[LCD]LCD Smartie 5.1 released
Pagina: 1 2 Laatste
  • 699 views sinds 30-01-2008
  • BasieP
  • Laatst online: 15-11 18:31
ok hierbij de officieele message:
HIJ IS UIT!!!!!!!
(eindelijk)
--> http://www.rendo.dekooi.nl/~basiep/smartie/ <-- daar dus
changes:
- I have made a checkbox for all you guys with a dial up connection. If you turn it off you don't check for a new version @ startup. This does also mean that you don't get a popup if you want to make a connection (dialup)
- Fixed Gamestats (which didn't work in 5.0)
- 20 screens instead of 10
- 10 pop3 email adresses instead of 1
- Upgraded Motherboard Monitor support (new version also works now)
- Randomize screens feature
new things:
- Winamp Status
- Network statistics (speeds, totals, errors and more)
- Weather.com support (for people in America)
- Folding@home statistics
- I made a very simple skin function so you can skin for yourself. (check the 'images' directory)
- Theme feature (which allowes you to make several 'theme's' which you can 'play' separatedly
- Resume on next line (will cut of the text that is to long for the screen, and pastes it on the next line)
- Center Text (will center the text on that line)
- Events screen where you can make your own events (i.e. skip all winamp tracks with a low bitrate, or flash your backlight 5 times when you have email
- Full support for Matrix Orbital buttons and keypads. (Also the LK404-55)
- $Counter (counts back to a specific day or time)
- $dll() (support for plugins)
- $Count() (Counts several, not limited, decimal values together)
- $Right() (alligns a small peace of text to the right)
- $Flash() (let't the text between the brackets flash)
- Lots of small and big bug fixes (i.e. the shutdown bug; Thanx supressor)
This message was sent on 100% recyclable electrons.
  • Der_Rudy
  • Laatst online: 06-09-2022
Der_Rudy
Thats me....
Very Nice
Keep up the good work..
ziet er goed uit jongens..
www.haller.nl nu op een Compaq Proliant DL380 2xPIII 933MHz / 1GB / Smart Array controller / Raid 5 met 8 stuks 36,4 en 4 stuks 18,2 GB schijfjes... en draaiend achter een APC 2200 UPS
  • DaRuLe
DaRuLe
Rauður, Hvítur, Blár!
_/-\o_
Per-fect!
En in Delphi natuurlijk :) Alleen al daarom een dikke 10!
Ég er eins ánægður og ég get orðið.
  • BasieP
koninklijk meervoud vind ik liev enzo.. maar behalve erg veel dankz naar teabeats voor de parallel driver heb ik alles selluf gedaan
ik ga hem meteen testen :)
wow skinnable smartie :D
vedder ziet hij er mooi uit :)
BassieP:
dealtje sluiten over een mooie website+hosting?
en je bent een feature vergeten te maken :'(
de screens met tabbladen ipv met zoon dropdown menu.
dit werkt heel langzaam, en je moet ook onthouden welk scherm je zat voordat je de setup sloot(makkelijk tijdens config)
vedder ziet het er :9~ uit!
  • BasieP
Verwijderd schreef op 16 augustus 2002 @ 22:48:
BassieP:
waarzo?
lcdsmartie.kingofdos.com(tegen betaling van 15$ krijg je een domain(.com of .net), maar dat moet je zelf beslissen, webruimte regel ik wel, ik kan onbeperkt domain's instellen dus no problem).
10mb
onbeperkt traffic(nouja als het echt veel te veel word zeg ik er iets van, ik heb 60GB traffic in totaal dus no problem).
PHP support
etc.etc.etc.
enne, is het mogelijk om stats van een andere website af te halen?
ik wil de stats van ccmod.com
als je een of ander systeem nodig hebt(file met ieder uur nieuwe gegevens), maak ik dat wel.
tja kan wel iets als scripter van ccmod hé ;)
  • BasieP
nah ik denk dat ik het maar ff over laat gaan, als ik me bedenk weet ik je wel te vinden.
ik verdien natuurlijk niks aan smartie, dus heb ook weinig zin om d'r wat aan uit te geven ("als je begrijpt wat ik bedoel" - Heer Ollie)
Over die stats.. schrijf een dll zou ik zeggen (dat kan nu)
BasieP schreef op 16 augustus 2002 @ 23:07:
dat merkte ik ;)
ik zie hier ook al wat error's tevoorschijn komen :P
$NetSpDownK(1) <= doet niets?
$NetDownM(1) <= error1)
$NetAdapter(1) <=niets?
$NetPackTot(1) =< error1)
en zo wel meer error's, vooral die netwerk dinges.
ik draai WinXP Prof.
  • Karel2001
  • Laatst online: 03-06-2022
Tof, ik zie dat de shutdown bug eruit gehaald is maar ik krijg die foutmelding ook abij het opstarten (shortcut naar smartie in startup)
verder draai ik smartie 5 al weer een paar maanden naar volle tevredenheid!
he GB aanduiding :)
  • BasieP
KingOfDos: probeer 2 is
of 3
(zou niet moeten mogen maarja 't is windows)
BasieP schreef op 16 augustus 2002 @ 23:22:
of 3
reageer ff @ icq
ik zie zowat alleen maar bugs @ windows XP
ik begin bijna te denken dat het allemaal BUG's zijn.
$HDTotag(C) werkt niet
alle andere dingen over de hdds ook niet.
netwerk werkt nix van.
gamestats werken niet(nouja ik vul het ip van een CS server in en heb hem op halflife staan, doet nix).
ik ga nu ff mbm testen.
ok ik geef hier een full list van wat er allemaal niet werkt:...
$DutchWeather (f1)
$T.netHL (f1)
$TomsHW (f1)
$Stocks (f1)
$CNN (f1)
$Weather.com(CAXX0504) (f2)
$HDFree(C) (f1)
$HDUsed(C) (f2)
$HDTotal(C) (f1)
$HDFreg(C) (f2)
$HDUseg(C) (f2)
$HDTotag(C) (f2)
$HDF%(C) (f2)
$HDU%(C) (f2)
$HDBarF(C,10) (f3)
$HDBarU(C,10) (f3)
alle netwerk dingen werken niet(of f1 of f2)
(f1) = laat niets zien op die regel....
(f2) = laat de regel zien die je hebt ingevuld, net of hij dat ding niet kent
(f3) = errorC,10)
niet dat ik het mis, want ik gebruikte het toch nooit.
maar nu het er in zit wil ik het toch hebben(vooral de hdd en netwerk, hdd had vroeger geen GB ondersteuning, das leuk met 80gig)
enne nog een vraagje:
"-register" writes all data to "HKEY_LOCAL_MACHINE\SOFTWARE\LCDSmartie\"
[ Voor 0% gewijzigd door Verwijderd op 17-08-2002 00:24 . Reden: meer bug's ]
Ik zou em in de meuktracker van T.net zetten BasieP!
  • Stealth2000
  • Laatst online: 17-11 15:10
Geweldig al die functionaliteit... sed1330 support ? ;)
hier werkt hdd space network en game stats niet... :( verder wel nais.. vooral dat flashing roeleert ..
Verwijderd schreef op 17 augustus 2002 @ 00:30:
zeker ook windows xp?
jups.. terwijl in 5.0 alle shet deed behalve.. gamestats..
Dubbelpost :(
hier een blauw scherm als ik het winamp schermpje opengooi
Verwijderd schreef op 17 augustus 2002 @ 01:08:
en netwerk stats, die had BassieP niet in 5.0 gemaakt, daarom vind ik dit vooruitgang.
als de bugs uit netwerk+hdd+gamestats zijn dan is het nog beter
ik heb nu alleen hdd niet in gebruik mbt vorige smartie.
goed nieuws, BassieP ik weer voor een stuk waar de bug zit.
tijdens het setuppen pakt hij mooi iedere keer dat schermpje, dat moet je refrechen EN.... hij geeft tijdens het editen niet de netwerk dingen weer.
ik denk ook dat het zo bij de rest werkt ;)
dan moet je dat even fixen, maak dan ook meteen, zodra je het scherm aanpast dat hij dan de gegevens refrechd.
ik zeg ook niet dat het slecht is.. het is bedoelt als uh hoe zeg je dat ... nahja niet lullig bedoelt vind het heel goed waar die jongen mee bezig is
:) petje af :) niet iedereen kan proggen :+ wacht wel op verbeterde versie :) doe nu zolang maar zonder temps enz
temps werken wel(MBM natuurlijk wel aan hebben staan), maar in het preview scherm werken ze niet.
zelfde geld voor netwerk stats, die werken ook niet in de preview scherm.
harddisk dingen werken helemaal niet :'(
dat scheelt al weer wat bugs.
dus BassieP, het preview scherm(netwerken, fan's en temps) werken niet, en zorg ook voor een refrech in het preview systeem, ook makkelijk.
al sik um ana het doet ie het ook niet en heb mbm 5.1.0.7 altijd aan staan...
allemaal netjes 0 0 0 0
en netwerk ook ...
en snap ook nie hoe dat is gedaan met die schempjes... 1|1 1|2 2|4 :? ben ik nu zo dom..
Verwijderd schreef op 17 augustus 2002 @ 02:01:
en netwerk ook ...
ik heb net 5.1.9.1 er op gezet, die werkt goed ;)
1 voor de | is de theme
1 na de | is het scherm
ik weet alleen niet waarvoor theme is :P
gamestarts werkt!!!
moet je wel buiten de setup kijken, zelfde geld voor netwerk, temp's, fan's maar hellaas niet voor hdd's.
[ Voor 0% gewijzigd door Verwijderd op 17-08-2002 02:08 . Reden: gamestats ]
netwerk loopt hier.. ff nieuwe mbm doune..
kijke of da helpt..
hoe heb je dat met gamestats gedaan.. kreeg net met UT 4 lijnen met ERROR hehehe
Verwijderd schreef op 17 augustus 2002 @ 02:13:
kijke of da helpt..
eerst moet je de server ip hebben(of net hoe je connect met de server).
je klikt op tab gamestats => klikt op de regel die je wilt gebruiken => zet het goeie ip/domain er op => zeg welke gegevens je wilt zien => toevoegen.
als het nog niet werkt, dan ff msn/icq ;)
game stats werkt wel... moet alleen ff w88 (en volgens mij ook niet te korte refresh tijd zetten), hdspace dingen werken deels, -> zolang je het in mb's laat aanduiden doet ie et wel, netwerk support doet het ook gewoon moet alleen ff uitvinden welk adapter nr jouw netwerk (tcp/ip) traffic afhandelt... alleen jammer dat je geen intern/extern ip's kan laten weergeven
zal het proberen tenx voor de tip van mbm :) maar als ik nou een eigen server start gewoon mijn ip??
Verwijderd schreef op 17 augustus 2002 @ 02:32:
watvoor server?
web/ftp/game?
owja, gameserver moet je gemiddeld 4kb/s download en 4kb/s upload rekenen(bij HalfLife, ik denk ook bij andere games) per persoon die op je server zit.
dus 4 man = 4x4=16kb/s download en upload ook 16kb/s
bij @home kan ik dus geen server draaien :(
  • D3LTA
  • Laatst online: 12-11 19:21
Werkt hier perfect hoor (winxp prof.) snap alleen niet waar die theme's voor zijn :S maar zal wel aan mij liggen
D3LTA schreef op 17 augustus 2002 @ 02:51:
ik merk het.
het is dus de functie 'preview' die laat zien wat je aan het editen bent.
zuur, de GB functie werkt maar voor 50% :S
  • BasieP
*zucht*
KingOfDos, bij mij werken dus van jouw lijst:
$DutchWeather (f1) wel
$T.netHL (f1) wel
$TomsHW (f1) wel
$Stocks (f1) wel
$CNN (f1) wel
$Weather.com(CAXX0504) (f2) wel --voor al deze dingen moet je gewoon wat geduld hebben (afhankelijk van je verbinding)
$HDFree(C) (f1) wel
$HDUsed(C) (f2) wel
$HDTotal(C) (f1) wel
$HDFreg(C) (f2) wel
$HDUseg(C) (f2) wel
$HDTotag(C) (f2) wel
$HDF%(C) (f2) wel
$HDU%(C) (f2) wel
$HDBarF(C,10) (f3) wel
$HDBarU(C,10) (f3) wel al die HD dingen gebruik ik elke dag
alle netwerk dingen werken niet(of f1 of f2) wel, hierzo wel (misschien ondersteund je netwerk kaart het niet
  • BasieP
check pic: Afbeeldingslocatie: http://members.lycos.nl/basiep/Image1.jpg
  • zwahiel
  • Laatst online: 13:58
zwahiel
Eindbaas HK
Keihard de lekkerste!
Kan binnen smartie misschien de nieuwe chips van Hitachi gesupport worden?
Is in mijn inkoopactie topic. Creepy heeft nu ondersteuning voor LCDinf, hij zegt dat 't simpel is, dan is Smartie nog breeder voor meer mensen :D
Altijd aan de knutsel her en der. Laten we gewoon gekke dingen bouwen en knutselen. YEAH!
RIP Lada 2105 "Igor" 31-12-1992 - † 21-02-2014. De nieuwe Igor: Tesla model 3 SR+ 21-08-2020
welles :+
check pic: http://www.ccmod.com/images/upload/lcdsmartie51error1.jpg
owja ik zet hem niet meteen neer omdat ccmod niet echt een snelle host heeft, anders trek ik hem op GoT weg.
en mijn eigen hosting is weer eens aant gekdoen.
kom en reageer ff op icq plz.
knulletje :p
Kan je ook even vertellen wat je gedaan hebt zodat het netwerk loopt, krijg hier alleen 0 of error, harddisk meters werken ook nog steeds niet ;-(
Ik wil ff weten of het ook mogelijk is smartie te laten "onthouden" hoeveel de totalen download en upload zijn, dus ook na reboot zodat je een totaal van wat allemaal gedownload/upload hebt sinds smartie...
hier werken game stats nog niet.. en hdd...
hdd en netwerk willen hier ook niet :'(
de gene die problemen heeft met hdd+netwerk+gamestats moetten dit doen:....
zorg dat de config goed is, maar kijk NIET naar de lcd als je in de setup zit.
als je naar de lcd in tijdens de setup kijkt wil niet alles werken.
dus zorg voor wat leuke instellingen, daarna even testen buiten de setup(dus gewoon wachten totdat het juiste scherm voorbij komt.
het enige wat niet werkt bij mij is de HDD ondersteuning met GB dus de MB versie werkt wel!
[ Voor 0% gewijzigd door Verwijderd op 17-08-2002 12:59 . Reden: typo ]
elke keer UT opstarten :( hehe ik heb je ff geadd hoof KoD op icq.. :) vind ut vaag,...
he he nu ook eindelijk eens met cf ver 1 support ?
zo te zien wel mocht ook onderhand wel eens lol
laat maar, is al geregeld :X
  • w00Dy
  • Laatst online: 16:15
w00Dy
Make soap, not war
hoe zit dat met die buttons die je kan assignen aan een variable
dat snap ik niet helemaal :?
  • Looki
  • Laatst online: 04-03 14:43
Looki
Als je zoekt dan zul je vinden
edit
Hieronder had ik iets leuks kunnen neerzetten... Maar waarom mensen hiermee vervelen....
  • Looki
Looki
Hoe krijg je de gamestats werkend? ik heb al vanalles geprobeert :( komt alleen de servername te staan :( die andere doen het niet :(
  • Looki
Looki
Het werkt al! ik had mijn firewall dicht staan :)
  • OliverBB
  • Laatst online: 23-11-2024
zwahiel schreef op 17 augustus 2002 @ 08:12:
als dat ff zou kunnen,...
die van mij geeft namelijk de volgende error:
Afbeeldingslocatie: http://members.home.nl/wgsnijders/lcd/errorsmartie.jpg
die van mij is er ook 1 uit de inkoop actie van zwahiel
  • Atmoz
  • Laatst online: 17-11 13:00
Atmoz
Techno!!
Complimenten!!! ziet er zeer goed uit!
ik snap alleen niet hoe email werkt. kan daT MeT hotmail?
atmoz schreef op 17 augustus 2002 @ 16:10:
alleen met pop3 mail.
ziet er erg goed uit hoor
en het geen wat nog niet werkt nou jah komt ook wel weer goed
ik ben wel blij met die net stats
mooi gedaan basiep
  • David
  • Laatst online: 15-11 12:52
Ik heb helaas net m'n LCD'tje verkocht aan twakker :'(. Naja, volgende inkoopactie maar eens opzoeken :)
Dato DUO synth voor twee
DiMension schreef op 17 augustus 2002 @ 16:18:
dom he nu moet je zelf weer aan de gang :-)
Ik ga mijn LCD weer is uit de kast halen...
Ondersteund hij ook dit schema?:
Afbeeldingslocatie: http://www.bugs.nl/lcd/backplate-schematics.gif
[quote]Verwijderd schreef op 17 augustus 2002 @ 16:40:
quote]
heb je hem zo al een gebruikt dan?
anders zou ik het eens het standaard schema gebruiken
  • Mad_Demon
  • Laatst online: 17:26
Wow, als ik opstart krijg ik al allemaal "violation errors" waardoor ik niet eens de eerste foutmelding kan lezen (missing ???? )
Back to 5.0 for me ;(
  • VIPER2001
  • Laatst online: 19-09 15:56
VIPER2001
[GOT]The Source
KLASSE ;)
Asus X99-DELUXE i7-5930K 16 GB (DDR3 2133) asus GTX1070 8 GB , asus xense ,asus usbdvdwriter,CM-COSMOS II,coirsair1200I,evo1TB,960pro512,Seagate2TB+Seagate 2x4TB,canon5350 logi g910+g502 iiyama G2773HS
ok BassieP ik moet zeggen het werkt allemaal lekker.
alleen ge GB support werkt niet.
ik mis zelf nog wel 1 dingetje:
• in de actions: Theme(id) (id = de theme waarnaartoe hij moet gaan).
wel makkelijk als je b.v. een nieuw mailtje krijgt, dan kan je hem altijd op 1 scherm zetten.
en dan krijg je opeens dat b.v. je pros warmer word, dan moet hij op weer een ander theme komen te staan.
[optie]
dan moet je ook iets maken, dat als je pros warmer is dan 40c(oid) hij ook niet van die theme afkan behalve doordat hij koeler als 39c(oid) word.
dit is dus iets wat leuk is, maar niet echt nodig.
[/optie]
vraagje, waar dient GPO voor?
[ Voor 0% gewijzigd door Verwijderd op 17-08-2002 17:18 . Reden: gpo? ]
  • OliverBB
het lcd dat ik graag aan de praat had willen hebben is:
http://www.kernelconcepts.de/products/pplcd.shtml
kun jij er wat mee?? het lukt me nu absoluut niet om er (fatsoenlijk) iets op te tonen.
ook niet met de eerder versies van smartie.
wel krijg ik info op het schermpj met lcdinf van creepy maar dat staat allemaal verschoven op beeld,plus dat er bij lange na niet zoveel futures in zitten.
ik hoop dat je me verder kunt helpen??
  • Looki
Looki
bug gevonden! hij zet de CS stats als je dnet done/speed aan hebt staan in je Dnet map neer!
[quote]Verwijderd schreef op 17 augustus 2002 @ 16:44:
quote]
Ja icm met LCDcenter en LCDdriver middels de WIRz Seetron driver...
gewoon testen dus
  • Looki
Looki
Mad_Demon schreef op 17 augustus 2002 @ 16:51:
moet je de poort ff goed instellen! hd..870 en dan poort 378 vaak op enter drukken en dan op setup klikken! heb ik ook met 5 gehad :) of ff opnieuw installen en de eerste keer in stellen
[ Voor 0% gewijzigd door Looki op 17-08-2002 17:28 . Reden: wat text erbij ]
  • Looki
Looki
het werkt hier helemaal goed.. alleen }:O werkt hier niet :( maar dat is niet zo erg :D g en gamestats doen ook. alleen kan je niet dat alle players met frag/dead erop komen? en dat als je continue @ next line aan zet dat hij dan alles door scrolt? alle regels? maar verder werkt het Super! thks
Volgens mij heb jij alleen wat techtposts nodig vandaar deze irrelevante posts.
Als je je wat verdiept had in de materie was je tot een andere antwoord gekomen. Smartie ondersteund namelijk deze driver niet en vroeg me dus af of deze op de een of andere manier geimplementeerd kan worden. Ik kan dan bv backpacks gaan maken voor bestaande displays voor een prettige prijs.
  • Keizer
Dat zou geweldig zijn! Smartie is een geweldig progje, maar met de zwahiel-mini-lcd's heeft ie wat problemen :(
Always outnumbered, never outgunned!
  • BasieP
Verwijderd schreef op 17 augustus 2002 @ 13:01:
anders had je het zelf mogen doen
grote bek hebben op andermans software is altijd wel makkelijk he
  • Mad_Demon
jeuuron schreef op 17 augustus 2002 @ 17:27:
Het probleem is dat ik niet eens bij het setup-scherm kan komen :(
heeft iemand een voorbeeld hoe het moet met gamestats...
zo van
servernaam
Plank 23 Frags
10 deaths ofzo??
  • Looki
Looki
Mad_Demon schreef op 17 augustus 2002 @ 18:16:
ik heb het ook met veel enteren en kilikken geprobeerd als je het schermpje weg (enter) haalt moet je in die tijd dat er een nieuwe komt op setup klikken.
SUC6 _/-\o_
Verwijderd schreef op 17 augustus 2002 @ 17:17:
Voor GPO (general purpose output (oid) zie de site van Matrix Orbital. Daar kan je bijvoorbeeld fans of relaitjes mee aansturen die dan weer je ccfl doen ontsteken.
  • Robino
  • Laatst online: 10:53
Werkt Smartie nu ook met een 2*8 LCD eigenlijk :?
  • Creepy
  • Laatst online: 17-11 18:27
Creepy
Tactical Espionage Splatterer
BasieP schreef op 17 augustus 2002 @ 18:13:
Wen er maar aan... grote bek trekken, en om features zeuren, en ondertussen zelf geen enkele moeite doen... 't gebeurt vaker. Ik kan (net als jij) tenminste zeggen dat ik het zelf doe ;)
Eeehh.. het viel me op dat er al een paar keer is gevraagd voor de HD66712 support (die kant en klare mini-LCD's). Laat ff weten als je die info wilt hebben, aangezien ik ze hier al aan de gang heb, op een iets verkeerde geheugen indeling na ;) Maar dat is ok weer snel opgelost, aangezien ik hier zo'n LCD heb liggen.
"I had a problem, I solved it with regular expressions. Now I have two problems". That's shows a lack of appreciation for regular expressions: "I know have _star_ problems" --Kevlin Henney
  • Looki
Looki
Verwijderd schreef op 17 augustus 2002 @ 18:25:
ja ff op het goeie vakje gaan staan, server invullen, klik een van de bovenste dingen aan (server naam/ gamers online/ map naam/ frags per player) en druk op invoegen. als je nu een ander veld invult moet je eerst de server weer goed instellen.. en telkens ff wachten.. moet smarty even info halen en dat kost tijd.
nu werkt het :)
  • Mad_Demon
jeuuron schreef op 17 augustus 2002 @ 18:51:
SUC6 _/-\o_
:? Als ik dat doe dan gebeurt er niks, dus ik enter alle schrempjes weg en ik krijg verder niks te zien.
  • Lieuwe
  • Laatst online: 25-08 15:16
Bij mij werken de MBM temperaturen niet meer, wat in Smartie 5.0 wel werkte met MBM versie 5.27. Oude MBM installatie resulteerd in een vastloper bij het opstarten van smartie.
Winxp Gebruiker met een HD44780 lcd
  • BasieP
5.27??
nooit van gehoord..
probeer gewoon 5.1.9.1
en creepy ik ga helemaal niks meer proggen..
al die mensen die alleen maar vragen doe dit en doe dat.. zou ik zeggen.
maak zelf een kant en klare copy paste driver en dan voeg ik hem in in smartie.
Zolang niemand daarmee komt ga ik er geen werk van maken.
Zelf heb ik die dingen toch niet. En het moet wel een hobby blijven
  • David
BasieP, had jij hem trouwens al gesubmit voor de Meuktracker? Ik wel namelijk, maar volgens mij komt 'ie er niet op.
  • zwahiel
zwahiel
Eindbaas HK
BasieP schreef op 18 augustus 2002 @ 11:49:
5.27??
nooit van gehoord..
Ik geloof dat Creepy al een kant en klare driver ervoor heeft... Ik weet alleen niet of die binnen LCDsmartie werkt...
Maar ik ben je wel dankbaar voor je werk hoor BasieP.
Lees als je tijd en zin hebt dit topic ff door: *gesloten* 4*20 kant en klaar part 2
Dan zul je zien dat LCDSmartie toch wel het favorite programma voor je LCD is wat vele tweakers gebruiken en willen gebruiken...
Het is met die kant en klare LCD's gewoon iets anders geregeld qua geheugen aansturing... Maar Creepy heeft dat opgelost voor LCDinf, maar mensen vroegen zich af of 't bij LCDSmartie ook kon omdat dat nou eenmaal (sorry Creepy) meer functies had als LCDinf... :)
* zwahiel kijkt BasieP héél lief aan...
  • Creepy
Creepy
zwahiel schreef op 18 augustus 2002 @ 12:04:
Voor mij hoef je je niet te verontschuldigen hoor. Ik denk er net zo over als BasieP. Ik bouw in wat ik in wil bouwen, en als een ander progje veel meer features heeft, boeiend, dan gebruik je mijn proggie toch niet. LCDInf is voor mij ook een hobby.
Hmm.. copy&paste driver, ik ben niet iemand die zomaar copy'n'paste code geeft, ik kan je wel vertellen wat je moet aanpassen in je HD44780 driver (aanpassingen zijn erg minimaal ). Als je wilt kunnen we overleggen over een driver zonder source (DLL of een klant en klaar Delphi Object).
  • BasieP
ach ik zit er niet op te wachten..
misschien fix ik die bugjes nog in de HD zooi en de f@home stats maar dan heb je't voor mij ook wel gehad
ik heb nog wel een CF 633 lcd liggen waar ik misschien wel is wat voor wil gaan maken.
alleen dat kutding werkt met packetjes data en allemaal nuttloze vage aansturingen (ik heb die gasten van CF al behoorlijk uitgescholden daarover ;) )
  • _ferry_
_ferry_
Moderator Tweaking
Nipple Tweaker
dank u!! kijken of nu dat flippen bij het afsluiten verdwijnt en of me temperaturen nu wel worden weergegeven, ziet er veelbelovend uit!!
  • BasieP
flippen bij afsluiten?
explain please (anders kan ik het niet fixen >:) )
en je temps gaat ik niks aan veranderen. download MBM 5.1.9.1 en het moet werken zo niet ga lekker met zijn allle alex van kaam spammen (ik mag hem toch al niet)
Hmm, tot grote tevredenheid werkt alles right out of the box met mijn Crystalfontz 634 20x4.
Moet wel allemaal nog es uitpluizen hoe ik alles instel op de schermpjes maar geen errors zoals bij de vorige versie.
Puik werk man ! :D
  • VIPER2001
VIPER2001
[GOT]The Source
email functie werkt goed voor een tijdje ,maar dan registreerd hij niks meer :'(
BasieP schreef op 18 augustus 2002 @ 14:53:
ah, dus toch dat GB bugje er uit halen mischien :)
kan je dan ook 1 functie inbouwen dat zorgt dat hij (via acties) naar theme nummer springt(dus GoToTheme(themenr) ofzo).
VIPER2001 schreef op 18 augustus 2002 @ 23:55:
werkt hier helemaal niet, nouja boeien, gebruikte ik toch niet.
nou ik ben je erg dankbaar voor je programma hoor vindt het erg flex werken zou het ook jammer vinden als je ermee stopt. maar ik heb verder geen bugs ofzo.
maar wel een vraagie:
Ik wou eigenlijk de nieuwe winamp gaan draaien. winamp 3 final namelijk. maar zat er al support voor winamp 3 in deze versie of niet? en zo nee ga je het voor de tweakers hier die je proggie graag gebruiken en je dankbaar zijn (kwijl kwijl :P ) nog inbouwen bij een nieuwere versie????
quote: BasieP
i am not adding winamp 3 support yet for 2 reasons:
1: winamp 3 takes for 1 single mp3 file about 11 MB of your RAM, and uses about 26% of a 800Mhz system and 21% of a 1400Mhz system.. (so don't use it)
2: they don't made a complete API for it, which means IF i should make support i have to change that everytime they change somehting
oke hij neemt hier bij mijn duron 700@800 ongeveer 16mb in maar iets van 1% zoals ik al zei tis de final versie van 3. En dat is nou niet overdreven veel. En als ze nou met een api ervoor komen wordt en blijft he dan nog steeds nee :P
  • zwahiel
zwahiel
Eindbaas HK
Tja, ik kan je natuurlijk geen ongelijk geven!
Creepy zei 't ook al, en je zei 't zelf ook al eerder, het is een hobby en dat moet ook zo blijven! ;)
Ik had nog wel ff een vraagje...
Ik geloof dat 't bij deze versie opgelost is...
Ik had eerst Smartie 5.0 en als ik die aan had staan, wilde winXP niet afsluiten... Ik heb 't bij deze versie nog niet geprobeerd... Maar is dat een bekend probleem BasieP :?
  • Robino
zwahiel schreef op 19 augustus 2002 @ 11:38:
Volgens mij was dat probleem verholpen in Smartie 5.1 :)
yes heb de netwerk info werkend gekregen
nu werkt op de e-mail na alles :) ik is blij
perfect programma !!!
  • ModmaN
  • Laatst online: 27-07-2015
ModmaN
Damn i'm good
weer een geweldig progsel _/-\o_ basiep
alles werkt hier perfect, en hou het bij je hobby :P
get rich or die try'in
  • BasieP
:P
ok
i will..
enneuh.. nog bugs?
anders breng ik morgne of overmorgen dat fixje uit
  • 3lmowww
  • Laatst online: 17-06-2022
3lmowww
hoe stel ik die pop 3 nou in??? ik kan nergens help oid vinden...
verder klasse!! ik heb hier nu een vfd display op zitten, waar ik naartoe kan echoen...
Electronics development
  • tymiek
  • Laatst online: 12-11 13:13
tymiek
drinkjedrankje slikjeslokje
Ik heb ff een vraagje.
Hoe kan je je up/downstream instellen voor de kabel.
Staat een nummer achter maar welke moet je daar intikken.
Iets met een snelle pc/ssd etc geen zin meer om alles op te schrijven :o
  • VIPER2001
VIPER2001
[GOT]The Source
3lmowww schreef op 19 augustus 2002 @ 23:00:
setup en dan email
eerst de email gegevens in vullen (met slider naar de volgende)
en als ale emails ingevuld is
links-boven email 1 t/m 10 uitkiezen en insert indrukken
soms met 1 email account ff uit smartie gaan want de info van de vorige email wil wel es blijven staan
  • VIPER2001
VIPER2001
[GOT]The Source
tymiek schreef op 19 augustus 2002 @ 23:46:
gewoon ff uitproberen (1)=netwerkkaart1 en (2)=netwerkkaart2
  • VIPER2001
VIPER2001
[GOT]The Source
Enne bassiep top proggie hoor _/-\o_
Pagina: 1 2 Laatste
