[Ervaringen] GigaByte GA-7VAXP (KT400)
Pagina: 1 2 ... 9 Laatste
  • 1.997 views sinds 30-01-2008
  • Chickendorp
Post hier al je ervaringen en resultaten over je GA-7VAXP (KT400)
Vermeld ook even je revisienummer en biosversie!
Afbeeldingslocatie: http://www.tweakers.net/ext/i.dsp/1031589654.jpg
Specificatie's:
PROCESSOR
Socket A for AMD Athlon™ XP / Athlon™ / Duron™ processor
CHIPSET
Northbridge : VIA KT400
Southbridge : VIA 8235
VIA 8X V-Link architecture (533MB/s)
VIA VT6306 IEEE1394 controller
Super I/O : ITE IT8705F
Smart I/O : Winbond Smart@IO
Promise PDC20276 ATA 133 RAID controller
Raeltek 8100BL Ethernet 10/100Mb LAN controller
AC97 Realtek ALC650 6-channel sound Chip
Dual BIOS
MEMORY
Type : DDR400(PC3200) / DDR333 (PC2700) / DDR266 (PC2100) / DDR200
(PC1600) -184pin
Max capacity : Up to 3GB by 3 DIMM slots
CONNECTOR
1 x AGP universal slot (8X/4X/2X-AGP 2.0 compliant)
5 x PCI slots (PCI 2.2 compliant)
1 x FDD port
4 x UDMA ATA133/100/66 Bus Master IDE ports
3 x IEEE 1394 connectors
2 x 2ports USB 2.0 connector (by front USB ports)
1 x 2ports USB 2.0 connector (by cable with rear USB bracket)
Memory Stick / Security Digital (MMC) / Smart Card Reader connectors
2 x cooling fan pin header
REAR PANEL
PS/2 Keyboard / Mouse
2 x USB 2.0 ports
2 x COM ports
1 x RJ45 LAN port
Audio (1 x Line-in / 1 x Line-out / 1 x Mic) connector
1 x joystick
CPU SETTING
CPU FSB adjustable via BIOS (1MHz-linear)
CPU multiplier by DIP Switch
CPU Vcore Voltage adjustable via BIOS
AGP Voltage : N/A
Memory Voltage : N/A
H/W MONITORING
System health status auto-detect and report by BIOS
H/W detect and report power-in voltage, CPU voltage, and Fan Speed Support
auto detect temperature thermal shutdown function
POWER
ATX power connector
Power-off by Windows 95/ 98/ Me/ 2000/ NT/ XP shut down and Switch
BIOS
2Mbit flash RAM
AMI BIOS with enhanced ACPI feature for PC98/Win98/Win2000/WinMe/XP
compliance, Green, PnP, DMI, INT13 (>8.4GB) and Anti-Virus functions
IDE#1~#4, SCSI, LS120, ZIP and CD-ROM bootable
AC recovery ON/OFF control
FORM FACTOR
ATX, Dimension : ( 23.5 x 30.4 cm )
OTHER FEATURES
GIGABYTE patented DualBIOS™
Suspend-To-RAM (STR)
Supports USB KB/MS Wake up from S3
Poly fuse for keyboard over-current protection
  • XWB
XWB
Devver
Wat zijn die kleine gele & witte sloten helemaal onderaan? Heb ik bij andere mobo's ook al gezien.
March of the Eagles
  • The Third Man
The Third Man
The Third Jellyfish
USB1.1 en USB2.0 connectors voor van die slotbrackets, zitten erbij, je kan ze ook met de USB connectoren aan de voorkant van je kast verbinden, als die ze heeft.
  • Chickendorp
Die 2 gele blokjes zijn aansluitingen voor een USB2.0 bracket aan de achterkant.
Voor de duidelijkheid, die 3 witte links ervan zijn voor de firewire.
  • Mentalist
  • Laatst online: 23-10 03:12
Mentalist
[avdD]
Dit keer geen grappen als met de eerdere revisies van de 7VRXP die geen GF4Ti en Radeon 8500 kon hebben?
Verstuurd vanaf mijn Computer®
  • Chickendorp
Nee voor zover ik andere fora heb doorgespit niks over de GF4 en Radeon 8500 problemen gehoord.
Wel het feit dat DDR400 geheugen in principe langzamer is.
Omdat je hem niet op de 'TOP-Perfomance' kan zetten in het bios, dan krijg je vastlopers.
Uit tests blijkt dat de KT333-versie sneller is. Ook het oc-en gaat makkelijk ed en je kunt (officieus) ook een 333mhz FSB draaien ;)
  • Chickendorp
Kan je dan ff een voorbeeld van zo'n test geven?!?
Ben nog niet tegen gekomen dat je met de KT333 beter kan overklokken. Of het moet percentueel zijn. Maar dat is natuurlijk logisch.
  • fredkroket
Ik zit te twijfelen tussen dit bord en een EPoX 8k5a2+. Die epox heeft de kt333 + 8235 chipcombi. Vrijwel gelijke opties, alleen deze heeft Dual Bios en Firewire, die epox heeft zo'n heerlijk ledje.
Ik weet het niet, adviezen!
  • Chickendorp
Nou ik heb nu een MSI K7T met van die ledjes, maar daar werd je weinig wijzer van.
soms klopten de foutmeldingen helemaal niet met het werkelijke probleem.
Zou er niet teveel waarde aan hechten.
En trouwens op die Epox zit dus een KT333 chipset, dit gigabyte een KT400.
Maar de meningen over de kwaliteit van de KT400 zijn verdeeld begrijp ik.
  • Dezjay
  • Laatst online: 21-10 16:12
Wordt ik dan echt de eerste dit vandaag (hopelijk) dat bordje binnen krijg? Ik weet dat een kt333 met ddr333 sneller is als een KT400 met DDR400 maar heb ik dit bordje gekocht om ervoor te zorgen dat ik over 6 maand niet weer een nieuwe moet kopen.. Dan ken ik vast wel goedkoop ddr400 kopen met bij passende cpu en dan zijn de foutjes der ook wel uit :)
  • Chickendorp
Je meldt wel ff als je hem hebt draaien he?!?
Welk geheugen heb je erbij gekocht en hoever kom je met overclocken?!?
Ook ff met benchmarks enzo.
  • Dezjay
wil hem nie overclocken..geen behoefte aan maar zal wel f reviewtje maken.. wil alle koeling vervangen door zalman spul
[OFFTOPIC POST] --> Berichtje even verwijderd
  • Dezjay
Verwijderd schreef op 16 september 2002 @ 16:42:
Wat ik wel nog vreemd vind is dat ik last heb van krakend geluid op dit R2 bord. :? Dit zou toch opgelost moeten zijn? Heb al even met de instellingen lopen rommelen maar helaas nog immer kraak en piep. 8)7
(Over het feit dat de raid controller mijn mooie nieuwe dubbel 740x-6L maxtor's niet kon verdragen en ze dus nu gewoon op IDE1 staan heb ik het maar even niet) :r
Iemand enige idee waarom het kraken blijft ??
Tijn
Hmmz... na je bios update heb je last van krakend geluid? Wel raar dat de raid conroller niet wil met die maxtors...
mijne is er nog steeds nie en morgen avond naar school :(
  • Chickendorp
Heren,
Eindelijk ok maar even het 7vaxp bordje geplaatst met een 2200+@2450. Natuurlijk wel meteen de revisie 2 genomen, geen enkele problemen met me radion 8500 (Hurray), werkt als een zonnetje.
Tijn, weet je zeker dat je het over het KT400 moederbord hebt?!?
Daar bestaat namelijk nog geen rev. 2 van.
Waarschijnlijk heb je een 7vrxp gekocht?!?
Euh....
Inderdaad heb ik het al die tijd over een 7vrxp
waar zie je KT400 staan dan ?
Oh Euh, ik snap het al (ik moet eens beter lezen)
Sorry, is laat aan het worden.
Ben een klein beetje offtopic...
  • Chickendorp
Tijn kan je ff je berichtje van hierboven dat het moederbord allerlei verschillende problemen geeft aanpassen?!?
Dit misleid een beetje.
  • Chickendorp
Tijn dat geluidsprobleem is op te lossen met de nieuwste bios.
Je moet dan de PCI latency van 64 naar 128 zetten. en klaar is Kees.......ehhh Tijn
Many Thx, ik ga het thuis vanavond proberen.
Heb de posts aangepast om verwarring te voorkomen
  • Dezjay
grr :( nog steeds niks...
toch maar es gaan bellen
  • MrMartinH
  • Laatst online: 29-07-2024
Chickendorp schreef op 15 september 2002 @ 23:40:
Als ik het niet vergeet al ik als ik thuis kom ff kijken of ik de test nog kan vinden. Gaat wel over de KT333 voor zover ik weet maar kwam als beste uit de test.
Signature
  • MrMartinH
dit is de link dus. Zijn 18 socket A mobo's getest. Probleem is wel dat de link niet helemaal wil werken soms omdat Tom's Hardware een beetje kuren heeft.
Signature
  • Dezjay
nou alst goed is komt ie vandaag....... ze hadden um alleen in gepakt en nog nie verstuurd
  • the-spawn
  • Laatst online: 16:06
the-spawn
.: Dark Storm :.
Ik heb er net ook een besteld :9~ :9~ :9~.
Heb er maar 1GB PC2700 geheugen bij gekocht.
Als da PC3200 toch niets sneller is.
Kijken wanneer hij geleverd wordt. Ik hoop snel. :9~ :9~
  • Dezjay
nou lekker... tpg rijdt net... voorbij.... argh..
Heb nog verder niemand dit bordje? ben benieuwd hoe de onboard raid is
  • CH4OS
CH4OS
It's a kind of magic
Chickendorp schreef op 15 September 2002 @ 17:34:
Dit komt allemaal omdat DDR400 nog geen standaard is / heeft en omdat de bios er ook nog niet goed mee om weet te gaan, dus het zal allemaal wel goed komen, mark my words!!
* CH4OS wil namelijk ook dat bordje hebbuh met een dikke XP erop :9~
  • ProgrammerX
  • Laatst online: 26-02-2021
Ik dacht er ook al over om dit bordje te kopen. Persoonlijk lijkt me dit het beste kt400 plankje dat er is, behalve die van abit (max bordje) dan maar die is rete duur t.o.v. de giga-byte.
Als iemand hem binnenheeft en toevallig ook een radeon bestelt heeft, laat me aub even weten of je problemen hebt. Wil dit bord namelijk i.c.m. de radeon 9700 bestellen, alleen als ik hoor dat er problemen zijn met 8x AGP dan begin ik toch te twijfelen of ik niet gewoon dit bord koop i.c.m. met een GF4 en dan later als het nodig is, pas een radeon 9700 koop.
Verder een super bord dacht ik zo :)
Hoop alleen dat ze die problemen met die 'heat protection' hebben opgelost want ik wil er graag een 2400+ bij gaan kopen.
Ben erg benieuwd naar de reacties hier :9
  • Chadi
  • Laatst online: 16-10 09:40
ProgrammerX schreef op 18 september 2002 @ 14:07:
De Abit krijg ik morgen binnen via een leverancier die hem voor 189 Euro levert. Dat is dus ongeveer 50 Euro meer dan de Gigabyte. En ongeveer 30 euro goedkoper dan de goedkoopste in Pricewatch.
  • Chickendorp
Welke is dat dan als ik het weten mag?!?
  • Dezjay
Joehoe hij is der... pakket is echt zeer compleet incl handleiding voor raid etc bordje is mooi blauw..
Goed ga nu inbouwen :)
  • ProgrammerX
Chickendorp schreef op 19 september 2002 @ 09:53:
ABIT AT7 MAX2
Review -> http://www.tbreak.com/reviews/article.php?id=143
Edit : foutje in link
  • Chickendorp
Hehe ik bedoelde juist die leverancier!!
Dat je dat moederbord bedoelde snapte ik wel.
  • Dezjay
nou ff eerste indruk.. prettig moederbord veel extra's en dat krijg je der meteen bij (firewire plaatje extra usb etc)
Onbaord raid ging bij mij in een keer goed. alleen jammer dat je zelf de drivers moet kopieren op een floppy omdat je in de winxp setup geen cdrom ken kiezen...
Ziet der goed uit en is retesnel... ik ben blij :)
  • Chickendorp
Zit er ook een firewire-snoer bij voor naar je camera?!
Want ik kan mijn Firewire kaartje voor 100 euro verkopen, en dan koop ik dus mooi dit mobo.
Maar het is mij onbekend of er wel een 4-6 aansluiting voor FireWire bij geleverd is.
  • Dezjay
Er zit geen kabel bij voor naar je camera (deze zijn ook nie altijd het zelfde.. vooral sony vind dat leuk) er zit natuurlijk wel een kabel voor firewire vanaf je mobo naar een backplate met 3 firewire aansluitingen...
Raid werkt echt heel makkelijk op dit bordje alleen jammer dat de drivers die windows XP tijdens de installatie op diskette wil hebben standaard op een cdrom staan.... Norton internetsecurtity wordt bij geleverd (demo 3 maand volgens mij)
Verder ben ik nog geen rare dingen tegen gekomen.. draai nu mijn raid 0 config trouwens met de Western Digital 80 Gb 8mb cache...
  • ProgrammerX
Dezjay schreef op 19 september 2002 @ 23:18:
Met wat van videokaart gebruik je dit bordje eigenlijk ?? En je hebt DDR333 neem ik aan ? :)
Verder makkelijk te installeren enzo, overal genoeg plaats ?
Je mag best wat uitgebreider zijn, je hoeft je niet te schamen hoor ;) ;)
  • Dezjay
Wil er nog een uit gebreide review van schrijven (huisje) Heb weinig tijd... gebruik nu nog een gf2mx kwam een klant voor een gf4ti dus ja .... en dat was de laatste :)
Maar goe ruimte is er genoeg rnd de socket ook wel.. Alleen de dimm sloten zitten erg dicht op het agp slot weet niet zeker of ik problemen gakrijgen met een gf4ti en zon nieuwe zalman passieve koeler maar goed dat weten we snel..
Gebruik idd 333ddr 512 mb geen prob... bordje is erg compleet en makkelijk in gebruik.. tekst staat duidelijk op het mobo voor leds etc en das wel fijn.. stroom floppy udma en raid zit allemaal gewoon aan een kant dis wel supermakkelijk maar maakt kabels netjes weg werken wel wat moeilijker verder draait het perfect nu ben zeer tevreden over dit bordje..
Nog meer vragen ? ;)
  • Dezjay
Hmmz... heb een enermax fan op een fan header op het mobo gezet. als je de fans op langzaam zet dan hebben ze soms de neiging om te stoppen... krijgen waarschijnlijk te weinig stroom
  • Chickendorp
Als de postbank morgenochtend heel lief is ga ik er ook 1 halen.
Waarschijnlijk gaat dit tegenvallen, maar wie weet!!
Indien dit lukt komen morgenavond bevindingen hier te staan.
  • Chickendorp
Hoeveel lawaai maakt die chipsetcooler?
Ik heb zelf laatst een Zalman NM32J gekocht omdat ik mijn huidige [scrable-mode]moederbordchipsetcooler [/scrable-mode] teveel lawaai vond maken.
Hoor je hem? en zoja waar kan je het mee vergelijken?!?
  • Dezjay
vind het wel meevallen maar vervang hem wel door die zalman.. Wil niks anders in me pc als zalman :)
  • Chickendorp
Heeft hij geen actieve koeling nodig dan?!?
Of heb je er een Zalman cpu koeler naast hangen met zo'n grote 92mm fan aan de zijkant?
Die voorziet de chipset toch ook van airflow, ze zitten namelijk erg dicht bij elkaar.
  • Spruit_elf
  • Laatst online: 29-05 11:02
Spruit_elf
Intentionally left blank
kan niet wachten tot ik hem ook heb :) :)
Those who danced were thought to be quite insane by those who could not hear the music.
  • Chickendorp
Zijn er helemaal geen mensen die grote problemen ondervinden met dit mobo??
  • Marsman83
  • Laatst online: 25-10 19:03
En heeft niemand deze in combinatie met een radeon 8500? Dr waren nogal veel problemen daarmee met het varoige bord.
Enne Dezjay, ken je ef kijken of je de mem timings kan aanpassen? Cas2-2,5 interleaving en al die andere opties? Bij een revieuw bleek dat je dat niet kon en das wel erg jammer. Zou je ef kenne checken wat voor opties je hebt voor overclocking?
  • Chickendorp
Die problemen zijn er niet meer heb ik gelezen op amdforum.
Ze hadden ook geen last meer van de GF4 die wel eens lastig deed of niet paste.
Het enige wat ik me nog afvraag is, wat voor een geheugen ik er het beste in kan doen.
Ik wil het het liefst zo goedkoop mogelijk houden tegen de beste prestatie's. (kan er alleen maar op vooruitgaan na mijn MSI K7T Turbo)
  • Dezjay
Chickendorp schreef op 22 september 2002 @ 18:47:
Ik heb r gewoon ddr333 in met een 2000xp is ook niet zo duur.. Ander geheugen heeft toch nog geen nut..
Overclock optie wat mem timings betrefd zal ik morgen ff naar kijken (ben nu nie thuis) Zit wel stukje software bij voor overclocken :)
Ik las in de manual op de giga-site dat de ddr 400 reepjes niet samenwerken met de nieuwe amd processors met een fsb van 333. Niet zo handig met het oog op toekomstige uitbreidingen.....
  • Chickendorp
Komt dat door de DDR400 reepjes of ligt het aan het moederbord?!?
Zoals ik jouw bericht lees moet het wel met DDR333 reepjes kunnen.
  • Semper Fight
  • Laatst online: 26-08 11:35
Semper Fight
Xbox Live = Semper Fight
Hey Tweakers, past op dit mobo, en de 7VRXP ook de Alpha PAL8045 Heatsink?
Met de search heb ik bijna niks kunnen vinden op deze combo.
Op http://www.micforg.co.jp/mb_inf_pal8045e.html kom ik ook niet meer.
Wie kan mij vertellen wat de bevindingen zijn?
Hier had uw advertentie kunnen staan! DM me voor meer info over de prijzen
Ligt aan het moederbord, kan idd wel met ddr 333 samen.
  • Chickendorp
Maar misschien is het dan ook met de eerst volgende Bios update op te lossen?!?!?
  • ProgrammerX
eLeCtRaBeLg schreef op 23 september 2002 @ 13:01:
Nee, helaas kun je hier geen PAL8045 of iets van watercooling opzetten simpelweg omdat er geen gaten zijn :) Daarom zie ik mij ook maar genoodzaakt te gaan voor een coolermaster HHC-001 (die met die heatpipe) ondanks dat dit veel geluid met zich meebrengt. Of heeft iemand anders nog een goede tip voor een athlon xp 2400+ die ik ga overclocken ? >:) :9~
Dit kun je ook zien en lezen bij deze review:
http://www.tbreak.com/rev...mobos&id=132&pagenumber=2
  • Cassius
Cassius
Moogles!
Welke functies heeft de GA-7VAXP allemaal bij zich ?
Heeft hij Raid, Lan, Audio, en USB2.0 bij zich --> zoja, dan koop ik deze maar eens :)
De meeste mensen deugen!
  • Dezjay
RAID ja
Audio ja
Lan ja
USB 2.0 JA
en ook firewire en dual bios
  • Cassius
Cassius
Moogles!
Damna, das dus heel wreed --> het probleem --> ik heb dus ook een Alpha Pal 8045 cooler... Das dus minder. Is zo'n goed ding ... afijn, past de Thermaltake Volcano 9 er wel op (die krijg ik namelijk ook) ???
(Ik kan niet wachten tot ik dit bordje heb :P )
en sata?
  • Cassius
Cassius
Moogles!
S-ATA zit er niet op, maar das niet zo heel erg hoor. Duurt nog wel ff voordat dat ingeburgert is :)
  • Dezjay
hoop vande week mijn gf4 ti te hebben dan zal ik wel ff wat meer posten.. loopt superstabiel en heb absoluut geen probs.. mijn wd80gb 8mbcache doet loop ook lekker in raid 0 rond de 47000/48000 in sisoft sandra
  • ProgrammerX
Misschien een beetje offtopic en eigenlijk niet bedoeld richting jou Bzrk, maar er is zo'n hype gaande over dat s-ata, ik heb pas 1 device gezien dat werkte met serial ata en dat was een demonstratie model. Veel mobo fabrikanten kiezen nu liever voor s-ata dan voor raid ata, iets dat ik zeer jammer vind en een van de redenen waarom ik voor dit bord (7VAXP) kies. Vind het zo'n onzin eigenlijk maar ja, wat doe je er als consument aan ? :/
Ga vrijdag m'n bordje bestellen, ben erg beniewd :9~ Moet misschien wel nog ff wachten op m'n amd xp 2400+, gezien de zaak dit niet in voorraad heeft :(
  • Cassius
Cassius
Moogles!
Werkt dit bord nou wel goed met een Geforce4 Ti kaart :| ???
  • ProgrammerX
marzzman schreef op 24 september 2002 @ 00:28:
Ik hoop het wel anders heb ik een probleem :)
Maar ff serieus, waarom zou ie niet werken met een geforce4 ?? Trouwens, ik heb al eens een review van dit bord gezien met een geforce4 op http://www.tbreak.com/rev...mobos&id=132&pagenumber=4. Verder heb ik ook nog nix gehoord van andere mensen, dus volgens mij werkt alles perfect behalve de radeon 9700 die misschien nog wat probleempjes zou hebben.
  • Chickendorp
ALS het probleem van de Radeon 9700 zich voordoet, hoef je alleen de AGP van 8x naar 4x te zetten in de bios.
  • Chickendorp
Verder niemand met dit moederbord?!
Sorry voor de kick >:)
  • Emcee
  • Laatst online: 25-10 17:14
ALS ik binnekort ga upgraden komt deze erin, je kunt bij deze de raid aansluiting toch ook gebruiken als extra ide aansluitingen (net als de 7vrxp)
  • ProgrammerX
Emcee schreef op 26 september 2002 @ 23:35:
Volgens mij wel ja, maar dat weet ik niet zeker.
Heb hem vandaag besteld i.c.m.:
athlon xp 2400+ en een volcano 7+
samsung 512 mb ddr ram
asus geforce4400 128 mb
2x ibm 60 gb 120 gxp
antec kast met 400 watt voeding
Laat wel ff weten wat ik eventueel van problemen tegenkom en ik zal t.z.t. ook wat benchmarkjes doen.
Ja kan de RAID inderdaad als 3e en 4e IDE gebruiken,geen punt.
7vaxp bezit raid,firewire,usb2.0,AGP8x,DDR333(3 dimm sloten) support en dual-bios (erg handig bij fout gelopen flashes) ik heb hem 2 weken terug hier online besteld.
Niet te duur met advies erbij en alles want stond nog niet op de site dus ik mailen kreeg direct reply met hoe en wat,en gleijk een radeon,xp,ddr-ram bijgenomen alles was volgende dag in huis erg toppie en snel via mails.
Na alles aangesloten en geinstaleerd te hebben heb ik wat mem.tests gedaan (Samsung DDR zit erin) en kan aardig goed tuning in het bios en blijft stabiel.
Heeft iemand al problemen gehad met dit bord??? Of juist positieve berichten.....
  • ProgrammerX
Verwijderd schreef op 30 september 2002 @ 18:34:
Ik heb eigenlijk alleen maar positieve berichten gehoord en positieve reviews gezien. Als iemand negatieve heeft, laat ze dan nu horen..dan kan ik misschien nog mijn bestelling afzeggen ;)
Heb Dram-clock op 333 Mhz gezet in de bios, maar WCPUID geeft aan 2*FSB. FSB staat ingesteld op 140 Mhz. Kan dus memory snelheid niet apart instellen.
7VAXP met DDR333 Mhz memory
  • ProgrammerX
Verwijderd schreef op 30 september 2002 @ 20:37:
Geen verdere informatie in het bios ?? Hmm, dan zou je dus alleen 333mhz hebben als je fsb op 166 hebt ?? :?
Laat ons even weten wat je hier verder over te weten komt aub :)
Ja klopt. Dan komt echter de pci freq. boven de 40 Mhz.
  • Chadi
Chickendorp schreef op 19 september 2002 @ 13:54:
www.knol-it.com
  • Pizzaman
Pizzaman
16:00 Cup-a-soup.
Wat is het verschil met de GA-7VAX :? Op de site van Gigabyte zie ik maar een paar kleine verschillen staan namelijk en het scheelt nogal in prijs.
  • Chickendorp
Op de GA-7VAX zit o.a. geen Raid en geen FireWire.
Of kunnen jullie nogmeer verschillen ontdekken?
Weer iemand of de Barton pros. op dit bord gaat werken??
  • Chickendorp
Daar ben ik zelf ook erg benieuwd naar!
Is er echt niemand die er wat over gelezen heeft.
In het Tweakers.net nieuws is er niks over te lezen.
  • Chickendorp
Hier een review met het bios dat volgende week uitkomt.
Je kan nu alle geheugenbanken vol zetten, en de RAM performance is nu nog beter!
http://www.anandtech.com/mb/showdoc.html?i=1721&p=1
  • Dezjay
Ik heb last van storing met de onboard geluidskaart... Hoor me cdrom erdoor.. is enigste min puntje tot nu toe...
  • ProgrammerX
Dezjay schreef op 07 oktober 2002 @ 10:19:
Hoor me cdrom erdoor ? Bedoel je hiermee dat je bijvoorbeeld de output van de cdrom door een ander kanaal heen hoort ??
  • Dezjay
nee.. als de cdrom opspint hoor je dit... hoor het vooral met koptelefoon.
  • ProgrammerX
Dezjay schreef op 07 oktober 2002 @ 12:11:
Dus als de cdrom opspint, hoor je een storing (gekraak?) op je hoofdtelefoon ??
  • Chickendorp
Hmm heb je je cdrom kabeltje dan wel goed aangesloten, misschien dat dat het hele probleem is.
Wat ook nog kan is dat je in geluidsbeheer, het schuifje van de cdrom naar beneden moet doen, zodat ie niets opneemt en weergeeft.
damn, ik had hem vandaag binnen gekregen, en geinstalleerd.
Hij deed het dus niet :(
Ik heb een Asus GeForce4 Ti4600, ik denk dat het daar aan ligt.
Hij deed het 1 keertje alleen toen deed m'n keyboard het niet zodat ik niet in de bios kon komen..
Ik ga hem terug sturen denk ik en ruilen voor een ander merk, alleen weet nu niet wat ik moet nemen, iemands suggesties? ;(
  • Dezjay
ProgrammerX schreef op 07 oktober 2002 @ 12:48:
Ik hoor over de koptelefoon de cdrom opspinnen. dus echt het geluid van de cdrom
Probeer het eerst even met een oud videokaartje zou ik zeggen. En zorg ervoor dat er zo weinig mogelijk in je plank zit, dit is dus alleen het broodnodige om een opstart te maken.
Verwijderd schreef op 08 oktober 2002 @ 10:36:
Hmm, geprobeert.
Werkt nog steeds niet :(
Ik denk dat ik hem terug stuur voor dezelfde..
  • the-spawn
the-spawn
.: Dark Storm :.
Ik heb ook eindelijk mijn 7VAXP.
Alleen installeer ik gisteren MBM 5. Ik alles ingesteld que temp. sensors en fan sensors. Fan sensors doen het perfect. Alleen bij de Temp. leest hij de Proc. temp goed uit, maar de temp van mobo niet?
Dan komt bij sensor2 een temp te staan van -55 en bij sensor3 ook -55. kies ik dan sensor2 diode dan ineens +80 en bij sensor3 diode ook. :?
Zou MBM dit (nog) niet ondersteunen?
  • Xavier
Ik krijg hem morgen binnen.
Mijn GA-7VRXP was kapot. En na 2 maanden gezeik krijg ik dus een nieuwe en dan meteen het nieuwste model :)
  • DeWaanzin
  • Laatst online: 14:26
DeWaanzin
Ja dat zeggen ze allemaal
Wat doen de temperaturen op dat ding?
Ik heb zelf een 7VRXP met een Xp2000 d'r op.
cpu = 47 en kast = 42 graden
Een collega heeft dit nieuwe bord met een Xp2200 d'r op
Zijn temps zijn:
cpu= 58 en kast= 45 graden
Is dit aan de hoge kant?
We hebben alle 2 dezelfde cooler , een Artic super silent pro.
XBL: theArthurrrr
  • Dezjay
Ga-7vaxp met een Xp2000 d'r op
Zijn temps zijn:
cpu= 41 en kast= 34 graden met een Zalman AL6000CU.... en 2 enermaxcase fans en een led fan..
  • BlackShadow
  • Laatst online: 15:50
een kameraad van me heeft ook net dit moederbord, zijn AMD XP 2000+ deze wordt wel 56°C met 5 casefans en een zalman 6000cu.
Is het normaal dat het core-voltage niet lager kan gezet worden dan 1.85V? :?
de airflow zit goed want de case-temp gaat niet hoger dan 30°C.
  • ProgrammerX
BlackShadow schreef op 10 oktober 2002 @ 20:02:
Volgens mij is dat voltage een beetje aan de hoge kant, dat zou ik zeker even controleren. Krijg mijn mobo pas volgende week, dus ik kan het nu niet nakijken. Ik zou zeggen, lees ff snel wat reviews door ofzo om erachter te komen of hoop op een reactie van hier :)
  • BlackShadow
Hij heeft hiernet naar de winkel gebeld, het is waarschijnlijk een fout in het mobo, het koelblok wordt bijne niet warm terwijl het programma (met 2 verschillende progs) 56° aangeeft...
  • Vrieskist
  • Laatst online: 03-04 09:28
ik heb nu ook een GA-7VAXP moederbord :) Ben er reuze tevreden over, in combinatie met een XP1800+, Ati Radeon 8500 pro en 256mb PC2100 Cas Kingston heb ik een stabiel en snel systeem (8489 3dmark2001 punten, zie ook specs in sig).
  • Ankh
  • Registratie: Mei 2001
  • Laatst online: 16:22
Ankh
.Howdy
hmm ik wil hem dus ook gaan kopen waarbij ik met een ding zit, ik lees net de review van anandtech.. en het schijnt dat ik de MP instellingen niet kan instellen?? Zelf heb ik een unlockt XP2200+, dus is mijn vraag kan ik deze gewoon gebruiken? (het is een Thotobred rev A.)
Ik krijg een koolance PC2-601BW case (waterkoeling) met dit mobo erin, daarop komt (voorlopig) een atlon xp2200+ met 512 mb DDR pc2700. gaat dit wel goed samen?
