Common Causes & Fixes
- VRAM / RAM Exhaustion:
- Over time, high texture settings, photogrammetry, or terrain pre-caching can fill up your VRAM and system RAM.
- Fix: Lower texture resolution, reduce Terrain/Object LOD, or disable ReBAR for MSFS 2024 via Nvidia Profile Inspector to free up VRAM. Ensure you have at least 32GB of system RAM if running heavy add-ons.
- AI Traffic & Mod Injection (e.g., FSLTL):
- Background traffic injectors often accumulate data or fail to clear models properly, tanking performance after 15–30 minutes.
- Fix: Disable external traffic injection programs or lower live/multiplayer traffic density in the simulator settings to test if performance stabilizes.
- Fauna & Wildlife Bugs:
- Specific animal spawns have been known to heavily burden the CPU and trigger severe frame drops in certain regions.
- Fix: Turn off Fauna in the simulator's data/general settings menu.
i5 13600KF - MSI Z790 Tomahawk - 64GB DDR5 - MSI RTX 3080Ti Suprim - Samsung 980 Pro - Oculus Quest 2 en 3
/f/image/WqqeVes3P2rQFql91fin9HSW.png?f=fotoalbum_large)
/f/image/e1z3d5omCU5Um2lmnxy7uzLB.png?f=fotoalbum_large)
