[PC] Battlefield 2142 - Deel 2 Vorige deel Overzicht Volgende deel Laatste deel
Pagina: 1 ... 10 11 Laatste
  • 7.205 views sinds 30-01-2008
  • W1ckeD
  • Laatst online: 05-12-2023
W1ckeD
Lifthill Studio
Ik had BF opnieuw geinstalleerd.
Daarna gepatched,en toen werd ik eruit gegooid wegens aangepaste content.
Toen ff de p.c gereboot, en voila hij deed het weer. :*)
Life is complicated
Het antwoord van EA op de 1.05 problemen (bron bf2142fever.com)
1. Crash to desktop at the end of the round in Titan maps. You should still earn credit for what you did in the round (thank you for the correction, MichaelBrobst2) although there may be a delay.
-If the Titan is moving when the shields go down and the rounds per map is set greater than one, then the client will crash at the end of the round. Until a fix is in place, server admins can prevent the issue by setting the rounds per map to one. (Medic 9017 kindly posted this workaround; it has also been verified by DICE). Soldiers can also choose to play Conquest maps to avoid running into the Titan crash if the rounds per map has not been changed to one.
2. EA Master Server disconnects and errors still occur.
-It's been verified that this is still a widespread issue. I'll update this when I have more information.
3. Crashing after login or choosing your soldier. 'Patching failed' errors.
-FerretPleb posted a possible cause for this issue (thank you exodusrage for sending it my way). If you have limited free space on your hard drive (particularly on the partition that houses Battlefield 2142), you may try freeing up some space. You should have about 1.35GB free space to install the patch.
4. When trying to join the server you are told that 'This Server Only Allows Unmodified Content' or similar messages.
-This may be due to an error whilst patching. Try a clean install/re-patch of the game to see if it helps. The manual uninstall directions are here: http://support.ea.com/cgi-bin/ea. cfg/php/enduser/std_adp.php?p_faqid=14051
5. Graphic corruption on the Titan. Everything is black or dark.
-This may be related to the in-game video options causing conflicts on some machines. One of the support guys here had the issue and adjusted the options for Dynamic Shadows and Lighting, Anti-Aliasing, and Texture Filtering to resolve the issue. Drop those options and then adjust them up one by one until you find out which one causes the issue. Let me know if that helps.
  • jorisdekloris
  • Laatst online: 18-11 18:13
Dus niemand mag de titan moven als de shields 'bijna' down gaan?
Tierelier
  • Risce
  • Laatst online: 14-11 12:46
W1ckeD-GT schreef op donderdag 23 november 2006 @ 13:59:
Hey Thanks,
Na een reboot werkte het spel weer en werd ik er niet meer uitgeknald. :*)
graag gedaan.
@ace: als je het spel nou zelf speelde, dan had je geweten dat dit soort problemen al verholpen zijn. En als je goed had gelezen staat dat ook al in mijn post. 8)7
[ Voor 7% gewijzigd door Risce op 23-11-2006 15:33 ]
Theorie: Ja. Praktijk...uh. Nee.
Risce schreef op donderdag 23 november 2006 @ 15:32:
graag gedaan.
Ja nu.
:P maar er zijn nog een paar leuke glitches in the house
Oh and by the way, de oplossingen om glitches aan te pakken zijn gewoon gaar.
1. de titan niet laten moven als schilden down zijn.
2.je kan niet meer spawnen op de titan met je spawn becons.
Dit zijn gewoon halfe gare oplossingen en niet eens waardig om het een fix te noemen.
Want:
1. je hebt nog steeds last van lag
2.je kan nog steeds met de becon gewoon in andere gebouwen glitchen
[ Voor 34% gewijzigd door Verwijderd op 23-11-2006 16:29 ]
  • empheron
  • Laatst online: 29-07 12:29
In de categorie gerechtigheid :
Er is gisteren of vandaag een massale statsreset geweest waarbij iedere account met 'te veel' Titan Jump points simpelweg gekilled is. op www.2142-stats.com zijn zeker de bovenste 100 accounts allemaal gewist (ook niet meer op te vragen dus).
Dus statpadders : eat your heart out!
  • Fern
  • Laatst online: 22-08 08:54
empheron schreef op donderdag 23 november 2006 @ 17:10:
Ik heb het ook gezien ,de hoogste scores liggen nu rond de 15K points, dat was bij velen boven de 100K,maar die zie ik niet meer terug _/-\o_
PowerStation
  • Risce
Klopt, heel goed gedaan. Ik zie wel nog 1 iemand in de top 100 met een round score max van 2200, dat lijkt me onwaarschijnlijk.
@Ace: Ik ben het met je eens dat het niet een juist oplossing is om ingame te veranderen om bugs te verwijderen. Dat krijg je als je een oude engine gebruikt. Maar de meeste glitches zijn dus WEL opgelost. Zoals de lag dus en zoals wegglijden van de titan. Verder wijd ik er geen woorden meer aan, want jij vindt het spel kut, en ik niet en het interesseert me verder geen jota.
  • W1ckeD
W1ckeD
Lifthill Studio
Niet te geloven..
Nou heb ik weer een ping van 200+.
Voor 18.00 uur speelde ik met een ping van rond de 30.
En daarna schoot die omhoog naar 200+.
Ik hou al me netwerk verkeer in de gaten maar ik zie niks verdachts.
Heb @home internet...
Life is complicated
  • martijn-
  • Laatst online: 24-11 20:03
ik heb nu twee keer achter elkaar een CTD gehad steeds als een ronde afgelopen is en de volgende ronde geladen is en wil beginnen stop hij er mee.
  • FF1987
martijn- schreef op donderdag 23 november 2006 @ 23:24:
Jah daar heb ik ook last van sinds de v1.05 patch. -O-
  • jorisdekloris
Wij hebben op de server de rondes ingesteld op 1 ronde per map. Dit werkte in eerste instantie niet. Toen hebben ij alle Ti mappen eruit gedonderd om alleen conquest te spelen. Toen hebben wij de mappen weer toegevoegd en nu crasht de server niet meer :D
servernaam staat vast nog wel ergens, heb ik eerder gepost :D
Tierelier
  • Stewie!
  • Laatst online: 16:47
Stewie!
Keen must die!
FF1987 schreef op vrijdag 24 november 2006 @ 10:21:
Er komt een middag dat ze dat fixen ;)
Strava: https://www.strava.com/athletes/149347154
  • martijn-
DaMorpheus schreef op vrijdag 24 november 2006 @ 11:49:
ik hoop dat die middag snel komt dan
  • fast-server
  • Laatst online: 08-11-2025
Met de nieuwe 1.06 patch lijkt ales goed te draaien, alleen af en toe nog master server losses.
PV Output SolarEdge SE5000H, 12x Jinko JKM390N-6RL3 Tiger> 4,68 kWp, Helling 42°, Oriëntatie 196° (ZZW)
  • Risce
Ja 1.06 heeft veel problemen met titan mode verholpen, maar ik zit nog wel steeds te wachten op een oplossing op de seatswitch exploit (leaderboard staat alweer vol met 2200 punten per ronde gemiddelde mensen). En het moment dat ze iets gaan doen aan bepaalde wapens, zoals de kracht van Anti Personnel Mines. Ze hebben in 1.05 de Assault Rifles iets sterker gemaakt, door de deviation per schot naar beneden bij te stellen.
  • Stewie!
Stewie!
Keen must die!
martijn- schreef op vrijdag 24 november 2006 @ 12:09:
Snel genoeg? 8)7
  • Stewie!
Stewie!
Keen must die!
Maken we hem even compleet:
Bron: http://www.battlefield2142.nl/?id=459
EA released patch 1.06 for Battlefield 2142. The patch fixes the serious crash bug introduced in patch 1.05. The filesize is 23 MB and there is only the full patch available.
Download mirror: http://files.i3d.nl/ (1000mbit mirror, file size 23 MB)
PATCH 1.06
BUG FIXES
- Fixed Client Side Crash on Titan Mode.
  • CrankyGamerOG
  • Laatst online: 25-11 15:03
CrankyGamerOG
Assumption is the mother.....
niet te geloven dit
was ooit een bf2 speler, maar na lang vol gehouden te hebben afgehaakt door brakke coding van het spel(was gewoon niet meer leuk)
zag dit topic en dacht hey, ens ff lezen allemaal
en goh wat blijkt bf2142 is niet veel beter !!!!
ik snap niet dat EA dit kan blijven doen
KPN - Vodafone Ziggo Partner
Agja beetje BS weer een noobie die een zogenaamde exploit laat zien..
Jamer aleen dat je geen beacon kan droppen als de andere nog actief is.
En btw de lijst staat nog steeds vol met cheaters, ze zijn aleen uit de eerste paar pagina's weg.
zodat het "lijkt" of ze er iets aan gedaan hebben...
  • R-O-Y
  • Laatst online: 03-06-2025
R-O-Y
Ik maak mijn zinnen nooit
Fern schreef op donderdag 23 november 2006 @ 17:16:
Denk je dat het die glitchers wat boeit. Net als in BF2 zijn er vast nog wel een shitload aan bugs/glitches. Somminge mensen maken ze ook niet bekend zodat ze het zelf kunnen gebruiken :)
Youtube Download ubersnel.nl
CrankyGamerOG schreef op zaterdag 25 november 2006 @ 09:16:
niet te geloven dit
EA kan het zich veroorloven, aangezien zij de allergrootste in dit genre zijn. Ze hebben zoveel macht dat het niet boeit dat er nog veel bugs inzitten. En let trouwens niet téveel op Ace's zijn posts, die zijn soms een beetje, tsja, hoe zal ik het zeggen, uit zijn verband getrokken ;). Er zitten wel goede kanten aan het spelen, en ook wat leermomenten tegenover BF2. Maarja, als zo'n game pas na de release al 20 patches heeft gehad, weet je wel weer hoelaat het is.
  • El_Bandito
  • Laatst online: 06-05-2024
Fern schreef op zaterdag 18 november 2006 @ 20:21:
Ik heb een nieuw probleem met BF2142,heb net een samsung 204b(tft) aangeschaft,blijkt nu dat BF2142 niet meer wil opstarten als ik erop klik,kom gewoon weer in windows terecht ,iemand hier bekend mee.Heb de resolutie al terug gebracht(tft)naar 1280x1024 waar ik standaard op speel,maar dat mag niet baten :'(
Heb toch maar weer een nieuwe installatie gedaan,werkt dan wel maar zou eigenlijk niet zo moeten omdat de rest van m;n games wel werken.
Video profile (video.con?) weggooien uit My documents\Battlefield2142\Profiles :)
i7 2600K / Gigabyte GA-Z68x-UD3H-B3 / 8GB Corsair / ZoTac GTX570 / 60GB SSD
  • The_Cure
  • Laatst online: 23-11 09:39
Toch maar bestelt, hoewel ik het eigelijk niet wilde doen :)
Maar voor 23,99 € kon ik het niet laten :)
(cd-wow.nl en dan met de telegraaf €5 bon telegraaf.nl/cdwow )
Ben benieuwd, heb het een beetje gehad met BF2 (kan ik onderhand dromen)
  • Risce
bf2142 is sowieso een stuk veelzijdiger dan bf2.
  • Fern
R-O-Y schreef op zaterdag 25 november 2006 @ 12:50:
Klopt,er zijn er weer bij die weer enorm scoren(Cheaten),maarja,zolang EA de boel niet op orde heeft blijven er lui bij die dat gewoonweg uitbuiten.Jammer dat EA er niet voor heeft gezorgd dat ze dit spel zonder bugs hebben uitgebracht,ik merk zelf nog steeds dat er veel bugs inzitten o.a zomaar afsluiten van het spel zodat ik zomaar weer in windows zit,mijn komplete uitrusting is verdwenen naar standaard terwijl ik wel de nodige punten heb maar bij een ander spel wel weer de komplete uitrusting heb,jammer van zo'n spel,komt de gameplay niet ten goede op den duur |:(
PowerStation
  • W1ckeD
W1ckeD
Lifthill Studio
Woei!
Net weer een lekker potje achter de rug,
Ik ben gewoon gek op de Chaos in het spel,wat er allemaal om je heen gebeurd.
De fijnste kit vind ik Sniper.. :) Heerlijk om mensen van afstanden een headshot te geven,nou nog meer punten verdienen voor die stabilisator
Life is complicated
  • Dutch_Razor
  • Laatst online: 01-11-2024
Damn de titan mode is zo laggy als ik weet niet wat, met een ping van 34 en 60+ fps :S
Maar snipen is wel leuk, heb al 2x de Infiltrator pin (4 headshots IAR), de Zeller H is volgens mij samen met de Lambert Carbine een van de beste wapens, af en toe werkt ie op close range nog :D
W1ckeD-GT schreef op zaterdag 25 november 2006 @ 22:48:
Woei!
En dan in een verre toekomst misschien ook nog eens iets voor je team doen ? :+
  • Nano2009
  • Laatst online: 21:23
hey,
Ik wordt de heletijd van alle servers gekickt door punkbuster "unknown windows API function [131133]" :?
[ Voor 7% gewijzigd door Nano2009 op 26-11-2006 12:16 ]
Nano2009 schreef op zondag 26 november 2006 @ 12:09:
hey,
Nou, dat is mooi. Weten we dat ook weer :)
  • W1ckeD
W1ckeD
Lifthill Studio
Verwijderd schreef op zondag 26 november 2006 @ 10:22:
Hey maar,ik lig niet de hele tijd te snipen. ;) :+
Life is complicated
  • martijn-
volgens mij werkt de punten telling van somige medals en ribons nog niet goed.
er is namelijk een ribon waarvoor je een best kill streak van minimaal 10 moet hebben en die heb ik ook maar dat word niet bij die ribbon weergegeven.
het zelfde heb ik met een medal waar je een best round van minimaal 70 moet hebben in titan mode maar die word ook niet getelt. heeft iemand meer hier last van?
  • Kid_E
  • Laatst online: 04-10-2025
Die best kill streak betekend wat anders.
Je moet in minimaal 10 ronden de beste kill streak van iedereen in de server hebben. Dus niet je algemene kill streak.
  • martijn-
Kid_E schreef op zondag 26 november 2006 @ 13:02:
waarom noemen ze het dan niet anders want zo word het wel heel verwarrend met twee verschillende dingen die de zelfde naam hebben.
  • Risce
hey,
teamspeak tool uit en je videokaart tool uit.
http://www.punksbusted.co...ion/index.php/t16717.html
Misschien volgende keer zelf doen:
1>Foutmelding overschrijven
2>Invoeren in google.
hey,
API Kick 131133:
Known cause: Ventrillo Voice Overlay - Possibly other overlay programs. (ATI tool tray from Omega Drivers suspect)
Solution: Disable overlay program
Known cause: DxTweaker
Solution: Disable DxTweaker program
Known cause: Older TSO - Causes a "Missing/Corrupted API" kick
Solution: Update TSO to latest build
ventrilo overlay AND ATI tool overlay. Disabled both and you can play!!!!!!!!!!!!!!!!
[ Voor 5% gewijzigd door Verwijderd op 26-11-2006 16:36 ]
  • Sky2k
  • Laatst online: 01:15
Kan voortaan niet meer normaal spelen!!! Ik krijg elke keer
Fout
De verbinding met de EA server is verbroken.
Hoe kan je dat oplossen?
  • Stewie!
Stewie!
Keen must die!
Sky2k schreef op zondag 26 november 2006 @ 22:12:
Fout
[ Voor 20% gewijzigd door Stewie! op 26-11-2006 22:24 ]
  • OCTheEagle
  • Laatst online: 27-08 14:39
Vandaag ff de PCM gelezen en daarin stone een reclame advertentie (blz 14) over BF2142. Volgens de reclameposter zijn er 1500 manieren om dood te gaan in het spel. Is er wellicht een site die verteld wat die 1500 manieren zijn?
  • Risce
In mijn ogen zijn dat er 4:
1-kogel in je lichaam (elk wapen)
2-opgeblazen (in vehicle, apm, rdx, rpk)
3-van grote hoogte gevallen (of kleine)
4-'suicide' button
Artiesten zijn trouwens van mening dat het er 6 miljoen zijn:
http://www.backtotheoldsk...udio/six_million_ways.ram (DJ Zinc)
http://www.blogmusik.net/?urlIdSong=85235 (Turbulence)
De bekendste is natuurlijk van Do or Die, maar daarvan kan ik alleen de lyrics vinden:
http://www.musicsonglyric...doordie6millionlyrics.htm
[ Voor 51% gewijzigd door Risce op 27-11-2006 03:27 ]
  • martijn-
Risce schreef op maandag 27 november 2006 @ 03:21:
4-'suicide' button
je bent nummer 5 vergeten door de Knife neergestoken worden.
  • ikman
  • Laatst online: 25-11 10:12
6 over reden worden
7 op iemand landen
8 tegen iemand aan vliegen
9 uit heli springen met droppod en dan ingehaald worden door de heli, ben je ook dood.
10 met een droppod op iemand landen
11 met droppod op tank landen, gaat tank ook dood.(werkt niet altijd)
ik vind het wel vervelend dat je door personen heen kan lopen, erg vervelend als je iemand probeerd te knife-en dat hij dan in een keer achter je staat.
[ Voor 81% gewijzigd door ikman op 27-11-2006 11:53 ]
  • jorisdekloris
ikman schreef op maandag 27 november 2006 @ 11:49:
Ik vind het ook niet goed. het kan niet altijd want als je in de titan bij een corridor loopt en iemand duwt je naar binnen is het juist vervelend.
Tierelier
  • Risce
Vandaag is de eerste Supreme Commander verkozen: Noobish-Noob, volgens zijn tag uit Maleisië.
Gast staat op de overall op plek 674 ongeveer. Hij heeft 150 uur gespeeld. Hij heeft een Score per Minute van 2.6 en K/D 2.07. Opvallend: hij heeft een overall accuracy van 32%, met een voss gemiddelde van 44%.
Al met al, heftige stats, maar niet extreem bijzonder. In ieder geval geen cheater. Wat mij betreft was het Woken geworden, staat nu op 1 en is al vanaf het begin top10 en niet zo'n lame commander dan.
Weet iemand wat de precieze manier is waarop iemand verkozen wordt?
[ Voor 6% gewijzigd door Risce op 28-11-2006 03:44 ]
  • jorisdekloris
Tierelier
  • xanthus666
  • Laatst online: 29-10 21:22
Weet iemand hoe ik dit spel kan spelen zonder de DVD? die dvdwriter maak zo'n herrie iedere keer dat ik BF start.
Ik heb geprobeerd een image te maken met Nero/alcohol/DVDdecryptor maar ze doen het allemaal niet. Staat iets van "put installation disc erin ofzo".
Heb op gamecopyw al gekeken maar daar kan je niet online mee spelen met die patch.
Iemand?
xanthus666 schreef op dinsdag 28 november 2006 @ 16:02:
Iemand?
Da's niet gewenst hier, maar op internet is dat zeker te vinden. Zoek zelf eens zou ik zeggen :).
  • Risce
Kontrol Crimson is alleen geen Supreme Commander, want zijn bf2142 is 'menschdefect', zoals ook linksbovenin het plaatje te zien is. Na Lieutenant-General is er simpelweg geen hogere rang en kun je dus alleen Supreme Commander nog halen, en dat is 1 iemand voor 1 week, of iig een bepaalde periode en dan weer een andere (alhoewel gesuggereerd wordt dat je het vaker kunt halen).
In de thread staat trouwens ook een common defect: bepaalde badges/ribbons meerdere keren krijgen. Krijg je als je als recruit wordt aangemerkt, maar toevallig wel je unlocks houdt. Die badges blijven wel tellen gewoon. Dat is lekker scoren kan ik je vertellen. Volgens Kontrol Crimson heeft hij een bepaalde ribbon ook 5 keer gekregen, a 2000/2500 punten per ribbon. Vriend van me heeft dat ook 1 keer gehad, heeft nu al zijn PAC Ribbon (req: 150 uur PAC zijde), maar is in totaal nog geen 110 uur aan het spelen.
De Supreme Commander is Noobish-Noob. Dit is trouwens zijn bf2 acccount: http://www.spielerstats.d...ld2+player+statistik.html. Ook niet mis zeg.
Iemand er al achter wat de requirements zijn?
[ Voor 5% gewijzigd door Risce op 28-11-2006 17:44 ]
  • CrankyGamerOG
CrankyGamerOG
Verwijderd schreef op dinsdag 28 november 2006 @ 16:09:
nee dat zal , maar hij heeft wel gelijk mijn dvd speler rammelt ook zo, en bij BF2 kon ik een miniimage in d-tools gooien, maar voor bf2142 kan ik geen miniimage vinden
  • Fern
Ik heb het probleem dat m'n hele kast rammelt tijdens een potje BF2142,maar dat zal misschien wel door m'n speakersetje komen daar ben ik nog niet helemaal achter 7(8)7
PowerStation
Joe...ben nog flink tegen de computer aan het spelen maar al aardig wat vorderingen gemaakt
dus zo begin volgend jaar lekker online en ff huishouden online.
Tegenstanders ..Ace,Equilized etc...komt U maar (hehe)
[ Voor 5% gewijzigd door Verwijderd op 28-11-2006 18:05 ]
  • ikman
waarom?
single player vorderingen tellen niet voor multi player
Ik vind dat ze bij EA genoeg moeten nemen met een originele cd-key/code.
Waarom zou ik in gods naam steeds de DVD in de DVD-ROM laten?
Overigen: EA zou vanavond alle servers updaten om connection lost probleem op te lossen.
  • Risce
Zij hebben geen controle over ALLE servers. Alleen over de officiele EA servers, die beginnen met EA weetjewel.
Beetje rare claim. Ze moeten werken aan hun master server, want die zorgt ervoor dat ik eens in de zoveel tijd als recruit wordt aangemerkt en dat ik dan geen unlocks meer heb (overigens wel lekker punten scoren, want je kunt ook meteen al je badges opnieuw halen en die tellen gewoon mee)
Iemand?
Mijn originele en met zuurverdiende centen aangekochte BF2142 DVD heeft ook reeds een haarscheurtje in het midden.
Na een image aangemaakt te hebben, disable ik mijn DVD-drive.
Works like a charm :-)
  • CrankyGamerOG
CrankyGamerOG
Verwijderd schreef op woensdag 29 november 2006 @ 02:41:
nou met mijn image lukt dat dus absoluut niet
kan jij het me niet eens op msn uitleggen vanavond ? oid ?
ik heb namelijkl niet eens een drive in me pc ook geen dvd oid
en als ik um mount in d-tools dan blijft ie zeuren voor de dvd
ik heb origineel spel image gemaakt en geprobeerd en de welbekende niet legale versie(razor) maxi image beiden lukt het me NIET mee
en
Na een zoektocht naar battlefield 2142 mini image, kwam ik ergens uit op dat de bf2142.exe van EA downloader verschilt t.o.v. de DVD versie. Als in dat er mensen zijn die claimen de DVD versie te hebben maar de bf2142.exe van EA downloader gebruiken om zonder DVD te kunnen spelen. Weet verder niet in hoeverre dit waar is, heb het spel niet dus kan het niet testen :P
En images schijnen niet te gaan werken met virtual drives software zolang deze niet geupdate worden omdat schijnbaar de nieuwe safedisc versie (4.7 meende ik) succesvol deze blacklisted.
Misschien dat het werkt als je de default driver name van bijvoorbeeld daemontools (3.47) renamed naar iets wat niet bekend en logisch is (kan alleen bij nieuwe installatie voorzover ik weet en pc restart nodig).
Is er een andere website voor stats dan www.2142-stats.com ?
Of iets van EA?
  • Stewie!
Stewie!
Keen must die!
Risce schreef op woensdag 29 november 2006 @ 02:25:
Drie keer raden wie die servers hosten ;)
  • CrankyGamerOG
CrankyGamerOG
Verwijderd schreef op woensdag 29 november 2006 @ 10:40:
nee dat klopt dus niet meer, het werkte schijnbaar tot aan patch 1.05 ofzo in die richting(die dl exe)
maar ik stap pas nu in, en wil echt niet me dvd verkrassen, want bij bf2 kon ik het ook
verder zijn er veel mensen die zeggen dat het wel met d-tools gewoon kan, maar je moet dan je echte phisical drives uitschakelen, alleen heb ik geen echte drive erin , en het lukt me dan ook niet
[ Voor 8% gewijzigd door CrankyGamerOG op 29-11-2006 11:37 ]
DaMorpheus schreef op woensdag 29 november 2006 @ 11:15:
dit ben jij toch van deze club? :X
  • Stewie!
Stewie!
Keen must die!
Hij is van i3d, en vind het blijkbaar belangrijk om nog even te benadrukken.
  • Stewie!
Stewie!
Keen must die!
Verwijderd schreef op woensdag 29 november 2006 @ 14:49:
Nee, ik vind het belangrijk om te benadrukken dat men hier geen bullshit moet roepen omdat dat ergens op vaag copy/paste forum staat.
Die zogenaamde EA servers worden door de ranked hosters gehost, niet door EA. Dus EA update niet alleen de EA servers, EA update niets. Als er servers worden geupdate, dan updaten alle ranked servers en krijgt iedereen ook een nieuwe clientversie.
Ik noem nergens een bedrijfsnaam, dus zie ook niet waar ik dat dan zou "benadrukken".
[ Voor 7% gewijzigd door Stewie! op 29-11-2006 14:56 ]
  • maxoss
  • Laatst online: 22:11
CrankyGamerOG schreef op woensdag 29 november 2006 @ 11:36:
je hebt geen drive maar wel het spel origineel legaal geinstalleerd ;)
  • Debtor
  • Laatst online: 20:04
Zijn ze weer met de servers bezig? Hij kan namelijk geen servers meer vinden.
  • empheron
Dit wel dan?
http://www.gamert.nl/forum/viewtopic.php?t=3711&start=60
Server:Gamert#9
Date:21-11-2006
Reason:padding
Ban:perm
Admin:JiMmY
DaMorpheus schreef op woensdag 29 november 2006 @ 14:55:
Hierdoor:
Verder niks aan het handje, maar benadrukken doe je het juist door geen bedrijfsnaam te noemen. Ik wil geen flamewar uitlokken dus laten we het hierbij houden ;).
  • Stewie!
Stewie!
Keen must die!
empheron schreef op woensdag 29 november 2006 @ 16:27:
Dit wel dan?
Server:Gamert#9
Date:21-11-2006
Reason:padding
Ban:perm
Admin:JiMmY
Ik ben 't niet, ik speel onder dezelfde naam BF2142 als BF2 (bij bf2 was dat morpeus, nu dus ook) :)
[ Voor 7% gewijzigd door Stewie! op 29-11-2006 16:47 ]
  • Stewie!
Stewie!
Keen must die!
Verwijderd schreef op woensdag 29 november 2006 @ 16:32:
Hierdoor:
Ok, zolang maar duidelijk is dat ALS er iets geupdate wordt, er ALTIJD een nieuwe client uitkomt. Dus alle verhalen over zogenaamde software updates kan je gewoon negeren als er geen nieuwe client uitkomt :)
  • Risce
DaMorpheus schreef op woensdag 29 november 2006 @ 16:48:
Nee precies, dat is waar. Die client moet wel geupdate worden inderdaad. Maar als zij dus client software gaan veranderen voor connection problemen, moet je ook een patch releasen voor users, want anders krijg je ook problemen, toch?
En over zogenaamde sluikreclame van Morpheus: Dat slaat dus weer helemaal nergens op, lees nog maar eens terug.
  • CrankyGamerOG
CrankyGamerOG
maxoss schreef op woensdag 29 november 2006 @ 14:59:
ooit gehoord van een drive inbouwen installeren en dan uitbouwen ? ik heb 3 pc's en maar 2 dvd drives en me vriendin vond het niet echt "grappig" dat ik haar dvd gejat had ;)
----edit-----------
BLEH. hoeft al niet meer, het lukt me al met een.
Ik heb gewoon een image gemaakt van de originele DVD met alcohol op mijn oude pc,
die via netwerk naar me nieuwe pc, gemount
en gaan met die banaan
dus geen irritante dvd meer in drive, maja wel nog -+4 Gb hdd space weg voor jan lul :P
een minidvd zou wel handiger zijn ,maar het werkt dus wel gewoon met d-tools
[ Voor 35% gewijzigd door CrankyGamerOG op 29-11-2006 18:25 ]
  • CrankyGamerOG
CrankyGamerOG
ik ben aan het slapen geloof ik , ik had reply ipv edit, excuses
[ Voor 85% gewijzigd door CrankyGamerOG op 29-11-2006 18:26 ]
CrankyGamerOG schreef op woensdag 29 november 2006 @ 18:10:
----edit-----------
of je gebruikt gewoon een mini image van 4MB :P
  • H3llSiNG
  • Laatst online: 25-10 14:02
H3llSiNG
Meh.
Niet echt fijn, krijg nu de hele tijd random disconnects, dit zou na de patch verholpen moeten zijn toch?
Niet te spelen zo, loop je in een walker rond gaat net goed, game freeze en poef je zit weer in het menu screen.
Is er een oplossing voor, topic beetje doorgenomen maar niks doorslagsgevends gevonden. Heb geen firewall en enige downloads die aanstonden ook maar uitgezet.
Systeem: Pentium II 350 MHZ @ 400MHZ, Nvidia Riva 128 LX, 128MB RAM, Windows ME Plus (32 Bit)
  • CrankyGamerOG
CrankyGamerOG
Verwijderd schreef op woensdag 29 november 2006 @ 21:54:
jah maar dan moet die er wel zijn, en die kan ik nergens vinden, en ik heb gelezen dat een mini-image voor bf2142 niet gaat werken
edit
ik probeer nu al 2 uur een mini-image te maken volgens de tutorials die er voor zijn, alleen wil het me echt niet lukken, ik denk dat het maken van een miniimage niet gaat werken bij bf2142
moet wel zeggen dat bf2142 een stuk chaotischer is dan bf2
[ Voor 30% gewijzigd door CrankyGamerOG op 30-11-2006 12:14 ]
  • Risce
H3llsing schreef op donderdag 30 november 2006 @ 01:07:
Je moet sowieso ALLES uitzetten als je een (online) spel gaat spelen. Verder kun je overwegen om VOIP uit te zetten (voice chat) en je moet ook niet alt-tabben.
Wil je daarmee zeggen dat jij een werkende mini image hebt? Zonder je drives te disablen enzo? Want daar heb ik echt geen trek in.
Het schijnt dus dat een mini image voor BF2142 niet gaat werken met de beveiliging die erop zit. Omdat deze verspreid over de hele DVD dingen checked. Dus zoals bij BF2 een image van ~3Mb zit er zeker niet in. Die beveilinging checkte alleen maar het begin van de DVD.
[ Voor 30% gewijzigd door Verwijderd op 30-11-2006 15:33 ]
Verwijderd schreef op donderdag 30 november 2006 @ 15:31:
ik en bf2142 gaan niet samen.
Met EA en zijn gekloot, leuk om te horen dat ze mini image ook proberen te verbannen. Maar ze schoppen de mensen die het spel legaal hebben. want wie het spel illigiaal wilt spelen doet het toch wel.
  • Risce
Verwijderd schreef op donderdag 30 november 2006 @ 16:48:
ik denk dat door de strenge maatregelen die ervoor zorgen dat mensen die het spel legaal hebben tegen irritante problemen aanlopen, er ook voor zorgen dat er niemand is die dit spel illegaal online speelt. Maar ken jij dan mensen die het spel illegaal spelen? Volgens mij is er geen werkende crack voor online namelijk, of wel?!
Risce schreef op donderdag 30 november 2006 @ 17:15:
Genoeg cracks dwalen er op het net. ;)
http://forums.fevergaming...no-cd-dvd-mini-image.html
Mini-image gaat niet werken idd.
maxi image volgens mij wel, dus weer 4gb binnenhalen voor deze beveiligingsonzin. mounten en eindelijk online spelen. (dvd ligt momenteel bij kenissen :( )
De no-cd .exe werkt ook niet, punkbuster kickt je dan van de server en voor elke versie weer een .exe zoeken is tijdverspilling.
Ik heb bij bf2 4 install cd's verkloot, wil dus wel een image kunnen maken.
[ Voor 4% gewijzigd door Verwijderd op 30-11-2006 18:09 ]
  • Stewie!
Stewie!
Keen must die!
Verwijderd schreef op donderdag 30 november 2006 @ 17:50:
Alleen kan je niet op ranked servers ermee spelen :z
  • Risce
bewijzen?
goede sniper kan heel wat doen voor zijn team
  • Rapide211
  • Laatst online: 15-03-2022
Kan iemand mij helpen??
Ik heb BattleField Vietnam en BattleField 2142. Vietnam doet het goed, alleen BF2142 valt uit. Ik krijg namelijk steeds de melding:
Fout
De verbinding met de server is verbroken.
  • Rapide211
Verwijderd schreef op donderdag 30 november 2006 @ 19:06:
Zeker als er een vijand komt is die de pineut. Zo help je tog ook??
  • Rapide211
Rapide211 schreef op donderdag 30 november 2006 @ 19:28:
Fout
En?
  • Rapide211
Modbreak:Het Afbeeldingslocatie: http://gathering.tweakers.net/global/templates/tweakers/images/icons/edit.gif-knopje zit er niet voor niets :o Gebruik deze dus ook i.p.v. meerdere keren achter elkaar te posten!
[ Voor 79% gewijzigd door Crash op 30-11-2006 21:59 ]
  • CrankyGamerOG
CrankyGamerOG
uhmm rapide gebruik edit ipv reply plz
en daarbij, wat heb je zelf al nagezocht waarom je disconnect ?
Ik denk dat je je niet populair maakt door 4x achter elkaar te posten...er is zoiets als een EDIT knop. En binnen 5 min een antwoord op je post verwachten is ook een beetje kortzichtig. Heb je al gepatched misschien?
  • CrankyGamerOG
CrankyGamerOG
hey phoenix, ik was eerder :P
bijdeweg phoenix waar speel jij altijd ? en waar kan ik goed als team spelen online, bf2142 is toch wel heel anders dan bf2 :X
  • Risce
Verwijderd schreef op donderdag 30 november 2006 @ 20:28:
Hench the name.
@Defiance: Hoe bedoel je?
CrankyGamerOG schreef op donderdag 30 november 2006 @ 20:29:
Ik speel nog niet zo heel veel...k vind het wel grappig voor de afwisseling. En wat je zegt...zonder team is er al helemaal geen zak aan. K speel dus alleen als er bekenden zijn. Alleen is maar zo alleen he ;)
Ik speel onder de naam lPhoeniXl (de l zijn de letter L want de echte streepjes werken niet)
[ Voor 12% gewijzigd door Verwijderd op 01-12-2006 00:13 ]
  • Risce
Er is iets verandert aan de masterserver vandaag. De inlog duurt een stuk langer (eerste scherm, waar je je username invult en password) en ik heb vandaag 2 'connection to master server lost' meegemaakt in 2 uur, terwijl ik dat nog nooit heb gehad (heb nu ongeveer 90 uur gespeeld).
Ik weet niet wat ze gedaan hebben, maar het helpt niet iig.
  • CrankyGamerOG
CrankyGamerOG
ik heb daar geen last van hoor, dus ik denk dat het toch echt ergens bij jou moet zijn risce, heb je een router ofzo
  • Stewie!
Stewie!
Keen must die!
Bron: http://www.battlefield2142.nl/?id=462
New patch, new map, new gamemode?
The upcoming Battlefield 2142 could introduce a new gamemode named "supply line". Server statistics of the testing of the new patch revealed also a new map: Garmisch Partenkirchen, after the famous south German bordercity.
Further details are still unknown, let's hope EA takes their time to finish this patch to ensure the quality of the game. We always welcome new maps to play ranked!
We will update you as soon as new information becomes available.
  • Stronkie
  • Laatst online: 23-11 21:28
Stronkie
Where wind is Trouble
Deeltje 3 hier
Tech related problemen horen _niet_ in dit topic thuis!
Post ontopic, dus geen geblaat en slow-chat!
