[CS] het grote: CS1.4 en HL1.1.0.9 topic
Pagina: 1 2 ... 10 Laatste
  • 2.151 views sinds 30-01-2008
  • CU2morO
  • Laatst online: 31-01 20:32
[topic=476330/1/25]
dit topic ging op slot met de quote "plaats maar in het grote CS topic" die bestaat bij mijn weten helemaal niet ;)
Mr. Lugosi has provided us with the changelog that came with the Linux RC1 CS 1.4 dedicated server. The date indicates that CS 1.4 (nope, the date is not just the Linux version, that'll come the night before) is set to be released this Wednesday.
Version 1.4
[4.24.02]
Changes/Additions:
» Added Anti-Cheat protection
-dit hadden we nodig, nu hopen dat het werkt
» User Interface redone for HLTV
» Dedicated servers (Win32 + Linux) now default to 32MB heapsize.
» Improved dedicated server FPS (sys_ticrate) accuracy in Windows NT/2K/XP and Linux.
» New map cs_havana
» New map de_chateau
-veel eyecandy, slechte gameplay (naar horen)
» Updated version of map de_train
» Enhanced in-game spectator mode to include HLTV features
-makkelijk cheaters herkennen in first person mode (mocht het ze toch lukken)
» Added new first-person mode to spectator modes
-zie hierboven
» Speaking players flash in team members' radars
-das ook wel makkelijk als iemand "help" over de voicecomm bralt
» Dead bodies remain on the ground for the entire round
-leuk...
» Dropped bomb blinks red in Terrorist team's radar
-nou that's handig!
» Changed so only Terrorists are notified when the bomb is dropped or picked up
-is wel zo eerlijk jah
» Changed so players must stand still when planting the bomb (including no jumping)
-idem
» Changed so players can't move or shoot while defusing the bomb
-idem
» Adjusted pistol accuracy while jumping (all pistols)
» Adjusted player jumping values to minimize bunny hopping
» Changed so the VIP can't drop any weapons
-ook een goede bugfix, altijd lullig als je als vip p.o. op "dropweapon" druk
» If player dies, view zooms away from falling body while changing the angle to show the killer
-wat moet ik me hierbij voorstellen? lijkt me niet echt geslaagd, een death scene duurt 1 a 2 seconden, en met een beetje lag zie je er dan toch nix van :?
» Changed color of the words 'BOMB' and 'VIP' in the scoreboard to make them more visible
» Changed so name changes for dead players are stored and processed when the players respawn back into the world
-daar had ik ook altijd last van, verander je naam terwijl je dood bent, en het werkt niet meer
» Changed the way "kevlar" and "kevlar/helmet" work using the buy menus...made them work together
» Added a sound when "kevlar" and "kevlar/helmet" are purchased
» Removed players hearing enemy radio calls
-huh? dit was toch juist een kei goeie feature? :(
» Added code to force "sv_clienttrace 1" on the server
» Changed so when someone mutes a player (in the scoreboard), they will no longer see that player's in-game text messages either
» Added cheering to HLTV.
» Steam beta clients and non-Steam clients can play together on the same server now
» Voice communication uses DirectSound by default now
-en dat is fijn, want... :?
» Added player ID to Half-Life DM
» Added chat flood protection to HLDM.
» Added logging of fatal Sys_Error server shutdowns
» Renamed setinfo items "ah" and "vgui_menus" to "_ah" and "_vgui_menus"
» Added new setinfo item "_cl_autowepswitch" (default: 1) which controls whether or not a client switches to picked up weapons (if they're more powerful)
New CVARS:
» "mp_kickpercent" sets the percentage of teammates it takes to vote off a player maximum: 1.0 minimum: 0.0 default: 0.66
» "sv_restart" acts exactly the same as "sv_restartround"
» "sv_send_logos" when "sv_allowdownloads" is set to 1, this cvar will control whether custom logos are propagated to clients default: 1
» "sv_send_resources" when "sv_allowdownloads" is set to 1, this cvar will control whether resources are propagated to clients default: 1
» "cl_corpsestay" client-side cvar to set the amount of time (in seconds) dead bodies will stay before sinking into the ground. Dead bodies are cleared at the beginning of each round. default: 600
-ze bleven toch altijd liggen? of gaat dit over HLDM ipv CS?
» "cl_righthand" client-side cvar to toggle using the right and left hand view-models default: 1
» "cl_minmodels" client-side cvar so clients can play using the minimum model set: leet.mdl, gign.mdl, and vip.mdl default: 0
Bug Fixes:
» Smoke grenade fix
» Radio command fix
» Fixed duplicate HUD weapon sprite bug
» Fixed footstep sounds to correctly play when not walking (fixes fastwalk cheats)
-grrr, +swimup werkt dus niet meer ;)
» Fixed uneven movement rate when moving through water
» Fixed server locking up at end of round when a lot of grenades are in play
» Fixed several ammo inconsistencies between weapons that share ammo types
» Fixed a T as CT skin bug
» Fixed bug with "kevlar/helmet" where players could buy it again at the beginning of each round even if they didn't need it
» Fixed some view_model animation bugs
» Fixed 'use' key causing an instant player stop with no deceleration
» Fixed bogus \SAVE\ directory being created when you ran Half-Life.
-oeh, das wel een goeie jah, daar had ik altijd last van
» Fixed filter logic in the launcher.
» Fixed bug where clients couldn't connect to server side only MODs.
» Fixed bug where you could "kill" the HLTV entity in Half-Life DM.
» Fixed AddIP command.
» Fixed crash when a func_breakable triggers a trigger_counter.
» Fixed Egon gun beam problem in Half-Life DM.
» Fixed Tau cannon prediction problem.
» Fixed fog messing Additive sprites.
» Fixed Alien Grunts not making any attack sounds.
» Fixed Egon's beam looking yellow in sofware mode.
» Removed "friends" connectionless packet query.
» Fixed "bad address type" fatal server error (caused by clients with long names).
» Fixed "condump" so the output won't overwrite previous files.
» Fixed "cvarlist" so the output won't overwrite previous files.
» Fixed rcon_port and rcon_address so they can be set manually by the player to rcon a server.
» Fixed server shutdowns related to using bots.
» Fixed "vote" and "votemap" commands to work correctly
» Fixed bug where clients would try to change their name while dead and then couldn't change it when they respawned.
van de site http://csnation.counter-strike.net
ff een paar opmerkingen:
-dit is niet allen CS 1.4, ook Half-Life 1.1.0.9
-de linux poort komt waarschijnlijk vanacht al uit
zullen we dan nu eindelijk van de cheaters af zijn?
edit: heb ff op sommige dingen commentaar gegeven
  • Crash
  • Laatst online: 27-10 21:47
zijn al topics over ;)
de vorige gingen ook dicht
voorbeeldje van slotje: [topic=476330/1/25]
(xie nu pas dat het boven aan je post al stond :X )
maar het is wel fijn om te horen dat morgen de nieuwe versies er zijn :)
  • CU2morO
Op dinsdag 23 april 2002 18:06 schreef Crash-Override het volgende:
die topix zie ik dus niet? ben ik nou zo scheel?
  • kNarf_
  • Laatst online: 04-09-2024
ja waar is dat topic dan? wel een voorbeeld van een slotje maar de topic zelf? :p
  • Palomar
ik zat ook al te zoeken naar dat topic :?
  • .GoO
  • Laatst online: 25-10 17:46
Dat text ignoren is een erg goede nieuwe functie!
  • Marruk
  • Laatst online: 09-09-2023
niet nog een update ;( ;( ;( ;( ;(
Dat kan mijn arme rendo modempje niet aan :'( :'(
TMAXTINT
  • Crash
Op dinsdag 23 april 2002 18:09 schreef CU2morO het volgende:
ja, ik zat ook al te zoeken, nadat ItSnows dat postte
maar dan houden we het gewoon simpel:
Dit wordt het grote CS 1.4 HL 1.1.0.9 topic :Y)
wel een paar goede verbeteringen, zoals dat text ignoren
  • Crash
Op dinsdag 23 april 2002 18:19 schreef Marruk het volgende:
iemand anders laten downen voor je en ff op cd'tje laten zetten ;)
sim-pel
Ha, daar had ik altijd al zo een last van :)
  • Jasper
  • Laatst online: 27-10 21:22
Op dinsdag 23 april 2002 18:05 schreef CU2morO het volgende:
Nee, want die radio commands worden via een headset ontvangen, dus kan jij die niet horen als je naast iemand staat. Alleen zou het dan wel zo moeten zijn dat je ze wel kan horen van mensen die deze radio commands zenden!
  • CU2morO
Op dinsdag 23 april 2002 20:16 schreef Jasper het volgende:
ja, zo was het ook in 1.3 hoor, als je in de buurt van de zender stond, dan hoorde je het, hoe verder je weg stond, hoe zachter je het hoorde
was juist handig om granaten te dodgen.
zachtjes: "fire in the hole" - snel wegrennen
  • R4NCOR
  • Laatst online: 22-10 14:21
R4NCOR
eigenlijk gewoon Niels
Op dinsdag 23 april 2002 18:22 schreef hicham het volgende:
Last van? Is een nieuwe feature.. Of bedoel je juist dat je het lastig vond dat die er niet was :? :D
Op dinsdag 23 april 2002 20:26 schreef R4NCOR het volgende:
juist, dat die er niet was dus :)
  • Marruk
Op dinsdag 23 april 2002 18:21 schreef Crash-Override het volgende:
sim-pel
aah. moed springt mij weer in de schoenen Y) :)
TMAXTINT
  • Crash
Op dinsdag 23 april 2002 22:39 schreef Marruk het volgende:
aight, that's the spirit >:)
  • CU2morO
wat ik vreemd vind, dat ik nergens iets teruglees over de accuracy van de wapens die zo drastisch veranderd zou zijn (alleen iets met handguns in air)
Kan aan mij liggen, maar ik zie ook niks staan over het niet meer "oneindige" jumpen..
Dat je dus na 2-3 jumps uitgeput ben en ff weer energie moet opbouwen (zoals bij DoD)
Of haal ik nu dingen door elkaar :?
  • Cloontje
  • Laatst online: 23-10 08:11
Cloontje
Tea. Earl Grey. Hot.
O nee kan ik vannacht weer bezig zijn met de server. Dit gaat fout for sure. En ik wou nog wel vroeg naar bed :( Nou ff site checken. Bedankt voor die lijst, ik heb me erin verdiept.
Let us make sure history never forgets the name ... Enterprise.
Op woensdag 24 april 2002 01:14 schreef Paestero het volgende:
Oh sh*t die optie is de reden dat ik nooit DoD of Firearms speel...
Als ze die implementeren in CS zweer ik dat ik het nooit meer zal doen ;) (nou ja, alleen op zaterdag dan)
[/edit]
en op zondag, maandag, dinsdag, woensdag, donderdag en vrijdag natuurlijk (maar da's logisch) :P
[edit]
  • Crash
mwoah, dit lijkt erop:
'Adjusted player jumping values to minimize bunny hopping'
  • Pete_Sampras
  • Laatst online: 23-07-2024
Pete_Sampras
Abominabele bavarois
Ik persoonlijk vind dat de text en spraak apart "gemute" moeten kunnen worden.
Ik speel vaak op Deense servers. Je wil die mensen niet horen want je kan ze toch niet begrijpen. Maar als ze Engels tikken dan is het wel handig dat je dat ziet.
Ik vind het dus een bagger optie.
Ook omdat ik vaak stopsound gebruik bij mappen die irritante geluidjes heben. Er is een bug dat het een persoon dan continue een geel icoontje boven zijn hoofd heeft en het geluid staat dan opeens veeel zachter, alsof diegene zijn microfoon constant aan staat. Dat gebeurt dus niet als ik ze van te voren mute.
Nu maar hopen dat ze dat gefixed hebben. Dan hoef ik dus niemand meer te muten behalve spammers, idioten en duitsers.
Old school gamer met een lag en een traan.
  • RaDKiLL
  • Registratie: Mei 2001
  • Laatst online: 26-03-2023
RaDKiLL
Revived
Nee, het is fijn als je teammates je verlinken door met die says te kloten.....
"Ik huiver de fluister, daarom schreeuw ik!"
  • buzz
  • Laatst online: 25-10 19:31
Op woensdag 24 april 2002 09:01 schreef RaDKiLL het volgende:
Daarom heet het ook team play :D
  • .GoO
Hij is er nog niet... Alleen de linux update ;(
Later vandaag komen de windows patches..
Muah toch best aardig wat ik hier allemaal lees valt me best meej :)
  • Bezulba
  • Laatst online: 27-10 17:27
Bezulba
Formerly known as Eendje
[b]-ze bleven toch altijd liggen? of gaat dit over HLDM ipv CS?[b]
nee de lijken ga na een paar seconde weg... nu krijg je van die lijkenhoopjes :) en das cool ;)
blup
  • CU2morO
je kon altijd alleen maar de ZENDER horen, dus degene die het bericht naar de rest roept
  • DeX
  • Laatst online: 13-01 09:52
DeX
Ik verheug me er nu al op.
Heeft er iemand al een geschatte tijd dat ze beschikbaar worden?
  • .GoO
Op woensdag 24 april 2002 10:37 schreef DeX het volgende:
20.00 Nederlandse tijd..
Zoals we gisteren al wisten te melden zijn vannacht de serverfiles uitgekomen voor de nieuwe Half-Life en Counterstrike versies.
In het bijgaande bericht van Valve software wordt tevens de tijd genoemt dat de clientbestanden uit gaan komen, om precies te zijn 11:00 PST. Dit houdt in dat we vanavond allemaal om rond 20:00 Nederlandse tijd de F5 toets kunnen gaan misbruiken in een zoektocht op zoek naar werkende mirror's.
  • DeX
DeX
Op woensdag 24 april 2002 10:38 schreef devv05 het volgende:
WOEI!
Mirror's vinden zal niet makkelijk zijn.. wel slim van ze dat ze eerst de servers uitgeven.. Toen we overgingen naar 1.3 waren er in totaal 4 Servers geupdate.. Maar elke minuut kwamen er 20 - 30 bij :9
  • KaMiKaZe
  • Laatst online: 17-10 12:44
hoop dat ze toch nog een tijdje 1.3 blijven draaien
Humanity is acquiring all the right technology for all the wrong reasons.
balen kan ik nog gaan wachten :(
  • Marv
  • Laatst online: 11-06 06:52
Zie Quake 2... daar is dat altijd al geweest... echt superhandig is dat..
Plop je wordt gekilled en je view draait direct naar diegene die je neergeschoten heeft... nu zit ik vaak te zoeken waar die persoon dan wel niet zat :?
"Everything I've ever done or said is the complete opposite of what I've wanted" -- George
  • CU2morO
Op woensdag 24 april 2002 10:54 schreef Marv het volgende:
das perhaps ook wel makkelijk om dan cheaters te zien als ze je door een muur killen
Op woensdag 24 april 2002 10:59 schreef CU2morO het volgende:
dat weet ik wel heel zeker
kan je ook gaan gebruiken in demos, dat ie naar je killer draait en geen killer ziet...hmmm very handig als je het mij vraagt!!!
  • RaDKiLL
RaDKiLL
Revived
Heeft geen zin zo cheaters te detecteren. Als de killer doorloopt en inmiddels 8er een muurtje of krat staat krijg je meteen een hoop gebl44t.
Ik hoorde dat de Win server ook al uit is...Nu maar w88 op de cliënts... :'(
  • KeRsTmAnNeKe
  • Laatst online: 27-10 21:54
Weet iemand of adminmod gewoon werkt met 1.4
en een snelle 1.4 server mirror ?
  • kNarf_
Lijkt me wel cool deze update.. slechter dan 1.3 kan hij sowieso niet zijn :P
Ben benieuwd of het weer een beetje normaal speelbaar wordt nu, hopelijk hebben ze wat aan dat 'ik sproei maar wat in het rond en maak vanzelf een lucky headshot' gedaan |:(
  • bazs2000
  • Laatst online: 18-10 18:29
bazs2000
Pixels zo groot als een atoom
Godzijdank dat er een aantal vervelende dingen zijn weggehaald.
Dat wordt vanavond weer downloaden met een lage snelheid. :D
Of ik doe hetzelfde als met 1.3, gewoon een week wachten met downloaden, kan ik ook geen verotte files krijgen of na een half uur een timeout voor mijn kiezen krijgen. :)
Krankzinnige muziek vind je hier.
  • RaDKiLL
RaDKiLL
Revived
En het risico dat je je favo server niet meer opkomt! :P ;)
  • Marv
Op woensdag 24 april 2002 12:29 schreef RaDKiLL het volgende:
Dat had ik dus met 1.3 en de updates daarvoor.... yes ik heb de update... snel installeren... werken al die servers niet meer omdat die nog steeds op de vorige versie draaien |:( |:(
  • KeRsTmAnNeKe
weet iemand een snelle mirror voor de serverfiles?
eemh je kan hem nu al downen bij www.cscentral.com
of is dat wat anders?
  • Jake
  • Registratie: September 1999
Vorige keer was er zo'n belgische site die de updates voortijdig lekte, weet iemand welke? (Toch altijd makkelijk om voor de massa uit te downen.)
Maar er is natuurlijk grote kans dat ze nu die files niet hebben gekregen.
  • Marv
Op woensdag 24 april 2002 12:52 schreef mazerati het volgende:
Proxy Reports:
11001 Host was not found
The host specified in your URL could not be found.
This error could have been caused by:
Bad / misspelled URL
Following an invalid link
Your network connection and/or transient conditions on the Internet
Zou best kunnen dus :P
  • RAJH
Vanmorgen deed die site het nog, nu is die dood :)
kun je hem gewoon installen of moet je weer helemaal met die steam gaan kloten??
  • RAJH
1.4 is gewoon als volledige mod versie te downloaden. 1.5 zal volledig op steam draaien.
  • unfor
  • Laatst online: 25-10 11:27
/me heeft 1.4 Retail Client net gedowned :P
  • RAJH
en waar weg Un4GiveN? :+
  • RaDKiLL
RaDKiLL
Revived
Un4, RaDje vind jou liev!!!!!
  • unfor
owja? vind je me nog steeds liev als ik nix zeg? :o
maarre.. www.demonleague.nl <= alleen de Retail versie is te downen... mod komt later blijkbaar... naja snel ff me CS Retail uit de kast getoverd. :)
  • Ronnie_T
  • Laatst online: 23-09 21:33
Ronnie_T
Shangri-La
Op woensdag 24 april 2002 11:54 schreef KeRsTmAnNeKe het volgende:
adminmod werkt wel, alleen is nu nog niet bug-vrij
zoek even voor mirrors op http://www.counter-strike.de/
Voor de mensen die niet kunnen wachten:
Download de linux server upgrade files en unzip hem met winzip, zodat je alvast de maps kan spelen met CS 1.3 ;)
Intel Forever. Specs. DKJJPQKU
  • Jake
Op woensdag 24 april 2002 13:15 schreef Un4GiveN het volgende:
TNX man!!!
Ik heb HL-Generations. Daarvan heb ik CS-retail installed, omdat je dan maar 1 file hoeft te downen bij updaten :)
  • Kees
  • Laatst online: 09:09
Kees
Serveradmin / BOFH / DoC
  • Marv
Kees is da man :7
  • unfor
Mja... kees... 1.4 client is ook al uit. :) niet officieel... maja boeje! :D
  • DeX
DeX
Op woensdag 24 april 2002 13:23 schreef Un4GiveN het volgende:
Je kan nooit weten of de officiele hetzelfde is als die je nu hebt.
Op woensdag 24 april 2002 13:08 schreef Un4GiveN het volgende:
WAAR? WAAR? WARR? :9~ :9~ :9~ :9~ :9~
  • Jake
Op woensdag 24 april 2002 13:25 schreef DeX het volgende:
Mmmm ok, maar waar halen ze dan ineens die niet officiele vandaan?
Als die er waren (beta's werden anders verspreid), waren ze wel eerder dan vandaag uitgelekt :).
Op woensdag 24 april 2002 13:27 schreef RixTeR het volgende:
Lezen...
  • unfor
idd.. ze gaan nu heus vandaag niet meer iets aanpassen... bepaalde sites zijn gewoon te vroeg met hun mirrors.
  • RaDKiLL
RaDKiLL
Revived
"bepaalde sites"....Hhe
Toevallig niet het NWG-forum waar je de links op gaat posten he?! :+ ;)
  • unfor
Radkill jij bent echt een clown :+ ga hierboven eens een post van me lezen. daar staat de link.
Ik heb er echt zin in :) .
Ik hoop dat het nu allemaal wat fijner is afgestemd :) .
Vooral de text ignore functie is perfect. Hoef ik niet naar mensen te luisteren die headshot blablabla zeggen :) heerlijk. Ik verheug me er nu al op.
wij hebben ook een mirror =]
http://ultra.edup.tudelft.nl/cs1004.exe
ook servers btw:
130.161.89.146:27015
130.161.89.146:27025
130.161.89.146:27035
  • Kees
Kees
Zolang de officiele files (en checksums) niet zijn vrijgegeven door counter-strike.net kun je ze beter niet neerhalen. Zowiezo is het netter om op de release te wachten :)
  • FreakNL
  • Laatst online: 15:35
FreakNL
Well do ya punk?
Ik heb een excuus :)
Nu zit ik nog op school met 100mbit, maar komende 2 weken ben ik thuis met 56k :(
  • KeRsTmAnNeKe
was der met 1.3 ook niet wat met shrimpwars... die kwamen eerder, maar dat scheen een beta te zijn oid waar weer een patch voor nodig was :?
  • KeRsTmAnNeKe
Connecting to files.tweakers.net:80... connected!
HTTP request sent, awaiting response... 403 Forbidden
14:51:41 ERROR 403: Forbidden.
En ze gingen net zo snel :'(
  • Jake
Op woensdag 24 april 2002 14:06 schreef Kees het volgende:
Dat is vooral belangrijk voor dat t.net ze gaat mirrorren.
Dat lijkt mij meer persoonlijk voorkeur, de file lijkt ok, als je installed staat de release-date (vandaag) in de readme; maar echt zeker weet je natuurlijk niet. Als ie fout is down ik wel een andere :).
Ik heb net even gespeeld, best leuk maps (die nieuwe). Nieuwe gun-accuratie is denk ik wel even wennen (maar bij Dual-Elites verandert je crosshair niet; die waren toch al onnauwkeurig).
Ik heb even de hossies gerescued, ze volgen je veel beter (ik kan ze niet afschudden op cs_havanna); daarna Bom gepland, toch vreemd dat je dan niet meer kan lopen. (alles op LAN, dus niet zoveel tegenstand ;)).
Ik zie nu aan de file-dates dat de_train ook gewijzigd is, ik ga nu even kijken hoe precies (had ik ook in changelog kunnen zien).
1.4 :r :r :r :r man alle recoil is verandert het jumpen is zo lelijk en verders je kan niet meer straven schieten
en het wordt nu gewoon duck shoot cs
Op woensdag 24 april 2002 15:06 schreef ThePreatorian het volgende:
1.4 :r :r :r :r man alle recoil is verandert het jumpen is zo lelijk en verers je kan niet meer straven schieten
duck shoot? moet je ook op eenden schieten dan?
nee wheheheeh ut is gewoon dat iedereen gaat bukken als ze schieten :(
  • Jake
Je kan gewoon niet meer rushen, is dus eigenlijk beter. Ik kwam laats bij de_dust als CT naar buiten gestormd, knal ik 3 T overhoop... Daar is toch eigenlijk niets aan (niet realistisch iig), want als je zit of staat moet je veel beter kunnen mikken (met als nadeel dat je ook een beter target bent.
Als je rent en dan snel bukt moet je nog steeds wachten tot je crosshair weer in rust is hoor. Het spel wordt gewoon wat slomer. Hopelijk wordt de team-play bevorderd met deze versie. Als je meer (lees: snellere) actie wilt ga je toch UT spelen ofzo (NOFI).
Grootste probleem lijkt mij alleen te worden: er komt straks een cheat (zal komen), zodat je kan rennen en super-accuraat bent... Daar is dan niet meer tegenop te spelen...
  • tjAb
  • Laatst online: 13-10 13:33
zal eens ff downloaden en bekijken
Don't put your mouth into motion, before your brain is in gear!
  • FragNeck
  • Laatst online: 20-10 19:00
Nog steeds jammer dat je niet kunt liggen of zo.
http://eu.battle.net/d3/en/profile/Paus-2178/hero/2313958
ik stap gewoon over op oldscool cs tsss dat lompe gedoe altijd ut wordt een kleverige game zo ut is een spelletje het hoeft niet realistich te zijn man zeg
  • DWZ
  • Laatst online: 29-11-2021
DWZ
damn.. als je zo graag 1.4 wilt.. de beta is al maanden lang verkrijgbaar...
maakt nou niet echt zoveeel uit of je het nu of morgen binnen hebt :s
  • KeRsTmAnNeKe
Link doet et weer wel als ik em thuis probeer te downloaden :|
  • Jake
Natuurlijk hoeft het niet realistisch te zijn: allemaal (enigszins) bestaande wapens, terroristische groeperingen en special forces.
CS is zo'n succes omdat ze het elke keer veranderen (steeds vlak voordat iedereen het zat is). Maar als jij 5.2 wilt spelen, moet je dat helemaal zelf weten.
Ik heb 5.2 dan nog nooit gespeeld, maar persoonlijk lijkt het mij niets dat je bij de_dust gewoon met je mes onderlangs kunt rennen, sniper(s) dodgen en dan ze ook nog eens killen (met dat zelfde mes), maar ieder zijn voorkeur.
Ik vond bunny hoppen altijd zo leuk dat mis ik wel :'(
Maarjah sommige zagen het als tjieten dus lmd ik zaag weer door :) (en ik gebruikte niet dat leeme bunny hop script voor n00bs :) gewoon lekker muis en toetsen bord )
K zie wel wat 1.4 me te bieden heeft k blijf igg wel cs'en ben al telang bezig om nu te stoppen :) beetje jammer als je 3,5 jaar cs opgeefd vanwege een l33t beta......
  • CU2morO
ik heb net die HLDS 1109 gedownd, maar dat is een .bin file. in linux typ je normaal gewoon:
tar -zxvf <file>.tar
maar hoe pak ik deze bin uit? (nee, het is geen bin/cue iso)
ik als groot Counter-Strike fanaat had natuurlijk allang de beta, maar nu wil ik ook cs 1.4 + hl updates kan alleen nog niet vinden :(
  • CU2morO
Op woensdag 24 april 2002 15:39 schreef SeVeN het volgende:
TIP VOOR IEDEREEN: CS1.4 IS NOG NIET UIT! ALLEN DE LINUX SERVERS.
CS1.4 KOMT VANAVOND ROND EEN UUR OF 8 UIT
oke :)
retail is al wel uit =]
onze site is slashdotted hehe
  • CU2morO
de HL 1109 ook al dacht ik. maar die kan ik nog niet vinden. cs1.4 duurt nog wel ff
altijd leuk ik zit 1.4 winblows retail al te downen hij is er dus wel degelijk ;)
110273244 Apr 24 14:32 cs1004.exe
of wel zo'n 110 MB ;)
  • CU2morO
Op woensdag 24 april 2002 16:04 schreef wouter10 het volgende:
de retail wel jah, maar de mod versie niet.
plaats ff wat links joh
  • RaDKiLL
RaDKiLL
Revived
RaD is blij. NWG heeft alle files al op de FTP staan. :+
  • Jake
Hallo staat al in dit topic hoor: http://www.demonleague.nl/index.php?p=26&c=1 (page is beetje overbelast)
Wees sociaal en download als het kan de upgrade (kunnen andere ook eerder/smeller downen), als je de Full op je HD wilt kan je die altijd nog downen (over een paar weken zijn veel mirrors nog up, maar is het lekker rustig).
Daar staan (links door mij erbij gezet):
Demonleague heeft het idee dat het er snel bij is met de updates maar ja.. erg goed heb ik ook nog niet rondgekeken hehe. In ieder geval: Wij hebben ze nu voor je! Dit is mogelijk gemaakt door Ruffneck. Heel erg bedankt maat!
HL client
HL client full: http://www.geforce.nl/demonleague/hl1109.exe
HL client full: ftp://demonleague:user@130.89.161.101/Client%20Full/
HL client update: http://www.geforce.nl/demonleague/11081109.exe
HL client update: ftp://demonleague:user@130.89.161.101/Client%20Update/
Retail
cs 1.4 full (retail): http://www.geforce.nl/demonleague/cs1004.exe
cs 1.4 full (retail): http://ultra.edup.tudelft.nl/cs1004.exe
cs 1.4 full (retail): ftp://demonleague:user@130.89.161.101/Retail%20Full/
cs 1.4 update (retail): http://www.geforce.nl/demonleague/cs10031004.exe
cs 1.4 update (retail): ftp://demonleague:user@130.89.161.101/Retail%20Update/
Server
... (niet belangrijk, mirrors zat)
Alle files (exclusief mod)
ftp://cs14:rentone@ftp.rentone.nl/
De meeste van die mirrors zullen ondertussen barlangzaam zijn, dan weet je dus gelijk waarop ze proberen alle mirrors op de wereld tegelijk 'up' te laten gaan :).
Valt mee. maar ja surfnet is ook zo ASO.
Transferred 1 file totaling 110,273,244 bytes in 05:32 (327.77 KB/Sec)
  • CU2morO
Op woensdag 24 april 2002 16:16 schreef wouter10 het volgende:
links mensen, geen namen
  • KeRsTmAnNeKe
Op woensdag 24 april 2002 15:33 schreef CU2morO het volgende:
chmod +x hlds_l_3109_full.bin
./hlds_l_3109_full.bin
tar -xzvf hlds_l_3109_full.tar.gz
  • CU2morO
Op woensdag 24 april 2002 16:33 schreef KeRsTmAnNeKe het volgende:
dank je
weet iemand hoe laat cs 1.4 uitkomt (de mod versie)
vanavond
  • CU2morO
Op woensdag 24 april 2002 16:54 schreef Metal-Kool4 het volgende:
geeft nix hoor, is pas 10x verteld :Z
Op woensdag 24 april 2002 16:55 schreef CU2morO het volgende:
ik bedoel de tijd :)
