• mrc4nl
  • Laatst online: 02:42
mrc4nl
Procrastinatie expert
hier de data van mn nieuwe scherm: (LP154WU2 (TL)(A2)
data van registery-active hieronder, opvallend stond in een ander register: "HP L1945w" maar dat is 19 inch :+
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
Monitor
  Windows description...... Generic PnP Monitor
  Manufacturer............. LG Display
  Plug and Play ID......... LGD018F
  Data string.............. HT009€154WU2  [*CP437]
  Serial number............ n/a
  Manufacture date......... 2008, ISO week 0
  Filter driver............ None
  EDID revision............ 1.3
  Input signal type........ Digital
  Color bit depth.......... Undefined
  Display type............. RGB color
  Screen size.............. 330 x 210 mm (15,4 in)
  Power management......... Not supported
  Extension blocs.......... None
  DDC/CI................... n/a
Color characteristics
  Default color space...... Non-sRGB
  Display gamma............ 2,20
  Red chromaticity......... Rx 0,596 - Ry 0,351
  Green chromaticity....... Gx 0,323 - Gy 0,549
  Blue chromaticity........ Bx 0,158 - By 0,148
  White point (default).... Wx 0,313 - Wy 0,329
  Additional descriptors... None
Timing characteristics
  Range limits............. Not available
  GTF standard............. Not supported
  Preferred timing......... Yes
  Native/preferred timing.. 1920x1200p at 60Hz (16:10)
    Modeline............... "1920x1200" 151,700 1920 1950 1980 2014 1200 1203 1209 1256 +hsync -vsync
  Detailed timing #1....... 1920x1200p at 40Hz (16:10)
    Modeline............... "1920x1200" 151,700 1920 1950 1980 2014 1200 1203 1209 1884 -hsync -vsync
Standard timings supported
Report information
  Date generated........... 25-3-2012
  Software revision........ 2.60.0.972
  Data source.............. Registry-Active
  Operating system......... 6.2.8250.2
Raw data
  00,FF,FF,FF,FF,FF,FF,00,30,E4,8F,01,00,00,00,00,00,12,01,03,80,21,15,78,0A,BE,85,98,59,52,8C,28,
  26,50,54,00,00,00,01,01,01,01,01,01,01,01,01,01,01,01,01,01,01,01,42,3B,80,5E,70,B0,38,40,1E,1E,
  36,00,4B,CF,10,00,00,1A,42,3B,80,5E,70,B0,AC,42,1E,1E,36,00,4B,CF,10,00,00,19,00,00,00,FE,00,48,
  54,30,30,39,80,31,35,34,57,55,32,0A,00,00,00,00,00,00,00,00,00,00,00,00,00,02,01,0A,20,20,00,B7
ora et labora
  • Tronic
  • Laatst online: 24-10 12:50
HP ProBook 6550b WD705EA#ABH (mat scherm)
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
Monitor
  Plug and Play ID......... LGD0258
  Data string.............. LP156WD1-TLD3
  Manufacture date......... 2009, ISO week 0
  Screen size.............. 350 x 190 mm (15.7 in)
  DDC/CI................... Not supported
  Display gamma............ 2.20
  Red chromaticity......... Rx 0.617 - Ry 0.349
  Green chromaticity....... Gx 0.314 - Gy 0.597
  Blue chromaticity........ Bx 0.151 - By 0.057
  White point (default).... Wx 0.313 - Wy 0.329
  Native/preferred timing.. 1600x900p at 60Hz (16:9)
    Modeline............... "1600x900" 107.800 1600 1648 1680 1920 900 903 908 936 -hsync -vsync
Report information
  Date generated........... 4/12/2012
  Data source.............. Real-time 0x0100
  Operating system......... 6.1.7601.2.Service Pack 1
Raw data
  00,FF,FF,FF,FF,FF,FF,00,30,E4,58,02,00,00,00,00,00,13,01,03,80,23,13,78,0A,1B,E5,9E,59,50,98,26,
  0E,50,54,00,00,00,01,01,01,01,01,01,01,01,01,01,01,01,01,01,01,01,1C,2A,40,40,61,84,24,30,30,20,
  35,00,59,C2,10,00,00,19,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,FE,00,4C,
  47,20,44,69,73,70,6C,61,79,0A,20,20,00,00,00,FE,00,4C,50,31,35,36,57,44,31,2D,54,4C,44,33,00,A3
dell / alienware m17x,
betreft het 120hz 3d panel:
van samsung??? :S
Monitor
Manufacturer............. Samsung
Plug and Play ID......... SEC5044
Data string.............. GN36T€173HT [*CP437]
Manufacture date......... 2012, ISO week 1
EDID revision............ 1.4
Input signal type........ Digital (DisplayPort)
Color bit depth.......... 6 bits per primary color
Color encoding formats... RGB 4:4:4
Screen size.............. 380 x 210 mm (17,1 in)
Extension blocs.......... 1 (Reserved - 0x00)
Red chromaticity......... Rx 0,553 - Ry 0,318
Green chromaticity....... Gx 0,352 - Gy 0,586
Blue chromaticity........ Bx 0,165 - By 0,110
Native/preferred timing.. 1920x1080p at 60Hz (16:9)
Modeline............... "1920x1080" 146,870 1920 1968 2000 2140 1080 1083 1088 1144 +hsync -vsync
Report information
Date generated........... 10-5-2012
Raw data
00,FF,FF,FF,FF,FF,FF,00,4C,A3,44,50,00,00,00,00,01,16,01,04,95,26,15,78,02,A0,55,8D,51,5A,96,2A,
1C,50,54,00,00,00,01,01,01,01,01,01,01,01,01,01,01,01,01,01,01,01,5F,39,80,DC,70,38,40,40,30,20,
35,00,7E,D7,10,00,00,1B,00,00,00,0F,00,00,00,00,00,00,00,00,00,3C,96,10,FE,00,00,00,00,FE,00,47,
4E,33,36,54,80,31,37,33,48,54,0A,20,00,00,00,00,00,00,41,21,9E,00,00,00,00,02,01,0A,20,20,01,D1
  • GS88
  • Laatst online: 13-10 22:41
GS88
π raat
http://www.tftcentral.co.uk/articles/laptop_panel_parts.htm
Is er trouwens ook een link waar je kan selecteren op bv. kleurbereik of kijkhoek, en dat je ziet welke laptop welk scherm heeft? 't kan zijn dat ik iets over het hoofd zie op die website, maar op het moment zie ik het niet.
Rotterdam
In de Panel Search Database staan ook alle koppelingen van laptops en paneel en daar kan in beide richting op gezocht worden (welk paneel zit er in laptop X? / welke laptops bevatten paneel Y?).
Daar staan verder geen specificaties, die zal je in de Laptop Panel Part Database handmatig op moeten zoeken aan de hand van het paneeltypenummer.
  • lucjuh8
  • Laatst online: 20-08 23:34
kijk maar naar het volgende
[ Voor 76% gewijzigd door lucjuh8 op 20-05-2012 18:31 ]
  • lucjuh8
dit is van de nieuwe dv6 7000 serie, met 1080p scherm, kunnen jullie hier wijs uit over hoe goed het scherm is want ik kan hier niet zo veel mee doen eigenlijk, ik kan er ook niet echt uit opmaken of het IPS is of niet.
Afbeeldingslocatie: http://forum.notebookreview.com/attachments/hp-pavilion-notebooks/78131d1337530766-hp-dv6t-dv7t-7xxx-series-ivy-bridge-owners-lounge-screen.png
  • Dijksman
  • Laatst online: 09-09 23:48
Een andere HP 8760W: mat 1600x900
Monitor
Manufacturer............. Chi Mei
Plug and Play ID......... CMO1724
Manufacture date......... 2010, ISO week 40
Color encoding formats... RGB 4:4:4, YCrCb 4:4:4
Screen size.............. 380 x 220 mm (17,3 in)
Red chromaticity......... Rx 0,613 - Ry 0,344
Green chromaticity....... Gx 0,326 - Gy 0,590
Blue chromaticity........ Bx 0,160 - By 0,082
Modeline............... "1600x900" 107,800 1600 1648 1680 1940 900 903 908 926 +hsync -vsync
Detailed timing #1....... 1600x900p at 40Hz (16:9)
Modeline............... "1600x900" 71,860 1600 1648 1680 1940 900 903 908 926 +hsync -vsync
Report information
Date generated........... 22-6-2012
Data source.............. Real-time 0x0021
Raw data
00,FF,FF,FF,FF,FF,FF,00,0D,AF,24,17,00,00,00,00,28,14,01,04,90,26,16,78,0A,08,05,9D,58,53,97,29,
15,50,54,00,00,00,01,01,01,01,01,01,01,01,01,01,01,01,01,01,01,01,1C,2A,40,54,61,84,1A,30,30,20,
35,00,7E,D7,10,00,00,1A,12,1C,40,54,61,84,1A,30,30,20,35,00,7E,D7,10,00,00,1A,00,00,00,00,00,00,
00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,02,0C,42,FC,0C,3C,6E,1B,1B,32,6E,00,00,00,00,C8
PS. Ik heb bij een leverancier van lcd-panelen gevraagd naar part nummer (652521-001) voor het FHD paneel voor de 8760w om mijn notebook te upgraden naar 1080p. Zij leverden hiervoor de LP173WF1-TLB3, nu weet ik niet of HP dit paneel ook gebruikt maar het is goed mogelijk natuurlijk het zit in de Dell m6600.
  • Mafketel
  • Laatst online: 05-08 20:49
Ik weet het geen laptop scherm maar misschien weet jij er iets nuttigs mee te doen ;)
En terra 2430w 24" ips 1920x1200 scherm
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
Monitor
  Model name............... TERRA 2430W
  Manufacturer............. WOR
  Plug and Play ID......... WOR2430
  Serial number............ YT2012030742
  Manufacture date......... 2012, ISO week 9
  Screen size.............. 530 x 300 mm (24,0 in)
  Power management......... Standby, Suspend, Active off/sleep
  Red chromaticity......... Rx 0,636 - Ry 0,349
  Green chromaticity....... Gx 0,290 - Gy 0,584
  Blue chromaticity........ Bx 0,143 - By 0,080
  Native/preferred timing.. 1920x1200p at 60Hz (16:9)
    Modeline............... "1920x1200" 154,000 1920 1968 2000 2080 1200 1203 1209 1235 +hsync -vsync
  Detailed timing #1....... 1680x1050p at 60Hz (4:3)
    Modeline............... "1680x1050" 146,250 1680 1784 1960 2240 1050 1053 1059 1089 -hsync +vsync
     720 x  400p at  70Hz - IBM VGA
     640 x  480p at  60Hz - IBM VGA
     640 x  480p at  67Hz - Apple Mac II
     640 x  480p at  72Hz - VESA
     640 x  480p at  75Hz - VESA
     800 x  600p at  56Hz - VESA
     800 x  600p at  60Hz - VESA
     800 x  600p at  72Hz - VESA
     800 x  600p at  75Hz - VESA
    1024 x  768p at  60Hz - VESA
    1024 x  768p at  70Hz - VESA
    1024 x  768p at  75Hz - VESA
    1280 x 1024p at  61Hz - VESA STD
    1152 x  864p at  60Hz - VESA STD
    1280 x 1024p at  60Hz - VESA STD
    1280 x 1024p at  75Hz - VESA STD
    1440 x  900p at  60Hz - VESA STD
    1600 x 1200p at  60Hz - VESA STD
    1920 x 1080p at  60Hz - VESA STD
Report information
  Date generated........... 3-7-2012
  Software revision........ 2.60.0.964
  Data source.............. File
Raw data
  00,FF,FF,FF,FF,FF,FF,00,5D,F2,30,24,21,1D,9A,00,09,16,01,03,80,35,1E,78,EA,D6,A5,A2,59,4A,95,24,
  14,50,54,BF,CE,00,81,81,71,40,81,80,81,8F,95,00,A9,40,D1,C0,01,01,28,3C,80,A0,70,B0,23,40,30,20,
  36,00,70,CF,10,00,00,1A,00,00,00,FF,00,59,54,32,30,31,32,30,33,30,37,34,32,0A,21,39,90,30,62,1A,
  27,40,68,B0,36,00,55,00,11,00,00,1C,00,00,00,FC,00,54,45,52,52,41,20,32,34,33,30,57,0A,20,00,4E
8bit frc mat
gemeten met spyder3express in de srgb preset colorhcfr, primaire kleuren, groen(x0,304-y0,603-Y52,778) dead on srgb, blauw(x0,148-y0,074-Y24,988) en rood(x0,621-y0,333-Y52,778) missen wel een stukje tov srgb. Maar tov van de meeste schermen nog een redelijke srgb dekking.
Mocht je meer willen weten hoor ik het wel
  • Nikeo
  • Laatst online: 20:10
Nikeo
Jawelles
Ik heb via ebay een vervangend scherm gekocht voor een kapotte dell studio 1558. Moninfo van het vervangende paneel: (leverancier: power-lcd op ebay. Levertijd: 4 werkdagen. http://www.ebay.nl/itm/20..._trksid=p3984.m1497.l2649)
Monitor
Plug and Play ID......... CMO15A7
Data string.............. N156BGE-L21
Manufacture date......... 2010, ISO week 31
Screen size.............. 350 x 190 mm (15,7 in)
Red chromaticity......... Rx 0,617 - Ry 0,340
Green chromaticity....... Gx 0,320 - Gy 0,598
Blue chromaticity........ Bx 0,160 - By 0,084
Native/preferred timing.. 1366x768p at 60Hz (16:9)
Modeline............... "1366x768" 69,300 1366 1382 1416 1466 768 770 776 788 -hsync -vsync
Report information
Date generated........... 20-8-2012
Data source.............. Real-time 0x0011
Raw data
00,FF,FF,FF,FF,FF,FF,00,0D,AF,A7,15,00,00,00,00,1F,14,01,03,80,23,13,78,0A,00,25,9E,57,52,99,29,
15,50,54,00,00,00,01,01,01,01,01,01,01,01,01,01,01,01,01,01,01,01,12,1B,56,64,50,00,14,30,10,22,
26,00,58,C1,10,00,00,18,00,00,00,FE,00,4E,31,35,36,42,47,45,2D,4C,32,31,0A,20,00,00,00,FE,00,43,
4D,4F,0A,20,20,20,20,20,20,20,20,20,00,00,00,FE,00,4E,31,35,36,42,47,45,2D,4C,32,31,0A,20,00,95
  • ferdw
Asus UX31A R4003V
Afbeeldingslocatie: http://maniacsmedia.nl/imagehost/?dm=PGMO
Canon 7D ★ 200-400 ★ 70-200/2.8 II ★ 17-40 ★ 15-85 ★ 50/1.8
  • Nixy
  • Registratie: Oktober 2008
  • Laatst online: 03-08 15:38
Dell Inspiron 17R SE (7720) met mat scherm.
Ik zie alleen een "Registry-Active" Display ID staan, waarvoor hieronder de data:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
Monitor
  Manufacturer............. CMN
  Plug and Play ID......... CMN1720
  Data string.............. HDKPVƒ173HGE  [*CP437]
  Manufacture date......... 2011, ISO week 2
  Filter driver............ Monitor
  Red chromaticity......... Rx 0,640 - Ry 0,330
  Green chromaticity....... Gx 0,300 - Gy 0,610
  Blue chromaticity........ Bx 0,150 - By 0,060
    Modeline............... "1920x1080" 141,290 1920 1976 2014 2110 1080 1084 1090 1116 +hsync -vsync
Report information
  Date generated........... 1-9-2012
Raw data
  00,FF,FF,FF,FF,FF,FF,00,0D,AE,20,17,00,00,00,00,02,15,01,04,90,26,15,78,02,ED,95,A3,54,4C,9C,26,
  0F,50,54,00,00,00,01,01,01,01,01,01,01,01,01,01,01,01,01,01,01,01,31,37,80,BE,70,38,24,40,38,26,
  46,00,7E,D7,10,00,00,1A,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,FE,00,48,
  44,4B,50,56,83,31,37,33,48,47,45,0A,00,00,00,00,00,00,41,01,9E,00,00,00,00,02,01,0A,20,20,00,F0
Forums are like a herd of performing elephants with diarrhoea -- massive, difficult to redirect, awe-inspiring, entertaining, and a source of mind-boggling amounts of excrement when you least expect it.
Dat is de 'beruchte' chi-mei.
Ik ben er eindelijk achter welke panelen er in de sony's en asusjes zitten met 1080p IPS @ 15.6.
LP156WF4(SL)(B1) datasheet 250Cd/m CIE 57.36% NTSC
LP156WF4(SL)(B2) datasheet identiek aan B1 maar bevat een extra bracklet
LP156WF4(SL)(B3) 300Cd/m
B1 en B2 zijn AH-IPS en LVDS. Van B3 kan ik het datasheet niet vinden.
Er bestaat ook een SLBA: datasheet 250Cd/m gamut identiek aan B1.
De sony S1511 is B1 source
En het heilige IPS zonder orangegate scherm is..... LG LP156WF4-SLB6 aldus https://hackpad.com/Best-Panels-Wiki-D5UvkrtVvJ9. Nu nog een adres vinden waar ik die kan aanschaffen.....
[ Voor 29% gewijzigd door Verwijderd op 12-01-2013 20:33 ]
Onder het motto "ik wil een IPS scherm in mijn laptop, en wel een LP156WF4-SLB6"
Mijn laptop is een latitude E6520 met 15.6" paneel. Uit het datasheet heb ik de afmetingen van de SLB1 variant gehaald. De afmetingen van een standaard 15.6" paneel komen van een B156HW01 v0 datahseet.
De afmetingen van het paneel zijn vrijwel gelijk, op wat punten na: de IPS variant is voorzien van extra attributen aan de onderkant:
Afbeeldingslocatie: http://tweakers.net/ext/f/rxmjMZ5dbqLUHoyN0hyU3T70/full.png
De 'mounting assembly' met 2 schroefgaten zit er bij een standaard 15.6" paneel niet. Het PCB wat je op de afbeelding ziet is 10.83mm hoog en is ook net aanwezig op een standaard paneel.
Behalve dat obsakel is het paneel 2mm minder hoog. De ingang voor de kabel zit ook op een andere plek, maar dat is geen issue. Ten slotte is het paneel 2mm dunner. Dat levert wat problemen op: de mounting holes zijn afwezig. Dubbelzijdig tape to the resque?
Het 'extended PCB' zal voor de meeste laptops een probleem zijn. Maar voor mijn E6520 niet. Als ik de mounting assembly van het scherm af haal valt het PCB precies tussen de schanieren in. Als ik vervolgens met de slijptol :P enkele kabelgeleiders van mijn latitude af sloop past het scherm er in. In YouTube: Dell Latitude E6520 Laptop Screen Replacement Procedure @ 5:20 heb je prime uitzicht op de constructie daarvan.
Nu moet ik alleen nog aan zo'n paneel komen. Het enige aankoopadres wat ik tot nu toe heb kunnen vinden is http://www.screen-shop.net/LP156WF4-SLB6 plus wat vage chinese sites. Het gros verkoopt 'compatibele' panelen.
  • Mafketel
Ik ga er even vanuit dat het scherm niet in de vbezel vastzit maar in de deksel.
En dan zou ik eerder voor spacers gaan achter de mounting gaatjes zodat het scherm op de juiste plek komt.
En voor die 2 extra schroefgaten kun je natuurlijk ook een stukje extra materiaal in je deksel aanbrengen.
ik heb verder geen plaatsjes bekeken maar dit uit de losse duim gezogen ;)
[ Voor 11% gewijzigd door Mafketel op 19-01-2013 16:32 ]
Ik had bedacht dat ik hem met duct tape aan de hinges vast kon zetten.
Afbeeldingslocatie: http://i00.i.aliimg.com/wsphoto/v0/316941650/-font-b-Laptop-b-font-font-b-Hinges-b-font-for-font-b-Asus-b.jpg (iets ander model)
Aan de zijkant van het scherm zit nog een centimeter metaal, met een zorgvuldig op maat geknipt stukje tape kan ik hem denk ik wel daaraan bevestigen. Dat het paneel wat dunner is is makkelijk op te lossen door er wat karton achter te plakken.
de 'mounting assembly' op het IPS scherm zit precies op de plek waar het scharnier in mijn E6520 zit, en moet er dus sowieso af.
Het grootste struikelblok is uberhaubt aan het paneel komen voor een fatsoenlijke prijs. Het duitse screen-shop heeft-m, maar dat kost dan weer meer dan het dubbele van wat een 95% gamut TN paneel kost.
http://www.aliexpress.com...LED/715993_713908652.html heeft ze ook op de site staan sinds vandaag.
[ Voor 24% gewijzigd door Verwijderd op 19-01-2013 16:50 ]
  • Mafketel
op die video ziet het er naar uit dat dat extra frampje om je paneel in vast te zetten aan de onderkant de schroefgaten behoorlijk in de buurt zitten van de twee tabjes aan je gewilde scherm
aan de bovenkant lijk je meer problemen te hebben
[ Voor 11% gewijzigd door Mafketel op 19-01-2013 17:11 ]
In de buurt, ja. Precies op de goede plek, helaas niet. Het wijkt een paar mm af.
  • Mafketel
dan kan je de gaten veranderen in slotjes ;)
  • CaptJackSparrow
CaptJackSparrow
x07 - License to Tweak.
Ik zie aankomen dat je hier beter een separaat topic voor kunt openen. Zijn er trouwens niet gewoon laptops te koop met dat scherm of een ander 'acceptabel' scherm?
Mafketel schreef op zaterdag 19 januari 2013 @ 17:12:
Misschien. Volgens mij past het stuk metaal aan de zijkant dan niet meer, en ik heb het idee dat dat vrij cruciaal is voor de correcte verticale positionering.
CaptJackSparrow schreef op zaterdag 19 januari 2013 @ 17:15:
Het scherm wat er nu in zit is best acceptabel. Maar het kan altijd beter. De enige optie met een beter scherm onder de €2000 is de sony S15. Maar incl sheet batterij betaal ik dan minstens 3x zoveel als ik voor mijn latitude heb betaald.
In de Vizio ct15-a2 zit een LP156WF4 SLB5:
source: http://forum.ixbt.com/topic.cgi?id=17:17899-46
google translate:
P.S. Not a professional, but I think red is red, not carrot (as complained by a similar model number LP156WF4-SLB1). Sample for comparison, unfortunately, no.
Wat dus ook een optie om te kopen is. Er is ook een chinees die SLB7 verkoopt. Bv. http://www.alibaba.com/pr..._Laptop_notebook_LCD.html http://www.alibaba.com/pr...creen_LP156WF4_SL_B5.html. Ziet er niet extreem betrouwbaar uit, tijd om er eens een mailtje aan te wagen.
Edit: SLB5 review: http://www.anandtech.com/...-something-new-and-edgy/3
[ Voor 7% gewijzigd door Verwijderd op 14-02-2013 22:11 ]
  • Quad
  • Laatst online: 00:13
Quad
Doof
Misschien niet onbelangrijk, maar een Medion P6631 notebook met volgende eigenschappen monitor:
Scherm is een 768p (helaas :() en mat.
Afbeeldingslocatie: http://i.imgur.com/nmPxrP2.jpg
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
Monitor
  Windows description...... Algemeen PnP-beeldscherm
  Manufacturer............. AUO
  Plug and Play ID......... AUO23EC
  Data string.............. B156XW02 V3
  Manufacture date......... 2009, ISO week 1
  Screen size.............. 340 x 190 mm (15,3 in)
  Red chromaticity......... Rx 0,620 - Ry 0,340
  Green chromaticity....... Gx 0,330 - Gy 0,570
    Modeline............... "1366x768" 69,300 1366 1398 1422 1432 768 771 775 806 -hsync -vsync
Report information
  Date generated........... 28-3-2013
  Operating system......... 6.2.9200.2
Raw data
  00,FF,FF,FF,FF,FF,FF,00,06,AF,EC,23,00,00,00,00,01,13,01,03,80,22,13,78,0A,C8,95,9E,57,54,92,26,
  0F,50,54,00,00,00,01,01,01,01,01,01,01,01,01,01,01,01,01,01,01,01,12,1B,56,42,50,00,26,30,20,18,
  34,00,58,C1,10,00,00,18,00,00,00,0F,00,00,00,00,00,00,00,00,00,00,00,00,00,20,00,00,00,FE,00,41,
  55,4F,0A,20,20,20,20,20,20,20,20,20,00,00,00,FE,00,42,31,35,36,58,57,30,32,20,56,33,20,0A,00,BE
Alles went behalve een Twent.
nggyu nglyd
In tegenstelling tot wat ik eerder melde lijkt de vizio geen SLB5 te bevatten. Anandtech heeft namelijk deze review:
http://www.anandtech.com/...o-w550eu-ultrabook-review
met de SLB5 en sub-50 color gamut.
Afbeeldingslocatie: http://images.anandtech.com/graphs/graph6969/54727.png
Terwijl de vizio 56% gamut haalt. Aan de andere kant zijn er ook (niet-professionele) bronnen die melden dat de vizio SLB5 bevat. Vaag verhaal.
  • martijn_tje
  • Laatst online: 09-09 18:45
Had je al een uitdraai van een Dell Inspiron R SE met 1080p mat scherm?
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
Monitor
  Plug and Play ID......... AUO21ED
  Data string.............. 35K06€B156HW2  [*CP437]
  Manufacture date......... 2011, ISO week 4
  Red chromaticity......... Rx 0,620 - Ry 0,350
  Green chromaticity....... Gx 0,320 - Gy 0,600
  Blue chromaticity........ Bx 0,150 - By 0,120
    Modeline............... "1920x1080" 148,000 1920 2020 2040 2186 1080 1090 1100 1128 +hsync -vsync
  Detailed timing #1....... 1920x1080p at 40Hz
    Modeline............... "1920x1080" 98,670 1920 2020 2040 2186 1080 1090 1100 1128 +hsync -vsync
Report information
  Date generated........... 25-5-2013
  Operating system......... 6.0.6000.2
Raw data
  00,FF,FF,FF,FF,FF,FF,00,06,AF,ED,21,00,00,00,00,04,15,01,04,90,22,13,78,02,E2,B5,9E,59,52,99,26,
  1E,50,54,00,00,00,01,01,01,01,01,01,01,01,01,01,01,01,01,01,01,01,D0,39,80,0A,71,38,30,40,64,14,
  AA,00,58,C2,10,00,00,1A,8B,26,80,0A,71,38,30,40,64,14,AA,00,58,C2,10,00,00,1A,00,00,00,FE,00,33,
  35,4B,30,36,80,42,31,35,36,48,57,32,00,00,00,00,00,00,41,21,9E,00,00,00,00,02,01,0A,20,20,00,16
Sony A6600 + Sigma 16 f/1.4, Tamron 17-70 f/2.8, Sigma 30 f/1.4, Sigma 56 f/1.4, Tamron 70-180 f/2.8 en Meike Mk320
Die hebben we al, ja. In het inspiron topic staat daar enige discussie over (met name gezeur van mij dat het scherm zoveel slechter is dan in de voorganger).
Tegenwoordig heeft laptopscreen de LP156WF4 sl b6 in de shop staan:
https://www.laptopscreen....LP156WF4%28SL%29%28B6%29/
Ik meen dat dat een reputabele seller is. De prijs is ook prima te doen. Ik zal er binnenkort een mailtje aan wagen.
  • mrc4nl
mrc4nl
Verwijderd schreef op zaterdag 12 januari 2013 @ 17:45:
die 15.4 is ook wel tof:
Samsung LSN154YL01-001
Retina Macbook Pro 15
2880x1800
30 pin connector, eDP
ik gok alleen dat edp voor display poort staat, en dat gaat m niet worden in mn acertje
Afbeeldingslocatie: http://cdn.alltheragefaces.com/img/faces/png/okay-okay.png
ora et labora
  • TheByteBoy
  • Laatst online: 24-10 15:05
Dell Latitude E6540, 1920x1080, mat
Uitdraai van Registry Active, aangezien Real-time ontbreekt in de lijst met Display IDs in Monitor Asset Manager.
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
Monitor
  Windows description...... Generic Monitor
  Plug and Play ID......... CMN15BA
  Data string.............. 9FN4Y€156HGE  [*CP437]
  Manufacture date......... 2012, ISO week 29
  Red chromaticity......... Rx 0,618 - Ry 0,340
  Green chromaticity....... Gx 0,341 - Gy 0,580
  Blue chromaticity........ Bx 0,152 - By 0,081
    Modeline............... "1920x1080" 152,540 1920 2010 2070 2226 1080 1086 1095 1142 +hsync -vsync
    Modeline............... "1920x1080" 101,690 1920 2010 2070 2226 1080 1086 1095 1142 +hsync -vsync
Report information
  Date generated........... 26-7-2013
  Software revision........ 2.70.0.989
Raw data
  00,FF,FF,FF,FF,FF,FF,00,0D,AE,BA,15,00,00,00,00,1D,16,01,04,90,22,13,78,02,46,35,9E,57,57,94,27,
  14,50,54,00,00,00,01,01,01,01,01,01,01,01,01,01,01,01,01,01,01,01,96,3B,80,32,71,38,3E,40,5A,3C,
  69,00,58,C2,10,00,00,1A,B9,27,80,32,71,38,3E,40,5A,3C,69,00,58,C2,10,00,00,1A,00,00,00,FE,00,39,
  46,4E,34,59,80,31,35,36,48,47,45,0A,00,00,00,00,00,00,41,31,9E,00,10,00,00,02,01,0A,20,20,00,13
  • mrc4nl
mrc4nl
hier de gegevens uit een HP elitebook 8540w (mat scherm)‏
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
Monitor
  Plug and Play ID......... AUO01EE
  Data string.............. B156RW01 V1
  Manufacture date......... 2008, ISO week 1
  Red chromaticity......... Rx 0,628 - Ry 0,350
  Green chromaticity....... Gx 0,341 - Gy 0,570
  Blue chromaticity........ Bx 0,151 - By 0,053
    Modeline............... "1600x900" 107,800 1600 1664 1706 1970 900 903 906 912 -hsync -vsync
Report information
  Date generated........... 2-10-2013
Raw data
  00,FF,FF,FF,FF,FF,FF,00,06,AF,EE,01,00,00,00,00,01,12,01,03,80,22,13,78,0A,E4,E5,A0,59,57,92,26,
  0D,50,54,00,00,00,01,01,01,01,01,01,01,01,01,01,01,01,01,01,01,01,1C,2A,40,72,61,84,0C,30,40,2A,
  33,00,58,C1,10,00,00,18,00,00,00,0F,00,00,00,00,00,00,00,00,00,00,00,00,00,20,00,00,00,FE,00,41,
  55,4F,0A,20,20,20,20,20,20,20,20,20,00,00,00,FE,00,42,31,35,36,52,57,30,31,20,56,31,20,0A,00,98
binnenkort hoop ik nog een panel te kunnen posten.
trouwens word er ook echt iets met deze gegevens gedaan of ligt het werk stil?
ora et labora
  • tc982
  • Laatst online: 18:04
Ik zal dan ook nog eens meedoen, sinds mijn MacBook het heeft opgegeven, heb ik nu een Dell XPS 15 glanzend scherm :
Afbeeldingslocatie: http://tweakers.net/ext/f/OPUgTFuphMKc7P8ys5uTTv8U/full.jpg
Computers make very fast, very accurate mistakes.
  • biobak
  • Registratie: Augustus 1999
  • Laatst online: 17:20
Alienware 17 met 120 Hz scherm (glossy)
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
Monitor
Report information
  Date generated........... 3-10-2013
Raw data
iemand een review over dit panel?
zit in een acer v5-573G
Afbeeldingslocatie: http://www.imgdumper.nl/uploads7/528780ae4a028/528780ae44e21-Naamloos.png
ik vind het op het zicht een heeeeeel mooi scherm
Yup: http://anandtech.com/show...eview-something-different
Dat is het beste scherm wat je kan krijgen op dit moment.
biobak schreef op donderdag 03 oktober 2013 @ 20:10:
zelfde panel als dat ik heb in mijn alienware.
erg helder / mooi scherm, redelijk kleurecht..
gewoon een goed panel
dat zal best... k ben echt diep onder de indruk !!
zit in deze laptop to be exac:
pricewatch: Acer Aspire V5-573G-54208G50aii
erg fijn ding !!
Gisteren weer eens dit topic bekeken na al bijna drie jaar niet meer de startpost te hebben geupdate en ruim anderhalf jaar niet in het topic gepost te hebben. Zag redelijk wat nieuwe paneeltypenummers voorbij komen en heb zodoende ook weer een aantal datasheets toe weten te voegen aan m'n collectie.
Nu maar weer eens de startpost updaten! :) Heb om te beginnen alvast even de nieuwste versie van Monitor Asset Manager er in gezet en een nieuwe vanaf datum voor de laptops. Het leek mij niet echt meer relevant om nog logjes te krijgen van laptops uit 2008, dus heb de vanaf nu op augustus 2012 gezet.
Ga denk ik dan ook gelijk maar wat doen aan de opmaak, zodat het er wat netter uit ziet, zoals bijvoorbeeld [TFT] Dell UltraSharp Serie - Deel 19, want het is nou nogal een puinhoop.
EDIT: ik heb de startpost opgeruimd en grotendeels herschreven. Verder heb ik de tabel geupdate tot en met Appelsap in "[Oproep] Monitor Asset Manager-logs voor paneel-DB laptops". De rest kom morgen wel.
EDIT 2: startpost nu up to date t/m FreezeXJ in "[Oproep] Monitor Asset Manager-logs voor paneel-DB laptops".
EDIT 3: met enig gepuzzel ook de opmaak van de tabel zo weten aan te passen dat de rijhoogte waar mogelijk maar één regel is. Ziet er nu in ieder geval in FF26 en IE11 goed uit.
EDIT 4: startpost nu up to date t/m CLB in "[Oproep] Monitor Asset Manager-logs voor paneel-DB laptops"
EDIT 5: startpost is weer volledig up to date! :)
EDIT 6 (20-1): heb gisteravond ook even de Panel Search Database en de 17.0-17.3" pagina van de Laptop Panel Part Database geupdate. Krijg net mailtje van Simon dat Laptop PPD update inmiddels ook live is op de site, PSD moet nog. De pagina's voor de 10.0-16.4" panelen van de Laptop PPD moet ik nog updaten. Zal proberen om dat zoveel mogelijk vandaag af te krijgen.
EDIT 7 (21-1): gisteren heb ik de 15.0-16.4" pagina van de Laptop PPD een gigantische update gegeven. Die is nu ook online en de PSD is inmiddels ook weer helemaal bijgewerkt. De 10.1-13.3" en 14.0-14.5" pagina's moet ik nog updaten, maar er gaat gigantisch veel tijd in zitten.
[ Voor 52% gewijzigd door Kid Jansen op 21-01-2014 11:38 ]
Ik heb de 10.1-13.3" pagina van de Laptop Panel Part Database opgesplitst in drie nieuwe pagina's:
  • 10.0-11.6"
  • 12.1-12.5"
  • 13.0-13.4"
De 10.0-11.6" pagina heb ik inmiddels af en naar Simon gestuurd om hem online te zetten. Die pagina is nu al bijna twee keer zo lang als de oorspronkelijke 10.1-13.3" pagina, de andere twee pagina's worden nog langer. Er staan straks dus een hele berg nieuwe panelen in de LPPD, probleem is nu alleen nog uitvinden in welke laptops ze gebruikt worden.
Blijf dus alsjeblieft logs posten van jullie laptops (zie startpost voor methode), zodat we deze koppeling kunnen blijven maken.
[ Voor 99% gewijzigd door Verwijderd op 08-06-2017 21:52 ]
Heb jammer genoeg geen idee welke paneelfabrikant dat zou moeten zijn. Kon op basis van het Plug & Play ID ook niks nuttigs vinden en de Data string voegt hier ook weinig toe (stuk voor tot en met €-teken is onzin en de rest is maar deel van typenummer).
Van de gangbare fabrikanten heeft alleen Samsung panelen met "HL" in het typenummer op die plaats (na de drie cijfers die beeldschermdiagonaal in tiende inches geven), maar dat is bij desktoppanelen, niet laptoppanelen. Daarnaast maakt Samsung geen IPS panelen en Samsung heeft de afkorting "SEC" als fabrikantcode in EDID's.
Het kleurbereik op basis van dit EDID is overigens vrijwel gelijk aan sRGB, wat vrij gebruikelijk is voor zo'n scherm.
NTSC relatieve grootte: 70,0%
sRGB dekking: 96,7%
Adobe RGB dekking: 73,1%
[ Voor 98% gewijzigd door Verwijderd op 08-06-2017 21:53 . Reden: Het is Samsung Display Corporation, niet Digital Corporation ]
Toch Samsung dus. Ik had gezocht op LTN108HL0x en LTN108HLx met x 1 t/m 9, allemaal 0 hits met Google. Kan op Panelook.com ook geen panelen vinden van 10,8" (en omliggende maten) met een resolutie van 1920x1080.
Zou nog eens kunnen proberen op LTN108HL1x, LTN108HL2x en LTN108HL3x, misschien dat ik dan wel wat vind. Overigens moeten die laatste twee panelen die je noemt dan LTN156AT29-401 en LTN156AT29-L01 zijn. Alle panelen voor mobiele apparaten van Samsung beginnen namelijk met LTN, desktoppanelen met LTM.
EDIT: ook allemaal niks
[ Voor 100% gewijzigd door Verwijderd op 08-06-2017 21:53 ]
  • mrc4nl
mrc4nl
paneel uit mijn asus N56VZ , 1080P, mat.
29
30
31
32
33
34
35
36
37
38
39
40
41
42
  Plug and Play ID......... SEC314C
  Data string.............. 156HT01-201
  Manufacture date......... 2011, ISO week 0
  Red chromaticity......... Rx 0,613 - Ry 0,361
  Green chromaticity....... Gx 0,308 - Gy 0,603
  Blue chromaticity........ Bx 0,155 - By 0,104
    Modeline............... "1920x1080" 138,650 1920 1944 1960 2080 1080 1082 1087 1111 -hsync -vsync
Report information
  Date generated........... 4-6-2014
  Software revision........ 2.90.0.1000
ora et labora
Zelfde zo te zien als Asus X5QSF en N53VZ die al in de startpost staan.
  • Ravefiend
  • Laatst online: 22-10 19:13
Ravefiend
Carpe diem!
Details van een Dell Latitude E7440 laptop (build eind april 2014) met op de order het scherm omschreven als:
391-BBFB 14.0 FHD (1920x1080) Wide View Anti-Glare WLED-backlit
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
Monitor
  Plug and Play ID......... AUO113D
  Data string.............. XTRY9€B140HAN  [*CP437]
  Manufacture date......... 2013, ISO week 17
  Screen size.............. 310 x 170 mm (13.9 in)
  Red chromaticity......... Rx 0.643 - Ry 0.336
  Green chromaticity....... Gx 0.313 - Gy 0.620
  Blue chromaticity........ Bx 0.151 - By 0.053
    Modeline............... "1920x1080" 141.000 1920 1936 1952 2104 1080 1083 1097 1116 +hsync -vsync
  Detailed timing #1....... 1920x1080p at 60Hz
Report information
  Date generated........... 6/24/2014
Raw data
  00,FF,FF,FF,FF,FF,FF,00,06,AF,3D,11,00,00,00,00,11,17,01,04,95,1F,11,78,02,87,E5,A4,56,50,9E,26,
  0D,50,54,00,00,00,01,01,01,01,01,01,01,01,01,01,01,01,01,01,01,01,14,37,80,B8,70,38,24,40,10,10,
  3E,00,35,AD,10,00,00,1A,14,37,80,B8,70,38,24,40,10,10,3E,00,35,AD,10,00,00,1A,00,00,00,FE,00,58,
  54,52,59,39,80,42,31,34,30,48,41,4E,00,00,00,00,00,00,41,02,9E,00,00,00,00,0A,01,0A,20,20,00,78
Ravefiend schreef op dinsdag 24 juni 2014 @ 15:55:
Heeft een tijd geduurd, maar zag net dat er eindelijk een fatsoenlijke versie van het paneeldatasheet op Panelook.com stond, dus meteen even gedownload. Normaal download ik niet zo snel datasheets daar, omdat het 30 P-coins per datasheet kost en die erg lastig te krijgen zijn, maar dit vond ik wel een interessant paneel.
AU Optronics B140HAN01.1 HW3A:
  • Advanced Hyper Viewing Angle (AHVA) paneeltechnologie (vergelijkbaar met IPS)
  • 1920x1080 resolutie
  • 700:1 contrast
  • eDP 1.3 interface
  • 6bit+FRC kleurdiepte
  • 300 cd/m² maximale helderheid van wit
  • 178°/178° kijkhoeken (H/V)
  • Kleurbereik:
    • 74,0% NTSC relatieve grootte
    • 96,8% sRGB dekking
    • 75,0% Adobe RGB dekking
Moet zeggen dat het een erg leuk scherm is voor een laptop
De laatste reactie hier is alweer een half jaar geleden, maar ik ben nog steeds geïnteresseerd in nieuwe logs. Mocht je dus een laptop hebben die hooguit zo'n anderhalf jaar oud, dan zie ik hier graag een logje terug.
Hoe je een bijdragen kan leveren aan dit topic wordt uitgelegd in de startpost in het onderdeel Hoe?
Het meest geïnteresseerd ben ik in laptops met een bovengemiddeld scherm:
  • IPS of vergelijkbaar (LG Display AH-IPS, Samsung PLS, AU Optronics AHVA)
  • varianten van VA, zoals AU Optronics AMVA
  • hoge resoluties, zoals 4K op 15.6"
  • hoge refresh rates
  • groot kleurbereik
  • Jaap-Jan
  • Laatst online: 20:26
Toshiba Satellite S50-B-15N.
Glossy 1920x1080 scherm, aan de kijkhoeken te beoordelen (en op internet zoeken, maar de informatie is schaars) een IPS- paneel.
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
Monitor
  Plug and Play ID......... LGD0470
  Data string.............. LP156WF6-SPA1
  Manufacture date......... 2014, ISO week 0
  Red chromaticity......... Rx 0.640 - Ry 0.345
  Green chromaticity....... Gx 0.335 - Gy 0.625
  Blue chromaticity........ Bx 0.150 - By 0.052
    Modeline............... "1920x1080" 138.700 1920 1968 2000 2080 1080 1083 1088 1111 +hsync -vsync
Report information
  Date generated........... 25/02/2015
Raw data
  00,FF,FF,FF,FF,FF,FF,00,30,E4,70,04,00,00,00,00,00,18,01,04,95,23,13,78,EA,DC,95,A3,58,55,A0,26,
  0D,50,54,00,00,00,01,01,01,01,01,01,01,01,01,01,01,01,01,01,01,01,2E,36,80,A0,70,38,1F,40,30,20,
  35,00,59,C2,10,00,00,1A,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,FE,00,4C,
  47,20,44,69,73,70,6C,61,79,0A,20,20,00,00,00,FE,00,4C,50,31,35,36,57,46,36,2D,53,50,41,31,00,7B
| Last.fm | "Mr Bent liked counting. You could trust numbers, except perhaps for pi, but he was working on that in his spare time and it was bound to give in sooner or later." -Terry Pratchett
Dat paneel kende ik nog niet. Moet ook een erg nieuw paneel zijn, want de LP156WF5 panelen zijn er ook nog niet zo lang. Ik heb geen idee wat de specs zijn anders dan wat er in dit logje staat, want ik kan jammer genoeg niet de datasheet vinden voor dit paneel.
Het kleurbereik is overigens 72% NTSC, met 91% sRGB dekking en 70% Adobe RGB dekking. Zowel de groene als de rode primair hebben niet echt een diepe tint, maar ze zijn wel allebei erg verzadigd voor een laptopscherm. Het is een beetje jammer dat laptopschermen vrijwel altijd maar 6 bit kleurdiepte per kanaal hebben, ook de IPS schermen, maar verder ziet het er uit als een leuk scherm.
  • Henkie-Jan
  • Laatst online: 14-10 12:34
Het scherm in mijn Vostro 3360. Sinds kort een andere overgezet uit een andere Vostro:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
Monitor
  Plug and Play ID......... AUO312C
  Data string.............. 9D0GV€B133XW3  [*CP437]
  Manufacture date......... 2012, ISO week 0
  Screen size.............. 290 x 160 mm (13,0 in)
  Red chromaticity......... Rx 0,590 - Ry 0,345
  Green chromaticity....... Gx 0,325 - Gy 0,540
  Blue chromaticity........ Bx 0,150 - By 0,145
    Modeline............... "1366x768" 76,600 1366 1414 1446 1598 768 771 777 798 +hsync -vsync
  Detailed timing #1....... 1366x768p at 40Hz
    Modeline............... "1366x768" 51,070 1366 1414 1446 1598 768 771 777 798 +hsync -vsync
Report information
  Date generated........... 9-8-2015
Dit scherm zat in mijn Vostro 3360:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
onitor
  Plug and Play ID......... SEC5441
  Data string.............. X08X4€133AT  [*CP437]
  Red chromaticity......... Rx 0,610 - Ry 0,340
  Green chromaticity....... Gx 0,330 - Gy 0,550
  Blue chromaticity........ Bx 0,155 - By 0,090
    Modeline............... "1366x768" 70,900 1366 1414 1446 1496 768 773 778 790 +hsync -vsync
  Detailed timing #1....... 1366x768p at 40Hz (16:9)
    Modeline............... "1366x768" 50,750 1366 1414 1446 1586 768 773 778 800 +hsync -vsync
Report information
Zonnepanelen: 800Wp op oost 80 graden aan balkon met schaduw
  • Henkie-Jan
Inmiddels weer een nieuw scherm in de laptop gekomen. Wat gesneuveld.... Nieuw gekocht maar gemaakt in 2011? Ik heb het idee dat het scherm stukken scherper is. Nog steeds de Dell Vostro 3360...
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
Monitor
    Modeline............... "1366x768" 76,300 1366 1404 1426 1592 768 771 777 798 -hsync -vsync
    Modeline............... "1366x768" 50,870 1366 1404 1426 1592 768 771 777 798 -hsync -vsync
Report information
  Date generated........... 23-8-2016
  Software revision........ 2.90.0.1020
  Operating system......... 10.0.10586.2
Raw data
  00,FF,FF,FF,FF,FF,FF,00,06,AF,2C,31,00,00,00,00,00,15,01,04,90,1D,10,78,02,15,85,97,58,53,8A,26,
  25,50,54,00,00,00,01,01,01,01,01,01,01,01,01,01,01,01,01,01,01,01,CE,1D,56,E2,50,00,1E,30,26,16,
  36,00,25,A4,10,00,00,18,DF,13,56,E2,50,00,1E,30,26,16,36,00,25,A4,10,00,00,18,00,00,00,00,00,00,
  00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,02,00,0C,48,FF,0A,3C,64,0F,0F,1A,64,20,20,20,00,F4
  • Priyantha Bleeker
  • Laatst online: 23-10 18:57
Priyantha Bleeker
Out and proud \o/ :D \o/
Ik heb sinds kort van mijn werkgever een nieuwe laptop gekregen, een pricewatch: Lenovo IdeaPad 700-15ISK 80RU008RMH
Daar zit blijkbaar een scherm in van de Chinese fabrikant BOE van het type NV156FHM-N42 wat iig volgens de specificaties vanuit Lenovo een IPS paneel is. Kijkhoeken zijn dan ook best redelijk :-)
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
Monitor
  Manufacturer............. BOE
  Plug and Play ID......... BOE065D
  Data string.............. NV156FHM-N42
  Manufacture date......... 2015, ISO week 1
  Red chromaticity......... Rx 0,590 - Ry 0,350
  Green chromaticity....... Gx 0,329 - Gy 0,555
  Blue chromaticity........ Bx 0,152 - By 0,118
  White point (default).... Wx 0,313 - Wy 0,328
    Modeline............... "1920x1080" 141,400 1920 1968 2000 2142 1080 1083 1089 1100 +hsync -vsync
Report information
  Date generated........... 4-12-2016
  Operating system......... 10.0.14971.2
Raw data
  00,FF,FF,FF,FF,FF,FF,00,09,E5,5D,06,00,00,00,00,01,19,01,04,95,22,13,78,02,24,10,97,59,54,8E,27,
  1E,50,54,00,00,00,01,01,01,01,01,01,01,01,01,01,01,01,01,01,01,01,3C,37,80,DE,70,38,14,40,30,20,
  36,00,58,C2,10,00,00,1A,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,FE,00,42,
  4F,45,20,48,46,0A,20,20,20,20,20,20,00,00,00,FE,00,4E,56,31,35,36,46,48,4D,2D,4E,34,32,0A,00,6C
  • aap
  • Laatst online: 23-10 17:03
aap
Dell XPS13 met mat Full HD scherm.
Kloppen die manufacture dates i.h.a.? In mijn geval zou het paneel meer dan een jaar op voorraad gelegen moeten hebben.
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
Monitor
  Manufacturer............. Sharp
  Plug and Play ID......... SHP1449
  Data string.............. DJCP6€LQ133M1  [*CP437]
  Manufacture date......... 2015, ISO week 32
  Color bit depth.......... 8 bits per primary color
  Screen size.............. 290 x 170 mm (13,2 in)
  Default color space...... sRGB
  Red chromaticity......... Rx 0,640 - Ry 0,329
  Green chromaticity....... Gx 0,300 - Gy 0,600
  Blue chromaticity........ Bx 0,149 - By 0,060
    Modeline............... "1920x1080" 138,500 1920 1968 2000 2080 1080 1083 1088 1111 -hsync -vsync
Report information
  Operating system......... 10.0.14393.2
Raw data
  00,FF,FF,FF,FF,FF,FF,00,4D,10,49,14,00,00,00,00,20,19,01,04,A5,1D,11,78,0E,DE,50,A3,54,4C,99,26,
  0F,50,54,00,00,00,01,01,01,01,01,01,01,01,01,01,01,01,01,01,01,01,1A,36,80,A0,70,38,1F,40,30,20,
  35,00,26,A5,10,00,00,18,00,00,00,10,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,FE,00,44,
  4A,43,50,36,80,4C,51,31,33,33,4D,31,00,00,00,00,00,02,41,03,28,00,12,00,00,0B,01,0A,20,20,00,66
Pagina: 1 ... 5 6 Laatste
