The cloud is lost.
I noticed I was able to control it from the Tuya smart app.
And I saw these commands do not flow through the cloud.
So I figured local control must be possible.
I installed the local tuya integration via HACS.
While still referencing my Tuya IoT Cloud account.
It found the Dehumidifier (CA-704 Smart) and relevant entities.
I used this: https://community.home-as...art-dehumidifier/417301/3
To translate the settings to HA.
A short summary of what I did:
1 – switch (to switch entity)
2 – mode: 0-normal, 1=continuous, 2=dry clothes, 3=purify (to select entity)
4 – target humidity (to number entity)
5 – uv (='ion', to switch entity)
6 – fan speed: 1=low, 3=high (value 2 is unused for my model) (to select entity)
7 – Not working (child_lock)
11 – status; 0 = OK, 8 = tank full or missing (to binary sensor, do not know if 8 means full for my model)
12 – timer (i did not implement this one yet)
102 – sleep mode (to switch entity)
103 – temperature (to sensor entity)
104 – humidity (to sensor entity)
101 – related to timer (don't know exactly)
105 – defrost (my device does not have defrost, did not implement it).
See screenshot below for result.
/f/image/QMDc5ta7CUq8LroD8uPLAhkJ.png?f=fotoalbum_large)
Edit: @kai_the_one check this out!
/f/image/4GT8nvw55ebqjIAJ4FCq99Mx.png?f=fotoalbum_large)
/f/image/aWiCQ43kgORiDVM4ORO7NXoM.png?f=fotoalbum_large)
:strip_exif()/f/image/JJ3sBDa6hxtK5PvEk0cszOAF.jpg?f=fotoalbum_large)
