Een pinemhi family member genaamd Kubrick heeft een nieuwe VR Frontend uitgebracht met pinemhi built in support !
Voor degene die VR gebruiken misschien iets om eens te bekijken.
I’m “Kubrick” on site and wanted to let you know that I’ve released a new free VR front end for VPX called Launchpin and it has PinemHi support built in. It auto starts your watcher on table load and closes the watcher on app exit. PinemHi scoring is available on the back of each table card in VR, as well as featuring in the tournament room.
More features and download link below. Would be appreciative if you can let interested users know!
https://github.com/SibioJak/launchpin-vr
LaunchPin VR — your pinball library, in the room with you.
LaunchPin VR is a VR front end for Visual Pinball X. Instead of alt-tabbing to a desktop list, your whole collection hangs on a curved wall in front of you — every table a card with its real artwork — and you browse, pick, and play without ever taking the headset off. When the game ends, you're back in the room, on the same card, ready for the next one.
The focus fix — the reason this exists
VPX only listens to your controller and plays its sounds when its window holds Windows focus — and Windows loves handing that focus to anything else: the editor, the desktop, whatever popped up last. So the table loads, you press flipper, and nothing happens. Silence. Every VR player has done the dance: headset half off, hunting a mouse to click the game window before the first ball drains. LaunchPin handles the hand-off itself — it launches the table and puts focus on the game where it belongs, every time, so your controller is live and the table sounds are there from the moment it loads. When you quit, it takes focus back for the room just as cleanly. Play, quit, play the next one — the dance is gone.
In the room
• Your library as a wall of cards, built from your own table folders — hundreds of tables, no paging through file lists
• Card backs carry your scores: PINemHi personal bests, all-time bests, and weekly cup boards, right on the table they belong to
• Favourites, a NEW shelf for recent additions, and a letter jump that takes you anywhere in the alphabet in one press
• Table art pulled from the Virtual Pinball Spreadsheet database, matched to your files automatically
World of Virtual Pinball, built in
• A dedicated Tournament Room with the week's challenges and live boards
• Submit scores from inside VR: finish the game, pick your screenshot, and LaunchPin reads the score back to you to confirm before anything is sent — no headset off, no phone photo of a monitor, no misread scores
• Your past submissions, one button away
Made to be painless
• First-run setup finds your VPX install and walks you through the rest in four steps
• Checks for its own updates at launch and tells you in the room when a new version is out
• Full manual installs with the app
Requirements: Windows PC, Visual Pinball X (the GL build for VR), and a PCVR headset — developed and tested on Quest 3 with Virtual Desktop. World of Virtual Pinball features use your own player key from your WoVP profile; everything else works with no account at all.
Install: run the Setup file — it's a per-user install, no admin prompt, and you pick the folder. Windows will warn once because the app isn't code-signed: More info → Run anyway.
