Het grote Nokia 7610 topic [deel 1]
Pagina: 1 ... 10 11 Laatste
  • 4.156 views sinds 30-01-2008
Maite schreef op zondag 17 april 2005 @ 02:04:
Ter informatie:
Het is nu ook mogelijk met je 7610 via BT te internetten met je ADSL verbinding :D
De oplossing het GNUBOX
Waaaat ik wil meer weten!!!!!!!! Eerst kon dat niet!
[ Voor 4% gewijzigd door Verwijderd op 17-04-2005 09:43 ]
  • Maite
  • Laatst online: 18:21
  • Raimon
  • Laatst online: 03-01-2023
Er is nieuwe software uit voor de 7610:
Changes/improvements made from MCU SW v 4.0437.4 to 5.0509.0:
Call and network management:
- Improvements to ringing tone handling in IHF when headset is connected
- When switching Auto time update on, date & time are not asked
- “Error in connection” -message no longer displayed when activating incoming call
- Incoming call –case corrected
GPRS:- Improvement to GPRS PDP context activation after multiple successful connections
- Improvements to GPRS attach/detach functionality
CSD:- Improvements to CSD connection establishments if GPRS always online is used
- Improvements to dial-up connection over USB in Win XP
USSD:
- Proper execution of “send USSD command”
SMS:- Improvements to message counter
- Improvements to SMS editor when T9 used
- Improvements to T9 dictionary handling (China specific)
- First character also seen when using theme 4 (China specific)
- Finding Web address in message no longer stops at ","
MMS:
- Correct error notification displayed when inserting video to MMS
- Improvements to MMS sending after resumed from GPRS suspend
E-mail:
- DRM protected video clip cannot be inserted to email from attachments view. Error message "Unable to add invalid attachment" shown
- Instant messaging
- Chat UI localization corrections
- GPRS disconnection improvements when logging out from IM server
- Improvements to message forwarding to IM contacts
- In ServiceRequests ClientID element, if MSISDN element is present, it cannot be empty. If application doesn't have any special ClientID it will send default value instead
Voice mail waiting indicator:- Improvements to soft notifications for the second voice mail waiting indicator
Browser
- Base64 encoding in multipart/mixed rendering
- WTAI – note localization improvements
- Browser stability improved when refreshing saved page
- Nokia Wireless keyboard (SU-8W) support added for browser input fields
- Improvements for displaying Chinese characters in browser (China specific)
Disconnect improvements when browsing over CSD
- WAP SI-PUSH message saving corrections
- Improvements in COD downloading
- Wrapping improvements in browser
- Hyperlink selection corrected
Streaming:- Some 3gp files did not work with 7610
- Improvement to streaming pause handling when streaming over GPRS nw mode1 and MT call received
- Improvements for playing H263 files in Real Player
- Streaming stability improvements when receiving MMS during streaming
Bluetooth:
- Bluetooth stability improvements
Gallery:
- Media gallery stability improvements during file handling
Alarm:
- Phone freeze case with locked MMC card and alarm corrected
MMC:
- Memory card name localization improvements (China specific)
- MMC backup stability improvements
Manual video editor:
- Manual video editor stability improvements
USB:
- USB cable connection/disconnection improvements
Helps:
- Lunar calendar removed from English help for Chinese SW
- Note & Tips localization corrections (China specific)
- Improvements to Login process to Kodak Mobile service
- Improvements to Nokia Flashlight PD-2 and imaging applications interaction
- Operator name list updated
Bron: Nokia.nl
don't worry, be happy...
Raimon schreef op maandag 18 april 2005 @ 14:13:
USSD:
MMS:
E-mail:
- Instant messaging
Browser
Bluetooth:
Gallery:
Alarm:
MMC:
USB:
Helps:
Bron: Nokia.nl
Das mooi, iemand enig idee wanneer 'ie beschikbaar is bij phonehouse ofzo?
  • Raimon
Verwijderd schreef op maandag 18 april 2005 @ 15:03:
Alle servicepoints kunnen deze vandaag downloaden. het is de vraag wanneer verschillende service-points deze downloaden en instaleren. Wij hebben deze al geinstalleerd.
Raimon schreef op maandag 18 april 2005 @ 17:02:
Ah, waar zit jouw servicepoint :D .
  • NiteSpeed
  • Laatst online: 20-09-2025
Inderdaad, waar zit dat kreng :P.
  • Maite
volgens mij in Winterswijk (Gld)
[ Voor 11% gewijzigd door Maite op 19-04-2005 15:01 ]
Wat wordt er verstaan onder een service punt......welke winkel gaan daar voor door?
Verwijderd schreef op maandag 25 april 2005 @ 15:52:
officiele dealers van nokia telefoons.
Als je je telefoon gekocht hebt bij z'n winkel kan je meestal onder je je koopgarantie je nokia laten flashe. Is dat niet zo dan moet je meestal wat bij betalen (30 euro ofzo).
Misschien een stomme vraag, maar zo ook de belcompany?
Of weet iemand een ander punt in de buurt van Enschede?
  • cornelixnootje1
  • Laatst online: 17-01-2022
Hier wordt beweerd dat er een STEREO HEADSET te koop is voor de 7610? Klopt dit, of is dit de zoveelste die denkt dat die dingen universeel zijn?
http://www.eu-gsm.nl/noki...stereo_headset_HDS_3.html
cornelixnootje1 schreef op woensdag 27 april 2005 @ 00:20:
Er bestaan wel dual-mono headsets voor de nokia 7610 op ebay. Dit is gewoon een foutje van de site; het is ook gewoon vreemd dat de 7610 mono is.
  • miggeltje
  • Laatst online: 13-11 09:26
Verwijderd schreef op dinsdag 26 april 2005 @ 14:57:
Volgens mij is het officieel alleen bij de Nokia ServicePoints te doen (ik kan het ook mis hebben hoor).
Zo ja, dan zijn er in Overijssel slechts 2.
1 in Deventer, en 1 in Rijssen volgens de lijst op de club nokia site.....
Ik zit vast aan Rijssen om mijn telefoon te laten flashen.
Weet iemand misschien hoe je je gsm moet formatteren? Ik merk dat mijn gsm ontzettend traag is als ik door mijn menu heen moet navigeren.
  • ScSi
  • Laatst online: 12-11 22:46
ScSi
Belg.
Verwijderd schreef op dinsdag 17 mei 2005 @ 00:01:
Daar is heel wat over te vinden, het had iets met uitgaande of ontvangen gesprekken te doen, even googlen..
Formateer code voor de Nokia 7610 overigens voor de meeste symbian 60s!
* # 7 3 7 0 #
Typ de bovenstaande code achterelkaar in en de telefoon geeft het vanzelf al aan!
Groetjes
Simone :+
Hallo allemaal,
Ik heb ook een nokia 7610 O-) met alles erop en eraan.
Het enige wat ik nog mis is mijn eigen stijl op de display. Je hebt 2 snelkoppelingen links 1 naar ''camera'' en rechts 1 naar ''favorieten''. Ik wil er graag ''berichten'' en ''camera''.
Nu is het mij al wel eens gelukt toen ik de telefoon net een dagje had. Maar na een formatatie stonden alle instelling weer als vanouds 8)7 en nu weet ik niet meer hoe het mij toen op puur geluk wel gelukt was |:(
Weet iemand hoe je dit kunt doen?
Groetjes Simone _/-\o_
  • Bramm
  • Laatst online: 12-11 08:43
Maite schreef op dinsdag 19 april 2005 @ 15:00:
jep, de INIA kantoorwinkel aan het beatrixpark dacht ik.
  • alex75
  • Laatst online: 13-11 20:53
@simonescholten
instellingen-standbymodus etc.
Even een schopje...
Hoe hebben jullie het 'Geen officiele carholder beschikbaar'-probleem getackeld?
Ik vind zelf alleen maar van die cheap ass klem systeempjes..
Heeft iemand een beter alternatief?
Greetz..
  • Raimon
Nieuwe Software
Versie 6.0522.0
Changes/improvements made from MCU SW v 5.0509.0 to v 6.0522.0:
- Call establishment/disconnection improvements
- Soft reject with SMS added as a new feature
- Correction for ascending .rng ringing tones
SMS
- Correction for configuration message handling
- 7-bit/Unicode character counter support for SMS
- T9 memory size increased
- Reply to SMS with MMS added as a new feature
Email
- Email attachment handling improvements
Browser
- Browser stability improvements
- Correction for input field entry confirmation
- Correction for login process to sites which requires username and password
Streaming
- Improvements to streaming connection establishment from browser
- UI corrections to streaming session interruption
Bluetooth
- Bluetooth device discovery improvements
- Bluetooth connection time to CK-7W improved
Calendar
- Calendar stability improved
Application installer
- Improvements to embedded SIS-file handling
SIM-ATK
- Launch browser command corrected in SIM-ATK
- Correction for crash when opening mp4-file from File Manager
- Boot up stability improvements
- File manager stability improvements
- Localisations corrections
- Correct response to AT+CNMI AT command
- Battery life time improvements
- Improvements to large image handling in gallery
- Thumbnail image visibility improved in phonebook
Bron: Nokia
  • Gregoor
  • Laatst online: 12-11 21:58
Klinkt allemaal zeer goed. Wordt toch maar eens tijd om een update te laten uitvoeren aangezien ik nog de allereerste firmware heb van toen de telefoon pas net uit was. Maar bij welk servicepunt werk je Raimon, en hoeveel kost flashen buiten de garantie?
Heb namelijk niet zo'n goede ervaringen met het Nokia servicecenter hier in de buurt in Eindhoven.
Gregoor schreef op dinsdag 13 september 2005 @ 01:06:
Bij Nokia Rotterdam kost het geloof ik € 50,- 8)7
Dat is de reden waarom ik de firmware niet laat updaten.
Voor € 30,- wil ik het nog wel doen. Ben benieuwd wat het bij Raimon kost :?
  • Gregoor
Dat is nogal wat geld ja. Al zou ik dat er nog wel voor over hebben aangezien ik er toch nog een jaar mee moet doen, en ik dan liever dat bedrag betaal dan me steeds stoor aan trage menu's en minder functionaliteit. Snap wel dat die menu's niet ineens super snel worden, maar vind is het soms erg irritant, vooral als de telefoon al een aantal weken aanstaat. Daarnaast zijn sommige bugs ook niet alles.
Twijfel nu alleen een beetje omdat mijn keypad ook niet helemaal meer goed reageert. Dat is alleen nogal van dag tot dag veranderlijk. Dus weet niet of ik hem nu helemaal naar Nokia wil sturen of alleen de firmware wil laten upgraden zodat ik dan mogelijk ook dezelfde dag mijn telefoon weer terug heb.
Gregoor schreef op dinsdag 20 september 2005 @ 01:20:
Die keypad is algemeen bekend.
Ligt trouwens aan de hardware en volgens mij heeft bijna ieder model hier last van.
Ik heb het zelf ook en ken 4 mensen die het ook hebben |:( . Inderdaad wel vreemd dat het van dag tot dag varieerd :O
  • JasperE
  • Laatst online: 31-10 22:09
Verwijderd schreef op dinsdag 20 september 2005 @ 10:31:
Die van mij is nu een jaar en 2 maanden oud, heeft alleen een tijdje een slecht reagerende ophang knop gehad maar dat lijkt nu weer voorbij....
* JasperE klopt even af
  • Denko
  • Laatst online: 09:33
Denko
|{ing Øf ßlitz
hm, wordt tijd dar ik ook ff me firmawe update (1,5 jaar oud, had hem sinds de eerste dag) :D
PSN & XBL: Denkoyugo
Mijn aan/uit knopje werkt niet meer! Is er een manier om 'm anders aan te krijgen?
  • JasperE
Nee
  • Canaria
Canaria
4313-3581-4704
Dit topic heeft meer dan 1000 replies en gaat dus dicht.
Mocht er behoefte bestaan om nog verder te posten over de Nokia 7610, dan mag er natuurlijk een deel 2 worden aangemaakt.
Apparticle SharePoint | Apps | Articles
