[Ervaringen] MSI K8N Neo2 (-54G)
Pagina: 1 2 ... 7 Laatste
  • 2.691 views sinds 30-01-2008
  • Tutti-frutti
Tutti-frutti
Graag gedaan!
Afbeeldingslocatie: http://www.chastelet.demon.nl/1/border.PNG
Na heel wat problemen met de levering van het bord, zijn de eerste eindelijk binnen bij de tweakers :)
Zo ook bij mij, en hierbij verklaar ik het echte Ervaringen topic voor geopend!
In a nutshell, MSI can be greatly considered as the "King of K8 platform."
Afbeeldingslocatie: http://www.msi.com.tw/images/product_img/mbd_img/7025.jpg
Afbeeldingslocatie: http://www.chastelet.demon.nl/1/specs.PNG
CPU
• Supports Socket 939 for AMD® Athlon™ 64 FX / Athlon™ 64 processor
• Supports up to 3500+, 3800+ Athlon 64 FX 53, or higher CPU
Chipset
• nVIDIA® nForce3 Ultra Chipset
- HyperTransport link to the AMD Athlon 64/Athlon 64 FX CPU
- HyperTransport supporting speed up to 1GHz (2000MT/s)
- AGP3.0 8X interface at 533 MT/s (million transfers per second)
- Two independent SATA controllers, for four drives
- IEEE 802.3 NVIDIA MAC for 1000BASE-T
- Dual Fast ATA-133 IDE controllers
Main Memory
• Supports dual channel DDR 266/333/400, using four 184-pin DDR DIMMs.
• Supports a maximum memory size up to 4GB with ECC.
• Supports 2.5v DDR SDRAM DIMM.
Slots
• One AGP (Accelerated Graphics Port) 1.5V 4X/8X slot
• Five 32-bit v2.3 Master PCI bus slots (support 3.3v/5v PCI bus interface).
On-Board IDE/SATA
• An IDE controller on the nVIDIA nForce3 Ultra chipset provides IDE HDD/CD-ROM with PIO,
Bus Master and Ultra DMA133/100/66 operation modes.
- Can connect up to 4 IDE devices
• Supports 4 SATA ports. Transfer rate is up to 150MB/s.
• NV RAID (Software)
• Supports up to 4 SATA & 2 ATA133 Hard drives
- RAID O or 1, 0+1, JBOD is supported
- RAID function work w/ATA133 + SATA H/D or 2 SATA H/D
Audio
• 7.1 channel audio codec RealTek ALC850.
- Compliance with AC97 v2.3 Spec.
- Meet PC2001 audio performance requirement.
LAN
• Supports dual LAN jacks
- 1 LAN supports 10/100/1000 Fast Ethernet by Marvell 88E1111 PHY
- 1 LAN supports 10/100/1000 Fast Ethernet by Realtek 8110S (1000Mbps)
IEEE1394
• VIA 6306 chipset
- Supports up to 3 x 1394 ports.
- Transfer rate is up to 400Mbps
On-Board Peripherals
On-Board Peripherals include:
- 1 floppy port supports 2 FDD with 360K, 720K, 1.2M, 1.44M and 2.88Mbytes
- 1 serial port
- 1 parallel port supports SPP/EPP/ECP mode
- 1 Audio jack(5-in-1), coaxial/fiber SPDIF out
- 8 USB 2.0 ports (Rear x 4 / Front x 4)
- 2 RJ45 LAN jack
- 3 IEEE 1394 connectors (Rear x 1/ Front x 2)
BIOS
• The mainboard BIOS provides "Plug & Play" BIOS which detects the peripheral devices and
expansion cards of the board automatically.
• The mainboard provides a Desktop Management Interface(DMI) function which records your mainboard specifications.
Dimension
• 30.5cm(L) x 24.5cm(W) ATX Form Factor
Mounting
• 6 mounting holes.
MSI’s Digicell
CoreCell Chip has four new technical features: Speedster, BuzzFree, PowerPro, and LifePro.
The Speedster technology of CoreCell Chip contains the most flexible BIOS options for overclocking, including async mode of FSB and memory frequency, 0.05V increment for memory voltage adjustment and the minimal increment of 0.0125V for Vcore.
BuzzFree technology examines the current system utilization and temperature level before leveraging thermal requirement & fan speed. It dramatically cuts the system noise by 50% by getting rid of the annoying buzz. Moreover, it also improves the quality of audio and video.
PowerPro prolongs the life of the motherboard, CPU, and fan by maintaining them under the optimum condition. It also detects and manages the motherboard utilization to prevent possible factors that may contribute to system crash.
LifePro technology prolongs the life of the motherboard, CPU and fan by maintaining then under the best condition. It can also detect and manage motherboard utilization to prevent possible factors that may contribute to system crash.
CoreCenter™, this all-in-one hardware console is an advanced combination of the popular PC alert and Fuzzy logic applications. It offers powerful functions such as hardware monitor, system alert, and instinctive overclocking UI.
Live Update™ 3 is a single utility software that automatically checks BIOS and driver updates. It includes MSI's Live BIOS™, Live Drive™, Live VGA BIOS™, and Live Utility™. Advanced users would also receive the latest information about MSI products and activities from MSI technical support.
De Doos :Y)
Afbeeldingslocatie: http://pics.computerbase.de/news/8228/2.jpg
[Meer...]
Inhoud:
• MSI Motherboard
• MSI Driver/Utility CD
• Sata(-raid)-Driver Floppy
• Sata-Cable (Optional)
• Sata Power-cable (for 2 Sata-devices)
• D-Bracket 2 (2 usb-ports)
• Round Cable of IDE-devices
• Round Cable of Floppydisk
• User's Guide
• Quick Guide
• Test Report
• Back IO Shield
Afbeeldingslocatie: http://www.chastelet.demon.nl/1/overklokken.PNG
Dit bordje is ook aardig interessant om over te klokken. Anandtech kreeg in hun review het bordje met gemak op het maximale instelbare, namelijk 300 mhz FSB >:). Met de nieuwste bios is 350 450 mhz instelbaar. De nforce 3 ultra hoeft dan ook niet extra gekoeld te worden , want dit gebeurt allemaal met het standaard fannetje :).
Afbeeldingslocatie: http://www.chastelet.demon.nl/1/koelertje.JPG
Ik kreeg hem zelf met een zalman nj47b blokje op 330 HTT.
Zoals te zien is, is het een wat andere plaats dan dat je gewend bent voor een northbridge (er is eigenlijk geen sprake meer van north- en southbridge, er is maar 1 chip). Voor waterkoeling op de northbridge lijkt deze plaats niet echt slim uitgekozen. Maar zoals je kan zien zou waterkoeling niet veel nut hebben, je zou er niet hoger door kunnen klokken. Verder zijn er wel wat wc-blokjes die erop passen. Bij koelercompatibility in de eerste reply staat welke koelers je zoal kan gebruiken.
Dit zijn de instelbare items met betrekking tot overklokken:
FSB: 200-450mhz, in stappen van 1mhz. Let wel dat je minimaal bios versie 1.2 erop moet hebben voor een max fsb van 450 mhz (bios 1.0: tot 300 mhz bios 1.1: tot 350 mhz) . Bios-links vind je onder links van dit topic.
CPU Multiplier: 4 - 20 x, Voor FX-cpu's kan men boven de standaard MP instellen. Vanaf bios 1.2 is het mogelijk dit met halve multipliers in te stellen :) Maar dit is niet altijd aan te raden (zie tips)
AGP: 66-100mhz, in stappen van 1mhz
Vcore: 1.55-1.85V, in stappen van 0,05V , maar met de Speedster technology van de Corecell in stappen van 0.0125V
Vdimm: 2.50-2.85V, in stappen van 0,05V. (vind ik een klein beetje jammer :|, had liever tot 3.3 gezien ;) )
AGP-voltage: 1.50-1.85V, in stappen van 0,05V
Verder zijn er ook nog Hidden Bios Opties:
Vid Hiermee kan je het voltage van de voltageregulator regelen als ik het goed heb begrepen. Dit zou misschien wat impact kunnen hebben op de hoogte en stabiliteit van de vcore.
NV/ATI Speed up Met deze setting kan je jou agp-kaart wat extra mhz-en laten geven, geregeld door het moederboard. Zowel je videogeheugen als gpu wordt iets opgekrikt (10 à 20 mhz). Clock je liever zelf gewoon je kaart over, zet deze functie dan op disabled.
Lees voordat je aan het overklokken gaat nog even de tips door, hier staan belangrijke dingen zoals het gebruik van sata-poorten en overklokken...
• Mods
OCZ DDR-Booster
Na even rondgeneusd te hebben op Xtreme Systems kwam ik een post tegen waar iemand de OCZ DDR-Booster gebruikte op de k8n Neo 2 :) Deze lijkt dus compatible te zijn:
Ok I am now running the ddr booster at 3.2v on my Neo2. It does work fine and has allowed me to hit 300HTT 1:1 so far on my 3500 EBs.
* Tutti-frutti heeft zelf de ddrbooster getest, en het werkte :)
Afbeeldingslocatie: http://www.chastelet.demon.nl/1/tips.PNG
Hier staan bekende problemen met oplossingen, of tips waardoor je meer performance kan krijgen.
Hogere Memory-bandwidth
Voor hogere geheugen scores moet je in het Cell-menu, bij memory settings de "1T/2T Memory Timings" op 1T zetten. De score met een HTT van 200 (ddr400) vliegt dan van zo'n 4800 MB/s naar 5900 MB/s !
Oplossing voor de combinatie: overklokken + Sata-schijven
Het blijkt dat de Sata-poorten 1 en 2 geen goedwerkende PCI-lock hebben. De pci-lock functioneert wel correct op de poorten 3 en 4. Gebruik daarom als je van plan bent te gaan overklokken de sata-poorten 3 en4. Zorg er ook voor dat je minimaal bios 1.2 draait.
Met de satapoorten 1 en 2 zou je niet hoog kunnen komen met de htt. Misschien komt hier nog een biosupdate voor...
Pas op met het gebruik van halve multipliers
Sinds bios 1.2 kunnen er in de cell menu (bios) halve multipliers voor de cpu-speed ingesteld worden. Het is aan te raden om deze niet te gebruiken, omdat je dan performance verliest op je geheugensnelheid. Het werkt namelijk alsvolgt:
Als je cpu-HTT en mem 1:1 lopen, en de multiplier van de cpu is 11x, dan wordt de memspeed vastgelegd door de cpu speed door 11 te delen. Voorbeeld: HTT=250, MP=10. Mem speed = 2500/10 = 250 (ddr500).
Pak je nu 10.5 als multiplier, dan wordt de mem speed als volgt:
cpu-speed = 10.5x250 = 2625
Mem-speed = 2625/11 = 239 mhz.
Dit zit hem in de cpu memcontroler en kan helaas niet veranderd worden, de cpu kan alleen door hele multipliers delen.
Halve multipliers zijn wel aan te raden , als je cpu nog niet aan zn max zit, maar mem wel. Je kan zelf het beste even kijken wat het beste resultaat oplevert.
In mijn geval heb ik ook even getest. Ik ga zelf wél voor een halve mp:
11x232 , ddr464 = 6903 MB/s @ sisoft membench
10.5x243 , ddr464 = 6907 MB/s @ sisoft membench
ik heb meerdere malen getest, maar veel verschil is het natuurlijk niet...
thnx to Pakjebakmeel voor quote van forum
Windows installeren op een Sata-Raid array
Tijdens het laden van de windows setup moet je, zoals gewoonlijk met raid-configuraties, op F6 rammen. Bij het bord is een floppy geleverd met daarop de Raid drivers. Je moet tijdens de setup niet 1, maar 2 drivers installeren, namelijk:
-Raid Class Driver
-Storage Controller
Dit is erg belangrijk, anders ziet windows de schijven appart, en niet als 1 raidarray.
BSOD's ? Aggressive timings op Disabled zetten!
Aggressive Timings blijkt nu ook een erg bekende oorzaak te zijn van de blauwe schermen. Je zal waarschijnlijk, met Aggresive timings aan, veel BSOD's krijgen met "Beginning of dump Physical Memory". Wanneer je Aggressive timings uitzet in het Cel menu, zal je systeem hoogstwaarschijnlijk stabiel zijn :).
Nog steeds Instabiel ?
Nadat er erg wat postings geweest waren met instabiliteitsproblemen lijkt het erop dat de gegevens uit de SPD-chips op de geheugenmodules niet goed worden uitgelezen. Ik weet niet of dit aan het bord of aan de geheugencontroler van de cpu's ligt. Oplossing lijkt gewoon het zelf instellen van memorytimings en geheugen voltage.
Daarnaast is het aan te raden om ALTIJD satapoort 3 en 4 te gebruiken, zoals hierboven beschreven.
Dual Channel, welke slots ?
Als je DUAL CHANNEL wilt laten werken dan moet je de 2 latjes ram in het groen EN paarse slot steken(slot 1 & 2). Dit zijn dus de 2 onderste geheugenbanken. Dit is dus niet, zoals bij intel, in het eerste en derde slot. Als je het in slot 1 & 3 plaatst heb je kans op een instabiel systeem. Dit staat ook volledig uitgelegd in de manual :)
thnx to kennes
Audio-driver installeren, erg belangrijk!
Als je standaard de drivers van nvidia installeerd (nforce drivers) dan worden de audio drivers niet geinstalleerd. En dan kan je de nvmixer ook niet gebruiken. En omdat de nvidia drivers veel beter klinken zijn die drivers toch aan te raden. Om hier gebruik van te kunnen maken moet je de drivers MANUEEL installeren. Rechts klikken in apparaatbeheer op het audiodingie. dan moet je NIET ZOEKEN nemen en dan bladeren en dan de file nvmcp.inf, en vervolgens 1 van de die items die erop komen. (die nvmcp.inf file haal je uit de c:\NVIDIA\4.27\audiodrv-map). Je kan op deze manier gebruik maken van alle nvidia geluidsfuncties, en bijvoorbeeld ook het volume per box instellen :).
thnx to kennes
Afbeeldingslocatie: http://www.chastelet.demon.nl/1/links.PNG
• Fabrikantinfo:
MSI K8N Neo 2 Platinum
• Handleiding
De Handleiding V1.1 (pdf , 7MB)
• Reviews
Anandtech Socket939 motherboard Round Up
PC Perspective Review
Een magere Zdnet review
Hot Hardware S939-motherboard round up
• Waar is de MSI K8N Neo2 het goedkoopste?
Link Naar de pricewatch
• Biossen
Update je bios, en je moederboard wordt instelbaar tot 450mhz })
Msi Biossen
In bios 1.2 zitten de volgende changelogs:
- Support FSB to 450MHz
- Support K8 CPU Rev. D 939-Pin 128-bit
+ Added .5 multipliers !
+ Fixed CPU temps !
+ Pci-lock werkt correct. Helaas nog niet op sata-poort 1 en 2
Beta:
Hier en hier kan je beta biossen vinden.
Nummering van biossen werkt als volgt: 1.23 = 1.2 beta 3 , 1.2= 1.2 official (nieuwer dan 1.23).
Afbeeldingslocatie: http://www.chastelet.demon.nl/1/etc.PNG
Mijn ervaring:
Na hem bij de volgende shops besteld te hebben, heb ik hem eindelijk binnen:
-Euromaxi
-Salland Automatisering
-Rodep IT
-Komplett, de gelukkige verkoper :+
Ik zal jullie eerst een foto impressie geven!
Afbeeldingslocatie: http://www.chastelet.demon.nl/1/thumbneo1.JPG Afbeeldingslocatie: http://www.chastelet.demon.nl/1/thumbneo2.JPG
Afbeeldingslocatie: http://www.chastelet.demon.nl/1/thumbneo3.JPG Afbeeldingslocatie: http://www.chastelet.demon.nl/1/thumbneo4.JPG
Afbeeldingslocatie: http://www.chastelet.demon.nl/1/thumbneo5.JPG Afbeeldingslocatie: http://www.chastelet.demon.nl/1/thumbneo6.JPG
De lay-out
Het eerste wat mij opviel dat deze pcb van een ander materiaal is gemaakt, het lijkt wel een soort hardboard of iets. Ik weet niet wat voor materiaal het is :?
De lay-out van dit bord is erg goed. Zo is de socket bijvoorbeeld 90 graden gedraaid met wat we "gewend" zijn, s939 staat nog aardig in de kinderschoentjes natuurlijk. Maar voor bepaalde koelers heeft dit namelijk wel een voordeel, want de warme lucht wordt daardoor direct naarboven geblazen. Verder blaast de cpu koeler de lucht over de dimm sloten heen, zodat de ramreepjes gekoeld worden.
Op het bord zitten 4x 3-pin fan connectors, waarvan er 1 door de standaard southbridge koeler wordt gebruikt. Onderin, naast de bios chip zit een aansluiting voor een system-fan. Onder de atx-connector zit er een voor de standaard sb-koeler. Links van de socket vinden we de cpu-fan connector, en als laatste plaats voor een 2e systemfan boven in het bord (bij de dimsloten). Er is dus overal wel een aansluiting in de buurt.
Wat alleen een beetje jammer blijft is de plaatsing van de nforce-chip. Deze valt net onder de agp kaart, waardoor het plaatsen van bijvoorbeeld waterkoeling op de NB, of een grote koeler op je vga (als je ook een andere koeler op de nforce wilt) misschien een beetje moeilijk wordt.
Zelf heb ik een Zalman NB47-j die ik er heb opgezet. Dit bleek eigenlijk heel erg mee te vallen. Het enige wat ik nog hoefte te doen, is 3 koelvinnen naar binnen buigen. Dit is zelfs overbodig, omdat het alleen het chassis van een condensator van de 9800pro lichtjes aanraakt:
Afbeeldingslocatie: http://www.chastelet.demon.nl/1/neozalman1.JPG
Afbeeldingslocatie: http://www.chastelet.demon.nl/1/neozalman2.JPG
Wat ook me ook opvalt is dat de connectors: IDE, FDD, ATX bij elkaar geplaatst zijn. Dit heeft bij inbouwen het voordeel dat alles vanuit 1 punt naar de rest van de kast gaat, is weer wat netter :).
Revisie
De revisie die op mijn bord staat is:
Afbeeldingslocatie: http://www.chastelet.demon.nl/1/revisie.JPG
Resultaten
Ik zal hier binnenkort mijn ervaring plaatsen met betrekking tot overklokken.
Ik zal benchmarks plaatsen. Waar ik erg naar benieuwd ben is de memory score. Ik haalde met mijn asus A8V-deluxe namelijk maar 4800 MB/s op 200mhz fsb (cas2.5-3-3-7)
Dit zijn nu mijn systeem specs:
Msi K8N Neo2 Platinum + Wireless
AMD64 3500+ (code)
2x 512 MB DDR400 c2.5-3-3-7 Twinmos pair (maybe vervang ik deze)
2x Maxtor DMP9 SATA 80GB @ Raid0
Sapphire 9800pro 128MB R350 @ 420/365
Creative Audigy 2 Player
Levicom 500w voeding
Waterkoeling: Alphacool NexXxos HP cpublok, Tha_Mafkees gpublok, 900l/u pomp, evo360 rad.
Samsung dvd-rom
Lite-on 832s dvd-rw
Update:
De eerste resultaatjes. Dit is nog totaal on-getuned.
De Nvidia sata-raid controler vind ik erg goede prestaties leveren. Op elk niveau beter dan mijn nforce2-bordje met silicon image controler. Ik haalde daarmee max 105 MB/s. Dit is het resultaat nu:
Afbeeldingslocatie: http://www.chastelet.demon.nl/1/atto.PNG
Dan de geheugen bench >:) . Ik haalde eerst op ddr400-2.5-3-3-7 maar 4850 MB/s, maar ik had de 1t/2t Memory timing toen op 2T staan. Dit was waarschijnlijk ook het probleem bij mij asus a8v, dat ik niet hoog scoorde. Dit is het resultaat met een HTT van 215: ddr430 cas 2.5-3-3-7 (1T Timings):
Afbeeldingslocatie: http://www.chastelet.demon.nl/1/mem215fsb.PNG
Htt van 230 ddr460 2.5-3-3-7 (1t timings), helaas wel memtest errors:
Afbeeldingslocatie: http://www.chastelet.demon.nl/1/mem230htt.PNG
En ook een htt van 280 is no problemo voor dit bord:
Afbeeldingslocatie: http://www.chastelet.demon.nl/1/htt.PNG
3dmark heb ik ook gedraaid. Dit is met een 9800pro op 405mhz gpu en 365 mem. Cpuspeed is uitgelezen met cnq aan, waardoor de cpu op dat moment 1050mhz liep. Tijdens de test was dit 11x210= 2310 mhz.
http://service.futuremark.com/compare?2k3=2969671
Toevoegingen / Vragen ?
Heb je nog vragen of toevoegingen waarvan je denkt dat dit de startpost moet komen ?
Mail me via Afbeeldingslocatie: http://www.tutti-frutti.speedlinq.nl/neo2/email.GIF
[ Voor 143% gewijzigd door Tutti-frutti op 29-09-2004 14:15 . Reden: Nieuwe lay-out en "compatible koelers" ]
4015Wp west (Dordrecht)
  • Tutti-frutti
Tutti-frutti
Graag gedaan!
(In)compatible Koelers
Afbeeldingslocatie: http://www.tweakers.net/g/table/spacer.gif
Als toevoeging op de startpost zal ik hier een lijst plaatsen met compatible koelers. Dit wegens de afwijkende lay-out van het bord die naast zijn voordelen (betere flow), helaas ook zijn nadelen kent dat er een aantal koelers niet passen. Hier plaats ik de koelers waar twijfels over kunnen bestaan.
Mail me dus als je weet dat jouw koeler/vgakoeler/cpukoeler-combinatie wel of niet past:
CPU
Zalman 7000 CNPS 7000 (A/B) (Cu/Al/Al-Cu)
Afbeeldingslocatie: http://www.tutti-frutti.speedlinq.nl/neo2/zalman70001.JPG Afbeeldingslocatie: http://www.tutti-frutti.speedlinq.nl/neo2/zalman70002.JPG
Deze koeler past mits je geen passieve heatpipe koeling gebruikt. Mocht je ook gebruik maken van wat hogere geheugenmodules zoals Corsair XXL Pro geheugen, dan zou je deze in slot 3 en 4 moeten doen.
Chipset
Zalman N47J
Afbeeldingslocatie: http://www.tutti-frutti.speedlinq.nl/neo2/zalman47.JPG
De N47J past op de nforce3-chip, als je geen heatpipegeval of grote vgakoeler (Arctic silencer) gebruikt. Hij past in ieder geval met de volgende 3dkaarten:
-9800pro (voor de zekerheid 2 pinnetjes iets naar binnen buigen)
Graph-O-Matic Rev2.0 VGA & Chipset
Afbeeldingslocatie: http://www.innovatek.de/contentServ/3.0/www.innovatek.de/data/media/191/500618.jpg
Deze past zonder problemen.
VGA-koelers
Heatpipe Koelers
Afbeeldingslocatie: http://www.tutti-frutti.speedlinq.nl/neo2/zalman80hp.JPG
Door het gebruik van heatpipekoelers vervallen een aantal mogelijkheden voor het plaatsen van andere koelers. Bepaalde cpu-koelers zullen hierdoor in de knoop komen (zoals de 7000-serie van zalman). Andere chipset-koeling wordt onmogelijk, tenzij je een betere en net zo'n lage koeler als de standaard msi koeler weet te vinden.
Arctic Silencer
Afbeeldingslocatie: http://www.colorstone.com.tw/proimages/f1/arcticcooling/vga.jpg
Door het plaatsen van deze koeler wordt het moeilijker om andere chipsetkoelers te plaatsen.
[ Voor 132% gewijzigd door Tutti-frutti op 22-09-2004 17:44 ]
Wat een pracht bord :9~ :9~ ! Als de cpu prijzen nog wat dalen dan koop ik er echt direct eentje :9~ :9~
Ben er letterlijk een hele dag ermee bezig geweest.
Vanmorgen kwam de mobo binnen samen met de SB Audigy 2 ZS en de Antec Lifestyle Sonata!
Wat een gedoe om al die ledjes van de kast op het moederbord aan te sluiten en de bedrading maakte het er niet allemaal makkerlijker op.
Laat in middag eindelijk windows er goed op nadat ik eerst problemen had met m'n Win XP cd die zit te kloten met m'n nieuwe dvd speler. Dan maar een normale cd-rom speler erin hangen en ja hoor, het werkte. Iemand een oplossing hiervoor? :?
Windows loopt zeer snel alleen al wat bsod's gehad en wat vage happeringen.
AMD Athlon64 3800+
1 GB PC3200 (Corsair TWINX1024 3200LLPL) (CAS 2)
Antec Lifestyle Sonata (380watt)
SB Audigy 2 ZS
X800XT PE
Wel raar dat ik nieteens SATA drivers hoefde te installeren aangezien m'n bios meteen m'n WD Raptor 10.00rpm SATA herkende. 3DMark2004 ging midden in de test terug naar windows, vermogen probleem?
Verder stond in de bios ook iets van 'SATA1/SATA2 dma transfer disabled' :?
Morgen nog maar en fresh install en dan met SP2 en de nieuwste drivers etc. Eerst aar even Doom 3 proberen. :)
  • Tutti-frutti
Tutti-frutti
Graag gedaan!
Bsod's zijn niet zo lekker. Misschien even wat meer volt (gewoon 2.85volt) over je ram zetten. Misschien even kijken of memtest een error geeft ?
[ Voor 77% gewijzigd door Tutti-frutti op 18-08-2004 22:04 ]
Volgens de handleiding van het mb moet ik mijn 2 latjes geheugen (2x 512) in een groen én paars plaatsen. Klopt dit?
Bij de intel chipsets moet je ze in dimm 1 en 3 plaatsen... en bij het msi k8n neo 2 mb precies in dim 1-2 (of 3-4 )
  • Tutti-frutti
Tutti-frutti
Graag gedaan!
Verwijderd schreef op 18 augustus 2004 @ 22:15:
Klopt. Ik had ze in eerste instantie beide in groen zitten. Maar je moet er 1 in channel A en 1 in channel B doen, dus gewoon naast elkaar, 1 in groen , 1 in paars :)
  • KifArU
Verwijderd schreef op 18 augustus 2004 @ 21:03:
AMD Athlon64 3800+
Gebruik je de standaard voeding van deze kast? (truepower 380 watt)
Zo ja, wat is het geluidsniveau van deze kast/voeding met de boxed cooler?
En op welke timings loopt je geheugen?
  • woekele
woekele
woekele
Jammer dat dit mobo geen PCI-E heeft... Als ik deze nu zou kopen moet ik straks weer upgraden.
  • Tutti-frutti
Tutti-frutti
Graag gedaan!
Ik heb nu het probleem dat ik windows niet op mijn raid array kan zetten :?
Ik heb een raid array aangemaakt, 2x 80 gb = 160 gb Raid0. Deze wordt ook gewoon herkend in de sataraid bios van nvidia. "0 healthy NVIDIA STRIPE 153GB"
Maar als ik , met f6 gebruikt en driver van nvidia, windows probeer te installeren, krijg ik 2 schijven van 80 gb te zien :(. Ik moet er dus gewoon 1 van 160 te zien krijgen. Ik kan nu dus gewoon niet windows installen op de raid array.. zucht
Mja je moet beide (raid & sata) drivers installeren (met F6 toets)
Maar dit weet je waarschijnlijk wel?
En het is idd spijtig dat de nforce 3 geen pci express ondersteund.
Mja ;-) hopelijk heeft msi of asus een moederbordje met de k8t890 chipset tegen eind september ;-) dan kan ik ook een pci express GeForce 6600gt aanschaffen.
nForce 4 wordt ook gereleased in Q4 ... maar dan wel eind november denkik.
[ Voor 61% gewijzigd door Verwijderd op 18-08-2004 23:31 ]
  • Tutti-frutti
Tutti-frutti
Graag gedaan!
Verwijderd schreef op 18 augustus 2004 @ 23:28:
Nee.. dat niet, maar ik kan 2 drivers selecteren... Raid class driver en Storage controler. Ik zal ze eens beide doen...
edit: You're the man!!! :D
[ Voor 9% gewijzigd door Tutti-frutti op 18-08-2004 23:33 ]
lol. Mja ik had het anders ook weeral op dit forum gevraagd hoor. Maar als je een hele maand op een moederbordje moet wachten dan ga je uit verveling de online manual lezen ;-) ... en daar viel me op dat je beide drivers moest laden ...
  • Tutti-frutti
Tutti-frutti
Graag gedaan!
Hmm, ik had het niet gezien in de manual eigk. Maar ik heb altijd maar 1 driver te hoeven installen, het was daarom niet zo vanzelfsprekend :)
Wat is trouwens jouw temperatuur. Ik heb waterkoeling erop, en ik zit in bios op 50 graden, default speed (3500+), en default vcore. Vind het wel aan de hoge kant eigk.
[ Voor 54% gewijzigd door Tutti-frutti op 18-08-2004 23:38 ]
  • steven2
  • Laatst online: 04-11 05:38
Welke IDE-drivers gebruiken jullie. Ik heb namelijk de eerste keer de drivers van Nvidia gebruikt (niet de SW, daar had ik nee op gezegt). Na het opnieuw starten duurde het een hele tijd voordat windows opstartscherm verscheen.
Herinstall gedaan en toen geen IDE-drivers en toen liep hij wel snel door :)
ASUS Sabertooth X79, Intel Core i7 3930@3800MHz, 16 GB DDR3 (G.Skill F3-17000CL9Q-16GBZ), XFX Radeon R9 290, Sound Blaster X-Fi XtremeMusic, 1x 256 GB Samsung 840 pro SSD, 1x 1 TB Samsung Spinpoint F3, 1 x 3 TB Seagate ST3000DM001
  • Tutti-frutti
Tutti-frutti
Graag gedaan!
steven2 schreef op 18 augustus 2004 @ 23:41:
Je moet gewoon met sw pakken.. alles installen van dat pakket (misschien op audio of ethernet uit, als je dat niet gebruikt)
  • steven2
Tutti-frutti schreef op 18 augustus 2004 @ 23:49:
Maar komt dit probleem bij jullie niet voor?
  • Tutti-frutti
Tutti-frutti
Graag gedaan!
steven2 schreef op 19 augustus 2004 @ 00:27:
Ik installeer mijn windows op een sataraid array, en installeer ook altijd de sw driver, dus ik zou niet weten of ik in jouw geval problemen zou hebben, in mij geval iig niet :).
Verder ben ik ook op nog iets kuts gelopen, wat ik bij mijn Asus A8V ook al had:
Bij modules van ddr333, kan ik op geen een manier het mem op ddr400 zetten. Ik heb namelijk een ddr333 blokje dat op 3.1 volt met gemak ddr480 2-2-2-11 deed. Op 2.8 volt was ddr440 ook geen probleem (infineon usa he ;)).
Weet iemand of het op een of andere manier mogelijk is om echt 1:1 te draaien en de SPD van het geheugen te negeren ?
  • Fusion_XT
  • Laatst online: 20-07-2023
Fusion_XT
Helemaal LEIP !
O+ ......wat een mobo zeg ! :9~
Shit ik moet nog 2 maande w8ten ;(
Dan krijg ik dit bord met een:
Amd Athlon 64 3500+
MSI Geforce 6800GT
2x512Mb Corsair TwinX 3200XL Pro
Raptor Sata schijfje komt later :)..
Maar ik hoop dat iets word ! _/-\o_ ...
Doom 3, Half-life 2, F.E.A.R, Stalker !!! Here i COME ! :D :9 ..ghehe.
  • pelican
pelican
Ik hoop dat het jullie allemaal wat beter vergaat... mijne is er al mee gekapt
na wat vreemde ervaringen met corecenter.... :+
  • tormentor1985
  • Laatst online: 24-11 09:13
pelican schreef op 19 augustus 2004 @ 08:04:
?? hele bord stuk ?? geen piepjes geen beeld nix meer ??
  • pelican
pelican
tormentor1985 schreef op 19 augustus 2004 @ 08:44:
Geen piepjes, geen lichtjes via de d-bracket... geen koeler die gaat draaien...
Voeding werkt nog wel, videokaart ook (getest in andere pc)...
of m'n cpu naar de haaien is weet ik niet, kan ik niet testen...
  • SH4D3H
  • Laatst online: 04-10-2025
Moet je kijken offie piept zonder CPU erin :)
  • Tutti-frutti
Tutti-frutti
Graag gedaan!
Pak toch eens een andere voeding. En probeer je systeem even te booten in labaratorium houding.. oftewel buiten de kast. Gewoon kijken of het mobo een kick geeft geheel kaal, dus zonder mem,cpu etc, met alleen de voeding erin. Even met schroendraaiertje de 2 pinnetjes van de powerswitch met elkaar verbinden, dan weet je zeker of hij het vol gaat houden.
Maar wat is er precies fout gegaan toen met corecentre... een stomme fout kan het niet zijn, want je moederboard gaat volgens mij niet kapot van kloten met corecell ;)
Kan dit bord Dual Channel met 2x 256 en 1 x 512 mb latjes?
  • Tutti-frutti
Tutti-frutti
Graag gedaan!
Verwijderd schreef op 19 augustus 2004 @ 11:55:
edit: Ik had gelezen 2x256, 2x512. Maar in het geval van 3 latjes wijs ik je op de handleiding, pagina E-2-8 (manual staat in startpost).
Please select the identical memory modules to install on the dual
channel, and DO NOT install three memory modules on three
DIMMs, or it may cause some unkonwn failure.
[ Voor 79% gewijzigd door Tutti-frutti op 19-08-2004 12:35 ]
  • Cartman!
ik heb em ook binnen, ff in mekaar knutselen! :)
Yeah, same here net 10mins binnen, ga zo bouwen maar al gezien dat me NB waterblock erop past zonder conflict met me vga kaart, nu een radeon9700pro over 2 weekjes een x800, beide lijkt het aardig mee te passen
voor de mensen die passende waterblokken zoeken deze gebruik ik : Nextcool WaterCUBE LT rel.B Kit
Afbeeldingslocatie: http://www.nextcool.com/LT-3small.jpg
  • Tutti-frutti
Tutti-frutti
Graag gedaan!
Verwijderd schreef op 19 augustus 2004 @ 14:04:
Dat gaat wel passen als je geen huge koeler op je vga hebt :)
  • jippen
  • Laatst online: 22-06 14:47
nice, de mijne is ook bestelt.
Heb je veel moeilijkheden gehad om het wc blok er op te krijgen?
want zo te zien moet dat zwart ding er af.
ik ga er namelijk een antartica op plaatsen.
En omdat er 2 vijsjes door moeten, moet da zwart ding er waarschijnlijk af.
ging dit zonder slag of stoot ?
was de nb cooler vast gelijmt? of ging ie der gewoon af ?
alvast bedankt
Hoeveel volt hebben jullie op je mem staan?
  • Tutti-frutti
Tutti-frutti
Graag gedaan!
Verwijderd schreef op 19 augustus 2004 @ 15:43:
2.85
  • diontjuh
  • Laatst online: 16-11-2014
diontjuh
for president
Ik heb t board dus ook vandaag ontvangen, maar nu heb ik voor me LCD stats MBM nodig, maar bij de installatie van MBM staat geen MSI erbij? hoe kan ik dan temps aflezen met dit board?
-=-=- [CM] Stainless Art -=-=-[cip] blauwe plexi cube -=-=-=
Anders misschien 'microstar' kiezen? K8N Neo 2 staat er spijtig genoeg niet bij...
  • diontjuh
diontjuh
for president
eens gaan proberen, en nog een vraag dan: van mijn Sata hdd werd bij de windows installatie maar 140 GB van de 250 Herkent, nu in windows dus ook.. is het mogelijk om de andere 90 GB nog op te halen?
  • Tutti-frutti
Tutti-frutti
Graag gedaan!
diontjuh schreef op 19 augustus 2004 @ 16:12:
Het is een enkele Sata-hdd ?
Heb je tijdens de setup f6 geramd en de IDE Storage driver geinstalleerd ?
Misschien kan je dat even bekjiken, watvoor schijfgrootte hij dan ziet, en desnoods installeer je beide drivers van de floppy tijdens de windows setup (Storage controller en Raid class driver)
  • diontjuh
diontjuh
for president
Tutti-frutti schreef op 19 augustus 2004 @ 16:14:
Het is idd 1 Sata hdd, maar ik hoefde geen sata drivers in te geven dus ook niet f6 te rammen, windhoos zag de hdd (toen nog 1 partitie van 250gb) gewoon zelf en toen ik die verwijderde had die nog maar 140 over
  • T-mo-T
  • Laatst online: 19:00
Ik vind de prijs nog best wel meevallen! :9
Misschien toch maar doorsparen... :*)
diontjuh schreef op 19 augustus 2004 @ 16:17:
Zelfde hier. Zonder sata drivers te installeren herkende windows de hdd a;.
Ik heb trouwens nogsteeds problems met Doom3. Als ik in de game zit dan gaat hij af en toe terug naar windows. Ik had de memory voltage al op 2.70 gezet maar nogsteeds af en tie terug naar windows. Ik snap er niks van. Op de default waarden moet het toch goed doen? Het ligt toch niet aan de Vcore?
Zie m'n specs voor de config...
  • diontjuh
diontjuh
for president
Verwijderd schreef op 19 augustus 2004 @ 16:25:
leuk systeem maar wat zijn je cpu temps? zit hier op idle 52 graden :S, mja binnenkort toch maar watercoolen
  • JJ Le Funk
JJ Le Funk
:twk
In de memory review van anandtech (http://www.anandtech.com/memory/showdoc.aspx?i=2145) valt te lezen dat de Corsair 3200XL reepjes een timing hebben van 2.5-3-3-7
2.75V @500MHz.
Nu zie ik bij de specs van de Corsair Twinx XMS4000 (500MHz) de volgende default timings: 3-4-4-8.
En in de diverse tests van Anandtech (zelfs de 500MHz test: http://www.anandtech.com/memory/showdoc.aspx?i=2145&p=17) komt de 3200XL als sneller uit de bus dan de 4000.
Volgens mij komt dit doordat de 4000 van dezelfde chips is voorzien. Betekent dit dat het voor mij geen zin heeft m'n 3200XL geheugen om te ruilen voor XMS4000 als ik de Neo2 aanschaf?
d:)b :henk d:)b
  • Macaco
  • Laatst online: 09-03-2022
Heeft iemand al een MSI K8N Neo 2 54G met een Zalman CNPS7000B-AlCu erop en
dan in combinatie met een videokaart waar een Zalman ZM80C-HP met ZM-OP1 80mm fan opzit ? Ben er benieuwd naar of dat dit allemaal gaat passen !
  • Tutti-frutti
Tutti-frutti
Graag gedaan!
Download eens memtest86+ 1.20. Even extracten en via "install.bat" op een floppy zetten :).
Laat deze gewoon een uurtje draaien, en kjik of je een error krijgt. Ik heb namelijk ook wat probleempjes dat aan het geheugen bleek te liggen. Ik had echt maar 2 memfoutjes in een kwartier tijd, maar genoeg om een bsod te veroorzaken.
  • woekele
woekele
woekele
Trouwens, als je geen floppydrive hebt, kan je memtest runnen vanaf de bootable CD van SuSe.
  • diontjuh
diontjuh
for president
sow hey, flink middagje liggen gamen.. mja nu ligt mijn systeem dus echt.. geheel gecrasht, windhoos opnieuw erop gezet en hij crasht nu bij alles waar die een beetje moeite mee heeft.. raar waar kan dat dan aan liggen?
  • Cartman!
Hier ook problemen....duurde eerst al onwijs lang om de 200GB te formatten met FDISK en ik heb ook een 80GB hdd waar ik windows + apps op wil hebben. Die drive wil windows niet op installen omdat ie beschadigd is :( iemand een idee om een hdd volledig te testen en te repareren? Ik heb em al geformat met fdisk (duurde ook weer lannnggg....) en ook met PQ Magic 8 gedaan, maar hij pakt t niet. De bios zegt : Invalid Partition Table :(
Kwerk nu met de windows install op de 200GB drive maar wil t liever niet zo :(
Ik heb hem ook aangeschaft I.c.m athlon 64 3500+.
Alleen werkt mn geheugen niet helemaal >_< het schijnt dus dat je niet 1 x 512 en 2 x 256 erin kan proppen want dat gaat ie lekker piepen.
Heb het al nagelezen in de handleiding en mn vermoeden werd bevestigd je kan niet en single sided geheugen en dual sided , dit is dus zeer stom want die van 512 heb ik pas net.
Kan iemand dit bevestigen ? anders moet ik die 2 van 256 maar gaan verkopen ....
Rest werkt toruwens tot nu toe , straks even een format ertegen aan gooien.
  • Cartman!
Ik haal 3839 3D Marks in versie 2003. Is dat niet wat weinig :?
3500+ met 4 * 512MB Crucial en n Radeon 9200SE AiW
  • The Source
  • Laatst online: 22:50
Highend systeem met een trage vga kaart... nee ik denk dat het heel wat is.
  • diontjuh
diontjuh
for president
g00fy schreef op 19 augustus 2004 @ 22:42:
nee 3dmark is gebaseert op je grafische power, en met een 9200 is dat niet zo hoog iig :)
mijn systeem is nu gerepareert van zijn crash,, door de diskette erin te proppen bij windows install ziet die nu 10gb meer.. dus 150 van de 250 :S?
  • Cartman!
ow mensen, sorry mijn fout.... tis een 9800SE :X
edit : unmodded, want met mod vertoont ie fouten
[ Voor 36% gewijzigd door Cartman! op 19-08-2004 22:51 ]
  • Fusion_XT
Fusion_XT
Helemaal LEIP !
Nou dan gaat er tog iets fout. Ik heb mijn 9600Pro en Amd 2400+ al 3833 3DMarks :).
Ff een vraagje ik krijg binnenkort de Neo2 en nu heb ik nog thuis 2 sticks van 512 liggen ( Twinmos PC3200 CAS 2.5, ok ok ik gaat corsair halen, maar daar heb ik even geen geld voor. )
Gaat dit in het bord, want zag dat een paar gasten CAS 2 erin hebbe zitten ?..
  • FBtje
  • Laatst online: 25-05-2025
Nou, ik wilde mijn PC ook zelf gaan bouwen, maar als ik het zo lees, dan weet ik het niet zo goed meer :o
Ik denk dat ik het nog maar even aankijk..
Ik heb gisteren mijn nieuwe bak kunnen ophalen bij Salland, en ik ben erg tevreden.
Nog niet veel tijd gehad om te testen, maar de eerste indrukken zijn prima.
Battlefield en Farcry lopen goed, HD en geheugen ook zonder problemen.
Alleen start windows met wat vertraging op na instaleren van alle drivers, als ie daar doorheen is loopt het als een zonnetje.
CPU temp is 50 idle , tegen de 60 stressed, kan dat ermee door of moet ik meer gaan koelen?
Er zitten nu 2 120 mm fans in en de standdaard AMD koeler.
[ Voor 24% gewijzigd door Verwijderd op 20-08-2004 08:36 ]
  • DaWaN
  • Laatst online: 24-11 08:47
DaWaN
'r you wicked ??
3500+ met 4 * 512MB Crucial en n Radeon 9200SE 9800SE AiW
Dat klopt wel ongeveer, 3dmark03 test bijna alleen je videokaart en de rest van je systeem maakt niet zoveel uit. 3839 is een normale score voor een niet gemodde 9800SE.
If you do not change direction, you may end up where you are heading
  • tormentor1985
Ok ik kwam gister ook tot een vreemde ontdekking.
Score: 6523
Date: 2004-08-20
CPU: AMD Athlon(tm) 64 2310 MHz
GPU: ATI RADEON 9800 PRO
424 MHz / 365 MHz
OS: Microsoft Windows 2000
Res: 1024x768@32 bit
Score: 6471
Date: 2004-08-19
420 MHz / 360 MHz
Score: 6468
Date: 2004-08-19
CPU: AMD Athlon(tm) 64 2343 MHz
420 MHz / 360 MHz
Let hierbij vooral op de laatste twee scores, waarbij de gpu hetzelfde draait maar de cpu sneller. Hierbij werdt dus duidelijk dat snellere cpu niet betekende meer performance.
Wat vandaag betreft, ik heb even genoeg overclocked, ik ga naar mallorca en spreek jullie over 1 weekje weer.
  • tormentor1985
Fusion_XT schreef op 19 augustus 2004 @ 23:32:
Gaat gewoon in het bord, het bord kan omgaan met cas 2 t/m cas 3. Dit heeft alleen met wacht-tijd te maken per lees-cycle als ik het zo goed zeg...
  • M55
M55
tormentor1985 schreef op 20 augustus 2004 @ 09:25:
Recently, RAM manufacturers have bandied about the terms CAS Latency, CAS2, and CAS3 with great relish. They make it sound like CAS2 is a huge improvement over CAS3. Is it, or is it mainly hype? For that matter, what on earth is it?
Simply put, CAS Latency is a number that refers to the ratio - rounded to the next higher whole number - between column access time and the clock cycle time. It is derived from dividing the column access time by the clock frequency, and raising the result to the next whole number. This formula is:
CL >= tCAC / tCLK
Where:
* CL is CAS Latency.
* tCAC is Column Access Time.
* tCLK is Length of Clock Cycle.
For example, if the tCAC is 20 nanoseconds and the tCLK is 10 ns. (as with a 100 Mhz. bus), then the CL must be 2. However, if tCAC is 25 ns., then CL must be 3, since 25/10 = 2.5.
bron
  • steven2
Verwijderd schreef op 20 augustus 2004 @ 08:03:
Dat vertraagd opstarten is zeker helemaal aan het begin direct na de POST. Daar had ik ook last van met de drivers van Nvidia installed.
[b]CPU temp is 50 idle , tegen de 60 stressed, kan dat ermee door of moet ik meer gaan koelen?
Gek genoeg heb ik ook dezelfde temps, terwijl het koelblok totaal niet warm is :?
Mja msi kennende is die temperatuuruitlezing totaal verkeerd.
Na een half jaar brengen ze wel ne patch uit ;-)
  • diontjuh
diontjuh
for president
vandaag 3e crash gehad na een stevig potje gamen, ik denk dat het aan het mobo licht want hij hangt zich nu bij iedere taak die een beetje zwaar is gewoon op :( terug voor RMA denk ik
MMh das wel raar ... zeker de juiste drivers geinstalled?
Die van nVidia gebruikt of van msi? (voor de nForce)
[ Voor 9% gewijzigd door Verwijderd op 20-08-2004 13:56 ]
  • Fusion_XT
Fusion_XT
Helemaal LEIP !
Dank u _/-\o_ ...en M55 voor de aanvullende info :)...Nog 2 weken ! dan is ie er O-) ..met een:
Amd Athlon 64 3500+ 2.2GHz
XFX Geforce 6800 GT 256Mb
S-ATA MaXtor 160Gb
TwinMos PC3200 2x 512Mb <--- I know.....
8) Wordt wel een leuk systeempie, kverw8t er wel ons veel van !
  • M55
M55
Fusion_XT schreef op 20 augustus 2004 @ 14:19:
S-ATA MaXtor 160Gb
dat is exact het zelfde systeem wat ik ga kopen :)
behalve corsair 2.5 valueram ipv twinmos
  • Fusion_XT
Fusion_XT
Helemaal LEIP !
M55 schreef op 20 augustus 2004 @ 14:49:
Haha lol, Jah die Twinmos staat niet zo mooi in dat rijtje, maar goed.
Kijke welk systeem de meeste 3dmarks haalt ;)....
Alvast gefeli met je systeem :Y)
  • Mad-X
  • Laatst online: 24-07 10:10
Ben ook al weken bezig m'n ultieme set bijelkaar te zoeken en was ook in gespannen afwachting van dit hoog beoordeelde bord. Ik kijk nu bijna elk uur naar de ervaringen hier (waarvoor dank), maar wordt nu niet echt enthousiast van de eerste reacties.
Wie heeft het wel stabiel draaien en is helemaal in de 7de "game" hemel?
K8N Neo2-54G, 2 x CMX512 3200XL, XFX 6800GT, Antec Sonata met 380 True Power Voeding
Donders, gisteren na problemen met Doom3 en 3DMark2003 (die gingen af en toe terug naar windows) heb ik besloten om alles erop nieuw op te zetten en het werd alleen maar erger.
Windows reset om de 1 minuut de vid kaart accelerator opnieuw op ('VPU Recorver reset your vid. card accelerator because was unable to process vid card stuff' <-- of iets in die geest)
Alles heb ik al geprobeerd. Nieuwe/oude mobo drivers, verschillende ATi drivers, DX9.0b/DX9.0c, wel en geen SP1. Na het installen van de Ati drivers blijkt het mis te gaan.
Memtest heb ik bovendien ook gedaan maar geeft na 1,5 uur geen enkele error gelukkig. :)
Nu heb ik de vid kaart (X800XT PE) opnieuw eruit gedaan er er weer ingedaan en de kabel weer aangesloten (molex connector naar de vid kaart) maar nu ik dit type heb ik gelukkig nog geen errors.
[ Voor 5% gewijzigd door Verwijderd op 20-08-2004 15:17 ]
=edit dubbel=
[ Voor 99% gewijzigd door Verwijderd op 20-08-2004 15:12 ]
  • Fusion_XT
Fusion_XT
Helemaal LEIP !
Verwijderd schreef op 20 augustus 2004 @ 15:10:
Vreemd hou ons op de hoogte :).....ik krijg binnenkort dus ook dit bordje en ik word ook niet echt blij van de eerste reacties erop... ;( .
Misschien moeten de kinderziektes er nog uitgewerkt worde ? ( of zeg ik nou iets stoms :X )
Na een poosje de topic over de levertijden gevolgd te hebben is het errug prettig eindelijk de ervaringen van anderen hier te zien ook al lijken die tot nu toe allesbehalve positief.
Ik ben erg benieuwd naar ervaringen met het moederbord en de volgende specificatie:
kast: chieftech 01-bd-U met plexi sidepanel, zonder voeding
moederbord: MSI K8N Neo2 platinum
Geheugen: Kingston HyperX KHX2700K2/1G of Crucial Ballistix DDR400 of Corsair TWINX1024-3200XLPRO (met leds)
Processor amd athlon 64 3500+ (socket 939)
Processorkoeling: CNPS7000B-Cu of CNPS7000B-AlCu
Voeding: Levicom X-alien zwart (Art.Nr. SPS-VP500B.BL) 500W
Videokaart Asus V9570
losse meuk (dvd-speler, cd-brandertje etc.)
  • Tutti-frutti
Tutti-frutti
Graag gedaan!
Ik heb nu ook even het bordje. Maar de problemen vallen hier wel mee. Tot nu toe 2x een bsod gehad, maar toen gaf memtest ook errors. Ik kan nu even niet testen. Ik zit namelijk bij een ontvangstweekend van mijn studie :). Maandag ga ik maar weer aan de gang ;)
Ik word er ook niet zo vrolijk van als ik dit hier allemaal lees |:( Als al zie wat bij Pelican gebeurd.Hoe verloopt het nu?
Ik wacht het nog eventjes af , doe het nou met de Asus A8V(waar ik veel problemen mee heb)top VGA kaart hebt ik nog niet terug , dus op dat wacht ik nog even.Zodra die weer terug is van de garantie ga ik reageren , kijken van welk mobo het nou wordt
Ik hoop dat de reacties wat positiever worden anders denk dat ik voor gigabyte ga. O-)
Maar we wachten rustig af
:o
  • pelican
pelican
Verwijderd schreef op 20 augustus 2004 @ 16:09:
:o
Gister had ik geen tijd, heb vanochtend nog eens geprobeerd zonder cpu en gelukkig gaf het moederbord weer een teken van leven... de koeler draaide en de d-bracket gaf netjes aan dat er een cpu probleem was. Heb nu goede hoop dat het aan de cpu ligt, cpu+moederbord+geheugen liggen nu bij de winkel waar ik de cpu heb gekocht, daar gaan ze hem testen, waarschijnlijk maandag of dinsdag gebeurt dat. Heb goede hoop dat alleen de cpu defect is.
Mijn ervaring over de eerste (en tot nu toe enige) 3 uur dat ik ermee gewerkt heb:
Bordje ging toen het draaide erg lekker. Alles draaide heel soepel (ik stap over van een Amd Tbird 1000 met 256 mb, dus wat wil je... :+ ) en geen bsod of iets dergelijks.
Had het systeem in een Nexus Breeze kast, en hij was een stuk stiller dan m'n oude pc-tje. Echt geen spijt dat ik dit moederbord gekozen heb... zodra ik weet wat er stuk was en ik alles weer terug en werkend heb zal ik eens gaan uitzoeken wat er nu fout is gegaan...
Doom3 ging nogsteeds terug naar Windows. Om mogelijk dat te verhelpen heb ik de voltage omhoog gedaan bij zowel mem als bij AGP. Ben nog niet toegekomen bij de 'rode cijfers' waar de bios aangeeft wanneer je ze gebruikt dat het systeem mogelijk instabiel wordt.
Maar voltage van zowel mem als AGP in het bijzonder omhoog doen om mogelijk 'terug gaan naar desktop bij doom3' te voorkomen wel velig ?
voltage mem: 2.70
voltage agp: 1.60
Dat kan toch geen kwaad?
[ Voor 12% gewijzigd door Verwijderd op 20-08-2004 17:16 ]
  • Fusion_XT
Fusion_XT
Helemaal LEIP !
Omdat zo veel mensen stabiliteits problemen hebben met de K8N NEO PL 2, zat ik er ook aan te denken om een nieuwe voeding aanteschaffen ( mede dankzij mijn Geforce 6800 GT )
Ik zat aan deze te denken:
Levicom X-Alien 500 Watt Voeding >:) ....
Ik denk dat deze wel voldoende is ....Zo niet, wat dan wel ? :)
[ Voor 86% gewijzigd door Fusion_XT op 21-08-2004 00:33 ]
Hallo allemaal,
Wou juist even melden dat het instabiliteitsverschijnsel bij 3D toepassingen geen alleenstaand geval is... hier manifesteert het zich ook al. Het o zo grootse overclockingsbord heeft al speciale ingrepen nodig om standaard te doen wat ervan mag verwacht worden. :|
Probeer hier Vietcong te spelen en om de haverklap krijg ik m'n desktop te zien na ongeveer 15min spel. Zie in de bios niks extravagant staan, alles op conservatief-standaard.. Mijn hoofd staat meer op slachten dan troubleshooten, zal morgen wel 'ns wat trial&errorren.
Goedenacht!
Edit: na het manueel instellen van de door de geheugenfabrikant opgegeven timings en het minimumvoltage lijkt de boel stabiel. De SPD leest de info van deze GeIL modules misschien niet goed uit.
Mij CPU leest onmiddellijk na een uurtje gamen 55°C in Corecenter.
Voor de rest snel systeempje voor games dus. Eindelijk een PC die Vietcong vlot draait. Na anderhalf jaar aanmodderen met een PIV2.6 zie ik met dezelfde graka grafische instellingen de frames stijgen van 39.9 naar 67.1. CPU gevoelig spelletje!
http://img52.exs.cx/img52/661/VietcongVoor.jpg
http://img52.exs.cx/img52/8436/VietcongNA.jpg
ter info: config:
Antec True Power 430 in Antec P160 kastje
A64 3500+
Geil Ultra Platinum 2x256 PC4000 Dual Channel
Saphire Radeon 9800Pro (XT Geflashed)
WD Raptor 36GB
2xWD 1200JB 120GB
Audigy 2
Highpoint Rocket 133S ATA133 controler
En niet te vergeten natuurlijk: The king of K8 platform, K8N Neo2 54G Platinum 8)
[ Voor 27% gewijzigd door Verwijderd op 21-08-2004 04:04 . Reden: Links naar screenshots fps Vietcong ]
  • M55
M55
Fusion_XT schreef op 20 augustus 2004 @ 19:56:
Ik dacht dat iedereen voor de tagan 480w ging :)
Guys ik lees dit topic ook met veel aandacht, ik hoop dat jullie elkaar kunnen helpen met alle problemen die er zijn. Ik wilde dit board ook kopen maar dan moet ik toch wat meer succes verhalen lezen, voorlopig is het allemaal helaas niet zo positief. Het board lijkt me nogal kritisch te zijn t.o.v. het geheugen qua instellingen etc, misschien zou het handig zijn als de mensen waarbij alles wel goed werkt kunnen posten wat hun instellingen zijn zodat de "ongelukkigen" hiervan kunnen profiteren.
In ieder geval hoop ik dat alle problemen worden opgelost en heb respect voor iedereen die het heeft aangedurft direct zoveel te investeren in zo'n nieuw platform _/-\o_ .
De game gaat steeds af en toe terug naar Windows bij zwaareisende spellen zoals Doom3 en testprogramma 3DMark2003 en CS:S is ook al 2 a 3 keer vastgelopen. Ik heb alles op default staan, vid kaart nooit overgeklokt, default voltages alhoewel mem en agp voltage omhoog niet veel helpt. Mobodrivers en de nieuwste Ati drivers.
Ik weet niet of m'n 3dMark2003 score goed genoeg is:
12355 met de volgende specs:
Athlon64 3800+
MSI K8N neo2 Platinum-54GB
1024 MB mem (cas 2-3-2-6 <-- default)
Sapphire X800XT PE
Audigy2 ZS
WinXP SP1
  • Voyage
  • Laatst online: 24-11 05:11
Ik zit ook aan te denken om dit moederbord te kopen in combinatie met het volgende systeem:
Moerderbord: MSI K8N Neo2 Platinum, nForce 3 250
Processor: AMD Athlon 64 3500+ (S939, 2,2GHz, 512KB, Boxed)
Geheugen: 2 x 512MB PC3200 DDR CL2,5 Corsair
Videokaart: MSI Geforce 6800 GT 256MB
Harde schijf: WD Caviar SE 200 GB SATA
Ik lees hier dat er veel geheugen problemen zijn. Welk geheugen werkt hier het beste mee, of is het een kwestie van alles goed instellen in de bios?
Ik heb nu een nforce2 moederbord en het geluid bevalt me prima, toch vroeg ik me af hoe het onboard geluid van dit bord presteert. Dus voor de mensen die van een nforce2 mobo naar deze mobo zijn overgestapt, hoe vinden jullie het onboard geluidschip?
  • Fusion_XT
Fusion_XT
Helemaal LEIP !
Verwijderd schreef op 21 augustus 2004 @ 12:01:
Athlon64 3800+
Sapphire X800XT PE
Audigy2 ZS
WinXP SP1
Zo das EGT GEEN SLECHTE SCORE MAN !
Als je nog iets draaien op de a8tergrond zet dat uit !....
_/-\o_ wat een score !
Als ik mijn systeem heb, draai ik ook ff 3DMark :)
  • Fusion_XT
Fusion_XT
Helemaal LEIP !
M55 schreef op 21 augustus 2004 @ 09:13:
M55 is die Levicom niet goed genoeg ?...op gebied van voeding ben ik egt een DIKKE n00b.....
Ik wilde juist deze omdat hij op de 12v rail max 38a aan kan ! >:) ( of zeg ik nou weer iets, waardoor het juist weer heel goed blijkt dat ik een n00b ben :7 )
Hey en hoe zit het met die geluidskaart, ik heb hier nog een Creative Audigy liggen, zou ik die onboard moeten gebruiken of die audigy ?..welke is beter..
[ Voor 17% gewijzigd door Fusion_XT op 21-08-2004 14:37 ]
  • M55
M55
Fusion_XT schreef op 21 augustus 2004 @ 14:09:
Ik heb van voedingen ook geen verstand :+ , maar in het geforce 6800 topic las ik dat veel mensen zo'n tagan gebruikte, of wilde kopen. Het blijkt een hele goede voeding te zijn, die ook nog eens stil is.
http://www.google.com/sea...=utf-8&q=tagan+480+review
http://www.3dvelocity.com/reviews/tagan/tg480.htm
Afbeeldingslocatie: http://www.3dvelocity.com/reviews/tagan/rails.gif
pricewatch
Welke voeding heb ik nodig? Deel 6
[ Voor 5% gewijzigd door M55 op 21-08-2004 15:15 ]
  • Fusion_XT
Fusion_XT
Helemaal LEIP !
M55 schreef op 21 augustus 2004 @ 15:09:
pricewatch
Ja daar had ik ook al een beetje rond gekeken, maar als ik zo kijk naar dat schema, lijkt het erop dan die Levicom beter is :? ...maar goed ik hou het daar wel bij...
Nog een paar dagen en dan merk ik het wel of ik een stabiel systeem heb O-)
  • M55
M55
Fusion_XT schreef op 21 augustus 2004 @ 17:17:
hogere getallen betekent niet dat automatisch beter is (kwaliteit != kwantiteit)
ik las dat die Levicom wat grotere afwijkingen vertoont, en dat sommige reviewers er niet zo positief over zijn. Maar ja beetje offtopic hier :).
  • Atomic-NI
  • Laatst online: 20-11 11:05
Heb nu ook sinds 2 dagen de Neo2 met een Athlon64 3500+ en Corsair Twinx1024-3200C2PRO (2x512 + LEDS).
Nu had ik in mij vorige systeem al watercooling zitten van het merk Innovatek (www.innovatek.de). Maakte me voor de aanschaf van het bord wel zorgen over het wel of niet passen van de chipset cooler, maar gelukkig hij past.
Hier wat gegevens en plaatjes van de watercooling:
Afbeeldingslocatie: http://www.webshop-innovatek.de/images/gomblau_152.jpg
Innovatek i-COOL rev4.0 (CPU)
Afbeeldingslocatie: http://www.webshop-innovatek.de/images/rev42small_152.gif
Nu heb ik alleen een probleem met de temperaturen van de CPU.
Idle: 62'
Stressed: 73'
Is dit wel goed? Zou graag wat meer temps willen weten van andere gebruikers
met een Neo2 en een Athlon64 3500+ (of vergelijkbaar)
Overige sys specs:
Afbeeldingslocatie: http://www.nova-inside.com/images/sys-atomic/cpu.jpg Afbeeldingslocatie: http://www.nova-inside.com/images/sys-atomic/geheugen-stats.jpg
Afbeeldingslocatie: http://www.nova-inside.com/images/sys-atomic/geheugen-bandbreedte.jpg
  • The Source
Ik heb een K8N NEO2 Plat + 3500+ maar ik heb totaal geen last van gekke problemen of crashes. Bij de installatie heb ik wel een gevecht gehad met de nvidia system drivers. Maar nu draait alles als een zonnetje, ben er zwaar tevreden mee. Als je zorgt dat je een goede PSU en goed geheugen gebruikt is er niets aan de hand.... ik gebruik zelfs Corsair value select geheugen :)
Atomic-NI > 46 graden bij cool 'n quiet (1004Mhz) idle (gemeten in CoreCenter)
[ Voor 20% gewijzigd door The Source op 22-08-2004 01:14 ]
71graden stressed? 61 graden idle? Dat lijkt me wel erg veel en slecht voor de cpu? :o
Wat voor koelblok zit daarop? De boxed koeler? Gebruik je wel koelpasta? Op de boxed zit er een laagje onder op de koeler.
Ik heb 57 stressed en rond de 54 graden idle alhoewel ik 57 al hoog vind.
Ik denk dat m'n 10/100 Realtek lan controller onboard is opgeblazen :'(
Na een fresh format ziet windows alleen maar 1 controller en dat is die Gigabyte. Windows Systems -> Hardware Device geeft opeens 2 unknown hardware aan. Updates helpen niet. Ik heb een vaag vermoeden dat dat met die andere defecte connecter heeft te maken. Je kan toch wel 2 nic's gebruiken tegelijk met die 2 onboard connectors? :?
  • Cartman!
Hier ook geen problemen tegen gekomen nog....nog niet echt veel mee gedaan ook nog maargoed...
Hier een Levicom 480Watt voeding erin overigens....(of was t 420watt, ik weet t niet meer...brak :X )
Na de klock te hebben rond gegamed en eerder te zijn gecrashed dan m'n nieuwe kan ik alleen maar dit bordje sterk aanbevelen.
Het enige van moeite dat ik moeten doen heb om zover te komen was even niet te lui zijn om m'n geheugen voltage alsook de geheugen timings manueel in te stellen.
Ere wat ere toekomt: dit bord is gepromoot als een overclockersplank en betreffende overclokken kan ik vooralsnog geen uitsluitsel geven maar gezien de zachte prijs ivgl met de Gigabyte kan ik dit K8N Neo2 bordje dan ook dik aanbevelen.
Maandag neem ik al :9~ -end mijn XP-120 cpu koeler in ontvangst en ga ik 'ns zien of er soms een paar extra mhzjes te rapen zijn.
Dit boardje bevalt me best , ff 2 dagen mee kunnen spelen nu en ondanks nog weinig echt te hebben overgeclocked zijn de resultaten hoopgevend.
Tis jammer dat ik me x800pro vivo nog niet binnen heb maar met me 9700pro scoort ie iig beter dan ik toch nu toe gehad heb, eindelijk de 20K grens overschreven, best aardig voor een 9700pro. Alleen die temps zijn weird, hij zegt idd rond de 50 graden terwijl coolblocken koel aanvoelen, kast temp is volgens corecenter 4 graden :? beetje vaag idd, me eigen tempsensor geeft 32.5 graden aan op de cpuheatspreader.
benches:
- 3Dmark2001, 20564 marks: http://service.futuremark.com/compare?2k1=8065494
- UT2004 benchmark:
[img]http://www.digitaltalent.nl./wismerhill/pics/UT2004bench_20-08-04_AMD64_225fsb.jpg[/img]
- Unreal Tournament GoTY ingame fps (deze vooral genomen om het belachelijke result, tis geen bech of vergelijkbaar met realworld perf, map face kijkend naar een texture):
[img]http://www.digitaltalent.nl./wismerhill/pics/UT_highestfps.JPG[/img]
volledige specs:
MSi K8N Neo2 Plt 54G
AMD64 3500+
2X512MB OCZ PC4000EL Gold
2XWD2000JD Raid0
Tagan TG480W
LianLi PC65 ALu
Hercules Radeon 9700Pro
NEC ND1300A DVD+-RW
Watercooled: CPU, Northbridge en VPU
maar er zit imo nog wel meer in dit systeem, helemaal als ik me x800 eens krijg :)
[ Voor 23% gewijzigd door Verwijderd op 22-08-2004 17:03 ]
  • delorean7
  • Laatst online: 19-11 17:54
delorean7
Let's take the Aston toni
steven2 schreef op 20 augustus 2004 @ 11:27:
Same here, na goed uurtje stresstesten op het gevoel kouder koelblok dan het pcb eromheen zo ongeveer. Wat nou 60 graden!? Dikke onzin.
  • Fusion_XT
Fusion_XT
Helemaal LEIP !
Jammer dat er dan op zo'n bord geen PCI-Express zit.. :? ....maar goed je kan niet alles hebbe :P..
Nog een paar dagen en dan is de mijne binnen !!!!!!!!!! WOOOOOOOOO !!! 8)7 _/-\o_
Mijn handen jeukten om te beginnen overclocken, dus alvast 'ns aan de slag met de standaard koeler:
Temp stressed: 59°C
Uitgelezen in Corecenter, ogenblikkelijk na 1u Vietcong spelen (een niet bepaald cpu-vriendelijk spelletje hoor)
http://img23.exs.cx/img23/6633/CoreCenter1.jpg
Idle geeft de Corecenter een 53°C aan maar zoals hierboven al vermeld voelt de standaard koeler niet warm aan 8)
AMD heeft me een 3800+ cadeau gedaan voor de prijs van een 3500+, da's pas value for money.
Al wie de levering van z'n K8N Neo2 bordje nog afwachtende is, zet uw kwijlproduktie maar in tweede versnelling!
vorige week heb ik alles binnengekregen
AMD 64 3500+
XFX Geforce 6800 Ultra
Twinmos 1024 PC3200 (2x512)
Zalman 7000 alcu
en natuurlijk de MSI K8N Neo2 (-54G)
had eerst ook nogal wat problemen met 3D toepassingen maar ben alle bios optie's langs gegaan en heb 't eindelijk opgelost.
Gewoon fastwrite uitzetten en nu draait alles super stabiel, nooit meer probs gehad :*)
[ Voor 13% gewijzigd door Verwijderd op 23-08-2004 03:00 ]
  • Tutti-frutti
Tutti-frutti
Graag gedaan!
Gelukkig zie ik dat jullie temperaturen ook een beetje "schrikbarend" zijn. Ik heb zelf ook een waterkoeling setup met een Alphacool NexXxos HP cpu-blok.
Ik zit met c&q aan op zo'n 38.5 graden idle.
Dit is op default 3500+ speeds (2,2 ghz) en op 1.50 volt. Stressed kom ik nu aan de 50 graden.
Jullie revisie, is dat trouwens ook allemaal Ver:1 (staat onder 3e pci-slot)
Ik heb lekker veel tijd nog.. dus ik ga veel testen aan het bordje. Als jullie vragen hebben, stel ze.. ik wil het best allemaal testen :)
edit: Ik haal trouwens 6931 3dmarks met mijn 9800pro op 405 mhz core/365 mhz mem. Dit was met 210 HTT (fsb) (3dm2k3 compare-url)
[ Voor 60% gewijzigd door Tutti-frutti op 23-08-2004 12:03 ]
nou ik heb er ook een aangeschaft, wel problemen dus.
dit is mijn setup:
Msi k8n neo2 platinum 54G
1GB ddr400 (2x 512)
ati 9800pro all-in-wonder
2x WD s-ata raid 0
temp idle: 52 graden
tem stressed: ~60 graden
standaard amd koeler
haal met alles standaard 6100 in 3dmark03 (lijkt mij wel ok) en 3dmark loopt prima, loopt niet vast, knalt er niet uit etc.
vooral in het begin had ik veel last van blauwe schermen en spontane reboots, heel vaak zelfs.
vervoglens had ik de drivers van ati gedownload en het ging al beter.
nu heb ik geen last van blauwe schermen meer.
echter reboot de pc zich wel spontaan af en toe. Dit wanneer ik gewoon in windows zit.
soms zit ik wat te installeren (of te synchroniseren met mijn palmtop) en dan reboot hij zich.
soms als ik bijv op geavanceerde eigenschappen van mijn videokaart druk, dan krijg ik soms blauwe schermen (of reboot).
ik zit zelf te denken aan twee dingen:
fast write uit
irq conflict ? (heb behalve het 54g kaartje in het oranje socket, geen pci kaarten meer)
zit nu op mijn werk dus kan die 2 dingen niet uitproberen, iemand anders nog een idee hierover?
wat veroorzaakt vaak een spontane reboot?
mijn ervaring leert mij dat blauwe schermen meestal iets met de warmte of geheugen te maken hebben, maar omdat mijn geheugen goed was en de cpu 3dmark doorstaan had, neem ik aan dat ik dit wel uit kan sluiten.
[ Voor 12% gewijzigd door Verwijderd op 23-08-2004 12:21 ]
wat voor voeding heb je?
Die moderne boards (en msi in het bijzonder) hebben vette voedingen nodig.
Daarbij is wattage niet het belangrijkst, vooral het amperage op de 12V line is interesant.
verder was dit topic specifiek NIET voor troubleshooting dacht ik?
Je kan in de logboeken van windows xp toch zien wat er is misgelopen?
En zet die optie af dat windows tijdens een error automatisch reboot.
>Deze computer>eigenschappen>geavanceerd>Opstart(instellingen)>derde vinkje bij systeemfouten.
[ Voor 26% gewijzigd door Verwijderd op 23-08-2004 12:29 ]
Verwijderd schreef op 23 augustus 2004 @ 12:27:
Ik zoek ook nog een goede voeding. Ik had een Antec TruePower 380watt voeding maar tijdens veeleisende appz crashed de computer (bij Doom3). Ik heb dat opgelost door een 2e voeding (300watt) dedicated aan m'n X800XT PE aan te sluiten. Vreemd genoeg is de 380watt niet genoeg? Ik zoek dus een goede vervanger
Mij lijkt me de Tagan 480W wel iets? Iemand ervaringen mee?
