Xtreme Overclocking of dual G.SKILL TCCD LA up to DDR720
  • 65 views sinds 30-01-2008
The DDR600 512LA Package.
Afbeeldingslocatie: http://hkp2p.shopping7.org/~hardware/TEST/LA/00.JPG
Testing Environment
K8 939 3000+ (0.09)
G-Skill TCCD LA 256MBX2 2.85V
K8N Neo4 Platinum
GeForce 6200
TEAC 512EB
Delta 300W
Afbeeldingslocatie: http://hkp2p.shopping7.org/~hardware/TEST/LA/01.JPG
DDR682 CL3 4-4-8 Testing Report
Booting Screencut
Afbeeldingslocatie: http://hkp2p.shopping7.org/~hardware/TEST/LA/BIOS.JPG
Memtest 1.40, can not judge the NForce4 chipset.Maybe 1.40 edition Later
CPU 342X9=2728Mhz,DDR682 CL3 4-4-8 1T,PASS 4 Cycle
Afbeeldingslocatie: http://hkp2p.shopping7.org/~hardware/TEST/LA/M1T.JPG
The memory brandwishis is used 2T Command Environment.
CPU 342X9=2728Mhz,DDR682 CL3 4-4-8 2T
If someone has any question,Please do the test by yourself.And we can compare the difference between 1T and 2T.Some Motherboard is more strong ,others are not.
Afbeeldingslocatie: http://hkp2p.shopping7.org/~hardware/TEST/LA/M2T.JPG
In Windows XP environment. It is in the 1T Command.
Afbeeldingslocatie: http://hkp2p.shopping7.org/~hardware/TEST/LA/1T.jpg
When we check this situation,we can find that it has difference 300MB/S of brandwish.
Afbeeldingslocatie: http://hkp2p.shopping7.org/~hardware/TEST/LA/2T.jpg
In the Windows2003 environment, it can run DDR720.Because my CPU is not veryspowerful. I slow down the CPU MULTIPULER. It is the reason of low brandwish.
Afbeeldingslocatie: http://hkp2p.shopping7.org/~hardware/TEST/LA/720.JPG
In the Force3,MSI K8N NEO2 testing report
Afbeeldingslocatie: http://hkp2p.shopping7.org/~hardware/TEST/666/01.jpg
Afbeeldingslocatie: http://hkp2p.shopping7.org/~hardware/TEST/DDR/M670.jpg
Afbeeldingslocatie: http://hkp2p.shopping7.org/~hardware/TEST/DDR/DDR670.jpg
Afbeeldingslocatie: http://hkp2p.shopping7.org/~hardware/TEST/DDR/670p95.JPG
Overclocking is not the AMD.Motherboard ,promise cpec.
CPU&Motherboard can access 200MHZ,RAM access 300MHZ
Like Msi_NEO2, 2/3 can pass 300MHZ.
1/3 can not pass 300 MHZ If we make the RAM of pass DDR600,it will be error situation in this Motherboard.
In this high MHZ, It must depend the CPU,MOTHERBOARD,RAM.
All of three equipment are powerful, It can pass the related testing tools.
As I know,DDR600 is the limited item in the market.
NOTE:Next test Nvidia GeForce 6600GT AGP,coming soon
  • collission
collission
I'm back! :P
hou hier eens mee op he.... :(
zo kun je voor elk wissewasje wel een topic openen
[ Voor 47% gewijzigd door collission op 23-12-2004 10:13 ]
M'n Pimprig :P | [EiP] Granite Bay | [CiP] Pimp My PC-70 8)
  • dennismaus
  • Laatst online: 19:50
Wat een verschrikkelijk zinloos topic zeg.
  • Apen-nootjes
  • Laatst online: 03-04-2025
Apen-nootjes
aka Apen-klootjes
Nice, but not realy usefull for us do you think?
Closed
SmartDoDo: Ach, afhankelijk van je smaak kan het best een lekker geil ding zijn :P
You never had a date you couldn't inflate
