Abit IC7(-G) [Ervaringen]-Deel 2
Pagina: 1 2 ... 6 Laatste
  • 1.026 views sinds 30-01-2008
  • ken
  • Laatst online: 17-12-2024
Tijd voor deel 2 van dit populaire moederbord met Canterwood chipset :)
Voor deel 1 zie:
[rml]Abit IC7(-G) [ Ervaringen][/rml]
Nogmaals de specs voor de mensen die dit bord nog willen aanschaffen :)
[CPU]
Supports Intel Pentium 4 Socket 478 processors with 800/533/400 MHz FSB
Supports Intel Hyper-Threading Technology
[Chipset]
Intel 875 / ICH5-R
Support Intel CSA Gigabit LAN
Supports Dual Channel DDR 400 with ECC function
Supports Performance Acceleration Technology (PAT) function
Supports Advanced Configuration and Power Management Interface (ACPI)
[Memory]
Four 184-pin DIMM sockets
Supports 4 DIMM Single/Dual Channel DDR 400 memory.(Max. 4GB)
Supports configurable ECC function
[AGP]
Accelerated Graphics Port connector supports AGP PRO 8X/4X (0.8V/1.5V)
[Serial ATA RAID]
2 channel Serial ATA 150MB/s data transfer rate with RAID 0 function support
2 channel Serial ATA 150MB/s data transfer rate with RAID function (0/1) via Silicon Image PCI Chip (IC7-G only)
[Audio]
6-Channel AC 97 CODEC on board
Professional digital audio interface supports 24-bit S/P DIF optical In/Out
[Media XP (Optional)]
Supports card reader function for Memory Stick™, Secure Digital™ and Type I/II CompactFlash™
Supports Wireless Remote Control and S/PDIF Out / Mic In / Headphone Out / USB 2.0 / IEEE 1394
[System BIOS]
SoftMenu™ Technology to set CPU parameters
Supports Plug-and-Play (PNP)
Supports Advanced Configuration Power Interface (ACPI)
Supports Desktop Management Interface (DMI)
Write-Protect Anti-Virus function by AWARD BIOS
[IEEE 1394]
Supports IEEE 1394a at 100/200/400 Mb/s transfer rate
[Internal I/O Connectors]
1 x AGP PRO, 5 x PCI slots
1 x IrDA
1 x Floppy Port supports up to 2.88MB
2 x Ultra DMA 33/66/100 Connectors
2 x Serial ATA 150 Connectors (4 on IC7-G)
2 x USB 2.0 headers, 2 x IEEE 1394a header
1 x CD-IN, 1 x AUX-IN
[Back Panel I/O]
1 x PS/2 Keyboard, 1 x PS/2 mouse
1 x Printer Port, 1 x COM port
1 x S/PDIF Out connector, 1 x S/PDIF In connector
1 x Audio connectors (Front Speaker, Line-in, Mic-in)
1 x Audio connectors (Center/Sub, Surround Speaker)
2 x USB 2.0, 1 x IEEE 1394a
2 x USB 2.0
1 x RJ-45 LAN Connector (IC7-G only)
[Miscellaneous]
ATX form factor
Hardware monitoring - Including Fan speeds, Voltages, System environment temperature
Verschil IC7 en IC7-G:
Geen Gigabit Lan.
Geen Silicon Image SATA controller
Nieuwste bios: (Versie 15)
http://fae.abit.com.tw/download/bios/ic7/ic715.exe
Nieuwe Intel IAA drivers: (Versie 3.5)
ftp://aiedownload.intel.c...t/6363/eng/iaar35_enu.exe
- Ondersteuning voor Raid1 (bios moet dit wel ondersteunen)
- Bij een restart gaan de schijven niet meer opnieuw opspinnen
Binnen een paar weken komt de IC7-G MAX3 :9~
Hier een plaatje:
Afbeeldingslocatie: http://www.3dnews.ru/documents/5468/abit-ic7-max3.jpg
Je zier hier duidelijk de nieuwe NB koeler. Deze nieuwe koeler maakt minder geluid en koelt net zo goed als de oude NB koeler. Ook zie je dat de mosfets hier nu ook gekoeld worden door een FAN :)
Hier een ander foto van de IC7-G MAX3
Afbeeldingslocatie: http://202.168.194.118/abit/upload/products/IC7-MAX3_pic6.jpg
Je zier hier dat de kleur van de mosfet koeler anders is. Wat de originele kleur is/wordt weet ik niet :)
Verder bied de IC7-G MAX3 officieel ondersteuning voor Prescott CPU's
Er wordt gespeculeerd over een Vmem van 3.2V ipv 2.8V :9~ , maar dit moeten we nog maar even afwachten. Nog niet officieel bevestigd door Abit :)
Voor mensen die toch hoger dan Vmem 2.8V willen, geen probleem. Gewoon een Vmod uitvoeren.
Zie: http://www.xtremesystems....0859e881ca&threadid=12914
Plaatje van een Vmod op een IC7-G ( Vatt ik heb even je mooie plaatje geleend :) )
Afbeeldingslocatie: http://members.home.nl/cwcheung/vmem.JPG
Het 'nadeel' van deze mod is dat de VDDR wel omhoog gaat maar de VTT niet (vtt=normaal gesproken de helft van vddr) als je via het bios verhoogt gaat vtt wel mee. De mod werkt wel, maar het werkt het best bij een gering verschil 2.8+0.1v of +0.2v ofzow want dan wijkt vtt het minst af van vddr /2.
Optimale geheugen instellingen om een hoger FSB te kunnen halen:
Afbeeldingslocatie: http://members.home.nl/cwcheung/game.JPG
Temp reading op Abit borden geven vaak een hoger temp. Dit komt omdat Abit een ander manier van meten heeft.
Zie: http://fae.abit.com.tw/eng/faq/qa/2003/2003052801.htm en http://forum.abit-usa.com...ead.php?s=&threadid=11496
Ook is het bekend dat deze borden problemen hebben met hun MIC. Veel ruis on vaak onverstaanbaar als ze via de MIC praten.
zie: http://forum.abit-usa.com...2&perpage=15&pagenumber=1
Als jullie problemen hebben met jullie moedborden (bijv MIC probleem), stuur dan een mailtje naar : technical@abit.nl en NIET naar rma@abit.nl. de rma is alleen voor het begleiden voor RMA formulieren etc. Wordt verder netjes afgehandeld :)
Reviews:
Tomshardware (met een 1.0 BIOS!!):
http://www.tomshardware.com/motherboard/20030519/index.html
Anandtech: http://www.anandtech.com/mb/showdoc.html?i=1822
Extreme Overclocking: http://www.extremeoverclo...rboards/ABIT_IC7-G_1.html
Hot hardware: http://www.hothardware.co...abitic7g_asusp4c800.shtml
HardOCP: http://www.hardocp.com/article.html?art=NDY5
Asusboards: http://www.asusboards.com...s.php?op=showcontent&id=6
Wat forums met een schat aan informatie:
http://forum.abit-usa.com/forumdisplay.php?s=&forumid=6
http://www.abxzone.com/fo...fee08c0868e491&forumid=41
Dit was het dan. Als jullie er nog iets aan willen toevoegen, moeten jullie het maar even doorgeven :)
[ Voor 28% gewijzigd door ken op 27-07-2003 13:57 ]
Canon 5D Mark II, Canon 35 f/1.4L
  • Intronic
  • Laatst online: 02-04 17:08
Originele kleur van de mosfetkoeling is gewoon blauw, staat ook op de officiele site ;)
BTW, optimale instellingen voor hogere fsb zijn dit:
Game Accelerator: Auto
Refresh Cycle Time: Normal
Read Delay(tRD): 11 Clocks
Read Delay Adjust(tRDA): Disabled
Command Per Clock(CPC): Disabled
  • ken
Intronic schreef op 27 July 2003 @ 03:19:
Met 11 clcok komt je idd vaak wel iets verder, maar de prestaties nemen dan af doordat het langzamer gaat lopen. Geadviseerd wordt dus:
Read Delay(tRD): Auto
Ik meen mij te herinneren dat Vatt dit ook al een keer heeft getest :)
@ Mr. Hard. Ga je ook een IC7 halen?? Welk CPU neem je erbij??
Ben benieuwd wat die Geil DDR500 het doet op deze moederbord :)
[ Voor 207% gewijzigd door ken op 27-07-2003 03:48 ]
jan / mr hard. heeft 2.8 malay week 21 besteld, daarnaast een ic7 ook, heeft het nog niet binnen.
  • ken
Verwijderd schreef op 27 July 2003 @ 03:57:
hmm. Hoop dat zijn 2.8C week21 beter is dan de 2.8C week21 die ik had.
Ik kon max op 3.5Ghz nog benchen. Was alleen niet 100% stabiel.
Niet dat dat heel slecht is, maar de week 17 die ik nu heb, doet het iets beter :)
[ Voor 5% gewijzigd door ken op 27-07-2003 04:06 ]
ken schreef op 27 July 2003 @ 04:01:
ik heb ook een week 17 malay, doet 4ghz maar kan niet booten omdat de temp niet onder 0 blijft met mijn vapo, daarom heb ik al me vapo's in de verkoop gezet, en me lian li gaat ook weg, begin een nieuw project met een prometeia r404a.
mijn week 21 komt vast wel hoger als 3,5 aangezien ik met een R404a prommy ga coolen ;)
btw er staat zelfs vermeld op de site van geil dat ze pc4200 (DDR533) hebben dus ik ga is goed rondkijken, specificaties van pc4000 zijn:
PC4000 500Mhz Dual Channel DDR Ultra Platinum Version:
Available only in 512MB (2X256MB) and 1GB (2X512MB) Dual Channel DDR Ultra Platinum Kits.
- 184pin, Non-ECC, Un-buffered, high performance DDR memory modules.
- Hand Picked 3.5ns GeIL Chips
- 6 Layers Ultra Low Noises Shielded PCB board.
- Optimized SPD for Intel’s 875/865 chipset Dual Channel DDR motherboards.
- Tin Coated Platinum - Copper Heat Spreader
- Lifetime Warranty
- CAS 2.5 7-4-4 Running @ DDR500Mhz PC4000
- 2.6v-2.95V
- Retail package with neon green clear acrylic case and instructions.
verder staat dit erboven:
Item - GeIL PC4000 500Mhz/ PC4200 533Mhz Dual Channel Ultra Platinum Series
maar over de pc4200 staat nog geen info, wel hoorde ik van intronic dat iemand in.... land het al getest had.
  • SirBlade
  • Laatst online: 06-04 15:42
Ik wil binnenkort de IC7-G MAX3 gaan kopen maar ik vraag me 1 ding af. De Gigabit NIC werkt die alleen op 1000mbit of kan hij ook 100mbit aan? M'n switch is namelijk een 100mbit model.
ga er maar 99 % vanuit dat ie 10/100/100 is, dat is mijne huidige intel pro 1000+ op me ic7-g ook.
Verwijderd schreef op 27 juli 2003 @ 19:24:
10/100/1000 bedoel je :+ (mierenneuken). Nog weinig reviews in de openingspost. Meer review van de Abit IC7 kun je hier vinden:
http://www.techview.nl/products/686
Complete lijst van die reviews:
PC Hardware http://www.pchardware.ro/Reviews/review.php?id=190
HardwareZone http://www.hardwarezone.com/articles/articles.hwz?...
X-Bit Labs http://www.xbitlabs.com/articles/mainboards/displa...
3DGameMan http://www.3dgameman.com/vr/abit/abit_ic7g/video_r...
Overclockers New Zealand http://www.overclockers.co.nz/ocnz/review.php?id=0...
Tom's Hardware http://www17.tomshardware.com/motherboard/20030707...
HEXUS.net http://www.hexus.net/review.php?review=567
The Tech Report http://www.tech-report.com/reviews/2003q3/abit-ic7...
Nordic Hardware http://www.nordichardware.com/reviews/motherboard/...
Amd3D http://www.amd3d.com/modules.php?name=Reviews&rop=...
LostCircuits http://www.lostcircuits.com/motherboard/abit_is7/
ExtremeTech http://www.extremetech.com/article2/0,3973,1129722...
Viper's Lair http://www.viperlair.com/reviews/cpu_mobo/abit/ic7...
UK Gamer http://www.ukgamer.com/article.php4?id=4&page=1
VR-Zone http://www.vr-zone.com/reviews/ABIT/ICS7G/
AnandTech http://www.anandtech.com/mb/showdoc.html?i=1831&p=...
Digit Life http://www.digit-life.com/articles2/roundupmobo/ro...
Techseekers.net http://www.techseekers.net/modules.php?name=Review...
Legit Reviews.com http://www.legitreviews.com/Reviews/i875_1.shtml
AnandTech http://www.anandtech.com/mb/showdoc.html?i=1822
AnandTech http://www.anandtech.com/chipsets/showdoc.html?i=1...
Tom's Hardware http://www17.tomshardware.com/motherboard/20030519...
OCAddiction http://www.ocaddiction.com/reviews/mobos/abit_ic7g...
AsusBoards.com http://www.asusboards.com/reviews.php?op=showconte...
HardOCP http://www.hardocp.com/article.html?art=NDY5
HotHardware http://www.hothardware.com/hh_files/Motherboards/a...
LostCircuits http://www.lostcircuits.com/motherboard/abit_ic7/
HardOCP http://www.hardocp.com/article.html?art=NDU5
//Edit
Dit Max3 ziet er erg mooi uit, vraag me alleen af hoeveel winst je in de praktijk haalt met ide actieve mosfet koeling.
[ Voor 4% gewijzigd door Verwijderd op 27-07-2003 19:40 ]
Verwijderd schreef op 27 July 2003 @ 19:36:
//Edit
leuke lijst,
winst? denk niet veel, alleen minder risico op doorgebrande mosfets op hogere voltages.
  • BalusC
BalusC
Carpe diem
* BalusC heeft even een aantal slowchatberichten verwijderd ..
Bij deze dus het verzoek om dat niet meer te doen. Verdere maatregelen zijn niet uitgesloten. Gebruik voortaan gewoon ICQ/email of eventueel MSN.
Zie ook de 2e posting van Dit graag lezen eer je post :) :)
[ Voor 10% gewijzigd door BalusC op 28-07-2003 07:39 ]
  • Remco20
  • Laatst online: 10-04 22:14
Hum ik begin een vaag probleem te krijgen met m'n onboard sound. Wanneer ik het volume redelijk vol zit, hoor je in een bepaald patroon gekraak. Wanneer m'n dvd drive begint te spinnen, hoor je hem spinnen over de speakers. :O
Iemand enige ervaring hiermee ?
  • STIMPPYYY
  • Laatst online: 22:11
waar kan je ook alweer zó'n nieuwe NB fan krijgen want hij doet wel erg irritant bij mij :(
kheb het al gevonden laat maar :)
- northbridge fan wordt lawaaiig, wat te doen? moet het board rma?, zijn er losse 'verbeterde' versie northbridge coolertjes verkrijgbaar of te koop? wat gebeurt er met de garantie bij het aanbrengen van een aftersales solution?
neem contact op met technical@abit.nl zij zullen een verbeterde versie op sturen van de northbridge koeler ,we hebben wel graag de oude retour omdat deze terug moeten naar Taiwan.Op dit moment kan het ven duren omdat we op nieuwe NB koelers wachten.De 2e vraag is een interessante ,eigenlijk moet ik zeggen dat de garantie vervalt,maar jullie tweakers zijn echt wel in staat om de NB koeler te vervangen zonder dat er schade aan het bord ontstaat.Als er zichtbare schade is zoals met een schroevendraaier door de sporen op de pcb gaan dan valt dit onder user abuse en kunnen we helaas geen garantie geven.
- het mic-in probleem, veel mensen hebben last van zoveel noise op de mic-in van de onboard sound dat deze prakties onbruikbaar is. wat is er aan te doen, en wat is het standpunt van abit(amor) indeze, hoe wordt het opgelost.
Hier kan ABIT NL op dit moment weinig aan doen omdat deze kwestie op dit moment nog in onderzoek is bij de Field Engineers in Taiwan.Zodra ik hier meer over weet dan kom ik hier op terug.
Ik zal gelijk ff de mail adressen er bij doen :
technical@abit.nl voor alle technische vragen
rma@abit.nl voor alle rma aanvragen
salesbenelux@abit.nl voor verkoop gerelateerde vragen
marketingbenelux@abit.nl voor marketing gerelateerde vragen,sponsoring ,banners,posters,vlaggen
orderparts@abit.nl voor het bestellen van Fan's ,bios chips etc
http://fae.abit.com.tw/eng/faq/generic/ voor onze faq
077-3204428 voor helpdesk
ftp://ftp.abit.com.tw/pub/download/fae/ voor manuals biossen etc.
Ik hoop dat ik jullie al een beetje op weg heb kunnen helpen.
Met vriendelijke groet,
Dave
[ Voor 92% gewijzigd door STIMPPYYY op 28-07-2003 20:48 ]
  • Pheno79
  • Laatst online: 05-01 15:26
Leuk, mijn zalman had blijkbaar net teveel spanning op de ring gezet. Ik hoorde een herrie uit mijn kast. Dus ik kijk eens in de kast en is er 1 van de 4 pinnen eruit geschoten (niet eens gebroken). Dan maar adhesive zooi erop gooien....
Raar dat dat pas na een paar weken gebeurd, maar ja het bord werkt nog, dat is het belangrijkste :)
  • MrDirect
  • Laatst online: 22:32
Ik heb een tijdje niet gepost, want mijn IC7-G is ter hemel gerezen :'(
Het ligt ergens aan de IDE poorten, zodra ik daar iets aanhang en ik zet de computer aan komt ie nog niet eens in het BIOS scherm.
Het begon met vage vastlopers en systeem freezes, en een reboot hielp dan wel weer. Maar de freezes kwamen steeds vaker, en bij de laatste reboot kwam die niet meer tot leven.
ik heb inmiddels al 3 IDE kabels getest, 5 harde schijven en het probleem blijft hetzelfde. Als ik er helemaal niks aanhang en alleen de SATA aansluiting gebruik boot ie wel. Ook IDE poort2 kan niet gebruikt worden, dus een CD-ROM speler kan ik ook niet eens aansluiten.
Garantie zit er niet op, want ik heb de soldeerbout erop gehad natuurlijk....
Wie weet nu al de echte specificaties van de IC7-G MAX 3? Yorcom denkt ze 1 augustus binnen te krijgen, maar kon het niet zeker zeggen. Als die echt 3.2 vdimm heeft koop ik de Abit, anders ga ik voor een Asus P4C800-E.
Mijne is ook naar de klote :( Ik zat even in de kamer koffie te drinken, en ik kom terug bij mijn PC, staat ie uit. Ik :? Ik zet hem weer aan, en vervolgens kapt hij er na 0.5 sec weer mee. Nog een keer aanzetten werkt niet, alleen als de standby stroom er af geweest is, lijkt dus op kortsluiting. Andere voeding geprobeerd, PC overnieuw in elkaar gezet, zonder PCI kaarten opstarten, niks mag baten. Morgen gaat hij terug naar Alternate :( Overklokken kan het ook niet geweest zijn, omdat mijn CPU gewoon 2.8 Ghz draaide die dag.
[ Voor 10% gewijzigd door Verwijderd op 29-07-2003 17:53 ]
  • Intronic
Vatt schreef op 29 July 2003 @ 15:24:
Zeg dat niet, de mijne had ik ook gesoldeert.. alleen ging iets fout, mobo dood. Had em gewoon ge-rma't (ja is stout maar ok :P) bij maxpert, en de volgende dag had ik al een nieuwe abit in huis!
Zorg gewoon dat het bord er als origineel uitziet, dus stock NB, nix op de SB etc.
Ik heb net een ic7-g opgehaald, maar er staat op het bord ic7 , op een barcode stikker boven de bedrukking op het bord staat het serienr en daaronder ic7-gv1.0
Heb ik nou wel een G of geen G?
Ik heb gekeken, naar de verschillen van de borden die op deel 1 staan, maar ik zie geen zichtbare verschillen(zijn die er wel?)
[ Voor 26% gewijzigd door Verwijderd op 29-07-2003 20:46 ]
  • MrDirect
Je hebt aan de achterkant een LAN aansluiting of niet.
Zo ja: IC7-G
Zo nee: IC7
Ik heb de -G versie en op het bord staat gewoon IC7.
Op het bord heb ik er wel 1, vreemd dat er niet gewoon ic7-G op staat.
Vatt schreef op 29 July 2003 @ 20:51:
Zo ja: IC7-G
Zo nee: IC7
op de standaard ic7 zit ook een lan port hoor.
Verwijderd schreef op 29 juli 2003 @ 21:28:
Dat meen je niet?! hoe kan ik het nou zien?
Is het niet vreemd dat er niet gewoon een G op het bord zelf staat?
Verwijderd schreef op 29 July 2003 @ 21:28:
  • Intronic
ja, maar zit een sticker op.. en die lan werkt niet.
Kan je voor de rest geen verschil zien aan die bordjes?qua componenten?
  • Rick2001
  • Laatst online: 08-04 21:23
Rick2001
9950X delidded en direct die
Je ziet het direct aan de netwerkcontroller chip.
Bij het IC7 zit er gewoon niets bovenaan waar de netwerkchip behoort te zitten.
Zit hier wel een chip, dan heb je het IC7-G board.
Het IC7 heeft dus GEEN netwerk. Dat er een aansluiting achterop zit die afgeplakt is wil niet zeggen dat er ook daadwerkelijk een netwerkcontroller aanwezig is.
MESHIFY 2XL - MSI X670E CARBON - 9950X - 32GB DDR5 LEXAR 6400 - RX 9070 - GIGABYTE M32UC 4K 160HZ - ALPHACOOL UT60 420 & 360 & 1080 - LAING DDC1+ - TECHN CPU - CORSAIR AX850 - 3x9100PRO 4TB - 2x850PRO 2TB - U.2 7.68TB + OPTANE P5800X + KINGSTON G5 8TB
Waar kan ik deze chip vinden en wat moet er op staan?
  • Rick2001
Rick2001
Die chip zit hier.
Afbeeldingslocatie: http://members.home.nl/rick2003/IC7-G.JPG
Jaaaa die zit er op 8)7 , kan ik eindelijk beginnen met bouwen.
Thanks!!!!!!!
Maar dit is ook een ic7 bord, komt dit dus vaker voor?
Rick, jij hebt die swifttech zie ik? Doet die het een beetje goed, of kan je beter naar een SLK900U kijken oid?
  • Rick2001
Rick2001
Verwijderd schreef op 29 July 2003 @ 22:45:
LOL.... Die foto heb ik gewoon ergens 'gevonden'.
Ik heb een SWIFTECH gehad heel lang geleden. Ben alweer meer dan een jaar aan het water. De SWIFTECH is zeker altijd een zeer goede heatsink geweest, denk alleen dat hij weer een beetje achterhaald is nu dat er zoveel concurrenten zijn die goedkoper/beter presteren/zijn.
Ok :) Ik zag in je sig al watercooling staan, maar ik dacht dat je die misschien getest had oid. Ik had niet naar de bron van het plaatje gekeken 8)7
  • ken
Hoe kan je eigenlijk 2 prime95 draaien??
Met maar 1 Prime95 krijg ik een CPU load van 60-80%
  • Rick2001
Rick2001
ken schreef op 29 July 2003 @ 23:58:
Maak een extra snelkoppeling naar PRIME95 en zet hetvolgende erin.
"C:\Program Files\Prime95\Prime95.exe" -A1
  • Pheno79
* Pheno79 ziet trouwens op het chippie tussen de IDE poorten en de PCI sloten IC7-G staan (met grote letters)...of is dat bij de IC7 ook zo :)
  • Dark
  • Registratie: September 1999
  • Laatst online: 16:41
Dark
who tweaked the light?
ThunderBert:
Ik heb zowel een swifttech(4000) als een een thermalright(slk900) gehad, die laatste heb ik er nu nog op zitten, en vindt ik persoonlijk prettiger dan die swifts... swifts zijn lastiger schoon te maken, blijft veel stof in zitten, en hebben naar mijn idee een hogere luchtdruk nodig om goed te kunnen werken...
de slk900 kan het af met een 92mm fan @ 1000-2000rpm(met speedfan gevarieerd), bij de swift heb je toch wel minstens 2000rpm nodig om er nog de nodig lucht doorheen te persen en liever nog een delta hp fan op nog meer rpm...
het zijn alle 2 bijzonder goeie heatsinks hoor, maar mijn voorkeur gaat toch uit naar de slk900, die vind ik erg prettig werken...
Op mijn ic7-g brand een groen(links) en een rood ledje(rechts)
Zit er iets niet goed?
  • ken
Met 2x Prime95 is 3.64Ghz niet 100% stabiel. Krijg error na een paar uur. Ook CPU test Sandra en CPU test PCmark kapt ermee na een paar uur. Op 3.6Ghz is alles wel 100% stabiel: 2x Prime95, Sisoft CPU test (Loop), PCMark2002 CPU test (loop) en 3DMark03 (loop)
Ik hou het dan "maar" op 3.6Ghz :)
[ Voor 6% gewijzigd door ken op 30-07-2003 15:09 ]
  • ken
Verwijderd schreef op 30 juli 2003 @ 15:02:
Lees je manual een goed door :)
Groen is als er power op je moederbord zit en rood is als je PC aanstaat
[ Voor 5% gewijzigd door ken op 30-07-2003 15:06 ]
ken schreef op 30 July 2003 @ 15:04:
Met 2x Prime95 is 3.64Ghz niet 100% stabiel. Krijg error na een paar uur. Ook Sandra en PCmark kapt ermee na een paar uur. Op 3.6Ghz is alles wel 100% stabiel: 2x Prime95, Sisoft CPU test (Loop), PCMark2002 CPU test (loop) en 3DMark03 (loop)
dan houd ik me pc maar op 4ghz >:)
  • ken
Verwijderd schreef op 30 July 2003 @ 15:08:
en, Is je Vapo al hervuld?? 4Ghz is 8) Met water is dit helaas niet te halen. Of ik moet er een dikke Peltier onderhangen, maar dat gaat me wat te ver ;) Ben benieuwd wat je max kan halen met je Vapo :)
[ Voor 24% gewijzigd door ken op 30-07-2003 15:15 ]
ken schreef op 30 July 2003 @ 15:05:
had ik gedaan maar niet zien staan 8)7
[ Voor 10% gewijzigd door Verwijderd op 30-07-2003 15:39 ]
Ik ga nu ook eindelijk een Prometeia Mach II aanschaffen, heeft iemand al de combinatie die ik in mijn sig heb staan en wat zijn de ervaringen qua installatie en gebruik?
ken schreef op 30 July 2003 @ 15:10:
nog niet, maar 4ghz haal ik wel. eerst wachten op me derde coolermaster kast om te beginnen met me modje >:)
  • NaZGuLL
NaZGuLL
Capo di Tutti Capi
Nieuwe bios IC7-series 1.6
Server is op het ogenblik down.
ftp://ftp.abit.com.tw/pub/download/fae/ic716.exe
of via directe link zoals ook gebruikt door flashmenu
ftp://ftp.abit.com.tw/pub/download/flashmenu/ic7_16.bin
BIOS ID:16
1. Updated CPU micro code (0F12H/2EH, 0F13H/05H)
2. Fixed the problem that no effect during POST if change "Delay IDE Initial" in BIOS setup.
3. Added function to automatically detect the IRQ availability and dynamically update assignation table in PnP/PCI configurations setup page.
4. Revised the wording of IEEE1394 controller in PCI device listing.
5. Fixed the problem that DOS4GW.EXE causes system hang-up in DOS environment.
6. Added function that automatically detects CPU operation speed after discharging CMOS data.
7. Added SATA RAID 1 function for Intel ICH5R south bridge.
8. BIOS Compile date: 7/11/2003.
Kijk van dit soort dingen word ik toch wel een
beetje moedeloos. Je kunt geen link aanklikken
bij Abit of er wordt een verbinding opgezet met
een site in Taiwan. Er werd nog door iemand
gesuggereerd om het met de nieuwe tool van
Abit te proberen, flashmenu. Deze tool heb ik
niet en je begrijpt wel waar je die kunt downloaden.
Abit Nederland als je dit leest als de drommel een
mirror-site starten zodat we niet alles van de andere
kant van de wereld moeten zien te downloaden.
Uiteindelijk binnen via directe link (2de).
[ Voor 34% gewijzigd door NaZGuLL op 30-07-2003 16:49 ]
I've seen things you people wouldn't believe, a P4 on fire at Mach2. I watched DDR-memory glitter in the dark. All those moments will be lost in time, like money down the drain. Time to spend.
  • ken
NaZGuLL schreef op 30 July 2003 @ 16:00:
Kijken of deze nieuwe bios wat is :)
Verwijderd schreef op 30 juli 2003 @ 15:53:
3de kast?? Ben benieuwd war je er allemaal mee gaat doen ;)
Is deze kast niks voor jou?
Afbeeldingslocatie: http://www.coolermaster.nl/Products/casepics/310-sx1small.jpg
[ Voor 3% gewijzigd door ken op 30-07-2003 16:14 ]
ken schreef op 30 July 2003 @ 16:12:
nee ik bedoel 3 kasten totaal, heb nu 2 cm kasten staan, der komt nog een derde bij.
Dark schreef op 30 juli 2003 @ 11:10:
ThunderBert:
Ok thx, maar qua temperatuur maakt het elkaar niet zo veel uit? toerental fan kom ik toch over die 2000 rpm heen, op mijn Aplha 8045 had ik een Delta MP zitten.
Verwijderd schreef op 30 juli 2003 @ 15:51:
Ik denk dat er maar weinig mensen met die combinatie zijn. Ik heb laatst wat gelezen over die Mach II ziet er echt mooi uit. vind je dat het geld wel waard?
  • NaZGuLL
NaZGuLL
Capo di Tutti Capi
Verwijderd schreef op 30 July 2003 @ 17:46:
Ik wil jullie niet meteen je plezier ontnemen, maar mijn
P4 2.4 / IC7-G combinatie komt net zover met een
Zalman 7000CU als met de Prometeia MachII.
Voor beiden ligt de uiterste stabiele overklok op 3,24Ghz(5:4).
Geheugen werkt dan op 216Mhz, dit terwijl het geheugen 1:1
stabiel werkt op 245Mhz. Tel uit je winst.
Het is alleen interessant als je geld als water hebt en indien
een moederbord, cpu of geheugen niet echt goed wil overklokken
je daar een ander "gelukkig" mee kunt maken en zelf weer op
zoek gaat naar iets beters.
Alleen die mensen met een zeer gelukkige hand of zij die de
mogelijkheid hebben hun hardware te selecteren alvorens
deze aan te schaffen zullen hier goede resultaten mee boeken.
Voor wat het waard is, doe je voordeel ermee.
[ Voor 13% gewijzigd door NaZGuLL op 30-07-2003 19:11 ]
NaZGuLL schreef op 30 July 2003 @ 18:57:
of mensen die die hard ocen.
  • NaZGuLL
NaZGuLL
Capo di Tutti Capi
ModKid
Jij hoort waarschijnlijk tot dat zeldzame soort
dat zelfs de interne cache van zijn CPU heeft
getweaked met een soldeerbout, "Dream on".
Misschien dat je geldelijke belangen hebt bij
dit soort zaken, in dat geval zal de objectiviteit
ook wel ver te zoeken zijn.
Over en uit.
NaZGuLL schreef op 30 July 2003 @ 19:50:
ModKid
Over en uit.
hoe kan jij nou beoordelen hoe ik me pc gebruik? ik ben een die hard ocer, en die hard modder.
Jongens de nieuwe Bios is er IC7-G 1.6
op abit site te downen
  • NaZGuLL
NaZGuLL
Capo di Tutti Capi
Goed lezen en je ziet de woorden misschien
en een "waarschijnlijk". Beoordelen doe ik
niet. Maar ik ga zeker niet een ander de zekerheid
van een mooie overklok voorhouden terwijl
dit van zeer veel zaken afhangt welke we
niet allemaal in de hand hebben.
We kunnen allemaal op de review sites lezen
hoe een reviewer een "random" CPU en een
"random" IC7 moederbord gaat testen en
vervolgens op miraculeuze wijze een fsb
van tegen de 300Mhz(1200) gaat halen.
Dit zijn echter uitzonderingen, en dan niet
eens toevallig tot stand gekomen.
Mijn overklok is een zeer fatsoenlijke
doch minder dan waarop ik had gehoopt.
Het toont ook aan dat het verschil in over-
klokken tussen een luchtkoeler en phase
chiller ook in grote mate wordt bepaald
door hardware die je hebt.
Overigens wie zegt dat ik geen "die-hard"
overklokker ben ;)
[ Voor 8% gewijzigd door NaZGuLL op 31-07-2003 15:30 ]
  • NaZGuLL
NaZGuLL
Capo di Tutti Capi
Verwijderd schreef op 30 July 2003 @ 20:54:
Sorry voor de kleine schermutseling
hierboven. Ja nieuwe bios staat op
mijn PC, geen verdere bijzonderheden.
[ Voor 192% gewijzigd door NaZGuLL op 30-07-2003 21:04 ]
  • Halo_Master
  • Laatst online: 01-04 15:41
Halo_Master
kan het cooler , pleaze?
als iemand geld heeft voor een machII, gun ik hem dat van harte.Voor een echte overclocker is het een goede investering.
Intel PIV 3.0@3600Mhz,2xiwaki md-15R en 1xswiftech mcp600, 4x xlr120 rad in externe boxes,dfi lanparty pro 875B,geil 512 mb pc4200, Ati Radeon 9800 pro,Audigy2,Silicon Graphics F180 (18,1 inch TFT)
NaZGuLL schreef op 30 July 2003 @ 20:55:
niet. Maar ik ga zeker een ander geen zekerheid
niet allemaal in de greep hebben.
overklokker ben ;)
Zeer goed !!! dat heb je mooi uiteen gezet.
Een goede uitleg.
Vaak maken ze ook nog een gebruik van een ge'unlockte cpu [intel]
waar wij als tweakers alleen maar van kunnen droomen.
zoiets van [oops hebben wij dat nog niet verteldt?]
En vaak wordt er dan gebruik gemaakt van vapo's en andere ZEER dure apparaten [lees 1200 euro] voor 2 of 300 mhz meer.
Maar als je daar gebruik van wilt maken ,ga gerust je gang [tis kick] en een mooie moment opname.
Het gaat mij ook meer om de lol van het overklokken. Ik weet wel dat er geen grenzen gaan gebroken worden met mijn OC. Ben ook maar een beginner voor mij gaat het om de lol van het bereiken van mijn top OC. En een Prom is daar een kek ding voor.
Dus, ik sta open voor alle adviezen. Trouwens moet eerst nog aan een Mach II zien te geraken want ze schijnen nogal schaars te zijn.
  • NaZGuLL
NaZGuLL
Capo di Tutti Capi
Dat is de juiste instelling. Voor specifieke
zaken omtrent de Prometeia Mach II raad
ik je aan de daarvoor specifieke threads
te lezen hierop GoT, we raken namelijk
behoorlijk offtopic.
Ik het Prometeia topic doorgelezen maar de combinatie IC7 en Prom komt niet zo vaak voor en ik hoopte misschien op wat insider info. Zodat ik niet zelf met mijn kop tegen het blok kom te slaan.
Maar even om weer Ontopic te komen. Ik heb vandaag de vervangende NB fan an Abit gekregen. Eergisteren gemaild, gisteren bevestiging en vandaag al in de bus. Prima ondersteuning.
@NaZGull : Heb jij toevallig de BIOS update via het Windows programma van Abit of gewoon via DOS/Flop ?
  • NaZGuLL
NaZGuLL
Capo di Tutti Capi
Verwijderd schreef op 30 juli 2003 @ 22:16:
Ik doe die updates altijd via een DOS bootflop.
  • MrDirect
Misschien is m'n IC7 toch niet kapot....
Ik heb m'n oude Epox 4PEA+ van stal gehaald en die heeft nu opeens EXACT dezelfde verschijnselen (vastlopers en niet eens kunnen booten 9 van de 10 keer).
Alleen het geheugen , de videokaart en de harde schijven zijn hetzelfde gebleven, dus ik ga nu eens kijken of ik die kan testen. Wat ik dus veranderd had zijn het moederbord en de CPU.....
Als m'n Corsair's maar niet overleden zijn.... :'(
Heeft iemand de RAID 1 functionaliteit al getest op de werking?
En zijn de officiele specs van die IC7-G MAX3 al bekend? Zoals vdimm enzo... reviews?
Ik heb bios 15 erop gezet, maar bij bios 12 kon ik de raid uitzetten, maar nu krijg ik tijdens het opstarten "press f4 to enter raid utility"en kan hij niets vinden ik gebruik dit nog niet.
Is dit nog uit te schakelen met bios 15.
  • ken
Verwijderd schreef op 30 July 2003 @ 22:46:
Is in de bios uit te zetten. Moet je kijken onder Intergrate peripherats, dan ergens bij SATA op disable
Net bios 16 erop gezet. Niet veel veranderingen. Alleen start mijn PC sneller op doordat de IDE devices sneller worden herkent :)
mmm, met bios 16 lukt het weer wel.
  • Dark
Dark
Mijn maxtor schijven gebruikt als raid0 via de intel raid worden niet meer herkend na bios update 1.6... de computer hangt op de detectie...
Als ik de schijven als 'normale' hdd aanspreek werkt het wel prima, maar zodra ik de ich5 raid bios activeer komt ie niet door die bios bij het opstarten... ik krijg ook niet de kans om ctrl-I te drukken, daarvoor zit ie al vast :S, ik kan dus geen nieuwe array maken ook.
damn... ik ben terug naar 1.5 ... :(
  • Pheno79
Hmm, ik wacht dus nog maar even. Ik draai ook raid0 en dit soort grappen zijn niet leuk...
  • Av3ng3rtje
  • Laatst online: 13-04 08:48
Hmm , ik wil de IC7 gaan kopen maar zoek nog goed geheugen wat in Nederland verkrijgbaar is en wat niet al te duur is (circa 200 euro , 2x256).. Heeft iemand enig idee welk merk ik het beste kan nemen (ik wil wel een mooie overclock halen natuurlijk)
Plz HELP! :9
Av3ng3rtje schreef op 31 July 2003 @ 14:43:
Plz HELP! :9
Voor 200 euro kan je aardig geheugen uitzoeken, Kingston Hyper X PC 3500, Corsair TwinX modules. Ik zou voor het Kingston geheugen gaan.
Maar in de V&A staan ook twee reepjes 256Mb OCZ geheugen voor 140 euro. En OCZ gaat wel erg had. Wel even vragen of het Gold is want dan gaat het helemaal lekker en hebben dan ook nog eens Voltage Protection
  • Av3ng3rtje
Verwijderd schreef op 31 juli 2003 @ 15:12:
Hmm Kingston PC4000 reepjes heb je ook voor 200 euro ongeveer, maar het probleem daar mee is dat ze brakke geheugen timings hebben. OCZ heeft daar in tegen ook PC4000 met strakke geheugen timings , maar ze zijn niet in Nederland verkrijgbaar of ze zijn gewoon niet te betallen (nieuw).
Ik heb wel een zaak gevonden waar ze OCZ goedkoop aanbieden , maar het enige probleem is dat ze in het buitenland zitten. 1. Ik heb geen creditcard 2. Ik heb geen cheques 3. Overschrijven kan lang duren geloof ik.. het gaat om:
http://www.pc-memory-upgrade.co.uk/
[ Voor 17% gewijzigd door Av3ng3rtje op 31-07-2003 15:27 ]
leuk hoor die diskette met SATA (raid) drivers was gaar bij mij en ik maar vanalles proberen omdat windows me SATA niet vond en ook niks op diskette, nu vanaf de CDrom mijn bestanden gehaald en die diskette geformateerd (moest ook want hij was onleesbaar) toen die bestanden erop gezet, win xp setup, en ja hoor deed het :D
leuk hoor net ineens orangje beeld toch ik in win xp koos voor de klassieke stijl, nu net weer aan, alles prima, krijg ik ineens een melding dat ...dll is beschadigt en ik hem moet vervangen, weet niet wat het is maar ziet er niet echt leuk uit, kost veel moeite zo :(
  • Gipsy King
  • Laatst online: 07-04 11:35
loop je weer te prullen jan!! :9
  • Ibidem
  • Laatst online: 24-02 19:28
sinds vandaag ook de trotse eigenaar van een Abit IC7 + 2,8C GHz. (3315A169) Miss. straks ff kieken wat ie doet, anders van t weekend. Want ja ik werk nu eenmaal erg veel :(
..::System Specs::..
  • ken
Tekn0z schreef op 31 July 2003 @ 22:03:
Ben benieuwd wat die gaat doen :)
Na mijn Vmem mod, is mijn Vmem niet echt stabiel meer. Varieerd tussen de 2.88-3.01V Lijkt me niet echt gezond??
Gipsy King schreef op 31 July 2003 @ 21:24:
nee nu boot i nieteens meer vanaf Sata raid0 en alles staat good, ook bij bootable staat er nog yes maar no fucking way, dan maar ff 1,6 downloaden en bidden.
btw heb jij dat ook dan zet je je pc uit en hoor je eerst TAK van je rapors komen en binnen een sec. daarna gaat je pc uit?
  • Intronic
Verwijderd schreef op 31 July 2003 @ 22:11:
Hij heeft geen raptors :P.
Maar ik heb iig niet, gaat gwoon uit zonder tikjes :P.
  • ken
Heb je in je bios. Bij Advance bios features--> HD boot priority-->bootable add in device gekozen?? Zo niet dan moet je dat maar gaan doen. Dan boot die zonder problemen. Ik heb ook 2 Raptors (Raid0). Bios 15 en 16 werkt er goed mee :)
Die Raptors hebben wel een harder tik geluid als deze aan of uit gaan. Lijkt me vrij normaal??
[ Voor 8% gewijzigd door ken op 31-07-2003 22:30 ]
haha zo nu weer up and running (mja was ik al eerder en ineens..... :( ) maarja ik zie wel had nog ff 1 vraag, wat is nou precies het verschil tussen de onboard SATA en de onCHIP SATA ? de een voor de IDE en de ander voor de SATA neem ik aan, alleen welke verzorgt welke?? volgens mij (gezien de boot info) vertaal ik de intel naar de SATA (die geeft de situatei van mijn RAPTORS namelijk aan) en de silicon vind niks (zit momenteel ook ff geen ide schijf aan klopt dit? (intel(de onboard) dus SATA en silicon (de onchip) dus IDE?
[ Voor 33% gewijzigd door Verwijderd op 31-07-2003 23:04 ]
  • Dark
Dark
intel is de onchip sata, en onboard is de silicon...
de intel zit op de ich5 system bus aangesloten en laat de pci bus dus vrij voor andere dingen gedurende harddisk toegang, of omgekeerd je transfers worden niet gestoord door andere dingen waardor het theoretisch sneller zou moeten gaan.
de silicon zit op de pci bus aangesloten, en heeft dat 'voordeel' dus niet...
[ Voor 21% gewijzigd door Dark op 31-07-2003 23:31 ]
volgens boot... is het de intel die ik momenteel gebruik dus dan zit het goed, alles draaid nu naar behoren :D en die raptors bevallen me wel, net sandra binnen, ff benche })
  • MrDirect
Wie heeft er nu al zekere informatie over de vdimm van de nieuwe IC7-G MAX3 ?
Ik moet een nieuwe kopen, omdat m'n oude het niet meer doet, maar ik wil weten hoe het met die vdimm zit, Wie heeft er al een review van gezien?
Niemand nog !
Maar yorcom kon mij verzekeren dat er vanaf volgende week 1 voor mij klaar ligt.
Tis wel vreemd dat er nog geen 1 site hem heeft.
Maarja we wachten af
Verwijderd schreef op 01 augustus 2003 @ 15:53:
Niemand nog !
Abit Nederland heeft nog maar 1 sample ontvangen, dus andere bedrijven kunnen nu nog geen mobo's leveren, want ze hebben die niet.
[ Voor 12% gewijzigd door Verwijderd op 01-08-2003 16:03 ]
  • NaZGuLL
NaZGuLL
Capo di Tutti Capi
Verwijderd schreef op 01 August 2003 @ 15:53:
Niemand nog !
Let even op dat je geen sample revisie in je handen
gedrukt krijgt, rev. 0.xx
[ Voor 3% gewijzigd door NaZGuLL op 01-08-2003 18:58 ]
Ik weet zeker dat niemand op dit moment al kan leveren want wij zelf hebben net 1 pre-production sample hier liggen.Deze is vandaag in Duitsland ,Maandag weer in Nederland en Vrijdag in Spanje.Zelf verwacht ik de eerste massaproductieborden in week 33 of 34 als we pech hebben.
  • STIMPPYYY
Heel even een vraagje.
Ik heb hier dus ook een IC7 lekker snel boardje. Maar als ik mijn koptelefoon in mijn geluidskaart prik dan krijg ik echt brak geluid uit mijn headset. Als ik dan mijn Logitech z560 erop aansluiten geeft hij gewoon perfect geluid. Maar als ik dan mijn headset in de POD van mijn z560 doe, dan is het geluid wel goed. Ligt dit nou aan mijn geluidskaart of aan het moederbord (mic probleem) ?
aaahh crap ,hebben ze zitten jokken bij yorcom.
Afwachten dan maar
  • Sartsj
  • Laatst online: 26-03 23:40
Ik heb ook sinds 2 dagen mijn IC7 + P4 2.6 + 1GB PC3200..
wat problemen op et begin, maar dat was omdat ik vergeten was de bios te flashen aangezien hij nog met de standaard 10 bios zat. Toch maar ff geflasht dus :)
Overigens, ik vraag me af.. Ik heb dus alvast geprobeer de FSB wat hoger te zetten, maar hij kan maar een paar Mhz-jes hoger, aangezien anders de onchip intel s-ata controller mijn Maxtor schijf niet meer herkent...
Is dit op te lossen?
Ook twijfel ik nog wat ik met het geheugen zal doen, want in eerste instantie had ik Kingston PC3200 besteld bij Alternate (de cas3 variant dus), toen wilde ik dit eigenlijk veranderen naar de hyperx cas2 variant, maar toen hadden ze het pakket al verstuurd met cas2.5 noname geheugen (weliswaar voor 8 euro minder).
Zou ik dit nog terug kunnen sturen met de reden dat ik zeker Kingston geheugen wil en dan dus voor de HyperX reepjes gaan?
  • Dark
Dark
als je wat meer wilt oc-en en gebruik wilt blijven maken van de intel ich5 sata, dan moet je de pci/agp locken op 66mhz zo blijft ie de schijven wel goed herkennen...
  • Halo_Master
Halo_Master
weet niemand waar ik zo een NB-cooler voor de abit ic7-g kan krijgen (de oude versie)
Ik wil er best wel wat voor betalen.Maar zelfs bij abit reageren ze niet.
ik heb nu bios 1,6 enz. alle nieuwste drivers, heb mijn onboard sound uitstaan en mijn audigy2 erin, alleen als ik scrool in Iexplorer dan komt er een piep door mijn muziek enz. heen, iemand een idee wat het kan zijn?
EDIT: ik heb het ook als ik de scroll balk gebruik i.p.v. de scoll knop, enkel waneer er niks te scrollen valt en ik scroll met mijn muisknop dan gebeurt er niks, is het nu softwarematig of hardware matig ik denk aan software (gelukkig) ga zo ook opzoek naar een andere versie van mijn audigy driver.
[ Voor 52% gewijzigd door Verwijderd op 01-08-2003 21:16 ]
  • roodhoedje
  • Laatst online: 19:04
Verwijderd schreef op 01 augustus 2003 @ 20:57:
Smooth scrolling misschien kan je uitzetten in internet options laatste tabblad. Dat smooth scrolling zuipt veel cpu dus misschien dat het met elkaar te maken heeft je kan het allicht proberen
  • Sartsj
Dark schreef op 01 August 2003 @ 20:47:
mja, et punt is dus dat ik em ook geprobeerd heb 20mhz hoger te zetten, dan was de pci/agp snelheid iets van 61/31 ofsow, dat zou toch gewoon goed moeten zijn dan, maar dan herkende hij de schijf ook niet meer...
bovendien heb ik iets gelezen dat die onchip intel sata controller direct aan de systeembus hangt, dus heeft die pci divider dan wel effect daarop?
ow ik zie al een aantal repies nouwja dan hier maar ff een update, ik heb het met alles waar een scroll mogelijk bij te gebruiken is, zowel met de balk als met de knop, het is dus echt vaag, draai ik met de scrollknop waar niks te scrollen valt, no prob, het is denk een software matig probleem dus ik ben nu hard opzoek naar een andere versie van mijn audigy2 driver.
EDIT: ok als ik in msn scroll nergens last van, eigenlijk dus alleen nog gehad met Iexplorer en in windows verkenner, windows prob dus denk.
[ Voor 17% gewijzigd door Verwijderd op 01-08-2003 21:20 ]
  • Sartsj
Overigens heb ik nog een vraag... heeft het nut om Hyper Threading te enablen? Ik draai zelf Windows 2000 SP4.. En als het voor W2k geen nut heeft, is het dan de moeite waard om er WXP voor te installeren?
  • Dark
Dark
ThaSarge schreef op 01 augustus 2003 @ 21:13:
probeer maar, locken is echt DE oplossing hoor...
