LinkedIn vraagt verificatie door 3rd party met paspoort / ID
Pagina: 1 2 Laatste
  • droesm
  • Registratie: December 2015
  • Laatst online: 16-11 10:18
Ik hoop uiteindelijk wat ik hier deel anderen helpt. Dit is wat ik per mail terug krijg op mijn melding ( ingediend via TSO-DPO formulier onder "I am unable to login to my account"). Ik vind een aantal dingen uit het antwoord nogal tegenstrijdig lezen (zoals geen acceptatie van IDs en verderop "If you'd like LinkedIn to assist directly with the process, please ensure that you have shared your ID data with us". En ik heb geen idee wat hiermee wordt bedoeld: "If we don't hear from you, we may need to remove your identity verification temporarily until this is resolved." Kan ik dan weer even bij mijn account (zal wel niet)? Anyway hier het hele bericht ter informatie:
Hi,
I hope this message finds you well.
I apologize for any inconvenience, but we no longer accept IDs via email attachment. In order for you to regain access back to this account, please upload a scanned image of a government issued ID (for example: a driver's license, passport, or country ID) through the following link:  https://www.linkedin.com/checkpoint/challenge/idv-start/..... Please make sure that the identification used contains your photo, name, and signature. The verification process will be handled by Persona. If you'd like LinkedIn to assist directly with the process, please ensure that you have shared your ID data with us.
Once you've completed the upload of your ID, kindly respond to this message, so we can help you gain access to your LinkedIn account. If we don't hear from you, we may need to remove your identity verification temporarily until this is resolved.
If you are located in Canada, the EU, UK, or Northern Ireland, you may use an alternative verification method by printing the Affidavit of Identity and signing it before a Notary Public. Once notarized, this form can be scanned and attached in your support case.
Affidavit of Identity form: https://www.linkedin.com/help/linkedin/answer/a1342243/
I understand that this may be a bit of an extra step, but it's essential to ensure the security and authenticity of your account. If there's anything unclear or if you need further assistance, please don't hesitate to reach out.
We look forward to hearing from you soon.
Regards,
Shabreen,
LinkedIn Member Safety and Recovery Consultant
  • Laguna
  • Laatst online: 17-11 23:02
Laguna
Connaisseur
@droesm ik heb helaas geen tips. Ik kan wel het bericht delen dat ik van AP had ontvangen, na eerst 6 maanden regelmatig gebeld te hebben voor een update en enkel te horen te krijgen dat mijn melding nog in behandeling is. Al komt dit bericht op hetzelfde neer:
Members only:
  • Laguna
Laguna
Connaisseur
Laguna schreef op woensdag 21 oktober 2026 @ 23:53:
Iemand nog suggesties om mijn account met al mijn zakelijke contacten terug te krijgen?
Eindelijk na 1,5 jaar weer toegang tot m'n LinkedIn account. Ik had aangenomen dat mijn VPN gebruik de restrictie had veroorzaakt, maar mogelijk was mijn account destijds al gecompromitteerd. Wat ik heel vreemd vind aangezien ik in de veronderstelling was dat 2FA aan stond, dus hoe het heeft kunnen gebeuren dat mijn profielnaam en titel waren aangepast is mij nog steeds een raadsel.
Het helpt niet dat LinkedIn hier niet op ingericht is. Ik wist namelijk niet dat er een andere naam op mijn profiel stond. Aangezien mijn account was beperkt was het voor niemand meer zichtbaar. LinkedIn vraagt vervolgens om je identiteit te bevestigen maar dat is een doodlopende weg aangezien ze vervolgens domweg de naam op je ID vergelijken met je profielnaam en die komt niet overeen dus wordt het verzoek afgewezen. Uiteindelijk kreeg ik na sparren met een AI-chatbot de tip om het volgende formulier te gebruiken:
https://www.linkedin.com/help/linkedin/ask/ppq
Ik moest dan wel een ander emailadres gebruiken anders is het onmogelijk om het formulier succesvol te versturen, vermoedelijk wederom vanwege de naam die niet overeenkomt (al krijg je geen duidelijke foutmelding). Vervolgens in een mailwisseling alles uitgelegd en nog dezelfde dag had ik weer toegang tot mijn account.
Als eindgebruiker is dit echt een gedrocht van een proces en het is dat ik redelijk handig ben, maar de gemiddelde persoon komt hier gewoon niet uit en met de LinkedIn support accounts op Instagram en Facebook kwam ik ook niet verder. De gehele ondersteuning is uiteraard uitbesteed aan India (want goedkoop) en je moet zelf maar uitzoeken hoe je geholpen kan worden. Even bellen of mailen is helaas niet mogelijk bij dit soort molochs.
  • Zenomyscus
  • Laatst online: 07:51
Iedere keer als dit topic weer voorbij komt stijgt mijn bloeddruk. Ik zou dus never nooit een 3D scan van mijn gezicht en mijn paspoort opsturen naar zo'n achterlijk Amerikaans bedrijf. Dit bevestigt maar weer eens mijn haat tegenover Amerikaanse bedrijven. 0 respect voor gebruikers.
  • Laguna
Laguna
Connaisseur
@Zenomyscus begrijpelijk, wie weet verandert dat ooit nog. Ik ben wel benieuwd wat uiteindelijk het resultaat gaat zijn van mijn melding bij de Autoriteit Persoonsgegevens. Al ligt die nog altijd bij de internationale tak en onduidelijk hoe lang het nog gaat duren.
  • Dem
  • Registratie: Oktober 2026
  • Laatst online: 10:12
Dem
Mooi!
Bij mij komen er wel berichten binnen op mijn account. Het aantal notificaties (het bolletje) loopt op, maar ik ontvang steeds opnieuw hetzelfde bericht over de ID-verificatie...
  • Laguna
Laguna
Connaisseur
@Dem je account was toch beperkt? Dan kan je toch niet inloggen?
  • Dem
Dem
Laguna schreef op dinsdag 17 november 2026 @ 23:01:
Klopt. Voordat je inlogt, dus je wachtwoord intikt, staat mijn account daar met een roodbolletje met een nummer met het aantal notificaties.
Pagina: 1 2 Laatste
