[PC][Racesim] Live for Speed S2 Overzicht Laatste deel
Pagina: 1 2 ... 11 Laatste
  • 7.314 views sinds 30-01-2008
  • duderuud
  • Laatst online: 10:20
duderuud
Sliden is koel
Tof, S2 demo beschikbaar! Ben een licensed S1 racer, maar LFS S1 ligt al tijden te verstoffen, vooral na uitkomen van GTR.
Ga S2 direct proberen vanavond!
Motor-Forum.nl
  • daroy
  • Laatst online: 29-04 13:53
kom op mensen, schrijf jullie eens in op simracing.nl en dan gaan we gezellig met een groepje Hollanders rond scheuren over de baan :Y)
iRacing Profiel
  • wheeler
  • Registratie: Juli 1999
  • Laatst online: 09:20
Er is een patch voor alpha demo van S2!
One of the most significant things is the use of a much better type of limited slip differential (LSD) which helps you to get the power to the ground more effectively. Up until this version, the only type available was a viscous LSD. The aim of a limited slip differential is to put more torque onto the driving wheel which has the most grip. The viscous LSD relied on the wheel with less grip spinning faster than the wheel with more grip, so that meant that all LFS cars suffered quite a lot from inside (unloaded) wheel spin.
The new type is the clutch pack differential. In this case, there is no viscous coupling, and instead, the differential unit contains some clutch plates between the drive shafts and the outer casing of the differential unit. When you apply torque to the differential (under acceleration or engine braking) the clutch plates are squeezed together, so reducing differentiation and effectively shifting torque from the very slightly faster moving wheel (the inside wheel which is just starting to spin) to the very slightly slower moving wheel (the outer, loaded wheel). This happens much more quickly than the torque shift of a viscous LSD.
In the final drive settings you will see a Locking slider bar. The "percent locking" refers to the maximum torque difference between the drive shafts, as a percentage of the total torque applied. Therefore as you get close to 100%, it's becomes similar to a fully locked diff, and as you get close to 0%, it gets more like a fully open diff (fully locked and fully open differentials are also selectable, for testing or for interest).
In real life the amount of locking is adjusted by changing the ramp angles. Acceleration or engine braking pushes in a different way, so there are in fact two ramp angles - one for power and one for coast. On the XR GT TURBO, you have separate control of these two angles.
It makes quite a significant difference to the handling of the cars.
Een technisch verhaal maar óh wat rijden ze nu lekker! Qua rijgevoel begint het allemaal steeds beter te worden. Nu maar hopen dat de final binnen 3 maanden klaar kan zijn. download page
  • daroy
klopt, het rijd nu allemaal weer net iets realistischer dan van te voren. Je hebt weer wat meer gevoel over de auto en de GTi is ook nog wat sneller geworden. 1.35 is nu makkelijk te doen in de GTi :9~
iRacing Profiel
  • Clithopias
  • Laatst online: 06-12-2024
Ik heb een tijdje geen LFS meer gespeeld, maar nu wil ik het weer eens gaan doen weet ik mijn login niet meer |:(
Staat er misschien ergens in de gamebestanden je loginnaam? Wachtwoord weet ik volgens mij nog wel.
  • daroy
dat is vrij vervelend zegmaar...Je zou Victor eens kunnen mailen of die dat niet kan achterhalen maar die kans lijkt me vrij klein.
Voor de rest, Maandag 9 Mei is er weer een test race voor LFS League op simracing.nl het gaat nu om de GTi op Blackwood met 48 rondjes dacht ik.
iRacing Profiel
  • CRiMiNaL
  • Laatst online: 10-01-2024
CRiMiNaL
Witlof ^^
daroy schreef op dinsdag 03 mei 2005 @ 09:30:
De link in de news post werkt niet, maar ik heb me ook ingeschreven .. iig in het topic.
... MMORPG Addict.
  • daroy
CRiMiNaL schreef op dinsdag 03 mei 2005 @ 13:04:
komt omdat een forum admin je daar toegang voor moet geven. Waarom dat is weet ik ook niet :/
iRacing Profiel
  • Beerkeeper
  • Laatst online: 11:17
Ik weet niet of LFS nog leeft op GoT, maar ik wil wat voorstellen:
Vroeger was er al eens de bedoeling geweest om een clan te starten onder GoT-ers, daarom vraag ik dus of deze nog actief is. Mijn bedoeling is namelijk om een clan te maken waarin iedereen deel mag nemen, maar echte racers ook kunnen "warren" (tegen andere clans deelnemen)
Zoals ik het zelf in gedachten had:
Iedereen kan (bijvoorbeeld) GoT voor zijn naam zetten, de tags eromheen kunnen voorlopig [ en ] zijn. De serieuze racers kunnen dan bijvoorbeeld GoT-R voor hun naam zetten, om aan te duiden dat deze in de clanwars deelnemen. Onderscheidt tussen clanleaders en clanmembers moeten we dan nog nader bespreken i.v.m. eventuele discriminatie (ik weet niet of jullie het dan te onderdanig vinden, maar dit is nog onder voorbehoud).
Ik weet niet wie ervoor is, maar hier alvast een lijstje (Iedereen kan deelnemen!)
Nick                 Doel
FoutTM               Niet serieus racen, gewoon erbij horen.
Arfman               Niet serieus en serieus racen
Deze lijst wordt bijgehouden
[ Voor 10% gewijzigd door Beerkeeper op 18-05-2005 06:53 ]
DM me voor Joulo referral
  • Arfman
Arfman
Drome!
Ach, waarom niet ? Wil best [GoT] voor mijn naam zetten, en als ik tijd heb rijd ik wel een race mee :)
  • daroy
zit al bij een team dus heb geen intresse hierin...En racen tegen andere nederlanders doe ik op simracing.nl ;)
iRacing Profiel
  • SAiN ONeZ
  • Laatst online: 29-10 12:55
SAiN ONeZ
Ⅎnll-Ԁɹooɟǝp Ⅎool
ik ben sinds gisteren volop bezig met LFS S2 demo nu is het me al gelukt skins te plaatsen, maar een setup vervangen lukt me niet!?
Ik heb een setup van LFS forum afgeplukt, die een .set extensie ipv de *.col die default in de map settings staan. Hij komt wel mooi naar voren in het garagemenu, maar zodra ik em kies, melding dat deze niet geladen kan worden, en hij weer de default hanteert. :'(
Ik race met een ffb wheel en dus in de demo, kan iemand me een goede setup sturen, zodat deze te gebruiken valt!? kijken of ik nog wat van me 1:44 kan afsnoepen met de default car :X :/
N47h4N|The secret to creativity is knowing how to hide your sources| Dyslexic atheists don't believe in doG! | ˙ʞuɐlq ʇɟǝl ʎllɐuoᴉʇuǝʇuᴉ sɐʍ ǝɔɐds sᴉɥ┴ ®
  • daroy
hier
de toppers rijden hier 1.34 mee :)
in je settings map plaatsen ;)
iRacing Profiel
  • SAiN ONeZ
SAiN ONeZ
Ⅎnll-Ԁɹooɟǝp Ⅎool
thnx had van hem al een andere gevonden en zat al op 1:41:91 :Y)
heb al een heel deel skins in me map staan, toch komen er maar 2 naar voren om te kiezen, is dat normaal of heb ik typische nodig, die enkel voor de demo werken!? Ook racete er vanmiddag iemand mee met een stationwagon, hoe komt ie aan die bak!?
  • daroy
de skins die je in je skins_x map hebt staan zijn alleen om te bekijken. Dus andere mensen die met die skin rijden kan jij dan zien, prive skins van andere zoals bijv teams komen in deze map. De skins map is voor skins die jezelf wil gaan gebruiken en dus niet prive skins zijn van andere. Als je hier een paar bestanden in hebt staan kies je in het spel in de garage bij de skins new en dan onderaan in beeld kan je op een balkje klikken waar een jpg bestand instaat, als je hier dan de naam kiest van de skin die je wilt gebruiken selecteer je deze en kan je met de sliders de kleuren nog wat aanpassen.
een stationwagen in LFS lijkt me zeer vreemd, er zitten maar 3 auto's in de demo namelijk deze:
XF GTi
Afbeeldingslocatie: http://www.liveforspeed.nl/nl/images/stories/liveforspeed/xf_gti_1.gif
XR GT
Afbeeldingslocatie: http://www.liveforspeed.nl/nl/images/stories/liveforspeed/xr_gt_2.gif
XR GTT
Afbeeldingslocatie: http://www.liveforspeed.nl/nl/images/stories/liveforspeed/xr_gt_turbo_2.gif
iRacing Profiel
  • SAiN ONeZ
SAiN ONeZ
Ⅎnll-Ԁɹooɟǝp Ⅎool
heb je een link met mooie s2 skins voor het wat te verfraaien!??
_/-\o_
  • daroy
skins @ RSC: http://forum.rscnet.org/forumdisplay.php?f=473
skins @ LFS.de: http://lfs.foren.4players...f50df49673e0dbfa2a8f6b11a
let wel goed op dat je geen prive skins gaat gebruiken om zelf mee te rijden ;)
iRacing Profiel
  • wheeler
In volledige S2 zal de mogelijkheid zitten dat skins uitwisselbaar zijn zonder ze van te voren te hoeven downloaden. Denk dat aan je S2 licentie de mogelijkheid krijgt een skin per auto te hangen, het zou het online racen zeker nog een beetje veraangenamen en "privé" skins kunnen niet meer gebruikt worden :)
Ik zet ook [GoT] voor mijn naam, ben een serieuze racer en mijn beste tijd in een GTi op Blackwood is een 1:39:72. Heb 5000km met S1 erop zitten maar dat speel ik niet meer. Al met al niet een toprijder maar wel constant en soms in staat een race te winnen door fouten van anderen.
[ Voor 33% gewijzigd door wheeler op 19-05-2005 10:32 ]
  • daroy
Klopt, in S2 heb je de mogelijkheid om in LFS world een x aantal skins te uploaden wat je wil gaan gebruiken. Als je dan op een server gaat zal LFS op de computers van de andere mensen die erop zitten jou skin downloaden en zo zien hun dus allemaal jou skin. Ben benieuwd hoe snel het allemaal zal gaan in de praktijk maar ik heb er wel vertrouwe in!
Mijn beste GTi tijd is op dit moment 1.35.39 en met de GT 1.34.90, vooral die tijd van de GT moet nog wat lager kunnen. Ben ook geen top rijder, daarvoor verlies ik nog 1sec teveel op een rondje maar kan redelijk meekomen :)
mijn ingame naam is: nic [Roy]
[ Voor 4% gewijzigd door daroy op 19-05-2005 10:42 ]
iRacing Profiel
  • SAiN ONeZ
SAiN ONeZ
Ⅎnll-Ԁɹooɟǝp Ⅎool
mijn pb is 1:39:45 op blackwood, na 2 dagen racen ;)
zijn de graphics in s1 beduidenswaardig minder, of valt dat wel mee, want ik zit er hard over te denken om deze te nemen, of kan ik instappen met alleen s2!?
  • daroy
als je S2 koopt zit je S1licencie er ook meteen bij. Je kan er nu voor kiezen om een S1 licencie te kopen voor £12. Hiermee kan je dus natuurlijk de S1 content spelen. Als S2 dus uit zou zijn en je hebt deze gedownload kan je het S1 gedeelte unlocken en kan je dus gebruik maken van die features.
Later heb je dan de mogelijkheid om je licencie te upgraden naar S2, dat kost dan ook weer £12 en kan je dus gebruik maken van de volledige content.
Je kan er ook voor kiezen om direct £24 te betalen en dan heb je meteen je S1 en S2 licencie en kan je dus als S2 beschikbaar is direct aan de slag ermee. Je kan dus nu dan ook gewoon S1 spelen.
Ik moet wel zeggen dat sinds de S2 demo er is ik S1 niet meer aangeraakt hebt...Ik zou dus meteen voor de S1 en S2 licencie gaan.
owja, S1 ziet er niet slecht uit...zeker niet met de nodige AA en AF maar het is wel een stuk minder dan S2 vind ik. S2 ziet er gewoon een stuk beter uit en speelt ook fijner!
[ Voor 11% gewijzigd door daroy op 20-05-2005 09:52 ]
iRacing Profiel
  • SAiN ONeZ
SAiN ONeZ
Ⅎnll-Ԁɹooɟǝp Ⅎool
oke erg duidelijk, lijkt me dat ik me nog even dus moet vermaken met de demo, maar zou het leuk vinden wat andere autos en banen te kunnen rijden.
voor de maximale grafische instellingen wat stel ik dan in?!
die simpele dingen uit (shadows, simpele wielen enz), en filters aan ?
  • daroy
als je nou gewoon die 24 pond betaald hoef je dat straks niet meer te doen en kan je meteen aan de slag. Kan je ook gelijk es ff S1 proberen.
en voor de graphics kijk hier maar eens, als je het zo instelt dan ziet het er erg netjes uit: http://forum.rscnet.org/s...php?p=2169102&postcount=4
moet je wel in windows ff wat AA en AF aanzetten, ik draai hier met 4x en 8x
iRacing Profiel
  • SAiN ONeZ
SAiN ONeZ
Ⅎnll-Ԁɹooɟǝp Ⅎool
perfect thnx heb em nu erg mooi staan met 6x aa en 16x af, maar dat moet lukken met een x800xt pe ;)
alleen zie in die thumbnails dat er een texturegrootte valt in te stellen, of is dit een S1 menu waarin dit zit, de overige opties vond ik allemaal wel terug, en met een vsync rijden is idd veel mooier..
  • daroy
dat is een s1 menu ja...heb geen idee of die optie wel of niet in s2 zit :P
ik draai hier maar met een 2.6 p4 en een geforce 6800le maar haal met mijn settings, bijna zoals op die plaatjes en 4x aa en 8x af toch nog zo'n 70-80 fps tijdens het racen. dus lfs is helemaal niet zwaar voor je pc
iRacing Profiel
  • Beerkeeper
Klik hier om het LFS kanaal in te gaan
Ik heb maar een kanaaltje aangemaakt om meetings te kunnen creëren op servers etc :) ook kan je er terecht voor de clan ^^
  • daroy
ik ben eigenlijk dagelijks te vinden in de lfs kanalen op gamesurge.
#liveforspeed
#teamnic
#lfs.nl
en dan ook nog van de endu league, crc, ocrana en dE
voel er weinig voor om er nog een kanaal bij te zetten :p
iRacing Profiel
hoi
ik versta dus heel dat concept van life for speed eig niet.
moet je dat kopen in winkel en moet je het eerste deel ook hebben?
of via internet?
en is het nu eig een zalig spel? of steekt het vlug tegen?
yo
  • wheeler
Ik doe mijn best je zinnen te begrijpen en ik denk dat je wilt weten wat Live for Speed kost, ik zal de openinspost aanpassen met informatie hierover.
en de zin "en is het nu eig een zalig spel? of steekt het vlug tegen?" vind ik een klassieker maar ik snap niet wat je hiermee bedoelt :?
Er is ook een S2 progressreport. De LX8 is (terecht) ingeruild voor een UFR. Beter wat competatieve wagens dan eentje die lastig te besturen is.
[ Voor 28% gewijzigd door wheeler op 03-06-2005 17:50 ]
  • CRiMiNaL
CRiMiNaL
Witlof ^^
Thanks voor die update wheeler :D ..
vind het ook niet zo'n ramp dat die LX8 pleite gaat. Ik "denk" dat je met de formula wagens op ogeveer dezelfde PK per Ton ratio zit, maar dan toch iets meer controle erover d.m.v downforce :) ..
... MMORPG Addict.
  • Rostvertol-Mil
  • Laatst online: 13:46
wheeler schreef op vrijdag 03 juni 2005 @ 17:48:
Ik vind et eigenlijk wel jammer, de LX6 vind ik het leukst om te rijden. :) Maar zoals de statusreport meldt: "and the old LX6 is much better to drive than in the S1 version - competing with the RA and the FZ50"
Zal nog wel wat worden dus
[ Voor 14% gewijzigd door Rostvertol-Mil op 03-06-2005 19:00 ]
dot.blaat
ok sry hoor voor taalgebruik
wat ik zou zeggen onder "is het zalig of steekt het vlug tegen"
is het een schitterend spel en wordt het vlug saai of kan je er nog wat mee amuseren
2de vraag hoe kom je aan het spel?
kopen in de winkel?
en ind prijskaartje :p
toch bedankt voor je antwoord
  • wheeler
Als je racegames leuk vindt en dan met name de realistische dan is LfS een absolute aanrader. Met name online is het erg leuk en genoeg mogelijkheden tot close racing. Je kan alleen online een registratiesleutel kopen om dan je versie van LfS te "unlocken", hierna heb je de keuze tot alle banen en auto's. Aanschaf gaat heel simpel via creditcard of Paypal (wat ook met bankoverschrijving kan).
  • sander817
  • Laatst online: 15-11 19:37
sander817
5260 Wp + 13,2GJ Zonneboiler
ik rijd 1:36:20 ik wil graag een keer een [GOT] race meedoen
LFS is nu nog in beta test(S2) dus niet alle banen en wagens zijn beschikbaar
[ Voor 40% gewijzigd door sander817 op 03-06-2005 23:20 ]
Ik wil ook best [GoT] races mee doen :).
Vanmorgen flink aan het proberen en oefenen geweest en eerst was mn snelste 1.46.12 en nu 1.39.32 :*). Best wel veel vooruit gegaan in een ochtend vind ik, had ook een goede server te pakken zonder n00bs die gewoon volgas rechtdoor gaan. Stuurtje heb ik ook al besteld een DFP, komt als het goed is volgende week binnen, hopen dat mn rondetijden dan toch richting de 1.36 gaan.
  • daroy
Ik vind het eigenlijk jammer dat de LX8 weg is, waarom gewoon niet EN de LX8 EN de UF GTR?
mja, de UF GTR lijkt me wel een gaaf karretje om mee rond te scheuren. Helaas heb ik het de komende weken nog heel druk voor school dus veel racen zit er niet in, pb's op dit moment zijn:
GTi: 1.35.39
GT: 1.34.90
GTT: 1.28.72
iRacing Profiel
Nette tijden Daroy! Mijn pb in de GTT is 1:29.68, heb net wel een nieuw stuur dus ik hoop er nog wat vanaf te halen :) k'Zal ook [GoT] voor m'n nick zetten (TheJAG), is weer wat herkenbaarder. Nog voorkeur voor een kleur-combinatie?
Verwijderd schreef op zondag 05 juni 2005 @ 13:32:
Heey,
Dus tegen jou heb ik deze avond geraced ;)
Waren weer mooie wedstrijden hoor. Goede mensen, geen n00bs, en hele lekkere tijden, sommige races zelfs bijna iedereen rond de 1.35 _/-\o_
Ik zie je nog wel een keertje op LFS ;)
Gr.
[GoT]Martin
Btw. Ik heb een aantal dagen gelden ook S1 en S2 licensie besteld :D
[ Voor 10% gewijzigd door Verwijderd op 12-06-2005 13:44 ]
Verwijderd schreef op zaterdag 11 juni 2005 @ 23:26:
Heey,
Gr.
[GoT]Martin
Hey Martin, het waren idd topraces zaterdagavond! Verrassend weinig wreckers en eindelijk een andere [GoT]-tag :) Ze mogen nu wel trouwens wel eens komen met S2, ik kan niet wachten op wat andere banen. Blackwood is gaaf, maar wordt wel eentonig na 20 wedstrijden achter elkaar ;) Cya on track!
  • CRiMiNaL
CRiMiNaL
Witlof ^^
Jaaaaa
Het is zover, FULL Public release van S2 op 24 Juni
Dat is nog maar 1 weekje _/-\o_ _/-\o_ _/-\o_ _/-\o_
Lees meer op www.liveforspeed.net of hier
... MMORPG Addict.
  • scorpie
  • Laatst online: 13:47
scorpie
Supra Addict
Damn heb de 27e en 29e nog tentamens :(
Lekker racen met m'n DFP daarna (GT4 en LFS S2) :D
wil een Toyota Supra mkIV!!!!! | wil een Yamaha YZF-R{1,6} | wil stiekem ook een Ducati
"Security is just a state of mind"
PSN: scorpie | Diablo 3: scorpie#2470
Hm...heb het spel nu ook, best moeilijk met een gamepad, wel gaar van dat credits systeem. Ik heb weinig tijd om te racen en nu kan ik dus alleen met gare auto´s racen.
Misschien mag ik hier niet om vragen, maar heeft niet iemand een bestand/cheat waarmee ik de credits wat omhoog kan werken?
  • Fuzz10
Verwijderd schreef op vrijdag 17 juni 2005 @ 17:54:
Gewoon ff de tegenstanders dezelfde setup geven als jezelf (een ENORM brakke uiteraard) , vervolgens stiekem zelf ff je setup veranderen en rijden maar... Kost je een uurtje dan heb je je credits bij elkaar.
Of werkt dat niet meer in de laatste versie(s) ?
  • daroy
het systeem met auto's vrijspelen werk in s2 anders volgens mij.
voor de mensen die te lui zijn om engels te lezen staat het hier in het nederlands:
iRacing Profiel
  • wheeler
vet, een publieke release van S2! :9 Ik ga dit weekend de startpost even opfrissen met de laatste info.
Fuzz10 schreef op vrijdag 17 juni 2005 @ 19:07:
Weet ik niet, zal het wel ff proberen.
btw: moet je nou een s1 licentie hebben om de s2 te kopen, ja toch? of niet?
  • scorpie
scorpie
Supra Addict
Je kunt ook S1 en S2 in een bundel kopen.. kost je wel het dubbele uiteraard ;)
  • Tentacle1
  • Laatst online: 13-03-2025
Tentacle1
60% Puur Sap!
Het nieuws is al een stuk eerder vandaag uitgekomen maar ik wou toch melden dat vrijdagavond 24 juni de alphaversie van S2 uitkomt :D. Er zijn ook 35 nieuwe screenshots verschenen van de geupdate South City track.
System specs
  • sander817
sander817
ja, ik kan niet wachten!! eiundelijk
  • CRiMiNaL
CRiMiNaL
Witlof ^^
Tentacle1 schreef op zondag 19 juni 2005 @ 23:10:
Spuit 11 O-)
... MMORPG Addict.
  • wheeler
Afbeeldingslocatie: http://home.planet.nl/~dewit276/lfs-s2/SCS2-small.jpg
aantal vergelijkingen van Southcity (stratencircuit) in S1 en S2:
vergelijking 1, 2, 3, 4, 5 en 6
goede metamorfose~!
  • Jazzper
  • Laatst online: 14-11 15:12
Jazzper
BB4E^Guerilla
zo mijn engelse clan van een fps wees me op dit spel S2 Demo met zijn allen gespeeld. Wat een ellende om dat voor het eerste te doen zeg. Jos verstappen modus :D
Vooral omdat ik met kuch muis kuch speel.
Soms moet ik op rechte stukken non stop tegensturen. Ik neem aan dat mijn wielen(ophanging) dan stuk is?
webstek // Urenwerk - horlogeblog // mijn fotogear en beste fotos // Instagram @jazzper_nl
amai ziet er spel uit
is de besturing realistisch
realischer dan andere spellen?
  • Tentacle1
Tentacle1
60% Puur Sap!
:X .. ik dacht er is al een tijdje niet meer gereageerd, dus maar ach het is nu duidelijk ja :+
System specs
  • CRiMiNaL
CRiMiNaL
Witlof ^^
Jazzper schreef op dinsdag 21 juni 2005 @ 15:49:
Als je tegen moet sturen om recht te gaan is je ophanging idd naar de klote ;)
... MMORPG Addict.
  • daroy
Verwijderd schreef op dinsdag 21 juni 2005 @ 21:45:
naar mijn meening is dit 1 van de realistische race sims op de mark!
iRacing Profiel
daroy schreef op woensdag 22 juni 2005 @ 08:29:
Helemaal mee eens _/-\o_ , ik vind het even realistisch rijden als gtr en dat kost 40 euro meer. :)
*en me pa vindt nfsu2 realistischer... 8)7
is hij nu al uit?
en hoe moet je betalen. kzou hem graag hebben.
enkele vraagjes
kan je er lang mee gamen voor je het beu bent?
zit er wat variatie in?
bedankt !
  • Impry
  • Laatst online: 13-05 22:08
Impry
Rallymedia.nl
Verwijderd schreef op woensdag 22 juni 2005 @ 20:00:
is hij nu al uit?
enkele vraagjes
bedankt !
Hello Racers!
The time has come to give you a precise date for the first public version of S2.
We have decided to release a FULL PUBLIC ALPHA version on Friday 24th June 2005!
Betalen kan via CreditCard, PayPal of overmaken naar een Engelse rekening.
Je kunt het behoorlijk lang blijven spelen omdat er een mooie multiplayer optie op zit. Alle gereden tijden in de Multiplayer mode worden vastgelegd op: http://www.lfsworld.net/
Je hebt dus een enorme database aan tijden, je kunt zien waar je gereden hebt, hoe snel je was, etc. Ook kun je kijken wat de snelste tijd van iedereen is op een bepaalde baan, deze kun je proberen te beaten.
Variatie is er zeker aanwezig, veel soorten auto's en circuits.
Ik heb S1 heel veel gespeeld en ben dat van plan om met S2 ook te doen ;)
Rallymedia op YouTube - Rallymedia Facebook
  • sander817
sander817
kan niet w8en tot de 24ste :)
  • daroy
het leukste vind ik om in een league mee te rijden, dat brengt toch weer extra spanning met zich mee. Deze races zijn vaak ook wat langer dan de races op de publieke servers.
iRacing Profiel
thanks voor de antwoorden
  • CRiMiNaL
CRiMiNaL
Witlof ^^
pff .... wil niet langer wachten .. het is 24e .. wil S2 spelen .. !!!! ghehehe
... MMORPG Addict.
  • daroy
ik hoop dat ie een beetje optijd uitkomt vandaag. Moet vanavond nog naar een feestje
*waar is een bier smiley?*
iRacing Profiel
  • CRiMiNaL
CRiMiNaL
Witlof ^^
Iemand hier een stukje webspace waar ik S2 naar kan uppen. Zelf heb ik niet genoeg ruimte.
File is 129MB, en nee ik maak geen geintje. Ik ben echt in het bezit van S2 Full Alpha P
Contact details staan in me profiel
... MMORPG Addict.
  • DaWaN
  • Laatst online: 11:10
DaWaN
'r you wicked ??
CRiMiNaL schreef op vrijdag 24 juni 2005 @ 10:40:
www.hjhosting.nl en dan gratis pakket :) Evt kun je ook www.yousendit.com gebruiken :)
If you do not change direction, you may end up where you are heading
  • CRiMiNaL
CRiMiNaL
Witlof ^^
DaWaN schreef op vrijdag 24 juni 2005 @ 10:48:
Bedankt voor de tips, maar om een (ookal is het gratis) hosting paket te nemen voor zo'n file. Nee dank je. Ik heb YouSendIt gebruikt. Maar er word maar geupload met 15kb/s. En voor zo'n grote file duurt het dan toch nog wel eventjes. :+ Iemand die nog een andere oplossing heeft is welkom :)
[ Voor 8% gewijzigd door CRiMiNaL op 24-06-2005 11:16 ]
... MMORPG Addict.
  • Impry
Impry
Rallymedia.nl
YouSendIt is de beste optie :) (als niemand anders ruimte over heeft, mijn host zit in ieder geval stampvol, nog 1 mb vrij ofzo :P )
[ Voor 63% gewijzigd door Impry op 24-06-2005 11:40 ]
  • Vecodo
  • Laatst online: 08-11 22:42
dus als ik het goed heb :D
kan je dus een license kopen zodat je dit spel Full kan downloaden.
je kan license kopen voor S1
een license voor S2 ( Update )
en license voor S1 - Pre order S2
is het niet gewoon mogelijk om alleen S2 te kopen ?
( s1 hoef ik niet meer te spelen....DuH 8)7 )
  • CRiMiNaL
CRiMiNaL
Witlof ^^
roy2001 schreef op vrijdag 24 juni 2005 @ 11:48:
die S staat voor Stage. Feitelijk koop je het spel in stages.
Om even een rare vergelijking te maken met andere spellen je koopt er steeds een paar levels bij.
De demo (die jij waarschijnlijk ook gespeeld hebt) is het basis level.
S(tage)1 Had 3 tracks 7? Cars
S(tage)2 Heeft nog is 3 tracks en een zooi extra cars.
Wat ik wil zeggen is dit, je wilt een spel spelen vanaf level 1, niet ineens de 1e 3 levels overslaan.
Bij LFS heb je S1 nodig om S2 te spelen zodat je pakket compleet is. Dus JA je kan S2 alleen kopen, maar daar zit dus altijd S1 bij in :+
... MMORPG Addict.
  • Vecodo
dank je wel :) dat wou ik dus even weten ,
en aangezien me baas mee zit te kijken , kan ik het diet niet helemaal goed opzoeken
  • CRiMiNaL
CRiMiNaL
Witlof ^^
Daarom is het dus ook legaal voor mij om S2 te verspreiden, want zonder S2 licentie is het niks meer dan een demo :)
... MMORPG Addict.
  • Palomar
ik ben hem nu aan het downloaden van CRiMiNaL, zet hem daarna online!
  • CRiMiNaL
CRiMiNaL
Witlof ^^
Lees dit voor je S2 download
De client die door Palomar on-line word gezet is volledig legaal en komt van www.liveforspeed.com af toen daar vanacht korte tijd een mirror heeft gestaan. (waarschijnlijk foutje, maargoed dat doet er niet toe). Maar tot aan de officiele unlock van S2 (waarschijnlijk vanavond) kun je S2 nog NIET spelen. Vanavond heb je dus een S2 Licentie + de S2 Client nodig om het spel on-line te unlocken, dan pas kun je S2 compleet spelen. Tot die tijd kun je wel alle veranderingen in de demo content (BL, GTI, GT, GTT) bekijken.
[ Voor 12% gewijzigd door CRiMiNaL op 24-06-2005 12:34 ]
... MMORPG Addict.
  • Palomar
Ik ben hem nu aan het uploaden. Duurt nog een half uur. Ik heb hem al wel ff geprobeerd en je kunt idd alleen nog die demo auto's spelen. Ik heb ook geprobeerd de S2 map over mn oude S1 map te kopieren. Dat werkt wel en hij geeft aan dat je S1 license hebt, maar als je de S1 auto's wilt selecteren (MRT5 etc.) geeft ie een car error...
  • _-= Erikje =-_
  • Laatst online: 09-11 13:29
Zo zojuist m'n S2 licence gepaypalled, nu hopen dat die nog een beetje op tijd verwerkt kan worden door LFS :)
[edit]
Woh, das snel :) nu dus al verwerkt, S2 here i come :)
[ Voor 26% gewijzigd door _-= Erikje =-_ op 24-06-2005 13:10 ]
  • Vecodo
zit egt zwaar te twijfelen,
het is tog 24 pond ( gauw zo 35 euro ) voor niks , een download file.
Ik koop sowieso bijna nooit games , en als ik ze koop vind ik het hoesje en dergelijke ook super :D
iemand nog tips/ervaring of wat dan ook om mij over te halen ?
  • C.44
  • Laatst online: 05-08-2020
C.44
TurboCharged Supra Driver
zonder serial kun je niet online spelen ;)
Toyota Supra 3.0i Turbo Targa in Panther Black Mica - 300D || 30D || 10-20 || 50mm 1.8 mk1 || 18-55 || 17-85 || 75-300 || Giottos || Manfrotto || Cullmann || Kenko || Hoya
  • scorpie
scorpie
Supra Addict
C.44 schreef op vrijdag 24 juni 2005 @ 13:17:
Jij rijdt Supra?!??!?! OMG OMG :D mk3 denk ik? jaar / specs? kom op :D
Ook ik ga in m'n vakantie LFS S2 paypallen en playen :D \o/
  • CRiMiNaL
CRiMiNaL
Witlof ^^
roy2001 schreef op vrijdag 24 juni 2005 @ 13:14:
Mjah, het spel verkoopt zichzelf eigenlijk wel. Vooral het on-line racen (wat je ook kunt doen in de demo) is zoo verslavend. Dus als je nog niet overtuigd bent zou ik zeggen blijf gewoon de demo nog even doorspelen. In LFS maakt het immers niet echt uit wanneer je het spel aanschaft, er is niks uit te spelen ofzo.
... MMORPG Addict.
  • scorpie
scorpie
Supra Addict
Het punt dat ik graag wil aanhalen is dat dit spel gewoon écht realistisch aanvoelt, vooral in combinatie met een reacestuur (ik heb een DFP, en dat is gewoon echt te stoer :D ), daarom heb ik hem ook gekocht. De demo haalde mij gewoon over dat dit spel echt je geld waard is.
  • Impry
Impry
Rallymedia.nl
100% mee eens!
  • impact
CRiMiNaL schreef op vrijdag 24 juni 2005 @ 13:19:
...In LFS maakt het immers niet echt uit wanneer je het spel aanschaft, er is niks uit te spelen ofzo...
Klopt, maar ik moet wel zeggen dat de sfeer op de server's een stuk beter is. Er zijn een hoop debielen die die demo spelen. Die heb je in de full version eigenlijk bijna niet. Zit echt heel erg veel verschil in..
  • Palomar
ok, upload is klaar: http://www.rhpweb.nl/lfs/ niet allemaal tegelijk he ;)
[edit] Hij is nu officieel via www.liveforspeed.net te downloaden, dus bestand offline gehaald :)
[ Voor 43% gewijzigd door Palomar op 24-06-2005 22:01 ]
  • CRiMiNaL
CRiMiNaL
Witlof ^^
sorry voor de spam nogmaals, maar anders krijgen we hier straks "WTF Ik kan het niet spelen" gedoe
HIJ IS ZONET OFFICIEEL UITGEKOMEN : http://www.liveforspeed.net/
Hij is dus gelijk te unlocken als je een licentie hebt
[ Voor 22% gewijzigd door CRiMiNaL op 24-06-2005 13:59 ]
... MMORPG Addict.
  • Impry
Impry
Rallymedia.nl
Palomar schreef op vrijdag 24 juni 2005 @ 13:38:
330 kb/s! Goed bezig!
Alvast bedankt!
  • _-= Erikje =-_
Hmm, nog 3 uurtjes werken :)
  • Impry
Impry
Rallymedia.nl
Ik heb hem al binnen, nog ff snel voor school verder en dan 's kijken of het wat is :)
  • daroy
jeeeeeej, mijn skins zijn gefeatured in S2 :D :P
iRacing Profiel
  • scorpie
scorpie
Supra Addict
Thnx voor de mirror Palomar en CRiMiNaL, maar nu staat hij ook (groot) op www.liveforspeed.net zelf :)
  • C.44
C.44
Scorperito ik denk dat je mij wel es op het forum van Arnout bent tegengekomen onder m'n eigen naam ;)
specs:
Toyota Supra MK3 1988-4
3.0i 7MGTE
met een zooi mods maar goed ;) was ooit een n/a maar die is nu 4 keer stuk gelopen dus heb ik een turbo blok met auto gekocht en de boel over gegooid.
/offtopic
maar om terug te komen op LFS S2 ik vind vooral de physics mooi, enigste wat ik nog mis is afbrekend assen en dergelijke. Ik had namelijk op dat blackwood circuit eens de proef op de som genomen en em na het "rechte" stuk door de grindbak in de muur geplant.. en vervolgens het rondje afgereden :s
  • wheeler
shit ik moet naar huis! Lfs spelen :D
daroy: welke skins heb je gemaakt? en wist je vooraf niet dat je skins in S2 zaten?
[ Voor 55% gewijzigd door wheeler op 24-06-2005 15:12 ]
  • scorpie
scorpie
Supra Addict
Damn S2 is weer goed zeg, had m'n bandendruk opgeschroeft voor wat betere topspeed (dacht ik), klappen allebei m'n voorbanden met 210km/h :D
gelijk 2/3 van m'n remcapaciteit kwijt uiteraard (zeer goed merkbaar) en sturen gaat ook al niet meer helemaal ok.
Echt super vet, nu maar snel geld overmaken naar paypal en dan weer naar LFS team, ze hebben het meer dan verdiend!
  • Arfman
Arfman
Drome!
Damn, is die AI aggressiever geworden ofzo ? Net even een paar offline testraces gedaan, om m'n stuur weer goed in te stellen e.d., maar ik ben in 5 races 5 keer van de baan getikt !
  • kNarf_
  • Laatst online: 04-09-2024
De nieuwe formulewagens in S2 bevallen in elk geval erg goed. Net even online gereden op Aston GP geloof ik, das echt een heerlijk snelle baan met de Formula V8. Wel een beetje lomp dat er dan ook van die mini's en XF GTI's rondrijden maar goed :7
Aan de Formule XR en V8 heb ik voorlopig wel genoeg, de rest van de auto's boeien me niet zo heel veel.
  • Impry
Impry
Rallymedia.nl
Welke auto's zijn er beschikbaar in de unlicensed versie?
  • Vecodo
ok dit spel draait dus vooral om MP.
maar is mijn idee erover dan goed ? ( demo nog niet gespeelt )
je maakt accountje aan/license.
en is het dan ook dat je auto's moet kopen ( en bepaalde statussen krijgt, neem aan dat je een vet getuned auto niet tegen een peugot laat rijden :P )
en dat die auto's kapot gaan , dat je ze weer voor geld moet laten repaeren ?
of kan je gewoon je auto kiezen , en race maar ?
  • Impry
Impry
Rallymedia.nl
roy2001 schreef op vrijdag 24 juni 2005 @ 16:48:
Jap, je hebt geen carreer ofzo. Je koopt de license en krijgt meteen toegang tot alle auto's/tracks. Auto kapot, restart de race en nieuwe auto :) Simple as that.
  • _-= Erikje =-_
Impry schreef op vrijdag 24 juni 2005 @ 16:52:
In deze alpha misschien, auto's moe(s)t je echt verdienen met credits hoor...
  • Impry
Impry
Rallymedia.nl
_-= Erikje =-_ schreef op vrijdag 24 juni 2005 @ 16:53:
Oh ja, 's waar ook. Bij S1 had ik de demo al zo vaak gespeeld dat ik al genoeg credits had :P
