• Alpha-sphere
  • Laatst online: 14-12-2021
De verbeteringen
Active Idle
* Active standby mailbox settings moved from Messaging/Options/Settings/Other to Tools/Settings/Phone/Standby mode
* Missing texts added to Active standby mailbox settings
* Active standby mailbox setting is now included in backup and restore
Application installer
* Not possible to launch some downloaded game.
Email
* Sound (or vibration) alert is added to Blackberry email)
Calendar / PIM
* Improvements to exception handling in recurring calendar notes.
* Improvements to end times handling with Calendar Memos.
* Support to RTF files added to Notepad.
* E61 keyboard support improved in Calculator for calculator Operands for languages where supports was missing
Contacts
* Changing the order of order corrected are in Malaysia language.
* Large vCard which received by IrDA can not be saved or deleted.
* Possibility to set Unprotected 3gpp2 and wma audio files contact's ringing tone removed
Office tools
* Sheet, Presentation and Documents mixed localisation improved to English only
Device Management
* Beep added to DM Server connection request Notification
* Application installation improved in first connection to DM server
* Policy handling improved in first connection to DM server
Synchronisation
* Increased robustness of recurring event synchronisation
* Synchronisation overall reliability extended
* Added support for larger data amounts
* Synchronisation fails if entering more than 2 entries in Calendar of the handset with synchronisation setting as "None".
* Added support for synchronisation while device is locked
* Device specific suspend-resume functionality added
Backup & restore
* Improvements to overall reliability and performance
* The backup function of PC Suite can not be used when the data folder of the UE registered files to be full.
DRM
* CFM protected files do not show the correct icon in the gallery.
* No icon is displayed next to DRM FL files to indicate DRM protection.
* E61 does not support ring tone=no eCFM flag.
RealPlayer
* Streaming maximum bandwidth increased in EGPRS from 65.28 kbps to 84.42 kbps and in WLAN from 268.80 kbps to 1 Mbps
Audio
* Audio quality improvements
Java: * Performance improvements.
* Ram consumption reduced.
* Canvas graphics scaling faster.
* Midlets installation and launching:
* ?!? (Exclamation mark) can be handled in URL.
* Midlets installing and launching process is more stable.
MMAPI improvements
* TempoControl.setTempo(int) now returns correct value.
* Audio and video works more stable/smooth during real time streaming.
* Hebrew strings are not mirrored in Forms.
* Cannot run the midlet from CMCC Java server.
SIM
* It is no longer possible to changes line when there is no ALS support in SIM.
* Improvement in Dual IMSI SIM handling.
SIM ATK
* Automatic and manual IMSI change with SIM ATK is supported, and SMSC number is automatically updated to text message settings
* Improvement to SIM toolkit command "SEND USSD.
Web Browser
* Improvement to pull-down lists, Browser is crashed when pressing "Select" key repeatedly during the display of pull-down list.
* Improvement to security icon functionality, There is a discrepancy on the states of the handset upon cancelling the moving process from http:// to https://
* Improvement to browser Tel URI support
Services (WAP Browser)
* Improvement to receiving multiple Push messages.
MMS
* Improved MMS handling when active BlackBerry connection.
Telephony
* Improvement to always on Email connections in situations where PDA shut off by low battery
* Home Zone indication not anymore shown during active 3G PS connection/download
* Improved context activation time in PS dialup (based on the PPP handshaking with MS Windows)
* Improvement to sending USSD short codes after the USSD menu has
* timed-out
* Always On functionality added for H3G
Wanneer wordt VOIP nou een beetje gefixed?
Assume there are no rules and it's one big free for all
  • janklp
  • Laatst online: 11-06 09:59
janklp
FortyTwo Capital
Pas hier mee wel op want het is al bij verschillende mensen fout gegaan!!
Ik doe het vooralsnog iig niet.
  • dentify
Bij mij is het gelukkig perfect gegaan :)
Januszjes schreef op maandag 11 september 2006 @ 23:36:
Het kan altijd misgaan, een beetje risico is wel spannend :)
Hoe dan ook, Nokia zegt:
My phone "died" during an update, who pays for the repair costs?
If the phone is within its warranty period, Nokia will repair the phone under the usual warranty terms and conditions.
If the phone is not within its warranty period, Nokia is not liable for any loss as defined within the End-User Software Agreement.
  • Attilla
  • Laatst online: 23-06-2021
Alpha-sphere schreef op maandag 11 september 2006 @ 23:35:
De verbeteringen
Welke problemen heb jij met VoIP dan ?
  • Pindkaas
  • Laatst online: 01-11-2025
Pindkaas
Smeert smeuïg tot...
Ik had meegekregen dat dat alleen de E70 betreft.
"Luie mensen worden ook moe!"
  • Ross
  • Laatst online: 22-12-2025
Ross
Live Life
mijne is door update dood. Hij is er mee opgehouden tijdens update en doet nu niets meer. Wordt ook niet meer door pc herkend. Dus pas op! :( :( :(
ola
  • Pindkaas
Pindkaas
yah schreef op dinsdag 12 september 2006 @ 09:18:
Nouja, dan rijdt je even naar een Nokia Service point en dan kunnen zij het volgens mij wel voor je oplossen. Je hebt immers garantie.
  • D2k
  • Laatst online: 09-01 11:25
D2k
mijn e60 nu dus ook :(
Doet iets met Cloud (MS/IBM)
  • Pindkaas
Pindkaas
Gaat het nog wel goed bij mensen??
Ik wacht ook nog wel even met het updaten..maar ik zou voor diegene die het wel gaan doen gewoon willen aanbevelen om de E61 en je kabel mooi netjes en vrij op de tafel te leggen..zodat je tijdens de update de kabel en verbinding niet kan verstoren. Want het is vrij logisch dat je telefoon dood gaat als de update tijdens het updaten gestoord wordt. Het is niet een pc die standaard een bios houdt die blijft werken als je je windows installatie verneukt. Als je bios update ook verneukt is, dan moet die chip ook vervangen worden.
Kortom, lees alles even goed rustig door, leg alles goed rustig klaar en probeer niets overhaast..
  • Pindkaas
Pindkaas
Ik heb net mijn E61 geupdate, je moet alleen niet gaan freaken wanneer het scherm voor een paar minuten grijs wordt en het lijkt alsof je computer geen progress maakt. :) Verder helemaal goed gegaan.
Yep hier ook volkomen goed gegaan.. idd niet onrustig worden (wat ik wel begrijp) als je com een paar minuten niets doet...
  • Ross
Ross
Live Life
Ik heb alles volgens het boekje gedaan en wordt niet ongeduldig als die geen progress maakt. Programma zei dat het was MISLUKT. dus ik heb het opnieuw geprobeerd. Zelfde resultaat. Sindsdien helemaal dood. Service point heeft m ook niet kunnen flashen. Hij gaat nu naar nokia.
ola
...Nu nog Mac-ondersteuning, en ik ben helemaal gelukkig... :P
fb_slim schreef op zaterdag 09 september 2006 @ 19:13:
Heeft iemand al de krusell classic case om zijn E61? Of kan iemand een case aanraden. Het liefst geen plastic over de toetsen en wellicht ook niet over het scherm, daarvoor een protect laagje (welke?)
Ik heb deze via Ebay gekocht. Niets over de toetsen.
http://cgi.ebay.nl/CRYSTA...ZWD1VQQrdZ1QQcmdZViewItem
Verwijderd schreef op maandag 11 september 2006 @ 14:40:
weet iemand al of er een alternatief is voor Agile Messenger? Waarvoor je sinds kort voor moet betalen..
Ja ben ik dus ook benieuwd naar. Zijn wij de enige die deze gebruiken???? :P
  • Peter Power
Verwijderd schreef op dinsdag 12 september 2006 @ 17:27:
Ik zoek mee!
irc.tweakers.net #php - Het channel voor de echte PHP-ers!
  • Peter Power
Ik luister veel muziek en podcasts op de E61. Wat is jullie ervaring met andere Nokia headsets? Het standaard meegeleverde mono oortje is niet ideal.
Is het ook mogelijk om radio te luisteren via een ander nokia headset? De applicatie om de zender te selecteren staat namelijk niet op de E61.
Voor een overzicht, zie http://www.nokia.nl/NL/Accessoires/index.html en dan even doorklikken...
Verwijderd schreef op dinsdag 12 september 2006 @ 16:41:
http://www.e-series.org/archives/15
Enjoy ;)
Hoi! Dit is mijn eerste post op dit forum.
Probeer als alternatief voor Agile Messenger deze eens: http://www.nimbuzz.com/
Is een mooi gratis alternatief. Het is nog in de Beta fase, maar werkt bij mij prima!
  • janzeeschuimers
  • Laatst online: 08-11-2024
Verwijderd schreef op dinsdag 12 september 2006 @ 22:56:
@robje76
of deze www.nootmobile.com
  • TriXje
  • Laatst online: 22-06 19:51
heeft er nog iemand last met een fout bij het openen van pdf bestanden, hij zegt altijd "bestandtype niet ondersteund. 5."
TriXje schreef op woensdag 13 september 2006 @ 00:04:
FF Adobe Reader installeren:
http://www.nokia-asia.com/nokia/0,,91844,00.html
  • TriXje
Adobe reader is standaard geinstalleerd, wat nu?
  • janzeeschuimers
TriXje schreef op woensdag 13 september 2006 @ 00:54:
@TriXje
Bij mij was Adobe reader niet standaard geinstalleerd.
(niet op mijn e61 en ook niet op mijn e60).
Die is er:
http://web.mac.com/mac.tomster/iWeb/mactomster/isync.html
Succes!
CNN op je E61
http://eu.handmark.com/xhtml/downloads.xhtml
klik op installeren onderaan de pagina en blijf op de hoogte van internationale nieuws ontwikkelingen.
Kan natuurlijk ook via RSS maar hier zitten thumbnails bij.
  • Alpha-sphere
THANKS!!!!!! Deze werkt echt super :)
Heb alleen even m'n tijden moeten aanpassen :P de vorige isync oplossing had nog problemen met zomertijd enzo.
  • fb_slim
  • Laatst online: 02-12-2021
thx voor alle info!
  • fb_slim
Verwijderd schreef op vrijdag 15 september 2006 @ 00:44:
CNN op je E61
Deze site is echt top (en bevat veel van jullie links): http://e-series.org/
Ook VOIP oplossingen las ik, nog niet geprobeerd...
  • René van Gaalen
  • Laatst online: 25-10-2024
Contacten sychroniseren wil maar niet lukken bij mij, ik snap er niets meer van.
Vandaag een nieuwe E61 gehaald, accu volgeladen en direct de nieuwe firmware erop gezet.
Hierna heb ik eerst de contacten (555 stuks) gesychroniseerd.
Alles lijkt normaal te verlopen, zowel in de E61 als ook op de pc zie ik dat de contacten gesygroniseerd zijn in het scherm.
Als ik nu in de E61 naar contacten ga dan staat er niet een in en er word een waarschuwing gegeven dat de contacten al in gebruik zijn.
In pc suite op de pc geeft het logboek aan dat er 555 contacten niet ingevoegs kunnen worden in de mobiele telefoon.
Wat kan hier de oorzaak van zijn, heb alle instellingen na gelopen maar zonder resultaat.
Wie heeft wat voor geheugenkaartje in z'n E61, en: ben je er tevreden mee?
...Ben benieuwd... :P
ik ben zeer tevreden van dit toestel enkel zou ik graag avi bestanden willen afspelen.
zijn er programmas voor de nokia e61 om dit te doen
alvast bedankt
  • Pindkaas
Pindkaas
Weet iemand hier of je in realplayer ook nog iets anders kan afspelen dan 3gp files (H.623) Volgens mij moet hij ook mpeg4 kunnen afspelen, maar dat is me nog niet gelukt.
ook bevalt het me niet dat je perse die resolutie van 352x288 moet gebruiken..
Wellicht dat smartmovie dit kan, maar ik ga er absoluut niet voor betalen..(omdat ik het gewoonweg alleen maar leuk vind om een keer mee te spelen.
  • fb_slim
René van Gaalen schreef op zaterdag 16 september 2006 @ 13:12:
Wellicht een stomme vraag terug, maar heb je Outlook geinstalled? Zonder Outlook kan je niet synchroniseren...
Pindkaas schreef op zondag 17 september 2006 @ 15:41:
Je kunt films ook omzetten naar mpeg4 (mobile mp4), betere kwaliteit dan .3gp en de resolutie zet je gewoon op 320 x 240.
Via Quicktime lukt het me nog niet, maar met het programma Visualhub (ff Googlen) wil het perfect: superscherp beeld, geen vertragingen en prachtig geluid. Alleen: kost je wel € 20... :(
  • René van Gaalen
Wellicht een stomme vraag terug, maar heb je Outlook geinstalled? Zonder Outlook kan je niet synchroniseren...[/quote]
Ja, outlook 2003.
Het vreemde is dat ik eerder met een E 61 hetzelfde probleem had, deze heb ik terug gebracht en geruild voor een nieuw toestel maar helaas met hetzelfde probleem.
Een Nokia 6230 geeft geen problemen overigens met de zelfde settings.
Ook een SE 990! geeft geen problemen met de SE software.
Ik ben er inmiddels wel achter gekomen dat als ik maar 50 contacten in een nieuwe contactenlijst zet die wel worden gesychroniseerd.
Wil ik er daarna echter weer 50 wegschrijven uit dezelfde map dan krijg ik weer een probleem.
Op de Nokia gaat dan een cursor streepje knipperen op het scherm links onderin.
Een adres waar ik in outlook een notitie heb toegevoegd geeft trouwens nog een ander probleem, de notitie word in de nokia namelijk niet geopend.
Ik vind het vreemd dat ik de enige met dit probleem ben, zijn er hier mensen die wel honderden adressen met veel adresgegevens per adres naar het toestel krijgen gesychroniseerd?
Ik zoek een transparante siliconen hoes voor mijn E61, zijn deze al in nederland verkrijgbaar ?
  • fb_slim
Verwijderd schreef op zondag 17 september 2006 @ 17:57:
Het is alleen voor de mac beschikbaar helaas...
  • fb_slim
Als ik via een Sitecom CN-512 eenbackup van mijn telefoon probeer te maken duurt dan A. erg lang en B. hij loopt vast bij 80%. Hebben anderen dit ook en is er een oplossing voor?
fb_slim schreef op maandag 18 september 2006 @ 11:51:
Da's waar, maar Pindkaas heeft ook een Mac... ;)
  • Pindkaas
Pindkaas
Verwijderd schreef op maandag 18 september 2006 @ 16:38:
Klopt helemaal, ik gebruik ffmpegx
Even zien of het me daar ook mee gaat lukken, hij kan ongeveer elk formaat er uit gooien dus dat moet dan wel toch? :)
ffmpegx gebruik ik ook, maar daar krijg ik mp4 (mpeg4) nog niet op gedaan; hij speelt 't niet af op de telefoon... :( En de kwaliteit met Visualhub is gewoon veel beter, het staat nog op mijn 'to-buy' lijstje (samen met een hele hoop andere dingen... :P )
  • Uberprutser
  • Laatst online: 08-07 17:36
Lijkt erop dat ik een vervanger voor mijn Blackberry heb gevonden en dan met IMAP ipv push mail.
Nu nog een beetje een goedkope zien te vinden aangezien ik mijn abbo al verlengd heb vorige maand...
As you may already have guessed, following the instructions may break your system and you are on your own to fix it again.
ik heb gisteren diverse RSS readers geinstalleerd, maar geen een heeft wat ik zoek: de mogelijkheid om nieuwe header/berichtkoppen op het hoofdscherm van de E61 te laten zien (bv onder items van de agenda oid). Iemand al zoiets gevonden ?
  • wace
  • Laatst online: 21-06 21:01
Verwijderd schreef op dinsdag 19 september 2006 @ 08:36:
Dat zou cool zijn idd, ik ben benieuwd!
  • Reintjuhh
  • Laatst online: 11:07
Heeft iemand al getest of Tomtom Mobile 6 met de Nokia LD-3W GPS receiver werkt op de E61.
Hi, mn collega heeft TomTom6 werkend op de E61 icm de Adapt AD-300
greetingz
  • Alpha-sphere
Heb TT6 i.c.m. een LD-3W en het werkt goed :)
  • Bram
Bram
Alpha-sphere schreef op woensdag 20 september 2006 @ 12:07:
Gaat het nog een beetje vloeiend wanneer je aan het navigeren bent?
Even een vraagje: je kan aan een contact een plaatje (thumb) vastmaken, zodat deze getoond wordt als die persoon belt. Dit plaatje is helaas maar heel klein, 1 bij 1 cm ofzo (als het groter is verkleint de telefoon hem automatisch). Kan je ergens instellen dat het plaatje groter wordt weergegeven, of heb je hier echt aparte software voor nodig ?? :?
  • Alpha-sphere
Bram schreef op woensdag 20 september 2006 @ 13:44:
Ga ik zo uitproberen :)
Verwijderd schreef op woensdag 20 september 2006 @ 13:52:
Je hebt apparte software ervoor nodig genaamd fullscreen caller ofzo
  • Alpha-sphere
Ik heb net even tomtom aangezet in de tram en het loopt best goed moet ik zeggen :) Niet onwijs langzaam ofzo. Lopend gaat dan weer niet helemaal goed. tomtom denkt dat ik een auto ben ofzo :S zelfs na het veranderen van de plannings-voorkeuren naar "altijd een wandel route" gaat het niet helemaal lekker.
Goedenavond,
Sinds ik de firmware van de E61 een update heb gegeven heb ik iets raars:
Als ik een e-mail stuur (maakt niet uit van welke account) naar iemand uit mijn contactenlijst, stuurt de E61 automatisch ook deze mail naar <achternaamcontact>@bos.nl !!!!!
Kan iemand dit verklaren? Is er een oplossing? Hebben andere E61 gebruikers dit ook?
Ik gebruik T-Mobile met Pocket internet Totaal.
Groet, Pim
  • janzeeschuimers
Bij bestandsbeheer staat RNEngineUser.cfg wat is dit voor een programma ?
Ik kan het ook niet verwijderen (telefoon geeft aan "kan niet verwijdert worden omdat het programma draait") , het programma staat er sinds 2 dagen op en de telefoon heeft alleen maar off line gestaan en geen wifi verbinding etc.gehad.
Dus wat voor een programma is RNEgineUser.cfg en hoe komt het op mijn telefoon?
[ Voor 11% gewijzigd door janzeeschuimers op 20-09-2006 22:36 ]
  • Ross
Ross
Live Life
mocht je de update doen, verwijder autolock dan eerst van je e61. Ik heb het idee dat de mijne daardoor is gecrasht met update.
ola
  • arnoman
  • Laatst online: 09-07 11:44
Ik vind al de GPS ontvangers die werken op de E61 icm TT6 zo duur. Zijn er geen alternatieven van <50€? Of kleven daar nadelen aan?
Ik ben nog eens flink aan het zoeken geweest en ik kan allerhande RSS applicaties vinden (headline, newstouch, rssnews! , maar ze werken allemaal met abonnementen (?). Heel apart allemaal...
Ik zoek gewoon een simpele RSS reader die het volgende moet kunnen
- zelf RSS feeds opvoeren
- via WIFI kunnen synchroniseren
- het synchroniseren van alle feeds in 1 keer (dus niet per feed)
- alles offline kunnen lezen
- liefst gratis.
Ik had zoiets gevonden (RSSManager), maar die kan helaas niet alles ineenkeer synchroniseren (alleen per feed). Dat is onwerkbaar. Ik wil gewoon sochtends ff snel op een knopje synchroniseren kunnen drukken zodat ik het nieuwste nieuws mee kan nemen naar mn werk e.d.
Iemand suggesties??
  • Pindkaas
Pindkaas
Heeft er iemand een idee hoe ik een bestand dat ik ontvang via bluetooth kan verplaatsen naar een map op bv. mijn sd-kaartje??
Ik heb ze al in alle mogelijke bestandsformaten gestuurd, maar mijn telefoon ziet het steeds als een tekstbestand. ook heb ik het geprobeerd te mailen.. ik kan wel "save" kiezen, maar dan zegt ie " file saved" en verder niet waar of wat er gebeurt is..
@Pindkaas: kun je niet kiezen als, 'opslaan als'? Dan kun je 'm meestal opslaan op je miniSD. Ik kan het in ieder geval wel op mijn kaartje opslaan. Wil dit niet, probeer anders eens met een programma als Filexplorer (o.i.d.), en verplaats het bestand dan gewoon van je C schijf naar je kaartje.
Over geheugenkaartjes gesproken... :P Ondersteunt de E61 ook 2GB (miniSD) kaartjes? Of gaat 'ie maar tot 1 GB?
  • Pindkaas
Pindkaas
Verwijderd schreef op donderdag 21 september 2006 @ 14:29:
Ik kan niet kiezen voor opslaan als.. alleen save.. het komt dan in een of andere beveiligde map te staan waar je met geen enkel programma bij kan.
bij mij werkt 2GB als een zonnetje
Ik heb een Vodafone abbo, maar weet niet goed hoe ik kan browsen over de UMTS lijn. Iemand een idee?
  • Reintjuhh
Pindkaas schreef op donderdag 21 september 2006 @ 13:52:
Ik kamp dus met hetzelfde probleem. Volgens mij komt het ook niet op je SD-kaart terecht, maar echt in het telefooongeheugen. Vervelend.
  • Alpha-sphere
arnoman schreef op donderdag 21 september 2006 @ 11:44:
€50,- en lager is wel erg weinig voor een GPS ontvanger. Ongeveer €65 ~ €100 is normaal.
Nadelen, als je ze voor die prijs vind, kan zijn dat de chipset die erin zit oud is. Bijvoorbeeld nog een sirfstar II. Deze is minder nauwkeurig en misschien nog wat minder standby of navigatie tijd voor je weer moet laden. Ik vind mijn LD-3W van nokia super. Kan zelfs de ontvanger onder m'n stoel leggen en er is nog goed bereik. :)
ik heb me al suf gezocht naar software waarmee je naar de Belgische internet radiostations kunt luisteren, de lijst vind je op http://www.digitaleradio....c/help/Links_streams.html
een voorbeeld is http://mp3.streampower.be/donna-low
via de PC lukt het perfect (windows media player wordt automatisch geopend), via de telefoon krijg ik het niet aan de praat, iemand die het werkende heeft of kan laten werken ?
Is het mogelijk om eventueel andere agenda software op de E61 te zetten ? Ik gebruik nl. geen outlook maar thunderbird van mozilla. Thunderbird zal wel niet ondersteund worden maar misschien kan een ander agendaprogramma ook.
Ben nl. op zoek naar een goede agendafunctie. Heb lang getwijfeld tussen de 9300i en de E61 en uiteindelijk de E61 gekozen.
  • Pindkaas
Pindkaas
Reintjuhh schreef op donderdag 21 september 2006 @ 21:02:
Ik heb het nu opgelost door de telefoon direct aan de pc te hangen via usb en dan kiezen voor "data stream" (zoiets iig) en dan kan ik direct op de SD schrijven en lezen.
Weet iemand misschien hoe je de icoontjes en opmaken van je main screen kan aanpassen?
Verder zoek ik een alternatief voor Psiloc Hotspot Finder. Ik vind het echt jammer dat je niet kan zien of een hotspot beveiligd is of open.
Momenteel heb ik een trial van Agile Messenger. Is er toevallig een andere MSN client die minimaal evengoed werkt, maar bijvoorbeeld gratis is?
Ook weer zo vreemd. Vodafone biedt de mogelijkheid om een sms te ontvangen als iemand geen boodschap heeft achtergelaten in je voicemailbox. Mijn E61 ontvangt de sms, maar na een halve seconde gooit die hem doodleuk weg (dit kan ik zien doordat ik mijn inbox op het standby scherm actief heb).
Iemand al ervaring met de Nokia Mobile Holder CR-47 ?? Op de nokia site zie ik namelijk deze alleen van voren staan, dus ik vraag me af hoe je hem bevestigd, en of hij gedraait kan worden (tilt swivel) ? En kan je er je autolader in stoppen zodat je die niet telkens apart in nokia hoeft te pluggen als je deze in de houder zet?
Het wordt me namelijk niet echt duidelijk van de NOkia site..
http://www.nokia.nl/NL/Telefoons/Modellen/E61/acc_car.html
Iemand enig idee hoe je ervoor kan zorgen dat applicaties blijven draaien op de achtergrong? Als ik nu check heb ik altijd alleen standby scherm staan.
  • Ross
Ross
Live Life
als je menu knop ingedrukt houdt zie je de applicaties die op achtergrond draaien en kan je zo switchen
ola
  • Pindkaas
Pindkaas
yah schreef op maandag 25 september 2006 @ 13:41:
volgens mij begrijp je het niet. Hij bedoeld volgens mij hoe hij applicaties kan laten draaien op de achtergrond, zonder dat ze afsluiten wanneer je op 'de rode knop' drukt.
Mijn 6670 liet ook applicaties draaien. Het is wel fijn wanneer je een gps registratie applicatie je eventueel ook je telefoon op toetsblokkering zetten kan.. Of dat tomtom niet meteen afsluit wanneer je op 'de rode knop' drukt.
Dat wist ik, maar ik zou soms een applicatie daarin willen hebben, terwijl die blijkbaar stopt. Meer precies is dus of ik kan instellen welke applicaties op de achtergrond mogen en kunnen draaien en welke niet.
  • Sick Nick
  • Laatst online: 13:52
Sick Nick
Drop the top!
Je progje starten en dan de menuknop gewoon ingedrukt houden. Dan kies je daar voor standby, en je prog blijft gewoon draaien.
  • fb_slim
als ik op de portal van vodafone probeer te komen via mobile.vodafone.com dan werkt dit niet in de internetbrowser, logisch: het is een wap site...maar hoe kan ik deze wel openen?
  • Speedfight
Zijn er hier ook mensen die een Windows Mobile telefoon gehad hebben en nu overgestapt zijn naar Symbian OS en hoe beviel dat? Heb namelijk nu nog een SPV C500 en zit te twijfelen tussen een Samsung i320 en de Nokia E61.
Vaillant aroTHERM plus VWL55/6, Zehnder WHR 930 WTW, Itho Daalderop douche-WTW, SolarEdge SE6K 6610Wp, SE3000H 3160Wp, Tesla Model Y Juniper RWD
  • Alpha-sphere
Ik heb zelf gewerkt met Windows mobile, Palm en Symbian S60 en ik moet zeggen dat S60 me heel erg goed bevalt. Zeker met een toetsenbord. WM vind ik een zooitje vergeleken met Palm en S60. Je kan WM vergelijken met m'n website. Overal kleine foutjes kwa programmeren maar toch voeg ik er elke keer nieuwe dingen aan toe in plaats van opnieuw bouwen en de foutjes herstellen.
Maarja, dat is mijn mening en iedereen gebruikt het ergens anders voor.
  • Speedfight
Alpha-sphere schreef op dinsdag 26 september 2006 @ 00:23:
Ik hou zelf wel van een beetje prutsen en software testen op de telefoon, dit was bij WM altijd wel leuk. Maar volgens mij zijn er voor Symbian ook heel wat progjes te vinden. En outlook syncen moet volgens mij bij geen enkele smartphone meer een probleem zijn. Denk dat ik hem binnenkort maar eens in een winkel ga bekijken!
Zoek alleen nog een geschikte provider die een goedkoop beltarief heeft en waar je voor niet al te veel geld nog een beetje van gprs gebruik kan maken voor wat websites en emaill....
  • Sick Nick
Sick Nick
Drop the top!
Zodra je overstapt van WM naar Symbian kan je alleen NIET meer je email die alleen lokaal in je outlook ofzo staan syncen met je telefoon. Met WM komt het dan gewoon in pocketoutlook, maar met Symbian gaat dat niet meer. In ieder geval niet met de E61 of andere S60 (al dan niet V3) telefoons, ik heb zelf een E50. Het kan geloof ik wel met de communicator telefoons, die draaien Symbian S90 geloof ik.
Enige manier om alsnog al je email op je telefoon te hebben is om dus al je mail op een imap server te gooien en die dan benaderen via de email client. Dat was voor mij een flinke tegenvaller, ik had hiervoor namelijk een mda vario met WM5 erop. Had dit niet verwacht eerlijk gezegd. Contacts en agenda gaat wel prima overigens.
  • Speedfight
Sick Nick schreef op dinsdag 26 september 2006 @ 11:26:
Bedankt voor de info! Maar kan je wel direct met Exchange je mail syncen of is dat ook niet mogelijk?
  • Sick Nick
Sick Nick
Drop the top!
Ja, exchange mailsync werkt prima. IMAP doet het ook gewoon en blackberry en nog een hele reeks pushmail varianten zijn ook beschikbaar.
Ik heb mijn mail dus allemaal op een imap server gezet zodat ik ze alsnog overal kan bekijken.
Ik gebruik ProfiMail. Je kan dan wel niet alle mail vanuit je Uitkijk erin zien, maar je kan wel mail binnenhalen op je telefoon om deze vervolgens wanneer gewenst ook binnen te halen op je pc.
[ Voor 21% gewijzigd door Verwijderd op 26-09-2006 17:23 ]
  • DaannO
  • Laatst online: 02-07 08:12
Nog even wat meer foto`s van de E62: http://www.nokia.com/A4136017?category=e62#
Volgens mij is dit niet een speciale amerikaanse versie :)
  • Hoedje
  • Laatst online: 14:00
Die heeft toch juist EDGE en de 850 band i.p.v. UMTS zodat ie het prima doet in the USA.
"If you get up in the morning and think the future is going to be better, it is a bright day. Otherwise, it's not."
Een echte Tweaker tweakt zelf zijn E61 :D Afbeeldingslocatie: http://www.takeitapart.net/photos/nokia_e61/10.jpg
http://www.takeitapart.net/archives/nokia-e61/
Bestaat er een converter/plugje waardoor ik gewoon een reguliere koptelefoon (mini jack) in mn e61 kan pluggen?
Verwijderd schreef op woensdag 27 september 2006 @ 09:01:
Google even op "AD-15 nokia"
Afbeeldingslocatie: http://i.expansys.nl/i/l/l123913.jpg
Of deze:
Afbeeldingslocatie: http://www.pdashop.be/images/product/image.php?id=9849&dimensionid=1&shopid=7
Brando Pop Port, maar die is net iets duurder zo te zien...
[ Voor 21% gewijzigd door Verwijderd op 27-09-2006 23:18 ]
  • k0ewl
  • Laatst online: 19-06 23:47
Verwijderd schreef op woensdag 27 september 2006 @ 23:13:
Of deze:
er is er nog 1, namelijk de AD-46. Deze heeft ook nog functies om met je headset het geluid harder/zachter te zetten, er zit in microfoon in voor gesprekken en natuurlijk zo'n knop om spraakherkenning aan te zetten of op te hangen. kost iets van € 24,95 online
deze dus:
http://www.telecomtelecom.nl/?p=5&id=7688&ref=1003
Afbeeldingslocatie: http://194.150.224.115/img/prd/std/7688.jpg
[ Voor 12% gewijzigd door k0ewl op 27-09-2006 23:41 ]
A byte walks into a bar and orders a pint. Bartender asks him "What's wrong?" Byte says "Parity error." Bartender nods and says "Yeah, I thought you looked a bit off."
De E62 is een uitgeklede versie van de E61 zonder features als WiFi en UMTS als tegenhanger van de BlackBerry
Ik heb even een klein probleempje: als ik iets wil installeren, dan installeert 'ie het (je ziet de voortgang), maar dan als het balkje vol is, doet 'ie even 3 seconden niets, en meldt dan: 'Kan niet installeren!'.
Dit heb ik bijvoorbeeld met diverse thema's.
Ik heb het sinds ik er een nieuwe miniSD in heb gedaan (die vooralsnog heerlijk werkt).
Iemand die een oorzaak weet, of een oplossing?
Bvb!
  • Speedfight
Kan iemand bevestigen of verzonden sms berichten ook worden opgeslagen?
  • Sick Nick
Sick Nick
Drop the top!
k0ewl schreef op woensdag 27 september 2006 @ 23:40:
deze dus:
En dan heb je ook nog de Nokia HS-20 AD-41, een controler voor de mediaspeler waar je je eigen doppen op aan kunt sluiten. Je krijgt er standaard van die in-ear noise-canceling doppen bij.
Afbeeldingslocatie: http://www.nokia.fi/img/products/hs-20/prodlist.jpg
Afbeeldingslocatie: http://nokia-asia.com/BaseProject/Sites/APAC_18024/CDA/Categories/Home/images/support/phone_support/_Content/_Static_Files/hs-20_126.jpg
  • BoXie
  • Laatst online: 30-03-2023
Speedfight schreef op donderdag 28 september 2006 @ 20:38:
Bij de E60 wel .. dus bij de E61 vast ook ...
  • BoXie
Ik weet eigenlijk nog steeds niet of mijn E60 (zal vast hetzelfde zijn als de E61) nou wel stereo geluid geeft als ik er zo'n AD-15 of andere adapter op aansluit.
[ Voor 12% gewijzigd door BoXie op 29-09-2006 10:34 ]
  • janzeeschuimers
BoXie schreef op vrijdag 29 september 2006 @ 10:34:
@BoXie
Je hebt stereo geluid via de AD-15 (dus alles met een draad ), je hebt geen stereo via de externe speaker en niet via blue tooth.
  • BoXie
janzeeschuimers schreef op vrijdag 29 september 2006 @ 12:45:
@BoXie
Ok dus de telefoon is wel in staat om stereogeluid te genereren dus. Daar ging het me even om.
Thanx.
Heeft iemand al zo'n AD-15 ? Klinkt het ok ? Zou een E60/E61 goed te gebruiken zijn wanneer je de audio op een autoradio aux aansluit? Of hoor je teveel storing bij het overschakelen naar de volgende mp3 ?
Pagina: 1 ... 6 ... 11 Laatste
