[xbox] Xbox media center - Deel V Vorige deel Overzicht Volgende deel Laatste deel
Pagina: 1 ... 5 ... 15 Laatste
  • 25.309 views sinds 30-01-2008
  • GoT
GoT
/ / ( . Y . ) \ \
Bigfoot87 schreef op vrijdag 28 april 2006 @ 16:35:
Normaal gesproken werd dat dus ook altijd gedaan. Daarom vond ik het vreemd :)
Als je kijkt naar de T3ch versie, daar gaat het wel door:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
                                     Xbox Media Center CHANGELOG
added/fixed: (dd-mm-yyyy) (please specify date in CET)
 - 27-04-2006 changed: if contenttype indicate flv, skip probing in dvdplayer (skips one seek)
 - 27-04-2006 fixed: curl (http, shout) would fail to seek after hitting eof.
 - 27-04-2006 fixed: Unnessecary HEAD request to last.fm servers resulting in an error log
 - 27-04-2006 changed: removed old python copy-string from Build.bat since it's no longer needed
 - 27-04-2006 fixed: [ 1463526 ] shoutcast mp2 streaming broken
 - 27-04-2006 updated: python is updated to version 2.4.3 and now moved into a dll. Do not forget to update the system folder
 - 27-04-2006 fixed: [ 1475703 ] LCD and .xbe playing message
 - 27-04-2006 fixed: [ 1475843 ] Freezes with invalid call to xbmcCmds
 - 27-04-2006 fixed: Filemanager didn't show the number and size of the selected objects.
 - 25-04-2006 fixed: [ 1476206 ] zip files don't show subfolders in file manager
 - 25-04-2006 changed: Karaoke display now uses a linear texture (should be marginally faster + less memory)
 - 25-04-2006 changed: Removed mastercode settings from xboxmediacenter.xml - they're now only in the GUI.  Cleaned up the code + GUI look as well.
 - 25-04-2006 updated: Maltese language file (Thnx to michelbugeja)
 - 25-04-2006 changed: dvdplayer now uses xbmc filesystem for shout/http streams instead of it's own. means shoutcast information will be displayed for aacp streams
 - 25-04-2006 updated: dvdplayer ffmpeg to mplayerhq cvs and changed maxstreams to 42 instead of the standard 20 ( don't forget to update your system/dvdplayer dir )
 - 25-04-2006 fixed: directory/file date of iso discs was not read
 - 25-04-2006 updated: Italian language file (Thnx to kotix)
 - 25-04-2006 updated: Chinese (Simple) language file (Thnx to gamepc)
 - 25-04-2006 fixed: subtitles could end up disabled even if they where enabled in dvd menu
 - 25-04-2006 fixed: enable/disable of subtitles with an id higher than 8 would always fails
 - 25-04-2006 fixed: dvdplayer would restart when disabling/enabling substitles
 - 25-04-2006 changed: viz and karaoke is now separated.
 - 24-04-2006 fixed: paplayer can now play shoutcast mp3 streams
 - 24-04-2006 changed: content type is now available in the CFileItem, and thus available to players for codec selection
 - 24-04-2006 fixed: Edit/Delete source (bookmark) did not work properly from UI
 - 24-04-2006 fixed: CFileCUrl::Exists (http reader) would return that a file at the specified url didn't exist even if it really did.
 - 24-04-2006 fixed: if a proxy port was set, shout:// would read unallocated memory.
 - 24-04-2006 updated: German language file
 - 24-04-2006 updated: Chinese (Traditional) language file (Thnx to omenpica)
 - 24-04-2006 updated: Norwegian language file (Thnx to vnm)
 - 24-04-2006 fixed: [ 1474938 ] non UTF-8 coded files displyed incorrectly (ccxstream share)
 - 24-04-2006 fixed: cdgreader tried to load on each frame
 - 24-04-2006 updated: french language file
 - 24-04-2006 fixed: Delete and Rename was disabled for stacked files.
 - 24-04-2006 changed: [ 1042376 ] Recording stops after 100 songs - now goes to 999 songs.
 - 24-04-2006 fixed: Unicode xbe descriptions were mangled.
 - 24-04-2006 fixed: [ 1475007 ] Sending button presses to webserver inconsistencies.
 - 24-04-2006 fixed: Hide File Extensions option applied to formatted labels instead of just filenames.
 - 24-04-2006 fixed: Unicode string input to xbmcgui.Dialog().select"
 - 24-04-2006 fixed: Thumbnail panels didn't wrap around when going up from first item or down from last item.
 - 24-04-2006 fixed: Crash when changing GUI resolution while playing media.
 - 23-04-2006 fixed: If screensaver window is activated externally (via web or python or whatever) it wouldn't register, so would be activated again after the usual timeout.
 - 23-04-2006 fixed: Karaoke is always rendered on top of visualisations.
 - 23-04-2006 fixed: Shoutcast directory did no caching.
 - 23-04-2006 fixed: [ 1474835 ] Cannot add media source after all are deleted.
 - 23-04-2006 added: Player.HasDuration conditional visibility tag.
 - 23-04-2006 changed: "empty CURL created" logs from warning to debug level.
 - 23-04-2006 fixed: Application notification about last.fm trackchanges.
 - 23-04-2006 fixed: Seeking was enabled for media that doesn't support it (last.fm, shoutcast..)
 - 23-04-2006 fixed: Incorrect "CDDB" errormessage when unable to connect to a shoutcast station.
 - 23-04-2006 fixed: Playlist files (strm/pls) containing an url to an online playlist (asx/pls) would not play.
 - 23-04-2006 fixed: Parts of [ 1398400 ] Multiple Bugs (5): Karaoke, Audio, MP3 + CDG Playback.
 - 23-04-2006 fixed: [ 1395189 ] CDG Seeking loses sync,  [ 1450824 ] Lyrics Lose Sync on FF / RW. Stup duping bug reports already!
 - 23-04-2006 fixed: bug in samba port code for retrieving directory listing from old lanman servers.
                     also reneabled large read requests with workaround for bug in windows servers as per samba.org.
etc.
etc.
etc.
Schweino eindigt op 30-03
o << Your asshole before prison.
O << Your asshole after prison.
Bigfoot87 schreef op vrijdag 28 april 2006 @ 15:24:
Als de skin uit komt moet hij op de laatste build van XBMC kunnen draaien.
Ik wacht er ook al maanden op, het duurt wel erg lang. :|
het duurt lang, maar ik denk dat het wachten het ook waard is. Zie filmpje
ik denk dat dit geldt voor het changlog.txt bestand ? iig is de compile wel van vandaag (weet niet of de changes er daadwerkelijk er in zitten)
  • Schweino
  • Laatst online: 07-07 19:06
Vreemd inderdaad, net handmatig even een nieuwe build van de CVS server gehaald:
Retrieving CVS source...
U XBMC/.cvsignore
U XBMC/Build.bat
U XBMC/Changelog.txt
U XBMC/FileZilla Server.xml
U XBMC/LICENSE.GPL
U XBMC/MS_Extender_Remote_keymap.rar
De changelog.txt die ik er net vanaf haal houdt ook op op 30/3..... :?
/edit
Ze zijn van server veranderd zonder de oude uit de lucht te halen. Heb het aangpast en nu krijg ik wel de juiste changelog.txt. Ik ga er van uit dat er na 30/3 geen nieuwe versie meer van de oude server is gehaald. Zodadelijk dus wel een nieuwe versie.
[ Voor 26% gewijzigd door Schweino op 29-04-2006 11:44 ]
  • GoT
GoT
/ / ( . Y . ) \ \
ok.. tnx...
Ik was overgestapt op T3ch vanwege een aantal bugfixes die niet bij jou voorkwam.
Morgen maar weer overstappen naar een schweino versie, nu eerst ff slapen :Z
  • kyddil
  • Laatst online: 18-01-2021
wat is het verschil tussen schweino en t3ch versies?
  • Schweino
de mijne is veeeeel gaver natuurlijk ;)
Het zijn allebei CVS builds, dus er zou geen verschil in de core functionaliteiten moeten zitten. De extra's zoals scrips, visualisaties, skins, codecs etc kan wel verschillen
[ Voor 70% gewijzigd door Schweino op 30-04-2006 11:06 ]
  • 0Burner0
  • Laatst online: 08-07 00:13
Ik zit met een ''probleem''
Als het goed is is het mogelijk om je eigen AB (afstand bedienning) te gebruiken in XBMC.
Maar ik kan nergens een Tutorial vinden.
Kan iemand mij hier mee helpen??
THNX
  • GoT
GoT
/ / ( . Y . ) \ \
Ik neem aan dat je zo'n universele afstansbediening bedoeld zoals die van Logitech ?
Hoewel ik er zelf geen heb ben ik wel van plan om 1 te halen, ik word ook gek van al die afstandsbedieningen.
Als iemand ervaringen heb met de Logitech icm XBMC/XBOX remote, aub meer info posten.
Ik ben benieuwd.
  • 0Burner0
GoT schreef op zondag 30 april 2006 @ 14:11:
Ik ben benieuwd.
Nee dat bedoel ik niet.
Het is volgens mij mogelijk om je XBMC je AB te herkennen en dan alle keys te mappe.
Wat ik wil is met mijn gewone XB dongel en mijn JVC afstandsbediening de XBMC te bedienen.
En als het goed is moet dat kunnen door middel van een script ofzo.
Wie weet hier meer van?
[ Voor 3% gewijzigd door 0Burner0 op 30-04-2006 15:54 ]
  • Schweino
Dat gaat je nooit lukken want de dongle werkt alleen met RCA codes dus zal je:
1) de originele afstandsbediening moeten gebruiken
2) een universele afstandsbediening moeten gebruiken waarin xbox/RCA codes zijn voorgeprogrammeerd
3) een zelflerende afstandsbediening moeten gebruiken
4) een afstandsbediening voor een RCA dvd speler moeten gebruiken
Alle andere opties gaan niet werken. Dit is overigens al eerder besproken.
Ik gebruik zelf een combinatie van 2 en 3: Bij mijn Pioneer versterker zit een afstandsbediening die al xbox codes voorgeprogrammeerd had, de overige extra codes heb ik via de "leerfunctie" aangeleerd.
[ Voor 20% gewijzigd door Schweino op 30-04-2006 17:53 ]
  • 0Burner0
Schweino schreef op zondag 30 april 2006 @ 17:51:
Oke thnx voor je info dan maar is kijken of ik me AB wat kan leren.
  • FaceDown
  • Laatst online: 08-05 13:25
FaceDown
Storende factor.
Gebruikt iemand hier postprocessing functies? Ik heb ze eigenlijk altijd uit staan, maar misschien zijn er wel goede tips om het beeld op de een of andere manier te verbeteren?
Groetjes, FaceDown.
  • Fire69
  • Laatst online: 11:21
Staat bij mij op Auto dacht ik...
Uitzetten als je native 720p filmpjes afspeelt ander krijg je gegarandeerd stotter issues.....
Ik heb het altijd uitstaan heb er nog geen voordeel van kunnen inzien (aan/uit)
Ik gebruik een One4All afstandsbediening voor m'n zooi (plasma,versterker,digitaleTV en xbox), werkt perfect ook voor XBMC, ondersteuning stond al standaard in het boekie (uiteraard niet xbmc, maar de xbox wel ;) )
[ Voor 39% gewijzigd door Verwijderd op 30-04-2006 23:17 ]
Ik ben benieuwd.
Yep, werkt prima. Staat gewoon in het lijstje van te kiezen apparaten
Schweino ik heb een vraagje, ik zag op je website een Evox rescue disc, alleen hoe zie je nu of hij werkt? ik start hem op met de cd erin en hij laat gewoon het dashboard zien.
weet iemand misschien waar de optie zit om de ondertitels te vergroten
ik kijk naar prisonbreak hdtv (via hardeschijf) 720/p1080i
het ziet er alemaal perfect uit ook de ondertitels die zijn superscherp alleen iets te klein
  • Schweino
Verwijderd schreef op maandag 01 mei 2006 @ 08:54:
Als je van die cd een spel oid draait werkt het dan wel? Ik heb het vermoeden dat de cd die je gebruikt niet gelezen wordt. Probeer het eens van een DVD, misschien dat dat wel werkt.
  • FaceDown
FaceDown
Storende factor.
Verwijderd schreef op maandag 01 mei 2006 @ 09:26:
Instellingen -> Video -> Ondertitels
Groetjes, FaceDown.
Hij werkt nu wel mijn EvoX dvd ;). kan ik hiermee gewoon op de ftp en dan dingen terugzetten? ik wil namelijk proberen te booten met xbmc maar ik weet niet hoe
  • FaceDown
FaceDown
Storende factor.
Verwijderd schreef op maandag 01 mei 2006 @ 10:55:
Dat kan.. laatst toen ik de boel vernaggeld had heb ik de zaak ook weer op orde gebracht met een bootdisk en FTP.
XBMC is trouwens makkelijk erop te zetten:
default.xbe (renamen naar je dashboard xbe, bijv evoxdash.xbe) en xboxmediacenter.xml zet je in c:\
xboxmediacenter.xml bewerk je zodat <home></home> (ergens bovenaan de file) naar de map wijst waar je XBMC hebt staan (bijv E:\APPS\XBMC\).
Da's alles.
Groetjes, FaceDown.
Ik ga het proberen :'). de vorige keer kon ik er niks meer mee
  • Schweino
Ja klopt, de evox rescue disk zet een evx ftp servertje open en maakt gebruik van DHCP. In het opstartscherm zou ook het IP adres moeten staan van je xbox. Gebruikersnaam en wachtwoord zijn xbox/xbox en de server draait op poort 21.
Maak wel eerst even een backup van je C:\ partitie voordat je gaat rommelen ;)
Er is overigens een makkelijkere manier dan je default.xbe en xboxmediacenter.xml naar C:\ te verplaatsen: maak een shortcut aan naar de default.xbe van xbmc (met http://www.xbox-scene.com...ep/EEkZppuApAArwjNkiE.php) en gooi die in C:\ (wel eerst hernoemen naar de naam van je huidige dashboard.xbe).
Je hoeft vervolgens xboxmediacenter.xml niet meer in C:\ te gooien en bij het updaten van XBMC in de toekomst hoef je alleen maar de XBMC directory op E:\ of F:\ te overschrijven.
zie ook: [rml]Schweino in "[ xbox] Xbox media center - Deel IV"[/rml]
[ Voor 65% gewijzigd door Schweino op 01-05-2006 11:21 ]
Service required :(.
dit doet zeer
lekker is dit
@facedown
8)7 tis maandag |:(
  • Schweino
Verwijderd schreef op maandag 01 mei 2006 @ 11:24:
dit doet zeer
Gewoon weer vanaf de rescue disc booten en je backup terugzetten. Daarna nog een keer proberen.
Schweino schreef op maandag 01 mei 2006 @ 12:39:
Die boot helaas niet meer
Sinds een tijdje doet het 6pack script het niet meer bij mij, hij blijft hangen bij "Bezig met laden..." Heb al geprobeerd opnieuw te installeren maar dat helpt niets? k Vind het wel jammer, had nog veel filmpjes te zien :P Ben ik de enige?
  • Gaitman
  • Laatst online: 06:57
Gaitman
The Real One
Hier werkt het dreambox script in ieder geval niet meer :( 6pack heb ik nog niet na gekeken)
  • Fire69
Verwijderd schreef op maandag 01 mei 2006 @ 12:49:
Had je een softmod dan? Dan zou je wel eens een probleem kunnen hebben nu. :/
  • FaceDown
FaceDown
Storende factor.
En deed ie het eerst wel? Hoe is je box gemod?
Ik zit in Limburg.. daar is het al dinsdag. ;)
[ Voor 35% gewijzigd door FaceDown op 01-05-2006 19:47 ]
Groetjes, FaceDown.
  • Schweino
Fire69 schreef op maandag 01 mei 2006 @ 18:05:
Dat vroeg ik me inderdaad ook af.....
  • seninha
  • Laatst online: 17:47
seninha
god's right foot
Gisteravond wou ik een Lost Series 2 bekijken op DVD , maar ik krijg oondertiteling niet aan de praat. IK krijg wel het Xbox menu te zien.
Daar staat onder ander audio maar ook dus ondertiteling.
Probleem is dat ik geen keuzes heb :?
Als ik deze DVD in een ander speler stop dan kan ik wel ondertiteling gebruiken.
Wil mn Xbox gebruiken omdat het beeld op de ander speler echt bagger is (vooral met donkere stukjes)
Iemand enig idee waar ik moet kijken om dit wel werkend te krijgen.
iRacing Profile Flickr
  • philipnorth
  • Laatst online: 08:06
philipnorth
Zeg maar Danny
Verwijderd schreef op maandag 01 mei 2006 @ 01:24:
Welke Logitech gebruik jij dan?
Is die Harmony 525 nou eigenlijk compatible?
Want ik wil op zich wel een remote ervoor aanschaffen, is toch wat relaxter dan met de controller..
-Xbox Gamertag: Dbongers
  • FaceDown
FaceDown
Storende factor.
Schweino schreef op maandag 01 mei 2006 @ 20:12:
Hoe werkt een softmod dan? Die boot toch ook gewoon een alternatieve executable neem ik aan? Of een aantal mogelijke executables in een bepaalde volgorde zoals een Xecuter chip doet?
Groetjes, FaceDown.
philipnorth schreef op maandag 01 mei 2006 @ 22:42:
Ja de HARMONY 525, dat is dan een "replacement" voor de DVD-KIT afstandsbediening v/d X-BOX.
Dus als je zo'n goedkope DVD kit erbij pakt (euro of 16 zijn die), zal het werken.
Of je het als vervanger voor een (draadloze)controller kan gebruiken weet ik zo 123 niet
[ Voor 11% gewijzigd door Verwijderd op 02-05-2006 00:38 ]
Dat had je ook wel even mogen melden hoor :')
  • Fire69
seninha schreef op maandag 01 mei 2006 @ 20:34:
Heb je al geprobeerd om de ondertitels te kiezen in het menu van de dvd ipv in het menu van xbmc?
dus tijdens spelen op Menu drukken, dan krijg je dus het xbmc 'kruis-menu', daar kies je links-boven het ballonnetje met DVD erin, en dan kom je in het echte dvd menu.
FaceDown schreef op maandag 01 mei 2006 @ 23:26:
Ja, maar eerst boot hij een xbe van MS die is aangepast om andere xbe's te laden.
Als hij die eerste xbe heeft weggegooid/overschreven...
  • philipnorth
philipnorth
Zeg maar Danny
Verwijderd schreef op maandag 01 mei 2006 @ 23:41:
Ja het zou gaan om alternatief voor de (goedkope) DVD kit.
Maar goed om te weten dat de 525 iig compatible is :)
Heb nu sinds een weekje XBMC draaien, en moet toegeven, vind het echt super! (Schweino build)
Moet alleen nog ff doorkrijgen hoe ik een spel van de HDD aan de praat krijg, gekke ding reboot gewoon :?
  • Fire69
Heb je dat bij alle games? Misschien is het gewoon een NTSC game die niet wil starten op een PAL-box. Heb ik ook wel eens gehad. :)
  • Motabeatz
  • Laatst online: 27-06 00:51
philipnorth schreef op dinsdag 02 mei 2006 @ 08:03:
Je kan Enigmah Video Switcher downloaden http://www.megagames.com/...ideo%20Mode%20Select%20CD
Kan je kiezen tussen NTSC of PAL
motabeatz.com
  • Fire69
Check even via Qwix anders of het PAL of NTSC is. :)
  • Sander
Wat voor IR oog gebruiken jullie dan? Want het lijkt me niet dat met de logitech harmony op dat ding schieten veel zin heeft als er geen IR oog op zit...
Zijn er B-merk infraroodontvangers te krijgen?
Ben erg tevreden over xbmc. Divx streamen enz. 8)
Maar mijn dutchstreams blijven na ongeveer 10 minuten hangen.
Heeft iemand een oplossing?
Internet verbinding via kabel (Chello) en een Linksys wrt54g router.
Verwijderd schreef op dinsdag 02 mei 2006 @ 21:12:
Yep, bij mediamarkt hebben ze ook de goedkopere (16euro) ipv die van MS zelf.
  • Sander
Verwijderd schreef op dinsdag 02 mei 2006 @ 21:49:
Werken deze ook met XMBC?
lijkt me wel. Ik heb zelf de originel van MS, maar de knoppen/bediening is toch hetzelfde
  • Sander
Verwijderd schreef op dinsdag 02 mei 2006 @ 22:23:
Ik heb ergens gelezen dat de orginele van MS niet met XMBC werkte? Maar dat is dus wel zo?
Snapt de XBOX trouwens WOL oid? Want ik wordt er soms een beetje moe van dat ik op moet staan om de xbox een schop te geven voor ik een filmpje kan kijken. Laptop ligt meestal toch naast de bank.
Tenminste ik neem aan dat aan/uit niet gaat lukken met AB?
  • Skimmer
  • Laatst online: 02-01 11:03
Skimmer
Inter Arma Enim Silent Leges
Verwijderd schreef op maandag 01 mei 2006 @ 23:45:
Heb je inderdaad een softmod?
In dat geval heb je vast wel een backup :P gemaakt van je HD voor je begon met het installeren van de nieuwe software? Met deze backup kun je je HD weer rebuilden... Als je een backup hebt tenminste.
Deze heb ik ook. De universele afstandbediening die ik heb (philips SBC RU 760) bied wel ondersteuning voor de XBOX, maar deze codes zijn schijnbaar niet compatible met de noname IR ontvanger. Met de XBMC (ir) debug functionaliteit aan, is te zien dat de IR ontvanger totaal niets registreert met de standaard XBOX codes. Na handmatig trainen van de knoppen werkt het wel, maar echt ideaal is het nog niet.
Ow, en de ontvangst van de standaard AB die bij deze set zit, is ook waardeloos. Als ik nu weer een setje zou kopen zou ik zeker voor de MS versie gaan.
In times of war the law falls silent
  • Fire69
ikbensander schreef op dinsdag 02 mei 2006 @ 22:40:
Originele werkt perfect met xbmc :)
Xbox heeft geen WOL, enige mogelijkheid om met de AB op te starten is door een extra mod, bvb de XIR (of zoiets) van Xecuter.
Skimmer schreef op dinsdag 02 mei 2006 @ 22:43:
Volgens mij krijgt hij die backup er niet meer op als zijn xbox een service-error geeft...
  • philipnorth
philipnorth
Zeg maar Danny
Fire69 schreef op dinsdag 02 mei 2006 @ 20:01:
Min of meer goed, ik wost sowieso dat t PAL was, en mijn Xbox is ook Pal.
Maar ik had de ISO zelf geftp'ed, en via complextools uitgepakt op de Xbox HD.
Nu heb ik via Qwix de ISO ingelezen en geftp'ed (en dan pakt ie m uit etc), en dan doet ie t wel ^O^
Yay!
Bedankt voor de tips iig :)
Verder relaxed filmpje gekeken enzo :) Nu nog op zoek naar een goede advanced scart voor de DD uit en idd een remote en we zijn er wel klaar voor :D
Werkt een remote trouwens binnen XBMC als je ook een controller hebt aangesloten?
Dus controller op poort 1 en remote op poort 2?
Of werken ze dan gewoon allebei?
  • Walkman
Ze werken gewoon beide...
  • FaceDown
FaceDown
Storende factor.
Ik kom er gisteren achter dat ook PAL spellen opeens werken op mijn progressive-only projector. Dit na een update van XBMC. Heeft iemand enig idee of dit daadwerkelijk een nieuwe feature / fix is of dat ik blijkbaar een instelling niet goed had staan?
Mijn Xbox stuurt dus ALLE spellen nu progressive uit.
Groetjes, FaceDown.
  • Schweino
Klopt, heb ik al eerder gemeld in dit forum overigens. De codeset die de xbox remote gebruikt zijn van een RCA DVD speler. Op deze codesets zit natuurlijk een copyright en royalties en de no-names gebruiken dus andere (onbekende) codesets. Je hebt dus geen idee hoe je je a/b moet inprogrammeren met imitatie IR ontvangers, zelf leren zoals Skimmer al zegt kan natuurlijk wel als je a/b dit ondersteunt.
Ook is het zo dat de imitatie remotes niet 100% compatible zijn met XBMC. Vraag me niet waarom maar in de praktijk blijkt dit zo te zijn.
FaceDown schreef op woensdag 03 mei 2006 @ 09:37:
Da's apart, XBMC zou niets te maken moeten hebben met hoe de spellen op het scherm getoond worden. Is er niet iets anders gewijzigd?
[ Voor 25% gewijzigd door Schweino op 03-05-2006 10:23 ]
Schweino schreef op woensdag 03 mei 2006 @ 10:17:
:) Is wel typisch, je zou toch denken dat ze intern hetzelfde signaal aan de XBOX afgeven, het is puur hardware toch? Dus de XBOX pikt die signalen op?
Ik heb b.v. zo'n MadCatz wireless controller (die met vibratie) en die werkt ook prima met XBMC maar dat zal wel weer een ander verhaal zijn dan die imitatie DVD Kits.
  • FaceDown
FaceDown
Storende factor.
Dat dacht ik ook maar er is een instelling onder 'programs' die daar iets mee te maken heeft ('switch video resolution for 60hz' of zoiets). Deze instelling had ik aangezet; toen werkte een aantal (volgens mij allemaal PAL-)spellen niet. Daarna zette ik de instelling uit en voor het eerst werkten al die spellen juist wel. De Xbox stuurt dan 480p uit, hoewel ik XBMC in 720p heb staan.
Blijkbaar heeft XBMC toch enige invloed op de resolutie van het scherm tijdens spellen. De XBOX crasht overigens niet, want ook als ik geen beeld krijg (als mijn projector een interlaced signaal door krijgt), hoor ik wel geluid van de spellen.
[ Voor 12% gewijzigd door FaceDown op 03-05-2006 11:45 ]
Groetjes, FaceDown.
  • Schweino
Waarschijnlijk zijn de spellen die je hebt geprobeerd allemaal spellen die 480p ondersteunen. Op http://www.hdtvarcade.com...autocom=custom&page=xboxa kan je een lijst zien met welke spellen welke resolutie ondersteunen. De meeste xbox spellen omndersteunen wel 480p, sommigen ook 720p of 1080i.
  • FaceDown
FaceDown
Storende factor.
Dat lijkt inderdaad te kloppen. Vreemd dat een heel stel dan niet werkt na het veranderen van die instelling.
Groetjes, FaceDown.
  • Schweino
Dat heeft waarschijnlijk te maken met het feit dat je een PAL spel dan forceert om in 60Hz te draaien vermoed ik.
  • MiZtraL
  • Laatst online: 27-05 07:09
Ik gebruik denk al meer dan 3 jaar mijn xbox als media center. Eerst had je XBMP en toen kreeg je XBMC. Echt de ideale multi media player, ik doe mijn xbox ook voorloopig niet meer weg.
Wat ik mij afvraag is een pagina als deze ook niet in XBMC te zetten als internet TV
http://www.channelchooser.com/
Ik ben geen progameur maar dit zijn wel veel leuke kanalen :*)
  • Schweino
"leuke kanalen" jaja -> kanaal 63 t/ 66 *kuch*
  • Bigfoot87
  • Laatst online: 07-07 14:53
Schweino schreef op vrijdag 05 mei 2006 @ 22:40:
Haha :) Ik ben toevallig bezig met het maken van een videostreampack van het broertje van die website: www.kanalenkiezer.nl.
EDIT:
Een eerste versie is te downloaden van mn website: www.xboxmediacenter.be onder "Scripts"
(Website is nog lang niet af! :p)
[ Voor 31% gewijzigd door Bigfoot87 op 06-05-2006 00:20 ]
Quatt Duo | Marstek 5.12kwh - V151 - HWP1
  • Schweino
Apart dat de "natuurfilms" op kanalenkiezer.nl betaald zijn, terwijl ze op channelchooser gratis zijn...
  • Bigfoot87
Schweino schreef op zaterdag 06 mei 2006 @ 00:25:
LOL, ik zat al te zoeken en te zoeken maar kon maar geen zender "Natuurfilms" vinden.
Maar nu snap ik um :+
  • Fire69
Bigfoot87 schreef op vrijdag 05 mei 2006 @ 23:17:
EDIT:
Waarom een .be als je overduidelijk Nederlander bent? :)
Fire69 schreef op zaterdag 06 mei 2006 @ 15:43:
Ze hebben laatst gratis be domeinnamen weggegeven. Zal daar wel iets mee te maken hebben :)
  • Sander
Stond laatst een berichtje op. De natuurfilms werden iets te druk bezocht en trokken veel te veel data... Vandaar dat ze dit besloten hebben.
  • -Skyhawk-
Nog even offtopic.
Maar dat snap ik dan weer niet. Want alle kanalen zijn naar mijn weten ook gewoon weer links.
Overigens bedankt Schweino voor je builds. ;)
[ Voor 23% gewijzigd door -Skyhawk- op 06-05-2006 19:19 ]
  • Stampre
  • Laatst online: 28-06 21:37
Ik probeer de livestream van dolfijnfm op de xbox te krijgen, maar dit lukt niet.
Ik heb de link http://dolfijnfm.dahstream.nl/wma8250.asx gekopieerd naar kladblok en opgeslagen als strm maar hij speelt niks af :-( iemand enig idee wat ik fout doe of welke link ik wel moet hebben?
het komt van de website www.dolfijnfm.com
http://specs.tweak.to/6635
  • Bigfoot87
Verwijderd schreef op zaterdag 06 mei 2006 @ 15:50:
Klopt inderdaad ;)
  • Bigfoot87
Stampre schreef op zaterdag 06 mei 2006 @ 20:09:
Zet deze link in een strm bestand en hij doet het wel: http://84.244.180.19:8250
Je moet het asx bestand eerst downloaden en dan openen met kladblok, daar zie je dan bovenstaande link staan. :)
  • Stampre
Tnx hij doet het inderdaad. Ik ga denk ik de fout in met het downloaden van dat asx bestand.
ben erg blij met mijn stream, kan ik het vakantiegevoel van curacao nog even voortzetten!
  • salgera
  • Laatst online: 23-09-2021
Sinds ik de laatste versie van XBMC (Schweino: XBMC_06-May-2006) erop gezet heb, werken geen van de subtitles meer.
Hebben jullie daar ook last van? Is er iets gewijzigd in 'XboxMediaCenter.xml', dat ik nu moet aanpassen?
In de versie van 22 april 2006 werkt het nog wel...
  • Fire69
Ik las in de changelog van de T3ch-release dat er heel wat veranderd is aan de xml-file, dus als je nog de oude xml gebruikt, zou ik hem toch even vervangen.
Misschien zelfs de U/TData/00face08 ook even wegkiepen desnoods...
  • CeeDeeS
  • Laatst online: 24-06 23:38
Ik werk al tijden met eenzelfde xbmc versie van een paar maanden oud, maar wilde nu wel weer eens updaten... dus had de nieuwste versie van Schweino gedownload (8 mei), alles in een nieuwe map gezet (F:\Apps\XBMC\) (map van oude XBMC was E:\XBMC\), de default.xbe (gerenamed naar xboxdash.xbe) en de XboxMediaCenter.xml in de root van C geplaatst.
Ook heb ik XboxMediaCenter.xml aangepast zodat deze naar de goede map verwijst (<home>F:\Apps\XBMC\</home>)
Dus ik opnieuw opstarten, start hij nog gewoon op in de oude versie. Ik heb er de gebackupte XboxMediaCenter.xml nog eens bij gepakt en zag daarin dat deze hiervoor naar een pad verwees waar hij niet eens stond. Het lijkt dus wel dat dit bestand niet uitgelezen wordt.
Weten jullie misschien wat ik nou moet veranderen om hem naar het juiste pad te laten gaan :?
Edit: Ik heb zojuist de logfiles er eens bij gepakt, en volgens mij leest hij de XboxMediaCenter.xml uit van de Q schijf ipv van de C schijf:
11-02-2006 11:36:32 NOTICE -----------------------------------------------------------------------
11-02-2006 11:36:32 NOTICE Starting XBoxMediaCenter.  Built on Jan  4 2006
11-02-2006 11:36:32 NOTICE Q is mapped to: Harddisk0\Partition2
11-02-2006 11:36:32 NOTICE Log File is located: Q:\xbmc.log
11-02-2006 11:36:32 NOTICE Setup DirectX
11-02-2006 11:36:32 INFO Available videomodes:
11-02-2006 11:36:32 INFO Found mode: 720x480 at 50Hz,
11-02-2006 11:36:32 INFO Found mode: 720x576 at 50Hz,
11-02-2006 11:36:32 NOTICE load settings...
11-02-2006 11:36:32 NOTICE loading T:\settings.xml
11-02-2006 11:36:32 NOTICE Getting hardware information now...
11-02-2006 11:36:32 INFO Using digital output
11-02-2006 11:36:32 INFO AC3 pass through is enabled
11-02-2006 11:36:32 INFO DTS pass through is enabled
11-02-2006 11:36:32 NOTICE Checking resolution 6
11-02-2006 11:36:32 INFO AV Pack: Scart
11-02-2006 11:36:32 INFO AV Flags:
11-02-2006 11:36:32 NOTICE loading Q:\XboxMediaCenter.xml
11-02-2006 11:36:35 NOTICE -----------------------------------------------------------------------
11-02-2006 11:36:35 NOTICE New Home Path! Q is mapped to: Harddisk0\Partition2
Maar via de FTP kan ik niet op die schijf komen. Weten jullie hoe dit kan en, nog belangrijker, hoe ik dit kan oplossen?
[ Voor 52% gewijzigd door CeeDeeS op 08-05-2006 10:03 ]
  • pvdlaan
  • Laatst online: 12-05 07:13
is het ondertussen al mogelijk om dvr-ms files af te spelen op xbmc. :?
Ik heb een computer met mce 2005 erop
en zou de hiermee opgenomen programma`s via xbmc willen bekijken ... 8)
Xbox One X | iPhone 12 | iPad Pro 11 | MacBook Air M1 | Sony HX50v | Sony HX400
pvdlaan schreef op maandag 08 mei 2006 @ 14:16:
xbox media center extender proberen aan te schaffen in de states ;)
  • Fire69
CeeDeeS schreef op maandag 08 mei 2006 @ 09:57:
De Q: is gewoon een redirect naar de folder waar XBMC geinstalleerd staat. ;)
Ben je er wel zeker van dat je xbox opstart vanaf xboxdash.xbe? :?
  • CeeDeeS
Ik dacht van wel.. hij is gewoon omgebouwd met mod chip en in het begin bootte die altijd naar het evox dashboard...
Wat zou het anders nog meer kunnen zijn?
  • Bigfoot87
CeeDeeS schreef op maandag 08 mei 2006 @ 15:22:
Dan moet je evoxdash.xbe hebben toch?
  • Schweino
Kan helaas niet. Ik gebruik autodvrconvert 1.3 (http://thegreenbutton.com/forums/thread/38951.aspx), werkt prima. Dit programmatje converteert automatisch dvr-ms bestanden naar mpeg2.
Of zoals al gezegd is kan je xbox media center extender installeren. Deze is overigens ook te downloaden van de "gebruikelijke plekken" en met de standaard xbox a/b te gebruiken.
  • Schweino
Bigfoot87 schreef op maandag 08 mei 2006 @ 16:05:
In principe wel ja, maar dit is helemaal afhankelijk van instellingen in de bios.
CeeDees: Op mijn site staat ook een "rescue disk", hiermee kan je je (gechipte) xbox altijd booten en er naartoe FTP-en.
  • pvdlaan
Schweino schreef op maandag 08 mei 2006 @ 16:31:
Deze ben ik al het installeren, maar krijg hem niet aan de praat, vandaar de vraag of het momenteel al mogelijk was binnen xbmc.
Het omzetten van de bestanden vind ik onzin, omdat dat onnodig veel tijd in beslag neemt en als ik het gezien hebt, verwijder ik het toch weer.
maar ga nog wel eens verder proberen met MCE
[/quote]
[quote]
voor wie intresse heeft ik heb van deze kanalen .strm files gemaakt en getest :+
ze werkten allemaal op een na (kan per dag wijzigen)
misschien wil/kan iemand ze hosten het is maar een paar kb
[ Voor 4% gewijzigd door Verwijderd op 09-05-2006 09:02 ]
  • Schweino
pvdlaan schreef op maandag 08 mei 2006 @ 17:14:
Dan heb je denk ik niet goed gelezen wat het programma doet. Het converteert naar mpeg2 on the fly. Aangezien dvr-ms een mpeg2 container is kost het converteren dus geen extra tijd. Je kan bijvoorbeeld dus nog steeds timeslippen op deze manier.
@snertpan -> schuif maar door die stm files, ik host ze dan wel.
  • Bigfoot87
Ik ben ook bezig geweest, maar heb ze lang niet allemaal :)
Dus als je ze naar Schweino of mij zou willen sturen graag _/-\o_
@ Schweino: Ik weet niet of je het al wist maar de changelog op je server klopt nog steeds niet.
[ Voor 11% gewijzigd door Bigfoot87 op 09-05-2006 13:11 ]
  • bitpixl
Natuurlijk heb ik interesse :P
Hosten maar! :)
  • Schweino
Bigfoot87 schreef op dinsdag 09 mei 2006 @ 13:05:
De url naar de sourceforge changelog bedoel je? De changelog in de xbmc rar klopt wel naar mijn weten, ik zal de nieuwe url eens nazoeken.
  • Bigfoot87
Schweino schreef op dinsdag 09 mei 2006 @ 15:25:
Ja sorry, dat bedoelde ik :)
thnx!
welke kanalen? wat zie ik nou over t hoofd?
  • Bigfoot87
Verwijderd schreef op dinsdag 09 mei 2006 @ 22:06:
De kanalen van www.kanalenkiezer.nl :)
  • GoT
GoT
/ / ( . Y . ) \ \
Ik heb net de versie van 08-05-2006 gedownload, maar nog niet geïnstalleerd.
Ik lees bij de changelog:
- 07-05-2006 changed: Rss feed setup to UserData\RssFeeds.xml
Keymap.xml to UserData\Keymap.xml
System\LCD.xml to UserData\LCD.xml
System\Partymode.xml to UserData\Partymode.xml
Waar zit de userData folder ?
  • Schweino
Skillz schreef op dinsdag 09 mei 2006 @ 14:05:
Hosten maar! :)
Voor alle natuurliefhebbers, de streams staan op mijn pagina
  • pasta
  • Laatst online: 04-04 23:18
pasta
Ondertitel
Doe toch maar geen linkje naar de streams, dat gaat nogal tegen Het algemeen beleid #porn in. ;)
Signature
@ Schweino
bedankt voor de snelle service :o
  • bitpixl
pasta schreef op dinsdag 09 mei 2006 @ 23:37:
P0rn? Het waren toch natuurzenders? :P
  • Schweino
Jup, met van die lieve kleine bevertjes ;)
[ Voor 5% gewijzigd door Schweino op 10-05-2006 13:21 ]
