(12)
More...
Teams Daily Top 15
posdailyteamtotal
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)587.738.836SETI.USA2.735.222.483(1)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif5)280.307Elite Games352.242.148(27)
31.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif1)265.120BOINC.Italy349.073.319(29)
32.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)265.012Sicituradastra.150.517.138(61)
33.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif8)257.036Ars Technica405.234.340(23)
34.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)251.219SETI@Ticino195.814.154(44)
35.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif5)242.665Space Quest86.751.695(107)
36.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)239.565Quebec162.926.236(56)
37.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)238.766Dutch Power Cows329.264.492(31)
38.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif2)236.890Phoenix Rising329.882.890(30)
39.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif2)227.420Sweden203.570.968(42)
40.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/down.gif1)224.767Brasil [SETIBR]320.563.460(34)
41.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif3)222.877The Search for EVE171.365.135(53)
42.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)222.0642CPU.com211.009.278(41)
43.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif3)201.373Hungary247.850.604(38)
44.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/up.gif5)199.278U.S.Air Force358.475.812(26)
More...
postotalteamdaily
1.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)2.735.222.483SETI.USA587.738.836(1)
24.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)375.306.470BOINC SETI@home RUSSIA721.467(10)
25.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)373.106.785Amateur Radio Operators311.811(25)
26.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)358.475.812U.S.Air Force199.278(44)
27.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)352.242.148Elite Games280.307(30)
28.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)350.778.699Team MacNN153.284(54)
29.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)349.073.319BOINC.Italy265.120(31)
30.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)329.882.890Phoenix Rising236.890(38)
31.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)329.264.492Dutch Power Cows238.766(37)
32.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)327.393.797Boone Community School District - Iowa551.000(17)
33.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)325.305.481UK BOINC Team304.921(27)
34.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)320.563.460Brasil [SETIBR]224.767(40)
35.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)318.740.694Team NIPPON296.032(29)
36.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)309.046.820Carl Sagan359.553(22)
37.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)300.279.976Universe Examiners191.944(45)
38.(Afbeeldingslocatie: http://www.tweakers.net/g/dpc/stil.gif)247.850.604Hungary201.373(43)
More...
Megaflush Top 5
posTeamFlushDate
More...
Mijlpalen
[DPC]Div.Delft8.000.000
Grutte Pier [Wa Oars]250.000
groentje70.000
Nieuwe Leden
Fierljeppen97.494
Mikkie2.274
Leaves
JNSILVIUS0
SETI@Home Links
SETI@Home webpage
SETI@Home forum
Bron
