[NEC 2500A] 1.07v2 Dual Layer Bitsetting Beta 5
Pagina: 1 2 3 4 Laatste
  • 2.421 views sinds 30-01-2008
  • Hermanvh
  • Laatst online: 17-03 10:14
Hermanvh
webOS fan, hacker, developer
Another firmware is ready for you guys & dolls to test >:)
Newly added features:
Dual Layer Support
Disc 1:
Afbeeldingslocatie: http://herrie.rpc1.org/images/2500@2510%20DL%20MKM%20001.PNG
Afbeeldingslocatie: http://herrie.rpc1.org/images/2500@2510%20MKM%20001%20DRU%20700%20drivespeed.png
Afbeeldingslocatie: http://herrie.rpc1.org/images/2500@2510DL%20MKM001%20CDDVDSpeed%20NEC.png
Afbeeldingslocatie: http://herrie.rpc1.org/images/2500@2510DL%20MKM001%20CDDVDSpeed.png
Disc 2:
Afbeeldingslocatie: http://herrie.rpc1.org/images/2500@2510%20DL%20MKM%20001%20Disc%202.PNG
Afbeeldingslocatie: http://herrie.rpc1.org/images/2500@2510%20DL%20MKM%20001%20Disc%202%20Speedtest.PNG
Tested on the following standalone players:
JVC XV-S302: OK
Max Gear: OK
LiteOn LVD 2001: Doesn't play
Support for the following media has been altered:
DVD+R:
IS001002 @ 8x using 6x and 8x from Philips 081
PRODISC R02 @ 8x using 6x and 8x from PRODISC R03
AML 001 @ 8x using 6x and 8x from Philips 081
AML 002 @ 8x using 6x and 8x from Philips 081
BeAll000P40 @ 8x using 6x and 8x from Philips 081
BeAll000P80 @ 8x using 6x and 8x from Philips 081
GSC503 H01 @ 8x using 6x and 8x from Philips 081
GSC502 002 @ 8x using 6x and 8x from Philips 081
Have fun testing!
Get it here:
Windows: http://herrie.rpc1.org/downloads/2k5107v2b5dl.rar
DOS: http://herrie.rpc1.org/downloads/2k5107v2b5dld.rar
Please post your results! Set the booktype with DVDInfoPro and burn with RecordNow Max!
Donations using Paypal are always welcome of course :)
Graag hoor ik jullie bevindingen :)
[ Voor 35% gewijzigd door Hermanvh op 22-05-2004 20:51 ]
webOS all the way!
daarmee maak ik mijn brander dual-layer? heb je 'm zelf al getest? (voordat ik mijn brander verziek)
  • Bierkameel
Bierkameel
I use Debian btw
Ik heb wel de brander alleen niet de dual layer schijfjes, ik zal hem toch eens flashen...
Alle proemn in n drek
  • Hermanvh
Hermanvh
Verwijderd schreef op 22 mei 2004 @ 20:24:
Alles is op eigen risico natuurlijk! Bij mij werkt ie prima! Ik had 4 stuks DL schijfjes weten te bemachtigen. Fikken gaat prima, spelen ook op de meeste spelers!
webOS all the way!
  • Slurpgeit
  • Laatst online: 19:48
toevallig niet in een gewone winkel gekocht zeker? :Y)
  • marsian
  • Laatst online: 19-11 20:32
Fantastisch! Mooi dat dit gelukt is! Had eerlijk gezegd niet verwacht dat de NEC 2500A dit ooit zou kunnen! Nou nog even afwachten wat de bevindingen zijn voordat ik ga flashen!
  • Hermanvh
Hermanvh
Slurpgeit schreef op 22 mei 2004 @ 20:40:
Nee, van een niet nader te noemen bron toegezonden gekregen :P
[ Voor 6% gewijzigd door Hermanvh op 22-05-2004 20:52 ]
webOS all the way!
Damn, lucky nec-fikkers-bezitters. Ik heb een pioneer a06, daar 'zou' ook dl mee gebrand kunnen worden, maar andere berichten spreken dit tegen..
  • lochtejans
  • Laatst online: 22:01
mmm wel interessant...
Ik wil namelijk ook binnen een bepaalde tijd een dvd-brander aanschaffen. Een NEC-2500A is dan natuurlijk wel een leuke optie als deze dmv een nieuwe firmware ook dual-layer discs kan branden. Scheelt weer wat centjes voor deze student :9~
Ik wacht in spanning af op meer gebruikerservaringen B)
  • Hermanvh
Hermanvh
lochtejans schreef op 22 mei 2004 @ 20:54:
Zal nog wel even duren, omdat er maar een heel select groepje gebruikers toegang hebben tot DL discs op dit moment :(
webOS all the way!
  • Xander
  • Laatst online: 19:05
Hermanvh schreef op 22 mei 2004 @ 21:28:
En die schijfjes die ik in de pricewatch zie staan van 9.4GB dan? Zijn geen gewone Dual Layer schijfjes?
http://www.tweakers.net/pricewatch/35052
pricewatch: Maxell DVD-R 9,4GB 4x, 50 stuks (Spindel)
edit: Hmm, eerste is DVD-RAM, maar 2e gewoon DVD-R?
[ Voor 8% gewijzigd door Xander op 22-05-2004 21:34 ]
Nope dit zijn dual sided: 2 kanten single layered
  • Hermanvh
Hermanvh
XanderH schreef op 22 mei 2004 @ 21:32:
pricewatch: Fuji DVD-RAM 9,4GB 4x, 1 stuk (Jewelcase)
1e is DVD-RAM
2e is DVD-R Dual Sided, geen DUAL LAYER.
Opus heeft ze staan voor 30-06-2004 :( 84 euro per 5!
webOS all the way!
  • lowfi
  • Laatst online: 09:26
waarom is dat eigenlijk? v&a? of andere redenen?
  • timovd
  • Laatst online: 20:52
timovd
Voorsprong door techniek
Misschien dat ik t hier kan posten.
Momenteel heb ik versie ND-2510A K0P2 RPC1. Ik heb deze f/w update gedaan via DOS. Ik had de NEC aan de pri master hangen en een toshiba aan de sec master.
Telkens als ik mijn PC opstart gaat de lade van de NEC automatisch open. De f/w update heb ik daarna geprobeert via de sec. Maar dit leverde helaas niets op.
Als ik deze nieuwe f/w wil installeren onder Win, wordt de ND-2500 niet herkend(omdat ik een 2510 heb waarschijnlijk). Hoe kan ik dit probleem verhelpen?
  • Xander
Ja, had ik ook al gezien, even niet goed gekeken
Ah, dat zag ik er dus nergens bijstaan ofzo? Maar het zal wel :)
Tsja, DVD-/+R's waren in het begin ook vrij duur :P
Ik "kijk liever even de kat uit de boom", maar als Dual Layer schijfjes betaalbaar & verkrijgbaar worden kan deze firmware update heel interessant zijn (ik heb ook een 2500 ja.)
  • Hermanvh
Hermanvh
timow schreef op 22 mei 2004 @ 21:36:
In DOS flashen (ik heb er niet voor niets een DOS-versie bijgezet ;)) Dat zou het probleem moeten oplossen :) Het probleem met het LEDje en de Tray die in K0P2 zat zou nu opgelost moeten zijn :)
P.s. Je moet je drive dan wel aan iets anders hangen dan Primary Master, want daarop flasht ie niet in DOS :(
webOS all the way!
  • Osiris
W00t!
Alleen.. Ik heb een NEC-1100A... En geen 1500. Nu heb ik em wel naar een 1500 geflashed, maar dat maakt hem nog geen 1500 zeker :P
Iemand enig idee of er ooit een gehackde firmware voor de 1100 uitkomt met Duallayer? 't Kon ook zonder DL-support, dus waarom niet met :)
*Jank* Ik las ff gigantisch verkeerd :+ Zat er zo'n 1000 naast :+
[ Voor 13% gewijzigd door Osiris op 22-05-2004 21:47 ]
  • timovd
timovd
Hermanvh schreef op 22 mei 2004 @ 21:40:
Thanx Herman!!!! It works!!!
  • Mr Magic
  • Laatst online: 21:14
Huh? Ik heb de firmware flasher van The Dangerous Brothers al meerdere malen gebruikt om m'n NEC 2500A te flashen terwijl 'ie aan de primary master hangt... nog nooit problemen gehad. Of bedoel je dat het met deze specifieke firmware niet kan?
  • Hermanvh
Hermanvh
Mr Magic schreef op 22 mei 2004 @ 23:56:
Met de 1x00A serie kreeg je "Primary Master Not Supported". Ik weet eigenlijk niet of dat met de 2x00A serie nog zo is, maar ik nam aan van wel. Dit er ter beveiliging, omdat 99,5% v/d mensen hun HD op Primary Master hebben hangen ;)
webOS all the way!
  • M@rijn
  • Laatst online: 30-10 08:31
FF tussendoor in de pricewatch kom ik alleen de 2500 tegen is dat dezelfde als de 2500A of zit er verschil tussen?
Ach ja, ongeveer 10-15euro. :+ Koop je toch de ''echte'' dvd wel :9
  • Hermanvh
Hermanvh
Hmmz in de VS hebben ze er 5 voor $29.00 :)
Ik voel een inkoopactie aankomen >:)
webOS all the way!
dit gaat vast niet werken bij een nd1000a met 1300a firmware? :P
of wel? 8)
Ik snap echt niet waarom er zo'n ophef gemaakt wordt over het dual layer maken van de huidige branders.
Voordat dual-layer schijfjes echt betaalbaar zijn zijn we weer een half jaar tot 3 kwart jaar verder, op dat moment zijn er weer nieuwere/goedkopere/betere branders, waardoor veel mensen op dat moment toch weer overstappen
  • RobertJ
  • Laatst online: 15-11 10:06
Beetje verwarring is het nu dual layer of dual sided support... Dual sided is niet echt relevant of wel?
Life is what you make of it. Always has been, always will be.
  • Hermanvh
Hermanvh
Verwijderd schreef op 23 mei 2004 @ 17:22:
Je bent een Tweaker, of je bent het niet :P
webOS all the way!
  • Xander
RobertJ schreef op 23 mei 2004 @ 17:25:
dual layer support
Het is wel handig als je al een dvd brander hebt om die dual layer te kunnen maken. Ik weet niet hoe dat bij jou gaat maar ik koop niet elk half jaar een nieuwe dvdbrander. :7
  • Roamor
NEC _/-\o_ Dit zijn updates waar we wat aan hebben.
  • Hermanvh
Hermanvh
RoamoR schreef op 23 mei 2004 @ 17:47:
Nou volgens NEC zelf zou het niet werken op de 2500A, maar inmiddels hebben 3 uit 3 testen gebleken dat het dus wel werkt :)
webOS all the way!
Hermanvh schreef op 23 mei 2004 @ 18:02:
Ikzelf heb de NEC1300a :'( . Maar ik wacht nog even of het ''echt'' waar is. En anders zullen eind 2004 a begin 2005 de dvd fikkers toch wel wat goedkoper worden ;)
Verwijderd schreef op 23 mei 2004 @ 17:45:
Ben inmiddels ook aan mn zoveelste brander toe(Liteon LDW411S@811S), voor mij pas een nieuwe brander mocht de tijd er rijp voor zijn(lees: betaalbare dual-layer schijfjes)
  • nhanssen
  • Laatst online: 18:33
nhanssen
QVL is non-tweakers
Ik snap niet hoe dat echt werkt dat dual layer. Wordt de eerste laag heter gebrand en vervolgens de buitenste laag minder hard gebrand zodat de binnenste laag niet wordt bijgebrand? Of 2 soorten lenzen? of 2 frequenties? Is het al eens ergens gepost deze manier? :?
En waarom zou je dan niet eenvoudig 2 dl dvd-r's op elkaar kunnen plakken? :Y) is toch zo'n 18-19 GB >:)
edit: Ow ja ik heb natuurlijk ook zo'n 2500 _/-\o_
[ Voor 14% gewijzigd door nhanssen op 23-05-2004 18:16 ]
Spec's PC
Verwijderd schreef op 23 mei 2004 @ 18:08:
hoop eigenlijk op een firmware "update" van die brander :)
  • Hermanvh
Hermanvh
nhanssen schreef op 23 mei 2004 @ 18:15:
The first recording layer of a Verbatim DVD+R DL disc is semi-transparent, providing sufficient reflectivity for drives to read/write data on the first layer and transmit enough laser power to read/ write on the second layer by refocusing the laser. In addition to optimizing laser reflectivity, the new Metal Azo recording dyes were developed by Mitsubishi for each layer to optimize parameters such as signal amplitudes and power margins and ensure full compatibility with current DVD standards.
Geeft een klein beetje inzicht. Komt uit het persbericht van Mitsubishi/Verbatim over hun DL schijfjes!
webOS all the way!
Ik heb een probleem met het flashen van de firmware :(.
Met de windows installer geeft ie na een minuut al een error en met de dos flasher geeft die aan dat ie de bin file niet kan openen. Zowel als primare slave als secundaire slave geprobeerd maar geeft zelfde probleem. UMDA staat aan. Heeft iemand enig idee waar dit aan kan liggen??
  • Hermanvh
Hermanvh
Verwijderd schreef op 23 mei 2004 @ 21:09:
De bestanden passen niet op een bootfloppy!
Dus 2 floppies gebruiken:
1e als bootfloppy
2e met nec2x00a.exe en de .bin-file :)
webOS all the way!
  • Fire69
  • Laatst online: 19:10
DVD van dubbele dikte zullen de meest spelers niet zo leuk vinden.
Ik las ergens dat de meeste DL's momenteel handmatig op elkaar geplakte 1-laags dvdtjes zijn. :)
Hermanvh schreef op 23 mei 2004 @ 21:20:
1e als bootfloppy
Ook dan geeft ie nog aan dat ie de bin file niet kan openen. Ik heb dus met drdflash een bootdisk gemaakt en op een andere floppy de bin en exe file. Nog idee waar het aan kan liggen?
  • Hermanvh
Hermanvh
Verwijderd schreef op 23 mei 2004 @ 22:04:
Gebruik je wel het juiste commando?
NEC2x00A.EXE -sec -mas -flash 107v2b5d.bin
In het geval je drive is aangesloten als Secondary Master.
webOS all the way!
Hermanvh schreef op 23 mei 2004 @ 22:11:
yep dat is het commando dat ik gebruik alleen heb ik hem als slave dus -sec -sla -flash. Anders probeer ik het morgen ff op een andere pc.
  • toastingnow
  • Laatst online: 10-11 17:00
Moet je eigenlijk nog een bepaalde serienummer hebben van de NEC 2500? Of is iedere 2500 te flashen? Kan dit niet opmaken vanuit dit topic.
Asus P5K Pro, 2 Gb DDR2, Samsung 500 GB HD, XFX Alpha DOG 670Mhz, E8400
  • AvK
AvK
Ready Set Go
toastingnow schreef op 24 mei 2004 @ 10:03:
Inderdaad, daar ben ik ook benieuwd naar.
Heb laatst ergens gelezen dat je het beste de productiedatum van maart 2004? kunt hebben.
Veel mensen hebben drive's van december 2003. Ook ik zelf.
Maakt dat verschil?
[ Voor 102% gewijzigd door Verwijderd op 31-10-2023 22:29 ]
  • toastingnow
Duidelijk verhaal.
Ach, dan wacht ik tot de pc-dumpdag waar ze de 2510 zullen verkopen tegen een nu verwachtte goede prijs ;)
  • xabre16v
Geflasht hier. Via Windows :) heb nu ook een 2500A met DVD+R DL, heb alleen geen DL schijfjes :P
  • kiekeboeboe
Verwijderd schreef op 23 mei 2004 @ 22:28:
je dos-versie die je gebruikt, heeft geen ondersteuning voor langere Filenames.
Verander gewoon een de *.bin file naar bijvb "update.bin", dan zou het waarschijnlijk moeten lukken het flashen in dos
Werkt deze nu wel of niet op de nec 1300?
kiekeboeboe schreef op 24 mei 2004 @ 18:14:
That's it!! bedankt :)
  • kiekeboeboe
Verwijderd schreef op 24 mei 2004 @ 19:55:
at your service
  • Shaggy
  • Laatst online: 14:44
Shaggy
Misantroop pur sang
Hehe, zou goed uitkomen, heb zaterdag ochtend, toevallig een 2500 uit maart 2004 gekocht, alvast voor mijn verjaardag, daarna zag ik deze post..hehe
Dat gaat goed zo... :)
Making an ass of myself since the 70's
Verwijderd schreef op 24 mei 2004 @ 18:16:
De 1300A is een hele andere soort drive dan de Nec2500A zover ik weet ;) . Dus jammer genoeg moet je upgraden/nieuw kopen :'(
  • powerflux
  • Laatst online: 15-11 19:27
powerflux
Edit zich kapot@375fsb
ook geflashed hier, en hij werkt nog steeds gewoon, en volgens nero kan ik er ook dual mee branden.
dvd+r(w)
dvd-r(w)
cd-r(w)
geven geen problemen zoals bij eerdere firmwares, het kan nog steeds zonder problemen.
nu nog een dual layer schijf vinden.
if computergames really affect us, we would be running around in dark rooms and eating magic pills.
  • Xander
Verwijderd schreef op 24 mei 2004 @ 21:54:
Mja, deze firmware werkt iig niet op de 1300... Maar het is niet helemaal uitgesloten dat er voor de 1300 ook Dual Layer firmware komt lijkt me... :)
XanderH schreef op 24 mei 2004 @ 22:11:
Nou dan zou de firmware door uimand geschreven moeten worden buiten NEC. Want ze zullen dom zijn als ze deze odnersteuning aan de oude dvd-fikkers meegeven he :)
  • MysterX
  • Laatst online: 12-02 17:44
MysterX
Memleak 4 ever
Ik heb hem gister gewoon maar gekocht die NEC2500A en meteen geflashed..
Kosten 83 Euro. En dat voor een Dual layer :9~
When does the hurding stop?
  • n00bs
  • Laatst online: 13-11 17:23
n00bs
Het is weer Zomer!
Wel bizar dat dit besproken mag worden op GOT ;)
Alle links mbt Lite On hacks e.d. werden altijd verwijderd... :?
Anyway hoop ik dat er zo een dual layer "hack" voor Lite On ook nog gaat komen :)
  • maikel7
  • Laatst online: 19-11 23:42
MysterX schreef op 25 mei 2004 @ 09:21:
€ 83 euro? waar heb jij deze brander gekocht? en zwarte variant?
Ben namelijk ook van plan om zo 1 aan te schaffen waarschijnlijk. Alleen is het nieuws van Aopen weer verleidelijk om te wachten op een 16x, maar ja wat zal de prijs daarvan zijn.
  • Tycoontje
  • Laatst online: 10-10 18:25
maikel7 schreef op 25 mei 2004 @ 12:22:
Dat is nog vrij prijzig aan de pricewatch te zien.. (74€ voor de OEM, 70€ voor de black, 85€ voor de retail en 118€ voor de retail).
Het goede topic hiervoor is: [rml][ NEC ND-2500] Ervaringen[/rml]
  • Xander
Verwijderd schreef op 24 mei 2004 @ 22:26:
Deze firmware van de ND2500 is ook niet door NEC zelf gemaakt, maar door Hermanvh? :)
  • powerflux
powerflux
hij is door nec gemaakt, en een beetje door anderen.
de nec 2500a en die dual layer zijn namelijk hardwarematig exact aan elkaar.
  • Xander
powerflux schreef op 25 mei 2004 @ 16:19:
Ja, en de Dual Layer functionaliteit is dan toch juist door de "anderen" eraan toegevoegd? :P
  • Tycoontje
Ik geloof dat het gebaseerd is op een drive van HP...
  • Xander
Tycoontje schreef op 25 mei 2004 @ 17:06:
Naja, whatever, maar iig dus niet zo orgineel door NEC....
Dus dat argument
klopt dan ook al niet meer helemaal ;)
  • Hermanvh
Hermanvh
XanderH schreef op 25 mei 2004 @ 17:49:
Dus dat argument
NEC firmwares zijn simpel. De 2510 is hardwarematig identiek aan de 2500 (tenminste in de meeste gevallen, percentages zullen moeten blijken wanneer DL schijfjes echt voor het grote publiek beschikbaar komen). Door de identificatie van de drive in de firmware aan te passen naar 2500, werkt het dus ook op de 2500.
Deze firmware komt van een HP 520i af, dit omdat deze bitsetting ondersteunt :)
Het is dus wel een officiële NEC firmware, maar met wat aanpassingen m.b.t. regio lock, rip lock, media en aangepast voor de 2500.
webOS all the way!
  • Xander
Hermanvh schreef op 25 mei 2004 @ 19:09:
Ah, ok, thanks voor de opheldering! :)
  • nero355
  • Laatst online: 21-10 18:32
nero355
ph34r my [WCG] Cows :P
n00bs schreef op 25 mei 2004 @ 09:29:
En dan wil ik niet eens beginnen over het Flashen+Flexen van een Motorola v525 naar een v600 :/
  • StarWars
  • Laatst online: 10-11 23:51
_/-\o_ Hermanvh _/-\o_
namens alle semi-n00bs bedankt weer voor de firmware :9~
hopla
  • SB249
nero355 schreef op 25 mei 2004 @ 19:46:
Das nog niets.. wat denk je van dat gameboy ombouw topic .. en ieder xbox-ombouw topic wordt meteen gesloten :X
  • Stampre
  • Laatst online: 28-06 21:37
Ik heb net mijn nec2500 a geflasht, lijkt allemaal goed gegaan te zijn. Hoe kan ik nu zien of mijn drive ook dual layers ondersteund? Graag iets specifieker dan alleen, dat zie je in Nero :P
ok ik zie het al, het werkt, gewoon ff nieuwe versie van Dvdinfo instaleren. Wat me opvalt is dat er geen Dvd-R DL bijstaat. bestaat dit niet of komt dit ook nooit?
[ Voor 31% gewijzigd door Stampre op 25-05-2004 23:47 ]
http://specs.tweak.to/6635
  • Hermanvh
Hermanvh
Stampre schreef op 25 mei 2004 @ 23:41:
Komt waarschijnlijk wel, maar is er nog niet ;)
webOS all the way!
  • TDLofCC
  • Laatst online: 23-06 09:27
Helpt deze firmware ook weer met het beter kunnen inlezen/kopieeren van gekopieerde DVDtjes ... ?
Want dat is echt een goed nadeel van deze fikker.
Wordt nu wel wat opgeheven door deze nieuwe firmware, DL support, maar toch ;)
Hell hath no fury like a freshly circumcised sleep deprived grizzly bear on amphetamines, being assaulted(aurally and otherwise) by George Bush dressed as a clown and singing vile covers of crap songs and wielding an electric cattle prod.
  • n00bs
n00bs
Het is weer Zomer!
idd :?
terwijl dat flexen toch niet eens boeiend is :?
Beetje hypocriet hier af en toe op GOT :/
(verder niet negatief bedoelt want ik heb 't wel naar mijn zin op GOT ;) )
Maar ik vind wel dat alles en iedereen gelijk behandeld moet worden :)
  • knights16
  • Laatst online: 14:47
Wat ik me eigenlijk ook afvroeg... op 8x branden van een volle dvd doe ik 9.minuut. Dit komt doordat me NEC op +- 50% pas van 6x naar 8x branden gaat.
Is het niet mogelijk dat de NEC2500 op bijvoorbeeld 30% al op 8x gaat branden ?
Ik denk te begrijpen dat dit de kwaliteit van dvd's naar beneden kan halen, is dit verschil zo groot ?
PVoutput
  • MysterX
MysterX
Memleak 4 ever
Nee een witte, bij De Wit computers in IJsselstein. Ze hadden de zwarte nog wel.
En trouwens die van mij brand op 11X nu die firmware erover heen zit.. tenminste dat zegt DVDencrypter.. geloof er eigenlijk bar weinig van..
[ Voor 15% gewijzigd door MysterX op 26-05-2004 10:41 ]
  • MaiorDomus
  • Laatst online: 10-11 03:56
knights16 schreef op 26 mei 2004 @ 10:27:
lijkt me een beetje raar als dat zou kunnen.. een brander gaat naar mijn weten namelijk steeds weer een stukje sneller (hij spint op)
correct me if I'm wrong ;)
  • cazzie
  • Laatst online: 18:44
na wat wikken en wegen toch de koe bij de horens gevat en met
de dual-layer firmware van herrie mijn nec 2500a drive geflashed.
een cdr gefikt, dat ging prima
een dvd gefikt, dat ging ook prima
de test met dvd-dual-layer moet nog even wachten :)
control alt oeps deleted
  • r.e.n
GoTAProblem schreef op 26 mei 2004 @ 14:57:
De NEC maakt gebruik van Z-CLV, 'steeds een stukje sneller' gaat onder de noemer P-CAV.
Kijk hier maar eens.
  • FiXeL
  • Laatst online: 12-02 18:22
woei, binnenkort mn firmware maar eens updaten :)
ik zit nu met een klein probleempje... ik heb een dual layer disk nodig... wie kan me daar (tegen betaling natuurlijk) aan helpen? ik wil een backup draaien van een navtech dvd en die is een kleine 8GB. strippen of opdelen is helaas geen optie gezien de data gewoonweg niet op te delen is door een leek zoals ik :/
ik gok dat de gelukkigen die er aan kunnen komen ze liever niet doorverkopen, maar wie weet heb ik geluk... als je nog eentje kan missen mail me aub ff: FXL666_AT_hotmail.com
bij voorbaat dank! _/-\o_
Mn 3D printer blogje..
  • Scorpion2k
  • Laatst online: 11-08 11:58
Ik heb ook de Nec ND 2500a en heb nu de firmgrade gedaan via windows en vervolgens via dos. Er werden geen fouten aangegeven tijdens de firmgrade.
Ik zit nu met het volgende probleem. Mijn dvd writer leest nu wel alle cd's en kan gewoon een cd kopieren naar mijn harde schijf.
Als ik vanaf een dvd ga kopieren, kan hij wel de kleine bestanden kopieren maar niet de grote vob files. Ik krijg dan de volgende fout:
Kan VTS_04_5 niet maken of vervangen. Bestandssysteemfout (-2147351799)
Kortom ik kan niks meer doen met dvd's.
Weet iemand wat ik hier tegen kan doen?
Extra info:
Er zat geen cd of dvd in de brander
Bios geeft geen problemen
De versie wordt gewoon goed geconstateerd met de windows flasher
Er is geen lampje ofzo wat raar doet
Er gaat niet zomaar een lade open, alleen wanneer je op het knopje drukt (logisch)
Ik heb de goede bin file gebruikt voor dos en de goede voor windows
hij zit op -sec -mas
** Goed ik heb dus getest met 2 dvd's en ik heb een klein stukje troep over het hoofd gezien wat op de dvd's zat. Nu kan ik gewoon met dvd decrypt films van de dvd halen. Ik gok nu dat deze melding standaard in windows zit als je dvd's wilt kopieren, klopt dat? **
[ Voor 41% gewijzigd door Scorpion2k op 27-05-2004 18:54 ]
  • Brede P
  • Laatst online: 08-01 14:43
Ik krijg, met welke firmware versie ik in de 1.07 serie ik het ook probeer, zowel DL als ook de gewone Single Layers, een Power Calibration error. In ieder geval op Fortis en op Arita DVD+R.
  • Tycoontje
En met welke software? (Versie?)
  • Madrox
  • Laatst online: 11-11 00:40
Madrox
Oh, Pharaoh!
En worden de lasers van de 2500 ook gecalibreerd en getest op DL-mode ?
Volgens NEC nml. niet, en dat dat een zeer nauwkeurig en precies zaakje is.
Da's nou precies waarom ze er niet garant voor staan. Een test van iemand geeft dit al aan: Hij kan idd. DL-mode branden, de NEC leest ze ook prima. Maar bijna alle andere DVD-roms waar hij het DL-mode gebrande schijfje inlegde, zag geen cdrom of bleef flikkeren. Alleen een Sony **** model zag hem wel goed, maar dan wel met de laatste firmware (hij had er twee van, 1 met de ouwe en 1 met de nieuwste firmware (alleen de laatste zag hem, de ander pas na een flash).
Dus ook al kan je DL-mode fikken na een flash, de bruikbaarheid is tot nog toe beperkt. Iedereen die meer info heeft over de compabiliteit met andere DVD-apps is welkom dit te komen melden.
Voor upgrade, complete zelfbouw, herstellen van windows/software klik hier!
Is deze firmware nou ook de beste/meest geupdate/compatibelste firmware wanneer je dus nog lang geen behoefte hebt aan DVD9 DL schijfjes.
Ik wil wel Herrie's recentste firmware draaien, dat doe ik al sinds ik mijn 2500a gekocht heb. Ik heb slechts 1 keer een stapje terug moeten doen, van beta9 naar beta7 en heb dus volledig vertrouwen in die firmwares!
Ik draai nu herrie 1.07v2b4, naar mijn weten de recentste die geen DL support. Is er een nieuwere? Ik heb gezocht maar zie op alle fora enkel gesloten topics van de b2v4 waarbij de laatste post verwijst naar de nieuwe DL firmwares (waar ik dus NOG geen behoefte aan heb).
Denk ik dom/naief als ik denk dat DL firmware overbodige extra's bevat die het single layer fikken alleen maar moeilijker/minder betrouwbaar maakt?
Of is de DL firmware qua single layer fikken ook geupdate in vergelijking met de 1.07v2b4?
  • Hermanvh
Hermanvh
Verwijderd schreef op 28 mei 2004 @ 23:11:
Single layer is ook weer verbeterd!
webOS all the way!
  • djengizz
Ik hem m'n NEC2500 net voor het eerst geflashed net de DL firmware. Heb ook geen schijfjes om te testen. Gewone DVD's gaan wel sneller en foutloos :)
Volgens de compuboer om de hoek heeft hij einde deze maand de eerste DL schijfies. Hij kon wel de prijs in de computer zien (€19), maar niet het aantal schijfjes (ik hoop niet één voor €19 >:) )
  • Henk007
  • Laatst online: 06-04-2025
djengizz schreef op 30 mei 2004 @ 12:07:
Ik denk wel dat dat de prijs per stuk is. Kijk bijvoorbeeld maar eens bij Opus. Daar staat een prijs van 73 euro ex btw voor 5 stuks DVD+R DL 2.4speed
Nee voor mij voorlopig nog geen dual layer. Kun je bijna net zo goed een tweede origineel kopen als backup :P
  • Cannondale
  • Laatst online: 20:45
Henk007 schreef op 30 mei 2004 @ 12:15:
Ik vraag me inderdaad ook af of consumenten zo gek zullen zijn om zoveel geld voor lege media neer te leggen. Ik vrees van niet, dus of die dingen worden geen succes of het is wachten tot ze goedkoper worden. Weet niet of de gewone dvd-r/+r bij introductie ook zo gortig duur waren btw?
"In the long run we are all dead" J.M. Keynes
  • Xander
Cannondale schreef op 30 mei 2004 @ 14:34:
Voor het branden van grote hoeveelheden data is het natuurlijk wel makkelijk :)
  • Slurpgeit
we willen natuurlijk allemaal en dual layer om een back-up van onze pc te maken B)
  • Maarten @klet.st
  • Laatst online: 18-10 12:34
Gewone DVD-R/+R's waren ook zo duur. Die zijn ook goedkoper geworden.
Het grote voordeel dat daar nu bij komt is dat de standalone DVD Recorders (als vervanger van videorecorders) door beginnen te breken. Dat maakt de markt/vraag veel groter dan als alleen computergebruikers DVD-R/+R schijfjes willen hebben. Zodra de productie goed en wel loopt zal de prijs dan snel dalen.
powerflux schreef op 24 mei 2004 @ 21:58:
dvd+r(w)
dvd-r(w)
cd-r(w)
Idem _/-\o_
  • mtbrainz
  • Laatst online: 12:43
Hermanvh schreef op 22 mei 2004 @ 20:22:
Misschien ben ik wel heel dom dat ik dit hier vraag, dit is de eerste firmware die ik flash op m'n nec2500 en zoveel verstand heb ik er allemaal niet van.. maar dit wil zeggen dat als ik de booktype met dvdinfopro heb geset, dat ik dan ook met recordnow max moet branden of kan ik ook net zo goed gewoon met nero branden?
Ik verwacht 't trouwens niet (dat ik ook met nero kan branden dus), ik meen me iets te herinneren dat ik op bepaalde pc's of met de originele firmware wel 'set booktype' zag staan in nero, dat zie ik met deze firmware niet (duallayer support wel trouwens, alleen heb ik daar zo weinig aan zonder media 8)7 ). Is 't de bedoeling dat dat ooit een keertje wel d'r in komt?
  • Tycoontje
Met Nero gaat het hier ook prima. Schijn je wel een recente versie voor te moeten hebben, want anders doet ie het niet goed heb ik geloof ik ergens gelezen.
  • mtbrainz
6.3.1.10, net vanavond geupgrade naar die versie. Lijkt me redelijk de nieuwste of niet?
Ik zie toch nergens iets van een booktype ikoontje staan.. niet bij 't Burn venster, niet bij Disc Info.. of ik ben gewoon blind natuurlijk.
Of ik begrijp je reactie gewoon niet ('t is al laat) en ik moet eerst de bitsetting doen met dvdinfopro en daarna gewoon branden met nero, dat kan natuurlijk ook nog.
  • djengizz
Hmm, ga toch weer terug naar de vorige firmware versie. Alles ging prima totdat ik gisteren een Imation DVD+R wou schrijven: power calibration error. Dit ging met mijn vorige firmware wel goed :( .
  • Xander
djengizz schreef op 31 mei 2004 @ 10:01:
Misschien was dat eenmalig? Kan altijd gebeuren natuurlijk...
