HOMEMADE ILLUMINATED MOUSEPAD
  • 162 views sinds 30-01-2008
this is a mod i just finnest .
hope u all like it
Hi all ,just finest my new mousepad.
Here are the pics with the explenation of how i made it.
(If my english writing is not to good "BUMMER")
First i got a pease of perplex.and draw a mousepad(little bigger) on it.
Afbeeldingslocatie: http://www.angelfire.com/droid/proximus/images/1.JPG
then i cut the perplex out.
Afbeeldingslocatie: http://www.angelfire.com/droid/proximus/images/2.JPG
Afbeeldingslocatie: http://www.angelfire.com/droid/proximus/images/3.JPG
Then i rounded the eathes of .
Afbeeldingslocatie: http://www.angelfire.com/droid/proximus/images/4.JPG
Then i smooded the sides of with a wetstone(for knifes).
Afbeeldingslocatie: http://www.angelfire.com/droid/proximus/images/5.JPG
I both 18 led's (red) and some wire and shrinkthingy for over the wire.
Afbeeldingslocatie: http://www.angelfire.com/droid/proximus/images/6.JPG
The led's are 5 milimeter big ,but the perplex is just 3 mm.So with a dremel i cut of the sides so they got 3 mm big.
Afbeeldingslocatie: http://www.angelfire.com/droid/proximus/images/7.JPG
After doing al of them i cut out the middle of the perplex and made a place for the leds on the side's of the perplex.
Afbeeldingslocatie: http://www.angelfire.com/droid/proximus/images/9.JPG
Then with a wheldergun i made 3 strings of 6 leds(1led=2 volts. going on a 12 volt powerswitch on my rig)
Afbeeldingslocatie: http://www.angelfire.com/droid/proximus/images/10.JPG
Afbeeldingslocatie: http://www.angelfire.com/droid/proximus/images/11.JPG
Afbeeldingslocatie: http://www.angelfire.com/droid/proximus/images/12.JPG
After testing i connected all the 3 strings.
Afbeeldingslocatie: http://www.angelfire.com/droid/proximus/images/13.JPG
Afbeeldingslocatie: http://www.angelfire.com/droid/proximus/images/14.JPG
Remember the first wire to the leds goes on the + side of the led.then connect a wire from the - side to the + on the next led.
Do that 5 times and make the last wire from the last led a black one(minus).see pictures.
Then i tested it and shouted a big YAY.
Afbeeldingslocatie: http://www.angelfire.com/droid/proximus/images/15.JPG
Then i fixed the leds in the perplex using normal seetruetape.
tested it again in the light and the dark(looked great)
Afbeeldingslocatie: http://www.angelfire.com/droid/proximus/images/16.JPG
Afbeeldingslocatie: http://www.angelfire.com/droid/proximus/images/17.JPG
Then i connected a long wire(1.5 meters) to the + and - wire .
Afbeeldingslocatie: http://www.angelfire.com/droid/proximus/images/18.JPG
Then i made of mall of the pad and used that to cut out the bottom for the pad using foam (like the bottom of a normal mousepad)
Afbeeldingslocatie: http://www.angelfire.com/droid/proximus/images/19.JPG
Afbeeldingslocatie: http://www.angelfire.com/droid/proximus/images/20.JPG
Using 2 sides sticky film"transparrent" i pasted the foam on the bottom.
Afbeeldingslocatie: http://www.angelfire.com/droid/proximus/images/21.JPG
Then i shoved the shrinkstingy over the wire and used a lighter to shrink it on the wire
Afbeeldingslocatie: http://www.angelfire.com/droid/proximus/images/22.JPG
Afbeeldingslocatie: http://www.angelfire.com/droid/proximus/images/23.JPG
After that i welded a jackplug on the end of the wire.
Afbeeldingslocatie: http://www.angelfire.com/droid/proximus/images/24.JPG
Afbeeldingslocatie: http://www.angelfire.com/droid/proximus/images/25.JPG
And welded the other pease of the jackplug on a wire,to go in my rig later.
Afbeeldingslocatie: http://www.angelfire.com/droid/proximus/images/26.JPG
Then i connected the jackplug and tested the circuit again.
Afbeeldingslocatie: http://www.angelfire.com/droid/proximus/images/27.JPG
I cut a mall of the pad out of the 2 sided sticky film and pasted it on the pad
Afbeeldingslocatie: http://www.angelfire.com/droid/proximus/images/28.JPG
Afbeeldingslocatie: http://www.angelfire.com/droid/proximus/images/29.JPG
Afbeeldingslocatie: http://www.angelfire.com/droid/proximus/images/30.JPG
Afbeeldingslocatie: http://www.angelfire.com/droid/proximus/images/31.JPG
Then i cleaned the glass mousepad i had have made by a glasscutter.
and pasted it on the pad.
Afbeeldingslocatie: http://www.angelfire.com/droid/proximus/images/33.JPG
Afbeeldingslocatie: http://www.angelfire.com/droid/proximus/images/34.JPG
I both some self sticking 3d film( there are tiny bumps on it for the mouse(optic) to read )and pasted it on the glass.
Afbeeldingslocatie: http://www.angelfire.com/droid/proximus/images/35.JPG
Afbeeldingslocatie: http://www.angelfire.com/droid/proximus/images/36.JPG
Then i build the jackplug connection in my rig.
Afbeeldingslocatie: http://www.angelfire.com/droid/proximus/images/37.JPG
Afbeeldingslocatie: http://www.angelfire.com/droid/proximus/images/38.JPG
Afbeeldingslocatie: http://www.angelfire.com/droid/proximus/images/39.JPG
And connected it to a 12 volt switch on my rig.
Afbeeldingslocatie: http://www.angelfire.com/droid/proximus/images/40.JPG
Ten i connected everything and this was the result.
Looks pretty good e?
Afbeeldingslocatie: http://www.angelfire.com/droid/proximus/images/41.JPG
Afbeeldingslocatie: http://www.angelfire.com/droid/proximus/images/42.JPG
It's a nice and fun thing to build a the cost's are not mutch.
the matterials costed about 18 euro's thats about 17 dollars.
and the glass (made by a firm) costed me 5 euro's about the same in dollars.
so for not to mucth money u have a pretty fine mod.
enjoy and seeyaaaaaaa!!
Powered bij Asci Technologies
  • DUX
  • Laatst online: 08:42
DUX
blijft ook nu voor Oranje
Brutal! It's things like this that makes me regret not having enough experience in playing around with electronics :)
[offtopic]What country are you from or a just pretending to be a foreigner?[/offtopic]
Bruut! Dit zijn stoere dingen en ik wil ze ook kunnen maken...Ik...kan...het alleen (nog) niet... :)
Blijkbaar kun je dus gewoon wel Nederlands (hier kon je het ook), waarom post je dan in het Engels (zeer slecht Engels zelfs) :?
[ Voor 88% gewijzigd door DUX op 12-07-2003 01:48 ]
.    < G o o o o o o o o g l e >
Vorige 1 2 3 4 5 6 7 8 Volgende
That's some impressive mousepad-tutorial :)
Maybe I need to make some of these myself, coz it isn't really that hard, but really looks nice...
Btw, plz don't start any topics anymore with those darn caps-lock-topic-names...Just make a topic name like: [CM] Homemade illuminated mousepad ... :)
DUX schreef op 12 July 2003 @ 01:41:
Blijkbaar kun je dus gewoon wel Nederlands, waarom post je dan in het Engels :?
Waar zie jij aan dat hij wel NL kan praten :?
[edit]
Maar idd volges mij is hij ook een NL of een Belg, aangezien die kast van Recom is en die fangrills ook...
[ Voor 10% gewijzigd door Verwijderd op 12-07-2003 01:48 ]
Nice pad, how much time did it take you to build?
  • DUX
DUX
Verwijderd schreef op 12 July 2003 @ 01:47:
Omdat hij het hier ook kan.
Hi, this is a Dutch forum, maybe a picture says more than a 1000 words, but if you could please post/translate this kind of stuff in Dutch and it could be considered to stay open, but for now I close this topic.
Hoi, dit is een Nederlandstalig Forum, misschien zegt een plaatje meer dan 1000 woorden, maar als je dit soort dingen in het Nederlands zou posten/vertalen zou ik het nog kunnen overwegen om open te laten, maar voor nu sluit ik dit topic.
Lees dit eerst voordat je een topic opent!
http://gathering.tweakers.net/forum/faq
En nu is hij wel Nederlandstalig :)
[rml][ CM]verlichte muismad[/rml]
[ Voor 8% gewijzigd door Verwijderd op 12-07-2003 04:45 ]
