[SC] Cryptocurrency Slowchat topic #29 Vorige deel Overzicht Volgende deel Laatste deel
Pagina: 1 ... 204 ... 252 Laatste
  • 944.711 views
  • Stukfruit
Sterkte @Guere!
Dat zit wel Schnorr.
  • Darrell
  • Laatst online: 23:14
Darrell
Fiat moonboy
.28 BTC = Top 1 percent Hodler
Grok answers - Estimated Approx Effective Supply is 16.8 million BTC
Determining the amount of Bitcoin (BTC) needed to be in the top 1%, 5%, and 10% of holders “forever” is complex due to Bitcoin’s uneven distribution, lost coins, and varying holder numbers over time. The estimates below are based on current data (as of April 2025) and assumptions about Bitcoin’s fixed supply of 21 million BTC, with adjustments for lost coins and concentration of ownership. These figures are approximations, as precise holder numbers and future distribution patterns are uncertain. All calculations assume the current global population of approximately 8 billion and account for factors like lost coins and whale accumulation.
Key Assumptions
• Total Bitcoin Supply: 21 million BTC, with ~19.8 million currently in circulation.
• Lost Coins: Estimates suggest 20–29% of Bitcoin is lost forever (e.g., inaccessible wallets, Satoshi’s unspent coins). A conservative 20% loss (4.2 million BTC) reduces the effective supply to ~16.8 million BTC.
• Uneven Distribution: Bitcoin is highly concentrated, with ~1.86% of addresses holding over 90% of BTC, and the top 10,000 investors (0.01% of holders) owning ~27% of the supply.
• Holder Population: The number of Bitcoin holders is estimated to be between 50–200 million globally, far less than the world population, but for “forever” estimates, we assume mass adoption scenarios where up to 1 billion people might hold Bitcoin.
• “Forever” Context: To be in the top percentiles indefinitely, you need to hold more than the average under a mass adoption scenario, accounting for whale accumulation and lost coins reducing available supply.
Methodology
The estimates are derived by:
1. Calculating the effective circulating supply (21M - 20% lost = 16.8M BTC).
2. Estimating the BTC needed to be in the top 1%, 5%, and 10% of holders under a simplified model where 1 billion people adopt Bitcoin, then adjusting for real-world concentration based on current blockchain data and whale behavior.
3. Using posts on X and web analyses for additional context, acknowledging their speculative nature.
Estimates for Top 1%, 5%, and 10% of Bitcoin Holders
Top 1% (Top 1% of 1B = 10M holders)
• Theoretical Calculation: If 16.8M BTC were evenly distributed among 1 billion people, each would hold 0.0168 BTC. To be in the top 1% (10M holders), you’d need more than the 99th percentile holder. Assuming a power-law distribution (as Bitcoin wealth follows), the top 1% likely hold significantly more than the average.
• Adjusted Estimate: Current analyses suggest 0.28 BTC guarantees top 1% status in today’s market due to concentration and lost coins. For “forever” with mass adoption, whale accumulation (e.g., top 10,000 holders owning 27%) suggests you’d need ~0.21–0.26 BTC to stay ahead of 99% of holders, as fewer coins will be available to the masses.
• Final Estimate: ~0.25 BTC to be in the top 1% forever, assuming 20% lost coins and high concentration.
Top 5% (Top 5% of 1B = 50M holders)
• Theoretical Calculation: To be in the top 5% (50M holders), you’d need more than the 95th percentile holder. With 16.8M BTC, the average holding per person (1B) is 0.0168 BTC, but the top 5% would hold disproportionately more due to wealth skew.
• Adjusted Estimate: Posts on X suggest 0.2 BTC for the top 5% in current conditions, but with mass adoption, the threshold decreases due to wider distribution. Accounting for whales and lost coins, ~0.1–0.2 BTC is likely sufficient to outrank 95% of holders.
• Final Estimate: ~0.15 BTC to be in the top 5% forever, reflecting moderate concentration.
Top 10% (Top 10% of 1B = 100M holders)
• Theoretical Calculation: To be in the top 10% (100M holders), you’d need more than the 90th percentile holder. The average holding (16.8M ÷ 1B) is 0.0168 BTC, but the top 10% would hold more due to uneven distribution.
• Adjusted Estimate: X posts estimate 0.026–0.1 BTC for the top 10% today, reduced by lost coins and whale holdings. For mass adoption, ~0.05 BTC should suffice, as the bottom 90% will hold minimal amounts (e.g., microtransactions or fractional sats).
• Final Estimate: ~0.05 BTC to be in the top 10% forever, given high whale control and limited supply.
Caveats
• Dynamic Distribution: Bitcoin’s distribution may become more or less concentrated over time. If whales consolidate further, thresholds could rise; if adoption spreads, they could fall.
• Lost Coins Uncertainty: If more than 20% of BTC is lost, thresholds decrease further (e.g., 29% lost reduces supply to ~15M BTC).
• Holder Numbers: The assumption of 1 billion holders is speculative. If fewer people adopt Bitcoin, less BTC is needed to rank in the top percentiles.
• Data Limitations: Blockchain data doesn’t reveal individual owners (one person can control multiple addresses), and exchange-held BTC skews perceptions of retail ownership.
• Market Volatility: These estimates focus on BTC amounts, not USD value, which fluctuates (e.g., 0.25 BTC ≈ $23,500 at $94,000/BTC as of April 2025).
Conclusion -
To be in the top 1%, 5%, and 10% of Bitcoin holders “forever,” you’d likely need ~0.25 BTC, ~0.15 BTC, and ~0.05 BTC, respectively, based on a 16.8M BTC effective supply and mass adoption by 1 billion people. These figures are lower than current estimates (e.g., 0.28 BTC for top 1%) due to lost coins and whale concentration reducing available BTC for the masses.
https://www.reddit.com/r/Bitcoin/s/0xl71FxRoz
  • anti elppa
  • Laatst online: 28-10 17:11
Darrell schreef op maandag 28 april 2025 @ 06:19:
Key Assumptions
Methodology
Caveats
Conclusion -
Afbeeldingslocatie: https://tweakers.net/i/V2qPo-ihw0ex-ekmHeisY-b-0hc=/fit-in/4920x3264/filters:max_bytes(3145728):no_upscale():strip_icc():strip_exif()/f/image/dEGjqvENZA1ZCKKaIuMxclpY.jpg?f=user_large
  • Darrell
Darrell
Fiat moonboy
Geen ETF bulletin vandaag dus even wat anders om men de maandagochtend door te helpen.
  • anti elppa
Darrell schreef op maandag 28 april 2025 @ 06:55:
is dat verhaal bullish dan? Sorry heb er echt maar 2 zinnen van gelezen
  • Numbers
  • Registratie: December 2021
Key Assumptions
Methodology
Caveats
Conclusion -
Afbeeldingslocatie: https://tweakers.net/i/txUTGbGlljitMjSv8_8Tsq_EK8U=/800x/filters:strip_icc():strip_exif()/f/image/gGHBTfmyXldmZnfPcNKEj894.jpg?f=fotoalbum_large
[ Voor 4% gewijzigd door Numbers op 28-04-2025 08:03 ]
  • BTC100K2021
  • Laatst online: 28-10 14:10
BTC100K2021
Kijk eens dom, ja ho maar.
@Guere Sterkte!
  • TakutoRadiance
  • Laatst online: 26-08 21:54
Key Assumptions
Methodology
Caveats
Conclusion -
Ik merk een trend: mensen beginnen me de laatste tijd belachelijk lange AI antwoorden te sturen in de verwachting dat ik dat dan maar ff ga lezen.
Afbeeldingslocatie: https://tweakers.net/i/A-YDc6jmesSWZSdkFYdiBMr-FGY=/800x/filters:gifsicle():strip_exif()/f/image/k5NBOGAT2J4DnLHrQhpfRBHp.gif?f=fotoalbum_large
  • Aeronaut
  • Registratie: Maart 2024
  • Laatst online: 23:15
Aeronaut
PF sinds TOP '24
TakutoRadiance schreef op maandag 28 april 2025 @ 08:25:
Daarom doorscrollen en conclusie/samenvatting lezen.
Zet de moeilijke stap, Praat over je gevoelens, Verstop ze niet, Deel ze met de juiste personen
  • BTC100K2021
BTC100K2021
BTC loopt toch vrij soepel omhoog richting de 95K.
Deze week weer 5 cijfers voor de komma?
  • Wippie1234
BTC100K2021 schreef op maandag 28 april 2025 @ 09:30:
Ik hoop het wel, maar waarschijnlijk niet
  • Eusebius
En ETH dan ...?
* kijkt naar koersen en eigen PF
.. oh ja die had ik gelukkig niet meer.
hoi
  • Eusebius
Wippie1234 schreef op maandag 28 april 2025 @ 09:50:
Ik hoop het niet, maar waarschijnlijk wel
Waarom hoop je het niet? Te volatiel niet goed?
hoi
  • Kol Nedra
  • Laatst online: 28-10 09:48
ik had $100k wel vorige week verwacht, deze week dan wel!
nothing stops this train
  • Wippie1234
Eusebius schreef op maandag 28 april 2025 @ 09:52:
Oeps, in mijn hoofd stonden "wel" en "niet" omgedraaid. :)
  • Danjel
Wat? Gaan we nu weer niet wel en niet omdraaien?
They who buy the dip, deserves the rip.
  • Wippie1234
Danjel schreef op maandag 28 april 2025 @ 10:00:
Wel blijven een beetje op en neer gaan, net zoals de meeste muntjes
  • sh4d0wman
  • Laatst online: 16:46
sh4d0wman
Attack | Exploit | Pwn
Wippie1234 schreef op maandag 28 april 2025 @ 10:04:
We blijven een beetje op en neer gaan, net zoals
Afbeeldingslocatie: https://encrypted-tbn0.gstatic.com/images?q=tbn:ANd9GcRKQjsyyNDGJxGgCGVVlWUHAa1YcPQAjFjwLW6sYavOuJvkMhRD2ZKe_dalI59wZgNcxMY&usqp=CAU
Could not resist. :> Hier onweer (en storm) in aantocht. Hoop dat mijn dak blijf zitten want er zijn in de buurt geen bruggen. :/
  • knakworst
  • Laatst online: 22:41
knakworst
Get more sats!
Nexo herbetreedt US market. Bullish voor Nexo token.
[ Voor 6% gewijzigd door knakworst op 28-04-2025 10:15 ]
  • Darrell
Darrell
Fiat moonboy
anti elppa schreef op maandag 28 april 2025 @ 06:56:
Geen idee wat je hier zei. Sorry heb er echt maar 2 woorden van gelezen.
  • kazzzdafke
  • Laatst online: 28-10 20:40
Belangrijk weekje wel..
We zijn er bijna, hopen dat we er kunnen doorbreken, of.. ik blijf dit scenario ook nog altijd heel plausible vinden dat we een pak lager droppen.
Afbeeldingslocatie: https://tweakers.net/i/RJFAihjEx7yvaeeyJx2PjERSRv0=/800x/filters:strip_exif()/f/image/lOc0a0ulwZWZKFgcUcgcu3AC.png?f=fotoalbum_large
  • Moiety
  • Laatst online: 27-10 15:37
Als iedereen nu eens “me” gaat schrijven ipv “mij”, dan worden de teksten vanzelf korter. Dunkt me.
  • Alpina
  • Registratie: November 2019
  • Laatst online: 13-10 21:51
Moiety schreef op maandag 28 april 2025 @ 10:48:
Me bags worden gepumpt.
  • BTC100K2021
BTC100K2021
kazzzdafke schreef op maandag 28 april 2025 @ 10:43:
Afbeeldingslocatie: https://i.imgflip.com/hynx2.jpg?a484752
  • Nubtrix
  • Registratie: September 2020
  • Laatst online: 17-05 11:17
Maandag moondag.
  • Moiety
Big wave incoming
Afbeeldingslocatie: https://tweakers.net/i/8WW7PwHJqaar20RrBEQmQh6nrcA=/fit-in/4000x4000/filters:no_upscale():gifsicle():strip_exif()/f/image/oc7TuE2naSDcBwf0hQBx1zNC.gif?f=user_large
  • kazzzdafke
  • knakworst
knakworst
Get more sats!
Nog 5 tot de 100 :p
  • koelebobes
  • Laatst online: 25-10 18:28
koelebobes
Wen BTC €100K
WAGMI <3
Afbeeldingslocatie: https://tweakers.net/i/MkZwaSjWDuRbLCX2RjlhFBnQm1w=/fit-in/4000x4000/filters:no_upscale():gifsicle():strip_exif()/f/image/UZPasyrli9SZkEOVmbaxvxPS.gif?f=user_large
BTC €94.837,08
  • ByteMe_
Toch maar weer een TP gepakt. Het wordt een dure maand, dus daar mag BTC winst mij helpen de pijn te verzachten
  • Danjel
SUI ook weer sterk!
  • BTC100K2021
BTC100K2021
When significante level gepakt?
Die lower high op de 4H van 2 maart hebben we in ieder geval te pakken wat mij betreft.
Volgende halte is 100K.
[ Voor 65% gewijzigd door BTC100K2021 op 28-04-2025 13:16 ]
  • knakworst
knakworst
Get more sats!
6 cent in 2011.
  • knakworst
knakworst
Get more sats!
Liquidaties incoming.
Afbeeldingslocatie: https://tweakers.net/i/_xydq5Qcacq3h1cDNIYM4hTk0ts=/x800/filters:strip_icc():strip_exif()/f/image/sYxfODsIqQ7u8rZFWfvNGQRE.jpg?f=fotoalbum_large
  • Kol Nedra
  • BTC100K2021
BTC100K2021
Afbeeldingslocatie: https://i.pinimg.com/736x/f0/8d/5b/f08d5b6e4d76488832a121a37ebf6a3e.jpg
  • Kol Nedra
en terecht! don't short against a winner :)
  • souljah1h
souljah1h
sneller dan het slotje!
https://nos.nl/artikel/25...-treft-spanje-en-portugal
Even geen (BTC) betalingen voor hun.
Wat doen wij/jullie met onze bitcoinen als het als het energie-netwerk lange tijd down is? Of hebben we dan andere problemen :+
[ Voor 50% gewijzigd door souljah1h op 28-04-2025 13:55 ]
  • knakworst
knakworst
Get more sats!
Geitenbende. Blijkt goud toch maar weer een stuk praktischer te zijn.
Hodl.
  • BTC100K2021
BTC100K2021
knakworst schreef op maandag 28 april 2025 @ 14:21:
Hodl.
Ja super praktisch. Alle winkels gaan dicht zodra de stroom uitvalt.
Sta je met je goudstaven te zwaaien voor een dichte deur.
  • knakworst
knakworst
Get more sats!
Het zou me verbazen als we de 100k deze week NIET zien.
  • Darrell
Darrell
Fiat moonboy
knakworst schreef op maandag 28 april 2025 @ 14:48:
Dat dacht @BTC100K2021 in 2021 ook.
  • Alpina
Nog even een paar achtergelaten broeders oppikken en dan kunnen we door naar Valhalla.
  • BTC100K2021
BTC100K2021
Toch is het wel bijzonder dat het sentiment op de brede markten weer positief lijkt te draaien terwijl daar weinig reden toe is behalve hopium.
Geen vrede in Oekraïne nog.
Geen tariefdeal VS en China.
Tarieven met andere landen zijn slechts gepauzeerd voor 90 dagen.
Verschillende bedrijven die fungeren als "kanarie in een kolenmijn" met slechte cijfers en vooruitzichten, bijvoorbeeld PepsiCo.
Creditcard debt print dagelijks een nieuwe ATH:
https://fred.stlouisfed.org/series/CCLACBW027SBOG
When moon.
[ Voor 10% gewijzigd door BTC100K2021 op 28-04-2025 14:56 ]
  • Oepsje
  • Laatst online: 14-01 16:18
BTC100K2021 schreef op maandag 28 april 2025 @ 14:54:
When moon.
Eens voor wat betreft de aandelenmarkten maar dat BTC positief reageert is op zich niet gek toch! Mooie hedge tegen al die onzekerheid die je aanstipt.
  • Amens
  • Laatst online: 28-10 11:37
Na eerder deze week weer te zijn ingestapt heb ik mijn positie in zowel BTC als ETH weer uitgebreid vandaag. Hoop op een korte termijn stijging van beide, maar ben vooral weer ingestapt voor de mid lange termijn. 200k soon?
  • Kol Nedra
Alpina schreef op maandag 28 april 2025 @ 14:52:
Halls of Valhalla? (Judas Priest) _/-\o_
  • Frozen-North
  • Laatst online: 29-10 08:47
Kol Nedra schreef op maandag 28 april 2025 @ 15:05:
Bathory – Valhalla :D
  • Kol Nedra
souljah1h schreef op maandag 28 april 2025 @ 13:52:
als stroom uitvalt kun je juist WEL betalen met BTC via Lightning Network: van mobiel naar mobiel, omdat bitcoin decentraal is is het niet afhankelijk van Spaanse stroomvoorziening...... de stroom van vulkanisme of van waterkrachtcentrales in Afrika kunnen mooi blijven door runnen :)
  • Luuk
Is het al donderdag?
  • TakutoRadiance
RL Grime ft. Djemba Djemba - Valhalla <3
  • Darrell
Darrell
Fiat moonboy
We yanken alweer omlaag.
  • sjorremans
  • Laatst online: 08-08 22:27
Yankees blijven amateurs
  • ByteMe_
Kut amerikanen...
  • knakworst
knakworst
Get more sats!
Het zou me verbazen als we de 80k deze week NIET zien.
Fixed.
  • TakutoRadiance
93,779 bounce incoming! :)
  • Frozen-North
Mag van mij nog wel wat lager. Dan kan ik weer wat verse fiat inzitten.
Daarna uiteraard weer omhoog! :P
  • ByteMe_
80k there we gooooo
  • keanu_
  • Laatst online: 06-01 20:59
  • Kol Nedra
  • Coldcat
  • Laatst online: 21-10 18:35
Coldcat
HODL
knakworst schreef op maandag 28 april 2025 @ 10:15:
Was te verwachten. De koers gedroeg zich ook erg raar de laatste tijd!
Lets go met die shitcoin!
  • MrMrq
  • Registratie: Februari 2021
  • Laatst online: 18:42
BTC100K2021 schreef op maandag 28 april 2025 @ 14:31:
Toch kun je met een kg goud makkelijker een ruit ingooien dan met een ledger.
My 2 cents.
Maktub
  • koelebobes
koelebobes
Wen BTC €100K
Burgers being burgers
Afbeeldingslocatie: https://tweakers.net/i/_DcQX-5PplmjbxHqD_zrG-aVWN8=/fit-in/4000x4000/filters:no_upscale():gifsicle():strip_exif()/f/image/odQWsYd1RfjkbKyUOrAYEwHN.gif?f=user_large
Afbeeldingslocatie: https://tweakers.net/i/oMLkgGYgatmd2RbZ_2tdL3EBsKg=/fit-in/4000x4000/filters:no_upscale():strip_exif()/f/image/T4dnEMiiVigDQfo70236eofK.png?f=user_large
BTC €94.837,08
  • Kol Nedra
MrMrq schreef op maandag 28 april 2025 @ 17:15:
My 2 sats.
ftfy!
  • tomtom901
  • Laatst online: 18:16
tomtom901
95k blijft een hobbel..
Afbeeldingslocatie: https://tweakers.net/i/nkPIpMMSIKU8-9-zMhZYoKKWr74=/800x/filters:strip_exif()/f/image/fDzpjOCafbzSbnY8iC6WtRY9.png?f=fotoalbum_large
  • JoebarRC
  • Registratie: November 2016
  • Laatst online: 27-10 11:46
Nee yanks blijven een hobbel, zonder die vervelende lui hadden we er allang doorheen gegaan
  • MrFX
  • Laatst online: 29-10 06:58
JoebarRC schreef op maandag 28 april 2025 @ 18:11:
Zonder die lui hadden we ook nooit zo hoog gestaan. Cheque vanuit de overheid, QE gaven in het verleden een aardige boost aan BTC.
  • Wiley99
  • Laatst online: 18:35
Kol Nedra schreef op maandag 28 april 2025 @ 15:42:
je maakt vast een grapje, maar ik mis de /s
Als je in een stroomstoring zit doe je heel weinig met bitcoin.
Hoe denk je dat die lightning nodes aan hun energie komen? Of de zendmasten waarmee je ze wil bereiken?
(nee, we gaan niet naar 'ik draai mijn eigen node op mijn mobiel en mijn betaalpartner ook')
  • BTC100K2021
BTC100K2021
Morgen een enorme miss op deze:
https://www.investing.com...cb-consumer-confidence-48
En dan alles rekt.
  • MrFX
  • cavemees
  • Registratie: Mei 2017
  • Laatst online: 23:17
Wiley99 schreef op maandag 28 april 2025 @ 18:35:
Jawel gaan we wel naartoe, sterker nog, draait al 2 jaar: Minima blockchain
  • Darrell
Darrell
Fiat moonboy
Ik las gister dat de hoeren niets meer te doen hebben en dat dat doorgaans een recessie voorspelt.
  • Vis
  • Laatst online: 21:46
Vis
Afbeeldingslocatie: https://tweakers.net/i/VFO72S8IdI71SV62rWFSXH7NFqo=/800x/filters:strip_icc():strip_exif()/f/image/8MnxYboQTho4JKPLCI3YpfLy.jpg?f=fotoalbum_large
De maandag is bijna voorbij... Wen moon carl?
  • Darrell
Darrell
Fiat moonboy
Vis schreef op maandag 28 april 2025 @ 19:35:
Even wachten tot Bob weer alles verkocht heeft.
  • tomtom901
tomtom901
Nee hoor. De markt doet wat hij wil.
[ Voor 5% gewijzigd door tomtom901 op 28-04-2025 19:49 ]
  • Wiley99
cavemees schreef op maandag 28 april 2025 @ 19:22:
Ik bedoelde 'het gesprek' over Lightning, niet zozeer 'dikke tech' in het algemeen.
Leuke tech, die Minima, hoewel de naam hier in NL een wat vreemde connotatie heeft, maar mag wel nog wat tractie krijgen, 100k handel per 24u en een MC van 12M kwam niet uit Spanje en Portugal
Oh en nog vergeten, ook Minima zal een keer consensus over het netwerk willen halen. Je hebt niets aan 2 volledige nodes die het wel met elkaar eens zijn. Stroomstoringen zijn gewoon niet handig voor blockchains.
[ Voor 18% gewijzigd door Wiley99 op 28-04-2025 20:02 ]
  • cavemees
Wiley99 schreef op maandag 28 april 2025 @ 20:00:
Mee eens. Als nodes plat komen te liggen door een stroomstoring heeft elke blockchain een probleem. Dan maakt centraal of decentraal ook niet meer uit.
Dan ben ik eigenlijk wel benieuwd wat het met het BTC network zou doen in de eerste uren als een Foundry of AntPool uitvallen... https://b10c.me/blog/015-bitcoin-mining-centralization/
[ Voor 10% gewijzigd door cavemees op 28-04-2025 20:21 ]
  • Kol Nedra
ik kan die gast echt niet aanzien, net zoals die ene Ben ;w
  • Wiley99
cavemees schreef op maandag 28 april 2025 @ 20:14:
Zorgelijker is als ze niet uitvallen en alleen maar groter worden, inderdaad.
Als ze wel uitvallen duren de blokken misschien wat langer en krijgen andere miners een grotere 'kans' om de eerste te zijn. En wordt de decentralisatie wat groter. Prijs wel weer omlaag waarschijnlijk (want fintech stress),
  • Tourniquet
  • Laatst online: 22:40
Tourniquet
Hiya, fellas!
Bitonic heeft nu target-orders. *O*
https://bitonic.nl/nl/new...bitonic-app-target-orders
Dat mistte ik nog na het stoppen van Bl3p, ben weer blij. :P
If our brain was easy to understand, we would be too dumb to understand.
  • jvel92
  • Laatst online: 12-10 22:06
Wat vandaag vooral laat zien, is het belang van thuis wat cash geld achter de hand te hebben. Je gaat bij de lokale Albert Heijn niet plotseling je bananen kunnen afrekenen met wat sats of een andere crypto.
Mocht de poep echt de ventilator raken, dan zou je eigenlijk fysiek goud of zilver moeten hebben. Op de korte termijn heb je dan even niets aan je sats op de blockchain.
jvel92 schreef op maandag 28 april 2025 @ 21:30:
Mooi dat er ook gelijk commercials van de overheid verschijnen over dat je je electrische auto niet mag opladen tussen 16 en 21 uur :')
Geeft mij het gevoel dat de regering niet klaar is voor de toekomst, aan de andere kant te weinig stroom salderingsregeling weer terug :+
  • jvel92
Verwijderd schreef op maandag 28 april 2025 @ 21:51:
Joh we zijn in Europa inderdaad niet klaar voor de toekomst. Als je wilt groeien en/of überhaupt welvaart wilt behouden moet je zorgen voor voldoende én betaalbare energie. Beiden de laatste jaren beetje een issue in Europa :P.
Hoop dat ze in de EU snel terugkomen op de anti-groei mindset en denken dat we het wel met minder energie kunnen doen, als we de auto maar op een ander moment opladen en de AC wat minder hard laten lopen :+
  • Coldcat
Coldcat
HODL
De toekomst begint met nu. Alles werkt prima!
Doe eerst maar 1 mln BTC reserve aanleggen. Die stroominfra mag daarna. Als er dan nog iemand met draadjes in de weer wilt.
[ Voor 12% gewijzigd door Coldcat op 28-04-2025 22:29 ]
  • YES
  • Laatst online: 27-10 20:32
YES
Bullflag! Vlaggenmast van de stierenvlag is de stijging die erna volgt volgens de patronen wijsheid. Dus volgende week dinsdag zitten we richting ATH. Can't go tits up.
Afbeeldingslocatie: https://tweakers.net/i/IR8HiydrLkt4-CMHKwYfMBlrVAo=/800x/filters:strip_exif()/f/image/UIaFQ8Isa7xq8T8HluWEDPde.png?f=fotoalbum_large
  • UnMetal
  • Registratie: Februari 2025
  • Laatst online: 15-02 23:17
Begrijpen jullie welicht waarom ik een bepaalde crypto niet kan kopen op mijn exchange?
Het gaat om Alpaca finance. Ik krijg al dagenlang, your order could not be placed.
Hetzelfde geldt voor Matr1x.
Kan het zijn dat alleen mijn exchange hier last van heeft? Ik heb geen bybit of bitvavo.
  • Darrell
Darrell
Fiat moonboy
YES schreef op maandag 28 april 2025 @ 23:14:
Afbeeldingslocatie: https://tweakers.net/i/1JaKGKsSFDFhaOX_ZHoFxJuEDow=/fit-in/4000x4000/filters:no_upscale():gifsicle():strip_exif()/f/image/pza4meDd7io3RC3E5uIYOj0o.gif?f=user_large
  • elektriekert
  • Laatst online: 21:36
Nu nog een dikke stierelul omhoog
  • Coldcat
Coldcat
HODL
Misschien een USDT pair dat niet meer support wordt wegens regelgeving?
  • MrFX
elektriekert schreef op dinsdag 29 april 2025 @ 00:01:
Afbeeldingslocatie: https://tweakers.net/i/9o6BFXQhN4xwvjVzUyvgBr3X9M4=/fit-in/4000x4000/filters:no_upscale():gifsicle():strip_exif()/f/image/QYASabMosGSs3KaZ7CeL0kSK.gif?f=user_large
  • YES
YES
Ik ben wel een keer weer toe aan een potje juinen bij de Bruna
  • WarsemaW
  • Registratie: Maart 2020
  • Laatst online: 27-09 20:33
YES schreef op dinsdag 29 april 2025 @ 08:16:
Afbeeldingslocatie: https://tweakers.net/i/qdN7IXm4dLkkFfaFdRSGRa85q3Y=/fit-in/4000x4000/filters:no_upscale():gifsicle():strip_exif()/f/image/GQZiQcQH2ki7akb9WKgd43Ny.gif?f=user_large
  • kazzzdafke
hahaha ik had deze getekend, die kwam netjes overeen met potientiele outbreak op mijn bullish lijn..
Afbeeldingslocatie: https://tweakers.net/i/UqVewICPGmG8GOCipjPAuvTyF6E=/800x/filters:strip_exif()/f/image/LT0DugNdOkzthnzS5zAyebkK.png?f=fotoalbum_large
  • Coldcat
Coldcat
HODL
Dikke inflow bij IBIT! Ik kan de totalen niet zien maar bijna $1 miljard. Wel wat negatief bij de rest $300m.
Zijn er binnenkort weer significante events naast de sentiment index vandaag?
  • kazzzdafke
Coldcat schreef op dinsdag 29 april 2025 @ 09:08:
Morgen de cijfers van het consumentenvertrouwen...
  • BTC100K2021
BTC100K2021
https://www.bitcoinstrategyplatform.com/etfs
Deze gisteren ook nog:
[ Voor 11% gewijzigd door BTC100K2021 op 29-04-2025 09:22 ]
  • Darrell
Darrell
Fiat moonboy
Op je telefoon toevallig? Vet irritant maar in landscape zie je ze wel.
  • Coldcat
Coldcat
HODL
Darrell schreef op dinsdag 29 april 2025 @ 09:30:
Yep. Ik dacht dat het aan mn telefoon lag door een te lage resolutie. Niet de enige dus.
  • ByteMe_
-verkeerd topic
[ Voor 94% gewijzigd door ByteMe_ op 29-04-2025 10:14 ]
  • BTC100K2021
BTC100K2021
ByteMe_ schreef op dinsdag 29 april 2025 @ 10:03:
Toch maar overstag gegaan van 3 deco mesh wifi spots naar 2 van KPN. Het was gewoon echt instabiel op zolder en ook zelfs 1e verdieping.
Nog geen haperingen gehad in calls, hopelijk blijjft het stabiel. Toch blijft het jammer dat ik max 100mbps kan halen op zolder terwijl de verbinding verhoogd is naar 1gbps. Maar kabels door het hele huis wil ik gewoon niet. So be it.
Afbeeldingslocatie: https://media.makeameme.org/created/goed-verhaal-boeit.jpg
  • Blijf on-topic, hypotheken, Corona/COVID19, voetbal en zonnepanelen zijn bijv. offtopic. Politiek, Trump en Elon Musk zijn alleen on-topic als dit relevant is mbt crypto.
