StatBar is still alive & kickin'! :) [v2.1 is uit]
Pagina: 1 2 Laatste
  • 457 views sinds 30-01-2008
  • Mr. B.
Een aantal maanden lang heb ik weinig tot niks aan StatBar gedaan (geen tijd en zin gehad), maar begin deze maand ben ik toch weer langzaamaan begonnen... er is een hoop aangepast en toegevoegd (d'r zijn ruim 1000 regels code bijgekomen), het resultaat is nu hier te downloaden :)
Voor je reageert met vragen/opmerkingen/bugreports: lees svp eerst onderstaande lijsten en het "Tips, Tricks, Notes & Bugs" gedeelte in de help file.
De lijst met veranderingen:
(copy-paste uit de helpfile, geen zin om het te vertalen :P)
• StatBar is now compiled with Visual Basic 6.0, former versions were compiled with VB 5.0.
• The list with available info modules wasn't sorted properly when you opened the configuration window. Fixed.
• The width of the CPU usage and Free & total RAM info modules wasn't updated when you (un)checked the graph options. Fixed.
• When switching screen resolution, StatBar would sometimes get an incorrect size (it was suddenly too short to cover the entire width of your screen). Fixed.
• Changed/added a few things in order to save screen space:
- Renamed "Running" to "Uptime", "CPU Usage" to "CPU" and "Free RAM" to "RAM".
- Removed the word "Status" in the battery status info module.
- Added the ability to hide the StatBar logo on the left.
- Added the ability to hide most of the module indicator texts.
• Renamed the Free & total RAM info module to Memory status.
• Removed the free registration screen; all it did was putting your name in the about box, which is actually quite useless. Registry entries relating to this screen, created by former versions of StatBar, are automatically deleted.
• Added the ability to display the amount of memory currently in use instead of the amount of free memory.
• Doubleclicking the NumLock, CapsLock or ScrollLock lights will now toggle the state for that particular key.
• Slightly modified the "Windows Default" color scheme; it now uses the Windows 2000/ME tint of gray instead of the old Windows 95/98/NT4 one.
• The total amount of RAM is now automatically corrected, as the GlobalMemoryStatus call in Windows always returns a little less than it should (see Tips, Tricks, Notes & Bugs). You can turn this behavior off by enabling the "Don't correct total amount of RAM" option.
• The Windows version info module now has a tooltip displaying the build number and service pack (if applicable).
• Rearranged the configuration window.
• Added Winamp controls.
• Added CD door eject/close buttons.
• Added the exit/lock buttons.
• Added the Harddisk information module.
• Added the "Open homepage on logo doubleclick" option.
• Added the "Require mouseclick when auto-hiding" option.
• Added the "Run StatBar on Windows startup" option. If you enable this option, you should remove any shortcuts to StatBar in your startup folder.
• Hopefully fixed some weird program crashes on Win98 and NT4 systems.
• Slightly modified this help file.
Op de "to do" lijst:
• DU meter (zodra ik weet hoe)
• SMP support (idem)
• Multimonitor support (idem)
• Display resolutie
• CD player controls (misschien)
• CPU/mem logs (idem)
• Quicklaunch (heel misschien, zie ik het nut niet echt van in; zit ook standaard in Windows)
• CPU temperatuur weergave m.b.v. Motherboard Monitor (ook heel misschien; dat kun je MBM eigenlijk net zo goed in de systray laten zetten)
• Meer "verdiepingen" (misschien ooit ;))
Have phun met StatBar 2.1 8-)
StatBar.nl - @GoT
Het verschil tussen theorie en praktijk is in de praktijk altijd veel groter dan in theorie.
  • Han
Han
Mmmm... ziet er goed uit, maar StatBar vermeld dat ik 1004Mb verbruik (van de 1500Mb) zonder iets te doen. Geen koe op dit moment, en photosoep en speedrazor staan ook uit. Hoe kan dat?
  • Mr. B.
Op zaterdag 29 september 2001 17:25 schreef Merely het volgende:
Welke Windows versie? 9x/ME: is normaal, het geheugengebruik van die Windows serie is gewoon *BEEP, censored* ;)
Check ook de Windows System Monitor maar eens, die geeft als het goed is dezelfde waardes aan.
StatBar.nl - @GoT
  • JJJ
JJJ
Ik vind hem echt beter dan de vorige versie!
Keep up the good work!
  • Buzzman
FYI: de SA faq is updated en hij staat nu ook op aphrodite om te downloaden :)
linkje
  • Zap
Zap
Yeah, ik heb hem ook ff geupgraded.. nice work! :) Blijft een fijn proggie...
Ik heb alleen nogsteeds 1 probleempje (dat ik ook al had bij de vorige versies): de volume control werkt niet. ("unable to get master volume control. volume control will be disabled") Dit werkt verder wel gewoon in andere programma's.. Ik heb een SB Live en ik draai Win98SE.
  • Han
Han
Ik gebruik Win2K. Versie 5.00.2195 System monitor zegt dat ik maar 104Mb verbruik. Toch een aardig verschilletje...
Vind WinBar toch mooier geloof ik en denk dat ik die maar blijf houden!
Afbeeldingslocatie: http://picserv.mediamonks.net/6071.jpg
ook vreemd trouwens.... zie nu dat WinBar 28% aangeeft en StatBar 33% op hetzelfde tijdstip
  • Klippy
  • Laatst online: 19:24
Klippy
Still Game
Ik ga 'm eens testen!
Steam | SXQncyBhbGwgZ29vZCwgbWFuISDwn5iO
  • Mr. B.
Op zaterdag 29 september 2001 17:34 schreef Zap het volgende:
Op zaterdag 29 september 2001 17:34 schreef Merely het volgende:
Allebei vrij vaag... heb ik zo direct geen oplossing voor, ik zal er eens naar kijken.
StatBar.nl - @GoT
  • Mr. B.
Op zaterdag 29 september 2001 17:35 schreef Tubbietje het volgende:
Dat ligt puur aan het meetmoment (zullen ongetwijfeld een paar milliseconden tussenzitten). Als je iedere 10 milliseconden de CPU usage zou meten zou het op en neer schommelen als een gek :P
StatBar.nl - @GoT
  • intoxicated
intoxicated
Haaaai :w | ALT-S
Dat soort programma's refreshen bijvoorbeeld elke 5 seconden en dat gebeurt dus nooit op exact hetzelfde moment, waardoor de metingen dus behoorlijk van elkaar kunnen variëren. Vroeger zag ik wel eens verschillen van 80% tussen 2 programma's. Tegenwoordig niet meer, want door m'n }:O geeft alles nu altijd 99 tot 100% aan :)
"Anyone who does not agree with me is mentally sick, and should be shot I'm afraid to say."
- Pastor Richards @ VCPR
hmmm werkt perfect draai win2k sp2 krijg aleen met win2k altijd de melding dat er al een auto-hide bar boven in verstopt zit maar volgens mij wordt ik voor de gek gehouden heb namelijk geen auto hide bar geinstalleert heb je hier michien een verklaring/oplossing voor? ;)
  • DR
DR
cool, de oude vertrouwde statbar :)
* DR is weer terug bij Statbar :P
  • eX0duS
  • Laatst online: 24-11 22:45
Eej, hartstikke cool man! WinBar heeft er nu een VETTE concurrent terug! Ik zat nog te twijfelen, maar nu vind ik statbar weer een van de betere! Ga zo door! :D
  • Mr. B.
Op zaterdag 29 september 2001 17:43 schreef rolandO het volgende:
Hmm, lekker vaag allemaal... :?
StatBar vraagt gewoon aan de shell uit of daar een auto-hide bar zit of niet; op de waarde die teruggegeven wordt heeft het programma zelf geen invloed.
StatBar.nl - @GoT
  • Klippy
Klippy
Still Game
Mooi programma weer.
Vindt 't mooi dat ik nu 't StatBar logo kan hiden. Scheelt weer plaats.
  • Remi
  • Laatst online: 15:55
Remi
Moo!
Ik heb even Winbar er op gehad vanwege de winamp controls maar dat ding had nogal moeite met resizen of zo en hij vergat de hele tijd m'n instellingen.
Dus ik draai nu weer netjes StatBar, ziet er niet alleen beter uit maar werkt ook veel beter. :)
GO GO GO Mr. B :)
  • Arno
  • Laatst online: 23-11 22:07
Arno
PF5A
VET !
Zeker die winamp controls *D
Klasse
"Supercars are made to mess around with G-forces, hypercars are made to mess around with G-strings"
Jeremy Clarkson
  • brammus
brammus
PATGOD
Op zaterdag 29 september 2001 17:48 schreef Mr. B. het volgende:
Misschien dat blokje van die Kazaa-spyware linksboven in de desktop :?
PC-Specs
"...You may feel a little sick..."
  • Mr. B.
Op zaterdag 29 september 2001 18:00 schreef brammus het volgende:
Zou best eens kunnen... ik draai zelf geen Kazaa, kan ik dus ook niet testen.
StatBar.nl - @GoT
ej bedankt joh!
ik ga 'm denk ik toch maar eens draaien, is wel verekkes handig!
ziet er strak uit!
bedankt!
  • syserr
  • Laatst online: 22-11 20:24
syserr
kangoeroe
en hij's wederom weer erg fijn... vooral dat logo weg en die winamp controls worden zeer gewaardeerd... maar eh, waarom maar die 4 en juist die kleuren? eigen kleurestelling (of bv transparante achtegrond ofzo) zou ook wel grappig zijn...
"Nee," zei de man "hij is onze goeroe die alles kan" en ik was lekker op dreef dus ik zeg: "Nou, dat zal dan wel een kangoeroe zijn"
  • Beaves
  • Laatst online: 13:31
Beaves
Usque ad Finem
Hier nog een tevreden gebruiker, had eerst Startbar en ben daarna Winbar gaan gebruiken wegens extra handige feature's zoals HD etc.
Nu Statbar die dingen ook heeft + een aantal extra modules zoals dat Exit/Lock buttons gebruik ik weer Statbar :)
Ik vind het wel leuk om te zien hoe Winbar en Statbar met elkaar in "gevecht" zijn :)
Schotlandofiel | Godzijdank ben ik atheïst
Canon 7D / 20D / 300D + glas | Just Light | Flickr
Waar is Winbar te vinden :? kan hem nergens vinden... Wil ik ook wel eens even proberen... ;)
Waaw! Zalig progje
Edit: zoals hierboven gezegd zou transparancy wel heel kewl zijn
Nog eens edit: Die cd opener kan die er meer dan 1x inkomen voor die mensen die meerdere cd-spelers hebben?
  • The Dolf
Mooi man
de eerste versies waren niet goed. Deze gebruik ik met plezier.
Het enigste nadeel vind ik het relatief hoge geheugengebruik.
Gezocht!
Samsung 1TB HD103SI printplaat
Router
If everything seems to be going well, you have obviously overlooked something
  • Arjan Scholl
  • Laatst online: 16-11 20:51
Op zaterdag 29 september 2001 18:10 schreef MSIBord het volgende:
Je zoekactie naar 'winbar' leverde 18 resultaten op. Resultaten 1 - 18. ;)
[topic=227424/1/500]
  • Mr. B.
Op zaterdag 29 september 2001 18:09 schreef syserr het volgende:
Het hele StatBar scherm is opgebouwd uit graphics (zodat je precies weet hoeveel plaats iets in beslag neemt); voor iedere kleur zijn er in deze versie 80 (ja, tachtig) verschillende graphics nodig. Al die graphics on-the-fly genereren is wel mogelijk, maar dat is gigantisch veel werk (het programma zou er veel trager door worden en ook veel meer geheugen vreten).
StatBar.nl - @GoT
Op zaterdag 29 september 2001 18:13 schreef arjanscholl het volgende:
Echt stom van me, ik heb wel op internet gezocht, maar ik kwam steeds bij een progje voor windows 3.11. Maar ik heb niet hier gezocht... :o
  • Mr. B.
Op zaterdag 29 september 2001 18:10 schreef grand.lord.of.chaos het volgende:
Waaw! Zalig progje
Op dit moment wordt de CD-ROM geopend die door het systeem aangegeven wordt als MCI device (in dit geval als audio-CD speler dus); ik zal kijken of ik dat voor een volgende versie kan aanpassen.
StatBar.nl - @GoT
Hier kan je WinBar vandaan halen
http://www.lunenburg.cistron.nl/winbar
  • BenJoep
Hey Mr bee, kan je niet samenwerken met die gast van winbar, ik denk dan dat je tot een aardig mooi product komt, ik vind de lay-out van winbar beter maar in gebruik vind ik statbar beter. Dus.. Is dat geen idee.
| I've got permission to color outside the lines |
  • d33n
  • Laatst online: 24-11 18:04
is er ook een mogelijkheid om em uit te lijnen...?
want nu staat al die shit in het midden van me scherm, en ik wil het mooi links hebben
  • Speedener
  • Laatst online: 20-11 13:05
Netjes Mr.B. ik had altijd al 2 draaien maar deze is ALWEER beter, ik gebruik uhm al vanaf het begin, ik heb ze ook nog alle maal.. :)
  • Nowhere
  • Laatst online: 24-10 14:16
Super Mr. B
Keep up the good work :)
* Nowhere is blij dat zijn suggestie ook verwerkt is in versie 2.1
www.kuiphuis.nl
  • Nowhere
Op zaterdag 29 september 2001 18:25 schreef Genotix het volgende:
Denk niet dat dat verstandig is.
Immers nu heb je eigenlijk 2 concurrenten, en dan blijkt uit de praktijk dat er dan altijd (bijna dan) een beter product ontstaat.
www.kuiphuis.nl
  • flat
jaja, mooi progsel hoor, dat statbar :)
"Happiness is a way of travel, not a destination."
--Roy Goodman
  • Marv
  • Laatst online: 11-06 06:52
Heb het er ook ff op gehad maar tis eigenlijk useless :P
Leuk om even te hebben maar ik vind het niks voor de lange termijn. Tis gewoon m'n mening dus geen flame o.i.d. :)
"Everything I've ever done or said is the complete opposite of what I've wanted" -- George
  • GandalfTheGrey
  • Laatst online: 24-11 07:32
GandalfTheGrey
Remember, Remember..
ziet er erg goed uit.. bedankt.. Statbar kicks kont :P
Computer Specs
  • Mr. B.
Als we zouden gaan samenwerken dan zouden we het hele programma vanaf de grond opnieuw moeten opbouwen, bovendien ben ik het ook wel eens met de reden die Nowhere opgeeft:
Op zaterdag 29 september 2001 18:52 schreef Nowhere het volgende:
StatBar.nl - @GoT
  • Mr. B.
Op zaterdag 29 september 2001 18:28 schreef marble het volgende:
Dat staat bij deze op de to do list.
StatBar.nl - @GoT
Mr. B rox. Keep it up!!!
Vooral die diskspace kicks ass. Zeer goed verbeterd. DIe winampcontroll, 8-) perfect
  • johnwoo
  • Laatst online: 18:56
johnwoo
3S-GTE
Ziet er weer errug strak uit hoor Mr. B. :) Maar ik hou het nu toch bij mn eigen proggel :)
Overigens is het met WinBar ook mogelijk om die logoff en lock knopjes te maken, met behulp van de QuickLaunch. Je moest dan rundll32 met wat parameters aanroepen, ik weet ff niet uit mn hoofd welke het waren...
WinBar is ondertussen enkele (niet-gereleaste) builds verder... De Winamp module is wat uitgebreider, en aan de t.net tracker wordt hard gewerkt :) Ik heb nu eindelijk een Win9x bak tot mn beschikking, en daar heb ik zelf ook problemen op met het onthouden van modulezichtbaarheid... Die code wordt ook opnieuw gedaan...
Dus, keep up the good work! (dan doe ik dat ook :) )
4200Wp ZO + 840Wp ZW + 1680Wp NW | 14xIQ7+ + 1xDS3-L | MTVenusE | HWP1
  • Stender83
  • Laatst online: 14-11 21:18
Draaide altijd al statbar, en Mr. B deze rulez echt zeker!
Die exit option zijn ook erg handig.
Ga zo door.
  • Mr. B.
Op zaterdag 29 september 2001 19:46 schreef johnwoo het volgende:
Ik vind WinBar ook een mooi stukje werk, maar ik hou het zelf uiteraard ook op m'n eigen prog :)
StatBar.nl - @GoT
  • GaMbiNo
GaMbiNo
1337
:9~
Ziet er erg strak uit!!! O+
  • Bobbert
Bobbert
Miss Caprice Bourret
Zeer netjes weer :D , kvind hem persoonlijk der mooier uit zien dan winbar, en blijf zeker deze gebruiken, van de nieuwe opties gebruik ik alleen cd in/uit en hd info, de rest heb ik niet zoveel (winamp knoppen op toetsenbord)
Maar zeker weer mooier werk :D
oh en die aanpassing waarom gevraagd werd dat je meerdere cd-rom kon open lijkt mij ook wel handig :D
  • tutterke
  • Laatst online: 15-11 14:48
tutterke
Klein maar tapper!
Lekker strak, vooral die winamp controls... (hoewel je met windows XP de audio player hebt, die net hetzelfde doet, daar staan de winamp controls in de taskbar, naast je klokje)
en die concurrentie tussen statbar, en die winbar die moet er zeker blijven, dan proberen ze elkaar steeds te overtroeven in features, en dat hebben we graag >:)
And I find it kind of funny
I find it kind of sad
The dreams in which I'm dying
are the best I've ever had.
Zou het ook zo geregeld kunnen worden dat als je de muis boven het Winamp gedeelte houdt, je dan de titel en uitvoerder van het liedje kan zien?
Dat zou wel heel leuk zijn.
Ga zo door!
  • Nowhere
Op zaterdag 29 september 2001 20:02 schreef Bobbert het volgende:
of bijv. Een functie dat je de cdrom drive kunt selecteren in het config-menu.
Nu gaat alleen de eerste drive open (en das bij mij de verkeerde :))
www.kuiphuis.nl
  • Mr. B.
Op zaterdag 29 september 2001 20:10 schreef tutterke het volgende:
Zeg johnwoo... zullen we toch maar gaan samenwerken, puur om de usertjes te pesten? >:) ;)
Op zaterdag 29 september 2001 20:13 schreef grand.lord.of.chaos het volgende:
Ga zo door!
Moet te doen zijn... staat op de todo list :)
StatBar.nl - @GoT
  • SaURoN
Yes, eindelijk weer statbar terug :)
Mooi stukkie werk, had nu winbar vanwege winamp controls, maar ik miste de RC meter :)
  • Mr. B.
Op zaterdag 29 september 2001 20:23 schreef SaURoN het volgende:
De Winamp controls zaten ook al een tijdje in StatBar, maar dit is idd de eerste versie met die controls die ik gereleased heb :)
Maarre, het is kermis hier in Weert en het is zaterdagavond, dus verwacht vanavond geen replies meer van me (en morgenvroeg hoogstwaarschijnlijk ook niet :+)
StatBar.nl - @GoT
Deze statbar is weer geweldig. Weg met winbar
  • m-m
m-m
Zwaar relaxed proggie! mijn complimenten!
Doch 2 dingen:
zou het mogelijk kunnen zijn ook een open-knop bij winamp controls te maken? Moet nu steeds met mijn muis naar de tray >:)
En als ik (XP) met mijn rechtermuisknop op de balk klik krijg ik gewoon t menutje maar soms blijft het deel dat de statbar zelf bedekte zichtbaar en gaat pas weg als dat deel geupdate is (wat dus niet gebeurt met sommige delen)
  • Rusty
  • Laatst online: 27-10 08:38
Hij is weer super. Thanks B.
Toch een klein verzoekje, zou het (voor ons XP gebruikers) mogelijk zijn om ook een switch user knoppie te krijgen?
[edit] laat maar, doet lock workstation al.
3 x Marstek Venus 5.12KW V151. CT003 V114 en HW P1
  • NG
NG
bzzzzt.
Is het misschien handig dat als je dubbelklikt op Winamp (op StatBar dus) dat hij dan automatisch Winamp opent.
Ik heb Winamp uit mijn taskbar en sys tray gehaald en gebruik alleen de winamp controls, zo kan ik toch snel Winamp openen :)
  • DJ^
DJ^
hmmz
wat ik nog wel wil zien, ivm al de mensen die een koetje oid draaien dat je een except toe kan wijzen aan een bepaald procesje, zodat je ziet hoeveel je cpu usage is zónder dát procesje, nu staat de cpu-meter een beetje nutteloos op 100% constant :(
dat nog niemand dit heeft geopperd (tenminste niemand heb ik het zien opperen :)) :)
hmmz
  • 8-Track
  • Laatst online: 19-09 17:07
8-Track
CoolInfo kan dat, maar da's misschien niet helemaal waar je naar op zoek bent (i.e. geen winamp controls en zo). :)
Kan een benodigd DLL-bestand, MSVBVM60.DLL, niet vinden.
IK WIL OOK WINAMP CONTROLS!!
'k ben zo te zien de enige met problemen??
voorlopig maar ff terug naar de vorige...
  • CV_SmileY
  • Laatst online: 24-11 14:53
CV_SmileY
JackOfAllTrades MasterOfNone
Op zaterdag 29 september 2001 18:19 schreef Mr. B. het volgende:
Mijn brander gaat open ipv mijn dvd-speler :(
maar verder : toppie
k'ben blij met die 'schermbreedte-fix'. Het kwam geregeld voor dat ik na het spelen van een spel nog maar over het halve beeld een statbar had.
  • DJ^
DJ^
hmmz
Op zondag 30 september 2001 00:51 schreef 8-Track het volgende:
Mja daar had ik het idee dus ook vandaan :)
hmmz
  • DJ^
DJ^
hmmz
Oja :) het icoon van de hardeschijven vind ik wel errug afsteken tegen de rest, dat is eigenlijk de reden dat ik hem gedisabled heb ;(
hmmz
Yess StatBAR R0els ook in mijn topique
[topic=279795]
  • Mr. B.
Op zaterdag 29 september 2001 21:27 schreef m-m het volgende:
Doch 2 dingen:
Moet niet zo'n probleem zijn... wordt geregeld :)
Ehr... wat bedoel je precies? :? Kun je ff een screenshot posten ofzo?
Op zaterdag 29 september 2001 22:56 schreef DJ^ het volgende:
Ik zal kijken of ik dat voor elkaar kan krijgen, maar ik kan niet garanderen dat het lukt.
Op zondag 30 september 2001 01:58 schreef Alain het volgende:
Dit is de eerste versie van StatBar die met VB6 gecompiled is; je kunt hier de VB6 runtime DLL downloaden. Als je die ff unzipt naar je WINDOWS\SYSTEM (of WINNT\SYSTEM32) dir moet ie het doen :)
Op zondag 30 september 2001 12:30 schreef DJ^ het volgende:
Ik zal kijken of ik een mooier icoontje kan vinden/maken. Ik heb nu gewoon hetzelfde icon als Windows gebruikt omdat het lekker herkenbaar is :)
StatBar.nl - @GoT
  • Rusty
Ehr... wat bedoel je precies? Kun je ff een screenshot posten ofzo?
Ik heb hetzelfde, zie
nu bij planet
voor een screenshot. Links bovenin.
  • Arno
Arno
PF5A
Op zondag 30 september 2001 14:31 schreef Rusty het volgende:
http://rusty360.freeservers.com/statbar.JPG
<h1>Forbidden</h1>
Host:
<font size=4 color=red>[212.120.***.***] cp*****-a.*****1.nb.nl.home.com</font>
You do not have permission to access
Data files must be stored on the same site they are linked from.
Thank you for using <a href=http://www.freeservers.com/>FreeServers</a>
Jeremy Clarkson
  • Mr. B.
Op zondag 30 september 2001 14:38 schreef Traag het volgende:
<h1>Forbidden</h1>
Host:
Ff de link copy-pasten werkt wel :)
Vaag... da's hetzelfde probleem waar ik het met Buzzman ook al via ICQ over heb gehad. Ik ga er eens naar kijken... ik draai zelf geen WinXP, maar lang leve VMware :P
StatBar.nl - @GoT
Op zondag 30 september 2001 13:17 schreef Mr. B. het volgende:
Thanx dude, hij ruled echt >:) super relax & handig proggie!! :)
  • Buzzman
Op zondag 30 september 2001 14:42 schreef Mr. B. het volgende:
Dus ik ben toch niet de enige met het probleem :o :P
  • johnwoo
johnwoo
3S-GTE
Ga zo door!
WinBar doet dat al :P (ok die versie is nog niet gereleased, maar hij komt binnenkort)
Op zaterdag 29 september 2001 20:21 schreef Mr. B. het volgende:
Hmmm... WinStat? ;)
Overigens heb ik dat dus ook, dat refreshprobleem onder XP (had het ook al in de vorige StatBar thread gepost)
  • Mr. B.
Op zondag 30 september 2001 16:11 schreef johnwoo het volgende:
Hmmm... WinStat? ;)
WatBar? :P ;)
StatBar.nl - @GoT
He, goed progje! complimenten! :)
  • Speed24
  • Registratie: Augustus 1999
Deze versie werkt echt lekker, goed werk!
Alleen 1 klein dingetje dat me opviel ... als je in WinXP (bij mij iig) op bv het harddisk-icoontje klikt, dan krijg je dat lijstje te zien, maar daarna valt de bovenste regel weg (die zit dan weer achter StatBar).
Dit is ook geval bij een rechtermuisklik op StatBar , met het vervelende gevolg dat je ff niet goed (moet je op onderste paar pixels klikken) bij de configuratie kunt komen ...
Het gebeurt alleen maar als je StatBar altijd aan laat staan, met auto-hide gaat statbar gewoon weg en kun je het menu altijd zien.
En nog een opmerking / tip : waarom zoek je geen mooi lettertype om voor StatBar te gebruiken? 6 mb aan geheugen innemen is nogal veel voor zo'n programma
//Edit: net nog ff een ideetje gehad :
waarom zet je de tijd er ook niet bij StatBar bij, dan kan ik die nl uit m'n systray halen, scheelt weer wat plaats onderaan :)
  • Leipo
het is inderdaad een cool proggie.. ik heb je vorige versie heel lang gebruikt totdat winbar kwam: ik vind winbar er toch mooier uitzien en kwa functionaliteit scheelt het niets.
Op zondag 30 september 2001 16:34 schreef speed24 het volgende:
Bij mij gebruikt Statbar maar 1744 K :?
  • Mr. B.
Vreemd... op de 1 of andere manier handelt XP het ontop zijn van het venster blijkbaar niet goed af. Zodra ik hier (onder VMware) XP heb draaien zal ik er naar kijken.
As I said: het hele StatBar scherm is opgebouwd uit graphics, zodat je precies weet hoeveel plaats iets in beslag neemt. Dat kun je met een gewoon font nooit precies bepalen (mensen kunnen de meest vreemde fontsizes ingesteld hebben ipv de standaard 96 dpi).
StatBar.nl - @GoT
  • Bobbert
Bobbert
Op zondag 30 september 2001 16:40 schreef grand.lord.of.chaos het volgende:
Bij mij 8172 :)
  • Arno
Arno
PF5A
4152k :)
Jeremy Clarkson
  • DR
DR
6728kb :)
boeiend.... :P
  • Mr. B.
7064 KB hier... ja, het geheugenmanagement van VB is vaag :P
StatBar.nl - @GoT
  • Arno
Arno
PF5A
Op zondag 30 september 2001 16:53 schreef DR het volgende:
boeiend.... :P
Neuh :)
Jeremy Clarkson
  • PPanic
  • Laatst online: 23-11 08:08
Volgens mij is Win Xp best juist in het gebruikte geheugen, en bij mij gebruikt statbar 8008 KB :( .
Maar het is een goed programma dus ik gebruik het wel :D
INVENTARIS
  • PWA
PWA
Wazig al die andere mem troep!!
  • HertogJan
  • Laatst online: 23-11 19:55
Mooi werk hoor, stuk beter dan Winbar. Met winbar crashte alles enorm vaak en had veel moeite met resizen!
  • Mr. B.
Op zondag 30 september 2001 17:43 schreef gerritblaat het volgende:
Mjah, as I said:
Op zondag 30 september 2001 16:54 schreef Mr. B. het volgende:
Owja, verwacht ook vanavond geen replies meer van me... :+
StatBar.nl - @GoT
  • Bobbert
Bobbert
Nou na 2 dagen gebruik:
*de time Synch werkt niet helemaal lekker, staat vaak op rood en als ik dan ff dubbel er op klik en hij probeert het opnieuw (blauw worden) dan gaat tie wel weer op groen..
*af en toe verdwijnt de hele balk en moet ik hem opnieuw opstarten :? da vind ik eigenlijk wel super vaag
*voor de rest, info van HD is wel makkelijk :D
  • C.44
  • Laatst online: 05-08-2020
C.44
TurboCharged Supra Driver
ik heb het progje gehad draaien onder win2k vandaag en het werkte perfect, totdat ik opnieuw opstartte...
ik had de optie automatische met windows meestarten aangezet zodat ik niet iedere keer naar die file opzoek hoef..
daar blijkt win2k dus heel slecht tegen te kunnen, ik had ineens een constante 100% load op de procs, iets waar ik niet blij mee ben :( alle mogelijke shit uitgezet (ook statbar) maar nix hoor 100% load. ik statbar weer gestart, hem gezegd dat ie niet hoeft te starten als ie win2k opstart, en wat denk je ? juist probleem verholpen :)
nu vraag ik mij af of dit een wazige bug is of waar dit aan kan ligge :?
Toyota Supra 3.0i Turbo Targa in Panther Black Mica - 300D || 30D || 10-20 || 50mm 1.8 mk1 || 18-55 || 17-85 || 75-300 || Giottos || Manfrotto || Cullmann || Kenko || Hoya
  • Mr. B.
Op zondag 30 september 2001 22:17 schreef Bobbert het volgende:
Vreemd... probeer eens een andere tijdserver?
Heb ik zo direct geen oplossing voor... maar ik zal d'r straks nog eens over denken, op dit moment ben ik gewoonweg VEEL te brak (het was ergens tussen 3:00 en 3:15 toen ik met een toch wel redelijk bezopen kop m'n nest indook, en 4 uur later werd ik weer wakkergemaakt omdat ik zoals gewoonlijk door de wekker heen sliep)... ja, lang leve de kermis :P
Op maandag 01 oktober 2001 01:00 schreef C44 het volgende:
Wazig... het enige wat StatBar doet is zichzelf onder HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Run neerzetten... het opstarten wordt dan verder door Windows afgehandeld.
StatBar.nl - @GoT
  • Bobbert
Bobbert
Op maandag 01 oktober 2001 08:46 schreef Mr. B. het volgende:
Had ik al gedaan, hielp niets :)
  • Mr. B.
Op maandag 01 oktober 2001 08:50 schreef Bobbert het volgende:
Hmmz... wat voor inetverbinding heb je?
StatBar.nl - @GoT
  • Schonhose
  • Laatst online: 18-11 12:46
Schonhose
Retro Icoon
StatBar crashed bij mij onder WinNT (SP 6).
Exception: (0xc000008f), Address: 0x77f1d479
Hij geeft vervolgens de bovenstaande ruimte niet meer vrij.
Ik moet notabene de concurrent opstarten om de ruimte weer vrij te krijgen.
MSVBVM60.DLL versie 6.00.8495
Enig idee waaraan het ligt? :?
"The thing under my bed waiting to grab my ankle isn't real. I know that, and I also know that if I'm careful to keep my foot under the covers, it will never be able to grab my ankle." - Stephen King
Quinta: 3 januari 2005
  • Bobbert
Bobbert
Op maandag 01 oktober 2001 08:53 schreef Mr. B. het volgende:
via netwerk -> microsoft proxy server
  • freddifish
  • Laatst online: 24-11 17:05
freddifish
schnappi !
Statbar is 8-) !
Time sync is perfect want ons netwerk wordt altijd centraal op (de verkeerde want 5 min afwijkende) tijd gezet.
alleen dat font met die digits vind ik minder duidelijk, zeker in het windows default scheme. Kun je hier niet een gewoon fixed font voor gebruiken ?
'people say I'm a drinker, but I'm sober half the time' - Mick Jagger | mail: freddifish_AT_gmx.net
  • Mr. B.
Op maandag 01 oktober 2001 10:37 schreef Morpheus25 het volgende:
Dubbelklikken op de rand van je taskbar werkt ook ;)
Ik heb hier versie 6.0.89.64... de link heb ik hierboven al ergens gepost, probeer die eens :)
Op maandag 01 oktober 2001 11:23 schreef Bobbert het volgende:
Vreemd dat ie het de ene keer wel doet en de andere keer niet... lijkt me een time-out probleem ofzo :?
Op maandag 01 oktober 2001 13:09 schreef freddifish het volgende:
Statbar is 8-) !
Op zondag 30 september 2001 16:44 schreef Mr. B. het volgende:
StatBar.nl - @GoT
  • Schonhose
Schonhose
Retro Icoon
Op maandag 01 oktober 2001 16:13 schreef Mr. B. het volgende:
Ow....ok :)
Neergehaald en geprobeerd: hetzelfde probleem. Statbar reserveerd wel de ruimte maar verschijnt niet. Eerdere versies deden het perfect. :?
  • Mr. B.
Op maandag 01 oktober 2001 17:22 schreef Morpheus25 het volgende:
Ow....ok :)
Hier werkt ie perfect op NT4 SP6, zowel in VMware als op een echte machine... vaag... :?
StatBar.nl - @GoT
  • Schonhose
Schonhose
Retro Icoon
Intresse in de output van Dr. Watson??? Dan stuur ik dat ff op.
Ik zal vanavond eens kijken op Win98SE.
  • superjoost
  • Laatst online: 20:09
wow.. kun je trouwens ook je harddisk ontkoppelen (win2k)
met deze versie ?
Pagina: 1 2 Laatste
