• Mr. B.
Goed... na veel, heel veel, te veel vertraging is hier dan eindelijk StatBar 2.4 *D
Hij heeft een aantal interessante nieuwigheden waar ook hier veel naar gevraagd is, zoals Winamp3 support, RC5-72 support, dual CPU support, process exclusion (nou hebben dus ook de mensen met een koetje iets aan die CPU meter :)), en support voor uptimes hoger dan 49:17:02:47 8) (die laatste 2 zijn NT-only) [Edit: die laatste 3 dus]
De complete lijst met vernieuwingen:
• The update check function would display a message stating "An error has occured while extracting the update files" when updating the program while the .HLP or .CNT file was not present in the StatBar folder. Fixed.
• Starting StatBar while your system uptime had reached 25 days would cause the program to quit with a "Run-time error 6: Overflow" message (keeping the program active while passing that "25 day limit" would cause no problems though). Fixed.
• Resetting the main window via the option in the popup menu would cause all adapters for the network traffic module to be suddenly deselected. Fixed.
• When earlier versions of StatBar were placed at the bottom of your desktop, some of the tooltips would appear at the top of your screen. This seemed to be an issue with VB and/or Windows, but StatBar now uses a custom-written tooltip mechanism for the main window. Ergo: fixed.
• Under WinNT/2000/XP, the disk information panel would not display a drive's volume label, file system type and total capacity if the volume label was longer than 11 characters. This is the maximum volume label length on FAT systems, but NTFS supports labels of up to 32 characters. Fixed.
• TDS3 (Trojan Defense Suite) incorrectly suspected StatBar to be a trojan; this was due to the way the CD door eject/close module in StatBar works. Fixed.
• Under Windows XP, the "jump to file" button in the Winamp controls module often didn't function properly. Should be fixed now.
• On some systems, the master volume control module somehow malfunctioned. Should be fixed now. (I hope...)
• On Windows NT/2000/XP and above, the uptime module is no longer limited to 49.7 days.
• The "skinning" part of the code has been rewritten almost completely. Switching color schemes is a bit slower now, but it uses much less resources under Win95/98/ME.
• Added the E-mail launcher module.
• Added the Winamp 3 controls module and renamed "Winamp controls" to "Winamp 2.x controls".
• Added the Search engine launcher module.
• Added detection of Windows Server 2003 (which is actually NT 5.2, formerly known as Windows.NET Server) and Longhorn (which is actually NT 6.0).
• Adapted the RC5/OGR counter module to the RC5-72 project logfile format.
• Added the ability to pause or stop Winamp playback when when you click the "Lock Workstation" button.
• Added the ability to show the "MB" text in the memory status info module again.
• The tooltip for the "WA2:" text now also displays the song duration, bitrate, samplerate and number of channels.
• The tooltips for the Previous and Next buttons (for both Winamp modules) now display the current song as well.
• The tooltip for the percentage digits in the battery status module now displays the remaining battery lifetime as well, if available.
• Added dual CPU support to the CPU usage module.
• Added the ability to exclude a process from the CPU usage calculations (useful if you are participating in a distributed computing project). Please note that this feature is only available under WinNT/2000/XP and above.
• Added an option to show mapped network drives and removable drives in the disk information panel.
• Added support for terabyte volumes to the disk information module.
• Extended the QuickLaunch module; it's now possible to specify a working directory, parameters, a custom icon, and the startup mode as well.
• The drives on the disk information panel are now clickable; clicking them launches a default Windows Explorer window for that drive.
• Added a tooltip to the activity monitor in the network traffic module, which displays the IP addresses of the adapters being monitored.
• Changed the look of the Locks status module and added support for the Insert key state.
• Replaced the "D:" and "U:" (download/upload) labels for the network traffic meter by arrows.
• StatBar now displays the amount of used RAM instead of the the amount of available RAM by default.
• The default color scheme is now "Silver (WinXP style)" instead of "Gray & Green".
• The "Show digit backgrounds" option is now turned off by default.
• The "Hide panel when mouse leaves it" option is now turned off by default.
• The transparency level is now indicated and editable using a percentage text field as well as via a scrollbar.
• Rearranged the configuration window, making the space meter visible at all times.
• Some huge internal restructurings; the code is much more modular now. Still a lot of work to do though...
• Removed some screenshots from the help file, thus reducing its size.
Voor downloadlocaties: zie www.statbar.nl
Als je StatBar al gebruikt kun je deze versie natuurlijk ook installeren via de update check :)
Voor de volgende versie ga ik om te beginnen verder met het intern herstructureren van de code, waarna ik mogelijk een aantal andere interessante features kan inbouwen waar ik al een tijdje aan denk. Ook heb ik wat ideeën over een skinning engine, maar wat ik daarvan in m'n hoofd heb moet allemaal nog uitgewerkt worden tot iets bruikbaars. Of iets dergelijks al in de volgende versie zal zitten kan ik dus niet beloven.
Maar ik ga eerst eens aan een nieuw design voor de website werken :)
Iig veel plezier met deze nieuwe StatBar!
UPDATE (12.07.2003):
Versie 2.405 is uit, zie hier
[ Voor 7% gewijzigd door Mr. B. op 12-07-2003 11:55 ]
StatBar.nl - @GoT
Het verschil tussen theorie en praktijk is in de praktijk altijd veel groter dan in theorie.
  • Klippy
  • Laatst online: 21:50
Klippy
Still Game
Eindelijk :D
Ik zit nog steeds met de vorige versie ;)
Ik ga meteen proberen, maar moetwel hoop meer gaan instellen nu :P Want ik wil nog steeds vrije RAM ipv gebruikte en digit backgrounds vind ik net mooi :) Dus die moet ik nu gaan aanzetten :P
Steam | SXQncyBhbGwgZ29vZCwgbWFuISDwn5iO
  • Mr. B.
LiquidSilver schreef op 11 juli 2003 @ 02:53:
Eindelijk :D
De settings van de vorige versie neemt ie gewoon over, dus als je 'm al op vrij RAM en met digit backgrounds had staan, dan blijft dat zo :)
De standaardwaardes zijn veranderd, dus als je 'm start op een pc waar ie nog nooit op gedraaid heeft dan pakt ie die waardes.
StatBar.nl - @GoT
Kijk, dat is nu vooruitgang :-)
  • bwt
  • Laatst online: 26-08 14:09
bwt
verplaatst zich op een GSX750F
ik vind het top.
auto update werkt prima. Ik heb em zelfs al in de meuktracker gedropt.
Je nieuwe programma ziet er goed uit, een aantal grafische verbeteringen en zo.
Was echt toeval dat ik zag dat er een update was.
[ Voor 14% gewijzigd door bwt op 11-07-2003 03:00 ]
My 1st proc. was a NEC V20 (4-8 Mhz) - Now I have an AMD 1300 / 2000 with Aero7+ ASRock ION 330
  • Klippy
Klippy
Still Game
Mr. B. schreef op 11 July 2003 @ 02:55:
Idd ik merk 't ja ;)
Dacht dat er cfg file bij zat, maar zit in registry dan blijkbaar ;)
Alleen... zodra in Winamp 3 controls wil toevoegen en op ok of apply klik sluit 'ie zich zonder error meteen af...
Al 3x geprobeerd nu, ga nog ff kijken waar dat aan ligt.
Kwam dus omdat Winamp nog liep 8)7
Werkt nu ;)
Edit2:
Ook als ik positie van WA3 controls verander sluit hij af als winamp nog draait, beetje irritant, is dat niet te fixen? desnoods met error melding dat je eerst winamp moet sluiten? :)
[ Voor 22% gewijzigd door Klippy op 11-07-2003 03:04 ]
  • bobsnl
  • Laatst online: 26-06 09:56
Ziet er goed uit, maar wat bedoel je precies met die RC5-support? Kan je zien hoever een blokje is, of wat de aantal Mkey/s is of ..... ?
[IMG]http://veloviewer.com/SigImage.php?a=1d38a&r=2&c=8&u=M&g=p&f=abcdefghij&z=a.gif[/IMG]
  • Mr. B.
LiquidSilver schreef op 11 July 2003 @ 03:00:
Werkt nu ;)
Wazig... zou niet mogen gebeuren :o
Welke Winamp liep nog? 2 of 3?
bobsnl schreef op 11 July 2003 @ 03:01:
Je kunt zien hoeveel blocks en work/stats units er in je buff-out.r72 staan.
StatBar.nl - @GoT
  • Klippy
Klippy
Still Game
Mr. B. schreef op 11 July 2003 @ 03:04:
Gaat over Winamp3 build #488
als WA3 controls in Statbar staat en ik wil Statbar starten krijg ik als Winamp loopt een "Runtime error '5', invalid function or procedure call"
  • Mr. B.
LiquidSilver schreef op 11 July 2003 @ 03:08:
/me nie snappe...
Wat ik doe:
1. Ik voeg de Winamp3 controls toe aan StatBar
2. Ik sluit StatBar
3. Ik start Winamp3 build 488 (of ik 'm daarna iets laat afspelen of niet maakt zo te zien niet uit)
4. Ik start StatBar
No problemo hiero... :?
StatBar.nl - @GoT
  • Klippy
Klippy
Still Game
Ik heb net ff reboot gedaan voor de zekerheid, Statbar start vanzelf op dus.
Daarna heb ik StatBar gesloten, Winamp3 gestart en StatBar weer gestart, ging goed.
Vervolgens StatBar weer gesloten en in Winamp op play gedrukt. Toen StatBar gestart en kreeg weer de error. Wat ik nu ook doe, error blijft komen, alleen Winamp3 afsluiten en daarna StatBar starten helpt...
Verder werken WA3 controls perfect trouwens...
Maarja aangezien StatBar vanzelf start hier en Winamp dan nooit loopt heb ik er geen last van, eens afwachten of andere mensen er nog last van hebben he :)
Draai trouwens Windows XP...
Eén ding wat ik me al een tijdje afvraag is:
Wat is het verschil nu precies tussen aan de ene kant
StatBar
en aan de andere kant
Winbar
Zou iemand mij dit uit kunnen leggen. Alvast bedankt. Ik gebruik nu namelijk Winbar en ben nieuwsgierig wat nu precies de voordelen van statbar zijn daar tegenover >:)
  • Mr. B.
LiquidSilver schreef op 11 July 2003 @ 03:33:
Ik vind dit echt extreem vaag... :? Wat ik hier ook doe in combinatie met Winamp 3, ik krijg het niet voor elkaar om StatBar te laten crashen...
* Mr. B. haat het als ie bug reports niet kan reproduceren :(
StatBar.nl - @GoT
  • Klippy
Klippy
Still Game
Verwijderd schreef op 11 July 2003 @ 03:36:
StatBar
Winbar
Zijn 2 hele aparte programma's natuurlijk ;)
Ik zou zegen probeer StatBar eens :)
Hou zelf meer van StatBar, vind ik mooer uitzien, overzichtelijker... en werkt prima verder.
WinBar heb ik ook geprobeerd, voor StatBar zelfs, maar dat hield ik geen uur uit.. irriteerde me op een of andere manier die balk :)
  • Mr. B.
StatBar
Winbar
[kort-door-de-bocht-modus] StatBar was er eerder en is dus beter :P [/kort-door-de-bocht-modus] ;)
Maarre, ff serieus:
In 2000 bracht ik de eerste versie van StatBar uit. Johnwoo heeft StatBar toen een tijd gebruikt, maar vond het een uitdaging om zelf ook zoiets te bouwen. Ruim een jaar later was WinBar het resultaat. Beide programma's hebben ongeveer dezelfde opzet; welke je beter vindt of liever gebruikt is een kwestie van smaak. Het moge duidelijk zijn dat ik voor StatBar kies :+
StatBar.nl - @GoT
Ok ik houwinbar gwn. Die gebruik ik al een paar maanden en zoveel verschil zal er niet zijn.
Niet lullig bedoeld ofzo O-)
Iig bedankt voor de info ;)
Ik wil dat statbar nu ook wel eens gebruiken(gebruik al een tijd winbar, tijd voor iets nieuws), maar ik krijg t maar niet aan de praat :( !!!
als ik m opstart gaat mijn computer alleen maar lopen ratelen en gebeurt er helemaal niets!
iemand misschien een oplossing???
Prachtig verbeterd.
Ik krijg alleen met geen mogelijkheid de Bar op de secundaire monitor (Radeon + UltraMon)?
Wel een stuk meer resource honger als WinBar (19MB [nu10MB?] vs 9MB) onder Windows XP SP1, PDH.DLL = 5.1.2600.1106 (xpsp1.020828-1920), geinstalleerd via Setup-installer
quote: regentry
HKCU \ Software \ VB and VBA Program Settings \ Globe Software \ StatBar
"CurBarPosition"="1"
"ColorMode"="3"
"InfoModules"="921FIC37E"
"DispCPUGraph"="1"
"DualCPUmode"="0"
"ExcludeProcess"=""
"DispMemGraph"="1"
"DispMB"="0"
"MemMode"="1"
"CorrectMem"="1"
"UpdateInterval"="245"
"RC5log"=""
"TimeServer"="ntp.xs4all.nl"
"TimeUpdate"="30"
"AutoHide"="0"
"ShowLogo"="0"
"HomepageDoubleClick"="0"
"RequireClick"="0"
"HideDiskPanel"="0"
"ShowNetworkDrives"="0"
"ShowRemovableDrives"="0"
"RememberModules"="1"
"Winamp"=""
"WinampTimeMode"="0"
"Winamp3"=""
"ModuleAlignment"="1"
"ForceAppKill"="0"
"WinampActionOnLock"="0"
"VolumeBeep"="0"
"DigitBackground"="0"
"DispSeparators"="1"
"Transparency"="0"
"DiskTransparency"="0"
"CheckInterfaces"="NNNY"
"SearchEngine"="http://www.google.com/search?q=$s"
"ClearSearch"="1"
"DispLabelUptime"="0"
"DispLabelRAM"="1"
"DispLabelCPU"="1"
"DispLabelBattery"="0"
"DispLabelVolume"="0"
"DispLabelSynch"="0"
"DispLabelWinamp"="0"
"DispLabelWinamp3"="0"
"DispLabelCD"="0"
"DispLabelDUN"="0"
"DispLabelSearch"="0"
Name          Pid Pri Thd  Hnd    Mem    User Time   Kernel Time   Elapsed Time
Idle            0   0   1    0     20  0:00:00.000   3:43:03.593    0:00:00.000
System          4   8  52  247    216  0:00:00.000   0:03:39.093    0:00:00.000
smss          288  11   3   21    344  0:00:00.015   0:00:00.078   11:03:17.750
csrss         404  13  11  287   1364  0:00:24.140   0:00:35.218   11:03:14.109
winlogon      428  13  19  499   2456  0:00:00.671   0:00:02.031   11:03:11.968
services      472   9  15  253   3052  0:00:01.031   0:00:03.671   11:03:10.890
lsass         484   9  14  253   1060  0:00:00.203   0:00:00.312   11:03:10.875
svchost       664   8   9  196   2960  0:00:00.265   0:00:00.156   11:03:09.781
svchost       728   8  63  873  14112  0:00:01.609   0:00:01.765   11:03:09.734
svchost       808   8   8   93   3064  0:00:00.062   0:00:00.000   11:03:09.218
spoolsv       856   8  13  155   3840  0:00:00.093   0:00:00.093   11:03:09.015
Ati2evxx     1508   8   3   45   1976  0:00:00.015   0:00:00.000   11:03:02.656
Explorer     1644   8  14  414  18492  0:00:15.984   0:00:23.937   11:00:43.296
sstray       1804   8   2   48   3520  0:00:00.031   0:00:00.093   11:00:42.796
StatBar       392   8   5  235  10140  0:00:00.312   0:00:00.203    0:02:21.312
cmd           308   8   1   21    612  0:00:00.031   0:00:00.015    0:02:11.156
notepad       612   8   1   33   3800  0:00:00.046   0:00:00.015    0:01:09.890
pslist       1408  13   2   70   1644  0:00:00.015   0:00:00.000    0:00:00.000
[ Voor 94% gewijzigd door Verwijderd op 11-07-2003 14:53 ]
  • Sir_Killalot
  • Laatst online: 26-10 21:20
Verwijderd schreef op 11 July 2003 @ 04:06:
Windows opnieuw installeren ;)
Maar meer info zou wel handig zijn :)
  • Kix@$$
  • Laatst online: 28-10 11:47
Same here... hij blijft als process bestaan maar laat zoch niet zien. CPU @ 93% en mem @ 50 MB :S
Voor de rest is meer info lastig te geven.
Os: Windows XP
  • Tefflar
  • Laatst online: 09-05-2025
Ook hier opstart problemen... Dubbelklikken geeft even een zandlopertje, meer niet. Blijft bij processen gewoon hangen.
OS: Windows 2003 Server
Update: Reg instellingen van 2.301 verwijdert, helpt niet. Compatibiliteitmodus (Win2K) helpt ook niet.
[ Voor 27% gewijzigd door Tefflar op 11-07-2003 08:08 ]
  • NoReseth
  • Laatst online: 21:43
Werkt perfect hier, keep up the good work :D
  • BtM909
BtM909
Watch out Guys...
Eindelijk :D _/-\o_
Woei looks good... :)
  • mrsar
  • Laatst online: 28-10 16:39
mrsar
waar een sar is,is een wodka
Jaaaaaaaa :)
process exclusion
woei,die is wel fijn :)
en al het andere natuurlijk ook (zal waarschijnlijk 1 van de weinige zijn die de complete changelog heeft doorgelezen :P )
steam: mr_sar1 / Battle.net : mrsar#2189 / xbox : mrsar1
  • Woudloper
Woudloper
« - _ - »
De verbeteringen zien er erg goed uit Mr. B.. Ik had nog even een additionele vraag over de verbeteringen.
  • Zit er nu ook ondersteuning in voor meerdere batterijen?? (dit voor mijn laptop)
  • Robin
Woei-er-de-woei, eindelijk es een nieuwe versie _O_. Ik heb het meteen in de meuktracker geplaatst :P.
Jammer genoeg zijn de nieuwe features dingen waar ik niks aan heb: ik gebruik Winamp2 (Winamp3 wordt niet meer ontwikkeld, dus ik zou eens gaan uitkijken naar Winamp5), draai helemaal geen koe, heb maar één processor en een uptime hoger dan 49 dagen heb ik nooit gehaald :P.
  • The Wrecker
  • Laatst online: 22-10 01:30
The Wrecker
Networking Rulez
Komt er ook iets voor seti?
Ik doe enkel seti op 't moment. Beetje laat voor die andere meuk.
  • jvvv
  • Laatst online: 25-10 14:19
wieee, deze soft is cool.
Thnx, dit draait vanaf nu altijd ier.
  • Mr. B.
Verwijderd schreef op 11 July 2003 @ 04:19:
Prachtig verbeterd.
Multi-monitor support staat op de to-do list.
Woudloper schreef op 11 July 2003 @ 09:37:
Idem.
The_Wrecker schreef op 11 July 2003 @ 12:25:
Idem.
Ik heb ook een aantal mailtjes binnengekregen van gebruikers waarbij ie bij het opstarten blijft hangen en alleen een hoop CPU tijd en geheugen vreet. Waar dat aan ligt weet ik nog niet, maar dat ga ik uiteraard uitzoeken.
StatBar.nl - @GoT
  • Mr. B.
Robin Vreuls schreef op 11 juli 2003 @ 11:47:
Thanx :)
StatBar.nl - @GoT
Mr. B. schreef op 11 July 2003 @ 12:47:
super!, hoop dat er snel een oplossing voor komt
  • job
  • Laatst online: 28-10 11:08
job
ik krijg 1 ding niet aan de praat.
m'n rc5 counter werkt niet. ik krijg: error retrieving rc5 stats.
zeker weten dat rc5-72 ondersteund wordt :). ik denk het wel, maar ik krijg het niet aan de praat.
heb al 2 maal m'n koe herstart.
heb statbar herstart. of moet ik soms wachten totdat er een blokje af is??
verder werkt het allemaal prima.
ga zo door :)
[ Voor 37% gewijzigd door job op 11-07-2003 13:01 ]
  • Mr. B.
damster schreef op 11 July 2003 @ 12:59:
m'n rc5 counter werkt niet. ik krijg een error retrieving rc5 stats.
Waarschijnlijk zul je ff moeten wachten tot er een blokje af is ja.
StatBar zoekt naar de laatste regel in het bestand van de vorm:
[Datum/tijd UTC] RC5-72: x packets (x stats units) are in buff-out.r72
Als er nog geen blokje af is, dan zal zo'n regel ook nog niet aanwezig zijn.
StatBar.nl - @GoT
  • Lief Adje
  • Laatst online: 08:05
Lief Adje
Love is in the air
Hulde _/-\o_ _/-\o_
PV: 2550WP | 520WP | een mens lijdt t meest door het lijden dat hij vreest
Mr. B. schreef op 11 July 2003 @ 12:47:Ik heb ook een aantal mailtjes binnengekregen van gebruikers waarbij ie bij het opstarten blijft hangen en alleen een hoop CPU tijd en geheugen vreet. Waar dat aan ligt weet ik nog niet, maar dat ga ik uiteraard uitzoeken.
Hmm, hier ook ja.
Win 2000 Pro, met SP4. 2.3 werkte prima.
  • job
job
Mr. B. schreef op 11 July 2003 @ 13:02:
Oke, dankje.
dan zal ik nog even wachten :)
Download meuk
Install meuk
Start meuk
Crash
Leuk tooltje, beetje grote download ... 1MB om je PC te laten klappen. . . .
'There was an error writing to the registry' Jah ... dus? en ? dan doe je t zonder ...
Geheugengebruik / CPU gebruik tot aan het dak ...
Start - Config scherm - Software - StatBar - Remove
Klaar
  • Mr. B.
Zou iedereen waarbij v2.4 blijft hangen en CPU/processortijd vreet me een mailtje willen sturen met de volgende gegevens:
• Windows versie incl. service pack
• Lijstje met draaiende processen (evt. screenshot van je task manager, maar liever de output van PsList, da's onderdeel van de PsTools van www.sysinternals.com)
• Als je NT/2K/XP gebruikt: versienummer van PDH.DLL (staat in \WINNT\System32, rechtsklikken en Properties kiezen om de versie op te vragen)
• Hoe je StatBar 2.4 geïnstalleerd hebt: via de update check, de zip gedownload, of de installer gebruikt.
• .reg filetje met de inhoud van de HKEY_CURRENT_USER\Software\VB and VBA Program Settings\Globe Software\StatBar key.
Met die gegevens kom ik hopelijk snel(ler) tot een oplossing...
Ik denk dat ik inmiddels wel genoeg informatie heb om het te onderzoeken; degenen die info hebben gestuurd worden hartelijk bedankt :)
[ Voor 10% gewijzigd door Mr. B. op 11-07-2003 17:08 ]
StatBar.nl - @GoT
Verwijderd schreef op 11 juli 2003 @ 13:31:
Download meuk
Install meuk
Start meuk
Crash
Klaar
Kan ook iets minder botter. :/
Hoezo is 1 MB tegenwoordig veel voor een proggie?
En bovenstaande is al een bekend (niettemin idd een ernstig) fout, Mr. B is almee bezig. Deze versie is net 1 dag uit, dus wacht nog ff tot er een patch voor is uitgekomen, en probeer het dan nog een keer voordat je er nu al een ordeel over stelt.
  • Kristof
  • Laatst online: 09-04 17:34
Kristof
is een Belgisch product
Hier w2k SP3 werkt alles ook ok!
Ik werk al een hele tijd met statbar, en ook deze versie ziet er goed uit, en weer wat extra handige functies! Ook van mij een dikke proficiat!!
Misschien nog enkele tips/opmerkingen (Ik neem aan dat je hiermee meer bent, dan enkel "heel goed" reacties :))
* als ik statbar opstart (automatisch met systeem of manueel), dan staat de time-sync button op rood. als ik erop klik, dan synct hij wel...
* Statbar start hier automatisch met het systeem. Ik heb ook ActiveDestop. bij het starten zet statbar zich bovenop de bvenste rij iconen. Als ik dan statbar even op AutoHide=on zet, en daarna terug off, dan shuift de ActiveDesktop en iconen een stukje naar onder, zoals het moet! Ik weet niet of jij daaraan iets kan doen (of het windows zaak is, of je er aan kan)
Je ziet maar wat je eraan kan doen.
* Je hebt er nu voor gezorgd dat de tooltip van vorige en volgende nummer bij de winamp2.x module, de songtitle weergeeft. Ik zou dit bij alle 5 de controls zo doen, dan hoeft je niet zo precies op die volgende of vorige knop te mikken...en ik neem aan dat iedereen wel de betekenis van de iconen vorige-play-pauze-stop-volgende kent...
Misschien ook een mogelijke module voorzien, die de songtitle altijd laat zien in de bar? Zeker als je multi-monitor support gaat voorzien (en de bar over 2 schermen gespreid kan worden?), is er plaats genoeg he, dus zou het misschien wel handig zijn!
"You can get more with a kind word and a gun than you can with a kind word alone." - Al Capone
  • Speedfight
Geweldig deze nieuwe versie. Ik gebruik altijd al Statbar, ik vind het veel beter dan soortgelijke programma's. En het komt natuurlijk uit nederland :)
_/-\o_ _/-\o_ _/-\o_
Vaillant aroTHERM plus VWL55/6, Zehnder WHR 930 WTW, Itho Daalderop douche-WTW, SolarEdge SE6K 6610Wp, SE3000H 3160Wp, Tesla Model Y Juniper RWD
  • Mr. B.
Kristof schreef op 11 July 2003 @ 13:38:
Thanx :P
Heb ik hier ook wel eens gemerkt. Als ik hier thuis m'n eigen server gebruik als timeserver, dan gaat het de 1e keer mis, als ik een server op internet gebruik gaat het meteen goed. Waar dat aan ligt weet ik nog niet.
Ben bang dat dat een zaak van Windows is. StatBar zegt bij het opstarten gewoon tegen Windows: "ik ben een nieuwe desktop toolbar, maak eens plaats". Bij het un-auto-hiden is het "ik ben al een desktop toolbar, en ik ga nu van autohide af, maak eens plaats". Als Windows dat de 1e keer niet doet dan kan ik d'r helaas niks aan doen :/
Multi-monitor support zal inhouden dat je kunt kiezen op welke monitor je de balk wilt plaatsen; het spreiden over 2 monitoren is voorzover ik weet niet mogelijk met een desktop toolbar. De plaats is ook de enige reden waarom de song title (nog) niet op de balk staat maar alleen in de tooltips. Dat ik de titel alleen laat zien bij prev/next is omdat het handig is bij het doorlopen van je playlist; je klikt op next en ziet meteen welk nummer je kunt laten spelen :)
StatBar.nl - @GoT
  • Kristof
Kristof
Mr. B. schreef op 11 juli 2003 @ 13:47:
Ik gebruik anders wel een server op internet (de standaard denk ik: ntp.xs4all.nl)
Nu ja, er zijn belangrijkere dingen!
Misschien een optie om na het starten, automatisch even die autohide=on en autohide=off te laten doen?
hmm dat is spijtig :(
zou anders mooi zijn
  • Woudloper
Woudloper
« - _ - »
Speedfight schreef op 11 juli 2003 @ 13:46:
Soortelijke programma's :? Ik ken er maar één en dat is Winbar, maar als er meerdere zijn zou ik dat wel graag willen weten. 't Is altijd leuk om even naar de concurenten van StatBar te kijken...
Wellicht dat er dan eens een vergelijkingsonderzoekje (tabelletje) kan worden gemaakt...
Kix@$$ schreef op 11 juli 2003 @ 07:51:
Os: Windows XP
Bij mij start hij ook niet meer. Ik drukte op CTRL+ALT+DEL om te kijken wat er gebeurde;
Statbar nam bij het starten ff 1,5 GB aan geheugen in beslag, en kwam zelf niet opdagen.
Versie 2.4 werkt hier gewoon NIET :(
  • Mr. B.
Verwijderd schreef op 11 juli 2003 @ 14:45:
Check m'n bericht hierboven ff: Mr. B. in "StatBar 2.4 released!"
Waar het aan ligt weet ik nog niet, ik heb het 1 en ander aan info nodig... dus als je me dat zou willen laten weten; graag.
StatBar.nl - @GoT
Mr. B. schreef op 11 July 2003 @ 14:48:
specs:
AMD Athlon 2800+
1024 MB DDR 333 MHz
ATI Radeon 9700 PRO
Verder nog iets?
Verwijderd schreef op 11 July 2003 @ 14:53:
specs:
AMD Athlon 2800+
1024 MB DDR 333 MHz
ATI Radeon 9700 PRO
Verder nog iets?
Ja, check die bericht dan. :P
  • La_Pazz
  • Laatst online: 22-09 09:51
Ik heb ook statbar draaien op mijn win2000sp3, ik heb de 'Update Check' gedraaid, dus gedownload en geinstalleerd over StatBar heen, en het draait al een aantal uur prima!
Ramverbruik is stabiel op 7.7 MB en cpu 2%.
  • Krul
  • Laatst online: 31-08 15:38
Krul
Holodoc
Weer een user erbij :) .....heb jaren lang Winbar gebruikt maar daar zit geen leven meer in. Wordt vrijwel niets (zichtbaars) aan gedaan, terwijl ik dagelijks last had van een irritante bug :(
Tot nu toe bevalt Statbar prima ;)
  • Ibbelz
  • Laatst online: 16-10 11:13
Mr. B. schreef op 11 juli 2003 @ 13:35:
Als het goed is heb je van mij een mailtje met de gegevens (op info@statbar.nl).
Ik hoop dat er een patch voor komt want ik ben wel benieuwd naar deze versie. :)
Even he, to whom most things that most people would think were pretty smart were pretty dumb, thought it was pretty smart.
  • axis
  • Laatst online: 26-01-2023
Mr. B. schreef op 11 July 2003 @ 13:35:
Je hebt van mij ook een mailtje gehad... Ben benieuwd ;)
Two advices for network troubleshooting.. learn to draw diagrams in Visio, and THINK IN LAYERS!
lijkt me een gigantische mem leak ofzo want na 5 minuten draaien heeft hij 700 mb in gebruik
  • axis
Verwijderd schreef op 11 July 2003 @ 17:00:
bij mij in 30 seconden 1,5GB :)
  • Vorkie
hij staat nu sinds vannochtend aan en hij gebruikt nu 30mb!!!! Geheugen.... denk dat er nog ergens iets fout staat oid :)
  • BlackB1rd
  • Laatst online: 16-09 12:00
Is het misschien een idee om een optie te maken waarbij aangegeven kan worden of het label "Time synch:" uitkan? Daardoor ontstaat een soortgelijk effect als in Winbar, waarbij alleen een blokje zichtbaar is.
Kan toch weer nét die paar pixels schelen die je mogelijk nodig hebt :)
Een hele zooooi
  • Mr. B.
Vorkie schreef op 11 July 2003 @ 18:22:
Zal waarschijnlijk dezelfde oorzaak hebben als die vreemde crashes... ik ben er nog mee bezig :/
BlackB1rd schreef op 11 July 2003 @ 18:28:
Op de "Misc. Options" tab in het config scherm kun je "Time synch." uitvinken.
StatBar.nl - @GoT
  • BlackB1rd
Mr. B. schreef op 11 July 2003 @ 18:30:
Aha, sorry daar had ik (uiteraard) overheen gekeken :) Bedankt
Een hele zooooi
  • AlvaK
Ik heb alweer tijden WinBar gebruikt, maar nu ga ik toch weer eens StatBar proberen. Eerste indruk is goed, maar heb ik maar 2 puntjes:
Ik vind het best irritant dat WinAmp afsluit wanneer je op "W" klikt, is het niet mogelijk om instelbaar te maken wat die optie doet? Ik wil graag gewoon WinAmp tevoorschijn halen. :)
Ik zou er nog wel een colorscheme bij willen, namelijk eigenlijk hetzelfde als de ME/2K versie, maar dan gewoon de kleur silver (#C0C0C0) ipv dat gelige grijze.
Hmm.. nog een puntje. Wanneer ik de colorscheme verander via configuration werkt het prima, maar wanneer ik het via het pulldown menu doe, veranderen alleen de lettertjes van kleur?
  • Mr. B.
AlvaK schreef op 11 July 2003 @ 19:43:
Da's wel een goeie... die komt op de to do list :)
Nieuwe kleurschema's ga ik niet meer toevoegen omdat dat alleen maar nog meer geheugen/resources gaat kosten. Skinning support staat op de planning, zodra dat d'r in zit kun je zelf een skin/kleurschema maken.
Ehr... vreemd :?
Tussen welke 2 kleurschema's switchte je?
StatBar.nl - @GoT
Ik vond eerst Winbar beter, maar na een midagje Statbar 2.4 te hebben gebruikt begin ik toch van mening te veranderen :)
Enige waar ik wel met smart op wacht is een modulle die controlleerd of er mail is, maar dat staat op de to-do lijst las ik net, en wat mischien ook handig is een klein klopje links en/of rechts zodat je de bar ff kan inschuifen.
Dit vond ik bij winbar altijd erg handig omdat als ik vaak een applicatie open dat deze met de titelbalk onder de bar zit, bij Winbar kon ik em gewoon ff inschuifen en het progie iets naar beneden schuifen, maar bij statbar moet ik meteen statbar afsluiten, progie naar beneden halen, en statbar weer starten, een klein minpuntje vind ik, maar verder begin ik em beter te vinden dat Winbar, vooral omdat er volgens mij niks meer aan Winbar gedaan word :(
  • Mr. B.
Verwijderd schreef op 11 July 2003 @ 20:10:
Dat applicaties met hun titelbalk onder de bar verschijnen is iets waar ik helaas niks aan kan doen (zie ook de FAQ op www.statbar.nl). Wat ook werkt is auto-hide in StatBar ff aan en weer uit zetten, dan hoef je 'm niet af te sluiten :)
StatBar.nl - @GoT
  • AlvaK
Mr. B. schreef op 11 July 2003 @ 20:02:
Thanks. :)
Ehr... vreemd :?
Maakt niet uit. Zolang ik via het pulldown menu verander gaat het mis, via 't configuratiescherm gewoon goed.
Overigens gebruik ik w2k pro. SP3
  • Change
  • Laatst online: 26-04-2025
Waarom staan RSS feed mogelijkheden niet op de to-do list? :P Die vind ik juist zo handig in WinBar (meteen ook de reden waarom ik Statbar nog niet ga proberen - terwijl ik het wel graag zou doen [ben begonnen met Statbar en toen naar WinBar geswitcht]).
AMD 64 3200+/2048MB/MSI K8N/2x Seagate 200GB SATA/Seagate 160GB/Seagate 320GB/LG GSA4120B DVDRW/nVidia 6800 XT/SB Audigy 2 ZS/DSL:20/1 - Telfort/21" Samsung SyncMaster 215TW/ToUCam Pro/WinXP Pro
  • jvvv
In Win 2k3 verbruikt ie ier 20% en start hij zelfs niet. Ik denk dat er toch ergens een foutje is.
Allé, hij start en is 'runing, maar komt niet op men scherm..
  • bobsnl
Misschien een ideetje voor de volgende versie. Bij RC5-72 staan nu 'blocks in buff-out' én 'WU's in buff-out' en dat is hetzelfde ;) Kan je niet van één van de twee de buff-in maken?
  • job
job
bobsnl schreef op 11 July 2003 @ 22:18:
het zou helemaal mooi zijn als je daar de keys/sec zou kunnen zien.
  • PrinsEdje80
  • Laatst online: 01-01 15:26
PrinsEdje80
Holographic, not grated...
Sinds ik de nieuwe versie draai, loopt er een extra process onder mijn XP: WMIAPSRV. Deze stond er voor 2.4 niet. Ook hier komt StatBar traag op gang, maar toch na enkele seconden heeft Windows het door en komt hij als nog en goed op ook...
Used to be Down Under... Foto gallery
  • Mr. B.
Change schreef op 11 July 2003 @ 21:17:
Omdat de to-do list momenteel niet bijgewerkt is :P
jvvv schreef op 11 July 2003 @ 21:56:
Voor iedereen waar v2.4 bij hangt bij het starten:
Ik heb het probleem waarschijnlijk gevonden... als het goed is heb ik morgen zekerheid, dus dan kan er een update online :)
Ehr... is dat zo? :D
Bij RC5-64 verschilden die waardes, en bij OGR ook... naja, ik pas het wel aan dan :)
* Mr. B. draait zelf geen koe, dus ik weet allemaal niet waar die getallen voor staan :+
PrinsEdje80 schreef op 11 July 2003 @ 23:34:
Dat WMI staat voor Windows Management Instrumentation; die wordt blijkbaar aangeroepen zodra StatBar de Windows Performance Counters benadert. Misschien draait er bij jou 1 of andere standaard service niet, die Windows dan maar zelf gaat starten?
StatBar.nl - @GoT
  • Mr. B.
Versie 2.405 released!
• On some Win2000/XP systems, StatBar 2.4 would consume all available memory on startup, and the program would eventually crash. This was due to a bug in the performance counter routines. Fixed.
• The RC5/OGR counter module has been updated. It now also displays the statistics for the buff-in file instead of only for the buff-out file. This data is now displayed in the tooltip for the cow icon. The "blocks" and work "units" indicators on the bar have been removed, which saves some space.
• Added an option to let the W button in both Winamp control modules pop up Winamp instead of close it.
• Added an option to let the disk information panel pop up when you move your mouse over the disk icon instead of having to click it.
• Added an option to turn off the tooltips for the main window.
Iedereen waarbij v2.4 crashte kan dus opgelucht ademhalen: het is verholpen.
En axis wordt hartelijk bedankt voor het nodige testwerk :)
StatBar.nl - @GoT
  • Tyrian
Tyrian
It's Unreal.
Dank voor de snelle bugfix. Dan kan ik hem hier ook ff uitproberen!
http://www.hypercoop.tk | GW user page | GW2 user page
Specs
  • Spider.007
Spider.007
* Tetragrammaton
Kunnen die lelijke groene rondjes voor num-scroll-caps lock niet weer net zo mooi worden als in de vorige versie? Ik vindt ze eigenlijk afdoen aan de strakheid van het design (net zoals de up/download pijltjes btw). Verder blijft dit natuurlijk een prachtig progseltje
Prozium - The great nepenthe. Opiate of our masses. Glue of our great society. Salve and salvation, it has delivered us from pathos, from sorrow, the deepest chasms of melancholy and hate
Hij werkt!!!!!!!! :*) Super gewoon.
Goed werk man!
  • Ibbelz
Damned Mr. B. goed werk hij doet het hier ook weer :D :D :D.. Bedankt voor de snelle bugfix, keep up the good work.. :)
  • Mr. B.
Spider.007 schreef op 12 July 2003 @ 13:25:
Mja, dat is een kwestie van smaak natuurlijk.
Die andere lampjes heb ik eruit gegooid omdat je daar NL/CL/SL naast moest; op deze manier bespaar je weer wat ruimte.
De pijlen vind ik persoonlijk een stuk duidelijker dan die D en U labels... maargoed, je kunt nooit iedereen tevreden houden ;)
[ Voor 11% gewijzigd door Mr. B. op 12-07-2003 18:27 ]
StatBar.nl - @GoT
Mr. B. schreef op 12 July 2003 @ 18:26:
Nou het ziet er strak uit, voorheen gebruikte ik winbar, maar statbar is toch net ietsjes beter vind ik persoonlijk. Netjes..
En die groene knopjes? Acht wat maakt die kleur nou uit van die balletjes? :) En anders bouw je een optie in waarmee de kleur kan veranderd worden ;)
  • Ibbelz
Nog een vraagje he ik heb nu ook een quicklauch bar in mn standaard taakbalk, nu wil ik alle shortcuts verplaatsen naar de quicklaunch bar van statbar.. Alleen ik heb Bureaublad weergeven en mn inbelverbinding (ja ISDN :?) ook in de quicklaunch staan ik heb geen ID hoe ik deze in statbar kan krijgen, omdat het natuurlijk geen normale paden enz zijn, iemand een ID?
Zet die snelkoppelingen ergens in een map en verwijs naar de snelkoppeling in die map ?
  • Mr. B.
IbBeLz schreef op 12 July 2003 @ 18:42:
Voor Show Desktop: voeg een QuickLaunch entry toe naar C:\Documents and Settings\<username>\Application Data\Microsoft\Internet Explorer\Quick Launch\Show Desktop.scf (althans, daar staat ie onder Win2000/XP)
Het bijbehorende icon kun je vinden in shell32.dll :)
Voor een inbelverbinding weet ik het zo ff niet. Waarschijnlijk gaat dat niet, omdat het inderdaad geen file is die je start.
StatBar.nl - @GoT
  • Ibbelz
Mr. B. schreef op 12 juli 2003 @ 18:48:
Thanx, bureaublad weergeven werkt prima nu :) alleen inbel werkt idd niet :(, maar krijgt toch binnen kort adsl :) :)
  • Scipionyx
Doet het bij mij niet. Moet nog steeds klikken om de info te krijgen.
(WinXP Pro NL, geen ServicePack)
Top 4 Anti-Stress regels:
1) Doe zo weinig mogelijk of laat het anderen doen.
2) Als je plots zin hebt om te werken, ga dan zitten en wacht tot het over gaat.
3) Als je iemand ziet rusten...help hem!!
4) Doe vandaag niet wat morgen kan.
  • Jerry
  • Laatst online: 24-03 16:08
Jerry
Who?
Scipionyx schreef op 12 July 2003 @ 22:48:
Check de Misc. opties -> Display information -> require mouseclick to open... :)
(die moet dus uitgevinkt worden ;)).
Bugje:
Wanneer ik dit "testje google" (voorbeeld) intik in de search functie van statbar (incl. de quotes). Dan komt er dit te staan in de google searchstring: "testjegoogle". Ik zoek best veel op een zin met google om m'n search returns wat naar beneden te halen :).
[ Voor 39% gewijzigd door Jerry op 12-07-2003 23:04 ]
  • bobsnl
Mr. B. schreef op 12 July 2003 @ 11:53:
Toppie werkt prima zo _/-\o_ alleen ....misschien een hele lullige vraag hoor, maar dat ik het aantal blocks in de bar kon zien, vond ik eigenlijk net zo fijn. Durf het bijna niet te vragen, maar is het niet mogelijk om 2 opties te hebben:
1: alleen de koe, 2: koe + aantal blocks in en uit. :X
  • Scipionyx
Mr_UnAnimouS schreef op 12 July 2003 @ 22:51:
Aaahh... dus dat was het! :)
  • Kramers
  • Laatst online: 05-08-2025
Kramers
Tijd voor iets nieuws
bobsnl schreef op 12 July 2003 @ 23:29:
I Agree!
Dat vind ik ook wel jammer dat dit in de allerlaatste versie is veranderd. Graag zou ik de WU ook weer gewoon in de bar willen zien staan.
Verder weer een top programma!
Huh.. moet ik hier wat typen of zo ?
  • Klippy
Klippy
Still Game
Heb net ff update geïnstalleerd, dacht lag misschien aan de build ofzo m'n winamp probleem, maar is nog steeds:
Afbeeldingslocatie: http://members.home.nl/s.klippert/SBerr.jpg
als Winamp aan staat.
Maar ik heb er zoals gezegd geen last van en zo te zien ben ik nog de enige met dit probleem, dus zal wel aan mij liggen :) Al zijn er niet al te veel mensen die WA3 gebruiken.
Maar goed dacht geeft 't toch maar door dat 't nog hetzelfde is voor als er toch nog iemand mocht opduiken met hetzelfde probleem :)
Verder mooie update als het XP opstart probleem bij veel users gefixt is, weet zelf hoe moelijk het kan zijn dat soort foutjes weg te krijgen en heb 't idee dat 'ie beetje sneller start hier d:)b
  • BlackB1rd
Ik ben met de release van versie 2.4 overgestapt van WinBar naar StatBar, alleen merk ik nu dat ik 1 optie heel erg mis in StatBar: huidige tijd / datum module. Altijd als ik ff snel wilde kijken welke dag het vandaag is, keek ik met een schuin oog naar rechtsboven. Dat doe ik nog steeds en elke keer kom ik weer tot de ontdekking dat StatBar die optie niet heeft ;)
Dus ik vroeg me af of er misschien zo'n module voor in de toekomst inzit? :)
Een hele zooooi
  • Mr. B.
Mr_UnAnimouS schreef op 12 juli 2003 @ 22:51:
Bugje:
Hmmz... je hebt gelijk. Zal kijken wat ik eraan kan doen.
bobsnl schreef op 12 juli 2003 @ 23:29:
Mja, ik heb het d'r om 2 redenen uitgesloopt:
1. Het bespaart plaats
2. Bij OGR zou je dan ineens 4 getallen moeten laten zien (in/out, en het aantal work/stats units is daar niet gelijk aan het aantal packets). Zoals het nu is kun je alle info gewoon in de tooltip zien, en dan boeit het niet hoeveel verschillende gegevens het zijn.
LiquidSilver schreef op 13 juli 2003 @ 11:36:
Mja, ik blijf het vaag vinden... ik krijg het hier echt niet voor elkaar om die fout te krijgen, dus waar het aan ligt zou ik niet weten :|
BlackB1rd schreef op 13 juli 2003 @ 13:29:
* Mr. B. kijkt juist met een schuin oog naar rechtsonder; TClock zet de datum hier keurig in de systray, bij de tijd :+
Maar ik heb een datum/tijd module op de to-do list voor de volgende versie gezet :)
StatBar.nl - @GoT
  • sus
  • Laatst online: 22:20
sus
is druk :+
waaaaaaaaaaaaaaaaaaaaaaanzinnig :) Heel rg top, nieuwe versie :)
Paar puntjes:
• De update werkte niet, statbar liep daarop vast. Had net 30KB binnen ofzo.
• Waar kan ik dat "process excluding" vinden?
• Op mijn server werkt de time-sync niet, hij houdt de UTC-tijd aan. Ligt misschien aan mij!!
Toppie dat er weer een nieuwe versie is, kunnen we die masaal gaan stress-testen :D
  • Mr. B.
SuspiciouS schreef op 14 July 2003 @ 14:23:
Paar puntjes:
Wazig... zou zo ff niet weten waar dat aan ligt. Hing StatBar helemaal of kon je wel nog op Abort klikken in het update venster?
Op de Misc. Options tab. Hij staat links onderaan onder het kopje "CPU usage", je zult ff naar beneden moeten scrollen.
Check ff de tijdzone en zomertijd instellingen van Windows, waarschijnlijk staan die verkeerd :)
* Mr. B. is inmiddels druk bezig met de nieuwe website... gaat toch aardig wat werk in zitten :P
StatBar.nl - @GoT
Ik zou het trouwens super vinden als bij de up en download ook een grafiekje komt netzoals cpu en ram... :)
  • Woksie
Woksie
Gone
Handig proggie, alleen heb ik (natuurlijk) een vraagje: ik gebruik vaak winamp en om het volume aan te passen, gebruik ik dan de volumescroll die in winamp zelf zit, nou is mijn vraag; kan je als de winamp module geactiveerd is (winamp speelt dus een nummer af) instellen dat als je dan scrolled het volume in winamp en dus niet het master volume veranderd?
  • Krul
Krul
Holodoc
Bug report: Na userswitching in Windows XP heeft Statbar een ietwat verneukte kleur (groene en witte streep door de hele balk).
Afbeeldingslocatie: http://www.bxl.nl/got/statbar.GIF
WinXP SP1, Statbar 2.405, SilverTheme
Feature request: Graag zou ik de titelsongs van Winamp in de bar zien (niet alleen als tooltip).
[ Voor 5% gewijzigd door Krul op 14-07-2003 15:53 ]
  • maratropa
nu gedraagt hij zich als de task bar, met een auto hide optie, en "always on top" lijkt bij statbar aan te staan. zou dit uit te schakelen zijn? want nu neemt ie scherm in beslag. Dus niet verstoppen maar gewoon dat andere windows er overheen kunnen.
specs
  • sus
sus
is druk :+
Mr. B. schreef op 14 juli 2003 @ 14:27:
Nee, hij zat helemaal vast. Moest echt het process killen.
IDD, gevonden. Had niet gezien dat er een scrollbalk zat.
Staan goed. :? :? :?
  • sus
sus
is druk :+
Krul schreef op 14 July 2003 @ 15:50:
Sleep hem eens ff van beneden naar boven en weer terug? Heb ik nl. ook gehad.
  • Krul
Krul
Holodoc
SuspiciouS schreef op 14 July 2003 @ 16:54:
Ja, dat werkt, maar naar de volgende keer switchen is ie weer corrupt :| .
  • Mr. B.
Verwijderd schreef op 14 July 2003 @ 14:47:
Staat op de to-do list :)
Sir Killalot schreef op 14 July 2003 @ 14:49:
Dat moet wel mogelijk zijn denk ik; zal kijken wat ik kan doen.
Zal ik eens naar kijken, maar ik denk eerder dat dat aan XP of aan je grafische kaart ligt. Het enige wat StatBar doet als je uit userswitching komt is zorgen dat ie op de goeie plaats staat.
Staat ook op de to-do list.
gladiool schreef op 14 July 2003 @ 16:46:
Eh... daar zie ik ff het nut niet van in. Als StatBar op auto-hide staat en always on top staat uit, dan zou je 'm alleen maar tevoorschijn kunnen halen als je geen gemaximaliseerde vensters hebt omdat die anders over het randje wat StatBar over laat heen vallen. Dat randje is er omdat ie tevoorschijn komt als je daar met je muis overheen gaat.
Dan weet ik niet waar het aan ligt, of de timeserver die je gebruikt geeft de verkeerde tijd terug, maar dat lijkt me sterk. Zo'n timeserver hoort de tijd altijd in UTC terug te geven, en StatBar zegt vervolgens tegen Windows "hier heb je je nieuwe systeemtijd in UTC, zoek zelf maar uit wat het in je eigen tijdzone moet zijn". Op de correctie die Windows daarop loslaat heeft StatBar geen enkele invloed.
StatBar.nl - @GoT
  • AlvaK
Ohja, bij mij bleef de autoupdate op een bepaald percentage (helemaal in 't begin al) hangen. Maar ik kon dus wel gewoon aborten.
Pagina: 1 2 Laatste
