[Algemeen] nVidia Nieuwdiscussie Topic - Deel 50 Vorige deel Overzicht Volgende deel Laatste deel
Pagina: 1 ... 5 6 Laatste
  • 32.839 views
  • Noel
  • Laatst online: 15:56
279$ staat hierboven ergens. Duurder, maar ook sneller.
Server: Xeon X3430 21TB RAID 5 | Game: 5900X, 6900XT, dual FS2735 | Mobile: Lenovo X1 Carbon, Thinkpad T440s, Moto G7 Plus
  • pino85
  • Laatst online: 16-11 17:29
pino85
Im just a Bird in the Sky
Whats next de 560 GT?
Liefhebber van Tweakers
  • Snoitkever
  • Laatst online: 09-11 21:20
Snoitkever
Volgens mij gelijke prijzen met de huidige 470 (en dus ook gelijke of iets betere perf.)
  • spNk
  • Laatst online: 13-11 15:49
Several early benchmarks of Nvidia’s upcoming GTX 560 Ti board were posted at the chiphell.com discussion board and the results look quite promising.
According to the figures, the 560 managed to outperform the old 460 by about 25 percent and the same goes for AMD’s HD 6870. Surprisingly, the 560 is very close to the Cayman based HD 6950, at least in 3Dmark.
The card scores P4118 in 3Dmark 11, while the Vantage score stands at P20644. As expected, the GTX 560 Ti ended up with 384 shaders, 32 ROPs, 1024MB of GDDR5 memory and a 256-bit bus with a total memory bandwidth of 128.3GB/s. The default GPU clock appears to be 823MHz, while the shaders and memory ended up at 1645MHz and 1002MHz respectively. This is quite a bit faster than the GTX 460, although some factory overclocked GTX 460 boards ended up at 850MHz.
Mind you, the results should be taken with a grain of salt, but nonetheless the GTX 560 appears to deliver impressive performance. It should be able to match AMD’s HD 6950, so at this point it all comes down to the price. The GTX 560 should launch later this month and January 25 is being tossed around as the launch date.
Aldus Fudzilla.
  • naaitsab
  • Laatst online: 17:03
Marc Rademaker schreef op woensdag 12 januari 2011 @ 13:56:
Ehm lol? nieuws: CES: Asus toont HD 6970 met speciale koeler en 6 video-uitgangen
Zelfde koeler, 2x dvi, 4x displayport, allemaal bruikbaar, daar kan de GTX 580 niet tegenop :P
Ja want iedereen heeft 6 monitoren thuis staan hé :9
2x Dvi en hdmi is zat, wil je dan toch een of andere exotische setup pak dan zon eyefinity kaart.
Die koeler is echt leip, als je dan toch 3 slots gaat gebruiken kun je zowat wel een mini waterkoeler monteren(ala h50-h70 idee) Lijkt me niet dat dat ding verkoopt, je bent gelijk 3 en qua ligging soms 4 slots kwijt voor 1 kaart :/ Muis stil zou 1 voordeel kunnen zijn maar dat is afwachten.
if (!coffee) {
Work = false; }
Pykow schreef op donderdag 13 januari 2011 @ 11:07:
Wat gaat de prijs worden van de GTX 560 ? 200 euro of veel meer ?
nVidia zet het als vervanger van de GTX470 neer, prestaties en prijs zitten dan ook op ongeveer hetzelfde niveau.
  • Deathchant
  • Laatst online: 16-11 20:07
Deathchant
Don't intend. Do!
hmmm 25 januari de launch....dan vraag ik me af wanneer de 2nd release komt, met de eigen cooling designs e.d. Ik vind die toch altijd wel meerwaarde hebben, vooral vanwege de pre-overklok en de goeie coolingsolutions. Ik was zo gebrand op de Gigabyte GTX460 SOC, maar ik kan beter wachten ;)
  • naaitsab
Deathchant schreef op donderdag 13 januari 2011 @ 13:20:
Zeker, stond ook op het punt om de GB 460 te kopen nu maar eventjes wachten dan, buiten het feit dat ik ook nog mn mobo+cpu+ram ga vervangen is het budget er ook ff doorheen :+
Hopelijk komt die koeler van de pricewatch: Gigabyte GV-N460OC-1GI ook op de 560, is een erg stille en goed presterende koeler :) al weet ik niet of die vapor-chamber techniek van de 580 hier ook toegepast moet worden ivm temperatuur maar dat is afwachten.
if (!coffee) {
Work = false; }
  • Deathchant
Deathchant
Don't intend. Do!
Ik zit in hetzelfde schuitje, Vanaf augustus ben ik al een nieuwe pc aan het kopen. het enige wat ik heb is de megahalems shadow, de lianli A77FB case, PT-FN04 fancontroller van Lianli en de ZM-F3BL zalman fans voor de megahalems.
Ik hoop de koeler van de SOC of een mooie GoldenSample van Gainward. Maar ja, de laatste tijd stellen ze me wat teleur, zeker wat betreft de gtx460. Daarom viel mijn oog op de SOC van Gigabyte.
En hoe koeler hoe beter. Of dat nou vapor chamber of heatpipes zijn, of een combinatie. I don't care :)
Hopelijk gaan ze nu niet weer zo moeilijk doen met VRM koeling enzo...pffff
Of Nvidia standaard een Vapor kamer op de GTX560 plaats is maar zeer de vraag, ik denk het namelijk niet. Als de temps met een goedekopere koeling laag genoeg zijn zullen ze die vapor kamer zeker achterwege laten zodat ze de productiekosten zo laag mogelijk kunnen houden.
@Deathchant; Op een gegeven moment moet je gewoon knopen doorhakken anders zit je over 3 jaar nog zonder nieuwe videokaart... ;)
Zou natuurlijk wel mooi zijn om met reference koeling flinke overclocks te draaien :P.
Maar ik denk dat het meer richting de gtx460 koeler zal gaan.
Afbeeldingslocatie: http://tweakers.net/ext/f/bYHxHbuxHubtbmNKCtXlKJbN/full.jpg
  • Cheetah
  • Laatst online: 29-07 17:48
Cheetah
Try to live without WWW ;)
Volgens nV ~30% sneller dan de GTX460 dus...
Binnenkort tijd om op zoek te gaan naar een leuk 2e hands 460je voor SLI :P
ASUS Max IV GENE-Z, Core i7 3770k, 16GB Kingston HyperX DDR3-1600, EVGA GTX970 FTW
Crucial M550 512GB SSD, 2TB WD HDD, LG GGW-H20L Blu/HD, Panasonic 40" AX630 UHD
Full Specz
  • Deathchant
Deathchant
Don't intend. Do!
Verwijderd schreef op donderdag 13 januari 2011 @ 16:19:
Ow, het is geen kwestie van geen knopen doorhakken hoor ;) ik heb tijd ZAT. Het geld blijft lekker op de bank staan, dus....Het probleem was dat het geheugen dat ik voor X58 wilde nog niet leverbaar was en dat ik nog niet zeker was van het moederbord. Maar dat hoeft nu niet meer :) Dus ik wacht gewoon lekker :)
  • Sm0k3r
  • Laatst online: 05-11 05:41
Sm0k3r
cough...cough...
Deathchant schreef op vrijdag 14 januari 2011 @ 11:23:
Same here, ik bid nog steeds voor een iets snellere variant op de GTX580, ik heb nog 3 maanden dus hopelijk komt er iets kleins aan, een GTX585 ofzo?
(jaja weet het, had het al met iemand erover gehad en de kans is miniem of helemaal niet dat dit zal gebeuren maar ik heb precies hetzelfde, geld staat op de bank en ik speel de "waiting game").
Kepler komt in 2011 maar wanneer denken jullie, ergens aan het eind of midden 2011?
[ Voor 5% gewijzigd door Sm0k3r op 14-01-2011 11:54 ]
"I believe that forgiving them is God's function. Our job is simply to arrange the meeting."
Sm0k3r schreef op vrijdag 14 januari 2011 @ 11:47:
Eind 2011 voor een high-end kaart waarschijnlijk, grote 28nm GPU's zullen ook wel weer een probleem zijn voor TMSC aangezien er nu al geruchten gaan over wat problemen bij TMSC op 28nm.
  • Sm0k3r
Sm0k3r
cough...cough...
Verwijderd schreef op vrijdag 14 januari 2011 @ 12:02:
NEEEEEEEEE (ben niet echt verbaasd, dit is overdrijven btw).
Ok wat zal ik doen dan, over 3 maanden een GTX580 kopen inclusief andere koeling (thermalright Shaman of Spitfire en clocken) of weer wachten en PC gamen nog een tijdje laten voor wat het is...
De Kepler specs of wat nvidia ons doet geloven zijn eigenlijk redelijk extreem en interessant genoeg om te wachten omdat hij 3x zo snel is i.t.t. de Fermi.
  • Allubz
  • Laatst online: 15-11 21:37
Sm0k3r schreef op vrijdag 14 januari 2011 @ 12:32:
NVIDIA laat altijd een heleboel geloven. Voordat die kaarten uit zijn is het net eind 2011 begin 2012. Lekker nu een price-performance kaart kopen, je zit altijd te wachten op het nieuwste van het nieuwste op deze manier; er staat altijd wel weer iets nieuws op de planning.
Interesse in een custom build workstation, voor gaming, wetenschappelijke toepassingen, of puur om de stijl? Contact @ https://vogd.design
  • madmaxnl
  • Laatst online: 09-08-2022
madmaxnl
Drie keer zo veel DP Gflops per watt als Fermi ja. SP en DP zijn twee dingen. SP is vooral voor gamen belangrijk en DP is vooral voor GPGPU belangrijk. M.a.w. DP is leuk maar op dit moment "nutteloos" tenzij je veel waarde hecht aan GPGPU. Daarbij komt ook nog eens dat het dus DP GFLOPS per Watt is. Over Kepler kunnen we dus niks zeggen. Immers hebben we het over verhoudingen. Kan dus best dat Kepler langzamer is als Fermi.
Kepler zal i.t.t. wat op de slide stond pas in 2012 het licht zien want Fermi is i.t.t. wat op de slide stond niet in 2009 uit gekomen maar in 2010. Wachten op iets beter in Hardwareland is eindeloos en slechts als op korte termijn iets beters uitkomt verstandig.
Dit heb ik zelf ondervonden met het wachten op Bulldozer :(
Betreffende slide trouwens:
Afbeeldingslocatie: http://images.vizworld.com/wp-content/uploads/2010/09/NVidia_GPU_Roadmap.png
[ Voor 5% gewijzigd door madmaxnl op 14-01-2011 14:06 ]
madmaxnl schreef op vrijdag 14 januari 2011 @ 14:06:
Dit is niet 100% van elkaar afhankelijk natuurlijk. Het is echt niet zo dat er één team aan beide projecten werkt en dat door de vertraging van Fermi automatisch Kepler ook vertraagd is. Het kan zijn dat ze wat resources extra hebben moeten gebruiken voor Fermi die ze anders voor Kepler hadden ingezet, maar er wordt echt wel aan doorgewerkt hoor. Daarbij is het natuurlijk een kleine kans dat bij Kepler dezelfde problemen gaan plaatsvinden als bij Fermi. Denk dat het TQM proces wel een schop onder de kont heeft gekregen. ;) En Nvidia is natuurlijk ook nog behoorlijk afhankelijk van TMSC, zoals Mask al zegt.
  • madmaxnl
madmaxnl
28nm gaat toch pas in het beste geval eind 2011 begin 2012 (goed) beschikbaar zijn ?
En dus zou een eventuele vertraging van Kepler niks met de vertraging van Fermi te maken hebben, maar met de ontwikkelingen bij TMSC... ;)
  • madmaxnl
madmaxnl
Dat zei ik niet zo zeer omdat Fermi vertraging had opgelopen maar eerder dat de tijden die nVidia aangeeft niet echt realistisch zijn. Immers wisten ze heus wel dat Fermi niet in 2009 uit te brengen viel. De mock-up was daarvan een goed indicatie.
En toch zei je het zo, pas het dan even aan voor je het post...
Ik persoonlijk neem het echter ook met een korrel zout, de vertraging bij fermi draagt ook wel aan die verwachting bij, net zoals het bij jou doet.
  • lightdestroyer
  • Laatst online: 07-09 16:19
Nieuw deel aangemaakt (plots was er enorm veel nieuws dankzij CES en dat juist op het einde van dit deeltje ..
[Algemeen] nVidia Nieuwdiscussie Topic - Deel 51
Blijkbaar is de nvidia website weer eens aangepast (specificaties van grafische kaarten gedeelte)
en tis deze keer,voor de verandering, er niet slechter op geworden de specs staan nu mooi duidelijk uitleesbaar.
Ook hebben de oude "echte" gpu reeksen een refresh gekregen, wss ten gevolge van de PR rond de miljardste GPU die gefabriceerd is geweest voor nvidia>
(de gpu's die niet onder nVidia naam werden verkocht worden hierbij niet meegeteld, riva TNT bv ..)
2 opmerkelijke puntjes
• Linken naar reviews zijn toegevoegd --> *O* Tweakers.net staat op de nvidia website *O*
• Er wordt voor de gtx580 enkel een min voeding van 600watt vermeld geen tdp... ;/ je zal hun dus er niet op pakken dat het meer is dan officieel aangeduid want officieel duiden ze niets meer aan -___-
En zeg nu nog eens dat Tegra2 en het Tegra platform geen succes kan worden, veel te veel links moeten bijvoegen over al die tablets die Tegra2 zouden gaan gebruiken :X
Specs
  • Edmin
  • Laatst online: 18-11 20:49
Edmin
Crew Council
get on my horse!
