Hoofdcategorieën
Topicacties
i-mate SPL
Gerelateerde producten
Pagina: 1 2 3 4 ... 9 10 11 12 13 14 15 16 17 ... 27 28 29 30 last
Reageer Nieuw Topic
Powered By Mozilla
quote:
dikakana schreef op vrijdag 16 februari 2007 @ 04:46:
Vraagje: weet iemand hoe je dat irritante geluid
kan uitzetten wanneer je een foto maakt?
heb dit niet in de opties kunen vinden, misschien register tweakje...
Die vind ik ook irritant, maar eens even wat op bedenken..
Zal het a.s.a.p. posten.
// Vond het via google zelfs op got:
quote:
Stap-voor-Stap-uitleg
Sollution to disable Shutter sound on your device:
*First of all download Resco Explorer ( http://www.resco.net/smartphone/explorer/default.asp )
Install this on your device.
*Record with the the standard voice-recorder in windows a wav-file without sound (so simply disable your microphone) make it 5 seconds to make sure it does not have any bad influence on your camera-application.
*Give this file a very simple name starting with an underscore or a number to have it on the top of your list (especially on smartphones the Windows folder is very very long for scrolling) Name it something like "_mute.wav"
* Copy this file from your PC to your device using your windows explorer, put this in the Windows folder on your device
* Now open Resco Explorer on your device, press "menu" , "options" , "browser" and uncheck the "Hide hidden files..." option
* Now browse on your device to the windows folder and locate your mute wav file, now choose "action" , "rename" and give the file the name of the standard shutter sound file (on a Samsung i320 it is "camera_shutter_1.wav" (please do not choose "camera_shutter_ 2.wav" or "camera_shutter_3.wav" because these are first played and afterwards you will get still the "camera_shutter_1.wav"-file)
* You now will get some alert-windows if you are sure etc. just press yes and then.... SILENT SHUTTER IS THERE!
Kaspers wijzigde dit bericht 16-02-2007 07:41 (98%)
de leven is hard
Carpe Aptenodytes!
Reg. datum: 10 juni 2001
Heb dit toestel ook gekocht, maar valt me eigenlijk best tegen...
Hij is breder EN langer dan mijn oude toestel (T-Mobile SDA) en dus alleen platter.
Voor de rest is het toestel 100% het zelfde op het scherm en de camera (en uiteraard het uiterlijk) na. Alles werkt verder prima maar hij is ook niet sneller ofzo, terwijl die SDA uit december 2004 komt...
En omdat ie zo plat en breed is vind ik 'm eigenlijk ook niet zo fijn in de hand liggen. Ga 'm denk ik weer verkopen en wachten tot er iets nieuws op de markt komt :)
http://img402.imageshack.us/img402/205/spl1hh5.jpg
http://img230.imageshack.us/img230/1117/spl2yg5.jpg
Desktop: AMD X2 5000+ - 780G - 6GB RAM - 2x 640GB raid0 + 1TB - 20" Samsung 206BW
Laptop: IBM ThinkPad T41 - P-M 1600 - 2GB RAM - 60GB 7200rpm - 14" SXGA+
Lost
Reg. datum: 05 mei 2004
quote:
sander- schreef op donderdag 15 februari 2007 @ 22:32:
En als je per ongeluk de hoek van een tafel meeneemt dan?
Laat ik het anders zeggen: Op dit moment heb ik een Nokia 6230 die meerdere keren per dag ernstig in aanraking komt met sleutels, vloeren, muren etc en waar op het scherm nog geen enkele hinderlijke kras zit. Terwijl ik het gevoel heb dat als ik de imate 1 dag in mijn zak vervoer hij helemaal naar de knoppen is. Het schermpje is zooo krasgevoelig. Had daarom ook eigenlijk wel verwacht dat mensen hier al screenprotectors zouden hebben.
Ehh... handiger worden? Een bril? Zo'n rood-witte stok met een mooie grote zwarte zonnebril?
Sorry hoor, maar als ik jou zo lees, dan zou ik op zoek gaan naar een metalen behuizing van een paar centimeter. Ik gebruik mijn toestel erg intensief en hij ziet er nog prima uit. Ik neem aan dat je begrijpt dat een bos sleutels bij je toestel in de broekzak iets met het toestel doet. Dan moet je niet te verbaasd zijn als er krassen op komen.
When I die, I want to die like my grandfather, who died peacefully in his sleep. Not screaming like all the passengers in his car.
Reg. datum: 18 juni 2004
quote:
roma0803 schreef op vrijdag 16 februari 2007 @ 18:27:
zoals ik al zei: Ik doe geen sleutels erbij in mijn broekzak. En spotten met blinde mensen vind ik ook totaal niet gepast in deze. Als je je telefoon gewoon normaal gebruikt dan valt hij nou eenmaal wel eens of loop je ergens langsaf. En bij de imate is mij dat dus 1 keer gebeurd en toen had ik een diepe kras in het scherm. Terwijl mijn 6230 al 2 jaar los in broekzak zit en nog steeds een nagenoeg krasvrij scherm heeft.
Reg. datum: 18 februari 2007
quote:
Kaspers schreef op vrijdag 16 februari 2007 @ 07:39:
Hmmm het bestandje heet ShutterSound.wav
Die kan ik niet wijzigen cq verwijderen, hij staat op read only en gek genoeg kan ik dat niet verander.
Reg. datum: 07 april 2002
Is die WM6 update er al?
En welke software kan ik gebruiken als navigatiesysteem op de SPL?
Powered By Mozilla
quote:
Nee
quote:
waardd schreef op maandag 19 februari 2007 @ 19:30:
TomTom
de leven is hard
Hallo, nu heb ik ook wat,
Ik heb een imate spl overgenomen van iemand en mijn telfort sim erin gezet.
Alles werkt perfect.
Ik kon alleen niet internetten, instellingen kreeg ik niet voor elkaar van telfort.
Nu heb de optie van rabobank wap en gprs aangevinkt en nu doet hij het wel!
Met andere woorden: met mijn telfort sim internet ik nu via de Rabo?
Kan dit?
Ik heb net even mijn prepaid saldo gekeken, die was 5,64
Daarna even een aantal pagina's geopend en toen weer saldo bekeken,nog steeds 5,64.
Op wie z'n kosten heb ik dan net geinternet?
quote:
Dank je voor de zeer korte uitleg ;)
Maar welke tomtom kan ik dan het beste gebruiken? Waar kan ik die vinden ? en hoe installeer ik hem?
Ik heb al een tomtom geprobeerd en een route 66 maar beiden lopen elke keer vast.
Powered By Mozilla
Mm ik heb daar helaas geen ervaring mee, maar ik heb in dit topic gelezen dat TomTom moet werken..
de leven is hard
Reg. datum: 18 juni 2006
quote:
waardd schreef op dinsdag 20 februari 2007 @ 00:59:
Volgens mij moet je TomTom 5 hebben, dus niet de nieuwe 6. But don't quote me on that.
Acer Aspire 5920G || HTC TyTN II || Microsoft Zune
Lost
Correct, TomTom Mobile 5.20 is de versie die op de SPL werkt.
Ik ga Rabo Mobiel m'n geld terug vragen. 3e Toestel, zelfde problemen na GPRS. Ben er doodziek van.
Waar kan ik die versie 5.2 dan nog vandaan halen tegenwoordig??
TinuX wijzigde dit bericht 21-02-2007 21:05 (8%)
Lost
Tja, da's een goeie. Ik denk niet meer legaal.
quote:
roma0803 schreef op dinsdag 20 februari 2007 @ 11:27:
Hou me even op de hoogte. Ik overweeg hier hetzelfde en ben ook van plan om Rabomobiel te gaan vertellen dat ze de telefoon + het abbonement maar mooi terug mogen nemen.
Zo ver was ik ook al "Lost" ;)
Heb je nog ideeen?
Powered By Mozilla
Bitorrent ?
Usenet ?
de leven is hard
Reg. datum: 20 februari 2007
Thuis draait er een windows exchange 2003 server. Deze server is geconfigureerd voor pushmail. Op een ander merk toestel werkt pushmail.
Alleen op de i-mate niet. We hebben eerst de registry geunlocked met een tooltje en daarna de registry geedit zoals in dit topic te vinden. Toch draait het niet. Het geeft een foutcode die duidt op problemen met het netwerk..zijn er mensen die mij op weg kunnen helpen? Op de i-mate staat gewoon mobile 5 en verder heb ik alleen tomtom 5 er op werkend.
Modbreak:
Da's geen zuivere koffie. We zien hier liever geen warez! :)
TinuX wijzigde dit bericht 21-02-2007 21:07 (82%)
Lost
quote:
ceesdg schreef op woensdag 21 februari 2007 @ 18:58:
Klinkt als GPRS instellingen die niet goed staan.
Nou, ik krijg ook nog steeds geen verbinding met internet via gprs.
Ik heb een telfort kaartje erin, het enige wat ik wel kan is bellen.
Is dit misschien het probleem:?
Ik probeerde mijn IMEI code te veranderen in mijn telfort site.
Nu kreeg ik: ONGELDIGE IMEI CODE??
Even bekeken en...IMEI code in toestel wijkt af van de code op het stickertje in de doos!
Wat nu?
Nou, en dat was dan een live chatsessie met support van clubimate..die vent wist echt niks, had ik het hele verhaal uitgelegd liet ie gewoon niks meer horen zodat een sessie timeout optrad en nu niet weer in kan loggen...tssss
Ok, nog een keer geprobeerd en kreeg de aardige "chloe" aan de andere kant.
Die zei dat ik de ROM moest updaten en heb SPL WWE SETUP V1.90 gedownload van de clubimate site.
In de SPL staat versie V 1.05 dus kan alleen maar beter worden...of niet?:)
durf het alleen nog niet aan, straks ben ik álles kwijt...
Maar aan de andere kant...alle rabo shit is er dan wel af..hahaha
Ik denk er nog even over na.
quote:
whibbit schreef op woensdag 21 februari 2007 @ 19:43:
[modbreak]Da's geen zuivere koffie. We zien hier liever geen warez! :)[/]
Sorry, mag dit dan wel?
tomtom 5.2
http://gsm-telecom.marktp...g4jAK%2F68lc%2FnltVYAY%3D
VNU Media logo Hosted by True
© 1998 - 2009 Tweakers.net - Alle rechten voorbehouden - Uw Privacy - Algemene Voorwaarden
Uitgever van:
