MacBook Late 2008 macOS herstellen na mislukte Mojave instal
Hello,
i have a Macbook Late 2008 and i tried to install macOS Mojave on it with the guide of dosdude1 but it failed..
So i tried everything to go back to el capitan but no luck so far.
What i tried was: tried normal recovery mode not working, internet recovery not working, transmac usb drive not working.
if i press alt at boot the only thing i see is a partition called "EFI Boot" the USB installer is not recognized.
internet recovery key combo not working and the key combo for normal recovery is not working either...
Is there anything that i can do to fix this ?
Thanks,
  • milotic
  • Registratie: April 2019
  • Laatst online: 25-09-2025
buy a new one
  • _Quadro
  • Laatst online: 22-10 15:32
You could try and install windows on it so you can backtrack from there?
MachielVeldkamp schreef op donderdag 8 augustus 2019 @ 00:51:
i tried that aswell i have a Windows 10 USB and when i plug it into my macbook it recognized the usb but when i click enter the machine would freeze
  • _Quadro
For how long? The 2008 macbooks aren't fast.
In any case. I don't know.
Good luck
MachielVeldkamp schreef op donderdag 8 augustus 2019 @ 00:53:
Good luck
it would freeze forever i am forced to shut it down.. i have a 120 GB SSD installed in it..
  • floorcleaner
  • Laatst online: 24-10 00:29
Do you have the possibility to connect the drive to another machine ?
floorcleaner schreef op donderdag 8 augustus 2019 @ 00:54:
the only machine i have is my PC i dont have another mac..
  • floorcleaner
If you dont need the data on it , connect it to your PC and do the next few steps :
download : https://downloads.wdc.com/windlg/WinDlg_v1_36.zip
Its from Western Digital so its a safe download and works with most other brands too.
Gives you the option to check the drives and to wipe it completely clean (write zero's), including the EFI partition(s). Be carefully not to erase the wrong drive !
Quick erase is usually sufficient. Then put it back in the mac and try reinstalling again from scratch.
Helped me several times , should work.
floorcleaner schreef op donderdag 8 augustus 2019 @ 01:04:
Thanks m8 i will try tomorrow,
do you have a good El Capitan DMG file for me that i can use to restore it to usb with transmac ?
Didnt work still no usb in startup manager
  • RobIII
RobIII
Admin Devschuur®
^ Romeinse Ⅲ ja!
(overleden)
Is er een hele goede reden waarom hier opeens Engels gesproken wordt :? Spreekt @Verwijderd geen Nederlands?
Je eigen tweaker.me redirect
Over mij
RobIII schreef op donderdag 8 augustus 2019 @ 01:41:
Ja sorry niet bij stil gestaan xD
  • RobIII
RobIII
Admin Devschuur®
^ Romeinse Ⅲ ja!
(overleden)
Verwijderd schreef op donderdag 8 augustus 2019 @ 01:41:
Na de laatste post(s) in je vorige topic ging er geen lichtje branden? Toen je alle andere vele duizenden topics hier bekeek ging er ook geen lichtje branden?
Wil je er dan voortaan wél bij stilstaan a.u.b.?
Over mij
RobIII schreef op donderdag 8 augustus 2019 @ 01:47:
Ja zal ik doen nogmaals excuus
  • floorcleaner
Mijn engels staat waarschijnlijk zo veel vol met fouten, dat een echte engelsman hier al lang weg was :-)
Die usb stick is toch niet NTFS geformateerd hoop ik ?
Op een kale lege disk zou je van stick moeten kunnen booten.
[ Voor 6% gewijzigd door floorcleaner op 08-08-2019 01:59 . Reden: onduidelijke uitleg ]
  • Kingston
  • Laatst online: 22-10 17:22
Een macbook uit 2008 kan volgens mij niet eens windows 10 runnen.
Je moet daar een minimaal een macbook uit 2012 voor hebben.
  • sypie
Kingston schreef op donderdag 8 augustus 2019 @ 06:17:
Nee, en ook geen Mojave. Tenzij je via die Dosdude1 een installeer download, dan kan het wel. Of het allemaal vlotjes verloopt moet je je afvragen.
In welke buurt woon je ergens @Verwijderd ? Ik heb nog een goede El Capitan installer.
sypie schreef op donderdag 8 augustus 2019 @ 07:54:
Ik woon in de buurt van Emmen (drenthe)
Kunt u niet de dmg file van el capitan door mailen naar mij ? Zodat ik die kan gebruiken in Transmac
  • Fiets
  • Laatst online: 23-10 22:04
Fiets
A.K.A. Bambi
https://www.macworld.co.u...without-recovery-3636668/
En dan verder zoeken op Recovery en Internet Recovery om een completen re-install te doen van MacOs
Maar 2 DPC'ers op DHEP! Ahum, nu nog maar 0 aktieve leden...
  • Daedalus
Daedalus
Moderator Apple Talk
Keep tryin'
Titel verduidelijk van 'Macbook broken' naar 'MacBook Late 2008 macOS herstellen na mislukte Mojave instal'
@Verwijderd als je als laatste heb gereageerd en je hebt nog wat toe te voegen, zou je dan je laatste reactie willen wijzigen in plaats van een nieuwe reactie te plaatsen?
“You know what I've noticed Hobbes? Things don't bug you if you don't think about them. So from now on, I simply won't think about anything I don't like, and I'll be happy all the time!” | 宇多田ヒカル \o/
  • jetspiking
  • Registratie: Februari 2016
  • Laatst online: 20-10 14:03
*snip* Als je commentaar hebt op de moderatie, doe dat dan in het daarvoor bedoelde topic aub: MS Feedback of DM diegene in kwestie.
Voor de TS:
Ik had zelf een MacBook uit 2006 (kunststof variant, die van jou zal alu zijn?), uit alle macht proberen deze te upgraden, maar ik kwam het installatie proces simpelweg niet door (ook DosDude's geprobeerd, maar later gelezen dat de 2006 variant gewoon echt niet meer ondersteund wordt, draaide OS X 10.7.5 op als ik mij niet vergis). Ik begrijp niet hoe jij het wel voor elkaar gekregen hebt het te doorlopen (normaal geeft hij namelijk aan dat je MacBook niet supported is en stopt de installatie zover ik weet), maar zoals je zegt is het installatie proces mislukt. Betekent dit dat je MacBook nu niet meer opstart?
Wat je dan zal moeten doen is installatie discs bemachtigen van de laatst ondersteunde Apple software voor je MacBook (ik gok dat dit Lion is?). Let hierbij op dat je een échte installatie disc pakt, en niet een upgrade disc (voor zover dat ik weet kan dit een issue zijn, maar mijn kennis over OS X gaat minder ver dan Windows).
Zodra je Apple opstart zijn er een aantal toetsencombinaties die je kan proberen.
Als je een recovery partitie hebt kun je deze proberen: Command (⌘) + r
Als dit niet werkt dan moet je een clean install doen, daarvoor lees ik dat je gebruik moet maken van het ingedrukt houden van de "c" knop tijdens het booten. De MacBook probeert dan te booten van een bootable DVD of USB (maar die laatste zal je MacBook waarschijnlijk niet ondersteunen), je moet dus een DVD hebben met de OS X software.
Verder zijn er online diverse gidsen te vinden die je precies vertellen hoe je installatieprocessen etc moet doorlopen.
[ Voor 15% gewijzigd door RobIII op 08-08-2019 11:54 ]
https://www.linkedin.com/in/dustinhendriks/
Fiets schreef op donderdag 8 augustus 2019 @ 10:11:
Heb ik al geprobeerd maar ik heb geen internet recovery en ook gwwn normale recovery partitie
  • Fiets
Fiets
A.K.A. Bambi
Verwijderd schreef op donderdag 8 augustus 2019 @ 11:11:
Dat... had ik niet verwacht. Dacht dat dat altijd kon. Zo heb ik mijn early 2011 kunnen reviven na een hd wissel.
  • Daedalus
Daedalus
Keep tryin'
Fiets schreef op donderdag 8 augustus 2019 @ 12:55:
Internet Recovery werkt vanaf mid 2010 MacBook Pro (na een EFI firmware update), dus niet op late 2008.
Daedalus schreef op donderdag 8 augustus 2019 @ 12:59:
Misschien een optie om een mac os 10.6 dmg/iso te downloaden en op een usb of dvd te zetten ?
  • Daedalus
Daedalus
Keep tryin'
Verwijderd schreef op donderdag 8 augustus 2019 @ 13:08:
Ja, dat is een manier. Je zult of de originele installatie DVD/USB moeten vinden (eBay oid), of iemand die een bootable installer kan aanmaken (AASP oid). Let wel dat het hier vragen om een kopie, of dat 'iemand ff kan mailen' niet gewenst is: Het algemeen beleid #verbodencopyright
  • nelizmastr
  • Laatst online: 21:47
nelizmastr
Goed wies kapot
Maar is het nou een. MacBook of een MacBook Pro? (Of zelfs een Air)?
De gewone MacBook 2008 kan alleen vloeiend tot Mountain Lion, de Air idem wegens de brakke Intel GMA.
  • rominick
  • Laatst online: 15-10 20:49
Je kan volgens mij via Apple een snow leopard dvd kopen voor 20 euro. Heb ik ook toen gedaan om een Mac te wissen en te herstellen. Later ook voor een Mac pro en een MacBook pro 2011 gebruikt. Is dat geen oplossing?
https://www.apple.com/nl/...mac-os-x-106-snow-leopard
Tevens ook lion te koop:
https://www.apple.com/nl/shop/product/D6106ZM/A/os-x-lion
