Abit IC7(-G) [Ervaringen]
Pagina: 1 2 ... 6 Laatste
  • 1.821 views sinds 30-01-2008
  • Pheno79
  • Laatst online: 24-09 21:34
Welkom bij het grote ABIt IC7(-G) topic.
Het is de bedoeling om al je vragen of tips over deze twee canterwoodsmaken van Abit in dit topic te stoppen, zodat alles handig bij elkaar staat.
Mocht je een leuke overclock hebben gedaan, zet er dan graag bij welke relevante bios settings je gebruikt hebt. Het zou zomaar kunnen zijn dat het anderen weer op het goede tweakpad krijgt :*)
Maar natuurlijk beginnen we met de specs:
[CPU]
Supports Intel Pentium 4 Socket 478 processors with 800/533/400 MHz FSB
Supports Intel Hyper-Threading Technology
[Chipset]
Intel 875 / ICH5-R
Support Intel CSA Gigabit LAN
Supports Dual Channel DDR 400 with ECC function
Supports Performance Acceleration Technology (PAT) function
Supports Advanced Configuration and Power Management Interface (ACPI)
[Memory]
Four 184-pin DIMM sockets
Supports 4 DIMM Single/Dual Channel DDR 400 memory.(Max. 4GB)
Supports configurable ECC function
[AGP]
Accelerated Graphics Port connector supports AGP PRO 8X/4X (0.8V/1.5V)
[Serial ATA RAID]
2 channel Serial ATA 150MB/s data transfer rate with RAID 0 function support
2 channel Serial ATA 150MB/s data transfer rate with RAID function (0/1) via Silicon Image PCI Chip (IC7-G only)
[Audio]
6-Channel AC 97 CODEC on board
Professional digital audio interface supports 24-bit S/P DIF optical In/Out
[Media XP (Optional)]
Supports card reader function for Memory Stick™, Secure Digital™ and Type I/II CompactFlash™
Supports Wireless Remote Control and S/PDIF Out / Mic In / Headphone Out / USB 2.0 / IEEE 1394
[System BIOS]
SoftMenu™ Technology to set CPU parameters
Supports Plug-and-Play (PNP)
Supports Advanced Configuration Power Interface (ACPI)
Supports Desktop Management Interface (DMI)
Write-Protect Anti-Virus function by AWARD BIOS
[IEEE 1394]
Supports IEEE 1394a at 100/200/400 Mb/s transfer rate
[Internal I/O Connectors]
1 x AGP PRO, 5 x PCI slots
1 x IrDA
1 x Floppy Port supports up to 2.88MB
2 x Ultra DMA 33/66/100 Connectors
2 x Serial ATA 150 Connectors (4 on IC7-G)
2 x USB 2.0 headers, 2 x IEEE 1394a header
1 x CD-IN, 1 x AUX-IN
[Back Panel I/O]
1 x PS/2 Keyboard, 1 x PS/2 mouse
1 x Printer Port, 1 x COM port
1 x S/PDIF Out connector, 1 x S/PDIF In connector
1 x Audio connectors (Front Speaker, Line-in, Mic-in)
1 x Audio connectors (Center/Sub, Surround Speaker)
2 x USB 2.0, 1 x IEEE 1394a
2 x USB 2.0
1 x RJ-45 LAN Connector (IC7-G only)
[Miscellaneous]
ATX form factor
Hardware monitoring - Including Fan speeds, Voltages, System environment temperature
Dan de plaatjes:
IC7:
Afbeeldingslocatie: http://picserver.student.utwente.nl/getpicture.php?id=126984
IC7-G
Afbeeldingslocatie: http://picserver.student.utwente.nl/getpicture.php?id=126987
Alle poortjes die je kan verzinnen:
Afbeeldingslocatie: http://picserver.student.utwente.nl/getpicture.php?id=126989
Doos:
Afbeeldingslocatie: http://picserver.student.utwente.nl/getpicture.php?id=126979
Northbridge fan:
Afbeeldingslocatie: http://picserver.student.utwente.nl/getpicture.php?id=126982
Hieronder de BIOS revisies, zodat je meteen ziet of een probleem van je in een BIOS update is opgelost:
Meest recente BIOS: http://fae.abit.com.tw/download/bios/ic7/ic715.exe
BIOS release 1.5 for IC7/IC7-G v1.0 Release information:
1. Shows the correct IRQ of IDE Controller in PCI Devices Listing.
2. Fixes CPU Thermal Throttling behavior while under minus temperature and supports minus temperature reading in BIOS Setup.
3. Fixes the problem that system could not automatically get into S4 mode after enabled Power Scheme of "Power Option" under Windows XP
4. Fixes wrong system operation caused by incomplete discharging CMOS data by CCMOS jumper.
BIOS release 1.4 for IC7/IC7-G v1.0 Release information:
1. Added new option "HDD Change Message" in Advanced BIOS Features and the default setting is "Disabled". If this option is changed to "Enabled", the system will show warning message and prompt for a confirmation when one or more than one HDD had been added into or removed from the system.
2. Changed the default setting of "OnCip Serial ATA" to "Auto".
3. Revised the wording of IDE channels inside the BIOS Setup. IDE Channel 0, 1, 2, and 3 are changed to 1, 2, 3, and 4.
4. Revised the error reading of fan speed for specific CPU cooling fan when FanEQ 60% enabled.
5. Fixed "CPU THRM-Throttling" function.
6. Fixed the slow detection problem when HDD simulation card installed.
7. Fixed the problem that SMARTDRV.EXE malfunction in DOS 6.22 environment.
8. Fixed the problem that Windows 98 bootable floppy disk causes system hang up during loading CD-ROM driver when "OnChip Serial ATA" is set to "Auto".
9. Added "Game Accelerator" technology.
10. Removed options "Virus Warning" and "Force Update ESCD".
BIOS release 1.3 for IC7/IC7-G v1.0 Release information:
New Fixes/Features
1. Fixed DOS 6.22 booting failure from FAT16 partition.
2. Revised display mode of HTT CPU LOGO.
3. Fixed BIOS hang-up problem which is caused by specific CPU cooling fan
reporting error RPM to BIOS when CPU FanEQ 60% enabled.
4. Revised the following default settings in BIOS setup page.
- Bootable Add-in Device: PCI Slot Device
- CPU FanEQ Active Temperature: 70 C
- CPU Warning Temperature: 85 C
5. Enabled "IDE Block Mode" and hided the option.
6. Revised ICH5R RAID BIOS display issue.
7. Fixed COM2 device existing in Windows Device Manager problem.
8. Revised power-on delay time from 4~5 seconds to 1~2 seconds after AC power
lost and resumed.
BIOS release 1.1 for IC7/IC7-G v1.0 Release information:
1. Added new option "SATA RAID ROM" to setup the BIOS of onboard and on-chip SATA.
2. Revised setup menu for on-chip Serial ATA.
3. Fixed IOMEGA USB-ZIP 250 boot issue.
4. Added SVID/SDID for IC7 and IC7-G respectively.
5. Added "Intel on-screen branding" and could be enabled/disabled.
6. Added new options "Read Delay (Trd)" and "Turbo Mode" for system performance.
7. Fixed on-chip SATA boot issue while another bootable hard drives exist and attached to IDE-1 or IDE-2.
8. Updated memory reference code and ICH5 BIOS spec to v1.2.
9. Updated ICH5 SATA RAID BIOS to v3.0.0.2344.
10. Updated CPU micro code (CPU: 0F29H, ID=11H).
11. Added new options "Refresh Cycle Time", "Read Delay Adjust (tRD Adj)", "Command Per Clock (CPC)", and "Performance Mode".
12. Added new option "IDE Bus Master".
13. Added CPU multiplier 8X for engineering sample CPU and maximum CPU frequency 412 MHz.
14. Fixed DRAM timing settings while manually set them.
Dan nog wat reviews:
Tomshardware (met een 1.0 BIOS!!):http://www.tomshardware.com/motherboard/20030519/index.html
Anandtech:http://www.anandtech.com/mb/showdoc.html?i=1822
Extreme Overclocking: http://www.extremeoverclo...rboards/ABIT_IC7-G_1.html
Hot hardware:http://www.hothardware.co...abitic7g_asusp4c800.shtml
HardOCP:http://www.hardocp.com/article.html?art=NDY5
Asusboards:http://www.asusboards.com...s.php?op=showcontent&id=6
Wat forums met een schat aan informatie (dankjewel Remco20):
http://forum.abit-usa.com/forumdisplay.php?s=&forumid=6
http://www.abxzone.com/fo...fee08c0868e491&forumid=41
[ Voor 54% gewijzigd door Pheno79 op 17-07-2003 11:37 ]
  • ken
  • Laatst online: 20-11 22:28
ken
Je mag niet via tomwebsite doorlinken en resize de plaatjes ook effe. Die vern**kt de lay-out :). Voor de rest een prima opening
Canon 5D Mark II, Canon 35 f/1.4L
  • Pheno79
Ikzelf heb dit bord net een dag binnen (nu mijn watercooling nog) maar het loopt nu op standaard settings al op 3G ipv 2.4. Kwestie van de FSB flink opschroeven. Het enige "voordeel" wat ik heb, is dat ik PC3500 geheugen gebruik. Helaas heb ik nog niet veel tijd gehad om het ding echt op de pijnbank te gaan leggen, maar ik beloof beterschap :) Het geheugen laten lopen op agressievere timings moet ik nog proberen, ook de andere biossettings moet ik nog uitproberen. Natuurlijk ga ik mijn uiteindelijke successen (tenminste dat hoop ik) hier posten met wat leuke pics.
Was het maar alvast weekend....
[ Voor 43% gewijzigd door Pheno79 op 23-05-2003 05:44 ]
  • MrDirect
  • Laatst online: 27-11 13:58
Keurige openings post ;)
Voltmod voor Vmem op de IC7 (-G)
ABXZone.com review.
En WD Raptors review op de IC7-G
Vooral die onderste is erg uitgebreid, met verschillende stripesizes e.d.
Het enige waar ik last van heb , is dat de Intel RAID controller soms m'n Maxtor native SATA schijven niet wil/kan zien. Hij blijft maar hangen waar ie normaal laat zien welke schijven er in RAID staan (net voordat je op <CTRL><I> kan drukken.
Het is me nu al een paar keer overkomen en na een paar keer resetten ziet ie ze uiteindelijk toch. Heel irritant, want elke keer denk ik dat m'n schijven kaopt zijn ofzo... Iemand een oplossing?
  • Remco20
  • Laatst online: 14:42
Voor volgende week staat er een nieuwe bios op de planning die onder andere de temperatuurproblemen moet oplossen:
http://forum.abit-usa.com...ead.php?s=&threadid=11496
Nog een aantal tips:
- Update je bios voordat je Windows gaat installeren eerst met de meest recente versie
- Wanneer je bij het installeren van Windows BSOD of andere errors krijgt, zet dan je memory timings via de bios handmatig op 2-7-3-2
- Wanneer je SATA schijven gaat gebruiken, wees er dan zeker van dat je ICH5R en de Silicon Image controller goed in de bios instelt. Hier een url met info over het opzetten van SATA Raid via ICH5R:
Opzetten van SATA Raid met ICH5R
- Wanneer je je memory agressief instelt (2-2-2-5), kun je problemen ondervinden. Zover bekend hebben alle Canterwood mobo's last van de RAS - CAS timing. Deze werkt het stabielste wanneer deze op 3 is ingesteld (2-2-3-5).
- Voor ATA schijven die je op SATA wilt aansluiten, heb je Serillel 2 adapters nodig. Aan Serillel 1 heb je dus niks :D. Er zit 1 Serillel 2 adapter bij de IC7-G
Verschil IC7 - IC7-G:
- IC7-G heeft 1 Gigabit lan en IC7 heeft helemaal geen LAN onboard
- IC7-G heeft een extra SATA raid controller, namelijk de Silicon Image SATA Raid controller
- IC7-G komt met 1 Serillel 2 adapter
Hier nog wat forums met een schat aan informatie:
- Abit forums
- abxzone forums
Alle info heb ik van de forums, hopelijk ontvang ik mijn IC7-G zeer binnenkort :7
(ps: die Tom's Hardware review had je wel weg mogen laten :) Die is namelijk zeer incorrect. Er is bios 1.0 gebruikt (in tegenstelling tot wat THG zegt). Deze had problemen met de memory timings die dus opgelost zijn met bios 1.1 en een enorme performance boost gaven.)
[ Voor 22% gewijzigd door Remco20 op 23-05-2003 00:42 ]
  • Pheno79
Ik heb de openingspost wat aangepast, dank je Remco20 ;)
Tomshardware laat ik er wel bij, er staan misschien wel wat relevante dingen in (op de issues die hij had met instabiliteit na). Mijn bord hier loopt al een paar dagen te primen en te 3dmarkbatchen, maar hij wil niet plat. Tom heeft dus een gouden regel vergeten: if it's broken, try to fix it with a driver/bios update :D Het lijkt me een kleine moeite om de op de Abit site een biosupdate te halen om je kwaliteit van je review te verbeteren. Maar goed, Tom is Asus freak (nofi), we zijn wat gewend.
  • M289
  • Laatst online: 22-10-2025
Ik heb mijn timings nog eens aangepast maar ik krijg m'n corsair twinx 2014-pc3200LL niet op de gespecificeerde timings lopen.
De timings waarop Windows wel wil opstarten is: 2-7-3-2
Andere timings zoals 2-2-2-5 en 2-2-2-6 (2-2-2-6 is gecertificeerd by corsair(staat ook op mem reepjes)) werken bij mij NIET. Totale crash bij laden Windows XP
Toch vind ik dit vreemd omdat ik veel mensen zie met timings als 2-2-2-5 en 2-2-2-6 met hetzelfde geheugen :(
Ik ben benieuwd op ABIT deze problemen nog gaat oplossen met een bios opdate.
/EDIT/
Weet iemand of het schadelijk is om je 2.4C continu op 3.0GHz (12x250) te laten lopen ?
Mijn temps zijn @ 2.4C 39 idle en 60 stressed
Mijn temps zijn @3.0Ghz 40 idle en 65 stressed
[ Voor 16% gewijzigd door M289 op 23-05-2003 10:22 . Reden: nfo ]
  • MrDirect
Trigger, werkt het ook niet als je het voltage iets verhoogt naar bv. 2.65 of 2.7 volt?
  • M289
Vatt schreef op 23 May 2003 @ 10:23:
Denk je dat dat zou werken ?
Volgens mij staat het geheugen nu op 2.6V
Weet iemand wat voor Voltage het Corsair LL geheugen max. aankan of nodig heeft ?
  • M289
Tr1gg3R schreef op 23 mei 2003 @ 10:35:
Dat noem ik nog eens een tip :)
Ik heb mijn vDDR op 2.65 gezet en nu draai ik mijn mem op 2-2-2-5 :)
_/-\o_ Thank you oh great Vatt _/-\o_
  • Remco20
np Pheno79 :)
Zo te zien is er nu een nieuwe bios te downloaden :D Het gaat om bios 1.3 die hier te krijgen is:
ftp://ftp.abit.com.tw/pub/download/bios/ic7-g/ic713.exe
New Fixes/Features
lost and resumed.
9. BIOS Compile Date: 5/19/2003.
Niet echt veel bijzonders op het eerste gezicht...
[ Voor 3% gewijzigd door Remco20 op 23-05-2003 13:21 ]
Mijn IC7-G ligt vandaag op het postkantoor. Straks na het werk even ophalen. Ik ben van plan er een 2.4c en 2x256 Corsair XMS3500 op te prikken en er 2 x 120GB SATA van Maxtor aan te hangen. Dat wordt dus lekker sleutelen in het weekend. 8)
Wat ik graag zou willen weten is hoe de Northbridge heatsink vast zit op het bord. Ik heb thuis een passieve Zalman Northbridge koeler klaar liggen maar vraag me af of die mooie blauwe fan op dit bordje wel zonder problemen te verwijderen is. Zit hij vast met push-pins? Wat ik ervan gezien heb op foto's, is dat het een soort veer-mechanisme is. :?
  • Remco20
Yup deze is gewoon te verwijderen. Er staat een topic over op het Abit forum :)
Hier een linkje met pics van iemand die een zalman cooler op de NB heeft gezet:
http://forum.abit-usa.com...&highlight=zalman+AND+ic7
Remco20 schreef op 23 May 2003 @ 13:32:
OK, bedankt! Precies de info die ik nodig had! _/-\o_
versie 1.3 lost mijn vreemde bios bug gelukkig op ! was erg vaag, kon misschien 1 op de 6 keer in het bios komen en anders zag ik alleen een enkel blauw balkje.
  • M289
Remco20 schreef op 23 mei 2003 @ 13:17:
np Pheno79 :)
New Fixes/Features
lost and resumed.
Is dit wel een officiele bios release ? Ik kan hem namelijk nog niet op de ABIT site vinden. ( http://www.abit.com.tw/ab...erBoard&pMODEL_NAME=IC7-G )
Heeft iemand hem al geinstalleerd ? En wat zijn de resultaten ?
P.S. Mijn systeempje draaid nu echt verschrikkelijk snel en stabiel.. _/-\o_ hulde aan ABIT en GoT _/-\o_
yep hij is wel degelijk officieel, heb hem zelf bij www.abit.com.tw vandaan gehaald ipv link.
  • M289
Verwijderd schreef op 23 May 2003 @ 17:22:
Bedankt..
Ik heb hem net geflashed en ik merk geen grote verschillen.
(Nog steeds stabiel, snel, snel en stabiel :D )
  • Remco20
lol, dat klinkt goed Tr1gg3R :)
De kansen voor deze week zijn verkeken :(, zal dus wel begin volgende week worden voordat ik mijn IC7-G kan afhalen.
  • M289
Remco20 schreef op 23 mei 2003 @ 18:02:
Spijtig...
Waar heb je hem besteld ?
  • Remco20
Bij Yorcom, vorige week dinsdag samen met nog wat andere onderdelen besteld.
Het probleem is dat de Kingston pc3500 nog niet binnen is. Ach ja, ik houd het nog wel even uit :)
  • M289
Remco20 schreef op 23 May 2003 @ 19:03:
Ik d8 al.
Ik heb mijn ABIT IC7-G en WD Rapor beide bij Yorcom gehaald en die waren met 1 dag in huis (woensdag raptor besteld en donderdag binnen, het mobo had ik al besteld en gevraagd of ze dat pas de 21e zouden versturen :) )
Mag ik vragen waarom je voor het Kingston geheugen hebt gekozen ?
krijg alleen die usb2 niet aan de praat, hoe hebben juliie dat gedaan ?
op wat voor FSB draai je nu Trigger ?
  • Remco20
Tr1gg3R schreef op 23 mei 2003 @ 19:59:
Ik d8 al.
Het zit zo: Het is een pc-privé project waarvan ik een bon nodig heb. Daarom bestel ik liever alles bij 1 shop en zet het vervolgens zelf in elkaar. Aangezien ik alleen maar kingston zag staan (en op de forums las dat dit goed geheugen is), ben ik voor dit geheugen gegaan :D
  • MrDirect
Ik schreef op 22 May 2003 @ 22:38:
Remco20 schreef op 23 May 2003 @ 13:17:
New Fixes/Features
Hmmm, zou het gefixt zijn? Ik heb nog niet geflasht, ga gelijk even proberen.
  • M289
Verwijderd schreef op 23 May 2003 @ 20:09:
Hey EPO,
Je eerste vraag:
De USB (2.0) krijg je aan de praat op de volgende manier:
Deze Computer -> Eigenschappen -> Hardware -> Apparaatbeheer -> USB Device (wat dus nog niet geinstalleerd is ) -> Eigenschappen -> driver (opnieuw) installeren.
En dan laten zoeken naar een driver (Automatisch de beste driver zoeken en installeren o.i.d.)
Als je SP1 (Windows XP) geinstalleerd heb vind hij nu een microsoft driver. Dit is de juiste USB driver.
LET OP! je moet altijd eerst sp1 installeren. (op ABIT site staat beste volgorde voor installeren systeem b.v. 1. Windows 2. SP1 3. intel inf 4. pat 5. etc. etc. etc.)
Klaar is Kees!
Je tweede vraag:
Ik draai op het moment op een fsb van 800MHz (200x12) omdat ik nog niet weet of het schadelijk is om altijd op de 1000MHz fsb te draaien (250x12 = 3GHz en 1GHz fsb)
Kan iemand daar uitleg/informatie over geven ?
Thanx
tja, met overklokken hebbie altijd een risico, echter heb ik nog nooit problemen gehad dus het zal wel meevallen denk ik zo. tx voor de usb tip, lukt nu idd, had het automatische gedeelte nog niet geprobeerd, dacht dat ie dat altijd zelf wel kon en anders je het eigenlijk alitjd handmatig moet doen.
[ Voor 36% gewijzigd door Verwijderd op 24-05-2003 02:29 ]
  • Pheno79
En nog een review: http://www.extremeoverclo...rboards/ABIT_IC7-G_1.html
Ik kan de nieuwe bios niet vinden, maar ik heb geen haast :)
  • Sir_Killalot
  • Laatst online: 25-11 02:54
Zijn die SATA naar IDE converters ook los te koop zodat je op beide SATA kanalen een IDE device kan aansluiten ? :)
En wat is nou het grote verschil tussen de IC7 en de G versie, alleen de SATA RAID optie :?
  • Chakotay
  • Laatst online: 27-11 19:39
Chakotay
Lick here to continue
Hm, dit plankje lijkt best leuk speelgoed in combinatie met een 2.4C... Ik moet me erg inhouden om niet een keer aan een P4 bak te gaan beginnen naast mn AMD OC-spul :)
Mensen die me willen overhalen om weer eens aan Intel te beginnen (het laatste wat ik van Intel in mn systemen heb gehad is een P166MMX ), be my guest :)
Sir_Killalot schreef op 24 May 2003 @ 14:31:
IC7-G heeft een 2e SATA controller met 2 extra kanalen en RAID 0/1 functie en Gigabit Ethernet dat direct in de southbridge hangt.
[ Voor 35% gewijzigd door Chakotay op 24-05-2003 15:47 ]
Stichting eth0
  • Sir_Killalot
Chakotay schreef op 24 May 2003 @ 15:45:
De G versie heeft dus eigenlijk 4 SATA kanalen ? :)
Kan je die ook alle 4 los gebruiken ?
  • Chakotay
Chakotay
Sir_Killalot schreef op 24 May 2003 @ 15:53:
Yup :)
Als je de RAID functies uitzet kan je er gewoon 4 losse schijven aan knopen.
Stichting eth0
  • Sir_Killalot
Chakotay schreef op 24 mei 2003 @ 16:36:
Yup :)
Jammer dat er dan maar 1 converter bijzit :(
  • M289
Sir_Killalot schreef op 24 May 2003 @ 16:37:
Dan koop je toch gewoon 4 Western Digital Raptor schijfjes ?
En dan hang je aan de ATA 100 poort gewoon een 120GB schijf voor opslag.
Geloof me je zult er geen spijt van krijgen :)
  • Sir_Killalot
Er staan nog geen pics bij van de MediaXP die je op het mobo kan aansluiten, zal ff een paar mooie pics plaatsen :P
Afbeeldingslocatie: http://www.tweakers.net/ext/f/1255/full.jpg
Afbeeldingslocatie: http://www.tweakers.net/ext/f/1254/full.jpg
Afbeeldingslocatie: http://www.tweakers.net/ext/f/1256/full.jpg
pricewatch: Abit Max Media XP bracket
  • Sir_Killalot
Tr1gg3R schreef op 24 May 2003 @ 16:40:
Ja, ik ga er gelijk ff 4 halen, die dingen kosten toch bijna niks 8)7 |:(
  • MrDirect
LOL @ killalot :P
Heeft iemand al de moeite genomen om elke BIOS setting uit te pluizen?
Welke settings de beste prestaties opleveren, bedoel ik dus.
Er zijn er zo ontzettend veel, daar ben je wel een tijdje mee bezig.
Ik heb er zelf al een paar getest met de Sandra UNbuffered memory bench en mijn snelste settings waren:
• Refresh Cycle Time: Strengthened
• Command per Clock: Enable
• Performance Mode: Fast
Die andere 2 settings die ertussen staan heb ik op 'AUTO' gelaten, ik heb geen idee wat die doen, en het werd ook al laat gisteren.
  • Chakotay
Chakotay
Handig ding die MediaXP, maar ik vind em persoonlijk wel erg lelijk...
Stichting eth0
  • M289
Weet iemand eigelijk welk koelblok je het beste voor de 2.4C kan kopen ?
Ik kijk op het moment naar een Swiftech MCX4000 i.c.m. een papst of Enermax maar ik weet niet of die wil op het mobo pas.
Iemand ervaring met andere koelblokken dan de boxed koelers ?
/EDIT/
Weet iemand of het nuttig is om een Zalman ZM-NB32J op de SouthBridge van de ABIT IC7-G te zetten ?
Ik ben van plan om de NorthBridge ook met een ZM-NB32J te gaan koelen dus dan wou ik ze gelijk alletwee "beplakken" met Zalman :)
/EDIT/
[ Voor 34% gewijzigd door M289 op 24-05-2003 19:41 . Reden: tsja ]
  • Remco20
Tr1gg3R, misschien heb je hier wat aan:
http://forum.abit-usa.com...read.php?s=&threadid=9578
[ Voor 10% gewijzigd door Remco20 op 24-05-2003 21:08 ]
Ik heb hier een raar probleempje met m'n Abit IC7-G.
Ik heb een convertor meegeleverd met de IC7-G + nog een convertor die bijgeleverd wordt met een NF7-S(rev2.0).
De print van de convertors is verschillend, de ene bruin, de andere groen en de componenten bevinden zich ook op een andere plaats op de print.
Nu m'n probleem;
Convertor 1 (bruine print) werkt op Sata1&2(Onchip Intel), maar niet op Sata3&4(Onboard Silicon Image).
Convertor 2 (groene print) werkt niet op Sata1&2(Onchip Intel), maar wel op Sata3&4(Onboard Silicon Image).
Nu wil ik 2 WD's 120JB in raid0 gebruiken, maar zal dus niet lukken :'(.
Ik wist dus ook niet dat er 2 verschillende soorten convertors bestonden.
Ook weet ik niet welke convertor er bij welk mobo hoorde (groen of bruine print-convertor).
Kan iemand dit bevestigen of misschien een oplossing weet?
  • DaRKie
  • Laatst online: 27-11 13:50
Ik haal met 3dmark03 maar 1127 3dmarks
is dit niet weinig?
Ik heb een P4 2.6@3.2(fsb800) met 512mb-pc3200 op een IC7 zitten + een 9500pro
  • MrDirect
Bij mijn IC7-G zit een zwarte converter, niet bruin.
  • Sir_Killalot
DaRKie schreef op 24 mei 2003 @ 23:01:
is dit niet weinig?
Voor dat soort dingen moet je in dit topic zijn: Help !! Mijn 3dmark score is laag... hoe te verhogen ?
Je moederbord heeft niet echt veel invloed op de score ;)
  • Chakotay
Chakotay
Verwijderd schreef op 24 May 2003 @ 21:49:
Nu m'n probleem;
Er schijnen inderdaad 2 verschillende te zijn, de Serrilel 1 en Serrilel 2... Waarvan de 1e niet goed met de I875 samen zou werken.
Stichting eth0
Vatt schreef op 24 mei 2003 @ 23:01:
Ik bedoel de print, niet de behuizing.
  • MrDirect
Verwijderd schreef op 24 May 2003 @ 23:05:
De print is groen.
Ik heb even zitten spelen met m'n IC7-G en P4 3.0(800)
Afbeeldingslocatie: http://www.xs4all.nl/~rvat/3900.gif
[ Voor 39% gewijzigd door MrDirect op 25-05-2003 14:41 ]
  • Remco20
nice hoor Vatt :) Je gebruikt hiervoor een Zalman cooler? Ik zag trouwens in je specs dat je onboard sound gebruikt. Hoe bevalt deze ?
  • Remco20
ahhh zag net wat info in je specs :)
Description Standard cooling on Ti4200, Prometeia cooling for CPU. No soldering, all standard stuff out of the box.
CPU Intel Pentium 4 4010 MHz
jum jum, die 4 ghz heb je ook gehaald zie ik :D
[ Voor 17% gewijzigd door Remco20 op 25-05-2003 15:11 ]
  • MrDirect
Nee, Prometeia cooling :D
Onboard sound is goed, maar ik heb ook maar simpele speakers, dus veel verschil hoor ik niet. Ik gebruik de onboard sound ook alleen maar voor games enzo.
Ietsje verder weer ;)
Afbeeldingslocatie: http://www.xs4all.nl/~rvat/3950.jpg
  • Remco20
oh, in je 3d marks resultaat staat dat je al 4ghz hebt gehaald ? :D
  • MrDirect
Yup, maar dan is die niet Prime stabiel. De 4100 haalt ie ook nog wel met 3DMark, maar ik vind dat ie altijd 100% stabiel moet zijn.
Anders telt het niet ;)
  • Remco20
Ahh daar heb je natuurlijk gelijk in Vatt :)
nog een interessante BIOS 1.3 review:
http://www.bleedinedge.co...bit_ic7_bios_1_3_pg1.html :7
[ Voor 19% gewijzigd door Remco20 op 25-05-2003 15:32 ]
  • M289
Is er al een update / nieuws wanneer er een bios update / fix komt om de temp. aanduidingen te fixen ? (ik draai nu 65Graden C stressed (3.0GHz 1000MHz fsb :) )
/EDIT/
Na de geweldige opmerking van Sir_Killalot :P heb ik m'n post eventjes aangepast.
Het moet dus 1000MHz fsb zijn :P (250x12 QDR)
/EDIT/
[ Voor 34% gewijzigd door M289 op 25-05-2003 16:13 . Reden: typo's :P ]
  • Sir_Killalot
Tr1gg3R schreef op 25 May 2003 @ 16:03:
Is er al een update / nieuws wanneer er een bios update / fix komt om de temp. aanduidingen te fixen ? (ik draai nu 65Graden C stressed (3.0GHz 100MHz fsb :) )
Zo, dus jij heb een MP van 30 ? :P
  • Remco20
die update schijnt deze week te komen... dus begin maar te duimen :D
  • Jack
  • Laatst online: 01-11 13:20
Jack
MHz Matters
05-22-2003 17:50 The temp issue on ALL Intel boards will have an update early next week
http://forum.abit-usa.com...aebb98b338&threadid=11496
[Specs]
  • M289
Mooi van die update voor het temperatuur probleem.
Maar welke koeler gebruiken de ABIT IC7(-G) gebruikers nu ?
  • Jack
Jack
MHz Matters
Tr1gg3R
jij hebt wel een lompe voeding... een Enermax EG-651P-V(E)
550 Watt toch?
Heb je dat echt nodig eigenlijk?
(Ik zit nu te denken aan een soortgelijk systeem als jou maar dacht aan een 480 Watt Antec.)
[Specs]
  • Sir_Killalot
550 Watt in een desktop PC zoals hij heeft is gewoon overkill, aan een goede 350/430 Watt merk voeding heb je genoeg :)
  • M289
Sir_Killalot schreef op 25 May 2003 @ 19:58:
Ik vind je niet meer aardig :+ (Grapje)
Nee, die 550Watt Enermax is een keer "per ongeluk" gekocht.
Kon hem krijgen voor dezelfde prijs als een 480 (of 450?) dus toen heb ik die maar genomen :)
Ben er zeer tevreden mee. Weinig geluid en stabiele lijntjes :)
Welk koelblokje ga je erbij nemen ? De Boxed koeler of een ander model ?
Ik denk zelf over een Swiftech MCX4000 maar ik weet niet of die er wel op past.
Ik gebruik tot grote tevredenheid een Zalman 6500B AlCu koeler en daarmee draai ik zonder problemen m'n 2.4C op 3GHz. Heb nog niet geprobeerd de FSB verder op te schroeven. Zou op zich moeten kunnen met m'n XMS3500 geheugen. :9 Temperatuur zit rond de 40-42C idle, heb nog geen stress-tests gedaan.
Het wachten is helaas nog even op de harddisks. Yorcom had per ongeluk 2 x 120GB PATA opgestuurd, i.p.v. SATA ;(. 1000x excuses natuurlijk, en inmiddels wordt eraan gewerkt. Ik hoop dinsdag of woensdag m'n SATA schijven binnen te hebben, dan kan ik met hemelvaart lekker aan het knutselen :).
Een nadeel van die 6500B koeler: je kunt geen NB32J meer op je northbridge zetten, omdat de koelers elkaar dan in de weg zitten. En om die NB32J nou schuin te gaan afkorten, ben bang dat ie dan minder goed koelt... :?
Suggesties?
[ Voor 6% gewijzigd door Verwijderd op 26-05-2003 08:56 ]
Eerste testje met Sandra Pro:
P4 2.4C op 3.1GHz (FSB 260, Mem 208 @ 2-2-2-5, 2.65V):
int RAM: 5529
float RAM: 5540
CPU dhrystone: 9557
CPU whetstone: 2701 / 5660
CPU is 40-42C idle en ongeveer 50C stressed (met Zalman CPS6500B AlCU).
:9~
  • Jack
Jack
MHz Matters
Tr1gg3R schreef op 25 May 2003 @ 23:47:
Hoe duur is zon Swiftech MCX4000 eigenlijk?
[Specs]
  • Remco20
nog een review (alleen is ie duits):
http://www.dark-tweaker.com/875p-roundup.htm
zoals je kunt zien scoort de abit hier weer als de beste in vergelijking met de asus p4c800 en de gigabyte 8IK1100 :D
[ Voor 5% gewijzigd door Remco20 op 26-05-2003 17:57 ]
Ff omhoog schoppen ;)
Ik krijg de Abit IC7-G volgende week binnen voor mezelf en die monteer ik natuurlijk onder m'n waterkoeling. Voor het moment zit er nog een Abit BD7-R onder.
Maar nu had ik graag die Northbridge cooler (incl. fan) vervangen door een passieve. De enige die ik tot nu toe heb gezien is van zalman, maar die lijkt niet echt bevestigingen te hebben voor P4 mobo's.
Zijn er nog andere heatsinks op de markt voor op de northbridge, of zal ik moeten gaan voor die zalman, of eventueel zelf iets fabriceren?
  • Scighera
  • Laatst online: 11:06
Scighera
swim-bike-run
Remco20 schreef op 26 May 2003 @ 17:56:
wat een kl**e lettertype bij dat review zeg.
opmerkingen bij de abit:
-na bios update extra ram opties toegevoegd
-bij het nieuwe bios worden de geheugentimings daadwerkelijk overgenomen, en is dit te zien in de benchmarks (was eerst niet het geval)
www.triathlete.nl
  • erikdeperik
  • Laatst online: 25-07-2024
ik ben een n00b op int€l( :+ )gebied
ik zit er aan te denken om van amd op intel over te stappen,en zat te denken aan dit mobo.
ik wil dan een 2400 >800fsb p4 kopen.
dus een paar vraagjes
1:ik zie steeds p4 2.4 C staan is dat deze
2:zitten er gaten rond de socket voor watecool blokje
3:ik heb 1 reepje corsair xms 3500, moet er een bij voor dual channel
4:wat is het verschil tussen de versie met G en zonder G
tips zijn van harte welkom ,ook voor het overklocken :Y)
edit/
idd tijdje niet gelezen :|
Ka_ka_rot schreef op 29 May 2003 @ 19:15:
antwoord op:
3) "Dual channel" wat denk je? :)
ik bedoelde hiermee of het nodig is dual te draaien,of kun je ook single,en wat scheelt het :)
[ Voor 33% gewijzigd door erikdeperik op 30-05-2003 09:45 ]
ik zeg maar zo "zeg maar niks"
  • Kakaroto
  • Laatst online: 15:37
erikdeprik schreef op 29 mei 2003 @ 18:55:
antwoord op:
1) Ja P4 C is met 800FSB (P4 met B is 533MHz)
2) Ja op de meeste moederborden zit zon bracket op, dat kan je weghalen.
4) Kijk eens op de site van Abit. veel plz met zoeken. :)
  • BalusC
BalusC
Carpe diem
erikdeprik schreef op 29 May 2003 @ 18:55:
Lees de sticky eens door: Abbadon in "Dit graag lezen eer je post *updated!*" B)
[ Voor 6% gewijzigd door BalusC op 29-05-2003 22:52 ]
  • Dark
  • Registratie: September 1999
  • Laatst online: 10:02
Dark
who tweaked the light?
Dit bordje (de ic7-g) ga ik ook ff proberen, ik heb besteld, en verwacht em vandaag binnen. Ik heb een p4c-2.8, 2 repen corsair 3200LL, en 2x maxtor d-max+ sata schijven om erop te prikken, dus dat wordt fijn spelen dit weekeind...
Het zal me benieuwen hoe de prestaties zijn tov mijn huidige systeem, een nforce2/tbred-b 2200mhz/200fsb, een lekker bakje, maar wat lawaaiig ... de sata maxtors heb ik al wel even met de onboard (sil) sata van de a7n8x geprobeerd, en dat loopt al lekker.
pics maxtor sata raid0 benchies op a7n8x
http://darkforce.dyndns.org/pics/sata/atto.jpg
http://darkforce.dyndns.org/pics/sata/hdtach.jpg
http://darkforce.dyndns.org/pics/sata/san1.jpg
Zou het op de i875 nu nog beter lopen, zit de onboard sata van de ic7-g via de systeembus of de pcibus verbonden?
  • MrDirect
Mijn benches van de Maxtor's zijn precies omgekeerd aan die van jouw.
Dus jouw READ scores zijn mijn WRITE scores en vice-versa.
Verder is de Silicon SATA controller via de PCI-bus verbonden en de Intel ICH5R via de systeembus. In theorie zou die Intel dus wat sneller kunnen zijn.
Verschil heb ik niet getest, mijn Maxtors heb ik gelijk via die Intel controller aangesloten.
Hoe veel ide apparaten kan je op de IC7 aansluiten krijg het maar niet voor mekaar om mijn sata schijf aan de praat te krijgen.
  • DaRKie
Verwijderd schreef op 30 May 2003 @ 20:45:
je kan 4 ide aparaten aansluiten ALS je geen sata apparaat aansluit
Als je een sata hd wilt gebruiken, moet je in de bios instellen dat de sata controller fungeert als ide1 of ide2 (of ide3 maar dit is dan enkel voor raid-config)
Dus, als je sata en ide samen gebruikt op dit mb, dan moet je 1 ide omruilen voor een sata aansluiting
  • MrDirect
Ik geloof 6:
2 SATA op de Intel ICH5R
2 SATA op de Silicon Image SATA controller
2 IDE op de standaard IDE poort.
1 floppy
4 IDE devices + 2 on-chip SATA RAID
First hand, there is DEFINITELY support for 6 IDE/SATA devices, so the person on another board who reported 4 total devices on IC7 obviously needed to read the manual I have just connected 4 IDE devices and 2 SATA as a RAID with i2S serial ATA to IDE converters. The confusion was apparently with the setup of the on-chip SATA controller. You must select 'manual', then assign the drives as Master 3, and Master4 for them to be bootable. You then enable SATA RAID, and set it up in boot bios just like other boards. There ARE options which apparently allow you to map SATA to IDE ports.
[ Voor 72% gewijzigd door MrDirect op 30-05-2003 20:53 ]
aha dat is dus het probleem dacht dat de sata afzonderlijk werkte , das jammer heb een dvd speler een dvd-brander een mobiele hd en een tweede interne hd heb dus eigelijk vijf dingen.
Als ik er dus een schijf bij koop en gebruik de raid op het board kan het dan wel.
Wat ik me eigelijk afvraag kan je de raid niet met 1 schijf draaien dan zou ik al de vijf dingen wel kunnen gebruiken.
  • MrDirect
Afbeeldingslocatie: http://www.xs4all.nl/~rvat/fsb.jpg
Review op http://www.legitreviews.com
[ Voor 22% gewijzigd door MrDirect op 31-05-2003 00:52 ]
  • Scighera
Scighera
swim-bike-run
de revies zijn zo verschillendend. een site kreeg de MSI 875 Neo op 271MHZ, terwijl een nader deze maar op 241 kreeg.
Dit geld ook voor de ABit. Tom kreeg deze plank nauwelijk overgeklockt)
www.triathlete.nl
  • Pheno79
Wie luister er nog naar Tom :)
Die gast heeft een oude BIOS gebruikt, die problemen had met memory timings etc. Elke computern00b weet dat je altijd op de paginas van je hardwarefabrikanten moet kijken voor updates of problemen, maar nee, Tom hoeft dat niet...
Maar de verschillen die je ook noemt, zullen ook liggen aan het gebruikte geheugen. Dat kan erg veel verschil uitmaken. 512 modules zijn bijvoorbeeld minder ocbaar dan 256. Dus het kan goed dat die 241mhz die je noemde 512mb modules waren, die 271mhz 256 modules. En dan ga ik nog niet beginnen over de verschillen tussen merken. Winbonds zijn over het algemeen beter ocbaar dan anderen. Het is dus erg fijn als reviewers het gebruikte geheugen erbij zetten, anders weet je eigenlijk nog niks.
Heb nu ook een IC7-G en een 2.4c draai nu op 3.1 ghz
aleen bij de strakste mem timing wil ie niet booten, (2x 512 corsair XMS 3500)
wat zijn jullie settings? (Draai met de 1.3 bios)
ff wat benches
trouwens staat ook bij jullie sisoft sandra dat HT niet aanstaat of niet word supported is
bij de CPU bench??
ik ben van amd weer naar intel gegaan, zonder windows xp opnieuw te instaleren
, het werkte namelijk (vreemd genoeg) meteen, (wel driver ed geinstalled)
MEMORY
http://picserver.student.utwente.nl/getpicture.php?id=135400
CPU
http://picserver.student.utwente.nl/getpicture.php?id=135405
CPU-Z
http://picserver.student.utwente.nl/getpicture.php?id=135406
edit: benches geupdate draai nu op 3.2 8)
[ Voor 7% gewijzigd door Verwijderd op 31-05-2003 17:41 ]
Ik had hetzelfde probleem. Ik heb nu 2 x 120GB Maxtor SATA, 1 x Maxtor PATA, 1x DVD-ROM PATA en 1 x CDRW PATA. Ik heb SATA geconfigureerd als IDE3 en 4. Het probleem is dat de ICH5R de schijven ALLEEN ziet als ik hem bootstrap met 800MHz PSB EN ik de PCI/AGP fixed op 66/33MHz zet.
Iemand enig idee waarom? 8)7
Ook kan ik volkomen stabiel op 250 MHz FSB draaien (2 x 256MB Corsair XMS3500 op 5/4 divider en 2-2-2-7), MAAAR... hoewel ik Sandra Pro en 3DMark perfect kan draaien weigeren sommige spellen dienst. Dat wil zeggen dat ze draaien, maar dat bepaalde zaken niet correct worden weergegeven. Ik gebruik een Radeon 9500NP die met softmod naar 9500Pro is omgezet en die draait op standaard frequenties. O-)
Om stabieler te zijn draai ik nu maar op 215MHz FSB met memory op 1/1 (en 2-3-3-7) en AGP/PCI op fixed. Iets lagere benchmark scores, maar wel 100% stabiel en compatible. :? Doe ik iets fout? Ik heb DRAM naar 2.7V gezet voor stabiliteit.
[ Voor 12% gewijzigd door Verwijderd op 31-05-2003 19:57 ]
OK, ik ben eruit denk ik. Heb urenlang zitten goochelen met allerlei settings (altijd 1 tegelijk veranderen!) en heb nu een stabiele oplossing. Op een gegeven moment rook ik ineens een flinke brandlucht, maar het was gelukkig de barbecue van de buren... 8)
De truc was om zowel het geheugen op SPD settings te zetten (dat is bij mijn Corsair XMS3500 2-3-3-7). Bovendien moest ik de videokaart overclocken naar 310MHz voor zowel core als geheugen.
Ik weet dat het een wazig verhaal is :'( , maar dit is de enige combinatie van instellingen waarmee alles super stabiel loopt bij een FSB van 250 MHz. :o
Mijn set-up:
Abit IC7-G, Pentium4 2.4C @ 3.0GHz, 2x256 MB Corsair XMS3500, Sapphire Radeon 9500NP @ 9500Pro, 310MHz core/mem.
Mijn benchmark scores:
Sandra CPU: 9187 dhrystones, 2595/5669 whetstones
Sandra MEM: 5103 integer, 5115 float
3DMark01SE: 13904 3DMarks
3DMark03: 3941 3DMarks
Code creatures: 2535 punten
  • Dark
Dark
de sysfan header geeft bij mij geen rpm weer, als ik er een fan op aansluit, werkt dat bij iemand anders wel?
Bij mij werk ie prima :?
  • Dark
Dark
:( als ik het draadje van mijn antec voeding op de northbridge header aansluit (en andersom dus de northbridge cooler op de sysfan header) dan nog krijg ik geen rpm op de sysfan header, wel kan ik dan de rpm van mijn voeding aflezen, dus hieruit maak ik op dat de rpm op de sys-fanheader bij mij niet werk ... da's balen... kan ik gaan rma-en voor een rotte fanheader :?
das balen!! wel weer een heel gekloot voor zoiets kleins....
Ik had ff een vraagje voor de IC7(-G) experts...
Is er een verschil tussen de IC7-G en de IC7-G Max2 Advance? Sommige reviews geven namelijk aan dat het om een Max2 Advance gaat, wat dan ook op de doos van het mobo aangeduid staat. En zo ja, wat mag dat verschil wel wezen...
  • Remco20
Verwijderd schreef op 01 juni 2003 @ 00:54:
Nop, er is geen verschil.
de IC7-G heet meen ik in bepaalde delen van de wereld IC7-G Max2 Advance
  • Intronic
  • Laatst online: 21-10 10:48
Ik krijg het bordje morgen (dinsdag) binnen samen met een P4 2.4c, ik zal dan mijn results posten. Wil zeker wel 3,3 halen met lucht, en 3,5 met water ;)
  • Dark
Dark
Ik heb wel wat problemen met de ICH5R sata zowel in raid0 als single: Onder dos werkt het nauwelijks. Als ik de silicon image gebruik is dit probleem er niet, maarja je wilt natuurlijk toch de ICH5R raid gebruiken vanwege de plaatsing op de bus.
- Dos based backup zoals ghost en driveimage werkt erg langzaam; 70 mb per minuut, dus een partitie met een systeem erop backuppen duurt een uur of meer.
- Extreem langzame boot zolang XP de drivers nog niet geladen heeft; de traagheid onder dos zie je dus ook terug in de xp-boot... het witte blokjes balkje kruipt voorbij, en het duurt lang voordat xp echt begint met laden.
- Bij een klein beetje overclocken herkent de ICH5R de schijven direct al niet meer.
- Bij het rebooten hoor je dat de ICH5R controller de power van de schijven uitgooit, met een luide klik, en de schijven evenlater opnieuw opspinnen. Soms spinnen de schijven niet op, en hangt de pc op de ICH5R biosdetectie.
- Soms worden een of beide sata schijven aan de ICH5R niet herkend, waardoor de ICH5R bios de array vernaggeld. Rebooten en opnieuw dor de sata bios wandelen, kan je de array wel herstellen, maar hij had al niet moeten beschadigen in de eerste plaats...
Mijn bord is nu retour omdat de |:( sysfan geen rpm weergeeft ... ik hoop deze week nog een nieuwe te hebben...
  • MrDirect
Je moet de snelheid van de AGP/PCI vast zetten op 66/33.
Dan zou de ICH5R wel moeten blijven werken.
Ik had hetzelfde probleem namelijk.....
Dat ie de power van de schijven gooit, vind ik ook mega irritant.
  • Dark
Dark
Vatt schreef op 02 June 2003 @ 11:52:
De ICH5R zit niet via de pci bus, maar via de syteembus. Het locken van de pci op 33 heeft dus geen invloed op de systeembus en deze controller. Als de systeembus overclocked is dan worden schijven aan de intel-sata dus slecht herkend. Voor de silicon controller zou dit eventueel wel helpen, want die zit wel via de pci aangesloten, maar heeft geen last van een paar mhz oc.
  • MrDirect
Probeer het nu maar eerst. Ik schrijf toch dat ik hetzelfde probleem had.....
Mijn FSB staat nu op 260 en de ICH5R werkt prima... dus..
/edit: hehe slow chat :P
Kan best dat je trouwens echt een brak bord had, want van jouw 6 of 7 problemen, herken ik er maar 2
[ Voor 61% gewijzigd door MrDirect op 02-06-2003 12:25 ]
  • Dark
Dark
;) ik ga het proberen, zodra ik een nieuw bord terug heb... tnx
  • NaZGuLL
NaZGuLL
Capo di Tutti Capi
New HSF on the Abit IC7-series (Anandtech).
http://www.64bits.se/recensioner/ic7-g/index2.php#1
I've seen things you people wouldn't believe, a P4 on fire at Mach2. I watched DDR-memory glitter in the dark. All those moments will be lost in time, like money down the drain. Time to spend.
  • Intronic
Ff result :
Afbeeldingslocatie: http://members.lycos.nl/cncgzone/P4%20OC/3400-klein.jpg
Dit is op lucht, boxed koeler. Ik kan ook in windows komen, i-netten, msnen op 3500mhz.. maar bij sandra slaat ie vast :P
Vcore 1,650 & Vddr 2,8. Heb er nu nog maar 1 reepje inzitten.. maar dat gaat snel veranderen :9~
Ohja het is een:
SL6WF
3312A097
Made in Costa Rica
Lekker bordje :)
[ Voor 3% gewijzigd door Intronic op 06-06-2003 13:14 ]
